Manage a VDI image source VM
Manage a VM through the console
Through the console, you can start, restart, and shut down an image source VM, so that you can manage the VM on the desktop image page.
To manage a VM through the console:
  1. From the navigation pane, select Images > Desktop Images.
  1. Click the Image Source VMs tab. Click the Console button in the Actions column for an image source VM. The image source VM console opens.
  1. On the console, you can perform the following operations:
Create a snapshot
  1. Click the Image Source VMs tab. Click More in the Actions column for an image source VM. From the dropdown menu, select Snapshot.
The snapshot management dialog box opens.
  1. Click Create.
  1. In the dialog box that opens, configure the snapshot name and description, specify whether to include memory state in the snapshot, and click OK.
Restore a VM
  1. Select the snapshot to restore, and then click Restore.
  1. Click OK.
Delete a snapshot
  1. Click Delete in the Actions column for the snapshot to be deleted.
  1. Click OK in the confirmation dialog box that opens.
Edit an image source VM
  1. Click the Image Source VMs tab. Click More in the Actions column for an image source VM. From the dropdown menu, select Edit.
The page for editing the image source VM opens.
  1. Edit the image source VM as needed.
For how to edit a VM, see Edit a VM.
Delete an image source VM
  1. Click the Image Source VMs tab. Click More in the Actions column for an image source VM. From the dropdown menu, select Delete.
