LSUM2QGS24RSG0 Card Manual-6PW104
HomeSupportSwitchesH3C S10500 Switch SeriesInstall & UpgradeService Module Card ManualsLSUM2QGS24RSG0 Card Manual-6PW104
Download Book
Title Size Downloads
LSUM2QGS24RSG0 Card Manual-6PW104-book.pdf 16.51 KB
Table of Contents
Related Documents
LSUM2QGS24RSG0 24-port 40GBASE-R-QSFP+ optical Ethernet interface card
1  Card identifier
The card identifier LSUM2QGS24RSG0 is in the upper right corner of the front panel.
2  Specifications
Table 1 Card specifications
Item
Specifications
Dimensions (H × W × D)
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in)
SDRAM (DDR3)
2 GB
Power consumption
65 W to 198 W
Ports
24 × 40GBASE-R-QSFP+ fiber ports
Port speed
40Gbps
·      To verify the compatibility of the card with the software release you are using, see the release notes.
·      For information about transceiver modules and cables available for the card, see the cards and transceiver modules compatibility matrixes for the device.
3  Related documentation
For information about card installation, see the installation guide for the device.
For software upgrade, see the release notes for the device.
Copyright © 2016-2019 New H3C Technologies Co., Ltd.
  • Become a Partner
  • Partner Resources
