02-CFD commands | 141.22 KB |
CFD commands
cfd cc enable
Use cfd cc enable to enable CCM sending on a specified MEP.
Use undo cfd cc enable to disable CCM sending on a specified MEP.
cfd cc service-instance instance-id mep mep-id enable
undo cfd cc service-instance instance-id mep mep-id enable
The CCM sending feature is disabled.
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191.
Follow these guidelines when you use the command:
· Configurations in Ethernet interface view take effect only on the current interface.
· Configurations in aggregate interface view take effect only on the current aggregate interface.
· If the MEP belongs to an MA that does not carry the VLAN attribute, configurations on a member port of an aggregation group view take effect only on the current member port.
· If the MEP belongs to an MA that carries the VLAN attribute, configurations on a member port of an aggregation group take effect only when the member port leaves the aggregation group.
# On port Twenty-FiveGigE 1/0/1, enable CCM sending on MEP 3 in service instance 5.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] cfd cc service-instance 5 mep 3 enable
cfd cc interval
cfd cc interval
Use cfd cc interval to set the value of the interval field in the CCM messages.
Use undo cfd cc interval to remove the value of the interval field in the CCM messages.
cfd cc interval interval-value service-instance instance-id
undo cfd cc interval [ interval-value ] service-instance instance-id
The value of this field is 4 for all CCM messages sent.
interval interval-value: Specifies the value of the interval field in CCM messages. The value range for the interval field is 1 to 7. If you set the value to 1 or 2, the continuity check might work incorrectly due to hardware restrictions.
When setting the CCM interval, use the settings described in Table 1.
Table 1 CCM interval field encoding
CCM interval field |
Transmission interval |
Maximum CCM lifetime |
1 |
10/3 milliseconds |
35/3 milliseconds |
2 |
10 milliseconds |
35 milliseconds |
3 |
100 milliseconds |
350 milliseconds |
4 |
1 second |
3.5 seconds |
5 |
10 seconds |
35 seconds |
6 |
60 seconds |
210 seconds |
7 |
600 seconds |
2100 seconds |
# Set the value of the interval field to 3 in CCM messages sent by MEPs in service instance 2.
[Sysname] cfd cc interval 3 service-instance 2
cfd cc enable
cfd enable
Use cfd enable to enable CFD.
Use undo cfd enable to disable CFD.
cfd enable
undo cfd enable
CFD is disabled.
[Sysname] cfd enable
cfd linktrace
Use cfd linktrace to identify the path between the source MEP and target MP.
cfd linktrace service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ ttl ttl-value ] [ hw-only ]
mep mep-id: Specifies the source MEP by its ID in the range of 1 to 8191.
target-mac mac-address: Specifies the destination MAC address, in the format of H-H-H.
target-map target-mep-id: Specifies the destination MEP by its ID in the range of 1 to 8191.
ttl ttl-value: Specifies the TTL value in the range of 1 to 255. The default value is 64.
hw-only: Sets the hw-only bits of the LTMs sent. If you specify this keyword, the MIP does not flood LTMs that have an unknown destination MAC address.
This command identifies the path between the source MEP and target MP by using LTMs and LTRs.
# Identify the path between source MEP 1101 and target MEP 2001 in service instance 1.
<Sysname> cfd linktrace service-instance 1 mep 1101 target-mep 2001
Linktrace to MEP 2001 with the sequence number 1101-43361:
MAC address TTL Last MAC Relay action
0010-fc00-6512 63 0010-fc00-6500 Hit
Linktrace to MEP 2001 with the sequence number 1101-43361 |
Linktrace to target MEP 2001 with the sequence number 1101-43361. |
MAC address |
Source MAC address in the LTRs. |
TTL |
TTL of the LTM when it passes the device. |
Last MAC |
MAC address of the last-hop device the LTM passes. |
Relay action |
Indicates whether the forwarding device found the destination MAC address in its MAC address table. When the standard version (IEEE 802.1ag) of CFD is used: · Hit—The current device is the destination device. · FDB—The forwarding device found the destination MAC address. · MPDB—The destination MAC address is not found, or the destination MAC address is found in the MEP or MIP database. |
cfd linktrace auto-detection
display cfd linktrace-reply
Use cfd linktrace auto-detection to enable automatic sending of LTMs.
Use undo cfd linktrace auto-detection to disable automatic sending of LTMs.
cfd linktrace auto-detection [ size size-value ]
Automatic sending of LTMs is disabled.
size size-value: Specifies the size of the buffer used to store the auto-detection result, in the range of 1 to 100 (in terms of auto-detection times). The default value is 5, which means the buffer stores the results of the recent five auto-detections.
This command enables the source MEP to send LTMs when it fails to receive CCMs from the target MEP within 3.5 times the sending interval. The destination of the LTMs is the target MEP, and the TTL field value is 255. Based on the returned LTRs, the fault source can be located on the faulty link.
If you disable automatic LTM sending, the content stored in the buffer will be removed.
# Enable automatic LTM sending, and set the size of the buffer used to store the auto-detection result to 100 (in terms of auto-detection times).
[Sysname] cfd linktrace auto-detection size 100
cfd linktrace
display cfd linktrace-reply auto-detection
cfd loopback
Use cfd loopback to enable loopback (LB).
cfd loopback service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
target-mac mac-address: Specifies the destination MAC address of the MP, in the format of H-H-H.
target-mep target-mep-id: Specifies the target MEP by its ID in the range of 1 to 8191.
number number: Specifies the number of the sent LBMs packets. The value is in the range of 1 to 10. The default value is 5.
The LB function verifies link connectivity between the source MEP and the target MP by using LBMs and LBRs.
# Enable LB for the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is normal).
<Sysname> cfd loopback service-instance 1 mep 1101 target-mep 2001
Loopback to MEP 2001 with the sequence number start from 1101-43404:
Reply from 0010-fc00-6512: sequence number=1101-43404 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43405 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43406 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43407 Time=5ms
Reply from 0010-fc00-6512: sequence number=1101-43408 Time=5ms
Sent: 5 Received: 5 Lost: 0
# Enable LB for the link between MEP 1101 and MEP 2001 in service instance 1 (assume that the link status is abnormal).
Sent: 5 Received: 0 Lost: 5
Loopback to MEP 2001 with the sequence number start from 1101-43404 |
Sends LBMs to remote MEP 2001 with the sequence number starting with 1101-43404. |
Reply from 0010-fc00-6512 |
Reply from the MP with the MAC address 0010-FC00-6512. |
sequence number |
Sequence number in the LBR messages. |
Time=5ms |
The interval between the sending of LBMs and receiving of LBRs is 5 milliseconds. |
Sent |
Number of sent LBMs. |
Received |
Number of received LBRs. |
Lost |
Number of lost LBRs. |
cfd md
Use cfd md to create an MD.
Use undo cfd md to delete an MD.
cfd md md-name [ index index-value ] level level-value [ md-id { dns dns-name | mac mac-address subnumber | none } ]
undo cfd md md-name
No MDs exist.
md md-name: Specifies the name of an MD, which is a string of 1 to 43 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark ('), comma (,), period (.), and slash (/).
index index-value: Specifies an MD index in the range of 1 to 4294967295. If you do not specify this option, the system automatically assigns the smallest index number that is not in use. As a best practice, use the index automatically assigned by the system.
level level-value: Specifies an MD level in the range of 0 to 7.
md-id: Specifies the MD name carried by packets sent by the MEP. If you do not provide this keyword, the MD name is represented by md-name.
dns dns-name: Specifies an MD name in the format of DNS name, where dns-name represents the DNS name.
mac mac-address subnumber: Specifies an MD name containing the MAC address and an integer. The mac-address argument represents the MAC address of the MD, and the subnumber argument is in the range of 0 to 65535.
none: Specifies that no MD name is carried in the packets sent by the MEP.
An MD name must be in compliant with the specifications in IEEE802.1ag-2007.
You can create only one MD with a specific level. MD cannot be created if you enter an invalid MD name or an existing MD name or the MD index is in use.
When deleting an MD, you will also delete the configurations related to that MD.
# Create an MD named test_md1, with its level being 3.
[Sysname] cfd md test_md1 level 3
# Create an MD named test_md2, and the MD name carried in the packet sent by the MEP comprises the MAC address 1-1-1 and integer 1.
[Sysname] cfd md test_md2 level 5 md-id mac 1-1-1 1
cfd mep
Use cfd mep to create a MEP.
Use undo cfd mep to delete a MEP.
cfd mep mep-id service-instance instance-id { inbound | outbound }
undo cfd mep mep-id service-instance instance-id
No MEPs exist.
mep mep-id: Specifies the MEP ID, in the range of 1 to 8191.
inbound: Creates an inward-facing MEP.
outbound: Creates an outward-facing MEP.
In creating a MEP, the service instance you specified defines the MD and MA to which the MEP belongs.
You cannot create a MEP if the MEP ID is not included in the MEP list of the relevant service instance.
· If the MEP belongs to an MA that does not carry the VLAN attribute, configurations on a member port of an aggregation group take effect only on the current member port.
# Configure a MEP list in service instance 5, and create inward-facing MEP 3 in service instance 5 on Twenty-FiveGigE 1/0/1.
[Sysname] cfd md test_md level 3
[Sysname] cfd service-instance 5 ma-id vlan-based md test_md vlan 100
[Sysname] cfd meplist 3 service-instance 5
[Sysname-Twenty-FiveGigE1/0/1] cfd mep 3 service-instance 5 outbound
cfd meplist
cfd meplist
Use cfd meplist to create a MEP list.
Use undo cfd meplist to delete a MEP list.
cfd meplist mep-list service-instance instance-id
undo cfd meplist mep-list service-instance instance-id
No MEP list is created.
meplist mep-list: Specifies a space-separated list of up to 10 MEP items. Each item specifies a MEP ID or a range of MEP IDs in the form of mep-id 1 to mep-id 2. The value range for the MEP ID is 1 to 8191. The mep-id 2 must be equal to or greater than mep-id 1.
A MEP list is a collection of local MEPs allowed to be configured and the remote MEPs to be monitored in the same MA.
Before creating a MEP list, create the relevant MD and service instance.
After you delete a MEP list, all local MEP configurations based on this list are deleted.
# Create a MEP list that includes MEP 9 through MEP 15 in service instance 5.
[Sysname] cfd meplist 9 to 15 service-instance 5
cfd md
cfd mip-rule
Use cfd mip-rule to configure the rules for generating MIPs.
Use undo cfd mip-rule to remove the rules for generating MIPs and the MIPs created in a service instance.
cfd mip-rule { default | explicit } service-instance instance-id
undo cfd mip-rule [ default | explicit ] service-instance instance-id
No rules for generating MIPs are configured and the system does not automatically generate any MIPs.
default: Specifies the default rule. If no lower-level MIP exists on an interface, a MIP is created on the current level. A MIP can be created even if no MEP is configured on the interface.
explicit: Specifies the explicit rule. If no lower-level MIP exists and a lower-level MEP exists on an interface, a MIP is created at the current level. A MIP can be created only when a lower-level MEP is created on the interface.
The system automatically generates MIPs on each port according to the rules configured.
# Configure the MIP generation rule as default in service instance 5.
[Sysname] cfd mip-rule default service-instance 5
cfd port-trigger
Use cfd port-trigger to specify the triggering event and triggered action for port collaboration.
Use undo cfd port-trigger to cancel the triggering event and triggered action for port collaboration.
cfd port-trigger { cc-expire | rdi } action { block | shutdown }
undo cfd port-trigger { cc-expire | rdi } action
The triggering event and triggered action are not specified for port collaboration.
cc-expire: Triggers port collaboration when continuity check expires.
rdi: Triggers port collaboration when the CCMs with the RDI flag bits set are received.
block: Blocks the port by changing its link layer protocol state to DOWN (CFD). The port cannot send or receive any data packets.
shutdown: Shuts down the port by changing its physical state to CFD DOWN. The port cannot send or receive any data packets or protocol packets.
If a port is blocked by CFD, it can automatically come up when the link recovers.
If a port is shut down by CFD, it cannot automatically come up when the link recovers.
· If port collaboration is triggered by continuity check expiration, you must execute the undo shutdown or undo cfd port-trigger { cc-expire | rdi } action command to bring up the port.
· If port collaboration is triggered by CCMs with the RDI flag bits set, you must execute the undo cfd port-trigger { cc-expire | rdi } action command to bring up the port.
You can specify multiple triggering events for an interface. All the triggering events can take effect. When you specify multiple triggered actions for a triggering event on an interface, the most recent configuration takes effect.
The command takes effect only on the ports with outward-facing MEPs configured.
# Specify the triggering event as cc-expire and the triggered action as block for port collaboration on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] cfd port-trigger cc-expire action block
# Specify the triggering event as cc-expire and the triggered action as shutdown for port collaboration on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] cfd port-trigger cc-expire action shutdown
cfd cc enable
cfd mep
Use cfd service-instance to create a service instance.
Use undo cfd service-instance to remove a service instance.
cfd service-instance instance-id ma-id { icc-based ma-name | integer ma-num | string ma-name | vlan-based [ vlan-id ] } [ ma-index index-value ] md md-name vlan vlan-id
undo cfd service-instance instance-id
No service instances exist.
service-instance instance-id: Specifies the service instance ID in the range of 1 to 32767.
ma-id: Creates an MA.
icc-based ma-name: Specifies that an MA is identified by an ICC. The ma-name argument is a string of 1 to 13 characters.
integer ma-num: Specifies that an MA is identified by an integer, where the ma-num argument is in the range of 0 to 65535.
string ma-name: Specifies that an MA is identified by a string, where the ma-name argument is string of 1 to 45 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark ('), comma (,), period (.), and slash (/).
vlan-based [ vlan-id ]: Specifies that an MA is identified by a VLAN ID, where the vlan-id argument is in the range of 1 to 4094. If you do not provide the vlan-id argument, the VLAN ID specified by vlan vlan-id is used. If the vlan vlan-id option is not provided, you must specify the vlan-id argument for the vlan-based [ vlan-id ] option.
ma-index index-value: Specifies an MA index in the range of 1 to 4294967295. If you do not specify this option, the system automatically assigns the smallest index number that is not in use. As a best practice, use the index automatically assigned by the system.
md md-name: Specifies the name of an MD. The md-name argument is a string of 1 to 43 characters that can contain letters, numbers, and special characters such as grave accent (`), tilde (~), exclamation mark (!), at sign (@), number sign (#), dollar sign ($), percent (%), caret (^), ampersand (&), asterisk (*), brackets ({ }, ( ),[ ], < >), hyphen (-), underscore (_), plus (+), equal sign (=), vertical bar (|), colon (:), semicolon (;), quotation mark (’), comma (,), period (.), and slash (/).
vlan vlan-id: Specifies the VLAN that the MA serves. The value range for the vlan-id argument is 1 to 4094.
A service instance is indicated by an integer to represent an MA in an MD. An MA index uniquely identifies a specific MA in an MD. An MA index can be used in different MDs.
With the vlan-based [ vlan-id ] or vlan vlan-id option, the command creates an MA carrying the VLAN attribute. If you do not specify the option, the command creates an MA carrying no VLAN attribute.
You must create the relevant MD before creating a service instance with the MD name.
Deleting a service instance also deletes the configurations related to that service instance.
Deleting a service instance not only removes the connection between the service instance and the relevant MA, but also deletes the MA.
# Create a level-3 MD named test_md and create service instance 5, in which the MA is identified by a VLAN and serves VLAN 100.
cfd md
Use display cfd linktrace-reply to display information about the LTRs received by a MEP.
display cfd linktrace-reply [ service-instance instance-id [ mep mep-id ] ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays the LTR information for all service instances.
mep mep-id: Specifies the ID of a MEP, in the range of 1 to 8191. If you do not specify this option, the command displays the LTR information for all MEPs.
This command displays only information about LTRs received by execution of the cfd linktrace command.
# Display the LTR information saved on all the MEPs in every service instance.
[Sysname] display cfd linktrace-reply
Service instance: 1 MEP ID: 1003
0000-fc00-6505 63 0000-fc00-6504 MPDB
000f-e269-a852 62 0000-fc00-6505 FDB
0000-fc00-6508 61 000f-e269-a852 Hit
Service instance: 2 MEP ID: 1023
Service instance |
Service instance to which the MEPs that send LTMs belong. |
MEP ID |
ID of the MEP that sends LTMs. |
MAC address |
Source MAC address in the LTR. |
TTL |
Last MAC |
Relay action |
cfd linktrace
Use display cfd linktrace-reply auto-detection to display information about the LTRs received as responses to the automatically sent LTMs.
display cfd linktrace-reply auto-detection [ size size-value ]
size size-value: Specifies the times of recent auto-detections, in the range of 1 to 100. If you do not specify this option, the command displays all information in the buffer.
This command displays only information about LTRs received by execution of the cfd linktrace auto-detection command.
# Display the contents of the LTRs received as responses to the LTMs automatically sent.
<Sysname> display cfd linktrace-reply auto-detection
Service instance: 1 MEP ID: 1003 Time: 2013/05/22 10:43:57
Target MEP ID: 2005 TTL: 64
Service instance: 2 MEP ID: 1023 Time: 2013/05/22 10:44:06
Target MEP ID: 2025 TTL: 64
Table 5 Command output
Service instance |
Service instance to which the MEPs that sent LTMs belong. |
MEP ID |
Time |
Time of the LTMs automatically sent. |
Target MEP ID |
ID of the target MEP. |
TTL |
Initial TTL of the automatically sent LTMs. |
MAC address |
TTL |
Last MAC |
Relay action |
display cfd md
Use display cfd md to display the MD configuration information.
display cfd md
# Display the MD configuration information.
<Sysname> display cfd md
CFD is enabled.
Maintenance domains configured: 4 in total
Level Index Maintenance domain MD format MD ID
0 1 md_0 CHARSTRING md_0
1 2 md_1 DNS dns1
2 3 md_2 MAC 0001-00
01-0001-1
3 4 md_3 NONE Without
ID
Table 6 Command output
Maintenance domains configured |
Number of MDs configured. |
Level |
Level of MD. |
Index |
MD index. |
Maintenance domain |
Name of MD. |
MD format |
MD name format: · CHARSTRING—Character string. · DNS—DNS name. · MAC—MAC address and an integer. · NONE—No MD name is carried. |
MD ID |
MD ID value: · A character string if the MD format is CHARSTRING. · A DNS name if the MD format is DNS. · A MAC address-subnumber if the MD format is MAC. · No ID if the MD format is NONE. |
display cfd mep
Use display cfd mep to display the attribute and operating information for a MEP.
display cfd mep mep-id service-instance instance-id
# Display the attribute and operating information for MEP 50 in service instance 1.
<Sysname> display cfd mep 50 service-instance 1
Interface: Twenty-FiveGigE1/0/2
Maintenance domain: md_0
Maintenance domain index: 1
Maintenance association: ma_0
Maintenance association index: 1
Level: 0 VLAN: 1 Direction: Outbound
Current state: Active CCM send: Enabled
FNG state: FNG_DEFECT_REPORTED
CCM:
Current state: CCI_WAITING
Interval: 1s SendCCM: 12018
Loopback:
NextSeqNumber: 8877
SendLBR: 0 ReceiveInOrderLBR: 0 ReceiveOutOrderLBR: 0
Linktrace:
NextSeqNumber: 8877
SendLTR: 0 ReceiveLTM: 0
No CCM received from some remote MEPs.
One or more streams of error CCMs is received. The last received CCM:
Maintenance domain: (Without ID)
Maintenance association: matest1
MEP ID: 5 Sequence Number:0x50A
MAC Address: 0011-2233-4402
Received Time: 2013/03/06 13:01:34
One or more streams of cross-connect CCMs is received. The last received CCM:
Maintenance domain: mdtest1
Maintenance association:matest1
MEP ID: 6 Sequence Number:0x63A
MAC Address: 0011-2233-4401
Some other MEPs are transmitting the RDI bit.
Table 7 Command output
Interface on which the MEP is configured. |
MD to which the MEP belongs. (If the MD does not have a name, this field is displayed as Without ID.) |
Maintenance domain index |
Index of the MD to which the MEP belongs. |
Maintenance association |
MA to which the MEP belongs. |
Maintenance association index |
Index of the MA to which the MEP belongs. |
Level |
Level of the MD. |
VLAN |
VLAN to which the MA belongs. |
Direction |
Direction of the MEPs. |
Current state |
State of MEP: · Active. · Inactive. |
CCM send |
Whether the MEP sends CCM. |
FNG state |
State of FNG (Fault Notification Generator): · FNG_RESET—A fault has been cleared. · FNG_DEFECT—A fault has been detected. · FNG_REPORT_DEFECT—Report a fault. · FNG_DEFECT_REPORTED—A fault has been reported. · FNG_DEFECT_CLEARING—A fault is being cleared. If this field is not supported, a hyphen (-) is displayed. |
CCM |
Information related to CCM. |
Current state |
State of CCMs sent: · CCI_IDLE—Initial state. · CCI_WAITING—Sending state. If this field is not supported, a hyphen (-) is displayed. |
Interval |
Interval to send CCM. Not supported means the MEP does not support CCM sending. |
SendCCM |
Number of CCMs that have been sent by the MEPs. If this field is not supported, a hyphen (-) is displayed. |
Loopback |
Information related to Loopback. |
NextSeqNumber |
Sequence number of the next LBM to be sent. |
SendLBR |
Number of LBRs that have been sent. If the MEP is inward-facing, the number of LBRs will not be counted. |
ReceiveInOrderLBR |
Number of LBRs received in correct sequence. |
ReceiveOutOrderLBR |
Number of LBRs received out of order. |
Linktrace |
Information related to linktrace. |
NextSeqNumber |
Sequence number of the next LTM to be sent. |
SendLTR |
Number of LTRs sent. If the MEP is inward-facing, the number of LTRs will not be counted. |
ReceiveLTM |
Number of LTMs received. |
No CCM received from some remote MEPs. |
Failure to receive CCMs from some remote MEPs. (This information is displayed only when some CCMs are lost.) |
One or more streams of error CCMs is received. The last received CCM: |
Display the content of the last error CCM when one or more error CCMs are received. (This information is displayed only when error CCMs are received.) |
MD of the last error CCM. If this field is not supported, a hyphen (-) is displayed. |
MA of the last error CCM. If this field is not supported, a hyphen (-) is displayed. |
MEP |
ID of the MEP that sent the last error CCM. If this field is not supported, a hyphen (-) is displayed. |
Sequence Number |
Sequence number of the last error CCM. If this field is not supported, a hyphen (-) is displayed. |
Received Time |
Time when the last error CCM is received. If this field is not supported, a hyphen (-) is displayed. |
One or more streams of cross-connect CCMs is received. The last received CCM: |
Cross-connect CCMs are received, and the content of the last cross-connect CCM is displayed. (This information is displayed only when cross-connect CCMs are received.) |
Some other MEPs are transmitting the RDI bit. |
CCMs with the RDI flag bits set are received from other MEPs. (This information is displayed only when this type of CCMs are received.) |
display cfd meplist
Use display cfd meplist to display the MEP list in a service instance.
display cfd meplist [ service-instance instance-id ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767. If you do not specify this option, the command displays MEP lists in all service instances.
# Display the MEP list in service instance 5.
<Sysname> display cfd meplist service-instance 5
Service instance: 5
MEP list: 1 to 20, 30, 50.
display cfd mp
Use display cfd mp to display the MP information.
display cfd mp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify this option, the command displays MP information for all ports.
The output is arranged by port name. On a port, the output shows MPs that serve VLANs, and then shows MPs that do not serve any VLANs. The MPs that serve VLANs are displayed in the ascending VLAN ID order. Within the same VLAN, the output is in the order of MIPs and MEPs (from high to low level). The MEPs that do not serve any VLANs are displayed by level (from high to low).
# Display the MP information on all ports.
<Sysname> display cfd mp
Interface Twenty-FiveGigE1/0/1 VLAN 100
MIP Level: 2 Service instance: 102
Maintenance domain: md_2
Maintenance domain index: 3
Maintenance association: ma_2
Maintenance association index: 3
MEP ID: 101 Level: 1 Service instance: 101 Direction: Inbound
Maintenance domain: md_1
Maintenance domain index: 2
Maintenance association: ma_1
Maintenance association index: 2
MEP ID: 100 Level: 0 Service instance: 100 Direction: Outbound
Table 8 Command output
Interface Twenty-FiveGigE1/0/1 VLAN 100 |
MP configuration of VLAN 100 on Twenty-FiveGigE 1/0/1. |
MIP |
A MIP in the MP. |
Level |
MD level to which the MP belongs. |
Service instance |
Service instance to which the MP belongs. |
MD to which the MP belongs. |
Index of the MD to which the MP belongs. |
MA to which the MP belongs. |
Index of the MA to which the MP belongs. |
Direction |
Direction of the MEP, inbound or outbound. |
display cfd remote-mep
Use display cfd remote-mep to display information about a remote MEP.
display cfd remote-mep service-instance instance-id mep mep-id
# Display remote MEP information for MEP 10 in service instance 4.
<Sysname> display cfd remote-mep service-instance 4 mep 10
MEP ID MAC address State Time MAC status
20 00e0-fc00-6565 OK 2013/03/06 02:36:38 UP
30 00e0-fc27-6502 OK 2013/03/06 02:36:38 DOWN
40 00e0-fc00-6510 FAILED 2013/03/06 02:36:39 DOWN
50 00e0-fc52-baa0 OK 2013/03/06 02:36:44 DOWN
60 0010-fc00-6502 OK 2013/03/06 02:36:42 DOWN
Table 9 Command output
MEP ID |
ID of the remote MED. |
MAC address |
MAC address of the remote MEP device. If this field is not supported, a hyphen (-) is displayed. |
State |
Running state of the remote MEP: · OK. · FAILED. |
Time |
Time when the remote MEP entered the FAILED or OK state for the last time. If this field is not supported, a hyphen (-) is displayed. |
MAC status |
State of the interface indicated by the last CCM received from the remote MEP: · UP—The interface is ready to pass packets. · DOWN—The interface cannot pass packets. · TESTING—The interface is in some test mode. · UNKNOWN—The interface status cannot be determined. · DORMANT—The interface is not in a state to pass packets. Instead, it is in a pending state, waiting for some external event. · NOT-PRESENT—Some component of the interface is missing. · LLD—The interface is down due to state of the lower layer interfaces. If this field is not supported, a hyphen (-) is displayed. |
display cfd service-instance
Use display cfd service-instance to display the configuration information of service instances.
display cfd service-instance [ instance-id ]
instance-id: Specifies a service instance ID in the range of 1 to 32767. If you do not specify this argument, the command displays configuration information for all service instances.
# Display the configuration information of all service instances.
<Sysname> display cfd service-instance
Service instances configured (2 in total):
Service instance 5:
Maintenance domain: md_5
Maintenance domain index: 5
Maintenance association: ma_5
Maintenance association index: 5
Level: 5 VLAN: 5 MIP rule: NONE CCM interval: 1s Direction: Inbound
MEP ID: 730 Interface: Twenty-FiveGigE1/0/1
Service instance 6:
Maintenance domain index: 6
Maintenance association: ma_6
Maintenance association index: 6
Level: 6 VLAN: 6 MIP rule: NONE CCM interval: 1s Direction: Outbound
MEP ID: 731 Interface: Twenty-FiveGigE1/0/2
Table 10 Command output
Service instances are configured. |
Number of service instances configured. |
Service instance |
Service instance ID. |
MD of the service instance. (If the MD does not have a name, this field displays Without ID.) |
Index of the MD to which the service instance belongs. |
Maintenance association: |
MA of the service instance. |
Index of the MA to which the service instance belongs. |
Level |
MD level. |
VLAN |
MIP rule |
MIP generation rules configured on the service instance. |
CCM interval |
Interval to send CCMs. |
Direction |
Direction of the MEPs configured on the service instance. |
MEP ID |
ID of MEPs configured on the service instance. |
Interface of the MEP configured on the service instance. |
display cfd status
Use display cfd status to display the CFD status.
display cfd status
# Display the CFD status. (This device series does not support AIS in the current software version.)
CFD is enabled.
AIS is disabled.
