06-三层技术-IP路由命令参考
10-OSPFv3命令
本章节下载 10-OSPFv3命令  (460.28 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/CR/CR19000/Command/Command_Manual/H3C_CR19000_CR-R1218-5W100/06/201909/1226066_30005_0.htm
10-OSPFv3命令
  录
1 OSPFv3
1.1 OSPFv3配置命令
1.1.1 abr-summary (OSPFv3 area view)
1.1.2 area
1.1.3 asbr-summary (OSPFv3 view)
1.1.4 authentication-mode
1.1.5 bandwidth-reference (OSPFv3 view)
1.1.6 default tag
1.1.7 default-cost (OSPFv3 area view)
1.1.8 default-route-advertise (OSPFv3 view)
1.1.9 display ospfv3
1.1.10 display ospfv3 abr-asbr
1.1.11 display ospfv3 abr-summary
1.1.12 display ospfv3 asbr-summary
1.1.13 display ospfv3 event-log
1.1.14 display ospfv3 global-statistics
1.1.15 display ospfv3 graceful-restart
1.1.16 display ospfv3 interface
1.1.17 display ospfv3 lsdb
1.1.18 display ospfv3 nexthop
1.1.19 display ospfv3 non-stop-routing
1.1.20 display ospfv3 peer
1.1.21 display ospfv3 request-queue
1.1.22 display ospfv3 retrans-queue
1.1.23 display ospfv3 routing
1.1.24 display ospfv3 spf-tree
1.1.25 display ospfv3 statistics
1.1.26 display ospfv3 vlink
1.1.27 dscp
1.1.28 enable ipsec-profile
1.1.29 event-log
1.1.30 fast-reroute (OSPFv3 view)
1.1.31 filter (OSPFv3 area view)
1.1.32 filter-policy export (OSPFv3 view)
1.1.33 filter-policy import (OSPFv3 view)
1.1.34 graceful-restart enable
1.1.35 graceful-restart helper enable
1.1.36 graceful-restart helper strict-lsa-checking
1.1.37 graceful-restart interval
1.1.38 import-route (OSPFv3 view)
1.1.39 ispf enable
1.1.40 log-peer-change
1.1.41 lsa-generation-interval
1.1.42 maximum load-balancing (OSPFv3 view)
1.1.43 non-stop-routing
1.1.44 nssa (OSPFv3 area view)
1.1.45 ospfv3
1.1.46 ospfv3 area
1.1.47 ospfv3 authentication-mode
1.1.48 ospfv3 bfd enable
1.1.49 ospfv3 cost
1.1.50 ospfv3 dr-priority
1.1.51 ospfv3 fast-reroute lfa-backup exclude
1.1.52 ospfv3 ipsec-profile
1.1.53 ospfv3 mib-binding
1.1.54 ospfv3 mtu-ignore
1.1.55 ospfv3 network-type
1.1.56 ospfv3 peer
1.1.57 ospfv3 prefix-suppression
1.1.58 ospfv3 primary-path-detect bfd
1.1.59 ospfv3 timer dead
1.1.60 ospfv3 timer hello
1.1.61 ospfv3 timer poll
1.1.62 ospfv3 timer retransmit
1.1.63 ospfv3 trans-delay
1.1.64 pic
1.1.65 preference
1.1.66 prefix-suppression
1.1.67 reset ospfv3 event-log
1.1.68 reset ospfv3 process
1.1.69 reset ospfv3 redistribution
1.1.70 reset ospfv3 statistics
1.1.71 router-id
1.1.72 silent-interface (OSPFv3 view)
1.1.73 snmp context-name
1.1.74 snmp trap rate-limit
1.1.75 snmp-agent trap enable ospfv3
1.1.76 spf-schedule-interval
1.1.77 stub (OSPFv3 area view)
1.1.78 stub-router
1.1.79 transmit-pacing
1.1.80 vlink-peer (OSPFv3 area view)
1 OSPFv3
1.1  OSPFv3配置命令
abr-summary命令用来配置ABR路由聚合。
undo abr-summary命令用来取消ABR对指定网段的路由聚合。
abr-summary ipv6-address prefix-length [ not-advertise ] [ cost cost-value ]
undo abr-summary ipv6-address prefix-length
ABR不对路由进行聚合。
OSPFv3区域视图
ipv6-address:聚合路由的目的IPv6地址。
prefix-length:聚合路由的目的IPv6地址前缀长度,取值范围为0~128。它指定地址中有多少连续的位组成IPv6网络前缀,即IPv6地址中的网络地址部分。
not-advertise:不通告聚合的IPv6路由。如果未指定本参数,则通告聚合的IPv6路由。
cost cost-value:聚合路由的开销值,取值范围为1~16777215,缺省值为所有被聚合的路由中最大的开销值。
本命令只适用于ABR,用来对当前区域进行路由聚合。对于落入该聚合网段的路由,ABR向其它区域只发送一条聚合后的路由。一个区域可配置多条聚合网段,这样OSPFv3可对多个网段进行聚合。
当配置了undo abr-summary命令后,原来被聚合的路由将重新被发布。
# 将OSPFv3区域1中两条路由2000:1:1:1::/64、2000:1:1:2::/64的路由聚合成一条前缀2000:1:1::/48向其它区域发送。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 1
[Sysname-ospfv3-1-area-0.0.0.1] abr-summary 2000:1:1:: 48
1.1.2  area
area命令用来创建OSPFv3区域,并进入区域视图。
undo area命令用来删除指定的OSPFv3区域。
area area-id
undo area area-id
不存在OSPFv3区域。
OSPFv3视图
area-id:区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。
# 进入OSPFv3区域0视图。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 0
[Sysname-ospfv3-1-area-0.0.0.0]
asbr-summary命令用来配置ASBR路由聚合。
undo asbr-summary命令用来取消ASBR对指定网段的路由聚合。
asbr-summary ipv6-address prefix-length [ cost cost-value | not-advertise | nssa-only | tag tag ] *
undo asbr-summary ipv6-address prefix-length
ASBR不对引入的路由进行聚合。
OSPFv3视图
cost cost-value:聚合路由的开销,取值范围为1~16777214。如果未指定本参数,cost-value取所有被聚合的路由中最大的开销值作为聚合路由的开销;如果是Type-7 LSA转化成的Type-5 LSA描述的路由匹配聚合、且是Type2外部路由,则cost-value取所有被聚合的路由中最大的开销值加1作为聚合路由的开销。
not-advertise:不通告聚合路由。如果未指定本参数,将通告聚合路由。
nssa-only设置Type-7 LSA的P比特位为不置位,即在对端路由器上不能转为Type-5 LSA。缺省时,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
tag tag:聚合路由的标记,取值范围为0~4294967295。
如果本地路由器是ASBR,对引入的聚合地址范围内的Type-5 LSA描述的路由进行聚合;当配置了NSSA区域时,对引入的聚合地址范围内的Type-7 LSA描述的路由进行聚合。
如果本地路由器同时是ASBR和ABR,并且是NSSA区域的转换路由器,则对由Type-7 LSA转化成的Type-5 LSA描述的路由进行聚合处理;如果不是NSSA区域的转换路由器,则不进行聚合处理。
配置asbr-summary命令后,对处于聚合地址范围内的外部路由,本地路由器只向邻居路由器发布一条聚合后的路由;配置undo asbr-summary命令后,原来被聚合的外部路由将重新被发布。
# 配置OSPFv3进程1对引入的路由进行聚合,聚合路由为2000::/16,开销值为100,标记为2。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] asbr-summary 2000:: 16 cost 100 tag 2
authentication-mode命令用来设置OSPFv3区域使用的验证模式。
undo authentication-mode命令用来恢复缺省情况。
authentication-mode keychain keychain-name
未配置区域验证模式。
OSPFv3区域视图
keychain:使用keychain验证模式。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
接口视图下配置的验证模式,其优先级高于OSPFv3区域视图下配置的验证模式。
在OSPFv3区域使用keychain验证模式时,本区域的OSPFv3报文验证过程如下:
·     OSPFv3在发送报文前,会先从keychain获取当前的有效发送key,然后发送报文。如果当前不存在有效发送key,则不会发送报文。
·     OSPFv3在收到报文后,会根据报文携带的key的标识符从keychain中获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验,校验成功后再对报文进行下一步处理。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
对于keychain认证算法和key的标识符的范围,OSPFv3的支持情况如下:
·     OSPFv3仅支持HMAC-SHA-256认证算法。
·     OSPFv3仅支持标识符取值范围为0~65535的key。
# 配置OSPFv3区域1使用keychain验证模式,keychain名为test。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] authentication-mode keychain test
bandwidth-reference命令用来配置计算链路开销时所依据的带宽参考值。
bandwidth-reference value
计算链路开销时所依据的带宽参考值为100Mbps。
OSPFv3视图
value:计算链路开销时所依据的带宽参考值,取值范围为1~4294967,单位为Mbps。
OSPFv3有两种方式来配置接口的开销值,第一种方法是在接口视图下直接配置开销值;第二种方法是配置接口的带宽参考值,OSPFv3根据带宽参考值自动计算接口的开销值,计算公式为:接口开销=带宽参考值÷接口带宽,当计算出来的开销值大于65535,开销取最大值65535;当计算出来的开销值小于1时,开销取最小值1。
如果没有在接口视图下显式的配置此接口的开销值,OSPFv3会根据该接口的带宽自动计算其开销值.
# 配置计算链路开销时所依据的带宽参考值为1000Mbps。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] bandwidth-reference 1000
1.1.6  default tag
default tag命令用来配置引入外部路由的全局标记。
undo default tag命令用来恢复缺省情况。
default tag tag
undo default tag
引入外部路由的全局标记为1。
OSPFv3视图
tag:外部路由的全局标记,取值范围为0~4294967295。
如果在配置default-route-advertiseimport-routeroute-tag命令时没有指定标记,则缺省使用本命令配置的全局标记。
# 配置OSPFv3引入外部路由的标记为2。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] default tag 2
·     default-route-advertise (OSPFv3 view)
·     import-route
·     route-tag(MPLS命令参考/MPLS L3VPN)
default-cost命令用来配置发送到Stub区域或NSSA区域的缺省路由的开销。
undo default-cost命令用来恢复缺省情况。
default-cost cost
undo default-cost
发送到Stub区域或NSSA区域的缺省路由的开销为1。
OSPFv3区域视图
cost:发送到Stub区域或NSSA区域的缺省路由的开销,取值范围为0~16777214。
该命令只有在Stub区域的ABR或NSSA区域的ABR/ASBR上配置才能生效。
# 将OSPFv3区域1设置为Stub区域,使发送到该Stub区域的缺省路由开销为60。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] stub
[Sysname-ospfv3-1-area-0.0.0.1] default-cost 60
·     nssa (OSPFv3 area view)
·     stub (OSPFv3 area view)
default-route-advertise命令用来将缺省路由引入到OSPFv3路由区域。
default-route-advertise [ [ always | permit-calculate-other ] | cost cost-value | route-policy route-policy-name | tag tag | type type ] *
未引入缺省路由。
OSPFv3视图
always:如果当前路由器的路由表中没有缺省路由,使用此参数可产生一个描述缺省路由的AS-external-LSA发布出去。如果没有指定该关键字,仅当本地路由器的路由表中存在缺省路由时,才可以产生一个描述缺省路由的AS-external-LSA发布出去。
permit-calculate-other:当路由器产生并发布了一个描述缺省路由的AS-external-LSA时,指定此参数的路由器仍然会计算来自于其他路由器的缺省路由,未指定此参数的路由器不再计算来自其他路由器的缺省路由。当路由器没有产生一个描述缺省路由的AS-external-LSA时,无论是否指定此参数,路由器都会计算来自其他路由器的缺省路由。
cost cost-value:该缺省路由的度量值,取值范围为0~16777214,缺省值为1。
route-policy route-policy-name:路由策略名,为1~63个字符的字符串,区分大小写。只有当前路由器的路由表中存在缺省路由,并且有路由匹配route-policy-name指定的路由策略,才可以产生一个描述缺省路由的AS-external-LSA发布出去,指定的路由策略会影响AS-external-LSA中的值。如果同时指定always参数,不论当前路由器的路由表中是否有缺省路由,只要有路由匹配指定的路由策略,就将产生一个描述缺省路由的AS-external-LSA发布出去,指定的路由策略会影响AS-external-LSA中的值。
tag tag:外部路由的标记,取值范围为0~4294967295。如果未指定本参数,将根据default tag命令的配置进行取值。
type type:该AS-external-LSA的类型,取值范围为1~2,缺省值为2。
使用import-route命令不能引入缺省路由,如果要引入缺省路由,必须使用本命令。当本地路由器的路由表中没有缺省路由时,要产生一个描述缺省路由的AS-external-LSA应使用always关键字。
# 将产生的缺省路由引入到OSPFv3自治系统中(本地路由器没有缺省路由)。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] default-route-advertise always
·     import-route (OSPFv3 area view)
display ospfv3命令用来显示OSPFv3的进程信息。
display ospfv3 [ process-id ] [ verbose ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的概要信息。
verbose:显示OSPFv3进程的详细信息。如果未指定本参数,将显示OSPFv3进程的概要信息。
# 显示所有OSPFv3进程的详细信息。
<Sysname> display ospfv3 verbose
               OSPFv3 Process 1 with Router ID 1.1.1.1
 RouterID: 1.1.1.1          Router type:  ABR  ASBR  NSSA
 Route tag: 0
 Route tag check: Disabled
 Multi-VPN-Instance: Disabled
 Type value of extended community attributes:
    Domain ID : 0x0005
    Route type: 0x0306
    Router ID : 0x0107
 Domain-id: 0.0.0.0
 DN-bit check: Enabled
 DN-bit set: Enabled
 Originating router-LSAs with maximum metric
    Condition: On startup while BGP is converging for 600 seconds, State: Inactive
    Advertise summary-LSAs with metric 16711680
    Advertise external-LSAs with metric 16711680
    Advertise intra-area-prefix-LSAs with maximum metric
 ISPF: Enabled
 SPF-schedule-interval: 5 50 200
 LSA generation interval: 5
 LSA arrival interval: 1000
 Default ASE parameters: Tag: 1
 Route preference: 10
 ASE route preference: 150
 FRR backup mode: LFA
 SPF calculation count: 0
 External LSA count: 0
 LSA originated count: 0
 LSA received count: 0
 Area count: 2  Stub area count: 0  NSSA area count: 1
 ExChange/Loading neighbors: 0
 Max equal cost paths: 32
 Up interfaces: 1
 Full neighbors: 1
 Normal areas with up interfaces: 1
 Calculation trigger type: Full
 Current calculation type: SPF calculation
 Current calculation phase: Calculation area topology
 Redistribute timer: Off
 Redistribute schedule type: RIB
 Redistribute route count: 0
 Process reset state: N/A
 Current reset type: N/A
 Next reset type: N/A
 Reset prepare message replied: -/-/-/-
 Reset process message replied: -/-/-/-
 Reset phase of module:
   M-N/A, P-N/A, S-N/A, C-N/A, R-N/A
 Area: 0.0.0.0
 Area flag: Normal
 SPF scheduled count: 0
 LSA count: 0
 Up interfaces: 0
 MTU: 1440
 Default cost: 1
 Created by Vlink
 Area: 0.0.0.2
 Area flag: Normal
 LSA count: 0
 IPsec profile name: Profile000
 Keychain authentication: Enabled (test)
 Up interfaces: 1
 MTU: 1500
 Default cost: 1
 Area: 0.0.0.3
 Area flag: NSSA
 SPF Scheduled Count: 0
 LSA Count: 0
 Up interfaces: 0
 MTU: 1440
 Default cost: 1
 Process reset flag: N/A
表1-1 display ospfv3 verbose命令显示信息描述表
OSPFv3进程是1,Router ID是1.1.1.1
RouterID
本路由器的Router ID
Router type
路由器类型,取值为:
·     ABR表示区域边界路由器
·     ASBR表示自治系统边界路由器
·     NSSA表示支持NSSA区域
为空表示非上面三种情况
Route tag
当前进程引入外部路由的缺省标记
Route tag check
当前进程是否使能检查OSPFv3 LSA的标记
Multi-VPN-Instance
当前进程对PE、多VPN实例的支持情况:
·     Multi-VPN-Instance:Disabled表示不支持多VPN实例
·     Multi-VPN-instance:Enabled表示支持多VPN实例
·     PE Router, Multi-VPN-Instance:Enabled表示为PE
OSPFv3扩展团体属性的类型编码
Domain-id
OSPFv3域标识符
DN-bit check
当前进程是否使能检查OSPFv3 LSA的DN位
DN-bit set
当前进程是否使能设置OSPFv3 LSA的DN位
Originating router-LSAs with maximum metric/Originating router-LSAs with R-bit clear
Router LSA中使用最大开销值发布/Router LSA中清除R-bit
Condition
Stub路由器的状态:
·     Always代表始终生效
·     On startup while BGP is converging for XXX seconds代表BGP收敛超时时间
·     On startup for XXX seconds代表重启后生效时间
Stub路由器是否生效:
·     Active表示生效
·     Inactive表示不生效
Summary LSA发布使用的开销值
外部LSA发布使用的开销值
Intra-area-prefix-LSA发布使用的开销值
ISPF
是否使能增量SPF计算功能:
·     Enabled:表示使能
·     Disabled:表示关闭
进行SPF计算的时间间隔
LSA生成时间间隔
LSA重复到达的最小时间间隔
Transmit pacing
接口发送LSU报文的速率,其中:
·     Interval表示接口发送LSU报文的时间间隔
·     Count表示接口一次发送LSU报文的最大个数
引入外部路由的缺省参数值,其中Tag代表路由标记
Route preference
内部路由优先级
外部路由优先级
FRR backup mode
指定快速重路由的备份下一跳地址的方式:
·     LFA: 为所有路由通过LFA(Loop Free Alternate)算法选取备份下一跳信息。如果显示为LFA ABR-only,则表示只有到ABR设备的路由才能够通过LFA算法被选取为备份路径。
·     route-policy route-policy-name:为通过策略的路由指定备份下一跳,route-policy-name为路由策略名
OSPFv3进程的路由计算总数
External LSA count
外部LSA数目,其中:
·     Count:LSA数目
·     checksum Sum:校验和
产生的LSA数目
LSA received count
接收的LSA数目
Area count
区域总数目
Stub area count
Stub区域数目
NSSA area count
NSSA区域数目
处于ExChange/Loading状态的邻居数
触发路由计算的类型,具体如下:
Full:触发全部路由计算
Area topology change:区域拓扑改变触发路由计算
Intra router change:增量的区域内路由器路由变化
ASBR change:增量的ASBR路由变化
Full IP prefix:触发全部IP前缀计算
Full intra AS:触发全部AS内部前缀计算
Inc intra AS:触发增量AS内部前缀计算
Full inter AS:触发全部AS外部前缀计算
Inc inter AS:触发增量AS外部前缀计算
Nexthop calculation:触发下一跳计算
N/A:未触发计算
当前路由计算的类型,具体如下:
SPF calculation:进行区域SPF计算
Intra router calculation:区域内路由器路由计算
ASBR calculation:区域间ASBR路由计算
Inc intra router:增量区域内路由器路由计算
Inc ASBR calculation:增量区域间ASBR路由计算
Full intra AS:进行全部AS内部前缀计算
Inc intra AS:进行增量AS内部前缀计算
Full inter AS:进行全部AS外部前缀计算
Inc inter AS:进行增量AS外部前缀计算
N/A:未触发计算
当前路由计算调度运行到的阶段,具体如下:
Calculation area topology:计算区域拓扑
Calculation router:计算路由器路由
Calculation intra AS:计算AS内部路由
Calculation ASBR:计算ASBR路由
Calculation inter AS:计算AS外部路由
Calculation end:计算收尾阶段
N/A:未触发计算
Redistribute timer
引入路由定时器,其中:
·     Off: 关闭
·     On:开启
引入路由调度类型,其中:
·     RIB: 触发遍历RIB表进行引入
·     Self: 触发遍历自身引入表进行引入
N/A:未触发引入
引入路由计数
Process reset state
进程重启状态标志,具体如下:
N/A:进程未重启
Under reset:进程正在重启
Under RIB smooth:进程正在同步RIB路由
Current reset type
当前进程重启类型,具体如下:
N/A:进程未重启
GR quit:GR异常退出进行普通重启
Delete:删除OSPFv3进程
Undo router-id:删除Router-id
Set router-id:设置Router-id
Next reset type
即将调度进程重启类型,具体如下:
N/A:进程未重启
Delete:删除OSPFv3进程
响应准备重启消息的模块,具体如下:
P代表邻居维护模块
S代表LSDB同步模块
C代表路由计算模块
R代表路由引入模块
响应进程重启消息的模块,具体如下:
P代表邻居维护模块
S代表LSDB同步模块
C代表路由计算模块
R代表路由引入模块
各模块所处重启阶段。其中M代表主控制模块,P代表邻居维护模块,S代表LSDB同步模块,其阶段有:
N/A:未重启
Delete ASE:删除所有ASE LSA
Delete area LSA:删除区域相关LSA
Delete area IF:删除区域下接口
C代表路由计算模块,其阶段有:
N/A:未重启
Delete topology:删除区域拓扑
Delete router:删除路由器路由
Delete intra AS:删除AS内部路由
Delete inter AS:删除AS外部路由
Delete ASBR:删除ASBR路由
R代表路由引入模块,其阶段有:
N/A:未重启
Delete import:删除引入路由
Area
区域信息
Area flag
区域类型
SPF scheduled count
OSPF区域的路由计算总数
LSA count
LSA数目,其中:
·     Count:LSA数目
·     checksum Sum:校验和
IPsec profile name
IPsec安全框架名
OSPFv3区域采用keychain验证模式,keychain名称为test
MTU
区域的MTU值
Default cost
路由的缺省开销值
Created by Vlink
区域由Vlink创建
Type-7 LSA转换为Type-5 LSA的转换者状态,取值为:
·     Enabled:表示本设备是通过命令指定的Type-7 LSA转换为Type-5 LSA的转换者
·     Elected:表示本设备是通过选举指定的Type-7 LSA转换为Type-5 LSA的转换者
·     Disabled:表示本设备不是Type-7 LSA转换为Type-5 LSA的转换者
Type-7 LSA转换为Type-5 LSA转换稳定定时器的超时时间间隔,单位为秒
display ospfv3 abr-asbr命令用来显示到OSPFv3的区域边界路由器和自治系统边界路由器的路由信息。
display ospfv3 [ process-id ] abr-asbr
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程下到区域边界路由器和自治系统边界路由器的路由信息。
# 显示所有OSPFv3进程的ABR和ASBR路由。
<Sysname> display ospfv3 abr-asbr
 Destination : 1.1.1.2                                   Rtr Type : ABR
 Area        : 0.0.0.0                                   Path Type: Intra
 Interface   : GE1/2/0/2                                 BkInterface: GE1/2/0/1
 NextHop     : FE80:1:1::1
 BkNexthop   : FE80:1:2::2
 Cost        : 1
 Destination : 1.1.1.3                                   Rtr Type : ASBR
 Interface   : GE1/2/0/3                                 BkInterface: GE1/2/0/4
 BkNexthop   : FE80:1:2::4
 NextHop     : FE80:2:1::1
 Cost        : 1
表1-2 display ospfv3 abr-asbr命令显示信息描述表
Destination
ABR或ASBR的路由器ID
Rtr Type
路由器类型,包括ABR和ASBR
Area
下一跳地址所在的区域ID
Path Type
到ABR或ASBR的路由类型,取值为:
·     Intra表示区域内路由
·     Inter表示区域间路由
路由出接口
BkInterface
备份出接口
NextHop
下一跳地址
BkNextHop
备份下一跳地址
Cost
从本路由器到达ABR或ASBR的开销
display ospfv3 abr-summary命令用来显示OSPFv3的ABR聚合信息。
display ospfv3 [ process-id ] [ area area-id ] abr-summary [ ipv6-address prefix-length ] [ verbose ]
process-id:当前的聚合配置所在进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的ABR聚合信息。
area area-id:显示位于指定区域的ABR聚合信息。如果未指定本参数,将显示所有区域的ABR聚合信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。
ipv6-address prefix-length:显示指定IPv6地址的ABR聚合信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为0~128。如果未指定本参数,将显示所有ABR聚合信息。
verbose:显示ABR聚合详细信息。如果未指定本参数,将显示ABR聚合的概要信息。
# 显示OSPFv3进程1的ABR聚合信息。
<Sysname> display ospfv3 1 abr-summary
             OSPFv3 Process 1 with Router ID 2.2.2.2
                     Area: 1.1.1.1
 Total summary addresses: 1
 Prefix      : 1000:4::/32
 Status      : Advertise
 NULL0       : Active
 Cost        : 1 (Configured)
 Routes count: 2
表1-3 display ospfv3 abr-summary命令显示信息描述表
Area
聚合路由所在的区域
聚合路由的路由数
Prefix
聚合路由的地址前缀
Status
聚合路由的状态:
·     Advertise:已发布
·     Not-advertise:未发布
NULL0
NULL0路由:
·     Active:激活
·     Inactive:未激活
Cost
聚合路由的开销
·     Configured:配置的聚合开销
·     Not Configured:未配置聚合开销
Routes count
被聚合的路由数
# 显示OSPFv3进程1的ABR聚合详细信息。
<Sysname> display ospfv3 1 abr-summary verbose
                        Area: 1.1.1.1
 Status      : Advertise
 NULL0       : Active
 Routes count: 2
   Destination                                        Metric
   1000:4:10:3::/96                                   1
   1000:4:11:3::/96                                   1
表1-4 display ospfv3 abr-summary verbose命令显示信息描述表
Destination
被聚合路由的目的地址
Metric
路由的开销值
display ospfv3 asbr-summary命令用来显示OSPFv3的ASBR聚合信息。
display ospfv3 [ process-id ] asbr-summary [ ipv6-address prefix-length ] [ verbose ]
process-id:当前的聚合配置所在进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的ASBR聚合信息。
ipv6-address prefix-length:显示指定IPv6地址的ASBR聚合信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为0~128。如果未指定本参数,将显示所有ASBR聚合信息。
verbose:显示ASBR聚合详细信息。如果未指定本参数,将显示ASBR聚合的概要信息。
# 显示OSPFv3进程1的ASBR聚合信息。
<Sysname> display ospfv3 1 asbr-summary
 Status      : Advertise
 NULL0       : Active
 Tag         : (Not configured)
 Nssa-only   : (Not configured)
 Routes count: 2
表1-5 display ospfv3 asbr-summary命令显示信息描述表
聚合路由的路由数
Prefix
聚合路由的地址前缀和前缀长度
Status
聚合路由的状态:
·     Advertise:已发布
·     Not-advertise:未发布
NULL0
NULL0路由:
·     Active:激活
·     Inactive:未激活
Cost
聚合路由的开销:
·     Not configured:未配置聚合开销
Tag
聚合路由的标记:
·     Configured:配置的聚合标记
·     Not configured:未配置聚合标记
Nssa-only
是否配置Nssa-only:
·     Configured:配置了Nssa-only
·     Not configured:未配置Nssa-only
Routes count
被聚合的路由数
# 显示OSPFv3进程1的ASBR聚合详细信息。
<Sysname> display ospfv3 1 asbr-summary verbose
 Status      : Advertise
 NULL0       : Active
 Routes count: 2
  Destination                                 Protocol Process Type Metric
  1000:4:10:3::/96                            Static   0       2    1
  1000:4:11:3::/96                            Static   0       2    1
表1-6 display ospfv3 asbr-summary verbose命令显示信息描述表
Destination
被聚合路由的前缀和前缀长度
Protocol
被聚合路由的协议类型
Process
被聚合路由的协议进程ID
被聚合路由的类型
Metric
被聚合路由的开销
display ospfv3 event-log命令用来显示OSPFv3的日志信息。
display ospfv3 [ process-id ] event-log { lsa-flush | peer | spf }
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有进程的日志信息。
lsa-flush:LSA老化的日志信息。
peer:邻居的日志信息。
spf:路由计算的日志信息。
路由计算的日志信息是指更新到IPv6路由表的路由计数信息。
邻居的日志信息包括OSPFv3邻居状态倒退到DOWN,以及收到BadLSReq、SeqNumberMismatch和1-Way事件导致邻居状态倒退的信息。
# 显示OSPFv3进程1的LSA老化日志信息。
<Sysname>display ospfv3 1 event-log lsa-flush
               OSPFv3 Process 1 with Router ID 1.3.3.3
 2014-09-02 07:55:25 Received MaxAge LSA from 1.1.1.1
 Type: 3   LS ID: 0.0.0.2         AdvRtr: 1.1.1.1           Seq#: 80000001
 2014-09-02 07:55:22 Flushed MaxAge LSA by itself
 Type: 3   LS ID: 0.0.0.2         AdvRtr: 1.3.3.3           Seq#: 80000001
 2014-09-02 07:55:07 Flushed MaxAge LSA by itself
 Type: 3   LS ID: 0.0.0.40        AdvRtr: 1.3.3.3           Seq#: 80000001
 Type: 3   LS ID: 0.0.0.39        AdvRtr: 1.3.3.3           Seq#: 80000001
表1-7 display ospfv3 event-log lsa-flush命令显示信息描述表
Received MaxAge LSA from X.X.X.X
从Router ID为X.X.X.X的源收到MaxAge LSA
自身发起的老化,洪泛MaxAge LSA
LSA类型
LS ID
LSA链路状态ID
AdvRtr
发布LSA的路由器,用Router ID表示
Seg#
LSA序列号
# 显示OSPFv3进程1的路由计算的日志信息。
<Sysname>display ospfv3 1 event-log spf
 Date       Time     Duration   Intra   Inter   External Reason
 2014-09-02 07:55:30 0.258827   0       0       0        Intra-area LSA
 2014-09-02 07:55:30 0.679      0       0       0        Intra-area LSA
 2014-09-02 07:55:30 0.51576    0       0       0        Intra-area LSA
 2014-09-02 07:55:30 0.372      0       0       0        Intra-area LSA
 2014-09-02 07:55:25 4.948353   0       0       0        Intra-area LSA
 2014-09-02 07:55:25 0.5288     0       0       0        Area 0 full neighbor
 2014-09-02 07:55:21 1.66013    0       0       0        Intra-area LSA
 2014-09-02 07:55:20 0.450905   0       0       0        Intra-area LSA
 2014-09-02 07:55:15 0.253688   0       0       0        Interface state change
 2014-09-02 07:55:15 0.5693     0       0       0        Intra-area LSA
表1-8 display ospfv3 event-log spf命令显示信息描述表
Date/Time
路由计算开始的时间
Duration
路由计算持续时间,单位为秒
Intra
区域内路由变化的个数
Inter
区域间路由变化的个数
External
外部路由变化的个数
Reason
路由计算的原因:
·     Intra-area LSA:区域内LSA变化
·     Inter-area LSA:区域间LSA变化
·     External LSA:外部LSA变化
·     Configuration:配置变化
·     Area 0 full neighbor:区域0 FULL邻居个数变化
·     Area 0 up interface:区域0 UP接口个数变化
·     AS number:AS号变化
·     ABR summarization:ABR聚合变化
·     GR end:GR结束
·     Routing policy:路由策略变化
·     Intra-area tunnel:区域内隧道变化
·     Others: 除上述原因之外的其他原因
# 显示OSPFv3进程1的邻居的日志信息。
<Sysname> display ospfv3 1 event-log peer
 Date       Time     Router ID       Reason       Instance ID  Interface
 2014-09-02 16:39:13 1.3.3.3         IntPhyChange 0            GE1/2/0/1
 2014-09-02 16:36:46 1.3.3.3         IntPhyChange 0            GE1/2/0/1
 2014-09-02 16:34:49 1.3.3.3         BFDDown      0            GE1/2/0/1
 2014-09-02 10:08:45 1.3.3.3         DeadExpired  0            GE1/2/0/2
 2014-09-02 10:08:39 1.3.3.3         DeadExpired  0            VLINK1
 2014-09-02 10:08:08 1.3.3.3         BFDDown      0            GE1/2/0/1
表1-9 display ospfv3 event-log peer命令显示信息描述表
Date &Time
邻居状态变化的时间
Router ID
邻居的Router ID
Reason
邻居状态变化的原因:
·     ResetConnect:内存不足,邻居关系中断
·     IntChange:接口参数改变
·     ResetOspfv3:重启OSPFv3进程
·     UndoOspfv3:删除OSPFv3进程
·     UndoArea:删除OSPFv3区域
·     UndoInt:接口去使能
·     IntLogChange:接口逻辑属性变化
·     IntPhyChange:接口物理属性变化
·     DeadExpired:Dead Timer超时
·     Retrans:重传过多
·     BFDDown:BFD Down
·     SilentInt:配置抑制接口
·     ConfStubArea:配置Stub区域参数
·     ConfNssaArea:配置NSSA区域参数
·     VlinkDown:虚连接Down
·     ShamlinkDown:伪连接Down
·     BadLSReq:收到BadLSReq事件
·     SeqMismatch:收到SeqNumberMismatch事件
·     1-Way:收到1-Way事件
Instance ID
接口所属的实例ID
接口名称
display ospfv3 global-statistics命令用来显示OSPFv3的全局统计信息。
display ospfv3 global-statistics [ public | vpn-instance vpn-instance-name ]
public:显示公网下OSPFv3的全局统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例下OSPFv3的全局统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
如果不指定任何参数,将显示公网和VPN实例下OSPFv3的全局统计信息。
# 显示OSPFv3的全局统计信息。
<Sysname> display ospfv3 global-statistics
  OSPFv3 global statistics
   Instance count   : 2
   Process count    : 2
   Interface information
    Down            : 1
    Up              : 1
   Neighbor information
    Down            : 0
    Init            : 0
    Attempt         : 0
    2-Way           : 0
    ExStart         : 0
    Exchange        : 0
    Loading         : 0
    Full            : 0
   Packets sent     : 0
   Packets received : 0
   LSA count        : 2
   Route count      : 1
表1-10 display ospfv3 global-statistics命令输出信息描述表
Instance count
公网和VPN实例下存在OSPFv3配置时,对公网和VPN实例总数的统计信息
Process count
进程数量
接口状态统计信息
Down
状态为Down的接口数目
Up
状态为Up的接口数目
邻居状态统计信息
Down
状态为Down的邻居路由器数目
Attempt
状态为Attempt的邻居路由器数目
Init
状态为Init的邻居路由器数目
2-Way
状态为2-Way的邻居路由器数目
ExStart
状态为ExStart的邻居路由器数目
Exchange
状态为Exchange的邻居路由器数目
Loading
状态为Loading的邻居路由器数目
Full
状态为Full的邻居路由器数目
Packet sent
发送协议报文的数目
Packet received
接收协议报文的数目
LSA count
链路状态数据库中所有LSA的数目
Route count
OSPFv3所有路由的数目
display ospfv3 graceful-restart命令用来显示OSPFv3进程的GR状态信息。
display ospfv3 [ process-id ] graceful-restart [ verbose ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的GR状态信息。
verbose:显示GR详细状态信息。如果未指定本参数,将显示OSPFv3进程的GR状态概要信息。
# 显示所有OSPFv3进程的GR状态信息(Restarter)。
<Sysname> display ospfv3 graceful-restart
               OSPFv3 Process 1 with Router ID 3.3.3.3
 Graceful-restart capability     : Enable
 Graceful-restart support        : Planned and un-planned, Partial
 Helper capability               : Enable
 Helper support                  : Planned and un-planned
 Current GR state                : Normal
 Graceful-restart period         : 120 seconds
 Number of neighbors under helper: 0
 Number of restarting neighbors  : 0
 Last exit reason:
   Restarter: None
   Helper   : None
表1-11 display ospfv3 graceful-restart命令显示信息描述表
OSPFv3进程是1,Router ID是3.3.3.3的GR状态信息
是否使能OSPFv3协议的GR能力
·     Enable:使能
·     Disable:未使能
进程GR支持模式(GR使能时才显示):
·     Planned and un-planned:支持计划和非计划GR
·     Planned only:只支持计划性GR
·     Partial:支持接口级GR
·     Global:不支持接口级GR,支持全局GR
Helper capability
是否使能OSPFv3协议的GR Helper能力
·     Enable:使能
·     Disable:未使能
Helper support
显示Helper的支持模式(Helper使能时才显示):
·     Strict LSA check:Helper端支持严格的LSA检查
·     Planned and un-planned:支持作为计划和非计划GR的Helper
·     Planned only:只支持作为计划GR的Helper
Current GR state
当前GR的状态,其状态有如下几种:
·     Normal:表示正处在非GR的正常状态
·     Under GR:表示正在GR过程中,自身作为Restarter
·     Under Helper:表示正在GR过程中,自身作为Helper
GR重启间隔时间
处于GR Helper模式的邻居个数
处于GR Restarter模式的邻居个数
Last exit reason
上次退出原因,其中:
·     Restarter:表示退出Restarter的原因
¡     None:无
¡     Completed:GR完成
¡     Interval timer is fired:GR定时器超时
¡     Interface state change:接口状态变化
¡     Received 1-way hello:收到邻居的1-way Hello报文
¡     Reset neighbor:邻居发生Reset操作
¡     DR or BDR change:DR或BDR发生变化
·     Helper:表示退出Helper的原因
¡     None:无
¡     Completed:GR完成
¡     Grace Period timer is fired:GR定时器超时
¡     Lsa check failed:LSA检查未通过
¡     Received MAXAGE gracelsa but neighbor is not full:收到到达老化时间的Grace LSA,但邻居状态未达到FULL状态
 Last exit reason:
   Restarter: None
   Helper   : None
表1-12 display ospfv3 graceful-restart命令显示信息描述表
是否使能OSPFv3协议的GR能力
·     Enable:使能
·     Disable:未使能
进程GR支持模式(GR使能时才显示):
·     Partial:支持接口级GR
Helper capability
·     Enable:使能
·     Disable:未使能
Helper support
Current GR state
当前GR的状态,其状态有如下几种:
GR重启间隔时间
处于GR Helper模式的邻居个数
Last exit reason
上次退出原因,其中:
¡     None:无
¡     Completed:GR完成
¡     None:无
¡     Completed:GR完成
# 显示OSPFv3进程的GR详细状态信息(Restarter)。
<Sysname> display ospfv3 graceful-restart verbose
 Last exit reason:
   Restarter: None
   Helper   : None
 Area: 0.0.0.0
 Area flag: Normal
 Area up interface count: 1
 Virtual-link Neighbor-ID: 100.1.1.1, Neighbor-state: Full
 Restarter state: Normal   State: P-2-P    Type: Virtual
 Interface: 6696 (GigabitEthernet1/2/0/2), Instance-ID: 0
 Local  IPv6 address: 200:1:FFFF::1
 Remote IPv6 address: 201:FFFF::2
 Transit area: 0.0.0.1
 Last exit reason:
   Restarter: None
   Helper   : None
 Neighbor       GR state       Last helper exit reason
 100.1.1.1      Normal         None
 Area: 0.0.0.1
 Area flag: Transit
 Area up interface count: 3
 Interface: 5506 (GigabitEthernet1/2/0/3), Instance-ID: 0
 Restarter state: Normal   State: DR       Type: Broadcast
 Last exit reason:
   Restarter: None
   Helper   : None
 Neighbor count of this interface: 0
 Last exit reason:
   Restarter: None
   Helper   : None
 Neighbor count of this interface: 1
 Sham-link Neighbor-ID: 100.1.1.1, Neighbor-state: Full
 Restarter state: Normal   State: P-2-P    Type: Sham
 Interface-ID: 2147483649, Instance-ID: 0
 Source      : 8000:88::FFFF
 Destination : 7000:77::FFFF
 Last exit reason:
   Restarter: None
   Helper   : None
 Area: 0.0.0.5
 Area flag: NSSANoSummaryNoImportRoute
 Area up interface count: 0
表1-13 display ospfv3 graceful-restart命令显示信息描述表
Area
区域信息
Area flag
区域类型:
·     Normal:普通区域
·     Transit:传输区
·     Stub:Stub区域
·     StubNoSummary:完全Stub区域
·     NSSA:NSSA区域
·     NSSANoSummary:完全NSSA区域
·     NSSANoSummaryNoImportRoute:完全NSSA区域,配置了no-import-route参数
·     Enabled:表示通过命令指定Type-7 LSA转换为Type-5 LSA的转换者
·     Elected:表示通过选举指定Type-7 LSA转换为Type-5 LSA的转换者
·     Disabled:表示不是Type-7 LSA转换为Type-5 LSA的转换者
Type-7 LSA转换为Type-5 LSA转换稳定定时器的超时时间,单位为秒
区域下up的接口计数
区域内的普通接口,以及虚连接所属的出接口
Instance-ID
接口实例ID
Restarter state
作为Restarter的状态
接口状态
接口的网络类型
接口下的邻居个数
Neighbor
邻居Router ID
GR state
邻居的GR状态:
·     Normal:普通状态
·     Under GR:进程正在GR
·     Under Helper:进程正在作为GR Helper
上一次作为该邻居Helper退出的原因
虚连接的邻居Router ID
Neighbor-State
虚连接和邻居的状态,包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
Local  IPv6 address
本地IPv6地址
Remote IPv6 address
对端IPv6地址
Transit area
传输区域ID
Shamlink的邻居Router ID
Source
Shamlink源地址
Destination
Shamlink目的地址
display ospfv3 interface命令用来显示OSPFv3的接口信息。
display ospfv3 [ process-id ] interface [ interface-type interface-number | verbose ]
interface-type interface-number:接口类型和接口编号。显示指定接口的详细信息。
verbose:显示所有接口的详细信息。
如果未指定OSPFv3进程号,将显示所有OSPFv3进程的接口概要信息。
如果未指定接口或参数verbose,将显示所有接口的概要信息。
# 显示运行OSPFv3的接口GigabitEthernet1/2/0/1的信息。
<Sysname> display ospfv3 interface gigabitethernet 1/2/0/1
 Area: 0.0.0.0
 GigabitEthernet1/2/0/1 is up, line protocol is up
  Interface ID 3        Instance ID 0
  IPv6 prefixes
    fe80::200:12ff:fe34:1  (Link-Local address)
    2001::1
  Cost: 1       State: BDR       Type: Broadcast    MTU: 1500
  Priority: 1
  Designated router: 2.2.2.2
  Backup designated router: 1.1.1.1
  Timers: Hello 10, Dead 40, Poll 40, Retransmit 5, Transmit delay 1
  FRR backup: Enabled
  Neighbor count is 1, Adjacent neighbor count is 1
  Primary path detection mode: BFD echo
  Keychain authentication: Enabled (test), inherited
  Exchanging/Loading neighbors: 0
  Wait timer: Off,  LsAck timer: Off
  Prefix-suppression is enabled
表1-14 display ospfv3 interface命令显示信息描述表
Area
接口所属的区域ID
Interface ID
接口ID
Instance ID
实例ID
IPv6 prefixes
IPv6前缀
Cost
接口开销
根据OSPFv3接口状态机确定的当前接口状态,取值为:
·     Down:表示在接口上没有发送和接收任何路由协议的报文
·     Waiting:表示接口开始发送和接收Hello报文,并试图去识别网络上的DR和BDR
·     P-2-P:表示接口将每隔HelloInterval的时间间隔发送Hello报文,并尝试和接口链路另一端相连的路由器建立邻接关系
·     DR:表示路由器是所连网络的指定路由器
·     BDR:表示路由器是所连网络的备份指定路由器
·     DROther:表示路由器既不是所连网络的指定路由器,也不是所连网络的备份指定路由器
接口的网络类型,取值为:
·     PTP:表示网络类型为点对点
·     PTMP:表示网络类型为点对多点
·     Broadcast:表示网络类型为广播
·     NBMA:表示网络类型为NBMA
MTU
接口MTU的值
Priority
接口的DR优先级
Designated router
本链路上的DR
本链路上的BDR
Timers
配置的OSPFv3定时器,分别定义如下:
·     Hello:表示接口发送Hello报文的时间间隔,单位为秒
·     Dead:表示邻居的失效时间,单位为秒
·     Poll:表示NBMA网络上发送轮询Hello报文的时间间隔,单位为秒
·     Retransmit:表示接口重传LSA的时间间隔,单位为秒
Transmit Delay
接口对LSA的传输延迟时间,单位为秒
FRR backup
是否使能接口参与LFA(Loop Free Alternate)计算:
·     Enabled:使能
·     Disabled:关闭
Neighbor count
接口的邻居数目
主链路检测方式:
·     BFD ctrl:BFD控制报文检测方式
·     BFD echo:BFD echo报文检测方式
接口的邻接数目
IPsec profile name
IPsec安全框架名
OSPFv3接口采用keychain验证模式,keychain名称为test,inherited表示接口继承的是其所属区域下配置的keychain验证模式
处于Exchanging或Loading状态的邻居个数
Wait timer
等待定时器,其中:
·     Off:关闭
·     On:开启
LsAck timer
报文确认定时器,其中:
·     Off:关闭
·     On:开启
接口处于前缀抑制
display ospfv3 lsdb命令用来显示OSPFv3的链路状态数据库信息。
display ospfv3 [ process-id ] lsdb [ { external | grace | inter-prefix | inter-router | intra-prefix | link | network | nssa | router | unknown [ type ] } [ link-state-id ] [ originate-router router-id | self-originate ] | statistics | total | verbose ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的链路状态数据库信息。
external:显示链路状态数据库中Type-5 LSA(AS External LSA)的信息。
grace:显示链路状态数据库中Type-11 LSA(Grace LSA)的信息。
inter-prefix:显示链路状态数据库中Type-3 LSA(Inter-Area-Prefix LSA)的信息。
inter-router:显示链路状态数据库中Type-4 LSA(Inter-Area-Router LSA)的信息。
intra-prefix:显示链路状态数据库中Type-9 LSA(Intra-Area-Prefix LSA)的信息。
link:显示链路状态数据库中Type-8 LSA(Link LSA)的信息。
network:显示链路状态数据库中Type-2 LSA(Network LSA)的信息。
nssa:显示链路状态数据库中Type-7 LSA(NSSA LSA)的信息。
router:显示链路状态数据库中Type-1 LSA(Router LSA)的信息。
unknown:显示链路状态数据库中未知类型LSA的信息。
type:LSA类型,取值范围为十六进制数0~ffff。如果未指定本参数,将显示所有未知类型LSA的信息。
link-state-id:链路状态ID,IPv4地址形式。
originate-router router-id:发布该LSA的路由器的Router ID。
self-originate:显示本地路由器自己产生的LSA的链路状态数据库信息。
statistics:显示链路状态数据库中LSA的统计信息。
total:显示链路状态数据库中各种LSA的总数。
# 显示OSPFv3的链路状态数据库信息。
<Sysname> display ospfv3 lsdb
                  Link-LSA (Interface GigabitEthernet1/2/0/1)
 Link State ID   Origin Router    Age   SeqNum     CkSum  Prefix
 0.15.0.8        2.2.2.2          0691  0x80000041 0x8315      1
 0.0.0.3         1.1.1.1          0623  0x80000001 0x0fee      1
                  Router-LSA (Area 0.0.0.1)
 Link State ID   Origin Router    Age   SeqNum     CkSum    Link
 0.0.0.0         1.1.1.1          0013  0x80000068 0x5d5f      2
 0.0.0.0         2.2.2.2          0024  0x800000ea 0x1e22      0
                  Network-LSA (Area 0.0.0.1)
 0.15.0.8        2.2.2.2          0019  0x80000007 0x599e
                  Intra-Area-Prefix-LSA (Area 0.0.0.1)
 Link State ID   Origin Router    Age   SeqNum     CkSum  Prefix  Reference
 0.0.0.2         2.2.2.2          3600  0x80000002 0x2eed      2 Network-LSA
 0.0.0.1         2.2.2.2          0018  0x80000001 0x1478      1 Network-LSA
表1-15 display ospfv3 lsdb命令显示信息描述表
Link State ID
链路状态ID
Origin Router
产生LSA的路由器
Age
LSA老化时间
SeqNum
LSA序列号
CkSum
LSA校验和
Prefix
前缀数目
Link
链路数目
Reference
引用的LSA类型
# 显示OSPFv3链路状态数据库中Link-LSA的信息。
<Sysname> display ospfv3 lsdb link
  LS age            : 833
  LS Type           : Link-LSA
  Link State ID     : 0.15.0.8
  Originating Router: 2.2.2.2
  LS Seq Number     : 0x80000041
  Checksum          : 0x8315
  Length            : 56
  Priority          : 1
  Options           : 0x000013 (-|R|-|x|E|V6)
  Link-Local Address: fe80::200:5eff:fe00:100
  Number of Prefixes: 1
      Prefix        : 1001::/64
      Prefix Options: 0 (-|R|-|x|E|V6)
表1-16 display ospfv3 lsdb link命令显示信息描述表
LS age
LSA老化时间
LS Type
LSA类型
Link State ID
链路状态ID
Originating Router
产生LSA的路由器
LS Seq Number
LSA序列号
Checksum
LSA校验和
Length
LSA长度
Priority
路由器优先级
Options
选项
Link-Local Address
链路本地地址
Number of Prefixes
前缀的数目
Prefix
地址前缀
Prefix Options
前缀选项
# 显示OSPFv3链路状态数据库中LSA的统计信息。
<System> display ospfv3 lsdb statistics
 Area ID         Router Network IntePre  InteRou IntraPre NSSA
 0.0.0.1         2      0       0        0       2        0
 0.0.0.3         1      0       0        0       1        1
 Total           3      0       0        0       3        1
                 Link   Grace   ASE
 Total           4      0       0
表1-17 display ospfv3 lsdb statistics命令显示信息描述表
Area ID
区域ID,显示该区域各类LSA的总数
Router
Type-1 LSA的数目
Network
Type-2 LSA的数目
IntePre
Type-3 LSA的数目
InteRou
Type-4 LSA的数目
IntraPre
Type-9 LSA的数目
NSSA
Type-7 LSA的数目
Link
Type-8 LSA的数目(只显示总数)
Grace
Type-11 LSA的数目
ASE
Type-5 LSA的数目(只显示总数)
Total
不同区域相同类型LSA的总数
# 显示OSPFv3的链路状态数据库的详细信息。
<Sysname> display ospfv3 lsdb verbose
                 SendCnt: 0       RxmtCnt: 0       Status: Stale
表1-18 display ospfv3 lsdb verbose命令显示信息描述表
SendCnt
待发送该LSA的接口数目
RxmtCnt
该LSA在重传列表中的数目
Status
LSA所处的状态:
·     Normal:正常状态
·     Delayed:延迟生成的LSA
·     Maxage routed:Maxage的LSA且已经经过拓扑前缀处理
·     Self originated:收到自己产生的LSA
·     Stale:GR过程中收到自己产生的LSA
display ospfv3 nexthop命令用来显示OSPFv3的路由下一跳信息。
display ospfv3 [ process-id ] nexthop
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的下一跳信息。
# 显示OSPFv3进程1的路由下一跳信息。
<Sysname> display ospfv3 1 nexthop
 Nexthop : FE80::20C:29FF:FED7:F308                Interface: GE1/2/0/2
 RefCount: 4                                       Status   : Valid
 NbrID   : 1.1.1.1                                 NbrIntID : 21
 Nexthop : FE80::20C:29FF:FED7:F312                Interface: GE1/2/0/3
 RefCount: 3                                       Status   : Valid
 NbrID   : 1.1.1.1                                 NbrIntID : 38
表1-19 display ospfv3 nexthop命令显示信息描述表
Nexthop
下一跳地址
出接口名
RefCount
下一跳引用计数
Status
该下一跳的状态:
·     Valid:有效
·     Invalid:无效
NbrID
邻居路由器ID
NbrIntID
邻居的接口ID
display ospfv3 non-stop-routing命令用来显示OSPFv3进程的NSR状态信息。
display ospfv3 [ process-id ] non-stop-routing
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的NSR状态信息。
# 显示所有OSPFv3进程的NSR状态信息。
<Sysname> display ospfv3 non-stop-routing
 Nonstop Routing capability: Enabled
 Upgrade phase             : Normal
表1-20 display ospfv3 non-stop-routing命令显示信息描述表
是否使能OSPFv3协议的NSR能力
·     Enabled:使能
·     Disabled:未使能
Upgrade phase
NSR的各个阶段,有如下几种:
·     Normal:普通状态
·     Preparation:准备阶段
·     Smooth:数据平滑阶段
·     Precalculation:路由计算预处理阶段
·     Calculation:路由计算阶段
·     Redistribution:路由引入阶段
display ospfv3 peer命令用来显示OSPFv3的邻居信息。
display ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id | statistics ]
process-id:OSPFv3进程号,取值范围为1~65535。如果不指定本参数,则显示所有OSPFv3进程的邻居信息。
area area-id:显示位于指定区域的邻居信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。如果不指定本参数,则显示所有区域的邻居信息。
verbose:显示邻居的详细信息。
peer-router-id:显示指定邻居的信息。
statistics:显示OSPFv3邻居的统计信息。
如果接口参数、邻居Router ID参数都不输入,则显示所有接口的邻居信息。
# 显示OSPFv3进程1的邻居信息。
<Sysname> display ospfv3 1 peer gigabitethernet 1/2/0/1
 Area: 0.0.0.1
 Router ID       Pri State             Dead-Time InstID Interface
 2.2.2.2         1   Full/DR           00:00:33  0      GE1/2/0/1
表1-21 display ospfv3 peer命令显示信息描述表
Router ID
邻居ID
Pri
邻居路由器优先级
邻居状态
Dead-Time
邻居路由器的失效时间
Inst ID
实例ID
和邻居相连的接口
# 显示接口上的OSPFv3进程1的邻居详细信息。
<Sysname> display ospfv3 1 peer gigabitethernet 1/2/0/2 verbose
 Area 0.0.0.1 interface GE1/2/0/2's neighbors
 Router ID: 2.2.2.2          Address: fe80::200:5eff:fe00:100
   DR: 2.2.2.2  BDR: None   MTU: 1500
   Options is 0x000413 (AT|-|-|-|-|-|R|-|x|E|V6)
   Dead timer due in 00:00:38
   Neighbor is up for 00:19:07
   Authentication sequence: (high) 0, (low) 59755
   Neighbor state change count: 120
   Database Summary List 0
   Link State Request List 0
   Link State Retransmission List 3
   Neighbor interface ID: 8037
   GR state: Normal
   Grace period: 0           Grace period timer: Off
   DD Rxmt Timer: Off        LS Rxmt Timer: On
表1-22 display ospfv3 peer verbose命令显示信息描述表
Router ID
邻居的Router ID
Address
接口链路本地地址
邻居状态
Mode
路由器在数据库同步阶段,路由器与邻居协商的主从关系,取值为:
·     Nbr is master:邻居路由器为主路由器
·     Nbr is slave:邻居路由器为从路由器
Priority
邻居路由器优先级
DR
接口所属网段的DR
BDR
接口所属网段的BDR
MTU
接口MTU的值
Options
邻居的LSA选项,各选项含义如下:
·     AT:报文是否带验证字段
·     DC:支持按需链路
·     R:是否为活跃路由器
·     N:是否支持NSSA外部LSA
·     x:保留
·     E:AS外部LSA的接受能力
·     V6:是否参与IPv6路由计算
Dead timer due in 33  sec
邻居将在33秒后被认为不可达
Neighbor is up for 00:24:19
与邻居建立的时长00:24:19
接收到的报文中的验证序列号,高32位的值为0,低32位的值为59755
邻居状态发生改变的次数
需要DD报文发送的LSA个数
链路状态请求列表中LSA个数
链路状态重传列表中LSA个数
邻居的接口ID
GR state
GR状态,取值为:
·     Normal:普通状态
·     Doing GR:正在作为GR Restarter
·     Complete GR:GR完成
·     Helper:正在作为GR Helper
Grace period
发送Grace LSA的间隔
Grace period timer
发送Grace LSA的间隔定时器,其中:
·     Off: 关闭
·     On:开启
DD Rxmt Timer
DD报文重传定时器,其中:
·     Off: 关闭
·     On:开启
LS Rxmt Timer
LSU报文重传定时器,其中:
·     Off: 关闭
·     On:开启
# 显示所有OSPFv3邻居的统计信息。
<Sysname> display ospfv3 peer statistics
 Area ID         Down Attempt Init 2-Way ExStart Exchange Loading Full Total
 0.0.0.0         0    0       0    0     0       0        0       1    1
 Total           0    0       0    0     0       0        0       1    1
表1-23 display ospfv3 peer statistics命令显示信息描述表
Area ID
区域标识
Down
该状态为OSPFv3建立邻居关系的初始化状态,表示OSPFv3路由器在一定时间之内没有收到从某一邻居路由器发送来的信息
Attempt
该状态仅对NBMA网络上的邻居有效,表示最近没有从邻居收到信息,但仍需作出进一步的尝试,用以与邻居联系
Init
此状态表示OSPFv3路由器已经接收到邻居路由器发送来的Hello数据包,但该Hello数据包内没有包含自己的Router ID,还没有建立起双方的双向通信
2-Way
此状态表示OSPFv3路由器与邻居路由器的双向通信已经建立。DR及BDR的选择是在这个状态(或更高的状态)完成的
ExStart
在此状态,路由器要确定邻居双方的主从关系并决定初始的DD报文的序列号
Exchange
在此状态,OSPFv3路由器向其邻居路由器发送DD报文来交换链路状态信息
Loading
在此状态,OSPFv3路由器向邻居路由器发送LSR报文,请求最新的链路状态信息
Full
在此状态,建立起邻居关系的路由器之间已经完成了数据库同步的工作,它们的链路状态数据库已经一致
Total
所有区域中处于相同状态的邻居数目的总和
display ospfv3 request-queue命令用来显示OSPFv3请求列表的信息。
display ospfv3 [ process-id ] [ area area-id ] request-queue [ interface-type interface-number ] [ neighbor-id ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的请求列表信息。
area area-id:显示位于指定区域的信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。如果未指定本参数,将显示所有OSPFv3区域的请求列表信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的请求列表信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的请求列表信息。
# 显示OSPFv3请求列表的信息。
<Sysname> display ospfv3 request-queue
                   Area: 0.0.0.0
                   Nbr-ID 1.3.3.3 Request List
 Type    LinkState ID    AdvRouter       SeqNum       Age   CkSum
 0x4005  0.0.34.127      1.3.3.3         0x80000001   0027  0x274d
 0x4005  0.0.34.128      1.3.3.3         0x80000001   0027  0x2d45
 0x4005  0.0.34.129      1.3.3.3         0x80000001   0027  0x333d
 0x4005  0.0.34.130      1.3.3.3         0x80000001   0027  0x3935
表1-24 display ospfv3 request-queue命令显示信息描述表
Area
区域ID
接口类型和序号
Nbr-ID
邻居ID
Request List
请求列表信息
LSA类型
LinkState ID
链路状态标示符
AdvRouter
通告路由器
SeqNum
LSA序列号
Age
LSA老化时间
CkSum
校验和
display ospfv3 retrans-queue命令用来显示OSPFv3重传列表的信息。
display ospfv3 [ process-id ] [ area area-id ] retrans-queue [ interface-type interface-number ] [ neighbor-id ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的重传列表信息。
area area-id:显示位于指定区域的信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。如果未指定本参数,将显示所有OSPFv3区域的重传列表信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的重传列表信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的重传列表信息。
# 显示OSPFv3重传列表的信息。
<Sysname> display ospfv3 retrans-queue
                   Area: 0.0.0.0
                   Nbr-ID 1.2.2.2 Retransmit List
 0x2009  0.0.0.0         1.3.3.3         0x80000001   3600  0x49fb
表1-25 display ospfv3 retrans-queue命令显示信息描述表
Area
区域ID
接口类型和序号
Nbr-ID
邻居ID
Retransmit List
重传列表信息
LSA类型
LinkState ID
链路状态标示符
AdvRouter
通告路由器
SeqNum
LSA序列号
Age
LSA老化时间
CkSum
校验和
display ospfv3 routing命令用来显示OSPFv3路由表的信息。
display ospfv3 [ process-id ] routing [ ipv6-address prefix-length ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的路由表信息。
ipv6-address prefix-length:显示指定IPv6地址的OSPFv3路由表的信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为0~128。
# 显示OSPFv3路由表的信息。
<Sysname> display ospfv3 routing
               OSPFv3 Process 1 with Router ID 9.9.9.9
 I  - Intra area route,  E1 - Type 1 external route,  N1 - Type 1 NSSA route
 IA - Inter area route,  E2 - Type 2 external route,  N2 - Type 2 NSSA route
 *  - Selected route
*Destination: 3::3/128
  Type       : I                                    Area       : 0.0.0.1
  AdvRouter  : 1.1.1.1                              Preference : 0
  NibID      : 0x130000001                          Cost       : 10
  Interface  : GE1/2/0/1                              BkInterface: GE1/2/0/2
  Nexthop    : FE80::20C:29FF:FED4:7171
  BkNexthop  : FE80:1:1:1
*Destination: 3::4/128
  Nexthop    : FE80::10C:29AF:FE97:1210
*Destination: 3::5/128
  Nexthop    : FE80::10BC:28AF:FE97:1008
Total: 3
 Intra area: 3         Inter area: 0         ASE: 0         NSSA: 0
表1-26 display ospfv3 routing命令显示信息描述表
Destination
目的网段
路由类型
Area
区域ID
AdvRouter
Preference
路由优先级
NibID
路由下一跳信息的ID值
Cost
路由开销值
出接口
BkInterface
备份下一跳出接口
Nexthop
下一跳地址
BkNexthop
备份下一跳地址
Nexthop
下一跳地址
出接口
AdvRouter
发布路由器
Area
区域ID
Tag
外部路由标记
Preference
路由优先级
Total
路由总数目
Intra area
区域内路由数目
Inter area
区域间路由数目
ASE
5类外部路由数目
NSSA
7类外部路由数目
display ospfv3 spf-tree命令用来显示OSPFv3区域的最短路径树信息。
display ospfv3 [ process-id ] [ area area-id ] spf-tree [ verbose ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程下区域的最短路径树信息。
area area-id:显示指定区域的最短路径树信息。如果未指定本参数,将显示所有区域的最短路径树信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。
verbose:显示OSPFv3区域的最短路径树的详细信息。如果未指定本参数,将显示OSPFv3区域的最短路径树的概要信息。
# 显示OSPFv3进程1下区域0的最短路径树信息。
<Sysname> display ospfv3 1 area 0 spf-tree
 Flags: S-Node is on SPF tree       R-Node is directly reachable
        I-Node or Link is init      D-Node or Link is to be deleted
        P-Neighbor is parent        A-Node is in candidate list
        C-Neighbor is child         H-Nexthop changed
        N-Link is a new path        V-Link is involved
                 Area: 0.0.0.0  Shortest Path Tree
 SPFNode         Type   Flag         SPFLink         Type   Cost  Flag
>1.1.1.1         Router S R
                                  -->2.2.2.2         RT2RT  1     C
                                  -->2.2.2.2         RT2RT  1     P
表1-27 display ospfv3 spf-tree命令显示信息描述表
SPFNode
SPF节点,以宣告路由器ID作为标识,其中,Type为节点类型:
·     Network:网络节点
·     Router:路由器节点
·     Flag为节点标志:
·     I:节点处于初始化状态
·     T:节点在候选列表上
·     S:节点在SPF树上
·     R:该节点与根节点直连
·     D:该节点将被删除
SPFLink
SPF链路,以宣告路由器ID作为标识,其中,Type为链路类型:
·     RT2RT:表示路由器到路由器链路
·     NET2RT:表示网络到路由器链路
·     RT2NET:表示路由器到网络链路
·     Cost为链路花费,Flag为链路标志:
·     I:链路处于初始化状态
·     P:目的节点是父节点
·     C:目的节点是子节点
·     D:链路将要被删除
·     H:下一跳发生改变
·     V:目的节点删除或者是新增节点时,链路的目的节点不在SPF树上或处于删除状态
·     N:新增链路,并且源节点和目的节点都在SPF树上
·     L:链路在区域变化列表中
# 显示OSPFv3进程1下区域0的最短路径树详细信息。
<Sysname> display ospfv3 1 area 0 spf-tree verbose
>SPFNode[0]
  AdvID        : 1.1.1.1                  LsID       : 0.0.0.0
  NodeType     : Router                   Distance   : 1
  NodeFlag     : S R
  Nexthop count: 1
 -->NbrID      : 1.1.1.1                  NbrIntID   : 21
    Interface  : GE1/2/0/2                  NhFlag     : Valid
    BkInterface: GE1/2/0/3                 RefCount    : 4
    BkNexthop  : FE80::4
  SPFLink count: 1
 -->AdvID      : 1.1.1.1                  LsID       : 0.0.0.0
    IntID      : 232                      NbrIntID   : 465
    NbrID      : 2.2.2.2                  LinkType   : RT2RT
    LinkCost   : 1                        LinkNewCost: 1
    LinkFlag   : C                        NexthopCnt : 0
  ParentLink count: 1
    IntID      : 215                      NbrIntID   : 466
    LinkFlag   : P                        NexthopCnt : 0
表1-28 display ospfv3 spf-tree verbose命令显示信息描述表
SPFNode
SPF节点
AdvID
通告路由器ID
LsID
链路状态ID
NodeType
节点类型
Distance
到根节点的开销
NodeFlag
节点标志
Nexthop count
下一跳计数
NbrID
邻居路由器ID
NbrIntID
邻居的接口ID
出接口
NhFlag
下一跳标志:
Valid:有效
Invalid:无效
BkInterface
备份下一跳出接口
RefCount
下一跳的引用计数
Nexthop
下一跳地址
BkNexthop
备份下一跳地址
SPFLink count
SPF链路计数
IntID
接口ID
LinkType
链路类型:
·     RT2RT:表示路由器到路由器链路
·     NET2RT:表示网络到路由器链路
·     RT2NET:表示路由器到网络链路
LinkCost
当前链路花费
LinkNewCost
新的链路花费
LinkFlag
链路标志:
·     I:链路处于初始化状态
·     P:目的节点是父节点
·     C:目的节点是子节点
·     D:链路将要被删除
·     H:下一跳发生改变
·     L:链路在区域变化列表中
NexthopCnt
下一跳个数
ParentLink count
父链路计数
display ospfv3 statistics命令用来显示OSPFv3的统计信息。
display ospfv3 [ process-id ] statistics [ error | packet [ interface-type interface-number ] ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的统计信息。
error:显示错误统计信息。如果未指定本参数,将显示OSPFv3进程的报文、LSA和路由的统计信息。
packet:显示OSPFv3的报文统计信息。
interface-type interface-number:接口类型和编号。显示指定接口的统计信息。如果未指定本参数,将显示所有接口的统计信息。
# 显示OSPFv3的统计信息。
<Sysname> display ospfv3 statistics
                   Packet Statistics
 Type                         Recv                Send
 Hello                        1746                1284
 DB Description               505                 941
 Ls Req                       252                 136
 Ls Upd                       851                 1553
 Ls Ack                       416                 450
             Local Originated LSAs Statistics
 Type                                             Count
 Router-LSA                                       192
 Network-LSA                                      0
 Inter-Area-Prefix-LSA                            0
 Inter-Area-Router-LSA                            0
 AS-external-LSA                                  0
 NSSA-LSA                                         0
 Link-LSA                                         10
 Intra-Area-Prefix-LSA                            112
 Grace-LSA                                        0
 Unknown-LSA                                      0
 Total                                            314
                   Routes Statistics
 Type                                             Count
 Intra Area                                       0
 Inter Area                                       0
 ASE                                              0
 NSSA                                             0
表1-29 display ospfv3 statistics命令显示信息描述表
Packet Statistics
收发报文统计
Hello
Hello报文
DB Description
数据库描述报文
Ls Req
链路状态请求报文
Ls Upd
链路状态更新报文
Ls Ack
链路状态确认报文
生成的LSA统计
Router-LSA
Type-1 LSA的数目
Network-LSA
Type-2 LSA的数目
Type-3 LSA的数目
Type-4 LSA的数目
AS-external-LSA
Type-5 LSA的数目
NSSA-LSA
Type-7 LSA的数目
Link-LSA
Type-8 LSA的数目
Type-9 LSA的数目
Grace-LSA
Type-11 LSA的数目
Unknown-LSA
Unknown-LSA数目
Total
总数目
Routes Statistics
路由计数
Intra Area
区域内路由
Inter Area
区域间路由
ASE
5类外部路由
NSSA
7类外部路由
# 显示OSPFv3进程的错误统计信息。
<sysname> display ospfv3 statistics error
 0         : Transmit error               0         : Neighbor state low
 0         : Packet too small             0         : Bad version
 0         : Bad checksum                 0         : Unknown neighbor
 0         : Bad area ID                  0         : Bad packet
 0         : Packet dest error            0         : Inactive area packet
 0         : Router ID confusion          0         : Bad virtual link
 0         : HELLO: Hello-time mismatch   0         : HELLO: Dead-time mismatch
 0         : HELLO: Ebit option mismatch  0         : DD: Ebit option mismatch
 0         : DD: Unknown LSA type         0         : DD: MTU option mismatch
 0         : REQ: Empty request           0         : REQ: Bad request
 0         : UPD: LSA checksum bad        0         : UPD: Unknown LSA type
 0         : UPD: Less recent LSA         0         : UPD: LSA length bad
 0         : UPD: LSA AdvRtr id bad       0         : ACK: Bad ack packet
 0         : ACK: Invalid ack             0         : Interface down
 0         : Multicast incapable          0         : Authentication failure
 0         : AuthSeqNumber error
表1-30 display ospfv3 statistics error命令显示信息描述表
Transmit error
发送出错的OSPFv3报文数
Neighbor state low
在低邻居状态收到的OSPFv3报文数
Packet too small
报文长度太小的OSPFv3报文数
Bad version
错误版本号的OSPFv3报文数
Bad checksum
校验和出错的OSPFv3报文数
Unknown neighbor
未知的邻居发来的OSPFv3报文数
Bad area ID
非法的区域ID的OSPFv3报文数
Bad packet
非法的OSPFv3报文数
Packet dest error
目的地址错误的OSPFv3报文数
非活动区域中接收到的报文数
Router ID confusion
含有重复路由器ID的OSPFv3报文数
Bad virtual link
错误的虚链路的OSPFv3报文数
Hello定时器不匹配的Hello报文数
Dead定时器不匹配的Hello报文数
Option字段E位不匹配的Hello报文数
Option字段E位不匹配的DD报文数
DD报文中含有未知类型LSA的数目
MTU不匹配的DD报文数
REQ: Empty request
不含有任何请求信息的LSR报文数
REQ: Bad request
请求错误LSA的LSR报文数
LSU报文中含有错误校验和LSA的数目
LSU报文中含有未知类型LSA的数目
LSU报文中含有不是最新LSA的数目
UPD: LSA length bad
LSU报文中含有错误长度LSA的数目
LSU报文中含有错误宣告路由器LSA的数目
ACK: Bad ack packet
对LSU报文错误确认的ack报文数
ACK: Invalid ack
LSAck报文中无效确认ack的数目
Interface down
接口down计数
Multicast incapable
加入组播组出错计数
接收到的报文验证失败
AuthSeqNumber error
接收到的报文验证序列号错误
# 显示OSPFv3进程和接口的报文统计信息。
<Sysname> display ospfv3 statistics packet
         Hello      DD         LSR        LSU        ACK        Total
 Input : 8727       128        28         1584       929        11396
 Output: 8757       159        86         987        1513       11502
 Area: 0.0.0.0
 Area: 0.0.0.1
 Interface: GigabitEthernet1/2/0/1
 Input : 16         0          45         7          68
 Output: 17         1          7          44         69
 Interface: GigabitEthernet1/2/0/2
 Input : 41         13         720        719        1493
 Output: 54         41         750        713        1558
表1-31 display ospfv3 statistics packet命令显示信息描述表
Hello
Hello报文
DD
数据库描述报文
LSR
链路状态请求报文
LSU
链路状态更新报文
ACK
链路状态确认报文
Total
报文总数
Input
接收报文数
Output
发送报文数
Area
区域ID
接口名称
display ospfv3 vlink命令用来显示OSPFv3的虚连接信息。
display ospfv3 [ process-id ] vlink
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的虚连接信息。
# 显示OSPFv3的虚连接信息。
<Sysname> display ospfv3 vlink
 Virtual-link Neighbor-id: 12.2.2.2, Neighbor-state: Full
 Interface: 2348 (GigabitEthernet1/2/0/2), Instance-ID: 0
 Local  IPv6 address: 3:3333::12
 Remote IPv6 address: 2:2222::12
 Cost: 1  State: P-2-P  Type: Virtual
表1-32 display ospfv3 vlink命令显示信息描述表
通过虚连接相连的邻居路由器的Router ID
Neighbor-state
邻居状态,包括Down、Init、2-Way、ExStart、Exchange、Loading和Full
此虚连接的本端接口的端口号和名称
Instance-ID
实例ID
Local IPv6 address
本地IPv6地址
Remote IPv6 address
对端IPv6地址
Cost
接口的路由开销
接口状态
类型:虚连接
Transit area
传输区域ID(如果当前接口为虚连接,则显示)
Timers
OSPFv3定时器,分别定义如下:
·     Retransmit:表示接口重传LSA时间间隔,单位为秒
Transmit Delay
接口对LSA的传输延迟时间,单位为秒
IPsec profile name
IPsec安全框架名
OSPFv3虚连接采用keychain验证模式,keychain名称为test,inherited表示虚连接继承的是骨干区域下配置的keychain验证模式
1.1.27  dscp
dscp命令用来配置OSPFv3发送协议报文的DSCP优先级。
undo dscp命令用来恢复缺省情况。
dscp dscp-value
undo dscp
OSPFv3发送协议报文的DSCP优先级为48。
OSPFv3视图
dscp-value:DSCP优先级,取值范围为0~63。
# 配置OSPFv3进程1发送协议报文的DSCP优先级为63。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] dscp 63
enable ipsec-profile命令用来在OSPFv3区域应用IPsec安全框架。
undo enable ipsec-profile命令用来取消在OSPFv3区域应用的IPsec安全框架。
enable ipsec-profile profile-name
OSPFv3区域没有应用IPsec安全框架。
OSPFv3区域视图
profile-name:IPsec安全框架名称,为1~63个字符的字符串,不区分大小写。
本命令应结合IPsec安全框架使用,IPsec安全框架的具体情况请参见“安全配置指导”中的“IPsec”。
# 配置OSPFv3进程1区域0的安全框架为profile001。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.0] enable ipsec-profile profile001
1.1.29  event-log
event-log命令用来配置保存OSPFv3的日志信息的最大个数。
undo event-log命令用来取消保存OSPFv3的日志信息的最大个数的配置。
event-log { lsa-flush | peer | spf } size count
undo event-log { lsa-flush | peer | spf } size
保存的路由计算、邻居和LSA老化的日志信息个数均为10个。
OSPFv3视图
lsa-flush:LSA老化日志信息个数。
peer:邻居日志信息个数。
spf:SPF日志信息个数。
count:日志信息个数,取值范围为0~65535。
# 配置保存OSPFv3进程100的路由计算日志信息的最大个数为50。
[Sysname] ospfv3 100
[Sysname-ospfv3-100] event-log spf size 50
fast-reroute命令用来配置OSPFv3快速重路由功能。
undo fast-reroute命令用来关闭OSPFv3快速重路由功能。
fast-reroute { lfa [ abr-only ] | route-policy route-policy-name }
undo fast-reroute
OSPFv3快速重路由功能处于关闭状态。
OSPFv3视图
lfa为所有路由通过LFA(Loop Free Alternate)算法选取备份下一跳信息。
abr-only:仅选取到ABR设备的路由作为备份下一跳。
route-policy route-policy-name:为通过策略的路由指定备份下一跳,route-policy-name为路由策略名,为1~63个字符的字符串,区分大小写。
OSPFv3快速重路由功能(通过LFA算法选取备份下一跳信息)使能后,不能配置vlink-peer命令。
# 使能OSPFv3进程1的快速重路由功能,为所有路由通过LFA算法选取备份下一跳信息。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute lfa
filter命令用来配置对Inter-Area-Prefix-LSA进行过滤。
undo filter命令用来取消对Inter-Area-Prefix-LSA进行过滤。
filter { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import }
不对Inter-Area-Prefix-LSA进行过滤。
OSPFv3区域视图
ipv6-acl-number:指定的基本或高级IPv6 ACL编号,对进出本区域的Inter-Area-Prefix-LSA进行过滤,取值范围为2000~3999。
prefix-list-name:指定的IPv6地址前缀列表,对进出本区域的Inter-Area-Prefix-LSA进行过滤,为1~63个字符的字符串,区分大小写。
route-policy-name:指定的路由策略,对进出本区域的Inter-Area-Prefix-LSA进行过滤,为1~63个字符的字符串,区分大小写。
export:对ABR向其它区域发布的Inter-Area-Prefix-LSA进行过滤。
import:对ABR向本区域发布的Inter-Area-Prefix-LSA进行过滤。
此命令只在ABR路由器上有效,对区域内部路由器无效。
# 根据IPv6地址前缀列表my-prefix-list和编号为2000的IPv6基本ACL分别对进出OSPFv3区域1的Inter-Area-Prefix-LSA进行过滤。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] filter prefix-list my-prefix-list import
[Sysname-ospfv3-1-area-0.0.0.1] filter 2000 export
filter-policy export命令用来配置对引入的路由信息进行过滤。
undo filter-policy export命令用来取消对引入的路由信息进行过滤。
filter-policy { ipv6-acl-number | prefix-list prefix-list-name } export [ protocol [ process-id ] ]
不对引入的路由信息进行过滤。
OSPFv3视图
ipv6-acl-number:用于过滤路由信息目的地址的基本或高级IPv6 ACL编号,取值范围为2000~3999。
prefix-list-name:用于过滤路由信息目的地址的IPv6地址前缀列表的名称,为1~63个字符的字符串,区分大小写。
protocol:路由协议名称,指定何种路由协议的路由信息将被过滤。如果没有指定protocol参数,对引入的任何一个协议产生的路由都要进行过滤。
process-id:路由协议进程号,取值范围为1~65535。只有当protocolisisv6ospfv3ripng时,支持该参数。
当配置的是高级ACL(3000~3999)时,其使用规则如下:
·     使用命令rule [ rule-id ] { deny | permit } ipv6 source sour-addr sour-prefix来过滤指定目的地址的路由。
·     使用命令rule [ rule-id ] { deny | permit } ipv6 source sour-addr sour-prefix destination dest-addr dest-prefix来过滤指定目的地址和掩码的路由。
其中,source用来过滤路由目的地址,destination用来过滤路由前缀,配置的前缀应该是连续的(当配置的前缀不连续时该过滤前缀的条件不生效)。
filter-policy export命令只对本设备使用import-route引入的路由起作用。如果没有配置import-route命令来引入其它外部路由(包括不同进程的OSPFv3路由),则filter-policy export命令无效。
# 根据IPv6地址前缀列表abc对引入的路由信息进行过滤。
[Sysname] ipv6 prefix-list abc permit 2002:1:: 64
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy prefix-list abc export
# 使用编号为3000的IPv6高级ACL对引入的路由进行过滤,只允许2001::1/128通过。
[Sysname-acl-ipv6-adv-3000] rule 10 permit ipv6 source 2001::1 128 destination ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff 128
[Sysname-acl-ipv6-adv-3000] rule 100 deny ipv6
[Sysname-acl-ipv6-adv-3000] quit
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 3000 export
filter-policy import命令用来过滤通过接收到的LSA计算出来的路由信息。
filter-policy { ipv6-acl-number [ gateway prefix-list-name ] | prefix-list prefix-list-name [ gateway prefix-list-name ] | gateway prefix-list-name | route-policy route-policy-name } import
不对通过接收到的LSA计算出来的路由信息进行过滤。
OSPFv3视图
gateway prefix-list-name:指定的IPv6地址前缀列表,基于要加入到路由表的路由信息的下一跳进行过滤。prefix-list-name为1~63个字符的字符串,区分大小写。如果未指定本参数,则不会基于要加入到路由表的路由信息的下一跳进行过滤。
prefix-list prefix-list-name:指定的地址前缀列表,基于目的地址对接收的路由信息进行过滤。prefix-list-name为1~63个字符的字符串,区分大小写。
route-policy route-policy-name:指定路由策略名,基于路由策略对接收的路由信息进行过滤。route-policy-name为1~63个字符的字符串,区分大小写。
当配置的是高级ACL(3000~3999)或者指定的路由策略中配置的是高级ACL时,其使用规则如下:
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-prefix来过滤指定目的地址的路由。
·     使用命令rule [ rule-id ] { deny | permit } ip source sour-addr sour-prefix destination dest-addr dest-prefix来过滤指定目的地址和前缀的路由。
filter-policy import命令只对OSPFv3计算出来的路由进行过滤,没有通过过滤的路由将不被加入路由表中,从而不能指导报文转发。
# 根据IPv6地址前缀列表abc对接收的路由信息进行过滤。
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy prefix-list abc import
# 使用编号为3000的IPv6高级ACL对接收的路由进行过滤,只允许2001::1/128通过。
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 3000 import
graceful-restart enable命令用来使能OSPFv3协议的GR能力。
undo graceful-restart enable命令用来关闭OSPFv3协议的GR能力。
graceful-restart enable [ global | planned-only ] *
OSPFv3的GR能力处于关闭状态。
OSPFv3视图
global:全局GR,必须保证所有的GR Helper都存在,整个GR才会完成,如果有一个GR Helper失效(比如,接口down),则整个GR失败。如果未指定本参数,表示支持接口级GR,即只要有一个GR Helper存在,则整个GR会完成。
planned-only:表示只支持计划重启。如果未指定本参数,表示计划重启和非计划重启都支持。
GR包括计划重启和非计划重启:
·     计划重启指的是手动通过命令执行重启或主备倒换,在进行重启或主备倒换前GR Restarter会先发送Grace-LSA。
·     非计划GR指的是由于设备故障等原因进行重启或主备倒换,在进行重启或主备倒换前GR Restarter不会事先发送Grace-LSA。
graceful-restart enablenon-stop-routing命令互斥,不能同时配置。
支持OSPFv3的GR Restarter能力的设备主备倒换后,为了实现设备转发业务的不中断,它必须完成下列两项任务:
·     重启过程GR Restarter转发表项保持稳定;
·     重启流程结束后重建所有邻居关系,重新获取完整的网络拓扑信息。
# 使能OSPFv3进程1的GR能力。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart enable
·     graceful-restart helper enable
graceful-restart helper enable命令用来使能OSPFv3的GR Helper能力。
undo graceful-restart helper enable命令用来关闭OSPFv3的GR Helper能力。
OSPFv3的GR Helper能力处于开启状态。
OSPFv3视图
planned-only:表示只支持计划重启。如果未指定本参数,表示计划重启和非计划重启(即异常重启)都支持。
收到Grace-LSA后,如果支持GR Helper能力则进入Helper模式(此时该邻居称为GR Helper)。在GR Restarter重新建立邻居的时候,GR Helper帮助GR Restarter进行LSDB的同步。
# 使能OSPFv3进程1的GR Helper能力。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart helper enable
·     graceful-restart enable
graceful-restart helper strict-lsa-checking命令用来使能GR Helper严格LSA检查能力。
undo graceful-restart helper strict-lsa-checking命令用来关闭GR Helper严格LSA检查能力。
GR Helper严格LSA检查能力处于关闭状态。
OSPFv3视图
使能GR Helper严格LSA检查能力,当检查到GR Helper设备的LSA发生变化时候,Helper设备退出GR Helper模式。
# 使能OSPFv3进程1的GR Helper严格LSA检查能力。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart helper strict-lsa-checking
graceful-restart interval命令用来配置OSPFv3协议的GR重启间隔时间。
OSPFv3协议的GR重启间隔时间为120秒。
OSPFv3视图
interval:指定OSPFv3协议的GR重启间隔时间(期望重启时间),取值范围为40~1800,单位为秒。
配置此命令的用户需要确保配置的GR重启间隔不小于OSPFv3所有接口的邻居失效时间的最大值,否则可能造成GR重启失败。
# 配置OSPFv3进程1的GR重启间隔时间为100秒。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart interval 100
·     ospfv3 timer dead
import-route命令用来配置引入外部路由信息。
undo import-route命令用来取消引入外部路由信息。
import-route protocol [ as-number ] [ process-id | all-processes | allow-ibgp ] [ allow-direct | cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] *
不引入外部路由信息。
OSPFv3视图
protocol:指定引入的路由协议。
as-number:引入指定AS内的路由。as-number为AS号,取值范围为1~4294967295。只有当protocolbgp4+时该参数可选。当protocolbgp4+时,如果没有指定本参数,则引入所有的IPv6 EBGP路由。建议配置时指定AS号,否则引入的IPv6 EBGP路由数量过多时,会引发设备内存资源紧张等问题。
process-id:路由协议进程号,取值范围为1~65535,缺省值为1。只有当protocolisisv6ospfv3ripng时该参数可选。
all-processes:引入指定路由协议所有进程的路由,只有当protocolripngospfv3isisv6时可以指定该参数。
allow-ibgp:允许引入IBGP路由。只有当protocolbgp4+时该参数可选。
allow-direct:在引入的路由中包含使能了该协议的接口网段路由。如果未指定本参数,在引入协议路由时不会包含使能了该协议的接口网段路由。当allow-directroute-policy route-policy-name参数一起使用时,需要注意路由策略中配置的匹配规则不要与接口路由信息存在冲突,否则会导致allow-direct配置失效。例如,当配置allow-direct参数引入OSPFv3直连时,在路由策略中不要配置if-match route-type匹配条件,否则,allow-direct参数失效。
cost cost-value:路由开销值,取值范围为0~16777214,缺省值为1。
nssa-only:设置Type-7 LSA的P比特位不置位,即在对端路由器上不能转为Type-5 LSA。如果未指定本参数,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
route-policy route-policy-name:配置只能引入符合指定路由策略的路由。route-policy-name为路由策略名称,为1~63个字符的字符串,区分大小写。
tag tag:外部LSA中的标记,取值范围为0~4294967295。如果未指定本参数,将根据default tag命令的配置进行取值。
type type:度量值类型,取值范围为1~2,缺省值为2。
外部路由是指到达自治系统外部的路由,有两类:
·     第一类外部路由(Type1 External):这类路由的可信程度较高,并且和OSPFv3自身路由的开销具有可比性,所以到第一类外部路由的开销等于本路由器到相应的ASBR的开销与ASBR到该路由目的地址的开销之和。
·     第二类外部路由(Type2 External):这类路由的可信度比较低,所以OSPFv3协议认为从ASBR到自治系统之外的开销远远大于在自治系统之内到达ASBR的开销。所以计算路由开销时将主要考虑前者,即到第二类外部路由的开销等于ASBR到该路由目的地址的开销。如果计算出开销值相等的两条路由,再考虑本路由器到相应的ASBR的开销。
该命令不能引入缺省路由。
import-route bgp4+表示只引入EBGP路由;import-route bgp4+ allow-ibgp表示将IBGP路由也引入,容易引起路由环路,请慎用。
import-route nssa-only命令配置后,引入的路由只在NSSA区域产生Type-7 LSA,不会在非NSSA区域产生Type-5 LSA。
# 指定引入进程号为10的RIPng路由为第二类路由,路由开销值为50。
[Sysname] ospfv3
[Sysname-ospfv3-1] import-route ripng 10 type 2 cost 50
# OSPFv3进程100引入OSPFv3进程160发现的路由。
[Sysname-ospfv3-100] import-route ospfv3 160
1.1.39  ispf enable
ispf enable命令用来开启OSPFv3 ISPF功能,即增量SPF计算功能。
undo ispf enable命令用来关闭OSPFv3 ISPF计算功能。
ispf enable
undo ispf enable
OSPFv3 ISPF功能处于开启状态。
OSPFv3视图
使能增量SPF计算功能后,当网络的拓扑结构发生变化影响到最短路径树的结构时,只将受影响的部分节点进行修正,而不重建整棵最短路径树。
# 关闭OSPFv3进程1的增量SPF计算功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] undo ispf enable
log-peer-change命令用来打开邻居状态变化的输出开关。
undo log-peer-change命令用来关闭邻居状态变化的输出开关。
log-peer-change
邻居状态变化的输出开关处于打开状态。
OSPFv3视图
打开邻居状态输出开关后,OSPFv3邻居状态变化时会生成日志信息发送到设备的信息中心,通过设置信息中心的参数,最终决定日志信息的输出规则(即是否允许输出以及输出方向)。(有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。)
# 关闭OSPFv3进程100的邻居状态变化的输出开关。
[Sysname-ospfv3-100] undo log-peer-change
lsa-generation-interval命令用来配置OSPFv3 LSA重新生成的时间间隔。
undo lsa-generation-interval命令用来恢复缺省情况。
OSPFv3 LSA重新生成的最大时间间隔为5秒,最小时间间隔为0毫秒,时间间隔惩罚增量为0毫秒。
OSPFv3视图
maximum-interval:OSPFv3 LSA重新生成的最大时间间隔,取值范围为1~60,单位为秒。
minimum-interval:OSPFv3 LSA重新生成的最小时间间隔,取值范围为10~60000,单位为毫秒。取值为0毫秒时表示不对OSPFv3 LSA重新生成的最小时间间隔进行限制。
incremental-interval:OSPFv3 LSA重新生成的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒。
通过调节LSA重新生成的时间间隔,可以抑制网络频繁变化可能导致的占用过多带宽资源和路由器资源。在网络变化不频繁的情况下,将LSA重新生成时间间隔缩小到minimum-interval,而在网络变化频繁的情况下可以进行相应惩罚,将等待时间按照配置的惩罚增量延长,最大不超过maximum-interval
minimum-intervalincremental-interval配置值不允许大于maximum-interval配置值。
# 设置LSA重新生成的最大时间间隔为2秒,最小时间间隔为100毫秒,惩罚增量为100毫秒。
[Sysname-ospfv3-100] lsa-generation-interval 2 100 100
·     lsa-arrival-interval
maximum load-balancing命令用来配置OSPFv3支持的等价路由的最大条数。
maximum load-balancing number
OSPFv3支持的等价路由的最大条数与系统支持最大等价路由的条数相同。
OSPFv3视图
number:等价路由的最大条数,当number取值为1时,相当于不进行负载分担。
本命令中number参数的取值范围和max-ecmp-num命令相关。通过max-ecmp-num命令配置系统支持的最大等价路由条数为m,并重启设备后,number参数的取值范围将修改为1~m。
# 配置OSPFv3支持的等价路由的最大条数为2。
[Sysname-ospfv3-100] maximum load-balancing 2
·     max-ecmp-num(三层技术-IP路由命令参考/IP路由基础)
non-stop-routing命令用来使能OSPFv3协议的NSR能力。
undo non-stop-routing命令用来关闭OSPFv3协议的NSR能力。
non-stop-routing
OSPFv3的NSR能力处于关闭状态。
OSPFv3视图
各个进程的NSR功能是相互独立的,只对本进程生效。如果存在多个OSPFv3进程,建议在各个进程下使能OSPFv3 NSR功能。
non-stop-routinggraceful-restart enable命令互斥,不能同时配置。
# 使能OSPFv3进程100的NSR能力。
[Sysname-ospfv3-100] non-stop-routing
nssa命令用来配置一个区域为NSSA区域。
undo nssa命令用来恢复缺省情况。
nssa [ default-route-advertise [ cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] * | no-import-route | no-summary | [ translate-always | translate-never ] | suppress-fa | translator-stability-interval value ] *
undo nssa
没有区域被配置为NSSA区域。
OSPFv3区域视图
default-route-advertise:该参数只用于NSSA区域的ABR或ASBR,配置后,对于ABR,不论本地是否存在缺省路由,都将生成一条Type-7 LSA向区域内发布缺省路由;对于ASBR,只有当本地存在缺省路由时,才产生Type-7 LSA向区域内发布缺省路由。
cost cost-value:该缺省路由的度量值,取值范围为0~16777214。如果未指定本参数,缺省路由的度量值将取default-cost命令配置的值。
nssa-only:设置Type-7 LSA的P比特位不置位,即在对端路由器上不能转为Type-5 LSA,对端路由器不能引入Type-7 LSA产生的外部路由。如果未指定本参数,Type-7 LSA的P比特位被置位,即在对端路由器上可以转为Type-5 LSA,对端路由器可以引入Type-7 LSA产生的外部路由(如果本地路由器是ABR,则会检查骨干区域是否存在FULL状态的邻居,当FULL状态的邻居存在时,产生的Type-7 LSA中P比特位不置位)。
route-policy route-policy-name:路由策略名,为1~63个字符的字符串,区分大小写。只有route-policy-name指定的路由策略匹配时,才可以产生一个描述缺省路由的Type-7 LSA发布出去,指定的路由策略会影响Type-7 LSA中的属性。
tag tag:缺省路由的标识,取值范围为0~4294967295。
type type:该NSSA LSA的类型,取值范围为1~2,缺省类型为2。
no-import-route:该参数用于禁止将AS外部路由以Type-7 LSA的形式引入到NSSA区域中,这个参数通常只用在既是NSSA区域的ABR,也是OSPFv3自治系统的ASBR的路由器上,以保证所有外部路由信息能正确地进入OSPFv3路由域。
no-summary:该参数只用于NSSA区域的ABR,配置后,NSSA ABR只通过Type-3 LSA向区域内发布一条缺省路由,不再向区域内发布任何其它Type-3 LSA(这种区域又称为Totally NSSA区域)。
translate-always:指定ABR为NSSA区域的Type-7 LSA转换为Type-5 LSA的转换路由器。
translate-never:指定ABR不能将NSSA区域的Type-7 LSA转换为Type-5 LSA。
suppress-fa:指定当Type-7 LSA转换为Type-5 LSA时,生成的Type-5 LSA不携带Forwarding Address。
translator-stability-interval value:当有新的设备成为NSSA区域的Type-7 LSA转换为Type-5 LSA的转换路由器后,原Type-7 LSA转换为Type-5 LSA的转换路由器保持转换能力的时间。value为保持时间,取值范围为0~900,单位为秒,缺省值为0,即不保持。
如果要将一个区域配置成NSSA区域,则该区域中的所有路由器都必须配置本命令。
# 将区域1配置成NSSA区域。
[Sysname] ospfv3 120
[Sysname-ospfv3-120] area 1
[Sysname-ospfv3-120-area-0.0.0.1] nssa
·     default-cost (OSPFv3 area view)
1.1.45  ospfv3
ospfv3命令用来启动OSPFv3进程,并进入OSPFv3视图。
undo ospfv3命令用来关闭指定的OSPFv3进程。
ospfv3 [ process-id | vpn-instance vpn-instance-name ] *
undo ospfv3 [ process-id ]
系统没有运行OSPFv3进程。
process-id:OSPFv3进程号,取值范围为1~65535,缺省值为1。
vpn-instance vpn-instance-name:指定OSPFv3进程所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示OSPFv3位于公网中。
只有在OSPFv3视图下配置了Router ID,OSPFv3进程才能正常运行,否则只能看到该进程,但无法生成LSA。
# 启动进程号为120的OSPFv3进程并配置路由器的Router ID为1.1.1.1。
[Sysname-ospfv3-120] router-id 1.1.1.1
·     router-id
1.1.46  ospfv3 area
ospfv3 area命令用来在接口上使能OSPFv3功能,并指定其所属区域。
undo ospfv3 area命令用来在指定接口上关闭OSPFv3功能。
ospfv3 process-id area area-id [ instance instance-id ]
undo ospfv3 process-id area area-id [ instance instance-id ]
接口上的OSPFv3功能处于关闭状态。
instance-id:接口所属的实例ID,取值范围为0~255,缺省值为0。
# 在接口GigabitEthernet1/2/0/1上启动OSPFv3实例1的运行,并使能到Area 1中。
[Sysname] interface gigabitethernet 1/2/0/1
[Sysname-GigabitEthernet1/2/0/1] ospfv3 1 area 1 instance 1
1.1.47  ospfv3 authentication-mode
ospfv3 authentication-mode命令用来设置接口上的OSPFv3报文的验证模式。
undo ospfv3 authentication-mode命令用来取消接口上的OSPFv3报文的验证模式的配置。
ospfv3 authentication-mode keychain keychain-name [ instance instance-id ]
undo ospfv3 authentication-mode [ instance instance-id ]
接口不对OSPFv3报文进行验证。
instance instance-id:接口所属的实例ID,取值范围为0~255,缺省值为0。
在使能了OSPFv3的接口上使用keychain验证模式时,报文的收、发过程如下:
# 配置接口GigabitEthernet1/2/0/1上OSPFv3使用keychain验证模式,keychain名为test。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 authentication-mode keychain test
1.1.48  ospfv3 bfd enable
ospfv3 bfd enable命令用来在运行OSPFv3的接口下使能BFD功能。
undo ospfv3 bfd enable命令用来在运行OSPFv3的接口下关闭BFD功能。
ospfv3 bfd enable [ instance instance-id ]
undo ospfv3 bfd enable [ instance instance-id ]
运行OSPFv3的接口的BFD功能处于关闭状态。
BFD(Bidirectional Forwarding Detection,双向转发检测)能够为OSPFv3邻居之间的链路提供快速检测功能。当邻居之间的链路出现故障时,加快OSPFv3协议的收敛速度。
OSPFv3通过BFD控制报文实现BFD功能。
# 使能接口GigabitEthernet1/2/0/1的OSPFv3实例1的BFD功能。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 bfd enable instance 1
1.1.49  ospfv3 cost
ospfv3 cost命令用来配置运行不同OSPFv3实例的接口的开销值。
undo ospfv3 cost命令用来取消运行不同OSPFv3实例的接口的开销值的配置。
ospfv3 cost cost-value [ instance instance-id ]
undo ospfv3 cost [ instance instance-id ]
路由器接口按照带宽自动计算运行OSPFv3协议所需的开销;对于Loopback接口,缺省值为0。
cost-value:接口运行OSPFv3协议的路由开销,Loopback接口的取值范围为0~65535,其他接口的取值范围为1~65535。
# 指定运行OSPFv3实例1的接口GigabitEthernet1/2/0/1的开销为33。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 cost 33 instance 1
1.1.50  ospfv3 dr-priority
ospfv3 dr-priority命令用来配置运行不同OSPFv3实例的接口的DR优先级。
undo ospfv3 dr-priority命令用来取消运行不同OSPFv3实例的接口的DR优先级的配置。
ospfv3 dr-priority priority [ instance instance-id ]
undo ospfv3 dr-priority [ instance instance-id ]
接口的DR优先级为1。
priority:接口的DR优先级,取值范围为0~255。
接口的DR优先级决定了该接口在选举DR/BDR时所具有的资格,优先级高的在选举时被首先考虑。
# 设置运行OSPFv3实例1的接口GigabitEthernet1/2/0/1在选举DR/BDR时的优先级为8。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 dr-priority 8 instance 1
1.1.51  ospfv3 fast-reroute lfa-backup exclude
ospfv3 fast-reroute lfa-backup exclude命令用来禁止接口参与LFA(Loop Free Alternate)计算。
undo ospfv3 fast-reroute lfa-backup exclude命令用来取消禁止接口参与LFA计算配置的配置。
ospfv3 fast-reroute lfa-backup exclude [ instance instance-id ]
undo ospfv3 fast-reroute lfa-backup exclude [ instance instance-id ]
接口参与LFA计算。
接口缺省参与LFA计算,有资格成为备份接口。配置本功能后,接口不会被选为备份接口。
# 禁止接口GigabitEthernet1/2/0/1参与LFA计算。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 fast-reroute lfa-backup exclude
1.1.52  ospfv3 ipsec-profile
ospfv3 ipsec-profile命令用来在OSPFv3接口上应用IPsec安全框架。
undo ospfv3 ipsec-profile命令用来取消OSPFv3接口上应用的IPsec安全框架。
ospfv3 ipsec-profile profile-name [ instance instance-id ]
undo ospfv3 ipsec-profile [ instance instance-id ]
OSPFv3接口没有应用IPsec安全框架。
# 配置OSPFv3接口GigabitEthernet1/2/0/1上应用的IPsec安全框架为profile001。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 ipsec-profile profile001
1.1.53  ospfv3 mib-binding
ospfv3 mib-binding命令用来配置OSPFv3进程绑定MIB。
undo ospfv3 mib-binding命令用来恢复缺省情况。
ospfv3 mib-binding process-id
MIB绑定在进程号最小的OSPFv3进程上。
如果指定的process-id不存在,配置OSPFv3进程绑定命令时将会提示OSPFv3进程不存在,无法完成配置。
如果配置了OSPFv3进程绑定MIB,若删除process-id对应的OSPFv3进程,则同时删除OSPFv3进程绑定MIB配置,MIB绑定到进程号最小的OSPFv3进程上。
# 配置OSPFv3进程100绑定MIB。
[Sysname] ospfv3 mib-binding 100
1.1.54  ospfv3 mtu-ignore
ospfv3 mtu-ignore命令用来配置接口在进行DD报文交换时忽略MTU检查。
undo ospfv3 mtu-ignore命令用来取消接口在进行DD报文交换时忽略MTU检查的配置。
ospfv3 mtu-ignore [ instance instance-id ]
undo ospfv3 mtu-ignore [ instance instance-id ]
接口在进行DD报文交换时执行MTU检查。
双方的接口MTU必须相同才能建立邻居关系。
# 配置运行OSPFv3实例1的接口GigabitEthernet1/2/0/1在进行DD报文交换时忽略MTU检查。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 mtu-ignore instance 1
1.1.55  ospfv3 network-type
ospfv3 network-type命令用来配置OSPFv3接口的网络类型。
undo ospfv3 network-type命令用来取消OSPFv3接口的网络类型的配置。
ospfv3 network-type { broadcast | nbma | p2mp [ unicast ] | p2p } [ instance instance-id ]
undo ospfv3 network-type [ instance instance-id ]
当接口封装的链路层协议不同时,OSPFv3接口网络类型的缺省值也不同:
·     当接口封装的链路层协议是Ethernet、FDDI时,OSPFv3接口网络类型的缺省值为广播类型;
·     当接口封装的链路层协议是PPP、LAPB、HDLC或POS时,OSPFv3接口网络类型的缺省值为P2P。
broadcast:配置接口的网络类型为广播类型。
nbma:配置接口的网络类型为NBMA类型。
p2mp:配置接口的网络类型为点到多点类型。
unicast:P2MP类型支持单播发送报文,缺省情况下是组播方式发送报文。
p2p:配置接口的网络类型为点到点类型。
如果在广播网络上有不支持组播地址的路由器,可以将接口的网络类型改为NBMA。
在NBMA网络中,如果任意两台路由器之间都有一条虚电路直接可达,或者说,这个网络是全连通的,那么可以把OSPFv3接口的网路类型配置为NBMA;否则,需要把OSPFv3接口的网络类型配置为点到多点,这样,两台不能直接可达的路由器之间可以通过一台与两者都直接可达的路由器来交换路由信息。
接口的网络类型为NBMA或P2MP(unicast)时,必须使用peer命令来配置邻接点。
接口的网络类型为P2MP(unicast)时,OSPFv3协议在该接口上发送的报文均为单播报文。
# 设置运行OSPFv3的接口GigabitEthernet1/2/0/1网络类型为NBMA。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 network-type nbma
·     ospfv3 dr-priority
1.1.56  ospfv3 peer
ospfv3 peer命令用来指定邻居接口的链路本地地址,并指定该邻居是否有选举权。
undo ospfv3 peer命令用来取消指定邻居接口的链路本地地址的配置。
ospfv3 peer ipv6-address [ cost cost-value | dr-priority priority ] [ instance instance-id ]
undo ospfv3 peer ipv6-address [ instance instance-id ]
未指定邻居接口的链路本地地址。
ipv6-address:邻居的链路本地地址。
cost cost-value:表示网络邻居的开销,取值范围为1~65535。
dr-priority priority:表示网络邻居的优先级,取值范围为0~255,缺省值为1。
当路由器的接口类型为如下网络类型时,需要为其指定相邻路由器IP地址:
·     NBMA网络
·     P2MP网络(仅当接口选择单播形式发送报文时,需要此配置)
由于无法通过广播Hello报文的形式发现相邻路由器,必须手工指定相邻路由器的本地链路地址。对于NBMA网络,可以指定该相邻路由器是否有选举权等。
# 在运行OSPFv3协议的接口GigabitEthernet1/2/0/1上指定邻居的链路本地地址为FE80::1111。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 peer fe80::1111
1.1.57  ospfv3 prefix-suppression
ospfv3 prefix-suppression命令用来抑制接口进行前缀发布。
undo ospfv3 prefix-suppression命令用来取消抑制接口进行前缀发布的配置。
ospfv3 prefix-suppression [ disable ] [ instance instance-id ]
undo ospfv3 prefix-suppression [ instance instance-id ]
不抑制接口进行前缀发布。
disable:不抑制接口进行前缀发布。
如果OSPFv3进程配置了抑制前缀发布,但某个接口不想进行抑制,此时可以配置本命令并指定disable参数。
# 抑制接口GigabitEthernet1/2/0/1进行前缀发布。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 prefix-suppression
prefix-suppression
1.1.58  ospfv3 primary-path-detect bfd
ospfv3 primary-path-detect bfd命令用来使能OSPFv3协议中主用链路的BFD检测功能。
undo ospfv3 primary-path-detect bfd命令用来关闭OSPFv3协议中主用链路的BFD检测功能。
ospfv3 primary-path-detect bfd { ctrl | echo } [ instance instance-id ]
undo ospfv3 primary-path-detect bfd [ instance instance-id ]
OSPFv3协议中主用链路的BFD检测功能处于关闭状态。
ctrl:配置通过工作于控制报文方式的BFD会话对主用链路进行检测。
echo:配置通过工作于echo报文方式的BFD会话对主用链路进行检测。
配置本功能后,OSPFv3协议的快速重路由特性中的主用链路将使用BFD进行检测。
# 在接口GigabitEthernet1/2/0/1上配置OSPFv3协议快速重路由特性中主用链路使能BFD(Echo方式)检测功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] quit
[Sysname] bfd echo-source-ipv6 1::1
[Sysname-GigabitEthernet1/2/0/1] ospfv3 primary-path-detect bfd echo
1.1.59  ospfv3 timer dead
ospfv3 timer dead命令用来配置OSPFv3的邻居失效时间。
undo ospfv3 timer dead命令用来取消OSPFv3的邻居失效时间的配置。
ospfv3 timer dead seconds [ instance instance-id ]
undo ospfv3 timer dead [ instance instance-id ]
P2P、Broadcast类型接口的OSPFv3邻居失效的时间为40秒;P2MP、NBMA类型接口的OSPFv3邻居失效的时间为120秒。
seconds:OSPFv3邻居失效的时间,取值范围为1~65535,单位为秒。
OSPFv3邻居的失效时间是指:在该时间间隔内,若未收到邻居的Hello报文,就认为该邻居已失效。dead seconds值至少应为hello seconds值的4倍,同一网段上的接口的dead seconds也必须相同。
# 配置接口GigabitEthernet1/2/0/1上的邻居失效时间为60秒。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 timer dead 60
·     ospfv3 timer hello
1.1.60  ospfv3 timer hello
ospfv3 timer hello命令用来配置接口发送Hello报文的时间间隔。
undo ospfv3 timer hello命令用来取消接口发送Hello报文的时间间隔的配置。
ospfv3 timer hello seconds [ instance instance-id ]
undo ospfv3 timer hello [ instance instance-id ]
P2P、Broadcast类型接口发送Hello报文的时间间隔为10秒;P2MP、NBMA类型接口发送Hello报文的时间间隔为30秒。
seconds的值越小,发现网络拓扑改变的速度越快,对系统资源的开销也就越大。同一网段上的接口的seconds必须相同。
# 配置接口GigabitEthernet1/2/0/1发送Hello报文的时间间隔为20秒。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 timer hello 20
·     ospfv3 timer dead
1.1.61  ospfv3 timer poll
ospfv3 timer poll命令用来配置在NBMA接口上向状态为down的邻居路由器发送轮询Hello报文的时间间隔。
undo ospfv3 timer poll命令用来取消在NBMA接口上向状态为down的邻居路由器发送轮询Hello报文的时间间隔的配置。
ospfv3 timer poll seconds [ instance instance-id ]
undo ospfv3 timer poll [ instance instance-id ]
在NBMA接口上向状态为down的邻居路由器发送轮询Hello报文的时间间隔为120秒。
seconds:向状态为down的邻居路由器发送轮询Hello报文的时间间隔,取值范围为1~65535,单位为秒。
在NBMA的网络上,当邻居失效后,将按轮询时间间隔定期地发送Hello报文。用户可配置轮询时间间隔以指定该接口在与相邻路由器构成邻居关系之前发送Hello报文的时间间隔。
发送轮询Hello报文的时间间隔至少应为发送Hello报文时间间隔的4倍。
# 配置接口GigabitEthernet1/2/0/1发送轮询Hello报文的时间间隔为120秒。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 timer poll 120
1.1.62  ospfv3 timer retransmit
ospfv3 timer retransmit命令用来配置接口重传LSA的时间间隔。
undo ospfv3 timer retransmit命令用来取消接口重传LSA的时间间隔的配置。
ospfv3 timer retransmit seconds [ instance instance-id ]
undo ospfv3 timer retransmit [ instance instance-id ]
接口重传LSA的时间间隔为5秒。
seconds:接口重传LSA的时间间隔,取值范围为1~3600,单位为秒。
相邻路由器重传LSA时间间隔的值不要设置得太小,否则将会引起不必要的重传。
# 指定运行OSPFv3实例1的接口GigabitEthernet1/2/0/1重传LSA的时间间隔为12秒。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 timer retransmit 12 instance 1
1.1.63  ospfv3 trans-delay
ospfv3 trans-delay命令用来配置接口对LSA的传输延迟时间。
undo ospfv3 trans-delay命令用来取消接口对LSA的传输延迟时间的配置。
ospfv3 trans-delay seconds [ instance instance-id ]
undo ospfv3 trans-delay [ instance instance-id ]
接口对LSA的传输延迟时间为1秒。
LSA在本路由器的LSDB中会随时间老化(LSA的老化时间每秒钟加1),但在网络的传输过程中却不会,所以有必要在发送之前在LSA的老化时间上增加一定的延迟时间。此配置对低速率的网络尤其重要。
# 指定运行OSPFv3实例1的接口GigabitEthernet1/2/0/1洪泛LSA的时延值为3秒。
[Sysname-GigabitEthernet1/2/0/1] ospfv3 trans-delay 3 instance 1
1.1.64  pic
pic命令用来使能前缀无关收敛功能。
undo pic命令用来关闭前缀无关收敛功能。
undo pic
前缀无关收敛功能处于使能状态。
OSPFv3视图
additional-path-always:支持非直连的次优路由作为备份。
PIC(Prefix Independent Convergence,前缀无关收敛),即收敛时间与前缀数量无关,加快收敛速度。传统的路由计算快速收敛都与前缀数量相关,收敛时间与前缀数量成正比。OSPFv3只实现区域间路由以及外部路由的前缀无关收敛。
OSPFv3快速重路由功能和PIC同时配置时,OSPFv3快速重路由功能生效。
# 使能OSPFv3协议的PIC支持非直连次优路由做备份功能。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] pic additional-path-always
1.1.65  preference
preference命令用来配置OSPFv3协议的路由优先级。
undo preference命令用来取消OSPFv3协议的路由优先级的配置。
undo preference [ ase ]
对于自治系统内部路由,OSPFv3协议的路由优先级为10;对于自治系统外部路由,OSPFv3协议的路由优先级为150。
OSPFv3视图
ase:配置OSPFv3协议对自治系统外部路由的优先级。如果未指定该参数,则配置的是OSPFv3协议对自治系统内部路的优先级。
preference:OSPFv3路由的优先级,取值范围为1~255。优先级的值越小,其实际的优先程度越高。
route-policy route-policy-name:应用路由策略,对特定的路由设置优先级。route-policy-name是路由策略名称,为1~63个字符的字符串,区分大小写。
由于路由器上可能同时运行多个动态路由协议,就存在各个路由协议之间路由信息共享和选择的问题,所以为每一种路由协议指定了一个缺省的优先级。在不同的路由协议发现去往同一目的地的多条路由时,优先级高的协议发现的路由将被选中以转发IPv6报文。
# 配置OSPFv3协议路由的优先级为150。
[Sysname] ospfv3
[Sysname-ospfv3-1] preference 150
1.1.66  prefix-suppression
prefix-suppression命令用来抑制OSPFv3进程进行前缀发布。
undo prefix-suppression命令用来恢复缺省情况。
prefix-suppression
不抑制OSPFv3进程进行前缀发布。
OSPFv3视图
接口使能OSPFv3后,会将接口下的所有网段路由都通过LSA发布,但有时候网段路由是不希望被发布的。通过前缀抑制配置,可以减少LSA中携带不需要的前缀,即不发布某些网段路由,从而提高网络安全性,加快路由收敛。
全局配置前缀抑制不能抑制LoopBack接口和处于silent-interface状态接口对应的前缀。如果想对Loopback接口或处于silent-interface状态接口进行抑制,可以通过接口下配置前缀抑制(ospfv3 prefix-suppression命令)来实现。
当使能前缀抑制时,具体处理如下:
·     Type-8 LSA中不发布处于抑制的接口前缀信息。
·     对于广播网/NBMA网络,DR在生成Type-9 LSA引用Type-2 LSA时,不发布处于抑制的接口前缀信息。
·     对于P2P/P2MP网络,生成Type-9 LSA引用Type-1 LSA时,不发布处于抑制的接口前缀信息。
# 抑制OSPFv3进程100的前缀发布。
[Sysname-ospfv3-100] prefix-suppression
1.1.67  reset ospfv3 event-log
reset ospfv3 event-log命令用于清除OSPFv3的日志信息。
reset ospfv3 [ process-id ] event-log [ lsa-flush | peer | spf ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,则清除所有OSPFv3进程的日志信息。
lsa-flush:清除LSA老化日志信息。
peer:清除邻居的日志信息。
spf:清除路由计算的日志信息。
如果未指定日志类型,则所有日志信息都被清除。
# 清除所有OSPFv3进程路由计算的日志信息。
<Sysname> reset ospfv3 event-log spf
·     display ospfv3 event-log
1.1.68  reset ospfv3 process
reset ospfv3 process命令用来重启OSPFv3进程。
reset ospfv3 [ process-id ] process [ graceful-restart ]
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,则重启所有OSPFv3进程。
graceful-restart:以GR方式重启OSPFv3进程。
使用reset ospfv3 process命令重启OSPFv3,可以获得如下结果:
·     可以立即清除无效的LSA,而不必等到LSA超时。
·     方便重新选举DR、BDR。
·     重启前的OSPFv3配置不会丢失。
执行该命令后,系统提示用户确认是否重启OSPFv3协议。
# 重启所有OSPFv3进程。
<Sysname> reset ospfv3 process
Reset OSPFv3 process? [Y/N]:y
1.1.69  reset ospfv3 redistribution
reset ospfv3 redistribution命令用来重新向OSPFv3引入外部路由。
reset ospfv3 [ process-id ] redistribution
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,所有OSPFv3进程都将重新引入外部路由。
# 重新向OSPFv3引入外部路由。
<Sysname> reset ospfv3 redistribution
1.1.70  reset ospfv3 statistics
reset ospfv3 statistics命令用来清除OSPFv3的统计信息。
reset ospfv3 [ process-id ] statistics
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,则清除所有OSPFv3进程的统计信息。
# 清除所有OSPFv3进程的统计信息。
<Sysname> reset ospfv3 statistics
1.1.71  router-id
router-id命令用来配置运行OSPFv3协议的路由器的Router ID。
undo router-id命令用来恢复缺省情况。
router-id router-id
undo router-id
运行OSPFv3协议的路由器没有Router ID。
OSPFv3视图
router-id:路由器标识符,IPv4地址格式。
Router ID是一台运行OSPFv3协议的路由器在自治系统中的唯一标识。如果用户没有指定路由器的Router ID,则OSPFv3进程无法运行。
同一台设备上以及同一自治系统中不同的OSPFv3进程,必须为其指定不同的Router ID。
# 设置OSPFv3进程1的Router ID为10.1.1.3。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] router-id 10.1.1.3
·     ospfv3
1.1.72  silent-interface (OSPFv3 view)
silent-interface命令用来禁止接口收发OSPFv3报文。
undo silent-interface命令用来取消禁止接口收发OSPFv3报文的配置。
允许接口收发OSPFv3报文。
OSPFv3视图
interface-type interface-number:接口类型和接口号,禁止指定OSPFv3接口收发OSPFv3报文。
all:禁止所有OSPFv3接口收发OSPFv3报文。
不同的进程可以对同一接口禁止收发OSPFv3报文,但silent-interface命令只对本进程已经使能的OSPFv3接口起作用,对其它进程的接口不起作用。
# 禁止接口GigabitEthernet1/2/0/1在OSPFv3进程100和200中收发OSPFv3报文。
[Sysname-ospfv3-100] router-id 10.100.1.9
[Sysname-ospfv3-100] silent-interface gigabitethernet 1/2/0/1
[Sysname-ospfv3-100] quit
[Sysname] ospfv3 200
[Sysname-ospfv3-200] router-id 20.100.1.9
[Sysname-ospfv3-200] silent-interface gigabitethernet 1/2/0/1
1.1.73  snmp context-name
snmp context-name命令用来创建一个管理OSPFv3的SNMP实体所使用的上下文名称。
不存在管理OSPFv3的SNMP实体所使用的上下文名称。
OSPFv3视图
context-name:管理OSPFv3的SNMP实体所使用的上下文名称,为1~32个字符的字符串,区分大小写。
OSPFv3使用MIB(Management Information Base,管理信息库)为NMS(Network Management System,网络管理系统)提供对OSPFv3实例的管理,但标准OSPFv3 MIB中定义的MIB为单实例管理对象,无法对多个OSPFv3实例进行管理。因此,参考RFC 4750中对OSPF多实例的管理方法,为管理OSPFv3的SNMP实体定义一个上下文名称,以此来区分不同的OSPFv3实例,实现对多个OSPFv3实例进行管理。由于上下文名称只是SNMPv3独有的概念,对于SNMPv1/v2c,会将团体名映射为上下文名称以对不同协议进行区分。
# 配置管理OSPFv3进程1的SNMP实体所使用的上下文名称为mib。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] snmp context-name mib
1.1.74  snmp trap rate-limit
snmp trap rate-limit命令用来配置OSPFv3在指定时间间隔内允许输出的告警信息条数。
undo snmp trap rate-limit命令用来恢复缺省情况。
OSPFv3在10内秒允许输出7条告警信息。
OSPFv3视图
interval trap-interval:指定时间间隔,取值范围为2~60,单位为秒。
count trap-number:在指定时间间隔内允许输出的告警信息条数,取值范围为0~300,为0时表示不输出告警信息。
# 配置OSPFv3在5秒内允许输出10条告警信息。
[Sysname-ospfv3-100] snmp trap rate-limit interval 5 count 10
1.1.75  snmp-agent trap enable ospfv3
snmp-agent trap enable ospfv3命令用来开启OSPFv3的告警功能。
undo snmp-agent trap enable ospfv3命令用来关闭OSPFv3的告警功能。
snmp-agent trap enable ospfv3 [ grrestarter-status-change | grhelper-status-change | if-state-change | if-cfg-error | if-bad-pkt | neighbor-state-change | nssatranslator-status-change | virtif-bad-pkt | virtif-cfg-error | virtif-state-change | virtgrhelper-status-change | virtneighbor-state-change ] *
undo snmp-agent trap enable ospfv3 [ grrestarter-status-change | grhelper-status-change | if-state-change | if-cfg-error | if-bad-pkt | neighbor-state-change | nssatranslator-status-change | virtif-bad-pkt | virtif-cfg-error | virtif-state-change | virtgrhelper-status-change | virtneighbor-state-change] *
OSPFv3的告警功能处于开启状态。
grrestarter-status-change:GR Restarter状态变化。
grhelper-status-change:邻居GR Helper状态变化。
if-state-change:接口状态变化。
if-cfg-error:接口配置错误。
if-bad-pkt:接口接收了错误报文。
neighbor-state-change:邻居状态变化。
nssatranslator-status-change:NSSA转换路由器状态变化。
virtif-bad-pkt:虚接口接收错误报文。
virt-cfg-error:虚接口配置错误。
virtif-state-change:虚接口状态变化。
virtgrhelper-status-change:虚接口邻居GR Helper状态变化。
virtneighbor-state-change:虚接口邻居状态变化。
# 关闭OSPFv3的告警功能。
[Sysname] undo snmp-agent trap enable ospfv3
1.1.76  spf-schedule-interval
spf-schedule-interval命令用来配置OSPFv3路由计算的时间间隔。
undo spf-schedule-interval命令用来恢复缺省情况。
OSPFv3路由计算的最大时间间隔为5秒,最小时间间隔为50毫秒,时间间隔惩罚增量为200毫秒。
OSPFv3视图
maximum-interval:OSPFv3路由计算的最大时间间隔,取值范围为1~60,单位为秒。
minimum-interval:OSPFv3路由计算的最小时间间隔,取值范围为10~60000,单位为毫秒。
incremental-interval:OSPFv3路由计算的时间间隔惩罚增量,取值范围为10~60000,单位为毫秒。
根据本地维护的LSDB,运行OSPFv3协议的路由器通过SPF算法计算出以自己为根的最短路径树,并根据这一最短路径树决定到目的网络的下一跳。通过调节SPF的计算间隔,可以抑制网络频繁变化可能导致的占用过多带宽资源和路由器资源。
本命令在网络变化不频繁的情况下将连续路由计算的时间间隔缩小到minimum-interval,而在网络变化频繁的情况下可以进行相应惩罚,将等待时间按照配置的惩罚增量延长,最大不超过maximum-interval
# 设置OSPFv3路由计算最大时间间隔为10秒,最小时间间隔为500毫秒,惩罚增量为300毫秒。
[Sysname-ospfv3-100] spf-schedule-interval 10 500 300
1.1.77  stub (OSPFv3 area view)
stub命令用来配置一个区域为Stub区域。
undo stub命令用来恢复缺省情况。
undo stub
没有区域被设置为Stub区域。
OSPFv3区域视图
default-route-advertise-always:该参数用于设置总是通告默认路由。
no-summary:该参数只用于Stub区域的ABR,配置后ABR只向区域内发布一条缺省路由的Inter-Area-Prefix-LSA。这种既没有AS-external-LSA,也没有其它Inter-Area-Prefix-LSA、Inter-Area-Router-LSA的Stub区域,又称为Totally Stub区域。
如果需要在ABR上取消配置no-summary参数,可以通过重新执行stub命令覆盖之前配置即可。
# 将OSPFv3区域1设置为Stub区域。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 1
[Sysname-ospfv3-1-area-0.0.0.1] stub
1.1.78  stub-router
stub-router命令用来配置当前路由器为Stub路由器。
undo stub-router命令用来恢复缺省情况。
stub-router r-bit [ include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } ] *
stub-router max-metric [ external-lsa [ max-metric-value ] | summary-lsa [ max-metric-value ] | include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } ] *
undo stub-router
当前路由器没有被配置为Stub路由器。
OSPFv3视图
r-bit:路由器发布的Type-1 LSA中,options域的R-bit将清除。
max-metric:路由器发布的Type-1 LSA的链路度量值将设置为最大值65535。
external-lsa max-metric-value:路由器发布的外部LSA链路度量值。max-metric-value表示链路度量值,取值范围为1~16777215,缺省值为16711680。
summary-lsa max-metric-value:路由器发布的Type-3 LSA和Type-4 LSA链路度量值。max-metric-value表示链路度量值,取值范围为1~16777215,缺省值为16711680。
include-stub:路由器发布的引用Type-1 LSA的Type-9 LSA中,链路度量值将设置为最大值65535。
on-startup seconds:在路由器重启期间,路由器做为Stub路由器。seconds表示超时时间,取值范围为5~86400,单位为秒。
wait-for-bgp seconds:在路由器重启后,等待BGP路由收敛期间,路由器做为Stub路由器。seconds表示超时时间,取值范围为5~86400,单位为秒,缺省值为600秒。
将当前路由器配置为Stub路由器的功能,可通过R-bit和max-metric两种模式来实现:
·     R-bit模式:通过清除该路由器发布Type-1 LSA中options域的R-bit,使其他路由器只能计算到该路由器但是不会通过该路由器来转发数据。
·     max-metric模式:该路由器发布的Type-1 LSA的链路度量值将设为最大值65535,这样其邻居计算出这条路由的开销就会很大,如果邻居上有到这个目的地址开销更小的路由,则数据不会通过这个Stub路由器转发。
# 配置当前路由器为Stub路由器。
[Sysname-ospfv3-100] stub-router r-bit
1.1.79  transmit-pacing
transmit-pacing用来配置接口发送LSU报文的时间间隔和一次发送LSU报文的最大个数。
undo transmit-pacing命令用来恢复缺省情况。
接口发送LSU报文的时间间隔为20毫秒,一次最多发送3个LSU报文。
OSPFv3视图
interval interval:接口发送LSU报文的时间间隔,interval的取值范围为10~1000,单位为毫秒。当路由器上使能OSPFv3功能的接口数比较多时,建议增大该值,以控制路由器每秒钟发送LSU报文的总数。
count count:接口一次发送LSU报文的最大个数,count的取值范围为1~200。当路由器上使能OSPFv3功能的接口数比较多时,建议减小该值,以控制路由器每秒钟发送LSU报文的总数。
# 配置OSPFv3进程1的所有接口发送LSU报文的时间间隔为30毫秒,一次最多发送10个LSU报文。
[Sysname] ospfv3 1
[Sysname-ospfv3-1] transmit-pacing interval 30 count 10
1.1.80  vlink-peer (OSPFv3 area view)
vlink-peer命令用来创建并配置一条虚连接。
undo vlink-peer命令用来删除一条已有的虚连接。
vlink-peer router-id [ dead seconds | hello seconds | instance instance-id | ipsec-profile profile-name | keychain keychain-name | retransmit seconds | trans-delay seconds ] *
undo vlink-peer router-id [ dead | hello | ipsec-profile | keychain | retransmit | trans-delay ] *
不存在虚连接。
OSPFv3区域视图
router-id:虚连接邻居的路由器ID。
dead seconds:失效时间间隔,取值范围为1~32768,单位为秒,缺省值为40秒。该值必须和与其建立虚连接路由器的dead seconds值相等,并至少为hello seconds值的4倍。
hello seconds:接口发送Hello报文的时间间隔,取值范围为1~8192,单位为秒,缺省值为10秒。该值必须和与其建立虚连接路由器上的hello seconds值相等。
instance instance-id:设置虚连接的实例ID,取值范围为0~255,缺省值为0。
ipsec-profile profile-name:应用IPsec安全框架。profile-name为IPsec安全框架名称,为1~63个字符的字符串,不区分大小写。IPsec安全框架的具体情况请参见“安全配置指导”中的“IPsec”。
keychain:使用keychain验证模式。
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。
retransmit seconds:接口重传LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为5。
trans-delay seconds:接口延迟发送LSA报文的时间间隔,取值范围为1~3600,单位为秒,缺省值为1。
对于没有和骨干区域直接相连的非骨干区域,或者不连续的骨干区域来说,可以使用vlink-peer命令建立逻辑上的连通性。在某种程度上,可以将虚连接看作一个普通的使能了OSPFv3的接口,因为在其上配置的hellodeadretransmittrans-delay等参数的原理是类似的。
虚连接的两端必须是ABR,vlink-peer命令必须在两端同时配置才可生效。
各参数取值规则如下:
·     hello值越小,发现网络变化的速度越快,消耗的网络资源也就越多。
·     不能将retransmit值设置的太小,否则将会引起不必要的重传。网络速度相对较慢的时候应把该值设的更大一些。
·     设置trans-delay值时必须考虑接口的发送延迟。
在OSPFv3虚连接下配置的验证模式,其优先级高于在骨干区域下配置的验证模式。只有在OSPFv3虚连接下未配置验证模式时,骨干区域下配置的验证模式才会对该虚连接生效。
在OSPFv3虚连接使用keychain验证模式时,报文的收、发过程如下:
·     OSPFv3在发送报文前,会先从keychain获取当前的有效发送key,然后发送报文。如果当前不存在有效发送key,则不会发送报文。
·     OSPFv3在收到报文后,会根据报文携带的key的标识符从keychain中获取有效接收key,根据该key的认证算法和认证密钥对报文进行校验,校验成功后再对报文进行下一步处理。如果报文校验失败,或者根据报文中携带的key的标识符无法从keychain中获取到有效接收key,则该报文将被丢弃。
对于keychain认证算法和key的标识符的范围,OSPFv3的支持情况如下:
·     OSPFv3仅支持HMAC-SHA-256认证算法。
·     OSPFv3仅支持标识符取值范围为0~65535的key。
# 创建一条到10.10.0.3的虚连接。
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] vlink-peer 10.10.0.3
·     display ospfv3 vlink
