For a course that has not been published yet, you can publish, open console for, close, edit, and delete the course. For a course that has been published, you can cancel publishing, edit, or delete the course.
Do not publish, cancel publishing, or copy courses during class. |
Before creating a course, you can upload required application software to the shared directory on a cloud host. When building the course, you can obtain the uploaded software by attaching a shared disk and install the software.
From the navigation pane, select Images > Course Images.
Click Software Upload.
Click Upload Files in the software upload section.
Click Upload.
In the dialog box that opens, select the target software or file.
The selected software or file will be automatically uploaded and displayed in the uploaded file list. You can delete software or files from the uploaded file list or download software or files.
· You can create subfolders under the default folder for saving uploaded software and files and upload files or software to the subfolders. · The management platform supports bulk file upload, resuming file upload, and filtering files by username or user who uploaded a file. |
You can publish only a course that has not been published yet. You must close the course before publishing it.
In the dialog box that opens, click OK. The course will be published after a period of time.
You can cancel publishing for only a course that has been published. This task does not apply to level-2 images of VOI courses or imported VOI images.
In the dialog box that opens, click OK. The published course will be canceled after a period of time.
You can open the console for only a course that has not been published yet.
You can close only a running course that has not been published yet.
You can start only a closed course that has not been published yet.
Click
in the tile for a course.
You can copy both published and unpublished courses. The courses created from the copies are in unpublished state. This task does not apply to level-2 images of VOI courses or imported VOI images.
Specify the new course name and storage path.
Click OK.
You can create snapshots for both published and unpublished courses. This task does not apply to level-2 images of VOI courses or imported VOI images.
Click Create. In the dialog box that opens, enter the snapshot name and click OK.
To restore a snapshot for the course, select the snapshot and click Restore. To delete the snapshot, select the snapshot and click Delete.
You can download only a course that has been published. The storage path for downloaded courses varies by browser settings.
For further use of a VOI course that will be uploaded to Space Console, do not edit its name after downloading it successfully. |
Click
You can edit both published and unpublished courses.
In the dialog box that opens, edit the course name, description, user access, classroom access, course logo, and advanced settings as needed, and then click OK.
You can delete both published and unpublished courses.
Click the name of a VOI course to view its information.
