HomeSupportSwitchesS6800 SeriesConfigure & DeployConfiguration GuidesH3C S6800 Switch Series Configuration Guide-Release 26xx-6W10701-Fundamentals Configuration Guide
08-ISSU configuration
08-ISSU configuration 222.25 KB
Performing an ISSU
Unless otherwise stated, the term "upgrade" refers to both software upgrade and downgrade in ISSU.
Overview
The In-Service Software Upgrade (ISSU) feature upgrades the Comware software with a minimum amount of downtime.
ISSU is implemented on the basis of the following design advantages:
·     Separation of service features from basic functions—Device software is segmented into boot, system, and feature images. The images can be upgraded individually.
·     Independence between service features—Features run independently. One feature can be added or upgraded without affecting the operation of the system or other features.
·     Support for hotfix—Patch images are available to fix system bugs without a system reboot.
·     Hardware redundancy—On a multichassis IRF fabric, one member device can be upgraded while other member devices are providing services.
For more information about images, see "Upgrading software."
ISSU methods
ISSU methods are automatically determined depending on the compatibility between software versions.
ISSU supports the following upgrade types:
·     Compatible upgrade—The running software version is compatible with the new software version. This upgrade type supports the ISSU methods in Table 1.
·     Incompatible upgrade—The running software version is incompatible with the new software version. The two versions cannot run concurrently.
This upgrade type supports only one upgrade method (also called incompatible upgrade). This method requires a cold reboot to upgrade both control and data planes. Incompatible upgrade disrupts service if hardware redundancy is not available.
For information about identifying the ISSU method, see "Identifying the ISSU method."
Table 1 ISSU methods for compatible upgrade
ISSU method
Incremental upgrade:
·     Service Upgrade
·     File Upgrade
Upgrades only user mode processes that have differences between the new and old software versions. Backup processes and a main/backup process switchover are required for service continuity.
·     Service upgrade—Upgrades service features. The upgrade does not affect the operation of the features that are not being upgraded.
·     File upgrade—Upgrades hidden system program files. The system can provide services during the upgrade.
Reboot
CAUTION CAUTION:
The Reboot method disrupts service on a single-member IRF fabric. As a best practice, schedule the downtime carefully to minimize the upgrade impact on the services.
The Reboot method reboots member devices to complete the software upgrade. While one member device is rebooting, the other member devices can provide services.
ISSU commands
ISSU includes the install and issu command sets. After you identify the recommended ISSU method, use Table 2 to choose the command set you want to use.
Table 2 Command set comparison
Item
issu commands
install commands
Upgrade types
·     Compatible.
·     Incompatible.
Compatible.
Patch install/uninstall
Not supported.
Supported.
Impact on the system
Large.
Small.
Technical skill requirements
Low.
As a best practice, use this command set.
High.
Administrators must have extensive system knowledge and understand the impact of each upgrade task on the network.
One-step ISSU
Supported.
Not supported.
Restrictions and guidelines: ISSU
In an IRF deployment, use the irf link-delay to set the IRF link down report delay to 0. For more information about this command, see IRF commands in Virtual Technologies Command Reference.
If the CPLD is also upgraded, it will take a long time to complete the upgrade. For the device to start up successfully, do not power off the device during the upgrade process.
Preparing for ISSU
To perform a successful ISSU, make sure all the preparation requirements are met.
Identifying availability of ISSU and licensing requirements
Read the software release notes to identify the following items:
·     Support of the device for ISSU between the current software version and the new software version.
·     Licensing requirements for the upgrade software images.
If the upgrade software images require licenses, make sure the device has the required licenses before ISSU. For more information about license installation, see "Managing licenses."
Verifying the device operating status
Use the display device command to verify that no member devices are in Fault state.
Preparing the upgrade images
1.     Use the dir command to verify that sufficient storage space is available for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete /unreserved file-url command. If the files to be deleted will be used, back up the files before deleting them. You will be unable to restore a deleted file if the /unreserved keyword is used. For more information, see "Managing file systems."
Make sure all members have sufficient storage space for the upgrade images.
2.     Use FTP or TFTP to transfer upgrade image files (in .bin or .ipe) to the root directory of a file system on the master device.
Execute the display version comp-matrix file command to identify the recommended ISSU methods.
·     If a compatible upgrade is required, check the Upgrade Way field to identify the recommended ISSU method. For more information about ISSU methods, see Table 1.
·     If an incompatible upgrade is required, check the end of command output for the Incompatible upgrade string.
Verifying the device configuration
For a successful ISSU reboot or incompatible upgrade and the IRF fabric integrity during the ISSU, a set of features must have the same configuration as expected after the upgrade. The following are the features and the commands for you to change and verify feature settings:
·     System operating mode.
system-working-mode
display system-working-mode
·     Hardware resource operating mode.
hardware-resource switch-mode
display hardware-resource switch-mode
·     Maximum number of ECMP routes.
max-ecmp-num
display max-ecmp-num
·     IPv4 enhanced ECMP mode.
ecmp mode enhanced
display ecmp mode
·     Support for IPv6 routes with prefixes longer than 64 bits.
hardware-resource routing-mode ipv6-128
display hardware-resource routing-mode
·     Packet loss prevention for OpenFlow forwarding.
openflow lossless enable
display current-configuration
·     VXLAN hardware resource mode.
hardware-resource vxlan
display hardware-resource vxlan
VXLAN hardware resource mode is not supported on devices labeled with product code LS-6800-32Q, LS-6800-2C, LS-6800-4C, LS-6800-54QF, or LS-6800-54QT.
For more information about system operating mode and hardware resource operating mode, see device management in Fundamentals Configuration Guide.
For more information about ECMP routes, IPv6 routes with prefixes longer than 64 bits, and IPv4 enhanced ECMP mode, see basic IP routing configuration in Layer 3IP Routing Configuration Guide.
For more information about packet loss prevention for OpenFlow forwarding, see OpenFlow Configuration Guide.
For more information about VXLAN hardware resource mode, see VXLAN Configuration Guide.
Verifying feature status
For service continuity during ISSU, configure the following feature settings:
Feature
Setting requirements
GR/NSR
Enable GR or NSR for protocols including LDP, RSVP, OSPF, ISIS, BGP, and FSPF.
BFD
Disable BFD for protocols including LDP, RSVP, OSPF, ISIS, RIP, BGP, VRRP, and NQA.
Ethernet link aggregation
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups.
IRF
Configure IRF bridge MAC persistence as follows:
·     Compatible upgrade—Configure the irf mac-address persistent timer or irf mac-address persistent always command.
·     Incompatible upgrade—Configure the irf mac-address persistent always command if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command.
Disable IRF MAD before performing an incompatible upgrade for an IRF fabric. To use IRF MAD, configure IRF MAD again after finishing the upgrade.
Determining the upgrade procedure
1.     Use Table 2 to choose an upgrade command set, depending on the ISSU method.
2.     Identify the hardware redundancy condition.
ISSU can maintain service continuity only when the IRF fabric has multiple members and uses the ring topology.
IMPORTANT
IMPORTANT:
If hardware redundancy is not available, service discontinuity is not avoidable. Make sure you understand the impact of the upgrade on the network.
3.     Perform one of the following tasks:
¡     Choose one-step ISSU to start and finish an ISSU by using a single command, as described in "Performing an ISSU in one step."
¡     Choose the correct procedure for a step-by step ISSU from the procedures described in the following sections:
-     Performing an ISSU by using issu commands step by step
-     Performing an ISSU by using install commands.
A step-by-step ISSU allows you to monitor the image status during the upgrade and roll back the upgrade.
Understanding ISSU guidelines
During an ISSU, use the following guidelines:
·     In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
·     Do not perform any of the following tasks during an ISSU:
¡     Reboot, add, or remove member devices.
¡     Execute commands that are irrelevant to the ISSU.
¡     Modify, delete, or rename image files.
·     You cannot use both install and issu commands for an ISSU. However, you can use display issu commands with both command sets. For more information, see "Displaying and maintaining ISSU."
·     To reduce service outage, strictly follow the steps for the selected procedure unless you are performing an ISSU in one step.
·     Before executing the following commands, use the display system stable state command to verify that the system is stable:
¡     issu commandsissu load, issu run switchover, issu commit, and issu one-step.
¡     install commandsinstall activate and install deactivate.
If the System State field displays Stable, the system is stable.
·     You may use issu commands to upgrade all or some of the software images. If you are upgrading only some of the images, make sure the new images are compatible with the images that are not to be upgraded. The upgrade will fail if a conflict exists.
After an ISSU, you must log in to the device again before you can configure the device.
Adjusting and saving the running configuration
1.     Remove all commands that the new software version does not support from the running configuration. To identify all feature changes between the current version and the new version, read the release notes for the device.
2.     To uninstall a feature image, remove the commands configured for the feature.
3.     Use the save command to save the running configuration.
Logging in to the device through the console port
Log in to the device through the console port after you finish all the preparation tasks and read all the ISSU guidelines. If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
Use this feature to perform an ISSU in one step. During the operation, you cannot perform a rollback or any other tasks.
If the IRF fabric has multiple member devices, follow these guidelines:
·     For a compatible upgrade, specify one subordinate member for the command. The member device will become the master device after the ISSU.
·     For an incompatible upgrade, specify one or more subordinate members for the command. If you specify one subordinate member, the member will become the master device after the ISSU. If you specify multiple subordinate members, the system automatically selects one of the subordinate members as the master device after the ISSU. As a best practice on a ring-topology IRF fabric, specify half of the subordinate members that are physically adjacent for the command.
·     Both the current version and the new version must support one-step ISSU.
To perform an ISSU in one step, execute one of the following commands in user view:
Perform an ISSU in one step.
·     issu one-step file { boot filename | system filename | feature filename&<1-30> } * [ slot slot-number&<1-9> ] [ reboot ]
·     issu one-step file ipe ipe-filename slot slot-number&<1-9> [ reboot ]
ISSU task list
Choose an ISSU procedure depending on the hardware redundancy status and ISSU method.
Tasks at a glance
Upgrading a multichassis IRF fabric:
·     Performing a compatible upgrade
·     Performing an incompatible upgrade
Upgrading a single-chassis IRF fabric:
·     Performing a service upgrade or file upgrade
·     Performing a reboot or incompatible upgrade
For a compatible upgrade on a multichassis IRF fabric, upgrade a subordinate member first. Then, upgrade the master and the other subordinate members.
To perform a compatible upgrade:
Step
Remarks
N/A
2.     (Optional.) Set the automatic rollback timer.
issu rollback-timer minutes
By default, the automatic rollback timer is set to 45 minutes.
This timer starts when you execute the issu run switchover command. If you do not execute the issu accept or issu commit command before this timer expires, the system automatically rolls back to the original software images.
3.     Return to user view.
N/A
4.     Verify that the system is stable.
The system is stable if the System State field displays Stable.
For a successful ISSU, you must make sure the system is stable before you proceed to the next step.
5.     Load the upgrade images as startup images on subordinate members.
·     Use .bin files:
issu load file { boot filename | system filename | feature filename&<1-30> } * slot slot-number [ reboot ]
·     Use an .ipe file:
issu load file ipe ipe-filename slot slot-number&<1-9> [ reboot ]
Specify the member ID of a subordinate member for the slot-number argument.
6.     Verify that the system is stable.
7.     Perform an ISSU switchover.
issu run switchover
N/A
8.     (Optional.) Accept the upgrade and delete the automatic rollback timer.
issu accept
N/A
9.     Verify that the system is stable.
10.     Upgrade the remaining members to complete the ISSU.
issu commit slot slot-number
Repeat step 10 and this step to upgrade the remaining members one by one, including the original master.
IMPORTANT IMPORTANT:
After executing the command for one member, you must wait for the member to restart and join the IRF fabric before you execute the command for another member.
To manually roll back to the original software images during this ISSU process, use the issu rollback command.
For more information about rollback, see Fundamentals Command Reference.
11.     Verify that the ISSU is finished.
display issu state
If the ISSU state field displays Init, the ISSU is finished.
For an incompatible upgrade on a multichassis IRF fabric, upgrade one or more subordinate members first. As a best practice, upgrade half of the subordinate members first. Then, upgrade the master and the other subordinate members.
Perform this task in user view.
Step
Remarks
1.     Verify that the system is stable.
2.     Load the upgrade images as startup images on subordinate members.
·     Use .bin files:
issu load file { boot filename | system filename | feature filename&<1-30> } * slot slot-number&<1-9> [ reboot ]
·     Use an .ipe file:
Because incompatible versions cannot run simultaneously, the upgraded subordinate devices will be isolated and cannot forward traffic until a master/subordinate switchover occurs.
As a best practice on a ring-topology IRF fabric, specify half of the subordinate members for this command to reduce service outage. Make sure the specified subordinate members are physically connected.
3.     Verify that the system is stable.
4.     Perform an ISSU switchover to complete the ISSU process.
issu run switchover
The issu run switchover command upgrades the remaining members.
To roll back to the original software images during this ISSU process, use the issu rollback command.
This ISSU process does not support automatic rollback.
5.     Verify that the ISSU is finished.
display issu state
Step
Remarks
2.     Load the upgrade images as startup images.
·     Use .bin files:
·     Use an .ipe file:
issu load file ipe ipe-filename slot slot-number [ reboot ]
Specify the member ID of the device for the slot slot-number option.
4.     Complete the ISSU process.
display issu state
Step
Remarks
N/A
2.     Return to user view.
N/A
4.     Load the upgrade images as startup images on subordinate members.
·     Use .bin files:
·     Use an .ipe file:
display issu state
ISSU task list
Tasks at a glance
Remarks
(Optional.) Decompressing an .ipe file
To use install commands for upgrade, you must use .bin image files. If the upgrade file is an .ipe file, perform this task before you use install commands for upgrade.
(Required.) Perform one of the following tasks to update software:
·     Installing or upgrading software images
¡     Installing or upgrading boot, system, and feature images
¡     Installing patch images
·     Uninstalling feature or patch images
¡     Uninstalling feature images
¡     Uninstalling patch images
Perform an activate operation to install new images or upgrade existing images.
Perform a deactivate operation to uninstall feature or patch images.
An image is added to or removed from the current software image list when it is activated or deactivated.
(Optional.) Rolling back the running software images
Perform this task to roll back running software image status after activate or deactivate operations.
A commit operation deletes all rollback points. You can perform this task only before software changes are committed.
(Optional.) Aborting a software activate/deactivate operation
You can perform this task while an image is being activated or deactivated.
This task is available only for service upgrade or file upgrade.
(Optional.) Committing software changes
This task updates the main startup image list with the changes.
If service upgrade or file upgrade is performed, you must perform this task for the changes to take effect after a reboot.
(Optional.) Verifying software images
Perform this task to verify that the software changes are correct.
(Optional.) Deleting inactive software images
Perform this task to delete images
Step
1.     (Optional.) Identify images that are included in the .ipe file.
display install ipe-info
2.     Decompress the .ipe file.
install add ipe-filename filesystem
Use one of the following methods to perform this task:
·     Slot by slot—Activate all the images on one slot, and then move to the next slot.
·     Image by image—Activate one type of images (for example, the boot image) on all slots before activating another type of images (for example, the system image).
When you install an image, you must begin with the master device. When you upgrade an image, you must begin with a subordinate device.
You can install up to 32 .bin files on the device, including one boot image file, one system image file, and up to 30 feature or patch image files.
Step
Remarks
2.     (Optional.) Identify the recommended ISSU method and the possible impact of the upgrade.
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number test
N/A
3.     Activate images.
N/A
Before installing patch images, check whether the device is already running patch images.
·     If not, install patch images.
·     If yes, read the release notes to identify the functionality differences between the running patch images and the new patch images.
¡     If the new patch images cover all functions provided by the old patch images, loading the patch images overwrites the old patch images. After installing the new patch images, delete the old patch images from the storage medium to release the storage space.
¡     If the new patch images do not cover one or more functions provided by the old patch images, loading the patch images does not affect the old patch images. The device uses both the new patch images and the old patch images.
Step
Remarks
For a successful installation, you must make sure the system is stable before you proceed to the next step.
2.     Activate patch images.
install activate patch filename { all | slot slot-number }
N/A
You can uninstall only feature and patch images.
The uninstall operation only removes images from the current software image list. For the change to take effect after a reboot, you must perform a commit operation to remove the images from the main startup image list.
Uninstalled images are still stored on the storage medium. To permanently delete the images, execute the install remove command. For more information, see "Deleting inactive software images."
Step
Remarks
For a successful uninstallation, you must make sure the system is stable before you proceed to the next step.
2.     Deactivate feature images.
install deactivate feature filename&<1-30> slot slot-number
N/A
Step
Remarks
2.     Deactivate patch images.
install deactivate patch filename { all | slot slot-number }
N/A
For each service or file upgrade performed through activate or deactivate operation, the system creates a rollback point. The rollback points are retained until any of the following events occur:
·     A reboot upgrade is performed.
·     The install commit command is executed.
After a reboot upgrade is performed, you can roll back the running software images only to the status before any activate or deactivate operations are performed.
After a commit operation is performed, you cannot perform a rollback.
For a rollback to take effect after a reboot, you must perform a commit operation to update the main startup software image list.
To roll back the software, execute the following commands in user view:
Step
Remarks
1.     (Optional.) Display available rollback points.
display install rollback
A maximum of 50 rollback points are available for service and file upgrades. The earliest rollback point is removed if this limit has been reached when a rollback point is created.
2.     Roll back the software.
install rollback to { point-id | original }
N/A
This task is available only for service upgrade or file upgrade performed through activate or deactivate operation. After the operation is aborted, the system runs with the software images that it was running with before the operation.
Abort a software activate/deactivate operation.
·     Method 1: Press Ctrl+C while a software image is being activated or deactivated.
·     Method 2: Abort a software activate/deactivate operation in user view.
install abort [ job-id ]
When you activate or deactivate images for an incremental upgrade, or install or uninstall patches, the main startup image list does not update with the changes. The software changes are lost at reboot. For the changes to take effect after a reboot, you must commit the changes.
Remarks
Commit the software changes.
install commit
This command commits all software changes.
Perform this task to verify the following items:
·     Integrity—Verify that the boot, system, and feature images are integral.
·     Consistency—Verify that the same active images are running across the entire system.
·     Software commit status—Verify that the active images are committed as needed.
If an image is not integral, consistent, or committed, use the install activate, install deactivate, and install commit commands as appropriate to resolve the issue.
Verify software images.
install verify
This task delete image files permanently. You cannot use the install rollback to command to revert the operation, or use the install abort command to abort the operation.
Delete an inactive software image file.
install remove [ slot slot-number ] { filename | inactive }
Unless otherwise stated, the display and reset commands can be used during an ISSU, regardless of whether the install or issu commands are used.
Remarks
Display active software images.
display install active [ slot slot-number ] [ verbose ]
N/A
Display backup startup software images.
display install backup [ slot slot-number ] [ verbose ]
N/A
Display main startup software images.
display install committed [ slot slot-number ] [ verbose ]
N/A
Display inactive software images.
display install inactive [ slot slot-number ] [ verbose ]
N/A
Display the software images included in an .ipe file.
display install ipe-info ipe-filename
N/A
Display ongoing ISSU activate, deactivate, and rollback operations.
display install job
N/A
Display ISSU log entries.
display install log [ log-id ] [ verbose ]
N/A
Display software image file information.
display install package { filename | all } [ verbose ]
N/A
Display rollback point information.
display install rollback [ point-id ]
The system does not record rollback points during an ISSU that uses issu commands.
Display the software image file that includes a specific component or file.
display install which { component name | file filename } [ slot slot-number ]
N/A
Display automatic rollback timer information.
display issu rollback-timer
N/A
Display ISSU status information.
display issu state
This command applies only to an ISSU that uses issu commands.
Display the recommended ISSU methods.
display version comp-matrix file { boot filename | system filename | feature filename&<1-30> } *
display version comp-matrix file ipe ipe-filename
N/A
Clear ISSU log entries.
reset install log-history oldest log-number
N/A
Clear ISSU rollback points.
reset install rollback oldest point-id
N/A
Examples of using issu commands for ISSU
Feature upgrade to a compatible version
Upgrade requirements
As shown in Figure 1, the IRF fabric has two members.
Upgrade the Feature1 feature from T0001015 to T0001016. The two versions are compatible.
Figure 1 Network diagram
Upgrade procedure
# Download the image file that contains the T0001016 Feature1 feature from the TFTP server.
<Sysname> tftp 2.2.2.2 get feature1-t0001016.bin
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   256  100  256     0     0    764      0 --:--:-- --:--:-- --:--:--   810
Writing file...Done.
# Display active software images.
<Sysname> display install active
Active packages on slot 1:
  flash:/boot-t0001015.bin
  flash:/system-t0001015.bin
  flash:/feature1-t0001015.bin
Active packages on slot 2:
# Identify the recommended ISSU methods and possible impact of the upgrade.
<Sysname> display version comp-matrix file feature flash:/feature1-t0001016.bin
Verifying the file flash:/feature1-t0001016.bin on slot 1...Done.
  Slot                        Upgrade Way
  1                           Reboot
  2                           Reboot
Influenced service according to following table on slot 1:
         Feature1
Influenced service according to following table on slot 2:
         Feature1
The output shows that a reboot upgrade is recommended and the Feature1 module will be rebooted during the upgrade.
# Upgrade the feature on the subordinate member.
·     Method 1: Use the recommended method.
<Sysname> issu load file feature flash:/feature1-t0001016.bin slot 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Copying file flash:/feature1-t0001016.bin to slot2#flash:/feature1-t0001016.bin......Done.
Verifying the file flash:/feature1-t0001016.bin on slot 2...Done.
Identifying the upgrade methods...Done.
  Running Version             New Version
  Test 0001015                Test 0001016
  Slot                        Upgrade Way
  2                           Reboot
Upgrading software images to compatible versions. Continue? [Y/N]: y
This operation might take several minutes, please wait...Done.
·     Method 2: Use the reboot method.
<Sysname> issu load file feature flash:/feature1-t0001016.bin slot 2 reboot
  Slot                        Upgrade Way
  2                           Reboot
# Perform a main/backup feature process switchover.
<Sysname> issu run switchover
  Slot                        Switchover Way
  1                           Active standby process switchover
# Upgrade the feature on the original master.
·     If the upgrade used the recommended method:
<Sysname> issu commit slot 1
  Slot                        Upgrade Way
  1                           Reboot
·     If the upgrade used the reboot method:
  Slot                        Upgrade Way
  1                           Reboot
# Verify that both members are running the new feature image.
Feature upgrade to an incompatible version
As shown in Figure 2, the IRF fabric has two members.
Upgrade the Feature1 feature from T0001015 to T0001016. The two versions are incompatible.
Figure 2 Network diagram
Upgrade procedure
Incompatible upgrade.
The output shows that the two versions are incompatible. The member devices will be rebooted for the upgrade.
  Slot                        Upgrade Way
  2                           Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]: y
  Slot                        Upgrade Way
  1                           Reboot
Feature rollback example
Rollback requirement
As shown in Figure 3, the IRF fabric has two members.
Roll back the Feature1 feature from T0001016 to T0001015 after upgrading it from T0001015 to T0001016. The two versions are compatible.
Figure 3 Network diagram
Rollback procedure
  Slot                        Upgrade Way
  1                           Reboot
  2                           Reboot
         Feature1
         Feature1
The output shows that a reboot upgrade is recommended.
  Slot                        Upgrade Way
  2                           Reboot
  Slot                        Switchover Way
# Roll back the feature to T0001015.
<Sysname> issu rollback
This command will quit the ISSU process and roll back to the previous version. Continue? [Y/N]:Y
# Verify that both members are running the old feature image.
Examples of using install commands for ISSU
Feature upgrade example
As shown in Figure 4, the IRF fabric has two members.
Figure 4 Network diagram
Upgrade procedure
# Download the .ipe file that contains the T0001016 Feature1 feature image from the TFTP server.
<Sysname> tftp 2.2.2.2 get feature1-t0001016.ipe
# Decompress the .ipe file.
<Sysname> install add flash:/feature1-t0001016.ipe flash:
Verifying the file flash:/feature1-t0001016.ipe on slot 1...Done.
Decompressing file feature1-t0001016.bin to flash:/feature1-t0001016.bin.......................Done.
# Identify the recommended ISSU methods, and possible impact of the upgrade.
<Sysname> install activate feature flash:/feature1-t0001016.bin slot 2 test
  Slot                        Upgrade Way
  2                           Reboot
         Feature1
<Sysname> install activate feature flash:/feature1-t0001016.bin slot 1 test
  Slot                        Upgrade Way
  1                           Reboot
         Feature1
The output shows that a reboot upgrade is recommended for both members, and the Feature1 module will be rebooted during the upgrade.
# Activate the new feature image to upgrade the feature.
flash:/feature1-t0001016.bin already exists on slot 2.
Overwrite it?[Y/N]:y
  Slot                        Upgrade Way
  2                           Reboot
  Slot                        Upgrade Way
  1                           Reboot
# Commit the software changes.
<Sysname> install commit
This operation will take several minutes, please wait...........................Done.
As shown in Figure 4, the IRF fabric has two members. The Feature1 feature has been upgraded from T0001015 to T0001016. However, the software change has not been committed.
Roll back the Feature1 feature from T0001016 to T0001015.
Rollback procedure
# Display available rollback points.
<Sysname> display install rollback
  Install rollback information 1 on slot 1:
    Updating from flash:/feature1-t0001015.bin
  Install rollback information 2 on slot 2:
<Sysname> install rollback to original
# Verify that the IRF members are running the old feature image.
  • Become a Partner
  • Partner Resources
