01-SPBM commands | 384.33 KB |
display spbm agreement-protocol
display spbm bvlan-info statistics
display spbm common statistics
display spbm fast-channel statistics
display spbm graceful-restart event-log
display spbm graceful-restart status
display spbm multicast-fib statistics
display spbm non-stop-routing event-log
display spbm non-stop-routing status
display spbm unicast-fib statistics
reset spbm bvlan-info statistics
reset spbm graceful-restart event-log
reset spbm multicast-fib statistics
reset spbm non-stop-routing event-log
reset spbm unicast-fib statistics
SPBM commands
SPBM requires a license to run on the device. For information about feature licensing, see Fundamentals Configuration Guide.
The S6861 and S6820 switch series do not support SPBM.
ap-mode
Use ap-mode to configure the agreement protocol (AP) mode.
Use undo ap-mode to restore the default.
ap-mode { both | multicast | off }
undo ap-mode
AP is enabled for both unicast and multicast FDB entries.
SPBM view
both: Enables AP for both unicast and multicast FDB entries.
multicast: Enables AP only for multicast FDB entries.
off: Disables AP.
AP prevents temporary loops that might occur when the topologies of SPBM neighbors do not match.
If AP is enabled, ISIS-SPB issues forwarding entries to the FIB tables in the data plane only if AP declares a topology match after LSDB synchronization is complete.
NOTE: In this document, "AP" refers to agreement protocol. In other documents, "AP" can also refer to access points. |
# Enable AP for multicast FDB entries.
[Sysname] spbm
[Sysname-spbm] ap-mode multicast
area-authentication send-only
Use area-authentication send-only to disable authentication for incoming ISIS-SPB topology advertisement packets (LSPs, CSNPs, and PSNPs).
Use undo area-authentication send-only to restore the default.
ISIS-SPB authenticates incoming topology advertisement packets if area authentication (area-authentication-mode) is configured. The device accepts a topology advertisement packet only if the authentication method and password in the packet match its local authentication settings.
SPBM view
Before you change area authentication settings for an SPBM network, configure this command to prevent temporary authentication setting mismatch from causing topology advertisement packets to be dropped.
For security purposes, restore the default to authenticate incoming topology advertisement packets after you change area authentication settings across the SPBM network.
This command does not affect outgoing topology advertisement packets. When area authentication is enabled, outgoing ISIS-SPB topology advertisement packets always contain authentication information.
# Disable authentication for incoming ISIS-SPB topology advertisement packets.
[Sysname] spbm
[Sysname-spbm] area-authentication send-only
Use area-authentication-mode to configure area authentication.
Use undo area-authentication-mode to restore the default.
area-authentication-mode { md5 | simple } { cipher | plain } string
Area authentication is disabled. No area authentication method or password is configured.
SPBM view
md5: Specifies MD5 authentication.
simple: Specifies simple authentication.
plain: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password. The plaintext password is a case-sensitive string of 1 to 16 characters. The encrypted password is a case-sensitive string of 33 to 53 characters.
ISIS-SPB area authentication guarantees that SPBM nodes learn topology data only from trustworthy neighbors.
For correct authentication, make sure the authentication method and password are the same across the SPBM network. ISIS-SPB sends these authentication settings in topology advertisement packets (LSPs, CSNPs, and PSNPs). The recipients accept a topology advertisement packet only if the authentication settings in the packet match their local authentication settings.
Example
# Set the area authentication method to simple and the password to 123456 in plain text.
[Sysname] spbm
[Sysname-spbm] area-authentication-mode simple plain 123456
bandwidth-reference
Use bandwidth-reference to set the bandwidth reference for automatic link metric calculation.
Use undo bandwidth-reference to restore the default.
bandwidth-reference value
The bandwidth reference is 40000 Mbps.
SPBM view
value: Specifies a bandwidth reference in the range of 1 to 2147483648 Mbps.
ISIS-SPB automatically calculates a link metric value for an interface if both the global and interface-specific link metric values are not set.
The following is the calculation formula:
Link metric value=(Reference bandwidth/Interface rate)x10
The value range for the link metric value is 1 to 16777214.
# Set the bandwidth reference to 200 Mbps.
[Sysname] spbm
[Sysname-spbm] bandwidth-reference 200
circuit-cost
spbm cost
bridge-priority
Use bridge-priority to set the SPBM bridge priority.
Use undo bridge-priority to restore the default.
bridge-priority priority
The SPBM bridge priority is 32768.
SPBM view
priority: Specifies a bridge priority. It must be a multiple of 4096 in the range of 0 to 61440. For example, the bridge priority can be 0, 4096, or 8192. A lower value represents higher priority.
In conjunction with the system ID, the SPBM bridge priority forms the SPBM bridge ID. The SPBM bridge ID is a tie-breaker used in the ECT algorithms for choosing shortest paths.
# Set the bridge priority to 4096.
[Sysname] spbm
[Sysname-spbm] bridge-priority 4096
b-vlan
Use b-vlan to assign a B-VLAN to an SPB VSI.
Use undo b-vlan to restore the default.
b-vlan vlan-id
undo b-vlan
No SPB VSI is assigned a B-VLAN.
SPB I-SID view
vlan-id: Specifies a B-VLAN ID in the range of 1 to 4094.
You can assign only one B-VLAN to an SPBM VSI, but different SPBM VSIs can use the same B-VLAN.
For an SPBM VSI, you must specify the same I-SID and B-VLAN across all BEBs and BCBs.
# Assign B-VLAN 100 to I-SID 256.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] spb i-sid 256
[Sysname-vsi-vpn1-256] b-vlan 100
circuit-cost
Use circuit-cost to set a global SPBM link metric value.
Use undo circuit-cost to restore the default.
circuit-cost cost-value
undo circuit-cost
No global SPBM link metric value is set.
SPBM view
cost-value: Specifies a link metric value in the range of 1 to 16777215.
To assign a link metric value to an interface, use one of the following methods:
· Set an interface-specific value in interface view.
· Set a global value in SPBM view. This global value applies to all SPBM-enabled interfaces.
· Set a bandwidth reference for the system to calculate a value automatically for the interface.
The system chooses a link metric value for an interface in order of interface-specific value, global value, and autocalculated value.
# Set the global SPBM link metric value to 11.
[Sysname] spbm
[Sysname-spbm] circuit-cost 11
bandwidth-reference
spbm cost
control-address
Use control-address to configure the control MAC address for ISIS-SPB.
Use undo control-address to restore the default.
control-address { all-cb | all-is | all-l1-is | all-l2-is | all-pb }
The control MAC address for ISIS-SPB is 0180-C200-002E (all-pb).
SPBM view
all-cb: Sets the control MAC address for ISIS-SPB to 0180-C200-002F.
all-is: Sets the control MAC address for ISIS-SPB to 0900-2B00-0005.
all-l1-is: Sets the control MAC address for ISIS-SPB to 0180-C200-0014.
all-l2-is: Sets the control MAC address to 0180-C200-0015.
all-pb: Sets the control MAC address to 0180-C200-002E.
ISIS-SPB uses a control MAC address for ISIS-SPB peer-to-peer communication. The control MAC specifies the destination MAC address for ISIS-SPB protocol frames.
Vendors might use different control MAC addresses. You can change the ISIS-SPB control MAC for interoperability in a multivendor network.
# Set the control MAC address for ISIS-SPB to 0900-2B00-0005 (all-is).
[Sysname] spbm
[Sysname-spbm] control-address all-is
display l2vpn minm connection
Use display l2vpn minm connection to display MAC-in-MAC connections.
display l2vpn minm connection [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, the command displays MAC-in-MAC connections for all VSIs.
# Display MAC-in-MAC connections for all VSIs.
<Sysname> display l2vpn minm connection
Total number of MinM connections: 6
Types: MC - multicast, UC - unicast
VSI name: 1
Link ID I-SID BMAC BVLAN Owner Type Interface
64 10001 9999-8888-7777 1234 SPB UC XGE1/0/1
65 10001 9999-8988-7777 1234 SPB UC XGE1/0/1
- 10001 0011-2222-3333 1234 SPB MC XGE1/0/1
VSI name: 2
68 10002 9999-8888-7777 1234 SPB UC XGE1/0/1
69 10002 9999-8988-7777 1234 SPB UC XGE1/0/1
- 10002 9999-9088-7777 1234 SPB MC XGE1/0/1
XGE1/0/2
Link ID |
Link ID of the MAC-in-MAC connection. |
I-SID |
Backbone service instance identifier. |
BMAC |
Backbone MAC address. |
BVLAN |
Backbone VLAN. |
Owner |
Entry source: · PBB—The connection is set up by PBB. · SPB—The connection is set up by SPBM. |
Type |
Type of the MAC-in-MAC connection: · MC—The connection is for multicast. · UC—The connection is for unicast. |
Outgoing interface. |
display l2vpn minm forwarding
Use display l2vpn minm forwarding to display MAC-in-MAC forwarding entries.
display l2vpn minm forwarding [ vsi vsi-name ] [ slot slot-number ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, the command displays MAC-in-MAC forwarding entries for all VSIs.
slot slot-number: Specifies an IRF member device. The slot-number argument represents its IRF member ID. If you do not specify a member device, the command displays MAC-in-MAC forwarding entries on the master device.
# Display all MAC-in-MAC forwarding entries.
<Sysname> display l2vpn minm forwarding
Status Flag: * - inactive
VSI name: 1
VSI name: 2
XGE1/0/2
Link ID |
I-SID |
BMAC |
BVLAN |
Backbone VLAN. |
Owner |
Type |
Outgoing interface. If the entry does not take effect, an asterisk (*) is displayed next to the outgoing interface. |
display l2vpn vsi
Use display l2vpn vsi to display VSI information.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, the command displays information about all VSIs.
verbose: Displays detailed VSI information. If you do not specify this keyword, the command displays brief VSI information.
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: 0
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : Unlimited
Broadcast Restrain : Unlimited
Multicast Restrain : Unlimited
Unknown Unicast Restrain: Unlimited
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
SPB I-SID : 10000
Flooding : Enabled
Statistics : Disabled
VXLAN ID : -
VSI Name: 1
VSI Index : 1
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
SPB I-SID : 10001
Flooding : Enabled
VXLAN ID : -
SPB Connections:
BMAC BVLAN Link ID Type
9999-8888-7777 1234 64 Unicast
9999-8988-7777 1234 65 Unicast
ACs:
AC Link ID State Type
BAGG1 srv1 0 Down Manual
VSI Description |
VSI description. This field is displayed only if you have configured a description for the VSI. |
VSI State |
VSI state: · Up—The VSI is up. · Down—The VSI is down. · Administratively down—The VSI has been manually shut down with the shutdown command. |
MTU |
MTU for the VSI. |
Bandwidth |
This field is not supported in the current software version. Bandwidth limit in kbps. If no bandwidth limit is set for the VSI, Unlimited is displayed. |
Broadcast Restrain |
Broadcast restraint bandwidth (in kbps). |
Multicast Restrain |
Multicast restraint bandwidth (in kbps). |
Unknown Unicast Restrain |
Unknown unicast restraint bandwidth (in kbps). |
MAC Learning |
State of the MAC learning feature: · Enabled—The feature is enabled. · Disabled—The feature is disabled. |
MAC Table Limit |
This field is not supported in the current software version. Maximum number of MAC address entries on the VSI. If the value is set to Unlimited, there is no limit on the number of MAC address entries. |
MAC Learning rate |
This field is not supported in the current software version. MAC entry learning rate of the VSI. |
Drop Unknown |
This field is not supported in the current software version. Action on frames that have unknown source MAC addresses after the maximum number of MAC entries is reached: · Enabled—Drops these packets. · Disabled—Forwards these packets. |
Flooding |
State of the VSI's flooding feature: · Enabled—Flooding is enabled on the VSI. · Disabled—Flooding is disabled on the VSI. |
Statistics |
Packet statistics state: · Enabled—The packet statistics feature is enabled for the VSI. · Disabled—The packet statistics feature is disabled for the VSI. |
VXLAN ID |
VXLAN ID. This field is not supported in SPBM and always displays a hyphen (-). |
Type |
Entry type: · Multicast—The entry is used for multicast forwarding. · Unicast—The entry is used for unicast forwarding. |
ACs |
Attachment circuits that are bound to the VSI. |
AC |
Represents an attachment circuit. This field consists of a Layer 2 interface name and an Ethernet service instance name. For example, XGE1/0/1 srv1. |
Link ID |
Link ID automatically assigned to the AC or PW in the VSI. |
State |
AC state: · Up. · Down. |
Type |
Type and traffic match mode of the Ethernet service instance. Manual indicates a static Ethernet service instance in VLAN-based traffic match mode. |
Use display spbm agreement-protocol to display AP information for an ECT algorithm on an interface.
display spbm agreement-protocol status interface interface-type interface-number ect ect-number
ect ect-number: Specifies an ECT algorithm index in the range of 1 to 16.
# Display AP information for ECT algorithm 1 on Ten-GigabitEthernet 1/0/1.
<Sysname> display spbm agreement-protocol status interface ten-gigabitethernet 1/0/1 ect 1
Port AP information:
TxDigest : 00000000000000000000000000003f1f5e5270ce
RxDigest : 00000000000000000000000000003f1f5e5270ce
NBRAPMode: Both
TxAN : 1 TxDAN : 0
RxAN : 0 RxDAN : 0
TxValid : No RxValid : No
MisOrder : No TopoAgree: Yes
CalcEnd : Yes AgreeSend: Normal
Port SPT AP information:
SystemID : 0011.2200.0001
Role : ROOT SelectedRole: ROOT
PSTState : 2 ReRoot : No
Agree : Yes Agreed : Yes
Sync : No Synced : Yes
Forward : Yes Forwarding : Yes
SystemID : 0011.2200.0101
Role : DESI SelectedRole: DESI
TxDigest |
Local agreement digest. |
RxDigest |
Agreement digest of the neighbor. |
NBRAPMode |
AP mode of the neighbor: · Both—Performs AP check for both unicast and multicast FDB entries. · Multicast—Performs AP check only for multicast FDB entries. · Off—AP mode is disabled. |
TxAN |
Local agreement number. |
TxDAN |
Local discarded agreement number. |
RxAN |
Neighbor's agreement number. |
RxDAN |
Neighbor's discarded agreement number. |
TxValid |
Validity of the local digest. |
RxValid |
Validity of the neighbor's digest. |
MisOrder |
Whether or not the message is out of order. |
TopoAgree |
Whether or not the topologies of the two sides match. |
CalcEnd |
Whether or not topology calculation has been finished. |
AgreeSend |
Digest transmit mode: · Normal—The agreement digest was sent at the normal speed. · Fast—The agreement digest was fast flooded. |
SystemID |
System ID for the root of the SPT that contains the port. |
Role |
Current port role: · ROOT—Root port. · ALTE—Alternate port. · DESI—Designated port. |
SelectedRole |
Newly computed role for the port: · ROOT—Root port. · ALTE—Alternate port. · DESI—Designated port. |
PSTState |
PST state of the port, including discarding, learning, and forwarding. |
ReRoot |
Whether or not a reroot is required for the port. |
Agree |
Whether or not the port sends the Agreement flag. |
Agreed |
Whether or not an Agreement has been received. |
Sync |
Whether or not a port state synchronization is required on the port. |
Synced |
Port state synchronization state. |
Forward |
Whether or not the port is to be placed in forwarding state. |
Forwarding |
Whether or not the port is in forwarding state. |
display spbm bridge
Use display spbm bridge to display SPBM bridge information.
display spbm bridge
# Display SPBM bridge information.
<Sysname> display spbm bridge
System ID Priority SPSource ID Host name
5555.1111.1111 32768 128 SPB-1
Table 5 Command output
Priority |
Bridge priority. |
SPSource ID |
Shortest path source identifier. |
Host name |
Hostname. If a hostname is not configured, this field displays the system ID. |
display spbm b-vlan
Use display spbm b-vlan to display ECT algorithm information for B-VLANs.
display spbm b-vlan [vlan-id ]
vlan-id: Specifies a B-VLAN ID in the range of 1 to 4094. If you do not specify a B-VLAN ID, the command displays ECT algorithm information for all B-VLANs.
# Display ECT algorithm information for all B-VLANs.
<Sysname> display spbm b-vlan
B-VLAN 1:
Mode: SPBM
Local use: Yes Remote use: No
ECT-Index: 1 Algorithm: 00-80-c2-01 Mask: 0x00
I-SID list: 300-302, 305, 309
B-VLAN 2:
Mode: SPBM
I-SID list: 400-402, 404
Table 6 Command output
Mode |
System operating mode. This field displays SPBM for an SPBM-enabled device. |
Local use |
Availability of the B-VLAN for transmitting traffic at the local end: · Yes—The B-VLAN can transmit traffic. · No—The B-VLAN cannot transmit traffic. |
Remote use |
Availability of the B-VLAN for transmitting traffic at the remote end: · Yes—The B-VLAN can transmit traffic. · No—The B-VLAN cannot transmit traffic. |
ECT-Index |
ECT algorithm index. |
Algorithm |
ECT algorithm content. |
Mask |
ECT algorithm mask. |
I-SID list |
I-SIDs mapped to the B-VLAN on the local device. This field displays N/A if no I-SIDs are mapped to the B-VLAN. |
Use display spbm bvlan-info to display SPBM B-VLAN information.
display spbm bvlan-info [ slot slot-number ]
slot slot-number: Specifies an IRF member device. The slot-number argument represents its IRF member ID. If you do not specify a member device, the command displays B-VLAN information for all member devices.
# Display SPBM B-VLAN information.
<Sysname> display spbm bvlan-info
Epoch: 0x1
Config B-VLAN list:
1-7, 20
Driver B-VLAN list:
1
Table 7 Command output
Epoch |
Number of SPBM process reinitiations. |
Config B-VLAN list |
B-VLANs mapped to MSTI 4092 at the CLI. |
Driver B-VLAN list |
B-VLANs issued to the driver. |
Use display spbm bvlan-info statistics to display SPBM B-VLAN statistics.
display spbm bvlan-info statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device. The slot-number argument represents its IRF member ID. If you do not specify a member device, the command displays B-VLAN statistics for all member devices.
# Display all SPBM B-VLAN statistics.
<Sysname> display spbm bvlan-info statistics
SPBM B-VLAN basic statistics:
RefreshMsg : 1 AgeNumber : 0
DrvAddNumber : 1 DrvDeleteNumber : 0
SPBM B-VLAN error statistics:
BVLANMsgError : 0 BVLANCreatFail : 0
DrvEnableFail : 0 DrvDisableFail : 0
AllocBVLANFail : 0
Table 8 Command output
RefreshMsg |
Number of B-VLAN refresh messages. |
AgeNumber |
Number of B-VLAN expirations. |
DrvAddNumber |
Number of messages sent to the driver for adding B-VLANs. |
DrvDeleteNumber |
Number of messages sent to the driver for deleting B-VLANs. |
BVLANMsgError |
Number of B-VLAN error messages received by SPBM. |
BVLANCreatFail |
Number of memory allocation failures for B-VLAN creation. |
DrvEnableFail |
Number of failures to notify the driver to enable B-VLANs. |
DrvDisableFail |
Number of failures to notify the driver to disable B-VLANs. |
AllocBVLANFail |
Number of B-VLAN allocation failures. |
Use display spbm common statistics to display global SPBM statistics.
display spbm common statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device. The slot-number argument represents its IRF member ID. If you do not specify a member device, the command displays global SPBM statistics for all member devices.
# Display global SPBM statistics.
<Sysname> display spbm common statistics
UMACReDRVCount : 0 MMACReDRVCount : 0
ActiveFail : 0 AllocMsgFail : 0
RTMsgTypeError : 0 WriteQueFail : 0
SyncRTMsgFail : 0 CommMsgTypeError : 0
ComQueMsgTypeError: 0 TimerQueMsgTypeError: 0
EpochNumber : 0 GetBMACNumber : 1
GetBMACFail : 0 SetIfNumber : 6
AgeIfNumber : 0 SetIfErrNumber : 0
Table 9 Command output
UMACReDRVCount |
Number of unicast MAC entries refreshed to the driver. |
MMACReDRVCount |
Number of multicast MAC entries refreshed to the driver. |
ActiveFail |
Number of failures for the standby MPU to take over the active MPU role. |
AllocMsgFail |
Number of memory allocation failures. |
RTMsgTypeError |
Number of routing messages received with a message type error. |
WriteQueFail |
Number of queue write failures. |
SyncRTMsgFail |
Number of routing message synchronization failures. |
CommMsgTypeError |
Number of messages received with a message type error. |
ComQueMsgTypeError |
Number of messages with a queue type error. |
TimerQueMsgTypeError |
Number of timer queue messages with a message type error. |
EpochNumber |
Number of global SPBM process reinitiations. If the timestamp of an entry is less than this value, the entry is deleted. |
GetBMACNumber |
Number of attempts to get B-MAC addresses from the driver. |
GetBMACFail |
Number of failures to get B-MAC addresses from the driver. |
SetIfNumber |
Number of SPBM enabling attempts on the interface. |
AgeIfNumber |
Number of age-outs on the interface. |
SetIfErrNumber |
Number of failures to set interfaces in the driver. |
display spbm ect
Use display spbm ect to display B-VLAN to ECT algorithm mappings by ECT algorithm index.
display spbm ect [ ect-index ]
ect-index: Specifies an ECT algorithm index in the range of 1 to 16. If you do not specify an ECT algorithm, the command displays information for all ECT algorithms.
# Display information about all ECT algorithms.
<Sysname> display spbm ect
ECT-1:
Active B-VLANs: 1-10
Inactive B-VLANs: 31-4094
ECT-2:
Algorithm: 00-80-c2-02 Mask: 0xff
Active B-VLANs: 11-20
Inactive B-VLANs: 21-30
ECT-3:
Algorithm: 00-80-c2-03 Mask: 0x88
Active B-VLANs: N/A
Inactive B-VLANs: N/A
ECT-4:
Algorithm: 00-80-c2-04 Mask: 0x77
Active B-VLANs: N/A
ECT-5:
Algorithm: 00-80-c2-05 Mask: 0x44
Active B-VLANs: N/A
ECT-6:
Algorithm: 00-80-c2-06 Mask: 0x33
Active B-VLANs: N/A
ECT-7:
Algorithm: 00-80-c2-07 Mask: 0xcc
Active B-VLANs: N/A
ECT-8:
Algorithm: 00-80-c2-08 Mask: 0xbb
Active B-VLANs: N/A
ECT-9:
Algorithm: 00-80-c2-09 Mask: 0x22
Active B-VLANs: N/A
ECT-10:
Algorithm: 00-80-c2-0a Mask: 0x11
Active B-VLANs: N/A
ECT-11:
Algorithm: 00-80-c2-0b Mask: 0x66
Active B-VLANs: N/A
ECT-12:
Algorithm: 00-80-c2-0c Mask: 0x55
Active B-VLANs: N/A
ECT-13:
Algorithm: 00-80-c2-0d Mask: 0xaa
Active B-VLANs: N/A
ECT-14:
Algorithm: 00-80-c2-0e Mask: 0x99
Active B-VLANs: N/A
ECT-15:
Algorithm: 00-80-c2-0f Mask: 0xdd
Active B-VLANs: N/A
ECT-16:
Algorithm: 00-80-c2-10 Mask: 0xee
Active B-VLANs: N/A
Table 10 Command output
Algorithm |
ECT algorithm. |
Mask |
Active B-VLANs |
Active B-VLANs mapped to the ECT algorithm. Active B-VLANs are VLANs mapped to MSTI 4092. This field displays N/A if no active B-VLANs are mapped to the algorithm. |
Inactive B-VLANs |
Inactive B-VLANs mapped to the ECT algorithm. This field displays N/A if no inactive B-VLANs are mapped to the algorithm. |
display spbm ect-migration
Use display spbm ect-migration to display ECT migration information for an I-SID.
display spbm ect-migration i-sid i-sid
i-sid i-sid: Specifies an I-SID in the range of 255 to 16777215.
# Display ECT migration information for I-SID 300.
<Sysname> display spbm ect-migration i-sid 300
ECT B-VLAN T R
00-80-c2-01 1 0 1
Table 11 Command output
ECT |
ECT algorithm. |
B-VLAN |
B-VLAN assigned to the I-SID. |
T |
Transmit (T) bit identifies the device's transmitter status in the multicast group for the I-SID: · 1—T bit set. The device is a transmitter. If tandem replication is used, the BEB sets the T bit. · 0—T bit not set. The device is not a transmitter. If head-end replication is used, the BEB does not set the T bit. |
R |
Receive (R) bit identifies the device's receiver status in the multicast group for the I-SID: · 1—R bit set. The device is a receiver. · 0—R bit not set. The device is not a receiver. |
Use display spbm fast-channel statistics to display fast-channel statistics.
# Display fast-channel statistics.
<Sysname> display spbm fast-channel statistics
Fast channel information for SPBM
VSI name : 1
B-VLAN : 1
I-SID : 255
State : Active
Replication mode : tandem
ECT algorithm : 00-80-c2-01
LSPs sent count : 10
LSPs received count : 20
LSP timer : 10
LSPs transmitted count: 10
Table 12 Command output
State |
Availability of the fast channel: · Active—The fast channel is available for transmitting LSPs. · Inactive—The fast channel is not available for transmitting LSPs. |
Replication mode |
Multicast replication mode: · head-end—Head-end replication. · tandem—Tandem replication. |
ECT algorithm |
ECT algorithm for the B-VLAN. |
LSPs sent count |
Number of LSPs transmitted in the fast channel. This field is cleared when one of the following events occurs: · The reset spbm database command is executed. · The SPB VSI with I-SID 255 comes down. · Process placement starts. For more information about process placement, see High Availability Configuration Guide. |
LSPs received count |
Number of LSPs received in the fast channel. This field is cleared when one of the following events occurs: · The reset spbm database command is executed. · The SPB VSI with I-SID 255 comes down. · Process placement starts. |
LSP timer |
Minimum LSP transmit interval, in milliseconds for the fast channel. The timer value is not user configurable. |
LSPs transmitted count |
Maximum number of LSPs that can be sent at each interval in the fast channel. The setting is not user configurable. |
Use display spbm graceful-restart event-log to display SPBM Graceful Restart logs.
display spbm graceful-restart event-log slot slot-number
slot slot-number: Specifies an IRF member device by its member ID.
# Display SPBM Graceful Restart logs for slot 1.
<Sysname> display spbm graceful-restart event-log slot 1
SPBM log information:
Oct 5 12:54:53 2013 -Slot=1 HA backup channel was blocked.
Oct 5 12:54:56 2013 -Slot=1 HA backup channel was unblocked.
Table 13 Command output
Initialization |
ISIS-SPB Graceful Restart was initialized. |
LSDB synchronization |
Peer ISIS-SPB processes synchronized LSDBs. |
LSP stability |
The local LSDB converged. |
LSP generation |
ISIS-SPB generated and flooded LSPs. |
SPF computation |
ISIS-SPB performed SPF computation. |
Flush smooth |
ISIS-SPB smoothed kernel data. |
Finish |
ISIS-SPB Graceful Restart entered the final phase. |
GR complete |
ISIS-SPB Graceful Restart was completed. |
Use display spbm graceful-restart status to display SPBM Graceful Restart information.
# Display SPBM Graceful Restart information.
<Sysname> display spbm graceful-restart status
Restart information for SPBM
Restart status : Restarting
Restart phase : LSDB synchronization
Restart interval : 300
SA bit : Supported
Total number of interfaces : 2
Number of waiting LSPs : 3
T2 remaining time : 41
Interface T1 remaining time RA received CSNP received T1 expirations
XGE1/0/1 2 Y N 2
XGE1/0/2 2 Y N 2
Table 14 Command output
Restart status |
Restart state of the device: · Restarting—The device is rebooting ISIS-SPB or performing an active/standby MPU switchover. In this state, the device can forward traffic because its FIB is usable. · Starting—The device is rebooting. In this state, the device cannot forward traffic because the FIB is not usable. · Complete—The GR process is complete. The device can forward traffic. |
Restart phase |
Restart phase: · Initialization—ISIS-SPB Graceful Restart is initialized. · LSDB synchronization—Peer ISIS-SPB processes are synchronizing LSDBs. · LSP stability—The local LSDB is converging. · LSP generation—ISIS-SPB generates and floods LSPs. · First SPF computation—ISIS-SPB performs the first SPF computation. · Finish—SPF computation is finished. |
Restart Interval |
The maximum adjacency hold time (in seconds). If the restarting device fails to complete restarting before this timer expires, the peer ISIS-SPB process removes the adjacency with the restarting ISIS-SPB. This timer is configurable with the graceful-restart t2 command. |
SA bit |
Support for setting the SA bit in the Restart TLV sent to the neighbor: · Supported—The device performs the following actions: ¡ When the FIB is not usable, the device sets the SA bit in the hello messages so the neighbor will not advertise its adjacency with the restarting device. ¡ When the routing table is usable, the device clears the SA bit in the hello messages so the neighbor will advertise its adjacency with the restarting device. · Not supported—The device clears the SA bit in the hello messages so the neighbor will always advertise its adjacency with the restarting device. |
Total number of interfaces |
Number of SPBM-enabled interfaces. |
Number of waiting LSPs |
Number of LSPs that are waiting to be synchronized with the GR helper for completing LSDB synchronization. |
T2 remaining time |
The remaining time (in seconds) of the T2 timer. If the restarting device fails to complete restarting before this timer expires, the neighbor removes the adjacency with the restarting device. |
T1 remaining time |
Remaining time (in seconds) of the T1 timer on the interface. The T1 timer sets the interval for the restarting device to retransmit hello messages with the RR bit set (restart request messages). The T1 timer is not user configurable. The restarting device retransmits a restart request message to the neighbor if it does not receive an acknowledgment for a restart request (hello message with the RA bit set) before the T1 timer expires. |
RA received |
Whether the interface received an ISIS-SPB hello with the RA flag from the neighbor device. |
CSNP received |
Whether the interface received a CSNP from the neighbor device. |
T1 expirations |
Number of T1 timer expirations on the interface. When this counter reaches 10, the restarting device stops retransmitting hello messages with the RR bit set. |
display spbm interface
Use display spbm interface to display information about SPBM-enabled interfaces.
display spbm interface [ interface-type interface-number ] [ verbose ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays information about all SPBM-enabled interfaces.
verbose: Displays detailed interface information. If you do not specify this keyword, the command displays the brief information.
# Display brief information about all SPBM-enabled interfaces.
<Sysname> display spbm interface
Interface information for SPBM
Interface Circuit ID State MTU Cost
XGE1/0/1 1 Up 1497 10
XGE1/0/2 2 Up 1497 100
# Display detailed information about all SPBM-enabled interfaces.
<Sysname> display spbm interface verbose
Hello timer : 10
Hello multiplier : 3
LSP timer : 33
LSP transmitted count : 5
Hello timer : 10
LSP timer : 33
# Display detailed SPBM information for Ten-GigabitEthernet 1/0/1.
<Sysname> display spbm interface ten-gigabitethernet 1/0/1 verbose
Hello timer : 10
LSP timer : 33
Table 15 Command output
MTU |
Maximum transmission unit of the interface. |
Cost |
SPBM link metric value of the interface. |
Hello timer |
ISIS-SPB hello interval (in seconds). |
Hello multiplier |
Hello multiplier for calculating the adjacency hold time. The adjacency hold time equals the ISIS-SPB hello interval multiplied by the hello multiplier. |
LSP timer |
Minimum LSP transmit interval (in milliseconds). |
LSP transmitted count |
Maximum number of LSPs sent at each LSP transmit interval. |
display spbm lsdb
Use display spbm lsdb to display the SPBM LSDB.
display spbm lsdb [ [ lsp-id lspid | lsp-name lspname ] | local | verbose ] *
lsp-id lspid: Specifies an LSP ID in SYSID.Pseudonode ID-fragment num format. The SYSID argument represents the system ID of the LSP originating node. The Pseudonode ID argument represents the ID of the pseudonode. The fragment num argument represents the LSP fragment number. If you do not specify an LSP ID, the command displays LSP information for all LSP IDs.
lsp-name lspname: Specifies the LSP name in Symbolic name-fragment num format. The Symbolic name argument represents the symbolic hostname of the LSP originating node. The fragment num argument represents the LSP fragment number. If you do not specify an LSP name, the command displays LSP information for all LSP names.
local: Displays LSPs generated by the local device. If you do not specify this keyword, the command displays information for LSPs generated by all devices.
verbose: Displays detailed LSDB information. If you do not specify this keyword, the command displays LSP digests.
If you do not specify any parameters, the command displays digests for all LSPs.
# Display digests for all LSPs.
<Sysname> display spbm lsdb
Database information for SPBM
LSP ID: * - Local LSP
LSP ID Seq Num Checksum Holdtime Length Overload
4455.6677.0001.00-00 0x00000fd2 0x1cea 1044 236 0
4455.6677.0001.00-01 0x00000fd2 0x1cea 1044 256 0
4455.6677.0003.00-00* 0x00001448 0x3d27 683 323 0
4455.6677.0003.00-01* 0x00001448 0xbd27 683 723 0
4455.6677.0004.00-00 0x00000ff8 0xd1d9 1090 323 0
4455.6677.0004.00-01 0x00000ff8 0xd7d9 1090 329 0
# Display detailed information about all LSPs.
<Sysname> display spbm lsdb verbose
0011.2200.0001.00-00 0x0000000e 0x29ef 429 69 0
System ID : 0011.2200.0001
NLPID : SPBM
Area address : 00.0000
MT capability TLV :
MT ID : 00
MT overload : 0
SPB instance sub-TLV:
CIST root identifier : 0000-0000-0000-0000
CIST ERPC : 0
Bridge priority : 32768
SPSourceID : 100
Number of trees : 1
B-VLAN: 10 U-Bit: 1 ECT: 00-80-c2-01 SPVID: 0
0011.2200.0001.00-01 0x0000000f 0x209e 1190 66 0
Hostname : 0011.2200.0001.00
MT capability TLV :
MT ID : 00
MT overload : 0
SPBM Service Identifier and Unicast Address sub-TLV:
B-MAC : 0011-2200-0001
B-VLAN : 10
I-SID : 300(R)
Extended neighbor reachability TLV:
Hostname : 0011.2200.0101.00
Cost : 11
Port number : 1
0011.2200.0101.00-00* 0x00000002 0x3846 1190 69 0
System ID : 0011.2200.0101
NLPID : SPBM
MT capability TLV :
MT ID : 00
MT overload : 0
CIST ERPC : 0
SPSourceID : 10
Number of Trees : 1
0011.2200.0101.00-01* 0x00000002 0xfdcd 1190 66 0
MT capability TLV :
MT ID : 00
MT overload : 0
B-MAC : 0011-2200-0101
B-VLAN : 10
I-SID : 300(R)
I-SID : 301(T&R)
Cost : 10
Port number : 1
Table 16 Command output
LSP ID |
LSP ID. An asterisk (*) indicates a local LSP. |
Seq Num |
LSP sequence number. |
Checksum |
LSP checksum. |
Holdtime |
LSP lifetime (in seconds). |
Length |
LSP length. |
Overload |
Overload bit in the LSP: · 1—Overload bit set. ISIS-SPB will not use this LSP for shortest path calculation because the LSP originating node is experiencing an LSDB error condition. · 0—Overload bit not set. The LSP can be used for shortest path calculation. |
System ID |
System ID of the LSP originating device. |
NLPID |
Network layer protocol running on the LSP originating device. This field is always SPBM for an SPBM node. |
Area address |
Area address of the LSP originating device. |
MT capability TLV |
Multi-topology capability TLV. |
MT ID |
Topology ID in a multi-topology environment. |
MT overload |
Overload bit in the multi-topology capability TLV: · 1—Overload bit set. · 0—Overload bit not set. |
SPB instance sub-TLV |
The SPB instance sub-TLV contains the SPSourceID of the LSP originating device. |
CIST root identifier |
This field is for SPBM that works with RSTP and MSTP at SPT Region boundaries. It is an imported value from a spanning tree. |
CIST ERPC |
CIST external root path cost is the cost to the CIST root. It is derived from the spanning tree algorithm. |
SPSourceID |
Shortest path source identifier. An SPSource ID uniquely identifies a device in an SPBM network. The SPSourceID is used for constructing multicast destination addresses for multicast frames that are originated from the LSP originating device. |
Bridge priority |
Bridge priority. The bridge priority and the system ID form the bridge identifier, which is a tie-breaker used in ECT algorithms for SPT computation. |
Number of trees |
Number of B-VLAN to ECT mappings. |
U-Bit |
U bit status: · 1—U bit set. The U bit is set if the LSP originating device can use the B-VLAN to transmit traffic. · 0—U bit not set. The U bit is not set if the LSP originating device cannot use the B-VLAN to transmit traffic. |
ECT |
ECT algorithm. |
SPVID |
SPBV ID. It is fixed at 0 for SPBM. |
SPBM Service Identifier and Unicast Address sub-TLV |
SPBM service identifier and unicast address sub-TLV. |
I-SID |
I-SID and the multicast group membership flags of the LSP originating device for the I-SID. The following are the flags: · T—T bit set. The LSP originating device is a transmitter in the multicast group for the I-SID. · R—R bit set. The LSP originating device is a receiver in the multicast group for the I-SID. This field displays (T&R) next to the I-SID if the originating device is both a receiver and a transmitter in the multicast group for the I-SID. |
Extended neighbor reachability TLV |
Extended neighbor reachability TLV. |
Hostname |
Symbolic hostname configured with the is-name command. If the LSP originating device is not assigned a hostname, this field displays its system ID. |
Cost |
Link metric value. |
Port number |
Number of ports that have adjacencies. |
is-name
display spbm multicast-fdb
Use display spbm multicast-fdb to display SPBM multicast FDB entries.
display spbm multicast-fdb [ b-vlan vlan-id | i-sid i-sid | system-id system-id ]
display spbm multicast-fdb [ b-vlan vlan-id ] count
b-vlan vlan-id: Specifies a B-VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a B-VLAN, the command displays multicast FDB entries for all B-VLANs.
i-sid i-sid: Specifies an I-SID in the range of 255 to 16777215. If you do not specify an I-SID, the command displays multicast FDB entries for all I-SIDs.
system-id system-id: Specifies a system ID in XXXX.XXXX.XXXX format. If you do not specify a system ID, the command displays multicast FDB entries for all system IDs.
count: Specifies the number of matching multicast FDB entries.
The SPBM multicast FDB contains multicast routes that ISIS-SPB calculates based on the SPBM LSDB.
If you do not specify any parameters, the command displays all multicast FDB entries.
# Display all SPBM multicast FDB entries.
<Sysname> display spbm multicast-fdb
Flags: E-Egress T-Transit
System ID MAC address B-VLAN Flags Port
0011.2200.de01 9334-6900-03e8 7 T XGE1/0/2
0011.2200.de01 9334-6900-0190 4 T XGE1/0/2
0011.2200.de01 9334-6900-01f4 5 T XGE1/0/2
# Display the total number of SPBM multicast FDB entries.
<Sysname> display spbm multicast-fdb count
Total entries: 2
Table 17 Command output
MAC address |
Multicast MAC address. |
Flags |
Forwarding actions: · E—Forwards the frame out of the tunnel to the customer site. · T—Forwards the frame to the next node in the tunnel. If this field displays both flags, the device performs both actions. |
Port |
Outgoing interfaces. This field displays N/A if no outgoing interfaces are available. |
Use display spbm multicast-fib to display SPBM multicast FIB entries.
display spbm multicast-fib [ mac-address mac-address [ b-vlan vlan-id ] | b-vlan vlan-id ] [ slot slot-number ] [ verbose ]
display spbm multicast-fib [ b-vlan vlan-id ] [ slot slot-number ] count
mac-address mac-address: Specifies an SPBM multicast address in H-H-H format. You can omit the consecutive 0s at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a multicast address, the command displays FIB entries for all multicast B-MACs.
b-vlan vlan-id: Specifies a B-VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a B-VLAN, the command displays multicast FIB entries for all B-VLANs.
mac-address mac-address b-vlan vlan-id: Specifies an SPBM multicast address in a B-VLAN. If you do not specify this option, the command displays all multicast FIB entries.
verbose: Displays detailed information about multicast FIB entries. If you do not specify this keyword, the command only displays brief information.
slot slot-number: Specifies an IRF member device. If you do not specify a member device, the command displays multicast FIB entries for all member devices. The slot-number argument represents its IRF member ID.
count: Specifies the number of matching multicast FIB entries.
The SPBM multicast FIB is used in the data plane for forwarding multicast traffic. It contains multicast entries derived from the SPBM multicast FDB.
# Display brief information about all SPBM multicast FIB entries.
<Sysname> display spbm multicast-fib
0300-0b00-0001 1 TE XGE1/0/2
# Display detailed information about all SPBM multicast FIB entries.
<Sysname> display spbm multicast-fib verbose
MAC address B-VLAN Flags Epoch Port Port flag
0300-0b00-0001 1 TE 0x1 XGE1/0/2 Done
# Display detailed information about the multicast FIB entry for 0300-0b00-0001 in B-VLAN 1.
<Sysname> display spbm multicast-fib mac-address 0300-0b00-0001 b-vlan 1 verbose
MAC address: 0300-0b00-0001 B-VLAN : 1
Flags : TE Driver flag: Done Epoch: 0x1
Context: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
Port Context Port flag
XGE1/0/2 0xffffaaaa 0xffffaaaa Done
XGE1/0/1 0xffffaaaa 0xffffbbbb Done
# Display the number of multicast FIB entries for B-VLAN 100.
<Sysname> display spbm multicast-fib b-vlan 100 count
Total entries: 3
Table 18 Command output
MAC address |
SPBM multicast MAC address. |
B-VLAN |
B-VLAN that contains the entry. |
Flags |
Driver flag |
State of issuing the entry to the driver: · Nores—SPBM failed to issue the entry to the driver because of insufficient resources. The entry is not usable. · Done—SPBM issued the entry to the driver. |
Epoch |
Timestamp of the entry. |
Context |
Context that the driver returned when the entry was set in the driver. |
Port |
Context |
Context that the driver returned for the outgoing interface. |
Port flag |
State of issuing the interface to the driver: · Nores—SPBM failed to issue the interface to the driver because of insufficient resources. · Done—SPBM issued the interface to the driver successfully. · N/A—SPBM does not issue the interface to the driver. |
Use display spbm multicast-fib statistics to display SPBM multicast FIB statistics.
display spbm multicast-fib statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device. The slot-number argument represents its IRF member ID. If you do not specify a member device, the command displays multicast FIB statistics for all member devices.
# Display all SPBM multicast FIB statistics.
<Sysname> display spbm multicast-fib statistics
SPBM multicast FIB basic statistics:
RefreshMsg : 0 DeleteMsg : 0
AddIfMsg : 1 DeleteIfMsg : 0
AddMMACNumber : 1 DeleteMMACNumber : 0
DeleteNotFound : 0 AgeNumber : 0
DrvAdd : 1 DrvDelete : 0
DrvAddIf : 0 DrvDeleteIf : 0
DrvModifyFlag : 0
SPBM multicast FIB error statistics:
MMACMsgError : 0 RefreshMsgFail : 0
DeleteMsgFail : 0 AddIfMsgFail : 0
DeleteIfMsgFail : 0 AddMMACFail : 0
DrvOtherFail : 0 DrvDeleteFail : 0
DrvNoResource : 0 SynMsgFail : 0
AllocEntryFail : 0 AllocReDrvMsgFail: 0
AllocDrvMsgFail : 0
Table 19 Command output
RefreshMsg |
Number of messages for refreshing multicast FIB entries. |
DeleteMsg |
Number of messages for deleting multicast FIB entries. |
AddIfMsg |
Number of messages for adding outgoing interfaces. |
DeleteIfMsg |
Number of messages for deleting outgoing interfaces. |
AddMMACNumber |
Number of multicast addresses added to the multicast FIB. |
DeleteMMACNumber |
Number of multicast addresses deleted from the multicast FIB. |
DeleteNotFound |
Number of failures to find multicast addresses to be deleted. |
AgeNumber |
Number of expired entries. |
DrvAdd |
Number of multicast entries added to the driver. |
DrvDelete |
Number of multicast entries deleted from the driver. |
DrvAddIf |
Number of outgoing interfaces added to the driver. |
DrvDeleteIf |
Number of outgoing interfaces deleted from the driver. |
DrvModifyFlag |
Number of times the driver modified the forwarding state. |
MMACMsgError |
Number of entry message errors. |
RefreshMsgFail |
Number of failures to process multicast B-MAC refresh messages. |
DeleteMsgFail |
Number of failures to process messages about deleting multicast addresses. |
AddIfMsgFail |
Number of failures to process messages about adding outgoing interfaces. |
DeleteIfMsgFail |
Number of failures to process messages about deleting outgoing interfaces. |
AddMMACFail |
Number of failures to add multicast addresses. |
DrvOtherFail |
Number of failures to process forwarding state messages. |
DrvDeleteFail |
Number of failures to notify the driver to delete multicast addresses. |
DrvNoResource |
Number of failures to issue multicast addresses to the driver because of insufficient system resources. |
SynMsgFail |
Number of failures to synchronize information to the driver. |
AllocEntryFail |
Number of memory allocation failures for multicast FIB entries. |
AllocReDrvMsgFail |
Number of memory allocation failures for refreshing multicast entries to the driver. |
AllocDrvMsgFail |
Number of memory allocation failures for issuing multicast entries to the driver. |
display spbm multicast-pw
Use display spbm multicast-pw to display multicast pseudo wires (PWs) on a BEB.
display spbm multicast-pw [ i-sid i-sid ] [ count ]
i-sid i-sid: Specifies an I-SID in the range of 255 to 16777215. If you do not specify an I-SID, the command displays multicast PW information for all I-SIDs.
count: Specifies the total number of multicast PWs. If you do not specify this keyword, the command only displays multicast PW information.
# Display all multicast PWs.
<Sysname> display spbm multicast-pw
System ID I-SID MAC address B-VLAN Port
0011.2200.0101 300 0300-0a00-012c 10 XGE1/0/1
XGE1/0/2
# Display the total number of multicast PWs.
<Sysname> display spbm multicast-pw count
Total entries: 2
Table 20 Command output
System ID |
System ID of the remote BEB. |
I-SID |
SPBM VSI identifier. |
MAC address |
Destination multicast MAC address for frames to be tunneled. |
B-VLAN |
B-VLAN to be encapsulated for frames to be tunneled. |
Port |
Outgoing interfaces. |
Use display spbm non-stop-routing event-log to display SPBM NSR logs.
display spbm non-stop-routing event-log slot slot-number
# Display SPBM NSR logs for slot 1.
<Sysname> display spbm non-stop-routing event-log slot 1
Oct 5 12:54:55 2013 -Slot=1 HA backup channel was unblocked.
Table 21 Command output
Initialization |
ISIS-SPB NSR was initialized. |
Smooth |
ISIS-SPB NSR smooth started. |
LSP stability |
LSP generation |
SPF computation |
Flush smooth |
Finish |
ISIS-SPB NSR entered the final phase. |
NSR complete |
ISIS-SPB NSR was completed. |
Use display spbm non-stop-routing status to display the SPBM NSR status.
# Display the SPBM NSR status.
<Sysname> display spbm non-stop-routing status
Nonstop Routing information for SPBM
NSR phase: Finish
Table 22 Command output
NSR phase |
NSR phase: · Initialization—ISIS-SPB NSR is initialized. · Smooth—ISIS-SPB NSR smooth starts. · LSP stability—The local LSDB is converging. · LSP generation—ISIS-SPB generates and floods LSPs. · SPF computation—ISIS-SPB performs SPF computation. · Flush smooth—ISIS-SPB smoothes kernel data. · Finish—ISIS-SPB NSR is finishing. |
display spbm peer
Use display spbm peer to display ISIS-SPB neighbor information.
display spbm peer [ system-id system-id ] [ verbose ]
system-id system-id: Specifies a neighbor by its system ID in XXXX.XXXX.XXXX format. If you do not specify a system ID, the command displays information about all ISIS-SPB neighbors.
verbose: Displays detailed information. If you do not specify this keyword, the command only displays brief information.
# Display brief information about all ISIS-SPB neighbors.
<Sysname> display spbm peer
Peer information for SPBM
System ID Port Circuit ID State Holdtime
5555.1111.1111 XGE1/0/2 1 Up 28s
5555.1111.2222 XGE1/0/3 1 Up* 20s
# Displays detailed information about all ISIS-SPB neighbors.
<Sysname> display spbm peer verbose
Peer information:
Host name: spbm-2
Circuit ID: 1 Cost: 10
MCID information:
Format selector : 0
Region name : spb
Revision level : 0
Configuration digest : 0x0253c1480d244e443b21e7c364d6e2a7
Aux MCID information:
Format selector : 0
Region name : spb
Revision level : 0
AP information:
AN: 2 DAN: 0 Valid: 1
Format identifier : 0
Format capabilities : 0
Convention identifier : 0
Convention capabilities : 0
Edge count : 2
Topology digest : 0x000000dc12854410daa2c29221f095144f661000
Local information:
Host name: spbm-1
MCID information:
Format selector : 0
Region name : spb
Revision level : 0
Format Selector : 0
Region Name : spb
Revision Level : 0
Configuration Digest : 0x0253c1480d244e443b21e7c364d6e2a7
AP information:
Edge count : 2
5555.1111.2222 XGE1/0/3 1 Up 20s
Peer information:
Host name: spbm-3
MCID information:
Format selector : 0
Region name : spb
Revision level : 0
Format selector : 0
Region name : spb
Revision level : 0
AP information:
Edge count : 2
Local information:
Host name: spbm-1
MCID information:
Format selector : 0
Region name : spb
Revision level : 0
Format selector : 0
Region name : spb
Revision level : 0
AP information:
Edge count : 2
# Display detailed information about the ISIS-SPB neighbor with a system ID of 5555.1111.1111.
<Sysname> display spbm peer system-id 5555.1111.1111 verbose
5555.1111.1111 XGE1/0/1 1 Up 28s
Peer information:
Host name: spbm-2
MCID information:
Format selector : 0
Region name : spb
Revision level : 0
Format selector : 0
Region name : spb
Revision level : 0
AP information:
Edge count : 2
Local information:
Host name: spbm-1
MCID information:
Format selector : 0
Region name : spb
Revision level : 0
Format selector : 0
Region name : spb
Revision level : 0
AP information:
Edge count : 2
Table 23 Command output
System ID |
System ID of the neighbor. |
Port |
Interface connected to the neighbor. |
Circuit ID |
Circuit ID of the link connected to the neighbor. |
State |
State of the adjacency with the neighbor: · Init—The device is trying to establish an adjacency with the neighbor. · Up—An adjacency has been established, and the link is up. Traffic can be transmitted on this adjacency. · Up*—An adjacency has been established, and the link is up. However, traffic cannot be transmitted on this adjacency. · Down—An adjacency has been established, but the link is down. Traffic cannot be transmitted on this adjacency. |
Holdtime |
Adjacency hold time. The adjacency hold time equals the ISIS-SPB hello interval multiplied by the hello multiplier. The device removes the adjacency with the neighbor if it does not receive hello packets from the neighbor within the hold time. The device maintains the adjacency with the neighbor if it receives a hello packet from the neighbor before the hold time expires. |
Peer information |
Neighbor information. |
Local information |
Information about the local SPBM node. |
Host name |
Symbolic hostname of the SPBM node. If the node is not assigned a symbolic hostname, this field displays its system ID. |
Circuit ID |
Circuit ID of the link. |
Cost |
MCID information |
Primary MST configuration identifier. It contains a digest of B-VLAN to MSTI mappings on the SPBM node. SPBM nodes must have the same MCID for the same I-SID. |
Aux MCID information |
Auxiliary MCID of the SPBM node. |
Format selector |
Format selector. It is fixed at 0 for IEEE 802.1aq SPB. |
Region name |
MST region name. |
Revision level |
MST region revision level. The default level is 0. You can use the revision-level command to change the revision level. |
Configuration digest |
The SPBM node's digest of B-VLAN to MSTI mappings. |
AP information |
AP information advertised on the adjacency. This field displays N/A if the SPBM node has not advertised AP information. |
AN |
Agreement number advertised by the SPBM node. |
DAN |
Discarded agreement number advertised by the SPBM node. |
Valid |
Validity of the advertised AP digest: · 0—The digest is invalid. · 1—The digest is valid. |
Format identifier |
Digest format identifier. |
Format capabilities |
Digest format options. |
Convention identifier |
Loop-free forwarding rules: · 1—No digest match. AP is disabled. Digests are exchanged but a match is not required. · 2—AP is enabled for both unicast and multicast FDB entries. The node forwards multicast and unicast traffic only after the two ends reach a strict agreement. · 3—AP is enabled only for multicast FDB entries. The node forwards multicast traffic only after the two ends reach a strict agreement. However, the node forwards unicast traffic unconditionally. |
Convention capabilities |
Loop-free forwarding rule conventions supported by the SPBM. |
Edge count |
The sum modulo 216 of all edges in the SPB topology. Each point-to-point physical link is counted as two edges. This field provides one component of the agreement digest for detecting topology mismatches. |
Topology digest |
Two neighbors must have the same topology digest to reach an agreement. |
display spbm summary
Use display spbm summary to display the SPBM digest.
# Display the SPBM digest.
<Sysname> display spbm summary
Summary information for SPBM
System control address : 0180-c200-002e
System name : spb-1
SPSource ID : 200
SPSource mode : Static
Agreement mode : Both
MCID information:
Format selector : 0
Region name : spb
Revision level : 0
B-VLANs : 1-10, 100-200
Table 24 Command output
Area address |
ISIS-SPB area address of the device. |
System ID |
System ID of the device in the ISIS-SPB area. |
System control address |
Multicast destination for ISIS-SPB protocol packets. |
System name |
Hostname configured with the is-name command. |
SPSource ID |
Shortest path source identifier uniquely identifies the device as a multicast source in an SPBM VSI. |
SPSource mode |
SPSource ID creation method: · Static—The SPSource ID is manually configured. · Dynamic—The SPSource ID is dynamically assigned by ISIS-SPB. |
Agreement mode |
AP mode: · Both—AP is enabled for both unicast and multicast FDB entries. The device issues a unicast or multicast FDB entry to the FIB for forwarding traffic only if it has reached an agreement with the neighbor. · Multicast—AP is enabled only for multicast. The node forwards multicast traffic only after the two ends reach a strict agreement. However, the node forwards unicast traffic unconditionally. · Off—AP is disabled. Digests are exchanged but a match is not required. |
MCID information |
Local primary MST configuration identifier. It contains a digest of B-VLAN to MSTI mappings on the SPBM node. SPBM nodes must have the same MCID for the same I-SID. |
Format selector |
Region name |
MST region name. |
Revision level |
B-VLANs |
B-VLANs configured on the device. |
display spbm unicast-fdb
Use display spbm unicast-fdb to display SPBM unicast FDB entries.
display spbm unicast-fdb [ b-mac mac-address | b-vlan vlan-id | system-id system-id ] [ count ]
b-mac mac-address: Specifies a B-MAC address in H-H-H format. You can omit the consecutive 0s at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a B-MAC, the command displays unicast FDB entries for all B-MACs.
b-vlan vlan-id: Specifies a B-VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a B-VLAN, the command displays unicast FDB entries for all B-VLANs.
system-id system-id: Specifies a system ID in XXXX.XXXX.XXXX format. If you do not specify a system ID, the command displays unicast FDB entries for all system IDs.
count: Specifies the number of matching unicast FDB entries. If you do not specify this keyword, the command displays unicast FDB entries.
The SPBM unicast FDB contains unicast routes that ISIS-SPB calculates based on the SPBM LSDB.
If you do not specify any parameters, this command displays all unicast FDB entries.
# Display all SPBM unicast FDB entries.
<Sysname> display spbm unicast-fdb
System ID B-MAC B-VLAN Flags Port
0011.2200.0001 0011-2200-0001 9 T XGE1/0/2
0011.2200.0001 0011-2200-0001 4 T XGE1/0/2
0011.2200.0001 0011-2200-0001 5 T XGE1/0/2
# Display the total number of SPBM unicast FDB entries.
<Sysname> display spbm unicast-fdb count
Total entries: 2
Table 25 Command output
Flags |
Port |
Use display spbm unicast-fib to display SPBM unicast FIB entries.
display spbm unicast-fib [ b-mac mac-address [ b-vlan vlan-id ] | b-vlan vlan-id ] [ slot slot-number ] [ verbose ]
display spbm unicast-fib [ b-vlan vlan-id ] [ slot slot-number ] count
b-mac mac-address: Specifies a B-MAC address in H-H-H format. You can omit the consecutive 0s at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a B-MAC, the command displays unicast FIB entries for all B-MACs.
b-vlan vlan-id: Specifies a B-VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a B-VLAN, the command displays unicast FIB entries for all B-VLANs.
b-mac mac-address b-vlan vlan-id: Specifies a B-MAC in a B-VLAN. If you do not specify this option, the command displays all unicast FIB entries.
verbose: Displays detailed information about unicast FIB entries. If you do not specify this keyword, the command only displays brief information.
slot slot-number: Specifies an IRF member device. The slot-number argument represents its IRF member ID. If you do not specify a member device, the command displays unicast FIB entries for all IRF member devices.
count: Specifies the number of matching unicast FIB entries.
The SPBM unicast FIB is used in the data plane for forwarding unicast traffic. It contains unicast entries derived from the SPBM unicast FDB.
# Display brief information about all SPBM unicast FIB entries.
<Sysname> display spbm unicast-fib
0011-2200-0101 1 T XGE1/0/1
0011-2200-0101 2 T XGE1/0/2
# Display detailed information about all SPBM unicast FIB entries.
<Sysname> display spbm unicast-fib verbose
B-MAC B-VLAN Flags Driver flag Epoch Port
0011-2200-0101 1 T Done 0x1 XGE1/0/2
0011-2200-0101 2 T Done 0x1 XGE1/0/2
# Display detailed information about the unicast FIB entry for B-MAC 0011-2200-0101 in B-VLAN 1.
<Sysname> display spbm unicast-fib b-mac 0011-2200-0101 b-vlan 1 verbose
B-MAC : 0011-2200-0101 B-VLAN : 1
Port : XGE1/0/2
Flags : T Driver flag: Done
Epoch : 0x1
# Display the number of SPBM unicast FIB entries for B-VLAN 100.
<Sysname> display spbm unicast-fib b-vlan 100 count
Total entries: 2
Table 26 Command output
Port |
Flags |
Driver flag |
Epoch |
Entry aging counter. |
Context |
display spbm unicast-fib statistics
Use display spbm unicast-fib statistics to display SPBM unicast FIB statistics.
display spbm unicast-fib statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device. The slot-number argument represents its IRF member ID. If you do not specify an IRF member device, the command displays unicast FIB statistics for all IRF member devices.
# Display SPBM unicast FIB statistics.
<Sysname> display spbm unicast-fib statistics
SPBM unicast FIB basic statistics:
RefreshMsg : 1 DeleteMsg : 0
AddUMACNumber : 1 DeleteUMACNumber : 0
DrvDelRefresh : 0
SPBM unicast FIB error statistics:
UMACMsgError : 0 RefreshMsgFail : 0
DeleteMsgFail : 0 AddUMACFail : 0
Table 27 Command output
RefreshMsg |
Number of messages received for refreshing unicast FIB entries. |
DeleteMsg |
Number of messages received for deleting unicast FIB entries. |
AddUMACNumber |
Number of unicast B-MACs added to the unicast FIB. |
DeleteUMACNumber |
Number of unicast B-MACs deleted from the unicast FIB. |
DeleteNotFound |
Number of failures to find B-MACs to be deleted. |
AgeNumber |
Number of expired unicast entries. |
DrvAdd |
Number of unicast entries added to the driver. |
DrvDelete |
Number of unicast entries deleted from the driver. |
DrvDelRefresh |
Number of unicast entries deleted because of entry modification. |
UMACMsgError |
Number of unicast B-MAC error messages. |
RefreshMsgFail |
Number of failures to process messages for refreshing unicast B-MACs. |
DeleteMsgFail |
Number of failures to process unicast B-MAC delete messages. |
AddUMACFail |
Number of failures to add unicast B-MAC entries. |
DrvOtherFail |
Number of failures to notify the driver to add or update unicast B-MAC entries. |
DrvDeleteFail |
Number of failures to notify the driver to delete unicast B-MAC entries. |
DrvNoResource |
Number of failures to issue unicast B-MACs to the driver because of insufficient system resources. |
SynMsgFail |
Number of messages not synchronized. |
AllocEntryFail |
Number of memory allocation failures for adding unicast entries. |
AllocReDrvMsgFail |
Number of memory allocation failures for refreshing unicast entries. |
display spbm unicast-pw
Use display spbm unicast-pw to display unicast PWs on a BEB.
display spbm unicast-pw [ i-sid i-sid ] [ count ]
i-sid i-sid: Specifies an I-SID in the range of 255 to 16777215. If you do not specify an I-SID, the command displays unicast PW information for all I-SIDs.
count: Specifies the total number of unicast PWs. If you do not specify this keyword, the command displays unicast PW information.
# Display all unicast PWs.
<Sysname> display spbm unicast-pw
System ID I-SID B-MAC B-VLAN Port
000f.e201.0101 300 000f-e201-0101 100 XGE1/0/1
000f.e201.0102 300 000f-e201-0102 100 XGE1/0/2
# Display the total number of unicast PWs.
<Sysname> display spbm unicast-pw count
Total entries: 2
Table 28 Command output
System ID |
I-SID |
B-MAC |
Unicast B-MAC of the remote BEB. |
B-VLAN |
B-VLAN for tunneled frames. |
Port |
display spbm unicast-tree
Use display spbm unicast-tree to display SPBM unicast tree information.
# Display SPBM unicast tree information.
<Sysname> display spbm unicast-tree
SPF tree information for SPBM
Flags: S-Node is on SPF tree D-Node or Link is to be deleted
O-Node is overload I-Node is invalid
T-Node is on tent list P-Neighbor is parent node
C-Neighbor is child node L-Link is on changelist
V-Link is involved N-Link is a new path
SPF node: 0011.2200.0001
LinkCount: 0x1 NodeFlags: T S
SPF link: -->0011.2200.0101
Cost: 0xb NewCost: 0xb LinkFlags: P
SPF node: 0011.2200.0101
LinkCount: 0x1 NodeFlags: S
SPF link: -->0011.2200.0001
Cost: 0xa NewCost: 0xb LinkFlags: C
Table 29 Command output
Flags |
Node or link flags: · S—Node on the SPT. · D—Node or link is to be deleted. · O—Overload bit set its LSPs. · I—Invalid node. · T—Candidate node. · P—Parent node of the link on the SPT. · C—Child node on the link. · L—Flapping link. · V—Involved bit set for the link. · N—Newly added link. |
LinkCount |
Number of links on which the SPF node is the source. |
NodeFlags |
SPF node state flags. |
SPF link |
SPF link information. |
Cost |
Link metric value advertised by the source node. |
NewCost |
Link metric value negotiated by the source and destination nodes. |
LinkFlags |
Link state flags. |
ect
Use ect to map an ECT algorithm to a list of B-VLANs.
Use undo ect to remove ECT algorithm and B-VLAN mappings.
ect ect-index b-vlan vlan-id-list
undo ect ect-index b-vlan [ vlan-id-list ]
All B-VLANs are mapped to ECT 1.
SPBM view
vlan-id-list: Specifies a space-separated list of up to 10 B-VLAN items. Each item specifies a B-VLAN ID or a range of B-VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for B-VLAN IDs is 1 to 4094. The ID for vlan-id2 must be equal to or greater than the ID for vlan-id1.
An ECT algorithm represents a set of tie-breakers for calculating SPTs.
To improve link efficiency in an SPBM network, you can distribute traffic of B-VLANs along different paths by mapping B-VLANs to different ECT algorithms.
To ensure correct SPT calculation for a B-VLAN, the B-VLAN to ECT algorithm mappings must be the same across the SPBM network for B-VLANs that are in use. If two neighbors map a B-VLAN to different ECT algorithms, the link between them cannot transmit data traffic for the B-VLAN.
You cannot remove the mappings between ECT algorithm 1 and B-VLANs. The undo ect command does not take effect if you specify ECT algorithm 1 in the command.
# Map B-VLAN 100 through B-VLAN 200 to ECT 2.
[Sysname] spbm
[Sysname-spbm] ect 2 b-vlan 100 to 200
# Remove all B-VLAN mappings for ECT 2.
[Sysname] spbm
[Sysname-spbm] undo ect 2 b-vlan
flash-flood
Use flash-flood to enable fast flooding of LSPs.
Use undo flash-flood to restore the default.
flash-flood [ flood-count flooding-count | max-timer-interval interval ] *
undo flash-flood
Fast flooding of LSPs is disabled.
SPBM view
flood-count flooding-count: Specifies the maximum number of LSPs that can be rapidly flooded before SPF computation is started. The value range for the flooding-count argument is 1 to 15. The default value is 5.
max-timer-interval interval: Specifies the delay before fast flooding is performed. The value range for the interval argument is 10 to 50000 milliseconds. The default value is 10.
Fast flooding of LSPs enables ISIS-SPB to flood the specified number of LSPs that invoke SPF before SPF computation is started. This mechanism improves ISIS-SPB convergence time.
# Enable fast flooding of LSPs, specify the maximum number of fast flooded LSPs to 10, and set the flooding delay to 100 milliseconds.
[Sysname] spbm
[Sysname-spbm] flash-flood flood-count 10 max-timer-interval 100
graceful-restart
Use graceful-restart to enable Graceful Restart for SPBM.
Use undo graceful-restart to disable Graceful Restart for SPBM.
graceful-restart
GR is disabled for SPBM.
SPBM view
NSR and Graceful Restart are mutually exclusive. You cannot configure them at the same time.
# Enable Graceful Restart for SPBM.
[Sysname] spbm
[Sysname-spbm] graceful-restart
graceful-restart suppress-sa
Use graceful-restart suppress-sa to disable setting the SA bit in hello messages sent when the FDB is not usable during a restart.
Use undo graceful-restart suppress-sa to enable setting the SA bit during a restart.
The SA bit is set during a restart.
SPBM view
Setting the SA bit prevents the neighbor from advertising the ISIS-SPB adjacency with the GR restarter. This command prevents route blackholes by temporarily excluding the restarter from the SPF computation on other SPBM nodes.
If the SA bit is not set, the ISIS-SPB neighbors advertise the adjacency with the device while the device is restarting.
# Disable setting the SA bit during a GR process.
[Sysname] spbm
[Sysname-spbm] graceful-restart suppress-sa
graceful-restart t2
Use graceful-restart t2 to set the T2 timer for ISIS-SPB GR.
Use undo graceful-restart t2 to restore the default.
graceful-restart t2 t2-value
The T2 timer is 300 seconds.
SPBM view
t2-value: Specifies the T2 timer in the range of 30 to 1800 seconds.
The device advertises the T2 timer as the adjacency hold time to its neighbor during a GR process.
Before the timer expires, the neighbor maintains the adjacency with the device. If the device fails to complete the restart before this timer expires, the neighbor removes the adjacency.
# Set the T2 timer to 120 seconds for ISIS-SPB GR.
[Sysname] spbm
[Sysname-spbm] graceful-restart t2 120
is-name
Use is-name to enable dynamic hostname exchange and assign an ISIS-SPB hostname to the device.
Use undo is-name to restore the default.
is-name is-name
undo is-name
Dynamic hostname exchange is disabled. The device does not have a symbolic ISIS-SPB hostname.
SPBM view
is-name: Assigns a hostname to the device, a case-sensitive string of 1 to 64 characters.
ISIS-SPB uses a 6-byte system ID to represent a node in the network. This type of system ID is difficult for administrators to identify devices when they examine ISIS-SPB adjacencies, FDB entries, and LSDB entries.
Dynamic hostname exchange enables you to assign a symbolic hostname to each SPBM node. ISIS-SPB advertises this information in the Dynamic hostname TLV in LSPs to remote LSDBs.
# Enable dynamic hostname exchange and assign ISIS-SPB hostname spbm to the device.
[Sysname] spbm
[Sysname-spbm] is-name spbm
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
# Enable L2VPN.
[Sysname] l2vpn enable
log-peer-change
Use log-peer-change to enable ISIS-SPB adjacency change logging.
Use undo log-peer-change to disable ISIS-SPB adjacency change logging.
log-peer-change
ISIS-SPB adjacency change logging is enabled.
SPBM view
This command enables SPBM to output adjacency change events to the information center. You can configure the information center to output the event log records to a destination as needed. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Disable ISIS-SPB adjacency change logging.
[Sysname] spbm
[Sysname-spbm] undo log-peer-change
multicast replicate-mode
Use multicast replicate-mode to configure the multicast replication mode.
Use undo multicast replicate-mode to restore the default.
multicast replicate-mode { head-end | tandem }
Head-end replication is used.
SPB I-SID view
head-end: Enables head-end replication mode.
tandem: Enables tandem replication mode.
SPBM supports head-end replication and tandem replication for broadcast, unknown unicast, and multicast traffic.
· Head-end replication—Replicates frames at the ingress BEB for frames to enter the SPBM network. This method is suitable for SPBM VSIs that have sparse multicast traffic. It does not require BCBs to maintain multicast FDB entries.
· Tandem replication—Replicates frames only at the node where the shortest path tree forks. This method is suitable for SPBM VSIs that have dense multicast traffic. It requires BCBs to maintain multicast FDB entries.
# Enables tandem replication.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] spb i-sid 256
[Sysname-vsi-vpn1-256] multicast replicate-mode tandem
multicast-bvlan enable
Use multicast-bvlan enable to enable the multicast B-VLAN feature.
Use undo multicast-bvlan enable to disable the multicast B-VLAN feature.
The multicast B-VLAN feature is disabled.
SPBM view
CAUTION: Enabling or disabling the multicast B-VLAN feature can cause transient traffic loss. |
By default, the device uses one B-VLAN to transmit both unicast and multicast traffic. If tandem replication is used, you can enable the multicast VLAN feature for the device to use separate VLANs for unicast and multicast traffic.
If the multicast B-VLAN feature is enabled, you must assign an odd B-VLAN ID to an I-SID for SPBM to transmit unicast traffic. SPBM automatically chooses the next higher even B-VLAN ID (odd B-VLAN ID plus 1) for multicast traffic.
ISIS-SPB only advertises the odd B-VLAN IDs. It uses the odd B-VLAN IDs when populating the unicast FDB table with routes. When populating the multicast FDB table with routes, it uses the even B-VLAN IDs.
When you use the multicast B-VLAN feature, follow these restrictions and guidelines:
· Enable or disable the multicast B-VLAN feature on all nodes in the SPBM network.
· Map both odd B-VLAN ID and even B-VLAN ID to MSTI 4092, and assign all ports on the path of the two VLANs to the VLANs.
· Assign the odd B-VLAN ID for unicast traffic to the I-SID when you use the b-vlan command. The device will automatically assign the even B-VLAN ID to the I-SID for multicast traffic.
# Enable the multicast B-VLAN feature.
[Sysname] spbm
[Sysname-spbm] multicast-bvlan enable
non-stop-routing
Use non-stop-routing to enable NSR for SPBM.
Use undo non-stop-routing to disable NSR for SPBM.
non-stop-routing
NSR is disabled for SPBM.
SPBM view
# Enable NSR for SPBM.
[Sysname] spbm
[Sysname-spbm] non-stop-routing
reset spbm bvlan-info statistics
Use reset spbm bvlan-info statistics to clear B-VLAN statistics.
reset spbm bvlan-info statistics slot slot-number
# Clear B-VLAN statistics for slot 1.
<Sysname> reset spbm bvlan-info statistics slot 1
reset spbm database
Use reset spbm database to clear operating data from the SPBM databases, including the LSDB, FDBs, FIBs, and PW tables.
reset spbm database [ graceful-restart ]
graceful-restart: Enables SPBM database restoration through the Graceful Restart feature. If you do not specify this keyword, you must use other methods to restore SPBM data after the database is cleared.
# Clear SPBM database.
<Sysname> reset spbm database
display spbm lsdb
reset spbm graceful-restart event-log
Use reset spbm graceful-restart event-log to clear SPBM Graceful Restart logs.
reset spbm graceful-restart event-log slot slot-number
# Clear SPBM Graceful Restart logs for slot 1.
<Sysname> reset spbm graceful-restart event-log slot 1
reset spbm multicast-fib statistics
Use reset spbm multicast-fib statistics to clear SPBM multicast FIB statistics.
reset spbm multicast-fib statistics slot slot-number
# Clear SPBM multicast FIB statistics for slot 1.
<Sysname> reset spbm multicast-fib statistics slot 1
reset spbm non-stop-routing event-log
Use reset spbm non-stop-routing event-log to clear SPBM NSR logs.
reset spbm non-stop-routing event-log slot slot-number
# Clear SPBM NSR logs for slot 1.
<Sysname> reset spbm non-stop-routing event-log slot 1
reset spbm unicast-fib statistics
Use reset spbm unicast-fib statistics to clear SPBM unicast FIB statistics.
reset spbm unicast-fib statistics slot slot-number
# Clear SPBM unicast FIB statistics.
<Sysname> reset spbm unicast-fib statistics
# Clear SPBM unicast FIB statistics for slot 1.
<Sysname> reset spbm unicast-fib statistics slot 1
set-overload
Use set-overload to enable ISIS-SPB to set the LSDB overload bit in LSPs.
Use undo set-overload to restore the default.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 ] ]
undo set-overload
The LSDB overload bit is not set.
SPBM view
on-startup: Sets the overload bit when the system starts up.
start-from-nbr system-id [ timeout1 [ nbr-timeout ] ]: Sets the timers for controlling the overload bit state during the process of adjacency establishment. The nbr-timeout timer starts when the device starts up. If the device fails to establish an adjacency with the neighbor identified by system-id before the timer expires, the overload bit is cleared. If adjacency establishment is complete before the timer expires, the timeout1 timer starts. The overload bit is set before the timeout1 timer expires. When the timeout1 timer expires, the overload bit is cleared.
· system-id: Specifies a neighbor by its system ID in XXXX.XXXX.XXXX format.
· timeout1: Sets the delay to clear the overload bit, in the range of 5 to 86400 seconds. The default value is 600 seconds.
· nbr-timeout: Sets the adjacency setup timer in the range of 5 to 86400 seconds. The default value is 1200 seconds.
timeout2: Specifies the amount of time for the overload bit to be set since the system startup. The value range for this argument is 5 to 86400 seconds. The default is 600 seconds.
ISIS-SPB sets the overload bit in LSPs to notify its neighbors that it is experiencing an LSDB error condition and cannot forward traffic correctly. During path calculation, ISIS-SPB does not choose a path as the shortest path if the path includes the device that has the overload bit set.
You can set the LSDB overload bit when the device cannot record complete topology data in the LSDB for insufficient memory or any other problems.
If you do not specify any parameters, the command sets the overload bit immediately. To clear the overload bit, you must use the undo set-overload command.
# Set the LSDB overload bit.
[Sysname] spbm
[Sysname-spbm] set-overload
snmp context-name
Use snmp context-name to configure an SNMP context for ISIS-SPB.
Use undo snmp context-name to restore the default.
No SNMP context is configured for ISIS-SPB.
SPBM view
context-name: Specify a context name, a case-sensitive string of 1 to 32 characters.
ISIS-SPB shares the standard IS-IS MIB with IS-IS and other protocols that use IS-IS in the control plane. For SNMP to correctly identify a protocol's management information in the standard IS-IS MIB, you must configure a unique context for each of these protocols. If a protocol supports multiple processes, you must assign a unique context to each process.
The context names must be unique among all the protocols and their processes.
Context is a method introduced to SNMPv3 for multiple instance managements. For SNMPv1/v2c, you must specify a context name as a community name for protocol identification.
# Configure the SNMP context name as spbm for ISIS-SPB.
[Sysname] spbm
[Sysname-spbm] snmp context-name spbm
snmp-agent trap enable spbm
Use snmp-agent trap enable spbm to enable SNMP notifications for SPBM.
Use undo snmp-agent trap enable spbm to disable SNMP notifications for SPBM.
snmp-agent trap enable spbm [ adjacency-state-change | area-mismatch | authentication | authentication-type | b-mac-conflict | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | spsource-conflict | version-skew ] *
undo snmp-agent trap enable spbm [ adjacency-state-change | area-mismatch | authentication | authentication-type | b-mac-conflict | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | spsource-conflict | version-skew ] *
SNMP notifications for SPBM are enabled.
adjacency-state-change: Specifies notifications about SPBM adjacency status changes.
area-mismatch: Specifies notifications about area address mismatches between hello packets.
authentication: Specifies notifications about authentication failures.
authentication-type: Specifies notifications about invalid authentication types.
b-mac-conflict: Specifies the B-MAC conflict notification. This notification is generated when a remote B-MAC conflicts with a local B-MAC.
buffsize-mismatch: Specifies notifications about buffer size mismatches for LSPs.
id-length-mismatch: Specifies notifications about system ID length mismatches of SPBM packets.
lsdboverload-state-change: Specifies notifications about LSDB overload status changes.
lsp-parse-error: Specifies notifications about LSP parse failures.
lsp-size-exceeded: Specifies notifications about propagation failures caused by oversized LSPs.
max-seq-exceeded: Specifies notifications about attempts to exceed the maximum LSP sequence number.
maxarea-mismatch: Specifies notifications about maximum area address mismatches of hello packets.
own-lsp-purge: Specifies notifications about attempts to remove the local LSP.
protocol-support: Specifies notifications about supported-protocol mismatches.
rejected-adjacency: Specifies notifications about adjacency creation failures.
skip-sequence-number: Specifies notifications about LSP sequence number duplications.
spsource-conflict: Specifies the SPSource ID conflict notification. This notification is generated when a remote SPSource ID conflict with the local SPSource ID.
version-skew: Specifies notifications about hello packet version mismatches.
The command enables all SPBM notifications if you execute the command without any keywords.
For SPBM notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for SPBM.
[Sysname] undo snmp-agent trap enable spbm
spb i-sid
Use spb i-sid to create an SPB VSI and enter its view, or enter the view of an existing SPB VSI.
Use undo spb i-sid to restore the default.
spb i-sid i-sid
undo spb i-sid
No SPB VSIs exist.
VSI view
i-sid: Specifies an I-SID for the VSI, in the range of 255 to 16777215.
You must assign a unique I-SID to each SPB VSI for identification. The name of an SPB VSI can be different on different SPBM nodes, but its I-SID must be the same across an SPBM network. For more information about VSIs, see MPLS Configuration Guide.
You can configure one SPB I-SID and one PBB I-SID for a VSI, but the two I-SIDs cannot be the same. For more information about PBB, see Layer 2—LAN Switching Configuration Guide.
The I-SID for the fast-channel VSI is 255. The fast channel feature provides a quicker LSP propagation method than conventional LSP propagation. To use the fast-channel feature, you must create a VSI and assign I-SID 255 to the VSI. You cannot associate any Ethernet service instance with the VSI that uses I-SID 255 for data transmission.
# Assign SPB I-SID 256 to VSI vpn1 and enter SPB I-SID view.
[Sysname] vsi vpn1
spbm
Use spbm to enable SPBM globally and enter SPBM view.
Use undo spbm to disable SPBM globally.
spbm
undo spbm
SPBM is disabled globally.
You must enable SPBM both globally and on the provider network ports on all BEBs and BCBs in the SPBM network.
You must enable SPBM globally before you can configure any other SPBM settings.
When you disable SPBM, all SPBM-related settings are removed automatically.
# Enable SPBM globally and enter SPBM view.
[Sysname] spbm
[Sysname-spbm]
spbm enable
spbm authentication send-only
Use spbm authentication send-only to disable authentication for incoming ISIS-SPB hello packets on an interface.
Use undo spbm authentication send-only to restore the default.
ISIS-SPB authenticates incoming ISIS-SPB hello packets on an interface if adjacency authentication (spbm authentication-mode) is configured.
Before you change adjacency authentication settings on a link, configure this command to prevent temporary authentication setting mismatch from causing loss of adjacencies.
For security purposes, restore the default to authenticate incoming ISIS-SPB hello packets after you change adjacency authentication settings on the link.
This command does not affect outgoing ISIS-SPB hello packets. When adjacency authentication is enabled, outgoing ISIS-SPB hello packets always contain authentication information.
# Disable authentication for incoming ISIS-SPB hello packets on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] spbm authentication send-only
Use spbm authentication-mode to configure adjacency authentication on an interface.
Use undo spbm authentication-mode to restore the default.
spbm authentication-mode { md5 | simple } { cipher | plain } string
Adjacency authentication is disabled on an interface. No adjacency authentication method or password is configured.
md5: Specifies MD5 authentication.
simple: Specifies simple authentication.
plain: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password. The plaintext password is a case-sensitive string of 1 to 16 characters. The encrypted password is a case-sensitive string of 33 to 53 characters.
ISIS-SPB adjacency authentication guarantees that SPBM nodes establish adjacencies only with trustworthy neighbors.
For correct authentication, make sure the authentication method and password are the same between SPBM neighbors. ISIS-SPB sends these authentication settings in hello packets. The recipients accept a hello packet only if the authentication settings in the packet match their local authentication settings.
# Set the adjacency authentication method to simple and the password to 123456 in plain text on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] spbm authentication-mode simple plain 123456
spbm cost
Use spbm cost to set an interface-specific SPBM link metric value for an interface.
Use undo spbm cost to restore the default.
spbm cost cost-value
undo spbm cost
SPBM automatically calculates link metric values for interfaces.
cost-value: Specifies a link metric value in the range of 1 to 16777215. If the link metric is set to 16777215, the link will not be used for transmitting data traffic even if the adjacency can be established and the link is up.
To assign a link metric value to an interface, use one of the following methods:
· Set an interface-specific value in interface view.
· Set a global value in SPBM view. This global value applies to all SPBM-enabled interfaces.
· Set a bandwidth reference for the system to calculate a value automatically for the interface.
The system chooses a link metric value for an interface in order of interface-specific value, global value, and autocalculated value.
# Set the SPBM link metric to 5 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] spbm cost 5
spbm enable
Use spbm enable to enable SPBM on an interface.
Use undo spbm enable to disable SPBM on an interface.
spbm enable
undo spbm enable
SPBM is disabled on interfaces.
You must enable SPBM on the provider network ports on all BEBs and BCBs.
You can configure SPBM parameters on an interface only after the SPBM feature is enabled on the interface.
All SPBM-related settings are removed from the interface after you disable SPBM on the interface.
An SPBM-enabled interface can identify only MAC-in-MAC frames. Frames of other types are dropped by the interface.
# Enable SPBM on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] spbm enable
spbm timer hello
Use spbm timer hello to set the ISIS-SPB hello interval on an interface.
Use undo spbm timer hello to restore the default.
spbm timer hello seconds
The ISIS-SPB hello interval is 10 seconds.
seconds: Specifies an interval in the range of 3 to 255 seconds.
ISIS-SPB sends hellos over links to establish and maintain adjacencies between SPBM nodes.
A short interval improves network convergence time, but it requires more system resources.
The maximum adjacency hold time is 65535 seconds. If this value is exceeded, the original hello interval remains unchanged.
# Set the ISIS-SPB hello interval to 20 seconds on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] spbm timer hello 20
spbm timer holding-multiplier
Use spbm timer holding-multiplier to set the hello multiplier for calculating the ISIS-SPB adjacency hold time.
Use undo spbm timer holding-multiplier to restore the default.
spbm timer holding-multiplier value
The multiplier is 3 for calculating the SPBM IS-IS adjacency hold time.
value: Specifies a multiplier in the range of 3 to 1000.
Adjacency hold time specifies the amount of time for one SPBM node to retain the adjacency with another. This timer determines how quick it takes for an SPBM node to detect a failed link.
The adjacency hold time equals the hello interval multiplied by the hello multiplier.
An SPBM node sends its adjacency hold time in hello packets to update the adjacencies with its neighbor. The neighbor removes the adjacency with the advertising node and recalculates routes if it does not receive a hello packet before the timer expires.
The maximum adjacency hold time is 65535 seconds. If this value is exceeded, the original hello multiplier remains unchanged.
# Set the hello multiplier to 6 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] spbm timer holding-multiplier 6
spbm timer hello
spbm timer lsp
Use spbm timer lsp to set the minimum LSP transmit interval on an interface and specify the maximum number of LSPs sent at each interval.
Use undo spbm timer lsp to restore the default.
spbm timer lsp time [ count count ]
undo spbm timer lsp
The minimum LSP transmit interval is 33 milliseconds. A maximum of five LSPs can be sent at each interval.
time: Specifies the minimum LSP transmit interval in the range of 1 to 1000 milliseconds.
count: Specifies the maximum number of LSPs that can be sent at each interval. The value range is 1 to 1000.
To control ISIS-SPB traffic on a circuit, set the minimum interval for the device to transmit LSPs out of the circuit and the maximum number of LSPs sent at each interval.
As a best practice, set a large minimum LSP transmit interval to prevent LSP storms in a network that contains a large number of provider network ports or routes.
# Set the minimum LSP transmit interval to 500 milliseconds on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] spbm timer lsp 500
spsource
Use spsource to set an SPSource ID.
Use undo spsource to restore the default.
spsource spsource-id
undo spsource
ISIS-SPB generates an SPSource ID automatically.
SPBM view
spsource-id: Specifies an SPSource ID in the range of 1 to 1048575.
An SPSource ID identifies a node in an SPB VSI. The SPSource ID must be unique in the VSI.
# Set the SPSource ID to 100.
[Sysname] spbm
[Sysname-spbm] spsource 100
timer lsp-generation
Use timer lsp-generation to set the LSP generation timer parameters.
Use undo timer lsp-generation to restore the default.
timer lsp-generation maximum-interval [ minimum-interval [ incremental-interval ] ]
The maximum interval is 2 seconds.
The minimum interval is 10 milliseconds.
The base number for the incremental interval is 10 milliseconds.
SPBM view
maximum-interval: Specifies the maximum LSP generation interval in the range of 1 to 120 seconds.
minimum-interval: Specifies the minimum LSP generation interval in the range of 10 to 60000 milliseconds. This setting must be smaller than the maximum interval.
incremental-interval: Specifies the base number for the incremental interval. The value range is 10 to 60000 milliseconds. This setting must be smaller than the maximum interval.
The LSP generation timer sets the delay for ISIS-SPB to generate a new version of an LSP in response to an LSP change. For example, an update occurs because of a change in adjacency, interface metric value, system ID, or area address.
The LSP generation timer is an exponential generation timer. With this timer, ISIS-SPB quickly responds to the first events for an LSP and then slows down to protect the CPU from frequent LSP generation.
When the network is stable, the LSP generation timer is set to the minimum interval for each LSP generation. When the network is unstable, the LSP generation timer increments by incremental-interval×2n-2 (n is the number of generation times) for each LSP generation until the maximum interval is reached. If an event triggers LSP generation after the maximum interval is reached, the LSP generation timer re-initiates with the minimum interval.
The network is considered unstable if the interval between consecutive LSP generation events is smaller than two times the maximum interval.
# Set the maximum LSP generation interval, the minimum LSP generation interval, and the base number for the incremental interval to 10 seconds, 100 milliseconds, 200 milliseconds, respectively.
[Sysname] spbm
[Sysname-spbm] timer lsp-generation 10 100 200
timer lsp-max-age
Use timer lsp-max-age to specify the maximum lifetime of LSPs.
Use undo timer lsp-max-age to restore the default.
timer lsp-max-age seconds
The maximum LSP lifetime is 1200 seconds.
SPBM view
seconds: Specifies the maximum LSP lifetime in the range of 1 to 65535 seconds.
This command specifies the maximum amount of time for an LSP generated by the device to be retained in an LSDB.
SPBM nodes add a lifetime in each LSP they have advertised. If an SPBM node does not receive an update for an LSP before its lifetime expires, the SPBM node performs the following actions:
· Removes the LSP from the LSDB.
· Retains the LSP digest for 60 seconds.
· Floods an update of the LSP with a lifetime of 0. The SPBM neighbors remove the LSP from their LSDBs when they receive the LSP update.
To prevent unnecessary LSP age-outs, increase the LSP lifetime on a slow network.
# Set the maximum LSP lifetime to 1500 seconds.
[Sysname] spbm
[Sysname-spbm] timer lsp-max-age 1500
timer lsp-refresh
timer lsp-refresh
Use timer lsp-refresh to set the LSP refresh interval.
Use undo timer lsp-refresh to restore the default.
timer lsp-refresh seconds
The LSP refresh interval is 900 seconds.
SPBM view
seconds: Specifies the LSP refresh interval in the range of 1 to 65534 seconds.
To prevent LSPs from age-out and synchronize LSDBs, ISIS-SPB performs periodic LSP update. The LSP refresh interval sets the interval at which ISIS-SPB regularly regenerates an LSP, regardless of whether any change has occurred to the LSP.
A short refresh interval improves network convergence time, but it also uses more bandwidth resources and system resources.
To avoid unnecessary LSP age-outs, make sure the LSP refresh interval is shorter than the LSP lifetime.
# Set the LSP refresh interval to 1200 seconds.
[Sysname] spbm
[Sysname-spbm] timer lsp-refresh 1200
timer lsp-max-age
timer spf
Use timer spf to set the SPF computation timer parameters.
Use undo timer spf to restore the default.
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ]
undo timer spf
The maximum interval is 5 seconds.
SPBM view
maximum-interval: Specifies the maximum SPF computation interval in the range of 1 to 120 seconds.
minimum-interval: Specifies the minimum SPF computation interval in the range of 10 to 60000 milliseconds. This setting must be smaller than the maximum interval.
incremental-interval: Specifies the base number for the incremental interval, in the range of 10 to 60000 milliseconds. This setting must be smaller than the maximum interval.
The SPF calculation timer sets the delay between consecutive SPF calculations. You can increase the timer for ISIS-SPB to react quickly to topology changes, and decrease the timer to protect the CPU from frequent SPF calculations.
The SPF timer is an exponential generation timer. With this timer, ISIS-SPB quickly responds to the first events that trigger SPF calculation and then slows down to protect the CPU from frequent SPF calculations.
When the network is stable, the SPF calculation timer is set to the minimum interval for each SPF computation. When the network is unstable, the SPF calculation timer increments by incremental-interval×2n-2 (n is the number of calculations) for each SPF calculation until the maximum interval is reached. If an event triggers SPF calculation after the maximum interval is reached, the SPF calculation timer re-initiates with the minimum interval.
The network is considered unstable if the interval between consecutive SPF calculations is smaller than two times the maximum interval.
# Set the maximum SPF computation interval, the minimum SPF computation interval, and the base number for the incremental interval to 10 seconds, 100 milliseconds, and 300 milliseconds, respectively.
[Sysname] spbm
[Sysname-spbm] timer spf 10 100 300
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
# Create VSI test and enter VSI view.
[Sysname] vsi test
[Sysname-vsi-test]
display l2vpn vsi
