LSUM2GP44TSSE0 Card Manual-6PW104
HomeSupportSwitchesH3C S10500 Switch SeriesInstall & UpgradeService Module Card ManualsLSUM2GP44TSSE0 Card Manual-6PW104
Download Book
Title Size Downloads
LSUM2GP44TSSE0 Card Manual-6PW104-book.pdf 17.30 KB
Table of Contents
Related Documents
44-port 1000BASE-X-SFP + 4-port 10GBASE-R-SFP+ optical Ethernet interface card—LSUM2GP44TSSE0
1  Card identifier
The card identifier LSUM2GP44TSSE0 is at the upper right corner of the front panel.
2  Specifications
Table 1 Card specifications
Item
Specifications
Card size (H × W × D)
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in)
SDRAM (DDR3)
1GB
Power consumption
39 W to 70 W
Ports
·         44 x 1000BASE-X-SFP fiber ports
·         4 x 10GBASE-R-SFP+ fiber ports
Port rate
·         1000 Mbps
·         10 Gbps
·      To verify the compatibility of the card with the software release you are using, see the release notes.
·      For information about transceiver modules and cables available for the card, see the cards and transceiver modules compatibility matrixes for the device.
IMPORTANT
IMPORTANT:
For the card to operate correctly, make sure a switching fabric module is installed in one of the two lowest numbered switching fabric module slots on the S10504, S10508, S10508-V, and S10512.
3  Related documentation
For information about card installation, see the installation guide for the device.
For software upgrade, see the release notes for the device.
Copyright © 2014-2019 New H3C Technologies Co., Ltd.
  • Become a Partner
  • Partner Resources
