Title | Size | Downloads |
LSUM2CQGS12SG0 Card Manual-6PW104-book.pdf | 17.28 KB |
LSUM2CQGS12SG0 12-port 40GBASE-R-QSFP+/4-port 100GBASE-R-QSFP28 optical Ethernet interface card
1 Card identifier
The card identifier LSUM2CQGS12SG0 is in the upper right corner of the front panel.
2 Specifications
IMPORTANT: After you change 40-GE interfaces to 100-GE interfaces, only ports 1, 4, 7, and 10 are available. |
Table 1 Card specifications
Item |
Specification |
Dimensions (H × W × D) |
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in) |
SDRAM (DDR3) |
2 GB |
Power consumption |
55W to 147W |
Interfaces |
12 × 40GGBASE-R-QSFP+ fiber port or 4 × 100GBASE-R-QSFP28 fiber port |
Transmission rate |
40GGBASE-R-QSFP+ fiber port: 40 Gbps 100GBASE-R-QSFP28 fiber port: 100 Gbps |
Net weight |
3.20 kg (7.05 lb) |
NOTE: · To verify the compatibility of the card with the software release you are using, see the release notes. · For information about transceiver modules and cables available for the card, see the cards and transceiver modules compatibility matrixes for the device. |
3 Related documentation
For module installation, see the installation guide for the device.
For software upgrade, see the release notes for the device.
Copyright © 2017-2019 New H3C Technologies Co., Ltd.
