10-Security Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release7374-6W73110-Security Command Reference
10-SSL commands
10-SSL commands 109.97 KB
SSL commands
ciphersuite
Use ciphersuite to specify the cipher suites supported by an SSL server policy.
Use undo ciphersuite to restore the default.
In non-FIPS mode:
ciphersuite { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_256_cbc_sha | exp_rsa_des_cbc_sha | exp_rsa_rc2_md5 | exp_rsa_rc4_md5 | rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha } *
undo ciphersuite
In FIPS mode:
ciphersuite { rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha } *
undo ciphersuite
An SSL server policy supports all cipher suites.
SSL server policy view
dhe_rsa_aes_128_cbc_sha: Specifies the key exchange algorithm DHE RSA, the data encryption algorithm 128-bit AES, and the MAC algorithm SHA.
dhe_rsa_aes_256_cbc_sha: Specifies the key exchange algorithm DHE RSA, the data encryption algorithm 256-bit AES, and the MAC algorithm SHA.
exp_rsa_des_cbc_sha: Specifies the export cipher suite that uses the key exchange algorithm RSA, the data encryption algorithm DES_CBC, and the MAC algorithm SHA.
exp_rsa_rc2_md5: Specifies the export cipher suite that uses the key exchange algorithm RSA, the data encryption algorithm RC2, and the MAC algorithm MD5.
exp_rsa_rc4_md5: Specifies the export cipher suite that uses the key exchange algorithm RSA, the data encryption algorithm RC4, and the MAC algorithm MD5.
rsa_3des_ede_cbc_sha: Specifies the key exchange algorithm RSA, the data encryption algorithm 3DES_EDE_CBC, and the MAC algorithm SHA.
rsa_aes_128_cbc_sha: Specifies the key exchange algorithm RSA, the data encryption algorithm 128-bit AES_CBC, and the MAC algorithm SHA.
rsa_aes_256_cbc_sha: Specifies the key exchange algorithm RSA, the data encryption algorithm 256-bit AES_CBC, and the MAC algorithm SHA.
rsa_des_cbc_sha: Specifies the key exchange algorithm RSA, the data encryption algorithm DES_CBC, and the MAC algorithm SHA.
rsa_rc4_128_md5: Specifies the key exchange algorithm RSA, the data encryption algorithm 128-bit RC4, and the MAC algorithm MD5.
rsa_rc4_128_sha: Specifies the key exchange algorithm RSA, the data encryption algorithm 128-bit RC4, and the MAC algorithm SHA.
SSL employs the following algorithms:
·     Data encryption algorithms—Encrypt data to ensure privacy. Commonly used data encryption algorithms are usually symmetric key algorithms, such as DES_CBC, 3DES_EDE_CBC, AES_CBC, and RC4. When using a symmetric key algorithm, the SSL server and the SSL client must use the same key.
·     Message Authentication Code (MAC) algorithms—Calculate the MAC value for data to ensure integrity. Commonly used MAC algorithms include MD5 and SHA. When using a MAC algorithm, the SSL server and the SSL client must use the same key.
·     Key exchange algorithms—Implement secure exchange of the keys used by the symmetric key algorithm and the MAC algorithm. Commonly used key exchange algorithms are usually asymmetric key algorithms, such as RSA.
After the SSL server receives a cipher suite from a client, the server matches the received cipher suite against the cipher suits it supports. If a match is found, the cipher suite negotiation succeeds. Otherwise, the negotiation fails.
# Configure SSL server policy policy1 to support the following cipher suites:
·     Key exchange algorithm DHE RSA, data encryption algorithm 128-bit AES, and MAC algorithm SHA
·     Key exchange algorithm RSA, data encryption algorithm 128-bit AES, and MAC algorithm SHA
[Sysname] ssl server-policy policy1
[Sysname-ssl-server-policy-policy1] ciphersuite dhe_rsa_aes_128_cbc_sha rsa_aes_128_cbc_sha
·     display ssl server-policy
·     prefer-cipher
client-verify enable
Use client-verify enable to enable the SSL server to use digital certificates to authenticate clients.
Use undo client-verify enable to restore the default.
The SSL server does not authenticate SSL clients.
The SSL client and server use digital certificates to authenticate each other. For more information about digital certificates, see Security Configuration Guide.
If you execute the client-verify enable command, an SSL client must send its own digital certificate to the SSL server for authentication. The client can access the SSL server only after it passes the authentication.
When authenticating a client by using the digital certificate, the SSL server performs the following tasks:
·     Verifies the certificate chain presented by the client.
·     Checks that the certificates in the certificate chain (except the root CA certificate) are not revoked.
# Enable the SSL server to use digital certificates to authenticate SSL clients.
[Sysname-ssl-server-policy-policy1] client-verify enable
display ssl client-policy
Use display ssl client-policy to display SSL client policy information.
display ssl client-policy [ policy-name ]
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify this argument, the command displays information about all SSL client policies.
# Display information about the SSL client policy policy1.
<Sysname> display ssl client-policy policy1
 SSL client policy: policy1
     SSL version: SSL 3.0
     PKI domain: client-domain
     Preferred ciphersuite:
         RSA_AES_128_CBC_SHA
     Server-verify: enabled
Server-verify
Indicates whether the client is enabled to use digital certificates to authenticate servers.
Use display ssl server-policy to display SSL server policy information.
display ssl server-policy [ policy-name ]
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify this argument, the command displays information about all SSL server policies.
# Display information about the SSL server policy policy1.
<Sysname> display ssl server-policy policy1
 SSL server policy: policy1
     PKI domain: server-domain
     Ciphersuites:
         DHE_RSA_AES_128_CBC_SHA
         RSA_AES_128_CBC_SHA
     Session cache size: 600
     Client-verify: enabled
Client-verify
Indicates whether the server is enabled to use digital certificates to authenticate clients.
pki-domain
Use pki-domain to specify a PKI domain for an SSL client policy or an SSL server policy.
Use undo pki-domain to restore the default.
pki-domain domain-name
undo pki-domain
No PKI domain is specified for an SSL client policy or an SSL server policy.
SSL client policy view, SSL server policy view
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters.
If you specify a PKI domain for an SSL client policy, the SSL client that uses the SSL client policy will obtain its digital certificate through the specified PKI domain.
If you specify a PKI domain for an SSL server policy, the SSL server that uses the SSL server policy will obtain its digital certificate through the specified PKI domain.
# Specify PKI domain client-domain for the SSL client policy policy1.
[Sysname] ssl client-policy policy1
[Sysname-ssl-client-policy-policy1] pki-domain client-domain
# Specify PKI domain server-domain for the SSL server policy policy1.
[Sysname-ssl-server-policy-policy1] pki-domain server-domain
·     display ssl client-policy
·     pki domain
prefer-cipher
Use prefer-cipher to specify a preferred cipher suite for an SSL client policy.
Use undo prefer-cipher to restore the default.
In non-FIPS mode:
prefer-cipher { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_256_cbc_sha | exp_rsa_des_cbc_sha | exp_rsa_rc2_md5 | exp_rsa_rc4_md5 | rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha }
undo prefer-cipher
In FIPS mode:
prefer-cipher { rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha }
undo prefer-cipher
In non-FIPS mode:
The preferred cipher suite of an SSL client policy is rsa_rc4_128_md5.
In FIPS mode:
The preferred cipher suite of an SSL client policy is rsa_aes_128_cbc_sha.
·     Key exchange algorithms—Implement secure exchange of the keys used by the symmetric key algorithm and the MAC algorithm. Commonly used key exchange algorithms are asymmetric key algorithms, such as RSA.
The SSL client sends the preferred cipher suite to the SSL server, the server matches the received cipher suite against the cipher suits it supports. If a match is found, the cipher suite negotiation succeeds. Otherwise, the negotiation fails.
# Configure the SSL client policy policy1 to support the key exchange algorithm RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
[Sysname-ssl-client-policy-policy1] prefer-cipher rsa_aes_128_cbc_sha
·     ciphersuite
server-verify enable
Use server-verify enable to enable the SSL client to use digital certificates to authenticate SSL servers.
Use undo server-verify enable to disable authentication. That is, the client does not authenticate any server.
The SSL client uses digital certificates to authenticate SSL servers.
If you execute the server-verify enable command, an SSL server must send its own digital certificate to the SSL client for authentication. The client can access the SSL server only after the server passes the authentication.
# Enable the SSL client to use digital certificates to authenticate SSL servers.
[Sysname-ssl-client-policy-policy1] server-verify enable
session cachesize
Use session cachesize to set the maximum number of sessions that the SSL server can cache.
Use undo session cachesize to restore the default.
session cachesize size
The SSL server can cache a maximum of 500 sessions.
size: Specifies the maximum number of cached sessions in the range of 100 to 1000.
The SSL handshake protocol follows a complicated procedure to negotiate session parameters and establish sessions. To simplify the procedure, SSL allows you to reuse negotiated session parameters to establish sessions. This feature requires that the SSL server maintain information about existing sessions.
This command limits the maximum number of sessions that the SSL server can cache. If the number of sessions in the cache reaches the maximum, SSL does not cache new sessions.
# Set the maximum number of cached sessions to 600.
[Sysname-ssl-server-policy-policy1] session cachesize 600
ssl client-policy
Use ssl client-policy to create an SSL client policy and enter SSL client policy view.
Use undo ssl client-policy to delete an SSL client policy.
ssl client-policy policy-name
undo ssl client-policy policy-name
No SSL client policy exists on the device.
This command creates an SSL client policy for which you can configure SSL parameters that the client uses to establish a connection to the server. The parameters include a PKI domain and a preferred cipher suite. An SSL client policy takes effect only after it is associated with an application such as the Dynamic Domain Name System (DDNS).
# Create SSL client policy policy1 and enter SSL client policy view.
ssl server-policy
Use ssl server-policy to create an SSL server policy and enter SSL server policy view.
Use undo ssl server-policy to delete an SSL server policy.
ssl server-policy policy-name
undo ssl server-policy policy-name
No SSL server policy exists on the device.
policy-name: Specifies a name for the SSL server policy, a case-insensitive string of 1 to 31 characters.
This command creates an SSL server policy for which you can configure SSL parameters such as a PKI domain and supported cipher suits. An SSL server policy takes effect only after it is associated with an application such as HTTPS.
# Create SSL server policy policy1 and enter SSL server policy view.
ssl version ssl3.0 disable
Use ssl version ssl3.0 disable to disable SSL 3.0 on the device.
Use undo ssl version ssl3.0 disable restore the default.
SSL 3.0 is enabled.
Use this command to disable SSL 3.0 on a device to enhance system security.
·     An SSL server supports only TLS 1.0 after SSL 3.0 is disabled.
·     An SSL client always uses SSL 3.0 if SSL 3.0 is specified for the client policy, whether you disable SSL 3.0 or not.
To ensure successful establishment of an SSL connection, do not disable SSL 3.0 on a device when the peer device only supports SSL 3.0. H3C recommends upgrading the peer device to support TLS 1.0 to improve security.
# Disable SSL 3.0 on the device.
[Sysname] ssl version ssl3.0 disable
version
Use version to specify an SSL version for an SSL client policy.
Use undo version to restore the default.
In non-FIPS mode:
version { ssl3.0 | tls1.0 }
undo version
In FIPS mode:
version tls1.0
undo version
The SSL protocol version for an SSL client policy is TLS 1.0.
ssl3.0: Specifies SSL 3.0.
tls1.0: Specifies TLS 1.0.
The SSL protocol version used by a client is determined by the configuration of both the version command the ssl version ssl3.0 disable command.
·     If TLS 1.0 is specified and SSL 3.0 is not disabled, the client first uses TLS 1.0 to connect to the SSL server. If the connection attempt fails, the client uses SSL 3.0.
·     If TLS 1.0 is specified and SSL 3.0 is disabled, the client only uses TLS 1.0 to connect to the SSL server.
·     If SSL 3.0 is specified, the client uses SSL 3.0 to connect to the SSL server, whether you disable SSL 3.0 or not.
To enhance system security, H3C recommends disabling SSL 3.0 on the device and specifying TLS 1.0 for an SSL client policy.
# Specify the SSL version for SSL client policy policy1 as TLS 1.0.
[Sysname-ssl-client-policy-policy1] version tls1.0
