10-Security Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release7374-6W73110-Security Command Reference
09-uRPF commands
09-uRPF commands 64.05 KB
uRPF commands
display ip urpf interface
Use display ip urpf interface to display uRPF configuration on an interface.
In standalone mode:
display ip urpf interface interface-type interface-number [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display ip urpf interface interface-type interface-number [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device, and the slot number argument specifies the number of the slot that holds the card. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number.
To display uRPF configuration on an interface, check whether the interface is a global interface:
·     If it is a global interface, specify the card where the interface resides. If you do not specify the slot slot-number or chassis chassis-number slot slot-number option, the command displays uRPF configuration for the MPU. A global interface has a one-dimensional number, such as VLAN-interface 10.
·     If it is not a global interface, you do not need to specify the card for the command to display the interface uRPF configuration. A non-global interface has a multiple-dimensional number, such as GigabitEthernet 3/0/1.
# Display uRPF configuration on VLAN-interface 10 for the card in slot 0.
<Sysname> display ip urpf interface Vlan-interface 10 slot 0
uRPF configuration information of interface Vlan-interface10:
   Check type: strict
   Allow default route
uRPF configuration on the interface.
(failed)
Failed to deliver the uRPF configuration to the forwarding chip because of insufficient chip resources. If this field is not displayed, the delivery is successful.
Check type
uRPF check mode is strict.
Allow default route
Allow use of the default route.
ip urpf strict
Use ip urpf strict to enable strict uRPF check.
Use undo ip urpf to disable strict uRPF check.
ip urpf strict [ link-check ]
undo ip urpf
Strict uRPF check is disabled.
Interface view
strict: Enables strict uRPF check. To pass strict uRPF check, the source address and receiving interface of a packet must match the destination address and output interface of a FIB entry.
link-check: Enables link layer check (Ethernet link).
Use this command on a VLAN interface. Otherwise, this command does not take effect.
uRPF can be deployed on a PE connected to a CE or another ISP, or on a CE.
If a Layer 3 PE interface connects a large number of PCs, configure the link-check keyword on the interface to enable link layer check. uRPF checks the validity of the source MAC address.
# Configure strict uRPF check on VLAN-interface 10.
[Sysname] interface Vlan-interface 10
[Sysname-Vlan-interface10] ip urpf strict
