- Released At: 03-12-2020
- Page Views:
- Downloads:
H3C LSWM18CQ interface
card
user manual-6PW108
▌About the LSWM18CQ interface card
Important information
The LSWM18CQ interface card is applicable to multiple H3C switch models. For the interface card compatibility with switches, contact H3C Support or marketing staff.
Front panel
The LSWM18CQ interface card provides eight QSFP28 ports.
Figure 1 Front panel
(1) QSFP28 port LED |
(2) QSFP28 port |
▌Ports
· As a best practice, use H3C transceiver modules and cables for the interface cards.
· The transceiver module and cable types supported by the LSWM18CQ interface card vary by device model. For more information, see the installation guide or hardware reference for the device, or contact H3C Support or marketing staff.
· The restrictions and guidelines for using the LSWM18CQ interface card vary by device model. For more information, see the installation guide or hardware reference for the device.
· For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide at www.h3c.com.
QSFP28 ports
You can install the following transceiver modules and cables in the QSFP28 ports on the card:
· QSFP28 transceiver modules described in Table 1 and Table 2
· QSFP28 cables in Table 3
· QSFP28 to SFP28 cables in Table 4
· QSFP+ transceiver modules in Table 5 and Table 6
· QSFP+ cables in Table 7
· QSFP+ to SFP+ cables in Table 8
Table 1 QSFP28 transceiver modules available for the QSFP28 ports (1)
QSFP28 transceiver module |
Central wavelength (nm) |
Connector |
QSFP-100G-ER4L-WDM1300 |
Four lanes: · 1294.53 to 1296.59 · 1299.02 to 1301.09 · 1303.54 to 1305.63 · 1308.09 to 1310.19 |
LC |
QSFP-100G-SR4-MM850 |
850 |
MPO (PC polished, 12-fiber) |
QSFP-100G-PSM4-SM1310 |
1295 to 1325 |
MPO (APC polished, 12-fiber) |
QSFP-100G-LR4-WDM1300 |
Four lanes: · 1295 · 1300 · 1304 · 1309 |
LC |
QSFP-100G-LR4L-WDM1300 |
Four lanes: · 1264.5 to 1277.5 · 1284.5 to 1297.5 · 1304.5 to 1317.5 · 1324.5 to 1337.5 |
LC |
QSFP-100G-SWDM4-MM850 |
Four lanes: · 850 · 880 · 910 · 940 |
LC |
Table 2 QSFP28 transceiver modules available for the QSFP28 ports (2)
QSFP+ transceiver module |
Cable/fiber diameter (µm) |
Modal bandwidth (MHz × km) |
Max transmission distance |
Single-mode, 9/125 |
N/A |
40 km (24.85 miles) |
Multi-mode, 50/125 |
2000 |
70 m (229.66 ft) |
4700 |
100 m (328.08 ft) |
N/A |
500 m (1640.42 ft) |
N/A |
10 km (6.21 miles) |
N/A |
2 km (1.24 miles) |
2000 |
75 m (246.06 ft) |
4700 |
100 m (328.08 ft) |
Table 3 QSFP28 cables available for the QSFP28 ports
Cable model |
Cable length |
Data rate |
QSFP28 copper cable |
QSFP-100G-D-CAB-1M |
1 m (3.28 ft) |
100 Gbps |
QSFP-100G-D-CAB-3M |
3 m (9.84 ft) |
QSFP-100G-D-CAB-5M |
5 m (16.40 ft) |
QSFP28 fiber cable |
QSFP-100G-D-AOC-7M |
7 m (22.97 ft) |
100 Gbps |
QSFP-100G-D-AOC-10M |
10 m (32.81 ft) |
QSFP-100G-D-AOC-20M |
20 m (65.62 ft) |
Table 4 QSFP28 to SFP28 cables available for the QSFP28 ports
QSFP28 to SFP28 cable |
Cable length |
Data rate |
QSFP-100G-4SFP-25G-CAB-1M |
1 m (3.28 ft) |
100 Gbps |
QSFP-100G-4SFP-25G-CAB-3M |
3 m (9.84 ft) |
Table 5 QSFP+ transceiver modules available for the QSFP28 ports (1)
Connector |
QSFP-40G-SR4-MM850 |
850 |
QSFP-40G-CSR4-MM850 |
850 |
QSFP-40G-LR4-PSM1310 |
1310 |
QSFP-40G-BIDI-SR-MM850 |
850 |
LC |
QSFP-40G-LR4-WDM1300 |
Four lanes: · 1271 · 1291 · 1311 · 1331 |
LC |
QSFP-40G-LR4L-WDM1300 |
LC |
Table 6 QSFP+ transceiver modules available for the QSFP28 ports (2)
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.12 ft) |
2000 |
300 m (984.25 ft) |
4700 |
400 m (1312.33 ft) |
N/A |
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.12 ft) |
N/A |
N/A |
2 km (1.24 miles) |
Table 7 QSFP+ cables available for the QSFP28 ports
QSFP+ cable |
Cable length |
Data rate |
QSFP+ copper cable |
LSWM1QSTK0 |
1 m (3.28 ft) |
40 Gbps |
LSWM1QSTK1 |
3 m (9.84 ft) |
LSWM1QSTK2 |
5 m (16.40 ft) |
QSFP+ fiber cable |
QSFP-40G-D-AOC-7M |
7 m (22.97 ft) |
40 Gbps |
QSFP-40G-D-AOC-10M |
10 m (32.81 ft) |
QSFP-40G-D-AOC-20M |
20 m (65.62 ft) |
Table 8 QSFP+ to SFP+ cables available for the QSFP28 ports
QSFP+ to SFP+ cable |
Cable length |
Data rate |
LSWM1QSTK3 |
1 m (3.28 ft) |
40 Gbps |
LSWM1QSTK4 |
3 m (9.84 ft) |
LSWM1QSTK5 |
5 m (16.40 ft) |
▌LEDs
The indications of the LEDs on the LSWM18CQ interface card vary by device model. For more information, see the installation guide or hardware reference for the device.
QSFP28 port LEDs
Table 9 describes QSFP28 port LEDs on the front panel.
Table 9 QSFP28 port LED description
LED status |
Steady green |
A transceiver module is installed in the port. The port is operating at 100 Gbps, and a link is present on the port. |
Flashing green |
The port is sending or receiving data at 100 Gbps. |
Steady yellow |
A transceiver module is installed in the port. The port is operating at 10/25/40 Gbps, and a link is present on the port. |
Flashing yellow (3 Hz) |
The port is sending or receiving data at 10/25/40 Gbps. |
Off |
No transceiver module is installed in the port, or no link is present on the port. |
▌Installing and removing the card
CAUTION: · Before you install or remove the card, wear an ESD wrist strap and make sure the strap makes good skin contact and is reliably grounded. · To avoid device damage, do not use excessive force when you install or remove the card. · The LSWM18CQ interface card is hot swappable. However, do not install or remove it during the startup of the switch. |
Installing the card
1. Remove the filler panel (if any) from the target slot.
Keep the removed filler panel secure for future use.
2. Unpack the interface card.
Figure 2 LSWM18CQ interface card
(1) Ejector lever |
(2) Latch |
3. Press the latch on the card to release the ejector lever.
4. As shown by callout 1 in Figure 3, insert the card slowly into the slot along the guide rails.
5. Rotate inward the ejector lever as shown by callout 2 in Figure 3 until the latch locks the ejector lever in place.
Figure 3 Installing an LSWM18CQ interface card
Removing the card
1. Prepare an anti-static bag.
2. Remove the cables from the card.
3. Press the latch to release the ejector lever
4. Rotate outward the ejector lever as shown by callout 1 in Figure 4.
5. Pull out the interface card slowly out of the interface card slot, as shown by callout 2 in Figure 4.
6. Place the removed interface card in the anti-static bag.
7. If you are not to install a new card, install a filler panel in the slot to prevent dust and ensure good ventilation in the device.
Figure 4 Removing an LSWM18CQ interface card
Installing and removing QSFP28/QSFP+ transceiver modules and cables
For information about installing and removing QSFP28 transceiver modules, QSFP28 cables, QSFP28 to SFP28 cables, QSFP+ transceiver modules, QSFP+ cables, and QSFP+ to SFP+ cables, see H3C Transceiver Modules and Network Cables Installation Guide at www.h3c.com.
Verifying the installation
After the installation is complete, determine whether the interface card is operating correctly.
If the card fails to operate correctly, perform the following steps:
1. Reinstall the card following the installation procedures described in this document.
2. If the problem persists, contact H3C Support.
▌Technical support
New H3C Technologies Co., Ltd. provides customers with comprehensive technical support and service. If you purchase the products from the sales agent of New H3C Technologies Co., Ltd., please contact our sales agent or technical personnel.
Website: http://www.h3c.com
BOM: 3101A0KH
