LSUM1TGT24FD0 Card Manual-6PW101
HomeSupportSwitchesH3C S10500 Switch SeriesInstall & UpgradeService Module Card ManualsLSUM1TGT24FD0 Card Manual-6PW101
Download Book
Title Size Downloads
LSUM1TGT24FD0 Card Manual-6PW101-book.pdf 24.78 KB
Table of Contents
Related Documents
LSUM1TGT24FD0 10GE copper interface module
1  Identifier
The module identifier LSUM1TGT24FD0 is in the upper right corner of the front panel.
2  Specifications
Table 1 Module specifications
Item
Specifications
Dimensions (H × W × D)
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in)
SDRAM (DDR4)
2 GB
Power consumption
60 W to 112 W
Connector type
RJ-45
Ports
24
Port rate
·         100 Mbps
·         1000 Mbps
·         2.5 Gbps
·         5 Gbps
·         10 Gbps
Available cables
·         100M/1000M/2.5G copper port: Category 5e or higher twisted pair cables
·         5G copper port: Category 6 or higher twisted pair cables
·         10G copper port: Category 6a or higher twisted pair cables
Transmission medium and max transmission distance
100 m (328.08 ft)
To verify the compatibility of the card with the software release you are using, see the release notes.
The 100M/1000M/2.5G/5G/10G copper port uses an RJ-45 connector.
Figure 1 RJ-45 connector
Table 2 RJ-45 connector pin assignment
Pin
10G/5G/2.5G/1000/100BASE-T
Signal
Function
1
MX_0+
Transmits and receives data
2
MX_0-
3
MX_1+
4
MX_2+
5
MX_2-
6
MX_1-
7
MX_3+
8
MX_3-
3  Related documentation
For module installation, see the installation guide for the device.
For software upgrade, see the release notes for the device.
Copyright © 2018-2019 New H3C Technologies Co., Ltd.
  • Become a Partner
  • Partner Resources
