Title | Size | Downloads |
H3C LSWM124XG2QFC Interface Card User Manual-6PW105-Text.pdf | 501.92 KB |
01-Text | 501.92 KB |
About the LSWM124XG2QFC interface card
Installing and removing an interface card
Installing and removing SFP, SFP+, and QSFP+ transceiver modules and SFP+ and QSFP+ cables
Important information
The LSWM124XG2QFC interface card is applicable to multiple H3C switch models. For the interface card compatibility with switches, contact H3C Support or marketing staff.
Front panel
The LSWM124XG2QFC interface card provides 24 SFP+ ports and two QSFP+ ports.
Figure 1 Front panel
(1) SFP+ port LED |
(2) QSFP+ port LED |
(3) QSFP+ port |
(4) SFP+ port |
Ports
· As a best practice, use H3C transceiver modules and cables for the interface cards.
· The transceiver module and cable types supported by the LSWM124XG2QFC interface card vary by device model. For more information, see the installation guide or hardware reference for the device, or contact H3C Support or marketing staff.
· The restrictions and guidelines for using the LSWM124XG2QFC interface card vary by device model. For more information, see the installation guide or hardware reference for the device.
· For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide at www.h3c.com.
SFP+ ports
You can install the following transceiver modules and cables in the SFP+ ports on an LSWM124XG2QFC interface card.
· SFP transceiver module in Table 1 and Table 2.
· SFP+ transceiver modules in Table 3 and Table 4.
· SFP+ DAC cables in Table 5.
· SFP+ fiber cables in Table 6.
Table 1 SFP transceiver modules available for the SFP+ ports (1)
SFP transceiver module |
Central wavelength (nm) |
Connector |
SFP-GE-T |
N/A |
RJ-45 |
SFP-GE-SX-MM850-A |
850 |
LC |
SFP-GE-LX-SM1310-A |
1310 |
LC |
SFP-GE-LH40-SM1310 |
1310 |
LC |
SFP-GE-LH40-SM1550 |
1550 |
LC |
SFP-GE-LH70-SM1550 |
1550 |
LC |
Table 2 SFP transceiver modules available for the SFP+ ports (2)
Cable/fiber diameter (µm) |
Modal bandwidth (MHz × km) |
Max transmission distance |
SFP-GE-T |
Twisted pair |
N/A |
100 m (328.08 ft) |
SFP-GE-SX-MM850-A |
Multi-mode, 50/125 |
500 |
550 m (1804.46 ft) |
400 |
500 m (1640.42 ft) |
Multi-mode, 62.5/125 |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
Single-mode, 9/125 |
N/A |
10 km (6.21 miles) |
500 or 400 |
500 |
N/A |
40 km (24.86 miles) |
N/A |
N/A |
70 km (43.50 miles) |
Table 3 SFP+ transceiver modules available for the SFP+ ports (1)
SFP+ transceiver module |
Connector |
SFP-XG-SX-MM850-A |
850 |
LC |
SFP-XG-LX-SM1310 |
1310 |
LC |
SFP-FC-8G-SW-MM850 |
850 |
LC |
SFP-FC-8G-LW-SM1310 |
1310 |
LC |
Table 4 SFP+ transceiver modules available for the SFP+ ports (2)
Fiber diameter (µm) |
SFP-XG-SX-MM850-A |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310 |
N/A |
200 |
150 m (492.12 ft) |
500 |
380 m (1246.72 ft) |
2000 |
N/A |
Table 5 SFP+ DAC cables available for the SFP+ ports
SFP+ DAC cable |
Cable length |
Data rate |
LSWM1STK |
0.65 m (2.13 ft) |
10.31 Gbps |
LSWM2STK |
1.2 m (3.94 ft) |
LSWM3STK |
3 m (9.84 ft) |
LSTM1STK |
5 m (16.40 ft) |
Table 6 SFP+ fiber cables available for the SFP+ ports
SFP+ fiber cable |
Cable length |
Data rate |
SFP-XG-D-AOC-7M |
7 m (22.97 ft) |
10.31 Gbps |
SFP-XG-D-AOC-10M |
10 m (32.81 ft) |
SFP-XG-D-AOC-20M |
20 m (65.62 ft) |
QSFP+ ports
You can install the following transceiver modules and cables in the QSFP+ ports on an LSWM124XG2QFC interface card:
· QSFP+ transceiver modules in Table 7 and Table 8.
· QSFP+ DAC cables in Table 9.
· QSFP+ to SFP+ DAC cables in Table 10.
· QSFP+ fiber cables in Table 11.
Table 7 QSFP+ transceiver modules available for the QSFP+ ports (1)
QSFP+ transceiver module |
Connector |
QSFP-40G-SR4-MM850 |
850 |
MPO |
QSFP-40G-CSR4-MM850 |
850 |
MPO |
QSFP-40G-LR4-WDM1300 |
Four lanes: · 1271 · 1291 · 1311 · 1331 |
LC |
QSFP-40G-LR4L-WDM1300 |
LC |
Table 8 QSFP+ transceiver modules available for the QSFP+ ports (2)
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.12 ft) |
2000 |
300 m (984.25 ft) |
4700 |
400 m (1312.33 ft) |
N/A |
N/A |
2 km (1.24 miles) |
Table 9 QSFP+ DAC cables available for the QSFP+ ports
QSFP+ DAC cable |
Cable length |
Data rate |
LSWM1QSTK0 |
1 m (3.28 ft) |
40 Gbps |
LSWM1QSTK1 |
3 m (9.84 ft) |
LSWM1QSTK2 |
5 m (16.40 ft) |
Table 10 QSFP+ to SFP+ DAC cables available for the QSFP+ ports
QSFP+ to SFP+ DAC cable |
Cable length |
Data rate |
LSWM1QSTK3 |
1 m (3.28 ft) |
40 Gbps |
LSWM1QSTK4 |
3 m (9.84 ft) |
LSWM1QSTK5 |
5 m (16.40 ft) |
Table 11 QSFP+ fiber cables available for the QSFP+ ports
QSFP+ fiber cable |
Cable length |
Data rate |
QSFP-40G-D-AOC-7M |
7 m (22.97 ft) |
40 Gbps |
QSFP-40G-D-AOC-10M |
10 m (32.81 ft) |
QSFP-40G-D-AOC-20M |
20 m (65.62 ft) |
LEDs
The indications of the LEDs on the LSWM124XG2QFC interface card vary by device model. For more information, see the installation guide or hardware reference for the device.
SFP+ port LEDs
Table 12 SFP+ port LED description
LED status |
Steady green |
A transceiver module is installed in the port. The port is operating at 10 Gbps, and a link is present on the port. |
Flashing green |
The port is sending or receiving data at 10 Gbps. |
Steady yellow |
A transceiver module is installed in the port. The port is operating at 1 Gbps, and a link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 1 Gbps. |
Off |
No transceiver module is installed in the port, or no link is present on the port. |
QSFP+ port LEDs
Table 13 QSFP+ port LED description
LED status |
Steady green |
A transceiver module is installed in the port. The port is operating at 40 Gbps, and a link is present on the port. |
Flashing green |
The port is sending or receiving data at 40 Gbps. |
Steady yellow |
Flashing yellow |
Off |
CAUTION: · Before you install or remove an interface card, wear an ESD wrist strap and make sure the strap makes good skin contact and is reliably grounded. · To avoid device damage, do not use excessive force when you install or remove an interface card. · The LSWM124XG2QFC interface card is hot swappable. However, do not install or remove it during the startup of the switch. |
Installing an interface card
Before you install an interface card, remove the filler panel (if any) from the target slot. Keep the removed filler panel secure for future use.
To install an interface card:
1. Unpack the interface card.
Figure 2 LSWM124XG2QFC interface card
(1) Ejector lever |
(2) Latch |
2. Press the latch on the interface card to release the ejector lever.
3. As shown by callout 1 in Figure 3, insert the interface card slowly into the slot along the guide rails.
4. Rotate inward the ejector lever as shown by callout 2 in Figure 3 until the latch locks the ejector lever in place.
Figure 3 Installing an LSWM124XG2QFC interface card
Removing an interface card
CAUTION: · Before you remove an interface card, remove the cable from it to avoid cable damage. · After removing an interface card, if no new interface card is to be installed, install the filler panel as soon as possible to prevent dust and ensure good ventilation in the device. |
To remove an interface card:
1. Prepare an anti-static bag.
2. Press the latch to release the ejector lever
3. Rotate outward the ejector lever as shown by callout 1 in Figure 4.
4. Pull out the interface card slowly out of the interface card slot, as shown by callout 2 in Figure 4.
5. Place the removed interface card in the anti-static bag.
Figure 4 Removing an LSWM124XG2QFC interface card
For information about installing and removing SFP/SFP+ transceiver modules and SFP+ cables, see H3C Transceiver Modules and Network Cables Installation Guide at www.h3c.com.
For information about installing and removing QSFP+ transceiver modules and QSFP+ cables, see H3C Transceiver Modules and Network Cables Installation Guide at www.h3c.com.
Verifying the installation
After the installation is complete, identify whether the interface card is operating correctly.
If the interface card fails to operate correctly, perform the following steps:
1. Reinstall it following the installation procedures described in this document.
2. If the problem persists, contact H3C Support.
