H3C S6800 & S6860 Switch Series Command References-Release 671x-6W100-book_CHM.rar(10.49 MB)
H3C S6800 & S6860 Switch Series Command References-Release 671x-6W100-book.pdf(28.55 MB)
- Released At: 29-08-2023
- Page Views:
- Downloads:
About the H3C S6800 & S6860 command references
These command references are applicable to the following product models:
· S6800-32Q(LS-6800-32Q-H1).
· S6800-54QF(LS-6800-54QF-H3).
· S6800-54QF(LS-6800-54QF-H5).
· S6800-54QT(LS-6800-54QT-H3).
· S6800-2C(LS-6800-2C-H1).
· S6800-4C(LS-6800-4C-H1).
· S6860-54HF(LS-6860-54HF).
· S6860-30HF(LS-6860-30HF).
· S6860-54HT(LS-6860-54HT).
Command reference |
Content |
Fundamentals Command Reference |
Covers the commands for logging in to and setting up the device. This command reference includes: · CLI (command privilege settings and CLI management commands). · RBAC. · Logging in to the switch. · FTP and TFTP. · File system management. · Configuration file management. · Software upgrade. · ISSU. · GIR. · Emergency shell. · Preprovisioning. · Device management. · Tcl. · Python. · License management. |
Virtual Technologies Command Reference |
Covers the commands for configuring an IRF fabric. |
Layer 2—LAN Switching Command Reference |
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes: · MAC address table and MAC Information. · Bulk interface configuration. · Ethernet interface. · Ethernet link aggregation. · M-LAG. · Port isolation. · VLAN (including VLAN, super VLAN, private VLAN, and voice VLAN). · MVRP. · Loopback, null, and inloopback interfaces. · QinQ. · VLAN mapping. · PBB. · Spanning tree. · Loop detection. · LLDP. · L2PT. · Service loopback group. · Layer 2 forwarding. |
Layer 3—IP Services Command Reference |
Covers the commands for configuring and managing IP addressing (including static and dynamic IPv4 and IPv6 address assignment), network performance optimization, ARP, and interoperation between IPv4 and IPv6. This command reference includes: · ARP (including ARP, gratuitous ARP, proxy ARP, ARP snooping, ARP fast reply, and ARP direct route advertisement). · DNS and DDNS. · Basic IP forwarding and load sharing. · Fast forwarding. · Adjacency table. · IRDP. · IP performance optimization. · IPv6 fast forwarding. · HTTP redirect. |
Layer 3—IP Routing Command Reference |
Covers the commands for configuring routes for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy based routing. This command reference includes: · Basic IP routing. · Static routing. · RIP. · OSPF. · IS-IS. · BGP. · Policy-based routing. · IPv6 static routing. · RIPng. · OSPFv3. · IPv6 policy-based routing. · Routing policy. · DCN. |
IP Multicast Command Reference |
Covers the commands for Layer 2 and Layer 3 multicast protocols. This command reference includes: · IGMP snooping. · PIM snooping. · Multicast VLAN. · Multicast routing and forwarding. · IGMP. · PIM. · MSDP. · Multicast VPN. · MLD snooping. · IPv6 multicast routing and forwarding. · MLD. · IPv6 PIM. |
MPLS Command Reference |
Covers the MPLS commands. This command reference includes: · Basic MPLS. · SR-MPLS. · Static LSP. · LDP. · MPLS TE. · Static CRLSP. · RSVP. · Tunnel policy. · MPLS L3VPN and IPv6 MPLS L3VPN. · MPLS L2VPN. · VPLS. · MPLS OAM. · MCE and IPv6 MCE. |
ACL and QoS Command Reference |
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes: · ACL. · QoS (including QoS policy, priority mapping, GTS and rate limit, congestion management, congestion avoidance, and global CAR). · Data buffer. · QCN. |
Security Command Reference |
Covers security feature commands. Available security features include identity authentication (AAA and PKI), access security (802.1X, MAC authentication, portal, and port security), secure management (public key management, SSH, SSL, and IPsec), and attack protection (IP source guard, ARP attack protection, uRPF, attack detection and prevention, and ND attack defense). This command reference includes: · AAA. · 802.1X. · MAC authentication. · Portal. · Web authentication. · Port security. · User profile. · Password control. · Keychain. · PKI. · SSH. · SSL. · Object group. · Attack detection and prevention. · TCP attack prevention. · IP source guard. · ARP attack protection. · ND attack defense. · uRPF. · SAVI · SAVA · Crypto engine. · FIPS. · MACsec. · Microsegmentation. |
High Availability Command Reference |
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes: · Ethernet OAM. · CFD. · DLDP. · RRPP. · ERPS. · Smart Link. · Monitor Link. · VRRP. · BFD. · Track. |
Network Management and Monitoring Command Reference |
Covers the commands that help you manage and monitor your network, for example, manage system events, collect traffic statistics, sample packets, assess network performance, and test network connectivity. This command reference includes: · System maintenance and debugging (ping, tracert, and system debugging). · NQA. · PTP. · Event MIB. · NETCONF. · CWMP. · EAA. · Process monitoring and maintenance. · Mirroring (including both port and traffic mirroring). · Information center. · Packet capture. · VCF fabric. · Performance management. |
FC and FCoE Command Reference |
Covers the commands for configuring FC and FCoE. |
Telemetry Command Reference |
Covers the commands for configuring gRPC. |
TRILL Command Reference |
Covers the commands for configuring TRILL. |
SPB Command Reference |
Covers the commands for configuring SPBM. |
EVB Command Reference |
Covers the commands for configuring EVB. |
OpenFlow Command Reference |
Covers the commands for configuring OpenFlow. |
VXLAN Command Reference |
Covers the commands for configuring VXLAN. |
EVPN Command Reference |
Covers the commands for configuring EVPN. |
Intelligent Lossless Network Command Reference |
Covers the commands for configuring PFC. |
