- Released At: 11-10-2020
- Page Views:
- Downloads:
Software version: Release 7595
Document Version: 6W100-20200930
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Managing and obtaining system log messages
Obtaining log messages from the console terminal
Obtaining log messages from a monitor terminal
Obtaining log messages from the log buffer
Obtaining log messages from the log file
Obtaining log messages from a log host
ACL_ACCELERATE_NONCONTIGUOUSMASK
ACL_ACCELERATE_NOT_SUPPORTHOPBYHOP
ACL_ACCELERATE_NOT_SUPPORTMULTITCPFLAG
APMGR_CWC_IMG_DOWNLOAD_COMPLETE
APMGR_CWC_RUN_DOWNLOAD_COMPLETE
APMGR_CWS_IMG_DOWNLOAD_COMPLETE
APMGR_CWS_RUN_DOWNLOAD_COMPLETE
ARP_ACTIVE_ACK_NOREQUESTED_REPLY
ARP_USER_DUPLICATE_IPADDR_DETECT
ATK_ICMPV6_DEST_UNREACH_RAW_SZ
ATK_ICMPV6_GROUPREDUCTION_RAW_SZ
ATK_ICMPV6_PACKETTOOBIG_RAW_SZ
ATK_IP4_TCP_INVALIDFLAGS_RAW_SZ
ATK_IP6_TCP_INVALIDFLAGS_RAW_SZ
ATK_IPOPT_LOOSESRCROUTE_RAW_SZ
ATK_IPOPT_STRICTSRCROUTE_RAW_SZ
DOT1X_LOGIN_SUCC (in open mode)
DOT1X_LOGOFF_ABNORMAL (in open mode)
DOT1X_NOTENOUGH_EADFREERULE_RES
DOT1X_NOTENOUGH_EADMACREDIR_RES
DOT1X_NOTENOUGH_EADPORTREDIR_RES
DOT1X_NOTENOUGH_ENABLEDOT1X_RES
DRNI_IFEVENT_DR_PEER_NOSELECTED
DRNI_IFEVENT_DR_PRIORITY_CHANGE
DRNI_KEEPALIVEINTERVAL_MISMATCH
DRNI_SYSEVENT_DEVICEROLE_CHANGE
EDEV_FAILOVER_GROUP_STATE_CHANGE
EMDI_INDICATOR_OVER_THRES_RESUME
ETHOAM_CONNECTION_FAIL_TIMEOUT
ETHOAM_CONNECTION_FAIL_UNSATISF
ETHOAM_ENTER_LOOPBACK_CTRLLING
ETHOAM_LOCAL_ERROR_FRAME_PERIOD
ETHOAM_LOCAL_ERROR_FRAME_SECOND
ETHOAM_LOOPBACK_EXIT_ERROR_STATU
ETHOAM_REMOTE_ERROR_FRAME_PERIOD
ETHOAM_REMOTE_ERROR_FRAME_SECOND
FCLINK_FDISC_REJECT_NORESOURCE
FCLINK_FLOGI_REJECT_NORESOURCE
FCOE_INTERFACE_NOTSUPPORT_FCOE
IF_BUFFER_CONGESTION_OCCURRENCE
L2PT_CREATE_TUNNELGROUP_FAILED
L2VPN_ARP_MOBILITY_SUPPRESS (public instance)
L2VPN_ARP_MOBILITY_SUPPRESS (VPN instance)
L2VPN_ARP_MOBILITY_UNSUPPRESS (public instance)
L2VPN_ARP_MOBILITY_UNSUPPRESS (VPN instance)
LAGG_INACTIVE_PARTNER_KEY_WRONG
LAGG_INACTIVE_PARTNER_MAC_WRONG
LAGG_INACTIVE_PARTNER_RDIRHANDLE
LAGG_INACTIVE_RESOURCE_INSUFICIE
LLDP_NEIGHBOR_PROTECTION_BLOCK
LLDP_NEIGHBOR_PROTECTION_UNBLOCK
MAC_VLAN_LEARNLIMIT_NORESOURCE
MAC_VLAN_LEARNLIMIT_NOTSUPPORT
MACA_LOGIN_SUCC (in open mode)
NAT_SERVICE_CARD_RECOVER_FAILURE
ND_SET_VLAN_REDIRECT_NORESOURCE
ND_SNOOPING_LEARN_ALARM_RECOVER
NQA_TWAMP_LIGHT_PACKET_INVALID
OFP_FLOW_ADD_TABLE_MISS_FAILED
OFP_FLOW_DEL_TABLE_MISS_FAILED
OFP_FLOW_MOD_TABLE_MISS_FAILED
PEX_AUTOCONFIG_BAGG_ASSIGNMEMBER
PEX_AUTOCONFIG_BAGG_NORESOURCE
PEX_AUTOCONFIG_BAGG_REMOVEMEMBER
PEX_AUTOCONFIG_CAPABILITY_ENABLE
PEX_AUTOCONFIG_CONNECTION_ERROR
PEX_AUTOCONFIG_DIFFGROUPNUMBER
PEX_AUTOCONFIG_DYNAMICBAGG_STP
PEX_AUTOCONFIG_NONUMBERRESOURCE
PEX_AUTOCONFIG_NOT_CASCADEPORT
PFILTER_VLAN_IPV4_DACT_UNK_ERR
PFILTER_VLAN_IPV6_DACT_UNK_ERR
PORTSEC_PORTMODE_NOT_EFFECTIVE
PTS_CREATE_SELFVERIFY_COUNTER_FAILED
PTS_CREATE_SELFVERIFY_TIMER_FAILED
QOS_QMPROFILE_MODIFYQUEUE_FAIL
RPR_LAGGCONFIG_INCONSISTENT_OVER
RPR_PROTECTION_INCONSISTENT_OVER
RPR_TOPOLOGY_INCONSISTENT_OVER
Introduction
This document includes the following system messages:
· Messages specific to Release 7595 of the switch.
· Messages for the Comware 7 software platform version based on which Release 7595 was produced. Some platform system messages might not be available on the switch.
This document is intended only for managing S12500G-AF switches. Do not use this document for any other device models.
This document assumes that the readers are familiar with data communications technologies and H3C networking products.
System log message format
By default, the system log messages use one of the following formats depending on the output destination:
· Log host:
<PRI>TIMESTAMP Sysname %%vendorMODULE/severity/MNEMONIC: location; CONTENT
· Destinations except for the log host:
Prefix TIMESTAMP Sysname MODULE/severity/MNEMONIC: CONTENT
NOTE: Log message examples in this document use the format for destinations except the log host. They do not contain elements available only for the log host, including the location element. |
Table 1 System log message elements
Element |
<PRI> |
Priority identifier. This element is contained only in messages sent to the log host. It is calculated by using the following formula: Priority identifier=facilityx8+severity Where: · Facility is specified by using the info-center loghost command. A log host uses this parameter to identify log sources and filter log messages. · Severity represents the importance of the message. For more information about severity levels, see Table 2. |
Prefix |
Message type identifier. This element is contained in the system log messages sent to non-log-host destinations. The element uses the following symbols to indicate message severity: · Percentage sign (%)—Informational and higher levels. · Asterisk (*)—Debug level. |
TIMESTAMP |
Date and time when the event occurred. The following are commands for configuring the timestamp format: · Log host—Use the info-center timestamp loghost command. · Non-log-host destinations—Use the info-center timestamp command. |
Sysname |
Name or IP address of the device that generated the message. |
%%vendor |
Manufacturer flag. This element is %%10 for H3C. This element is only available in messages sent to the log host. |
MODULE |
Name of the module that produced the message. |
severity |
Severity level of the message. (For more information about severity levels, see Table 2.) |
MNEMONIC |
Text string that uniquely identifies the system message. The maximum length is 32 characters. |
location |
Optional. This element identifies where the message occurred. This element is contained only in messages sent to the log host. This element presents location information for the message in the following format: -attribute1=x-attribute2=y…-attributeN=z The following are examples of location attributes: · -MDC=XX, which represents the MDC on which the message occurred. · -DevIp=XXX.XXX.XXX.XXX, which represents the source IP of the message. · -Slot=XX, which represents the slot on which the message occurred. · -Chassis=XX-Slot=XX, which represents the chassis and slot on which the message occurred. This element is separated from the message description by using a semicolon (;). |
CONTENT |
Text string that contains detailed information about the event or error. For variable fields in this element, this document uses the representations in Table 3. |
System log messages are classified into eight severity levels from 0 to 7. The lower the number, the higher the severity, as shown in Table 2.
Table 2 System log message severity levels
Level |
Severity |
0 |
Emergency |
The system is unusable. For example, the system authorization has expired. |
1 |
Alert |
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit. |
2 |
Critical |
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails. |
3 |
Error |
Error condition. For example, the link state changes or a storage card is unplugged. |
4 |
Warning |
Warning condition. For example, an interface is disconnected, or the memory resources are used up. |
5 |
Notification |
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots. |
6 |
Informational |
Informational message. For example, a command or a ping operation is executed. |
7 |
Debug |
Debugging message. |
For variable fields in the message text, this document uses the representations in Table 3. The values are case insensitive, even though the representations are uppercase letters.
Table 3 Variable field representations
Representation |
Information type |
INT16 |
Signed 16-bit decimal number. |
UINT16 |
Unsigned 16-bit decimal number. |
INT32 |
Signed 32-bit decimal number. |
UINT32 |
Unsigned 32-bit decimal number. |
INT64 |
Signed 64-bit decimal number. |
UINT64 |
Unsigned 64-bit decimal number. |
DOUBLE |
Two dot-separated signed 32-bit decimal numbers. The format is [INTEGER].[INTEGER]. |
HEX |
Hexadecimal number. |
CHAR |
Single character. |
STRING |
Character string. |
IPADDR |
IP address. |
MAC |
MAC address. |
DATE |
Date. |
TIME |
Time. |
You can manage system log messages by using the information center.
By default, the information center is enabled. Log messages can be output to the console, monitor terminal, log buffer, log host, and log file.
To filter log messages, use the info-center source command to specify log output rules. A log output rule specifies the source modules and the lowest severity level of log messages that can be output to a destination. A log message is output if its severity level is higher than or equal to the specified level. For example, if you specify a severity level of 6 (informational), log messages that have a severity level from 0 to 6 are output.
For more information about using the information center, see the network management and monitoring configuration guide for the product.
Access the device through the console port. Real-time log messages are displayed on the console terminal.
Monitor terminals refer to terminals that access the device through the AUX, VTY, or TTY lines (for example, Telnet). To obtain log messages from a monitor terminal, use the following guidelines:
· To display log messages on the monitor terminal, you must configure the terminal monitor command.
· For monitor terminals, the lowest level of log messages that can be displayed is determined by both the terminal logging level and info-center source commands.
NOTE: Settings for the terminal monitor and terminal logging level commands take effect only on the current login session. The default settings for the commands restore at a relogin. |
Use the display logbuffer command to display history log messages in the log buffer.
By default, the log file feature automatically saves logs from the log file buffer to the log file every 24 hours. You can use the info-center logfile frequency command to change the automatic saving internal.
To manually save logs to the log file, use the logfile save command. The log file buffer is cleared each time a save operation is performed.
By default, you can obtain the log file from the cfa0:/logfile/ path if the CF card is not partitioned. If the CF card is partitioned, the file path is cfa1:/logfile/.
To view the contents of the log file on the device, use the more command.
Use the info-center loghost command to specify the service port number and IP address of a log host. To specify multiple log hosts, repeat the command.
For a successful log message transmission, make sure the specified port number is the same as the port number used on the log host. The default service port number is 514.
Software module list
Table 4 lists all software modules that might produce system log messages. This document uses "OPENSRC" to represent all open source modules.
Module name representation |
Module name expansion |
AAA |
Authentication, Authorization and Accounting |
ACL |
Access Control List |
ANCP |
Access Node Control Protocol |
APMGR |
Access Point Management |
ARP |
Address Resolution Protocol |
ATK |
Attack Detection and Prevention |
ATM |
BFD |
Bidirectional Forwarding Detection |
BGP |
Border Gateway Protocol |
BLS |
Blacklist |
CFD |
Connectivity Fault Detection |
CFGMAN |
Configuration Management |
CONNLMT |
Connection Limit |
DEV |
Device Management |
DHCPR |
IPv4 DHCP Relay |
DHCPS |
DHCP Server |
DHCPS6 |
DHCPv6 Server |
DHCPSP4 |
DHCP Snooping |
DHCPSP6 |
DHCPv6 Snooping |
DIAG |
Diagnosis |
DLDP |
Device Link Detection Protocol |
DOT1X |
802.1X |
DRNI |
Distributed Resilient Network Interconnect |
EDEV |
EPA |
Endpoint Analysis |
ERPS |
Ethernet Ring Protection Switching |
ETH |
Ethernet |
ETHDRNI |
Ethernet Distributed Resilient Network Interconnect |
ETHOAM |
Ethernet Operation, Administration and Maintenance |
EVB |
Edge Virtual Bridging |
EVIISIS |
Ethernet Virtual Interconnect Intermediate System-to-Intermediate System |
FCOE |
Fibre Channel Over Ethernet |
FCLINK |
Fibre Channel Link |
FCZONE |
Fibre Channel Zone |
FIB |
Forwarding Information Base |
FILTER |
Filter |
FIPSNG |
FIP Snooping |
FS |
File System |
gRPC |
Google Remote Procedure Call |
HA |
High Availability |
HLTH |
Health |
HQOS |
Hierarchical QoS |
HTTPD |
Hypertext Transfer Protocol Daemon |
IFNET |
Interface Net Management |
IKE |
Internet Key Exchange |
IMA |
Integrity Measurements Architecture |
iNQA |
Intelligent Network Quality Analyzer |
IP6ADDR |
IPv6 Addressing |
IP6FW |
IPv6 Forwarding |
IPADDR |
IP Addressing |
IPFW |
IP Forwarding |
IPSEC |
IP Security |
IRDP |
ICMP Router Discovery Protocol |
IRF |
Intelligent Resilient Framework |
ISIS |
ISSU |
In-Service Software Upgrade |
L2PT |
Layer 2 Protocol Tunneling |
L2TPV2 |
Layer 2 Tunneling Protocol Version 2 |
L2VPN |
Layer 2 VPN |
LAGG |
Link Aggregation |
LDP |
Label Distribution Protocol |
LLDP |
Link Layer Discovery Protocol |
LOAD |
Load Management |
LOGIN |
Login |
LPDT |
Loopback Detection |
LS |
Local Server |
LSPV |
LSP Verification |
MAC |
Media Access Control |
MACA |
MAC Authentication |
MACSEC |
MAC Security |
MBFD |
MPLS BFD |
MBUF |
Memory buffer |
MDC |
Multitenant Device Context |
MFIB |
Multicast Forwarding Information Base |
MGROUP |
Mirroring group |
MPLS |
Multiprotocol Label Switching |
MTLK |
Monitor Link |
NAT |
Network Address Translation |
NETCONF |
Network Configuration Protocol |
ND |
Neighbor Discovery |
NQA |
NSS |
Session-based NetStream |
NTP |
Network Time Protocol |
OAP |
Open Application Platform |
OPENSRC (FreeRADIUS) |
Open Source |
OFP |
OpenFlow Protocol |
OPTMOD |
Optical Module |
OSPF |
Open Shortest Path First |
OSPFV3 |
Open Shortest Path First Version 3 |
PFILTER |
Packet Filter |
PBB |
Provider Backbone Bridge |
PBR |
Policy-Based Routing |
PEX |
Port Extender |
PIM |
Protocol Independent Multicast |
PING |
Packet Internet Groper |
PKG |
Package |
PKI |
Public Key Infrastructure |
PKT2CPU |
Packet to CPU |
PKTCPT |
Packet Capture |
PoE |
Power over Ethernet |
PORTAL |
Portal |
PORTSEC |
Port Security |
PPP |
Point to Point Protocol |
PTS |
Platform Trust Services |
PWDCTL |
Password Control |
QOS |
Quality of Service |
RADIUS |
Remote Authentication Dial In User Service |
RESMON |
Resource Monitor |
RDDC |
Redundancy |
RIP |
Routing Information Protocol |
RIPNG |
Routing Information Protocol Next Generation |
RM |
Routing Management |
RPR |
Resilient Packet Ring |
RRPP |
Rapid Ring Protection Protocol |
RTM |
Real-Time Event Manager |
SCMD |
Service Control Manager Daemon |
SCRLSP |
Static CRLSP |
SESSION |
Session |
SHELL |
Shell |
SLSP |
Static LSP |
SMLK |
Smart Link |
SNMP |
Simple Network Management Protocol |
SQA |
Service Quality Analysis |
SSHC |
Secure Shell Client |
SSHS |
Secure Shell Server |
STAMGR |
Station Management |
STM |
Stack Topology Management |
STP |
Spanning Tree Protocol |
SYSEVENT |
System Event |
SYSLOG |
System Log |
TACACS |
Terminal Access Controller Access Control System |
TCSM |
Trusted Computing Services Management |
TRILL |
Transparent Interconnect of Lots of Links |
VCF |
Vertical Converged Framework |
VLAN |
Virtual Local Area Network |
VRRP |
Virtual Router Redundancy Protocol |
VSRP |
Virtual Service Redundancy Protocol |
VXLAN |
Virtual eXtensible LAN |
WEB |
Web |
WIPS |
Wireless Intrusion Prevention System |
Using this document
This document categorizes system log messages by software module. The modules are ordered alphabetically. Except for OPENSRC, the system log messages for each module are listed in alphabetic order of their mnemonic names. The OPENSRC messages are unordered because they use the same mnemonic name (SYSLOG). For each OPENSRC message, the section title uses a short description instead of the mnemonic name.
This document explains messages in tables. Table 5 describes information provided in these tables.
Table 5 Message explanation table contents
Item |
Content |
Example |
Message text |
Presents the message description. |
ACL [UINT32] [STRING] [UINT64] packet(s). |
Variable fields |
Briefly describes the variable fields in the order that they appear in the message text. The variable fields are numbered in the "$Number" form to help you identify their location in the message text. |
$1: ACL number. $2: ID and content of an ACL rule. $3: Number of packets that matched the rule. |
Severity level |
Provides the severity level of the message. |
6 |
Example |
Provides a real message example. The examples do not include the "<PRI>TIMESTAMP Sysname %%vendor" part or the "Prefix TIMESTAMP Sysname" part, because information in this part varies with system settings. |
ACL/6/ACL_STATIS_INFO: ACL 2000 rule 0 permit source 1.1.1.1 0 logging 10000 packet(s). |
Explanation |
Explains the message, including the event or error cause. |
Number of packets that matched an ACL rule. This message is sent when the packet counter changes. |
Recommended action |
Provides recommended actions. For informational messages, no action is required. |
No action is required. |
AAA messages
This section contains AAA messages.
AAA_FAILURE
Message text |
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA failed. |
Variable fields |
$1: AAA type. $2: AAA scheme. $3: Service. $4: Username. |
Severity level |
5 |
Example |
AAA/5/AAA_FAILURE: -AAAType=AUTHOR-AAADomain=domain1-Service=login-UserName=cwf@system; AAA failed. |
Explanation |
An AAA request was rejected. The following are the common reasons: · No response was received from the server. · The username or password was incorrect. · The service type that the user applied for was incorrect. |
1. Verify that the device is correctly connected to the server. 2. Enter the correct username and password. 3. Verify that the server settings are the same as the settings on the device. 4. If the problem persists, contact H3C Support. |
AAA_LAUNCH
Message text |
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA launched. |
Variable fields |
Severity level |
6 |
Example |
AAA/6/AAA_LAUNCH: -AAAType=AUTHEN-AAADomain=domain1-Service=login-UserName=cwf@system; AAA launched. |
Explanation |
An AAA request was received. |
AAA_SUCCESS
Message text |
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA succeeded. |
Variable fields |
Severity level |
6 |
Example |
AAA/6/AAA_SUCCESS: -AAAType=AUTHOR-AAADomain=domain1-Service=login-UserName=cwf@system; AAA succeeded. |
Explanation |
An AAA request was accepted. |
ACL messages
This section contains ACL messages.
ACL_ACCELERATE_NO_RES
Message text |
Failed to accelerate [STRING] ACL [UINT32]. The resources are insufficient. |
Variable fields |
$1: ACL type. $2: ACL number. |
Severity level |
4 |
Example |
ACL/4/ACL_ACCELERATE_NO_RES: Failed to accelerate IPv6 ACL 2001. The resources are insufficient. |
Explanation |
Hardware resources were insufficient for accelerating an ACL. |
Delete some rules or disabled ACL acceleration for other ACLs to release hardware resources. |
Message text |
Failed to accelerate ACL [UINT32]. ACL acceleration supports only contiguous wildcard masks. |
Variable fields |
$1: ACL number. |
Severity level |
4 |
Example |
ACL/4/ACL_ACCELERATE_NONCONTIGUOUSMASK: Failed to accelerate ACL 2001. ACL acceleration supports only contiguous wildcard masks. |
Explanation |
ACL acceleration failed because rules containing noncontiguous wildcard masks exist in the ACL. |
Check the ACL rules and delete the unsupported configuration. |
Message text |
Failed to accelerate [STRING] ACL [UINT32]. The operation is not supported. |
Variable fields |
Severity level |
4 |
Example |
ACL/4/ACL_ACCELERATE_NOT_SUPPORT: Failed to accelerate IPv6 ACL 2001. The operation is not supported. |
Explanation |
ACL acceleration failed because the system does not support ACL acceleration. |
Message text |
Failed to accelerate IPv6 ACL [UINT32]. ACL acceleration does not support the rules that contain the hop-by-hop keywords. |
Variable fields |
$1: ACL number. |
Severity level |
4 |
Example |
ACL/4/ACL_ACCELERATE_NOT_SUPPORTHOPBYHOP: Failed to accelerate IPv6 ACL 2001. ACL acceleration does not support the rules that contain the hop-by-hop keywords. |
Explanation |
ACL acceleration failed for the IPv6 ACL because rules containing the hop-by-hop keyword exist in the ACL. |
Message text |
Failed to accelerate IPv6 ACL [UINT32]. ACL acceleration does not support specifying multiple TCP flags in one rule. |
Variable fields |
$1: ACL number. |
Severity level |
4 |
Example |
ACL/4/ACL_ACCELERATE_NOT_SUPPORTMULTITCPFLAG: Failed to accelerate IPv6 ACL 2001. ACL acceleration does not support specifying multiple TCP flags in one rule. |
Explanation |
ACL acceleration failed for the IPv6 ACL because rules containing multiple TCP flags exist in the ACL. |
ACL_ACCELERATE_UNK_ERR
Message text |
Failed to accelerate [STRING] ACL [UINT32]. |
Variable fields |
Severity level |
4 |
Example |
ACL/4/ACL_ACCELERATE_UNK_ERR: Failed to accelerate IPv6 ACL 2001. |
Explanation |
ACL acceleration failed because of an unknown error. |
ACL_IPV6_STATIS_INFO
Message text |
IPv6 ACL [UINT32] [STRING] [UINT64] packet(s). |
Variable fields |
$1: ACL number. $2: ID and content of an IPv6 ACL rule. $3: Number of packets that matched the rule. |
Severity level |
6 |
Example |
ACL/6/ACL_IPV6_STATIS_INFO: IPv6 ACL 2000 rule 0 permit source 1:1::/64 logging 1000 packet(s). |
Explanation |
The number of packets matching the IPv6 ACL rule changed. |
ACL_NO_MEM
Message text |
Failed to configure [STRING] ACL [UINT] due to lack of memory. |
Variable fields |
Severity level |
3 |
Example |
ACL/3/ACL_NO_MEM: Failed to configure ACL 2001 due to lack of memory. |
Explanation |
Configuring the ACL failed because memory is insufficient. |
Use the display memory-threshold command to check the memory usage. |
ACL_STATIS_INFO
Message text |
Variable fields |
$1: ACL number. $2: ID and content of an IPv4 ACL rule. $3: Number of packets that matched the rule. |
Severity level |
6 |
Example |
Explanation |
The number of packets matching the IPv4 ACL rule changed. |
ANCP messages
This section contains ANCP messages.
ANCP_INVALID_PACKET
Message text |
-NeighborName=[STRING]-State=[STRING]-MessageType=[STRING]; The [STRING] value [STRING] is wrong, and the value [STRING] is expected. |
Variable fields |
$1: ANCP neighbor name. $2: Neighbor state. $4: Field. $5: Wrong value of the field. $6: Expected value of the field. |
Severity level |
6 |
Example |
ANCP/6/ANCP_INVALID_PACKET: -NeighborName=Dslam-State=SYNSENT-MessageType=SYNACK; The Sender Instance value 0 is wrong, and the value 1 is expected. |
Explanation |
The system received an adjacency message that had a field with a wrong value. |
APMGR messages
This section contains access point management messages.
APMGR_AC_MEM_ALERT
Message text |
The memory utilization has reached the threshold. |
Variable fields |
N/A |
Severity level |
4 |
Example |
APMGR/4/APMGR_AC_MEM_ALERT: The memory utilization has reached the threshold. |
Explanation |
The AP failed to come online because the memory utilization exceeded the limit. |
Stop creating manual APs and prevent APs from coming online. |
APMGR_ADD_AP_FAIL
Message text |
AP [STRING] failed to come online using serial ID [STRING]: MAC address [STRING] is being used by AP [STRING]. |
Variable fields |
$1: AP name. $2: Serial ID. $3: MAC address. $4: AP name. |
Severity level |
4 |
Example |
APMGR/4/ APMGR_ADD_AP_FAIL: AP ap1 failed to come online using serial ID 01247ef96: MAC address 0023-7961-5201 is being used by AP ap2. |
Explanation |
The AP failed to come online because a manual AP that has the same MAC address already exists on the AC. |
Delete either the manual AP that has the MAC address or the serial ID. |
APMGR_ADDBAC_INFO
Message text |
Add BAS AC [STRING]. |
Variable fields |
$1: MAC address of the BAS AC. |
Severity level |
6 |
Example |
APMGR/6/APMGR_ADDBAC_INFO: Add BAS AC 3ce5-a616-28cd. |
Explanation |
The BAS AC was connected to the master AC. |
APMGR_AP_OFFLINE
Message text |
AP [STRING] went offline. State changed to Idle. |
Variable fields |
$1: AP name. |
Severity level |
6 |
Example |
APMGR/6/APMGR_AP_OFFLINE: AP ap1 went offline. State changed to Idle. |
Explanation |
The AP went offline. The state of the AP changed to Idle. |
If the AP went offline abnormally, check the debugging information to locate the issue and resolve it. |
APMGR_AP_ONLINE
Message text |
AP [STRING] went online. State changed to Run. |
Variable fields |
$1: AP name. |
Severity level |
6 |
Example |
APMGR/6/APMGR_AP_ONLINE: AP ap1 went online. State changed to Run. |
Explanation |
The AP came online. The state of the AP changed to Run. |
Message text |
System software image file [STRING] downloading through the CAPWAP tunnel to AC [STRING] completed. |
Variable fields |
$1: Image file name. $2: AC IP address. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWC_IMG_DOWNLOAD_COMPLETE: System software image file 5800.ipe downloading through the CAPWAP tunnel to AC 192.168.10.1 completed. |
Explanation |
The AP downloaded the image file from the AC successfully. |
APMGR_CWC_IMG_DOWNLOAD_START
Message text |
Started to download the system software image file [STRING] through the CAPWAP tunnel to AC [STRING]. |
Variable fields |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWC_IMG_DOWNLOAD_START: Started to download the system software image file 5800.ipe through the CAPWAP tunnel to AC 192.168.10.1. |
Explanation |
The AP started to download the image file from the AC. |
Make sure the AP is correctly connected to the AC. |
APMGR_CWC_IMG_NO_ENOUGH_SPACE
Message text |
Insufficient flash memory space for downloading system software image file [STRING]. |
Variable fields |
$1: Image file name. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWC_IMG_NO_ENOUGH_SPACE: Insufficient flash memory space for downloading system software image file 5800.ipe. |
Explanation |
The AP failed to download the image file from the AC because of insufficient flash memory. |
Delete files not in use from the AP. |
APMGR_CWC_LOCAL_AC_DOWN
Message text |
CAPWAP tunnel to Central AC [STRING] went down. Reason: [STRING]. |
Variable fields |
$1: IP address of the central AC. $2: Reason: · Added local AC IP address. · Deleted local AC IP address. · Local AC interface used for CAPWAP tunnel went down. · Local AC config changed. · N/A |
Severity level |
4 |
Example |
APMGR/4/APMGR_CWC_LOCAL_AC_DOWN: CAPWAP tunnel to Central AC 2.2.2.1 went down. Reason: Added local AC IP address. |
Explanation |
The CAPWAP tunnel between the central AC and the local AC was terminated for a specific reason. |
To resolve the issue: 5. Examine the network connection between the central AC and the local AC. 6. Verify that the central AC is correctly configured. 7. Verify that the local AC is correctly configured. 8. If the issue persists, contact H3C Support. |
APMGR_CWC_LOCAL_AC_UP
Message text |
CAPWAP tunnel to Central AC [STRING] went up. |
Variable fields |
$1: IP address of the central AC. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWC_LOCAL_AC_UP: CAPWAP tunnel to Central AC 2.2.2.1 went up. |
Explanation |
The central AC has established a CAPWAP tunnel with the local AC. |
APMGR_CWC_REBOOT
Message text |
AP in state [STRING] is rebooting. Reason: [STRING] |
Variable fields |
$1: AP state. $2: Reason: · AP was reset. · Image was downloaded successfully. · AP stayed in idle state for a long time. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWC_REBOOT: AP in State Run is rebooting. Reason: AP was reset. |
Explanation |
The AP rebooted for a specific reason. |
Message text |
File [STRING] successfully downloaded through the CAPWAP tunnel to AC [STRING]. |
Variable fields |
$1: File name. $2: AC IP address. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWC_RUN_DOWNLOAD_COMPLETE: File ac.cfg successfully downloaded through the CAPWAP tunnel to AC 192.168.10.1. |
Explanation |
The AP downloaded the file from the AC successfully. |
APMGR_CWC_RUN_DOWNLOAD_START
Message text |
Started to download the file [STRING] through the CAPWAP tunnel to AC [STRING]. |
Variable fields |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWC_RUN_DOWNLOAD_START: Started to download the file ac.cfg through the CAPWAP tunnel to AC 192.168.10.1. |
Explanation |
The AP started to download the file from the AC. |
APMGR_CWC_RUN_NO_ENOUGH_SPACE
Message text |
Insufficient flash memory space for downloading file [STRING]. |
Variable fields |
$1: File name. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWC_RUN_NO_ENOUGH_SPACE: Insufficient flash memory space for downloading file ac.cfg. |
Explanation |
The AP failed to download the file from the AC because of insufficient flash memory. |
APMGR_CWC_TUNNEL_DOWN
Message text |
CAPWAP tunnel to AC [STRING] went down. Reason: [STRING]. |
Variable fields |
$1: AC IP address. $2: Reason: · Added AP IP address. · Deleted AP IP address. · AP interface used for CAPWAP tunnel went down. · AP config changed. · AP was reset. · Number of echo retransmission attempts exceeded the limit. · Full retransmission queue. · Data channel timer expired. · Backup AC IP address changed. · Backup tunnel changed to master tunnel. · Failed to change backup tunnel to master tunnel. · Backup method changed. · N/A. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWC_TUNNEL_DOWN: CAPWAP tunnel to AC 192.168.10.1 went down. Reason: AP was reset. |
Explanation |
The CAPWAP tunnel between the AP and the AC was terminated for a specific reason. |
Examine the network connection between the AP and the AC. |
APMGR_CWC_TUNNEL_UP
Message text |
[STRING] CAPWAP tunnel to AC [STRING] went up. |
Variable fields |
$1: Tunnel type: · Master. · Backup. $2: AC IP address. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWC_TUNNEL_UP: Master CAPWAP tunnel to AC 192.168.10.1 went up. |
Explanation |
The AP was connected to the AC successfully and entered Run state. |
Message text |
System software image file [STRING] downloading through the CAPWAP tunnel for AP [STRING] completed. |
Variable fields |
$1: Image file name. $2: AP name. |
Severity level |
6 |
Example |
APMGR/6/APMGR_ CWS_IMG_DOWNLOAD_COMPLETE: System software image file 5800.ipe downloading through the CAPWAP tunnel for AP ap2 completed. |
Explanation |
APMGR_CWS_IMG_DOWNLOAD_START
Message text |
AP [STRING] started to download the system software image file [STRING]. |
Variable fields |
$1: AP name. $2: Image file name. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWS_IMG_DOWNLOAD_START: AP ap1 started to download the system software image file 5800.ipe. |
Explanation |
APMGR_CWS_LOCAL_AC_DOWN
Message text |
CAPWAP tunnel to local AC [STRING] went down. Reason: [STRING]. |
Variable fields |
$1: IP address of the local AC. $2: Reason: · Neighbor dead timer expired. · Local AC was deleted. · Serial number changed. · Processed join request in Run state. · Failed to retransmit message. · N/A |
Severity level |
4 |
Example |
APMGR/4/APMGR_CWS_LOCAL_AC_DOWN: CAPWAP tunnel to local AC 1.1.1.1 went down. Reason: Serial number changed. |
Explanation |
To resolve the issue: 9. Examine the network connection between the central AC and the local AC. 10. Verify that the central AC is correctly configured. 11. Verify that the local AC is correctly configured. 12. If the issue persists, contact H3C Support. |
APMGR_CWS_LOCAL_AC_UP
Message text |
CAPWAP tunnel to local AC [STRING] went up. |
Variable fields |
$1: IP address of the local AC. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWS_LOCAL_AC_UP: CAPWAP tunnel to local AC 1.1.1.1 went up. |
Explanation |
Message text |
File [STRING] successfully downloaded through the CAPWAP tunnel for AP [STRING]. |
Variable fields |
$1: File name. $2: AP name. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWS_RUN_DOWNLOAD_COMPLETE: File ac.cfg successfully downloaded through the CAPWAP tunnel for AP ap2. |
Explanation |
APMGR_CWS_RUN_DOWNLOAD_START
Message text |
AP [STRING] started to download the file [STRING]. |
Variable fields |
$1: AP name. $2: File name. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWS_RUN_DOWNLOAD_START: AP ap1 started to download the file ac.cfg. |
Explanation |
APMGR_CWS_TUNNEL_DOWN
Message text |
CAPWAP tunnel to AP [STRING] went down. Reason: [STRING]. |
Variable fields |
$1: AP name. $2: Reason: · Neighbor dead timer expired. · AP was reset. · AP was deleted. · Serial number changed. · Processed join request in Run state. · Failed to retransmit message. · Received WTP tunnel down event from AP. · Backup AC closed the backup tunnel. · Tunnel switched. · N/A. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWS_TUNNEL_DOWN: CAPWAP tunnel to AP ap1 went down. Reason: AP was reset. |
Explanation |
The AP went offline for a specific reason. |
To resolve the issue: 13. Examine the network connection between the AP and the AC. 14. Verify that the AP is correctly configured. 15. Verify that the AC is correctly configured. 16. If the issue persists, contact H3C Support. |
APMGR_CWS_TUNNEL_UP
Message text |
[STRING] CAPWAP tunnel to AP [STRING] went up. |
Variable fields |
$1: Tunnel type: · Master. · Backup. $2: AP name. |
Severity level |
6 |
Example |
APMGR/6/APMGR_CWS_TUNNEL_UP: Backup CAPWAP tunnel to AP ap1 went up. |
Explanation |
The AP came online and entered Run state. |
APMGR_DELBAC_INFO
Message text |
Delete BAS AC [STRING]. |
Variable fields |
Severity level |
6 |
Example |
APMGR/6/APMGR_DELBAC_INFO: Delete BAS AC 3ce5-a616-28cd. |
Explanation |
The BAS AC was disconnected from the master AC. |
APMGR_LOCAL_AC_OFFLINE
Message text |
Local AC [STRING] went offline. State changed to Idle. |
Variable fields |
$1: Name of the local AC. |
Severity level |
6 |
Example |
APMGR/6/APMGR_LOCAL_AC_OFFLINE: Local AC ac1 went offline. State changed to Idle. |
Explanation |
The local AC went offline. The state of the local AC changed to Idle. |
17. If the local AC went offline abnormally, check the debugging information to locate the issue and resolve it. 18. If the issue persists, contact H3C Support. |
APMGR_LOCAL_AC_ONLINE
Message text |
Local AC [STRING] went online. State changed to Run. |
Variable fields |
Severity level |
6 |
Example |
APMGR/6/APMGR_LOCAL_AC_ONLINE: Local AC ac1 went online. State changed to Run. |
Explanation |
The local AC came online. The state of the local AC changed to Run. |
ARP messages
This section contains ARP messages.
ARP_ACTIVE_ACK_NO_REPLY
Message text |
No ARP reply from IP [STRING] was received on interface [STRING]. |
Variable fields |
$1: IP address. $2: Interface name. |
Severity level |
6 |
Example |
ARP/6/ARP_ACTIVE_ACK_NO_REPLY: No ARP reply from IP 192.168.10.1 was received on interface GigabitEthernet1/0/1. |
Explanation |
The ARP active acknowledgement feature did not receive an ARP reply after it sent an ARP request to the sender IP of an ARP message. This message indicates the risk of attacks. |
19. Verify that the learned ARP entries on the device are consistent with the existing legal devices. When gateways and servers are on the network, check the ARP entries for these devices first. 20. If the ARP entries are correct and the attack continues, contact H3C Support. |
Message text |
Interface [STRING] received from IP [STRING] an ARP reply that was not requested by the device. |
Variable fields |
$1: Interface name. $2: IP address. |
Severity level |
6 |
Example |
ARP/6/ARP_ACTIVE_ACK_NOREQUESTED_REPLY: Interface GigabitEthernet1/0/1 received from IP 192.168.10.1 an ARP reply that was not requested by the device. |
Explanation |
The ARP active acknowledgement feature received an unsolicited ARP reply from a sender IP. This message indicates the risk of attacks. |
No action is required. The device discards the ARP reply automatically. |
ARP_BINDRULETOHW_FAILED
Message text |
Failed to download binding rule to hardware on the interface [STRING], SrcIP [IPADDR], SrcMAC [MAC], VLAN [UINT16], Gateway MAC [MAC]. |
Variable fields |
$1: Interface name. $2: Source IP address. $3: Source MAC address. $4: VLAN ID. $5: Gateway MAC address. |
Severity level |
5 |
Example |
ARP/5/ARP_BINDRULETOHW_FAILED: Failed to download binding rule to hardware on the interface GigabitEthernet1/0/1, SrcIP 1.1.1.132, SrcMAC 0015-E944-A947, VLAN 1, Gateway MAC 00A1-B812-1108. |
Explanation |
The system failed to set a binding rule to the hardware on an interface. The message is sent in any of the following situations: · The resources are not sufficient for the operation. · The memory is not sufficient for the operation. · A hardware error occurs. |
To resolve the problem: 21. Execute the display qos-acl resource command to check if the ACL resources for the operation are sufficient. ¡ If yes, proceed to step 2. ¡ If no, delete unnecessary configuration to release ACL resources. If no configuration can be deleted, proceed to step 2. 22. Execute the display memory command to check if the memory for the operation is sufficient. ¡ If yes, proceed to step 3. ¡ If no, delete unnecessary configuration to release memory. If no configuration can be deleted, proceed to step 3. 23. Delete the configuration and perform the operation again. |
ARP_DETECTION_LOG
Message text |
Detected an ARP attack on interface [STRING]: IP [STRING], MAC [STRING], VLAN [STRING]. [UINT32] packet(s) dropped. |
Variable fields |
$1: Interface name. $2: IP address. $3: MAC address. $4: VLAN ID. $5: Number of dropped packets. |
Severity level |
5 |
Example |
ARP/5/ARP_INSPECTION: -MDC=1; Detected an ARP attack on interface GigabitEthernet1/0/1: IP 1.1.1.1, MAC 1-1-1, VLAN 100. 2 packet(s) dropped. |
Explanation |
An ARP attack was detected on an interface and attack packets were dropped. |
Check the source of the ARP attack. |
ARP_DUPLICATE_IPADDR_DETECT
Message text |
Detected an IP address conflict. The device with MAC address [STRING] connected to interface [STRING] in VSI [STRING] and the device with MAC address [STRING] connected to interface [STRING] in VSI [STRING] were using the same IP address [IPADDR]. |
Variable fields |
$1: MAC address. $2: Interface name. (The interface can be a tunnel interface, Layer 3 interface, or Ethernet service instance.) $3: VSI name. $4: MAC address. $5: Interface name. (The interface can be a tunnel interface, Layer 3 interface, or Ethernet service instance.) $6: VSI name. $7: Conflicting IP address. |
Severity level |
4 |
Example |
ARP/4/ARP_DUPLICATE_IPADDR_DETECT: Detected an IP address conflict. The device with MAC address 00-00-01 connected to interface GigabitEthernet1/0/1 service-instance 1000 in VSI vpna and the device with MAC address 00-00-02 connected to interface tunnel 10 in VSI vpna were using the same IP address 192.168.1.1. |
Explanation |
This message is sent when an interface receives an ARP message in which the sender information conflicts with an existing ARP entry. The sender IP address is the same as the IP address in the entry, but the MAC addresses are different. |
Change the IP address on either of the two devices. |
ARP_DYNAMIC
Message text |
The maximum number of dynamic ARP entries for the device reached. |
Variable fields |
N/A |
Severity level |
6 |
Example |
ARP/6/ARP_DYNAMIC: The maximum number of dynamic ARP entries for the device reached. |
Explanation |
The maximum number of dynamic ARP entries for the device was reached. |
ARP_DYNAMIC_IF
Message text |
The maximum number of dynamic ARP entries for interface [STRING] reached. |
Variable fields |
$1: Interface name. |
Severity level |
6 |
Example |
ARP/6/ARP_DYNAMIC_IF: The maximum number of dynamic ARP entries for interface GigabitEthernet1/0/1 reached. |
Explanation |
The maximum number of dynamic ARP entries for the specified interface was reached. |
ARP_DYNAMIC_SLOT
Message text |
Pattern 1: The maximum number of dynamic ARP entries for slot [INT32] reached. Pattern 2: The maximum number of dynamic ARP entries for chassis [INT32] slot [INT32] reached. |
Variable fields |
Pattern 1: $1: Slot number. Pattern 2: $1: Chassis number. $2: Slot number. |
Severity level |
6 |
Example |
ARP/6/ARP_DYNAMIC_SLOT: The maximum number of dynamic ARP entries for slot 2 reached. |
Explanation |
Pattern 1: The maximum number of dynamic ARP entries for the slot was reached. Pattern 2: The maximum number of dynamic ARP entries for the slot on the chassis was reached. |
ARP_ENTRY_CONFLICT
Message text |
The software entry for [STRING] on [STRING] and the hardware entry did not have the same [STRING]. |
Variable fields |
$1: IP address. $2: VPN instance name. If the ARP entry belongs to the public network, this field displays the public network. $3: Inconsistent items: ¡ MAC address. ¡ output interface. ¡ output port. ¡ outermost layer VLAN ID. ¡ second outermost layer VLAN ID. ¡ VSI index. ¡ link ID. |
Severity level |
6 |
Example |
ARP/6/ARP_ENTRY_CONFLICT: The software entry for 1.1.1.1 on the VPN a and the hardware entry did not have the same MAC address, output port, VSI index, and link ID. ARP/6/ARP_ENTRY_CONFLICT: The software entry for 1.1.1.2 on the public network and the hardware entry did not have the same MAC address, output port, VSI index, and link ID. |
Explanation |
The software entry for the specified IP address is not the same as the hardware entry. For example, they do not have the same output interface. |
No action is required. ARP automatically refreshes the hardware entries. |
ARP_HOST_IP_CONFLICT
Message text |
Variable fields |
$1: IP address. $2: Interface name. $3: Interface name. |
Severity level |
4 |
Example |
Explanation |
The sender IP address in a received ARP message conflicted with the IP address of a host connected to another interface. |
Check whether the hosts that send the ARP messages are legitimate. Disconnect the illegal host from the network. |
ARP_LOCALPROXY_ENABLE_FAILED
Message text |
Failed to enable local proxy ARP on interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
ARP/4/ARP_LOCALPROXY_ENABLE_FAILED: -MDC=1-Slot=2; Failed to enable local proxy ARP on interface VSI-interface 1. |
Explanation |
This message is sent when the device fails to enable local proxy ARP on an interface in a slot. If the interface resides on the MPU, the slot number is 0. |
24. Verify that the card supports local proxy ARP. 25. Verify that sufficient hardware resources are available. |
ARP_RATE_EXCEEDED
Message text |
The ARP packet rate ([UINT32] pps) exceeded the rate limit ([UINT32] pps) on interface [STRING] in the last [UINT32] seconds. |
Variable fields |
$1: ARP packet rate. $2: ARP limit rate. $3: Interface name. $4: Interval time. |
Severity level |
4 |
Example |
ARP/4/ARP_RATE_EXCEEDED: The ARP packet rate (100 pps) exceeded the rate limit (80 pps) on interface GigabitEthernet1/0/1 in the last 10 seconds. |
Explanation |
An interface received ARP messages at a higher rate than the rate limit. |
Verify that the hosts at the sender IP addresses are legitimate. |
ARP_RATELIMIT_NOTSUPPORT
Message text |
Pattern 1: ARP packet rate limit is not support on slot [INT32]. Pattern 2: ARP packet rate limit is not support on chassis [INT32] slot [INT32]. |
Variable fields |
Severity level |
6 |
Example |
ARP/6/ARP_RATELIMIT_NOTSUPPORT: ARP packet rate limit is not support on slot 2. |
Explanation |
Pattern 1: ARP packet rate limit is not supported on the slot. Pattern 2: ARP packet rate limit is not supported on the slot of the chassis was reached. |
Verify that the host at the sender IP address is legitimate. |
ARP_SENDER_IP_INVALID
Message text |
Sender IP [STRING] was not on the same network as the receiving interface [STRING]. |
Variable fields |
Severity level |
6 |
Example |
ARP/6/ARP_SENDER_IP_INVALID: Sender IP 192.168.10.2 was not on the same network as the receiving interface GigabitEthernet1/0/1. |
Explanation |
The sender IP of a received ARP message was not on the same network as the receiving interface. |
ARP_SENDER_MAC_INVALID
Message text |
Sender MAC [STRING] was not identical to Ethernet source MAC [STRING] on interface [STRING]. |
Variable fields |
$1: MAC address. $2: MAC address. $3: Interface name. |
Severity level |
6 |
Example |
ARP/6/ARP_SENDER_MAC_INVALID: Sender MAC 0000-5E14-0E00 was not identical to Ethernet source MAC 0000-5C14-0E00 on interface GigabitEthernet1/0/1. |
Explanation |
An interface received an ARP message. The sender MAC address in the message body was not identical to the source MAC address in the Ethernet header. |
Verify that the host at the sender MAC address is legitimate. |
ARP_SENDER_SMACCONFLICT
Message text |
Packet was discarded because its sender MAC address was the MAC address of the receiving interface. Interface: [STRING], sender IP: [STRING], target IP: [STRING]. |
Variable fields |
$1: Interface name. $2: Sender IP address. $3: Target IP address. |
Severity level |
6 |
Example |
ARP/6/ ARP_SENDER_SMACCONFLICT: Packet discarded for the sender MAC address is the same as the receiving interface. Interface: GigabitEthernet1/0/1 sender IP: 1.1.2.2 target IP: 1.1.2.1, |
Explanation |
The sender MAC address of a received ARP packet conflicts with the MAC address of the device. |
ARP_SENDER_SMACCONFLICT_VSI
Message text |
Packet was discarded because its sender MAC address was the MAC address of the receiving interface. Interface: [STRING], sender IP: [STRING], target IP: [STRING],VSI index: [UINT32], link ID: [UINT32]. |
Variable fields |
$1: Interface name. $2: Sender IP address. $3: Target IP address. $4: VSI index. $5: Link ID. |
Severity level |
6 |
Example |
ARP/6/ ARP_SENDER_SMACCONFLICT_VSI: Packet discarded for the sender MAC address is the same as the receiving interface. Interface: VSI3 sender IP: 1.1.2.2 target IP: 1.1.2.1, VSI Index: 2, Link ID: 0 |
Explanation |
The sender MAC address of a received ARP packet conflicts with the MAC address of the device. The receiving interface is a VSI interface. |
ARP_SRC_MAC_FOUND_ATTACK
Message text |
An attack from MAC [STRING] was detected on interface [STRING]. |
Variable fields |
$1: MAC address. $2: Interface name. |
Severity level |
6 |
Example |
ARP/6/ARP_SRC_MAC_FOUND_ATTACK: An attack from MAC 0000-5E14-0E00 was detected on interface GigabitEthernet1/0/1. |
Explanation |
The source MAC-based ARP attack detection feature received more ARP packets from the same MAC address within 5 seconds than the specified threshold. This message indicates the risk of attacks. |
Verify that the host at the source MAC address is legitimate. |
ARP_SUP_ENABLE_FAILED
Message text |
Failed to enable ARP flood suppression on VSI [STRING]. |
Variable fields |
$1: VSI name. |
Severity level |
4 |
Example |
ARP/4/ARP_SUP_ENABLE_FAILED: -MDC=1; Failed to enable ARP flood suppression on VSI vpna. |
Explanation |
This message is sent when the system failed to enable ARP flood suppression for a VSI. The minimum interval between two log messages is 2 seconds. To make the system send the message successfully, wait for a minimum of 2 seconds before you enable ARP flood suppression for another VSI. |
26. Verify that the device supports ARP flood suppression. 27. Verify that the hardware resources are sufficient. |
ARP_TARGET_IP_INVALID
Message text |
Target IP [STRING] was not the IP of the receiving interface [STRING]. |
Variable fields |
Severity level |
6 |
Example |
ARP/6/ARP_TARGET_IP_INVALID: Target IP 192.168.10.2 was not the IP of the receiving interface GigabitEthernet1/0/1. |
Explanation |
The target IP address of a received ARP message was not the IP address of the receiving interface. |
ARP_THRESHOLD_REACHED
Message text |
The alarm threshold for dynamic ARP entry learning was reached on interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
ARP/4/ARP_THRESHOLD_REACHED: The alarm threshold for dynamic ARP entry learning was reached on interface GigabitEthernet1/0/1. |
Explanation |
This message is sent when the alarm threshold for dynamic ARP learning was reached on GigabitEthernet 1/0/1. |
Verify that the number of learned dynamic ARP entries matches the actual number of devices in the network and no ARP attack sources exist in the network. |
Message text |
Detected a user IP address conflict. New user (MAC [STRING], SVLAN [STRING], CVLAN [STRING]) on interface [STRING] and old user (MAC [STRING], SVLAN [STRING], CVLAN [STRING]) on interface [STRING] were using the same IP address [IPADDR]. |
Variable fields |
$1: MAC address of a new user. $2: Outer VLAN to which the new user belongs. $3: Inner VLAN to which the new user belongs. $4: Name of the interface connecting to the new user. $5: MAC address of an old user. $6: Outer VLAN to which the old user belongs. $7: Inner VLAN to which the old user belongs. $8: Name of the interface connecting to the old user. $9: IP address. |
Severity level |
6 |
Example |
ARP/6/ARP_USER_DUPLICATE_IPADDR_DETECT: Detected a user IP address conflict. New user (MAC 0010-2100-01e1, SVLAN 100, CVLAN 10) on interface GigabitEthernet1/0/1 and old user (MAC 0120-1e00-0102, SVLAN 100, CVLAN 10) on interface GigabitEthernet1/0/1 were using the same IP address 192.168.1.1. |
Explanation |
ARP detected a user IP address conflict. The IP address of a new user is the same as the IP address of an old user. |
Verify that all users have different IP addresses. |
ARP_USER_MOVE_DETECT
Message text |
Detected a user (IP address [IPADDR], MAC address [STRING]) moved to another interface. Before user move: interface [STRING], SVLAN [STRING], CVLAN [STRING]. After user move: interface [STRING], SVLAN [STRING], CVLAN [STRING]. |
Variable fields |
$1: IP address of the user. $2: MAC address of the user. $3: Interface name before the migration. $4: Outer VLAN to which the user belongs before the migration. $5: Inner VLAN to which the user belongs before the migration. $6: Interface name after the migration. $7: Outer VLAN to which the user belongs after the migration. $8: Inner VLAN to which the user belongs after the migration. |
Severity level |
6 |
Example |
ARP/6/ARP_USER_MOVE_DETECT: Detected a user (IP address 192.168.1.1, MAC address 0010-2100-01e1) moved to another interface. Before user move: interface GigabitEthernet1/0/1, SVLAN 100, CVLAN 10. After user move: interface GigabitEthernet1/0/2, SVLAN 100, CVLAN 10. |
Explanation |
ARP detected a user accesses the network through another port. |
Use the display arp user-move record command to verify that the migration is legitimate. |
DUPIFIP
Message text |
Duplicate address [STRING] on interface [STRING], sourced from [STRING]. |
Variable fields |
$1: IP address. $2: Interface name. $3: MAC Address. |
Severity level |
6 |
Example |
ARP/6/DUPIFIP: Duplicate address 1.1.1.1 on interface GigabitEthernet1/0/1, sourced from 0015-E944-A947. |
Explanation |
ARP detected a duplicate address. The sender IP in the received ARP packet was being used by the receiving interface. |
Modify the IP address configuration. |
DUPIP
Message text |
IP address [STRING] conflicted with global or imported IP address, sourced from [STRING]. |
Variable fields |
$1: IP address. $2: MAC Address. |
Severity level |
6 |
Example |
ARP/6/DUPIP: IP address 30.1.1.1 conflicted with global or imported IP address, sourced from 0000-0000-0001. |
Explanation |
The sender IP address of the received ARP packet conflicted with the global or imported IP address. |
DUPVRRPIP
Message text |
IP address [STRING] conflicted with VRRP virtual IP address on interface [STRING], sourced from [STRING]. |
Variable fields |
$1: IP address. $2: Interface name. $3: MAC address. |
Severity level |
6 |
Example |
ARP/6/DUPVRRPIP: IP address 1.1.1.1 conflicted with VRRP virtual IP address on interface GigabitEthernet1/0/1, sourced from 0015-E944-A947. |
Explanation |
The sender IP address of the received ARP packet conflicted with the VRRP virtual IP address. |
ATK messages
This section contains attack detection and prevention messages.
ATK_ICMP_ADDRMASK_REQ
Message text |
IcmpType(1058)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: ICMP message type. $2: Receiving interface name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Actions against the attack. $8: Start time of the attack. $9: End time of the attack. $10: Attack times. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ADDRMASK_REQ: IcmpType(1058)=17; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP address mask request logs are aggregated. |
ATK_ICMP_ADDRMASK_REQ_RAW
Message text |
IcmpType(1058)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: ICMP message type. $2: Receiving interface name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ADDRMASK_REQ_RAW: IcmpType(1058)=17; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP address mask requests of the same attributes, this message is sent only when the first request is received. If log aggregation is disabled, this message is sent every time an ICMP address mask request is received. |
ATK_ICMP_ADDRMASK_REQ_RAW_SZ
Message text |
IcmpType(1058)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: ICMP message type. $2: Source security zone name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ADDRMASK_REQ_RAW_SZ: IcmpType(1058)=17; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_ADDRMASK_REQ_SZ
Message text |
IcmpType(1058)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: ICMP message type. $2: Source security zone name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Actions against the attack. $8: Start time of the attack. $9: End time of the attack. $10: Attack times. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ADDRMASK_REQ_SZ: IcmpType(1058)=17; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_ADDRMASK_RPL
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ADDRMASK_RPL: IcmpType(1058)=18; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP address mask reply logs are aggregated. |
ATK_ICMP_ADDRMASK_RPL_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ADDRMASK_RPL_RAW: IcmpType(1058)=18; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP address mask replies of the same attributes, this message is sent only when the first reply is received. If log aggregation is disabled, this message is sent every time an ICMP address mask reply is received. |
ATK_ICMP_ADDRMASK_RPL_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ADDRMASK_RPL_RAW_SZ: IcmpType(1058)=18; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_ADDRMASK_RPL_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ADDRMASK_RPL_SZ: IcmpType(1058)=18; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_ECHO_REQ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ECHO_REQ: IcmpType(1058)=8; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP echo request logs are aggregated. |
ATK_ICMP_ECHO_REQ_RAW
Message text |
IcmpType(1058)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; DstPort(1004)=[UINT16]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: ICMP message type. $2: Receiving interface name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Destination port number. $7: Name of the receiving VPN instance. $8: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ECHO_REQ_RAW: IcmpType(1058)=8; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DstPort(1004)=22; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP echo requests of the same attributes, this message is sent only when the first request is received. If log aggregation is disabled, this message is sent every time an ICMP echo request is received. |
ATK_ICMP_ECHO_REQ_RAW_SZ
Message text |
IcmpType(1058)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; DstPort(1004)=[UINT16]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: ICMP message type. $2: Source security zone name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Destination port number. $7: Name of the receiving VPN instance. $8: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ECHO_REQ_RAW_SZ: IcmpType(1058)=8; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DstPort(1004)=22; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_ECHO_REQ_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ECHO_REQ_SZ: IcmpType(1058)=8; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_ECHO_RPL
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ECHO_RPL: IcmpType(1058)=0; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP echo reply logs are aggregated. |
ATK_ICMP_ECHO_RPL_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ECHO_RPL_RAW: IcmpType(1058)=0; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP echo replies of the same attributes, this message is sent only when the first reply is received. If log aggregation is disabled, this message is sent every time an ICMP echo reply is received. |
ATK_ICMP_ECHO_RPL_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ECHO_RPL_RAW_SZ: IcmpType(1058)=0; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_ECHO_RPL_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_ECHO_RPL_SZ: IcmpType(1058)=0; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_FLOOD
Message text |
RcvIfName(1023)=[STRING]; DstIPAddr(1007)=[IPADDR]; DstPort(1008)=[UINT16]; RcvVPNInstance(1041)=[STRING]; UpperLimit(1048)=[UINT32]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Destination IP address. $3: Destination port number. $4: Name of the receiving VPN instance. $5: Rate limit. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
This message is sent when the number of ICMP packets sent to a destination per second exceeds the rate limit. |
ATK_ICMP_FLOOD_SZ
Message text |
SrcZoneName(1025)=[STRING]; DstIPAddr(1007)=[IPADDR]; DstPort(1008)=[UINT16]; RcvVPNInstance(1041)=[STRING]; UpperLimit(1048)=[UINT32]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Destination IP address. $3: Destination port number. $4: Name of the receiving VPN instance. $5: Rate limit. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
ATK_ICMP_INFO_REQ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_INFO_REQ: IcmpType(1058)=15; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP information request logs are aggregated. |
ATK_ICMP_INFO_REQ_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_INFO_REQ_RAW: IcmpType(1058)=15; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP information requests of the same attributes, this message is sent only when the first request is received. If log aggregation is disabled, this message is sent every time an ICMP information request is received. |
ATK_ICMP_INFO_REQ_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_INFO_REQ_RAW_SZ: IcmpType(1058)=15; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_INFO_REQ_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_INFO_REQ_SZ: IcmpType(1058)=15; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_INFO_RPL
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_INFO_RPL: IcmpType(1058)=16; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP information reply logs are aggregated. |
ATK_ICMP_INFO_RPL_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_INFO_RPL_RAW: IcmpType(1058)=16; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP information replies of the same attributes, this message is sent only when the first reply is received. If log aggregation is disabled, this message is sent every time an ICMP information reply is received. |
ATK_ICMP_INFO_RPL_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_INFO_RPL_RAW_SZ: IcmpType(1058)=16; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_INFO_RPL_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_INFO_RPL_SZ: IcmpType(1058)=16; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_LARGE
Message text |
Variable fields |
$1: Receiving interface name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. $8: End time of the attack. $9: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_LARGE: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
This message is sent when large ICMP packet logs are aggregated. |
ATK_ICMP_LARGE_RAW
Message text |
Variable fields |
$1: Receiving interface name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_LARGE_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for large ICMP packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a large ICMP packet is received. |
ATK_ICMP_LARGE_RAW_SZ
Message text |
Variable fields |
$1: Source security zone name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_LARGE_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_LARGE_SZ
Message text |
Variable fields |
$1: Source security zone name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. $8: End time of the attack. $9: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_LARGE_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_PARAPROBLEM
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_PARAPROBLEM: IcmpType(1058)=12; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP parameter problem logs are aggregated. |
ATK_ICMP_PARAPROBLEM_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_PARAPROBLEM_RAW: IcmpType(1058)=12; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP parameter problem packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMP parameter problem packet is received. |
ATK_ICMP_PARAPROBLEM_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_PARAPROBLEM_RAW_SZ: IcmpType(1058)=12; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_PARAPROBLEM_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_PARAPROBLEM_SZ: IcmpType(1058)=12; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_PINGOFDEATH
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_PINGOFDEATH: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for ICMP packets larger than 65535 bytes with the MF flag set to 0. |
ATK_ICMP_PINGOFDEATH_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_PINGOFDEATH_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for the ping of death attack. The attack uses ICMP packets larger than 65535 bytes with the MF flag set to 0. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_ICMP_PINGOFDEATH_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_PINGOFDEATH_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_PINGOFDEATH_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_PINGOFDEATH_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_REDIRECT
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_REDIRECT: IcmpType(1058)=5; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP redirect logs are aggregated. |
ATK_ICMP_REDIRECT_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_REDIRECT_RAW: IcmpType(1058)=5; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP redirect packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMP redirect packet is received. |
ATK_ICMP_REDIRECT_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_REDIRECT_RAW_SZ: IcmpType(1058)=5; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_REDIRECT_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_REDIRECT_SZ: IcmpType(1058)=5; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_SMURF
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_SMURF: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for ICMP echo requests whose destination IP address is one of the following addresses: · A broadcast or network address of A, B, or C class. · An IP address of D or E class. · The broadcast or network address of the network where the receiving interface resides. |
ATK_ICMP_SMURF_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_SMURF_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for the smurf attack. The attack uses ICMP echo requests with the destination IP address being one of the following addresses: · A broadcast or network address of A, B, or C class. · An IP address of D or E class. · The broadcast or network address of the network where the receiving interface resides. If log aggregation is enabled, for requests of the same attributes, this message is sent only when the first request is received. If log aggregation is disabled, this message is sent every time a request is received. |
ATK_ICMP_SMURF_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_SMURF_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_SMURF_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_SMURF_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_SOURCEQUENCH
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_SOURCEQUENCH: IcmpType(1058)=4; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP source quench logs are aggregated. |
Recommended action |
ATK_ICMP_SOURCEQUENCH_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_SOURCEQUENCH_RAW: IcmpType(1058)=4; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP source quench packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMP source quench packet is received. |
No action is required. |
ATK_ICMP_SOURCEQUENCH_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_SOURCEQUENCH_RAW_SZ: IcmpType(1058)=4; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_SOURCEQUENCH_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_SOURCEQUENCH_SZ: IcmpType(1058)=4; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_TIMEEXCEED
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TIMEEXCEED: IcmpType(1058)=11; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP time exceeded logs are aggregated. |
ATK_ICMP_TIMEEXCEED_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TIMEEXCEED_RAW: IcmpType(1058)=11; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP time exceeded packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMP time exceeded packet is received. |
ATK_ICMP_TIMEEXCEED_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TIMEEXCEED_RAW_SZ: IcmpType(1058)=11; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_TIMEEXCEED_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TIMEEXCEED_SZ: IcmpType(1058)=11; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_TRACEROUTE
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_TRACEROUTE: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for ICMP time exceeded packets of code 0. |
ATK_ICMP_TRACEROUTE_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_TRACEROUTE_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP time exceeded packets of code 0 of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMP time exceeded packet of code 0 is received. |
ATK_ICMP_TRACEROUTE_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_TRACEROUTE_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_TRACEROUTE_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMP_TRACEROUTE_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_TSTAMP_REQ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TSTAMP_REQ: IcmpType(1058)=13; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP timestamp logs are aggregated. |
ATK_ICMP_TSTAMP_REQ_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TSTAMP_REQ_RAW: IcmpType(1058)=13; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP timestamp packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMP timestamp packet is received. |
ATK_ICMP_TSTAMP_REQ_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TSTAMP_REQ_RAW_SZ: IcmpType(1058)=13; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_TSTAMP_REQ_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TSTAMP_REQ_SZ: IcmpType(1058)=13; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_TSTAMP_RPL
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TSTAMP_RPL: IcmpType(1058)=14; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP timestamp reply logs are aggregated. |
ATK_ICMP_TSTAMP_RPL_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TSTAMP_RPL_RAW: IcmpType(1058)=14; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP timestamp replies of the same attributes, this message is sent only when the first reply is received. If log aggregation is disabled, this message is sent every time an ICMP timestamp reply is received. |
ATK_ICMP_TSTAMP_RPL_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TSTAMP_RPL_RAW_SZ: IcmpType(1058)=14; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_TSTAMP_RPL_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TSTAMP_RPL_SZ: IcmpType(1058)=14; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_TYPE
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TYPE: IcmpType(1058)=38; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for user-defined ICMP packets. |
ATK_ICMP_TYPE_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TYPE_RAW: IcmpType(1058)=38; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for user-defined ICMP packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a user-defined ICMP packet is received. |
ATK_ICMP_TYPE_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TYPE_RAW_SZ: IcmpType(1058)=38; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_TYPE_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_TYPE_SZ: IcmpType(1058)=38; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMP_UNREACHABLE
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_UNREACHABLE: IcmpType(1058)=3; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMP destination unreachable logs are aggregated. |
ATK_ICMP_UNREACHABLE_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_UNREACHABLE_RAW: IcmpType(1058)=3; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMP destination unreachable packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMP destination unreachable packet is received. |
ATK_ICMP_UNREACHABLE_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_UNREACHABLE_RAW_SZ: IcmpType(1058)=3; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMP_UNREACHABLE_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMP_UNREACHABLE_SZ: IcmpType(1058)=3; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011091319; EndTime_c(1012)=20131011091819; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_DEST_UNREACH
Message text |
Icmpv6Type(1059)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: ICMPv6 message type. $2: Receiving interface name. $3: Source IPv6 address. $4: Destination IPv6 address. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. $8: End time of the attack. $9: Attack times. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_DEST_UNREACH: Icmpv6Type(1059)=133; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMPv6 destination unreachable logs are aggregated. |
ATK_ICMPV6_DEST_UNREACH_RAW
Message text |
Icmpv6Type(1059)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: ICMPv6 message type. $2: Receiving interface name. $3: Source IPv6 address. $4: Destination IPv6 address. $5: Name of the receiving VPN instance. $6: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_DEST_UNREACH_RAW: Icmpv6Type(1059)=133; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMPv6 destination unreachable packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMPv6 destination unreachable packet is received. |
ATK_ICMPV6_DEST_UNREACH_RAW_SZ
Message text |
Icmpv6Type(1059)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: ICMPv6 message type. $2: Source security zone name. $3: Source IPv6 address. $4: Destination IPv6 address. $5: Name of the receiving VPN instance. $6: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_DEST_UNREACH_RAW_SZ: Icmpv6Type(1059)=133; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_DEST_UNREACH_SZ
Message text |
Icmpv6Type(1059)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: ICMPv6 message type. $2: Source security zone name. $3: Source IPv6 address. $4: Destination IPv6 address. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. $8: End time of the attack. $9: Attack times. |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_DEST_UNREACH_SZ: Icmpv6Type(1059)=133; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_ECHO_REQ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_ECHO_REQ: Icmpv6Type(1059)=128; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMPv6 echo request logs are aggregated. |
ATK_ICMPV6_ECHO_REQ_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_ECHO_REQ_RAW: Icmpv6Type(1059)=128; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMPv6 echo requests of the same attributes, this message is sent only when the first request is received. If log aggregation is disabled, this message is sent every time an ICMPv6 echo request is received. |
ATK_ICMPV6_ECHO_REQ_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_ECHO_REQ_RAW_SZ: Icmpv6Type(1059)=128; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_ECHO_REQ_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_ECHO_REQ_SZ: Icmpv6Type(1059)=128; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_ECHO_RPL
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_ECHO_RPL: Icmpv6Type(1059)=129; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMPv6 echo reply logs are aggregated. |
ATK_ICMPV6_ECHO_RPL_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_ECHO_RPL_RAW: Icmpv6Type(1059)=129; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMPv6 echo replies of the same attributes, this message is sent only when the first reply is received. If log aggregation is disabled, this message is sent every time an ICMPv6 echo reply is received. |
ATK_ICMPV6_ECHO_RPL_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_ECHO_RPL_RAW_SZ: Icmpv6Type(1059)=129; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_ECHO_RPL_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_ECHO_RPL_SZ: Icmpv6Type(1059)=129; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_FLOOD
Message text |
RcvIfName(1023)=[STRING]; DstIPv6Addr(1037)=[IPADDR]; DstPort(1008)=[UINT16]; RcvVPNInstance(1041)=[STRING]; UpperLimit(1048)=[UINT32]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Destination IPv6 address. $3: Destination port number. $4: Name of the receiving VPN instance. $5: Rate limit. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMPV6_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPv6Addr(1007)=2002::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
This message is sent when the number of ICMPv6 packets sent to a destination per second exceeds the rate limit. |
ATK_ICMPV6_FLOOD_SZ
Message text |
SrcZoneName(1025)=[STRING]; DstIPv6Addr(1037)=[IPADDR]; DstPort(1008)=[UINT16]; RcvVPNInstance(1041)=[STRING]; UpperLimit(1048)=[UINT32]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Destination IPv6 address. $3: Destination port number. $4: Name of the receiving VPN instance. $5: Rate limit. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMPV6_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPv6Addr(1007)=2002::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
ATK_ICMPV6_GROUPQUERY
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPQUERY: Icmpv6Type(1059)=130; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMPv6 multicast listener query logs are aggregated. |
ATK_ICMPV6_GROUPQUERY_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPQUERY_RAW: Icmpv6Type(1059)=130; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMPv6 multicast listener queries of the same attributes, this message is sent only when the first query is received. If log aggregation is disabled, this message is sent every time an ICMPv6 multicast listener query is received. |
ATK_ICMPV6_GROUPQUERY_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPQUERY_RAW_SZ: Icmpv6Type(1059)=130; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_GROUPQUERY_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPQUERY_SZ: Icmpv6Type(1059)=130; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_GROUPREDUCTION
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPREDUCTION: Icmpv6Type(1059)=132; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMPv6 multicast listener done logs are aggregated. |
ATK_ICMPV6_GROUPREDUCTION_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPREDUCTION_RAW: Icmpv6Type(1059)=132; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMPv6 multicast listener done packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMPv6 multicast listener done packet is received. |
ATK_ICMPV6_GROUPREDUCTION_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPREDUCTION_RAW_SZ: Icmpv6Type(1059)=132; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_GROUPREDUCTION_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPREDUCTION_SZ: Icmpv6Type(1059)=132; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_GROUPREPORT
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPREPORT: Icmpv6Type(1059)=131; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMPv6 multicast listener report logs are aggregated. |
ATK_ICMPV6_GROUPREPORT_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPREPORT_RAW: Icmpv6Type(1059)=131; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMPv6 multicast listener reports of the same attributes, this message is sent only when the first report is received. If log aggregation is disabled, this message is sent every time an ICMPv6 multicast listener report is received. |
ATK_ICMPV6_GROUPREPORT_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPREPORT_RAW_SZ: Icmpv6Type(1059)=131; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_GROUPREPORT_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_GROUPREPORT_SZ: Icmpv6Type(1059)=131; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_LARGE
Message text |
Variable fields |
$1: Receiving interface name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. $6: Start time of the attack. $7: End time of the attack. $8: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMPV6_LARGE: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when large ICMPv6 packet logs are aggregated. |
ATK_ICMPV6_LARGE_RAW
Message text |
Variable fields |
$1: Receiving interface name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMPV6_LARGE_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for large ICMPv6 packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a large ICMPv6 packet is received. |
ATK_ICMPV6_LARGE_RAW_SZ
Message text |
Variable fields |
$1: Source security zone name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMPV6_LARGE_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_LARGE_SZ
Message text |
Variable fields |
$1: Source security zone name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. $6: Start time of the attack. $7: End time of the attack. $8: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_ICMPV6_LARGE_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_PACKETTOOBIG
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_PACKETTOOBIG: Icmpv6Type(1059)=136; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMPv6 packet too big logs are aggregated. |
ATK_ICMPV6_PACKETTOOBIG_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_PACKETTOOBIG_RAW: Icmpv6Type(1059)=136; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMPv6 packet too big packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMPv6 packet too big packet is received. |
ATK_ICMPV6_PACKETTOOBIG_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_PACKETTOOBIG_RAW_SZ: Icmpv6Type(1059)=136; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_PACKETTOOBIG_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_PACKETTOOBIG_SZ: Icmpv6Type(1059)=136; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_PARAPROBLEM
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_PARAPROBLEM: Icmpv6Type(1059)=135; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMPv6 parameter problem logs are aggregated. |
ATK_ICMPV6_PARAPROBLEM_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_PARAPROBLEM_RAW: Icmpv6Type(1059)=135; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMPv6 parameter problem packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMPv6 parameter problem packet is received. |
ATK_ICMPV6_PARAPROBLEM_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_PARAPROBLEM_RAW_SZ: Icmpv6Type(1059)=135; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_PARAPROBLEM_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_PARAPROBLEM_SZ: Icmpv6Type(1059)=135; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_TIMEEXCEED
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_TIMEEXCEED: Icmpv6Type(1059)=134; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when ICMPv6 time exceeded logs are aggregated. |
ATK_ICMPV6_TIMEEXCEED_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_TIMEEXCEED_RAW: Icmpv6Type(1059)=134; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for ICMPv6 time exceeded packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMPv6 time exceeded packet is received. |
ATK_ICMPV6_TIMEEXCEED_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_TIMEEXCEED_RAW_SZ: Icmpv6Type(1059)=134; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_TIMEEXCEED_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_TIMEEXCEED_SZ: Icmpv6Type(1059)=134; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_TRACEROUTE
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMPV6_TRACEROUTE: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for ICMPv6 time exceeded packets of code 0. |
ATK_ICMPV6_TRACEROUTE_RAW
Message text |
RcvIfName(1023)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]. |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMPV6_TRACEROUTE_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435. |
Explanation |
If log aggregation is enabled, for ICMPv6 time exceeded packets of code 0 of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an ICMPv6 time exceeded packet of code 0 is received. |
ATK_ICMPV6_TRACEROUTE_RAW_SZ
Message text |
SrcZoneName(1025)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]. |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMPV6_TRACEROUTE_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435. |
Explanation |
ATK_ICMPV6_TRACEROUTE_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_ICMPV6_TRACEROUTE_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_ICMPV6_TYPE
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_TYPE: Icmpv6Type(1059)=38; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for user-defined ICMPv6 packets. |
ATK_ICMPV6_TYPE _RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_TYPE_RAW_SZ: Icmpv6Type(1059)=38; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for user-defined ICMPv6 packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a user-defined ICMPv6 packet is received. |
ATK_ICMPV6_TYPE_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_TYPE_RAW: Icmpv6Type(1059)=38; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_ICMPV6_TYPE_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_ICMPV6_TYPE_SZ: Icmpv6Type(1059)=38; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=5600::12; DstIPv6Addr(1037)=1200:0:3400:0:5600:0:7800:0; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011100935; EndTime_c(1012)=20131011101435; AtkTimes(1050)=2. |
Explanation |
ATK_IP_OPTION
Message text |
IPOptValue(1057)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: IP option value. $2: Receiving interface name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Protocol type. $8: Actions against the attack. $9: Start time of the attack. $10: End time of the attack. $11: Attack times. |
Severity level |
5 |
Example |
ATK/5/ATK_IP_OPTION: IPOptValue(1057)=38; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for packets with a user-defined IP option. |
ATK_IP_OPTION_RAW
Message text |
IPOptValue(1057)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: IP option value. $2: Receiving interface name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Protocol type. $8: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_IP_OPTION_RAW: IPOptValue(1057)=38; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for packets with a user-defined IP option and of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet with a user-defined IP option is received. |
ATK_IP_OPTION_RAW_SZ
Message text |
IPOptValue(1057)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: IP option value. $2: Source security zone name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Protocol type. $8: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_IP_OPTION_RAW_SZ: IPOptValue(1057)=38; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
ATK_IP_OPTION_SZ
Message text |
IPOptValue(1057)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: IP option value. $2: Source security zone name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Protocol type. $8: Actions against the attack. $9: Start time of the attack. $10: End time of the attack. $11: Attack times. |
Severity level |
5 |
Example |
ATK/5/ATK_IP_OPTION_SZ: IPOptValue(1057)=38; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
ATK_IP4_ACK_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_ACK_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
This message is sent when the number of IPv4 ACK packets sent to a destination per second exceeds the rate limit. |
ATK_IP4_ACK_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_ACK_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
ATK_IP4_DIS_PORTSCAN
Message text |
RcvIfName(1023)=[STRING]; Protocol(1001)=[STRING]; TcpFlag(1074)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Protocol name. $3: TCP packet type. (This field is available only for TCP packets.) $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_DIS_PORTSCAN: RcvIfName(1023)=Ethernet0/0/2; Protocol(1001)=TCP; TcpFlag(1074)=[SYN]; DstIPAddr(1007)=6.1.1.5; RcvVPNInstance(1041)=vpn1; Action(1049)=logging,block-source; BeginTime_c(1011)=20131009052955. |
Explanation |
This message is sent when an IPv4 distributed port scan attack is detected. |
ATK_IP4_DIS_PORTSCAN_SZ
Message text |
SrcZoneName(1025)=[STRING]; Protocol(1001)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Protocol name. $3: Destination IP address. $4: Name of the receiving VPN instance. $5: Actions against the attack. $6: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_DIS_PORTSCAN_SZ: SrcZoneName(1025)=Trust; Protocol(1001)=TCP; DstIPAddr(1007)=6.1.1.5; RcvVPNInstance(1041)=vpn1; Action(1049)=logging,block-source; BeginTime_c(1011)=20131009052955. |
Explanation |
ATK_IP4_DNS_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_DNS_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
This message is sent when the number of IPv4 DNS queries sent to a destination per second exceeds the rate limit. |
ATK_IP4_DNS_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_DNS_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
ATK_IP4_FIN_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_FIN_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
This message is sent when the number of IPv4 FIN packets sent to a destination per second exceeds the rate limit. |
ATK_IP4_FIN_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_FIN_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
ATK_IP4_FRAGMENT
Message text |
Variable fields |
$1: Receiving interface name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Protocol type. $7: Actions against the attack. $8: Start time of the attack. $9: End time of the attack. $10: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_FRAGMENT: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for IPv4 packets with an offset smaller than 5 but bigger than 0. |
ATK_IP4_FRAGMENT_RAW
Message text |
Variable fields |
$1: Receiving interface name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Protocol type. $7: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_FRAGMENT_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging. |
Explanation |
This message is for the IPv4 fragment attack. The attack uses IPv4 packets with an offset smaller than 5 but bigger than 0. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_FRAGMENT_RAW_SZ
Message text |
Variable fields |
$1: Source security zone name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Protocol type. $7: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_FRAGMENT_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging. |
Explanation |
ATK_IP4_FRAGMENT_SZ
Message text |
Variable fields |
$1: Source security zone name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Protocol type. $7: Actions against the attack. $8: Start time of the attack. $9: End time of the attack. $10: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_FRAGMENT_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
ATK_IP4_HTTP_FLOOD
Message text |
RcvIfName(1023)=[STRING]; DstIPAddr(1007)=[IPADDR]; DstPort(1008)=[UINT16]; RcvVPNInstance(1041)=[STRING]; UpperLimit(1048)=[UINT32]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Destination IP address. $3: Destination port number. $4: Name of the receiving VPN instance. $5: Rate limit. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_HTTP_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
This message is sent when the number of IPv4 HTTP Get packets sent to a destination per second exceeds the rate limit. |
ATK_IP4_HTTP_FLOOD_SZ
Message text |
SrcZoneName(1025)=[STRING]; DstIPAddr(1007)=[IPADDR]; DstPort(1008)=[UINT16]; RcvVPNInstance(1041)=[STRING]; UpperLimit(1048)=[UINT32]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Destination IP address. $3: Destination port number. $4: Name of the receiving VPN instance. $5: Rate limit. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_HTTP_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
ATK_IP4_IMPOSSIBLE
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_IMPOSSIBLE: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for IPv4 packets whose source IPv4 address is the same as the destination IPv4 address. |
ATK_IP4_IMPOSSIBLE_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_IMPOSSIBLE_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging. |
Explanation |
This message is for the IPv4 impossible packet attack. The attack uses IPv4 packets whose source IPv4 address is the same as the destination IPv4 address. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_IMPOSSIBLE_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_IMPOSSIBLE_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging. |
Explanation |
ATK_IP4_IMPOSSIBLE_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_IMPOSSIBLE_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
ATK_IP4_IPSWEEP
Message text |
RcvIfName(1023)=[STRING]; Protocol(1001)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Protocol name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_IPSWEEP: RcvIfName(1023)=Ethernet0/0/2; Protocol(1001)=TCP; SrcIPAddr(1003)=9.1.1.5; DSLiteTunnelPeer(1040)=--; RcvVPNInstance(1041)=vpn1; Action(1049)=logging,block-source; BeginTime_c(1011)=20131009060657. |
Explanation |
This message is sent when an IPv4 sweep attack is detected. |
ATK_IP4_IPSWEEP_SZ
Message text |
SrcZoneName(1025)=[STRING]; Protocol(1001)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Protocol name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_IPSWEEP_SZ: SrcZoneName(1025)=Trust; Protocol(1001)=TCP; SrcIPAddr(1003)=9.1.1.5; DSLiteTunnelPeer(1040)=--; RcvVPNInstance(1041)=vpn1; Action(1049)=logging,block-source; BeginTime_c(1011)=20131009060657. |
Explanation |
ATK_IP4_PORTSCAN
Message text |
RcvIfName(1023)=[STRING]; Protocol(1001)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; RcvVPNInstance(1041)=[STRING]; DstIPAddr(1007)=[IPADDR]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Protocol name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Name of the receiving VPN instance. $6: Destination IP address. $7: Actions against the attack. $8: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_PORTSCAN: RcvIfName(1023)=Ethernet0/0/2; Protocol(1001)=TCP; SrcIPAddr(1003)=9.1.1.5; DSLiteTunnelPeer(1040)=--; RcvVPNInstance(1041)=vpn1; DstIPAddr(1007)=6.1.1.5; Action(1049)=logging,block-source; BeginTime_c(1011)=20131009052955. |
Explanation |
This message is sent when an IPv4 port scan attack is detected. |
ATK_IP4_PORTSCAN_SZ
Message text |
SrcZoneName(1025)=[STRING]; Protocol(1001)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; RcvVPNInstance(1041)=[STRING]; DstIPAddr(1007)=[IPADDR]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Protocol name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Name of the receiving VPN instance. $6: Destination IP address. $7: Actions against the attack. $8: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_PORTSCAN_SZ: SrcZoneName(1025)=Trust; Protocol(1001)=TCP; SrcIPAddr(1003)=9.1.1.5; DSLiteTunnelPeer(1040)=--; RcvVPNInstance(1041)=vpn1; DstIPAddr(1007)=6.1.1.5; Action(1049)=logging,block-source; BeginTime_c(1011)=20131009052955. |
Explanation |
ATK_IP4_RST_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_RST_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
This message is sent when the number of IPv4 RST packets sent to a destination per second exceeds the rate limit. |
ATK_IP4_RST_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_RST_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
ATK_IP4_SYN_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_SYN_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
This message is sent when the number of IPv4 SYN packets sent to a destination per second exceeds the rate limit. |
ATK_IP4_SYN_FLOOD_SZ
Message text |
SrcZoneName(1025)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; UpperLimit(1048)=[UINT32]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Destination IP address. $3: Name of the receiving VPN instance. $4: Rate limit. $5: Actions against the attack. $6: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_SYN_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPAddr(1007)=6.1.1.5; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
ATK_IP4_SYNACK_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_SYNACK_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
This message is sent when the number of IPv4 SYN-ACK packets sent to a destination per second exceeds the rate limit. |
ATK_IP4_SYNACK_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_SYNACK_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
ATK_IP4_TCP_ALLFLAGS
Message text |
RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: Receiving interface name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. $8: End time of the attack. $9: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_ALLFLAGS: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for IPv4 TCP packets that have all flags set. |
ATK_IP4_TCP_ALLFLAGS_RAW
Message text |
RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_ALLFLAGS_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv4 TCP packets that have all flags set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_TCP_ALLFLAGS_RAW_SZ
Message text |
SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_ALLFLAGS_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP4_TCP_ALLFLAGS_SZ
Message text |
SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: Source security zone name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. $8: End time of the attack. $9: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_ALLFLAGS_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
ATK_IP4_TCP_FINONLY
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_FINONLY: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for IPv4 TCP packets that have only the FIN flag set. |
Recommended action |
ATK_IP4_TCP_FINONLY_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_FINONLY_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv4 TCP packets that have only the FIN flag set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
No action is required. |
ATK_IP4_TCP_FINONLY_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_FINONLY_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP4_TCP_FINONLY_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_FINONLY_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
ATK_IP4_TCP_INVALIDFLAGS
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_INVALIDFLAGS: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for IPv4 TCP packets that have invalid flag settings. Invalid flag settings include: · The RST and FIN flags are both set. · The RST and SYN flags are both set. · The RST, FIN, and SYN flags are all set. · The PSH, RST, and FIN flags are all set. · The PSH, RST, and SYN flags are all set. · The PSH, RST, SYN, and FIN flags are all set. · The ACK, RST, and FIN flags are all set. · The ACK, RST, and SYN flags are all set. · The ACK, RST, SYN, and FIN flags are all set. · The ACK, PSH, SYN, and FIN flags are all set. · The ACK, PSH, RST, and FIN flags are all set. · The ACK, PSH, RST, and SYN flags are all set. |
ATK_IP4_TCP_INVALIDFLAGS_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_INVALIDFLAGS_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv4 TCP packets that have invalid flag settings. Invalid flag settings include: · The RST and FIN flags are both set. · The RST and SYN flags are both set. · The RST, FIN, and SYN flags are all set. · The PSH, RST, and FIN flags are all set. · The PSH, RST, and SYN flags are all set. · The PSH, RST, SYN, and FIN flags are all set. · The ACK, RST, and FIN flags are all set. · The ACK, RST, and SYN flags are all set. · The ACK, RST, SYN, and FIN flags are all set. · The ACK, PSH, SYN, and FIN flags are all set. · The ACK, PSH, RST, and FIN flags are all set. · The ACK, PSH, RST, and SYN flags are all set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_TCP_INVALIDFLAGS_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_INVALIDFLAGS_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP4_TCP_INVALIDFLAGS_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_INVALIDFLAGS_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
ATK_IP4_TCP_LAND
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_LAND: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for IPv4 TCP packets whose source IP address is the same as the destination IP address. |
ATK_IP4_TCP_LAND_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_LAND_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for the IPv4 land attack. The attack uses IPv4 TCP packets whose source IP address is the same as the destination IP address. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_TCP_LAND_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_LAND_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP4_TCP_LAND_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_LAND_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
ATK_IP4_TCP_NULLFLAG
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_NULLFLAG: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=4. |
Explanation |
This message is sent when logs are aggregated for IPv4 TCP packets that have no flag set. |
ATK_IP4_TCP_NULLFLAG_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_NULLFLAG_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv4 TCP packets that have no flag set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_TCP_NULLFLAG_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_NULLFLAG_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP4_TCP_NULLFLAG_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_NULLFLAG_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=4. |
Explanation |
ATK_IP4_TCP_SYNFIN
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_SYNFIN: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv4 TCP packets that have SYN and FIN flags set. |
ATK_IP4_TCP_SYNFIN_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_SYNFIN_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv4 TCP packets that have SYN and FIN flags set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_TCP_SYNFIN_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_SYNFIN_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP4_TCP_SYNFIN_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_SYNFIN_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
ATK_IP4_TCP_WINNUKE
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_WINNUKE: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=5. |
Explanation |
This message is sent when logs are aggregated for IPv4 TCP packets with destination port 139, the URG flag set, and a nonzero Urgent Pointer. |
ATK_IP4_TCP_WINNUKE_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_WINNUKE_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for the IPv4 WinNuke attack. The attack uses IPv4 TCP packets with destination port 139, the URG flag set, and a nonzero Urgent Pointer. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_TCP_WINNUKE_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_WINNUKE_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP4_TCP_WINNUKE_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TCP_WINNUKE_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=5. |
Explanation |
ATK_IP4_TEARDROP
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TEARDROP: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for IPv4 overlapping fragments. |
ATK_IP4_TEARDROP_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TEARDROP_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for IPv4 overlapping fragments of the same attributes, this message is sent only when the first overlapping fragment is received. If log aggregation is disabled, this message is sent every time an IPv4 overlapping fragment is received. |
ATK_IP4_TEARDROP_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TEARDROP_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging. |
Explanation |
ATK_IP4_TEARDROP_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TEARDROP_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=3. |
Explanation |
ATK_IP4_TINY_FRAGMENT
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TINY_FRAGMENT: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=6. |
Explanation |
This message is sent when logs are aggregated for IPv4 packets with a datagram smaller than 68 bytes and the MF flag set. |
ATK_IP4_TINY_FRAGMENT_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TINY_FRAGMENT_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging. |
Explanation |
This message is for the IPv4 tiny fragment attack. The attack uses IPv4 packets with a datagram smaller than 68 bytes and the MF flag set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_TINY_FRAGMENT_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TINY_FRAGMENT_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging. |
Explanation |
ATK_IP4_TINY_FRAGMENT_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_TINY_FRAGMENT_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=TCP; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=6. |
Explanation |
ATK_IP4_UDP_BOMB
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_BOMB: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv4 UDP packets in which the length value in the IP header is larger than the IP header length plus the length in the UDP header. |
ATK_IP4_UDP_BOMB_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_BOMB_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv4 UDP bomb attack. The attack uses IPv4 UDP packets in which the length value in the IP header is larger than the IP header length plus the length in the UDP header. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_UDP_BOMB_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_BOMB_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP4_UDP_BOMB_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_BOMB_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
ATK_IP4_UDP_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
This message is sent when the number of IPv4 UDP packets sent to a destination per second exceeds the rate limit. |
ATK_IP4_UDP_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPAddr(1007)=6.1.1.5; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009093351. |
Explanation |
ATK_IP4_UDP_FRAGGLE
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_FRAGGLE: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=11. |
Explanation |
This message is sent when logs are aggregated for IPv4 UDP packets with source port 7 and destination port 19. |
ATK_IP4_UDP_FRAGGLE_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_FRAGGLE_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv4 UDP fraggle attack. The attack uses IPv4 UDP packets with source port 7 and destination port 19. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_UDP_FRAGGLE_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_FRAGGLE_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP4_UDP_FRAGGLE_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_FRAGGLE_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=11. |
Explanation |
ATK_IP4_UDP_SNORK
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_SNORK: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv4 UDP packets with source port 7, 19, or 135, and destination port 135. |
ATK_IP4_UDP_SNORK_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_SNORK_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv4 UDP snork attack. The attack uses IPv4 UDP packets with source port 7, 19, or 135, and destination port 135. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP4_UDP_SNORK_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_SNORK_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP4_UDP_SNORK_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP4_UDP_SNORK_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131011074913; EndTime_c(1012)=20131011075413; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_ACK_FLOOD
Message text |
RcvIfName(1023)=[STRING]; DstIPv6Addr(1037)=[IPADDR]; DstPort(1008)=[UINT16]; RcvVPNInstance(1041)=[STRING]; UpperLimit(1048)=[UINT32]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Destination IPv6 address. $3: Destination port number. $4: Name of the receiving VPN instance. $5: Rate limit. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_ACK_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
This message is sent when the number of IPv6 ACK packets sent to a destination per second exceeds the rate limit. |
ATK_IP6_ACK_FLOOD_SZ
Message text |
SrcZoneName(1025)=[STRING]; DstIPv6Addr(1037)=[IPADDR]; DstPort(1008)=[UINT16]; RcvVPNInstance(1041)=[STRING]; UpperLimit(1048)=[UINT32]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Destination IPv6 address. $3: Destination port number. $4: Name of the receiving VPN instance. $5: Rate limit. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_ACK_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
ATK_IP6_DIS_PORTSCAN
Message text |
RcvIfName(1023)=[STRING]; Protocol(1001)=[STRING]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Protocol name. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. $6: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_DIS_PORTSCAN: RcvIfName(1023)=Ethernet0/0/2; Protocol(1001)=UDP; DstIPv6Addr(1037)=2::2; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009100928. |
Explanation |
This message is sent when an IPv6 distributed port scan attack is detected. |
ATK_IP6_DIS_PORTSCAN_SZ
Message text |
SrcZoneName(1025)=[STRING]; Protocol(1001)=[STRING]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Protocol name. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. $6: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_DIS_PORTSCAN_SZ: SrcZoneName(1025)=Trust; Protocol(1001)=TCP; DstIPv6Addr(1037)=2::2; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009100928. |
Explanation |
ATK_IP6_DNS_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_DNS_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
This message is sent when the number of IPv6 DNS queries sent to a destination per second exceeds the rate limit. |
ATK_IP6_DNS_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_DNS_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
ATK_IP6_FIN_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_FIN_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
This message is sent when the number of IPv6 FIN packets sent to a destination per second exceeds the rate limit. |
ATK_IP6_FIN_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_FIN_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
ATK_IP6_FRAGMENT
Message text |
RcvIfName(1023)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: Receiving interface name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Protocol type. $6: Actions against the attack. $7: Start time of the attack. $8: End time of the attack. $9: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_FRAGMENT: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=1::1; RcvVPNInstance(1041)=--; Protocol(1001)=IPv6-ICMP; Action(1049)=logging; BeginTime_c(1011)=20131011103335; EndTime_c(1012)=20131011103835; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 packets with an offset smaller than 5 but bigger than 0. |
ATK_IP6_FRAGMENT_RAW
Message text |
RcvIfName(1023)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Protocol type. $6: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_FRAGMENT_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=1::1; RcvVPNInstance(1041)=--; Protocol(1001)=IPv6-ICMP; Action(1049)=logging. |
Explanation |
This message is for the IPv6 fragment attack. The attack uses IPv6 packets with an offset smaller than 5 but bigger than 0. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_FRAGMENT_RAW_SZ
Message text |
SrcZoneName(1025)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Protocol type. $6: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_FRAGMENT_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=1::1; RcvVPNInstance(1041)=--; Protocol(1001)=IPv6-ICMP; Action(1049)=logging. |
Explanation |
ATK_IP6_FRAGMENT_SZ
Message text |
SrcZoneName(1025)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: Source security zone name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Protocol type. $6: Actions against the attack. $7: Start time of the attack. $8: End time of the attack. $9: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_FRAGMENT_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=1::1; RcvVPNInstance(1041)=--; Protocol(1001)=IPv6-ICMP; Action(1049)=logging; BeginTime_c(1011)=20131011103335; EndTime_c(1012)=20131011103835; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_HTTP_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_HTTP_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
This message is sent when the number of IPv6 HTTP Get packets sent to a destination per second exceeds the rate limit. |
ATK_IP6_HTTP_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_HTTP_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
ATK_IP6_IMPOSSIBLE
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_IMPOSSIBLE: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=1::1; RcvVPNInstance(1041)=--; Protocol(1001)=IPv6-ICMP; Action(1049)=logging; BeginTime_c(1011)=20131011103335; EndTime_c(1012)=20131011103835; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 packets whose source IPv6 address is the same as the destination IPv6 address. |
ATK_IP6_IMPOSSIBLE_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_IMPOSSIBLE_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=1::1; RcvVPNInstance(1041)=--; Protocol(1001)=IPv6-ICMP; Action(1049)=logging. |
Explanation |
This message is for the IPv6 impossible packet attack. The attack uses IPv6 packets whose source IPv6 address is the same as the destination IPv6 address. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_IMPOSSIBLE_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_IMPOSSIBLE_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=1::1; RcvVPNInstance(1041)=--; Protocol(1001)=IPv6-ICMP; Action(1049)=logging. |
Explanation |
ATK_IP6_IMPOSSIBLE_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_IMPOSSIBLE_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=1::1; RcvVPNInstance(1041)=--; Protocol(1001)=IPv6-ICMP; Action(1049)=logging; BeginTime_c(1011)=20131011103335; EndTime_c(1012)=20131011103835; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_IPSWEEP
Message text |
RcvIfName(1023)=[STRING]; Protocol(1001)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Protocol name. $3: Source IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. $6: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_IPSWEEP: RcvIfName(1023)=Ethernet0/0/2; Protocol(1001)=UDP; SrcIPv6Addr(1036)=1::5; RcvVPNInstance(1041)=--; Action(1049)=logging,block-source; BeginTime_c(1011)=20131009100639. |
Explanation |
This message is sent when an IPv6 sweep attack is detected. |
ATK_IP6_IPSWEEP_SZ
Message text |
SrcZoneName(1025)=[STRING]; Protocol(1001)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Protocol name. $3: Source IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. $6: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_IPSWEEP_SZ: SrcZoneName(1025)=Trust; Protocol(1001)=TCP; SrcIPv6Addr(1036)=1::5; RcvVPNInstance(1041)=--; Action(1049)=logging,block-source; BeginTime_c(1011)=20131009100639. |
Explanation |
ATK_IP6_PORTSCAN
Message text |
RcvIfName(1023)=[STRING]; Protocol(1001)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; DstIPv6Addr(1037)=[IPADDR]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Protocol name. $3: Source IPv6 address. $4: Name of the receiving VPN instance. $5: Destination IPv6 address. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_PORTSCAN: RcvIfName(1023)=Ethernet0/0/2; Protocol(1001)=UDP; SrcIPv6Addr(1036)=1::5; RcvVPNInstance(1041)=--; DstIPv6Addr(1037)=2::2; Action(1049)=logging,block-source; BeginTime_c(1011)=20131009100455. |
Explanation |
This message is sent when an IPv6 port scan attack is detected. |
ATK_IP6_PORTSCAN_SZ
Message text |
SrcZoneName(1025)=[STRING]; Protocol(1001)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; DstIPv6Addr(1037)=[IPADDR]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Protocol name. $3: Source IPv6 address. $4: Name of the receiving VPN instance. $5: Destination IPv6 address. $6: Actions against the attack. $7: Start time of the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_PORTSCAN_SZ: SrcZoneName(1025)=Trust; Protocol(1001)=TCP; SrcIPv6Addr(1036)=1::5; RcvVPNInstance(1041)=--; DstIPv6Addr(1037)=2::2; Action(1049)=logging,block-source; BeginTime_c(1011)=20131009100455. |
Explanation |
ATK_IP6_RST_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_RST_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPv6Addr(1037)=2::2; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
This message is sent when the number of IPv6 RST packets sent to a destination per second exceeds the rate limit. |
ATK_IP6_RST_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_RST_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPv6Addr(1037)=2::2; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
ATK_IP6_SYN_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_SYN_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
This message is sent when the number of IPv6 SYN packets sent to a destination per second exceeds the rate limit. |
ATK_IP6_SYN_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_SYN_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
ATK_IP6_SYNACK_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_SYNACK_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
This message is sent when the number of IPv6 SYN-ACK packets sent to a destination per second exceeds the rate limit. |
ATK_IP6_SYNACK_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_SYNACK_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
ATK_IP6_TCP_ALLFLAGS
Message text |
RcvIfName(1023)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: Receiving interface name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. $6: Start time of the attack. $7: End time of the attack. $8: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_ALLFLAGS: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 TCP packets that have all flags set. |
ATK_IP6_TCP_ALLFLAGS_RAW
Message text |
RcvIfName(1023)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_ALLFLAGS_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv6 TCP packets that have all flags set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_TCP_ALLFLAGS_RAW_SZ
Message text |
SrcZoneName(1025)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_ALLFLAGS_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP6_TCP_ALLFLAGS_SZ
Message text |
SrcZoneName(1025)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: Source security zone name. $2: Source IPv6 address. $3: Destination IPv6 address. $4: Name of the receiving VPN instance. $5: Actions against the attack. $6: Start time of the attack. $7: End time of the attack. $8: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_ALLFLAGS_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_TCP_FINONLY
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_FINONLY: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 TCP packets that have only the FIN flag set. |
ATK_IP6_TCP_FINONLY_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_FINONLY_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv6 TCP packets that have only the FIN flag set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_TCP_FINONLY_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_FINONLY_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP6_TCP_FINONLY_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_FINONLY_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_TCP_INVALIDFLAGS
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_INVALIDFLAGS: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 TCP packets that have invalid flag settings. Invalid flag settings include: · The RST and FIN flags are both set. · The RST and SYN flags are both set. · The RST, FIN, and SYN flags are all set. · The PSH, RST, and FIN flags are all set. · The PSH, RST, and SYN flags are all set. · The PSH, RST, SYN, and FIN flags are all set. · The ACK, RST, and FIN flags are all set. · The ACK, RST, and SYN flags are all set. · The ACK, RST, SYN, and FIN flags are all set. · The ACK, PSH, SYN, and FIN flags are all set. · The ACK, PSH, RST, and FIN flags are all set. · The ACK, PSH, RST, and SYN flags are all set. |
ATK_IP6_TCP_INVALIDFLAGS_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_INVALIDFLAGS_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv6 TCP packets that have invalid flag settings. Invalid flag settings include: · The RST and FIN flags are both set. · The RST and SYN flags are both set. · The RST, FIN, and SYN flags are all set. · The PSH, RST, and FIN flags are all set. · The PSH, RST, and SYN flags are all set. · The PSH, RST, SYN, and FIN flags are all set. · The ACK, RST, and FIN flags are all set. · The ACK, RST, and SYN flags are all set. · The ACK, RST, SYN, and FIN flags are all set. · The ACK, PSH, SYN, and FIN flags are all set. · The ACK, PSH, RST, and FIN flags are all set. · The ACK, PSH, RST, and SYN flags are all set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_TCP_INVALIDFLAGS_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_INVALIDFLAGS_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP6_TCP_INVALIDFLAGS_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_INVALIDFLAGS_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_TCP_LAND
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_LAND: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 TCP packets whose source IPv6 address is the same as the destination IPv6 address. |
ATK_IP6_TCP_LAND_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_LAND_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for the IPv6 land attack. The attack uses IPv6 TCP packets whose source IPv6 address is the same as the destination IPv6 address. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_TCP_LAND_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_LAND_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP6_TCP_LAND_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_LAND_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_TCP_NULLFLAG
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_NULLFLAG: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 TCP packets that have no flag set. |
ATK_IP6_TCP_NULLFLAG_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_NULLFLAG_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv6 TCP packets that have no flag set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_TCP_NULLFLAG_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_NULLFLAG_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP6_TCP_NULLFLAG_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_NULLFLAG_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_TCP_SYNFIN
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_SYNFIN: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 TCP packets that have SYN and FIN flags set. |
ATK_IP6_TCP_SYNFIN_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_SYNFIN_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv6 TCP packets that have SYN and FIN flags set. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_TCP_SYNFIN_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_SYNFIN_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=2000::1; DstIPv6Addr(1037)=2003::200; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP6_TCP_SYNFIN_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_SYNFIN_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_TCP_WINNUKE
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_WINNUKE: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 TCP packets with destination port 139, the URG flag set, and a nonzero Urgent Pointer. |
ATK_IP6_TCP_WINNUKE_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_WINNUKE_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for the IPv6 WinNuke attack. The attack uses IPv6 TCP packets with destination port 139, the URG flag set, and a nonzero Urgent Pointer. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_TCP_WINNUKE_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_WINNUKE_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP6_TCP_WINNUKE_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_TCP_WINNUKE_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_UDP_FLOOD
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_UDP_FLOOD: RcvIfName(1023)=Ethernet0/0/2; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
This message is sent when the number of IPv6 UDP packets sent to a destination per second exceeds the rate limit. |
ATK_IP6_UDP_FLOOD_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_UDP_FLOOD_SZ: SrcZoneName(1025)=Trust; DstIPv6Addr(1037)=2::2; DstPort(1008)=22; RcvVPNInstance(1041)=--; UpperLimit(1048)=10; Action(1049)=logging; BeginTime_c(1011)=20131009100434. |
Explanation |
ATK_IP6_UDP_FRAGGLE
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_UDP_FRAGGLE: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 UDP packets with source port 7 and destination port 19. |
ATK_IP6_UDP_FRAGGLE_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_UDP_FRAGGLE_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv6 UDP fraggle attack. The attack uses IPv6 UDP packets with source port 7 and destination port 19. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_UDP_FRAGGLE_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_UDP_FRAGGLE_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP6_UDP_FRAGGLE_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_UDP_FRAGGLE_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
ATK_IP6_UDP_SNORK
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_UDP_SNORK: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 UDP packets with source port 7, 19, or 135, and destination port 135. |
ATK_IP6_UDP_SNORK_RAW
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_UDP_SNORK_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
This message is for IPv6 UDP snork attack. The attack uses IPv6 UDP packets with source port 7, 19, or 135, and port 135. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet is received. |
ATK_IP6_UDP_SNORK_RAW_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_UDP_SNORK_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IP6_UDP_SNORK_SZ
Message text |
Variable fields |
Severity level |
3 |
Example |
ATK/3/ATK_IP6_UDP_SNORK_SZ: SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
ATK_IPOPT_ABNORMAL
Message text |
RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: Receiving interface name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Protocol type. $7: Actions against the attack. $8: Start time of the attack. $9: End time of the attack. $10: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_IPOPT_ABNORMAL: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011072002; EndTime_c(1012)=20131011072502; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for packets with more than two IP options. |
ATK_IPOPT_ABNORMAL_RAW
Message text |
RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: Receiving interface name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Protocol type. $7: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IPOPT_ABNORMAL_RAW: RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
This message is for packets that each has more than two IP options. If log aggregation is enabled, for packets of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet with more than two IP options is received. |
ATK_IPOPT_ABNORMAL_RAW_SZ
Message text |
SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: Source security zone name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Protocol type. $7: Actions against the attack. |
Severity level |
3 |
Example |
ATK/3/ATK_IPOPT_ABNORMAL_RAW_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
ATK_IPOPT_ABNORMAL_SZ
Message text |
SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: Source security zone name. $2: Source IP address. $3: IP address of the peer DS-Lite tunnel interface. $4: Destination IP address. $5: Name of the receiving VPN instance. $6: Protocol type. $7: Actions against the attack. $8: Start time of the attack. $9: End time of the attack. $10: Attack times. |
Severity level |
3 |
Example |
ATK/3/ATK_IPOPT_ABNORMAL_SZ: SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011072002; EndTime_c(1012)=20131011072502; AtkTimes(1050)=3. |
Explanation |
ATK_IPOPT_LOOSESRCROUTE
Message text |
IPOptValue(1057)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)= [UINT32]. |
Variable fields |
$1: IP option value. $2: Receiving interface name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Protocol type. $8: Actions against the attack. $9: Start time of the attack. $10: End time of the attack. $11: Attack times. |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_LOOSESRCROUTE: IPOptValue(1057)=131; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for packets with IP option 131. |
ATK_IPOPT_LOOSESRCROUTE_RAW
Message text |
IPOptValue(1057)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: IP option value. $2: Receiving interface name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Protocol type. $8: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_LOOSESRCROUTE_RAW: IPOptValue(1057)=131; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for packets with IP option 131 and of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet with IP option 131 is received. |
Recommended action |
ATK_IPOPT_LOOSESRCROUTE_RAW_SZ
Message text |
IPOptValue(1057)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: IP option value. $2: Source security zone name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Protocol type. $8: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_LOOSESRCROUTE_RAW_SZ: IPOptValue(1057)=131; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
No action is required. |
ATK_IPOPT_LOOSESRCROUTE_SZ
Message text |
IPOptValue(1057)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)= [UINT32]. |
Variable fields |
$1: IP option value. $2: Source security zone name. $3: Source IP address. $4: IP address of the peer DS-Lite tunnel interface. $5: Destination IP address. $6: Name of the receiving VPN instance. $7: Protocol type. $8: Actions against the attack. $9: Start time of the attack. $10: End time of the attack. $11: Attack times. |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_LOOSESRCROUTE_SZ: IPOptValue(1057)=131; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
ATK_IPOPT_RECORDROUTE
Message text |
IPOptValue(1057)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_RECORDROUTE: IPOptValue(1057)=7; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for packets with IP option 7. |
ATK_IPOPT_RECORDROUTE_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_RECORDROUTE_RAW: IPOptValue(1057)=7; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for packets with IP option 7 and of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet with IP option 7 is received. |
ATK_IPOPT_RECORDROUTE_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_RECORDROUTE_RAW_SZ: IPOptValue(1057)=7; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
ATK_IPOPT_RECORDROUTE_SZ
Message text |
IPOptValue(1057)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; DstIPAddr(1007)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Protocol(1001)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_RECORDROUTE_SZ: IPOptValue(1057)=7; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
ATK_IPOPT_ROUTEALERT
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_ROUTEALERT: IPOptValue(1057)=148; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for packets with IP option 148. |
ATK_IPOPT_ROUTEALERT_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_ROUTEALERT_RAW: IPOptValue(1057)=148; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for packets with IP option 148 and of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet with IP option 148 is received. |
ATK_IPOPT_ROUTEALERT_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_ROUTEALERT_RAW_SZ: IPOptValue(1057)=148; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
ATK_IPOPT_ROUTEALERT_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_ROUTEALERT_SZ: IPOptValue(1057)=148; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
ATK_IPOPT_SECURITY
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_SECURITY: IPOptValue(1057)=130; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131009091022; EndTime_c(1012)=20131009091522; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for packets with IP option 130. |
ATK_IPOPT_SECURITY_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_SECURITY_RAW: IPOptValue(1057)=130; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for packets with IP option 130 and of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet with IP option 130 is received. |
ATK_IPOPT_SECURITY_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_SECURITY_RAW_SZ: IPOptValue(1057)=130; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
ATK_IPOPT_SECURITY_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_SECURITY_SZ: IPOptValue(1057)=130; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131009091022; EndTime_c(1012)=20131009091522; AtkTimes(1050)=2. |
Explanation |
ATK_IPOPT_STREAMID
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_STREAMID: IPOptValue(1057)=136; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for packets with IP option 136. |
ATK_IPOPT_STREAMID_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_STREAMID_RAW: IPOptValue(1057)=136; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for packets with IP option 136 and of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet with IP option 136 is received. |
ATK_IPOPT_STREAMID_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_STREAMID_RAW_SZ: IPOptValue(1057)=136; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
ATK_IPOPT_STREAMID_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_STREAMID_SZ: IPOptValue(1057)=136; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
ATK_IPOPT_STRICTSRCROUTE
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_STRICTSRCROUTE: IPOptValue(1057)=137; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for packets with IP option 137. |
ATK_IPOPT_STRICTSRCROUTE_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_STRICTSRCROUTE_RAW: IPOptValue(1057)=137; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for packets with IP option 137 and of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet with IP option 137 is received. |
ATK_IPOPT_STRICTSRCROUTE_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_STRICTSRCROUTE_RAW_SZ: IPOptValue(1057)=137; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
ATK_IPOPT_STRICTSRCROUTE_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_STRICTSRCROUTE_SZ: IPOptValue(1057)=137; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
ATK_IPOPT_TIMESTAMP
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_TIMESTAMP: IPOptValue(1057)=68; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
This message is sent when logs are aggregated for packets with IP option 68. |
ATK_IPOPT_TIMESTAMP_RAW
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_TIMESTAMP_RAW: IPOptValue(1057)=68; RcvIfName(1023)=Ethernet0/0/2; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for packets with IP option 68 and of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time a packet with IP option 68 is received. |
ATK_IPOPT_TIMESTAMP_RAW_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_TIMESTAMP_RAW_SZ: IPOptValue(1057)=68; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging. |
Explanation |
ATK_IPOPT_TIMESTAMP_SZ
Message text |
Variable fields |
Severity level |
5 |
Example |
ATK/5/ATK_IPOPT_TIMESTAMP_SZ: IPOptValue(1057)=68; SrcZoneName(1025)=Trust; SrcIPAddr(1003)=9.1.1.1; DSLiteTunnelPeer(1040)=--; DstIPAddr(1007)=6.1.1.1; RcvVPNInstance(1041)=--; Protocol(1001)=RAWIP; Action(1049)=logging; BeginTime_c(1011)=20131011063123; EndTime_c(1012)=20131011063623; AtkTimes(1050)=3. |
Explanation |
ATK_IPV6_EXT_HEADER
Message text |
IPv6ExtHeader(1060)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: IPv6 extension header value. $2: Receiving interface name. $3: Source IPv6 address. $4: Destination IPv6 address. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. $8: End time of the attack. $9: Attack times. |
Severity level |
5 |
Example |
ATK/5/ATK_IPV6_EXT_HEADER: IPv6ExtHeader(1060)=43; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
This message is sent when logs are aggregated for IPv6 packets with a user-defined extension header. |
ATK_IPV6_EXT_HEADER_RAW
Message text |
IPv6ExtHeader(1060)=[UINT32]; RcvIfName(1023)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: IPv6 extension header value. $2: Receiving interface name. $3: Source IPv6 address. $4: Destination IPv6 address. $5: Name of the receiving VPN instance. $6: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_IPV6_EXT_HEADER_RAW: IPv6ExtHeader(1060)=43; RcvIfName(1023)=Ethernet0/0/2; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
If log aggregation is enabled, for IPv6 packets with a user-defined extension header and of the same attributes, this message is sent only when the first packet is received. If log aggregation is disabled, this message is sent every time an IPv6 packet with a user-defined extension header is received. |
ATK_IPV6_EXT_HEADER_RAW_SZ
Message text |
IPv6ExtHeader(1060)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]. |
Variable fields |
$1: IPv6 extension header value. $2: Source security zone name. $3: Source IPv6 address. $4: Destination IPv6 address. $5: Name of the receiving VPN instance. $6: Actions against the attack. |
Severity level |
5 |
Example |
ATK/5/ATK_IPV6_EXT_HEADER_RAW_SZ: IPv6ExtHeader(1060)=43; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging. |
Explanation |
ATK_IPV6_EXT_HEADER_SZ
Message text |
IPv6ExtHeader(1060)=[UINT32]; SrcZoneName(1025)=[STRING]; SrcIPv6Addr(1036)=[IPADDR]; DstIPv6Addr(1037)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Action(1049)=[STRING]; BeginTime_c(1011)=[STRING]; EndTime_c(1012)=[STRING]; AtkTimes(1050)=[UINT32]. |
Variable fields |
$1: IPv6 extension header value. $2: Source security zone name. $3: Source IPv6 address. $4: Destination IPv6 address. $5: Name of the receiving VPN instance. $6: Actions against the attack. $7: Start time of the attack. $8: End time of the attack. $9: Attack times. |
Severity level |
5 |
Example |
ATK/5/ATK_IPV6_EXT_HEADER_SZ: IPv6ExtHeader(1060)=43; SrcZoneName(1025)=Trust; SrcIPv6Addr(1036)=1::1; DstIPv6Addr(1037)=2::11; RcvVPNInstance(1041)=--; Action(1049)=logging; BeginTime_c(1011)=20131009103631; EndTime_c(1012)=20131009104131; AtkTimes(1050)=2. |
Explanation |
ATM
This section contains ATM messages.
ATM_PVCDOWN
Variable fields |
Severity level |
Example |
ATM/5/ATM_PVCDOWN: Interface ATM2/0/2 PVC 0/100 status is down. |
Explanation |
The PVC state became down. Possible reasons include the following: · The ATM interface to which the PVC belongs went down. · The OAM state of the PVC became down. · The PVC had been manually shut down. |
Use the display atm pvc-info command to display detailed information about the PVC and take relevant actions: · If the interface state is down, take the following actions: ¡ Make sure both the local and remote ATM interfaces are up by using the display interface atm command. If the interfaces have been manually shut down, execute the undo shutdown command in interface view to bring them up. ¡ Make sure the two interfaces are correctly connected. · If the OAM state is down, take the following actions: ¡ Make sure the VPI/VCI value of the remote PVC is the same as the VPI/VCI value of the local PVC. ¡ Make sure the OAM configuration of the remote PVC is consistent with the OAM configuration of the local PVC. For example, if one end is configured as the OAM CC cell sink, the other end must be configured as the OAM CC cell source. ¡ Make sure the remote PVC is up. If the remote PVC has been manually shut down, execute the undo shutdown command in PVC view to bring it up. ¡ Make sure the two ends are correctly connected. ¡ If the two routers are connected through an ATM network, in addition to the previous check items, you must check the forwarding rule of the ATM network. If the ATM network cannot reach the PVC, the PVC cannot come up. · If the PVC state is down, check if the local PVC has been manually shut down. To bring up the PVC, execute the undo shutdown command in PVC view. |
ATM_PVCUP
Variable fields |
Severity level |
Example |
Explanation |
The PVC state became up. |
BFD messages
This section contains BFD messages.
BFD_CHANGE_FSM
Message text |
Sess[STRING], Ver, Sta: [STRING]->[STRING], Diag: [STRING] |
Variable fields |
$1: Source address, destination address, interface, and message type of the BFD session. $2: Name of FSM before changing. $3: Name of FSM after changing. $4: Diagnostic information: · 0 (No Diagnostic)—The BFD session is in up state. · 1 (Control Detection Time Expired)—A control packet mode BFD session goes down, because local detection times out. · 2 (Echo Function Failed)—An echo packet mode BFD session goes down, because local detection times out or the source IP address of echo packets is deleted. · 3 (Neighbor Signaled Session Down)—The remote end notifies the local end of BFD session down. · 7 (Administratively Down)—The local system prevents a BFD session from being established. |
Severity level |
5 |
Example |
BFD/5/BFD_CHANGE_FSM:Sess[20.0.4.2/20.0.4.1,LD/RD:533/532, Interface:Vlan204, SessType:Ctrl, LinkType:INET], Ver.1, Sta: INIT->UP, Diag: 0 (No Diagnostic). |
Explanation |
The FSM of the BFD session has been changed. This informational message appears when a BFD session comes up or goes down. Unexpected session loss might indicate high error or packet loss rates in the network. |
Check for incorrect BFD configuration or network congestion. |
BFD_REACHED_UPPER_LIMIT
Message text |
The total number of BFD sessions [ULONG] reached the upper limit. Can’t create a new session. |
Variable fields |
$1: Total number of BFD sessions. |
Severity level |
5 |
Example |
BFD/5/BFD_REACHED_UPPER_LIMIT: The total number of BFD session 100 reached upper limit. |
Explanation |
The total number of BFD sessions has reached the upper limit. |
Check the BFD session configuration. |
BGP messages
This section contains BGP messages.
BGP_EXCEED_ROUTE_LIMIT
Message text |
BGP.[STRING]: The number of routes from peer [STRING] ([STRING]) exceeds the limit [UINT32]. |
Variable fields |
$1: VPN instance name. This field is blank for the public network. $2: IP address of the BGP peer. $3: Address family of the BGP peer. $4: Maximum number of routes. |
Severity level |
4 |
Example |
BGP/4/BGP_EXCEED_ROUTE_LIMIT: BGP.vpn1: The number of routes from peer 1.1.1.1 (IPv4-UNC) exceeds the limit 100. |
Explanation |
The number of routes received from a peer exceeded the maximum number of routes that can be received from the peer. |
Determine whether it is caused by attacks: · If yes, configure the device to defend against the attacks. · If not, increase the maximum number of routes. |
BGP_REACHED_THRESHOLD
Message text |
BGP.[STRING]: The ratio of the number of routes received from peer [STRING] ([STRING]) to the number of allowed routes [UINT32] has reached the threshold ([UINT32]%). |
Variable fields |
$1: VPN instance name. This field is blank for the public network. $2: IP address of the BGP peer. $3: Address family of the BGP peer. $4: Maximum number of routes can be received from the BGP peer. $5: Percentage of received routes to the maximum allowed routes. |
Severity level |
5 |
Example |
BGP/5/BGP_REACHED_THRESHOLD: BGP.vpn1: The ratio of the number of routes received from peer 1.1.1.1 (IPv4-UNC) to the number of allowed routes 100 has reached the threshold (60%). |
Explanation |
The percentage of received routes to the maximum allowed routes reached the threshold. |
Determine whether it is caused by attacks: · If yes, configure the device to defend against the attacks. · If not, increase the threshold value or the maximum number of routes that can be received from the peer. |
BGP_LOG_ROUTE_FLAP
Message text |
BGP.[STRING]: The route [STRING] [STRING]/[UINT32] learned from peer [STRING] ([STRING]) flapped. |
Variable fields |
$1: VPN instance name. This field is blank for the public network. $2: RD of the BGP route. This field is blank for a route without an RD. $3: BGP route prefix. $4: Mask of the BGP route prefix. $5: IP address of the BGP peer. $6: Address family of the BGP peer. |
Severity level |
4 |
Example |
BGP/4/BGP_LOG_ROUTE_FLAP: BGP.vpn1: The route 15.1.1.1/24 learned from peer 1.1.1.1 (IPv4-UNC) flapped. |
Explanation |
The route learned from a BGP peer flapped. |
If a large number of routes flap, determine the route flapping cause and develop a solution. |
BGP_MEM_ALERT
Message text |
BGP process received system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alarm, stop and start. |
Severity level |
5 |
Example |
BGP/5/BGP_MEM_ALERT: BGP process received system memory alert start event. |
Explanation |
BGP received a memory alarm. |
If BGP received a system memory alert start event, check the system memory and try to free some memory by adjusting modules that occupied too much memory. |
BGP_PEER_LICENSE_REACHED
Message text |
Number of peers in Established state reached the license limit. |
Variable fields |
N/A |
Severity level |
5 |
Example |
BGP/5/BGP_PEER_LICENSE_REACHED: Number of peers in Established state reached the license limit. |
Explanation |
The number of peers in Established state reached the license limit. |
Determine whether a new license is required. |
BGP_ROUTE_LICENSE_REACHED
Message text |
Number of [STRING] routes reached the license limit. |
Variable fields |
$1: BGP address family: · IPv4-UNC public—IPv4 unicast routes for the public network. · IPv6-UNC public—IPv6 unicast routes for the public network. · IPv4 private—IPv4 unicast routes, VPNv4 routes, and nested VPN routes for the private network. · IPv6 private—IPv6 unicast routes and VPNv6 routes for the private network. |
Severity level |
5 |
Example |
BGP/5/BGP_ROUTE_LICENSE_REACHED: Number of IPv4-UNC public routes reached the license limit. |
Explanation |
The number of routes in the specified address family reached the license limit. |
Determine whether a new license is required. After the number of routes in the specified family falls below the license limit or the license limit increases, you must manually restore the discarded routes. |
BGP_STATE_CHANGED
Message text |
BGP.[STRING]: [STRING] state has changed from [STRING] to [STRING]. |
Variable fields |
$1: VPN instance name. This field is blank for the public network. $2: IP address of the BGP peer. $3: Name of FSM before the state change. $4: Name of FSM after the state change. |
Severity level |
5 |
Example |
BGP/5/BGP_STATE_CHANGED: BGP.vpn1:192.99.0.2 state has changed from ESTABLISHED to IDLE. |
Explanation |
The FSM of a BGP peer has changed. This informational message appears when a BGP peer comes up or goes down. |
If a peer goes down unexpectedly, determine whether an error or packet loss occurs. |
BGP_STATE_CHANGED_REASON
Message text |
BGP.[STRING]: [STRING] state has changed from [STRING] to [STRING]. ([STRING]) |
Variable fields |
$1: VPN instance name. This field does not display anything for the public network. $2: IP address of the BGP peer. $3: Original BGP peer state. $4: New BGP peer state. $5: BGP peer down information: · Reason: Reason why the BGP peer goes down. · Error code: Error code or sub error code in the sent or received notification. This field does not display anything if the BGP peer goes down because of TCP connection failures. · Local interface: Physical interface used to connect to the BGP peer. This field is displayed only when a directly connected BGP peer goes down because of interface connectivity failures. |
Severity level |
5 |
Example |
BGP/5/BGP_STATE_CHANGED_REASON: BGP.vpn1: 192.99.0.2 state has changed from ESTABLISHED to IDLE. (Reason: Directly connected physical interface was down, Error code: Send Notificationcode 6/0, Local interface: GigabitEthernet1/0/1) |
Explanation |
The state of the BGP peer changed from Established to another state. |
Determine whether network errors or packet loss occurs based on the displayed reason. |
BLS messages
This section contains blacklist messages.
BLS_ENTRY_ADD
Message text |
SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; RcvVPNInstance(1041)=[STRING]; TTL(1051)=[STRING]; Reason(1052)=[STRING]. |
Variable fields |
$1: Blacklisted IP address. $2: Peer address of the DS-Lite tunnel. $3: VPN instance name. $4: TTL of a blacklist entry. $5: Reason why the blacklist entry was added. |
Severity level |
5 |
Example |
BLS/5/BLS_ENTRY_ADD: SrcIPAddr(1003)=1.1.1.6; DSLiteTunnelPeer(1040)=--; RcvVPNInstance(1041)=; TTL(1051)=; Reason(1052)=Configuration. BLS/5/BLS_ENTRY_ADD: SrcIPAddr(1003)=9.1.1.5; DSLiteTunnelPeer(1040)=--; RcvVPNInstance(1041)=vpn1; TTL(1051)=10; Reason(1052)=Scan behavior detected. |
Explanation |
A blacklist entry was added. The message is sent when a blacklist entry is manually configured or dynamically created according to the scanning result. |
BLS_ENTRY_DEL
Message text |
SrcIPAddr(1003)=[IPADDR]; DSLiteTunnelPeer(1040)=[STRING]; RcvVPNInstance(1041)=[STRING]; Reason(1052)=[STRING]. |
Variable fields |
$1: Blacklisted IP address. $2: Peer address of the DS-Lite tunnel. $3: VPN instance name. $4: Reason why the blacklist entry was deleted. |
Severity level |
5 |
Example |
BLS/5/BLS_ENTRY_DEL: SrcIPAddr(1003)=1.1.1.3; DSLiteTunnelPeer(1040)=--; RcvVPNInstance(1041)=; Reason(1052)=Configuration. BLS/5/BLS_ENTRY_DEL: SrcIPAddr(1003)=9.1.1.5; DSLiteTunnelPeer(1040)=--; RcvVPNInstance(1041)=vpn1; Reason(1052)=Aging. |
Explanation |
A blacklist entry was deleted. The message is sent when a blacklist entry is manually deleted or dynamically deleted due to the aging. |
BLS_IPV6_ENTRY_ADD
Message text |
SrcIPv6Addr(1036)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; TTL(1051)=[STRING]; Reason(1052)=[STRING]. |
Variable fields |
$1: Blacklisted IPv6 address. $2: VPN instance name. $3: TTL of a blacklist entry. $4: Reason why the blacklist entry was added. |
Severity level |
5 |
Example |
BLS/5/BLS_IPV6_ENTRY_ADD: SrcIPv6Addr(1036)=2::2; RcvVPNInstance(1041)=; TTL(1051)=; Reason(1052)=Configuration. BLS/5/BLS_IPV6_ENTRY_ADD: SrcIPv6Addr(1036)=1::5; RcvVPNInstance(1041)=--; TTL(1051)=10; Reason(1052)=Scan behavior detected. |
Explanation |
BLS_IPV6_ENTRY_DEL
Message text |
SrcIPv6Addr(1036)=[IPADDR]; RcvVPNInstance(1041)=[STRING]; Reason(1052)=[STRING]. |
Variable fields |
$1: Blacklisted IPv6 address. $2: VPN instance name. $3: Reason why the blacklist entry was deleted. |
Severity level |
5 |
Example |
BLS/5/BLS_IPV6_ENTRY_DEL: SrcIPv6Addr(1036)=2::2; RcvVPNInstance(1041)=; Reason(1052)=Configuration. |
Explanation |
CFD messages
This section contains CFD messages.
CFD_CROSS_CCM
Message text |
MEP [UINT16] in SI [INT32] received a cross-connect CCM. It’s SrcMAC is [MAC], SeqNum is [INT32], RMEP is [UINT16], MD ID is [STRING], MA ID is [STRING]. |
Variable fields |
$1: Service instance ID. $2: Local MEP ID. $3: Source MAC address. $4: Sequence number. $5: Remote MEP ID. $6: MD ID. If no MD ID is available, "without ID" is displayed. $7: MA ID. |
Severity level |
6 |
Example |
CFD/6/CFD_CROSS_CCM: MEP 13 in SI 10 received a cross-connect CCM. Its SrcMAC is 0011-2233-4401, SeqNum is 78, RMEP is 12, MD ID is without ID, MA ID is 0. |
Explanation |
A MEP received a cross-connect CCM containing a different MA ID or MD ID. |
Check the configurations of MEPs on both ends. Make sure the MEPs have consistent configurations, including MD, MA, and level. |
CFD_ERROR_CCM
Message text |
MEP [UINT16] in SI [INT32] received an error CCM. It’s SrcMAC is [MAC], SeqNum is [INT32], RMEP is [UINT16], MD ID is [STRING], MA ID is [STRING]. |
Variable fields |
Severity level |
6 |
Example |
CFD/6/CFD_ERROR_CCM: MEP 2 in SI 7 received an error CCM. Its SrcMAC is 0011-2233-4401, SeqNum is 21, RMEP is 2, MD ID is 7, MA ID is 1. |
Explanation |
A MEP received an error CCM containing an unexpected MEP ID or lifetime. |
Check the CCM configuration. Make sure the CCM intervals are consistent on both ends, and the remote MEP ID is included in the MEP list of the local end. |
CFD_LOST_CCM
Message text |
MEP [UINT16] in SI [INT32] failed to receive CCMs from RMEP [UINT16]. |
Variable fields |
$1: Local MEP ID. $2: Service instance ID. $3: Remote MEP ID. |
Severity level |
6 |
Example |
CFD/6/CFD_LOST_CCM: MEP 1 in SI 7 failed to receive CCMs from RMEP 2. |
Explanation |
A MEP failed to receive CCMs within 3.5 sending intervals because the link is faulty or the remote MEP does not send CCM within 3.5 sending intervals. |
Check the link status and the configuration of the remote MEP. If the link is down or faulty (becomes unidirectional, for example), restore the link. If the remote MEP is configured with the same service instance, make sure the CCM sending intervals are consistent on both ends. |
CFD_RECEIVE_CCM
Message text |
MEP [UINT16] in SI [INT32] received CCMs from RMEP [UINT16] |
Variable fields |
Severity level |
6 |
Example |
CFD/6/CFD_RECEIVE_CCM: MEP 1 in SI 7 received CCMs from RMEP 2. |
Explanation |
A MEP received CCMs from a remote MEP. |
CFGMAN messages
This section contains configuration management messages.
CFGMAN_ARCHIVE_SCP_FAIL
Message text |
Archive configuration to SCP server failed: IP = [STRING], Directory = [STRING], Username = [STRING] |
Variable fields |
$1: IP address of the SCP server. $2: Directory that saves the configuration archives on the SCP server. $3: Username for logging in to the SCP server. |
Severity level |
5 |
Example |
CFGMAN/5/CFGMAN_ARCHIVE_SCP_FAIL: Archive configuration to SCP server failed: IP = 192.168.21.21, Directory = /test/, Username = admin |
Explanation |
The device failed to archive the running configuration to an SCP server. |
CFGMAN_CFGCHANGED
Message text |
-EventIndex=[INT32]-CommandSource=[INT32]-ConfigSource=[INT32]-ConfigDestination=[INT32]; Configuration changed. |
Variable fields |
$1: Event index in the range of 1 to 2147483647. $2: Configuration change source: ¡ cli—The configuration change came from the CLI. ¡ snmp—The configuration change came from SNMP or was a configuration database change detected by SNMP. ¡ other—The configuration change came from other sources. $3: Source configuration: ¡ erase—Deleting or renaming a configuration file. ¡ running—Saving the running configuration. ¡ commandSource—Copying a configuration file. ¡ startup—Saving the running configuration to the next-startup configuration file. ¡ local—Saving the running configuration to a local file. ¡ networkFtp—Using FTP to transfer and save a configuration file to the device as the running configuration or next-startup configuration file. ¡ hotPlugging—A card hot swapping caused the configuration to be deleted or become ineffective. $4: Destination configuration: ¡ erase—Deleting or renaming a configuration file. ¡ running—Saving the running configuration. ¡ commandSource—Copying a configuration file. ¡ startup—Saving the running configuration to the next-startup configuration file. ¡ local—Saving the running configuration to a local file. ¡ networkFtp—Using FTP to transfer and save a configuration file to the device as the running configuration or next-startup configuration file. ¡ hotPlugging—A card hot swapping caused the configuration to be deleted or become ineffective. |
Severity level |
5 |
Example |
CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=[6]-CommandSource=[snmp]-ConfigSource=[startup]-ConfigDestination=[running]; Configuration changed. |
Explanation |
The running configuration changed in the past 10 minutes. |
CFGMAN_EXIT_FROM_CONFIGURE
Message text |
Line=[STRING], IP address=[STRING], user=[STRING]; Exit from the system view or a feature view to the user view. |
Variable fields |
$1: User line name. If the system failed to obtain the user line name, this field displays two asterisks (**). $2: IP address of the user. If the system failed to obtain the IP address, this field displays two asterisks (**). $3: Username. If the system failed to obtain the username, this field displays two asterisks (**). |
Severity level |
5 |
Example |
CFGMAN/5/CFGMAN_EXIT_FROM_CONFIGURE: Line=con0, IP address=**, user=**; Exit from the system view or a feature view to the user view. |
Explanation |
The user exited from system view or a feature view to user view. |
CFGMAN_OPTCOMPLETION
Message text |
-OperateType=[INT32]-OperateTime=[INT32]-OperateState=[INT32]-OperateEndTime=[INT32]; Operation completed. |
Variable fields |
$1: Operation type: ¡ running2startup—Saves the running configuration to the next-startup configuration file. ¡ startup2running—Loads the configuration in the next-startup configuration file. ¡ running2net—Saves the running configuration to a host on the network. ¡ net2running—Transfers a configuration file from a host on the network and loads the configuration. ¡ net2startup—Transfers a configuration file from a host on the network and specifies the file as the next-startup configuration file. ¡ startup2net—Copies the next-startup configuration file to a host on the network. $2: Operation start time. $3: Operation status: ¡ InProcess—Operation is in progress. ¡ success—Operation succeeded. ¡ InvalidOperation—Invalid operation. ¡ InvalidProtocol—Invalid protocol. ¡ InvalidSource—Invalid source file name. ¡ InvalidDestination—Invalid destination file name. ¡ InvalidServer—Invalid server address. ¡ DeviceBusy—The device is busy. ¡ InvalidDevice—Invalid device address. ¡ DeviceError—An error occurred on the device. ¡ DeviceNotWritable—The storage medium on the device is write protected. ¡ DeviceFull—The device does not have enough free storage space for the file. ¡ FileOpenError—Failed to open the file. ¡ FileTransferError—Failed to transfer the file. ¡ ChecksumError—File checksum error. ¡ LowMemory—The memory space is not sufficient. ¡ AuthFailed—User authentication failed. ¡ TransferTimeout—Transfer timed out. ¡ UnknownError—An unknown error occurred. ¡ invalidConfig—Invalid configuration. $4: Operation end time. |
Severity level |
5 |
Example |
CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=[running2startup]-OperateTime=[248]-OperateState=[success]-OperateEndTime=[959983]; Operation completed. |
Explanation |
The device is performing or has completed an operation. |
If the operation is not successful, locate and resolve the issue. |
CONNLMT messages
This section contains connection limit messages.
CONNLMT_IPV4_OVERLOAD
Message text |
RcvIfName(1023)=[STRING];Protocol(1001)=[STRING];SrcIPAddr(1003)=[IPADDR];DstIPAddr(1007)=[IPADDR];ServicePort(1071)=[UINT16];RcvVPNInstance(1042)=[STRING];SndVPNInstance(1043)=[STRING];SndDSLiteTunnelPeer(1041)=[STRING];UpperLimit(1049)=[UINT32];LimitRuleNum(1051)=[UINT16];Event(1048)=[STRING]; |
Variable fields |
$1: Global, or interface name. $2: Transport layer protocol type. $3: Source IP address. $4: Destination IP address. $5: Service port number. $6: Source VPN instance name. $7: Destination VPN instance name. $8: Peer tunnel ID. $9: Upper threshold. $10: Rule ID. $11: Event message. |
Severity level |
6 |
Example |
CONNLMT/6/CONNLMT_IPV4_OVERLOAD: RcvIfName(1023)=Global;Protocol(1001)=;SrcIPAddr(1003)=10.10.10.1;DstIPAddr(1007)=;ServicePort(1071)=;RcvVPNInstance(1042)=;SndVPNInstance(1043)=;SndDSLiteTunnelPeer(1041)=;UpperLimit(1049)=1000;LimitRuleNum(1051)=1;Event(1048)=Exceeds upper threshold; |
Explanation |
The number of concurrent connections exceeded the upper threshold. |
CONNLMT_IPV4_RECOVER
Message text |
RcvIfName(1023)=[STRING];Protocol(1001)=[STRING];SrcIPAddr(1003)=[IPADDR];DstIPAddr(1007)=[IPADDR];ServicePort(1071)=[UINT16];RcvVPNInstance(1042)=[STRING];SndVPNInstance(1043)=[STRING];SndDSLiteTunnelPeer(1041)=[STRING];DropPktCount(1052)=[UINT32];LowerLimit(1050)=[UINT32];LimitRuleNum(1051)=[UINT16];Event(1048)=[STRING]; |
Variable fields |
$1: Global, or interface name. $2: Transport layer protocol type. $3: Source IP address. $4: Destination IP address. $5: Service port number. $6: Source VPN instance name. $7: Destination VPN instance name. $8: Peer tunnel ID. $9: Number of dropped packets. $10: Lower threshold. $11: Rule ID. $12: Event message. |
Severity level |
6 |
Example |
CONNLMT/6/CONNLMT_IPV4_RECOVER: RcvIfName(1023)=Global;Protocol(1001)=;SrcIPAddr(1003)=10.10.10.1;DstIPAddr(1007)=;ServicePort(1071)=;RcvVPNInstance(1042)=;SndVPNInstance(1043)=;SndDSLiteTunnelPeer(1041)=;DropPktCount(1052)=306004;LowerLimit(1050)=10;LimitRuleNum(1051)=1;Event(1048)=Reduces below lower threshold; |
Explanation |
The number of concurrent connections dropped to the lower threshold from the upper threshold. |
CONNLMT_IPV6_OVERLOAD
Message text |
RcvIfName(1023)=[STRING];Protocol(1001)=[STRING];SrcIPv6Addr(1036)=[IPADDR];DstIPv6Addr(1037)=[IPADDR];ServicePort(1071)=[UINT16];RcvVPNInstance(1042)=[STRING];SndVPNInstance(1043)=[STRING];SndDSLiteTunnelPeer(1041)=[STRING];UpperLimit(1049)=[UINT32];LimitRuleNum(1051)=[UINT16];Event(1048)=[STRING]; |
Variable fields |
$1: Global, or interface name. $2: Transport layer protocol type. $3: Source IPv6 address. $4: Destination IPv6 address. $5: Service port number. $6: Source VPN instance name. $7: Destination VPN instance name. $8: Peer tunnel ID. $9: Upper threshold. $10: Rule ID. $11: Event message. |
Severity level |
6 |
Example |
CONNLMT/6/CONNLMT_IPV6_OVERLOAD: RcvIfName(1023)=Global;Protocol(1001)=;SrcIPv6Addr(1036)=2001::1;DstIPv6Addr(1037)=;ServicePort(1071)=;RcvVPNInstance(1042)=;SndVPNInstance(1043)=;SndDSLiteTunnelPeer(1041)=;UpperLimit(1049)=1000;LimitRuleNum(1051)=1;Event(1048)=Exceeds upper threshold; |
Explanation |
CONNLMT_IPV6_RECOVER
Message text |
RcvIfName(1023)=[STRING];Protocol(1001)=[STRING];SrcIPv6Addr(1036)=[IPADDR];DstIPv6Addr(1037)=[IPADDR];ServicePort(1071)=[UINT16];RcvVPNInstance(1042)=[STRING];SndVPNInstance(1043)=[STRING];SndDSLiteTunnelPeer(1041)=[STRING];DropPktCount(1052)=[UINT32];LowerLimit(1050)=[UINT32];LimitRuleNum(1051)=[UINT16];Event(1048)=[STRING]; |
Variable fields |
$1: Global, or interface name. $2: Transport layer protocol type. $3: Source IPv6 address. $4: Destination IPv6 address. $5: Service port number. $6: Source VPN instance name. $7: Destination VPN instance name. $8: Peer tunnel ID. $9: Number of dropped packets. $10: Lower threshold. $11: Rule ID. $12: Event message. |
Severity level |
6 |
Example |
CONNLMT/6/CONNLMT_IPV6_RECOVER: RcvIfName(1023)=Global;Protocol(1001)=;SrcIPAddr(1003)=2001::1;DstIPAddr(1007)=;ServicePort(1071)=;RcvVPNInstance(1042)=;SndVPNInstance(1043)=;SndDSLiteTunnelPeer(1041)=;DropPktCount(1052)=306004;LowerLimit(1050)=10;LimitRuleNum(1051)=1;Event(1048)=Reduces below lower threshold; |
Explanation |
DEV messages
This section contains device management messages.
BOARD_INSERTED
Board was inserted on [STRING], type is unknown. |
Variable fields |
$1: Chassis number and slot number or slot number. |
Severity level |
5 |
Example |
DEV/5/BOARD_INSERTED: Board was inserted on slot 1, type is unknown. |
Explanation |
A card of an unknown type was installed on the device. The device outputs this log message before a newly installed card starts up. |
BOARD_REBOOT
Message text |
Board is rebooting on [STRING]. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/BOARD_REBOOT: Board is rebooting on slot 1. |
Explanation |
A card was manually or automatically rebooted. |
If an unexpected automatic reboot occurred, perform the following tasks: 28. Execute the display version command after the slot starts up. 29. Check the Last reboot reason field for the reboot reason. 30. If an exception caused the reboot, contact HP Support. |
BOARD_REMOVED
Message text |
Board was removed from [STRING], type is [STRING]. |
Variable fields |
$1: Chassis number and slot number or slot number. $2: Card type. |
Severity level |
3 |
Example |
DEV/3/BOARD_REMOVED: Board was removed from slot 1, type is LSQ1FV48SA. |
Explanation |
An LPU or a standby MPU was removed from a member device, causing the device to leave the IRF fabric. |
If the LPU or MPU was not manually removed, perform the following tasks: 31. Verify that the card is securely seated. 32. Replace the card if the message persists. 33. Reboot the device to make it join the IRF fabric. 34. If the problem persists, contact HP Support. |
BOARD_STATE_FAULT
Message text |
Board state changed to Fault on [STRING], type is [STRING]. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on slot 1, type is LSQ1FV48SA. |
Explanation |
The card was starting up (initializing or loading software) or was not operating correctly. |
· If the card was newly installed, wait for the card to start up. The required startup time varies by card model and software version and is typically less than 10 minutes. · If the card was not newly installed, contact HP Support. |
BOARD_STATE_NORMAL
Message text |
Board state changed to Normal on [STRING], type is [STRING]. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on slot 1, type is LSQ1FV48SA. |
Explanation |
A newly installed LPU or standby MPU completed initialization. |
BOARD_STATE_STARTING
Message text |
Board state changed to Starting on [STRING], type is unknown. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/BOARD_STATE_STARTING: Board state changed to Starting on slot 1, type is unknown. |
Explanation |
A card was starting up (initializing or loading software). |
35. Verify that the card model is compatible with the device model. 36. Verify that the startup software images, the device software version, and the hardware are compatible. 37. If the problem persists, contact HP Support. |
CFCARD_INSERTED
Message text |
CF card was inserted in [STRING] CF card slot [INT32]. |
Variable fields |
Severity level |
4 |
Example |
DEV/4/CFCARD_INSERTED: CF card was inserted in slot 1 CF card slot 1. |
Explanation |
A CF card was installed. |
CFCARD_REMOVED
Message text |
CF card was removed from [STRING] CF card slot [INT32]. |
Variable fields |
$1: Chassis number and slot number or slot number. $2: CF card slot number. |
Severity level |
3 |
Example |
DEV/3/CFCARD_REMOVED: CF card was removed from slot 1 CF card slot 1. |
Explanation |
A CF card was removed. |
If the CF card was not manually removed, perform the following tasks: 38. Verify that the card is securely seated. 39. Replace the card if the message persists. 40. If the problem persists, contact HP Support. |
CHASSIS_REBOOT
Message text |
Chassis [INT32] is rebooting now. |
Variable fields |
$1: Chassis number. |
Severity level |
5 |
Example |
DEV/5/CHASSIS_REBOOT: Chassis 1 is rebooting now. |
Explanation |
The chassis was manually or automatically rebooted. |
If an unexpected automatic reboot occurs, perform the following tasks: 41. Execute the display version command after the chassis starts up. 42. Check the Last reboot reason field for the reboot reason. 43. If an exception caused the reboot, contact HP Support. |
DEV_CLOCK_CHANGE
Message text |
-User=[STRING]-IPAddr=[IPADDR]; System clock changed from [STRING] to [STRING]. |
Variable fields |
$1: Username of the login user. $2: IP address of the login user. $3: Old time. $4: New time. |
Severity level |
5 |
Example |
DEV/5/DEV_CLOCK_CHANGE: -User=admin-IPAddr=192.168.1.2; System clock changed from 15:49:52 01/02/2013 to 15:50:00 01/02/2013. |
Explanation |
The system time changed. |
DEV_FAULT_TOOLONG
Message text |
Card in [STRING] is still in Fault state for [INT32] minutes. |
Variable fields |
$1: Chassis number and slot number or slot number. $2: Time duration during which the card stayed in Fault state. |
Severity level |
4 |
Example |
DEV/4/DEV_FAULT_TOOLONG: Card in slot 1 is still in Fault state for 60 minutes. |
Explanation |
A card stayed in Fault state for a long period of time. |
44. Reboot the card. 45. If the problem persists, contact HP Support. |
FAN_ABSENT
Message text |
Pattern 1: Fan [INT32] is absent. Pattern 2: Chassis [INT32] fan [INT32] is absent. |
Variable fields |
Pattern 1: $1: Fan tray number. Pattern 2: $1: Chassis number. $2: Fan tray number. |
Severity level |
3 |
Example |
DEV/3/FAN_ABSENT: Fan 2 is absent. |
Explanation |
A fan tray was not in place. |
46. Check the fan tray slot: ¡ If the fan tray slot is empty, the temperature might have increased and the system recommends that you install a fan tray. ¡ If a fan tray is present, verify that the fan tray is securely seated. 47. Replace the fan tray if the message persists. 48. If the problem persists, contact HP Support. |
FAN_DIRECTION_NOT_PREFERRED
Message text |
Fan [INT32] airflow direction is not preferred on [STRING], please check it. |
Variable fields |
$1: Fan tray number. $2: Chassis number and slot number or slot number. |
Severity level |
1 |
Example |
DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 1 airflow direction is not preferred on slot 1, please check it. |
Explanation |
The airflow direction of the fan tray is different from the airflow direction setting. |
49. Verify that the airflow direction setting is correct. 50. Verify that the fan tray model provides the same airflow direction as the configured setting. 51. If the problem persists, contact HP Support. |
FAN_FAILED
Message text |
Pattern 1: Fan [INT32] failed. Pattern 2: Chassis [INT32] fan [INT32] failed. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/FAN_FAILED: Fan 2 failed. |
Explanation |
The fan tray stopped because of an exception. |
Replace the fan tray. |
FAN_RECOVERED
Message text |
Pattern 1: Fan [INT32] recovered. Pattern 2: Chassis [INT32] fan [INT32] recovered. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/FAN_RECOVERED: Fan 2 recovered. |
Explanation |
The fan tray started to operate correctly after it was installed. |
MAD_DETECT
Message text |
Multi-active devices detected, please fix it. |
Variable fields |
N/A |
Severity level |
1 |
Example |
DEV/1/MAD_DETECT: Multi-active devices detected, please fix it. |
Explanation |
Multiple member devices were found active. |
52. Use the display irf command to view which member devices have left the original IRF fabric. 53. Use the display irf link command to locate the IRF link with problems. 54. Fix the IRF link in DOWN state. |
MAD_PROC
Message text |
[STRING] protocol detected MAD conflict: Local health value=[UINT32], Peer health value=[UINT32]. |
Variable fields |
$1: Protocol that detected the MAD conflict, ARP, ND, LACP, or BFD. $2: Current health value of the local IRF. $3: Current health value of the peer IRF. |
Severity level |
6 |
Example |
DEV/6/MAD_PROC: ARP protocol detected MAD conflict: Local health value=1, Peer health value=0. |
Explanation |
ARP, ND, LACP, or BFD detected a MAD conflict on the IRF fabric. A health value of 0 indicates that the IRF fabric is healthy. A greater health value indicates a worse health situation. |
POWER_ABSENT
Message text |
Pattern 1: Power [INT32] is absent. Pattern 2: Chassis [INT32] power [INT32] is absent. |
Variable fields |
Pattern 1: $1: Power supply number. Pattern 2: $1: Chassis number. $2: Power supply number. |
Severity level |
3 |
Example |
DEV/3/POWER_ABSENT: Power 1 is absent. |
Explanation |
A power supply was removed. |
55. Check the power supply slot. ¡ If the power supply slot is empty, install a power supply. ¡ If a power supply is present, verify that the power supply is securely seated. 56. If the problem persists, replace the power supply. 57. If the problem persists, contact HP Support. |
POWER_FAILED
Message text |
Pattern 1: Power [INT32] failed. Pattern 2: Chassis [INT32] power [INT32] failed. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/POWER_FAILED: Power 1 failed. |
Explanation |
A power supply failed. |
Replace the power supply. |
POWER_MONITOR_ABSENT
Message text |
Pattern 1: Power monitor unit [INT32] is absent. Pattern 2: Chassis [INT32] power monitor unit [INT32] is absent. |
Variable fields |
Pattern 1: $1: Power monitoring module number. Pattern 2: $1: Chassis number. $2: Power monitoring module number. |
Severity level |
3 |
Example |
DEV/3/POWER_MONITOR_ABSENT: Power monitor unit 1 is absent. |
Explanation |
A power monitoring module was removed. |
58. Check the power monitoring module slot. ¡ If the power monitoring module slot is empty, install a power monitoring module. ¡ If a power monitoring module is present, verify that the power monitoring module is securely seated. 59. If the problem persists, replace the power monitoring module. 60. If the problem persists, contact HP Support. |
POWER_MONITOR_FAILED
Message text |
Pattern 1: Power monitor unit [INT32] failed. Pattern 2: Chassis [INT32] power monitor unit [INT32] failed. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/POWER_MONITOR_FAILED: Power monitor unit 1 failed. |
Explanation |
A power monitoring module failed. |
Replace the power monitoring module. |
POWER_MONITOR_RECOVERED
Message text |
Pattern 1: Power monitor unit [INT32] recovered. Pattern 2: Chassis [INT32] power monitor unit [INT32] recovered. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/POWER_MONITOR_RECOVERED: Power monitor unit 1 recovered. |
Explanation |
The power monitoring module started to operate correctly after it was installed. |
POWER_RECOVERED
Message text |
Pattern 1: Power [INT32] recovered. Pattern 2: Chassis [INT32] power [INT32] recovered. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/POWER_RECOVERED: Power 1 recovered. |
Explanation |
The power supply started to operate correctly after it was installed. |
RPS_ABSENT
Message text |
Pattern 1: RPS [INT32] is absent. Pattern 2: Chassis [INT32] RPS [INT32] is absent. |
Variable fields |
Pattern 1: $1: RPS number. Pattern 2: $1: Chassis number. $2: RPS number. |
Severity level |
3 |
Example |
DEV/3/RPS_ABSENT: RPS 1 is absent. |
Explanation |
An RPS was removed. |
61. Check the RPS slot. ¡ If the RPS slot is empty, install an RPS. ¡ If an RPS is present, verify that the RPS is securely seated. 62. If the problem persists, replace the RPS. 63. If the problem persists, contact HP Support. |
RPS_FAILED
Message text |
Pattern 1: RPS [INT32] failed. Pattern 2: Chassis [INT32] RPS [INT32] failed. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/RPS_FAILED: RPS 2 failed. |
Explanation |
An RPS failed or is not providing power. |
64. Verify that the power cable is firmly connected. 65. If the problem persists, remove the RPS and then install it again. 66. If the problem persists, replace the RPS. |
RPS_NORMAL
Message text |
Pattern 1: RPS [INT32] is normal. Pattern 2: Chassis [INT32] RPS [INT32] is normal. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/RPS_NORMAL: RPS 1 is normal. |
Explanation |
The RPS started to operate correctly after it was installed. |
SUBCARD_FAULT
Message text |
Subcard state changed to Fault on [STRING] subslot [INT32], type is [STRING]. |
Variable fields |
$1: Chassis number and slot number or slot number. $2: Subslot number. $3: Subcard type. |
Severity level |
2 |
Example |
DEV/2/SUBCARD_FAULT: Subcard state changed to Fault on slot 1 subslot 1, type is MIM-1ATM-OC3SML. |
Explanation |
The subcard failed, or its status changed to Fault after it was rebooted. |
Track the status of the subcard. · If the status of the subcard changes to Normal later, no action is required. · If the status is always Fault, replace the subcard. |
SUBCARD_INSERTED
Message text |
Subcard was inserted in [STRING] subslot [INT32], type is [STRING]. |
Variable fields |
Severity level |
4 |
Example |
DEV/4/SUBCARD_INSERTED: Subcard was inserted in slot 1 subslot 1, type is MIM-1ATM-OC3SML. |
Explanation |
A subcard was installed. |
SUBCARD_REBOOT
Message text |
Subcard is rebooting on [STRING] subslot [INT32]. |
Variable fields |
$1: Chassis number and slot number or slot number. $2: Subslot number. |
Severity level |
5 |
Example |
DEV/5/SUBCARD_REBOOT: Subcard is rebooting on slot 1 subslot 1. |
Explanation |
The subcard was manually or automatically rebooted. |
· If the subcard operates correctly after it starts up, no action is required. · If you want to know the reboot reason or the subcard keeps rebooting, contact HP Support. |
SUBCARD_REMOVED
Message text |
Subcard was removed from [STRING] subslot [INT32], type is [STRING]. |
Variable fields |
Severity level |
3 |
Example |
DEV/3/SUBCARD_REMOVED: Subcard was removed from slot 1 subslot 1, type is MIM-1ATM-OC3SML. |
Explanation |
A subcard was removed. |
If the subcard was not manually removed, perform the following tasks: 67. Verify that the subcard is securely seated. 68. Replace the subcard if the message persists. 69. If the problem persists, contact HP Support. |
SYSTEM_REBOOT
Message text |
System is rebooting now. |
Variable fields |
N/A |
Severity level |
5 |
Example |
DEV/5/SYSTEM_REBOOT: System is rebooting now. |
Explanation |
The system was manually or automatically rebooted. |
If an unexpected automatic reboot occurred, perform the following tasks: 70. Execute the display version command after the system starts up. 71. Check the Last reboot reason field for the reboot reason. 72. If an exception caused the reboot, contact HP Support. |
TEMPERATURE_ALARM
Message text |
Pattern 1: Temperature is greater than the high-temperature alarming threshold on sensor [STRING] [USHOT]. Pattern 2: Temperature is greater than the high-temperature alarming threshold on [STRING] sensor [STRING] [USHOT]. Pattern 3: Temperature is greater than the high-temperature alarming threshold on [STRING] [STRING] sensor [STRING] [USHOT]. |
Variable fields |
Pattern 1: $1: Sensor type. $2: Sensor number. Pattern 2: $1: Slot number. $2: Sensor type. $3: Sensor number. Pattern 3: $1: Chassis number. $2: Slot number. $3: Sensor type. $4: Sensor number. |
Severity level |
4 |
Example |
DEV/4/TEMPERATURE_ALARM: Temperature is greater than the high-temperature alarming threshold on slot 1 sensor inflow 1. |
Explanation |
A sensor's temperature exceeded the high-temperature alarming threshold. The ambient temperature was too high or the fan tray was not operating correctly. |
73. Verify that the ambient temperature is normal and the ventilation system is operating correctly. 74. Use the display fan command to verify that the fan trays are in position and operating correctly. If a fan tray is missing, install the fan tray. If a fan tray does not operate correctly, replace it. |
TEMPERATURE_LOW
Message text |
Pattern 1: Temperature is less than the low-temperature threshold on sensor [STRING] [INT32]. Pattern 2: Temperature is less than the low-temperature threshold on [STRING] sensor [STRING] [INT32]. Pattern 3: Temperature is less than the low-temperature threshold on [STRING] [STRING] sensor [STRING] [INT32]. |
Variable fields |
Severity level |
4 |
Example |
DEV/4/TEMPERATURE_LOW: Temperature is less than the low-temperature threshold on slot 1 sensor inflow 1. |
Explanation |
A sensor's temperature fell below the low-temperature threshold. |
Adjust the ambient temperature higher. |
TEMPERATURE_NORMAL
Message text |
Pattern 1: Temperature changed to normal on sensor [STRING] [INT32]. Pattern 2: Temperature changed to normal on [STRING] sensor [STRING] [INT32]. Pattern 3: Temperature changed to normal on [STRING] [STRING] sensor [STRING] [INT32]. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on slot 1 sensor inflow 1. |
Explanation |
A sensor's temperature was normal (between the low-temperature threshold and the high-temperature warning threshold). |
TEMPERATURE_SHUTDOWN
Message text |
Pattern 1: Temperature is greater than the high-temperature shutdown threshold on sensor [STRING] [INT32]. The slot will be powered off automatically. Pattern 2: Temperature is greater than the high-temperature shutdown threshold on [STRING] sensor [STRING] [INT32]. The slot will be powered off automatically. Pattern 3: Temperature is greater than the high-temperature shutdown threshold on [STRING] [STRING] sensor [STRING] [INT32]. The slot will be powered off automatically. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/TEMPERATURE_SHUTDOWN: Temperature is greater than the high-temperature shutdown threshold on slot 1 sensor inflow 1. The slot will be powered off automatically. |
Explanation |
A sensor's temperature exceeded the high-temperature shutdown threshold. The ambient temperature was too high or the fan tray was not operating correctly. |
75. Verify that the ambient temperature is normal and the ventilation system is operating correctly. 76. Use the display fan command to verify that the fan trays are in position and operating correctly. If a fan tray is missing, install the fan tray. If a fan tray does not operate correctly, replace it. |
TEMPERATURE_WARNING
Message text |
Pattern 1: Temperature is greater than the high-temperature warning threshold on sensor [STRING] [INT32]. Pattern 2: Temperature is greater than the high-temperature warning threshold on [STRING] sensor [STRING] [INT32]. Pattern 3: Temperature is greater than the high-temperature warning threshold on [STRING] [STRING] sensor [STRING] [INT32]. |
Variable fields |
Severity level |
4 |
Example |
DEV/4/TEMPERATURE_WARNING: Temperature is greater than the high-temperature warning threshold on slot 1 sensor inflow 1. |
Explanation |
A sensor's temperature exceeded the high-temperature warning threshold. The ambient temperature was too high or the fan tray was not operating correctly. |
Recommended action |
77. Verify that the ambient temperature is normal and the ventilation system is operating correctly. 78. Use the display fan command to verify that the fan trays are in position and operating correctly. If a fan tray is missing, install the fan tray. If a fan tray does not operate correctly, replace it. |
VCHK_VERSION_INCOMPATIBLE
Message text |
Software version of [STRING] is incompatible with that of the MPU. |
Variable fields |
Severity level |
1 |
Example |
DEV/1/ VCHK_VERSION_INCOMPATIBLE: Software version of slot 1 is incompatible with that of the MPU. |
Explanation |
A PEX that was starting up detected that its software version is incompatible with the parent device's software version. |
Specify a set of startup software images for the PEX. Make sure the images are compatible with the parent device's software images. |
DHCP
This section contains DHCP messages.
DHCP_NOTSUPPORTED
Message text |
Failed to apply filtering rules for DHCP packets because some rules are not supported. |
Variable fields |
N/A |
Severity level |
3 |
Example |
DHCP/3/DHCP_NOTSUPPORTED: Failed to apply filtering rules for DHCP packets because some rules are not supported. |
Explanation |
The system failed to apply filtering rules for DHCP packets because some rules are not supported on the device. |
No action is required. |
DHCP_NORESOURCES
Message text |
Failed to apply filtering rules for DHCP packets because hardware resources are insufficient. |
Variable fields |
N/A |
Severity level |
3 |
Example |
DHCP/3/DHCP_NORESOURCES: Failed to apply filtering rules for DHCP packets because hardware resources are insufficient. |
Explanation |
The system failed to apply filtering rules for DHCP packets because the hardware resources are insufficient. |
Release hardware resources and then apply the rules again. |
DHCPR
This section contains DHCP relay agent messages.
DHCPR_SERVERCHANGE
Message text |
Switched to the server at [IPADDR] (VPN name: [STRING]) because the current server did not respond. Switched to the DHCP server at [IPADDR] (Public network) because the current DHCP server did not respond. |
Variable fields |
$1: IP address of the DHCP server. $2: VPN information of the DHCP server. $3: IP address of the DHCP server on the public network. |
Severity level |
3 |
Example |
DHCPR/3/DHCPR_SERVERCHANGE: -MDC=1; Switched to the server at 2.2.2.2 ( VPN name: 1 ) because the current server did not respond. |
Explanation |
The DHCP relay agent did not receive any responses from the current DHCP server and switched to another DHCP server in the specified VPN or on the public network for IP address acquisition. |
DHCPR_SWITCHMASTER
Message text |
Switched to the master DHCP server at [IPADDR]. |
Variable fields |
$1: IP address of the master DHCP server. |
Severity level |
3 |
Example |
DHCPR/3/DHCPR_SWITCHMASTER: -MDC=1; Switched to the master DHCP server at 2.2.2.2. |
Explanation |
After a switchback delay time, the DHCP relay agent switched from a backup DHCP server back to the master DHCP server for IP address acquisition. |
DHCPS messages
This section contains DHCP server messages.
DHCPS_ALLOCATE_IP
Message text |
DHCP server received a DHCP client's request packet on interface [STRING], and allocated an IP address [IPADDR](lease [UINT32] seconds) for the DHCP client(MAC [MAC]) from [STRING] pool. |
Variable fields |
$1: Name of the interface on which DHCP server is configured. $2: IPv4 address assigned to the DHCP client. $3: Lease duration of the assigned IPv4 address. $4: MAC address of the DHCP client. $5: Name of the address pool to which the assigned IPv4 address belongs. |
Severity level |
5 |
Example |
DHCPS/5/DHCPS_ALLOCATE_IP: DHCP server received a DHCP client’s request packet on interface Ethernet0/2, and allocated an IP address 1.0.0.91(lease 86400 seconds) for the DHCP client(MAC 0000-0000-905a) from p1 pool. |
Explanation |
The DHCP server assigned an IPv4 address with a lease to a DHCP client. |
DHCPS_CONFLICT_IP
Message text |
A conflict IP [IPADDR] from [STRING] pool was detected by DHCP server on interface [STRING]. |
Variable fields |
$1: IPv4 address that is in conflict. $2: Name of the address pool to which the conflicting IPv4 address belongs. $3: Name of the interface on which DHCP server is configured. |
Severity level |
5 |
Example |
DHCPS/5/DHCPS_CONFLICT_IP: A conflict IP 100.1.1.1 from p1 pool was detected by DHCP server on interface Ethernet0/2. |
Explanation |
The DHCP server deleted a conflicting IPv4 address from an address pool. |
DHCPS_EXTEND_IP
Message text |
DHCP server received a DHCP client's request packet on interface [STRING], and extended lease from [STRING] pool for the DHCP client (IP [IPADDR], MAC [MAC]). |
Variable fields |
$1: Name of the interface on which DHCP server is configured. $2: Name of the address pool to which the client's IPv4 address belongs. $3: IPv4 address of the DHCP client. $4: MAC address of the DHCP client. |
Severity level |
5 |
Example |
DHCPS/5/DHCPS_EXTEND_IP: DHCP server received a DHCP client’s request packet on interface Ethernet0/2, and extended lease from p1 pool for the DHCP client (IP 1.0.0.91, MAC 0000-0000-905a). |
Explanation |
The DHCP server extended the lease for a DHCP client. |
DHCPS_FILE
Message text |
Failed to save DHCP client information due to lack of storage resources. |
Variable fields |
N/A |
Severity level |
4 |
Example |
DHCPS/4/DHCPS_FILE: Failed to save DHCP client information due to lack of storage resources. |
Explanation |
The DHCP server failed to back up DHCP bindings to the backup file due to lack of storage resources. |
Delete unnecessary files to release resources. |
DHCPS_RECLAIM_IP
Message text |
DHCP server reclaimed a [STRING] pool’s lease(IP [IPADDR], lease [UINT32] seconds), which is allocated for the DHCP client (MAC [MAC]). |
Variable fields |
$1: Name of the address pool to which the assigned IPv4 address belongs. $2: IPv4 address assigned to the DHCP client. $3: Lease duration of the assigned IPv4 address. $4: MAC address of the DHCP client. |
Severity level |
5 |
Example |
DHCPS/5/DHCPS_RECLAIM_IP: DHCP server reclaimed a p1 pool’s lease(IP 1.0.0.91, lease 86400 seconds), which is allocated for the DHCP client (MAC 0000-0000-905a). |
Explanation |
The DHCP server reclaimed the IPv4 address assigned to a DHCP client. |
DHCPS_VERIFY_CLASS
Message text |
Illegal DHCP client-PacketType=[STRING]-ClientAddress=[MAC]; |
Variable fields |
$1: Type of the packet. $2: Hardware address of the DHCP client. |
Severity level |
5 |
Example |
Explanation |
The DHCP server verified that the DHCP client was not on the user class whitelist. |
Check the validity of the DHCP client. |
DHCPS6 messages
This section contains DHCPv6 server messages.
DHCPS6_ALLOCATE_ADDRESS
Message text |
DHCPv6 server received a DHCPv6 client’s request packet on interface [STRING], and allocated an IPv6 address [IPADDR] (lease [UINT32] seconds) for the DHCP client(DUID [HEX], IAID [HEX]) from [STRING] pool. |
Variable fields |
$1: Name of the interface on which DHCPv6 server is configured. $2: IPv6 address assigned to the DHCPv6 client. $3: Lease duration of the assigned IPv6 address. $4: DUID of the DHCPv6 client. $5: IAID of the DHCPv6 client. $6: Name of the address pool to which the assigned IPv6 address belongs. |
Severity level |
5 |
Example |
DHCPS6/5/DHCPS6_ALLOCATE_ADDRESS: DHCPv6 server received a DHCPv6 client’s request packet on interface Ethernet0/2, and allocated an IPv6 address 2000::3(lease 60 seconds) for the DHCP client(DUID 0001000118137c37b4b52facab5a, IAID 10b4b52f) from p1 pool. |
Explanation |
The DHCPv6 server assigned an IPv6 address with a lease to a DHCPv6 client. |
DHCPS6_ALLOCATE_PREFIX
Message text |
DHCPv6 server received a DHCPv6 client’s request packet on interface [STRING], and allocated an IPv6 prefix [IPADDR] (lease [UINT32] seconds) for the DHCP client(DUID [HEX], IAID [HEX]) from [STRING] pool. |
Variable fields |
$1: Name of the interface on which DHCPv6 server is configured. $2: IPv6 prefix assigned to the DHCPv6 client. $3: Lease duration of the assigned IPv6 prefix. $4: DUID of the DHCPv6 client. $5: IAID of the DHCPv6 client. $6: Name of the address pool to which the assigned IPv6 prefix belongs. |
Severity level |
5 |
Example |
DHCPS6/5/DHCPS6_ALLOCATE_PREFIX: DHCPv6 server received a DHCPv6 client’s request packet on interface Ethernet0/2, and allocated an IPv6 prefix 2000::(lease 60 seconds) for the DHCP client(DUID 0001000118137c37b4b52facab5a, IAID 10b4b52f) from p1 pool. |
Explanation |
The DHCPv6 server assigned an IPv6 prefix with a lease to a DHCPv6 client. |
DHCPS6_CONFLICT_ADDRESS
A conflict IPv6 address [IPADDR] from [STRING] pool was detected by DHCPv6 server on interface [STRING]. |
Variable fields |
$1: IPv6 address that is in conflict. $2: Name of the address pool to which the conflicting IPv6 address belongs. $3: Name of the interface on which DHCPv6 server is configured. |
Severity level |
5 |
Example |
DHCPS6/5/DHCPS6_CONFLICT_ADDRESS: A conflict IPv6 address 33::1 from p1 pool was detected by DHCPv6 server on interface Ethernet0/2. |
Explanation |
The DHCPv6 server deleted a conflicting IPv6 address from an address pool. |
DHCPS6_EXTEND_ADDRESS
Message text |
DHCPv6 server received a DHCP client’s request packet on interface [STRING], and extended lease from [STRING] pool for the DHCP client (IPv6 address [IPADDR], DUID [HEX], IAID [HEX]). |
Variable fields |
$1: Name of the interface on which DHCPv6 server is configured. $2: Name of the address pool to which the client's IPv6 address belongs. $3: IPv6 address of the DHCPv6 client. $4: DUID of the DHCPv6 client. $5: IAID of the DHCPv6 client. |
Severity level |
5 |
Example |
DHCPS6/5/DHCPS6_EXTEND_ADDRESS: DHCPv6 server received a DHCP client’s request packet on interface Ethernet0/2, and extended lease from p1 pool for the DHCP client (IPv6 address 2000::3, DUID 0001000118137c37b4b52facab5a, IAID 10b4b52f). |
Explanation |
The DHCPv6 server extended the address lease for a DHCPv6 client. |
DHCPS6_EXTEND_PREFIX
Message text |
DHCPv6 server received a DHCP client’s request packet on interface [STRING], and extended lease from [STRING] pool for the DHCP client (IPv6 prefix [IPADDR], DUID [HEX], IAID [HEX]). |
Variable fields |
$1: Name of the interface on which DHCPv6 server is configured. $2: Name of the address pool to which the client's IPv6 prefix belongs. $3: IPv6 prefix of the DHCPv6 client. $4: DUID of the DHCPv6 client. $5: IAID of the DHCPv6 client. |
Severity level |
5 |
Example |
DHCPS6/5/DHCPS6_EXTEND_PREFIX: DHCPv6 server received a DHCP client’s request packet on interface Ethernet0/2, and extended lease from p1 pool for the DHCP client (IPv6 prefix 2000::, DUID 0001000118137c37b4b52facab5a, IAID 10b4b52f). |
Explanation |
The DHCPv6 server extended the prefix lease for a DHCPv6 client. |
DHCPS6_FILE
Message text |
Variable fields |
N/A |
Severity level |
4 |
Example |
DHCPS6/4/DHCPS6_FILE: Failed to save DHCP client information due to lack of storage resources. |
Explanation |
The DHCPv6 server failed to back up DHCPv6 bindings to the backup file due to lack of storage resources. |
DHCPS6_RECLAIM_ADDRESS
Message text |
DHCPv6 server reclaimed a [STRING] pool's lease(IPv6 address [IPADDR], lease [UINT32] seconds), which is allocated for the DHCPv6 client (DUID [HEX], IAID [HEX]). |
Variable fields |
$1: Name of the address pool to which the assigned IPv6 address belongs. $2: IPv6 address assigned to the DHCPv6 client. $3: Lease duration of the assigned IPv6 address. $4: DUID of the DHCPv6 client. $5: IAID of the DHCPv6 client. |
Severity level |
5 |
Example |
DHCPS6/5/DHCPS6_RECLAIM_ADDRESS: DHCPv6 server reclaimed a p1 pool’s lease(IPv6 address 2000::3, lease 60 seconds), which is allocated for the DHCPv6 client (DUID 0001000118137c37b4b52facab5a, IAID 10b4b52f). |
Explanation |
The DHCPv6 server reclaimed the IPv6 address assigned to a DHCPv6 client. |
DHCPS6_RECLAIM_PREFIX
Message text |
DHCPv6 server reclaimed a [STRING] pool’s lease(IPv6 prefix [IPADDR], lease [INTEGER] seconds), which is allocated for the DHCPv6 client (DUID [HEX], IAID [HEX]). |
Variable fields |
$1: Name of the address pool to which the assigned IPv6 prefix belongs. $2: IPv6 prefix assigned to the DHCPv6 client. $3: Lease duration of the assigned IPv6 prefix. $4: DUID of the DHCPv6 client. $5: IAID of the DHCPv6 client. |
Severity level |
5 |
Example |
DHCPS6/5/DHCPS6_RECLAIM_PREFIX: DHCPv6 server reclaimed a p1 pool’s lease(IPv6 prefix 2000::, lease 60 seconds), which is allocated for the DHCPv6 client (DUID 0001000118137c37b4b52facab5a, IAID 10b4b52f). |
Explanation |
The DHCPv6 server reclaimed the IPv6 prefix assigned to a DHCPv6 client. |
DHCPSP4
This section contains DHCP snooping messages.
DHCPSP4_FILE
Message text |
Variable fields |
N/A |
Severity level |
4 |
Example |
DHCPSP4/4/DHCPSP4_FILE: Failed to save DHCP client information due to lack of storage resources. |
Explanation |
The DHCP snooping device failed to back up DHCP snooping entries to the backup file due to lack of storage resources. |
DHCPSP6
This section contains DHCPv6 snooping messages.
DHCPSP6_FILE
Message text |
Variable fields |
N/A |
Severity level |
4 |
Example |
DHCPSP6/4/DHCPSP6_FILE: Failed to save DHCP client information due to lack of storage resources. |
Explanation |
The DHCPv6 snooping device failed to back up DHCPv6 snooping entries to the backup file due to lack of storage resources. |
DIAG messages
This section contains diagnostic messages.
CPU_MINOR_RECOVERY
Message text |
CPU usage recovered to normal state. |
Variable fields |
N/A |
Severity level |
5 |
Example |
DIAG/5/CPU_MINOR_THRESHOLD: CPU usage recovered to normal state. |
Explanation |
The CPU usage decreased below the recovery threshold. The minor alarm was removed and the CPU usage status changed from minor alarm state to recovered state. |
CPU_MINOR_THRESHOLD
Message text |
CPU usage is in minor alarm state. CPU usage: [UINT]% in last 1 minute. CPU usage thresholds: Minor: [UINT]% Severe: [UINT]% Recovery: [UINT]% Process info: JID PID PRI State FDs HH:MM:SS CPU Name [UINT] [UINT] [UINT] [CHAR] [UINT] [CHAR] [CHAR] [CHAR] Core states: ID Idle User Kernel Interrupt Busy CPU[UINT] [CHAR] [CHAR] [CHAR] [CHAR] [CHAR] |
Variable fields |
$1: CPU usage during the last minute. $2: Minor CPU usage alarm threshold. $3: Severe CPU usage alarm threshold. $4: CPU usage recovery threshold. $5: Job ID of the process. $6: PID of the process. $7: Priority of the process. $8: Status of the process. $9: Number of file handles. $10: Running time of the process. $11: CPU usage of the process. $12: Name of the process. $13: Core ID. $14: Idle time. $15: Time used by processes in the user space. $16: Time used by kernel threads. $17: Time used by interrupts. $18: Total time used. |
Severity level |
4 |
Example |
DIAG/4/CPU_MINOR_THRESHOLD: CPU usage is in minor alarm state. CPU usage: 3% in last 1 minute. CPU usage thresholds: Minor: 1% Severe: 2% Recovery: 0% Process info: JID PID PRI State FDs HH:MM:SS CPU Name 108398 108398120 S 36 00:00:0 12.58% snmpd 52 52 102 S 0 00:01:2 2.58% [DRV_FWD] 371 371 120 S 95 00:18:5 0.17% pppd 90 90 120 R 18 00:12:0 0.34% diagd 109 109 119 S 41 00:11:1 0.00% vbrd Core states: ID Idle User Kernel Interrupt Busy CPU0 98.61% 0.24% 0.62% 0.53% 1.39% CPU1 99.88% 0.00% 0.03% 0.09% 0.12% |
Explanation |
The CPU usage increased above the minor alarm threshold and entered minor alarm state. The device sends this message periodically until the CPU usage increases above the severe threshold or the minor alarm is removed. |
Operate according to prompt information and use CPU resource reasonably. |
CPU_SEVERE_RECOVERY
Message text |
CPU usage severe alarm removed. |
Variable fields |
N/A |
Severity level |
5 |
Example |
DIAG/5/CPU_RECOVERY: CPU usage severe alarm removed. |
Explanation |
The CPU usage decreased to or below the minor alarm threshold and the severe alarm was removed. |
CPU_SEVERE_THRESHOLD
Message text |
CPU usage is in severe alarm state. CPU usage: [UINT]% in last 1 minute. CPU usage thresholds: Minor: [UINT]% Severe: [UINT]% Recovery: [UINT]% Process info: JID PID PRI State FDs HH:MM:SS CPU Name [UINT] [UINT] [UINT] [CHAR] [UINT] [CHAR] [CHAR] [CHAR] Core states: ID Idle User Kernel Interrupt Busy CPU[UINT] [CHAR] [CHAR] [CHAR] [CHAR] [CHAR] |
Variable fields |
Severity level |
3 |
Example |
DIAG/3/CPU_THRESHOLD: CPU usage is in severe alarm state. CPU usage: 3% in last 1 minute. CPU usage thresholds: Minor: 1% Severe: 2% Recovery: 0% Process info: JID PID PRI State FDs HH:MM:SS CPU Name 108398 108398120 S 36 00:00:0 12.58% snmpd 52 52 102 S 0 00:01:2 2.58% [DRV_FWD] 371 371 120 S 95 00:18:5 0.17% pppd 90 90 120 R 18 00:12:0 0.34% diagd 109 109 119 S 41 00:11:1 0.00% vbrd Core states: ID Idle User Kernel Interrupt Busy CPU0 98.61% 0.24% 0.62% 0.53% 1.39% CPU1 99.88% 0.00% 0.03% 0.09% 0.12% |
Explanation |
The CPU usage increased above the severe alarm threshold and entered severe alarm state. The device sends this message periodically until the severe alarm is removed. |
Use the display current-configuration | include "monitor cpu-usage" command to view the alarm thresholds. Use the monitor cpu-usage command to adjust the alarm thresholds as required. |
CPU_USAGE_LASTMINUTE
Message text |
CPU usage was [STRING] in last minute. |
Variable fields |
$1: CPU usage in percentage. |
Severity level |
5 |
Example |
DIAG/5/CPU_USAGE_LASTMINUTE: CPU usage was 10% in last minute. |
Explanation |
This message indicates the average CPU usage in the last minute. |
MEM_ALERT
Message text |
system memory info: total used free shared buffers cached Mem: [ULONG] [ULONG] [ULONG] [ULONG] [ULONG] [ULONG] -/+ buffers/cache: [ULONG] [ULONG] Swap: [ULONG] [ULONG] [ULONG] Lowmem: [ULONG] [ULONG] [ULONG] |
Variable fields |
· Mem—Memory information of the whole system: ¡ $1: Total size of allocatable physical memory. The system physical memory contains allocatable physical memory and unallocatable physical memory. Unallocatable physical memory is mainly used for kernel code storage, kernel management, and running of basic functions. Allocatable physical memory is used for such tasks as running service modules and storing files. The size of unallocatable physical memory is automatically calculated based on the system operation requirements. The size of allocatable physical memory is the total physical memory size minus the unallocatable physical memory size. ¡ $2: Size of the physical memory used by the system. ¡ $3: Size of free physical memory of the system. ¡ $4: Total size of physical memory shared by processes. ¡ $5: Size of physical memory used for buffers. ¡ $6: Size of physical memory used for caches. · -/+ buffers/cache—Memory usage information of applications: ¡ $7: -/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the size of physical memory used by applications. ¡ $8: -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the size of physical memory available for applications. · Swap—Swap memory usage information: ¡ $9: Total size of swap memory. ¡ $10: Size of used swap memory. ¡ $11: Size of free swap memory. · Lowmem—Low memory usage information: ¡ $12: Total size of low memory. ¡ $13: Size of used low memory. ¡ $14: Size of free low memory. |
Severity level |
4 |
Example |
DIAG/4/MEM_ALERT: system memory info: total used free shared buffers cached Mem: 1784424 920896 863528 0 0 35400 -/+ buffers/cache: 885496 898928 Swap: 0 0 0 Lowmem: 735848 637896 97952 |
Explanation |
A memory alarm was generated, displaying memory usage information. The system generates this message when the used memory is greater than or equal to the minor, severe, or critical threshold of memory usage. |
You can perform the following tasks to help remove the alarm: · Verify that appropriate alarm thresholds are set. To view the alarm thresholds, use the display memory-threshold command. Then you can use the memory-threshold command to modify the alarm thresholds if required. · Verify that the device is not under attack by checking the ARP table and routing table. · Examine and optimize the network, for example, reduce the number of routes, or replace the device with a higher-performance device. |
MEM_BELOW_THRESHOLD
Message text |
Memory usage has dropped below [STRING] threshold. |
Variable fields |
$1: Memory usage threshold name: minor, severe, or critical. |
Severity level |
1 |
Example |
DIAG/1/MEM_BELOW_THRESHOLD: Memory usage has dropped below critical threshold. |
Explanation |
A memory alarm was removed. The message is sent when the system free memory is greater than a memory alarm recovery threshold. |
MEM_EXCEED_THRESHOLD
Message text |
Memory [STRING] threshold has been exceeded. |
Variable fields |
Severity level |
1 |
Example |
DIAG/1/MEM_EXCEED_THRESHOLD: Memory minor threshold has been exceeded. |
Explanation |
A memory alarm was notified. When the used memory size is greater than or equal to the minor, severe, or critical threshold of memory usage, the system generates this message and notifies services modules to perform auto repair, such as releasing memory and stopping requesting memory. |
You can perform the following tasks to help remove the alarm: · Verify that appropriate alarm thresholds are set. To view the alarm thresholds, use the display memory-threshold command. Then you can use the memory-threshold command to modify the alarm thresholds if required. · Verify that the device is not under attack by checking the ARP table and routing table. · Examine and optimize the network, for example, reduce the number of routes or replace the device with a higher-performance device. |
MEM_USAGE
Message text |
Current memory usage is [STRING]. |
Variable fields |
$1: Memory usage in percentage. |
Severity level |
5 |
Example |
DIAG/5/MEM_USAGE: Current memory usage is 10%. |
Explanation |
This message indicates the current memory usage. |
DLDP messages
This section contains DLDP messages.
DLDP_AUTHENTICATION_FAILED
Message text |
The DLDP packet failed the authentication because of unmatched [STRING] field. |
Variable fields |
$1: Authentication field. · AUTHENTICATION PASSWORD—Authentication password mismatch. · AUTHENTICATION TYPE—Authentication type mismatch. · INTERVAL—Advertisement interval mismatch. |
Severity level |
5 |
Example |
DLDP/5/DLDP_AUTHENTICATION_FAILED: The DLDP packet failed the authentication because of unmatched INTERVAL field. |
Explanation |
The packet authentication failed. Possible reasons include unmatched authentication type, unmatched authentication password, and unmatched advertisement interval. |
Check the DLDP authentication type, authentication password, and advertisement interval are consistent with peer end. |
DLDP_LINK_BIDIRECTIONAL
Message text |
DLDP detected a bidirectional link on interface [STRING]. |
Variable fields |
$1: Interface name. |
Severity level |
6 |
Example |
DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ethernet1/1. |
Explanation |
DLDP detected a bidirectional link on an interface. |
DLDP_LINK_SHUTMODECHG
Message text |
DLDP automatically [STRING] interface [STRING] because the port shutdown mode was changed [STRING]. |
Variable fields |
$1: Action according to the port shutdown mode: ¡ blocked. ¡ brought up. $2: Interface name. $3: Shutdown mode change: ¡ from manual to auto. ¡ from manual to hybrid. ¡ from hybrid to auto. ¡ from hybrid to manual. |
Severity level |
5 |
Example |
DLDP/5/DLDP_LINK_SHUTMODECHG: DLDP automatically blocked interface Ethernet1/1 because the port shutdown mode was changed from manual to auto. |
Explanation |
The interface was shut down or brought up because the shutdown mode changed. |
DLDP_LINK_UNIDIRECTIONAL
Message text |
DLDP detected a unidirectional link on interface [STRING]. [STRING]. |
Variable fields |
$1: Interface name. $2: Action according to the port shutdown mode: · DLDP automatically blocked the interface. · Please manually shut down the interface. · DLDP automatically shut down the interface. Please manually bring up the interface. |
Severity level |
3 |
Example |
DLDP/3/DLDP_LINK_UNIDIRECTIONAL: DLDP detected a unidirectional link on interface Ethernet1/1. DLDP automatically blocked the interface. |
Explanation |
DLDP detected a unidirectional link on an interface. |
Check for incorrect cable connection, cable falloff, or other problems. |
DLDP_NEIGHBOR_AGED
Message text |
A neighbor on interface [STRING] was deleted because the neighbor was aged. The neighbor's system MAC is [MAC], and the port index is [UINT16]. |
Variable fields |
$1: Interface name. $2: MAC address. $3: Port index. |
Severity level |
5 |
Example |
DLDP/5/DLDP_NEIGHBOR_AGED: A neighbor on interface Ethernet1/1 was deleted because the neighbor was aged. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1. |
Explanation |
The interface deleted an aged neighbor. |
DLDP_NEIGHBOR_CONFIRMED
Message text |
A neighbor was confirmed on interface [STRING]. The neighbor's system MAC is [MAC], and the port index is [UINT16]. |
Variable fields |
Severity level |
6 |
Example |
DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ethernet1/1. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1. |
Explanation |
The interface detected a confirmed neighbor. |
DLDP_NEIGHBOR_DELETED
Message text |
A neighbor on interface [STRING] was deleted because a [STRING] packet arrived. The neighbor's system MAC is [MAC], and the port index is [UINT16]. |
Variable fields |
$1: Interface name. $2: Packet type, DISABLE or LINKDOWN. $3: MAC address. $4: Port index. |
Severity level |
5 |
Example |
DLDP/5/DLDP_NEIGHBOR_DELETED: A neighbor on interface Ethernet1/1 was deleted because a DISABLE packet arrived. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1. |
Explanation |
The interface deleted a confirmed neighbor because it received a DISABLE or LINKDOWN packet. |
DOT1X messages
This section contains 802.1X messages.
DOT1X_CONFIG_NOTSUPPORT
Message text |
802.1X is not supported on interface [STRING]. |
Variable fields |
$1: Interface type and number. |
Severity level |
3 |
Example |
DOT1X/3/DOT1X_CONFIG_NOTSUPPORT: 802.1X is not supported on interface GigabitEthernet1/0/1. |
Explanation |
The interface does not support 802.1X configuration. |
DOT1X_LOGIN_FAILURE
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-ErrCode=[STRING]; User failed 802.1X authentication. Reason: [STRING]. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: VLAN ID. $4: Username. $5: Error code. $6: Failure cause: · MAC address authorization failed. · VLAN authorization failed. · VSI authorization failed. · ACL authorization failed. · User profile authorization failed. · URL authorization failed. |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_LOGIN_FAILURE: -IfName=GigabitEthernet1/0/1-MACAddr=0000-0001-0020-VLANID=2-Username=aaa-ErrCode=5; User failed 802.1X authentication. Reason: ACL authorization failed. |
Explanation |
The user failed 802.1X authentication for a specific reason. |
Locate the failure cause and handle the issue according to the failure cause. |
DOT1X_LOGIN_SUCC
Message text |
-IfName=[STRING]-MACAddr=[STRING]-AccessVLANID=[STRING]-AuthorizationVLANID=[STRING]-Username=[STRING]; User passed 802.1X authentication and came online. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: ID of the access VLAN. $4: ID of the authorization VLAN. $5: Username. |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_LOGIN_SUCC:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-AccessVLANID=444-AuthorizationVLANID=444-Username=aaa; User passed 802.1X authentication and came online. |
Explanation |
The user passed 802.1X authentication. |
DOT1X_LOGIN_SUCC (in open mode)
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]; The user that failed 802.1X authentication passed open authentication and came online. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: VLAN ID. $4: Username. |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_LOGIN_SUCC:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=00-10-84-00-22-b9; The user that failed 802.1X authentication passed open authentication and came online. |
Explanation |
A user failed 802.1X authentication but passed open authentication. |
DOT1X_LOGOFF
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-ErrCode=[STRING]; 802.1X user was logged off. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: VLAN ID. $4: Username. $5: Error code 1, which indicates that the user was logged off. Possible reasons: · The user sent EAPOL-LogOff packets to go offline. · The user is an IP phone user and its PC interface lost connection. |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_LOGOFF:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=aaa-ErrCode=1; 802.1X user was logged off. |
Explanation |
The 802.1X user was logged off as requested. |
DOT1X_LOGOFF (in open mode)
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-ErrCode=[STRING]; 802.1X open user was logged off. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: VLAN ID. $4: Username. $5: Error code. |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_LOGOFF:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=aaa-ErrCode=1; 802.1X open user was logged off. |
Explanation |
An 802.1X open user was logged off as requested. |
DOT1X_LOGOFF_ABNORMAL
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-ErrCode=[STRING]; 802.1X user was logged off abnormally. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: VLAN ID. $4: Username. $5: Error code: · 2—Port status error. Possible reasons: ¡ Authorization request or assignment failed. ¡ The port was down or deactivated while the system was synchronizing or restoring online user information after a process reboot or active/standby switchover. ¡ The authorization VLAN of the user is not in the permitted VLAN list of access port. ¡ 802.1X SmartOn kicked off users that have not passed authentication. · 3—This code is reserved for future use. · 4—Reauthentication failure. · 5—Deauthorization by the device. Possible reasons: ¡ Authorization processing failure. ¡ Number of online users has reached the upper limit. ¡ Open authentication was disabled globally and the open user went offline. ¡ 802.1X was disabled and the user went offline. ¡ MAC-based VLAN disabling event occurred. ¡ The reset dot1x access-user command was executed. · 6—Port went down and then came up again. This code is reserved for future use. · 7—One of the following operations were performed while the system was synchronizing or restoring user information: ¡ Disabled 802.1X. ¡ Executed the dot1x port-method command to change the port access control method. ¡ Executed the dot1x port-control command to change the port authorization state. · 8—Username or password error or lack of device information on the server. · 9—Online handshake failure (the device has not received any handshake packets from the user). · 10—The user was logged off by the idle cut feature. · 11—The session timeout timer expired. · 12—The server logged the user off. ¡ The server forcibly logged the user off. ¡ The server logged the user off through the session-control feature. · 13—Real-time accounting failure. · 14—Default error. Possible reasons: ¡ MAC address binding failure. ¡ The device failed to remove the user from an 802.1X guest VLAN, Auth-Fail VLAN, or critical VLAN after the user passed authentication. ¡ Accounting failure. ¡ The device failed to perform reauthorization for the user after processing an IPCIM event. |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_LOGOFF_ABNORMAL:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=aaa-ErrCode=11; 802.1X user was logged off abnormally. |
Explanation |
The 802.1X user was logged off abnormally. |
Locate the logoff cause and remove the issue. |
DOT1X_LOGOFF_ABNORMAL (in open mode)
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-ErrCode=[STRING]; 802.1X open user was logged off abnormally. |
Variable fields |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_LOGOFF_ABNORMAL:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=aaa-ErrCode=11; 802.1X open user was logged off abnormally. |
Explanation |
An 802.1X open user was logged off abnormally. |
DOT1X_MACBINDING_EXIST
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]; MAC address was already bound to interface [STRING]. |
Variable fields |
$1: Type and number of the access interface. $2: MAC address. $3: VLAN ID. $4: Username. $5: Type and number of the interface to which the MAC address was bound. |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_MACBINDING_EXIST: -IfName=GigabitEthernet1/0/1-MACAddr=0000-0001-0020-VLANID=2-Username=aaa; MAC address was already bound to interface GigabitEthernet1/0/3. |
Explanation |
The user failed to come online on an interface because its MAC address was already bound to another interface. |
Delete the related 802.1X MAC address binding entry from the bound interface. |
DOT1X_NOTENOUGH_EADFREEIP_RES
Message text |
Failed to assign a rule for free IP [IPADDR] on interface [STRING] due to lack of ACL resources. |
Variable fields |
$1: Free IP. $2: Interface type and number. |
Severity level |
3 |
Example |
DOT1X/3/DOT1X_NOTENOUGH_EADFREEIP_RES: Failed to assign a rule for free IP 1.1.1.0 on interface Ethernet3/1/2 due to lack of ACL resources. |
Explanation |
The device failed to assign an ACL rule to permit a free IP on an interface because of ACL resource shortage. |
DOT1X_NOTENOUGH_EADFREERULE_RES
Message text |
Failed to assign a rule for permitting DHCP and DNS packets on interface [STRING] due to lack of ACL resources. |
Variable fields |
Severity level |
3 |
Example |
DOT1X/3/DOT1X_NOTENOUGH_EADFREERULE_RES: Failed to assign a rule for permitting DHCP and DNS packets on interface Ethernet3/1/2 due to lack of ACL resources. |
Explanation |
The device failed to assign an ACL rule to permit DHCP and DNS packets on an interface because of ACL resource shortage. |
DOT1X_NOTENOUGH_EADMACREDIR_RES
Message text |
Failed to assign a rule for redirecting HTTP packets with source MAC address [MAC] on interface [STRING]. |
Variable fields |
$1: Source MAC address of HTTP packets. $2: Interface type and number. |
Severity level |
3 |
Example |
DOT1X/3/DOT1X_NOTENOUGH_EADMACREDIR_RES: Failed to assign a rule for redirecting HTTP packets with source MAC address 00e0-fc00-5915 on interface Ethernet3/1/2. |
Explanation |
The device failed to redirect HTTP packet with the designated source MAC on an interface because of ACL resource shortage. |
DOT1X_NOTENOUGH_EADPORTREDIR_RES
Message text |
Failed to assign a rule for redirecting HTTP packets on interface [STRING] due to lack of ACL resources. |
Variable fields |
Severity level |
3 |
Example |
DOT1X/3/DOT1X_NOTENOUGH_EADPORTREDIR_RES: Failed to assign a rule for redirecting HTTP packets on interface Ethernet3/1/2 due to lack of ACL resources. |
Explanation |
The device failed to assign an ACL rule to redirect HTTP packets on an interface because of ACL resource shortage. |
DOT1X_NOTENOUGH_ENABLEDOT1X_RES
Message text |
Failed to enable 802.1X on interface [STRING] due to lack of ACL resources. |
Variable fields |
Severity level |
3 |
Example |
DOT1X/3/DOT1X_NOTENOUGH_ENABLEDOT1X_RES: Failed to enable 802.1X on interface Ethernet3/1/2 due to lack of ACL resources. |
Explanation |
Failed to enable 802.1X on an interface because of ACL resource shortage. |
Disable 802.1X on the interface, and then re-enable 802.1X. |
DOT1X_PEXAGG_NOMEMBER_RES
Message text |
Failed to enable 802.1X on interface [STRING] because the Layer 2 extended-link aggregate interface does not have member ports. |
Variable fields |
Severity level |
3 |
Example |
DOT1X/3/DOT1X_PEXAGG_NOMEMBER_RES: Failed to enable 802.1X on interface Bridge-Aggregation100 because the Layer 2 extended-link aggregate interface does not have member ports. |
Explanation |
Failed to enable 802.1X on a Layer 2 extended-link aggregate interface because the interface does not have member ports. |
Disable 802.1X on the interface, add a member port to the interface, and then re-enable 802.1X. |
DOT1X_SMARTON_FAILURE
Message text |
-IfName=[STRING]-MACAddr=[STRING]; User failed SmartOn authentication because [STRING]. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: Cause of failure: · the password was wrong. · the switch ID was wrong. |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_SMARTON_FAILURE:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9; User failed SmartOn authentication because the password was wrong. |
Explanation |
SmartOn authentication failed for a specific reason. |
Handle the issue according to the failure cause. |
DOT1X_UNICAST_NOT_EFFECTIVE
Message text |
The unicast trigger feature is enabled but is not effective on interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
DOT1X/3/DOT1X_UNICAST_NOT_EFFECTIVE: The unicast trigger feature is enabled but is not effective on interface Ethernet3/1/2. |
Explanation |
The unicast trigger setting does not take effect on an interface, because the interface does not support unicast trigger. |
79. Reconnect the 802.1X clients to another interface that supports the unicast trigger feature. 80. Enable the unicast trigger feature on the new interface. |
DRNI
This section contains DRNI messages.
DRNI_AUTORECOVERY_TIMEOUT
Message text |
The reload delay timer timed out. Please check configuration of the DR system. |
Variable fields |
N/A |
Severity level |
4 |
Example |
DRNI/4/DRNI_AUTORECOVERY_TIMEOUT: The reload delay timer timed out. Please check configuration of the DR system. |
Explanation |
The reload delay timer expired, and the DR system had only one available member device or had two primary member devices. |
· Verify that the unavailable member device is operating correctly. · Verify that the IPL and keepalive link are correctly configured and connected. · Increase the reload delay timer. |
DRNI_GLBCHECK_CONSISTENCY
Message text |
Finished global type [UINT16] configuration consistency check. No inconsistency exists. |
Variable fields |
$1: Configuration consistency check type. |
Severity level |
6 |
Example |
DRNI/6/DRNI_GLBCHECK_CONSISTENCY: Finished global type 1 configuration consistency check. No inconsistency exists. |
Explanation |
No inconsistency was detected in global type 1 or type 2 configuration. |
DRNI_GLBCHECK_INCONSISTENCY
Message text |
Detected global type [UINT16] configuration inconsistency. |
Variable fields |
Severity level |
6 |
Example |
DRNI/6/DRNI_GLBCHECK_INCONSISTENCY: Detected global type 1 configuration inconsistency. |
Explanation |
Inconsistencies were detected in global type 1 or type 2 configuration. |
If type 1 configuration inconsistencies exist, use the display drni consistency command to view the inconsistent settings and modify them on the DR member devices. If type 2 configuration inconsistencies exist, modify the inconsistent settings on the DR member devices. |
DRNI_IFCHECK_CONSISTENCY
Message text |
Finished DR interface [STRING] type [UINT16] configuration consistency check. No inconsistency exists. |
Variable fields |
$1: Layer 2 aggregate interface name. $2: Configuration consistency check type. |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFCHECK_CONSISTENCY: Finished DR interface Bridge-Aggregation2 type 1 configuration consistency check. No inconsistency exists. |
Explanation |
No inconsistency was detected in type 1 or type 2 configuration of a DR interface. |
DRNI_IFCHECK_INCONSISTENCY
Message text |
Detected type [UINT16] configuration inconsistency on interface [STRING]. |
Variable fields |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFCHECK_INCONSISTENCY: Detected type 1 configuration inconsistency on interface Bridge-Aggregation2. |
Explanation |
Inconsistencies were detected in type 1 or type 2 configuration of a DR interface. |
If type 1 configuration inconsistencies exist, use the display drni consistency command to view the inconsistent settings and modify them on the DR interfaces. If type 2 configuration inconsistencies exist, modify the inconsistent settings on the DR interfaces. |
DRNI_IFEVENT_DR_BIND
Message text |
Interface [STRING] was assigned to DR group [UINT32]. |
Variable fields |
$1: Layer 2 aggregate interface name. $2: DR group number. |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_DR_BIND: Interface Bridge-Aggregation1 was assigned to DR group 1. |
Explanation |
A Layer 2 aggregate interface was assigned to a DR group. |
DRNI_IFEVENT_DR_GLOBALDOWN
Message text |
The state of DR group [UINT32] changed to down. |
Variable fields |
$1: DR group number. |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_DR_GLOBALDOWN: The state of DR group 2 changed to down. |
Explanation |
A DR group went down because all the member interfaces of its DR interfaces became Unselected. |
Verify that the device and the DR peer use the same system priority and system MAC address, and different system numbers. |
DRNI_IFEVENT_DR_GLOBALUP
Message text |
The state of DR group [UINT32] changed to up. |
Variable fields |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_DR_GLOBALUP: The state of DR group 2 changed to up. |
Explanation |
A DR group came up because member interfaces of its DR interfaces became Selected for the first time. |
DRNI_IFEVENT_DR_MAC_CHANGE
Message text |
Local DR interface [STRING]'s system MAC address changed to [STRING]. Please ensure that the configuration is consistent with that of the peer DR interface. |
Variable fields |
$1: Layer 2 aggregate interface name. $2: System MAC address. |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_DR_MAC_CHANGE: Local DR interface Bridge-Aggregation1's system MAC address changed to 2-2-2. Please ensure that the configuration is consistent with that of the peer DR interface. |
Explanation |
The system MAC address of a DR interface was modified. |
DRNI_IFEVENT_DR_NOSELECTED
Message text |
Local DR interface [STRING] in DR group [UINT32] does not have Selected member ports because [STRING]. |
Variable fields |
$1: Layer 2 aggregate interface name. $2: DR group number. $3: Cause of the down state of the DR interface: · The aggregate interface went down. Please check the aggregate link status. · No peer DR interface was detected. Please check peer DR interface configuration. · Configuration consistency check failure. Please check the type 1 configuration of the DR member devices for inconsistencies. · The DR interface was removed from a DR group. Please reconfigure the DR interface settings as needed. |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_DR_NOSELECTED: Local DR interface Bridge-Aggregation1 in DR group 2 does not have Selected member ports because no peer DR interface was detected. Please check peer DR interface configuration. |
Explanation |
The local DR interface in a DR group does not have member ports in Selected state. |
Verify that the member ports of the DR interface are correctly configured and connected. |
DRNI_IFEVENT_DR_PEER_NOSELECTED
Message text |
Peer DR interface in DR group [UINT32] does not have Selected member ports. |
Variable fields |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_DR_PEER_NOSELECTED: Peer DR interface in DR group 10 does not have Selected member ports. |
Explanation |
The peer DR interface in a DR group does not have member ports in Selected state. |
DRNI_IFEVENT_DR_PEER_SELECTED
Message text |
Peer DR interface in DR group [UINT32] has Selected member ports. |
Variable fields |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_DR_PEER_SELECTED: Peer DR interface in DR group 10 has Selected member ports. |
Explanation |
The peer DR interface in a DR group has member ports in Selected state. |
DRNI_IFEVENT_DR_PRIORITY_CHANGE
Message text |
DR interface [STRING]'s system priority changed to [UINT16]. Please ensure that the configuration is consistent with that of the peer DR interface. |
Variable fields |
$1: Layer 2 aggregate interface name. $2: New system priority. |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_PRIORITY_CHANGE: DR interface Bridge-Aggregation1's system priority changed to 564. Please ensure that the configuration is consistent with that of the peer DR interface. |
Explanation |
The system priority of a DR interface was modified. |
DRNI_IFEVENT_DR_SELECTED
Message text |
Local DR interface [STRING] in DR group [UINT32] has Selected member ports. |
Variable fields |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_DR_SELECTED: Local DR interface Bridge-Aggregation1 in DR group 2 has Selected member ports. |
Explanation |
The local DR interface has member ports in Selected state. |
DRNI_IFEVENT_DR_UNBIND
Message text |
Interface [STRING] was removed from DR group [UINT32]. |
Variable fields |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_DR_UNBIND: Interface Bridge-Aggregation1 was removed from DR group 1. |
Explanation |
A Layer 2 aggregate interface was removed from a DR group. |
DRNI_IFEVENT_IPP_BIND
Message text |
Interface [STRING] was configured as IPP [UINT16]. |
Variable fields |
$1: Layer 2 aggregate interface name. $2: IPP number. |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_IPP_BIND: Interface Bridge-Aggregation1 was configured as IPP 1. |
Explanation |
A Layer 2 aggregate interface was configured as the IPP. |
DRNI_IFEVENT_IPP_DOWN
Message text |
IPP [STRING] went down because [STRING]. |
Variable fields |
$1: Layer 2 aggregate interface name. $2: Cause of the down state of the IPP: · The aggregate interface went down. Please check the aggregate link status. · The tunnel interface went down. Please check the tunnel link status. · No DRCPDUs were received. Please check the devices' DRCPDU transmission and reception status. · The peer failed to receive DRCPDUs. Please check the devices' DRCPDU transmission and reception status. · The IPP role of the interface was removed. Please reconfigure an interface as the IPP. |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_IPP_DOWN: IPP Bridge-Aggregation1 went down because the tunnel interface went down. Please check the tunnel link status. |
Explanation |
The IPP went down. |
· Verify that the device and the DR peer use the same system priority and system MAC address, and different system numbers. · Verify that the device and the DR peer have the same authentication key and DRNI sequence number check status. · Verify that the Layer 2 aggregate interface that acts as the IPP is working correctly. |
DRNI_IFEVENT_IPP_UNBIND
Message text |
Configuration for IPP [UINT16] was removed from interface [STRING]. |
Variable fields |
$1: IPP number. $2: Layer 2 aggregate interface name. |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_IPP_UNBIND: Configuration for IPP 1 was removed from interface Bridge-Aggregation1. |
Explanation |
The IPP configuration was removed. |
DRNI_IFEVENT_IPP_UP
Message text |
IPP [STRING] came up. |
Variable fields |
$1: Layer 2 aggregate interface name. |
Severity level |
6 |
Example |
DRNI/6/DRNI_IFEVENT_IPP_UP: IPP Bridge-Aggregation1 came up. |
Explanation |
The IPP came up because it could receive and send DRCPDUs. |
DRNI_IPP_BLOCK
Message text |
The status of IPP [STRING] changed to blocked. |
Variable fields |
Severity level |
6 |
Example |
DRNI/6/DRNI_IPP_BLOCK: The status of IPP Bridge-Aggregation20 changed to blocked. |
Explanation |
The status of the IPP changed to blocked because the device had been assigned a DR role, and the IPP went down. |
· Verify that the IPL is correctly connected and the cable is working correctly. · Verify that the device and the DR peer have correct DR settings. |
DRNI_IPP_UNBLOCK
Message text |
The status of IPP [STRING] changed to unblocked. |
Variable fields |
Severity level |
6 |
Example |
DRNI/6/DRNI_IPP_UNBLOCK: The status of IPP Bridge-Aggregation20 changed to unblocked. |
Explanation |
The status of the IPP changed to unblocked because the device had been assigned a DR role, and the IPP came up. |
DRNI_KEEPALIVEINTERVAL_MISMATCH
Message text |
Keepalive interval on the local DR device is different from that on the neighbor. |
Variable fields |
N/A |
Severity level |
6 |
Example |
DRNI/6/DRNI_KEEPALIVEINTERVAL_MISMATCH: Keepalive interval on the local DR device is different from that on the neighbor. |
Explanation |
The device and the DR peer use different keepalive intervals. |
Make sure the device and the DR peer use the same keepalive interval. |
DRNI_KEEPALIVELINK_DOWN
Message text |
Keepalive link went down because [STRING]. |
Variable fields |
$1: Cause of the down state of the keepalive link and recommended remedy: · Keepalive IP address was not configured. Please configure keepalive IP address. · The device failed to send keepalive packets. Please check Layer 3 reachability to the peer. · The local keepalive timeout timer expired. Please check the keepalive packet transmission and reception status at the two ends. · The peer keepalive timeout timer expired. Please check the keepalive packet transmission and reception status at the two ends. |
Severity level |
6 |
Example |
DRNI/6/DRNI_KEEPALIVELINK_DOWN: Keepalive link went down because the local keepalive timeout timer expired. Please check the keepalive packet transmission and reception status at the two ends. |
Explanation |
The keepalive link went down. |
· Verify that the role of the device is correct. · Verify that the device and the DR peer use consistent packet source and destination IP addresses for keepalive detection. · Verify that the keepalive link has Layer 3 connectivity. |
DRNI_KEEPALIVELINK_UP
Message text |
Keepalive link came up. |
Variable fields |
N/A |
Severity level |
6 |
Example |
DRNI/6/DRNI_KEEPALIVELINK_UP: Keepalive link came up. |
Explanation |
The keepalive link came up. |
DRNI_DEVICE_MADDOWN
Message text |
[STRING] will change to the DRNI MAD DOWN state because [STRING]. |
Variable fields |
$1: Interfaces to be placed in DRNI MAD DOWN state: · All service interfaces not excluded from the DRNI MAD DOWN action. · All service interfaces included in the DRNI MAD DOWN action. · All new service interfaces not excluded from the DRNI MAD DOWN. · All new service interfaces included in the DRNI MAD DOWN action. $1: Cause of the DRNI MAD DOWN state and recommended remedy: · The device is Initializing. Please set up the DR system fisrt. · The IPL went down and the keepalive link remains up. Please check the IPL settings on both ends of the IPL. · The IPL came up. Please wait for the data restoration delay timer to expire. · The IPL and all DR interfaces went down. Please first check the IPL settings on both ends of the IPL. |
Severity level |
4 |
Example |
DRNI/4/DRNI_DEVICE_MADDOWN: All service interfaces not excluded from the DRNI MAD DOWN action will change to the DRNI MAD DOWN state because the IPL went down and the keepalive link remains up. Please check the IPL settings on both ends of the IPL. |
Explanation |
Network interfaces on the device will be shut down by DRNI MAD. |
Verify that the IPL is correctly connected and the cable is working correctly. |
DRNI_DEVICE_MADRECOVERY
Message text |
All service interfaces on the device will be recovered from the DRNI MAD DOWN state. |
Variable fields |
N/A |
Severity level |
4 |
Example |
DRNI/4/DRNI_DEVICE_MADRECOVERY: All service interfaces on the device will be recovered from the DRNI MAD DOWN state. |
Explanation |
The device will restore the state of all service interfaces that have been placed in DRNI MAD DOWN state. |
DRNI_SYSEVENT_DEVICEROLE_CHANGE
Message text |
Device role changed from [STRING] to [STRING] for [STRING]. |
Variable fields |
$1: Old device role, which can be primary, secondary, or none. $2: New device role, which can be primary, secondary, or none. $3: Reason for the role change: ¡ DR system initialization—The DR system initialized. ¡ IPL down and all DR interfaces down—All DR interfaces were shut down because the IPL failed. ¡ IPL and keepalive link down—Both the IPL and keepalive link failed. ¡ IPL calculation—The role was negotiated over the IPL. ¡ IPL down and role calculation based on keepalive link—The IPL failed and the local role was negotiated over the keepalive link. |
Severity level |
6 |
Example |
DRNI/6/DRNI_SYSEVENT_DEVICEROLE_CHANGE: Device role changed from Secondary to Primary for IPL calculation. |
Explanation |
The DR role of the device changed. |
Examine the reason for the change and take action to recover the IPL or keepalive link if it has failed. |
DRNI_SYSEVENT_MAC_CHANGE
Message text |
System MAC address changed from [STRING] to [STRING]. |
Variable fields |
$1: Old system MAC address. $2: New system MAC address. |
Severity level |
6 |
Example |
DRNI/6/DRNI_SYSEVENT_MAC_CHANGE: System MAC address changed from 1-1-1 to 2-2-2. |
Explanation |
The DR system MAC address was modified. |
DRNI_SYSEVENT_MODE_CHANGE
Message text |
Variable fields |
$1: Working mode of the device: · DR system—The device is operating as a DR member device. · standalone—The device is operating as a standalone device. |
Severity level |
6 |
Example |
DRNI/6/DRNI_SYSEVENT_MODE_CHANGE: The device's working mode changed to standalone. |
Explanation |
The working mode of the device changed because the DR system split or reunited. |
DRNI_SYSEVENT_NUMBER_CHANGE
Message text |
System number changed from [STRING] to [STRING]. |
Variable fields |
$1: Old system number. $2: New system number. |
Severity level |
6 |
Example |
DRNI/6/DRNI_SYSEVENT_NUMBER_CHANGE: System number changed from 1 to 2. |
Explanation |
The DR system number was modified. |
DRNI_SYSEVENT_PRIORITY_CHANGE
Message text |
System priority changed from [UINT16] to [UINT16]. |
Variable fields |
$1: Old system priority. $2: New system priority. |
Severity level |
6 |
Example |
DRNI/6/DRNI_SYSEVENT_PRIORITY_CHANGE: System priority changed from 123 to 564. |
Explanation |
The DR system priority was modified. |
DRVPLAT
This section contains driver messages.
DRVDEBUGMOD_DEVM
DRVPLAT/4/DrvDebug
Message text |
At least one fabric module slot is empty. Make sure a blank filler module has been installed in each empty slot so the switch can work correctly. |
Variable fields |
N/A |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1; At least one fabric module slot is empty. Make sure a blank filler module has been installed in each empty slot so the switch can work correctly. |
Explanation |
One or more switching fabric module slots were not installed with a switching fabric module or a blank filler panel. The device checks for empty switching fabric module slots when it detects the temperature is higher than 68°C (154.4°F). |
Install a switching fabric module or a blank filler panel in each empty switching fabric module slot. |
DRVPLAT/2/DrvDebug
Message text |
Please restart all service modules after replacing all fabric modules. |
Variable fields |
N/A |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1; Please restart all service modules after replacing all fabric modules. |
Explanation |
The system prompts the user to restart all service modules because the fabric module type changed. This message is available only for an S12516G-AF switch. |
Restart all service modules. |
DRVPLAT/2/DrvDebug
Message text |
Please restart all service modules on member device [UINT32] after replacing all fabric modules on it. |
Variable fields |
$1: IRF member ID. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1; Please restart all service modules on member device 2 after replacing all fabric modules on it. |
Explanation |
The system prompts the user to restart all service modules on a member device because the fabric module type on it changed. This message is available only for an S12516G-AF switch. |
Restart all service modules on the specified member device. |
DRVPLAT/2/DrvDebug
Message text |
No switching fabric modules are present. For the system to work correctly, verify that at least one fabric module is available and operating correctly. |
Variable fields |
N/A |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;No switching fabric modules are present. For the system to work correctly, verify that at least one fabric module is available and operating correctly. |
Explanation |
The device detected that it did not have a switching fabric module installed. The system outputs this log in the following situations: · The device does not find any switching fabric modules at startup. · You remove all switching fabrics from the device while the device is operating. |
81. Check all switching fabric module slots. ¡ If no switching fabric modules are installed, install a minimum of one switching fabric module. ¡ If one or more switching fabric modules are installed, reinstall the modules firmly. 82. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
Fabric modules don't exist. Please install one or multiple fabric modules. |
Variable fields |
N/A |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1; Fabric modules don't exist. Please install one or multiple fabric modules. |
Explanation |
The device detected that it did not have a switching fabric module installed. The device checks for switching fabric modules every second. If no switching fabric modules are found within 60 seconds, the device outputs this log. |
83. Check all switching fabric module slots. ¡ If no switching fabric modules are installed, install a minimum of one switching fabric module. ¡ If one or more switching fabric modules are installed, reinstall the modules firmly. 84. If the problem persists, contact H3C Support. |
DRVDEBUGMOD_GOLD
DRVPLAT/4/DrvDebug
Message text |
WARNING: interface [STRING] has FCS errors, please check. |
Variable fields |
$1: Interface number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1;WARNING: interface GigabitEthernet 1/0/1 has FCS errors, please check. |
Explanation |
A frame check sequence (FCS) error was detected on an interface. |
Contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
WARNING: Chassis [UINT32] Slot [UINT32] Unit [UINT32] Port [UINT32] has FCS errors, please check. |
Variable fields |
$1: IRF member ID. $2: Slot number. $3: Chip number. $4: Port number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5;WARNING: Chassis 1 Slot 5 Unit 0 Port 1 has FCS errors, please check. |
Explanation |
A frame check sequence (FCS) error was detected on an interface of an IRF member device. |
DRVPLAT/2/DrvDebug
Message text |
WARNING: interface [STRING] link down |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;WARNING: interface GigabitEthernet 1/0/1 link down |
Explanation |
The link on an interface went down. |
85. Verify that the network cable is installed correctly. If the cable is installed incorrectly, remove it and install it again. 86. Verify that the network cable is not faulty. If the network cable is faulty, replace it. 87. Verify that the local interface is not faulty by connecting the cable to another port. H3C recommends that you use a port on the same type of card in another slot. 88. Verify that the peer interface is not faulty by connecting the cable to another port. H3C recommends that you use a port on the same type of card in another slot. 89. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
WARNING: Chassis [UINT32] Slot [UINT32] Unit [UINT32]Port [UINT32] link down |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1-Chassis=1-Slot=5;WARNING: Chassis 1 Slot 5 Unit 0 Port 1 link down |
Explanation |
The link on an interface went down on an IRF member device. |
Recommended action |
90. Verify that the network cable is installed correctly. If the cable is installed incorrectly, remove it and install it again. 91. Verify that the network cable is not faulty. If the network cable is faulty, replace it. 92. Verify that the local interface is not faulty by connecting the cable to another port. H3C recommends that you use a port on the same type of card in another slot. 93. Verify that the peer interface is not faulty by connecting the cable to another port. H3C recommends that you use a port on the same type of card in another slot. 94. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
WARNING: Chip [UINT32] IPT CRC [UINT32], please check. |
Variable fields |
$1: Chip number. $2: Port number. |
Severity level |
4 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;WARNING: Chip 0 IPT CRC 101, please check. |
Explanation |
A cyclic redundancy check (CRC) error was detected by a chip. |
DRVPLAT/4/DrvDebug
Message text |
WARNING: Unit=[UINT32],Port=[UINT32] has FCS errors, please check. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1;WARNING: Unit=0,Port=1 has FCS errors, please check. |
Explanation |
DRVPLAT/2/DrvDebug
Message text |
WARNING: Local Slot [UINT32] update port info for GOLD failed, while port monitor enable! |
Variable fields |
$1: Slot number. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;WARNING: Local Slot 5 update port info for GOLD failed, while port monitor enable! |
Explanation |
GOLD interface information update failed on a card when interface monitoring was enabled. |
DRVPLAT/2/DrvDebug
Message text |
WARNING: Chassis [UINT32] Slot [UINT32] Unit [UINT32] Port [UINT32] link up/down too frequently |
Variable fields |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug:-MDC=1-Chassis=1-Slot=5;WARNING: Chassis 1 Slot 5 Unit 0 Port 1 link up/down too frequently |
Explanation |
The link on an interface came up and went down frequently on an IRF member device. |
95. Verify that the network cable is installed correctly. If the cable is installed incorrectly, remove it and install it again. 96. Verify that the network cable is not faulty. If the network cable is faulty, replace it. 97. Verify that the local interface is not faulty by connecting the cable to another port. H3C recommends that you use a port on the same type of card in another slot. 98. Verify that the peer interface is not faulty by connecting the cable to another port. H3C recommends that you use a port on the same type of card in another slot. 99. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
Chassis [UINT32] Slot [UINT32] Unit [UINT32] Port [UINT32] error frame detected! |
Variable fields |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1-Chassis=1-Slot=5;Chassis 1 Slot 5 Unit 0 Port 1 error frame detected! |
Explanation |
An interface of an IRF member device received error frames. |
DRVPLAT/4/DrvDebug
Message text |
WARNING: Chassis [UINT32] slot [UINT32] is isolated already. Maybe caused by the hardware failure, please remove and check it. |
Variable fields |
$1: IRF member ID. $2: Slot number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5;WARNING: Chassis 1 slot 5 is isolated already. Maybe caused by the hardware failure, please remove and check it. |
Explanation |
A card was isolated on an IRF member device because of hardware errors. |
100. Remove the isolated card. 101. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
WARNING: Slot [UINT32] is isolated already. Maybe caused by the hardware failure, please remove and check it. |
Variable fields |
$1: Slot number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1;WARNING: Slot 5 is isolated already. Maybe caused by the hardware failure, please remove and check it. |
Explanation |
A card was isolated because of hardware errors. |
102. Remove the isolated card. 103. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
MMU Crashed, Please replace the device |
Variable fields |
N/A |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:-MDC=1;MMU Crashed, Please replace the device |
Explanation |
The MMU became faulty. |
104. Replace the faulty MMU. 105. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
Board fault: chassis [UINT32] slot [UINT32], please check it. |
Variable fields |
$1: Chassis ID. In standalone mode, this field displays 0. $2: Slot ID. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: Board fault: chassis 1 slot 10, please check it. |
Explanation |
Hardware failures were detected on the specified card. |
106. Use the reboot command to reboot the card, or remove and then reinstall the card. 107. If the problem persists, replace the card. 108. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
Board fault: chassis [UINT32] slot [UINT32] or chassis [UINT32] slot [UINT32], please check them. |
Variable fields |
N/A |
Severity level |
$1 and $3: Chassis IDs. In standalone mode, these fields display 0. $2 and $4: Slot IDs. |
Example |
DRVPLAT/4/DrvDebug: Board fault: chassis 1 slot 11 or chassis 1 slot 9, please check them. |
Explanation |
Hardware failures were detected on one of the specified cards. |
109. Use the reboot command to reboot the specified cards one by one, or remove and then reinstall the cards one by one. 110. If the problem persists, replace the cards one by one. 111. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
Chassis [UINT32] slot [UINT32] will be isolated, please check it. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: Chassis 1 slot 2 will be isolated, please check it. |
Explanation |
Hardware failures were detected on the specified card. The system will isolate the card and place the card in Fault state. |
112. Remove and then reinstall the card. 113. If the problem persists, replace the card. 114. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
Board in slot [INT32] is rebooting to change its port mode from 40G to 100G. |
Variable fields |
$1: Slot number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: Board in slot 2 is rebooting to change its port mode from 40G to 100G. |
Explanation |
When the following conditions are met for a card, the device reboots the card and changes the operating mode of the card from 40G to 100G: · The card is not configured. · No interfaces on the card are connected to a device. · Only 100G transceiver modules are installed on the card. · After the port mode switchover, the card has a minimum of one 100G transceiver module installed on an available interface. |
No action is required. |
DRVPLAT/4/DrvDebug
Message text |
Board in chassis [INT32] slot [INT32] is rebooting to change its port mode from 40G to 100G. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: Board in chassis 2 slot 2 is rebooting to change its port mode from 40G to 100G. |
Explanation |
DRVDEBUGMOD_SYSM
DRVPLAT/2/DrvDebug
Message text |
Please check switch mode in slot [UINT]. May need reboot it. |
Variable fields |
$1: Slot ID. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug:-MDC=1; Please check switch mode in slot 3. May need reboot it. |
Explanation |
The operating mode specified for the LPU was different from the current mode of the LPU. |
115. Use the display switch-mode status command to display the operating modes of LPUs. 116. Save the running configuration. 117. Reboot the LPUs whose configured operating modes are different from the current operating modes. |
DRVPLAT/2/DrvDebug
Message text |
Please check switch mode in chassisID [UINT] slot [UINT]. May need reboot it. |
Variable fields |
$1: Chassis ID. $2: Slot ID. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug:-MDC=1; Please check switch mode in chassisID 1 slot 7. May need reboot it. |
Explanation |
118. Use the display switch-mode status command to display the operating modes of LPUs. 119. Save the running configuration. 120. Reboot the LPUs whose configured operating modes are different from the current operating modes. |
DRVPLAT/2/DrvDebug
Message text |
Power [UINT32] Remove. |
Variable fields |
$1: Power module ID. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1-Slot=2;Power 2 Remove. |
Explanation |
A power module was removed. |
Determine whether it is required to install a power module. If it is required, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
The power of this device is not enough. |
Variable fields |
N/A |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1-Slot=2;The power of this device is not enough. |
Explanation |
Device power was insufficient. |
121. Determine the power requirement of the device. 122. Determine the number of power modules to install. Make sure the total output power of the power modules is greater than the required power. H3C recommends that you arrange a power allowance of 20%. 123. Install power modules as required. |
DRVPLAT/2/DrvDebug
Message text |
Fan Fault! Chassis [UINT32] Frame [UINT32] fan [UINT32] speed < 500(R.P.M). |
Variable fields |
$1: Chassis ID. $2: Fan tray ID. $3: Fan ID. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Fan Fault! Chassis 1 Frame 0 fan 1 speed < 500(R.P.M). |
Explanation |
The speed of a fan was lower than 500 rpm. |
124. Use the display fan command to display the operating status of the fan tray. 125. If the fan tray status is fault, reinstall the fan tray. 126. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
Fan Fault! Frame [UINT32] fan [UINT32] speed < 500(R.P.M). |
Variable fields |
$1: Fan tray ID. $2: Fan ID. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug:-MDC=1; Fan Fault! Frame 0 fan 1 speed < 500(R.P.M). |
Explanation |
127. Use the display fan command to display the operating status of the fan tray. 128. If the fan tray status is fault, reinstall the fan tray. 129. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
Fan Adjusting failed! Chassis [UINT32] Frame [UINT32] fan [UINT32] speed is [UINT32] (R.P.M), is too low! |
Variable fields |
$1: Chassis ID. $2: Fan tray ID. $3: Fan ID. $4: Fan speed. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Fan Adjusting failed! Chassis 1 Frame 0 fan 1 speed is 1124(R.P.M), is too low! |
Explanation |
The actual fan speed was lower than the minimum speed for the specified fan operating mode. |
130. Identify whether the log message appeared multiple times. 131. If the log message appeared only once, identify whether a user was using the debug sysm fan command to set the fan operating mode to high. If yes, no problems occurred. No action is required. 132. If the log message appeared multiple times or no user was performing the configuration task, execute the display fan command. 133. If the fan tray status is fault, reinstall the fan tray. 134. If the fan tray status is normal, wait two minutes and identify whether the log message appeared again. 135. If the log message does not appear again, the fan has automatically adjusted its speed. No action is required. 136. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
Fan Adjusting failed! Frame [UINT32] fan [UINT32] speed is [UINT32] (R.P.M), is too low! |
Variable fields |
$1: Fan tray ID. $2: Fan ID. $2: Fan speed. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Fan Adjusting failed! Frame 0 fan 1 speed is 1124(R.P.M), is too low! |
Explanation |
137. Identify whether the log message appeared multiple times. 138. If the log message appeared only once, identify whether a user was using the debug sysm fan command to set the fan operating mode to high. If yes, no problems occurred. No action is required. 139. If the log message appeared multiple times or no user was performing the configuration task, execute the display fan command. 140. If the fan tray status is fault, reinstall the fan tray. 141. If the fan tray status is normal, wait two minutes and identify whether the log message appeared again. 142. If the log message does not appear again, the fan has automatically adjusted its speed. No action is required. 143. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
Fan Adjusting failed! Chassis [UINT32] Frame [UINT32] fan [UINT32] speed is [UINT32] (R.P.M), is too high! |
Variable fields |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Fan Adjusting failed! Chassis 1 Frame 0 fan 1 speed is 3524(R.P.M), is too high! |
Explanation |
The actual fan speed was higher than the maximum speed for the specified fan operating mode. |
144. Identify whether a user was using the debug sysm fan [ fan-id ] [ section-id ] command to set the fan operating mode to low or auto. If yes, no problems occurred. No action is required. 145. If no user was performing the configuration task, execute the display fan command. 146. If the fan tray status is fault, reinstall the fan tray. 147. If the fan tray status is normal, wait two minutes and identify whether the log message appeared again. 148. If the log message does not appear again, the fan has automatically adjusted its speed. No action is required. 149. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
Fan Adjusting failed! Frame [UINT32] fan [UINT32] speed is [UINT32] (R.P.M), is too high! |
Variable fields |
$1: Fan tray ID. $2: Fan ID. $3: Fan speed. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Fan Adjusting failed! Frame 0 fan 1 speed is 3524(R.P.M), is too high! |
Explanation |
150. Identify whether a user was using the debug sysm fan [ fan-id ] [ section-id ] command to set the fan operating mode to low or auto. If yes, no problems occurred. No action is required. 151. If no user was performing the configuration task, execute the display fan command. 152. If the fan tray status is fault, reinstall the fan tray. 153. If the fan tray status is normal, wait two minutes and identify whether the log message appeared again. 154. If the log message does not appear again, the fan has automatically adjusted its speed. No action is required. 155. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
Warning:Fans stop running in chassis [UINT32], please check it right now. otherwise all lpu boards will be powered down after [UINT32] minutes. |
Variable fields |
$1: Chassis ID. $2: Time duration in minutes. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Warning:Fans stop running in chassis 1, please check it right now. otherwise all lpu boards will be powered down after 3 minutes. |
Explanation |
All fans had stopped operating or no fans were present on an IRF member device. When such an event occurs, the system powers off all cards on the device after a period of time. Before powering off all cards, the system issues an alarm every minute. |
156. Use the display fan command to display the operating status of fan trays. ¡ If a fan tray is in absent state, identify whether there is a fan tray installed in the slot. If a fan tray is installed, reinstall the fan tray firmly. ¡ If a fan is in fault state, reinstall the fan tray. 157. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
Warning:Fans stop running, please check it right now. otherwise all lpu boards will be powered down after [UINT32] minutes. |
Variable fields |
$1: Time duration in minutes. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Warning:Fans stop running, please check it right now. |
Explanation |
All fans had stopped operating or no fans were present on the device. When such an event occurs, the system powers off all cards after a period of time. Before powering off all cards, the system issues an alarm every minute. |
158. Use the display fan command to display the operating status of fan trays. ¡ If a fan tray is in absent state, identify whether there is a fan tray installed in the slot. If a fan tray is installed, reinstall the fan tray firmly. ¡ If a fan is in fault state, reinstall the fan tray. 159. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
The device does not support board in chassis [UINT32] slot [UINT32] ,type is unknown(0x[UINT32]), Please check. |
Variable fields |
$1: Chassis ID. $2: Slot ID. $3: Card type value. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5;The device does not support board in chassis 1 slot 5 ,type is unknown(0x108), Please check. |
Explanation |
An IRF member device did not support an installed card. |
DRVPLAT/4/DrvDebug
Message text |
The device does not support board in slot [UINT32] ,type is unknown(0x[UINT32]), Please check. |
Variable fields |
$1: Slot ID. $2: Card type value. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1;The device does not support board in slot 5 ,type is unknown(0x108), Please check. |
Explanation |
The device did not support an installed card. |
DRVPLAT/2/DrvDebug
Message text |
Warning: Power off all lpu boards, please check it right now. |
Variable fields |
N/A |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1; Warning: Power off all lpu boards, please check it right now. |
Explanation |
The system was powering off all cards. |
160. Use the display fan command to display the operating status of fan trays. ¡ If a fan tray is in absent state, identify whether there is a fan tray installed in the slot. If a fan tray is installed, reinstall the fan tray firmly. ¡ If a fan is in fault state, reinstall the fan tray. 161. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
All lpu boards were powered down because Fans stopped running. |
Variable fields |
N/A |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;All lpu boards were powered down because Fans stopped running. |
Explanation |
The system was powering off all cards because it did not detect any fans or all fans had stopped operating. |
162. Use the display fan command to display the operating status of fan trays. ¡ If a fan tray is in absent state, identify whether there is a fan tray installed in the slot. If a fan tray is installed, reinstall the fan tray firmly. ¡ If a fan is in fault state, reinstall the fan tray. 163. If the problem persists, contact H3C Support. |
DRVPLAT/2/DrvDebug
Message text |
Warning: Not enough power to power on board chassis [UINT32] slot [UINT32]. Board power is [UINT32]w, system available power is [UINT32]w. |
Variable fields |
$1: Chassis ID. $2: Slot ID. $3: Power required for the card to operate correctly. $4: Available power. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1-Chassis=1-Slot=5;Warning: Not enough power to power on board chassis 1 slot 5. Board power is 225w, system available power is 130w. |
Explanation |
The system did not have enough power to power on the specified card. |
164. Use the display power command to display power module information. 165. If no power modules are in fault state, install a new power module. 166. If a power module is in fault state, reinstall the power module firmly. 167. If the problem persists, use a power cord that can operate correctly to replace the power cord. 168. If the problem persists, replace the power module. |
DRVPLAT/2/DrvDebug
Message text |
Warning: Not enough power to power on board slot [UINT32]. Board power is [UINT32]w, system available power is [UINT32]w. |
Variable fields |
$1: Slot ID. $2: Power required for the card to operate correctly. $3: Available power. The value of this field is fixed at 0. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Warning: Not enough power to power on board slot 5. Board power is 225w, system available power is 130w. |
Explanation |
169. Use the display power command to display power module information. 170. If no power modules are in fault state, install a new power module. 171. If a power module is in fault state, reinstall the power module firmly. 172. If the problem persists, use a power cord that can operate correctly to replace the power cord. 173. If the problem persists, replace the power module.. |
DRVPLAT/2/DrvDebug
Message text |
Warning: Not enough power on chassis [UINT32], system available power is [UINT32]w. |
Variable fields |
$1: Chassis ID. $2: Available power. The value of this field is fixed at 0. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Warning: Not enough power on chassis 1, system available power is 0w. |
Explanation |
If the available power is 0, the system outputs this log message every 3 minutes. |
174. Use the display power command to display power module information. 175. If no power modules are in fault state, install a new power module. 176. If a power module is in fault state, reinstall the power module firmly. 177. If the problem persists, use a power cord that can operate correctly to replace the power cord. 178. If the problem persists, replace the power module. |
DRVPLAT/2/DrvDebug
Message text |
Warning: Not enough power on the device, system available power is [UINT32]w. |
Variable fields |
$1: Available power. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Warning: Not enough power on the device, system available power is 0w. |
Explanation |
179. Use the display power command to display power module information. 180. If no power modules are in fault state, install a new power module. 181. If a power module is in fault state, reinstall the power module firmly. 182. If the problem persists, use a power cord that can operate correctly to replace the power cord. 183. If the problem persists, replace the power module. |
DRVPLAT/2/DrvDebug
Message text |
Warning: The LPU board on chassis [UINT32] slot [UINT32] is not compatible with MPU board, its board type is [ULONG]. |
Variable fields |
$1: Chassis ID. $2: Slot ID. $3: Card type. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug:-MDC=1-Chassis=1-Slot=5;Warning: The LPU board on chassis 1 slot 5 is not compatible with MPU board, its board type is 261.2. |
Explanation |
The card in the specified slot had a different device identification label than the local active MPU. |
DRVPLAT/2/DrvDebug
Message text |
Warning: The LPU board on slot [UINT32] is not compatible with MPU board, its board type is [ULONG]. |
Variable fields |
$1: Slot ID. $2: Card type. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1; Warning: The LPU board on slot 5 is not compatible with MPU board, its board type is 261.2. |
Explanation |
The card in the specified slot had a different device identification label than the active MPU. |
DRVPLAT/2/DrvDebug
Message text |
Warning: Standby board on chassis [UINT32] slot [UINT32] is not compatible with master board, Standby board type is [ULONG]. |
Variable fields |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug:-MDC=1-Chassis=1-Slot=5;Warning: Standby board on chassis 1 slot 1 is not compatible with master board, Standby board type is 256.2. |
Explanation |
The standby MPU had a different device identification label than the local active MPU. |
DRVPLAT/2/DrvDebug
Message text |
Warning: Standby board on slot [UINT32] is not compatible with master board, Standby board type is [ULONG]. |
Variable fields |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1;Warning: Standby board on slot1 is not compatible with master board, Standby board type is 256.2. |
Explanation |
The standby MPU had a different device identification label than the active MPU. |
DRVPLAT/4/DrvDebug
Message text |
Some cards do not support the data center features. See the release notes for more information. |
Variable fields |
N/A |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1; Some cards do not support the data center features. See the release notes for more information. |
Explanation |
The system outputs this log when you use data center features on a card that does not support these features. For more information, see the release notes. |
Do not use data center features on a card that does not support these features. |
DRVPLAT/4/DrvDebug
Message text |
The power module in [STRING] was removed. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: The power module in 1 was removed. |
Explanation |
The specified power module was removed. |
DRVPLAT/4/DrvDebug
Message text |
The power module in [STRING] on chassis [STRING] was removed. |
Variable fields |
$1: Power module ID. $2: Chassis ID. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: The power module in 1 on chassis 1 was removed. |
Explanation |
DRVPLAT/4/DrvDebug
Message text |
A power module was inserted into [STRING]. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: A power module was inserted into 1. |
Explanation |
A power module was installed. |
DRVPLAT/4/DrvDebug
Message text |
A power module was inserted into [STRING] on chassis [STRING]. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: A power module was inserted into 1 on chassis 1. |
Explanation |
DRVPLAT/4/DrvDebug
Message text |
The fan tray in [STRING] was removed. |
Variable fields |
$1: Fan tray ID. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: The fan tray in 1 was removed. |
Explanation |
The specified fan tray was removed. |
Install a fan tray within 3 minutes. |
DRVPLAT/4/DrvDebug
Message text |
The fan tray in [STRING] on chassis [STRING] was removed. |
Variable fields |
$1: Fan tray ID. $2: Chassis ID. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: The fan tray in 1 on chassis 1 was removed. |
Explanation |
DRVPLAT/4/DrvDebug
Message text |
A fan tray was inserted into [STRING]. |
Variable fields |
$1: Fan tray ID. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: A fan tray was inserted into 1. |
Explanation |
A fan tray was installed. |
DRVPLAT/4/DrvDebug
Message text |
A fan tray was inserted into [STRING] on chassis [STRING]. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: A fan tray was inserted into 1 on chassis 1. |
Explanation |
DRVPLAT/4/DrvDebug
Message text |
Hotspot sensor [STRING] on the MPU in chassis [UINT32] slot [UINT32] has reached [STRING] and exceeded the overtemperature threshold,but the MPU does not support overtemperature shutdown. |
Variable fields |
$1: Hotspot sensor ID. $2: Chassis ID. $3: Slot ID. $4: Temperature reading of the sensor. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1; Hotspot sensor 1 on the MPU in chassis 1 slot 1 has reached 111 and exceeded the overtemperature threshold,but the MPU does not support overtemperature shutdown. |
Explanation |
The temperature of an MPU exceeded the high-temperature shutdown threshold, but the MPU does not support automatic overtemperature shutdown. |
Verify that the fans are operating correctly. |
DRVPLAT/4/DrvDebug
Message text |
Hotspot sensor [STRING] on the MPU in slot [UINT32] has reached [STRING] and exceeded the overtemperature threshold,but the MPU does not support overtemperature shutdown. |
Variable fields |
$1: Hotspot sensor ID. $2: Slot ID. $3: Temperature reading of the sensor. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1; Hotspot sensor 1 on the MPU in slot 0 has reached 111 and exceeded the overtemperature threshold,but the MPU does not support overtemperature shutdown. |
Explanation |
DRVDEBUGMOD_RXTX
DRVPLAT/2/DrvDebug
Message text |
Loopback exists on the interface [UINT32] [STRING]. |
Variable fields |
$1: Interface number in the card. $2: Interface name. |
Severity level |
2 |
Example |
DRVPLAT/2/DrvDebug: -MDC=1; Loopback exists on the interface 1 Ten-GigabitEthernet 3/0/1. |
Explanation |
The loop detection feature detected a loop on the interface. |
184. Check cable connections for the loop. 185. Run protocols such as a spanning tree protocol to remove the loop condition. 186. If the problem persists, contact H3C Support. |
DRVDEBUGMOD_PORT
DRVPLAT/4/DrvDebug
Message text |
The IRF port [STRING] doesn't support GE transceiver modules. Please remove the module. |
Variable fields |
$1: IRF physical interface name. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1; The IRF port Ten-GigabitEthernet 1/0/1 doesn't support GE transceiver modules. Please remove the module. |
Explanation |
IRF links must operate at a minimum of 10 Gbps. This message occurs if an SFP transceiver module is installed for an IRF physical interface. |
Replace the transceiver module. |
DRVPLAT/4/DrvDebug
Message text |
Do not install a 1000-Mbps transceiver module after you configure generic flow control or PFC on interface [STRING]. |
Variable fields |
$1: Local interface name. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=6; Do not install a 1000-Mbps transceiver module after you configure generic flow control or PFC on interface Ten-GigabitEthernet1/6/0/29. |
Explanation |
An interface configured with the generic flow control feature (the flow-control or flow-control receive enable command) or the PFC feature (the priority-flow-control or priority-flow-control no-drop dot1p command) cannot have a 1000-Mbps transceiver module installed. |
To continue to use the 1000-Mbps transceiver module, use the undo form of the corresponding command to cancel the generic flow control or PFC configuration. Otherwise, remove the 1000-Mbps transceiver module. |
DRVDEBUGMOD_STACK
DRVPLAT/4/DrvDebug
Message text |
The port [STRING] has been changed to inactive status, please check. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=2; The port Ten1/2/0/1 has been changed to inactive status, please check. |
Explanation |
The IRF physical interface changed to the inactive state. |
187. Verify that the transceiver module is installed securely. 188. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
The port [STRING] has been changed to active status. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=2-Slot=4; The port Ten2/4/0/1 has been changed to active status. |
Explanation |
The IRF physical interface changed to the active state. |
DRVPLAT/4/DrvDebug
Message text |
The port [STRING] can't receive irf pkt and has been changed to inactive status, please check. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=2-Slot=4; The port Ten2/4/0/1 can't receive irf pkt and has been changed to inactive status, please check. |
Explanation |
The IRF physical interface cannot receive IRF protocol packets, and it has changed to the inactive state. |
189. Verify that the transceiver module is installed securely. 190. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
The port [STRING] can't receive irf pkt, please check. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=2; The port Ten1/2/0/13 can't receive irf pkt, please check. |
Explanation |
The IRF physical interface cannot receive IRF protocol packets. |
191. Verify that the transceiver module is installed securely. 192. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
Port [STRING] Connect fail, Reason: [STRING], please check. |
Variable fields |
$1: IRF physical interface name. $2: Failure reason, including: ¡ MemberID is the same. ¡ IRF-Port is the same. ¡ LoopBack. ¡ Check timeout. ¡ Fiber Connect Error. ¡ Topo Invalid. ¡ Peer Notify. ¡ Other reason. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5; Port Ten1/5/0/1 Connect fail, Reason: Check timeout, please check. |
Explanation |
The IRF physical interface failed to connect to the peer because of the reason displayed in the message. |
193. Resolve the problem depending on the failure reason: ¡ MemberID is the same—Change the IRF member ID of either member device. Make sure each member device has a unique IRF member ID. ¡ IRF-Port is the same—Make sure the IRF physical interfaces of IRF-port 1 on one member are connected to the IRF physical interfaces of IRF-port 2 on the other member device. ¡ LoopBack—Use the undo loopback command to remove the loopback configuration on the IRF physical interface. ¡ Check timeout—Check the settings on the local and peer ports for any errors. Verify that the local and peer ports are IRF physical interfaces. ¡ Fiber Connect Error—Verify that the IRF connections are consistent with the IRF port bindings. ¡ Topo Invalid—Check the IRF connections for topology errors. ¡ Peer Notify—Reinstall the transceiver module of the peer IRF physical interface. ¡ Other reason—Contact H3C Support. 194. If the problem persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
The max-ecmp-num configuration should be the same on devices in one IRF. Please check it on the neighbor device connected to IRF-port [STRING] |
Variable fields |
$1: IRF port index. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1; The max-ecmp-num configuration should be the same on devices in one IRF. Please check it on the neighbor device connected to IRF-port 2 |
Explanation |
The maximum number of ECMP routes must be the same across member devices in an IRF fabric. |
195. Execute the display max-ecmp-num command to check the maximum number of ECMP routes on each device. 196. Execute the max-ecmp-num command to change the maximum number of ECMP routes to the same value for the devices. The value change takes effect after a reboot. |
DRVPLAT/4/DrvDebug
Message text |
The device vendor must be the same for all member devices in one IRF fabric. Please check the vendor of the neighbor device connected to IRF-port [STRING]. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1; The device vendor must be the same for all member devices in one IRF fabric. Please check the vendor of the neighbor device connected to IRF-port [STRING]. |
Explanation |
This message appears if the device and the neighbor device are from different vendors. |
Use devices from the same vendor to set up an IRF fabric. |
DRVPLAT/4/DrvDebug
Message text |
The Systemworking mode configuration should be the same on devices in one IRF. Please check it on the neighbor device connected to IRF-port [STRING] |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1; The Systemworking mode configuration should be the same on devices in one IRF. Please check it on the neighbor device connected to IRF-port 2 |
Explanation |
The system operating mode must be the same across member devices in an IRF fabric. |
197. Execute the display system-working-mode command to check the device operating mode on each device. 198. Execute the system-working-mode command to change the system operating mode to the same mode for the devices. The mode change takes effect after a reboot. |
DRVPLAT/4/DrvDebug
Message text |
To use ports on an MPU as IRF physical interfaces, the IRF member ID must be 1 or 2. |
Variable fields |
N/A |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1; To use ports on an MPU as IRF physical interfaces, the IRF member ID must be 1 or 2. |
Explanation |
This message appears if the IRF member ID is not 1 or 2 when you bind a physical interface on an MPU to an IRF port. |
Use one of the following methods: · Use the irf member command in standalone mode or the irf member renumber command in IRF mode to change the IRF member ID to 1 or 2. The member ID takes effect after a reboot. · Use ports on interface modules as IRF physical interfaces. |
DRVPLAT/4/DrvDebug
Message text |
To use ports on an MPU as IRF physical interfaces, the IRF operating mode must be normal. |
Variable fields |
N/A |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1; To use ports on an MPU as IRF physical interfaces, the IRF operating mode must be normal. |
Explanation |
This message appears if the IRF operating mode is not normal when you bind a physical interface on an MPU to an IRF port. |
Use one of the following methods: · Use the irf mode command to change the IRF operating mode to normal. The mode takes effect after a reboot. · Use ports on interface modules as IRF physical interfaces. |
DRVPLAT/4/DrvDebug
Message text |
WARNING: Chassis [UINT32] Slot [UINT32] LSW Unit [UINT32] Port [UINT32] link down. |
Variable fields |
$1: IRF member ID of the device. $2: Slot number of the card. $3: LSW chip number. $4: Port number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5;WARNING: Chassis 1 Slot 5 LSW Unit 0 Port 1 link down. |
Explanation |
A port on an LSW chip of a card on an IRF member device went down. This message is generated only for the standby MPU. |
199. Make sure the IRF fabric does not perform active/standby switchover. 200. Bring up the port on the LSW chip of the standby MPU. 201. If the issue persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
WARNING: Slot [UINT32] LSW Unit [UINT32] Port [UINT32] link down. |
Variable fields |
$1: Slot number of the card. $2: LSW chip number. $3: Port number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Slot=5;WARNING: Slot 5 LSW Unit 0 Port 1 link down. |
Explanation |
A port on an LSW chip of a card went down. This message is generated only for the standby MPU. |
202. Make sure the IRF fabric does not perform active/standby switchover. 203. Bring up the port on the LSW chip of the standby MPU. 204. If the issue persists, contact H3C Support. |
DRVDEBUGMOD_SWFA
DRVPLAT/4/DrvDebug
Message text |
Chassis [UINT32] Slot [UINT32] Unit [UINT32] Port [UINT32] link down |
Variable fields |
$1: IRF member ID of the device. $2: Slot number of the card. $3: Chip number. $4: Port number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug :Chassis 1 Slot 2 Unit 0 Port 18 link down |
Explanation |
Port 18 on chip 0 of card 2 on member device 1 was down. |
If this log appears during device loading, no action is required. If this log persists, contact H3C Support. |
DRVPLAT/4/DrvDebug
Message text |
Variable fields |
$1: Slot number of the card. $2: Chip number. $3: Port number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:Slot 2 Unit 0 Port 18 link down. |
Explanation |
Port 18 on chip 0 of card 2 was down. |
DRVPLAT/4/DrvDebug
Message text |
Warning: In chassis [UINT32] slot [UINT32],all interconnected ports from chip [UINT32] to chip [UINT32] are fault,please check. |
Variable fields |
$1: IRF member ID of the device. $2: Slot number of the card. $3: Chip number. $4: Chip number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug :Warning: In chassis 1 slot 1,all interconnected ports from chip 0 to chip 1 are fault,please check. |
Explanation |
The status was down for the port connecting chip 0 on card 1 and chip 1 on card 2 of IRF member device 1. |
DRVPLAT/4/DrvDebug
Message text |
Warning: In slot [UINT32],all interconnected ports from chip [UINT32] to chip [UINT32] are fault,please check.. |
Variable fields |
$1: Slot number of the card. $2: Chip number. $3: Chip number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug :Warning: In slot 1 ,all interconnected ports from chip 0 to chip 1 are fault,please check. |
Explanation |
The status was down for the port connecting chip 0 and chip 1 on card 1. |
DRVPLAT/4/DrvDebug
Message text |
Warning: In chassis [UINT32],all interconnected ports from slot [UINT32] to slot [UINT32] are fault,please check. |
Variable fields |
$1: IRF member ID of the device. $2: Slot number of the card. $3: Slot number of the card. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:Warning: In chassis 1,all interconnected ports from slot 2 to slot 4 are fault,please check. |
Explanation |
The status was down for the port connecting card 2 and card 4 on IRF member device 1. |
DRVPLAT/4/DrvDebug
Message text |
Warning: All interconnected ports from slot [UINT32] to slot [UINT32] are fault,please check. |
Variable fields |
$1: Slot number of the card. $2: Slot number of the card. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:Warning: All interconnected ports from slot 1 to slot 2 are fault,please check. |
Explanation |
The status was down for the port connecting card 1 and card 2. |
DRVPLAT/4/DrvDebug
Message text |
In chassis [UINT32] slot [UINT32], some internal channels 'RxCrcError' counter increase continuously. Please check.The error channels are [UINT32] |
Variable fields |
$1: IRF member ID of the device. $2: Slot number of the card. $3: Channel number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:In chassis 1 slot 2, some internal channels 'RxCrcError' counter increase continuously. Please check.The error channels are1 |
Explanation |
The number of error packets increased for Channel 1 on card 2 of IRF member device 1. |
DRVPLAT/4/DrvDebug
Message text |
In slot [UINT32], some internal channels 'RxCrcError' counter increase continuously. Please check.The error channels are [UINT32] |
Variable fields |
$1: Slot number of the card. $2: Channel number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:In slot 1, some internal channels 'RxCrcError' counter increase continuously. Please check.The error channels are 1 |
Explanation |
The number of error packets increased for Channel 1 on card 1. |
DRVPLAT/4/DrvDebug
Message text |
On chip [UINT32] in chassis [UINT32] slot [UINT32], at least two internal ports are down. Please check the internal ports.The down ports are sfi [UINT32] |
Variable fields |
$1: Chip number. $2: IRF member ID of the device. $3: Chip number. $4: Internal port number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:On chip 0 in chassis 1 slot 2, at least two internal ports are down. Please check the internal ports.The down ports are sfi1 sfi 2 |
Explanation |
The status was down for ports sfi1 and sfi2 on chip 0 of card 2 on IRF member device 1. |
DRVPLAT/4/DrvDebug
Message text |
On chip [UINT32] in slot [UINT32], at least two internal ports are down. Please check the internal ports. The down ports are sfi [UINT32] |
Variable fields |
$1: Chip number. $2: Chip number. $3: Internal port number. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:On chip 0 in slot 1, at least two internal ports are down. Please check the internal ports. The down ports are sfi1 sfi 2 |
Explanation |
The status was down for ports sfi1 and sfi2 on chip 0 of card 1. |
DRVPLAT/4/DrvDebug
Message text |
In chassis [UINT32],the specified fabric-board [UINT32] does not work |
Variable fields |
$1: IRF member ID of the device. $2: Slot number of the card. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:In chassis 1,the specified fabric-board 2 does not work |
Explanation |
The switching fabric module is isolated and is not operating. |
DRVPLAT/4/DrvDebug
Message text |
The specified fabric-board [UINT32] does not work. |
Variable fields |
$1: Slot number of the card. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:The specified fabric-board 1 does not work. |
Explanation |
DRVPLAT/4/DrvDebug
Message text |
In chassis [UINT32],the specified fabric-board [UINT32] resume work. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:In chassis1,the specified fabric-board 1 resume work. |
Explanation |
The switching fabric module is not isolated and is operating. |
DRVPLAT/4/DrvDebug
Message text |
The specified fabric-board [UINT32] resume work. |
Variable fields |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug:The specified fabric-board 1 resume work. |
Explanation |
DRVPLAT/4/DrvDebug
Message text |
All internal ports on an interface module that were connected to other modules were down. The system would reboot the interface module. |
Variable fields |
None |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=2-Slot=5; All internal ports on an interface module that were connected to other modules were down. The system would reboot the interface module |
Explanation |
The system detected that all internal ports on an interface module that were connected to other modules were down. |
205. Verify that the MPUs were securely installed. 206. Verify that the switching fabric modules were securely installed. 207. If the problem persists, contact H3C Support. |
DRVDEBUGMOD_BSP
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] is busy, SlaveAddr: [STRING] |
Variable fields |
$1: I2C bus number. $2: I2C address of the subordinate device. |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 is busy, SlaveAddr: 0x59 |
Explanation |
The I2C bus with the specified subordinate I2C address is busy. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] generate start failed, dev: [STRING], status: [STRING] |
Variable fields |
$1: I2C bus number. $2: I2C address of the device. $3: I2C status. |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 generate start failed, dev:0x59 , status: busy |
Explanation |
The I2C bus with the specified I2C address failed to start. The I2C bus is busy. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] wait interrupt failed when writing data, dev: [STRING]. |
Variable fields |
$1: I2C bus number. $2: I2C address of the device. |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 wait interrupt failed when writing data, dev: 0x59. |
Explanation |
Errors occurred for the specified waiting process during the writing for the I2C bus with the specified I2C address. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] interrupt process [STRING] is error when writing data, dev: [STRING]. |
Variable fields |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 interrupt process 1 is error when writing data, dev: 0x59. |
Explanation |
Errors occurred for the specified interrupting process during the writing for the I2C bus with the specified I2C address. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] wait interrupt failed when reading data, dev: [STRING]. |
Variable fields |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 wait interrupt failed when reading data, dev:0x59. |
Explanation |
Errors occurred for the specified waiting process during the reading for the I2C bus with the specified I2C address. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] interrupt process [STRING] is error when reading data, dev: [STRING]. |
Variable fields |
$1: I2C bus number. $2: Process number. $3: I2C address of the device. |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 interrupt process 1 is error when reading data, dev:0x59. |
Explanation |
Errors occurred for the specified interrupting process during the reading for the I2C bus with the specified I2C address. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] write failed, invalid param. dev: [STRING], reg: [STRING], datalen: [STRING]. |
Variable fields |
$1: I2C bus number. $2: I2C address of the device. $3: I2C address offset. $4: Data length. |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 write failed, invalid param. dev: 0x59, reg:0x20, datalen: 0x20. |
Explanation |
Writing failed for the I2C bus with the specified address and offset because of the invalid parameter. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] write failed, invalid bus num. |
Variable fields |
$1: I2C bus number. |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 write failed, invalid bus num. |
Explanation |
Writing failed for the I2C bus because of the invalid bus number. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] free-sem take failed when writing data. |
Variable fields |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 free-sem take failed when writing data. |
Explanation |
The I2C bus failed to obtain the signal volume during the writing process. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] write failed, retry resume! i2c trace: [STRING], dev: [STRING], reg: [STRING] |
Variable fields |
$1: I2C bus number. $2: I2C trace. $3: I2C address of the device. $4: I2C address offset. |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 write failed, retry resume! i2c trace: 2, dev: 0x59, reg: 0x20 |
Explanation |
Writing failed for the I2C bus with the specified trace, address, and offset. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] read failed, invalid param. dev: [STRING], reg: [STRING], datalen: [STRING]. |
Variable fields |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 read failed, invalid param. dev: 0x59, reg:0x20, datalen: 0x20. |
Explanation |
Reading failed for the I2C bus with the specified address and offset because of the invalid parameter. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] read failed, invalid bus num. |
Variable fields |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 read failed, invalid bus num. |
Explanation |
Reading failed for the I2C bus because of the invalid bus number. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING] free-sem take failed when reading data. |
Variable fields |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 free-sem take failed when reading data. |
Explanation |
The I2C bus failed to obtain the signal volume during the reading process. |
DRVPLAT/3/DrvDebug
Message text |
I2C bus [STRING]read failed, retry resume! i2c trace: [STRING], dev: [STRING], reg: [STRING] |
Variable fields |
$1: Bus number. $2: I2C trace $3: I2C address of the device. $4: I2C address offset |
Severity level |
3 |
Example |
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 read failed, retry resume! i2c trace: 2, dev: 0x59, reg:0x20 |
Explanation |
DRVDEBUGMOD_BFD
DRVDEBUGMOD_BFD
Message text |
The key ID is in use.LD = [STRING]. |
Variable fields |
$1: Local discriminator. |
Severity level |
4 |
Example |
DRVPLAT/4/DrvDebug: -MDC=1-Slot=3; The key ID is in use.LD = 4097. |
Explanation |
The system outputs this log when the following conditions are met: · The system is in expert operating mode. · The bfd authentication-mode simple command is executed to specify a key ID for a session but the key ID has been used by another session. |
Modify the key ID to be different than the existing key IDs. |
EDEV messages
This section contains messages for extended-device management.
ALARM_IN_REMOVED
Message text |
Alarm removed on the alarm-in port [UNIT]. |
Variable fields |
$1: Number of the alarm input port. |
Severity level |
5 |
Example |
EDEV/5/ALARM_IN_REMOVED: Alarm removed on the alarm-in port 1. |
Explanation |
The external alarm received from the alarm input port was removed. |
ALARM_IN_REPORTED
Message text |
Alarm reported on the alarm-in port [UNIT]. |
Variable fields |
Severity level |
5 |
Example |
EDEV/5/EDEV_ALARM_IN_REPORTED: Alarm reported on the alarm-in port 1. |
Explanation |
The alarm input port received an external alarm. |
Verify that the device connected to the alarm input port is operating correctly. |
EDEV_BOOTROM_UPDATE_FAILED
Message text |
Failed to execute the bootrom update command. |
Variable fields |
None |
Severity level |
5 |
Example |
EDEV/5/EDEV_BOOTROM_UPDATE_FAILED: -IPAddr=192.168.79.1-User=**; Failed to execute the bootrom update command. |
Explanation |
A user executed the bootrom update command but the command failed. The BootWare image was not loaded from the file system to the Normal BootWare area. |
Take actions as prompted. |
EDEV_BOOTROM_UPDATE_SUCCESS
Message text |
Executed the bootrom update command successfully. |
Variable fields |
None |
Severity level |
5 |
Example |
EDEV/5/EDEV_BOOTROM_UPDATE_SUCCESS: -IPAddr=192.168.79.1-User=**; Executed the bootrom update command successfully. |
Explanation |
A user executed the bootrom update command successfully. The BootWare image was loaded from the file system to the Normal BootWare area. |
EDEV_FAILOVER_GROUP_STATE_CHANGE
Message text |
Status of stateful failover group [STRING] with ID [UINT32] changed to [STRING]. |
Variable fields |
$1: Failover group name. $2: Failover group ID. $3: Failover group state. |
Severity level |
5 |
Example |
Explanation |
The status of a failover group changed. |
eMDI messages
This section contains eMDI messages.
EMDI_INDICATOR_OVER_THRES
Message text |
[STRING] alarm for instance [USHORT] was triggered: Value=[UINT32]/100000, Threshold=[UINT32]/100000, SuppressionTimes=[UCHAR]. |
Variable fields |
$1: Monitored item: ¡ RTP-LR—RTP packet loss rate. ¡ RTP-SER—RTP packet sequence error rate. ¡ DPLR—Downstream TCP packet loss rate. ¡ UPLR—Upstream TCP packet loss rate. $2: Instance ID. $3: Value of the monitored item. $4: Alarm threshold. $5: Number of consecutive alarms to be suppressed before logging the event. |
Severity level |
5 |
Example |
EMDI/5/EMDI_INDICATOR_OVER_THRES: RTP-LR alarm for instance 100 was triggered: Value=150/100000, Threshold=100/100000, SuppressionTimes=3. |
Explanation |
The value of the monitored item reached or exceeded the alarm threshold continuously and triggered the system to send an alarm log message. |
208. Execute the display emdi statistics command to view monitored statistics for the eMDI instance on all relevant devices. 209. Analyze the statistics to locate the faults. |
EMDI_INDICATOR_OVER_THRES_RESUME
Message text |
[STRING] alarm for instance [USHORT] was removed: Value=[UINT32]/100000, Threshold=[UINT32]/100000, SuppressionTimes=[UCHAR]. |
Variable fields |
$1: eMID monitored item: ¡ RTP-LR—RTP packet loss rate. ¡ RTP-SER—RTP packet sequence error rate. ¡ DPLR—Downstream TCP packet loss rate. ¡ UPLR—Upstream TCP packet loss rate. $2: Instance ID. $3: Value of the monitored item. $4: Alarm threshold. $5: Number of consecutive alarms to be suppressed before logging the event. |
Severity level |
5 |
Example |
EMDI/5/EMDI_INDICATOR_OVER_THRES_RESUME: RTP-LR alarm for instance 100 was removed: Value=50/100000, Threshold=100/100000, SuppressionTimes=3. |
Explanation |
The value of the monitored item was less than the alarm threshold continuously and triggered the system to send an alarm-removed log message. |
EMDI_INSTANCE_CONFLICT_FLOW
Message text |
The flow (SrcIP=[STRING], SrcPort=[USHORT], DstIP=[STRING], DstPort=[USHORT], Protocol=[STRING]) to be bound to a dynamic instance overlaps with the flow bound to instance [USHORT]. |
Variable fields |
$1: Source IP address. $2: Source port number. $3: Destination IP address. $4: Destination port number. $5: Flow type: ¡ tcp—TCP flow. ¡ udp—UDP flow. $6: ID of the eMDI instance that had an overlapping data flow. |
Severity level |
5 |
Example |
EMDI/5/EMDI_INSTANCE_CONFLICT_FLOW: The flow (SrcIP=10.0.0.1, SrcPort=10, DstIP=20.0.0.1, DstPort=20, Protocol=tcp) to be bound to a dynamic instance overlaps with the flow bound to instance 1. |
Explanation |
The data flow specified for a dynamic eMDI instance overlapped the data flow bound to an existing eMDI instance. |
Delete the flow settings for the existing eMDI instance. |
EMDI_INSTANCE_EXCEED
Message text |
Maximum number of running instances on [STRING] already reached. |
Variable fields |
$1: Chassis number plus slot number, slot number, or device. |
Severity level |
5 |
Example |
EMDI/5/EMDI_INSTANCE_EXCEED: Maximum number of running instances on slot 1 already reached. |
Explanation |
The maximum number of running eMDI instances on the module was already reached. |
To start new eMDI instances, first stop unnecessary eMDI instances on the module. |
EMDI_INSTANCE_SAME_FLOW
Message text |
The flow to be bound to a dynamic instance was already bound to instance [USHORT]: SrcIP=[STRING], SrcPort=[USHORT], DstIP=[STRING], DstPort=[USHORT], Protocol=[STRING]. |
Variable fields |
$1: ID of the eMDI instance that was already bound to the data flow. $2: Source IP address. $3: Source port number. $4: Destination IP address. $5: Destination port number. $6: Flow type: ¡ tcp—TCP flow. ¡ udp—UDP flow. |
Severity level |
5 |
Example |
EMDI/5/EMDI_INSTANCE_SAME_FLOW: The flow to be bound to a dynamic instance was already bound to instance 1: SrcIP=10.0.0.1, SrcPort=10, DstIP=20.0.0.1, DstPort=20, Protocol= tcp. |
Explanation |
The flow specified for a dynamic instance was the same as the flow bound to an existing eMDI instance. |
EPA messages
This section contains EPA messages.
EPA_ENDPOINT_ONLINE
Message text |
Detected the association of an endpoint (device ID [STRING], MAC address [STRING]) on interface [STRING] in VLAN [UINT16]. |
Variable fields |
$1: Bridge MAC address of the connected device. $2: MAC address of the endpoint. $3: Name of the interface from which the endpoint came online. $4: ID of the VLAN to which the endpoint belongs. |
Severity level |
6 |
Example |
EPA/6/EPA_ENDPOINT_ONLINE: Detected the association of an endpoint (device ID a4c2-d4ad-0200, MAC address 12c2-d4ed-0200) on interface GigabitEthernet1/0/1 in VLAN 1. |
Explanation |
The device detected that an endpoint came online. |
EPA_ENDPOINT_OFFLINE
Message text |
Detected the disassociation of an endpoint (device ID [STRING], MAC address [STRING]) on interface [STRING] in VLAN [UINT16]. |
Variable fields |
Severity level |
6 |
Example |
EPA/6/EPA_ENDPOINT_OFFLINE: Detected the disassociation of an endpoint (device ID a4c2-d4ad-0200, MAC address 12c2-d4ed-0200) on interface GigabitEthernet1/0/1 in VLAN 1. |
Explanation |
The device detected that an endpoint went offline. |
EPA_DEVICETYPE_CHANGE
Message text |
Cleared EPA monitor rule configurations. Reason: Device type changed from [STRING] to [STRING]. |
Variable fields |
$1: Device type before the change. Options include: · TM—Indicates the commander in a SmartMC network. · TC—Indicates a member in a SmartMC network. · Self-managed—Indicates a device in a non-SmartMC network. $2: Device type after the change. |
Severity level |
6 |
Example |
EPA/6/EPA_DEVICETYPE_CHANGE: Cleared EPA monitor rule configurations. Reason: Device type changed from TC to Self-managed. |
Explanation |
EPA monitor rules were deleted from the device because the device type changed. |
ERPS messages
This section contains ERPS messages.
ERPS_STATE_CHANGED
Message text |
Ethernet ring [UINT16] instance [UINT16] changed state to [STRING] |
Variable fields |
$1: ERPS ring ID. $2: ERPS instance ID. $3: ERPS instance status. |
Severity level |
6 |
Example |
ERPS/4/ERPS_STATE_CHANGED: Ethernet ring 1 instance 1 changed state to Idle. |
Explanation |
The status of the ERPS instance changed. |
ETH messages
This section contains ETH messages.
ETH_SET_MAC_FAILED
Message text |
Failed to set the MAC address [STRING] on [STRING]. |
Variable fields |
$1: MAC address. $2: Interface name. |
Severity level |
5 |
Example |
ETH/5/ETH_SET_MAC_FAILED: Failed to set the MAC address 0001-0001-0001 on GigabitEthernet1/0/1. |
Explanation |
Failed to set the MAC address for an interface because the highest 36 bits of the MAC address are inconsistent with the highest 36 bits of the device's bridge MAC address in the case of configuration recovery, IRF split, or new interface module plugging. |
Configure a proper MAC address again for the interface. |
ETHDRNI
This section contains ETHDRNI messages.
ETHDRNI_MAC_INEFFECTIVE
Message text |
ETHDRNI failed to add the MAC address [STRING] of remote interface [STRING]. Cause: [STRING]. |
Variable fields |
$1: MAC address. $2: Interface name. $3: Cause. |
Severity level |
3 |
Example |
ETHDRNI/3/ETHDRNI_MAC_INEFFECTIVE: ETHDRNI failed to add the MAC address 2-2-2 of remote interface Vlan-interface20. Cause: Insufficient hardware resources. |
Explanation |
The ETHDRNI module failed to add the MAC address of a remote VLAN interface. |
Contact the administrator to locate the cause and resolve the problem. |
ETHOAM messages
This section contains Ethernet OAM messages.
ETHOAM_CONNECTION_FAIL_DOWN
Message text |
The link is down on interface [string] because a remote failure occurred on peer interface. |
Variable fields |
$1: Interface name. |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_CONNECTION_FAIL_DOWN: The link is down on interface Ethernet1/0/1 because a remote failure occurred on peer interface. |
Explanation |
The link goes down because a remote failure occurred on the peer interface. |
Recommended action |
Check the link status or the OAM status on the peer. |
ETHOAM_CONNECTION_FAIL_TIMEOUT
Message text |
Interface [string] removed the OAM connection because it received no Information OAMPDU before the timer times out. |
Variable fields |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_CONNECTION_FAIL_TIMEOUT: Interface Ethernet1/0/1 removed the OAM connection because it received no Information OAMPDU before the timer times out. |
Explanation |
The interface removed the OAM connection because it had not received Information OAMPDUs before the timer timed out. |
ETHOAM_CONNECTION_FAIL_UNSATISF
Message text |
Interface [string] failed to establish an OAM connection because the peer doesn’t match the capacity of the local interface. |
Variable fields |
Severity level |
3 |
Example |
ETHOAM/3/ETHOAM_CONNECTION_FAIL_UNSATISF: Interface Ethernet1/0/1 failed to establish an OAM connection because the peer doesn’t match the capacity of the local interface. |
Explanation |
Failed to establish an OAM connection because the peer does not match the OAM protocol state of the local interface. |
Check the State field of the OAMPDUs sent from both ends. |
ETHOAM_CONNECTION_SUCCEED
Message text |
An OAM connection is established on interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_CONNECTION_SUCCEED: An OAM connection is established on interface Ethernet1/0/1. |
Explanation |
An OAM connection is established. |
ETHOAM_DISABLE
Message text |
Ethernet OAM is now disabled on interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_DISABLE: Ethernet OAM is now disabled on interface Ethernet1/0/1. |
Explanation |
Ethernet OAM is disabled. |
ETHOAM_DISCOVERY_EXIT
Message text |
OAM interface [string] quit the OAM connection. |
Variable fields |
Severity level |
5 |
Example |
ETHOAM/5/ ETHOAM_DISCOVERY_EXIT: OAM interface Ethernet1/0/1 quit the OAM connection. |
Explanation |
The local interface ended the OAM connection. |
ETHOAM_ENABLE
Message text |
Ethernet OAM is now enabled on interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_ENABLE: Ethernet OAM is now enabled on interface Ethernet1/0/1. |
Explanation |
Ethernet OAM is enabled. |
ETHOAM_ENTER_LOOPBACK_CTRLLED
Message text |
The local OAM entity enters remote loopback as controlled DTE on OAM interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ ETHOAM_ENTER_LOOPBACK_CTRLLED: The local OAM entity enters remote loopback as controlled DTE on OAM interface Ethernet1/0/1. |
Explanation |
The local OAM entity enters remote loopback as controlled DTE after you enable OAM loopback on the peer end. |
ETHOAM_ENTER_LOOPBACK_CTRLLING
Message text |
The local OAM entity enters remote loopback as controlling DTE on OAM interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ ETHOAM_ENTER_LOOPBACK_CTRLLING: The local OAM entity enters remote loopback as controlling DTE on OAM interface Ethernet1/0/1. |
Explanation |
The local OAM entity enters remote loopback as controlling DTE after you enable OAM loopback on the interface. |
ETHOAM_LOCAL_DYING_GASP
Message text |
A local Dying Gasp event has occurred on [string]. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOCAL_DYING_GASP: A local Dying Gasp event occurred on interface Ethernet1/0/1. |
Explanation |
A local Dying Gasp event occurs when you reboot the local device or shut down the interface. |
Do not use the link until it recovers. |
ETHOAM_LOCAL_ERROR_FRAME
Message text |
An errored frame event occurred on local interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME: An errored frame event occurred on local interface Ethernet1/0/1. |
Explanation |
An errored frame event occurred on the local interface. |
Check the link between the local and peer ends. |
ETHOAM_LOCAL_ERROR_FRAME_PERIOD
Message text |
An errored frame period event occurred on local interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME_PERIOD: An errored frame period event occurred on local interface Ethernet1/0/1. |
Explanation |
An errored frame period event occurred on the local interface. |
ETHOAM_LOCAL_ERROR_FRAME_SECOND
Message text |
An errored frame seconds event occurred on local interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME_SECOND: An errored frame seconds event occurred on local interface Ethernet1/0/1. |
Explanation |
An errored frame seconds event occurred on the local interface. |
ETHOAM_LOCAL_ERROR_SYMBOL
Message text |
An errored symbol event occurred on local interface [string]. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOCAL_ERROR_SYMBOL: An errored symbol event occurred on local interface Ethernet1/0/1. |
Explanation |
An errored symbol event occurred on the local interface. |
ETHOAM_LOCAL_LINK_FAULT
Message text |
A local Link Fault event occurred on interface [string]. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOCAL_LINK_FAULT: A local Link Fault event occurred on interface Ethernet1/0/1. |
Explanation |
A local Link Fault event occurred when the local link goes down. |
Re-connect the Rx end of the fiber on the local interface. |
ETHOAM_LOOPBACK_EXIT
Message text |
OAM interface [string] quit remote loopback. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOOPBACK_EXIT: OAM interface Ethernet1/0/1 quit remote loopback. |
Explanation |
The OAM interface ended remote loopback after one of the following events occurred: · Remote loopback was disabled on the interface before the OAM connection was established. · The established OAM connection was torn down. |
ETHOAM_LOOPBACK_EXIT_ERROR_STATU
Message text |
OAM interface [string] quit remote loopback due to incorrect multiplexer or parser status. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_LOOPBACK_EXIT_ERROR_STATU: OAM interface Ethernet1/0/1 quit remote loopback due to incorrect multiplexer or parser status. |
Explanation |
OAM interface Ethernet1/0/1 ended remote loopback due to incorrect multiplexer or parser status. |
Disable and then re-enable Ethernet OAM on the OAM entity. |
ETHOAM_LOOPBACK_NO_RESOURCE
Message text |
OAM interface [string] can’t enter remote loopback due to insufficient resources. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOOPBACK_NO_RESOURCE: OAM interface Ethernet1/0/1 can’t enter remote loopback due to insufficient resources. |
Explanation |
The OAM interface cannot enter remote loopback due to insufficient resources when you execute the oam remote-loopback start command on the local or remote OAM entity. |
To enable remote loopback on an interface, you must set the hardware forwarding resources on the interface. Enabling remote loopback on a large number of interfaces might cause insufficient resources. Disable remote loopback on other interfaces, and execute the oam remote-loopback start command on the interface again. |
ETHOAM_LOOPBACK_NOT_SUPPORT
Message text |
OAM interface [string] can’t enter remote loopback because the operation is not supported. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOOPBACK_NOT_SUPPORT: OAM interface Ethernet1/0/1 can't enter remote loopback because the operation is not supported. |
Explanation |
The OAM interface cannot enter remote loopback because the operation is not supported on the device. |
No action is required. |
ETHOAM_QUIT_LOOPBACK_CTRLLED
Message text |
The local OAM entity quit remote loopback as controlled DTE on OAM interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ ETHOAM_QUIT_LOOPBACK_CTRLLED: The local OAM entity quit remote loopback as controlled DTE on OAM interface Ethernet1/0/1. |
Explanation |
As the Loopback Control OAMPDUs receiving end, the local end quit remote loopback after you disabled OAM loopback on the peer end. |
ETHOAM_QUIT_LOOPBACK_CTRLLING
Message text |
The local OAM entity quit remote loopback as controlling DTE on OAM interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_QUIT_LOOPBACK_CONTROLLING: The local OAM entity quit remote loopback as controlling DTE on OAM interface Ethernet1/0/1. |
Explanation |
The local end quit remote loopback after you disabled OAM loopback on the local interface. |
ETHOAM_REMOTE_CRITICAL
Message text |
A remote Critical event occurred on interface [string]. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_REMOTE_CRITICAL: A remote Critical event occurred on interface Ethernet1/0/1. |
Explanation |
A remote critical event occurred. |
ETHOAM_REMOTE_DYING_GASP
Message text |
A remote Dying Gasp event occurred on interface [string]. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_REMOTE_DYING_GASP: A remote Dying Gasp event occurred on interface Ethernet1/0/1. |
Explanation |
A remote Dying Gasp event occurred when you reboot the remote device and shut down the interface. |
Do not use this link until it recovers. |
ETHOAM_REMOTE_ERROR_FRAME
Message text |
An errored frame event occurred on the peer interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME: An errored frame event occurred on the peer interface Ethernet1/0/1. |
Explanation |
An errored frame event occurred on the peer. |
ETHOAM_REMOTE_ERROR_FRAME_PERIOD
Message text |
An errored frame period event occurred on the peer interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME_PERIOD: An errored frame period event occurred on the peer interface Ethernet1/0/1. |
Explanation |
An errored frame period event occurred on the peer interface. |
ETHOAM_REMOTE_ERROR_FRAME_SECOND
Message text |
An errored frame seconds event occurred on the peer interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME_SECOND: An errored frame seconds event occurred on the peer interface Ethernet1/0/1. |
Explanation |
An errored frame seconds event occurred on the peer. |
ETHOAM_REMOTE_ERROR_SYMBOL
Message text |
An errored symbol event occurred on the peer interface [string]. |
Variable fields |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_REMOTE_ERROR_SYMBOL: An errored symbol event occurred on the peer interface Ethernet1/0/1. |
Explanation |
An errored symbol event occurred on the peer. |
ETHOAM_REMOTE_EXIT
Message text |
OAM interface [string] quit OAM connection because Ethernet OAM is disabled on the peer interface. |
Variable fields |
Severity level |
5 |
Example |
ETHOAM/5/ ETHOAM_REMOTE_EXIT: OAM interface Ethernet1/0/1 quit OAM connection because Ethernet OAM is disabled on the peer interface. |
Explanation |
The local interface ended the OAM connection because Ethernet OAM was disabled on the peer interface. |
ETHOAM_REMOTE_FAILURE_RECOVER
Message text |
Peer interface [string] recovered. |
Variable fields |
Severity level |
5 |
Example |
ETHOAM/5/ ETHOAM_REMOTE_FAILURE_RECOVER: Peer interface Ethernet1/0/1 recovered. |
Explanation |
The Link fault was cleared from the peer interface and the OAM connection was restored. |
ETHOAM_REMOTE_LINK_FAULT
Message text |
A remote Link Fault event occurred on interface [string]. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_REMOTE_LINK_FAULT: A remote Link Fault event occurred on interface Ethernet1/0/1. |
Explanation |
A remote Link Fault event occurred when the remote link went down. |
Reconnect the Rx end of the fiber on the remote interface. |
ETHOAM_NO_ENOUGH_RESOURCE
Message text |
The configuration failed on OAM interface [string] because of insufficient resources. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ ETHOAM_NO_ENOUGH_RESOURCE: The configuration failed on OAM interface Ethernet1/0/1 because of insufficient resources. |
Explanation |
The configuration failed on the OAM interface because of insufficient system resources. |
Remove useless configurations to release the resources, and execute the command again. |
ETHOAM_NOT_CONNECTION_TIMEOUT
Message text |
Interface [string] quit Ethernet OAM because it received no Information OAMPDU before the timer times out. |
Variable fields |
Severity level |
5 |
Example |
ETHOAM/5/ ETHOAM_NOT_CONNECTION_TIMEOUT: Interface Ethernet1/0/1 quit Ethernet OAM because it received no Information OAMPDU before the timer times out. |
Explanation |
The local interface ended Ethernet OAM because it had not received Information OAMPDUs before the timer timed out. |
Check the link status and the OAM status on the peer. |
EVB messages
This section contains EVB messages.
EVB_AGG_FAILED
Message text |
Remove port [STRING] from aggregation group [STRING]. Otherwise, the EVB feature does not take effect. |
Variable fields |
$1: Port name. $2: Aggregate interface name. |
Severity level |
6 |
Example |
EVB/6/EVB_AGG_FAILED: Remove port GigabitEthernet5/0/5 from aggregation group Bridge-Aggregation5. Otherwise, the EVB feature does not take effect. |
Explanation |
EVB bridge fails to process a port in an aggregation group. |
Remove the port from the aggregation group. |
EVB_LICENSE_EXPIRE
Message text |
The EVB feature's license will expire in [UINT32] days. |
Variable fields |
$1: Number of days. |
Severity level |
6 |
Example |
EVB/6/EVB_LICENSE_EXPIRE: The EVB feature's license will expire in 15 days. |
Explanation |
The license for EVB will expire in the specified number of days. |
Purchase and register a new license for the EVB feature. |
EVB_VSI_OFFLINE
Message text |
VSI [STRING] went offline. |
Variable fields |
$1: VSI interface/VSI aggregate interface name. |
Severity level |
6 |
Example |
EVB/6/EVB_VSI_OFFLINE: VSI Schannel-Aggregation1:2.0 went offline. |
Explanation |
The VSI interface or VSI aggregate interface is deleted when either of the following events occurs: · The EVB bridge receives a VDP packet from the EVB station. · The EVB bridge has not received an acknowledgement after a VDP packet times out. |
EVB_VSI_ONLINE
Message text |
VSI [STRING] came online, status is [STRING]. |
Variable fields |
$1: VSI interface/VSI aggregate interface name. $2: VSI status. |
Severity level |
6 |
Example |
EVB/6/EVB_VSI_ONLINE: VSI Schannel-Aggregation1:2.0 came online, status is association. |
Explanation |
The EVB bridge receives a VDP packet and creates a VSI interface or VSI aggregate interface successfully. |
EVIISIS messages
This section contains EVI IS-IS messages.
EVIISIS_LICENSE_EXPIRED
Message text |
The EVIISIS feature is being disabled, because its license has expired. |
Variable fields |
N/A |
Severity level |
3 |
Example |
EVIISIS/3/EVIISIS_LICENSE_EXPIRED: The EVIISIS feature is being disabled, because its license has expired. |
Explanation |
The EVI IS-IS license has expired. |
Install a valid license for EVI IS-IS. |
EVIISIS_LICENSE_EXPIRED_TIME
Message text |
The EVIISIS feature will be disabled in [ULONG] days. |
Variable fields |
$1: Available period of the feature. |
Severity level |
5 |
Example |
EVIISIS/5/EVIISIS_LICENSE_EXPIRED_TIME: The EVIISIS feature will be disabled in 2 days. |
Explanation |
EVI IS-IS will be disabled because no EVI IS-IS license is available. After an active/standby MPU switchover or IRF master/subordinate switchover, you can use EVI IS-IS only for 30 days if the new active MPU or master does not have an EVI IS-IS license. |
EVIISIS_LICENSE_UNAVAILABLE
Message text |
The EVIISIS feature has no available license. |
Variable fields |
N/A |
Severity level |
3 |
Example |
EVIISIS/3/EVIISIS_LICENSE_UNAVAILABLE: The EVIISIS feature has no available license. |
Explanation |
No license was found for EVI IS-IS when the EVI IS-IS process started. |
EVIISIS_NBR_CHG
Message text |
EVIISIS [UINT32], [STRING] adjacency [STRING] ([STRING]), state changed to: [STRING]. |
Variable fields |
$1: EVI IS-IS process ID. $2: EVI IS-IS neighbor level. $3: Neighbor system ID. $4: Interface name. $5: Adjacency state: ¡ up—Adjacency was set up. ¡ initializing—Neighbor state was initializing. ¡ down—Adjacency was lost. |
Severity level |
5 |
Example |
EVIISIS/5/EVIISIS_NBR_CHG: EVIISIS 1, Level-1 adjacency 0011.2200.1501 (Evi-Link0), state changed to: down. |
Explanation |
The EVI IS-IS adjacency state changed on an interface. |
When the adjacency with a neighbor changes to down or initializing on an interface, check for EVI IS-IS configuration errors or loss of network connectivity. |
FCLINK messages
This section contains FC link messages.
FCLINK_FDISC_REJECT_NORESOURCE
Message text |
VSAN [UINT16], Interface [STRING]: An FDISC was rejected because the hardware resource is not enough. |
Variable fields |
$1: VSAN ID. $2: Interface name. |
Severity level |
4 |
Example |
FCLINK/4/FCLINK_FDISC_REJECT_NORESOURCE: VSAN 1, Interface FC2/0/1: An FDISC was rejected because the hardware resource is not enough. |
Explanation |
An FDISC is received when the hardware resources are insufficient. |
Reduce the number of nodes. |
FCLINK_FLOGI_REJECT_NORESOURCE
Message text |
VSAN [UINT16], Interface [STRING]: An FLOGI was rejected because the hardware resource is not enough. |
Variable fields |
Severity level |
4 |
Example |
FCLINK/4/FCLINK_FLOGI_REJECT_NORESOURCE: VSAN 1, Interface FC2/0/1: An FLOGI was rejected because the hardware resource is not enough. |
Explanation |
An FLOGI is received when the hardware resources are insufficient. |
FCOE messages
This section contains FCoE messages.
FCOE_INTERFACE_NOTSUPPORT_FCOE
Message text |
Because the aggregate interface [STRING] has been bound to a VFC interface, assigning the interface [STRING] that does not support FCoE to the aggregate interface might cause incorrect processing. |
Variable fields |
$1: Aggregate interface name. $2: Ethernet interface name. |
Severity level |
4 |
Example |
FCOE/4/FCOE_INTERFACE_NOTSUPPORT_FCOE: Because the aggregate interface Bridge-Aggregation 1 has been bound to a VFC interface, assigning the interface Ten-GigabitEthernet 2/0/1 that does not support FCoE to the aggregate interface might cause incorrect processing. |
Explanation |
This message is generated when an interface that does not support FCoE is assigned to an aggregate interface that has been bound to a VFC interface. |
Assign an interface that supports FCoE to the aggregate interface, or remove the binding from the VFC interface. |
FCOE_LAGG_BIND_ACTIVE
Message text |
The binding between aggregate interface [STRING] and the VFC interface takes effect again, because the member port is unbound from its bound VFC interface or removed from the aggregate interface. |
Variable fields |
$1: Aggregate interface name. |
Severity level |
4 |
Example |
FCOE/4/FCOE_LAGG_BIND_ACTIVE: The binding between aggregate interface Bridge-Aggregation1 and the VFC interface takes effect again, because the member port is unbound from its bound VFC interface or removed from the aggregate interface. |
Explanation |
This message is generated when a member port of an aggregate interface is unbound from its bound VFC interface or removed from the aggregate interface. |
FCOE_LAGG_BIND_DEACTIVE
Message text |
The binding between aggregate interface [STRING] and the VFC interface is no longer in effect, because the new member port has been bound to a VFC interface. |
Variable fields |
Severity level |
4 |
Example |
FCOE/4/FCOE_LAGG_BIND_DEACTIVE: The binding between aggregate interface Bridge-Aggregation1 and the VFC interface is no longer in effect, because the new member port has been bound to a VFC interface. |
Explanation |
This message is generated when a new member port of an aggregate interface has been bound to a VFC interface. |
FCZONE messages
This section contains FC zone messages.
FCZONE_DISTRIBUTE_FAILED
Message text |
-VSAN=[UINT16]; Zone distribution failed. The zoning configurations might consequently be inconsistent across the fabric. |
Variable fields |
$1: VSAN ID. |
Severity level |
4 |
Example |
FCZONE/4/FCZONE_DISTRIBUTE_FAILED: -VSAN=2; Zone distribution failed. The zoning configurations might consequently be inconsistent across the fabric. |
Explanation |
A distribution operation failed. Consequently, the zoning configurations might be inconsistent across the fabric. |
To resolve the problem if the distribution operation is triggered by using the zoneset activate command: 210. Verify that the contents of the active zone set are consistent on all switches by using the display current-configuration command. 211. Reactivate the zone set and distribute it to the entire fabric by using the zoneset activate command. To resolve the problem if the distribution operation is triggered by using the zoneset distribute command: 212. Verify that the contents of the active zone set and zone database are consistent on all switches by using the display current-configuration command. 213. Trigger a new complete distribution by using the zoneset distribute command. To resolve the problem if the distribution operation is triggered by a zoning mode switchover: 214. Verify that the zoning mode is the same on all switches by using the display zone status command. 215. Trigger a new complete distribution by using the zoneset distribute command. |
FCZONE_HARDZONE_DISABLED
Message text |
-VSAN=[UINT16]: No enough hardware resource for zone rule, switched to soft zoning. |
Variable fields |
$1: VSAN ID. |
Severity level |
4 |
Example |
FCZONE/4/FCZONE_HARDZONE_DISABLED: -VSAN=2: No enough hardware resource for zone rule, switched to soft zoning. |
Explanation |
Activate a smaller zone set. |
FCZONE_HARDZONE_ENABLED
Message text |
-VSAN=[UINT16]: Hardware resource for zone rule is restored, switched to hard zoning. |
Variable fields |
$1: VSAN ID. |
Severity level |
6 |
Example |
FCZONE/6/FCZONE_HARDZONE_ENABLED: -VSAN=2: Hardware resource for zone rule is restored, switched to hard zoning. |
Explanation |
Hard zoning is enabled in a VSAN because the hardware resources are restored. |
FCZONE_ISOLATE_ALLNEIGHBOR
Message text |
Variable fields |
$1: VSAN ID. |
Severity level |
4 |
Example |
Explanation |
E_Ports connected to all neighbors were isolated because the length of the locally generated MR packet exceeded the limit. |
To resolve the problem: 216. Use the display current-configuration command on the local switch to view the zoning configuration. 217. Delete unnecessary zoning configuration of the active zone set. 218. Execute the shutdown and undo shutdown command sequence on those isolated E_Ports to trigger a new merge operation. Or 219. Activate a smaller zone set. 220. Execute the shutdown and undo shutdown command sequence on those isolated E_Ports to trigger a new merge operation. |
FCZONE_ISOLATE_CLEAR_VSAN
Message text |
-Interface=[STRING]-VSAN=[UINT16]; Isolation status was cleared. |
Variable fields |
$1: Interface name. $2: VSAN ID. |
Severity level |
6 |
Example |
FCZONE/6/FCZONE_ISOLATE_CLEAR_VSAN: -Interface=Fc1/0/1-VSAN=2; Isolation status was cleared. |
Explanation |
The isolation status of an interface was cleared in a VSAN. |
FCZONE_ISOLATE_CLEAR_ALLVSAN
Message text |
-Interface=[STRING]; Isolation status was cleared in all supported VSANs. |
Variable fields |
Severity level |
6 |
Example |
Explanation |
The isolation status of an interface was cleared in all supported VSANs. |
FCZONE_ISOLATE_NEIGHBOR
Message text |
-VSAN=[UINT16]; All the E ports connected to a neighbor were isolated because of merge failure, and the neighbor’s switch WWN is [STRING]. |
Variable fields |
$1: VSAN ID. $2: Neighbor's switch WWN. |
Severity level |
4 |
Example |
FCZONE/4/FCZONE_ISOLATE_NEIGHBOR: -VSAN=2; All the E ports connected to a neighbor were isolated because of merge failure, and the neighbor’s switch WWN is 10:00:00:11:22:00:0d:01. |
Explanation |
All E_Ports connected to a neighbor were isolated because a merge operation with the neighbor failed. |
To resolve the problem: 221. Use the display current-configuration command on the local switch and the neighbor switch to view their zoning configurations. 222. Modify those noncompliant configurations on both switches to be compliant with merge rules. 223. Execute the shutdown and undo shutdown command sequence on those isolated E_Ports to trigger a new merge operation. |
FGROUP messages
This section contains flow group messages.
FLOWGROUP_APPLY_FAIL
Message text |
Failed to apply flow group [STRING]. Reason: [STRING] |
Variable fields |
$1: Flow group ID. $2: Failure cause: ¡ The operation is not supported. ¡ Not enough resources to complete the operation. |
Severity level |
4 |
Example |
FGROUP/4/FLOWGROUP_APPLY_FAIL: Failed to apply flow group 1. Reason: The operation is not supported. |
Explanation |
This message was generated when a flow group fails to be applied. |
Modify or delete the flow group. |
FLOWGROUP_MODIFY_FAIL
Message text |
Failed to modify flow group [STRING]. Reason: [STRING] |
Variable fields |
Severity level |
4 |
Example |
FGROUP/4/FLOWGROUP_MODIFY_FAIL: Failed to modify flow group 1. Reason: The operation is not supported. |
Explanation |
This message is generated when a flow group fails to be modified. |
Delete unnecessary settings on the device if the failure is due to insufficient resources. |
FIB messages
This section contains FIB messages.
FIB_FILE
Message text |
Failed to save the IP forwarding table due to lack of storage resources. |
Variable fields |
N/A |
Severity level |
4 |
Example |
FIB/4/FIB_FILE: -MDC=1; Failed to save the IP forwarding table due to lack of storage resources. |
Explanation |
Delete unused files to release storage space. |
FILTER messages
This section contains filter messages.
FILTER_EXECUTION_ICMP
Message text |
RcvIfName(1023)=[STRING];Direction(1070)=[STRING];AclType(1067)=[STRING];Acl(1068)=[STRING];Protocol(1001)=[STRING];SrcIPAddr(1003)=[IPADDR];DstIPAddr(1007)=[IPADDR];IcmpType(1062)=[STRING]([UINT16]);IcmpCode(1063)=[UINT16];MatchAclCount(1069)=[UINT32];Event(1048)=[STRING]; |
Variable fields |
$1: Receiving interface name. $2: Direction. $3: ACL type. $4: ACL number or name. $5: Layer 4 protocol name. $6: Source IP address. $7: Destination IP address. $8: ICMP message type. $9: ICMP message code. $10: Match count. $11: Event information. |
Severity level |
6 |
Example |
FILTER/6/FILTER_EXECUTION_ICMP: RcvIfName(1023)=GigabitEthernet2/0/2;Direction(1067)=inbound;AclType(1064)=ACL;Acl(1065)=3000;Protocol(1001)=ICMP;SrcIPAddr(1003)=100.1.1.1;DstIPAddr(1007)=200.1.1.1;IcmpType(1059)=Echo(8);IcmpCode(1060)=0;MatchAclCount(1066)=1000;Event(1048)=Permit; |
Explanation |
ICMP packets matched the packet filter. This message is sent when the first ICMP packet of a flow matches the packet filter, and it will be sent regularly for the flow. |
FILTER_EXECUTION_ICMPV6
Message text |
RcvIfName(1023)=[STRING];Direction(1070)=[STRING];AclType(1067)=[STRING];Acl(1068)=[STRING];Protocol(1001)=[STRING];SrcIPv6Addr(1036)=[IPADDR];DstIPv6Addr(1037)=[IPADDR];Icmpv6Type(1064)=[STRING]([UINT16]);Icmpv6Code(1065)=[UINT16];MatchAclCount(1069)=[UINT32];Event(1048)=[STRING]; |
Variable fields |
$1: Receiving interface name. $2: Direction. $3: ACL type. $4: ACL number or name. $5: Layer 4 protocol name. $6: Source IPv6 address. $7: Destination IPv6 address. $8: ICMPv6 message type. $9: ICMPv6 message code. $10: Match count. $11: Event information. |
Severity level |
6 |
Example |
FILTER/6/FILTER_EXECUTION_ICMPV6: RcvIfName(1023)=GigabitEthernet2/0/2;Direction(1067)=inbound;AclType(1064)=ACL;Acl(1065)=3000;Protocol(1001)=ICMPV6;SrcIPv6Addr(1036)=2001::1;DstIPv6Addr(1037)=3001::1;Icmpv6Type(1064)=Echo(128);Icmpv6Code(1065)=0;MatchAclCount(1066)=1000;Event(1048)=Permit; |
Explanation |
ICMPv6 packets matched the packet filter. This message is sent when the first ICMPv6 packet of a flow matches the packet filter, and it will be sent regularly for the flow. |
FILTER_IPV4_EXECUTION
Message text |
RcvIfName(1023)=[STRING];Direction(1070)=[STRING];AclType(1067)=[STRING];Acl(1068)=[STRING];Protocol(1001)=[STRING];SrcIPAddr(1003)=[IPADDR];SrcPort(1004)=[UINT16];DstIPAddr(1007)=[IPADDR];DstPort(1008)=[UINT16];MatchAclCount(1069)=[UINT32];Event(1048)=[STRING]; |
Variable fields |
$1: Receiving interface name. $2: Direction. $3: ACL type. $4: ACL number or name. $5: Layer 4 protocol name. $6: Source IP address. $7: Source port. $8: Destination IP address. $9: Destination port number. $10: Match count. $11: Event information. |
Severity level |
6 |
Example |
FILTER/6/FILTER_IPV4_EXECUTION: RcvIfName(1023)=GigabitEthernet2/0/2;Direction(1070)=inbound;AclType(1067)=ACL;Acl(1068)=3000;Protocol(1001)=TCP;SrcIPAddr(1003)=100.1.1.1;SrcPort(1004)=1025;DstIPAddr(1007)=200.1.1.1;DstPort(1008)=1026;MatchAclCount(1069)=1000;Event(1048)=Permit; |
Explanation |
Packets other than ICMP packets matched the packet filter. This message is sent when the first packet of a flow matches the packet filter, and it will be sent regularly for the flow. |
FILTER_IPV6_EXECUTION
Message text |
RcvIfName(1023)=[STRING];Direction(1070)=[STRING];AclType(1067)=[STRING];Acl(1068)=[STRING];Protocol(1001)=[STRING];SrcIPv6Addr(1036)=[IPADDR];SrcPort(1004)=[UINT16];DstIPv6Addr(1037)=[IPADDR];DstPort(1008)=[UINT16];MatchAclCount(1069)=[UINT32];Event(1048)=[STRING]; |
Variable fields |
$1: Receiving interface name. $2: Direction. $3: ACL type. $4: ACL number or name. $5: Layer 4 protocol name. $6: Source IPv6 address. $7: Source port number. $8: Destination IPv6 address. $9: Destination port number. $10: Match count. $11: Event information. |
Severity level |
6 |
Example |
FILTER/6/FILTER_IPV6_EXECUTION: RcvIfName(1023)=GigabitEthernet2/0/2;Direction(1070)=inbound;AclType(1067)=ACL;Acl(1068)=3000;Protocol(1001)=TCP;SrcIPv6Addr(1036)=2001::1;SrcPort(1004)=1025;DstIPv6Addr(1037)=3001::1;DstPort(1008)=1026;MatchAclCount(1069)=1000;Event(1048)=Permit; |
Explanation |
Packets other than ICMPv6 packets matched the packet filter. This message is sent when the first packet of a flow matches the packet filter, and it will be sent regularly for the flow. |
FIPSNG messages
This section contains FIP snooping messages.
FIPSNG_HARD_RESOURCE_NOENOUGH
Message text |
No enough hardware resource for FIP snooping rule. |
Variable fields |
N/A |
Severity level |
4 |
Example |
FIPSNG/4/FIPSNG_HARD_RESOURCE_NOENOUGH: No enough hardware resource for FIP snooping rule. |
Explanation |
Hardware resources are insufficient. |
FIPSNG_HARD_RESOURCE_RESTORE
Message text |
Hardware resource for FIP snooping rule is restored. |
Variable fields |
N/A |
Severity level |
6 |
Example |
FIPSNG/6/FIPSNG_HARD_RESOURCE_RESTORE: Hardware resource for FIP snooping is restored. |
Explanation |
Hardware resources for FIP snooping rules are restored. |
FS messages
This section contains file system messages.
FS_UNFORMATTED_PARTITION
Message text |
Partition [%s] is not formatted yet. Please format the partition first. |
Variable fields |
$1: Partition name. |
Severity level |
4 |
Example |
FS/4/FS_UNFORMATED_PARTITION: Partition usba0: is not formatted yet. Please format the partition first. |
Explanation |
The partition is not formatted. You must format a partition before you can perform other operations on the partition. |
Format the specified partition. |
FTP messages
This section contains File Transfer Protocol messages.
FTP_ACL_DENY
Message text |
The FTP Connection [IPADDR]([STRING]) request was denied according to ACL rules. |
Variable fields |
$1: IP address of the FTP client. $2: VPN instance to which the IP address of the FTP client belongs. |
Severity level |
5 |
Example |
FTP/5/FTP_ACL_DENY: The FTP Connection 1.2.3.4(vpn1) request was denied according to ACL rules. |
Explanation |
The ACL for controlling FTP access denied the access request of an FTP client. |
FTP_REACH_SESSION_LIMIT
Message text |
FTP client [STRING] failed to log in. The current number of FTP sessions is [NUMBER]. The maximum number allowed is ([NUMBER]). |
Variable fields |
$1: IP address of the FTP client. $2: Current number of FTP sessions. $3: Maximum number of FTP sessions allowed by the device. |
Severity level |
Example |
Explanation |
The number of FTP connections reached the limit. |
224. Use the display current-configuration | include session-limit command to view the current limit for FTP connections. If the command does not display the limit, the device is using the default setting. 225. If you want to set a greater limit, execute the aaa session-limit command. If you think the limit is proper, no action is required. |
FTPD_AUTHOR_FAILED
Message text |
Authorization failed for user [STRING]@[STRING]. |
Variable fields |
$1: Username. $1: IP address of the FTP client. |
Severity level |
4 |
Example |
FTP/4/FTPD_AUTHOR_FAILED: Authorization failed for user admin@10.11.115.63. |
Explanation |
Authorization for a user failed. |
Check whether the user is assigned the FTP service. |
gRPC messages
This section contains gRPC messages.
GRPC_LOGIN
Message text |
[STRING] logged in from [STRING], session id [INT32]. |
Variable fields |
$1: Username. $2: Client ID. $3: Session ID. |
Severity level |
6 |
Example |
GRPC/6/GRPC_LOGIN: user logged in from 127.0.0.1, session id 1. |
Explanation |
A user logged in successfully. |
GRPC_LOGIN_FAILED
Message text |
[STRING] from [STRING] login failed. Or: [STRING] from [STRING] login failed. [STRING] |
Variable fields |
$1: Username. $2: Client ID. $3: Login failure reason. The value might be Number of the gRPC sessions reached the limit. |
Severity level |
4 |
Example |
GRPC/4/GRPC_LOGIN_FAILED: user from 127.0.0.1 login failed. |
Explanation |
A user failed to log in. |
226. If no failure reason is displayed, verify that the user is configured and the user entered the correct username and password. 227. If the maximum number of gRPC sessions was already reached, release gRPC sessions as required. |
GRPC_LOGOUT
Message text |
[STRING] logged out, session id [INT32]. |
Variable fields |
$1: Username. $2: Session ID. |
Severity level |
6 |
Example |
GRPC/6/GRPC_LOGOUT: user logged out, session id 1. |
Explanation |
A user logged out successfully. |
GRPC_SERVER_FAILED
Message text |
Failed to enable gRPC server. |
Variable fields |
N/A |
Severity level |
4 |
Example |
GRPC/4/GRPC_SERVER_FAILED: Failed to enable gRPC server. |
Explanation |
A port conflict caused a gRPC server connection failure. |
Identify whether a port conflict exist. If yes, modify the port settings as required. |
GRPC_SUBSCRIBE_EVENT_FAILED
Message text |
Failed to subscribe event [STRING]. |
Variable fields |
$ 1: Event name. |
Severity level |
4 |
Example |
GRPC/4/GRPC_SUBSCRIBE_EVENT_FAILED: Failed to subscribe event syslog. |
Explanation |
Failed to subscribe to an event. |
GRPC_RECEIVE_SUBSCRIPTION
Message text |
Received a subscription of module [STRING]. |
Variable fields |
$ 1: Module name. |
Severity level |
6 |
Example |
GRPC/6/GRPC_RECEIVE_SUBSCRIPTION: Received a subscription of module syslog. |
Explanation |
The device received a subscription request for a module. |
HA messages
This section contains HA messages.
HA_BATCHBACKUP_FINISHED
Message text |
Batch backup of standby board in [STRING] has finished. |
Variable fields |
$1: Chassis number and slot number or slot number. |
Severity level |
5 |
Example |
HA/5/HA_BATCHBACKUP_FINISHED: Batch backup of standby board in slot 1 has finished. |
Explanation |
Batch backup from the active MPU to the standby MPU has finished. |
HA_BATCHBACKUP_STARTED
Message text |
Batch backup of standby board in [STRING] started. |
Variable fields |
Severity level |
5 |
Example |
HA/5/HA_BATCHBACKUP_STARTED: Batch backup of standby board in slot 1 started. |
Explanation |
Batch backup from the active MPU to the standby MPU has started. |
HA_STANDBY_NOT_READY
Message text |
Standby board in [STRING] is not ready, reboot ... |
Variable fields |
Severity level |
4 |
Example |
HA/4/HA_STANDBY_NOT_READY: Standby board in slot 1 is not ready, reboot ... |
Explanation |
This message appears on the standby MPU. When batch backup is not complete on the standby MPU, performing active and standby MPU switchover results in restart of the active and standby MPUs. |
Do not perform active and standby MPU switchover before batch backup is complete on the standby MPU. |
HA_STANDBY_TO_MASTER
Message text |
Standby board in [STRING] changed to the master. |
Variable fields |
Severity level |
5 |
Example |
HA/5/HA_STANDBY_TO_MASTER: Standby board in slot 1 changed to the master. |
Explanation |
An active and standby MPU switchover occurs. The standby MPU changed to active. |
HLTH messages
This section contains health messages.
LIPC_COMM_FAULTY
Message text |
LIPC [STRING] between [STRING] and [STRING] might be faulty. |
Variable fields |
$1: LIPC communication type. Options include: ¡ unicast—Unicast communication. ¡ broadcast—Broadcast communication. ¡ topo—Topology communication. $2: Chassis number and slot number and CPU number, or slot number and CPU number. A CPU number is present only if the slot supports multiple CPUs. $3: Chassis number and slot number and CPU number, or slot number and CPU number. A CPU number is present only if the slot supports multiple CPUs. |
Severity level |
4 |
Example |
HLTH/4/LIPC_COMM_FAULTY: LIPC unicast between slot 1 and slot 2 might be faulty. |
Explanation |
An LIPC communication exception occurred. |
Execute the display system health command to identify system health status. If the issue persists after 30 minutes, contact H3C Support. |
LIPC_COMM_RECOVER
Message text |
LIPC [STRING] between [STRING] and [STRING] recovered. |
Variable fields |
Severity level |
6 |
Example |
HLTH/6/LIPC_COMM_NORMAL: LIPC unicast between slot 1 and slot 2 recovered. |
Explanation |
The LIPC communication recovered. |
HQOS messages
This section contains HQoS messages.
HQOS_DP_SET_FAIL
Message text |
Failed to set drop profile [STRING] globally. |
Variable fields |
$1: Drop profile name. |
Severity level |
4 |
Example |
HQOS/4/HQOS_DP_SET_FAIL: Failed to set drop profile b globally. |
Explanation |
The system failed to perform one of the following actions: · Apply a drop profile globally. · Modify a drop profile applied globally. |
Check the drop profile settings. |
HQOS_FP_SET_FAIL
Message text |
Failed to set [STRING] in forwarding profile [STRING] globally. |
Variable fields |
$1: Policy type: · gts. · bandwidth. · queue. · drop profile. $2: Forwarding profile name. |
Severity level |
4 |
Example |
HQOS/4/HQOS_FP_SET_FAIL: Failed to set gts in forwarding profile b globally. |
Explanation |
The system failed to perform one of the following actions: · Apply a forwarding profile globally. · Modify a forwarding profile applied globally. |
Examine the forwarding profile, and make sure it is supported and has no conflicted contents. |
HQOS_POLICY_APPLY_FAIL
Message text |
Failed to apply some forwarding classes or forwarding groups in scheduler policy [STRING] to the [STRING] direction of interface [STRING]. |
Variable fields |
$1: Scheduler policy name. $2: Policy direction: inbound or outbound. $3: Interface name. |
Severity level |
4 |
Example |
HQOS/4/HQOS_POLICY_APPLY_FAIL: Failed to apply some forwarding classes or forwarding groups in scheduler policy b to the inbound direction of interface Ethernet3/1/2. |
Explanation |
The system failed to perform one of the following actions: · Apply a scheduler policy to a specific direction of an interface. · Modify a scheduler policy applied to a specific direction of an interface. |
Use the display qos scheduler-policy diagnosis interface command to identify the nodes that failed to be applied and the failure causes, and modify the running configuration. |
Message text |
Failed to recover scheduler policy [STRING] to the [STRING] direction of interface [STRING] due to [STRING]. |
Variable fields |
$1: Scheduler policy name. $2: Policy direction: inbound or outbound. $3: Interface name. $4: Cause. |
Severity level |
4 |
Example |
HQOS/4/HQOS_POLICY_RECOVER_FAIL: Failed to recover scheduler policy b to the outbound direction of interface Ethernet3/1/2 due to conflicting with QoS configuration. |
Explanation |
The system failed to recover an applied scheduler policy after the card or device rebooted, because the scheduler policy conflicted with the QoS configuration on the interface. |
Check the scheduler policy configuration according to the failure cause. |
HTTPD messages
This section contains HTTP daemon messages.
HTTPD_CONNECT
Message text |
[STRING] client [STRING] connected to the server successfully. |
Variable fields |
$1: Connection type, HTTP or HTTPS. $2: Client IP address. |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_CONNECT: HTTP client 192.168.30.117 connected to the server successfully. |
Explanation |
The HTTP or HTTPS server accepted the request from a client. An HTTP or HTTPS connection was set up. |
HTTPD_CONNECT_TIMEOUT
Message text |
[STRING] client [STRING] connection idle timeout. |
Variable fields |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_CONNECT_TIMEOUT: HTTP client 192.168.30.117 connection to server idle timeout. |
Explanation |
An HTTP or HTTPS connection was disconnected because the idle timeout timer expires. |
HTTPD_DISCONNECT
Message text |
[STRING] client [STRING] disconnected from the server. |
Variable fields |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_DISCONNECT: HTTP client 192.168.30.117 disconnected from the server. |
Explanation |
An HTTP or HTTPS client was disconnected from the server. |
HTTPD_FAIL_FOR_ACL
Message text |
[STRING] client [STRING] failed the ACL check and could not connect to the server. |
Variable fields |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_FAIL_FOR_ACL: HTTP client 192.168.30.117 failed the ACL check and cannot connect to the server. |
Explanation |
An HTTP or HTTPS client was filtered by the ACL. |
HTTPD_FAIL_FOR_ACP
Message text |
[STRING] client [STRING] was denied by the certificate access control policy and could not connect to the server. |
Variable fields |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_FAIL_FOR_ACP: HTTP client 192.168.30.117 was denied by the certificate attribute access control policy and could not connect to the server. |
Explanation |
An HTTP or HTTPS client was denied by the certificate access control policy. |
HTTPD_REACH_CONNECT_LIMIT
Message text |
[STRING] client [STRING] failed to connect to the server, because the number of connections reached the upper limit. |
Variable fields |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_REACH_CONNECT_LIMIT: HTTP client 192.168.30.117 failed to connect to the server, because the number of connections reached the upper limit. |
Explanation |
The number of connections reached the limit. |
228. Use the display current-configuration | include session-limit command to view the current limit for connections of the specified type. If the command does not display the limit, the device is using the default setting. 229. If you want to specify a greater limit, execute the aaa session-limit command. If you think the limit is proper, no action is required. |
IFNET messages
This section contains interface management messages.
IF_BUFFER_CONGESTION_OCCURRENCE
Message text |
[STRING] congestion occurs on queue [INTEGER] of [STRING]. |
Variable fields |
$1: Data buffer type: ingress (for receive data buffer) or egress (for transmit data buffer). $2: Queue ID in the range of 0 to 7. $3: Interface name. |
Severity level |
4 |
Example |
IFNET/4/IF_BUFFER_CONGESTION_OCCURRENCE: Ingress congestion occurs on queue 1 of GigabitEthernet1/0/1. |
Explanation |
On queue 1 of GigabitEthernet 1/0/1, congestion occurs in the receive data buffer. |
Examine the network status. |
IF_BUFFER_CONGESTION_CLEAR
Message text |
[STRING] congestion on queue [UINT32] of [STRING] is cleared. [UINT64] packets are discarded. |
Variable fields |
$1: Data buffer type: ingress (for receive data buffer) or egress (for transmit data buffer). $2: Queue ID in the range of 0 to 7. $3: Interface name. $4: Number of packets dropped. |
Severity level |
5 |
Example |
IFNET/5/IF_BUFFER_CONGESTION_CLEAR: Ingress congestion on queue 1 of GigabitEthernet1/0/1 is cleared. 1000 packets are discarded. |
Explanation |
On queue 1 of GigabitEthernet 1/0/1, congestion in the receive data buffer is removed. 1000 packets are dropped. |
IF_JUMBOFRAME_WARN
Message text |
The specified size of jumbo frames on the aggregate interface [STRING] is not supported on the member port [STRING]. |
Variable fields |
$1: Aggregate interface name. $2: Member port name. |
Severity level |
3 |
Example |
IFNET/3/IF_JUMBOFRAME_WARN: -MDC=1-Slot=3; The specified size of jumbo frames on the aggregate interface Bridge-Aggregation1 is not supported on the member port GigabitEthernet1/0/1. |
Explanation |
Some member ports do not support the jumbo frame size configured on the aggregate interface. |
230. Identify the value ranges for the jumbo frame size supported on member ports. 231. Specify a jumbo frame size supported by member ports for the aggregate interface. |
IF_LINKFLAP_DETECTED
Message text |
Link flapping was detected on [STRING]. |
Variable fields |
$1: Interface name |
Severity level |
3 |
Example |
IFNET/3/IF_LINKFLAP_DETECTED: Link flapping was detected on GigabitEthernet1/0/1. |
Explanation |
The number of detected flaps reached or exceeded the link flapping detection threshold during the link flapping detection interval. |
232. Identify whether the cable is frequently plugged and unplugged for the local or peer interface. 233. Execute the port link-flap protect enable command to adjust the link flapping detection interval and the link flapping detection threshold. |
INTERFACE_NOTSUPPRESSED
Message text |
Interface [STRING] is not suppressed. |
Variable fields |
Severity level |
6 |
Example |
IFNET/6/INTERFACE_NOTSUPPRESSED: Interface Ethernet0/0/0 is not suppressed. |
Explanation |
The interface changed from suppressed state to unsuppressed state. When the interface is unsuppressed, the upper-layer services can detect the physical state changes of the interface. |
INTERFACE_SUPPRESSED
Message text |
Interface [STRING] was suppressed. |
Variable fields |
Severity level |
5 |
Example |
IFNET/5/INTERFACE_SUPPRESSED: Interface Ethernet0/0/0 was suppressed. |
Explanation |
The interface was suppressed because its state frequently changed. When the interface is suppressed, the upper-layer services cannot detect the physical state changes of the interface. |
234. Check whether the network cable of the interface or peer interface is frequently plugged and unplugged. 235. Configure physical state change suppression to adjust the suppression parameters. |
LINK_UPDOWN
Message text |
Line protocol state on the interface [STRING] changed to [STRING]. |
Variable fields |
$1: Interface name. $2: State of link layer protocol, which can be up or down. |
Severity level |
5 |
Example |
IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ethernet0/0 changed to down. |
Explanation |
The link layer protocol state changed on an interface. |
When the link layer protocol state of an interface is down, use the display interface command to display the link layer protocol state and locate the reason for which the link layer protocol state changed to down on the interface. |
PHY_UPDOWN
Message text |
Physical state on the interface [STRING] changed to [STRING]. |
Variable fields |
$1: Interface name. $2: Link state, which can be up or down. |
Severity level |
3 |
Example |
IFNET/3/PHY_UPDOWN: Physical state on the Ethernet0/0 changed to down. |
Explanation |
The physical state changed on an interface. |
When the interface is physically down, check whether a physical link is present or whether the link fails. |
PROTOCOL_UPDOWN
Message text |
Protocol [STRING] state on the interface [STRING] changed to [STRING]. |
Variable fields |
$1: Protocol name. $2: Interface name. $3: Protocol state, which can be up or down. |
Severity level |
5 |
Example |
IFNET/5/PROTOCOL_UPDOWN: Protocol IPX state on the interface Ethernet6/4/1 changed to up. |
Explanation |
The state of a protocol has been changed on an interface. |
When the state of a network layer protocol is down, check the network layer protocol configuration. |
TUNNEL_LINK_UPDOWN
Message text |
Variable fields |
$1: Interface name. $2: Protocol state, which can be up or down. |
Severity level |
5 |
Example |
IFNET/5/TUNNEL_LINK_UPDOWN: Line protocol state on the interface Tunnel1 changed to down. |
Explanation |
The state of a link layer protocol has been changed on a tunnel interface. |
When the link layer protocol state of a tunnel interface is down, use the display interface command to display the link layer protocol state and locate the reason for which the link layer protocol state changed to down on the tunnel interface. |
TUNNEL_PHY_UPDOWN
Message text |
Variable fields |
Severity level |
3 |
Example |
IFNET/3/TUNNEL_PHY_UPDOWN: Physical state on the Tunnel1 changed to down. |
Explanation |
When the physical state of a link layer protocol is down, check whether a physical link is present or whether the link fails. |
VLAN_MODE_CHANGE
Message text |
Dynamic VLAN [INT32] has changed to a static VLAN. |
Variable fields |
$1: VLAN ID. |
Severity level |
5 |
Example |
IFNET/5/VLAN_MODE_CHANGE: Dynamic VLAN 20 has changed to a static VLAN. |
Explanation |
Creating a VLAN interface for a VLAN cause the dynamic VLAN to become a static VLAN. |
IKE messages
This section contains IKE messages.
IKE_P1_SA_ESTABLISH_FAIL
Message text |
Failed to establish phase 1 SA for the reason of [STRING]. The SA's source address is [STRING], and its destination address is [STRING]. |
Variable fields |
$1: Reason for the failure: ¡ No matching proposal. ¡ Invalid ID information. ¡ Unavailable certificate. ¡ Unsupported DOI. ¡ Unsupported situation. ¡ Invalid proposal syntax. ¡ Invalid SPI. ¡ Invalid protocol ID. ¡ Invalid certificate. ¡ Authentication failure. ¡ Invalid message header. ¡ Invalid transform ID. ¡ Malformed payload. ¡ Retransmission timeout. ¡ Incorrect configuration. $2: Source address. $3: Destination address. |
Severity level |
6 |
Example |
IKE/6/IKE_P1_SA_ESTABLISH_FAIL: Failed to establish phase 1 SA for the reason of no matching proposal. The SA’s source address is 1.1.1.1 and its destination address is 2.2.2.2. |
Explanation |
An IKE SA cannot be established in phase 1. The failure reason is displayed. |
Check the IKE configuration on the local and remote devices. |
IKE_P2_SA_ESTABLISH_FAIL
Message text |
Failed to establish phase 2 SA for the reason of [STRING]. The SA's source address is [STRING], and its destination address is [STRING]. |
Variable fields |
$1: Reason for the failure: ¡ Invalid key information. ¡ Invalid ID information. ¡ Unavailable proposal. ¡ Unsupported DOI. ¡ Unsupported situation. ¡ Invalid proposal syntax. ¡ Invalid SPI. ¡ Invalid protocol ID. ¡ Invalid hash information. ¡ Invalid message header. ¡ Malformed payload. ¡ Retransmission timeout. ¡ Incorrect configuration. $2: Source address. $3: Destination address. |
Severity level |
6 |
Example |
IKE/6/IKE_P2_SA_ESTABLISH_FAIL: Failed to establish phase 2 SA for the reason of invalid key information. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
Explanation |
An IPsec SA cannot be established in phase 2. The failure reason is displayed. |
Check the IKE and IPsec configurations on the local and remote devices. |
IKE_P2_SA_TERMINATE
Message text |
The IKE phase 2 SA was deleted for the reason of [STRING]. The SA's source address is [STRING], and its destination address is [STRING]. |
Variable fields |
$1: Reason that the SA is deleted, which is SA expiration. $2: Source address. $3: Destination address. |
Severity level |
6 |
Example |
IKE/6/IKE_P2_SA_TERMINATE: The IKE phase 2 SA was deleted for the reason of SA expiration. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
Explanation |
An IPsec SA is deleted in phase 2 because it expires. |
IKE_VERIFY_CERT_FAIL
Message text |
Failed to verify the peer certificate. Reason: [STRING]. |
Variable fields |
$1: Failure reason: ¡ Unable to get issuer certificate. ¡ Unable to get certificate CRL. ¡ Unable to decrypt CRL's signature. ¡ Unable to decode issuer public key. ¡ Certificate signature failure. ¡ CRL signature failure. ¡ Unable to decrypt certificate's signature. ¡ Certificate is not yet valid. ¡ Certificate has expired. ¡ CRL is not yet valid. ¡ CRL has expired. ¡ Format error in certificate's notBefore field. ¡ Format error in certificate's notAfter field. ¡ Format error in CRL's lastUpdate field. ¡ Format error in CRL's nextUpdate field. ¡ Out of memory. ¡ Self signed certificate. ¡ Self signed certificate in certificate chain. ¡ Unable to get local issuer certificate. ¡ Unable to verify the first certificate. ¡ Certificate chain too long. ¡ Certificate revoked. ¡ Invalid CA certificate. ¡ Invalid non-CA certificate (has CA markings). ¡ Path length constraint exceeded. ¡ Proxy path length constraint exceeded. ¡ Proxy certificates not allowed, please set the appropriate flag. ¡ Unsupported certificate purpose. ¡ Certificate not trusted. ¡ Certificate rejected. ¡ Application verification failure. ¡ Subject issuer mismatch. ¡ Authority and subject key identifier mismatch. ¡ Authority and issuer serial number mismatch. ¡ Key usage does not include certificate signing. ¡ Unable to get CRL issuer certificate. ¡ Unhandled critical extension. ¡ Key usage does not include CRL signing. ¡ Key usage does not include digital signature. ¡ Unhandled critical CRL extension. ¡ Invalid or inconsistent certificate extension. ¡ Invalid or inconsistent certificate policy extension. ¡ No explicit policy. ¡ Different CRL scope. ¡ Unsupported extension feature. ¡ RFC 3779 resource not subset of parent's resources. ¡ Permitted subtree violation. ¡ Excluded subtree violation. ¡ Name constraints minimum and maximum not supported. ¡ Unsupported name constraint type. ¡ CRL path validation error. ¡ Unsupported or invalid name syntax. ¡ Unsupported or invalid name constraint syntax. ¡ Suite B: certificate version invalid. ¡ Suite B: invalid public key algorithm. ¡ Suite B: invalid ECC curve. ¡ Suite B: invalid signature algorithm. ¡ Suite B: curve not allowed for this LOS. ¡ Suite B: cannot sign P-384 with P-256. ¡ Hostname mismatch. ¡ Email address mismatch. ¡ IP address mismatch. ¡ Invalid certificate verification context. ¡ Issuer certificate lookup error. ¡ Proxy subject name violation. |
Severity level |
6 |
Example |
IKE/6/IKE_VERIFY_CERT_FAIL: Failed to verify the peer certificate. Reason: invalid or inconsistent certificate extension. |
Explanation |
Failed to verify a peer certificate. The reason for the failure is displayed. |
IMA
This section contains Integrity Measurements Architecture (IMA) messages.
IMA_ALLOCATE_FAILED
Message text |
Failed to allocate resource for file [STRING]. |
Variable fields |
$1: Name of the file of which you want to measure the integrity. |
Severity level |
4 |
Example |
IMA/4/IMA_ALLOCATE_FAILED: Failed to allocate resource for file /sbin/tcsmd. |
Explanation |
IMA failed to allocate resources to the specified file. |
Contact H3C Support. |
IMA_DATA_ERROR
Can't collect data of file [STRING]. |
Variable fields |
Severity level |
4 |
Example |
IMA/4/IMA_DATA_ERROR: Can't collect data of file /sbin/tcsmd. |
Explanation |
IMA failed to open the specified file, read data from the file, or compute the hash value of the file. |
IMA_FILE_HASH_FAILED
Message text |
Hash value of file [STRING] is not consistent with that in the RM file. |
Variable fields |
Severity level |
4 |
Example |
IMA/4/IMA_FILE_HASH_FAILED: Hash value of file /sbin/tcsmd is not consistent with that in the RM file. |
Explanation |
The computed hash value of the specified file is different from the hash value of the file stored in the RM file. The specified file is not trustworthy. |
IMA_RM_FILE_MISS
Message text |
File [STRING] is missing in the RM file. |
Variable fields |
Severity level |
4 |
Example |
IMA/4/IMA_RM_FILE_MISS: File /sbin/tcsmd is missing in the RM file. |
Explanation |
IMA did not find information about the specified file in the RM file. |
IMA_RM_HASH_MISS
Message text |
Hash value of file [STRING] is missing in the RM file. |
Variable fields |
Severity level |
4 |
Example |
IMA/4/IMA_RM_HASH_MISS: Hash value of file /sbin/tcsmd is missing in the RM file. |
Explanation |
IMA did not find the hash value of the specified file in the RM file. The hash algorithm used for integrity measurement of the specified file might not be supported in the RM. |
IMA_TEMPLATE_ERROR
Message text |
Failed to extend template hash value of file [STRING] to the PCR. |
Variable fields |
Severity level |
4 |
Example |
IMA/4/IMA_TEMPLATE_ERROR: Failed to extend template hash value of file /sbin/tcsmd to the PCR. |
Explanation |
IMA failed to extend the template hash value of the specified file to the PCRs. |
iNQA messages
This section contains Intelligent Network Quality Analyzer (iNQA) messages.
INQA_BWD_LOSS_EXCEED
Message text |
Packet loss rate of the backward flow in instance [UINT] exceeded the upper limit. |
Variable fields |
$1: Instance ID. |
Severity level |
5 |
Example |
INQA/5/INQA_BWD_LOSS_EXCEED: Packet loss rate of the backward flow in instance 1 exceeded the upper limit. |
Explanation |
The message is sent when the packet loss rate of the backward flow exceeds the upper limit. |
Examine the network and verify the physical connections are correct. |
INQA_BWD_LOSS_RECOV
Message text |
Packet loss rate of the backward flow in instance [UINT] recovered. |
Variable fields |
$1: Instance ID. |
Severity level |
6 |
Example |
INQA/6/INQA_BWD_LOSS_RECOV: Packet loss rate of the backward flow in instance 1 recovered. |
Explanation |
The message is sent when the packet loss rate of the backward flow drops down below the upper limit. |
N/A |
INQA_DEBUG_FAIL
Message text |
Setting debugging switch to drive failed. |
Severity level |
5 |
Example |
INQA/5/INQA_DEBUG_FAIL: Setting debugging switch to drive failed. |
Explanation |
This message is sent when the system fails to set iNQA debugging switch to drive. |
Delete the iNQA debugging switch setting and reconfigure the debugging. |
INQA_FLAG_DIFF
Message text |
Flags of collectors bound with the analyzer instance [UINT] are inconsistent. |
Variable fields |
$1: ID of the analyzer instance. |
Severity level |
5 |
Example |
INQA/5/INQA_FLAG_DIFF: Flags of collectors bound with the analyzer instance 1 are inconsistent. |
Explanation |
This message is sent when iNQA detects that the flag bit settings on the collectors bound to analyzer instance 1 are inconsistent. |
Verify that the same flag bit is set on all collectors that are bound to the analyzer instance. |
INQA_FLAG_FAIL
Message text |
Setting coloring bit to drive failed. |
Severity level |
5 |
Example |
INQA/5/INQA_FLAG_FAIL: Setting coloring bit to drive failed. |
Explanation |
This message is sent when the system fails to set the color bit setting to the drive. |
236. Use the display qos-acl resource command to verify that the ACL resources are sufficient. 237. If the resources are not sufficient, delete unnecessary ACLs and reconfigure the instance. |
INQA_FLOW_DIFF
Message text |
Flows of collectors bound with the analyzer instance [UINT] are inconsistent. |
Variable fields |
Severity level |
5 |
Example |
INQA/5/INQA_FLOW_DIFF: Flows of collectors bound with the analyzer instance 1 are inconsistent. |
Explanation |
This message is sent when iNQA detects that the target flows in statistics packets reported by the collectors bound to analyzer instance 1 are inconsistent. |
Verify that the same target flow is defined on all collectors that are bound to the analyzer instance. |
INQA_FWD_LOSS_EXCEED
Message text |
Packet loss rate of the forward flow in instance [UINT] exceeded the upper limit. |
Variable fields |
$1: Instance ID. |
Severity level |
5 |
Example |
INQA/5/INQA_FWD_LOSS_EXCEED: Packet loss rate of the forward flow in instance 1 exceeded the upper limit. |
Explanation |
The message is sent when the packet loss rate of the forward flow exceeds the upper limit. |
Recommended action |
INQA_FWD_LOSS_RECOV
Message text |
Packet loss rate of the forward flow in instance [UINT] recovered. |
Variable fields |
$1: Instance ID. |
Severity level |
6 |
Example |
INQA/6/INQA_FWD_LOSS_RECOV: Packet loss rate of the forward flow in instance 1 recovered. |
Explanation |
The message is sent when the packet loss rate of the forward flow drops down below the upper limit. |
N/A |
INQA_INST_FAIL
Message text |
Setting instance [UINT] information to drive failed. |
Variable fields |
$1: Instance ID. |
Severity level |
5 |
Example |
INQA/5/INQA_INST_FAIL: Setting instance 1 information to drive failed. |
Explanation |
This message is sent when the system fails to send the instance configuration to the drive. |
238. Use the display qos-acl resource command to verify that the ACL resources are sufficient. 239. If the resources are not sufficient, delete unnecessary ACLs and reconfigure the instance. |
INQA_INTVL_DIFF
Message text |
Intervals of collectors bound with analyzer instance [UINT] are inconsistent. |
Variable fields |
Severity level |
5 |
Example |
INQA/5/INQA_INTVL_DIFF: Intervals of collectors bound with analyzer instance 1 are inconsistent. |
Explanation |
This message is sent when iNQA detects that the measurement intervals in statistics packets reported by the collectors bound to analyzer instance 1 are inconsistent. |
Verify that the same measurement intervals are configured on all collectors that are bound to the analyzer instance. |
INQA_NO_RESOURCE
Message text |
Failed to configure instance [UINT] due to insufficient resources. |
Variable fields |
$1: ID of the instance. |
Severity level |
5 |
Example |
INQA/5/INQA_NO_RESOURCE: Failed to configure instance 1 due to insufficient resources. |
Explanation |
This message is sent when iNQA fails to configure an instance due to insufficient ACL resources. |
Release ACL resources by deleting unused iNQA instances or unused ACL resources, and then configure the instance. |
INQA_NO_SUPPORT
Message text |
iNQA is not supported in this slot. |
Severity level |
5 |
Example |
INQA/5/INQA_NO_SUPPORT: iNQA is not supported in this slot. |
Explanation |
This message is sent when the specified slot does not support iNQA. |
Install an iNQA-capable module in the slot or switch the traffic for iNQA measurement to another slot that supports iNQA. |
INQA_SMOOTH_BEGIN_FAIL
Message text |
Setting smoothing beginning to kernel failed. |
Severity level |
5 |
Example |
INQA/5/INQA_ SMOOTH_BEGIN_FAIL: Setting smoothing beginning to the kernel failed. |
Explanation |
This message is sent when iNQA fails to notify the kernel of the start of the smooth. |
Please contact H3C support. |
INQA_SMOOTH_END_FAIL
Message text |
Setting smoothing ending to kernel failed. |
Severity level |
5 |
Example |
INQA/5/INQA_ SMOOTH_END_FAIL: Setting smoothing ending to kernel failed. |
Explanation |
This message is sent when iNQA fails to notify the kernel of the end of the smooth. |
IP6ADDR
This section contains IPv6 addressing messages.
IP6ADDR_CREATEADDRESS_ERROR
Message text |
Failed to create an address by the prefix. Reason: [STRING] on [STRING] and [STRING] on [STRING] overlap. |
Variable fields |
$1: IPv6 prefix $2: Interface name. $3: IPv6 prefix $4: Interface name. |
Severity level |
4 |
Example |
IP6ADDR/4/IP6ADDR_CREATEADDRESS_ERROR: Failed to create an address by the prefix. Reason: 2001::/ 64 on GigabitEthernet1/0/2 and 2001::/64 on GigabitEthernet1/0/1 overlap. |
Explanation |
The device failed to generate an IPv6 address for an interface by using the prefix because the prefixes overlapped on this interface and another interface. |
Cancel the IPv6 address configuration on the conflicting interface and configure the interface to generate an IPv6 address by using a different prefix. |
IP6ADDR_FUNCTION_FAIL
Message text |
Failed to enable IPv6 on interface [STRING]. Reason: [STRING]. |
Variable fields |
$1: Interface name. $2: Failure reasons: ¡ Insufficient resources. ¡ IPv6 is not supported. ¡ Unknown error. |
Severity level |
6 |
Example |
IP6ADDR/6/IP6ADDR_FUNCTION_FAIL: Failed to enable IPv6 on interface GigabitEthernet1/0/1. Reason: Insufficient resources. |
Explanation |
This message is sent when the device failed to enable IPv6 on an interface during the stateful or stateless IPv6 address autoconfiguration or manual IPv6 address assignment. |
· If the failure is caused by insufficient resources, release memory and then execute the operation again. · If the failure is caused by an unknown error, please contact H3C Support. |
IP6FW
This section contains IPv6 forwarding messages.
IPv6_MTU_SET_DRV_NOT_SUPPORT
Message text |
The operation is not supported to set driver IPv6 interface MTU: interface is [STRING], MTU is [UINT32]. |
Variable fields |
$1: Interface name. $2: MTU value. |
Severity level |
5 |
Example |
IP6FW/5/IPv6_MTU_SET_DRV_NOT_SUPPORT: The operation is not supported to set driver IPv6 interface MTU: interface is GigabitEthernet1/0/1, MTU is 1400. |
Explanation |
The device does not support sending the interface MTU setting for IPv6 packets to the driver. |
· If the device uses hardware for forwarding, no action is required. The device does not support setting the interface MTU for IPv6 packets. · If the device uses software for forwarding, please contact H3C Support. |
IPADDR messages
This section contains IP addressing messages.
IPADDR_HA_EVENT_ERROR
Message text |
A process failed HA upgrade because [STRING]. |
Variable fields |
$1: HA upgrade failure reason: · IPADDR failed the smooth upgrade. · IPADDR failed to reupgrade to the master process. · IPADDR stopped to restart the timer. · IPADDR failed to upgrade to the master process. · IPADDR failed to restart the upgrade. · IPADDR failed to add the unicast object to the master task epoll. · IPADDR failed to create an unicast object. · IPADDR role switchover failed when the standby process switched to the master process. · IPADDR switchover failed when the master process switched to the standby process. · IPADDR HA upgrade failed. · IPADDR failed to set the interface filtering criteria. · IPADDR failed to register interface events. · IPADDR failed to subscribe port events. · IPADDR failed to add a VPN port event to the master epoll. · IRDP failed to open DBM. · IRDP failed to initiate a connection to the device management module. · IRDP failed to add the master task epoll with the handle used to connect to the device management module. · IRDP failed to register device management events. · IRDP failed to subscribe port events. · IRDP failed to add the master task epoll with the handle used to subscribe port events. · IRDP failed to set the interface filtering criteria. · IRDP failed to register interface events. · IRDP failed to register network events. · IRDP failed to create the interface control block storage handle. · IRDP failed to create the timer. · IRDP failed to add the master task epoll with the handle used to create the timer. · IRDP failed to set the schedule time for the timer. · IRDP failed to set the timer to unblocked status. · IRDP failed to create a timer instance. |
Severity level |
4 |
Example |
IPADDR/4/IPADDR_HA_EVENT_ERROR: A process failed HA upgrade because IPADDR failed the smooth upgrade. |
Explanation |
A process failed HA upgrade and the message showed the failure reason. |
Please contact H3C Support. |
IPADDR_HA_STOP_EVENT
Message text |
The device received an HA stop event. |
Variable fields |
None. |
Severity level |
4 |
Example |
IPADDR/4/IPADDR_HA_STOP_EVENT: The device received an HA stop event. |
Explanation |
This message is sent when the device receives an HA stop event. |
IPFW
This section contains IP forwarding messages.
IPFW_FAILURE
Message text |
The card doesn't support the split horizon forwarding configuration. |
Variable fields |
N/A |
Severity level |
5 |
Example |
IPFW/5/IPFW_FAILURE: -MDC=1; The card doesn't support the split horizon forwarding configuration. |
Explanation |
240. Make sure the card on which you configure split horizon forwarding supports this feature. 241. Please contact H3C Support. |
Message text |
Failed to configure split horizon forwarding on the card. |
Variable fields |
N/A |
Severity level |
5 |
Example |
IPFW/5/IPFW_FAILURE: -MDC=1; Failed to configure split horizon forwarding on the card. |
Explanation |
IPv4_MTU_SET_DRV_NOT_SUPPORT
Message text |
The operation is not supported to set driver IPv4 interface MTU: interface is [STRING], MTU is [UINT32]. |
Variable fields |
Severity level |
5 |
Example |
IPFW/5/IPv4_MTU_SET_DRV_NOT_SUPPORT: The operation is not supported to set driver IPv4 interface MTU: interface is GigabitEthernet1/0/1, MTU is 1400. |
Explanation |
The device does not support sending the interface MTU setting for IPv4 packets to the driver. |
· If the device uses hardware for forwarding, no action is required. The device does not support setting the interface MTU for IPv4 packets. · If the device uses software for forwarding, please contact H3C Support. |
IPSEC messages
This section contains IPsec messages.
IPSEC_FAILED_ADD_FLOW_TABLE
Message text |
Failed to add flow-table due to [STRING]. |
Variable fields |
$1: Reason for the failure. |
Severity level |
4 |
Example |
IPSEC/4/IPSEC_FAILED_ADD_FLOW_TABLE: Failed to add flow-table due to no enough resource. |
Explanation |
Failed to add the flow table. Possible reasons include not enough hardware resources. |
If the failure is caused by not enough hardware resources, contact H3C Support. |
IPSEC_PACKET_DISCARDED
Message text |
IPsec packet discarded, Src IP:[STRING], Dst IP:[STRING], SPI:[UINT32], SN:[UINT32], Cause:[STRING]. |
Variable fields |
$1: Source IP address. $2: Destination IP address. $3: Security parameter index (SPI). $4: Sequence number of the packet. $5: Reason for dropping this packet: · Anti-replay checking failed. · AH authentication failed. · ESP authentication failed. · Invalid SA. · ESP decryption failed. · Source address of packet does not match the SA. · No ACL rule matched. |
Severity level |
6 |
Example |
IPSEC/6/IPSEC_PACKET_DISCARDED: IPsec packet discarded, Src IP:1.1.1.2, Dest IP:1.1.1.4, SPI:1002, SN:0, Cause:ah authentication failed |
Explanation |
An IPsec packet is dropped. Possible reasons include anti-replay checking failed, AH/ESP authentication failed, invalid SA, ESP decryption failed, source address of packet does not match the SA, and no ACL rule matched. |
No action is required. |
IPSEC_SA_ESTABLISH
Message text |
Established IPsec SA. The SA's source address is [STRING], destination address is [STRING], protocol is [STRING], and SPI is [UINT32]. |
Variable fields |
$1: Source address. $2: Destination address. $3: Security protocol. $4: SPI. |
Severity level |
6 |
Example |
IPSEC/6/IPSEC_SA_ESTABLISH: Established IPsec SA. The SA's source address is 1.1.1.1, destination address is 2.2.2.2, protocol is AH, and SPI is 2435. |
Explanation |
An IPsec SA is established. |
IPSEC_SA_ESTABLISH_FAIL
Message text |
Failed to establish IPsec SA for the reason of [STRING]. The SA's source address is [STRING], and its destination address is [STRING]. |
Variable fields |
$1: Reason for the IPsec SA establishment failure: · Tunnel establishment failure. · Incomplete configuration. · Unavailable transform set. $2: Source address. $3: Destination address. |
Severity level |
6 |
Example |
IPSEC/6/IPSEC_SA_ESTABLISH_FAIL: Failed to establish IPsec SA for the reason of creating tunnel failure. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
Explanation |
Failed to establish the IPsec SA. Possible reasons include creating tunnel failure, incomplete configuration, and unavailable transform set. |
Verify the IPsec configurations on the local and remote devices. |
IPSEC_SA_INITINATION
Message text |
Began to establish IPsec SA. The SA's source address is [STRING], and its destination address is [STRING]. |
Variable fields |
$1: Source address. $2: Destination address. |
Severity level |
6 |
Example |
IPSEC/6/IPSEC_SA_INITINATION: Began to establish IPsec SA. The SA's source address is 1.1.1.1, and its destination address is 2.2.2.2. |
Explanation |
An IPsec SA is to be established. |
IPSEC_SA_TERMINATE
Message text |
The IPsec SA was deleted for the reason of [STRING]. The SA's source address is [STRING], destination address is [STRING], protocol is [STRING], and SPI is [UINT32]. |
Variable fields |
$1: Reason for the IPsec SA removal: · SA idle timeout. · reset command executed. $2: Source address. $3: Destination address. $4: Security protocol. $5: SPI. |
Severity level |
6 |
Example |
IPSEC/6/IPSEC_SA_TERMINATE: The IPsec SA was deleted for the reason of SA idle timeout. The SA’s source address is 1.1.1.1, destination address is 2.2.2.2, protocol is ESP, and SPI is 34563. |
Explanation |
An IPsec SA is deleted. Possible reasons include SA idle timeout and using the reset command. |
IPSG messages
This section contains IPSG messages.
IPSG_ADDENTRY_ERROR
Message text |
Failed to add an IP source guard binding (IP [STRING], MAC [STRING], and VLAN [UINT16]) on interface [STRING]. [STRING]. |
Variable fields |
$1: IPv4 address or IPv6 address. If you do not specify an IP address, this field displays N/A. $2: MAC address. If you do not specify a MAC address, this field displays N/A. $3: VLAN ID. If you do not specify a VLAN, this field displays 65535. $4: Interface name. If you do not specify an interface, this field displays N/A. $5: Failure reasons. Available options include: ¡ Feature not supported. ¡ Resources not sufficient. ¡ Maximum number of IPv4 binding entries already reached. ¡ Maximum number of IPv6 binding entries already reached. ¡ Unknown error. |
Severity level |
6 |
Example |
IPSG/6/IPSG_ADDENTRY_ERROR: Failed to add an IP source guard binding (IP 1.1.1.1, MAC 0001-0001-0001, and VLAN 1) on interface Vlan-interface1. Resources not sufficient. |
Explanation |
IPSG failed to issue a static or dynamic IPSG binding. The message is sent in any of the following situations: · The IPSG feature is not supported. · The hardware resources are not sufficient for the operation. · The maximum number of IPv4SG or IPv6SG bindings is already reached. · An unknown error occurs. |
To resolve the problem, you can perform the following tasks: · Clear the memory to release hardware resources when the failure is caused by insufficient hardware resources. · Add the IPSG binding again if you are adding a static binding. · Contact H3C Support if the failure is caused by an unknown error. |
IPSG_ADDEXCLUDEDVLAN_ERROR
Message text |
Failed to add excluded VLANs (start VLAN [UINT16] to end VLAN [UINT16]). [STRING]. |
Variable fields |
$1: Start VLAN ID of the VLAN range that has been configured to be excluded from IPSG filtering. $2: End VLAN ID of the VLAN range that has been configured to be excluded from IPSG filtering. $3: Failure reasons. Available options include: · Feature not supported. · Resources not sufficient. · Unknown error. |
Severity level |
6 |
Example |
IPSG/6/IPSG_ADDEXCLUDEDVLAN_ERROR: -MDC=1-Slot=4; Failed to add excluded VLANs (start VLAN 1 to end VLAN 5). Resources not sufficient. |
Explanation |
IPSG failed to issue the specified excluded VLANs. The message is sent in any of the following situations: · Excluded VLANs are not supported. · The hardware resources are not sufficient for the operation. · An unknown error occurs. |
To resolve the problem, you can perform the following tasks: · Clear the memory to release hardware resources when the failure is caused by insufficient hardware resources. Then configure the excluded VLANs again. · Contact H3C Support if the failure is caused by an unknown error. |
IPSG_ARP_LOCALMAC_CONFLICT
Message text |
MAC conflict exists between an ARP entry and a local entry: IP=[STRING], VPN=[STRING], ARPMAC=[STRING], LocalMAC=[STRING]. |
Variable fields |
$1: IP address. $2: VPN instance name. $3: MAC address in the ARP entry. $4: MAC address in the local IPSG binding. |
Severity level |
5 |
Example |
IPSG/5/IPSG_ARP_LOCALMAC_CONFLICT: MAC conflict exists between an ARP entry and a local entry: IP=1.1.1.1, VPN=1, ARPMAC=0008-0008-0008, LocalMAC=0008-0008-0009. |
Explanation |
This message is sent when an ARP entry and a local IPSG binding have the same IP address but different MAC addresses. |
Check the host for which the device learns the ARP entry to determine whether it is an attacker. |
IPSG_ARP_REMOTEMAC_CONFLICT
Message text |
MAC conflict exists between an ARP entry and a remote entry: IP=[STRING], VPN=[STRING], ARPMAC=[STRING], RemoteMAC=[STRING]. |
Variable fields |
$1: IP address. $2: VPN instance name. $3: MAC address in the ARP entry. $4: MAC address in the remote IPSG binding. |
Severity level |
5 |
Example |
IPSG/5/IPSG_ARP_REMOTEMAC_CONFLICT: MAC conflict exists between an ARP entry and a remote entry: IP=1.1.1.1, VPN=1, ARPMAC=0008-0008-0008, RemoteMAC=0008-0008-0009. |
Explanation |
This message is sent when an ARP entry and a remote IPSG binding have the same IP address but different MAC addresses. Such a MAC address conflict occurs under one of the following situations: · An ARP attacker exists in the network. · A user uses the same IP address but a different MAC address when roaming from a remote device to the local device. |
Verify the reason that such a MAC address conflict occurs. · If it is caused by user roaming, no action is required. · If it is not caused by user roaming, check the host for which the device learns the ARP entry to determine whether it is an attacker. |
IPSG_DELENTRY_ERROR
Message text |
Failed to delete an IP source guard binding (IP [STRING], MAC [STRING], and VLAN [UINT16]) on interface [STRING]. [STRING]. |
Variable fields |
$1: IP address. If you do not specify an IP address, this field displays N/A. $2: MAC address. If you do not specify a MAC address, this field displays N/A. $3: VLAN ID. If you do not specify a VLAN, this field displays 65535. $4: Interface name. If you do not specify an interface, this field displays N/A. $5: Failure reason. Available options include: · Feature not supported. · Unknown error. |
Severity level |
6 |
Example |
IPSG/6/IPSG_DELENTRY_ERROR: Failed to delete an IP source guard binding (IP 1.1.1.1, MAC 0001-0001-0001, and VLAN 1) on interface Vlan-interface1. Unknown error. |
Explanation |
IPSG failed to delete a global static IPSG binding. The message is sent in any of the following situations: · The IPSG feature is not supported. · An unknown error occurs. |
To resolve the problem, you can perform the following tasks: · Delete the global static IPSG binding again. · Contact H3C Support if the failure is caused by an unknown error. |
IPSG_DELEXCLUDEDVLAN_ERROR
Message text |
Failed to delete excluded VLANs (start VLAN [UINT16] to end VLAN [UINT16]). [STRING]. |
Variable fields |
Severity level |
6 |
Example |
IPSG/6/IPSG_DELEXCLUDEDVLAN_ERROR: -MDC=1-Slot=4; Failed to delete excluded VLANs (start VLAN 1 to end VLAN 5). Resources not sufficient. |
Explanation |
IPSG failed to delete the specified excluded VLANs. The message is sent in any of the following situations: · Excluded VLANs are not supported. · The hardware resources are not sufficient for the operation. · An unknown error occurs. |
To resolve the problem, you can perform the following tasks: · Clear the memory to release hardware resources when the failure is caused by insufficient hardware resources. Then delete the excluded VLANs again. · Contact H3C Support if the failure is caused by an unknown error. |
IPSG_MAC_CONFLICT
Message text |
MAC conflict exists between a local entry and a remote entry: IP=[STRING], VPN=[STRING], LocalMAC=[STRING], RemoteMAC=[STRING]. |
Variable fields |
$1: IP address. $2: VPN instance name. $3: MAC address in the local IPSG binding. $4: MAC address in the remote IPSG binding. |
Severity level |
5 |
Example |
IPSG/5/IPSG_MAC_CONFLICT: MAC conflict exists between a local entry and a remote entry: IP=1.1.1.1, VPN=1, LocalMAC=0008-0008-0008, RemoteMAC=0008-0008-0009. |
Explanation |
This message is sent when a local IPSG binding and a remote IPSG binding have the same IP address but different MAC addresses. |
IPSG_ND_LOCALMAC_CONFLICT
Message text |
MAC conflict exists between an ND entry and a local entry: IPv6=[STRING], VPN=[STRING], NDMAC=[STRING], LocalMAC=[STRING]. |
Variable fields |
$1: IP address. $2: VPN instance name. $3: MAC address in the ND entry. $4: MAC address in the local IPSG binding. |
Severity level |
5 |
Example |
IPSG/5/IPSG_ND_LOCALMAC_CONFLICT: MAC conflict exists between an ND entry and a local entry: IPv6=1::1, VPN=1, NDMAC=0008-0008-0008, LocalMAC=0008-0008-0009. |
Explanation |
This message is sent when an ND entry and a local IPSG binding have the same IP address but different MAC addresses. |
Check the host for which the device learns the ND entry to determine whether it is an attacker. |
IPSG_ND_REMOTEMAC_CONFLICT
Message text |
MAC conflict exists between an ND entry and a remote entry: IPv6=[STRING], VPN=[STRING], NDMAC=[STRING], RemoteMAC=[STRING]. |
Variable fields |
$1: IP address. $2: VPN instance name. $3: MAC address in the ND entry. $4: MAC address in the remote IPSG binding. |
Severity level |
5 |
Example |
IPSG/5/IPSG_ND_REMOTEMAC_CONFLICT: MAC conflict exists between an ND entry and a remote entry: IPv6=1::1, VPN=1, NDMAC=0008-0008-0008, RemoteMAC=0008-0008-0009. |
Explanation |
This message is sent when an ND entry and a remote IPSG binding have the same IP address but different MAC addresses. Such a MAC address conflict occurs under one of the following situations: · An ARP attacker exists in the network. · A user uses the same IP address but a different MAC address when roaming from a remote device to the local device. |
Verify the reason that such a MAC address conflict occurs. · If it is caused by user roaming, no action is required. · If it is not caused by user roaming, check the host for which the device learns the ND entry to determine whether it is an attacker. |
IPSG_IPV4_ALARMCLEAR
Message text |
The packet dropping rate on [STRING] dropped below [UINT32] pps. |
Variable fields |
$1: Interface name. $2: IPv4SG alarm threshold. |
Severity level |
4 |
Example |
IPSG/4/IPSG_IPV4_ALARMCLEAR: The packet dropping rate on GigabitEthernet1/0/1 dropped below 100 pps. |
Explanation |
This message is sent when the packet dropping rate on an interface dropps below the IPSG alarm threshold. |
IPSG_IPV4_ALARMEMERGE
Message text |
The packet dropping rate on [STRING] reached or exceeded [UINT32] pps. |
Variable fields |
Severity level |
4 |
Example |
IPSG/4/IPSG_IPV4_ALARMEMERGE: The packet dropping rate on GigabitEthernet1/0/1 reached or exceeded 100 pps. |
Explanation |
This message is sent when the packet dropping rate on an interface exceeds or reaches the IPv4SG alarm threshold. |
Verify that no attack sources are connected to the interface. |
IPSG_IPV6_ALARMCLEAR
Message text |
Variable fields |
$1: Interface name. $2: IPv6SG alarm threshold. |
Severity level |
4 |
Example |
IPSG/4/IPSG_IPV6_ALARMCLEAR: The packet dropping rate on GigabitEthernet1/0/1 dropped below 100 pps. |
Explanation |
This message is sent when the packet dropping rate on an interface dropps below the IPv6SG alarm threshold. |
IPSG_IPV6_ALARMEMERGE
Message text |
Variable fields |
Severity level |
4 |
Example |
IPSG/4/IPSG_IPV6_ALARMEMERGE: The packet dropping rate on GigabitEthernet1/0/1 reached or exceeded 100 pps. |
Explanation |
This message is sent when the packet dropping rate on an interface exceeds or reaches the IPv6SG alarm threshold. |
IRDP messages
This section contains IRDP messages.
IRDP_EXCEED_ADVADDR_LIMIT
Message text |
The number of advertisement addresses on interface [STRING] exceeded the limit 255. |
Variable fields |
$1: Interface name. |
Severity level |
6 |
Example |
IRDP/6/IRDP_EXCEED_ADVADDR_LIMIT: The number of advertisement addresses on interface Ethernet1/1/0/2 exceeded the limit 255. |
Explanation |
The number of addresses to be advertised on an interface exceeds the upper limit. |
Remove unused addresses on the interface. |
IRF
This section contains IRF messages.
IRF_LINK_BLOCK
Message text |
IRF port went blocked. |
Variable fields |
N/A |
Severity level |
2 |
Example |
IRF/2/IRF_LINK_BLOCK: IRF port went blocked. |
Explanation |
The IRF port was blocked. A blocked IRF port cannot send and receive service packets, but it can send and receive IRF protocol packets. For example, this message appears on the member device that has the lower priority when an IRF member ID conflict is detected for member devices. |
Check the IRF member ID on each member device for any conflict, and change the IRF member IDs of member devices to be unique. |
IRF_LINK_DOWN
Message text |
IRF port went down. |
Variable fields |
N/A |
Severity level |
3 |
Example |
IRF/3/IRF_LINK_DOWN: IRF port went down. |
Explanation |
The IRF port went down. |
Verify the following items: · Network interfaces have been bound to the IRF port. · The IRF network interfaces and the peer interfaces have Layer 2 connectivity. |
IRF_LINK_UP
Message text |
IRF port came up. |
Variable fields |
N/A |
Severity level |
6 |
Example |
IRF/6/IRF_LINK_UP: IRF port came up. |
Explanation |
The IRF port came up. |
IRF_MEMBERID_CONFLICT
Message text |
IRF member ID conflict occurred. The ID [UINT32] has been used for another device with CPU-Mac: [STRING]. |
Variable fields |
$1: IRF member ID of the device. $2: CPU MAC address of the device. |
Severity level |
4 |
Example |
IRF/4/IRF_MEMBERID_CONFLICT:-slot = 5; IRF member ID conflict occurred, The ID 5 has been used for another device with CPU-Mac: 000c-29d7-c1ae. |
Explanation |
This message appears when the device detects that it has the same IRF member ID as another device in the same broadcast domain. |
Check the IRF member IDs and change the IRF member ID of a device. Make sure the member devices use unique member IDs. |
IRF_MERGE
Message text |
IRF merge occurred. |
Variable fields |
N/A |
Severity level |
4 |
Example |
IRF/4/IRF_MERGE: IRF merge occurred. |
Explanation |
IRF_MERGE_NEED_REBOOT
Message text |
IRF merge occurred. This IRF system needs a reboot. |
Variable fields |
N/A |
Severity level |
4 |
Example |
IRF/4/IRF_MERGE_NEED_REBOOT: IRF merge occurred. This IRF system needs a reboot. |
Explanation |
IRF merge occurred. This IRF fabric needs a reboot to complete the IRF merge because the master of this IRF fabric failed the master election for IRF merge. |
Reboot the IRF fabric to complete the IRF merge. |
IRF_MERGE_NOT_NEED_REBOOT
Message text |
IRF merge occurred. This IRF system does not need to reboot. |
Variable fields |
N/A |
Severity level |
5 |
Example |
IRF/5/IRF_MERGE_NOT_NEED_REBOOT: IRF merge occurred. This IRF system does not need to reboot. |
Explanation |
IRF merge occurred. This IRF fabric does not need to reboot because the master of this IRF fabric won the master election for IRF merge. |
ISIS messages
This section contains IS-IS messages.
ISIS_LSP_CONFLICT
Message text |
IS-IS [UINT16], [STRING] LSP, LSPID=[STRING], SeqNum=[HEX], system ID conflict might exist. |
Variable fields |
$1: IS-IS process ID. $2: IS type. The IS type can be Level-1 or Level-2. $3: LSP ID. $4: LSP sequence number. |
Severity level |
5 |
Example |
ISIS/5/ISIS_LSP_CONFLICT: -MDC=1; IS-IS 1, Level-1 LSP, LSPID=1111.1111.1111.00-00, SeqNum=0x000045bf, system ID conflict might exist. |
Explanation |
System ID conflict might exist. |
Check whether the system ID of the device that generates the LSP conflicts with the system ID of another device. |
ISIS_MEM_ALERT
Message text |
ISIS Process received system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alarm. |
Severity level |
5 |
Example |
ISIS/5/ISIS_MEM_ALERT: ISIS Process received system memory alert start event. |
Explanation |
IS-IS received a memory alarm. |
Check the system memory and release memory for the modules that occupy too many memory resources. |
ISIS_NBR_CHG
Message text |
IS-IS [UINT16], [STRING] adjacency [STRING] ([STRING]), state changed to [STRING], Reason: [STRING]. |
Variable fields |
$1: IS-IS process ID. $2: Neighbor level. $3: Neighbor ID. $4: Interface name. $5: Current neighbor state. $6: Reason of neighbor state change. |
Severity level |
5 |
Example |
ISIS/5/ISIS_NBR_CHG: IS-IS 1, Level-1 adjacency 0000.0000.0001 (GigabitEthernet1/0/1), state changed to DOWN, Reason: circuit data clean. |
Explanation |
The IS-IS neighbor state changed. |
When the neighbor state changes to down, check for IS-IS configuration errors and loss of network connectivity. |
ISSU messages
This section contains ISSU messages.
ISSU_LOAD_FAILED
Message text |
Failed to execute the issu load command. |
Variable fields |
N/A |
Severity level |
5 |
Example |
ISSU/5/ISSU_LOAD_FAILED: -IPAddr=192.168.79.1-User=**; Failed to execute the issu load command. |
Explanation |
A user executed the issu load command, but the operation failed. |
Take actions as prompted. |
ISSU_LOAD_SUCCESS
Message text |
Executed the issu load command successfully. |
Variable fields |
N/A |
Severity level |
5 |
Example |
ISSU/5/ISSU_LOAD_SUCCESS: -IPAddr=192.168.79.1-User=**; Executed the issu load command successfully. |
Explanation |
A user executed the issu load command successfully. |
ISSU_PROCESSWITCHOVER
Message text |
Switchover completed. The standby process became the active process. |
Variable fields |
N/A |
Severity level |
5 |
Example |
ISSU/5/ISSU_PROCESSWITCHOVER: Switchover completed. The standby process became the active process. |
Explanation |
A user executed the issu run switchover command. |
ISSU_ROLLBACKCHECKNORMAL
Message text |
The rollback might not be able to restore the previous version for [STRING] because the status is not normal. |
Variable fields |
Severity level |
4 |
Example |
ISSU/4/ISSU_ROLLBACKCHECKNORMAL: The rollback might not be able to restore the previous version for chassis 1 slot 2 because the state is not normal. |
Explanation |
While an ISSU was in Switching state, a user executed the issu rollback command or the ISSU automatic-rollback timer expired. However, the status of the MPU was not Normal. |
L2PT messages
This section contains L2PT messages.
L2PT_SET_MULTIMAC_FAILED
Message text |
Variable fields |
$1: MAC address. |
Severity level |
4 |
Example |
L2PT/4/L2PT_SET_MULTIMAC_FAILED: Failed to set a tunnel destination MAC address to 010f-e200-0003. |
Explanation |
Failed to specify the destination multicast MAC address for tunneled packets. |
L2PT_CREATE_TUNNELGROUP_FAILED
Message text |
Variable fields |
$1: Protocol name. |
Severity level |
4 |
Example |
L2PT/4/L2PT_CREATE_TUNNELGROUP_FAILED: Failed to create a VLAN tunnel group for STP. |
Explanation |
Failed to create a VLAN tunnel group for a protocol. |
L2PT_ADD_GROUPMEMBER_FAILED
Message text |
Failed to add [STRING] as a member to the VLAN tunnel group for [STRING]. |
Variable fields |
$1: Interface name. $2: Protocol name. |
Severity level |
4 |
Example |
Explanation |
Failed to add an interface to a VLAN tunnel group for a protocol. |
L2PT_ENABLE_DROP_FAILED
Message text |
Variable fields |
$1: Protocol name. $2: Interface name. |
Severity level |
4 |
Example |
L2PT/4/L2PT_ENABLE_DROP_FAILED: Failed to enable STP packet drop on GigabitEthernet2/0/1. |
Explanation |
Failed to enable L2PT drop for a protocol on an interface. |
L2TPv2 messages
This section contains L2TPv2 messages.
L2TPV2_TUNNEL_EXCEED_LIMIT
Message text |
Variable fields |
N/A |
Severity level |
4 |
Example |
L2TPV2/4/L2TPV2_TUNNEL_EXCEED_LIMIT: Number of L2TP tunnels exceeded the limit. |
Explanation |
The number of established L2TP tunnels has reached the limit. |
242. Perform one of the following tasks: ¡ Execute the reset l2tp tunnel command to disconnect an idle tunnel. ¡ Wait for the device to automatically disconnect an idle tunnel after the hello interval elapses. 243. If the problem persists, contact H3C Support. |
L2TPV2_SESSION_EXCEED_LIMIT
Message text |
Variable fields |
N/A |
Severity level |
4 |
Example |
L2TPV2/4/L2TPV2_SESSION_EXCEED_LIMIT: Number of L2TP sessions exceeded the limit. |
Explanation |
The number of established L2TP sessions has reached the limit. |
L2VPN messages
This section contains L2VPN messages.
L2VPN_ARP_MOBILITY_SUPPRESS (public instance)
Message text |
ARP (IP [STRING], MAC [STRING]) was suppressed in the public instance due to frequent ARP mobility events. |
Variable fields |
$1: IP address. $2: MAC address. |
Severity level |
4 |
Example |
L2VPN/4/L2VPN_ARP_MOBILITY_SUPPRESS: ARP (IP 10.1.1.1, MAC 0001-0001-0001) was suppressed in the public instance due to frequent ARP mobility events. |
Explanation |
The IP address in the public instance moved too frequently, so the distributed EVPN gateways suppressed the excess ARP mobility events. |
Verify that IP addresses in the public instance do not conflict with one another. |
L2VPN_ARP_MOBILITY_SUPPRESS (VPN instance)
Message text |
ARP (IP [STRING], MAC [STRING]) was suppressed in VPN instance [STRING] due to frequent ARP mobility events. |
Variable fields |
$1: IP address. $2: MAC address. $3: VPN instance name. |
Severity level |
4 |
Example |
L2VPN/4/L2VPN_ARP_MOBILITY_SUPPRESS: ARP (IP 10.1.1.1, MAC 0001-0001-0001) was suppressed in VPN instance vpna due to frequent ARP mobility events. |
Explanation |
The IP address in the VPN instance moved too frequently, so the distributed EVPN gateways suppressed the excess ARP mobility events. |
Verify that IP addresses in the VPN instance do not conflict with one another. |
L2VPN_ARP_MOBILITY_UNSUPPRESS (public instance)
Message text |
ARP (IP [STRING], MAC [STRING]) was unsuppressed in the public instance. |
Variable fields |
Severity level |
4 |
Example |
L2VPN/4/L2VPN_ARP_MOBILITY_UNSUPPRESS: ARP (IP 10.1.1.1, MAC 0001-0001-0001) was unsuppressed in the public instance. |
Explanation |
ARP mobility event suppression was disabled by using the undo evpn route arp-mobility suppress command, and the device would advertise ARP information for the IP address in the public instance. |
L2VPN_ARP_MOBILITY_UNSUPPRESS (VPN instance)
Message text |
ARP (IP [STRING], MAC [STRING]) was unsuppressed in VPN instance [STRING]. |
Variable fields |
Severity level |
4 |
Example |
L2VPN/4/L2VPN_ARP_MOBILITY_UNSUPPRESS: ARP (IP 10.1.1.1, MAC 0001-0001-0001) was unsuppressed in VPN instance vpna. |
Explanation |
The IP address in the VPN instance was unsuppressed by using the undo evpn route arp-mobility suppress command, and distributed EVPN gateways can advertise ARP information for the IP address. |
L2VPN_MAC_MOBILITY_SUPPRESS
Message text |
MAC address [STRING] was suppressed in VSI [STRING] due to frequent MAC mobility events. |
Variable fields |
$1: MAC address. $2: VSI name. |
Severity level |
4 |
Example |
L2VPN/4/L2VPN_MAC_MOBILITY_SUPPRESS: MAC address 0001-0001-0001 was suppressed in VSI vpna due to frequent MAC mobility events. |
Explanation |
The MAC address moved too frequently, so the device suppressed the excess MAC mobility events. |
Verify that MAC addresses in the network do not conflict with one another. |
L2VPN_MAC_MOBILITY_UNSUPPRESS
Message text |
MAC address [STRING] was unsuppressed in VSI [STRING]. |
Variable fields |
Severity level |
4 |
Example |
L2VPN/4/L2VPN_MAC_MOBILITY_UNSUPPRESS: MAC address 0001-0001-0001 was unsuppressed in VSI vpna. |
Explanation |
MAC mobility event suppression was disabled by using the undo evpn route mac-mobility suppress command, and the device would advertise the MAC address. |
L2VPN_BGPVC_CONFLICT_LOCAL
Message text |
Remote site ID [INT32] (From [STRING], route distinguisher [STRING]) conflicts with local site. |
Variable fields |
$1: ID of a remote site. $2: IP address of the remote site. $3: Route distinguisher of the remote site. |
Severity level |
5 |
Example |
L2VPN/5/L2VPN_BGPVC_CONFLICT_LOCAL: Remote site ID 1 (From 1.1.1.1, route distinguisher 1:1) conflicts with local site. |
Explanation |
A remote site ID conflicted with the local site ID. This message is generated when one of the following situations occurs: · The received remote site ID is the same as the local site ID. · The local site ID is configured the same as a received remote site ID. |
Modify the site ID configuration on the local device or remote device. Or, configure the remote site ID in a different VPLS instance than the local site ID. |
L2VPN_BGPVC_CONFLICT_REMOTE
Message text |
Remote site ID [INT32] (From [STRING], route distinguisher [STRING]) conflicts with another remote site. |
Variable fields |
Severity level |
5 |
Example |
L2VPN/5/L2VPN_BGPVC_CONFLICT_REMOTE: Remote site ID 1 (From 1.1.1.1, route distinguisher 1:1) conflicts with another remote site. |
Explanation |
Two remote site IDs conflicted. This message is generated when the received remote site ID is the same as another received remote site ID. |
Modify the site ID configuration on one remote device. Or, configure the two remote site IDs in different VPLS instances. |
L2VPN_HARD_RESOURCE_NOENOUGH
Message text |
No enough hardware resource for L2VPN. |
Variable fields |
N/A |
Severity level |
4 |
Example |
L2VPN/4/L2VPN_HARD_RESOURCE_NOENOUGH: No enough hardware resource for L2VPN. |
Explanation |
Hardware resources for L2VPN were insufficient. |
Check whether unnecessary VSIs, PWs, or ACs had been generated. If yes, delete them. |
L2VPN_HARD_RESOURCE_RESTORE
Message text |
Hardware resources for L2VPN are restored. |
Variable fields |
N/A |
Severity level |
6 |
Example |
L2VPN/6/L2VPN_HARD_RESOURCE_RESTORE: Hardware resources for L2VPN are restored. |
Explanation |
Hardware resources for L2VPN were restored. |
L2VPN_LABEL_DUPLICATE
Message text |
Incoming label [INT32] for a static PW in [STRING] [STRING] is duplicate. |
Variable fields |
$1: Incoming label value. $2: Type of L2VPN, Xconnect-group or VSI. $3: Name of the Xconnect-group or VSI. |
Severity level |
4 |
Example |
L2VPN/4/L2VPN_LABEL_DUPLICATE: Incoming label 1024 for a static PW in Xconnect-group aaa is duplicate. |
Explanation |
The incoming label of a static PW in this Xconnect-group or VSI was occupied by another configuration, for example, by a static LSP or by a static CRLSP. This message is generated when one of the following events occurs: · When MPLS is enabled, configure a static PW with an incoming label which is occupied by another configuration. · Enable MPLS when a static PW whose incoming label is occupied by another configuration already exists. |
Remove this static PW, and reconfigure it with another incoming label. |
L2VPN_MLAG_AC_CONFLICT
Message text |
The dynamic AC created for Ethernet service instance [INT32] on interface [STRING] causes a conflict. |
Variable fields |
$1: Ethernet service instance ID. $2: Interface on which the Ethernet service instance is created. |
Severity level |
4 |
Example |
L2VPN/4/L2VPN_MLAG_AC_CONFLICT: The dynamic AC created for Ethernet service instance 10 on interface Bridge-Aggregation 5 causes a conflict. |
Explanation |
On an EVPN distributed relay system, the dynamic ACs created for different static ACs conflict when the IPL is changed from a tunnel to an aggregate link. |
Delete and then reconfigure the corresponding static ACs. Make sure the match criterion specified for different ACs do not overlap. |
LAGG messages
This section contains link aggregation messages.
LAGG_ACTIVE
Message text |
Member port [STRING] of aggregation group [STRING] changed to the active state. |
Variable fields |
$1: Port name. $2: Link aggregation group type and ID. |
Severity level |
6 |
Example |
LAGG/6/LAGG_ACTIVE: Member port FGE1/0/50 of aggregation group BAGG1 changed to the active state. |
Explanation |
A member port in an aggregation group changed to the Selected state. |
LAGG_AUTO_AGGREGATION
Message text |
Failed to assign automatic assignment-enabled interface [STRING] to an aggregation group. Please check the configuration on the interface. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
LAGG/6/LAGG_AUTO_AGGREGATON: Failed to assign automatic assignment-enabled interface FGE1/0/1 to an aggregation group. Please check the configuration on the interface. |
Explanation |
A port failed to join an automatically created aggregation group for one of the following reasons: · The attribute configuration of the port is inconsistent with that of the aggregate interface. · Some settings on the port prevent it from joining the aggregation group. |
To resolve this issue: · Modify the attribute configuration of the port to be consistent with the aggregate interface. · Remove the settings that affect automatic member port assignment from the port. |
LAGG_INACTIVE_AICFG
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the port and the aggregate interface had different attribute configurations. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_AICFG: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the port and the aggregate interface had different attribute configurations. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the member port and the aggregate interface had different attribute configurations. |
Modify the attribute configuration of the member port to be the same as the attribute configuration of the aggregate interface. |
LAGG_INACTIVE_BFD
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the BFD session state of the port was down. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_BFD: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the BFD session state of the port is down. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the BFD session on the port went down. |
To resolve this issue: · Check for a link failure. · Modify the port settings to make sure it has the same operational key and attribute configuration as the reference port. |
LAGG_INACTIVE_CONFIGURATION
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the link aggregation configuration of the port was incorrect. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_CONFIGURATION: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the link aggregation configuration of the port was incorrect. |
Explanation |
A member port in an aggregation group changed to the Unselected state because some configuration on the member port cannot be issued to the driver. |
Check the port configuration for software and hardware incompatibilities or errors. |
LAGG_INACTIVE_DUPLEX
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the duplex mode of the port was different from that of the reference port. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_DUPLEX: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the duplex mode of the port was different from that of the reference port. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the duplex mode was different between the member port and the reference port. |
Change the duplex mode of the member port to be the same as the reference port. |
LAGG_INACTIVE_HARDWAREVALUE
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because of the port's hardware restriction prevented it from being Selected. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_HARDWAREVALUE: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because of the port's hardware restriction prevented it from being Selected. |
Explanation |
A member port in an aggregation group changed to the Unselected state because of the port's hardware restriction. |
Remove the port from the aggregation group. |
LAGG_INACTIVE_IFCFG_DEFAULT
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because no LACPDU was received by the reference port. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_IFCFG_DEFAULT: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because no LACPDU was received by the reference port. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the port had not received LACPDUs from its peer port. |
Verify whether the peer end has sent LACPDUs. |
LAGG_INACTIVE_IFCFG_LOOPPORT
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the reference port received its own LACPDUs. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_IFCFG_LOOPPORT: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the reference port received its own LACPDUs. |
Explanation |
The reference port in an aggregation group changed to the Unselected state because it received the LACPDUs sent out of itself. |
Check the device for a loop condition. |
LAGG_INACTIVE_IFCFG_NONAGG
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the link of the port was not aggregatable. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_IFCFG_NONAGG: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the link of the port was not aggregatable. |
Explanation |
A member port in an aggregation group changed to the Unselected state because its link was not aggregatable. |
Reconfigure the port to be compliant with the aggregation requirements. |
LAGG_INACTIVE_KEY_INVALID
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the port's operational key was invalid. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_KEY_INVALID: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the port's operational key was invalid. |
Explanation |
A member port in an aggregation group changed to the Unselected state because its operational key was invalid. This message typically occurs when the operational key of the reference port is invalid. |
Modify the settings for the parameters (for example, port speed and duplex settings) used to calculate the operational key on the reference port. Make sure the member port is reconfigured with the same settings for those parameters as the reference port. |
LAGG_INACTIVE_LOWER_LIMIT
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the number of Selected ports was below the lower limit. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_LOWER_LIMIT: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the number of Selected ports was below the lower limit. |
Explanation |
A member port in an aggregation group was placed in Unselected state because the required minimum number of Selected ports was not reached. |
Make sure the minimum number of Selected ports is met. |
LAGG_INACTIVE_NODEREMOVE
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the card that hosts the port was absent. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_NODEREMOVE: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the card that hosts the port was absent. |
Explanation |
A member port in an aggregation group changed to the Unselected state on removal of the card that contains the port. |
To bring up the port, re-insert its card. |
LAGG_INACTIVE_OPERSTATE
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the peer port did not have the Synchronization flag. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_OPERSTATE: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the peer port did not have the Synchronization flag. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the LACPDUs received from the peer port did not contain the Synchronization flag. |
Examine the LACPDUs received from the peer port. |
LAGG_INACTIVE_PARTNER
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the link aggregation configuration of its peer port was incorrect. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_PARTNER: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the link aggregation configuration of its peer port was incorrect. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the port's partner changed to the Unselected state. |
LAGG_INACTIVE_PARTNER_KEY_WRONG
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the operational key of the peer port was different from that of the reference port. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_PARTNER_KEY_WRONG: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the operational key of the peer port was different from that of the reference port. |
Explanation |
A member port in an aggregation group changed to the Unselected state because its peer port had a different operational key than the reference port. |
Reconfigure the peer port to use the same settings as the reference port for the parameters used to calculate the operational key. These parameters include port speed and duplex settings. |
LAGG_INACTIVE_PARTNER_MAC_WRONG
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the system MAC address of the peer port was different from that of the peer port for the reference port. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_PARTNER_MAC_WRONG: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the system MAC address of the peer port was different from that of the peer port for the reference port. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the system MAC address of its peer port was different from that of the reference port. |
Make sure the peer aggregation systems use the same LACP system MAC address. |
LAGG_INACTIVE_PARTNER_NONAGG
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the link of the peer port was not aggregatable. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_PARTNER_NONAGG: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the link of the peer port was not aggregatable. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the link of its peer port was not aggregatable. |
LAGG_INACTIVE_PARTNER_RDIRHANDLE
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because link-aggregation traffic redirection was triggered on the peer port. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_PARTNER_RDIRHANDLE: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because link-aggregation traffic redirection was triggered on the peer port. |
Explanation |
A member port in an aggregation group changed to the Unselected state because link-aggregation traffic redirection was triggered on its peer port. |
Reconfigure the peer port of the aggregation member port. |
LAGG_INACTIVE_PHYSTATE
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the physical or line protocol state of the port was down. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the physical or line protocol state of the port was down. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the port went down. |
Check the member port for physical or link layer issues. |
LAGG_INACTIVE_PORT_DEFAULT
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the port had not received LACPDUs. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_PORT_DEFAULT: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the port had not received LACPDUs. |
Explanation |
A member port in an aggregation group changed to the Unselected state because it had not received LACPDUs. |
Verify whether the peer port of the aggregation member port can correctly send LACPDUs. |
LAGG_INACTIVE_RDIRHANDLE
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because link-aggregation traffic redirection was triggered on the local port. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_RDIRHANDLE: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because link-aggregation traffic redirection was triggered on the local port. |
Explanation |
A member port in an aggregation group changed to the Unselected state because link-aggregation traffic redirection was triggered on it. |
LAGG_INACTIVE_REDUNDANCY
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the port was in secondary state in a redundancy group. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_ REDUNDANCY: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the port was in secondary state in a redundancy group. |
Explanation |
A member port in an aggregation group changed to the Unselected state because it was in secondary state in a redundancy group. |
Check the upstream interface for a link failure. |
LAGG_INACTIVE_RESOURCE_INSUFICIE
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because hardware resources were not enough. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_RESOURCE_INSUFICIE: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because hardware resources were not enough. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the aggregation resources were insufficient. |
LAGG_INACTIVE_SPEED
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the speed configuration of the port was different from that of the reference port. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_SPEED: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the speed configuration of the port was different from that of the reference port. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the speed was different between the member port and the reference port. |
Change the speed of the member port to be the same as the reference port. |
LAGG_INACTIVE_STANDBY
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the port was in Standby state. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_STANDBY: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the port was in Standby state. |
Explanation |
A member port in an aggregation group changed to the Unselected state because it was placed in Standby state. |
Wait for a while, and then check the aggregation state of the aggregation member port. If it is still in Unselected state, execute the display link-aggregation troubleshooting command to identify the reason and obtain the recommended action. |
LAGG_INACTIVE_UPPER_LIMIT
Message text |
Member port [STRING] of aggregation group [STRING] changed to the inactive state, because the number of Selected ports had reached the upper limit. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_UPPER_LIMIT: Member port FGE1/0/50 of aggregation group BAGG1 changed to the inactive state, because the number of Selected ports had reached the upper limit. |
Explanation |
The number of Selected ports reached the upper limit in a dynamic aggregation group. A member port in the aggregation group changed to the Unselected state because a more eligible port joined the aggregation group. |
LAGG_SELECTPORT_INCONSISTENT
Message text |
The maximum number of Selected ports for [STRING] on PEXs is inconsistent with that on the parent fabric. Please reconfigure this setting. |
Variable fields |
$1: Link aggregation group type and ID. |
Severity level |
4 |
Example |
LAGG/4/LAGG_SELECTPORT_INCONSISTENT: The maximum number of Selected ports for Route-Aggregation1 on PEXs is inconsistent with that on the parent fabric. Please reconfigure this setting. |
Explanation |
The number of Selected ports in an aggregation group on PEXs exceeded the configured maximum number of Selected ports in the aggregation group on the parent fabric. This message is generated when ports join or leave an aggregation group. |
To resolve this issue, use either of the following methods: · Increase the maximum number of Selected ports in the aggregation group on the parent fabric. · Remove some ports from the aggregation group. |
LDP messages
This section contains LDP messages.
LDP_MPLSLSRID_CHG
Message text |
Please reset LDP sessions if you want to make the new MPLS LSR ID take effect. |
Variable fields |
N/A |
Severity level |
5 |
Example |
LDP/5/LDP_MPLSLSRID_CHG: -MDC=1; Please reset LDP sessions if you want to make the new MPLS LSR ID take effect. |
Explanation |
If you configure an LDP LSR ID by using the lsr-id command in LDP view or LDP-VPN instance view, LDP uses the LDP LSR ID. Otherwise, LDP uses the MPLS LSR ID configured by the mpls lsr-id command. This message is sent when the following situations occur: · No LDP LSR ID is configured by using the lsr-id command. · The MPLS LSR ID is modified. |
244. Execute the display mpls ldp parameter command to display the LSR ID. 245. Verify that the LSR ID is the same as the configured MPLS LSR ID. |
LDP_SESSION_CHG
Message text |
Session ([STRING], [STRING]) is [STRING]. |
Variable fields |
$1: Peer's LDP ID. Value 0.0.0.0:0 indicates that the peer's LDP ID cannot be obtained. $2: VPN instance's name. Value public instance indicates that the session belongs to the public network. $3: State of the session, up or down. When the state is down, this field also displays the reason for the down state error. Possible reasons include: · interface not operational. · MPLS disabled on interface. · LDP disabled on interface. · LDP auto-configure disabled on interface. · VPN instance changed on interface. · LDP instance deleted. · targeted peer deleted. · L2VPN disabled targeted peer. · TE tunnel disabled targeted peer. · session protection disabled targeted peer. · process deactivated. · failed to receive the initialization message. · graceful restart reconnect timer expired. · failed to recover adjacency by NSR. · failed to upgrade session by NSR. · closed the GR session. · keepalive hold timer expired. · adjacency hold timer expired. · session reset manually. · TCP connection down. · received a fatal notification message. · internal error. · memory in critical state. · transport address changed on interface. |
Severity level |
5 |
Example |
LDP/5/LDP_SESSION_CHG: Session (22.22.22.2:0, public instance) is up. LDP/5/LDP_SESSION_CHG: Session (22.22.22.2:0, VPN instance: vpn1) is down (hello hold timer expired). |
Explanation |
The session state changed. |
Recommended action |
When the session state is up, no action is required. When the session state is down, check the interface state, link state, and other configurations depending on the reason displayed. |
LDP_SESSION_GR
Message text |
Session ([STRING], [STRING]): ([STRING]). |
Variable fields |
$1: Peer's LDP ID. Value 0.0.0.0:0 indicates that the peer's LDP ID cannot be obtained. $2: VPN instance's name. Value public instance indicates that the session belongs to the public network. $3: State of the session graceful restart: ¡ Start reconnection. ¡ Reconnection failed. ¡ Start recovery. ¡ Recovery completed. |
Severity level |
5 |
Example |
LDP/5/LDP_SESSION_GR: Session (22.22.22.2:0, VPN instance: vpn1): Start reconnection. |
Explanation |
State of the session graceful restart. When a GR-capable LDP session is down, the LDP GR started. This message is generated during the GR of the LDP session, indicating the current GR state. |
Check for the reason of session graceful restart, which can be obtained from the LDP_SESSION_CHG log message. When the graceful restart state Reconnection failed is displayed, verify the interface state, link state, and other configurations according to the reason for the session graceful restart. No action is required for other graceful restart states. |
LDP_SESSION_SP
Message text |
Variable fields |
$1: Peer's LDP ID. Value 0.0.0.0:0 indicates that the peer's LDP ID cannot be obtained. $2: VPN instance's name. Value public instance indicates that the session belongs to the public network. $3: State of the session protection: ¡ Hold up the session. ¡ Session recovered successfully. ¡ Session recovery failed. |
Severity level |
5 |
Example |
LDP/5/LDP_SESSION_SP: Session (22.22.22.2:0, VPN instance: vpn1): Hold up the session. |
Explanation |
When the last link adjacency of the session was lost, session protection started. This message is generated during the session protection process, indicating the current session protection state. |
Verify the interface state and link state. |
LLDP messages
This section contains LLDP messages.
LLDP_CREATE_NEIGHBOR
Message text |
[STRING] agent new neighbor created on port [STRING] (IfIndex [UINT32]), neighbor's chassis ID is [STRING], port ID is [STRING]. |
Variable fields |
$1: Agent type. $2: Port name. $3: Port ifIndex. $4: Neighbor's chassis ID. $5: Neighbor's port ID. |
Severity level |
6 |
Example |
LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent new neighbor created on port Ten-GigabitEthernet10/0/15 (IfIndex 599), neighbor's chassis ID is 3822-d666-ba00, port ID is GigabitEthernet6/0/5. |
Explanation |
The port received an LLDP message from a new neighbor. |
LLDP_DELETE_NEIGHBOR
Message text |
[STRING] agent neighbor deleted on port [STRING] (IfIndex [UINT32]), neighbor's chassis ID is [STRING], port ID is [STRING]. |
Variable fields |
Severity level |
6 |
Example |
LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on port Ten-GigabitEthernet10/0/15 (IfIndex 599), neighbor's chassis ID is 3822-d666-ba00, port ID is GigabitEthernet6/0/5. |
Explanation |
The port received a deletion message when a neighbor was deleted. |
LLDP_LESS_THAN_NEIGHBOR_LIMIT
Message text |
The number of [STRING] agent neighbors maintained by port [STRING] (IfIndex [UINT32]) is less than [UINT32], and new neighbors can be added. |
Variable fields |
$1: Agent type. $2: Port name. $3: Port ifIndex. $4: Maximum number of neighbors a port can maintain. |
Severity level |
6 |
Example |
LLDP/6/LLDP_LESS_THAN_NEIGHBOR_LIMIT: The number of nearest bridge agent neighbors maintained by port Ten-GigabitEthernet10/0/15 (IfIndex 599) is less than 5, and new neighbors can be added. |
Explanation |
New neighbors can be added for the port because the limit has not been reached. |
LLDP_NEIGHBOR_AGE_OUT
Message text |
[STRING] agent neighbor aged out on port [STRING] (IfIndex [UINT32]), neighbor's chassis ID is [STRING], port ID is [STRING]. |
Variable fields |
Severity level |
5 |
Example |
LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on port Ten-GigabitEthernet10/0/15 (IfIndex599), neighbor's chassis ID is 3822-d666-ba00, port ID is GigabitEthernet6/0/5. |
Explanation |
This message is generated when the port failed to receive LLDPDUs from the neighbor within a certain period of time. |
Verify the link status or the receive/transmit status of LLDP on the peer. |
LLDP_NEIGHBOR_PROTECTION_BLOCK
Message text |
The status of port [STRING] changed to blocked ([STRING]) for the [STRING] agent. |
Variable fields |
$1: Interface name. $2: Neighbor protection feature that caused the state change: aging or validation. $3: LLDP agent type. |
Severity level |
4 |
Example |
LLDP/4/LLDP_NEIGHBOR_PROTECTION_BLOCK: -MDC=1; -ifDescr=GigabitEthernet1/0/1; The status of port GigabitEthernet1/0/1 changed to blocked (aging) for the nearest bridge agent. |
Explanation |
The port was blocked because of neighbor aging or neighbor validation failure. |
· If the port is blocked because of neighbor aging, verify the link status or the receive/transmit status of LLDP on both ends. · If the port is blocked because of neighbor validation failure, verify that the following attribute values in the received LLDP packet match those configured on the port: ¡ Chassis ID subtype. ¡ Chassis ID. ¡ Port ID subtype. ¡ Port ID. |
LLDP_NEIGHBOR_PROTECTION_DOWN
Message text |
The status of port [STRING] changed to down (aging) for the [STRING] agent. |
Variable fields |
$1: Interface name. $2: LLDP agent type. |
Severity level |
4 |
Example |
LLDP/4/LLDP_NEIGHBOR_PROTECTION_DOWN: -MDC=1; -ifDescr=GigabitEthernet1/0/1; The status of port GigabitEthernet1/0/1 changed to down (aging) for the nearest bridge agent. |
Explanation |
The port was shut down because of neighbor aging. |
Verify the link status or the receive/transmit status of LLDP on both ends. |
LLDP_NEIGHBOR_PROTECTION_UNBLOCK
Message text |
The status of port [STRING] changed to unblocked for the [STRING] agent. |
Variable fields |
Severity level |
4 |
Example |
LLDP/4/LLDP_NEIGHBOR_PROTECTION_UNBLOCK: -MDC=1; -ifDescr=GigabitEthernet1/0/1; The status of port GigabitEthernet1/0/1 changed to unblocked for the nearest bridge agent. |
Explanation |
The port state changed from blocked to unblocked. |
LLDP_NEIGHBOR_PROTECTION_UP
Message text |
The status of port [STRING] changed to up for the [STRING] agent. |
Variable fields |
Severity level |
4 |
Example |
LLDP/4/LLDP_NEIGHBOR_PROTECTION_UP: -MDC=1; -ifDescr=GigabitEthernet1/0/1; The status of port GigabitEthernet1/0/1 changed to up for the nearest bridge agent. |
Explanation |
The port state changed from DOWN to UP. |
LLDP_PVID_INCONSISTENT
Message text |
PVID mismatch discovered on [STRING] (PVID [UINT32]), with [STRING] [STRING] (PVID [STRING]). |
Variable fields |
Severity level |
Example |
Explanation |
LLDP_REACH_NEIGHBOR_LIMIT
Message text |
The number of [STRING] agent neighbors maintained by the port [STRING] (IfIndex [UINT32]) has reached [UINT32], and no more neighbors can be added. |
Variable fields |
Severity level |
5 |
Example |
LLDP/5/LLDP_REACH_NEIGHBOR_LIMIT: The number of nearest bridge agent neighbors maintained by the port Ten-GigabitEthernet10/0/15 (IfIndex 599) has reached 5, and no more neighbors can be added. |
Explanation |
This message is generated when the port with its maximum number of neighbors reached received an LLDP packet. |
LOAD messages
This section contains load management messages.
BOARD_LOADING
Message text |
Board in chassis [INT32] slot [INT32] is loading software images. |
Variable fields |
$1: Chassis ID. $2: Slot ID. |
Severity level |
4 |
Example |
LOAD/4/BOARD_LOADING: Board in chassis 1 slot 5 is loading software images. |
Explanation |
The card is loading software images during the boot process. |
LOAD_FAILED
Message text |
Board in chassis [INT32] slot [INT32] failed to load software images. |
Variable fields |
Severity level |
3 |
Example |
LOAD/3/LOAD_FAILED: Board in chassis 1 slot 5 failed to load software images. |
Explanation |
The card failed to load software images during the boot process. |
246. Execute the display boot-loader command to identify the startup software images. 247. Execute the dir command to verify that the startup software images exist. If the startup software images do not exist or are damaged, re-upload the software images to the device or set another one as the startup software images. 248. If the problem persists, contract H3C/H3C Support. |
LOAD_FINISHED
Message text |
Board in chassis [INT32] slot [INT32] has finished loading software images. |
Variable fields |
Severity level |
5 |
Example |
LOAD/5/LOAD_FINISHED: Board in chassis 1 slot 5 has finished loading software images. |
Explanation |
The card has finished loading software images. |
LOGIN messages
This section contains login messages.
LOGIN_FAILED
Message text |
[STRING] failed to login from [STRING]. |
Variable fields |
$1: Username. $2: Line name or IP address. |
Severity level |
5 |
Example |
LOGIN/5/LOGIN_FAILED: TTY failed to log in from console0. LOGIN/5/LOGIN_FAILED: usera failed to log in from 192.168.11.22. |
Explanation |
A login attempt failed. |
LOGIN_ INVALID_USERNAME_PWD
Message text |
Invalid username or password from [STRING]. |
Variable fields |
$1: User line name and user IP address. |
Severity level |
5 |
Example |
LOGIN/5/LOGIN_INVALID_USERNAME_PWD: Invalid username or password from console0. LOGIN/5/LOGIN_INVALID_USERNAME_PWD: Invalid username or password from 192.168.11.22. |
Explanation |
A user entered an invalid username or password. |
LPDT messages
This section contains loop detection messages.
LPDT_LOOPED
Message text |
A loop was detected on [STRING]. |
Variable fields |
$1: Port name. |
Severity level |
4 |
Example |
LPDT/4/LPDT_LOOPED: A loop was detected on GigabitEthernet1/0/1. |
Explanation |
The first intra-VLAN loop was detected on a port. |
Check the links and configuration on the device for the loop, and remove the loop. |
LPDT_RECOVERED
Message text |
All loops were removed on [STRING]. |
Variable fields |
$1: Port name. |
Severity level |
5 |
Example |
LPDT/5/LPDT_RECOVERED: All loops were removed on GigabitEthernet1/0/1. |
Explanation |
All intra-VLAN loops on a port were removed. |
No action is required. |
LPDT_VLAN_LOOPED
Message text |
A loop was detected on [STRING] in VLAN [UINT16]. |
Variable fields |
$1: Port name. $2: VLAN ID. |
Severity level |
4 |
Example |
LPDT/4/LPDT_VLAN_LOOPED: A loop was detected on GigabitEthernet1/0/1 in VLAN 1. |
Explanation |
A loop in a VLAN was detected on a port. |
Check the links and configurations in the VLAN for the loop, and remove the loop. |
LPDT_VLAN_RECOVERED
Message text |
A loop was removed on [STRING] in VLAN [UINT16]. |
Variable fields |
Severity level |
5 |
Example |
LPDT/5/LPDT_VLAN_RECOVERED: A loop was removed on GigabitEthernet1/0/1 in VLAN 1. |
Explanation |
A loop in a VLAN was removed on a port. |
LPDT_VSI_LOOPED
Message text |
A loop was detected on VSI [STRING]'s Ethernet service instance srv[UINT8] on [STRING]. |
Variable fields |
$1: VSI name. $2: Ethernet service instance number. $3: Port name. |
Severity level |
4 |
Example |
LPDT/4/LPDT_VSI_LOOPED: A loop was detected on VSI 1's Ethernet service instance srv1 on GigabitEthernet1/0/1. |
Explanation |
The device detected a loop on an Ethernet service instance of a VSI. |
Remove the loop from the interface where the looped Ethernet service instance resides. |
LPDT_VSI_RECOVERED
Message text |
All loops were removed from VSI [STRING]'s Ethernet service instance srv[UINT8] on [STRING]. |
Variable fields |
Severity level |
5 |
Example |
LPDT/5/LPDT_VSI_RECOVERED: All loops were removed from VSI 1's Ethernet service instance srv1 on GigabitEthernet1/0/1. |
Explanation |
All loops were removed from an Ethernet service instance of a VSI. |
LPDT_VSI_BLOCKFAIL
Message text |
Failed to block [STRING] that hosts VSI [STRING]'s Ethernet service instance srv[UINT8] because of insufficient resources. |
Variable fields |
$1: Port name. $2: VSI name. $3: Ethernet service instance number. |
Severity level |
5 |
Example |
LPDT/5/LPDT_VSI_BLOCKFAIL: Failed to block GigabitEthernet1/0/1 that hosts VSI 1's Ethernet service instance srv1 because of insufficient resources. |
Explanation |
The device failed to block an interface where a looped Ethernet service instance resides. |
Remove the loop from the interface. |
LS messages
This section contains Local Server messages.
LOCALSVR_PROMPTED_CHANGE_PWD
Message text |
Please change the password of [STRING] [STRING], because [STRING]. |
Variable fields |
$1: Password type: ¡ device management user. ¡ user line. ¡ user line class. $2: Username, user line number, or user line class number. $3: Reason for password change: ¡ the current password is a weak-password. ¡ the current password is the default password. ¡ it is the first login of the current user or the password had been reset. ¡ the password had expired. |
Severity level |
6 |
Example |
LOCALSVR/6/LOCALSVR_PROMPTED_CHANGE_PWD: Please change the password of device management user hhh, because the current password is a weak password. |
Explanation |
The device generated a log message to prompt a user to change the password of the user, user line, or user line class. The device will generate such a log message every 24 hours after the user logs in to the device if the password does not meet the password control requirements. |
Change the user password as required: · If scheme authentication is used, change the local password of the user. · If password authentication is used, change the authentication password of the user line or user line class for the user. |
LS_ADD_USER_TO_GROUP
Message text |
Admin [STRING] added user [STRING] to group [STRING]. |
Variable fields |
$1: Admin name. $2: Username. $3: User group name. |
Severity level |
4 |
Example |
LS/4/LS_ADD_USER_TO_GROUP: Admin admin added user user1 to group group1. |
Explanation |
The administrator added a user into a user group. |
LS_AUTHEN_FAILURE
Message text |
User [STRING] from [STRING] failed authentication. [STRING] |
Variable fields |
$1: Username. $2: IP address. $3: Failure reason: ¡ "User not found." ¡ "Password verified failed." ¡ "User not active." ¡ "Access type mismatch." ¡ "Binding attribute is failed." ¡ "User in blacklist." |
Severity level |
5 |
Example |
LS/5/LS_AUTHEN_FAILURE: User cwf@system from 192.168.0.22 failed authentication. "User not found." |
Explanation |
The local server rejected a user's authentication request. |
LS_AUTHEN_SUCCESS
Message text |
User [STRING] from [STRING] was authenticated successfully. |
Variable fields |
$1: Username. $2: IP address. |
Severity level |
6 |
Example |
LS/6/LS_AUTHEN_SUCCESS: User cwf@system from 192.168.0.22 was authenticated successfully. |
Explanation |
The local server accepted a user's authentication request. |
LS_DEL_USER_FROM_GROUP
Message text |
Admin [STRING] delete user [STRING] from group [STRING]. |
Variable fields |
Severity level |
4 |
Example |
LS/4/LS_DEL_USER_FROM_GROUP: Admin admin delete user user1 from group group1. |
Explanation |
The administrator deleted a user from a user group. |
LS_DELETE_PASSWORD_FAIL
Message text |
Failed to delete the password for user [STRING]. |
Variable fields |
$1: Username. |
Severity level |
4 |
Example |
LS/4/LS_DELETE_PASSWORD_FAIL: Failed to delete the password for user abcd. |
Explanation |
Failed to delete the password for a user. |
Check the file system for errors. |
LS_PWD_ADDBLACKLIST
Message text |
User [STRING] at [STRING] was added to the blacklist due to multiple login failures, [STRING]. |
Variable fields |
$1: Username. $2: IP address. $3: Options include: ¡ but could make other attempts. ¡ and is permanently blocked. ¡ and was temporarily blocked for [UINT32] minutes. |
Severity level |
4 |
Example |
LS/4/LS_PWD_ADDBLACKLIST: User user1 at 192.168.0.22 was added to the blacklist due to multiple login failures, but could make other attempts. |
Explanation |
A user was added to the blacklist because of multiple login failures. |
Check the user's password. |
LS_PWD_CHGPWD_FOR_AGEDOUT
Message text |
User [STRING] changed the password because it was expired. |
Variable fields |
$1: Username. |
Severity level |
4 |
Example |
LS/4/LS_PWD_CHGPWD_FOR_AGEDOUT: User aaa changed the password because it was expired. |
Explanation |
A user changed the password because the old password has expired. |
LS_PWD_CHGPWD_FOR_AGEOUT
Message text |
User [STRING] changed the password because it was about to expire. |
Variable fields |
$1: Username. |
Severity level |
4 |
Example |
LS/4/LS_PWD_CHGPWD_FOR_AGEOUT: User aaa changed the password because it was about to expire. |
Explanation |
A user changed the password because the old password was about to expire. |
LS_PWD_CHGPWD_FOR_COMPOSITION
Message text |
User [STRING] changed the password because it had an invalid composition. |
Variable fields |
$1: Username. |
Severity level |
4 |
Example |
LS/4/LS_PWD_CHGPWD_FOR_COMPOSITION: User aaa changed the password because it had an invalid composition. |
Explanation |
A user changed the password because it had an invalid composition. |
LS_PWD_CHGPWD_FOR_FIRSTLOGIN
Message text |
User [STRING] changed the password at the first login. |
Variable fields |
$1: Username. |
Severity level |
4 |
Example |
LS/4/LS_PWD_CHGPWD_FOR_FIRSTLOGIN: User aaa changed the password at the first login. |
Explanation |
A user changed the password at the first login. |
LS_PWD_CHGPWD_FOR_LENGTH
Message text |
User [STRING] changed the password because it was too short. |
Variable fields |
$1: Username. |
Severity level |
4 |
Example |
LS/4/LS_PWD_CHGPWD_FOR_LENGTH: User aaa changed the password because it was too short. |
Explanation |
A user changed the password because it was too short. |
LS_PWD_FAILED2WRITEPASS2FILE
Message text |
Failed to write the password records to file. |
Variable fields |
N/A |
Severity level |
4 |
Example |
LS/4/LS_PWD_FAILED2WRITEPASS2FILE: Failed to write the password records to file. |
Explanation |
LS_PWD_MODIFY_FAIL
Message text |
Admin [STRING] from [STRING] could not modify the password for user [STRING], because [STRING]. |
Variable fields |
$1: Admin name. $2: IP address. $3: Username. $4: Failure reason: ¡ old password is incorrect. ¡ password is too short. ¡ password has not minimum different chars. ¡ invalid password composition. ¡ password has repeated chars. ¡ password contains username. ¡ password used already. ¡ password is in update-wait time. |
Severity level |
4 |
Example |
LS/4/LS_PWD_MODIFY_FAIL: Admin admin from 1.1.1.1 could not modify the password for user user1, because old password is incorrect. |
Explanation |
An administrator failed to modify a user's password. |
LS_PWD_MODIFY_SUCCESS
Message text |
Admin [STRING] from [STRING] modify the password for user [STRING] successfully. |
Variable fields |
$1: Admin name. $2: IP address. $3: Username. |
Severity level |
6 |
Example |
LS/6/LS_PWD_MODIFY_SUCCESS: Admin admin from 1.1.1.1 modify the password for user abc successfully. |
Explanation |
An administrator successfully modified a user's password. |
LS_REAUTHEN_FAILURE
Message text |
User [STRING] from [STRING] failed reauthentication. |
Variable fields |
Severity level |
5 |
Example |
LS/5/LS_REAUTHEN_FAILURE: User abcd from 1.1.1.1 failed reauthentication. |
Explanation |
A user failed reauthentication. |
Check the old password. |
LS_UPDATE_PASSWORD_FAIL
Message text |
Failed to update the password for user [STRING]. |
Variable fields |
$1: Username. |
Severity level |
4 |
Example |
LS/4/LS_UPDATE_PASSWORD_FAIL: Failed to update the password for user abc. |
Explanation |
Failed to update the password for a user. |
LS_USER_CANCEL
Message text |
User [STRING] from [STRING] cancelled inputting the password. |
Variable fields |
Severity level |
5 |
Example |
LS/5/LS_USER_CANCEL: User 1 from 1.1.1.1 cancelled inputting the password. |
Explanation |
The user cancelled inputting the password or did not input the password in 90 seconds. |
LS_USER_PASSWORD_EXPIRE
Message text |
User [STRING]'s login idle timer timed out. |
Variable fields |
$1: Username. |
Severity level |
5 |
Example |
LS/5/LS_USER_PASSWORD_EXPIRE: User 1's login idle timer timed out. |
Explanation |
The login idle time for a user expired. |
LS_USER_ROLE_CHANGE
Message text |
Admin [STRING] [STRING] the user role [STRING] for [STRING]. |
Variable fields |
$1: Admin name. $2: Added/Deleted. $3: User role. $4: Username. |
Severity level |
4 |
Example |
LS/4/LS_USER_ROLE_CHANGE: Admin admin add the user role network-admin for abcd. |
Explanation |
The administrator added a user role for a user. |
LSPV messages
This section contains LSP verification messages.
LSPV_PING_STATIS_INFO
Message text |
Ping statistics for [STRING]: [UINT32] packets transmitted, [UINT32] packets received, [DOUBLE]% packets loss, round-trip min/avg/max = [UINT32]/[UINT32]/[UINT32] ms. |
Variable fields |
$1: FEC. $2: Number of echo requests sent. $3: Number of echo replies received. $4: Percentage of the non-replied packets to the total requests. $5: Minimum round-trip delay. $6: Average round-trip delay. $7: Maximum round-trip delay. |
Severity level |
6 |
Example |
LSPV/6/LSPV_PING_STATIS_INFO: Ping statistics for FEC 192.168.1.1/32: 5 packets transmitted, 5 packets received, 0.0% packets loss, round-trip min/avg/max = 1/2/5 ms. |
Explanation |
Ping statistics for an LSP tunnel or a PW. This message is generated when the ping mpls command is executed. |
If no reply is received, verify the connectivity of the LSP tunnel or the PW. |
MAC messages
This section contains MAC messages.
MAC_DRIVER_ADD_ENTRY
Message text |
Driver failed to add MAC address entry: MAC address=[STRING], VLAN=[UINT32], State=[UINT32], interface=[STRING]. |
Variable fields |
$1: MAC address. $2: VLAN ID. $3: Entry type number. $4: Interface type and interface number. |
Severity level |
4 |
Example |
MAC/4/MAC_DRIVER_ADD_ENTRY: Driver failed to add MAC address entry: MAC address=1-1-1, VLAN=1, State=2, interface=GigabitEthernet1/0/1. |
Explanation |
Failed to add a MAC address entry on an interface. |
MAC_PROTOCOLPKT_NORES_GLOBAL
Message text |
The card does not have enough hardware resources to send protocol packets destined for [STRING] to the CPU for [STRING], |
Variable fields |
$1: MAC address. $2: Protocol type. |
Severity level |
5 |
Example |
MAC/5/MAC_PROTOCOLPKT_NORES_GLOBAL: The card does not have enough hardware resources to send protocol packets destined for 0180-C200-000e to the CPU for LLDP. |
Explanation |
Protocol packets fail to be sent to the CPU because the hardware resources of the card are insufficient. |
MAC_PROTOCOLPKT_NORES_PORT
Message text |
The card does not have enough hardware resources to send protocol packets destined for [STRING] to the CPU for [STRING] on [STRING]. |
Variable fields |
$1: MAC address. $2: Protocol type. $3: Interface name. |
Severity level |
5 |
Example |
MAC/5/MAC_PROTOCOLPKT_NORES_PORT: The card does not have enough hardware resources to send protocol packets destined for 0180-C200-000e to the CPU for LLDP on GigabitEthernet2/0/32. |
Explanation |
Protocol packets on an interface fail to be sent to the CPU because the hardware resources of the card are insufficient. |
MAC_PROTOCOLPKT_NORES_VLAN
Message text |
The card does not have enough hardware resources to send protocol packets destined for [STRING] to the CPU for [STRING] in VLAN [UINT16]. |
Variable fields |
$1: MAC address. $2: Protocol type. $3: VLAN ID. |
Severity level |
5 |
Example |
MAC/5/MAC_PROTOCOLPKT_NORES_VLAN: The card does not have enough hardware resources to send protocol packets destined for 0180-C200-000e to the CPU for LLDP in VLAN 100. |
Explanation |
Protocol packets in a VLAN fail to be sent to the CPU because the hardware resources of the card are insufficient. |
MAC_TABLE_FULL_GLOBAL
Message text |
The number of MAC address entries exceeded the maximum number [UINT32]. |
Variable fields |
$1: Maximum number of MAC addresses. |
Severity level |
4 |
Example |
MAC/4/MAC_TABLE_FULL_GLOBAL: The number of MAC address entries exceeded the maximum number 1024. |
Explanation |
The number of entries in the global MAC address table exceeded the maximum number supported by the table. |
MAC_TABLE_FULL_PORT
Message text |
The number of MAC address entries exceeded the maximum number [UINT32] for interface [STRING]. |
Variable fields |
$1: Maximum number of MAC addresses. $2: Interface name. |
Severity level |
4 |
Example |
MAC/4/MAC_TABLE_FULL_PORT: The number of MAC address entries exceeded the maximum number 1024 for interface GigabitEthernet2/0/32. |
Explanation |
The number of entries in the MAC address table for an interface exceeded the maximum number supported by the table. |
MAC_TABLE_FULL_VLAN
Message text |
The number of MAC address entries exceeded the maximum number [UINT32] in VLAN [UINT32]. |
Variable fields |
$1: Maximum number of MAC addresses. $2: VLAN ID. |
Severity level |
4 |
Example |
MAC/4/MAC_TABLE_FULL_VLAN: The number of MAC address entries exceeded the maximum number 1024 in VLAN 2. |
Explanation |
The number of entries in the MAC address table for a VLAN exceeded the maximum number supported by the table. |
MAC_VLAN_LEARNLIMIT_NORESOURCE
Message text |
The card does not have enough hardware resources to set MAC learning limit for VLAN [UINT16]. |
Variable fields |
$1: VLAN ID. |
Severity level |
5 |
Example |
MAC/5/MAC_VLAN_LEARNLIMIT_NORESOURCE: The card does not have enough hardware resources to set MAC learning limit for VLAN 100. |
Explanation |
Failed to set the MAC learning limit for a VLAN because the card does not have enough hardware resources. |
MAC_VLAN_LEARNLIMIT_NOTSUPPORT
Message text |
The card does not support setting MAC learning limit for VLAN [UINT16]. |
Variable fields |
$1: VLAN ID. |
Severity level |
5 |
Example |
MAC/5/ MAC_VLAN_LEARNLIMIT_NOTSUPPORT: The card does not support setting MAC learning limit for VLAN 100. |
Explanation |
MAC learning limit setting for a VLAN is not supported on the card. |
MACA messages
This section contains MAC authentication messages.
MACA_ENABLE_NOT_EFFECTIVE
Message text |
MAC authentication is enabled but is not effective on interface [STRING]. |
Variable fields |
$1: Interface type and number. |
Severity level |
3 |
Example |
MACA/3/MACA_ENABLE_NOT_EFFECTIVE: MAC authentication is enabled but is not effective on interface Ethernet3/1/2. |
Explanation |
MAC authentication configuration does not take effect on an interface, because the interface does not support MAC authentication. |
249. Disable MAC authentication on the interface. 250. Reconnect the connected devices to another interface that supports MAC authentication. 251. Enable MAC authentication on the new interface. |
MACA_LOGIN_FAILURE
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-UsernameFormat=[STRING]; User failed MAC authentication. Reason: [STRING]. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: VLAN ID. $4: Username. $5: User account format. $6: Failure cause: · MAC address authorization failed. · VLAN authorization failed. · VSI authorization failed. · ACL authorization failed. · User profile authorization failed. · URL authorization failed. · Authentication process failed. |
Severity level |
6 |
Example |
MACA/6/MACA_LOGIN_FAILURE: -IfName=GigabitEthernet1/0/1-MACAddr=0000-0000-0001-VLANID=1-Username=0000-0000-0001-UsernameFormat=MAC address; User failed MAC authentication. Reason: VLAN authorization failed. |
Explanation |
The user failed MAC authentication for a specific reason. |
Locate the failure cause and handle the issue according to the failure cause. |
MACA_LOGIN_SUCC
Message text |
-IfName=[STRING]-MACAddr=[STRING]-AccessVLANID=[STRING]-AuthorizationVLANID=[STRING]-Username=[STRING]-UsernameFormat=[STRING]; User passed MAC authentication and came online. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: ID of the access VLAN. $4: ID of the authorization VLAN. $5: Username. $6: User account format. |
Severity level |
6 |
Example |
MACA/6/MACA_LOGIN_SUCC:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-AccessVLANID=444-AuthorizationVLANID=444-Username=00-10-84-00-22-b9-UsernameFormat=MAC address; User passed MAC authentication and came online. |
Explanation |
The user passed MAC authentication. |
MACA_LOGIN_SUCC (in open mode)
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-UsernameFormat=[STRING]; The user that failed MAC authentication passed open authentication and came online. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: VLAN ID. $4: Username. $5: User account format. |
Severity level |
6 |
Example |
MACA/6/MACA_LOGIN_SUCC:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=00-10-84-00-22-b9-UsernameFormat=MAC address; The user that failed MAC authentication passed open authentication and came online. |
Explanation |
A user failed MAC authentication but passed open authentication. |
MACA_LOGOFF
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-UsernameFormat=[STRING]; MAC authentication user was logged off. |
Variable fields |
Severity level |
6 |
Example |
MACA/6/MACA_LOGOFF:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=00-10-84-00-22-b9-UsernameFormat=MAC address; MAC authentication user was logged off. |
Explanation |
The MAC authentication user was logged off. |
Locate the logoff cause and remove the issue. If the logoff was requested by the user, no action is required. |
MACA_LOGOFF (in open mode)
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-UsernameFormat=[STRING]; MAC authentication open user was logged off. |
Variable fields |
Severity level |
6 |
Example |
MACA/6/MACA_LOGOFF:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=00-10-84-00-22-b9-UsernameFormat=MAC address; MAC authentication open user was logged off. |
Explanation |
A MAC authentication open user was logged off. |
MACSEC messages
This section contains MACsec messages.
MACSEC_MKA_KEEPALIVE_TIMEOUT
Message text |
The live peer with SCI [STRING] and CKN [STRING] aged out on interface [STRING]. |
Variable fields |
$1: SCI. $2: CKN. $3: Interface name. |
Severity level |
4 |
Example |
MACSEC/4/MACSEC_MKA_KEEPALIVE_TIMEOUT: The live peer with SCI 00E00100000A0006 and CKN 80A0EA0CB03D aged out on interface GigabitEthernet1/0/1. |
Explanation |
A live peer aged out on an interface, because the local participant had not received any MKA packets from the peer before the keepalive timer expired. The local participant removed the peer information from the port. |
Check the link between the local participant and the live peer for link failure. If the link is down, recover the link. |
MACSEC_MKA_PRINCIPAL_ACTOR
Message text |
The actor with CKN [STRING] became principal actor on interface [STRING]. |
Variable fields |
$1: CKN. $2: Interface name. |
Severity level |
6 |
Example |
MACSEC/6/MACSEC_MKA_PRINCIPAL_ACTOR: The actor with CKN 80A0EA0CB03D became principal actor on interface GigabitEthernet1/0/1. |
Explanation |
The actor with the highest key server priority became the principal actor. |
MACSEC_MKA_SAK_REFRESH
Message text |
The SAK has been refreshed on interface [STRING]. |
Variable fields |
$1: Interface name. |
Severity level |
6 |
Example |
MACSEC/6/MACSEC_MKA_SAK_REFRESH: The SAK has been refreshed on interface GigabitEthernet1/0/1. |
Explanation |
The participant on the interface derived or received a new SAK. |
MACSEC_MKA_SESSION_REAUTH
Message text |
The MKA session with CKN [STRING] was re-authenticated on interface [STRING]. |
Variable fields |
Severity level |
6 |
Example |
MACSEC/6/MACSEC_MKA_SESSION_REAUTH: The MKA session with CKN 80A0EA0CB03D was re-authenticated on interface GigabitEthernet1/0/1. |
Explanation |
The interface performed 802.1X reauthentication. After the 802.1X reauthentication, the participants received a new CAK, and used it to re-establish the MKA session. |
MACSEC_MKA_SESSION_SECURED
Message text |
The MKA session with CKN [STRING] was secured on interface [STRING]. |
Variable fields |
Severity level |
6 |
Example |
MACSEC/6/MACSEC_MKA_SESSION_SECURED: The MKA session with CKN 80A020EA0CB03D was secured on interface GigabitEthernet1/0/1. |
Explanation |
The MKA session on the interface was secured. Packets are encrypted and transmitted in cipher text. The event occurs in the following situations: · The MKA session state changes from unsecured to secured. · The local participant and the peer negotiate a new MKA session when the following conditions exist: ¡ Both the key server and the peer support MACsec. ¡ A minimum of one participant is enabled with the MACsec desire feature. |
MACSEC_MKA_SESSION_START
Message text |
The MKA session with CKN [STRING] started on interface [STRING]. |
Variable fields |
Severity level |
6 |
Example |
MACSEC/6/MACSEC_MKA_SESSION_START: The MKA session with CKN 80A020EA0CB03D started on interface GigabitEthernet1/0/1. |
Explanation |
The MKA session negotiation was initiated. Possible reasons include: · New CAK is available after MKA is enabled. · The user re-establishes the MKA session. · The interface that failed MKA session negotiation receives an MKA packet. |
MACSEC_MKA_SESSION_STOP
Message text |
The MKA session with CKN [STRING] stopped on interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
MACSEC/5/MACSEC_MKA_SESSION_STOP: The MKA session with CKN 80A020EA0CB03D stopped on interface GigabitEthernet1/0/1. |
Explanation |
The MKA session was terminated. Possible reasons include: · The user removes or re-establishes the MKA session on the interface. · The link associated to the session is down. |
252. Use the display mka session command to check whether the session exists: ¡ If the session has been re-established, ignore the message. ¡ If the session does not exist and is not removed by the user, check the link associated with the session for link failure. 253. Recover the link if the link is down. |
MACSEC_MKA_SESSION_UNSECURED
Message text |
The MKA session with CKN [STRING] was not secured on interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
MACSEC/5/MACSEC_MKA_SESSION_UNSECURED: The MKA session with CKN 80A020EA0CB03D was not secured on interface GigabitEthernet1/0/1. |
Explanation |
The MKA session on the interface was not secured. Packets are transmitted in plain text. The event occurs in the following situations: · The MKA session state changes from secured to unsecured. · The local participant and the peer negotiate a new MKA session when the following conditions exist: ¡ The key server and the peer are not both MACsec capable. ¡ No participant is enabled with the MACsec desire feature. |
To secure the MKA session, perform the following tasks: · Verify that both the key server and the peer support MACsec. · Verify that a minimum of one participant is enabled with the MACsec desire feature. |
MBFD messages
This section contains MPLS BFD messages.
MBFD_TRACEROUTE_FAILURE
Message text |
[STRING] is failed. ([STRING].) |
Variable fields |
$1: LSP information. $2: Reason for the LSP failure. |
Severity level |
5 |
Example |
MBFD/5/MBFD_TRACEROUTE_FAILURE: LSP (LDP IPv4: 22.22.2.2/32, nexthop: 20.20.20.2) is failed. (Replying router has no mapping for the FEC.) MBFD/5/MBFD_TRACEROUTE_FAILURE: TE tunnel (RSVP IPv4: Tunnel1) is failed. (No label entry.) |
Explanation |
LSP/MPLS TE tunnel failure was detected by periodic MPLS tracert. This message is generated when the system receives an MPLS echo reply with an error return code. |
Verify the configuration for the LSP or MPLS TE tunnel. |
MBUF messages
This section contains MBUF messages.
MBUF_DATA_BLOCK_CREATE_FAIL
Message text |
Failed to create an MBUF data block because of insufficient memory. Failure count: [UINT32]. |
Variable fields |
$1: Failure count. |
Severity level |
2 |
Example |
MBUF/2/MBUF_DATA_BLOCK_CREATE_FAIL: Failed to create an MBUF data block because of insufficient memory. Failure count: 128. |
Explanation |
The message is output when the system fails to create an MBUF data block 1 minute or more after the most recent creation failure. |
254. Execute the display system internal kernel memory pool | include mbuf command in probe view to view the number of the allocated MBUF data blocks. 255. Execute the display memory command in system view to display the total size of the system memory. 256. Determine whether an excessive number of MBFU data blocks are allocated by comparing the size of the allocated MBUF data blocks with that of the system memory. ¡ If it is not an excessive number, use the memory management commands to check for the memory-intensive modules. ¡ If it is an excessive number, go to step 257. 257. Execute the display system internal mbuf socket statistics command in probe view to view the number of the MBUF data blocks buffered in the socket. Determine whether a process has too many MBUF data blocks buffered in the socket buffer. ¡ If it is too many, locate the reason why the MBUF data blocks cannot be released from the socket buffer. ¡ If it is not too many, use other means to locate the reasons for excessive allocation of MBUF data blocks. 258. If the problem persists, contact H3C Support. |
MDC messages
This section contains MDC messages.
MDC_CREATE_ERR
Message text |
Failed to create MDC [UINT16] for insufficient resources. |
Variable fields |
$1: MDC ID. |
Severity level |
5 |
Example |
MDC/5/MDC_CREATE_ERR: -Slot=1; Failed to create MDC 2 for insufficient resources. |
Explanation |
The standby MPU did not have enough resources to create the MDC. At startup, the standby MPU obtains MDC configuration information from the active MPU. If the standby MPU does not have enough resources to create an MDC, it outputs this log message. |
259. Use the display mdc resource command to display the CPU, memory, and disk space resources on the standby MPU. 260. Perform one of the following tasks: ¡ If the memory space is insufficient, increase the memory space. If the disk space is insufficient, delete unused files. ¡ Use the undo mdc command to delete the specified MDC. ¡ Replace the standby MPU with an MPU that has sufficient resources. |
MDC_CREATE
Message text |
MDC [UINT16] was created. |
Variable fields |
$1: MDC ID. |
Severity level |
5 |
Example |
MDC/5/MDC_CREATE: MDC 2 was created. |
Explanation |
An MDC was created successfully. |
MDC_DELETE
Message text |
MDC [UINT16] was deleted. |
Variable fields |
$1: MDC ID. |
Severity level |
5 |
Example |
MDC/5/MDC_DELETE: MDC 2 was deleted. |
Explanation |
An MDC was deleted successfully. |
MDC_KERNEL_EVENT_TOOLONG
Message text |
[STRING] [UINT16] kernel event in sequence [STRING] function [STRING] failed to finish within [UINT32] minutes. |
Variable fields |
$1: Object type, MDC or Context. $2: MDC ID or context ID. $3: Kernel event phase. $4: Address of the function corresponding to the kernel event. $5: Time duration. |
Severity level |
4 |
Example |
MDC/4/MDC_KERNEL_EVENT_TOOLONG: -slot=1; MDC 2 kernel event in sequence 0x4fe5 function 0xff245e failed to finish within 15 minutes. |
Explanation |
A kernel event stayed unfinished for a long period of time. |
261. Reboot the card in the specified slot. 262. If the problem persists, contact HP Support. |
MDC_LICENSE_EXPIRE
Message text |
The MDC feature's license will expire in [UINT32] days. |
Variable fields |
$1: Number of days, in the range of 1 to 30. |
Severity level |
5 |
Example |
MDC/5/MDC_LICENSE_EXPIRE: The MDC feature’s license will expire in 5 days. |
Explanation |
The license for the MDC feature was about to expire. |
Install a new license. |
MDC_NO_FORMAL_LICENSE
Message text |
The feature MDC has no formal license. |
Variable fields |
N/A |
Severity level |
5 |
Example |
MDC/5/MDC_NO_FORMAL_LICENSE: The feature MDC has no formal license. |
Explanation |
The standby MPU became the active MPU but it did not have a formal license. The MDC feature has a free trial period. To use the feature after the period elapses, you must install a license for the standby MPU. |
Install a formal license. |
MDC_NO_LICENSE_EXIT
Message text |
The MDC feature is being disabled, because it has no license. |
Variable fields |
N/A |
Severity level |
5 |
Example |
MDC/5/MDC_NO_LICENSE_EXIT: The MDC feature is being disabled, because it has no license. |
Explanation |
The MDC feature was disabled because the license for the MDC feature expired or was uninstalled. |
Install the required license. |
MDC_OFFLINE
Message text |
MDC [UINT16] is offline now. |
Variable fields |
$1: MDC ID. |
Severity level |
5 |
Example |
MDC/5/MDC_OFFLINE: MDC 2 is offline now. |
Explanation |
An MDC was stopped. |
MDC_ONLINE
Message text |
MDC [UINT16] is online now. |
Variable fields |
$1: MDC ID. |
Severity level |
5 |
Example |
MDC/5/MDC_ONLINE: MDC 2 is online now. |
Explanation |
An MDC was started. |
MDC_STATE_CHANGE
Message text |
MDC [UINT16] status changed to [STRING]. |
Variable fields |
$1: MDC ID. $2: MDC status: ¡ updating–The system is assigning interface cards to the MDC (executing the location command). ¡ stopping–The system is stopping the MDC (executing the undo mdc start command). ¡ inactive–The MDC is inactive. ¡ starting–The system is starting the MDC (executing the mdc start command). ¡ active–The MDC is operating correctly. |
Severity level |
5 |
Example |
MDC/5/MDC_STATE_CHANGE: MDC 2 status changed to active. |
Explanation |
The status of an MDC changed. |
MFIB messages
This section contains MFIB messages.
MFIB_MEM_ALERT
Message text |
MFIB process received system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alert event. |
Severity level |
5 |
Example |
MFIB/5/MFIB_MEM_ALERT: MFIB process receive system memory alert start event. |
Explanation |
The MFIB module received a memory alert event from the system. |
263. Check the system memory to make sure the memory usage does not exceed the thresholds. 264. Release memory from memory-intensive modules. |
MGROUP messages
This section contains mirroring group messages.
MGROUP_APPLY_SAMPLER_FAIL
Message text |
Failed to apply the sampler for mirroring group [UINT16], because the sampler resources are insufficient. |
Variable fields |
$1: Mirroring group ID. |
Severity level |
3 |
Example |
MGROUP/3/MGROUP_APPLY_SAMPLER_FAIL: Failed to apply the sampler for mirroring group 1, because the sampler resources are insufficient. |
Explanation |
A sampler was not applied to the mirroring group because the sampler resources were insufficient. |
MGROUP_RESTORE_CPUCFG_FAIL
Message text |
Failed to restore configuration for mirroring CPU of [STRING] in mirroring group [UINT16], because [STRING] |
Variable fields |
$1: Slot number. $2: Mirroring group ID. $3: Failure reason. |
Severity level |
3 |
Example |
MGROUP/3/MGROUP_RESTORE_CPUCFG_FAIL: Failed to restore configuration for mirroring CPU of chassis 1 slot 2 in mirroring group 1, because the type of the monitor port in the mirroring group is not supported. |
Explanation |
When the CPU of the card in the slot is the source CPU in the mirroring group, configuration changes after the card is removed. When the card is reinstalled into the slot, restoring the source CPU configuration might fail. |
Check for the failure reason. If the reason is that the system does not support the changed configuration, delete the unsupported configuration, and reconfigure the source CPU in the mirroring group. |
MGROUP_RESTORE_GROUP_FAIL
Message text |
Failed to restore configuration for mirroring group [UINT16], because [STRING] |
Variable fields |
$1: Mirroring group ID. $2: Failure reason, which is monitor resources are insufficient. |
Severity level |
3 |
Example |
MGROUP/3/MGROUP_RESTORE_GROUP_FAIL: Failed to restore configuration for mirroring group 1, because monitor resources are insufficient. |
Explanation |
Failed to restore the configuration of a mirroring group after device reboot because the monitor resources are insufficient. |
Delete mirroring configurations to release monitor resources and then re-configure the mirroring group for which configuration restoration failed. After device reboot, flow mirroring configurations are restored before port mirroring configurations. The monitor resources are limited and restoration of port mirroring configurations might fail if the monitor resources are insufficient. |
MGROUP_RESTORE_IFCFG_FAIL
Failed to restore configuration for interface [STRING] in mirroring group [UINT16], because [STRING] |
Variable fields |
$1: Interface name. $2: Mirroring group ID. $3: Failure reason. |
Severity level |
3 |
Example |
MGROUP/3/MGROUP_RESTORE_IFCFG_FAIL: Failed to restore configuration for interface Ethernet3/1/2 in mirroring group 1, because the type of the monitor port in the mirroring group is not supported. |
Explanation |
When the interface of the card in the slot is the monitor port in the mirroring group, configuration changes after the card is removed. When the card is reinstalled into the slot, restoring the monitor port configuration might fail. |
Check for the failure reason. If the reason is that the system does not support the changed configuration, delete the unsupported configuration, and reconfigure the monitor port in the mirroring group. |
MGROUP_SYNC_CFG_FAIL
Message text |
Failed to restore configuration for mirroring group [UINT16] in [STRING], because [STRING] |
Variable fields |
$1: Mirroring group ID. $2: Slot number. $3: Failure reason. |
Severity level |
3 |
Example |
MGROUP/3/MGROUP_SYNC_CFG_FAIL: Failed to restore configuration for mirroring group 1 in chassis 1 slot 2, because monitor resources are insufficient. |
Explanation |
When the complete mirroring group configuration was synchronized on the card in the slot, restoring configuration failed because resources on the card were insufficient. |
Delete the mirroring group. |
MPLS messages
This section contains MPLS messages.
MPLS_HARD_RESOURCE_NOENOUGH
Message text |
No enough hardware resource for MPLS. |
Variable fields |
N/A |
Severity level |
4 |
Example |
MPLS/4/MPLS_HARD_RESOURCE_NOENOUGH: No enough hardware resource for MPLS. |
Explanation |
Hardware resources for MPLS were insufficient. |
Check whether unnecessary LSPs had been generated. If yes, configure or modify the LSP generation policy, label advertisement policy, and label acceptance policy to filter out unnecessary LSPs. |
MPLS_HARD_RESOURCE_RESTORE
Message text |
Hardware resources for MPLS are restored. |
Variable fields |
N/A |
Severity level |
6 |
Example |
MPLS/6/MPLS_HARD_RESOURCE_RESTORE: Hardware resources for MPLS are restored. |
Explanation |
Hardware resources for MPLS were restored. |
MTLK messages
This section contains Monitor Link messages.
MTLK_UPLINK_STATUS_CHANGE
Message text |
The uplink of monitor link group [UINT32] is [STRING]. |
Variable fields |
$1: Monitor link group ID. $2: Monitor Link group status, up or down. |
Severity level |
6 |
Example |
MTLK/6/MTLK_UPLINK_STATUS_CHANGE: The uplink of monitor link group 1 is up. |
Explanation |
The uplink of a monitor link group went up or down. |
Troubleshoot the uplink when it fails. |
NAT messages
This section contains NAT messages.
NAT_ADDR_BIND_CONFLICT
Message text |
Failed to activate NAT configuration on interface [STRING], because global IP addresses already bound to another service card. |
Variable fields |
Severity level |
4 |
Example |
NAT/4/NAT_ADDR_BIND_CONFLICT: Failed to activate NAT configuration on interface Ethernet0/0/2, because global IP addresses already bound to another service card. |
Explanation |
The NAT configuration did not take effect, because the global IP addresses that the interface references have been bound to another service card. |
If multiple interfaces reference the same global IP addresses, you must specify the same service card to process NAT traffic passing through these interfaces. To resolve the problem: 265. Use the display nat all command to check the current configuration. 266. Remove the service card configuration on the interface. 267. Specify the same service card for interfaces referencing the same global IP addresses. |
NAT_FAILED_ADD_FLOW_RULE
Message text |
Failed to add flow-table due to: [STRING]. |
Variable fields |
$1: Reason for the failure. |
Severity level |
4 |
Example |
NAT/4/NAT_FAILED_ADD_FLOW_RULE: Failed to add flow-table due to: Not enough resources are available to complete the operation. |
Explanation |
The system failed to deploy flow entries. Possible reasons include insufficient hardware resources or memory. |
Contact H3C Support. |
NAT_FAILED_ADD_FLOW_TABLE
Message text |
Failed to add flow-table due to [STRING]. |
Variable fields |
$1: Failure reason: · no enough resource. · The item already exists. |
Severity level |
4 |
Example |
NAT/4/NAT_FAILED_ADD_FLOW_TABLE: Failed to add flow-table due to no enough resource. |
Explanation |
The system failed to add a flow table due to insufficient hardware resources or NAT address overlapping. |
If the failure is caused by insufficient hardware resources, contact H3C Support. If the failure is caused by address overlapping, reconfigure the NAT addresses. Make sure the NAT address ranges do not overlap. |
NAT_FLOW
Message text |
Protocol(1001)=[STRING];SrcIPAddr(1003)=[IPADDR];SrcPort(1004)=[UINT16];NATSrcIPAddr(1005)=[IPADDR];NATSrcPort(1006)=[UINT16];DstIPAddr(1007)=[IPADDR];DstPort(1008)=[UINT16];NATDstIPAddr(1009)=[IPADDR];NATDstPort(1010)=[UINT16];InitPktCount(1044)=[UINT32];InitByteCount(1046)=[UINT32];RplyPktCount(1045)=[UINT32];RplyByteCount(1047)=[UINT32];RcvVPNInstance(1042)=[STRING];SndVPNInstance(1043)=[STRING];RcvDSLiteTunnelPeer(1040)=[STRING];SndDSLiteTunnelPeer(1041)=[STRING];BeginTime_e(1013)=[STRING];EndTime_e(1014)=[STRING];Event(1048)=([UNIT16])[STRING]; |
Variable fields |
$1: Protocol type. $2: Source IP address. $3: Source port number. $4: Source IP address after translation. $5: Source port number after translation. $6: Destination IP address. $7: Destination port number. $8: Destination IP address after translation. $9: Destination port number after translation. $10: Total number of incoming packets. $11: Total number of incoming bytes. $12: Total number of outgoing packets. $13: Total number of outgoing bytes. $14: Source VPN instance name. $15: Destination VPN instance name. $16: Source DS-Lite tunnel. $17: Destination DS-Lite tunnel. $18: Time when the session is created. $19: Time when the session is removed. $20: Event time. $21: Event description: ¡ Session created. ¡ Active flow threshold. ¡ Normal over. ¡ Aged for timeout. ¡ Aged for reset or config-change. ¡ Other. |
Severity level |
6 |
Example |
NAT/6/NAT_FLOW: Protocol(1001)=UDP;SrcIPAddr(1003)=10.10.10.1;SrcPort(1004)=1024;NATSrcIPAddr(1005)=20.20.20.20;NATSrcPort(1006)=1024;DstIPAddr(1007)=20.20.20.1;DstPort(1008)=21;NATDstIPAddr(1009)=20.20.20.1;NATDstPort(1010)=21;InitPktCount(1044)=1;InitByteCount(1046)=50;RplyPktCount(1045)=0;RplyByteCount(1047)=0;RcvVPNInstance(1042)=;SndVPNInstance(1043)=;RcvDSLiteTunnelPeer(1040)=;SndDSLiteTunnelPeer(1041)=;BeginTime_e(1013)=03182024082546;EndTime_e(1014)=;Event(1048)=(8)Session created; |
Explanation |
This message is sent in one of the following conditions: · A NAT session is created or removed. · Regularly during a NAT session. · The traffic threshold or aging time of a NAT session is reached. |
NAT_SERVER_INVALID
Message text |
The NAT server with Easy IP is invalid because its global settings conflict with that of another NAT server on this interface. |
Variable fields |
N/A |
Severity level |
4 |
Example |
NAT/4/NAT_SERVER_INVALID: The NAT server with Easy IP is invalid because its global settings conflict with that of another NAT server on this interface. |
Explanation |
The NAT Server with Easy IP did not take effect because its global settings conflict with that the global settings of another NAT Server on the same interface. |
Modify the NAT Server configuration on the interface. The combination of protocol type, global IP addresses and global ports must be unique for each NAT Server on the same interface. |
NAT_SERVICE_CARD_RECOVER_FAILURE
Message text |
Pattern 1: Failed to recover the configuration of binding the service card on slot [UINT16] to interface [STRING], because [STRING]. Pattern 2: Failed to recover the configuration of binding the service card on chassis [UINT16] slot [UINT16] to interface [STRING], because [STRING]. |
Variable fields |
Pattern 1: $1: Slot number. $2: Interface name. $3: Reasons why restoring the binding between the service card and the interface fails. Pattern 2: $1: Chassis number. $2: Slot number. $3: Interface name. $4: Reasons why restoring the binding between the service card and the interface fails. |
Severity level |
4 |
Example |
NAT/4/NAT_SERVICE_CARD_RECOVER_FAILURE: Failed to recover the configuration of binding the service card on slot 3 to interface GigabitEthernet0/0/2, because NAT service is not supported on this service card. |
Explanation |
Restoring the binding between the service card and the interface failed. |
· If the operation fails because the NAT addresses have already been bound to another service card: ¡ Use the display nat all command to check the current configuration. ¡ Specify the same service card for interfaces referencing the same NAT addresses. · Check the service card for hardware problems if the failure is caused by one of the following reasons: ¡ NAT service is not supported on this service card. ¡ The hardware resources are not enough. ¡ Unknown error. |
ND messages
This section contains ND messages.
ND_COMMONPROXY_ENABLE_FAILED
Message text |
Failed to enable common ND proxy on interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
ND/4/ND_COMMONPROXY_ENABLE_FAILED: -MDC=1-Slot=2; Failed to enable common ND proxy on interface Vlan-interface 1. |
Explanation |
Failed to enable common ND proxy on an interface on the card. |
268. Verify that the card supports common ND proxy. 269. Make sure the device has sufficient hardware resources. |
ND_CONFLICT
Message text |
[STRING] is inconsistent. |
Variable fields |
$1: Configuration type: ¡ M_FLAG. ¡ O_FLAG. ¡ CUR_HOP_LIMIT. ¡ REACHABLE TIME. ¡ NS INTERVAL. ¡ MTU. ¡ PREFIX VALID TIME. ¡ PREFIX PREFERRED TIME. |
Severity level |
6 |
Example |
ND/6/ND_CONFLICT: PREFIX VALID TIME is inconsistent |
Explanation |
The configuration information in the received router advertisement was not consistent with the configuration on the device. A message is sent if an inconsistency is detected. |
Verify that the configurations on the device and the neighboring router are consistent. |
ND_DUPADDR
Message text |
Duplicate address: [STRING] on the interface [STRING]. |
Variable fields |
$1: IPv6 address that is to be assigned to the interface. $2: Name of the interface. |
Severity level |
6 |
Example |
ND/6/ND_DUPADDR: Duplicate address: 33::8 on interface Vlan-interface9. |
Explanation |
The IPv6 address that was to be assigned to the interface is being used by another device. |
Assign another IPv6 address to the interface. |
ND_HOST_IP_CONFLICT
Message text |
The host [STRING] connected to interface [STRING] cannot communicate correctly, because it uses the same IPv6 address as the host connected to interface [STRING]. |
Variable fields |
$1: IPv6 global unicast address of the host. $2: Name of the interface. $3: Name of the interface. |
Severity level |
4 |
Example |
ND/4/ND_HOST_IP_CONFLICT: The host 2::2 connected to interface GigabitEthernet1/0/1 cannot communicate correctly, because it uses the same IPv6 address as the host connected to interface GigabitEthernet1/0/1. |
Explanation |
The IPv6 global unicast address of the host is being used by another host that connects to the same interface. |
Disconnect the host and assign another IPv6 global unicast address to the host. |
ND_LOCALPROXY_ENABLE_FAILED
Message text |
Failed to enable local ND proxy on interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
ND/4/ND_LOCALPROXY_ENABLE_FAILED: -MDC=1-Slot=2; Failed to enable local ND proxy on interface Vlan-interface 1. |
Explanation |
Failed to enable local ND proxy on an interface on the card. |
270. Verify that the card supports local ND proxy. 271. Make sure the device has sufficient hardware resources. |
ND_MAC_CHECK
Message text |
Packet received on interface [STRING] was dropped because source MAC [STRING] was inconsistent with link-layer address [STRING]. |
Variable fields |
$1: Receiving interface of the ND packet. $2: Source MAC address in the Ethernet frame header of the ND packet. $3: Source link-layer address in the ND packet. |
Severity level |
6 |
Example |
ND/6/ND_MAC_CHECK: Packet received on interface Ethernet2/0/2 was dropped because source MAC 0002-0002-0001 was inconsistent with link-layer address 0002-0002-0002. |
Explanation |
The device dropped an ND packet because source MAC consistency check detected that the source MAC address and the source link-layer address in the packet are inconsistent. |
Verify the validity of the ND packet originator. |
ND_NETWORKROUTE_DUPLICATE
Message text |
Prefix [STRING] of the IPv6 ND network route matches different ports: [STRING] and [STRING]. |
Variable fields |
$1: IPv6 address prefix. $2: Interface name. $3: Interface name. |
Severity level |
5 |
Example |
ND/5/ND_NETWORKROUTE_DUPLICATE: Prefix 120::/70 of the IPv6 ND network route matches different ports: GigabitEthernet1/0/1 and GigabitEthernet1/0/2. |
Explanation |
This message is sent when a network route is generated for different ND entries of neighbors in the same VLAN but connected to different Layer 2 ports. |
Modify the network configuration. |
ND_RAGUARD_DROP
Message text |
Dropped RA messages with the source IPv6 address [STRING] on interface [STRING]. [STRING] messages dropped in total on the interface. |
Variable fields |
$1: IPv6 source IP address of the dropped RA messages. $2: Interface name on which the RA messages are dropped. $3: Total number of dropped RA messages on the interface. |
Severity level |
4 |
Example |
ND/4/ND_RAGUARD_DROP: Dropped RA messages with the source IPv6 address FE80::20 on interface GigabitEthernet1/0/1. 20 RA messages dropped in total on the interface. |
Explanation |
RA guard dropped RA messages and displayed the information when RA guard detected an attack. |
Verify the validity of the RA message originator. |
ND_RATE_EXCEEDED
Message text |
The ND packet rate ([UINT32] pps) exceeded the rate limit ([UINT32] pps) on interface [STRING] in most recent [UINT32] seconds. |
Variable fields |
$1: ND packet rate. $2: ND limit rate. $3: Interface name. $4: Interval time. |
Severity level |
4 |
Example |
ND/4/ND_RATE_EXCEEDED: The ND packet rate (100 pps) exceeded the rate limit (80 pps) on interface GigabitEthernet1/0/1 in most recent 10 seconds. |
Explanation |
An interface received ND messages at a rate higher than the rate limit. |
Verify that the hosts at the sender IP addresses are legitimate. |
ND_RATELIMIT_NOTSUPPORT
Message text |
Pattern 1: ND packet rate limit is not support on slot [INT32]. Pattern 2: ND packet rate limit is not support on chassis [INT32] slot [INT32]. |
Variable fields |
Pattern 1: $1: Slot number. Pattern 2: $1: Chassis number. $2: Slot number. |
Severity level |
6 |
Example |
ND/6/ND_RATELIMIT_NOTSUPPORT: ND packet rate limit is not support on slot 2. |
Explanation |
ND packet rate limit is not supported on the slot. |
ND_SET_PORT_TRUST_NORESOURCE
Message text |
Not enough resources to complete the operation. |
Variable fields |
N/A |
Severity level |
6 |
Example |
ND/6/ND_SET_PORT_TRUST_NORESOURCE: Not enough resources to complete the operation. |
Explanation |
Failed to execute the command because driver resources were not enough. |
Recommended action |
Release the driver resources and execute the command again. |
ND_SET_VLAN_REDIRECT_NORESOURCE
Message text |
Variable fields |
N/A |
Severity level |
6 |
Example |
ND/6/ND_SET_VLAN_REDIRECT_NORESOURCE: Not enough resources to complete the operation. |
Explanation |
ND_SNOOPING_LEARN_ALARM
Message text |
The total number of ND snooping entries learned in all VLANs reached or exceeded the alarm threshold. |
Variable fields |
N/A |
Severity level |
4 |
Example |
ND/4/ND_SNOOPING_LEARN_ALARM: -MDC=1; The total number of ND snooping entries learned in all VLANs reached or exceeded the alarm threshold. |
Explanation |
Examine whether an ND attack exists. |
ND_SNOOPING_LEARN_ALARM_RECOVER
Message text |
The total number of ND snooping entries learned in all VLANs dropped below the alarm threshold. |
Variable fields |
N/A |
Severity level |
4 |
Example |
ND/4/ND_SNOOPING_LEARN_ALARM_RECOVER: -MDC=1; The total number of ND snooping entries learned in all VLANs dropped below the alarm threshold. |
Explanation |
ND_USER_DUPLICATE_IPV6ADDR
Message text |
Detected a user IPv6 address conflict. New user (MAC [STRING], SVLAN [STRING], CVLAN [STRING]) on interface [STRING] and old user (MAC [STRING], SVLAN [STRING], CVLAN [STRING]) on interface [STRING] were using the same IPv6 address [IPV6ADDR]. |
Variable fields |
$1: MAC address of the new user. $2: SVLAN of the new user. $3: CVLAN of the new user. $4: Name of the interface connected to the new user. $5: MAC address of the old user. $6: SVLAN of the old user. $7: CVLAN of the old user. $8: Name of the interface connected to the old user. $9: IPv6 address of the user. |
Severity level |
6 |
Example |
ND/6/ND_USER_DUPLICATE_IPV6ADDR: Detected a user IPv6 address conflict. New user (MAC 0010-2100-01e1, SVLAN 100, CVLAN 10) on interface GigabitEthernet1/0/1 and old user (MAC 0120-1e00-0102, SVLAN 100, CVLAN 10) on interface GigabitEthernet1/0/1 were using the same IPv6 address 10::1. |
Explanation |
This message is sent when ND detects an IPv6 address conflict. |
Examine IPv6 addresses of all endpoint users, locate the address conflict reason, and take actions to remove the conflict. |
ND_USER_MOVE
Message text |
Detected a user (IPv6 address [IPV6ADDR], MAC address [STRING]) moved to another interface. Before user move: interface [STRING], SVLAN [STRING], CVLAN [STRING]. After user move: interface [STRING], SVLAN [STRING], CVLAN [STRING]. |
Variable fields |
$1: IPv6 address of the user. $2: MAC address of the user. $3: Interface name before the migration. $4: Old SVLAN of the user. $5: Old CVLAN of the user. $6: Interface name after the migration. $7: New SVLAN of the user. $8: New CVLAN of the user. |
Severity level |
6 |
Example |
ND/6/ND_USER_MOVE: Detected a user (IPv6 address 10::1, MAC address 0010-2100-01e1) moved to another interface. Before user move: interface GigabitEthernet1/0/1, SVLAN 100, CVLAN 20. After user move: interface GigabitEthernet1/0/2, SVLAN 100, CVLAN 10. |
Explanation |
This message is sent when ND detects that a user accesses the network through another port. |
Execute the display ipv6 nd user-move record command to verify that the migration is valid. |
ND_USER_OFFLINE
Message text |
Detected a user (IPv6 address [IPV6ADDR], MAC address [STRING]) was offline from interface [STRING]. |
Variable fields |
$1: IPv6 address of the offline user. $2: MAC address of the offline user. $3: Name of the interface connected to the offline user. |
Severity level |
6 |
Example |
ND/6/ND_USER_OFFLINE: Detected a user (IPv6 address 10::1, MAC address 0010-2100-01e1) was offline from interface GigabitEthernet1/0/1. |
Explanation |
This message is sent when ND detects a user offline event. |
ND_USER_ONLINE
Message text |
Detected a user (IPv6 address [IPV6ADDR], MAC address [STRING]) was online on interface [STRING]. |
Variable fields |
$1: IPv6 address of the online user. $2: MAC address of the online user. $3: Name of the interface connected to the online user. |
Severity level |
6 |
Example |
ND/6/ND_USER_ONLINE: Detected a user (IPv6 address 10::1, MAC address 0010-2100-01e1) was online on interface GigabitEthernet1/0/1. |
Explanation |
This message is sent when ND detects a user online event. |
Verify the validity of the online user. |
NETCONF messages
This section contains NETCONF messages.
CLI
Message text |
User ([STRING], [STRING][STRING]) performed an CLI operation: [STRING] operation result=[STRING][STRING] |
Variable fields |
$1: Username or user line type. · If scheme login authentication was performed for the user, this field displays the username. · If no login authentication was performed or password authentication was performed, this field displays the user line type, such as VTY. $2: User IP address or user line type and relative number. · For a Telnet or SSH user, this field displays the IP address of the user. · For a user who logged in through the console or AUX port, this field displays the user line type and the relative line number, such as CON0. $3: ID of the NETCONF session. This field is not displayed for Web and RESTful sessions. $4: Message ID of the NETCONF request. This field is not displayed for Web and RESTful sessions. $5: Operation result, Succeeded or Failed. $6: Cause for an operation failure. This field is displayed only if the failure is caused by a known reason. |
Severity level |
6 |
Example |
XMLSOAP/6/CLI: -MDC=1; User (test, 169.254.5.222, session ID=1) performed an CLI operation: message ID=101, operation result=Succeeded. |
Explanation |
After a CLI command is executed by using NETCONF, the device outputs this message to show the operation result. |
EDIT-CONFIG
Message text |
User ([STRING], [STRING][STRING])[STRING] operation=[STRING] [STRING] [STRING], result=[STRING]. No attributes. Or: User ([STRING], [STRING],[STRING]),[STRING] operation=[STRING] [STRING] [STRING], result=[STRING]. Attributes: [STRING]. |
Variable fields |
$1: Username or user line type. ¡ If scheme login authentication was performed for the user, this field displays the username. ¡ If no login authentication was performed or password authentication was performed, this field displays the user line type, such as VTY. $2: User IP address or user line type and relative number. ¡ For a Telnet or SSH user, this field displays the IP address of the user. ¡ For a user who logged in through the console or AUX port, this field displays the user line type and the relative line number, such as CON0. $3: ID of the NETCONF session. This field is not displayed if the session does not have a session ID. $4: Message ID of the NETCONF request. This field is not displayed if the request does not have a message ID. $5: Name of a NETCONF row operation. $6: Module name and table name. $7: Index information. If there are multiple indexes, this field uses a comma as the delimiter. This field is displayed only when there are indexes. $8: Operation result, Succeeded or Failed. $9: Attribute column information. This field is displayed only when the operation configures an attribute column. |
Severity level |
6 |
Example |
XMLSOAP/6/EDIT-CONFIG: User (test, 192.168.100.20, session ID 1), message ID=1, operation=create Ifmgr/Interfaces (IfIndex="GigabitEthernet1/0/1"), result=Succeeded. Attributes: Description="This is Desc1", AdminDown=1, Speed=1. |
Explanation |
The device outputs this log message for each row operation for an <action> or <edit-config> operation. |
NETCONF_MSG_DEL
Message text |
A NETCONF message was dropped. Reason: Packet size exceeded the upper limit. |
Variable fields |
N/A |
Severity level |
7 |
Example |
NETCONF/7/NETCONF_MSG_DEL: A NETCONF message was dropped. Reason: Packet size exceeded the upper limit. |
Explanation |
The system dropped a NETCONF request message that was received from a NETCONF over SSH client or at the XML view. The reason is that the message size exceeded the upper limit. |
272. Reduce the size of the request message. For example, delete blank spaces, carriage returns, and tab characters. 273. Contact H3C Support to segment the request message and then re-encapsulate the segments before sending them to the device. |
THREAD
Message text |
Maximum number of NETCONF threads already reached. |
Variable fields |
N/A |
Severity level |
3 |
Example |
XMLCFG/3/THREAD: -MDC=1; Maximum number of NETCONF threads already reached. |
Explanation |
The number of NETCONF threads already reached the upper limit. |
Please try again later. |
NQA messages
This section contains NQA messages.
NQA_ENTRY_PROBE_RESULT
Message text |
Reaction entry [STRING] of NQA entry admin-name [STRING] operation-tag [STRING]: [STRING]. |
Variable fields |
$1: ID of the NQA reaction entry. $2: Admin name of the NQA entry. $3: Operation tag of the NQA entry. $4: Test result. The value can be: ¡ Probe-pass: Succeeded. ¡ Probe-fail: Failed. |
Severity level |
6 |
Example |
NQA/6/NQA_ENTRY_PROBE_RESULT: Reaction entry 1 of NQA entry admin-name 1 operation-tag 1: Probe-pass. |
Explanation |
A change in the monitoring result of an NQA reaction entry was detected. |
If the test result is Probe-pass, no action is required. If the test result is Probe-fail, check the network environment. |
NQA_LOG_UNREACHABLE
Message text |
Server [STRING] unreachable. |
Variable fields |
$1: IP address of the NQA server. |
Severity level |
6 |
Example |
NQA/6/NQA_LOG_UNREACHABLE: Server 192.168.30.117 unreachable. |
Explanation |
An unreachable server was detected. |
Check the network environment. |
NQA_START_FAILURE
Message text |
NQA entry ([STRING]-[STRING]): [STRING] |
Variable fields |
$1: Admin name of the NQA operation. $2: Operation tag of the NQA operation. $3: Failure reason: ¡ Operation failed due to configuration conflicts. ¡ Operation failed because the driver was not ready to perform the operation. ¡ Operation not supported. ¡ Not enough resources to complete the operation. ¡ Operation failed due to an unknown error. |
Severity level |
6 |
Example |
NQA/6/NQA_START_FAILURE: NQA entry 1-1: Operation failed due to configuration conflicts. |
Explanation |
The message is sent when the system fails to issue an NQA operation to the drive because of the configuration conflicts. |
274. Examine the parameters for the incorrect settings, modify the settings, and restart the Y.1564 operation. 275. If the problem persists, contact H3C Support. |
NQA_TWAMP_LIGHT_PACKET_INVALID
Message text |
NQA TWAMP Light test session [UINT32] index [UINT32]: The number of packets captured for statistics collection is invalid. |
Variable fields |
$1: Test session ID. $2: Serial number of the statistics data. |
Severity level |
6 |
Example |
NQA/6/ NQA_TWAMP_LIGHT_PACKET_INVALID: NQA TWAMP Light test session 1 index 7: The number of packets captured for statistics collection is invalid. |
Explanation |
The number of probe packets was invalid in the TWAMP Light test because the test collection interval was shorter than the packet sending interval. |
Verify that the test collection interval is no less than the packet sending interval. |
NQA_TWAMP_LIGHT_REACTION
Message text |
NQA TWAMP Light test session [UINT32] reaction entry [UINT32]: Detected continual violation of the [STRING] [STRING] threshold for a threshold violation monitor time of [UINT32] ms. |
Variable fields |
$1: Test session ID. $2: Reaction entry ID. $3: Reaction entry type: ¡ Two-way delay. ¡ Two-way loss. ¡ Two-way jitter. $4: Threshold violation value: ¡ upper—Be equal to or greater than the upper threshold limit. ¡ lower—Be equal to or less than the lower threshold limit. $5: Statistics collection interval. |
Severity level |
6 |
Example |
NQA/6/NQA_TWAMP_LIGHT_REACTION: NQA TWAMP Light test session 1 reaction entry 1: Detected continual violation of the two-way loss upper threshold for a threshold violation monitor time of 2000 ms. |
Explanation |
In a TWAMP test, the device monitors the test result, and starts the monitoring time when either of the following conditions is met: · The monitoring result goes beyond the upper threshold limit. · The monitoring result drops below the lower threshold limit from a monitoring result higher than the lower limit. If either condition is always true during the monitoring time, a threshold violation occurs. |
No action is required. |
NQA_TWAMP_LIGHT_START_FAILURE
Message text |
NQA TWAMP Light test session [UINT32]: Failed to start the test session. Please check the parameters. |
Variable fields |
$1: Test session ID. |
Severity level |
6 |
Example |
NQAS/6/NQA_TWAMP_LIGHT_START_FAILURE: NQA TWAMP Light test session 1: Failed to start the test session, Please check the parameters. |
Explanation |
This message is sent when the TWAMP Light responder failed to start the test session. The message asks you to examine the parameter settings. |
276. Execute the display this command to examine the parameter settings of the test-session command. 277. Re-execute the test-session command with the required parameters according to your network requirements. |
NSS messages
This section contains session-based NetStream messages.
NSS_ENABLE_FAIL
Message text |
Failed to apply the command session-based netstream enable to the driver. Reason: [STRING]. |
Variable fields |
$1: Failure reason: ¡ The operation is not supported. ¡ The operation conflicts with existing configuration. |
Severity level |
4 |
Example |
NSS/4/NSS_ENABLE_FAIL: Failed to apply the command session-based netstream enable to the driver. Reason: The operation is not supported. |
Explanation |
This message is sent when the system fails to issue the command session-based netstream enable to the driver. |
· Verify that the NetStream interface module is present on the device, and then issue the command again. · Verify that sFlow and NetStream are disabled on the device. |
NSS_SESSION_TIMEOUT_FAIL
Message text |
Failed to apply the command session-based netstream session-timeout to the driver. Reason: [STRING]. |
Variable fields |
$1: Failure reason: ¡ The operation is not supported. |
Severity level |
4 |
Example |
NSS/4/NSS_SESSION_TIMEOUT_FAIL: Failed to apply the command session-based netstream session-timeout to the driver. Reason: The operation is not supported. |
Explanation |
This message is sent when the system fails to issue the command session-based netstream session-timeout to the driver. |
Verify that the NetStream interface module is present on the device, and then issue the command again. |
NTP messages
This section contains NTP messages.
NTP_CLOCK_CHANGE
Message text |
System clock changed from [STRING] to [STRING], the NTP server's IP address is [STRING]. |
Variable fields |
$1: Time before synchronization. $2: Time after synchronization. $3: IP address. |
Severity level |
5 |
Example |
NTP/5/NTP_CLOCK_CHANGE: System clock changed from 02:12:58 12/28/2012 to 02:29:12 12/28/2012, the NTP server's IP address is 192.168.30.116. |
Explanation |
The NTP client has synchronized its time to the NTP server. |
NTP_LEAP_CHANGE
Message text |
System Leap Indicator changed from [UINT32] to [UINT32] after clock update. |
Variable fields |
$1: Original Leap Indicator. $2: Current Leap Indicator. |
Severity level |
5 |
Example |
NTP/5/NTP_LEAP_CHANGE: System Leap Indicator changed from 00 to 01 after clock update. |
Explanation |
The system Leap Indicator changed. For example, the NTP status changed from unsynchronized to synchronized. NTP Leap Indicator is a two-bit code warning of an impending leap second to be inserted in the NTP timescale. The bits are set before 23:59 on the day of insertion and reset after 00:00 on the following day. This causes the number of seconds (rolloverinterval) in the day of insertion to be increased or decreased by one. |
NTP_SOURCE_CHANGE
Message text |
NTP server's IP address changed from [STRING] to [STRING]. |
Variable fields |
$1: IP address of the original time source. $2: IP address of the new time source. |
Severity level |
5 |
Example |
NTP/5/NTP_SOURCE_CHANGE: NTP server's IP address changed from 1.1.1.1 to 1.1.1.2. |
Explanation |
The system changed the time source. |
NTP_SOURCE_LOST
Message text |
Lost synchronization with NTP server with IP address [STRING]. |
Variable fields |
$1: IP address. |
Severity level |
5 |
Example |
NTP/5/NTP_SOURCE_LOST: Lost synchronization with NTP server with IP address 1.1.1.1. |
Explanation |
The clock source of the NTP association is in unsynchronized state or it is unreachable. |
278. Verify the NTP server and network connection. 279. For NTP server failures: ¡ Use the ntp-service unicast-server command to specify a new NTP server. ¡ Use the ntp-service multicast-client command to configure the device to operate in NTP multicast client mode and receive NTP multicast packets from a new NTP server. 280. If the problem persists, contract H3C Support. |
NTP_STRATUM_CHANGE
Message text |
System stratum changed from [UINT32] to [UINT32] after clock update. |
Variable fields |
$1: Original stratum. $2: Current stratum. |
Severity level |
5 |
Example |
NTP/5/NTP_STRATUM_CHANGE: System stratum changed from 6 to 5 after clock update. |
Explanation |
System stratum has changed. |
OAP messages
This section contains OAP messages.
OAP_CLIENT_DEREG
Message text |
OAP client [UINT32] on interface [STRING] deregistered. |
Variable fields |
$1: Client ID. $2: Interface type and name. |
Severity level |
5 |
Example |
OAP/5/OAP_CLIENT_DEREG: OAP client 1 on interface GigabitEthernet1/0/24 deregistered. |
Explanation |
The OAP client on an interface deregistered. |
Check the login information of the OAP client. |
OAP_CLIENT_TIMEOUT
Message text |
OAP client [UINT32] on interface [STRING] timed out. |
Variable fields |
Severity level |
4 |
Example |
OAP/4/OAP_CLIENT_TIMEOUT: OAP client 1 on interface GigabitEthernet1/0/24 timed out. |
Explanation |
The OAP client on an interface was timed out. |
Verify that the link is up. |
OBJP messages
This section contains object policy messages.
OBJP_ACCELERATE_NO_RES
Message text |
Failed to accelerate [STRING] object-policy [STRING]. The resources are insufficient. |
Variable fields |
$1: Object policy version. $2: Object policy name. |
Severity level |
4 |
Example |
OBJP/4/OBJP_ACCELERATE_NO_RES: Failed to accelerate IPv6 object-policy a. The resources are insufficient. |
Explanation |
Object policy acceleration failed because of insufficient hardware resources. |
Delete unnecessary rules or disable acceleration for other object policies to release hardware resources. |
OBJP_ACCELERATE_NOT_SUPPORT
Message text |
Failed to accelerate [STRING] object-policy [STRING]. The operation is not supported. |
Variable fields |
Severity level |
4 |
Example |
OBJP/4/OBJP_ACCELERATE_NOT_SUPPORT: Failed to accelerate IPv6 object-policy a. The operation is not supported. |
Explanation |
Object policy acceleration failed because the system did not support acceleration. |
OBJP_ACCELERATE_UNK_ERR
Message text |
Failed to accelerate [STRING] object-policy [STRING]. |
Variable fields |
Severity level |
4 |
Example |
OBJP/4/OBJP_ACCELERATE_UNK_ERR: Failed to accelerate IPv6 object-policy a. |
Explanation |
Object policy acceleration failed because of a system failure. |
OFP messages
This section contains OpenFlow messages.
OFP_ACTIVE
Message text |
Activate openflow instance [UINT16]. |
Variable fields |
$1: Instance ID. |
Severity level |
5 |
Example |
OFP/5/OFP_ACTIVE: Activate openflow instance 1. |
Explanation |
A command is received from comsh to activate an OpenFlow instance. |
OFP_ACTIVE_FAILED
Message text |
Failed to activate instance [UINT16]. |
Variable fields |
$1: Instance ID. |
Severity level |
4 |
Example |
OFP/4/OFP_ACTIVE_FAILED: Failed to activate instance 1. |
Explanation |
An OpenFlow instance cannot be activated. |
OFP_CONNECT
Message text |
Openflow instance [UINT16], controller [CHAR] is [STRING]. |
Variable fields |
$1: Instance ID. $2: Controller ID. $3: Connection status: connected or disconnected. |
Severity level |
5 |
Example |
OFP/5/OFP_CONNECT: Openflow instance 1, controller 0 is connected. |
Explanation |
The connection status with a controller is changed in an OpenFlow instance. |
OFP_FAIL_OPEN
Message text |
Openflow instance [UINT16] is in fail [STRING] mode. |
Variable fields |
$1: Instance ID. $2: Connection interruption mode: secure or standalone. |
Severity level |
5 |
Example |
OFP/5/OFP_FAIL_OPEN: Openflow instance 1 is in fail secure mode. |
Explanation |
An activated instance cannot connect to any controller or is disconnected from all controllers. The connection interrupt mode is also displayed. |
OFP_FLOW_ADD
Message text |
Openflow instance [UINT16] controller [CHAR]: add flow entry [UINT32], xid 0x[HEX], cookie 0x[HEX], table id [CHAR]. |
Variable fields |
$1: Instance ID. $2: Controller ID. $3: Rule ID. $4: XID. $5: Cookie of the flow entry. $6: Table ID. |
Severity level |
5 |
Example |
OFP/5/OFP_FLOW_ADD: Openflow instance 1 controller 0: add flow entry 1, xid 0x1, cookie 0x0, table id 0. |
Explanation |
A flow entry is to be added to a flow table, according to a flow table modification message that has passed the packet check. |
OFP_FLOW_ADD_ARP_FAILED
Message text |
Failed to add OpenFlow ARP entry: IPAddr=[STRING], OutIfIndex=[UINT32], MACAddr=[STRING]. |
Variable fields |
$1: IP address in an OpenFlow ARP entry. $2: Index of the outgoing interface in the OpenFlow ARP entry. $3: MAC address in the OpenFlow ARP entry. |
Severity level |
5 |
Example |
OFP/5/OFP_FLOW_ADD_ARP_FAILED: Failed to add OpenFlow ARP entry: IPAddr=102.0.1.1, OutIfIndex=605, MACAddr=0002-0300-0002. |
Explanation |
Failed to add an OpenFlow ARP entry. |
Contact the technical support. |
OFP_FLOW_ADD_DUP
Message text |
Variable fields |
$1: Instance ID. $2: Controller ID. $3: Rule ID. $4: XID. $5: Cookie. $6: Table ID. |
Severity level |
5 |
Example |
Explanation |
A duplicate flow entry was added. |
OFP_FLOW_ADD_FAILED
Message text |
Openflow instance [UINT16] controller [CHAR]: failed to add flow entry [UINT32],table id [CHAR],because of insufficient resources. |
Variable fields |
$1: Instance ID. $2: Controller ID. $3: Rule ID. $4: Table ID. |
Severity level |
4 |
Example |
OFP/4/OFP_FLOW_ADD_FAILED: Openflow instance 1 controller 0: failed to add flow entry 641,table id 0,because of insufficient resources. |
Explanation |
A flow entry failed to be added because of insufficient resources. |
OFP_FLOW_ADD_FAILED
Message text |
Openflow instance [UINT16] controller [CHAR]: failed to add flow entry [UINT32], table id [CHAR]. |
Variable fields |
Severity level |
4 |
Example |
OFP/4/OFP_FLOW_ADD_FAILED: Openflow instance 1 controller 0: failed to add flow entry1, table id 0. |
Explanation |
Failed to add a flow entry. |
OFP_FLOW_ADD_ND_FAILED
Message text |
Failed to add OpenFlow ND entry: IPv6Addr=[STRING], OutIfIndex=[UINT32], MACAddr=[STRING]. |
Variable fields |
$1: IPv6 address in an OpenFlow ND entry. $2: Index of the outgoing interface in the OpenFlow ND entry. $3: MAC address in the OpenFlow ND entry. |
Severity level |
5 |
Example |
OFP/5/OFP_FLOW_ADD_ND_FAILED: Failed to add OpenFlow ND entry: IPv6Addr=1:1::1:1, OutIfIndex=5, MACAddr=1-1-1. |
Explanation |
Failed to add an OpenFlow ND entry. |
OFP_FLOW_ADD_TABLE_MISS
Message text |
Openflow instance [UINT16] controller [CHAR]: add table miss flow entry, xid 0x[HEX], cookie 0x[HEX], table id [CHAR]. |
Variable fields |
$1: Instance ID. $2: Controller ID. $3: XID. $4: Cookie of the flow entry. $5: Table ID. |
Severity level |
5 |
Example |
OFP/5/OFP_FLOW_ADD_TABLE_MISS: Openflow instance 1 controller 0: add table miss flow entry, xid 0x1, cookie 0x0, table id 0. |
Explanation |
A table-miss flow entry is to be added to a flow table, according to a flow table modification message that has passed the packet check. |
OFP_FLOW_ADD_TABLE_MISS_FAILED
Message text |
Openflow instance [UINT16] controller [CHAR]: failed to add table miss flow entry, table id [CHAR]. |
Variable fields |
$1: Instance ID. $2: Controller ID. $3: Table ID. |
Severity level |
4 |
Example |
OFP/4/OFP_FLOW_ADD_TABLE_MISS_FAILED: Openflow instance 1 controller 0: failed to add table miss flow entry, table id 0. |
Explanation |
Failed to add a table-miss flow entry. |
OFP_FLOW_DEL
Message text |
Openflow instance [UINT16] controller [CHAR]: delete flow entry, xid 0x[HEX], cookie 0x[HEX], table id [STRING]. |
Variable fields |
Severity level |
5 |
Example |
OFP/5/OFP_FLOW_DEL: Openflow instance 1 controller 0: delete flow entry, xid 0x1, cookie 0x0, table id 0. |
Explanation |
A list of flow entries are to be deleted, according to a flow table modification message that has passed the packet check. |
OFP_FLOW_DEL_L2VPN_DISABLE
Message text |
[UINT32] flow entries in table [UINT8] of instance [UINT16] were deleted because L2VPN was disabled. |
Variable fields |
$1: Total number of deleted flow entries. $2: Table ID. $3: Instance ID. |
Severity level |
5 |
Example |
OFP/5/OFP_FLOW_DEL_L2VPN_DISABLE: 2 flow entries in table 1 of instance 1 were deleted because L2VPN was disabled. |
Explanation |
Multiple OpenFlow flow entries were deleted because L2VPN was disabled. |
OFP_FLOW_DEL_TABLE_MISS
Message text |
Openflow instance [UINT16] controller [CHAR]: delete table miss flow entry, xid 0x[HEX], cookie 0x[HEX], table id [STRING]. |
Variable fields |
Severity level |
5 |
Example |
OFP/5/OFP_FLOW_DEL_TABLE_MISS: Openflow instance 1 controller 0: delete table miss flow entry, xid 0x1, cookie 0x0, table id 0. |
Explanation |
A list of table-misses flow entries are to be deleted, according to a flow table modification message that has passed the packet check. |
OFP_FLOW_DEL_TABLE_MISS_FAILED
Message text |
Openflow instance [UINT16] controller [CHAR]: failed to delete table miss flow entry, table id [STRING]. |
Variable fields |
Severity level |
4 |
Example |
OFP/4/OFP_FLOW_DEL_TABLE_MISS_FAILED: Openflow instance 1 controller 0: failed to delete table miss flow entry, table id 0. |
Explanation |
Failed to delete a table-miss flow entry. |
OFP_FLOW_DEL_VXLAN_DEL
Message text |
[UINT32] flow entries in table [UINT8] of instance [UINT16] were deleted because a tunnel (ifindex [UINT32]) in VXLAN [UINT32] was deleted. |
Variable fields |
$1: Total number of deleted flow entries. $2: Table ID. $3: Instance ID. $4: Index of a tunnel interface. $5: VXLAN ID. |
Severity level |
5 |
Example |
OFP/5/OFP_FLOW_DEL_VXLAN_DEL: 2 flow entries in table 1 of instance 1 were deleted because a tunnel (ifindex 141) in VXLAN 1 was deleted. |
Explanation |
Multiple OpenFlow flow entries were deleted because a VXLAN tunnel was deleted. |
OFP_FLOW_MOD
Message text |
Openflow instance [UINT16] controller [CHAR]: modify flow entry, xid 0x[HEX], cookie 0x[HEX], table id [CHAR]. |
Variable fields |
Severity level |
5 |
Example |
OFP/5/OFP_FLOW_MOD: Openflow instance 1 controller 0: modify flow entry, xid 0x1, cookie 0x0, table id 0. |
Explanation |
A list of flow entries are to be modified, according to a flow table modification message that has passed the packet check. |
OFP_FLOW_MOD_FAILED
Message text |
Openflow instance [UINT16] controller [CHAR]: failed to modify flow entry, table id [CHAR]. |
Variable fields |
Severity level |
4 |
Example |
OFP/4/OFP_FLOW_MOD_FAILED: Openflow instance 1 controller 0: failed to modify flow entry, table id 0. |
Explanation |
Failed to modify a flow entry. |
The controller must retry to modify the flow entry. If the flow entry still cannot be modified, the controller will delete it. |
OFP_FLOW_MOD_TABLE_MISS
Message text |
Openflow instance [UINT16] controller [CHAR]: modify table miss flow entry, xid 0x[HEX], cookie 0x[HEX], table id [CHAR]. |
Variable fields |
Severity level |
5 |
Example |
OFP/5/OFP_FLOW_MOD_TABLE_MISS: Openflow instance 1 controller 0: modify table miss flow entry, xid 0x1, cookie 0x0, table id 0. |
Explanation |
OFP_FLOW_MOD_TABLE_MISS_FAILED
Message text |
Openflow instance [UINT16] controller [CHAR]: failed to modify table miss flow entry, table id [CHAR]. |
Variable fields |
Severity level |
4 |
Example |
OFP/4/OFP_FLOW_MOD_TABLE_MISS_FAILED: Openflow instance 1 controller 0: failed to modify table miss flow entry, table id 0. |
Explanation |
Failed to modify a table-miss flow entry. |
The controller must retry to modify the table-miss flow entry. If the entry still cannot be modified, the controller will delete it. |
OFP_FLOW_RMV_GROUP
Message text |
The flow entry [UINT32] in table [CHAR] of instance [UINT16] was deleted with a group_mod message. |
Variable fields |
$1: Rule ID. $2: Table ID. $3: Instance ID. |
Severity level |
5 |
Example |
Explanation |
A flow entry was deleted due to a group modification message. |
OFP_FLOW_RMV_HARDTIME
Message text |
Variable fields |
Severity level |
5 |
Example |
Explanation |
A flow entry was deleted because of a hard time expiration. |
OFP_FLOW_RMV_IDLETIME
Message text |
Variable fields |
Severity level |
5 |
Example |
Explanation |
A flow entry was deleted because of an idle time expiration. |
OFP_FLOW_RMV_METER
Message text |
The flow entry [UINT32] in table [CHAR] of instance [UINT16] was deleted with a meter_mod message. |
Variable fields |
Severity level |
5 |
Example |
Explanation |
A flow entry was deleted due to a meter modification message. |
OFP_FLOW_UPDATE_FAILED
Message text |
OpenFlow instance [UINT16] table [CHAR]: failed to update or synchronize flow entry [UINT32]. |
Variable fields |
$1: Instance ID. $2: Table ID. $3: Flow entry ID. |
Severity level |
4 |
Example |
OFP/4/OFP_FLOW_SMOOTH_FAILED: OpenFlow instance 1 table 0: failed to update or synchronize flow entry 10000. |
Explanation |
When an active/standby switchover occurred, the new active MPU failed to update flow entries. When a new interface card was installed on the device, the interface card failed to synchronize flow entries from the MPUs. When a master/subordinate switchover occurred in an IRF fabric, the new master device failed to update flow entries. When new member devices joined an IRF fabric, the new member devices failed to synchronize flow entries from the master device. |
Delete the flow entries that fail to be deployed. |
OFP_GROUP_ADD
Message text |
Openflow instance [UINT16] controller [CHAR]: add group [STRING], xid 0x[HEX]. |
Variable fields |
$1: Instance ID. $2: Controller ID. $3: Group ID. $4: XID. |
Severity level |
5 |
Example |
OFP/5/OFP_GROUP_ADD: Openflow instance 1 controller 0: add group 1, xid 0x1. |
Explanation |
A group entry is to be added to a group table, according to a group table modification message that has passed the packet check. |
OFP_GROUP_ADD_FAILED
Message text |
Openflow instance [UINT16] controller [CHAR]: failed to add group [STRING]. |
Variable fields |
$1: Instance ID. $2: Controller ID. $3: Group ID. |
Severity level |
4 |
Example |
OFP/4/OFP_GROUP_ADD_FAILED: Openflow Instance 1 controller 0: failed to add group 1. |
Explanation |
Failed to add a group entry. |
OFP_GROUP_DEL
Message text |
Openflow instance [UINT16] controller [CHAR]: delete group [STRING], xid [HEX]. |
Variable fields |
Severity level |
5 |
Example |
OFP/5/OFP_GROUP_DEL: Openflow instance 1 controller 0: delete group 1, xid 0x1. |
Explanation |
A group entry is to be deleted, according to a group table modification message that has passed the packet check. |
OFP_GROUP_MOD
Message text |
Openflow instance [UINT16] controller [CHAR]: modify group [STRING], xid 0x[HEX]. |
Variable fields |
Severity level |
5 |
Example |
OFP/5/OFP_GROUP_MOD: Openflow instance 1 controller 0: modify group 1, xid 0x1. |
Explanation |
A group entry is to be modified, according to a group table modification message that has passed the packet check. |
OFP_GROUP_MOD_FAILED
Message text |
Openflow instance [UINT16] controller [CHAR]: failed to modify group [STRING]. |
Variable fields |
Severity level |
4 |
Example |
OFP/4/OFP_GROUP_MOD_FAILED: Openflow instance 1 controller 0: failed to modify group 1. |
Explanation |
Failed to modify a group entry. |
The controller must retry to modify the group. If the group still cannot be modified, the controller will delete it. |
OFP_GROUP_REFRESH_FAILED
Message text |
Openflow instance [STRING]:Failed to refresh group [STRING]. |
Variable fields |
$1: Instance ID. $2: Group ID. |
Severity level |
4 |
Example |
OFP/4/OFP_GROUP_REFRESH_FAILED: Openflow instance 1:Failed to refresh group 1. |
Explanation |
After the controller successfully deploys a group to the device, the interface information of some buckets in the group must be refreshed if interface cards are plugged or unplugged or interfaces are deleted or re-created on the device. However, the group fails to be refreshed because the hardware resources are insufficient or the device fails. |
OFP_GROUP_ROLLBACK_FAILED
Message text |
Openflow instance [STRING]:Failed to roll back group [STRING]. |
Variable fields |
Severity level |
4 |
Example |
OFP/4/OFP_GROUP_ROLLBACK_FAILED: Openflow instance 1:Failed to roll back group 1. |
Explanation |
When the controller fails to modify the group of the device, the device needs to roll the group back to the status before modification. However, rolling back the group fails because the hardware resources are insufficient or the device fails. |
OFP_METER_ADD
Message text |
Openflow instance [UINT16] controller [CHAR]: add meter [STRING], xid 0x[HEX]. |
Variable fields |
$1: Instance ID. $2: Controller ID. $3: Meter ID. $4: XID. |
Severity level |
5 |
Example |
OFP/5/OFP_METER_ADD: Openflow instance 1 controller 0: add meter 1, xid 0x1. |
Explanation |
A meter entry is to be added to a meter table. |
OFP_METER_ADD_FAILED
Message text |
Openflow instance [UINT16] controller [CHAR]: failed to add meter [STRING]. |
Variable fields |
$1: Instance ID. $2: Controller ID. $3: Meter ID. |
Severity level |
4 |
Example |
OFP/4/OFP_METER_ADD_FAILED: Openflow Instance 1 controller 0: failed to add meter 1. |
Explanation |
Failed to add a meter entry. |
OFP_METER_DEL
Message text |
Openflow instance [UINT16] controller [CHAR]: delete meter [STRING], xid 0x[HEX]. |
Variable fields |
Severity level |
5 |
Example |
OFP/5/OFP_METER_DEL: Openflow instance 1 controller 0: delete meter 1, xid 0x1. |
Explanation |
A meter entry is to be deleted, according to a meter table modification message that has passed the packet check. |
OFP_METER_MOD
Message text |
Openflow instance [UINT16] controller [CHAR]: modify meter [STRING], xid 0x[HEX]. |
Variable fields |
Severity level |
5 |
Example |
OFP/5/OFP_METER_MOD: Openflow Instance 1 controller 0: modify meter 1, xid 0x1. |
Explanation |
A meter entry is to be modified, according to a meter table modification message that has passed the packet check. |
OFP_METER_MOD_FAILED
Message text |
Openflow instance [UINT16] controller [CHAR]: failed to modify meter [STRING]. |
Variable fields |
Severity level |
4 |
Example |
OFP/4/OFP_METER_MOD_FAILED: Openflow instance 1 controller 0: failed to modify meter 1. |
Explanation |
Failed to modify a meter entry. |
The controller must retry to modify the meter entry. If the meter entry still cannot be modified, the controller will delete it. |
OFP_MISS_RMV_GROUP
Message text |
The table-miss flow entry in table [CHAR] of instance [UINT16] was deleted with a group_mod message. |
Variable fields |
$1: Table ID. $2: Instance ID. |
Severity level |
5 |
Example |
Explanation |
The table-miss flow entry was deleted due to a group modification message. |
OFP_MISS_RMV_HARDTIME
Message text |
Variable fields |
Severity level |
5 |
Example |
Explanation |
The table-miss flow entry was deleted because of a hard time expiration. |
OFP_MISS_RMV_IDLETIME
Message text |
Variable fields |
Severity level |
5 |
Example |
Explanation |
The table-miss flow entry was deleted because of an idle time expiration. |
OFP_MISS_RMV_METER
Message text |
The table-miss flow entry in table [CHAR] of instance [UINT16] was deleted with a meter_mod message. |
Variable fields |
Severity level |
5 |
Example |
Explanation |
The table-miss flow entry was deleted due to a meter modification message. |
OFP_RADARDETECTION
Message text |
inIfIndex = [UINT32], packageId = [UINT16], innerTTL = [CHAR], outerTTL = [CHAR]. |
Variable fields |
$1: Index of the ingress port of the packet. $2: Packet identifier. $3: Time To Live value in the inner IP header of the packet. $4: Time To Live value in the outer IP header of the packet. |
Severity level |
5 |
Example |
OFP/5/OFP_RADARDETECTION: inIfIndex = 1, packageId = 1, innerTTL = 128, outerTTL = 128. |
Explanation |
A packet used for radar detection or VM simulation was received. |
PORT_MOD
Message text |
Port modified. InstanceID =[UINT16], IfIndex =[UINT32], PortDown=[STRING], NoRecv=[STRING], NoFwd=[STRING], NoPktIn=[STRING], Speed=[STRING], Duplex=[STRING]. |
Variable fields |
$1: Instance ID. $2: Interface index. $3: Whether to set the status of the interface to down: · NoChange—Does not change the status of the interface. · True—Sets the status of the interface to down. · False—Sets the status of the interface to up. $4: Whether to disable the interface from receiving packets: · NoChange—Does not change the setting of the interface. · True—Disables the interface from receiving packets. · False—Enables the interface to receive packets. $5: Whether to disable the interface from forwarding packets: · NoChange—Does not change the setting of the interface. · True—Disables the interface from forwarding packets. · False—Enables the interface to forward packets. $6: Whether to disable the interface from sending packets to the controller: · NoChange—Does not change the setting of the interface. · True—Disables the interface from sending packets to the controller. · False—Enables the interface to send packets to the controller. $7: Sets the speed of the interface. An empty field means that the interface speed is not set. The field has the following possible values: · Auto—Enables the interface to negotiate a speed with its peer. · Error—Sets the interface speed to an unsupported value. · 10M—Sets the interface speed to 10 Mbps. · 100M—Sets the interface speed to 100 Mbps. · 1G—Sets the interface speed to 1 Gbps. · 10G—Sets the interface speed to 10 Gbps. $8: Sets the duplex mode of the interface. An empty filed means that the duplex mode of the interface is not set. The field has the following possible values: · Full—Configures the interface to operate in full duplex mode. · Half—Configures the interface to operate in half duplex mode. · Auto—Configures the interface to negotiate the duplex mode with the peer. · Error—Configures the interface to operate in an unsupported duplex mode. |
Severity level |
5 |
Example |
OFP/5/PORT_MOD: Port modified. InstanceID =1, IfIndex =2, PortDown=True, NoRecv=NoChange, NoFwd=NoChange, NoPktIn=NoChange, Speed=, Duplex=. |
Explanation |
The controller modified the settings of an interface in an OpenFlow instance. |
OPENSRC (FreeRADIUS) messages
This section contains FreeRADIUS system log messages.
HUP event
Message text |
[DATE] [TIME] radiusd[UINT32]: [STRING] |
Variable fields |
$1: Date in month abbreviation and day format. $2: Time in hh:mm:ss format. $3: FreeRADIUS process ID. $4: HUP event description, as listed in Table 6. |
Severity level |
6 |
Example |
OPENSRC/6/SYSLOG: Jan 1 01:14:04 radiusd[427]: Received HUP sign |
Explanation |
A HUP signal was received and the user configuration was reloaded for authentication, including the user name, password, authorization VLAN, authorization ACL, and user validity period. The HUP signal could be ignored if it arrived in less than 5 seconds since the last signal reception. |
For the recommended action for each event, see Table 6. |
Explanation |
Received HUP sign |
A HUP signal was received. |
Module: Reloaded module "files" |
The module configuration file was reloaded. |
HUP - Files loaded by a module have changed. |
A HUP signal was received and the configuration file was reloaded. |
Ignoring HUP (less than 5s since last one) |
The HUP signal was ignored because it was less than 5 seconds since the last signal reception. |
To immediately activate the new user configuration, use the radius-server activate command. |
Process restart event
Message text |
Variable fields |
$1: Date in month abbreviation and day format. $2: Time in hh:mm:ss format. $3: FreeRADIUS process ID. $4: Process restart event description, as listed in Table 7. |
Severity level |
6 |
Example |
OPENSRC/6/SYSLOG: Jan 1 02:00:02 radiusd[427]: Signalled to terminate |
Explanation |
The current process was terminated and restarted. |
Table 7 Process restart events
Process restart event |
Explanation |
A process termination signal was received. |
Exiting normally |
The process was closed. |
Debugger not attached |
Debugging was disabled for the process. |
Loaded virtual server <default> |
The virtual server was loaded. |
Loaded virtual server inner-tunnel |
The inner tunnel of the virtual server was loaded. |
Loaded virtual server default |
The default configuration of the virtual server was loaded. |
Ready to process requests |
Ready to process authentication packets. |
Process start event
Message text |
Variable fields |
$1: Date in month abbreviation and day format. $2: Time in hh:mm:ss format. $3: FreeRADIUS process ID. $4: Process restart event description, as listed in Table 8. |
Severity level |
4 |
Example |
OPENSRC/4/SYSLOG: Jan 1 02:00:03 radiusd[460]: [//etc/raddb/mods-config/attr_filter/access_reject]:11 Check item "FreeRADIUS-Response-Delay" found in filter list for realm "DEFAULT". |
Explanation |
The system loaded default filter options when the process started. |
Process start event |
Explanation |
The default filter option FreeRADIUS-Response-Delay was checked in the specified file. |
11 Check item "FreeRADIUS-Response-Delay-USec" found in filter list for realm "DEFAULT". |
The default filter option FreeRADIUS-Response-Delay-USec was checked in the specified file. |
Ignoring "sql" (see raddb/mods-available/README.rst) |
SQL was ignored. |
Ignoring "ldap" (see raddb/mods-available/README.rst) |
LDAP was ignored. |
User authentication
Message text |
[DATE] [TIME] radiusd[UINT32]: ([UINT32]) [STRING]: [[STRING]] (from client [IPADDR] port [UINT32] cli [MAC]) |
Variable fields |
$1: Date in month abbreviation and day format. $2: Time in hh:mm:ss format. $3: FreeRADIUS process ID. $4: Log ID. $5: Authentication result. $6: User name. $7: RADIUS client IP address. $8: RADIUS client port number. $9: User's MAC address. |
Severity level |
5 |
Example |
OPENSRC/5/SYSLOG: Jan 1 02:06:15 radiusd[460]: (0) Login OK: [test] (from client 7.7.7.7 port 33591297 cli 00-00-00-00-00-02) |
Explanation |
User authentication succeeded. |
For the recommended action for each authentication result, see Table 9. |
Table 9 Authentication results
Authentication result |
Explanation |
Login OK |
Authentication succeeded or shared key mismatch occurred. |
· If user authentication succeeded, no action is required. · If user authentication failed, verify that the
RADIUS client and server use the same shared key. |
Login incorrect (pap: Cleartext password does not match "known good" password) |
Incorrect password for PAP authentication. |
Provide the correct user password. |
Login incorrect (chap: Password comparison failed: password is incorrect) |
Incorrect password for CHAP authentication. |
Login incorrect (No Auth-Type found: rejecting the user via Post-Auth-Type = Reject) |
User name mismatch occurred during PAP authentication, or the EAP authentication type was specified for an 802.1X user. |
· If the user is unauthorized and should be ignored, no action is required. · If the user is new and should be authenticated, create a local user account for it by using the local-user command. · If a configuration error has occurred, modify the authentication type. For example, check the authentication type of 802.1X users by using the display dot1x command, and then modify the authentication type by using the authentication-method command. |
Login incorrect (chap: &control:Cleartext-Password is required for authentication) |
User name mismatch occurred during CHAP authentication. |
· If the user is unauthorized and should be ignored, no action is required. · If the user is new and should be authenticated, create a local user account for it by using the local-user command. |
Invalid user (expiration: Account expired at 'Jan 1 2013 02:19:00 UTC') |
The user had expired. |
· To ignore the expired user, no action is required. · To extend the validity, modify the expiration period of the local user by using the validity-datetime command. |
Message text |
[DATE] [TIME] radiusd[UINT32]: ([UINT32]) Login incorrect (No Auth-Type found: rejecting the user via Post-Auth-Type = Reject): [[STRING]] (from client [IPADDR] port [UINT32]) |
Variable fields |
$1: Date in month abbreviation and day format. $2: Time in hh:mm:ss format. $3: FreeRADIUS process ID. $4: Log ID. $5: User name. $6: RADIUS client IP address. $7: RADIUS client port number. |
Severity level |
5 |
Example |
OPENSRC/5/SYSLOG: Jan 1 02:21:20 radiusd[460]: (16) Login incorrect (No Auth-Type found: rejecting the user via Post-Auth-Type = Reject): [ddd] (from client 7.7.7.7 port 0) |
Explanation |
Authentication requests of login users were not supported. |
Message text |
[DATE] [TIME] radiusd[UINT32]: Ignoring request to auth address * port 1812 bound to server default from unknown client [IPADDR] port [UINT32] proto udp |
Variable fields |
$1: Date in month abbreviation and day format. $2: Time in hh:mm:ss format. $3: FreeRADIUS process ID. $4: RADIUS client IP address. $5: RADIUS client port number. |
Severity level |
3 |
Example |
OPENSRC/3/SYSLOG: Jan 1 02:31:05 radiusd[548]: Ignoring request to auth address * port 1812 bound to server default from unknown client 7.7.7.7 port 11969 proto udp |
Explanation |
The authentication request was sent from an unknown client and was ignored. |
· If the client cannot be trusted, no action is required. · If the client is new and safe, add the RADIUS client configuration by using the radius-server client command. |
OPTMOD messages
This section contains transceiver module messages.
BIAS_HIGH
Message text |
[STRING]: Bias current is high. |
Variable fields |
$1: Interface type and number. |
Severity level |
2 |
Example |
OPTMOD/2/BIAS_HIGH: GigabitEthernet1/0/1: Bias current is high. |
Explanation |
The bias current of the transceiver module exceeded the high threshold. |
281. Execute the display transceiver diagnosis interface command to verify that the bias current of the transceiver module has exceeded the high threshold. 282. Execute the display transceiver alarm interface command to verify that a high bias current alarm for the transceiver module has been generated and not cleared. 283. Replace the transceiver module. |
BIAS_LOW
Message text |
[STRING]: Bias current is low. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/BIAS_LOW: GigabitEthernet1/0/1: Bias current is low. |
Explanation |
The bias current of the transceiver module went below the low threshold. |
284. Execute the display transceiver diagnosis interface command to verify that the bias current of the transceiver module is below the low threshold. 285. Execute the display transceiver alarm interface command to verify that a low bias current alarm for the transceiver module has been generated and not cleared. 286. Replace the transceiver module. |
BIAS_NORMAL
Message text |
[STRING]: Bias current is normal. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/BIAS_NORMAL: GigabitEthernet1/0/1: Bias current is normal. |
Explanation |
The bias current of the transceiver module returned to the acceptable range. |
CFG_ERR
Message text |
[STRING]: Transceiver type and port configuration mismatched. |
Variable fields |
Severity level |
3 |
Example |
OPTMOD/3/CFG_ERR: GigabitEthernet1/0/1: Transceiver type and port configuration mismatched. |
Explanation |
The transceiver module type does not match the port configurations. |
Check for the transceiver module type and the current port configurations. If they mismatch, replace the transceiver module or update the port configurations. |
CHKSUM_ERR
Message text |
[STRING]: Transceiver information checksum error. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/CHKSUM_ERR: GigabitEthernet1/0/1: Transceiver information checksum error . |
Explanation |
Checksum verification on the register information on the transceiver module failed. |
Replace the transceiver module, or contact H3C Support. |
FIBER_SFP MODULE_INVALID
Message text |
[STRING]: This transceiver module is not compatible with the interface card. HP does not guarantee the correct operation of the transceiver module. The transceiver module will be invalidated in [UINT32] days. Please replace it with a compatible one as soon as possible. |
Variable fields |
$1: Interface type and number. $2: Number of days that the transceiver module will be invalid. |
Severity level |
4 |
Example |
OPTMOD/4/FIBER_SFPMODULE_INVALID: GigabitEthernet1/0/1: This transceiver module is not compatible with the interface card. HP does not guarantee the correct operation of the transceiver module. The transceiver module will be invalidated in 3 days. Please replace it with a compatible one as soon as possible. |
Explanation |
The transceiver module is not compatible with the interface card. |
FIBER_SFPMODULE_NOWINVALID
Message text |
[STRING]: This is not a supported transceiver for this platform. HP does not guarantee the normal operation or maintenance of unsupported transceivers. Please review the platform datasheet on the HP web site or contact your HP sales rep for a list of supported transceivers. |
Variable fields |
Severity level |
4 |
Example |
OPTMOD/4/FIBER_SFPMODULE_NOWINVALID: GigabitEthernet1/0/1: This is not a supported transceiver for this platform. HP does not guarantee the normal operation or maintenance of unsupported transceivers. Please review the platform datasheet on the HP web site or contact your HP sales rep for a list of supported transceivers. |
Explanation |
The system does not support the transceiver module. |
IO_ERR
Message text |
[STRING]: The transceiver information I/O failed. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/IO_ERR: GigabitEthernet1/0/1: The transceiver information I/O failed. |
Explanation |
The device failed to access the register information of the transceiver module. |
Execute the display transceiver diagnosis interface and display transceiver alarm interface commands. If both commands fail to be executed, the transceiver module is faulty. Replace the transceiver module. |
MOD_ALM_OFF
Message text |
[STRING]: [STRING] was removed. |
Variable fields |
$1: Interface type and number. $2: Fault type. |
Severity level |
5 |
Example |
OPTMOD/5/MOD_ALM_OFF: GigabitEthernet1/0/1: Module_not_ready was removed.. |
Explanation |
A fault was removed from the transceiver module. |
MOD_ALM_ON
Message text |
[STRING]: [STRING] was detected. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/MOD_ALM_ON: GigabitEthernet1/0/1: Module_not_ready wasdetected. |
Explanation |
A fault was detected on the transceiver module. |
287. Execute the display transceive alarm interface command to verify that a corresponding alarm for the fault has been generated and not cleared. 288. Replace the transceiver module. |
MODULE_IN
Message text |
[STRING]: The transceiver is [STRING]. |
Variable fields |
$1: Interface type and number. $2: Type of the transceiver module. |
Severity level |
4 |
Example |
OPTMOD/4/MODULE_IN: GigabitEthernet1/0/1: The transceiver is 1000_BASE_T_AN_SFP. |
Explanation |
When a transceiver module is inserted, the OPTMOD module generates the message to display the transceiver module type. |
MODULE_OUT
Message text |
[STRING]: Transceiver absent. |
Variable fields |
Severity level |
4 |
Example |
OPTMOD/4/MODULE_OUT: GigabitEthernet1/0/1: The transceiver is absent. |
Explanation |
The transceiver module was removed. |
PHONY_MODULE
Message text |
[STRING]: This transceiver is not sold by H3C. H3C does not guarantee the correct operation of the module or assume maintenance responsibility. |
Variable fields |
Severity level |
4 |
Example |
OPTMOD/4/PHONY_MODULE: GigabitEthernet1/0/1: This transceiver is not sold by H3C. H3C does not guarantee the correct operation of the module or assume maintenance responsibility. |
Explanation |
The transceiver module is not sold by H3C. |
RX_ALM_OFF
Message text |
Variable fields |
$1: Interface type and number. $2: RX fault type. |
Severity level |
5 |
Example |
OPTMOD/5/RX_ALM_OFF: GigabitEthernet1/0/1: RX_not_ready was removed. |
Explanation |
An RX fault was removed from the transceiver module. |
RX_ALM_ON
Message text |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/RX_ALM_ON: GigabitEthernet1/0/1: RX_not_ready was detected. |
Explanation |
An RX fault was detected on the transceiver module. |
289. Execute the display transceiver alarm interface command to verify that a corresponding alarm for the fault has been generated and not cleared. 290. Replace the transceiver module. |
RX_POW_HIGH
Message text |
[STRING]: RX power is high. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/RX_POW_HIGH: GigabitEthernet1/0/1: RX power is high. |
Explanation |
The RX power of the transceiver module exceeded the high threshold. |
291. Execute the display transceiver diagnosis interface command to verify that the RX power of the transceiver module has exceeded the high threshold. 292. Execute the display transceiver alarm interface command to verify that a high RX power alarm for the transceiver module has been generated and not cleared. 293. Replace the transceiver module. |
RX_POW_LOW
Message text |
[STRING]: RX power is low. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/RX_POW_LOW: GigabitEthernet1/0/1: RX power is low. |
Explanation |
The RX power of the transceiver module went below the low threshold. |
294. Execute the display transceiver diagnosis interface command to verify that the RX power of the transceiver module is below the low threshold. 295. Execute the display transceiver alarm interface command to verify that a low RX power alarm for the transceiver module has been generated and not cleared. 296. Replace the transceiver module. |
RX_POW_NORMAL
Message text |
[STRING]: RX power is normal. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/RX_POW_NORMAL: GigabitEthernet1/0/1: RX power is normal. |
Explanation |
The RX power of the transceiver module returned to the acceptable range. |
TEMP_HIGH
Message text |
[STRING]: Temperature is high. |
Variable fields |
$1: Interface type and number |
Severity level |
5 |
Example |
OPTMOD/5/TEMP_HIGH: GigabitEthernet1/0/1: Temperature is high. |
Explanation |
The temperature of the transceiver module exceeded the high threshold. |
297. Verify that the fan trays are operating correctly. ¡ If there are no fan trays, install fan trays. ¡ If the fan trays fail, replace the fan trays. 298. Verify that the ambient temperature is in the acceptable range. If it is out of the acceptable range, take measures to lower the temperature. 299. Replace the transceiver module. |
TEMP_LOW
Message text |
[STRING]: Temperature is low. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TEMP_LOW: GigabitEthernet1/0/1: Temperature is low. |
Explanation |
The temperature of the transceiver module went below the low threshold. |
300. Verify that the ambient temperature is in the acceptable range. If it is out of the acceptable range, take measures to raise the temperature. 301. Replace the transceiver module. |
TEMP_NORMAL
Message text |
[STRING]: Temperature is normal. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TEMP_NORMAL: GigabitEthernet1/0/1: Temperature is normal. |
Explanation |
The temperature of the transceiver module returned to the acceptable range. |
TX_ALM_OFF
Message text |
Variable fields |
$1: Interface type and number. $2: TX fault type. |
Severity level |
5 |
Example |
OPTMOD/5/TX_ALM_OFF: GigabitEthernet1/0/1: TX_fault was removed. |
Explanation |
A TX fault was removed from the transceiver module. |
TX_ALM_ON
Message text |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TX_ALM_ON: GigabitEthernet1/0/1: TX_fault was detected. |
Explanation |
A TX fault was detected on the transceiver module. |
302. Execute the display transceiver alarm interface command to verify that a corresponding alarm for the fault has been generated and not cleared. 303. Replace the transceiver module. |
TX_POW_HIGH
Message text |
[STRING]: TX power is high. |
Variable fields |
Severity level |
2 |
Example |
OPTMOD/2/TX_POW_HIGH: GigabitEthernet1/0/1: TX power is high. |
Explanation |
The TX power of the transceiver module exceeded the high threshold. |
304. Execute the display transceiver diagnosis interface command to verify that the TX power of the transceiver module has exceeded the high threshold. 305. Execute the display transceiver alarm interface command to verify that a high TX power alarm for the transceiver module has been generated and not cleared. 306. Replace the transceiver module. |
TX_POW_LOW
Message text |
[STRING]: TX power is low. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TX_POW_LOW: GigabitEthernet1/0/1: TX power is low. |
Explanation |
The TX power of the transceiver module went below the low threshold. |
307. Execute the display transceiver diagnosis interface command to verify that the TX power of the transceiver module is below the low threshold. 308. Execute the display transceiver alarm interface command to verify that a low TX power alarm for the transceiver module has been generated and not cleared. 309. Replace the transceiver module. |
TX_POW_NORMAL
Message text |
[STRING]: TX power is normal. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TX_POW_NORMAL: GigabitEthernet1/0/1: TX power is normal. |
Explanation |
The TX power of the transceiver module returned to the acceptable range. |
TYPE_ERR
Message text |
[STRING]: The transceiver type is not supported by port hardware. |
Variable fields |
Severity level |
3 |
Example |
OPTMOD/3/TYPE_ERR: GigabitEthernet1/0/1: The transceiver type is not supported by port hardware. |
Explanation |
The transceiver module is not supported by the port. |
VOLT_HIGH
Message text |
[STRING]: Voltage is high. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/VOLT_HIGH: GigabitEthernet1/0/1: Voltage is high. |
Explanation |
The voltage of the transceiver module exceeded the high threshold. |
310. Execute the display transceiver diagnosis interface command to verify that the voltage of the transceiver module has exceeded the high threshold. 311. Execute the display transceiver alarm interface command to verify that a high voltage alarm for the transceiver module has been generated and not cleared. 312. Replace the transceiver module. |
VOLT_LOW
Message text |
[STRING]: Voltage is low. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/VOLT_LOW: GigabitEthernet1/0/1: Voltage is low. |
Explanation |
The voltage of the transceiver module went below the low threshold. |
313. Execute the display transceiver diagnosis interface command to verify that the voltage of the transceiver module is below the low threshold. 314. Execute the display transceiver alarm interface command to verify that a low voltage alarm for the transceiver module has been generated and not cleared. 315. Replace the transceiver module. |
VOLT_NORMAL
Message text |
[STRING]: Voltage is normal. |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/VOLT_NORMAL: GigabitEthernet1/0/1: Voltage is normal. |
Explanation |
The voltage of the transceiver module returned to the acceptable range. |
OSPF messages
This section contains OSPF messages.
OSPF_DUP_RTRID_NBR
Message text |
OSPF [UINT16] Duplicate router ID [STRING] on interface [STRING], sourced from IP address [IPADDR]. |
Variable fields |
$1: OSPF process ID. $2: Router ID. $3: Interface name. $4: IP address. |
Severity level |
6 |
Example |
OSPF/6/OSPF_DUP_RTRID_NBR: OSPF 1 Duplicate router ID 11.11.11.11 on interface GigabitEthernet0/0/3, sourced from IP address 11.2.2.2. |
Explanation |
Two directly connected devices were configured with the same router ID. |
Recommended action |
Modify the router ID on one device and use the reset ospf process command to make the new router ID take effect. |
OSPF_IP_CONFLICT_INTRA
Message text |
OSPF [UINT16] Received newer self-originated network-LSAs. Possible conflict of IP address [IPADDR] in area [STRING] on interface [STRING]. |
Variable fields |
$1: OSPF process ID. $2: IP address. $3: OSPF area ID. $4: Interface name. |
Severity level |
6 |
Example |
OSPF/6/OSPF_IP_CONFLICT_INTRA: OSPF 1 Received newer self-originated network-LSAs. Possible conflict of IP address 11.1.1.1 in area 0.0.0.1 on interface GigabitEthernet0/0/3. |
Explanation |
The interfaces on two devices in the same OSPF area might have the same primary IP address. At least one of the devices is a DR. |
Modify IP address configuration after you make sure no router ID conflict occurs in the same OSPF area. |
OSPF_LAST_NBR_DOWN
Message text |
OSPF [UINT32] Last neighbor down event: Router ID: [STRING] Local address: [STRING] Remote address: [STRING] Reason: [STRING] |
Variable fields |
$1: OSPF process ID. $2: Router ID. $3: Local IP address. $4: Neighbor IP address. $5: Reason. |
Severity level |
6 |
Example |
OSPF/6/OSPF_LAST_NBR_DOWN: OSPF 1 Last neighbor down event: Router ID: 2.2.2.2 Local address: 10.1.1.1 Remote address: 10.1.1.2 Reason: Dead Interval timer expired. |
Explanation |
The device records the OSPF neighbor down event caused by a specific reason. |
· When a down event occurred because of configuration changes (for example, interface parameter changes), check for the configuration errors. · When a down event occurred because of dead interval expiration, check for the dead interval configuration error and loss of network connectivity. · When a down event occurred because of BFD session down, check for the BFD detection time configuration error and loss of network connectivity. · When a down event occurred because of interface status changes, check for loss of network connectivity. |
OSPF_MEM_ALERT
Message text |
OSPF Process received system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alarm. |
Severity level |
5 |
Example |
OSPF/5/OSPF_MEM_ALERT: OSPF Process received system memory alert start event. |
Explanation |
OSPF received a memory alarm. |
Check the system memory and release memory for the modules that occupy too many memory resources. |
OSPF_NBR_CHG
Message text |
OSPF [UINT32] Neighbor [STRING] ([STRING]) changed from [STRING] to [STRING]. |
Variable fields |
$1: OSPF process ID. $2: Neighbor router ID. $3: Interface name. $4: Old adjacency state. $5: New adjacency state. |
Severity level |
5 |
Example |
OSPF/5/OSPF_NBR_CHG: OSPF 1 Neighbor 12.1.1.2(GigabitEthernet10/1) changed from FULL to DOWN. |
Explanation |
The OSPF adjacency state changed on an interface. |
Check for OSPF configuration errors and loss of network connectivity. |
OSPF_NBR_CHG_REASON
Message text |
OSPF [UINT32] Area [STRING] Router [STRING]([STRING]) CPU usage: [STRING], VPN name: [STRING], IfMTU: [UINT32], Neighbor address: [STRING], NbrID [STRING] changed from [STRING] to [STRING] at [STRING]. Last 4 hello packets received at: [STRING] Last 4 hello packets sent at: [STRING] |
Variable fields |
$1: OSPF process ID. $2: Area ID. $3: Router ID. $4: Interface name. $5: CPU utilization. $6: VPN name. $7: Interface MTU. $8: Neighbor IP address. $9: Neighbor router ID. $10: Old neighbor state. $11: New neighbor state and the reason. $12: Neighbor state change time. $13: Time when the last four hello packets were received before neighbor state change. $14: Time when the last four hello packets were sent before neighbor state change. |
Severity level |
5 |
Example |
OSPF/5/OSPF_NBR_CHG_REASON: OSPF 1 Area 0.0.0.0 Router 2.2.2.2(GE1/0/1) CPU usage:3.80%, VPN name: a, IfMTU:1500, Neighbor address:10.1.1.2, NbrID:1.1.1.1 changed from Full to Down because OSPF interface parameters changed at 2019-04-01 15:20:57:034. Last 4 hello packets received at: 2019-04-01 15:19:46:225 2019-04-01 15:19:56:224 2019-04-01 15:20:06:225 2019-04-01 15:20:16:225 Last 4 hello packets sent at: 2019-04-01 15:20:22:033 2019-04-01 15:20:32:033 2019-04-01 15:20:42:032 2019-04-01 15:20:52:033 |
Explanation |
The OSPF neighbor state changed on an interface. |
OSPF_RT_LMT
Message text |
OSPF [UINT32] route limit reached. |
Variable fields |
$1: OSPF process ID. |
Severity level |
4 |
Example |
OSPF/4/OSPF_RT_LMT: OSPF 1 route limit reached. |
Explanation |
The number of routes of an OSPF process reached the upper limit. |
316. Check for network attacks. 317. Reduce the number of routes. |
OSPF_RTRID_CHG
Message text |
OSPF [UINT32] New router ID elected, please restart OSPF if you want to make the new router ID take effect. |
Variable fields |
Severity level |
5 |
Example |
OSPF/5/OSPF_RTRID_CHG: OSPF 1 New router ID elected, please restart OSPF if you want to make the new router ID take effect. |
Explanation |
The OSPF router ID was changed because the user had changed the router ID or the interface IP address used as the router ID had changed. |
Use the reset ospf process command to make the new router ID take effect. |
OSPF_RTRID_CONFLICT_INTER
Message text |
OSPF [UINT16] Received newer self-originated ase-LSAs. Possible conflict of router ID [STRING]. |
Variable fields |
$1: OSPF process ID. $2: Router ID. |
Severity level |
6 |
Example |
OSPF/6/OSPF_RTRID_CONFILICT_INTER: OSPF 1 Received newer self-originated ase-LSAs. Possible conflict of router ID 11.11.11.11. |
Explanation |
Two indirectly connected devices in the same OSPF area might have the same router ID. One of the devices is an ASBR. |
OSPF_RTRID_CONFLICT_INTRA
Message text |
OSPF [UINT16] Received newer self-originated router-LSAs. Possible conflict of router ID [STRING] in area [STRING]. |
Variable fields |
$1: OSPF process ID. $2: Router ID. $3: OSPF area ID. |
Severity level |
6 |
Example |
OSPF/6/OSPF_RTRID_CONFLICT_INTRA: OSPF 1 Received newer self-originated router-LSAs. Possible conflict of router ID 11.11.11.11 in area 0.0.0.1. |
Explanation |
Two indirectly connected devices in the same OSPF area might have the same router ID. |
OSPF_VLINKID_CHG
Message text |
OSPF [UINT32] Router ID changed, reconfigure Vlink on peer |
Variable fields |
Severity level |
5 |
Example |
OSPF/5/OSPF_VLINKID_CHG:OSPF 1 Router ID changed, reconfigure Vlink on peer |
Explanation |
A new OSPF router ID takes effect. |
Check and modify the virtual link configuration on the peer router to match the new router ID. |
OSPFV3 messages
This section contains OSPFv3 messages.
OSPFV3_LAST_NBR_DOWN
Message text |
OSPFv3 [UINT32] Last neighbor down event: Router ID: [STRING] Local interface ID: [UINT32] Remote interface ID: [UINT32] Reason: [STRING]. |
Variable fields |
$1: OSPFv3 process ID. $2: Router ID. $3: Local interface ID. $4: Remote interface ID. $5: Reason. |
Severity level |
6 |
Example |
OSPFV3/6/OSPFV3_LAST_NBR_DOWN: OSPFv3 1 Last neighbor down event: Router ID: 2.2.2.2 Local interface ID: 1111 Remote interface ID: 2222 Reason: Dead Interval timer expired. |
Explanation |
The device records the OSPFv3 neighbor down event caused by a specific reason. |
OSPFV3_MEM_ALERT
Message text |
OSPFV3 Process received system memory alert [STRING] event. |
Variable fields |
Severity level |
5 |
Example |
OSPFV3/5/OSPFV3_MEM_ALERT: OSPFV3 Process received system memory alert start event. |
Explanation |
OSPFv3 received a memory alarm. |
OSPFV3_NBR_CHG
Message text |
OSPFv3 [UINT32] Neighbor [STRING] ([STRING]) received [STRING] and its state from [STRING] to [STRING]. |
Variable fields |
$1: Process ID. $2: Neighbor router ID. $3: Interface name. $4: Neighbor event. $5: Old adjacency state. $6: New adjacency state. |
Severity level |
5 |
Example |
OSPFV3/5/OSPFV3_NBR_CHG: OSPFv3 1 Neighbor 2.2.2.2 (Vlan100) received 1-Way and its state from Full to Init. |
Explanation |
The OSPFv3 adjacency state changed on an interface. |
When the adjacency with a neighbor changes from Full to another state on an interface, check for OSPFv3 configuration errors and loss of network connectivity. |
OSPFV3_RT_LMT
Message text |
OSPFv3 [UINT32] route limit reached. |
Variable fields |
$1: Process ID. |
Severity level |
5 |
Example |
OSPFV3/5/OSPFV3_RT_LMT:OSPFv3 1 route limit reached. |
Explanation |
The number of routes of an OSPFv3 process reached the upper limit. |
318. Check for network attacks. 319. Reduce the number of routes. |
PBB messages
This section contains PBB messages.
PBB_JOINAGG_WARNING
Message text |
Because the aggregate interface [STRING] has been configured with PBB, assigning the interface [STRING] that does not support PBB to the aggregation group will cause incorrect processing. |
Variable fields |
$1: Aggregation group name. $2: Interface name. |
Severity level |
4 |
Example |
PBB/4/PBB_JOINAGG_WARNING: Because the aggregate interface Bridge-Aggregation1 has been configured with PBB, assigning the interface Ten-GigabitEthernet9/0/30 that does not support PBB to the aggregation group will cause incorrect processing. |
Explanation |
Assigning an interface that does not support PBB to an aggregation group that has been configured with PBB will cause incorrect processing. If an aggregate interface is a PBB uplink port, all its members should support PBB. |
Remove the interface from the aggregation group. |
PBR messages
This section contains PBR messages.
PBR_HARDWARE_ERROR
Message text |
Failed to update policy [STRING] due to [STRING]. |
Variable fields |
$1: Policy name. $2: Hardware error reasons: · The hardware resources are insufficient. · The system does not support the operation. · The hardware resources are insufficient and the system does not support the operation. |
Severity level |
4 |
Example |
PBR/4/PBR_HARDWARE_ERROR: Failed to update policy aaa due to insufficient hardware resources and not supported operations. |
Explanation |
The device failed to update PBR configuration. |
Modify the PBR policy configuration according to the failure reason. |
PCE messages
This section contains PCE messages.
PCE_PCEP_SESSION_CHG
Message text |
Session ([STRING], [STRING]) is [STRING]. |
Variable fields |
$1: Peer address of the session. $2: VPN instance name. Value unknown indicates that the VPN instance cannot be obtained. $3: State of the session, up or down. When the state is down, this field also displays the reason for the down state error. Possible reasons include: · TCP connection down. · received a close message. · reception of a malformed PCEP message. · internal error. · memory in critical state. · dead timer expired. · process deactivated. · remote peer unavailable/untriggered. · reception of an unacceptable number of unrecognized PCEP messages. · reception of an unacceptable number of unknown requests/replies. · PCE address changed. · initialization failed. |
Severity level |
5 |
Example |
PCE/5/PCE_PCEP_SESSION_CHG: Session (22.22.22.2, public instance) is up. PCE/5/PCE_PCEP_SESSION_CHG: Session (22.22.22.2, public instance) is down (dead timer expired). |
Explanation |
The session state changed. |
When the session state is up, no action is required. When the session state is down, verify the network and configuration according to the reason displayed. |
PEX messages (IRF 3)
This section contains IRF 3 PEX messages.
PEX_ASSOCIATEID_MISMATCHING
Message text |
The associated ID of PEX port [UNIT32] is [UNIT32] on the parent fabric, but the PEX connected to the port has obtained ID [UNIT32]. |
Variable fields |
$1: PEX port ID. $2: Virtual slot or chassis number configured on the parent fabric for a PEX. $3: Virtual slot or chassis number that the PEX has obtained. |
Severity level |
5 |
Example |
PEX/5/PEX_ASSOCIATEID_MISMATCHING: The associated ID of PEX port 1 is 100 on the parent fabric, but the PEX connected to the port has obtained ID 101. |
Explanation |
The configured virtual slot or chassis number for a PEX is different from the virtual slot or chassis number that the PEX has obtained. |
Check the network connection. |
PEX_CONFIG_ERROR
Message text |
PEX port [UINT32] discarded a REGISTER request received from [STRING] through interface [STRING]. Reason: The PEX was not assigned an ID, or the PEX was assigned an ID equal to or greater than the maximum value ([UINT32]). |
Variable fields |
$1: PEX port ID. $2: PEX model. $3: Name of a PEX physical interface. $4: Maximum virtual slot or chassis number for the PEX model. |
Severity level |
4 |
Example |
PEX/4/PEX_CONFIG_ERROR: PEX port 1 discarded a REGISTER request received from PEX-S5120HI-S5500HI through interface Ten-GigabitEthernet10/0/31. Reason: The PEX was not assigned an ID, or the PEX was assigned an ID equal to or greater than the maximum value 130. |
Explanation |
This message is generated in the following situations: · The PEX is not assigned a virtual slot or chassis number. · The PEX is assigned a virtual slot or chassis number that is greater than the maximum value allowed for the PEX model. |
Use the associate command to assign a valid virtual slot or chassis number to the PEX. Make sure the number is within the value range for the PEX model. |
PEX_CONNECTION_ERROR
Message text |
PEX port [UINT32] discarded a REGISTER request received from [STRING] through interface [STRING]. Reason: Another PEX has been registered on the PEX port. |
Variable fields |
$1: PEX port ID. $2: PEX model. $3: Name of a PEX physical interface. |
Severity level |
4 |
Example |
PEX/4/PEX_CONNECTION_ERROR: PEX port 1 discarded a REGISTER request received from PEX-S5120HI-S5500HI through interface Ten-GigabitEthernet10/0/31. Reason: Another PEX has been registered on the PEX port. |
Explanation |
This message is generated if a PEX port is connected to multiple PEXs. |
Reconnect PEXs to ensure sure that only one PEX is connected to the PEX port. |
PEX_FORBID_STACK
Message text |
Can't connect PEXs [UNIT32] and [UNIT32]: The PEX ports to which the PEXs belong are in different PEX port groups. |
Variable fields |
$1: Virtual slot or chassis number of a PEX. $2: Virtual slot or chassis number of a PEX. |
Severity level |
5 |
Example |
PEX/5/PEX_FORBID_STACK: Can't connect PEXs 100 and 102: The PEX ports to which the PEXs belong are in different PEX port groups. |
Explanation |
PEXs belonging to PEX ports of different PEX port groups were connected. |
PEX_LINK_BLOCK
Message text |
Status of [STRING] changed from [STRING] to blocked. |
Variable fields |
$1: Name of a PEX physical interface. $2: Data link status of the interface. |
Severity level |
4 |
Example |
PEX/4/PEX_LINK_BLOCK: Status of Ten-GigabitEthernet2/0/1 changed from forwarding to blocked. |
Explanation |
Data link of the PEX physical interface has changed to blocked. The blocked state is a transitional state between forwarding and down. In blocked state, a PEX physical interface can forward protocol packets, but it cannot forward data packets. This state change occurs in one of the following situations: · Incorrect physical connection: ¡ The PEX physical links on a PEX are connected to different PEX ports on the parent fabric. ¡ The PEX port on the parent fabric contains physical links to different PEXs. · The data link is forced to the blocked state. In the startup phase, a PEX blocks the link of a PEX physical interface if the interface is physically up, but it is not used for loading startup software. · The physical state of the interface is up, but the PEX connection between the PEX and the parent fabric has been disconnected. The PEX and the parent fabric cannot receive PEX heartbeat packets from each other. |
If a down PEX link changes from blocked to up quickly, you do not need to take action. If the link stays in blocked state, check the PEX cabling to verify that: · The PEX's all PEX physical interfaces are connected to the physical interfaces assigned to the same PEX port on the parent fabric. · The PEX port contains only physical links to the same PEX. If a forwarding PEX link stays in blocked state when it is changing to the down state, verify that an IRF fabric split has occurred. When an IRF fabric split occur, a PEX link is be blocked if it is connected to the Recovery-state IRF member device. |
PEX_LINK_DOWN
Message text |
Status of [STRING] changed from [STRING] to down. |
Variable fields |
Severity level |
4 |
Example |
PEX/4/PEX_LINK_DOWN: Status of Ten-GigabitEthernet2/0/1 changed from forwarding to down. |
Explanation |
Data link of the PEX physical interface has changed to the down state and cannot forward any packets. The following are common reasons for this state change: · Physical link fails. · The interface is shut down administratively. · The system reboots. |
If the interface has been shut down administratively or in the down state because of a system reboot, use the undo shutdown command to bring up the interface as needed. If the interface is down because of a physical link failure, verify that the cable has been securely connected and is in good condition. |
PEX_LINK_FORWARD
Message text |
Status of [STRING] changed from [STRING] to forwarding. |
Variable fields |
Severity level |
5 |
Example |
PEX/5/PEX_LINK_FORWARD: Status of Ten-GigabitEthernet2/0/1 changed from blocked to forwarding. |
Explanation |
Data link of the PEX physical interface has changed to the forwarding state and can forward data packets. This link state change occurs when one of the following events occurs: · The link is detected again after it changes to the blocked state. · The PEX finishes loading startup software images from the parent fabric through the interface. |
No action is required. |
PEX_REG_JOININ
Message text |
PEX ([STRING]) registered successfully on PEX port [UINT32]. |
Variable fields |
$1: Virtual slot or chassis number of a PEX. $2: PEX port ID. |
Severity level |
5 |
Example |
PEX/5/PEX_REG_JOININ: PEX (slot 101) registered successfully on PEX port 1. |
Explanation |
The PEX has been registered successfully. You can configure and manage the PEX attached to the PEX port on the parent fabric as if the PEX was an interface card. |
PEX_REG_LEAVE
Message text |
PEX ([STRING]) unregistered on PEX port [UINT32]. |
Variable fields |
Severity level |
4 |
Example |
PEX/4/PEX_REG_LEAVE: PEX (slot 101) unregistered on PEX port 1. |
Explanation |
The PEX has been unregistered. You cannot operate the PEX from the parent fabric. A PEX unregister event occurs when one of the following events occurs: · The PEX reboots. · All physical interfaces in the PEX port are down. For example, all physical interfaces are shut down administratively, or all the physical links are disconnected. · The PEX fails to start up within 30 minutes. · Link detection fails on all physical interfaces in the PEX port. |
If the event occurs because the PEX reboots or PEX physical interfaces are shut down administratively, use the undo shutdown command to bring up the interfaces as needed. To resolve the issue that occurs for any other reasons: · Use the display device command to verify that the virtual slot or chassis number of the PEX is present and the state is correct. · Use the display pex-port command to verify that the PEX physical interfaces are configured correctly and in a correct state. · Use the display interface command to verify that the physical state of the PEX physical interfaces is up. If the Current state field displays down, check the cabling for a physical link failure. |
PEX_REG_REQUEST
Message text |
Received a REGISTER request on PEX port [UINT32] from PEX ([STRING]). |
Variable fields |
$1: PEX port ID. $2: Virtual slot or chassis number of a PEX. |
Severity level |
5 |
Example |
PEX/5/PEX_REG_REQUEST: Received a REGISTER request on PEX port 1 from PEX (slot 101). |
Explanation |
The PEX sent a registration request to the parent fabric. This event occurs when the PEX starts up after PEX configuration is completed and the PEX device is connected to the patent device correctly. The parent fabric will allow the PEX to load startup software images after it receives a REGISTER request. |
PEX_STACKCONNECTION_ERROR
Message text |
A device was connected to a PEX that already had two neighboring devices. |
Variable fields |
N/A |
Severity level |
5 |
Example |
PEX/5/PEX_STACKCONNECTION_ERROR: A device was connected to a PEX that already had two neighboring devices. |
Explanation |
Connection error was detected. A device was connected to a PEX that already has two neighboring devices in an IRF 3 system. |
PEX messages (IRF 3.1)
This section contains IRF 3.1 PEX messages.
PEX_AUTOCONFIG_BAGG_ASSIGNMEMBER
Message text |
[STRING] was assigned to [STRING]. |
Variable fields |
$1: Physical interface name. $2: Layer 2 aggregate interface name. |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_BAGG_ASSIGNMEMBER: GigabitEthernet 1/2/0/1 was assigned to Bridge-Aggregation10. |
Explanation |
The parent fabric automatically assigned the physical interface connecting to a PEX to the cascade port for PEX autoconfiguration. |
PEX_AUTOCONFIG_BAGG_CREATE
Message text |
[STRING] was created by the PEX auto-config feature. |
Variable fields |
$1: Layer 2 aggregate interface name. |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_BAGG_CREATE: Bridge-Aggregation10 was created by the PEX auto-config feature. |
Explanation |
The parent fabric automatically created a Layer 2 aggregate interface for PEX connection. |
PEX_AUTOCONFIG_BAGG_NORESOURCE
Message text |
Not enough resources to create a Layer 2 aggregate interface. |
Variable fields |
N/A |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_BAGG_NORESOURCE: Not enough resources to create a Layer 2 aggregate interface. |
Explanation |
PEX autoconfiguration failed because the parent fabric does not have enough resources to automatically create a Layer 2 aggregate interface for PEX connection. |
Delete idle Layer 2 aggregate interfaces on the system to release resources. |
PEX_AUTOCONFIG_BAGG_REMOVEMEMBER
Message text |
[STRING] was removed from [STRING]. |
Variable fields |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_BAGG_REMOVEMEMBER: GigabitEthernet 1/2/0/1 was removed from Bridge-Aggregation10. |
Explanation |
The parent fabric automatically removed a physical interface from one cascade port to another cascade port for PEX autoconfiguration. Interface removal occurs if the physical interface that connects to a PEX is assigned to a cascade port different from the cascade port dedicated to the PEX. The parent fabric will automatically remove the physical interface to the cascade port dedicated to the PEX. |
PEX_AUTOCONFIG_CAPABILITY_ENABLE
Message text |
PEX connection capability was enabled on [STRING] and the interface was assigned to PEX group [UINT32]. |
Variable fields |
$1: Layer 2 aggregate interface name. $2: PEX group number. |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_CAPABILITY_ENABLE: PEX connection capability was enabled on Bridge-Aggregation 10 and the interface was assigned to PEX group 1. |
Explanation |
The parent fabric automatically enabled PEX connection capability on the Layer 2 aggregate interface connecting to a PEX and assigned the interface to a PEX group. |
PEX_AUTOCONFIG_CASCADELIMIT
Message text |
Failed to assign cascade port [STRING] to PEX group [UINT32]. Reason: Maximum number of cascade ports already reached in the PEX group. |
Variable fields |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_CASCADELIMIT: Failed to assign cascade port Bridge-Aggregation10 to PEX group1. Reason: Maximum number of cascade ports already reached in the PEX group. |
Explanation |
PEX autoconfiguration failed because the number of cascade ports in the PEX group already reached the upper limit. No additional cascade ports can be assigned to the PEX group. |
Delete idle cascade ports in the PEX group to release resources. |
PEX_AUTOCONFIG_CONNECTION_ERROR
Message text |
A PEX connected to more than one upper-tier PEXs. |
Variable fields |
N/A |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_CONNECTION_ERROR: A PEX connected to more than one upper-tier PEXs. |
Explanation |
Autoconfiguration failed for a PEX because the PEX is connected to more than one upper-tier PEX. |
Reconnect the PEX to ensure that the PEX has only one upper-tier PEX. |
PEX_AUTOCONFIG_DIFFGROUPNUMBER
Message text |
[STRING] failed to join in PEX group [UINT32]. Reason: Its upper-tier PEX was in PEX group [UINT32]. Please make sure they are in the same PEX group. |
Variable fields |
$1: Layer 2 aggregate interface name. $2: PEX group number. $3: PEX group number. |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_DIFFGROUPNUMBER: Bridge-Aggregation10 failed to join in PEX group 1. Reason: Its upper-tier PEX was in PEX group 2. Please make sure they are in the same PEX group |
Explanation |
Autoconfiguration failed for a lower-tier PEX because the cascade port that connects to the lower-tier PEX is assigned to a PEX group different than the upper-tier PEX. |
Modify the configuration to ensure that the lower-tier PEX is assigned to the same PEX group as its upper-tier PEX. |
PEX_AUTOCONFIG_DYNAMICBAGG_STP
Message text |
[STRING] was automatically set to dynamic aggregation mode and configured as an STP edge port. |
Variable fields |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_DYNAMICBAGG_STP: Bridge-Aggregation10 was automatically set to dynamic aggregation mode and configured as an STP edge port. |
Explanation |
During PEX autoconfiguration, the parent fabric automatically set the cascade port of a PEX to operate in dynamic aggregation mode and act as an STP edge port. |
PEX_AUTOCONFIG_GROUP_CREATE
Message text |
PEX group [UINT32] was created. |
Variable fields |
$1: PEX group number. |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_GROUP_CREATE: PEX group 1 was created. |
Explanation |
The parent fabric automatically created a PEX group for PEX autoconfiguration. |
PEX_AUTOCONFIG_NONUMBERRESOURCE
Message text |
Pattern 1: No virtual slot numbers are available. Pattern 2: No virtual chassis numbers are available. |
Variable fields |
N/A |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_NONUMBERRESOURCE: No virtual slot numbers are available. |
Explanation |
PEX autoconfiguration failed because no virtual slot numbers or chassis numbers are available for PEX autoconfiguration. |
Delete idle cascade ports or remove the assignment of virtual slot or chassis numbers on idle cascade ports to release resources. |
PEX_AUTOCONFIG_NOT_CASCADEPORT
Message text |
[STRING] was already assigned to [STRING], which is an aggregate interface not enabled with PEX connection capability. Please remove [STRING] from [STRING] or use another physical interface to connect the PEX. |
Variable fields |
$1: Physical interface name. $2: Layer 2 aggregate interface name. $3: Physical interface name. $4: Layer 2 aggregate interface name. |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_NOT_CASCADEPORT: GigabitEthernet 1/2/0/1 was already assigned to Bridge-Aggregation10, which is an aggregate interface not enabled with PEX connection capability. Please remove GigabitEthernet 1/2/0/1 from Bridge-Aggregation10 or use another physical interface to connect the PEX. |
Explanation |
Autoconfiguration failed for a PEX because the physical interface connecting to the PEX was assigned to an aggregate interface not enabled with PEX connection capability. |
Remove the physical interface from the aggregate interface not enabled with PEX connection capability or use another physical interface to connect the PEX. |
PEX_AUTOCONFIG_NUMBER_ASSIGN
Message text |
Pattern 1: Virtual slot number [UINT32] was assigned on [STRING]. Pattern 2: Virtual chassis number [UINT32] was assigned on [STRING]. |
Variable fields |
Pattern 1: $1: Virtual slot number. $2: Layer 2 aggregate interface name. Pattern 2: $1: Virtual chassis number. $2: Layer 2 aggregate interface name. |
Severity level |
5 |
Example |
PEX/5/PEX_AUTOCONFIG_NUMBER_ASSIGN: Virtual slot number 100 was assigned on Bridge-Aggregation 10. |
Explanation |
The parent fabric automatically assigned a virtual slot or chassis number to a PEX on the cascade port for PEX autoconfiguration. |
PEX_LLDP_DISCOVER
Message text |
Discover peer device on interface [STRING]: MAC=STRING, priority=UINT32. |
Variable fields |
$1: Interface name. $2: MAC address of the peer device. $3: Priority of the PEX upstream port. |
Severity level |
5 |
Example |
PEX/5/PEX_LLDP_DISCOVER: Discover peer device on interface Ten-GigabitEthernet1/0/1: MAC=20f4-9cb6-0100, priority=0. |
Explanation |
The parent fabric or a PEX discovered a peer device through LLDP. |
PEX_MEMBERID_EXCEED
Message text |
To use the IRF fabric connected to interface [STRING] as a PEX, the IRF member ID must be in the range of 1 to 4. |
Variable fields |
$1: Interface name. |
Severity level |
4 |
Example |
PEX/4/PEX_MEMBERID_EXCEED: To use the IRF fabric connected to interface Bridge-Aggregation1 as a PEX, the IRF member ID must be in the range of 1 to 4. |
Explanation |
To use an IRF fabric as a PEX, the IRF member ID must be in the range of 1 to 4. Only single-member IRF fabrics can be used as PEXs in an IRF 3.1 system. |
320. Check the IRF member ID of the device to be used as a PEX. 321. Execute the irf member renumber command to change the IRF member ID to be in the range of 1 to 4. |
PEX_PECSP_OPEN_RCVD
Message text |
Received a CSP Open message on interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
PEX/5/PEX_PECSP_OPEN_RCVD: Received a CSP Open message on interface Bridge-Aggregation1. |
Explanation |
A cascade port on the parent fabric or an upstream port on a PEX received a PE CSP Open packet from the peer to request connection establishment. If each side can receive a response from the peer within 60 seconds after sending a PE CSP Open request, connection between them is established. |
PEX_PECSP_OPEN_SEND
Message text |
Sent a CSP Open message on interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
PEX/5/PEX_PECSP_OPEN_SEND: Sent a CSP Open message on interface Bridge-Aggregation1. |
Explanation |
A cascade port on the parent fabric or an upstream port on a PEX sent a PE CSP Open packet to request connection establishment. If each side can receive a response from the peer within 60 seconds after sending a PE CSP Open request, connection between them is established. |
PEX_PECSP_TIMEOUT
Message text |
PE CSP timed out on interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
PEX/4/PEX_PECSP_TIMEOUT: PE CSP timed out on interface Bridge-Aggregation1. |
Explanation |
PE CSP timed out on an interface because no PE CSP packet was received on the interface. The parent fabric and the PEX cannot establish connection. |
322. Check the links between the parent fabric and the PEX. Make sure a minimum of one link is up. 323. Check IRF 3.1 configuration. Verify that the configuration is correct. |
PFILTER messages
This section contains packet filter messages.
PFILTER_GLB_IPV4_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction globally. The resources are insufficient. |
Variable fields |
$1: Traffic direction. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction globally. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying the IPv4 default action to a specific direction globally. · Updating the IPv4 default action applied to a specific direction globally. |
Use the display qos-acl resource command to check hardware resource usage. |
PFILTER_GLB_IPV4_DACT_UNK_ERR
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction globally. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction globally. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying the IPv4 default action to a specific direction globally. · Updating the IPv4 default action applied to a specific direction globally. |
PFILTER_GLB_IPV6_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction globally. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction globally. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying the IPv6 default action to a specific direction globally. · Updating the IPv6 default action applied to a specific direction globally. |
PFILTER_GLB_IPV6_DACT_UNK_ERR
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction globally. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction globally. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying the IPv6 default action to a specific direction globally. · Updating the IPv6 default action applied to a specific direction globally. |
PFILTER_GLB_MAC_DACT_NO_RES
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction globally. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction globally. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying the MAC default action to a specific direction globally. · Updating the MAC default action applied to a specific direction globally. |
PFILTER_GLB_MAC_DACT_UNK_ERR
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction globally. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction globally. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying the MAC default action to a specific direction globally. · Updating the MAC default action applied to a specific direction globally. |
PFILTER_GLB_NO_RES
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. The resources are insufficient. |
Variable fields |
$1: ACL type. $2: ACL number. $3: ACL rule ID. $4: Traffic direction. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying an ACL rule to a specific direction globally. · Updating an ACL rule applied to a specific direction globally. |
PFILTER_GLB_NOT_SUPPORT
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. The ACL is not supported. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_NOT_SUPPORT: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. The ACL is not supported. |
Explanation |
The system failed to perform one of the following actions because the ACL rule is not supported: · Applying an ACL rule to a specific direction globally. · Updating an ACL rule applied to a specific direction globally. |
Verify the ACL configuration and remove the settings that are not supported. |
PFILTER_GLB_ RES_CONFLICT
Message text |
Failed to apply or refresh [STRING] ACL [UINT] to the [STRING] direction globally. [STRING] ACL [UINT] has already been applied globally. |
Variable fields |
$1: ACL type. $2: ACL number. $3: Traffic direction. $4: ACL type. $5: ACL number. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_RES_CONFLICT: Failed to apply or refresh IPv6 ACL 2000 to the inbound direction globally. IPv6 ACL 3000 has already been applied globally. |
Explanation |
The system failed to perform one of the following actions because an ACL of the same type (IPv4 ACL, IPv6 ACL, or MAC ACL) has already been applied: · Applying the ACL to a specific direction globally. · Updating the ACL applied to a specific direction globally. |
Remove the ACL of the same type. |
PFILTER_GLB_UNK_ERR
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_UNK_ERR: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying an ACL rule to a specific direction globally. · Updating an ACL rule applied to a specific direction globally. |
PFILTER_IF_IPV4_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of interface [STRING]. The resources are insufficient. |
Variable fields |
$1: Traffic direction. $2: Interface name. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying the IPv4 default action to a specific direction of an interface. · Updating the IPv4 default action applied to a specific direction of an interface. |
PFILTER_IF_IPV4_DACT_UNK_ERR
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction of interface Ethernet 3/1/2. |
Explanation |
The system failed to perform one of the following actions because an unknown error: · Applying the IPv4 default action to a specific direction of an interface. · Updating the IPv4 default action applied to a specific direction of an interface. |
PFILTER_IF_IPV6_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of interface [STRING]. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying the IPv6 default action to a specific direction of an interface. · Updating the IPv6 default action applied to a specific direction of an interface. |
PFILTER_IF_IPV6_DACT_UNK_ERR
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction of interface Ethernet 3/1/2. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying the IPv6 default action to a specific direction of an interface. · Updating the IPv6 default action applied to a specific direction of an interface. |
PFILTER_IF_MAC_DACT_NO_RES
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction of interface [STRING]. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying the MAC default action to a specific direction of an interface. · Updating the MAC default action applied to a specific direction of an interface. |
PFILTER_IF_MAC_DACT_UNK_ERR
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction of interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction of interface Ethernet 3/1/2. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying the MAC default action to a specific direction of an interface. · Updating the MAC default action applied to a specific direction of an interface. |
PFILTER_IF_NO_RES
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. The resources are insufficient. |
Variable fields |
$1: ACL type. $2: ACL number. $3: ACL rule ID. $4: Traffic direction. $5: Interface name. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying an ACL rule to a specific direction of an interface. · Updating an ACL rule applied to a specific direction of an interface. |
PFILTER_IF_NOT_SUPPORT
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. The ACL is not supported. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_NOT_SUPPORT: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. The ACL is not supported. |
Explanation |
The system failed to perform one of the following actions because the ACL rule is not supported: · Applying an ACL rule to a specific direction of an interface. · Updating an ACL rule applied to a specific direction of an interface. |
PFILTER_IF_RES_CONFLICT
Message text |
Failed to apply or refresh [STRING] ACL [UINT] to the [STRING] direction of interface [STRING]. [STRING] ACL [UINT] has already been applied to the interface. |
Variable fields |
$1: ACL type. $2: ACL number. $3: Traffic direction. $4: Interface name. $5: ACL type. $6: ACL number. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_RES_CONFLICT: Failed to apply or refresh IPv6 ACL 2000 to the inbound direction of interface Ethernet 3/1/2. IPv6 ACL 3000 has already been applied to the interface. |
Explanation |
The system failed to perform one of the following actions because an ACL of the same type (IPv4 ACL, IPv6 ACL, or MAC ACL) has already been applied: · Applying the ACL to a specific direction of an interface. · Updating the ACL applied to a specific direction of an interface. |
PFILTER_IF_UNK_ERR
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_UNK_ERR: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying an ACL rule to a specific direction of an interface. · Updating an ACL rule applied to a specific direction of an interface. |
PFILTER_IPV4_FLOW_INFO
Message text |
ACL [STRING] [STRING] [STRING] rule [STRING] [STRING] |
Variable fields |
$1: ACL number or name. $2: Traffic direction. $3: Destination to which packet filter applies. $4: ID and content of an ACL rule. $5: Information about the first packet of a flow that matches the rule. |
Severity level |
6 |
Example |
PFILTER/6/PFILTER_IPV4_FLOW_INFO: ACL 3000 inbound Ethernet 3/1/2 rule 0 permit tcp 192.168.1.1(1024) -> 192.168.5.1(1024). |
Explanation |
This message is sent when the first packet of a flow matches an IPv4 advanced ACL rule for packet filtering. The rule has been configured with the flow-logging keyword. |
PFILTER_IPV4_FLOW_STATIS
Message text |
ACL [STRING] [STRING] rule [STRING] [STRING], [UINT64] packet(s). |
Variable fields |
$1: ACL number or name. $2: Traffic direction. $3: ID and content of an ACL rule. $4: Information about the first packet of a flow that matched the rule. $5: Number of packets that match the rule. |
Severity level |
6 |
Example |
PFILTER/6/PFILTER_IPV4_FLOWLOG_STATIS: ACL 3000 inbound rule 0 permit icmp 192.168.1.1(1024) -> 192.168.5.1(1024), 1000 packets. |
Explanation |
This message is sent at the logging interval. The rule has been configured with the flow-logging keyword. |
PFILTER_IPV6_FLOW_INFO
Message text |
IPv6 ACL [STRING] [STRING] [STRING] rule [STRING] [STRING] |
Variable fields |
Severity level |
6 |
Example |
PFILTER/6/PFILTER_IPV6_FLOW_INFO: IPv6 ACL 3000 inbound Ethernet 3/1/2 rule 0 permit tcp 0:1020::200:0(0)->0:720::200:0(0). |
Explanation |
This message is sent when the first packet of a flow matches an IPv6 advanced ACL rule applied for packet filtering. The rule has been configured with the flow-logging keyword. |
PFILTER_IPV6_FLOW_STATIS
Message text |
IPv6 ACL [STRING] [STRING] rule [STRING] [STRING], [UINT64] packet(s). |
Variable fields |
Severity level |
6 |
Example |
PFILTER/6/PFILTER_IPV6_FLOWLOG_STATIS: IPv6 ACL 3000 rule 0 permit icmpv6 0:1020::200:0(0)->0:720::200:0(0), 1000 packets. |
Explanation |
PFILTER_IPV6_STATIS_INFO
Message text |
[STRING] ([STRING]): Packet-filter IPv6 [UINT32] [STRING] [STRING] [UINT64] packet(s). |
Variable fields |
$1: Destination to which packet filter applies. $2: Traffic direction. $3: ACL number or name. $4: ID and content of an ACL rule. $5: Number of packets that matched the rule. |
Severity level |
6 |
Example |
PFILTER/6/PFILTER_IPV6_STATIS_INFO: Ethernet0/4/0 (inbound): Packet-filter IPv6 2000 rule 0 permit source 1:1::/64 logging 1000 packet(s). |
Explanation |
This message is generated at the logging interval. The rule has been configured with the logging keyword. |
PFILTER_MAC_FLOW_INFO
Message text |
MAC ACL [STRING] [STRING] [STRING] rule [STRING] [STRING] |
Variable fields |
$1: ACL number or name. $2: Traffic direction. $3: Destination to which packet filter applies. $4: ID and content of an ACL rule. $5: Information about the first packet that matches the rule. |
Severity level |
6 |
Example |
PFILTER/6/PFILTER_MAC_FLOW_INFO: MAC ACL 4000 inbound Ethernet 3/1/2 rule 0 permit 0800-2700-9000 -> 0CDA-411D-0676. |
Explanation |
This message is sent when the first packet matches an Layer 2 ACL rule for packet filtering. |
PFILTER_STATIS_INFO
Message text |
[STRING] ([STRING]): Packet-filter [UINT32] [STRING] [UINT64] packet(s). |
Variable fields |
Severity level |
6 |
Example |
PFILTER/6/PFILTER_STATIS_INFO: Ethernet0/4/0 (inbound): Packet-filter 2000 rule 0 permit source 1.1.1.1 0 logging 10000 packet(s). |
Explanation |
This message is sent at the logging interval. |
PFILTER_VLAN_IPV4_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
Variable fields |
$1: Traffic direction. $2: VLAN ID. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction of VLAN 1. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying the IPv4 default action to a specific direction of a VLAN. · Updating the IPv4 default action applied to a specific direction of a VLAN. |
PFILTER_VLAN_IPV4_DACT_UNK_ERR
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of VLAN [UINT16]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction of VLAN 1. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying the IPv4 default action to a specific direction of a VLAN. · Updating the IPv4 default action applied to a specific direction of a VLAN. |
PFILTER_VLAN_IPV6_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction of VLAN 1. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying the IPv6 default action to a specific direction of a VLAN. · Updating the IPv6 default action applied to a specific direction of a VLAN. |
PFILTER_VLAN_IPV6_DACT_UNK_ERR
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of VLAN [UINT16]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction of VLAN 1. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying the IPv6 default action to a specific direction of a VLAN. · Updating the IPv6 default action applied to a specific direction of a VLAN. |
PFILTER_VLAN_MAC_DACT_NO_RES
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction of VLAN 1. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying the MAC default action to a specific direction of a VLAN. · Updating the MAC default action applied to a specific direction of a VLAN. |
PFILTER_VLAN_MAC_DACT_UNK_ERR
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction of VLAN [UINT16]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction of VLAN 1. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying the MAC default action to a specific direction of a VLAN. · Updating the MAC default action applied to a specific direction of a VLAN. |
PFILTER_VLAN_NO_RES
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
Variable fields |
$1: ACL type. $2: ACL number. $3: ACL rule ID. $4: Traffic direction. $5: VLAN ID. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of VLAN 1. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources are insufficient: · Applying an ACL rule to a specific direction of a VLAN. · Updating an ACL rule applied to a specific direction of a VLAN. |
PFILTER_VLAN_NOT_SUPPORT
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. The ACL is not supported. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_NOT_SUPPORT: Failed to apply or refresh ACL 2000 rule 1 to the inbound direction of VLAN 1. The ACL is not supported. |
Explanation |
The system failed to perform one of the following actions because the ACL rule is not supported: · Applying an ACL rule to a specific direction of a VLAN. · Updating an ACL rule applied to a specific direction of a VLAN. |
PFILTER_VLAN_RES_CONFLICT
Message text |
Failed to apply or refresh [STRING] ACL [UINT] to the [STRING] direction of VLAN [UINT16]. [STRING] ACL [UINT] has already been applied to the VLAN. |
Variable fields |
$1: ACL type. $2: ACL number. $3: Traffic direction. $4: VLAN ID. $5: ACL type. $6: ACL number. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_RES_CONFLICT: Failed to apply or refresh IPv6 ACL 2000 to the inbound direction of VLAN 1. IPv6 ACL 3000 has already been applied to the VLAN. |
Explanation |
The system failed to perform one of the following actions because an ACL of the same type (IPv4 ACL, IPv6 ACL, or MAC ACL) has already been applied: · Applying the ACL to a specific direction of a VLAN. · Updating the ACL applied to a specific direction of a VLAN. |
PFILTER_VLAN_UNK_ERR
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_UNK_ERR: Failed to apply or refresh ACL 2000 rule 1 to the inbound direction of VLAN 1. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying an ACL rule to a specific direction of a VLAN. · Updating an ACL rule applied to a specific direction of a VLAN. |
PIM messages
This section contains PIM messages.
PIM_NBR_DOWN
Message text |
[STRING]: Neighbor [STRING] ([STRING]) is down. |
Variable fields |
$1: VPN instance name. If the PIM neighbor belongs to the public network, this field is not displayed. $2: IP address of the PIM neighbor. $3: Interface name. |
Severity level |
5 |
Example |
PIM/5/PIM_NBR_DOWN: Neighbor 10.1.1.1(Vlan-interface10) is down. |
Explanation |
A PIM neighbor went down. |
Check the PIM configuration and network status. |
PIM_NBR_UP
Message text |
[STRING]: Neighbor [STRING] ([STRING]) is up. |
Variable fields |
Severity level |
5 |
Example |
PIM/5/PIM_NBR_UP: Neighbor 10.1.1.1(Vlan-interface10) is up. |
Explanation |
A PIM neighbor came up. |
PING messages
This section contains ping messages.
PING_STATISTICS
Message text |
[STRING] statistics for [STRING]: [UINT32] packets transmitted, [UINT32] packets received, [DOUBLE]% packet loss, round-trip min/avg/max/std-dev = [DOUBLE]/[DOUBLE]/[DOUBLE]/[DOUBLE] ms. |
Variable fields |
$1: Ping or ping6. $2: IP address, IPv6 address, or host name for the destination. $3: Number of sent echo requests. $4: Number of received echo replies. $5: Percentage of the non-replied packets to the total request packets. $6: Minimum round-trip delay. $7: Average round-trip delay. $8: Maximum round-trip delay. $9: Standard deviation round-trip delay. |
Severity level |
6 |
Example |
PING/6/PING_STATISTICS: Ping statistics for 192.168.0.115: 5 packets transmitted, 5 packets received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms. |
Explanation |
A user uses the ping command to identify whether a destination in the public network is reachable. |
If there is no packet received, identify whether the interface is down. |
PING_VPN_STATISTICS
Message text |
[STRING] statistics for [STRING] in VPN instance [STRING] : [UINT32] packets transmitted, [UINT32] packets received, [DOUBLE]% packet loss, round-trip min/avg/max/std-dev = [DOUBLE]/[DOUBLE]/[DOUBLE]/[DOUBLE] ms. |
Variable fields |
$1: Ping or ping6. $2: IP address, IPv6 address, or host name for the destination. $3: VPN instance name. $4: Number of sent echo requests. $5: Number of received echo replies. $6: Percentage of the non-replied packets to the total request packets. $7: Minimum round-trip delay. $8: Average round-trip delay. $9: Maximum round-trip delay. $10: Standard deviation round-trip delay. |
Severity level |
6 |
Example |
PING/6/PING_VPN_STATISTICS: Ping statistics for 192.168.0.115 in VPN instance vpn1: 5 packets transmitted, 5 packets received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms. |
Explanation |
A user uses the ping command to identify whether a destination in a private network is reachable. |
If there is no packet received, identify whether the interface is down and identify whether a valid route exists in the routing table. |
PKG messages
This section contains package management messages.
PKG_BOOTLOADER_FILE_FAILED
Message text |
Failed to execute the boot-loader file command. |
Variable fields |
None |
Severity level |
5 |
Example |
PKG/5/PKG_BOOTLOADER_FILE_FAILED: -IPAddr=192.168.79.1-User=**; Failed to execute the boot-loader file command. |
Explanation |
A user executed the boot-loader file command, but the command failed. |
Take actions as prompted by the command. |
PKG_BOOTLOADER_FILE_SUCCESS
Message text |
Executed the boot-loader file command successfully. |
Variable fields |
· None |
Severity level |
5 |
Example |
PKG/5/PKG_BOOTLOADER_FILE_SUCCESS: -IPAddr=192.168.79.1-User=**; Executed the boot-loader file command successfully. |
Explanation |
A user executed the boot-loader file command successfully. |
PKG_INSTALL_ACTIVATE_FAILED
Message text |
Failed to execute the install activate command. |
Variable fields |
None |
Severity level |
5 |
Example |
PKG/5/PKG_INSTALL_ACTIVATE_FAILED: -IPAddr=192.168.79.1-User=**; Failed to execute the install activate command. |
Explanation |
A user executed the install activate command, but the command failed. |
PKG_INSTALL_ACTIVATE_SUCCESS
Message text |
Executed the install activate command successfully. |
Variable fields |
None |
Severity level |
5 |
Example |
PKG/5/PKG_INSTALL_ACTIVATE_SUCCESS: -IPAddr=192.168.79.1-User=**; Executed the install activate command successfully. |
Explanation |
A user executed the install activate command successfully. |
PKI messages
This section contains PKI messages.
GET_CERT_FROM_CA_SERVER_FAIL
Message text |
Failed to get the CA or RA certificate from the CA server. Reason: [STRING]. |
Variable fields |
$1: Failure reason: · Failed to get the source IP address of PKI protocol packets. · Failed to get the certificate chain. · Root CA not found in the certificate chain. · Failed to verify the CA/RA certificate chain (%s). |
Severity level |
5 |
Example |
PKI/5/GET_CERT_FROM_CA_SERVER_FAIL: Failed to get the CA or RA certificate from the CA server. Reason: root CA not found in the certificate chain. |
Explanation |
Failed to get the CA or RA certificate from the CA server. The reason for the failure is displayed. |
IMPORT_CERT_FAIL
Message text |
Failed to import the certificate. Reason: [STRING]. |
Variable fields |
$1: Failure reason: · Unable to get issuer certificate. · Unable to get certificate CRL. · Unable to decrypt CRL's signature. · Unable to decode issuer public key. · Certificate signature failure. · CRL signature failure. · Unable to decrypt certificate's signature. · Certificate is not yet valid. · Certificate has expired. · CRL is not yet valid. · CRL has expired. · Format error in certificate's notBefore field. · Format error in certificate's notAfter field. · Format error in CRL's lastUpdate field. · Format error in CRL's nextUpdate field. · Out of memory. · Self signed certificate. · Self signed certificate in certificate chain. · Unable to get local issuer certificate. · Unable to verify the first certificate. · Certificate chain too long. · Certificate revoked. · Invalid CA certificate. · Invalid non-CA certificate (has CA markings). · Path length constraint exceeded. · Proxy path length constraint exceeded. · Proxy certificates not allowed, please set the appropriate flag. · Unsupported certificate purpose. · Certificate not trusted. · Certificate rejected. · Application verification failure. · Subject issuer mismatch. · Authority and subject key identifier mismatch. · Authority and issuer serial number mismatch. · Key usage does not include certificate signing. · Unable to get CRL issuer certificate. · Unhandled critical extension. · Key usage does not include CRL signing. · Key usage does not include digital signature. · Unhandled critical CRL extension. · Invalid or inconsistent certificate extension. · Invalid or inconsistent certificate policy extension. · No explicit policy. · Different CRL scope. · Unsupported extension feature. · RFC 3779 resource not subset of parent's resources. · Permitted subtree violation. · Excluded subtree violation. · Name constraints minimum and maximum not supported. · Unsupported name constraint type. · CRL path validation error. · Unsupported or invalid name syntax. · Unsupported or invalid name constraint syntax. · Suite B: certificate version invalid. · Suite B: invalid public key algorithm. · Suite B: invalid ECC curve. · Suite B: invalid signature algorithm. · Suite B: curve not allowed for this LOS. · Suite B: cannot sign P-384 with P-256. · Hostname mismatch. · Email address mismatch. · IP address mismatch. · Invalid certificate verification context. · Issuer certificate lookup error. · proxy subject name violation. |
Severity level |
5 |
Example |
PKI/5/IMPORT_CERT_FAIL: failed to import the certificate. Reason: invalid CA certificate. |
Explanation |
Failed to import a certificate. The reason for the failure is displayed. |
Recommended action |
REQUEST_CERT_FAIL
Message text |
Failed to request certificate of domain [STRING]. |
Variable fields |
$1: PKI domain name |
Severity level |
5 |
Example |
PKI/5/REQUEST_CERT_FAIL: Failed to request certificate of domain abc. |
Explanation |
Failed to request certificate for a domain. |
Check the configuration of the device and CA server, and the network between them. |
REQUEST_CERT_SUCCESS
Message text |
Request certificate of domain [STRING] successfully. |
Variable fields |
Severity level |
5 |
Example |
PKI/5/REQUEST_CERT_SUCCESS: Request certificate of domain abc successfully. |
Explanation |
Successfully requested certificate for a domain. |
RETRIEVE_CRL_FAIL
Message text |
Failed to retrieve the CRL. Reason: [STRING]. |
Variable fields |
$1: Failure reason: · Certificate request URL is not configured. · No local certificate. · No RA certificate. · Type of certificate request reception authority is not configured. · Failed to get the source IP address of PKI protocol packets. · Local certificate and key mismatch. · Failed to get the encryption certificate. · Failed to get issuer name from CA certificate. · Failed to get serial number from CA certificate. · Failed to parse the URL. · Failed to get CRLs from reply. · Failed to get CRL data from the reply. · Unable to get local issuer certificate. · CRL signature failure. · Unable to decode issuer public key. · Format error in CRL's lastUpdate field. · CRL is not yet valid. · Format error in CRL's nextUpdate field. · CRL has expired. · Unable to get issuer certificate. · Failed to save the CRL to the device. · Unable to get certificate CRL. · Unable to decrypt CRL's signature. |
Severity level |
5 |
Example |
PKI/5/RETRIEVE_CRL_FAIL: Failed to retrieve the CRL. Reason: CRL has expired. |
Explanation |
Failed to retrieve the CRL. The reason for the failure is displayed. |
VALIDATE_CERT_FAIL
Message text |
Failed to validate the certificate. Reason: [STRING]. |
Variable fields |
$1: Failure reason: · Unable to get issuer certificate. · Unable to get certificate CRL. · Unable to decrypt CRL's signature. · Unable to decode issuer public key. · Certificate signature failure. · CRL signature failure. · Unable to decrypt certificate's signature. · Certificate is not yet valid. · Certificate has expired. · CRL is not yet valid. · CRL has expired. · Format error in certificate's notBefore field. · Format error in certificate's notAfter field. · Format error in CRL's lastUpdate field. · Format error in CRL's nextUpdate field. · Out of memory. · Self signed certificate. · Self signed certificate in certificate chain. · Unable to get local issuer certificate. · Unable to verify the first certificate. · Certificate chain too long. · Certificate revoked. · Invalid CA certificate. · Invalid non-CA certificate (has CA markings). · Path length constraint exceeded. · Proxy path length constraint exceeded. · Proxy certificates not allowed, please set the appropriate flag. · Unsupported certificate purpose. · Certificate not trusted. · Certificate rejected. · Application verification failure. · Subject issuer mismatch. · Authority and subject key identifier mismatch. · Authority and issuer serial number mismatch. · Key usage does not include certificate signing. · Unable to get CRL issuer certificate. · Unhandled critical extension. · Key usage does not include CRL signing. · Key usage does not include digital signature. · Unhandled critical CRL extension. · Invalid or inconsistent certificate extension. · Invalid or inconsistent certificate policy extension. · No explicit policy. · Different CRL scope. · Unsupported extension feature. · RFC 3779 resource not subset of parent's resources. · Permitted subtree violation. · Excluded subtree violation. · Name constraints minimum and maximum not supported. · Unsupported name constraint type. · CRL path validation error. · Unsupported or invalid name syntax. · Unsupported or invalid name constraint syntax. · Suite B: certificate version invalid. · Suite B: invalid public key algorithm. · Suite B: invalid ECC curve. · Suite B: invalid signature algorithm. · Suite B: curve not allowed for this LOS. · Suite B: cannot sign P-384 with P-256. · Hostname mismatch. · Email address mismatch. · IP address mismatch. · Invalid certificate verification context. · Issuer certificate lookup error. · Proxy subject name violation. |
Severity level |
5 |
Example |
PKI/5/VALIDATE_CERT_FAIL: Failed to validate certificate. Reason: Invalid CA certificate. |
Explanation |
Failed to validate the certificate. The reason for the failure is displayed. |
PKT2CPU messages
This section contains PKT2CPU messages.
PKT2CPU_NO_RESOURCE
Message text |
-Interface=[STRING]-ProtocolType=[UINT32]-MacAddr=[STRING]; The resources are insufficient. -Interface=[STRING]-ProtocolType=[UINT32]-SrcPort=[UINT32]-DstPort=[UINT32]; The resources are insufficient. |
Variable fields |
$1: Interface type and number. $2: Protocol type. $3: MAC address or source port. $4: Destination port. |
Severity level |
4 |
Example |
PKT2CPU/4/PKT2CPU_NO_RESOURCE: -Interface=Ethernet0/0/2-ProtocolType=21-MacAddr=0180-c200-0014; The resources are insufficient. |
Explanation |
Hardware resources were insufficient. |
Cancel the configuration. |
PKTCPT
This section contains packet capture messages.
PKTCPT_AP_OFFLINE
Message text |
Failed to start packet capture. Reason: AP was offline. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_AP_OFFLINE: Failed to start packet capture. Reason: AP was offline. |
Explanation |
Packet capture failed to start because the AP configured with packet capture was offline. |
324. Verify the AP configuration, and restart packet capture after the AP comes online. 325. If the problem persists, contact H3C Support. |
PKTCPT_AREADY_EXIT
Message text |
Failed to start packet capture. Reason: The AP was uploading frames captured during the previous capturing operation. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_AREADY_EXIT: Failed to start packet capture. Reason: The AP was uploading frames captured during the previous capturing operation. |
Explanation |
When packet capture is stopped on the AC, the fit AP might be still uploading the captured frames. This message is generated when the user restarted packet capture at that time. |
326. Restart packet capture later. 327. If the problem persists, contact H3C Support. |
PKTCPT_CONN_FAIL
Message text |
Failed to start packet capture. Reason: Failed to connect to the FTP server. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_CONN_FAIL: Failed to start packet capture. Reason: Failed to connect to the FTP server. |
Explanation |
Packet capture failed to start because the device failed to be connected to the FTP server in the same network segment. |
328. Verify that the URL of the FTP server is valid. Possible reasons for an invalid URL include: ¡ The specified IP address does not exist or is not the FTP server address. ¡ The specified FTP server port is disabled. 329. Verify that the domain name resolution is successful. 330. Verify that the FTP server is reachable for the device configured with packet capture. 331. Verify that the FTP server is online. 332. If the problem persists, contact H3C Support. |
PKTCPT_INVALID_FILTER
Message text |
Failed to start packet capture. Reason: Invalid expression for matching packets to be captured. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_INVALD_FILTER: Failed to start packet capture. Reason: Invalid expression for matching packets to be captured. |
Explanation |
Packet capture failed to start because the capture filter expression was invalid. |
333. Correct the capture filter expression. 334. If the problem persists, contact H3C Support. |
PKTCPT_LOGIN_DENIED
Message text |
Packet capture aborted. Reason: FTP server login failure. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_LOGIN_DENIED: Packet capture aborted. Reason: FTP server login failure. |
Explanation |
Packet capture stopped because the user failed to log in to the FTP server. |
335. Verify the username and password. 336. If the problem persists, contact H3C Support. |
PKTCPT_MEMORY_ALERT
Message text |
Packet capture aborted. Reason: Memory threshold reached. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_MEMORY_ALERT: Packet capture aborted. Reason: Memory threshold reached. |
Explanation |
Packet capture stopped because the memory threshold was reached. |
N/A |
PKTCPT_OPEN_FAIL
Message text |
Failed to start packet capture. Reason: File for storing captured frames not opened. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_OPEN_FAIL: Failed to start packet capture. Reason: File for storing captured frames not opened. |
Explanation |
Packer capture failed to start because the file for storing the captured frames cannot be opened. |
337. Verify that the user has the write permission to the file. If the user does not have the write permission, assign the permission to the user. 338. Verify that the specified file has been created and is not used by another feature. If the file is used by another feature, use another file. 339. If the problem persists, contact H3C Support. |
PKTCPT_OPERATION_TIMEOUT
Message text |
Failed to start or continue packet capture. Reason: Operation timed out. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_OPERATION_TIMEOUT: Failed to start or continue packet capture. Reason: Operation timed out. |
Explanation |
This message is generated in the following situations: · Packet capture failed to start because the FTP server in a different network segment is not reachable and the connection timed out. · Packet capture stopped because the FTP server in a different network segment is offline and uploading the captured frames timed out. |
340. Verify that the FTP server is reachable. 341. Verify that the FTP server is online. 342. If the problem persists, contact H3C Support. |
PKTCPT_SERVICE_FAIL
Message text |
Failed to start packet capture. Reason: TCP or UDP port binding faults. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_SERVICE_FAIL: Failed to start packet capture. Reason: TCP or UDP port binding faults. |
Explanation |
Packet capture failed to start because an error occurs during TCP or UDP port binding. |
343. Verify that Wireshark has been closed before you start packet capture. If it is not closed, close Wireshark, and then restart packet capture. 344. Bind a new TCP or UDP port, and then restart packet capture. 345. If the problem persists, contact H3C Support. |
PKTCPT_UNKNOWN_ERROR
Message text |
Failed to start or continue packet capture. Reason: Unknown error. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_UNKNOWN_ERROR: Failed to start or continue the packet capture. Reason: Unknown error. |
Explanation |
Packet capture failed to start or packet capture stopped because of an unknown error. |
N/A |
PKTCPT_UPLOAD_ERROR
Message text |
Packet capture aborted. Reason: Failed to upload captured frames. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_UPLOAD_ERROR: Packet capture aborted. Reason: Failed to upload captured frames. |
Explanation |
Packet capture stopped because the capture failed to upload the captured frames. |
346. Verify that the FTP working directory is not changed. 347. Verify that the user has the write permission to the file on the FTP server. 348. Verify that the FTP server is online. 349. Verify that the FTP server is reachable. 350. Verify that the FTP server has enough memory space. 351. Verify that the packet capture is not stopped during the upload of captured frames. 352. If the problem persists, contact H3C Support. |
PKTCPT_WRITE_FAIL
Message text |
Packet capture aborted. Reason: Not enough space to store captured frames. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKTCPT/6/PKTCPT_WRITE_FAIL: Packet capture aborted. Reason: Not enough space to store captured frames. |
Explanation |
Packet capture stopped because the memory space is not enough for storing captured frames. |
353. Delete unnecessary files to release the space. 354. If the problem persists, contact H3C Support. |
PoE messages
This section contains PoE messages.
POE_AI_CLEAR
Message text |
Clearing all preceding AI configurations on PoE port [STRING]. Reason: The port still cannot supply power to the PD after forced power supply has been enabled on the port. |
Variable fields |
$1: PI name. |
Severity level |
6 |
Example |
POE/6/POE_AI_CLEAR: Recover the ai PoE configuration on the PoE port GigabitEthernet1/0/1. Reason: The port still cannot supply power to the PD after forced power supply has been enabled on the port. |
Explanation |
A PI still cannot supply power to the PD after forced power supply has been enabled on it. The system is clearing all preceding AI configurations on the PI. |
Check the link between the PI and PD for hardware faults. |
POE_AI_DETECTIONMODE_NONE
Message text |
Changing the PD detection mode for PoE port [STRING] to none. Reason: The port still cannot supply power to the PD after the PD detection mode has been changed to simple. |
Variable fields |
$1: PI name. |
Severity level |
6 |
Example |
POE/6/POE_AI_DETECTIONMODE_NONE: Changing the PD detection mode for PoE port GigabitEthernet1/0/1 to none. Reason: The port still cannot supply power to the PD after the PD detection mode has been changed to simple. |
Explanation |
A PI still cannot supply power to the PD after the PD detection mode has been changed to simple. The system is changing the PD detection mode on the PI to none. |
No action is required |
POE_AI_DETECTIONMODE_SIMPLE
Message text |
Changing the PD detection mode for PoE port [STRING] to simple. Reason: The port still cannot supply power to the PD after non-standard PD detection is enabled. |
Variable fields |
$1: PI name. |
Severity level |
6 |
Example |
POE/6/POE_AI_DETECTIONMODE_SIMPLE: Changing the PD detection mode for PoE port GigabitEthernet1/0/1 to simple. Reason: The port still cannot supply power to the PD after non-standard PD detection is enabled. |
Explanation |
A PI still cannot supply power to the PD after non-standard PD detection is enabled. The system is changing the PD detection mode on the PI to simple. |
POE_AI_DISCONNECT_AC
Message text |
Changing from MPS detection to AC detection on PoE port [STRING]. Reason: The port still cannot supply power to the PD after MPS detection is delayed. |
Variable fields |
$1: PI name. |
Severity level |
6 |
Example |
POE/6/POE_AI_DISCONNET_AC: Changing from MPS detection to AC detection on PoE port GigabitEthernet1/0/1. Reason: The port still cannot supply power to the PD after MPS detection is delayed. |
Explanation |
A PI still cannot supply power to the PD after MPS detection is delayed. The system is changing the detection mode on the PI to AC detection from MPS detection. |
POE_AI_DISCONNECT_DELAY
Message text |
Delaying the MPS detection on PoE port [STRING]. Reason: The port has stopped power supply because of MPS current insufficiency. |
Variable fields |
$1: PI name. |
Severity level |
6 |
Example |
POE/6/POE_AI_DISCONNET_DELAY: Delaying the MPS detection on PoE port GigabitEthernet1/0/1. Reason: The port has stopped power supply because of MPS current insufficiency. |
Explanation |
A PI has stopped power supply to the PD because of MPS current insufficiency. The system is delaying the MPS detection on the PI. |
POE_AI_FORCE_PoE
Message text |
Enabling forced power supply on PoE port [STRING]. Reason: The port still cannot supply power to the PD after the PD detection mode has been changed to none. |
Variable fields |
$1: PI name. |
Severity level |
6 |
Example |
POE/6/POE_AI_FORCE_PoE: Enabling forced power supply on PoE port GigabitEthernet1/0/1. Reason: The port still cannot supply power to the PD after the PD detection mode has been changed to none. |
Explanation |
A PI still cannot supply power to the PD after the PD detection mode has been changed to none. The system is enabling forced power supply on the PI. |
No action is required. |
POE_AI_HIGH_INRUSH
Message text |
Increasing the inrush current threshold for PoE port [STRING]. Reason: The port has stopped power supply because of a high inrush current. |
Variable fields |
N/A |
Severity level |
6 |
Example |
POE/6/POE_AI_HIGH_INRUSH: Increasing the inrush current threshold for PoE port GigabitEthernet1/0/1. Reason: The port has stopped power supply because of a high inrush current. |
Explanation |
A PI has stopped power supply to the PD because of a high inrush current. The system is Increasing the inrush current threshold for the PI. |
POE_AI_LEGACY
Message text |
Enabling non-standard PD detection on PoE port [STRING]. Reason: The port cannot supply power to the PD. |
Variable fields |
$1: PI name. |
Severity level |
6 |
Example |
POE/6/POE_AI_LEGACY: Enabling non-standard PD detection on PoE port GigabitEthernet1/0/1. Reason: The port cannot supply power to the PD. |
Explanation |
A PI cannot supply power to the PD. The system is enabling non-standard PD detection on the PI. |
POE_AI_MAXPOWER
Message text |
Increasing the maximum power of PoE port [STRING] to [UINT32]. Reason: An instant power surge has caused overload self-protection of the port |
Variable fields |
$1: PI name. $2: Maximum power. |
Severity level |
6 |
Example |
POE/6/POE_AI_MAXPOWER: Increasing the maximum power of PoE port GigabitEthernet1/0/1 to 2000. Reason: An instant power surge has caused overload self-protection of the port. |
Explanation |
A PI has entered overload self-protection due to an instant power surge. The system is increasing the maximum power of the PI. |
POE_AI_RESTART
Message text |
Re-enabling PoE on port [STRING]. Reason: The power consumption of the port is 0. |
Variable fields |
$1: PI name. |
Severity level |
6 |
Example |
POE/6/POE_AI_RESTART: Re-enabling PoE on port GigabitEthernet1/0/1. Reason: The power consumption of the port is 0. |
Explanation |
A PI is in power supply state but its power consumption is 0. The system is re-enabling PoE on the PI. |
Portal messages
This section contains portal messages.
PORTAL_RULE_FAILED
Message text |
Failed to assign a portal rule. Reason=[STRING]. |
Variable fields |
$1: Reason for rule assignment failure, see Table 10. |
Severity level |
4 |
Example |
PORTAL/4/PORTAL_RULE_FAILED: -Slot=10; Failed to assign a portal rule. Reason=Not enough resources. |
Explanation |
Failed to assign a portal rule. |
Choose a recommended action according to the reason (see Table 10). |
Table 10 Reason for rule assignment failure and recommended action
Reason |
Portal failed to assign a rule to the driver. |
Save this message to a local file, and then contact H3C Support. |
Input parameters in the rule are incorrect. |
The rule already exists. |
The driver doesn't support rule assignment. |
Identify whether the device supports portal filtering rules. · If the device does not support portal filtering rules, no action is required. · If the device supports portal filtering rules, report this message to H3C Support for help. |
355. Examine the hardware resource usage by using the display qos-acl resource command. 356. Release some hardware resources. |
PORTSEC messages
This section contains port security messages.
PORTSEC_ACL_FAILURE
Message text |
-IfName=[STRING]-MACAddr=[STRING]; ACL authorization failed because [STRING]. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: Cause of failure: · the specified ACL didn't exist. · this type of ACL is not supported. · hardware resources were insufficient. · the specified ACL conflicted with other ACLs applied to the interface. · the specified ACL didn't contain any rules. |
Severity level |
4 |
Example |
PORTSEC/4/PORTSEC_ACL_FAILURE:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9; ACL authorization failed because the specified ACL didn't exist. |
Explanation |
ACL authorization failed for a specific reason. |
Handle the issue according to the failure cause. |
PORTSEC_CAR_FAILURE
Message text |
-IfName=[STRING]-MACAddr=[STRING]; Failed to assign CAR attributes to driver. |
Variable fields |
$1: Interface type and number. $2: MAC address. |
Severity level |
5 |
Example |
PORTSEC/5/PORTSEC_CAR_FAILURE:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9; Failed to assign CAR attributes to driver. |
Explanation |
The device failed to assign CAR attributes to the driver. |
PORTSEC_CREATEAC_FAILURE
Message text |
-IfName=[STRING]-VLANID=[STRING]-MACAddr=[STRING]-VSIName=[STRING]; Failed to map an Ethernet service instance to the VSI. |
Variable fields |
$1: Interface type and number. $2: VLAN ID. $3: MAC address. $4: VSI name. |
Severity level |
3 |
Example |
PORTSEC/3/PORTSEC_CREATEAC_FAILURE:-IfName=GigabitEthernet1/0/4-VLANID=444-MACAddr=0010-8400-22b9-VSIName=aaa; Failed to map an Ethernet service instance to the VSI. |
Explanation |
The operation of mapping an Ethernet service instance to a specific VSI failed. |
Execute the display l2vpn vsi command and verify that the VSI exists. If the VSI does not exist, create the VSI by using the vsi command. |
PORTSEC_LEARNED_MACADDR
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]; A new MAC address was learned. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: VLAN ID. |
Severity level |
6 |
Example |
PORTSEC/6/PORTSEC_LEARNED_MACADDR:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444; A new MAC address was learned. |
Explanation |
A new secure MAC address was learned on the interface. |
PORTSEC_NTK_NOT_EFFECTIVE
Message text |
The NeedToKnow feature is configured but is not effective on interface [STRING]. |
Variable fields |
$1: Interface type and number. |
Severity level |
3 |
Example |
PORTSEC/3/PORTSEC_NTK_NOT_EFFECTIVE: The NeedToKnow feature is configured but is not effective on interface Ethernet3/1/2. |
Explanation |
The NeedToKnow mode does not take effect on an interface, because the interface does not support the NeedToKnow mode. |
357. Disable the NeedToKnow feature on the interface. 358. Reconnect the connected devices to another interface that supports the NeedToKnow mode. 359. Configure the NeedToKnow mode on the new interface. |
PORTSEC_PORTMODE_NOT_EFFECTIVE
Message text |
The port security mode is configured but is not effective on interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PORTSEC/3/PORTSEC_PORTMODE_NOT_EFFECTIVE: The port security mode is configured but is not effective on interface Ethernet3/1/2. |
Explanation |
The port security mode does not take effect on an interface, because the interface does not support this mode. |
· Change the port security mode to another mode that is supported by the interface. · Reconnect the connected devices to another interface that supports this port security mode, and configure the port security mode on the new interface. |
PORTSEC_PROFILE_FAILURE
Message text |
-IfName=[STRING]-MACAddr=[STRING]; Failed to assign a user profile to driver. |
Variable fields |
Severity level |
5 |
Example |
PORTSEC/5/PORTSEC_PROFILE_FAILURE:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9; Failed to assign a user profile to driver. |
Explanation |
The device failed to assign a user profile to the driver. |
PORTSEC_URL_FAILURE
Message text |
-IfName=[STRING]-MACAddr=[STRING]; URL authorization failed because [STRING]. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: Cause of failure: · this operation was not supported. · hardware resources were insufficient. · parameters were invalid. · an unknown error existed. |
Severity level |
4 |
Example |
PORTSEC/4/PORTSEC_URL_FAILURE:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9; URL authorization failed because hardware resources were insufficient. |
Explanation |
URL authorization failed for a specific reason. |
PORTSEC_VIOLATION
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-IfStatus=[STRING]; Intrusion protection was triggered. |
Variable fields |
$1: Interface type and number. $2: MAC address. $3: VLAN ID. $4: Interface status. |
Severity level |
5 |
Example |
PORTSEC/5/PORTSEC_VIOLATION:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-IfStatus=Up; Intrusion protection was triggered. |
Explanation |
· Check the port security configuration. · Change the port security mode to another mode. |
PORTSEC_VLANMACLIMIT
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]; Maximum number of MAC addresses already reached in the VLAN. |
Variable fields |
Severity level |
5 |
Example |
PORTSEC/5/PORTSEC_VLANMACLIMIT:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444; Maximum number of MAC addresses already reached in the VLAN. |
Explanation |
Access attempt from a new user in a VLAN was rejected on a port because the number of MAC addresses has reached port security's limit on the port for that VLAN. |
Examine the network for the risk of unknown source MAC attacks. |
PPP messages
This section contains PPP messages.
IPPOOL_ADDRESS_EXHAUSTED
Message text |
The address pool [STRING] was exhausted. |
Variable fields |
$1: Pool name. |
Severity level |
5 |
Example |
PPP/5/IPPOOL_ADDRESS_EXHAUSTED: The address pool aaa was exhausted. |
Explanation |
This message is generated when the last address is assigned from the pool. |
Add addresses to the pool. |
PPP_USER_LOGON_SUCCESS
Message text |
-UserName=[STRING]-IPAddr=[IPADDR]-IfName=[STRING]-OutVlan=[UINT16]-InVlan=[UINT16]-MACAddr=[MAC]; User got online successfully. |
Variable fields |
$1: Username. $2: IP address. $3: Interface name. $4: Outer VLAN ID. $5: Inner VLAN ID. $6: MAC address. |
Severity level |
6 |
Example |
PPP/6/PPP_USER_LOGON_SUCCESS: -UserName=abc-IPAddr=1.1.1.2-IfName=Route-Aggregation1023.4000-OutVlan=1000-InVlan=4000-MACAddr=0230-0103-5601; User got online successfully. |
Explanation |
The user has come online. |
PPP_USER_LOGON_FAILED
Message text |
-UserName=[STRING]-IPAddr=[IPADDR]-IfName=[STRING]-OutVlan=[UINT16]-InVlan=[UINT16]-MACAddr=[MAC]-Reason=[STRING]; User got online failed. |
Variable fields |
$1: Username. $2: IP address. $3: Interface name. $4: Outer VLAN ID. $5: Inner VLAN ID. $6: MAC address. $7: Cause. |
Severity level |
5 |
Example |
PPP/5/PPP_USER_LOGON_FAILED: -UserName=abc-IPAddr=1.1.1.2-IfName=Route-Aggregation1023.4000-OutVlan=1000-InVlan=4000-MACAddr=0230-0103-5601-Reason=Authentication failed; User got online failed. |
Explanation |
The user failed to come online. |
360. Verify that the username and password are correct. 361. Verify that the AAA server is operating correctly. 362. Verify that the address pool is configured correctly. |
PPP_USER_LOGOFF
Message text |
-UserName=[STRING]-IPAddr=[IPADDR]-IfName=[STRING]-OutVlan=[UINT16]-InVlan=[UINT16]-MACAddr=[MAC]-Reason=[STRING]; User logged off. |
Variable fields |
$1: Username. $2: IP address. $3: Interface name. $4: Outer VLAN ID. $5: Inner VLAN ID. $6: MAC address. $7: Cause (see Table 11). |
Severity level |
6 |
Example |
PPP/6/PPP_USER_LOGOFF: -UserName=abc-IPAddr=1.1.1.2-IfName=Route-Aggregation1023.4000-OutVlan=1000-InVlan=4000-MACAddr=0230-0103-5601-Reason=Use request; User logged off. |
Explanation |
The user has gone offline. |
Cause |
User request |
The user session was terminated at the user's request. |
Lost carrier |
The Keepalive packets were lost, possibly because the link between the user device and the device connecting to the BAS fails. |
Lost service |
The service server terminated the service, such as L2TP. |
BAS error |
The BAS software errors caused the user logoff. |
BAS reboot |
The BAS sent disconnection information before an unexpected reboot. |
Admin reset |
The user session was terminated because of management reasons. |
BAS request |
Unknown reasons. |
Session timeout |
The user session timed out or the traffic quota was used up. |
Server command |
The AAA server logged off the user. |
Idle timeout |
The user traffic did not reach the threshold within the specified period. |
Account update fail |
The accounting update failed. |
Port error |
The BAS detected errors on the user access port. |
Admin reboot |
The BAS sent disconnection information before a reboot. |
PTS
This section contains Platform Trust Services (PTS) messages.
PTS_AK_AUTH_FAILED
Message text |
Inconsistent authorization data for attestation key [STRING]. |
Variable fields |
$1: AK name. |
Severity level |
4 |
Example |
PTS/4/PTS_AK_AUTH_FAILED: Inconsistent authorization data for attestation key abc. |
Explanation |
The authorization data specified for the integrity report attestation-key command is different from the authorization data specified for the AK when the AK was created. The command for creating a key is key create. |
Specify the same authorization data for the integrity report attestation-key command as the authorization data you specified when you created the key. |
PTS_AK_INVALID
Message text |
The attestation key [STRING] is incorrect. |
Variable fields |
$1: AK name. |
Severity level |
4 |
Example |
PTS/4/PTS_AK_INVALID: The attestation key abc is incorrect. |
Explanation |
The specified AK is invalid. |
Specify a valid AK for TC reporting. |
PTS_AK_NO_CERT
Message text |
No certificate file found for attestation key [STRING]. |
Variable fields |
$1: AK name. |
Severity level |
4 |
Example |
PTS/4/PTS_AK_NO_CERT: No certificate file found for attestation key abc. |
Explanation |
No certificate was found for the AK. |
Use the manager to sign an AK certificate for the AK of the device. |
PTS_AK_NO_EXIST
Message text |
Attestation key [STRING] doesn't exist. |
Variable fields |
$1: AK name. |
Severity level |
4 |
Example |
PTS/4/PTS_AK_NO_EXIST: The attestation key abc doesn't exist. |
Explanation |
The AK does not exist. |
Use the key create command to create the AK. |
PTS_AK_NO_LOAD
Message text |
The attestation key [STRING] is not loaded. |
Variable fields |
$1: AK name. |
Severity level |
4 |
Example |
PTS/4/PTS_AK_NO_LOAD: The attestation key abc is not loaded. |
Explanation |
The AK is not loaded to the TC chip. |
Use the key load command to load the AK to the TC chip. |
PTS_BTW_PCR_FAILED
Message text |
Hash value computed based on BootWare IML is not consistent with that in PCR ([UINT]). |
Variable fields |
$1: PCR index. |
Severity level |
4 |
Example |
PTS/4/PTS_BTW_PCR_FAILED: Hash value computed based on BootWare IML is not consistent with that in PCR(0). |
Explanation |
The hash value computed by using the BootWare IML for the basic or extended segment is different from the hash value stored in the PCR. The BootWare is not trustworthy. |
Contact H3C Support. |
PTS_CHECK_RM_VERSION_FAILED
Message text |
Version the RM file [STRING] is not supported. |
Variable fields |
$1: RM file name. |
Severity level |
4 |
Example |
PTS/4/PTS_CHECK_RM_VERSION_FAILED: Version the RM file BOOTWARE_BASIC_52B.rm is not supported. |
Explanation |
The device does not support the RM file version. |
PTS_CREATE_AGED_TIMER_FAILED
Message text |
Failed to create PTS session ageing timer. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PTS/4/PTS_CREATE_AGED_TIMER_FAILED: Failed to create PTS session ageing timer. |
Explanation |
PTS failed to create the session aging timer. |
363. Execute the undo pts command and the pts command in turn to restart the PTS service. 364. If the problem persists, contact H3C Support. |
PTS_CREATE_CHECK_TIMER_FAILED
Message text |
Failed to create server check timer. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PTS/4/PTS_CREATE_CHECK_TIMER_FAILED: Failed to create server check timer. |
Explanation |
PTS failed to create the server check timer. |
1. Execute the undo pts command and the pts command in turn to restart the PTS service. 2. If the problem persists, contact H3C Support. |
PTS_CREATE_CONTEXT_FAILED
Message text |
Failed to create TSS context. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PTS/4/PTS_CREATE_CONTEXT_FAILED: Failed to create TSS context. |
Explanation |
PTS failed to create the TPM software stack context. |
PTS_CREATE_EPOLL_FAILED
Message text |
Failed to create epoll service. |
Variable fields |
N/A |
Severity level |
3 |
Example |
PTS/3/PTS_CREATE_EPOLL_FAILED: Failed to create epoll service. |
Explanation |
PTS failed to create the epoll service. |
3. Execute the undo pts command and the pts command in turn to restart the PTS service. 4. If the problem persists, contact H3C Support. |
PTS_CREATE_HASH_FAILED
Message text |
Failed to create hash table. |
Variable fields |
N/A |
Severity level |
3 |
Example |
PTS/3/PTS_CREATE_HASH_FAILED: Failed to create hash table. |
Explanation |
PTS failed to create the hash table. |
5. Execute the undo pts command and the pts command in turn to restart the PTS service. 6. If the problem persists, contact H3C Support. |
PTS_CREATE_SELFVERIFY_COUNTER_FAILED
Message text |
Failed to create selfverify counter. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PTS/4/PTS_CREATE_SELFVERIFY_COUNTER_FAILED: Failed to create selfverify counter. |
Explanation |
PTS failed to create the integrity self-verification IML counter. The integrity self-verification feature is not available. |
7. Execute the undo pts command and the pts command in turn to restart the PTS service. 8. If the problem persists, contact H3C Support. |
PTS_CREATE_SELFVERIFY_TIMER_FAILED
Message text |
Failed to create selfverify timer. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PTS/4/PTS_CREATE_SELFVERIFY_TIMER_FAILED: Failed to create selfverify timer. |
Explanation |
PTS failed to create the integrity self-verification timer. The periodic integrity self-verification feature is not available. |
· Contact H3C Support. · Use the integrity selfverify command to manually perform an integrity self-verification. |
PTS_CREATE_SOCKET_FAILED
Message text |
Failed to create socket service. |
Variable fields |
N/A |
Severity level |
3 |
Example |
PTS/3/PTS_CREATE_SOCKET_FAILED: Failed to create socket service. |
Explanation |
PTS failed to create the socket service. |
9. Execute the undo pts command and the pts command in turn to restart the PTS service. 365. If the problem persists, contact H3C Support. |
PTS_CREATE_TIMER_FAILED
Message text |
Failed to create timer. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PTS/4/PTS_CREATE_TIMER_FAILED: Failed to create timer. |
Explanation |
PTS failed to create a timer. PTS generates this log message whenever it fails to create a timer. |
10. Execute the undo pts command and the pts command in turn to restart the PTS service. 11. If the problem persists, contact H3C Support. |
PTS_FILE_HASH_FAILED
Message text |
Hash value of file [STRING] is not consistent with that in the RM file. |
Variable fields |
$1: Name of the file of which you want to measure the integrity. |
Severity level |
4 |
Example |
PTS/4/PTS_FILE_HASH_FAILED: Hash value of file /sbin/ls is not consistent with that in the RM file. |
Explanation |
The hash value computed for the specified file is different from the hash value of the file stored in the RM file. The file is not trustworthy. |
PTS_LOAD_KEY_FAILED
Message text |
Failed to load attestation key [STRING]. |
Variable fields |
$1: AK name. |
Severity level |
4 |
Example |
PTS/4/PTS_LOAD_KEY_FAILED: Failed to load attestation key abc. |
Explanation |
PTS failed to load the AK name to the TPM. |
12. Verify that the AK exists and is enabled. To display AK information, use the display tcsm key name command. 13. If the problem persists, contact H3C Support. |
PTS_PARSE_IML_FAILED
Message text |
Failed to parse IML. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PTS/4/PTS_PARSE_IML_FAILED: Failed to parse IML. |
Explanation |
PTS failed to parse an IML. |
14. Execute the undo pts command and the pts command in turn to restart the PTS service. 15. If the problem persists, contact H3C Support. |
PTS_PKG_PCR_FAILED
Message text |
Hash value computed based on Package IML is not consistent with that in PCR ([UINT]). |
Variable fields |
$1: PCR index. |
Severity level |
4 |
Example |
PTS/4/PTS_PKG_PCR_FAILED: Hash value computed based on Package IML is not consistent with that in PCR (12). |
Explanation |
The hash value computed by using the Comware image IML is different from the hash value stored in the PCR. The Comware images are not trustworthy. |
PTS_READ_PCR_FAILED
Message text |
Failed to read PCR ([UINT]). |
Variable fields |
$1: PCR index. |
Severity level |
4 |
Example |
PTS/4/PTS_READ_PCR_FAILED: Failed to read PCR(0). |
Explanation |
PTS failed to read PCR data. |
PTS_RM_FILE_FAILED
Message text |
Wrong signature for RM file [STRING]. |
Variable fields |
$1: RM file name. |
Severity level |
4 |
Example |
PTS/4/PTS_RM_FILE_FAILED: Wrong signature for RM file BOOTWARE_BASIC_52B.rm. |
Explanation |
The signature for the RM file is incorrect. |
PTS_RUNTIME_PCR_FAILED
Message text |
Hash value computed based on runtime IML is not consistent with that in PCR ([UINT]). |
Variable fields |
$1: PCR index. |
Severity level |
4 |
Example |
PTS/4/PTS_RUNTIME_PCR_FAILED: Hash value computed based on runtime IML is not consistent with that in PCR (10). |
Explanation |
The hash value computed by using the runtime IML is different from the hash value stored in the PCR. The runtime-related executable files are not trustworthy. |
PTS_SELFVERIFY_FAILED
Message text |
Failed to start integrity selfverify. Reason: TPM doesn't exist or isn't enabled. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PTS/4/PTS_SELFVERIFY_FAILED: Failed to start integrity selfverify because TPM does not exist or is not enabled. |
Explanation |
Because the TPM did not exist or was disabled, the integrity self-verification failed. |
Verify that the TPM is available. To display relevant information, use the display tcsm trusted-computing-chip command. |
PTS_SELFVERIFY_START_FAILED
Message text |
Failed to start selfverify. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PTS/4/PTS_SELFVERIFY_START_FAILED: Failed to start selfverify. |
Explanation |
PTS failed to start integrity self-verification. |
16. Start integrity self-verification again. 17. If the problem persists, contact H3C Support. |
PTS_TEMPLATE_HASH_FAILED
Message text |
Calculated template hash value of [STRING] is not consistent with that in IML. |
Variable fields |
Severity level |
4 |
Example |
PTS/4/PTS_TEMPLATE_HASH_FAILED: Calculated template hash value of /sbin/ls is not consistent with that in IML. |
Explanation |
The template hash value computed by using parameters including the measurement time and the hash value of the program file is different from the template hash value in the IML. The IML might have been tempered with. |
PWDCTL messages
This section contains password control messages.
PWDCTL_ADD_BLACKLIST
Message text |
[STRING] was added to the blacklist for failed login attempts. |
Variable fields |
$1: Username. |
Severity level |
6 |
Example |
PWDCTL/6/PWDCTRL_ADD_BLACKLIST: hhh was added to the blacklist for failed login attempts. |
Explanation |
The user entered an incorrect password. It failed to log in to the device and was added to the password control blacklist. |
PWDCTL_CHANGE_PASSWORD
Message text |
[STRING] changed the password because [STRING]. |
Variable fields |
$1: Username. $2: The reasons for changing the password. ¡ it was the first login of the account. ¡ the password had expired. ¡ the password was too short. ¡ the password was not complex enough. ¡ the password was default password |
Severity level |
6 |
Example |
PWDCTL/6/PWDCTL_CHANGE_PASSWORD: hhh changed the password because it was the first login of the account. |
Explanation |
The user changed the password for some reason. For example, the user changed the password because it is the first login of the user's account. |
PWDCTL_FAILED_TO_WRITEPWD
Message text |
Failed to write the password records to file. |
Variable fields |
N/A |
Severity level |
3 |
Example |
PWDCTL/6/PWDCTL_FAILED_TO_WRITEPWD: Failed to write the password records to file. |
Explanation |
The device failed to write a password to a file. |
Check the file system of the device for memory space insufficiency. |
PWDCTL_FAILED_TO_OPENFILE
Message text |
Failed to open the password file. |
Variable fields |
N/A |
Severity level |
3 |
Example |
PWDCTL/6/PWDCTL_FAILED_TO_OPENFILE: Failed to open the password file. |
Explanation |
The device failed to create or open a .dat file because of file system exception. |
PWDCTL_NOENOUGHSPACE
Message text |
Not enough free space on the storage media where the file is located. |
Variable fields |
N/A |
Severity level |
3 |
Example |
PWDCTL/3/PWDCTL_NOENOUGHSPACE: Not enough free space on the storage media where the file is located. |
Explanation |
Operation failed. There is no sufficient memory space on the storage media such as the flash or CF card where the .dat file is located. |
PWDCTL_NOTFOUNDUSER
Message text |
Can't find the username in the file. |
Variable fields |
N/A |
Severity level |
3 |
Example |
PWDCTL/3/PWDCTL_NOTFOUNDUSER: Can't find the username in the file. |
Explanation |
Failed to set the password for a local user because the device cannot find the user information in the .dat file. |
Create a new local user, or disable and then enable the global password control feature. |
PWDCTL_UPDATETIME
Message text |
Last login time updated after clock update. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PWDCTL/6/PWDCTL_UPDATETIME: Last login time updated after clock update. |
Explanation |
This message is sent when the last login time is updated. |
QOS messages
This section contains QoS messages.
MIRROR_SYNC_CFG_FAIL
Message text |
Failed to restore configuration for monitoring group [UINT32] in [STRING], because [STRING] |
Variable fields |
$1: Monitoring group. $2: Chassis number plus slot number or slot number. $3: Failure cause. |
Severity level |
4 |
Example |
QOS/4/MIRROR_SYNC_CFG_FAIL: Failed to restore configuration for monitoring group 1 in chassis 2 slot 1, because monitoring resources are insufficient. |
Explanation |
After a card was installed, the system failed to restore the configuration for a monitoring group on the card for the following possible reasons: · The number of member ports in the monitoring group exceeds the limit. · The monitoring resources are insufficient on the card. · Member ports in the monitoring group are not supported by the card. |
Delete or modify unsupported settings. |
QOS_CAR_APPLYUSER_FAIL
Message text |
[STRING]; Failed to apply the [STRING] CAR in [STRING] profile [STRING] to the user. Reason: [STRING]. |
Variable fields |
$1: User identity. $2: Application direction. $3: Profile type. $4: Profile name. $5: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_CAR_APPLYUSER_FAIL: -MAC=1111-2222-3333-IP=192.168.1.2-SVLAN=100-VPN=”N/A”-Port=GigabitEthernet5/1/5; Failed to apply the inbound CAR in user profile a to the user. Reason: The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions: · Apply a CAR policy when a user went online. · Modify a configured CAR policy or configure a new CAR policy when a user is online. |
Delete the CAR policy from the profile or modify the parameters of the CAR policy. |
QOS_CBWFQ_REMOVED
Message text |
CBWFQ is removed from [STRING]. |
Variable fields |
$1: Interface name. |
Severity level |
3 |
Example |
QOS/3/QOS_CBWFQ_REMOVED: CBWFQ is removed from GigabitEthernet4/0/1. |
Explanation |
CBWFQ was removed from an interface because the maximum bandwidth or speed configured on the interface was below the bandwidth or speed required for CBWFQ. |
Increase the bandwidth or speed and apply the removed CBWFQ again. |
QOS_GTS_APPLYUSER_FAIL
Message text |
[STRING]; Failed to apply GTS in user profile [STRING] to the user. Reason: [STRING]. |
Variable fields |
$1: User identity. $2: User profile name. $3: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_GTS_APPLYUSER_FAIL: -MAC=1111-2222-3333-IP=192.168.1.2/16-CVLAN=100-Port=GigabitEthernet5/1/5; Failed to apply GTS in user profile a to the user. Reason: The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions: · Apply a GTS action when a user went online. · Modify a configured GTS action or configure a new GTS action when a user is online. |
Delete the GTS action from the user profile or modify the parameters of the GTS action. |
QOS_IFA_CONFIG_FAIL
Message text |
Failed to configure [STRING]. |
Variable fields |
$1: INT setting: ¡ the collector ¡ the device ID ¡ packet drop |
Severity level |
4 |
Example |
QOS/4/QOS_IFA_CONFIG_FAIL: -Slot=2; Failed to configure the device ID. |
Explanation |
The system failed to configure an INT setting. |
Do not perform the configuration. The configuration is not supported. |
QOS_IFA_REFRESH_FAIL
Message text |
Failed to refresh IFA action [UINT32] on interface [STRING]. |
Variable fields |
$1: INT action ID. $2: Interface name. |
Severity level |
4 |
Example |
QOS/4/QOS_IFA_REFRESH_FAIL: Failed to refresh IFA action 1 on interface GigabitEthernet1/0/1. |
Explanation |
The system failed to refresh an INT action on an interface. |
Check the ACL configuration in the INT action. |
QOS_LR_APPLYIF_FAIL
Message text |
Failed to apply the rate limit on interface [STRING]. Reason: [STRING] |
Variable fields |
$1: Interface name. $2: Failure cause: ¡ The operation is not supported. ¡ The resources are insufficient. |
Severity level |
4 |
Example |
QOS/4/QOS_LR_APPLYIF_FAIL: Failed to apply the rate limit on interface GigabitEthernet1/0/1. Reason: The operation is not supported. |
Explanation |
The system failed to apply the rate limit on an interface because the interface does not support rate limit configuration or the resources are insufficient. |
Delete or modify the rate limit configuration according to the failure cause. |
QOS_NOT_ENOUGH_BANDWIDTH
Message text |
Policy [STRING] requested bandwidth [UINT32](kbps). Only [UINT32](kbps) is available on [STRING]. |
Variable fields |
$1: Policy name. $2: Required bandwidth for CBWFQ. $3: Available bandwidth on an interface. $4: Interface name. |
Severity level |
3 |
Example |
QOS/3/QOS_NOT_ENOUGH_BANDWIDTH: Policy d requested bandwidth 10000(kbps). Only 80(kbps) is available on GigabitEthernet4/0/1. |
Explanation |
Configuring CBWFQ on an interface failed because the maximum bandwidth on the interface was less than the bandwidth required for CBWFQ. |
Increase the maximum bandwidth configured for the interface or set lower bandwidth required for CBWFQ. |
QOS_NOT_ENOUGH_NNIBANDWIDTH
Message text |
The total UNI bandwidth is greater than the NNI bandwidth. The total UNI bandwidth is greater than the NNI bandwidth. The bandwidth of [STRING] is changed. The total UNI bandwidth is greater than the NNI bandwidth. [STRING] is created based on [STRING] of the UNI interface |
Variable fields |
Severity level |
4 |
Example |
QOS/4/ QOS_NOT_ENOUGH_NNIBANDWIDTH: The total UNI bandwidth is greater than the NNI bandwidth. QOS/4/ QOS_NOT_ENOUGH_NNIBANDWIDTH: The total UNI bandwidth is greater than the NNI bandwidth. The bandwidth of GigabitEthernet4/0/1 is changed. QOS/4/ QOS_NOT_ENOUGH_NNIBANDWIDTH: The total UNI bandwidth is greater than the NNI bandwidth. Virtual-Access1 is created based on Virtual-Template1 of the UNI interface. |
Explanation |
This message is generated when the total UNI bandwidth is still greater than the NNI bandwidth after the NNI bandwidth is increased or the total UNI bandwidth is reduced. This message is generated when the total UNI bandwidth is greater than the NNI bandwidth because the interface bandwidth is changed. This message is generated when the total UNI bandwidth is greater than the NNI bandwidth because a virtual access interface is created based on a virtual template of the UNI interface. |
Increase the NNI bandwidth or reduce the total UNI bandwidth. |
QOS_POLICY_APPLYCOPP_CBFAIL
Message text |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction of control plane slot [UINT32]. [STRING]. |
Variable fields |
$1: Name of a classifier-behavior association. $2: Policy name. $3: Application direction. $4: Slot number. $5: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYCOPP_CBFAIL: Failed to apply classifier-behavior d in policy b to the inbound direction of control plane slot 3. The behavior is empty. |
Explanation |
The system failed to perform one of the following actions: · Apply a classifier-behavior association to a specific direction of a control plane. · Update a classifier-behavior association applied to a specific direction of a control plane. |
Modify the configuration of the QoS policy according to the failure cause. |
QOS_POLICY_APPLYCOPP_FAIL
Message text |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of control plane slot [UINT32]. [STRING]. |
Variable fields |
$1: Policy name. $2: Traffic direction. $3: Slot number. $4: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYCOPP_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of control plane slot 3. The operation is not supported. |
Explanation |
The system failed to perform one of the following actions: · Apply a QoS policy to a specific direction of a control plane. · Update a QoS policy applied to a specific direction of a control plane. |
QOS_POLICY_APPLYGLOBAL_CBFAIL
Message text |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction globally. [STRING]. |
Variable fields |
$1: Name of a classifier-behavior association. $2: Policy name. $3: Traffic direction. $4: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYGLOBAL_CBFAIL: Failed to apply classifier-behavior a in policy b to the outbound direction globally. The behavior is empty. |
Explanation |
The system failed to perform one of the following actions: · Apply a classifier-behavior association to a specific direction globally. · Update a classifier-behavior association applied to a specific direction globally. |
QOS_POLICY_APPLYGLOBAL_FAIL
Message text |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction globally. [STRING]. |
Variable fields |
$1: Policy name. $2: Traffic direction. $3: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYGLOBAL_FAIL: Failed to apply or refresh QoS policy b to the inbound direction globally. The operation is not supported. |
Explanation |
The system failed to perform one of the following actions: · Apply a QoS policy to a specific direction globally. · Update a QoS policy applied to a specific direction globally. |
QOS_POLICY_APPLYIF_CBFAIL
Message text |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction of interface [STRING]. [STRING]. |
Variable fields |
$1: Name of a classifier-behavior association. $2: Policy name. $3: Traffic direction. $4: Interface name. $5: Failure cause: · The behavior is empty. · The card where the interface specified in the class-behavior association resides is not in position. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYIF_CBFAIL: Failed to apply classifier-behavior b in policy b to the inbound direction of interface Ethernet3/1/2. The behavior is empty. |
Explanation |
The system failed to perform one of the following actions: · Apply a classifier-behavior association to a specific direction of an interface. · Update a classifier-behavior association applied to a specific direction of an interface. |
QOS_POLICY_APPLYIF_FAIL
Message text |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of interface [STRING]. [STRING]. |
Variable fields |
$1: Policy name. $2: Traffic direction. $3: Interface name. $4: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYIF_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of interface Ethernet3/1/2. The operation is not supported. |
Explanation |
The system failed to perform one of the following actions: · Apply a QoS policy to a specific direction of an interface. · Update a QoS policy applied to a specific direction of an interface. |
QOS_POLICY_APPLYUSER_FAIL
Message text |
[STRING]; Failed to apply the [STRING] QoS policy [STRING] in user profile [STRING] to the user.Reason: [STRING]. |
Variable fields |
$1: User identity. $2: Application direction. $3: QoS policy name. $4: User profile name. $5: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYUSER_FAIL: -MAC=1111-2222-3333-IP=192.168.1.2/16-CVLAN=100-Port=GigabitEthernet5/1/5; Failed to apply the inbound QoS policy p in user profile a to the user.Reason: The QoS policy is not supported. |
Explanation |
The system failed to perform one of the following actions: · Issue the settings of a QoS policy when a user went online. · Modify an applied QoS policy or apply a new QoS policy when a user is online. |
Remove the QoS policy from the user profile or modify the parameters of the QoS policy. |
QOS_POLICY_APPLYVLAN_CBFAIL
Message text |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction of VLAN [UINT32]. [STRING]. |
Variable fields |
$1: Name of a classifier-behavior association. $2: Policy name. $3: Application direction. $4: VLAN ID. $5: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYVLAN_CBFAIL: Failed to apply classifier-behavior b in policy b to the inbound direction of VLAN 2. The behavior is empty. |
Explanation |
The system failed to perform one of the following actions: · Apply a classifier-behavior association to a specific direction of a VLAN. · Update a classifier-behavior association applied to a specific direction of a VLAN. |
QOS_POLICY_APPLYVLAN_FAIL
Message text |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of VLAN [UINT32]. [STRING]. |
Variable fields |
$1: Policy name. $2: Application direction. $3: VLAN ID. $4: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYVLAN_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of VLAN 2. The operation is not supported. |
Explanation |
The system failed to perform one of the following actions: · Apply a QoS policy to a specific direction of a VLAN. · Update a QoS policy applied to a specific direction of a VLAN. |
QOS_QMPROFILE_APPLYIF_FAIL
Message text |
Failed to apply queue management profile [STRING] on interface [STRING]. Reason: [STRING] |
Variable fields |
$1: Queue scheduling profile name. $2: Interface name. $3: Failure cause: ¡ The operation is not supported. ¡ The resources are insufficient. |
Severity level |
4 |
Example |
QOS/4/QOS_QMPROFILE_APPLYIF_FAIL: Failed to apply queue management profile b on interface GigabitEthernet1/0/1. Reason: The operation is not supported. |
Explanation |
The system failed to apply a queue scheduling profile to an interface because the interface does not support queue scheduling profiles or the resources are insufficient. |
Remove or modify the queue scheduling profile configuration according to the failure cause. |
QOS_QMPROFILE_APPLYUSER_FAIL
Message text |
[STRING]; Failed to apply queue management profile [STRING] in session group profile [STRING] to the user. Reason: [STRING]. |
Variable fields |
$1: User identity. $2: Queue scheduling profile name. $3: Session group profile name. $4: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_QMPROFILE_APPLYUSER_FAIL: -MAC=1111-2222-3333-IP=192.168.1.2/16-SVLAN=100-Port=GigabitEthernet5/1/5; Failed to apply queue management profile b in session group profile a to the user. Reason: The QMProfile is not supported. |
Explanation |
The system failed to perform one of the following actions: · Issue the settings of a queue scheduling profile when a user went online. · Modify an applied queue scheduling profile or apply a new queue scheduling profile when a user is online. |
Remove the queue scheduling profile from the session group profile or modify the parameters of the queue scheduling profile. |
QOS_QMPROFILE_MODIFYQUEUE_FAIL
Message text |
Failed to configure queue [UINT32] in queue management profile [STRING]. [STRING]. |
Variable fields |
$1: Queue ID. $2: Profile name. $3: Failure cause. |
Severity level |
4 |
Example |
QOS/4/QOS_QMPROFILE_MODIFYQUEUE_FAIL: Failed to configure queue 1 in queue management profile myqueue. The value is out of range. |
Explanation |
The system failed to modify a queue in a queue scheduling profile successfully applied to an interface because the new parameter was beyond port capabilities. |
Remove the queue scheduling profile from the interface, and then modify the parameters for the queue. |
QOS_QUEUE_APPLYIF_FAIL
Message text |
Failed to apply queue scheduling on interface [STRING]. Reason: [STRING] |
Variable fields |
Severity level |
4 |
Example |
QOS/4/QOS_QUEUE_APPLYIF_FAIL: Failed to apply queue scheduling on interface GigabitEthernet1/0/1. Reason: The operation is not supported. |
Explanation |
The system failed to apply queuing configuration to an interface because the interface does not support queuing configuration or the resources are insufficient. |
Delete or modify the queuing configuration according to the failure cause. |
QOS_UNI_RESTORE_FAIL
Message text |
Failed to restore the UNI configuration of [STRING], because the total UNI bandwidth is greater than the NNI bandwidth. |
Variable fields |
Severity level |
4 |
Example |
QOS/4/ QOS_NNIBANDWIDTH_OVERFLOW: Failed to restore the UNI configuration of the interface GigabitEthernet5/1/5, because the total UNI bandwidth is greater than the NNI bandwidth. |
Explanation |
The system failed to restore the UNI configuration of an interface, because the total UNI bandwidth is greater than the NNI bandwidth. |
Increase the NNI bandwidth or reduce the total UNI bandwidth, and then reconfigure the downlink ports as UNI ports. |
WRED_TABLE_CFG_FAIL
Message text |
Failed to dynamically modify the configuration of WRED table [STRING], because [STRING]. |
Variable fields |
$1: WRED table name. $2: Failure cause. |
Severity level |
4 |
Example |
QOS/4/WRED_TABLE_CFG_FAIL: Failed to dynamically modify the configuration of WRED table a, because ECN is not supported. |
Explanation |
Failed to dynamically modify the configuration of a WRED table, because some settings are not supported. |
RADIUS messages
This section contains RADIUS messages.
RADIUS_ACCT_SERVER_DOWN
Message text |
RADIUS accounting server was blocked: Server IP=[STRING], port=[UINT32], VPN instance=[STRING]. |
Variable fields |
$1: IP address of the accounting server. $2: Port number of the accounting server. $3: VPN instance name. This field displays public if the server belongs to the public network. |
Severity level |
4 |
Example |
RADIUS/4/RADIUS_ACCT_SERVER_DOWN: RADIUS accounting server was blocked: Server IP=1.1.1.1, port=1812, VPN instance=public. |
Explanation |
An accounting server became blocked. |
366. Verify that the accounting server has started up. 367. Ping the accounting server to verify that the server is reachable. If the server is not reachable, check the link for connectivity issues and resolve the issues. 368. Collect logs and diagnostic logs, and then contact H3C Support. |
RADIUS_ACCT_SERVER_UP
Message text |
RADIUS accounting server became active: Server IP=[STRING], port=[UINT32], VPN instance=[STRING]. |
Variable fields |
Severity level |
6 |
Example |
RADIUS/6/RADIUS_ACCT_SERVER_UP: RADIUS accounting server became active: Server IP=1.1.1.1, port=1812, VPN instance=public. |
Explanation |
An accounting server became active. |
Recommended action |
RADIUS_AUTH_FAILURE
Message text |
User [STRING] at [STRING] failed authentication. |
Variable fields |
$1: Username. $2: IP address. |
Severity level |
5 |
Example |
RADIUS/5/RADIUS_AUTH_FAILURE: User abc@system at 192.168.0.22 failed authentication. |
Explanation |
An authentication request was rejected by the RADIUS server. |
RADIUS_AUTH_SERVER_DOWN
Message text |
RADIUS authentication server was blocked: Server IP=[STRING], port=[UINT32], VPN instance=[STRING]. |
Variable fields |
$1: IP address of the authentication server. $2: Port number of the authentication server. $3: VPN instance name. This field displays public if the server belongs to the public network. |
Severity level |
4 |
Example |
RADIUS/4/RADIUS_AUTH_SERVER_DOWN: RADIUS authentication server was blocked: Server IP= 1.1.1.1, port=1812, VPN instance=public. |
Explanation |
An authentication server became blocked. |
369. Verify that the authentication server has started up. 370. Ping the authentication server to verify that the server is reachable. If the server is not reachable, check the link for connectivity issues and resolve the issues. 371. Collect logs and diagnostic logs, and then contact H3C Support. |
RADIUS_AUTH_SERVER_UP
Message text |
RADIUS authentication server became active: Server IP=[STRING], port=[UINT32], VPN instance=[STRING]. |
Variable fields |
Severity level |
6 |
Example |
RADIUS/6/RADIUS_AUTH_SERVER_UP: RADIUS authentication server became active: Server IP=1.1.1.1, port=1812, VPN instance=public. |
Explanation |
An authentication server became active. |
RADIUS_AUTH_SUCCESS
Message text |
User [STRING] at [STRING] was authenticated successfully. |
Variable fields |
Severity level |
6 |
Example |
RADIUS/6/RADIUS_AUTH_SUCCESS: User abc@system at 192.168.0.22 was authenticated successfully. |
Explanation |
An authentication request was accepted by the RADIUS server. |
RADIUS_REMOVE_SERVER_FAIL
Message text |
Failed to remove servers in scheme [STRING]. |
Variable fields |
$1: Scheme name. |
Severity level |
4 |
Example |
RADIUS/4/RADIUS_REMOVE_SERVER_FAIL: Failed to remove servers in scheme abc. |
Explanation |
Failed to delete servers from a RADIUS scheme. |
RDDC messages
This section contains RDDC messages.
RDDC_ACTIVENODE_CHANGE
Message text |
Redundancy group [STRING] active node changed to [STRING], because of [STRING]. |
Variable fields |
$1: Redundancy group name. $2: Active node information. $3: Status change reason: ¡ manual switchover ¡ group's configuration changed ¡ node's weight changed |
Severity level |
5 |
Example |
RDDC/5/RDDC_ACTIVENODE_CHANGE: Redundancy group 1 active node changed to node 1 (chassis 1), because of manual switchover. |
Explanation |
The active node in the redundancy group changed because of manual switchover, configuration change of the group, or weight change of the node. |
RESMON
This section contains resource monitoring messages.
RESMON_MINOR
Message text |
-Resource=[STRING]-Total=[STRING]-Used=[STRING]-Free=[STRING]; Free resource decreased to or below minor threshold [STRING]. [STRING]. |
Variable fields |
$1: Resource type. $2: Total amount. $3: Used amount. $4: Available amount. $5: Minor resource depletion threshold. $6: Resource usage description. Some types of resources do not have description information. |
Severity level |
4 |
Example |
RESMON/4/RESMON_MINOR: -Resource=AA-Total=100%-Used=83%-Free=17%; Free resource decreased to or below minor threshold 20%. |
Explanation |
When the available resource amount decreases to or below the minor resource depletion threshold, the resource type enters minor alarm state and the device outputs this log message periodically. |
Configure the device based on the resource type so the device allocates the type of resources reasonably. |
RESMON_MINOR_RECOVERY
Message text |
-Resource=[STRING]-Total=[STRING]-Used=[STRING]-Free=[STRING]; Free resource increased above minor threshold [STRING]. [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RESMON/5/RESMON_MINOR_RECOVER: -Resource=AA-Total=100%-Used=77%-Free=23%; Free resource increased above minor threshold 20%. |
Explanation |
When the available resource amount increases above the minor resource depletion threshold, the resource type enters recovered state. The device removes the minor resource depletion alarm and outputs this log message. |
RESMON_SEVERE
Message text |
-Resource=[STRING]-Total=[STRING]-Used=[STRING]-Free=[STRING]; Free resource decreased to or below severe threshold [STRING]. [STRING]. |
Variable fields |
$1: Resource type. $2: Total amount. $3: Used amount. $4: Available amount. $5: Severe resource depletion threshold. $6: Resource usage description. Some types of resources do not have description information. |
Severity level |
3 |
Example |
RESMON/3/RESMON_SEVERE: -Resource=AA-Total=100%-Used=93%-Free=7%; Free resource decreased to or below severe threshold 10%. |
Explanation |
When the available resource amount decreases to or below the severe resource depletion threshold, the resource type enters severe alarm state and the device outputs this log message periodically. |
RESMON_SEVERE_RECOVERY
Message text |
-Resource=[STRING]-Total=[STRING]-Used=[STRING]-Free=[STRING]; Free resource increased above severe threshold [STRING]. [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RESMON/5/RESMON_SEVERE_RECOVER: -Resource=AA-Total=100%-Used=83%-Free=17%; Free resource increased above severe threshold 10%. |
Explanation |
When the available resource amount increases above the severe resource depletion threshold, the device removes the severe resource depletion alarm and outputs this log message. |
RESMON_USEDUP
Message text |
-Resource=[STRING]-Total=[STRING]-Used=[STRING]-Free=[STRING]; Resources used up. [STRING]. |
Variable fields |
$1: Resource type. $2: Total amount. $3: Used amount. $4: Available amount. $5: Resource usage description. Some types of resources do not have description information. |
Severity level |
2 |
Example |
RESMON/2/RESMON_USEDUP: -Resource=vlaninterface-Total=2048-Used=2048-Free=0; Resources used up. |
Explanation |
When the available resource amount decreases to zero, the device outputs this log message periodically. |
To ensure correct operation of the relevant services, immediately clear data or entries of the resource type that are not used. |
RESMON_USEDUP_RECOVERY
Message text |
-Resource=[STRING]-Total=[STRING]-Used=[STRING]-Free=[STRING]; The amount of free resources increased from zero to a non-zero value. [STRING]. |
Variable fields |
$1: Resource type. $2: Total amount, which can be 100% or an integer for an absolute value. $3: Used amount, a percentage or an integer for an absolute value. $4: Available amount, a percentage or an integer for an absolute value. $5: Additional resource usage information. This field might be null. |
Severity level |
5 |
Example |
RESMON/5/RESMON_USEDUP_RECOVER: -Resource=vlaninterface-Total=2048-Used=2047-Free=1; The amount of free resources increased from zero to a non-zero value. |
Explanation |
When the available resource amount increases from zero, the device outputs this log message. |
RIP messages
This section contains RIP messages.
RIP_MEM_ALERT
Message text |
RIP Process received system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alarm. |
Severity level |
5 |
Example |
RIP/5/RIP_MEM_ALERT: RIP Process received system memory alert start event. |
Explanation |
RIP received a memory alarm. |
Check the system memory and release memory for the modules that occupy too many memory resources. |
RIP_RT_LMT
Message text |
RIP [UINT32] Route limit reached |
Variable fields |
$1: Process ID. |
Severity level |
6 |
Example |
RIP/6/RIP_RT_LMT: RIP 1 Route limit reached. |
Explanation |
The number of routes of a RIP process reached the upper limit. |
372. Check for network attacks. 373. Reduce the number of routes. |
RIPNG messages
This section contains RIPng messages.
RIPNG_MEM_ALERT
Message text |
RIPng Process received system memory alert [STRING] event. |
Variable fields |
Severity level |
5 |
Example |
RIPNG/5/RIPNG_MEM_ALERT: RIPNG Process received system memory alert start event. |
Explanation |
RIPng received a memory alarm. |
RIPNG_RT_LMT
Message text |
RIPng [UINT32] Route limit reached |
Variable fields |
$1: Process ID |
Severity level |
6 |
Example |
RIPNG/6/RIPNG_RT_LMT: RIPng 1 Route limit reached. |
Explanation |
The number of routes of a RIPng process reached the upper limit. |
374. Check for network attacks. 375. Reduce the number of routes. |
RM messages
This section contains RM messages.
RM_ACRT_REACH_LIMIT
Message text |
Max active [STRING] routes [UINT32] reached in URT of [STRING] |
Variable fields |
$1: IPv4 or IPv6. $2: Maximum number of active routes. $3: VPN instance name. |
Severity level |
4 |
Example |
RM/4/RM_ACRT_REACH_LIMIT: Max active IPv4 routes 100000 reached in URT of VPN1 |
Explanation |
The number of active routes reached the upper limit in the unicast routing table of a VPN instance. |
Remove unused active routes. |
RM_ACRT_REACH_THRESVALUE
Message text |
Threshold value [UINT32] of max active [STRING] routes reached in URT of [STRING] |
Variable fields |
$1: Threshold of the maximum number of active routes in percentage. $2: IPv4 or IPv6. $3: VPN instance name. |
Severity level |
4 |
Example |
RM/4/RM_ACRT_REACH_THRESVALUE: Threshold value 50% of max active IPv4 routes reached in URT of vpn1 |
Explanation |
The percentage of the maximum number of active routes was reached in the unicast routing table of a VPN instance. |
Modify the threshold value or the route limit configuration. |
RM_THRESHLD_VALUE_REACH
Message text |
Threshold value [UINT32] of active [STRING] routes reached in URT of [STRING] |
Variable fields |
$1: Maximum number of active routes. $2: IPv4 or IPv6. $3: VPN instance name. |
Severity level |
4 |
Example |
RM/4/RM_THRESHLD_VALUE_REACH: Threshold value 10000 of active IPv4 routes reached in URT of vpn1 |
Explanation |
The number of active routes reached the threshold in the unicast routing table of a VPN instance. |
Modify the route limit configuration. |
RM_TOTAL_THRESHLD_VALUE_REACH
Message text |
Threshold value [UINT32] reached for active [STRING] routes in all URTs |
Variable fields |
$1: Maximum number of active routes. $2: IPv4 or IPv6. |
Severity level |
4 |
Example |
RM/4/ RM_TOTAL_THRESHLD_VALUE_REACH:Threshold value 1000 reached for active IPv4 routes in all URTs |
Explanation |
The total number of active routes in the public network and all VPN instances reached the alarm threshold. |
Check the routing table and take relevant actions. |
RPR messages
This section contains RPR messages.
RPR_EXCEED_MAX_SEC_MAC
Message text |
A maximum number of secondary MAC addresses exceeded defect is present on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
RPR/4/RPR_EXCEED_MAX_SEC_MAC: A maximum number of secondary MAC addresses exceeded defect is present on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The number of RPR secondary MAC addresses on the ring has reached the upper limit. |
Disable VRRP on RPR stations. |
RPR_EXCEED_MAX_SEC_MAC_OVER
Message text |
A maximum number of secondary MAC addresses exceeded defect is cleared on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_EXCEED_MAX_SEC_MAC_OVER: A maximum number of secondary MAC addresses exceeded defect is cleared on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The number of secondary MAC addresses on the ring has dropped below the upper limit. |
RPR_EXCEED_MAX_STATION
Message text |
A maximum number of stations exceeded defect is present on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
RPR/4/RPR_EXCEED_MAX_STATION: A maximum number of stations exceeded defect is present on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The number of RPR stations on the ring has reached the upper limit. |
Remove some RPR stations. |
RPR_EXCEED_MAX_STATION_OVER
Message text |
A maximum number of stations exceeded defect is cleared on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_EXCEED_MAX_STATION_OVER: A maximum number of stations exceeded defect is cleared on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The number of RPR stations on the ring has dropped below the upper limit. |
RPR_EXCEED_RESERVED_RATE
Message text |
An excess reserved rate defect is present on ringlet0/ringlet1 corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
RPR/3/RPR_EXCEED_RESERVED_RATE: An excess reserved rate defect is present on ringlet0 corresponding to RPR logical interface RPR-Router1. |
Explanation |
The reserved bandwidth for the RPR station was greater than the total bandwidth of the RPR ring. |
Reduce the reserved bandwidth. |
RPR_EXCEED_RESERVED_RATE_OVER
Message text |
An excess reserved rate defect is cleared on ringlet0/ringlet1 corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_EXCEED_RESERVED_RATE_OVER: An excess reserved rate defect is cleared on ringlet0 corresponding to RPR logical interface RPR-Router1. |
Explanation |
The reserved bandwidth for the RPR station was smaller than the total bandwidth of the RPR ring. |
RPR_IP_DUPLICATE
Message text |
A duplicate IP address defect is present on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
RPR/3/RPR_IP_DUPLICATE: A duplicate IP address defect is present on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
Another RPR station used the same IP address. |
Locate the RPR station, and change its IP address. |
RPR_IP_DUPLICATE_OVER
Message text |
A duplicate IP address defect is cleared on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_IP_DUPLICATE_OVER: A duplicate IP address defect is cleared on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The duplicate IP address defect was cleared. |
RPR_JUMBO_INCONSISTENT
Message text |
A jumbo configuration defect is present on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
6 |
Example |
RPR/6/RPR_JUMBO_INCONSISTENT: A jumbo configuration defect is present on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
An RPR station used different Jumbo frame configuration. |
Locate the RPR station and change its Jumbo frame configuration. |
RPR_JUMBO_INCONSISTENT_OVER
Message text |
A jumbo configuration defect is cleared on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
6 |
Example |
RPR/6/RPR_JUMBO_INCONSISTENT_OVER: A jumbo configuration defect is cleared on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The Jumbo frame configuration inconsistency defect was cleared. |
RPR_LAGGCONFIG_INCONSISTENT
Message text |
An inconsistent LAGG configuration is present on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
RPR/4/RPR_LAGGCONFIG_INCONSISTENT: An inconsistent LAGG configuration is present on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
An RPR station used different link aggregation configuration. |
Locate the RPR station and change its link aggregation configuration. |
RPR_LAGGCONFIG_INCONSISTENT_OVER
Message text |
An inconsistent LAGG configuration is cleared on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_LAGGCONFIG_INCONSISTENT: An inconsistent LAGG configuration is cleared on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The link aggregation configuration inconsistency defect was cleared. |
No action is required. |
RPR_MISCABLING
Message text |
A miscabling defect is present on ringlet0/ringlet1 corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
RPR/3/RPR_MISCABLING: A miscabling defect is present on ringlet0 corresponding to RPR logical interface RPR-Router1. |
Explanation |
The west port of an RPR station was not connected to the east port of anther RPR station. |
Examine the physical port connection of the two RPR stations. |
RPR_MISCABLING_OVER
Message text |
A miscabling defect is cleared on ringlet0/ringlet1 corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_MISCABLING_OVER: A miscabling defect is cleared on ringlet0 corresponding to RPR logical interface RPR-Router1. |
Explanation |
The RPR physical port connection defect was cleared. |
RPR_PROTECTION_INCONSISTENT
Message text |
A protection configuration defect is present on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
RPR/3/RPR_PROTECTION_INCONSISTENT: A protection configuration defect is present on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
An RPR station used different protection mode. |
Locate the RPR station and change its protection mode. |
RPR_PROTECTION_INCONSISTENT_OVER
Message text |
A protection configuration defect is cleared on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_PROTECTION_INCONSISTENT_OVER: A protection configuration defect is cleared on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The protection mode inconsistency defect was cleared. |
RPR_SEC_MAC_DUPLICATE
Message text |
A duplicate secondary MAC addresses defect is present on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
RPR/3/RPR_SEC_MAC_DUPLICATE: A duplicate secondary MAC addresses defect is present on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
Another RPR station used the same secondary MAC address. |
Locate the RPR station, and change its secondary MAC address. |
RPR_SEC_MAC_DUPLICATE_OVER
Message text |
A duplicate secondary MAC addresses defect is cleared on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_SEC_MAC_DUPLICATE_OVER: A duplicate secondary MAC addresses defect is cleared on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The duplicate secondary MAC address defect was cleared. |
RPR_TOPOLOGY_INCONSISTENT
Message text |
An inconsistent topology defect is present on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
RPR/3/RPR_TOPOLOGY_INCONSISTENT: An inconsistent topology defect is present on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The topology information collected by the ports on the PRP stations was different. |
Execute the shutdown command and then the undo shutdown command on the ports to collect topology information again. |
RPR_TOPOLOGY_INCONSISTENT_OVER
Message text |
An inconsistent topology defect is cleared on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_TOPOLOGY_INCONSISTENT_OVER: An inconsistent topology defect is cleared on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The topology information inconsistency defect was cleared. |
RPR_TOPOLOGY_INSTABILITY
Message text |
A topology instability defect is present on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
RPR/4/RPR_TOPOLOGY_INSTABILITY: A topology instability defect is present on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The RPR ring topology was unstable. |
RPR_TOPOLOGY_INSTABILITY_OVER
Message text |
A topology instability defect is cleared on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_TOPOLOGY_INSTABILITY_OVER: A topology instability defect is cleared on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The RPR ring topology was stable. |
RPR_TOPOLOGY_INVALID
Message text |
A topology invalid defect is present on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
RPR/4/RPR_TOPOLOGY_INVALID: A topology invalid defect is present on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The topology information collected by the RPR stations was invalid. |
Execute the shutdown command and then the undo shutdown command on the RPR stations to collect topology information again. |
RPR_TOPOLOGY_INVALID_OVER
Message text |
A topology invalid defect is cleared on the ring corresponding to RPR logical interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
RPR/5/RPR_TOPOLOGY_INVALID_OVER: A topology invalid defect is cleared on the ring corresponding to RPR logical interface RPR-Router1. |
Explanation |
The topology information collected by the RPR stations was valid. |
RRPP messages
This section contains RRPP messages.
RRPP_RING_FAIL
Message text |
Ring [UINT32] in Domain [UINT32] failed. |
Variable fields |
$1: Ring ID. $2: Domain ID. |
Severity level |
4 |
Example |
RRPP/4/RRPP_RING_FAIL: Ring 1 in Domain 1 failed. |
Explanation |
A ring failure occurred in the RRPP domain. |
Check each RRPP node to clear the network fault. |
RRPP_RING_RESTORE
Message text |
Ring [UINT32] in Domain [UINT32] recovered. |
Variable fields |
Severity level |
4 |
Example |
RRPP/4/RRPP_RING_RESTORE: Ring 1 in Domain 1 recovered. |
Explanation |
The ring in the RRPP domain was recovered. |
RTM messages
This section contains RTM messages.
RTM_ENVIRONMENT
Message text |
Can't find environment variable [STRING]. |
Variable fields |
$1: Name of the EAA environment variable. |
Severity level |
4 |
Example |
RTM/4/RTM_ENVIRONMENT: Can't find environment variable eee. |
Explanation |
The CLI monitoring policy failed to find the specified environment variable when it tried to replace the variable. The CLI monitoring policy failed to be executed. |
Define the EAA environment variable before using the variable. |
RTM_TCL_LOAD_FAILED
Message text |
Failed to load the Tcl script file of policy [STRING]. |
Variable fields |
$1: Name of a Tcl-defined policy. |
Severity level |
4 |
Example |
RTM/4/RTM_TCL_LOAD_FAILED: Failed to load the Tcl script file of policy test. |
Explanation |
The system failed to load the Tcl script file for the policy to memory. |
RTM_TCL_MODIFY
Message text |
Failed to execute Tcl-defined policy [STRING] because the policy's Tcl script file had been modified. |
Variable fields |
Severity level |
4 |
Example |
RTM/4/RTM_TCL_MODIFY: Failed to execute Tcl-defined policy aaa because the policy's Tcl script file had been modified. |
Explanation |
The Tcl script file for the policy was modified. |
Reconfigure the policy, or modify the Tcl script to be the same as it was when it was bound with the policy. |
RTM_TCL_NOT_EXIST
Message text |
Failed to execute Tcl-defined policy [STRING] because the policy's Tcl script file was not found. |
Variable fields |
Severity level |
4 |
Example |
RTM/4/RTM_TCL_NOT_EXIST: Failed to execute Tcl-defined policy aaa because the policy's Tcl script file was not found. |
Explanation |
The system did not find the Tcl script file for the policy while executing the policy. |
376. Check that the Tcl script file exists. 377. Reconfigure the policy. |
SCMD messages
This section contains SCMD messages.
PROCESS_ABNORMAL
Message text |
The process [STRING] exited abnormally. ServiceName=[STRING], ExitCode=[STRING], KillSignal=[STRING], StartTime=[STRING], StopTime=[STRING]. |
Variable fields |
$1: Process name. $2: Service name defined in the script. $3: Process exit code. If the process was closed by a signal, this field displays NA. $4: Signal that closed the process. If the process was not closed by a signal, this field displays NA. $5: Time when the process was created. $6: Time when the process was closed. |
Severity level |
4 |
Example |
SCMD/4/PROCESS_ABNORMAL: The process diagd exited abnormally. ServiceName=DIAG, ExitCode=1, KillSignal=NA, StartTime=2019-03-06 14:18:06, StopTime=2019-03-06 14:35:25. |
Explanation |
A process exited abnormally. You can use the process parameters for troubleshooting. |
378. Use the display process command to identify whether the process exists. If the process exists, the process is recovered. a. Execute the view /var/log/trace.log > trace.log command in probe view. b. Upload the trace.log file saved in the storage media of the device to the server through FTP or TFTP (in binary mode). c. Contact H3C Support. Do not reboot the device so H3C Support can help you locate the problem. |
PROCESS_ACTIVEFAILED
Message text |
The standby process [STRING] failed to switch to the active process due to uncompleted synchronization, and was restarted. |
Variable fields |
$1: Process name. |
Severity level |
4 |
Example |
SCMD/4/PROCESS_ACTIVEFAILED: The standby process [STRING] failed to switch to the active process due to uncompleted synchronization, and was restarted. |
Explanation |
The standby process failed to switch to the active process because the active process exited abnormally when the standby process has not completed synchronization. The standby process was restarted. |
PROCESS_CORERECORD
Message text |
Exceptions occurred with process [STRING]. A core dump file was generated. |
Variable fields |
$1: Process name. |
Severity level |
4 |
Example |
SCMD/4/PROCESS_CORERECORD: Exceptions occurred with process diagd. A core dump file was generated. |
Explanation |
Exceptions occurred with the process and a core dump file was generated. The core dump file contains information relevant to the process exceptions. You can use the file for troubleshooting. |
380. Execute the display exception context command to collect process exception information, and save the information to a file. 381. Execute the display exception filepath command to display the core file. 382. Upload the core file and the file that stores the process exception information to the server through FTP or TFTP (in binary mode). 383. Contact H3C Support. Do not reboot the device so H3C Support can help you locate the problem. |
SCM_ABNORMAL_REBOOT
Message text |
Failed to restore process [STRING]. Rebooting [STRING]. |
Variable fields |
$1: Process name. $2: Chassis number and slot number, slot number, or string the system. |
Severity level |
3 |
Example |
SCMD/3/SCM_ABNORMAL_REBOOT: Failed to restore process ipbased. Rebooting slot 1. |
Explanation |
The process exited abnormally during the device startup. If the process cannot recover after multiple automatic restart attempts, the slot or device will restart automatically. |
384. Use the display process command to verify that the process has recovered after the card or device restarts. 385. If the problem persists, contact H3C Support. |
SCM_ABNORMAL_REBOOTMDC
Message text |
Failed to restore process [STRING] on [STRING] [UINT16]. Rebooting [STRING] [UINT16]. |
Variable fields |
$1: Process name. $2: Object type, MDC or context. $3: ID of the MDC or context. $4: Object type, MDC or context. $5: ID of the MDC or context. |
Severity level |
3 |
Example |
SCMD/3/SCM_ABNORMAL_REBOOTMDC: Failed to restore process ipbased on MDC 2. Rebooting MDC 2. |
Explanation |
The process exited abnormally during the startup of the MDC on the active MPU or the context on the main security engine in the security engine group. If the process cannot recover after multiple automatic restart attempts, the MDC or context will restart automatically. This message will be output in MDC 1 or Context 1. |
386. Use the display process command to verify that the process has recovered after the card restarts. 387. If the problem persists, contact H3C Support. |
SCM_ABORT_RESTORE
Message text |
Variable fields |
$1: Process name. |
Severity level |
3 |
Example |
SCMD/3/SCM_ABORT_RESTORE: Failed to restore process ipbased. Restoration aborted. |
Explanation |
The process exited abnormally during the system operation. If the process cannot recover after multiple automatic restart attempts, the device will not restore the process. |
388. Use the display process log command in any view to display the details about process exit. 389. Restart the card or the MDC where the process is located. 390. Provide the output from the display process log command to H3C Support. |
SCM_INSMOD_ADDON_TOOLONG
Message text |
Failed to finish loading [STRING] in [UINT32] minutes. |
Variable fields |
$1: Kernel file name. $2: File loading duration. |
Severity level |
4 |
Example |
SCMD/4/SCM_INSMOD_ADDON_TOOLONG: Failed to finish loading addon.ko in 30 minutes. |
Explanation |
Kernel file loading timed out during device startup. |
391. Restart the card. 392. Contact H3C Support. |
SCM_KERNEL_INIT_TOOLONG
Message text |
Kernel init in sequence [STRING] function [STRING] is still starting for [UINT32] minutes. |
Variable fields |
$1: Kernel event phase. $2: Address of the function corresponding to the kernel event. $3: Time duration. |
Severity level |
4 |
Example |
SCMD/4/SCM_KERNEL_INIT_TOOLONG: Kernel init in sequence 0x25e7 function 0x6645ffe2 is still starting for 15 minutes. |
Explanation |
A function at a phase during kernel initialization ran too long. |
393. Restart the card. 394. Contact H3C Support. |
SCM_KILL_PROCESS
Message text |
Pattern 1: The process [STRING] was killed because it failed to stop within [STRING]. Pattern 2: The process [STRING] on [STRING] [UINT16] was killed because it failed to stop within [STRING]. |
Variable fields |
Pattern 1: $1: Process name. $2: Time that elapsed after the process received the stop signal and before the device output this log message. Pattern 2: $1: Process name. $2: Object type, MDC or context. $3: ID of the MDC or context. $4: Time that elapsed after the process received the stop signal and before the device output this log message. |
Severity level |
6 |
Example |
SCMD/6/SCM_KILL_PROCESS: The process stamgrd was killed because it failed to stop within 30 minutes. |
Explanation |
If a process does not stop after running a specific period of time, the system will kill the process. |
395. After the system, MDC, or context operates stably, use the display process command to identify whether the process has recovered. 396. If the process does not recover, contact H3C Support. |
SCM_PROCESS_STARTING_TOOLONG
Message text |
Pattern 1: The process [STRING] has not finished starting in [UINT32] hours. Pattern 2: The process [STRING] on [STRING] [UINT16] has not finished starting in [STRING] hours. |
Variable fields |
Pattern 1: $1: Process name. $2: Time duration. Pattern 2: $1: Process name. $2: Object type, MDC or context. $3: ID of the MDC or context. $4: Time duration. |
Severity level |
4 |
Example |
SCMD/4/SCM_PROCESS_STARTING_TOOLONG: The process ipbased has not finished starting in 1 hours. |
Explanation |
The process initialization takes a long time and has not been finished. Too many processes have been configured or the process is abnormal. |
397. Wait 6 hours and then verify that the process has been started. 398. Restart the card/MDC/context, and then use the display process command to verify that the process has recovered. 399. Contact H3C Support. |
SCM_PROCESS_STILL_STARTING
Message text |
Pattern 1: The process [STRING] is still starting for [UINT32] minutes. Pattern 2: The process [STRING] on [STRING] [UINT16] is still starting for [STRING] minutes. |
Variable fields |
Severity level |
6 |
Example |
SCMD/6/SCM_PROCESS_STILL_STARTING: The process ipbased is still starting for 20 minutes. |
Explanation |
A process is always in startup state. |
SCM_SKIP_PROCESS
Message text |
Pattern 1: The process [STRING] was skipped because it failed to start within 6 hours. Pattern 2: The process [STRING] on [STRING] [UINT16] was skipped because it failed to start within 6 hours. |
Variable fields |
Pattern 1: $1: Process name. Pattern 2: $1: Process name. $2: Object type, MDC or context. $3: ID of the MDC or context. |
Severity level |
3 |
Example |
SCMD/3/SCM_SKIP_PROCESS: The process ipbased was skipped because it failed to start within 6 hours. |
Explanation |
A process failed to start within 6 hours. The device will skip this process and continue to start. |
400. Restart the card/MDC/context, and then use the display process command to verify that the process has restored. 401. Contact H3C Support. |
SCRLSP messages
This section contains static CRLSP messages.
SCRLSP_LABEL_DUPLICATE
Message text |
Incoming label [INT32] for static CRLSP [STRING] is duplicate. |
Variable fields |
$1: Incoming label value. $2: Static CRLSP name. |
Severity level |
4 |
Example |
SCRLSP/4/SCRLSP_LABEL_DUPLICATE: Incoming label 1024 for static CRLSP aaa is duplicate. |
Explanation |
The incoming label of a static CRLSP was occupied by another configuration, for example, by a static PW or by a static LSP. This message is generated when one of the following events occurs: · When MPLS is enabled, configure a static CRLSP with an incoming label which is occupied by another configuration. · Enable MPLS when a static CRLSP whose incoming label is occupied by another configuration already exists. |
Remove this static CRLSP, and reconfigure it with another incoming label. |
SESSION messages
This section contains session messages.
SESSION_IPV4_FLOW
Message text |
Protocol(1001)=[STRING];SrcIPAddr(1003)=[IPADDR];SrcPort(1004)=[UINT16];NATSrcIPAddr(1005)=[IPADDR];NATSrcPort(1006)=[UINT16];DstIPAddr(1007)=[IPADDR];DstPort(1008)=[UINT16];NATDstIPAddr(1009)=[IPADDR];NATDstPort(1010)=[UINT16];InitPktCount(1044)=[UINT32];InitByteCount(1046)=[UINT32];RplyPktCount(1045)=[UINT32];RplyByteCount(1047)=[UINT32];RcvVPNInstance(1042)=[STRING];SndVPNInstance(1043)=[STRING];RcvDSLiteTunnelPeer(1040)=[STRING];SndDSLiteTunnelPeer(1041)=[STRING];BeginTime_e(1013)=[STRING];EndTime_e(1014)=[STRING];Event(1048)=([UNIT16])[STRING]; |
Variable fields |
$1: Protocol type. $2: Source IP address. $3: Source port number. $4: Source IP address after translation. $5: Source port number after translation.. $6: Destination IP address. $7: Destination port number. $8: Destination IP address after translation. $9: Destination port number after translation. $10: Total number of inbound packets. $11: Total number of inbound bytes. $12: Total number of outbound packets. $13: Total number of outbound bytes. $14: Source VPN instance name. $15: Destination VPN instance name. $16: Source DS-Lite tunnel. $17: Destination DS-Lite tunnel. $18: Time when the session is created. $19: Time when the session is removed. $20: Event type. $20: Event description: · Session created. · Active flow threshold. · Normal over. · Aged for timeout. · Aged for reset or config-change. · Other. |
Severity level |
6 |
Example |
SESSION/6/SESSION_IPV4_FLOW: Protocol(1001)=UDP;SrcIPAddr(1003)=10.10.10.1;SrcPort(1004)=1024;NATSrcIPAddr(1005)=10.10.10.1;NATSrcPort(1006)=1024;DstIPAddr(1007)=20.20.20.1;DstPort(1008)=21;NATDstIPAddr(1009)=20.20.20.1;NATDstPort(1010)=21;InitPktCount(1044)=1;InitByteCount(1046)=50;RplyPktCount(1045)=0;RplyByteCount(1047)=0;RcvVPNInstance(1042)=;SndVPNInstance(1043)=;RcvDSLiteTunnelPeer(1040)=;SndDSLiteTunnelPeer(1041)=;BeginTime_e(1013)=03182024082546;EndTime_e(1014)=;Event(1048)=(8)Session created; |
Explanation |
This message is sent in one of the following conditions: · An IPv4 session is created or removed. · Periodically during an IPv4 session. · The traffic-based or time-based threshold of an IPv4 session is reached. |
SESSION_IPV6_FLOW
Message text |
Protocol(1001)=[STRING];SrcIPv6Addr(1036)=[IPADDR];SrcPort(1004)=[UINT16];DstIPv6Addr(1037)=[IPADDR];DstPort(1008)=[UINT16];InitPktCount(1044)=[UINT32];InitByteCount(1046)=[UINT32];RplyPktCount(1045)=[UINT32];RplyByteCount(1047)=[UINT32];RcvVPNInstance(1042)=[STRING];SndVPNInstance(1043)=[STRING];BeginTime_e(1013)=[STRING];EndTime_e(1014)=[STRING];Event(1048)=([UNIT16])[STRING]; |
Variable fields |
$1: Protocol type. $2: Source IPv6 address. $3: Source port number. $4: Destination IP address. $5: Destination port number. $6: Total number of inbound packets. $7: Total number of inbound bytes. $8: Total number of outbound packets. $9: Total number of outbound bytes. $10: Source VPN instance name. $11: Destination VPN instance name. $12: Time when the session is created. $13: Time when the session is removed. $14: Event type. $15: Event description: · Session created. · Active flow threshold. · Normal over. · Aged for timeout. · Aged for reset or config-change. · Other. |
Severity level |
6 |
Example |
SESSION/6/SESSION_IPV6_FLOW: Protocol(1001)=UDP;SrcIPv6Addr(1036)=2001::2;SrcPort(1004)=1024;DstIPv6Addr(1037)=3001::2;DstPort(1008)=53;InitPktCount(1044)=1;InitByteCount(1046)=110;RplyPktCount(1047)=0;RplyByteCount(1047)=0;RcvVPNInstance(1042)=;SndVPNInstance(1043)=;BeginTime_e(1013)=03182024082901;EndTime_e(1014)=;Event(1048)=(8)Session created; |
Explanation |
This message is sent in one of the following conditions: · An IPv6 session is created or removed. · Periodically during an IPv6 session. · The traffic-based or time-based threshold of an IPv6 session is reached. |
SFLOW messages
This section contains sFlow messages.
SFLOW_HARDWARE_ERROR
Message text |
Variable fields |
$1: Configuration item: update sampling mode $2: Interface name. $3: Failure reason: not supported operation |
Severity level |
4 |
Example |
Explanation |
The configuration failed because the device does not support the fixed flow sampling mode. |
Specify the random flow sampling mode. |
SHELL messages
This section contains shell messages.
SHELL_CMD
Message text |
-Line=[STRING]-IPAddr=[STRING]-User=[STRING]; Command is [STRING] |
Variable fields |
$1: User line type and number. If there is not user line information, this field displays **. $2: IP address. If there is not IP address information, this field displays two asterisks (**). $3: Username. If there is not username information, this field displays two asterisks (**). $4: Command string. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMD: -Line=aux0-IPAddr=**-User=**; Command is quit |
Explanation |
A command was executed. |
SHELL_CMD_CONFIRM
Message text |
Confirm option of command [STRING] is [STRING]. |
Variable fields |
$1: Command string. $2: Confirm option. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMD_CONFIRM: Confirm option of command save is no. |
Explanation |
A user selected a confirmation option for a command. |
SHELL_CMD_EXECUTEFAIL
Message text |
-User=[STRING]-IPAddr=[STRING]; Command [STRING] in view [STRING] failed to be executed. |
Variable fields |
$1: Username. $2: IP address. $3: Command string. $4: Command view. |
Severity level |
4 |
Example |
SHELL/4/SHELL_CMD_EXECUTEFAIL: -User=**-IPAddr=192.168.62.138; Command save in view system failed to be executed. |
Explanation |
A command that a background program issued failed to be executed. |
SHELL_CMD_INPUT
Message text |
Variable fields |
$1: Command string. $2: String entered by the user. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMD_INPUT: Input string for the save command is startup.cfg. SHELL/6/SHELL_CMD_INPUT: Input string for the save command is CTRL_C. SHELL/6/SHELL_CMD_INPUT: Input string for the save command is the Enter key. |
Explanation |
A user responded to the input requirement of a command. |
SHELL_CMD_INPUT_TIMEOUT
Message text |
Operation timed out: Getting input for the [STRING] command. |
Variable fields |
$1: Command string. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMD_INPUT_TIMEOUT: Operation timed out: Getting input for the fdisk command. |
Explanation |
The user did not respond to the input requirement of a command before the timeout timer expired. |
SHELL_CMD_INVALID_CHARACTER
Message text |
Execution failed for the [STRING] command. Reason: The command contains invalid characters (? or \t). |
Variable fields |
$1: Command to be executed. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMD_INVALID_CHARACTER: Execution failed for the sysname abc?? command. Reason: The command contains invalid characters (? or \t). |
Explanation |
Invalid characters (? or \t) were detected in the text-type configuration file used for configuration deployment, such as configuration restoration or rollback. |
Delete the invalid characters and deploy the configuration manually. |
SHELL_CMD_MATCHFAIL
Message text |
-User=[STRING]-IPAddr=[STRING]; Command [STRING] in view [STRING] failed to be matched. |
Variable fields |
Severity level |
4 |
Example |
SHELL/4/SHELL_CMD_MATCHFAIL: -User=**-IPAddr=192.168.62.138; Command description 10 in view system failed to be matched. |
Explanation |
The command string has errors, or the view does not support the command. |
Enter the correct command string. Make sure the command is supported in the view. |
SHELL_CMDDENY
Message text |
-Line=[STRING]-IPAddr=[STRING]-User=[STRING]; Command=[STRING] is denied. |
Variable fields |
$1: User line type and number. If there is not user line information, this field displays **. $2: IP address. If there is not IP address information, this field displays **. $3: Username. If there is not username information, this field displays **. $4: Command string. |
Severity level |
5 |
Example |
SHELL/5/SHELL_CMDDENY: -Line=vty0-IPAddr=192.168.62.138-User=**; Command vlan 10 is permission denied. |
Explanation |
The user did not have the right to execute the command. |
SHELL_CMDFAIL
Message text |
The [STRING] command failed to restore the configuration. |
Variable fields |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMDFAIL: The “vlan 1024” command failed to restore the configuration. |
Explanation |
The specified command failed to be restored during a configuration restoration from a .cfg file. |
SHELL_COMMIT
Message text |
The configuration has been committed. |
Variable fields |
N/A |
Severity level |
5 |
Example |
SHELL/5/SHELL_COMMIT: The configuration has been committed. |
Explanation |
A configuration commit operation succeeded. |
SHELL_COMMIT_DELAY
Message text |
A configuration rollback will be performed in [INT32] minutes. |
Variable fields |
$1: Configuration commit delay timer. |
Severity level |
5 |
Example |
SHELL/5/SHELL_COMMIT_DELAY: A configuration rollback will be performed in 3 minutes. |
Explanation |
The configuration commit delay timer was set successfully. |
Complete and commit the configuration before the timer expires. If you cannot complete the configuration, execute the configuration commit delay command again to delay the expiration. |
SHELL_COMMIT_REDELAY
Message text |
The commit delay has been reset, a configuration rollback will be performed in [INT32] minutes. |
Variable fields |
$1: Configuration commit delay timer reconfigured. |
Severity level |
5 |
Example |
SHELL/5/SHELL_COMMIT_REDELAY: The commit delay has been reset, a configuration rollback will be performed in 3 minutes. |
Explanation |
The configuration commit delay timer was reconfigured before the timer expires. |
SHELL_COMMIT_ROLLBACK
Message text |
The configuration commit delay is overtime, a configuration rollback will be performed. |
Variable fields |
N/A |
Severity level |
5 |
Example |
SHELL/5/SHELL_COMMIT_ROLLBACK: The configuration commit delay is overtime, a configuration rollback will be performed. |
Explanation |
The configuration commit delay timer expired. A configuration rollback will occur. |
Stop configuring the device and wait for the rollback to finish. |
SHELL_COMMIT_ROLLBACKDONE
Message text |
The configuration rollback has been performed. |
Variable fields |
N/A |
Severity level |
5 |
Example |
SHELL/5/SHELL_COMMIT_ROLLBACKDONE: The configuration rollback has been performed. |
Explanation |
The configuration rollback was finished. |
You can continue to configure the device as required. |
SHELL_COMMIT_WILLROLLBACK
Message text |
A configuration rollback will be performed in 1 minute. To retain the configuration you have made after executing the configuration commit delay command, execute the commit command. |
Variable fields |
N/A |
Severity level |
5 |
Example |
SHELL/5/SHELL_COMMIT_WILLROLLBACK: A configuration rollback will be performed in 1 minute. To retain the configuration you have made after executing the configuration commit delay command, execute the commit command. |
Explanation |
A configuration rollback will be performed in 1 minute. |
Complete the configuration within 1 minute and commit the configuration, or execute the configuration commit delay command again to delay the expiration. |
SHELL_CRITICAL_CMDFAIL
Message text |
-User=[STRING]-IPAddr=[STRING]; Command=[STRING] . |
Variable fields |
$1: Username. $2: IP address. $3: Command string. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CRITICAL_CMDFAIL: -User=admin-IPAddr=169.254.0.7; Command is save. |
Explanation |
A command failed to be executed. |
SHELL_LOGIN
Message text |
[STRING] logged in from [STRING]. |
Variable fields |
$1: Username. $2: User line type and number. |
Severity level |
5 |
Example |
SHELL/5/SHELL_LOGIN: Console logged in from console0. |
Explanation |
A user logged in. If the user logged in to the standby MPU, the user line type and number field displays local. |
SHELL_LOGOUT
Message text |
[STRING] logged out from [STRING]. |
Variable fields |
Severity level |
5 |
Example |
SHELL/5/SHELL_LOGOUT: Console logged out from console0. |
Explanation |
A user logged out. If the user logged out from the standby MPU, the user line type and number field displays local. |
SLSP messages
This section contains static LSP messages.
SLSP_LABEL_DUPLICATE
Message text |
Incoming label [INT32] for static LSP [STRING] is duplicate. |
Variable fields |
$1: Incoming label value. $2: Static LSP name. |
Severity level |
4 |
Example |
SLSP/4/SLSP_LABEL_DUPLICATE: Incoming label 1024 for static LSP aaa is duplicate. |
Explanation |
The incoming label of a static LSP was occupied by another configuration, for example, by a static PW or by a static CRLSP. This message is generated when one of the following events occurs: · When MPLS is enabled, configure a static LSP with an incoming label which is occupied by another configuration. · Enable MPLS when a static LSP whose incoming label is occupied by another configuration already exists. |
Remove this static LSP, and reconfigure it with another incoming label. |
SMLK messages
This section contains Smart Link messages.
SMLK_LINK_SWITCH
Message text |
Not all the members in smart link group [UINT16] are DR ports. An IPP port can't be a member of a smart link group. |
Variable fields |
$1: Smart link group ID. |
Severity level |
4 |
Example |
SMLK/4/SMLK_DRPORT_CHECK: -MDC=1; Not all the members in smart link group 1 are DR ports. |
Explanation |
This message is generated for a DRNI network when not all the members in a smart link group are DR ports or a smart link group includes an IPP port. |
Add only DR ports to a smart link group in a DRNI network. |
SMLK_LINK_SWITCH
Message text |
Status of port [STRING] in smart link group [UINT16] changes to active. |
Variable fields |
$1: Port name. $2: Smart link group ID. |
Severity level |
4 |
Example |
SMLK/4/SMLK_LINK_SWITCH: Status of port GigabitEthernet0/1/4 in smart link group 1 changes to active. |
Explanation |
The port takes over to forward traffic after the original active port fails. |
Remove the network faults. |
SNMP messages
This section contains SNMP messages.
SNMP_ACL_RESTRICTION
Message text |
SNMP [STRING] from [STRING] is rejected due to ACL restriction. |
Variable fields |
$1: SNMP community/usm-user/group. $2: IP address of the NMS. |
Severity level |
3 |
Example |
SNMP/3/SNMP_ACL_RESTRICTION: SNMP community public from 192.168.1.100 is rejected due to ACL restrictions. |
Explanation |
SNMP packets are denied because of ACL restrictions. |
Check the ACL configuration on the SNMP agent, and identify whether the agent was attacked. |
SNMP_AUTHENTICATION_FAILURE
Message text |
Variable fields |
N/A |
Severity level |
4 |
Example |
SNMP/4/SNMP_AUTHENTICATION_FAILURE: Failed to authenticate SNMP message. |
Explanation |
An NMS failed to be authenticated by the agent. |
SNMP_GET
Message text |
-seqNO=[UINT32]-srcIP=[STRING]-op=GET-node=[STRING]-value=[STRING]; The agent received a message. |
Variable fields |
$1: Sequence number of an SNMP operation log. $2: IP address of the NMS. $3: MIB object name and OID. $4: Value field of the request packet. |
Severity level |
6 |
Example |
SNMP/6/SNMP_GET: -seqNO=1-srcIP=192.168.28.28-op=GET-node=sysLocation(1.3.6.1.2.1.1.6.0)-value=; The agent received a message. |
Explanation |
SNMP received a Get request from an NMS. The system logs SNMP operations only when SNMP logging is enabled. |
SNMP_INFORM_LOST
Message text |
Inform failed to reach NMS [STRING]: Inform [STRING][STRING]. |
Variable fields |
$1: NMS host address and port number. $2: Notification name and OID. $3: Variable-binding field of notifications. ¡ If no MIB object exists, NMS host address and port number and notification name and OID are displayed. ¡ If MIB objects are included, " with " are displayed before the MIB object and OID. MIB objects are separated by semicolons (;). |
Severity level |
3 |
Example |
SNMP/3/SNMP_INFORM_LOST: Inform failed to reach NMS 192.168.111.222(163): Inform coldStart(1.3.6.1.6.3.1.1.5.1). |
Explanation |
If the SNMP agent sends an Inform packet to an NMS and does not receive any response, the SNMP agent determines that the NMS is unreachable. The agent will print the message for issue location. If a message is oversized, the system will automatically fragment the message and add a location identifier "-PART=xx" to each fragment before sending them. xx represents the sequence number of a fragment. |
Identify whether the SNMP agent and the NMS are reachable to each other. |
SNMP_NOTIFY
Message text |
Notification [STRING][STRING]. |
Variable fields |
$1: Notification name and OID. $2: Variable-binding field of notifications. ¡ If no MIB object exists, only notification name and OID are displayed. ¡ If MIB objects are included, " with " are displayed before the MIB object and OID. MIB objects are separated by semicolons (;). |
Severity level |
6 |
Example |
Example of a complete message: SNMP/6/SNMP_NOTIFY: Notification hh3cLogIn(1.3.6.1.4.1.25506.2.2.1.1.3.0.1) with hh3cTerminalUserName(1.3.6.1.4.1.25506.2.2.1.1.2.1.0)=;hh3cTerminalSource(1.3.6.1.4.1.25506.2.2.1.1.2.2.0)=Console. Example of a fragmented message: SNMP/6/SNMP_NOTIFY: -MDC=1; -PART=1; Notification syslogMsgNotification(1.3.6.1.2.1.192.0.1) with syslogMsgFacility(1.3.6.1.2.1.192.1.2.1.2.1)=23;syslogMsgSeverity(1.3.6.1.2.1.192.1.2.1.3.1)=6;syslogMsgVersion(1.3.6.1.2.1.192.1.2.1.4.1)=1;syslogMsgTimeStamp(1.3.6.1.2.1.192.1.2.1.5.1)=07-e2-04-12-12-26-35-00-00-00-2d-00-00[hex];syslogMsgHostName(1.3.6.1.2.1.192.1.2.1.6.1)=H3C;syslogMsgAppName(1.3.6.1.2.1.192.1.2.1.7.1)=SHELL;syslogMsgProcID(1.3.6.1.2.1.192.1.2.1.8.1)=-;syslogMsgMsgID(1.3.6.1.2.1.192.1.2.1.9.1)=SHELL_CMD;syslogMsgSDParams(1.3.6.1.2.1.192.1.2.1.10.1)=4;syslogMsgMsg(1.3.6.1.2.1.192.1.2.1.11.1)= Command is snmp-agent trap enable syslog;syslogMsgSDParamValue(1.3.6.1.2.1.192.1.3.1.4.1.1.12.83.121.115.76.111.99.64.50.53.53.48.54.3.77.68.67)=1;syslogMsgSDParamValue(1.3.6.1.2.1.192.1.3.1.4.1.2.12.65.112.112.76.111.99.64.50.53.53.48.54.4.76.105.110.101)=con0. SNMP/6/SNMP_NOTIFY: -MDC=1; -PART=2; Notification syslogMsgNotification(1.3.6.1.2.1.192.0.1) with syslogMsgSDParamValue(1.3.6.1.2.1.192.1.3.1.4.1.3.12.65.112.112.76.111.99.64.50.53.53.48.54.6.73.80.65.100.100.114)=**;syslogMsgSDParamValue(1.3.6.1.2.1.192.1.3.1.4.1.4.12.65.112.112.76.111.99.64.50.53.53.48.54.4.85.115.101.114)=**. |
Explanation |
The SNMP agent sent a notification. This message displays the notification content. If a message is oversized, the system will automatically fragment the message and add a location identifier "-PART=xx" to each fragment before sending them. xx represents the sequence number of a fragment. |
SNMP_SET
Message text |
-seqNO=[UINT32]-srcIP=[STRING]-op=SET-errorIndex=[UINT32]-errorStatus=[STRING]-node=[STRING]-value=[STRING]; The agent received a message. |
Variable fields |
$1: Sequence number of an SNMP operation log. $2: IP address of the NMS. $3: Error index of the Set operation. $4: Error status of the Set operation. $5: MIB object name and OID. $6: Value of the MIB object changed by the Set operation. |
Severity level |
6 |
Example |
SNMP/6/SNMP_SET: -seqNO=3-srcIP=192.168.28.28-op=SET-errorIndex=0-errorStatus=noError-node=sysLocation(1.3.6.1.2.1.1.6.0)-value=Hangzhou China; The agent received a message. |
Explanation |
SNMP received a Set request from an NMS. The system logs SNMP operations only when SNMP logging is enabled. |
SNMP_USM_NOTINTIMEWINDOW
Message text |
-User=[STRING]-IPAddr=[STRING]; SNMPv3 message is not in the time window. |
Variable fields |
$1: Username. $2: IP address of the NMS. |
Severity level |
4 |
Example |
SNMP/4/SNMP_USM_NOTINTIMEWINDOW: -User=admin-IPAddr=169.254.0.7; SNMPv3 message is not in the time window. |
Explanation |
The SNMPv3 message is not in the time window. |
SSHC messages
This section contains SSH client messages.
SSHC_ALGORITHM_MISMATCH
Message text |
The SSH client failed to log in because of [STRING] algorithm mismatch. |
Variable fields |
$1: Type of the algorithm: ¡ encryption—Encryption algorithm. ¡ key exchange—Key exchange algorithm. ¡ MAC—HMAC algorithm. ¡ public key—Public key algorithm. |
Severity level |
5 |
Example |
SSHC/5/SSHC_ALGORITHM_MISMATCH: The SSH client failed to log in because of encryption algorithm mismatch. |
Explanation |
The SSH client failed to log in because the algorithms on the SSH client did not have a match on the SSH server. |
Change algorithms used by the SSH client to ensure that the SSH client and the SSH server use the same algorithms. |
SSHC_AUTH_PASSWORD_FAIL
Message text |
SSH user [STRING] failed to pass password authentication because of invalid username or wrong password. |
Variable fields |
$1: Username. |
Severity level |
5 |
Example |
SSHC/5/SSHC_AUTH_PASSWORD_FAIL: SSH user aaa failed to pass password authentication because of invalid username or wrong password. |
Explanation |
The SSH user failed to pass password authentication because of invalid username or wrong password. |
Make sure the username and the user password are correct. |
SSHC_AUTH_PUBLICKEY_FAIL
Message text |
SSH user [STRING] failed to pass publickey authentication. |
Variable fields |
$1: Username. |
Severity level |
5 |
Example |
SSHC/5/SSHC_AUTH_PUBLICKEY_FAIL: SSH user abc failed to pass publickey authentication. |
Explanation |
The SSH user failed to pass publickey authentication. |
Verify that the correct public key of the client is saved on the SSH server. |
SSHC_CERT_VERIFY_FAIL
Message text |
Failed to verify the certificate because [STRING]. |
Variable fields |
$1: Failure reason: ¡ null certificate. ¡ null certificate name. ¡ unable to get issuer certificate. ¡ unable to get certificate CRL. ¡ unable to decrypt CRL's signature. ¡ certificate signature failure. ¡ CRL signature failure. ¡ unable to decrypt certificate's signature. ¡ certificate is not yet valid. ¡ certificate has expired. ¡ CRL is not yet valid. ¡ CRL has expired. ¡ format error in certificate's notBefore field. ¡ format error in certificate's notAfter field. ¡ format error in CRL's lastUpdate field. ¡ format error in CRL's nextUpdate field. ¡ out of memory. ¡ self signed certificate. ¡ self signed certificate in certificate chain. ¡ unable to verify the first certificate. ¡ certificate chain too long. ¡ certificate revoked. ¡ invalid CA certificate. ¡ invalid non-CA certificate (has CA markings). ¡ path length constraint exceeded. ¡ proxy path length constraint exceeded. ¡ proxy certificates not allowed, please set the appropriate flag. ¡ unsupported certificate purpose. ¡ certificate not trusted. ¡ certificate rejected. ¡ application verification failure. ¡ subject issuer mismatch. ¡ authority and subject key identifier mismatch. ¡ authority and issuer serial number mismatch. ¡ key usage does not include certificate signing. ¡ unable to get CRL issuer certificate. ¡ unhandled critical extension. ¡ key usage does not include CRL signing. ¡ key usage does not include digital signature. ¡ unhandled critical CRL extension. ¡ invalid or inconsistent certificate extension. ¡ invalid or inconsistent certificate policy extension. ¡ no explicit policy. ¡ Different CRL scope. ¡ CRL path validation error. ¡ unsupported or invalid name syntax. ¡ unsupported or invalid name constraint syntax. ¡ Suite B: certificate version invalid. ¡ Suite B: invalid public key algorithm. ¡ Suite B: invalid ECC curve. ¡ Suite B: invalid signature algorithm. ¡ Suite B: curve not allowed for this LOS. ¡ Suite B: cannot sign P-384 with P-256. ¡ Invalid certificate verification context. ¡ Issuer certificate lookup error. ¡ proxy subject name violation. |
Severity level |
5 |
Example |
SSHC/5/SSHC_CERT_VERIFY_FAIL: Failed to verify the certificate because null certificate. |
Explanation |
Certificate authentication failed. |
Make sure the certificate is valid. |
SSHC_CONNECT_FAIL
Message text |
The SSH client failed to connect to SSH server [IPADDR] port [UINT32]. |
Variable fields |
$1: IP address of the SSH server. $2: Port number of the SSH server. |
Severity level |
5 |
Example |
SSHC/5/SSHC_CONNECT_FAIL: The SSH client failed to connect to SSH server 1.1.1.1 port 2000. |
Explanation |
The SSH client failed to establish a connection to the SSH server. |
Verify that the IP address and port number of the SSH server are correct and the SSH server service has been enabled. |
SSHC_DECRYPT_FAIL
Message text |
The SSH client failed to use [STRING] to decrypt the packet received from the SSH server. |
Variable fields |
$1: Encryption algorithm. |
Severity level |
5 |
Example |
SSHC/5/SSHC_DECRYPT_FAIL: The SSH client failed to use aes256-cbc to decrypt the packet received from the SSH server. |
Explanation |
The SSH client failed to decrypt the packet received from the SSH server. |
Please contact H3C Support. |
SSHC_DISCONNECT
Message text |
The SSH client was disconnected from the SSH server because the network was not available. |
Variable fields |
None. |
Severity level |
5 |
Example |
SSHC/5/SSHC_DISCONNECT: The SSH client was disconnected from the SSH server because the network was not available. |
Explanation |
Make sure the network is available. |
SSHC_ENCRYPT_FAIL
Message text |
The SSH client failed to use [STRING] to encrypt the packet sent to the SSH server. |
Variable fields |
$1: Encryption algorithm, such as aes256-cbc. |
Severity level |
5 |
Example |
SSHC/5/SSHC_ENCRYPT_FAIL: The SSH client failed to use aes256-cbc to encrypt the packet sent to the SSH server. |
Explanation |
The SSH client failed to encrypt the packet sent to the SSH server. |
SSHC_HOST_NAME_ERROR
Message text |
The SSH server host name [STRING] is incorrect. |
Variable fields |
$1: Host name. |
Severity level |
5 |
Example |
SSHC/5/SSHC_HOST_NAME_ERROR: The SSH server host name AAA is incorrect. |
Explanation |
The host name of the SSH server is incorrect. |
Verify that the host name is correct. |
SSHC_KEY_EXCHANGE_FAIL
Message text |
The SSH client failed to exchange keys with the SSH server. |
Variable fields |
None. |
Severity level |
5 |
Example |
SSHC/5/SSHC_KEY_EXCHANGE_FAIL: The SSH client failed to exchange keys with the SSH server. |
Explanation |
Recommended action |
Verify that the SSH client and the SSH server use the same key exchange algorithm. If the algorithms used by the two parties do not match, change the algorithm on the SSH client. |
SSHC_MAC_ERROR
Message text |
The SSH client received from the SSH server a packet with incorrect message authentication code. |
Variable fields |
None. |
Severity level |
5 |
Example |
SSHC/5/SSHC_MAC_ERROR: The SSH client received from the SSH server a packet with incorrect message authentication code. |
Explanation |
The SSH client received a packet from the SSH server, and the message authentication code of the packet was incorrect. |
SSHC_PUBLICKEY_NOT_EXIST
Message text |
The public key of the SSH server does not exist. |
Variable fields |
None. |
Severity level |
5 |
Example |
SSHC/5/SSHC_PUBLICKEY_NOT_EXIST: The public key of the SSH server does not exist. |
Explanation |
The specified public key of the SSH server does not exist. |
Use the display public-key peer command on the SSH client to verify that the client has the specified public key of the SSH server. |
SSHC_VERSION_MISMATCH
Message text |
The SSH client failed to log in because of version mismatch. |
Variable fields |
None. |
Severity level |
5 |
Example |
SSHC/5/SSHC_VERSION_MISMATCH: The SSH client failed to log in because of version mismatch. |
Explanation |
The SSH client failed login because the SSH client and the SSH server use different SSH versions. |
Modify the SSH client version on the client to ensure that it uses the same SSH version as the SSH server. |
SSHS messages
This section contains SSH server messages.
SSHS_ACL_DENY
Message text |
The SSH Connection [IPADDR]([STRING]) request was denied according to ACL rules. |
Variable fields |
$1: IP address of the SSH client. $2: VPN instance to which the IP address of the SSH client belongs. |
Severity level |
5 |
Example |
SSHS/5/SSH_ACL_DENY: The SSH Connection 1.2.3.4(vpn1) request was denied according to ACL rules. |
Explanation |
The SSH server detected a login attempt from the invalid SSH client and denied the connection request of the client by using the ACL rules. |
SSHS_ALGORITHM_MISMATCH
Message text |
SSH client [STRING] failed to log in because of [STRING] algorithm mismatch. |
Variable fields |
$1: IP address of the SSH client. $2: Type of the algorithm, including encryption, key exchange, MAC, and public key. |
Severity level |
6 |
Example |
SSHS/6/SSHS_ALGORITHM_MISMATCH: SSH client 192.168.30.117 failed to log in because of encryption algorithm mismatch. |
Explanation |
The SSH client and the SSH server used different algorithms. |
Verify that the SSH client and the SSH server use the same algorithm. |
SSHS_AUTH_EXCEED_RETRY_TIMES
Message text |
SSH user [STRING] (IP: [STRING]) failed to log in, because the number of authentication attempts exceeded the upper limit. |
Variable fields |
$1: User name. $2: IP address of the SSH client. |
Severity level |
6 |
Example |
SSHS/6/SSHS_AUTH_EXCEED_RETRY_TIMES: SSH user David (IP: 192.168.30.117) failed to log in, because the number of authentication attempts exceeded the upper limit. |
Explanation |
The number of authentication attempts by an SSH user reached the upper limit. |
Prompt the SSH user to use the correct login data to try again. |
SSHS_AUTH_FAIL
Message text |
SSH user [STRING] (IP: [STRING]) didn't pass public key authentication for [STRING]. |
Variable fields |
$1: Username. $2: IP address of the SSH client. $3: Failure reasons: ¡ Wrong public key algorithm. ¡ Wrong public key. ¡ Wrong digital signature. |
Severity level |
6 |
Example |
SSHS/6/SSHS_AUTH_FAIL: SSH user David (IP: 192.168.30.117) didn't pass public key authentication for wrong public key algorithm. |
Explanation |
An SSH user failed the publickey authentication. |
Tell the SSH user to try to log in again. |
SSHS_AUTH_KBDINT_FAIL
Message text |
SSH user [STRING] (IP: [STRING]) didn't pass keyboard-interactive authentication. |
Variable fields |
$1: Username. $2: IP address of the SSH client. |
Severity level |
6 |
Example |
SSHS/6/SSHS_AUTH_KBDINT_FAIL: SSH user David (IP: 192.168.30.117) didn't pass keyboard-interactive authentication. |
Explanation |
An SSH user failed the keyboard-interactive authentication. |
SSHS_AUTH_PWD_FAIL
Message text |
Authentication failed for user [STRING] from [STRING] port [INT32] because of invalid username or wrong password. |
Variable fields |
$1: Username. $2: IP address of the SSH client. $3: Port number. |
Severity level |
6 |
Example |
SSHS/6/SSHS_AUTH_PWD_LOG: Authentication failed for user David from 140.1.1.46 port 16266 because of invalid username or wrong password. |
Explanation |
An SSH user failed authentication because of invalid username or wrong password. |
Make sure the SSH user uses correct username and password. |
SSHS_AUTH_TIMEOUT
Message text |
Authentication timed out for [IPADDR]. |
Variable fields |
$1: IP address of the SSH client. |
Severity level |
6 |
Example |
SSHS/6/SSHS_AUTH_TIMEOUT: Authentication timed out for 1.1.1.1. |
Explanation |
The authentication timeout timer expired, and the SSH user failed the authentication. |
Make sure the SSH user enters correct authentication information before the authentication timeout timer expires. |
SSHS_AUTH_SUCCESS
Message text |
SSH user [STRING] from [IPADDR] port [INTEGER] passed [STRING] authentication. |
Variable fields |
$1: Username. $2: IP address of the SSH client. $3: TCP source port. $4: Authentication method: keyboard-interactive, password, or publickey. |
Severity level |
6 |
Example |
SSHS/6/SSHS_AUTH_SUCCESS: SSH user ABC from 1.1.1.1 port 55361 passed keyboard-interactive authentication. |
Explanation |
An SSH user passed authentication. |
SSHS_AUTHOR_FAIL
Message text |
Authorization failed for user [STRING] from [STRING] port [INT32]. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_AUTHOR_FAIL: Authorization failed for user David from 140.1.2.46 port 15000. |
Explanation |
Authorization failed for an SSH user. |
Check the configuration of the local user or the authentication server. |
SSHS_CERT_VERIFY_FAIL
Message text |
Variable fields |
Severity level |
5 |
Example |
SSHS/5/SSHS_CERT_VERIFY_FAIL: Failed to verify the certificate because null certificate. |
Explanation |
Certificate authentication fails. |
SSHS_CONNECT
Message text |
SSH user [STRING] (IP: [STRING]) connected to the server successfully. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_CONNECT: SSH user David (IP: 192.168.30.117) connected to the server successfully. |
Explanation |
An SSH user logged in to the server successfully. |
SSHS_DECRYPT_FAIL
Message text |
The packet from [STRING] failed to be decrypted with [STRING]. |
Variable fields |
$1: IP address of the SSH client. $2: Encryption algorithm, such as AES256-CBC. |
Severity level |
5 |
Example |
SSHS/5/SSHS_DECRYPT_FAIL: The packet from 192.168.30.117 failed to be decrypted with aes256-cbc. |
Explanation |
A packet from an SSH client failed to be decrypted. |
SSHS_DISCONNECT
Message text |
SSH user [STRING] (IP: [STRING]) disconnected from the server. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_DISCONNECT: SSH user David (IP: 192.168.30.117) disconnected from the server. |
Explanation |
An SSH user logged out. |
SSHS_ENCRYPT_FAIL
Message text |
The packet to [STRING] failed to be encrypted with [STRING]. |
Variable fields |
$1: IP address of the SSH client. $2: Encryption algorithm, such as aes256-cbc. |
Severity level |
5 |
Example |
SSHS/5/SSHS_ENCRYPT_FAIL: The packet to 192.168.30.117 failed to be encrypted with aes256-cbc. |
Explanation |
A packet to an SSH client failed to be encrypted. |
SSHS_LOG
Message text |
Authentication failed for user [STRING] from [STRING] port [INT32] because of invalid username or wrong password. Authorization failed for user [STRING] from [STRING] port [INT32]. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_LOG: Authentication failed for user David from 140.1.1.46 port 16266 because of invalid username or wrong password. SSHS/6/SSHS_LOG: Authorization failed for user David from 140.1.2.46 port 15000. |
Explanation |
An SSH user failed authentication because the username or password was wrong. An SSH user failed authorization. |
SSHS_MAC_ERROR
Message text |
SSH server received a packet with wrong message authentication code (MAC) from [STRING]. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_MAC_ERROR: SSH server received a packet with wrong message authentication code (MAC) from 192.168.30.117. |
Explanation |
The SSH server received a packet with a wrong MAC from a client. |
SSHS_REACH_SESSION_LIMIT
Message text |
SSH client [STRING] failed to log in. The current number of SSH sessions is [NUMBER]. The maximum number allowed is [NUMBER]. |
Variable fields |
$1: IP address of the SSH client. $2: Current number of SSH sessions. $3: Maximum number of SSH sessions allowed on the device. |
Severity level |
6 |
Example |
SSHS/6/SSHS_REACH_SESSION_LIMIT: SSH client 192.168.30.117 failed to log in. The current number of SSH sessions is 10. The maximum number allowed is 10. |
Explanation |
The number of SSH sessions reached the upper limit. |
SSHS_REACH_USER_LIMIT
Message text |
SSH client [STRING] failed to log in, because the number of users reached the upper limit. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_REACH_USER_LIMIT: SSH client 192.168.30.117 failed to log in, because the number of users reached the upper limit. |
Explanation |
The number of SSH users reached the upper limit. |
SSHS_SCP_OPER
Message text |
User [STRING] at [IPADDR] requested operation: [STRING]. |
Variable fields |
$1: Username. $2: IP address of the SCP client. $3: Requested file operations: ¡ get file "name"'—Downloads the file name from the SCP server. ¡ put file "name"—Uploads the file name to the SCP server. |
Severity level |
6 |
Example |
SSHS/6/SSHS_SCP_OPER: -MDC=1; User user1 at 1.1.1.1 requested operation: put file "aa". |
Explanation |
The SCP sever received an operation request from an SCP client. |
SSHS_SFTP_OPER
Message text |
Variable fields |
$1: Username. $2: IP address of the SFTP client. $3: Requested operations on a file or directory: ¡ open dir "path"—Opens the directory path. ¡ open "file" (attribute code code) in MODE mode—Opens the file file with the attribute code code in mode MODE. ¡ remove file "path"—Deletes the file path. ¡ mkdir "path" (attribute code code)—Creates a new directory path with the attribute code code. ¡ rmdir "path"—Deletes the directory path. ¡ rename old "old-name" to new "new-name"—Changes the name of a file or folder from old-name to new-name. |
Severity level |
6 |
Example |
SSHS/6/SSHS_SFTP_OPER: User user1 at 1.1.1.1 requested operation: open dir "flash:/". |
Explanation |
The SFTP sever received an operation request from an SFTP client. |
SSHS_SRV_UNAVAILABLE
Message text |
The [STRING] server is disabled or the [STRING] service type is not supported. |
Variable fields |
$1: Service type, which can be Stelnet, SCP, SFTP, or NETCONF. |
Severity level |
6 |
Example |
SSHS/6/SSHS_SRV_UNAVAILABLE: The SCP server is disabled or the SCP service type is not supported. |
Explanation |
The server was disconnecting the connection because of unavailable Stelnet/SCP/SFTP service. |
Verify that the Stelnet/SCP/SFTP service is available and the user configuration is correct. |
SSHS_VERSION_MISMATCH
Message text |
SSH client [STRING] failed to log in because of version mismatch. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_VERSION_MISMATCH: SSH client 192.168.30.117 failed to log in because of version mismatch. |
Explanation |
The SSH client and the SSH server used different SSH versions. |
Verify that the SSH client and the SSH server use the same SSH version. |
STAMGR messages
This section contains station management messages.
STAMGR_ADD_FAILVLAN
Message text |
-SSID=[STRING]-UserMAC=[STRING]; Added a user to the Fail VLAN [STRING]. |
Variable fields |
$1: SSID. $2: MAC address of the client. $3: ID of the Fail VLAN. |
Severity level |
5 |
Example |
Explanation |
The client failed to pass the authentication and was assigned to the Auth-Fail VLAN. |
STAMGR_ADDBAC_INFO
Message text |
Add BAS AC [STRING]. |
Variable fields |
$1: MAC address of the BAS AC. |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_ADDBAC_INFO: Add BAS AC 3ce5-a616-28cd. |
Explanation |
The BAS AC was connected to the master AC. |
STAMGR_ADDSTA_INFO
Message text |
Add client [STRING]. |
Variable fields |
$1: MAC address of the client. |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_ADDSTA_INFO: Add client 3ce5-a616-28cd. |
Explanation |
The client was connected to the BAS AC. |
STAMGR_AUTHORACL_FAILURE
Message text |
-SSID=[STRING]-UserMAC=[STRING]; Failed to assign an ACL. Reason: [STRING]. |
Variable fields |
$1: SSID. $2: MAC address of the client. $3: Reason: · Not enough hardware resources. · The ACL conflicts with other ACLs. · The ACL doesn't contain any rules. · Unknown error. |
Severity level |
5 |
Example |
Explanation |
The authentication server failed to assign an ACL to the client. |
STAMGR_AUTHORUSERPROFILE_FAILURE
Message text |
-SSID=[STRING]-UserMAC=[STRING]; Failed to assign a user profile. |
Variable fields |
$1: SSID. $2: MAC address of the client. |
Severity level |
5 |
Example |
Explanation |
The authentication server failed to assign a user profile to the client. |
STAMGR_CLIENT_OFFLINE
Message text |
Client [STRING] went offline from BSS [STRING] with [STRING]. State changed to Unauth. |
Variable fields |
$1: MAC address of the client. $2: BSSID. $3: SSID defined in the service template. |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 0023-8933-2147 went offline from BSS 0023-12ef-78dc with SSID abc. State changed to Unauth. |
Explanation |
The client went offline from the BSS. The state of the client changed to Unauth. |
To resolve the issue: 402. Examine whether the AP and its radios operate correctly if the client went offline abnormally. 403. If they do not operate correctly, check the debugging information to locate the issue and resolve it. 404. If the issue persists, contact H3C Support. |
STAMGR_CLIENT_ONLINE
Message text |
Client [STRING] went online from BSS [STRING] with SSID [STRING]. State changed to Run. |
Variable fields |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_CLIENT_ONLINE: Client 0023-8933-2147 went online from BSS 0023-12ef-78dc with SSID abc. State changed to Run. |
Explanation |
The client came online from the BSS. The state of the client changed to Run. |
STAMGR_DELBAC_INFO
Message text |
Delete BAS AC [STRING]. |
Variable fields |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_DELBAC_INFO: Delete BAS AC 3ce5-a616-28cd. |
Explanation |
The BAS AC was disconnected from the master AC. |
STAMGR_DELSTA_INFO
Message text |
Delete client [STRING]. |
Variable fields |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_DELSTA_INFO: Delete client 3ce5-a616-28cd. |
Explanation |
The client was disconnected from the BAS AC. |
STAMGR_DOT1X_LOGIN_FAILURE
Message text |
Variable fields |
$1: Username. $2: MAC address of the client. $3: SSID. $4: VLAN ID. |
Severity level |
5 |
Example |
Explanation |
The client failed to pass 802.1X authentication. The failure can be caused by one of the following reasons: · Unavailable AAA server. · Incorrect username or password. |
To resolve the issue: 405. Examine the network connection between the device and the AAA server. 406. Verify that the AAA server works correctly. 407. Verify that the AAA server is configured with the correct username and password. 408. If the issue persists, contact H3C Support. |
STAMGR_DOT1X_LOGIN_SUCC
Message text |
Variable fields |
Severity level |
6 |
Example |
Explanation |
The client came online after passing 802.1X authentication. |
STAMGR_DOT1X_LOGOFF
Message text |
Variable fields |
Severity level |
6 |
Example |
Explanation |
The 802.1X authenticated client was logged off. |
No action is required. |
STAMGR_MACA_LOGIN_FAILURE
Message text |
Variable fields |
$1: Username. $2: MAC address of the client. $3: SSID. $4: VLAN ID. $5: Username format: · fixed. · MAC address. |
Severity level |
5 |
Example |
Explanation |
The client failed to pass MAC authentication. The failure can be caused by one of the following reasons: · Unavailable AAA server. · Incorrect username or password. |
To resolve the issue: 409. Examine the network connection between the device and the AAA server. 410. Verify that the AAA server works correctly. 411. Verify that the AAA server is configured with the correct username and password. 412. If the issue persists, contact H3C Support. |
STAMGR_MACA_LOGIN_SUCC
Message text |
Variable fields |
Severity level |
6 |
Example |
Explanation |
The client came online after passing MAC authentication. |
STAMGR_MACA_LOGOFF
Message text |
Variable fields |
Severity level |
6 |
Example |
Explanation |
The MAC authenticated client was logged off. |
STAMGR_STAIPCHANGE_INFO
Message text |
IP address of client [STRING] changed to [STRING]. |
Variable fields |
$1: MAC address of the client. $1: New IP address of the client. |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_STAIPCHANGE_INFO: IP address of client 3ce5-a616-28cd changed to 4.4.4.4. |
Explanation |
The IP address of the client was updated. |
STAMGR_TRIGGER_IP
Message text |
-SSID=[STRING]-UserMAC=[STRING]-VLANID=[STRING]; Intrusion protection triggered. Action: [STRING]. |
Variable fields |
$1: SSID. $2: MAC address of the client. $4: VLAN ID. $5: Action: · Added the user to the blocked MAC address list. · Closed the user's BSS temporarily. · Closed the user's BSS permanently. |
Severity level |
5 |
Example |
Explanation |
Intrusion protection was triggered and the action was displayed. |
STM messages
This section contains IRF messages.
STM_AUTO_UPDATE_FAILED
Message text |
Pattern 1: Slot [UINT32] auto-update failed. Reason: [STRING]. Pattern 2: Chassis [UINT32] slot [UINT32] auto-update failed. Reason: [STRING]. |
Variable fields |
Pattern 1: $1: IRF member ID. $2: Failure reason: ¡ Timeout when loading—The IRF member device failed to complete loading software within the required time period. ¡ Wrong description when loading—The file description in the software image file does not match the current attributes of the software image. This issue might occur when the file does not exist or is corrupted. ¡ Disk full when writing to disk—The storage medium does not have sufficient space. Pattern 2: $1: IRF member ID. $2: Slot number of an MPU. $3: Failure reason: ¡ Timeout when loading—The MPU failed to complete loading software within the required time period. ¡ Wrong description when loading—The file description in the software image file does not match the current attributes of the software image. This issue might occur when the file does not exist or is corrupted. ¡ Disk full when writing to disk—The MPU does not have sufficient storage space. |
Severity level |
4 |
Example |
STM/4/STM_AUTO_UPDATE_FAILED: Slot 5 auto-update failed. Reason: Timeout when loading. |
Explanation |
Pattern 1: Software synchronization from the master failed on a subordinate device. Pattern 2: Software synchronization from the global active MPU failed on a standby MPU. |
413. Remove the issue depending on the failure reason: ¡ If the failure reason is Timeout when loading, verify that all IRF links are up. ¡ If the failure reason is Wrong description when loading, download the software images again. ¡ If the failure reason is Disk full when writing to disk, delete unused files to free the storage space. 414. Upgrade software manually for the device or MPU to join the IRF fabric, and then connect the device to the IRF fabric. |
STM_AUTO_UPDATE_FINISHED
Message text |
Pattern 1: File loading finished on slot [UINT32]. Pattern 2: File loading finished on chassis [UINT32] slot [UINT32]. |
Variable fields |
Pattern 1: $1: IRF member ID. Pattern 2: $1: IRF member ID. $2: Slot number of an MPU. |
Severity level |
5 |
Example |
STM/5/STM_AUTO_UPDATE_FINISHED: File loading finished on slot 3. |
Explanation |
Pattern 1: The member device finished loading software images. Pattern 2: The MPU finished loading software images. |
STM_AUTO_UPDATING
Message text |
Pattern 1: Don't reboot the slot [UINT32]. It is loading files. Pattern 2: Don't reboot the chassis [UINT32] slot [UINT32]. It is loading files. |
Variable fields |
Severity level |
5 |
Example |
STM/5/STM_AUTO_UPDATING: Don't reboot the slot 2. It is loading files. |
Explanation |
Pattern 1: The member device is loading software images. To avoid software upgrade failure, do not reboot the member device. Pattern 2: The MPU is loading software images. To avoid software upgrade failure, do not reboot the MPU. |
STM_HELLOPKT_NOTSEND
Message text |
Hello thread hasn't sent packets for [UINT32] seconds. |
Variable fields |
$1: Time value. |
Severity level |
5 |
Example |
STM/5/STM_HELLOPKT_NOTSEND: Hello thread hasn't sent packets for 10 seconds. |
Explanation |
The hello thread hasn't sent packets for 10 seconds. |
Execute the display cpu-usage command to identify whether the CPU usage has increased to a high level for a period of time. If yes, decrease the CPU usage. For example, the CPU usage increases dramatically when an attack occurs or when the system is processing CPU-intensive tasks. If you cannot locate the cause, please contact H3C Support. The IRF fabric splits if the hello thread hasn't sent packets before the heartbeat time expires. |
STM_HELLOPKT_NOTRCV
Message text |
Hello thread hasn't received packets for [UINT] seconds. |
Variable fields |
$1: Time value. |
Severity level |
5 |
Example |
STM/5/STM_HELLOPKT_NOTRCV: Hello thread hasn't received packets for 10 seconds. |
Explanation |
The hello thread hasn't received packets for 10 seconds. |
Execute the display cpu-usage command to identify whether the CPU usage has increased to a high level for a period of time. If yes, decrease the CPU usage. For example, the CPU usage increases dramatically when an attack occurs or when the system is processing CPU-intensive tasks. If you cannot locate the cause, please contact H3C Support. The IRF fabric splits if the hello thread hasn't received packets for a long time. |
STM_LINK_DOWN
Message text |
IRF port [UINT32] went down. |
Variable fields |
$1: IRF port name. |
Severity level |
3 |
Example |
STM/3/STM_LINK_DOWN: IRF port 2 went down. |
Explanation |
This event occurs when all physical interfaces bound to an IRF port are down. |
Check the physical interfaces bound to the IRF port. Make sure a minimum of one member physical interface is up. |
STM_LINK_TIMEOUT
Message text |
IRF port [UINT32] went down because the heartbeat timed out. |
Variable fields |
Severity level |
2 |
Example |
STM/2/STM_LINK_TIMEOUT: IRF port 1 went down because the heartbeat timed out. |
Explanation |
The IRF port went down because of heartbeat timeout. |
Check the IRF link for link failure. |
STM_LINK_UP
Message text |
IRF port [UINT32] came up. |
Variable fields |
Severity level |
6 |
Example |
STM/6/STM_LINK_UP: IRF port 1 came up. |
Explanation |
An IRF port came up. |
STM_MERGE
Message text |
IRF merge occurred. |
Variable fields |
N/A |
Severity level |
4 |
Example |
STM/4/STM_MERGE: IRF merge occurred. |
Explanation |
STM_MERGE_NEED_REBOOT
Message text |
IRF merge occurred. This IRF system needs a reboot. |
Variable fields |
N/A |
Severity level |
4 |
Example |
STM/4/STM_MERGE_NEED_REBOOT: IRF merge occurred. This IRF system needs a reboot. |
Explanation |
You must reboot the current IRF fabric for IRF merge, because it failed in the master election. |
Log in to the IRF fabric, and use the reboot command to reboot the IRF fabric. |
STM_MERGE_NOT_NEED_REBOOT
Message text |
IRF merge occurred. This IRF system does not need to reboot. |
Variable fields |
N/A |
Severity level |
5 |
Example |
STM/5/STM_MERGE_NOT_NEED_REBOOT: IRF merge occurred. This IRF system does not need to reboot. |
Explanation |
You do not need to reboot the current IRF fabric for IRF merge, because it was elected the master. |
Reboot the IRF fabric that has failed in the master election to finish the IRF merge. |
STM_SAMEMAC
Message text |
Failed to stack because of the same bridge MAC addresses. |
Variable fields |
N/A |
Severity level |
4 |
Example |
STM/4/STM_SAMEMAC: Failed to stack because of the same bridge MAC addresses. |
Explanation |
Failed to set up the IRF fabric because some member devices are using the same bridge MAC address. |
415. Verify that IRF bridge MAC persistence is disabled on the member devices. To disable this feature, use the undo irf mac-address persistent command. 416. If the issue persists, contact H3C Support. |
STM_SOMER_CHECK
Message text |
Neighbor of IRF port [UINT32] cannot be stacked. |
Variable fields |
Severity level |
3 |
Example |
STM/3/STM_SOMER_CHECK: Neighbor of IRF port 1 cannot be stacked. |
Explanation |
The neighbor connected to the IRF port cannot form an IRF fabric with the device. |
Check the following items: · The device models can form an IRF fabric. · The IRF settings are correct. For more information, see the IRF configuration guide for the device. |
STP messages
This section contains STP messages.
STP_BPDU_PROTECTION
Message text |
BPDU-Protection port [STRING] received BPDUs. |
Variable fields |
$1: Interface name. |
Severity level |
4 |
Example |
STP/4/STP_BPDU_PROTECTION: BPDU-Protection port GigabitEthernet1/0/1 received BPDUs. |
Explanation |
A BPDU-guard-enabled port received BPDUs. |
Check whether the downstream device is a terminal and check for possible attacks from the downstream device or other devices. |
STP_BPDU_RECEIVE_EXPIRY
Message text |
Instance [UINT32]'s port [STRING] received no BPDU within the rcvdInfoWhile interval. Information of the port aged out. |
Variable fields |
$1: Instance ID. $2: Interface name. |
Severity level |
5 |
Example |
STP/5/STP_BPDU_RECEIVE_EXPIRY: Instance 0's port GigabitEthernet1/0/1 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out. |
Explanation |
The state of a non-designated port changed because the port did not receive a BPDU within the max age. |
Check the STP status of the upstream device and possible attacks from other devices. |
STP_CONSISTENCY_CHECK
Message text |
DR role assignment finished. Please verify that the local device and the peer device have consistent global and DR-interface-specific STP settings. |
Variable fields |
N/A |
Severity level |
5 |
Example |
STP/5/STP_CONSISTENCY_CHECK: DR role assignment finished. Please verify that the local device and the peer device have consistent global and DR-interface-specific STP settings. |
Explanation |
The DR member devices in a DR system must have the same global and DR-interface-specific STP settings. |
Check the global and DR-interface-specific STP settings on the local and peer DR member devices. |
STP_CONSISTENCY_RESTORATION
Message text |
Variable fields |
$1: VLAN ID. $2: Interface name. |
Severity level |
6 |
Example |
STP/6/STP_CONSISTENCY_RESTORATION: Consistency restored on VLAN 10's port GigabitEthernet1/0/1. |
Explanation |
Port link type or PVID inconsistency was removed on a port. |
STP_DETECTED_TC
Message text |
[STRING] [UINT32]'s port [STRING] detected a topology change. |
Variable fields |
$1: Instance or VLAN. $2: Instance ID or VLAN ID. $3: Interface name. |
Severity level |
6 |
Example |
STP/6/STP_DETECTED_TC: Instance 0's port GigabitEthernet1/0/1 detected a topology change. |
Explanation |
The MSTP instance or VLAN to which a port belongs had a topology change, and the local end detected the change. |
Identify the topology change cause and handle the issue. For example, if the change is caused by a link down event, recover the link. |
STP_DISABLE
Message text |
STP is now disabled on the device. |
Variable fields |
N/A |
Severity level |
6 |
Example |
STP/6/STP_DISABLE: STP is now disabled on the device. |
Explanation |
STP was globally disabled on the device. |
STP_DISCARDING
Message text |
Instance [UINT32]'s port [STRING] has been set to discarding state. |
Variable fields |
Severity level |
6 |
Example |
STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/1 has been set to discarding state. |
Explanation |
MSTP calculated the state of ports within an instance, and a port was set to the discarding state. |
STP_DISPUTE
Message text |
[STRING] [UINT32]'s port [STRING] received an inferior BPDU from a designated port which is in forwarding or learning state. |
Variable fields |
Severity level |
4 |
Example |
STP/4/STP_DISPUTE: Instance 0's port GigabitEthernet1/0/2 received an inferior BPDU from a designated port which is in forwarding or learning state. |
Explanation |
A port in the MSTI or VLAN received a low-priority BPDU from a designated port in forwarding or learning state. |
Verify that the peer port can receive packets from the local port: 417. Use the display stp abnormal-port command to display information about ports that are blocked by dispute protection. 418. Verify that the VLAN configurations on the local and peer ports are consistent. 419. Shut down the link between the two ports and then bring up the link, or connect the local port to another port. |
STP_ENABLE
Message text |
STP is now enabled on the device. |
Variable fields |
N/A |
Severity level |
6 |
Example |
STP/6/STP_ENABLE: STP is now enabled on the device. |
Explanation |
STP was globally enabled on the device. |
STP_FORWARDING
Message text |
Instance [UINT32]'s port [STRING] has been set to forwarding state. |
Variable fields |
Severity level |
6 |
Example |
STP/6/STP_FORWARDING: Instance 0's port GigabitEthernet1/0/1 has been set to forwarding state. |
Explanation |
MSTP calculated the state of ports within an instance, and a port was set to the forwarding state. |
STP_LOOP_PROTECTION
Message text |
Instance [UINT32]'s LOOP-Protection port [STRING] failed to receive configuration BPDUs. |
Variable fields |
Severity level |
4 |
Example |
STP/4/STP_LOOP_PROTECTION: Instance 0's LOOP-Protection port GigabitEthernet1/0/1 failed to receive configuration BPDUs. |
Explanation |
A loop-guard-enabled port failed to receive configuration BPDUs. |
STP_LOOPBACK_PROTECTION
Message text |
[STRING] [UINT32]'s port [STRING] received its own BPDU. |
Variable fields |
Severity level |
4 |
Example |
STP/4/STP_LOOPBACK_PROTECTION: Instance 0's port GigabitEthernet1/0/2 received its own BPDU. |
Explanation |
A port in the MSTI or VLAN received a BPDU sent by itself. |
Check for forged BPDUs from attackers or loops in the network. |
STP_NOT_ROOT
Message text |
The current switch is no longer the root of instance [UINT32]. |
Variable fields |
$1: Instance ID. |
Severity level |
5 |
Example |
STP/5/STP_NOT_ROOT: The current switch is no longer the root of instance 0. |
Explanation |
The current switch is no longer the root bridge of an instance. It received a superior BPDU after it was configured as the root bridge. |
Check the bridge priority configuration and possible attacks from other devices. |
STP_NOTIFIED_TC
Message text |
[STRING] [UINT32]'s port [STRING] was notified of a topology change. |
Variable fields |
Severity level |
6 |
Example |
STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/1 was notified of a topology change. |
Explanation |
The neighboring device on a port notified the current device that a topology change occurred in the instance or VLAN to which the port belongs. |
STP_PORT_TYPE_INCONSISTENCY
Message text |
Access port [STRING] in VLAN [UINT32] received PVST BPDUs from a trunk or hybrid port. |
Variable fields |
$1: Interface name. $2: VLAN ID. |
Severity level |
4 |
Example |
Explanation |
An access port received PVST BPDUs from a trunk or hybrid port. |
Check the port link type setting on the ports. |
STP_PVID_INCONSISTENCY
Message text |
Port [STRING] with PVID [UINT32] received PVST BPDUs from a port with PVID [UINT32]. |
Variable fields |
$1: Interface name. $2: VLAN ID. $3: VLAN ID. |
Severity level |
4 |
Example |
Explanation |
A port received PVST BPDUs from a remote port with a different PVID. |
Verify that the PVID is consistent on both ports. |
STP_PVST_BPDU_PROTECTION
Message text |
PVST BPDUs were received on port [STRING], which is enabled with PVST BPDU protection. |
Variable fields |
Severity level |
4 |
Example |
Explanation |
In MSTP mode, a port enabled with PVST BPDU guard received PVST BPDUs. |
Identify the device that sends the PVST BPDUs. |
STP_ROOT_PROTECTION
Message text |
Instance [UINT32]'s ROOT-Protection port [STRING] received superior BPDUs. |
Variable fields |
Severity level |
4 |
Example |
STP/4/STP_ROOT_PROTECTION: Instance 0's ROOT-Protection port GigabitEthernet1/0/1 received superior BPDUs. |
Explanation |
A root-guard-enabled port received BPDUs that are superior to the BPDUs generated by itself. |
STP_STG_NUM_DETECTION
Message text |
STG count [UINT32] is smaller than the MPU's STG count [UINT32]. |
Variable fields |
$1: Number of STGs on a card. $2: Number of STGs on the MPU. |
Severity level |
4 |
Example |
STP/4/STP_STG_NUM_DETECTION: STG count 64 is smaller than the MPU's STG count 65. |
Explanation |
The system detected that the STG count on a card was smaller than that on the MPU. |
Make sure the number of spanning tree instances is not larger than the smallest card-specific STG count. For example, if the number of spanning tree instances is m and the smallest STG count among cards is n, m cannot be larger than n. |
SYSLOG messages
This section contains syslog (information center) messages.
SYSLOG_LOGBUFFER_FAILURE
Message text |
Log cannot be sent to the logbuffer because of communication timeout between syslog and DBM processes. |
Variable fields |
N/A |
Severity level |
4 |
Example |
SYSLOG/4/SYSLOG_LOGBUFFER_FAILURE: Log cannot be sent to the logbuffer because of communication timeout between syslog and DBM processes. |
Explanation |
Failed to output logs to the logbuffer because of the communication timeout between syslog and DBM processes. |
Reboot the device or contact H3C Support. |
SYSLOG_LOGFILE_FULL
Message text |
Log file space is full. |
Variable fields |
N/A |
Severity level |
4 |
Example |
SYSLOG/4/SYSLOG_LOGFILE_FULL: Log file space is full. |
Explanation |
The log file is full. |
Back up the log file, remove the original file, and then bring up interfaces as needed. |
SYSLOG_NO_SPACE
Message text |
Failed to save log file due to lack of space resources. |
Variable fields |
N/A |
Severity level |
4 |
Example |
SYSLOG/4/SYSLOG_NO_SPACE: -MDC=1; Failed to save log file due to lack of space resources. |
Explanation |
Failed to save logs to the log file due to lack of storage space. |
Clean up the storage space of the device regularly to ensure sufficient storage space for saving logs to the log file. |
SYSLOG_RESTART
Message text |
System restarted -- [STRING] [STRING] Software. |
Variable fields |
$1: Company name. $2: Software name. |
Severity level |
6 |
Example |
SYSLOG/6/SYSLOG_RESTART: System restarted -- H3C Comware Software |
Explanation |
A system restart log was generated. |
SYSLOG_RTM_EVENT_BUFFER_FULL
Message text |
In the last minute, [STRING] syslog logs were not monitored because the buffer was full. |
Variable fields |
$1: Number of system logs that were not sent to the EAA module in the last minute. |
Severity level |
5 |
Example |
SYSLOG/5/SYSLOG_RTM_EVENT_BUFFER_FULL: In the last minute, 100 syslog logs were not monitored because the buffer was full. |
Explanation |
This message records the number of system logs that are not processed by EAA because the log buffer monitored by EAA is full. The log buffer can be filled up if the device generates large numbers of system logs in a short period of time. |
· Identify log sources and take actions to reduce system logs. · Use the rtm event syslog buffer-size command to increase the log buffer size. |
TACACS messages
This section contains TACACS messages.
TACACS_ACCT_SERVER_DOWN
Message text |
TACACS accounting server was blocked: Server IP=[STRING], port=[UINT32], VPN instance=[STRING]. |
Variable fields |
$1: IP address of the accounting server. $2: Port number of the accounting server. $3: VPN instance name. This field displays public if the server belongs to the public network. |
Severity level |
4 |
Example |
TACACS/4/TACACS_ACCT_SERVER_DOWN: TACACS accounting server was blocked: Server IP=1.1.1.1, port=1812, VPN instance=public. |
Explanation |
An accounting server became blocked. |
420. Verify that the accounting server has started up. 421. Ping the accounting server to verify that the server is reachable. If the server is not reachable, check the link for connectivity issues and resolve the issues. 422. Collect logs and diagnostic logs, and then contact H3C Support. |
TACACS_ACCT_SERVER_UP
Message text |
TACACS accounting server became active: Server IP=[STRING], port=[UINT32], VPN instance=[STRING]. |
Variable fields |
Severity level |
6 |
Example |
TACACS/6/TACACS_ACCT_SERVER_UP: TACACS accounting server became active: Server IP=1.1.1.1, port=1812, VPN instance=public. |
Explanation |
An accounting server became active. |
TACACS_AUTH_FAILURE
Message text |
User [STRING] at [STRING] failed authentication. |
Variable fields |
$1: Username. $2: IP address. |
Severity level |
5 |
Example |
TACACS/5/TACACS_AUTH_FAILURE: User cwf@system at 192.168.0.22 failed authentication. |
Explanation |
An authentication request was rejected by the TACACS server. |
TACACS_AUTH_SERVER_DOWN
Message text |
TACACS authentication server was blocked: Server IP=[STRING], port=[UINT32], VPN instance=[STRING]. |
Variable fields |
$1: IP address of the authentication server. $2: Port number of the authentication server. $3: VPN instance name. This field displays public if the server belongs to the public network. |
Severity level |
4 |
Example |
TACACS/4/TACACS_AUTH_SERVER_DOWN: TACACS authentication server was blocked: Server IP=1.1.1.1, port=1812, VPN instance=public. |
Explanation |
An authentication server became blocked. |
423. Verify that the authentication server has started up. 424. Ping the authentication server to verify that the server is reachable. If the server is not reachable, check the link for connectivity issues and resolve the issues. 425. Collect logs and diagnostic logs, and then contact H3C Support. |
TACACS_AUTH_SERVER_UP
Message text |
TACACS authentication server became active: Server IP=[STRING], port=[UINT32], VPN instance=[STRING]. |
Variable fields |
Severity level |
6 |
Example |
TACACS/6/TACACS_AUTH_SERVER_UP: TACACS authentication server became active: Server IP=1.1.1.1, port=1812, VPN instance=public. |
Explanation |
An authentication server became active. |
TACACS_AUTH_SUCCESS
Message text |
User [STRING] at [STRING] was authenticated successfully. |
Variable fields |
Severity level |
6 |
Example |
TACACS/6/TACACS_AUTH_SUCCESS: User cwf@system at 192.168.0.22 was authenticated successfully. |
Explanation |
An authentication request was accepted by the TACACS server. |
TACACS_AUTHOR_SERVER_DOWN
Message text |
TACACS authorization server was blocked: Server IP=[STRING], port=[UINT32], VPN instance=[STRING]. |
Variable fields |
$1: IP address of the authorization server. $2: Port number of the authorization server. $3: VPN instance name. This field displays public if the server belongs to the public network. |
Severity level |
4 |
Example |
TACACS/4/TACACS_AUTHOR_SERVER_DOWN: TACACS authorization server was blocked: Server IP=1.1.1.1, port=1812, VPN instance=public. |
Explanation |
An authorization server became blocked. |
426. Verify that the authorization server has started up. 427. Ping the authorization server to verify that the server is reachable. If the server is not reachable, check the link for connectivity issues and resolve the issues. 428. Collect logs and diagnostic logs, and then contact H3C Support. |
TACACS_AUTHOR_SERVER_UP
Message text |
TACACS authorization server became active: Server IP=[STRING], port=[UINT32], VPN instance=[STRING]. |
Variable fields |
Severity level |
6 |
Example |
TACACS/6/TACACS_AUTHOR_SERVER_UP: TACACS authorization server became active: Server IP=1.1.1.1, port=1812, VPN instance=public. |
Explanation |
An authorization server became active. |
TACACS_REMOVE_SERVER_FAIL
Message text |
Failed to remove servers in scheme [STRING]. |
Variable fields |
$1: Scheme name. |
Severity level |
4 |
Example |
TACACS/4/TACACS_REMOVE_SERVER_FAIL: Failed to remove servers in scheme abc. |
Explanation |
Failed to delete servers from a TACACS scheme. |
TCSM
This section contains Trusted Computing Services Management (TCSM) messages.
TCSM_CERT_BROKEN
Message text |
Certificate [STRING] is missing or corrupted. |
Variable fields |
$1: Certificate name. |
Severity level |
3 |
Example |
TCSM/3/TCSM_CERT_BROKEN: Certificate ak1-cert is missing or corrupted. |
Explanation |
A certificate stored in a storage medium is lost or corrupted. |
· If the certificate is user defined, perform the following tasks: a. Replace the storage medium. b. From the manager, sign a new certificate for the TCSM key of the device. · If the certificate is system defined, contact H3C Support. |
TCSM_KEY_BROKEN
Message text |
Key [STRING] is corrupted or missing. |
Variable fields |
$1: Key name. |
Severity level |
3 |
Example |
TCSM/3/TCSM_KEY_BROKEN: Key abc is corrupted or missing. |
Explanation |
A key file stored in a storage medium is lost or corrupted. |
· If the key is user defined, perform the following tasks: c. Use the key destroy command to destroy the key. d. As a best practice, replace the storage medium. · If the key is system defined, contact H3C Support. |
TCSM_KEY_HIERARCHY_BROKEN
Message text |
Key hierarchy of [STRING] is corrupted. |
Variable fields |
$1: Key name |
Severity level |
3 |
Example |
TCSM/3/TCSM_KEY_HIERARCHY_BROKEN: Key hierarchy of abc is corrupted. |
Explanation |
An upper-level key of the specified key is corrupted. |
18. Use the key destroy command to destroy the specified key and its upper-level keys. 19. As a best practice, replace the storage medium. |
TCSM_TSS_SVC_DOWN
Message text |
TSS service is down. |
Variable fields |
N/A |
Severity level |
3 |
Example |
TCSM/3/TCSM_TSS_SVC_DOWN: TSS service is down. |
Explanation |
The TPM software stack process is down. |
Contact H3C Support. |
TCSM_TSS_SVC_UP
Message text |
TSS service is up. |
Variable fields |
N/A |
Severity level |
5 |
Example |
TCSM/5/TCSM_TSS_SVC_DOWN: TSS service is up. |
Explanation |
The TPM software stack process is up. |
TELNETD messages
This section contains Telnet daemon messages.
TELNETD_ACL_DENY
Message text |
The Telnet Connection [IPADDR]([STRING]) request was denied according to ACL rules. |
Variable fields |
$1: IP address of the Telnet client. $2: VPN instance to which the IP address of the Telnet client belongs. |
Severity level |
5 |
Example |
TELNETD/5/TELNETD_ACL_DENY: The Telnet Connection 1.2.3.4(vpn1) request was denied according to ACL rules. |
Explanation |
The ACL for controlling Telnet access denied the access request of a Telnet client. |
TELNETD_REACH_SESSION_LIMIT
Message text |
Telnet client [STRING] failed to log in. The current number of Telnet sessions is [NUMBER]. The maximum number allowed is ([NUMBER]). |
Variable fields |
$1: IP address of the Telnet client. $2: Current number of Telnet sessions. $3: Maximum number of Telnet sessions allowed by the device. |
Severity level |
Example |
Explanation |
The number of Telnet connections reached the limit. |
429. Use the display current-configuration | include session-limit command to view the current limit for Telnet connections. If the command does not display the limit, the device is using the default setting. 430. If you want to set a greater limit, execute the aaa session-limit command. If you think the limit is proper, no action is required. |
TRILL messages
This section contains TRILL messages.
TRILL_DUP_SYSTEMID
Message text |
Duplicate system ID [STRING] in [STRING] PDU sourced from RBridge 0x[HEX]. |
Variable fields |
$1: System ID. $2: PDU type. $3: Source RBridge's nickname. |
Severity level |
5 |
Example |
TRILL/5/TRILL_DUP_SYSTEMID: Duplicate system ID 0011.2200.1501 in LSP PDU sourced from RBridge 0xc758. |
Explanation |
The local RBridge received an LSP or IIH PDU that has the same system ID as the local RBridge. The possible reasons include: · The same system ID is assigned to the local RBridge and the remote RBridge. · The local RBridge received a self-generated LSP PDU with an old nickname. |
Please check the RBridge system IDs on the campus network. |
TRILL_INTF_CAPABILITY
Message text |
The interface [STRING] does not support TRILL. |
Variable fields |
Severity level |
4 |
Example |
TRILL/4/TRILL_INTF_CAPABILITY: The interface GigabitEthernet0/1/3 does not support TRILL. |
Explanation |
An interface that does not support TRILL is assigned to a link aggregation group. |
Remove the interface that does not support TRILL from the link aggregation group. |
TRILL_LICENSE_EXPIRED
Message text |
The TRILL feature is being disabled, because its license has expired. |
Variable fields |
N/A |
Severity level |
3 |
Example |
TRILL/3/TRILL_LICENSE_EXPIRED: The TRILL feature is being disabled, because its license has expired. |
Explanation |
The TRILL license has expired. |
Install a valid license for TRILL. |
TRILL_LICENSE_EXPIRED_TIME
Message text |
The TRILL feature will be disabled in [ULONG] days. |
Variable fields |
$1: Available period of the feature. |
Severity level |
5 |
Example |
TRILL/5/TRILL_LICENSE_EXPIRED_TIME: The TRILL feature will be disabled in 2 days. |
Explanation |
TRILL will be disabled because no TRILL license is available. After an active/standby MPU switchover, you can use TRILL only for 30 days if the new active MPU does not have a TRILL license. |
Install a new license. |
TRILL_LICENSE_UNAVAILABLE
Message text |
The TRILL feature has no available license. |
Variable fields |
N/A |
Severity level |
3 |
Example |
TRILL/3/TRILL_LICENSE_UNAVAILABLE: The TRILL feature has no available license. |
Explanation |
No license was found for TRILL when the TRILL process started. |
TRILL_MEM_ALERT
Message text |
TRILL process receive system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alert event. |
Severity level |
5 |
Example |
TRILL/5/TRILL_MEM_ALERT: TRILL process receive system memory alert start event. |
Explanation |
TRILL receives a memory alert event from the system. |
Check the system memory. |
TRILL_NBR_CHG
Message text |
TRILL [UINT32], [STRING] adjacency [STRING] ([STRING]), state changed to [STRING]. |
Variable fields |
$1: TRILL process ID. $2: Neighbor level. $3: Neighbor system ID. $4: Interface name. $5: Current neighbor state: · up—The neighbor has been established, and can operate correctly. · initializing—The neighbor is being initialized. · down—The neighbor is down. |
Severity level |
5 |
Example |
TRILL/5/TRILL_NBR_CHG: TRILL 1, Level-1 adjacency 0011.2200.1501 (GigabitEthernet0/1/3), state changed to down. |
Explanation |
The state of a TRILL neighbor changed. |
When the neighbor state changed to down or initializing, please check the TRILL configuration and network status according to the reason for the neighbor state change. |
VCF messages
This section contains VCF messages.
VCF_AGGR_CREAT
Message text |
Phase [STRING], Device [STRING] created Layer 2 aggregation group [INT32]: member ports=[STRING]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: ID of a Layer 2 aggregation group. $4: List of Layer 2 aggregation member ports. |
Severity level |
6 |
Example |
VCF/6/VCF_AGGR_CREAT: Phase 2.0.5, Device 0000-0000-0000 created Layer 2 aggregation group 10: member ports=Ten-GigabitEthernet1/0/2, Ten-GigabitEthernet1/0/10. |
Explanation |
A Layer 2 aggregation group was created and member ports were added to the aggregation group. |
VCF_AGGR_DELETE
Message text |
Phase [STRING], Device [STRING] deleted Layer 2 aggregation group [INT32]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: ID of a Layer 2 aggregation group. |
Severity level |
6 |
Example |
VCF/6/VCF_AGGR_DELETE: Phase 2.0.6, Device 0000-0000-0000 deleted Layer 2 aggregation group 10. |
Explanation |
A Layer 2 aggregation group was deleted when only one link in the aggregation group was up. |
VCF_AGGR_FAILED
Message text |
Phase [STRING], Device [STRING] failed to create Layer 2 aggregation group [INT32]. |
Variable fields |
Severity level |
3 |
Example |
VCF/3/ VCF_AGGR_FAILED: Phase 2.0.7, Device 0000-0000-0000 failed to create Layer 2 aggregation group 10. |
Explanation |
Failed to create a Layer 2 aggregation group. |
Troubleshoot the reasons for the aggregation group creation failure, such as insufficient resources. |
VCF_AUTO_ANALYZE_USERDEF
Message text |
Phase [STRING], Device [STRING] started to parse template file. |
Variable fields |
$1: Phase. $2: MAC address of the device. |
Severity level |
6 |
Example |
VCF/6/VCF_AUTO_ANALYZE_USERDEF: Phase 1.2.2, Device 0000-0000-0000 started to parse template file. |
Explanation |
Started to parse user-defined configurations in the template file. |
VCF_AUTO_NO_USERDEF
Message text |
Phase [STRING], Device [STRING] found undefined variable [STRING] in command [STRING] on line [INTEGER]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Undefined user variable. $4: Command in which the undefined user variable resides. $5: Number of the command line. |
Severity level |
3 |
Example |
VCF/3/VCF_AUTO_NO_USERDEF: Phase 1.2.3, Device 0000-0000-0000 found undefined variable $$_ABC in command interface $$_ABC on line 192. |
Explanation |
An undefined user variable exists in the template file. This message is displayed each time an undefined user variable is detected. |
Verify whether the user-defined variables in the template file are correct. |
VCF_AUTO_START
Message text |
Phase [STRING], Device [STRING] (Role [STRING]) started VCF automated deployment. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Role of the device, spine, leaf, or access. |
Severity level |
5 |
Example |
VCF/5/VCF_AUTO_START: Phase 1.0.1, Device 0000-0000-0000 (Role leaf) started VCF automated deployment. |
Explanation |
Started VCF automated deployment. |
VCF_AUTO_STATIC_CMD
Message text |
Phase [STRING], Device [STRING] automatically executed static commands. |
Variable fields |
Severity level |
6 |
Example |
VCF/6/VCF_AUTO_STATIC_CMD: Phase 1.2.4, Device 0000-0000-0000 automatically executed static commands. |
Explanation |
Executed static commands in the template file. Static commands refer to commands that are independent from the VCF fabric topology. |
VCF_BGP
Message text |
Phase [STRING], Device [STRING] established a BGP session with peer [STRING] in AS [INT32]. Pattern 2: Phase [STRING], Device [STRING] established a BGP session with peers [[STRING]] in AS [INT32]. |
Variable fields |
Pattern 1: $1: Phase. $2: MAC address of the device. $3: Address of a BGP peer. $4: Number of the AS where the BGP peer resides. Pattern 2: $1: Phase. $2: MAC address of the device. $3: List of BGP peer addresses, separated by commas (,). $4: Number of the AS where the BGP peers reside. |
Severity level |
6 |
Example |
Pattern 1: VCF/6/VCF_BGP: Phase 3.0.5, Device 0000-0000-0000 established a BGP session with peer 1.1.1.1 in AS 100. Pattern 2: VCF/6/VCF_BGP: Phase 3.0.5, Device 0000-0000-0000 established a BGP session with peers [‘1.1.1.1’ , ‘1.1.1.2’] in AS 100. |
Explanation |
Pattern 1: Established a BGP session with a BGP peer. Pattern 2: Established BGP sessions with multiple BGP peers. Only the master spine node on a Layer 3 network generates this message. |
VCF_DOWN_LINK
Message text |
Phase [STRING], Device [STRING] discovered downlink interface [STRING]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Name of a downlink interface. |
Severity level |
6 |
Example |
VCF/6/VCF_DOWN_LINK: Phase 2.0.8, Device 0000-0000-0000 discovered downlink interface Ten-GigabitEthernet1/0/1. |
Explanation |
A downlink interface was found and the device deployed configuration to the downlink interface. On a spine node, a downlink interface is the interface through which the spine node connects to a leaf node. On a leaf node, a downlink interface is the interface through which the leaf node connects to a downstream access device. |
VCF_DRIVER_INIT
Message text |
Phase [STRING], failed to find driver [STRING]. Driver initialization failed. |
Variable fields |
$1: Phase. $2: Driver name. |
Severity level |
3 |
Example |
VCF/3/VCF_DRIVER_INIT: Phase 3.0.8, failed to find driver 6820. Driver initialization failed. |
Explanation |
Driver initialization failed because the driver was not found. |
431. Verify that the name of the driver is correct. 432. Contact H3C Support to verify that VCF fabric supports the driver. |
VCF_FAILED_ADD_IRFPORT
Message text |
Phase [STRING], failed to bind IRF physical interface [STRING] on device with MAC address [STRING] to an IRF port three times. |
Variable fields |
$1: Phase. $2: IRF physical interface. $3: MAC address. |
Severity level |
4 |
Example |
VCF/4/VCF_FAILED_ADD_IRFPORT: Phase 2.0.10, failed to bind IRF physical interface [STRING] on device with MAC address 4c85-5206-0100 to an IRF port three times. |
Explanation |
This message is generated when VCF stops trying to bind an IRF physical interface to an IRF port after three failed attempts during automated deployment. |
Check the IRF links in the VCF fabric. |
VCF_GET_IMAGE
Message text |
Phase [STRING], Device [STRING] obtained information about update startup image file [STRING]: new version=[STRING], current version=[STRING]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Name of the new startup image file. $4: Version number of the new startup image file. $5: Version number of the current startup image file. |
Severity level |
6 |
Example |
VCF/6/VCF_GET_IMAGE: Phase 1.3.1, Device 0000-0000-0000 obtained information about update startup image file s6800.ipe: new version=V300R009B01D002, current version=V300R009B01D001. |
Explanation |
Obtained the name and the version number of the new startup image file through the template file. |
VCF_GET_TEMPLATE
Message text |
Phase [STRING], Device [STRING] downloaded template file [STRING]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Name of the template file. |
Severity level |
6 |
Example |
VCF/6/VCF_GET_TEMPLATE: Phase 1.2.1, Device 0000-0000-0000 downloaded template file /mnt/flash:/vxlan_spine.template. |
Explanation |
Downloaded the template file for automated deployment. |
VCF_INSTALL_IMAGE
Message text |
Phase [STRING], Device [STRING] started to install the [STRING] version of startup image. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Version number of the new startup image file. |
Severity level |
6 |
Example |
VCF/6/VCF_INSTALL_IMAGE: Phase 1.3.3, Device 0000-0000-0000 started to install the V700R001B70D001 version of startup image. |
Explanation |
Started to install the new software version. |
VCF_IRF_FINISH
Message text |
Phase [STRING], Device [STRING] finished IRF configuration: result=[INT32]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Result of IRF configuration: · 0—Success. · -1—Failure. |
Severity level |
5 |
Example |
VCF/5/VCF_IRF_FINISH: Phase 2.0.3, Device 0000-0000-0000 finished IRF configuration: result=0. |
Explanation |
Finished IRF configuration. |
Contact H3C Support if IRF configuration failed. |
VCF_IRF_FOUND
Message text |
Phase [STRING], Device [STRING] (Role [STRING]) found a peer ([STRING]) with the same role, IRF stackability check result: [INT32]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Role of the device. $4: MAC address of the peer device. $5: Result of the IRF stackability check: · 0—Capable to form an IRF fabric. · 1—MAC address conflict. |
Severity level |
5 |
Example |
VCF/5/VCF_IRF_FOUND: Phase 2.0.1, Device 0000-0000-0000 (Role leaf) found a peer with the same role, IRF stackability check result: 0. |
Explanation |
Found a peer device with the same role in VCF fabric topology discovery and checked whether the device can form an IRF fabric with the peer device. |
VCF_IRF_START
Message text |
Phase [STRING], Device [STRING] started IRF configuration: current member ID=[INT32], new member ID=[INT32], priority=[INT32], IRF-port 1's member ports=[STRING], IRF-port 2's member ports=[STRING]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Current IRF member ID of the device. $4: New IRF member ID of the device. $5: New IRF member priority of the device. $6: List of IRF physical interfaces bound to IRF-port 1. The value none indicates that no IRF physical interfaces were bound to IRF-port 1. $7: List of IRF physical interfaces bound to IRF-port 2. The value none indicates that no IRF physical interfaces were bound to IRF-port 2. |
Severity level |
5 |
Example |
VCF/5/VCF_IRF_START: Phase 2.0.2, Device 0000-0000-0000 started IRF configuration: current member ID=2, new member ID=1, priority=2, IRF-port 1's member ports=GigabitEthernet1/0/1, IRF-port 2's member ports=none. |
Explanation |
Started to deploy IRF configuration. |
VCF_LOOPBACK_START
Message text |
Phase [STRING], IP address assignment started for [STRING] on other nodes. |
Variable fields |
$1: Phase. $2: Interface name. |
Severity level |
5 |
Example |
VCF/5/VCF_LOOPBACK_START: Phase 3.0.1, IP address assignment started for Loopback0 on other nodes. |
Explanation |
The master spine node started to assign IP addresses to interfaces on other devices. |
VCF_LOOPBACK_START_FAILED
Message text |
Phase [STRING], failed to assign IP addresses to [STRING] on other nodes: reason=[STRING]. |
Variable fields |
$1: Phase. $2: Interface name. $3: Reason for failure to start IP address assignment: ¡ -1—No IP address range is specified. ¡ -2—Invalid IP addresses. |
Severity level |
5 |
Example |
VCF/5/VCF_LOOPBACK_START_FAILED: Phase 3.0.1, failed to assign IP addresses to Loopback0 on other nodes: reason=-1. |
Explanation |
The master spine node failed to assign IP addresses to interfaces on other devices due to one of the following reasons: · No IP address range is specified. · Invalid IP addresses. |
Verify that whether the IP address range in the template file is correct. |
VCF_LOOPBACK_ALLOC
Message text |
Phase [STRING], assigned IP [STRING] to [STRING] on Device [STRING]: result=[INT32]. |
Variable fields |
$1: Phase. $2: IP address. $3: Interface name. $4: MAC address of the device. $5: Result of IP address assignment: ¡ 0—Success. ¡ -1—NETCONF failed to implement IP address assignment. ¡ -2—NETCONF processed IP address assignment incorrectly. ¡ -3—NETCONF failed to initialize. |
Severity level |
5 |
Example |
VCF/5/VCF_LOOPBACK_ALLOC: Phase 3.0.2, assigned IP 10.100.1.1 to Loopback0 on Device 0000-0000-0000: result=0. |
Explanation |
The master spine node assigned an IP address to an interface on a device. |
Troubleshoot the reasons for the IP address assignment failure according to the result. |
VCF_LOOPBACK_NO_FREE_IP
Message text |
Phase [STRING], no IP addresses available for Device [STRING]. |
Variable fields |
Severity level |
4 |
Example |
VCF/4/VCF_LOOPBACK_NO_FREE_IP: Phase 3.0.4, no IP addresses available for Device 0000-0000-0000. |
Explanation |
The master spine node failed to assign an IP address to an interface on a device because no IP address was available. |
Verify whether the specified IP address range in the template file is correct. |
VCF_LOOPBACK_RECLAIM
Message text |
Phase [STRING], reclaimed IP [STRING] from [STRING] on Device [STRING]: reason=[INT32]. |
Variable fields |
$1: Phase. $2: Reclaimed IP address. $3: Interface name. $4: MAC address of the device from which the IP address was reclaimed. $5: Reason for reclaiming the IP address. The value 1 indicates that the device was down. |
Severity level |
5 |
Example |
VCF/5/VCF_LOOPBACK_RECLAIM: Phase 3.0.3, reclaimed IP 10.10.10.1 from Loopback0 on Device 0000-0000-0000: reason=1. |
Explanation |
The master spine node reclaimed the IP address that had been assigned to an interface on a device. |
Recommended action |
VCF_REBOOT
Message text |
Phase [STRING], Device [STRING] will reboot. Reason: [STRING]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Reboot cause: ¡ Hardware resource mode change. ¡ Version upgrade success. ¡ IRF member ID change. ¡ IRF fabric setup success. ¡ Change of the maximum number of ECMP routes. ¡ Standalone-to-IRF mode switchover. |
Severity level |
5 |
Example |
VCF/5/VCF_REBOOT: Phase 1.2.3, Device 00e0-fc20-6304 will reboot. Reason: IRF member ID change. |
Explanation |
The device was about to reboot because of software update, IRF member ID change, or other reason. |
VCF_SKIP_INSTALL
Message text |
Phase [STRING], Device [STRING] skipped automatic version update. |
Variable fields |
Severity level |
5 |
Example |
VCF/5/VCF_SKIP_INSTALL: Phase 1.3.2, Device 0000-0000-0000 skipped automatic version update. |
Explanation |
Skipped software upgrade because the current startup image version is the same as the startup image version obtained from the template file. |
VCF_STATIC_CMD_ERROR
Message text |
Phase [STRING], Device [STRING] failed to automatically execute static command '[STRING]' in context '[STRING]'. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Command that fail to be executed. $4: Context in which the command resides. |
Severity level |
4 |
Example |
VCF/4/VCF_STATIC_CMD_ERROR: Phase 1.2.5, Device 0000-0000-0000 failed to automatically execute static command 'port link bridge' in context 'interface ten-gigabitethernet1/0/1; port link bridge'. |
Explanation |
Failed to execute a static command during automated deployment. |
Troubleshoot the reasons for the failure, correct the errors, and then restart the automated deployment. |
VCF_UP_LINK
Message text |
Phase [STRING], Device [STRING] discovered uplink interface [STRING]. |
Variable fields |
$1: Phase. $2: MAC address of the device. $3: Name of an uplink interface. |
Severity level |
6 |
Example |
VCF/6/VCF_UP_LINK: Phase 2.0.9, Device 0000-0000-0000 discovered uplink interface Ten-GigabitEthernet1/0/1. |
Explanation |
An uplink interface was found and the device deployed configuration to the uplink interface. An uplink interface is the interface through which a leaf node connects to an upstream spine node. |
VCF_WHITE_LIST_CHECK
Message text |
Phase [STRING], Device [STRING] failed whitelist check and automated undelay network deployment stopped. |
Variable fields |
Severity level |
5 |
Example |
VCF/5/VCF_WHITE_LIST_CHECK: Phase 1.0.1, Device 00e0-fc20-6304 failed whitelist check and automated undelay network deployment stopped. |
Explanation |
The device failed whitelist check, which caused automated undelay network deployment to stop. |
VLAN messages
This section contains VLAN messages.
VLAN_CREATEFAIL
Message text |
Failed to create VLAN [STRING]. The maximum number of VLANs has been reached. |
Variable fields |
$1: VLAN ID. |
Severity level |
4 |
Example |
VLAN/4/ VLAN_CREATEFAIL: Failed to create VLAN 1025-4094. The maximum number of VLANs has been reached. |
Explanation |
A VLAN failed to be created because hardware resources were insufficient. |
VLAN_FAILED
Message text |
Failed to add interface [STRING] to the default VLAN. |
Variable fields |
Severity level |
4 |
Example |
VLAN/4/VLAN_FAILED: Failed to add interface S-Channel4/2/0/19:100 to the default VLAN. |
Explanation |
An S-channel interface was created when hardware resources were insufficient. The S-channel interface failed to be assigned to the default VLAN. |
VLAN_QINQETHTYPE_FAILED
Message text |
Failed to set the TPID value in CVLAN tags to [UINT32] (hexadecimal). The operation is not supported. |
Variable fields |
$1: TPID value in inner VLAN tags |
Severity level |
4 |
Example |
VLAN/5/VLAN_QINQETHTYPE_FAILED: Failed to set the TPID value in CVLAN tags to 8200 (hexadecimal). The operation is not supported. |
Explanation |
In IRF 3.1 system, this message was printed to prompt that the configuration failed when the qinq ethernet-type customer-tag command was executed on a parent fabric if the following conditions existed: · The parent fabric supported setting the TPID value in inner VLAN tags. · PEXs did not support setting the TPID value in inner VLAN tags. |
Identify whether PEXs support setting the TPID value in inner VLAN tags. |
VLAN_VLANMAPPING_FAILED
Message text |
The configuration failed because of resource insufficiency or conflicts on [STRING]. |
Variable fields |
Severity level |
4 |
Example |
VLAN/4/VLAN_VLANMAPPING_FAILED: The configuration failed because of resource insufficiency or conflicts on Ethernet0/0. |
Explanation |
Part of or all VLAN mapping configurations on the interface were lost because of one of the following occurrences: · Hardware resources were insufficient for the interface. · The interface joined or left a Layer 2 aggregation group. |
VLAN_VLANTRANSPARENT_FAILED
Message text |
Variable fields |
Severity level |
4 |
Example |
VLAN/4/VLAN_VLANTRANSPARENT_FAILED: The configuration failed because of resource insufficiency or conflicts on Ethernet0/0. |
Explanation |
Part of or all VLAN transparent transmission configurations on the interface were lost because of one of the following occurrences: · Hardware resources were insufficient for the interface. · The interface joined or left a Layer 2 aggregation group. |
VRRP messages
This section contains VRRP messages.
VRRP_STATUS_CHANGE
Message text |
The status of [STRING] virtual router [UINT32] (configured on [STRING]) changed from [STRING] to [STRING]: [STRING]. |
Variable fields |
$1: VRRP version. $2: VRRP group number. $3: Name of the interface where the VRRP group is configured. $4: Original status. $5: Current status. $6: Reason for status change: · Interface event received—An interface event was received. · IP address deleted—The virtual IP address has been deleted. · The status of the tracked object changed—The status of the associated track entry changed. · VRRP packet received—A VRRP advertisement was received. · Current device has changed to IP address owner—The current device has become the IP address owner. · Zero priority packet received—A VRRP packet containing priority 0 was received. · Preempt—Preemption occurred. · Master group drove—The state of the master group changed. |
Severity level |
6 |
Example |
VRRP/6/VRRP_STATUS_CHANGE: The status of IPv4 virtual router 10 (configured on Ethernet0/0) changed (from Backup to Master): Master-down-timer expired. |
Explanation |
The VRRP group status changed because of the following reasons: · An interface event was received. · The virtual IP address has been deleted. · The status of the associated track entry changed. · A VRRP advertisement was received. · The current device has become the IP address owner. · The master down timer (3 × VRRP advertisement interval + Skew_Time) expired. · A VRRP packet containing priority 0 was received. · Preemption occurred. · The state of the master group changed. |
Check the VRRP group status to make sure it is operating correctly. |
VRRP_VF_STATUS_CHANGE
Message text |
The [STRING] virtual router [UINT32] (configured on [STRING]) virtual forwarder [UINT32] detected status change (from [STRING] to [STRING]): [STRING]. |
Variable fields |
$1: VRRP version. $2: VRRP group number. $3: Name of the interface where the VRRP group is configured. $4: VF ID. $5: Original status of VF. $6: Current status of VF. $7: Reason for the status change. |
Severity level |
6 |
Example |
VRRP/6/VRRP_VF_STATUS_CHANGE: The IPv4 virtual router 10 (configured on GigabitEthernet5/1) virtual forwarder 2 detected status change (from Active to Initialize): Weight changed. |
Explanation |
The status of the virtual forwarder has changed because the weight changed, the timeout timer expired, or VRRP went down. |
Check the status of the track entry. |
VRRP_VMAC_INEFFECTIVE
Message text |
The [STRING] virtual router [UINT32] (configured on [STRING]) failed to add virtual MAC: [STRING]. |
Variable fields |
$1: VRRP version. $2: VRRP group number. $3: Name of the interface where the VRRP group is configured. $4: Reason for the error. |
Severity level |
3 |
Example |
VRRP/3/VRRP_VMAC_INEFFECTIVE: The IPv4 virtual router 10 (configured on Ethernet0/0) failed to add virtual MAC: Insufficient hardware resources. |
Explanation |
The virtual router failed to add a virtual MAC address. |
Find out the root cause for the operation failure and fix the problem. |
VSRP messages
This section contains VSRP messages.
VSRP_BIND_FAILED
Message text |
Failed to bind the IP addresses and the port on VSRP peer [STRING]. |
Variable fields |
$1: VSRP peer name. |
Severity level |
6 |
Example |
VSRP/6/VSRP_BIND_FAILED: Failed to bind the IP addresses and the port on VSRP peer aaa. |
Explanation |
Failed to bind the IP addresses and the port when creating a TCP connection to the VSRP peer because the TCP port is in use. |
VXLAN messages
This section contains VXLAN messages.
VXLAN_LICENSE_UNAVAILABLE
Message text |
The VXLAN feature is disabled, because no licenses are valid. |
Variable fields |
N/A |
Severity level |
3 |
Example |
VXLAN/3/VXLAN_LICENSE_UNAVAILABLE: The VXLAN feature is disabled, because no licenses are valid. |
Explanation |
VXLAN was disabled because no licenses were valid. |
Install valid licenses for VXLAN. |
WEB messages
This section contains WEB messages.
LOGIN
Message text |
[STRING] logged in from [STRING]. |
Variable fields |
$1: Username. $2: IP address of the user. |
Severity level |
5 |
Example |
WEB/5/LOGIN: admin logged in from 127.0.0.1. |
Explanation |
A user logged in successfully. |
LOGIN_FAILED
Message text |
[STRING] failed to log in from [STRING]. |
Variable fields |
Severity level |
5 |
Example |
WEB/5/LOGIN_FAILED: admin failed to log in from 127.0.0.1. |
Explanation |
A user failed to log in. |
LOGOUT
Message text |
[STRING] logged out from [STRING]. |
Variable fields |
Severity level |
5 |
Example |
WEB/5/LOGOUT: admin logged out from 127.0.0.1. |
Explanation |
A user logged out. |
WIPS messages
This section contains WIPS messages.
APFLOOD
Message text |
-VSD=[STRING]; AP flood detected. |
Variable fields |
$1: VSD name. |
Severity level |
5 |
Example |
WIPS/5/APFLOOD: -VSD=home; AP flood detected. |
Explanation |
The number of APs detected in the specified VSD reached the threshold. |
Determine whether the device has suffered an attack. |
AP_CHANNEL_CHANGE
Message text |
-VSD=[STRING]-SrcMAC=[MAC]; Channel change detected. |
Variable fields |
$1: VSD name. $2: MAC address of the AP. |
Severity level |
5 |
Example |
WIPS/5/AP_CHANNEL_CHANGE: -VSD=home-SrcMAC=1122-3344-5566; Channel change detected. |
Explanation |
The channel of the specified AP changed. |
Determine whether the channel change is valid. |
ASSOCIATEOVERFLOW
Message text |
-VSD=[STRING]-SrcMAC=[MAC]; Association/Reassociation DoS attack detected. |
Variable fields |
Severity level |
5 |
Example |
WIPS/5/ASSOCIATEOVERFLOW: -VSD=home-SrcMAC=1122-3344-5566; Association/Reassociation DoS attack detected. |
Explanation |
The specified AP sent an association response with the status code 17. |
Determine whether the AP has suffered an attack. |
HONEYPOT
Message text |
-VSD=[STRING]-SrcMAC=[MAC]; Honeypot AP detected. |
Variable fields |
Severity level |
5 |
Example |
WIPS/5/HONEYPOT: -VSD=home-SrcMAC=1122-3344-5566; Honeypot AP detected. |
Explanation |
The specified AP was detected as a honeypot AP. |
HTGREENMODE
Message text |
-VSD=[STRING]-SrcMAC=[MAC]; HT-Greenfield AP detected. |
Variable fields |
Severity level |
5 |
Example |
WIPS/5/HTGREENMODE: -VSD=home-SrcMAC=1122-3344-5566; HT-Greenfield AP detected. |
Explanation |
The specified AP was detected as an HT-greenfield AP. |
MAN_IN_MIDDLE
Message text |
-VSD=[STRING]-SrcMAC=[MAC]; Man-in-the-middle attack detected. |
Variable fields |
$1: VSD name. $2: MAC address of the client. |
Severity level |
5 |
Example |
WIPS/5/MAN_IN_MIDDLE: -VSD=home-SrcMAC=1122-3344-5566; Man-in-the-middle attack detected. |
Explanation |
The specified client suffered a man-in-the-middle attack. |
Determine whether the client has suffered a man-in-the-middle attack. |
WIPS_DOS
Message text |
-VSD=[STRING]; [STRING] rate attack detected. |
Variable fields |
$1: VSD name. $2: Device type: AP or client. |
Severity level |
5 |
Example |
WIPS/5/WIPS_DOS: -VSD=home; AP rate attack detected. |
Explanation |
The number of device entries learned within the specified interval reached the threshold. |
WIPS_FLOOD
Message text |
-VSD=[STRING]-SrcMAC=[MAC]; [STRING] flood detected. |
Variable fields |
$1: VSD name. $2: Attacker's MAC address. $3: Flood attack type. Options include the following: · Association request · Authentication · Disassociation · Reassociation request · Deauthentication · Null data · Beacon · Probe request · BlockAck · CTS · RTS · EAPOL start |
Severity level |
5 |
Example |
WIPS/5/WIPS_FLOOD: -VSD=home-SrcMAC=1122-3344-5566; Association request flood detected. |
Explanation |
The number of a specific type of packets detected within the specified interval reached the threshold. |
Determine whether the packet sender is an authorized device. |
WIPS_MALF
Message text |
-VSD=[STRING]-SrcMAC=[MAC]; Error detected: [STRING]. |
Variable fields |
$1: VSD name. $2: Sender's MAC address. $3: Malformed packet type. Options include the following: · invalid ie length—Invalid IE length. · duplicated ie—Duplicate IE. · redundant ie—Redundant IE. · invalid pkt length—Invalid packet length. · illegal ibss ess—Abnormal IBSS and ESS setting. · invalid source addr—Invalid source MAC address. · overflow eapol key—Oversized EAPOL key. · malf auth—Malformed authentication request frame. · malf assoc req—Malformed association request frame. · malf ht ie—Malformed HT IE. · large duration—Oversized duration. · null probe resp—Malformed probe response frame. · invalid deauth code—Invalid deauthentication code. · invalid disassoc code—Invalid disassociation code. · over flow ssid—Oversized SSID. · fata jack—FATA-Jack. |
Severity level |
5 |
Example |
WIPS/5/WIPS_MALF: -VSD=home-SrcMAC=1122-3344-5566; Error detected: fata jack. |
Explanation |
A malformed packet was detected. |
WIPS_SPOOF
Message text |
-VSD=[STRING]-SrcMAC=[MAC]; [STRING] detected. |
Variable fields |
$1: VSD name. $2: MAC address of the device being spoofed. $3: Spoofing attack type. Options include the following: · AP spoofing AP—A fake AP spoofs an authorized AP. · AP spoofing client—A fake AP spoofs an authorized client. · AP spoofing ad-hoc—A fake AP spoofs an Ad hoc device. · Ad-hoc spoofing AP—An Ad hoc device spoofs an authorized AP. · Client spoofing AP—A client spoofs an authorized AP. |
Severity level |
5 |
Example |
WIPS/5/WIPS_SPOOF: -VSD=home-SrcMAC=1122-3344-5566; AP spoofing AP detected. |
Explanation |
A spoofing attack was detected. |
WIPS_WEAKIV
Message text |
-VSD=[STRING]-SrcMAC=[MAC]; Weak IV detected. |
Variable fields |
$1: VSD name. $2: Sender's MAC address. |
Severity level |
5 |
Example |
WIPS/5/WIPS_WEAKIV: -VSD=home-SrcMAC=1122-3344-5566; Weak IV detected. |
Explanation |
A weak IV was detected. |
Use a more secure encryption method to encrypt packets. |
WIRELESSBRIDGE
Message text |
-VSD=[STRING]-AP1=[MAC]-AP2=[MAC]]; Wireless bridge detected. |
Variable fields |
$1: VSD name. $2: MAC address of AP 1. $3: MAC address of AP 2. |
Severity level |
5 |
Example |
WIPS/5/WIRELESSBRIDGE: -VSD=home-AP1=1122-3344-5566-AP2=7788-9966-5544; Wireless bridge detected. |
Explanation |
The specified APs set up a wireless bridge. |
Determine whether the wireless bridge is valid. |
