Title | Size | Downloads |
LSUM1QGS6EC0 Card Manual-6PW107-book.pdf | 16.98 KB |
6-port 40GBASE-R-QSFP+ optical Ethernet interface card– LSUM1QGS6EC0
1 Card identifier
The card identifier LSUM1QGS6EC0 is in the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specifications |
Card size (H × W × D) |
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in) |
SDRAM (DDR3) |
4GB |
Power consumption |
142 W to 183 W |
Ports |
6 x 40GBASE-R-QSFP+ fiber ports |
Port speed |
40Gbps |
NOTE: · To verify the compatibility of the card with the software release you are using, see the release notes. · For information about transceiver modules and cables available for the card, see the cards and transceiver modules compatibility matrixes for the device. |
3 Related documentation
For module installation, see the installation guide for the device.
For software upgrade, see the release notes for the device.
Copyright © 2014-2019 New H3C Technologies Co., Ltd.
