LSQM1XPT12TSFD0 Card Manual-6PW103
HomeSupportSwitchesH3C S7500X Switch SeriesInstall & UpgradeService Module Card ManualsLSQM1XPT12TSFD0 Card Manual-6PW103
Download Book
Title Size Downloads
LSQM1XPT12TSFD0 Card Manual-6PW103-book.pdf 16.70 KB
12-port 10G EPON OLT + 8-port 10G Ethernet optical interface module—LSQM1XPT12TSFD0
1  Card identifier
The card identifier LSQM1XPT12TSFD0 is in the upper right corner of the front panel.
2  Specifications
Table 1 Card specifications
Item
Specification
Card size (H × W × D)
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in)
SDRAM (DDR3)
2 GB
Power consumption
100 W to 162 W
Ports
8 x 10GBASE-R-SFP+ fiber ports
12 x 10G EPON OLT fiber ports
Port speed
SFP+ fiber port: 10 Gbps
EPON fiber port (symmetric transceiver module): 10 Gbps
EPON fiber port (nonsymmetric transceiver module): 10 Gbps transmit rate, 1 Gbps receive rate
·      To verify the compatibility of the card with the software release you are using, see the release notes.
·      For information about transceiver modules and cables available for the card, see the cards and transceiver modules compatibility matrixes for the device.
3  Related documentation
For module installation, see the installation guide for the device
For software upgrade, see the release notes for the device.
Copyright © 2017-2019 New H3C Technologies Co., Ltd.
  • Become a Partner
  • Partner Resources
