- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Emergency shell configuration
- 10-Device management configuration
- 11-Tcl configuration
- 12-Python configuration
- 13-License management
- 14-Preprovisioning feature configuration
- 15-Automatic configuration
14-Preprovisioning feature configuration | 43.95 KB |
Configuring preprovisioning
Preprovisioning allows you to preconfigure offline modules, including IRF member devices.
You can preprovision a module before installing or attaching the module to the system. The preprovisioned settings are applied when the module comes online. If the module goes offline, the existing preprovisioned settings are retained. You can continue to change the existing settings or add new settings. The final settings are applied when the module comes online again.
You can also preprovision an online module. The model specified for the slot must be the same as the model of the slot.
Enabling preprovisioning
The device automatically creates interfaces when preprovisioning is enabled for a module. The display interface command does not display these interfaces until the module comes online.
After preprovisioning is enabled for a module, you can configure the module. To verify the preprovisioned settings, see "Displaying and maintaining preprovisioned settings."
For the preprovisioned settings to survive a reboot, you must use the save command to save the settings to the next-startup configuration file.
When you disable preprovisioning on a slot, the device removes all commands preprovisioned for the slot.
To enable preprovisioning:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Select the slot to preprovision and enter slot view. |
slot slot-number |
N/A |
3. Enable preprovisioning on the slot for a member device. |
provision model model |
By default, preprovisioning is disabled. The specified model must match the model of the module you want to preprovision. If not, the module cannot come online. |
Task |
Command |
Remarks |
Display preprovisioned-commands application failure records. |
display provision failed-config |
A preprovisioned command cannot be applied if it conflicts with the running configuration. Use this command to verify the application result of preprovisioned commands except for the following commands: · duplex · speed · sflow To verify the application result of the listed commands, use the display current-configuration command. The display provision failed-config command might display incorrect application results for the listed commands. |
Clear preprovisioned-commands application failure records. |
reset provision failed-config |
N/A |
