10-Security Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release7374-6W73110-Security Command Reference
15-Attack detection and prevention commands
15-Attack detection and prevention commands 42.35 KB
attack-defense tcp fragment enable
Use attack-defense tcp fragment enable to enable TCP fragment attack prevention.
Use undo attack-defense tcp fragment enable to disable TCP fragment attack prevention.
TCP fragment attack prevention is enabled.
This command enables the device to drop attack TCP fragments to prevent TCP fragment attacks.
TCP fragment attacks can be detected by both software and hardware chips.
# Enable TCP fragment attack prevention.
<Sysname> System-view
[Sysname] attack-defense tcp fragment enable
# Disable TCP fragment attack prevention.
[Sysname] undo attack-defense tcp fragment enable
