选择区域语言: EN CN HK
03-接口管理命令参考
03-WAN接口命令
本章节下载  (509.70 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/SR_Router/SR6600-X/Command/Command_Manual/H3C_SR6600_SR6600-X_CR-R7612-6W100/03/201809/1111952_30005_0.htm
03-WAN接口命令
1 WAN接口
1.1 WAN接口公共命令
1.1.1 bandwidth
1.1.2 default
1.1.3 description
1.1.4 shutdown
1.1.5 timer-hold
1.1.6 timer-hold retry
1.2 同步串口配置命令
1.2.1 baudrate
1.2.2 code
1.2.3 crc
1.2.4 clock
1.2.5 detect dcd
1.2.6 detect dsr-dtr
1.2.7 display interface serial
1.2.8 idle-code
1.2.9 interface serial
1.2.10 invert receive-clock
1.2.11 invert transmit-clock
1.2.12 itf
1.2.13 link-protocol
1.2.14 loopback
1.2.15 mtu
1.2.16 reset counters interface
1.2.17 reverse-rts
1.2.18 sub-interface rate-statistic
1.2.19 virtualbaudrate
1.3 CE1接口基本配置命令
1.3.1 alarm-detect
1.3.2 cable (CE1 interface)
1.3.3 channel-set (CE1 interface)
1.3.4 clock (CE1 interface)
1.3.5 clock-change auto
1.3.6 code (CE1 interface)
1.3.7 controller e1
1.3.8 data-coding (CE1 interface)
1.3.9 detect-ais
1.3.10 display controller e1
1.3.11 frame-format (CE1 interface)
1.3.12 idle-code (CE1 interface)
1.3.13 itf (CE1 interface)
1.3.14 loopback (CE1 interface)
1.3.15 reset counters controller e1
1.3.16 using (CE1 interface)
1.4 CT1接口基本配置命令
1.4.1 alarm-detect
1.4.2 alarm-threshold
1.4.3 bert (CT1 interface)
1.4.4 cable (CT1 interface)
1.4.5 channel-set (CT1 interface)
1.4.6 clock (CT1 interface)
1.4.7 code (CT1 interface)
1.4.8 controller t1
1.4.9 data-coding (CT1 interface)
1.4.10 display controller t1
1.4.11 fdl
1.4.12 frame-format (CT1 interface)
1.4.13 idle-code (CT1 interface)
1.4.14 itf (CT1 interface)
1.4.15 loopback (CT1 interfacei)
1.4.16 reset counters controller t1
1.4.17 sendloopcode
1.5 E1-F接口配置命令
1.5.1 clock-change auto
1.5.2 crc
1.5.3 display fe1
1.5.4 fe1 alarm-detect
1.5.5 fe1 cable
1.5.6 fe1 clock
1.5.7 fe1 code
1.5.8 fe1 data-coding
1.5.9 fe1 detect-ais
1.5.10 fe1 frame-format
1.5.11 fe1 idle-code
1.5.12 fe1 itf
1.5.13 fe1 loopback
1.5.14 fe1 timeslot-list
1.5.15 fe1 unframed
1.5.16 mtu
1.5.17 reset counters interface
1.6 T1-F接口配置命令
1.6.1 crc
1.6.2 display ft1
1.6.3 ft1 alarm-detect
1.6.4 ft1 alarm-threshold
1.6.5 ft1 bert
1.6.6 ft1 cable
1.6.7 ft1 clock
1.6.8 ft1 code
1.6.9 ft1 data-coding
1.6.10 ft1 fdl
1.6.11 ft1 frame-format
1.6.12 ft1 idle-code
1.6.13 ft1 itf
1.6.14 ft1 loopback
1.6.15 ft1 sendloopcode
1.6.16 ft1 timeslot-list
1.6.17 mtu
1.6.18 reset counters interface
1.7 CT3接口配置命令
1.7.1 alarm
1.7.2 cable
1.7.3 clock
1.7.4 controller t3
1.7.5 display controller t3
1.7.6 feac
1.7.7 frame-format
1.7.8 ft3
1.7.9 loopback
1.7.10 mdl
1.7.11 reset counters controller t3
1.7.12 t1 alarm
1.7.13 t1 channel-set
1.7.14 t1 clock
1.7.15 t1 fdl
1.7.16 t1 frame-format
1.7.17 t1 loopback
1.7.18 t1 sendloopcode
1.7.19 t1 show
1.7.20 t1 shutdown
1.7.21 t1 unframed
1.7.22 using
1.8 T3接口配置命令
1.8.1 alarm
1.8.2 cable
1.8.3 clock
1.8.4 controller t3
1.8.5 display controller t3
1.8.6 ft3
1.8.7 loopback
1.8.8 reset counters controller t3
1.8.9 using t3
1 WAN接口
1.1  WAN接口公共命令
1.1.1  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbit/s)。
串口视图/串口子接口视图/E1-F接口视图/T1-F接口视图
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbit/s。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 设置串口Serial2/1/1的期望带宽为50kbit/s。
[Sysname] interface serial 2/1/1
[Sysname-Serial2/1/1] bandwidth 50
1.1.2  default
default命令用来恢复当前接口的缺省配置。
default
串口视图/串口子接口视图/E1-F接口视图/T1-F接口视图/CT3接口视图/T3接口视图
CE1接口视图
CT1接口视图
# 将串口Serial2/1/1恢复为缺省配置。
[Sysname-Serial2/1/1] default
1.1.3  description
description命令用来设置当前接口的描述信息。
undo description命令用来恢复缺省情况。
接口的描述信息为“该接口的接口名 Interface”,比如:Serial2/1/1 Interface。
CE1接口视图
CT1接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 配置串口Serial2/1/1的描述信息为“router-interface”。
[Sysname-Serial2/1/1] description router-interface
1.1.4  shutdown
shutdown命令用来关闭接口。
undo shutdown命令用来恢复缺省情况。
shutdown
接口处于打开状态。
CE1接口视图
CT1接口视图
# 关闭串口Serial2/1/1。
[Sysname-Serial2/1/1] shutdown
1.1.5  timer-hold
timer-hold命令用来配置Keepalive报文的发送周期。
undo timer-hold命令用来恢复缺省情况。
timer-hold seconds
undo timer-hold
Keepalive报文的发送周期为10秒。
串口视图/E1-F接口视图/T1-F接口视图
seconds:Keepalive报文的发送周期,取值范围为0~32767,单位为秒。
当接口上封装的链路层协议为PPP、FR或HDLC时,链路层会定期(可通过本命令修改)向对端发送Keepalive报文。如果在一段时间内无法收到对端发来的Keepalive报文,链路层会认为对端故障,从而上报链路层down。
在速率非常低的链路上,Keepalive报文的发送周期不能过小,因为大报文在低速链路上可能需要很长时间才能传送完毕,这样就会延迟Keepalive报文的收发。而接口在若干个(可通过timer-hold retry命令修改)Keepalive报文发送周期后仍未收到对端发来的Keepalive报文,就认为链路发生故障,从而拆除链路。
# 在串口Serial2/1/1上配置Keepalive报文的发送周期为15秒。
[Sysname-Serial2/1/1] timer-hold 15
·     timer-hold retry
timer-hold retry命令用来配置发送Keepalive报文的重试次数。
undo timer-hold retry命令用来恢复缺省情况。
timer-hold retry retries
发送Keepalive报文的重试次数为5。
retries:发送Keepalive报文的重试次数,取值范围为1~255。
当接口上封装的链路层协议为PPP、FR或HDLC时,链路层会定期(可通过timer-hold命令修改)向对端发送Keepalive报文。如果在一段时间内无法收到对端发来的Keepalive报文,链路层会认为对端故障,上报链路层Down。
在速率非常低的链路上,Keepalive报文的发送周期不能过小,因为大报文在低速链路上可能需要很长时间才能传送完毕,会延迟Keepalive报文的收发。而接口在retries个Keepalive报文发送周期后仍未收到对端发来的Keepalive报文,就认为链路发生故障,从而拆除链路。
# 在串口Serial2/1/1上,配置发送Keepalive报文的重试次数为10次。
[Sysname-Serial2/1/1] timer-hold retry 10
·     timer-hold
1.2  同步串口配置命令
1.2.1  baudrate
baudrate命令用来设置同步串口的波特率。
undo baudrate命令用来恢复缺省情况。
baudrate baudrate
undo baudrate
同步串口的波特率为64000bps。
同步串口视图
baudrate:同步串口的波特率,单位为bps。
仅MIM-2SAE、MIM-4SAE和MIM-8SAE接口模块上的串口支持本命令。
同步串口支持的波特率有:
1200bps、2400bps、4800bps、9600bps、19200bps、38400bps、56000bps、57600bps、64000bps、72000bps、115200bps、128000bps、192000bps、256000bps、384000bps、512000bps、1024000bps、2048000bps。
在设置同步串口波特率时,需要注意同步串口外接电缆的电气规程等因素,另外同步串口对于不同的物理电气规程,所支持的波特率范围有所不同。
·     V.24 DTE/DCE:1200bps~64000bps
·     V.35 DCE/DCE、X.21 DTE/DCE:1200bps~8192000bps
DCE设备和DTE设备之间线路传输的波特率,由DCE设备决定。
# 设置DCE设备的同步串口Serial2/1/1的波特率为115200bps。
[Sysname-Serial2/1/1] baudrate 115200
·     virtualbaudrate
1.2.2  code
code命令用来配置同步串口的数字信号编码格式。
undo code命令用来恢复缺省情况。
code { nrz | nrzi }
undo code
同步串口的数字信号编码格式为NRZ。
同步串口视图
nrz:采用NRZ(Non-Return to Zero,不归零)的数字信号编码格式。
nrzi采用NRZI(Non-Return to Zero Inverted,反向不归零)的数字信号编码格式。
# 配置同步串口Serial2/1/1的数字信号编码格式为NRZI。
[Sysname-Serial2/1/1] code nrzi
1.2.3  crc
crc命令用来配置同步串口的CRC校验模式。
undo crc命令用来恢复缺省情况。
crc { 16 | 32 | none }
undo crc
使用16位CRC校验。
同步串口视图
16:同步串口使用16位CRC校验。
32:同步串口使用32位CRC校验。
none:同步串口不进行CRC校验。
# 配置同步串口Serial2/1/1使用32位CRC校验。
[Sysname-Serial2/1/1] crc 32
1.2.4  clock
clock命令用来设置同步串口的时钟选择方式。
undo clock命令用来恢复缺省情况。
clock { dteclk1 | dteclk2 | dteclk3 | dteclk4 | dteclk5 | dteclkauto }
undo clock
同步串口DTE侧的时钟为dteclk1
同步串口视图
dteclk1:设置接口时钟方式为DTE时钟选择方式1。
dteclk2:设置接口时钟方式为DTE时钟选择方式2。
dteclk3:设置接口时钟方式为DTE时钟选择方式3。
dteclk4:设置接口时钟方式为DTE时钟选择方式4。
dteclk5:设置接口时钟方式为DTE时钟选择方式5。本参数暂不支持。
dteclkauto:设置接口时钟方式为DTE自动协商。
同步串口有两种工作方式:DTE和DCE,DTE工作方式有不同的工作时钟选择。
·     如果同步串口作为DCE侧,则需要向对端DTE侧提供时钟DCEclk,为缺省的dceclk1
·     如果同步串口作为DTE侧,则需要接受对端DCE侧提供的时钟,由于同步设备的接收和发送时钟是独立的,则DTE侧的接收时钟可以选择DCE侧的发送或接收时钟,DTE侧的发送时钟也可以选择DCE侧的发送或接收时钟,由此产生五种组合,即在DTE侧可以有五种时钟选择。
图1-1 同步串口时钟选择示意图
其中,TxClk为发送时钟,RxClk为接收时钟。
时钟选择方法规定如下表所示。
表1-1 同步串口DTE侧时钟的选择方法
选择方法
意义
DTEclk1
TxClk = TxClk, RxClk = RxClk
DTEclk2
TxClk = TxClk, RxClk = TxClk
DTEclk3
TxClk = RxClk, RxClk = TxClk
DTEclk4
TxClk = RxClk, RxClk = RxClk
DTEclk5
TxClk = Local, RxClk = Local
其中,‘=’前为DTE侧时钟,‘=’后为DCE侧时钟。
# 设置同步串口Serial2/1/1作为DTE侧的时钟选择方式为DTEclk2。
[Sysname-Serial2/1/1] clock dteclk2
1.2.5  detect dcd
detect dcd命令用来打开数据载波检测功能。即检测DSU/CSU的DCD(Data Carrier Detect,数据载波检测)信号。
undo detect dcd命令用来关闭数据载波检测功能。
detect dcd
undo detect dcd
数据载波检测功能处于打开状态。
同步串口视图
系统在判断同步串口的状态(up或down)时,缺省情况下将同时检测DSR信号、DCD信号以及接口是否外接电缆。只有当三个信号全部有效时,系统才认为同步串口处于up状态,否则为down状态。
# 打开同步串口Serial2/1/1的数据载波检测功能。
[Sysname-Serial2/1/1] detect dcd
·     detect dsr-dtr
detect dsr-dtr命令用来打开电平检测功能,即检测DSU/CSU(Data Service Unit/Channel Service Unit,数据服务单元/信道服务单元,表示数字MODEM)的DSR(Data Set Ready,数据置位就绪)和DTR(Data Terminal Ready,数据终端就绪)信号。
undo detect dsr-dtr命令用来关闭电平检测功能。
detect dsr-dtr
undo detect dsr-dtr
电平检测功能处于打开状态。
同步串口视图
系统在判断同步串口的状态(up或down)时,缺省情况下将同时检测DSR信号、DCD信号以及接口是否外接电缆。只有当三个信号全部有效时,系统才认为同步串口处于up状态,否则为down状态。如果禁止同步串口进行电平检测,系统检测到外接电缆后,接口状态为up,且DTR = up、DSR = up。
# 打开同步串口Serial2/1/1的电平检测功能。
[Sysname-Serial2/1/1] detect dsr-dtr
·     detect dcd
display interface serial命令用来显示Serial接口的相关信息。
display interface [ serial [ interface-number ] ] [ brief [ description | down ] ]
interface-number:显示指定Serial接口的信息。
如果不指定serial参数,将显示设备支持的所有接口的相关信息。
如果指定serial参数,不指定interface-number参数,将显示所有已创建的Serial接口的相关信息。
# 显示同步串口Serial2/1/1的详细信息。
<Sysname> display interface serial 2/1/1
Serial2/1/1
Current state: UP
Line protocol state: UP
Description: Serial2/1/1 Interface
Bandwidth: 64kbps
Hold timer:10 seconds, retry times: 5
Internet Address: 9.9.9.6/24 Primary
Link layer protocol: PPP
LCP: opened
Last link flapping: 6 hours 39 minutes 25 seconds
Physical layer is synchronous, Virtual baudrate is 64000 bps
Interface is DTE, Cable type is V35, Clock mode is DTECLK1
Last 300 seconds input rate: 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Last 300 seconds output rate: 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
Input: 0 packets, 0 bytes, 0 no buffers
           0 errors, 0 runts, 0 giants
           0 CRC, 0 align errors, 0 overruns
           0 dribbles, 0 aborts, 0 frame errors
    Output:0 packets, 0 bytes
           0 errors, 0 underruns, 0 aborts
    DCD=UP  DTR=UP  DSR=UP  RTS=UP  CTS=UP
# 显示同步串口Serial2/1/1的概要信息。
<Sysname> display interface serial 2/1/1 brief
Protocol: (s) - spoofing
Ser2/1/1             UP   UP(s)    --
# 显示当前物理状态为down的Serial接口的信息以及down的原因。
<Sysname> display interface serial brief down
Ser2/1/1             ADM  Administratively
表1-2 display interface serial命令显示信息描述表
Serial2/1/1
Current state
串口当前的物理状态和管理状态,可能的取值及含义如下:
·     DOWN(Administratively):表示该串口已经通过shutdown命令被关闭,即管理状态为关闭
·     DOWN:表示该串口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     UP:该串口的管理状态和物理状态均为开启
Line protocol state
该接口的链路层协议状态,可能的状态及含义如下:
·     UP:表示数据链路层协议状态为开启
·     DOWN:表示数据链路层协议状态为关闭
接口的描述信息
Bandwidth
接口的期望带宽
接口的最大传输单元
Hold timer
当前接口发送keepalive报文的周期
retry times
在多少个keepalive周期内没有收到keepalive报文的应答就拆除链路
Internet Address
接口的主IP地址
fe1 timeslot-list
E1-F接口的时隙捆绑信息
接口当前不能处理IP报文
Link layer protocol
串口的数据链路层协议
LCP
LCP(链路控制协议)状态
输出队列(紧急队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
输出队列(协议队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
输出队列(先进先出队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
Last link flapping
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过)
最近一次使用reset counters interface命令清除接口下的统计信息的时间。如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never
Input error packet detect
错包扩散抑制功能(暂不支持)
Physical layer
物理层链路信息
Virtual baudrate
串口的波特率
同步串口DTE侧的时钟选择方式
Last 300 seconds input rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的报文数
Last 300 seconds output rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的报文数
接口收到的总报文数和总字节数:
·     broadcasts:接收的广播报文的数目
·     multicasts:接收的组播报文的数目
·     errors:在物理层检测时发现的错误报文数目
·     runts:接口接收到小于规定的最小报文长度报文数
·     giants:接收到长度大于规定长度的报文数目
·     crc:接收长度正常但CRC校验错误的报文数目
·     align errors:排列错误
·     overruns:接收的报文速度大于转发处理能力导致无法处理的报文
·     aborts:接收报文的异常错误
·     no buffers:在接收报文时由于内部缓存满,导致帧丢弃
·     frame errors:帧错误
接口发送的报文数和总字节数
·     underruns:因为接口读取内存的速度小于转发的速度而无法发送报文数目
·     collisions:发送报文时,检测到冲突的报文数目
·     deferred:因为延时或超时无法发送报文的数目
DCD(Data Carrier Detect)、DTR(Data Terminal Ready)和DSR(Data Set Ready)信号处于up状态,关于DCD、DTR和DSR请参考detect命令
RTS(Request to Send)和CTS(Clear to Send)处于up状态
三层接口的概要信息
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
接口名称缩写
Link
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被手工关闭了,需要执行undo shutdown命令才能打开接口
·     Stby:表示该接口是一个备份接口
Protocol
接口数据链路层协议状态,取值可能为:
·     UP:表示接口的数据链路层是连通的
·     DOWN:表示接口的数据链路层不通
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
Primary IP
接口主IP地址
用户通过description命令给接口配置的描述信息。使用display interface brief命令,不指定description参数时,该字段最多显示27个字符;指定description参数时,可显示配置的全部描述信息
Cause
接口物理连接状态为down的原因,取值为Administratively时表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态;取值为Not connected时表示没有物理连接(可能没有插网线或者网线故障)
·     reset counters interface
1.2.8  idle-code
idle-code命令用来设置同步串口的线路空闲码类型。
undo idle-code命令用来恢复缺省情况。
idle-code { 7e | ff }
undo idle-code
同步串口的线路空闲码类型为0x7e。
同步串口视图
7e:线路空闲码为0x7e类型。
ff:线路空闲码为0xff类型。
通常情况下,同步串口使用0x7e来表示线路的空闲状态,而有的设备在空闲时间采用0xff(即全“1”的高电平)来表示线路的空闲状态。为了更好的兼容这种设备,需要设置同步串口的线路空闲码。
# 设置同步串口Serial2/1/1的线路空闲码为“0xFF”。
[Sysname-Serial2/1/1] idle-code ff
interface serial命令用来进入串口视图或创建串口子接口并进入串口子接口视图。如果指定的串口子接口已经存在,则直接进入串口子接口视图。
undo interface serial命令用来删除串口子接口。
interface serial { interface-number | interface-number.subnumber [ p2mp | p2p ] }
undo interface serial interface-number.subnumber
不存在串口子接口。
interface-number:串口编号。
interface-number.subnumber:串口子接口编号,其中interface-number为主接口编号;subnumber为子接口编号,取值范围为0~1023。
p2mp:点到多点子接口。子接口缺省为p2mp类型。
p2p:点到点子接口。
只有串口主接口上封装的链路层协议为FR时,才能创建子接口。
# 创建串口子接口Serial2/1/1.1。
[Sysname] interface serial 2/1/1.1
[Sysname-Serial2/1/1.1]
·     link-protocol
invert receive-clock命令用来允许翻转DTE侧同步串口的接收时钟信号。
undo invert receive-clock命令用来恢复缺省情况。
同步串口作为DTE侧时,禁止翻转接收时钟信号。
同步串口视图
在某些特殊情况下,为了消除线路上半个时钟周期的时延,可以将DTE侧同步串口的接收时钟信号翻转。只有连接某些特殊的DCE设备时,DTE侧才需要配置该命令,对于通常的应用,时钟不应作翻转。
# 将DTE侧同步串口Serial2/1/1的接收时钟翻转。
[Sysname-Serial2/1/1] invert receive-clock
·     invert transmit-clock
invert transmit-clock命令用来允许翻转DTE侧同步串口的发送时钟信号。
undo invert transmit-clock命令用来恢复缺省情况。
同步串口作为DTE侧时,禁止翻转发送时钟信号。
同步串口视图
在某些特殊情况下,为了消除线路上半个时钟周期的时延,可以将DTE侧同步串口的发送时钟信号翻转。只有连接某些特殊的DCE设备时,DTE侧才需要配置该命令,对于通常的应用,时钟不应作翻转。
# 将DTE侧同步串口Serial2/1/1的发送时钟翻转。
[Sysname-Serial2/1/1] invert transmit-clock
·     invert receive-clock
1.2.12  itf
itf命令用来设置帧间填充字节的个数。
undo itf命令用来恢复缺省情况。
itf number number
undo itf number
帧间填充字节个数为4。
同步串口视图
number number:设置帧间填充字节的个数,取值范围为0~14,单位为字节。
# 设置同步串口Serial2/1/1的帧间填充字节个数为5。
[Sysname-Serial2/1/1] itf number 5
link-protocol命令用来设置接口的链路层协议。
link-protocol { fr | hdlc | ppp | mfr }
同步串口使用PPP作为链路层协议。
同步串口视图
fr:使用帧中继作为接口的链路层协议。
hdlc:使用HDLC作为接口的链路层协议。
ppp:使用PPP作为接口的链路层协议。
mfr:使用多链路帧中继作为接口的链路层协议。
# 设置同步串口Serial2/1/1的链路层协议为HDLC。
[Sysname-Serial2/1/1] link-protocol hdlc
1.2.14  loopback
loopback命令用来开启对内自环功能。
undo loopback命令用来关闭对内自环功能。
loopback
undo loopback
对内自环功能处于关闭状态。
同步串口视图
只有在进行某些特殊功能测试时,才将接口设为对内自环。
# 配置同步串口Serial2/1/1对内自环。
[Sysname-Serial2/1/1] loopback
1.2.15  mtu
mtu命令用来设置接口的MTU(Maximum Transmission Unit,最大传输单元)值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
串口的MTU值为1500字节。
同步串口视图/串口子接口视图
接口的MTU值影响IP协议报文在该接口上传输时的分片与重组。
需要注意的是,配置了mtu命令后需要执行命令shutdownundo shutdown,这样该配置才能在接口上生效。
# 配置同步串口Serial2/1/1的MTU值为1430字节。
[Sysname-Serial2/1/1] mtu 1430
reset counters interface命令用来清除指定Serial接口的统计信息。
reset counters interface [ serial [ interface-number ] ]
serial interface-number:指定Serial接口。
·     如果不指定serialinterface-number,则清除所有接口的统计信息;
·     如果指定serial而不指定interface-number,则清除所有Serial接口的统计信息;
·     如果同时指定serialinterface-number,则清除指定Serial接口的统计信息。
# 清除同步串口Serial2/1/1的统计信息。
<Sysname> reset counters interface serial 2/1/1
·     display interface serial
1.2.17  reverse-rts
reverse-rts命令用来配置翻转RTS信号。
undo reverse-rts命令用来恢复缺省情况。
reverse-rts
undo reverse-rts
不翻转RTS信号。
同步串口视图
配置reverse-rts命令后,本端发送数据时不允许对端发送数据。
只在特定的调试需要时,才需要翻转RTS信号。
# 设置同步串口Serial2/1/1翻转RTS信号。
[Sysname-Serial2/1/1] reverse-rts
sub-interface rate-statistic命令用来开启串口子接口的速率统计功能。
undo sub-interface rate-statistic命令用来关闭串口子接口的速率统计功能。
串口子接口的速率统计功能处于关闭状态。
同步串口视图
开启本功能后可能需要耗费大量系统资源,请谨慎使用。
支持该功能的串口子接口包括同步串口、子通道串口。
# 开启同步串口Serial2/1/1的子接口速率统计功能。
[Sysname-Serial2/1/1] sub-interface rate-statistic
virtualbaudrate命令用来配置DTE接口的虚拟波特率。
undo virtualbaudrate命令用来取消虚拟波特率的配置。
virtualbaudrate virtualbaudrate
同步串口的虚拟波特率为64000bps。
同步串口视图
virtualbaudrate:指定的波特率,需要与DCE侧的配置保持一致。其取值范围为1200、2400、4800、9600、19200、38400、56000、57600、64000、72000、115200、128000、192000、256000、384000、512000、1024000、2048000,单位为bps。
当串口工作为DTE模式时,接口波特率通过协商从对端(DCE侧)获得。virtualbaudrate命令给用户提供一种手工配置DTE侧波特率的方式。
接口波特率和虚拟波特率的区别在于:
·     波特率和虚拟波特率不能在链路的同一端配置,波特率用于DCE端,虚拟波特率用于DTE端(仅同步模式)
·     在DCE端,通过display interface命令看到的是接口的波特率;而在DTE端,通过display interface命令看到的是接口的虚拟波特率。
# 设置DTE设备的同步串口Serial2/1/1的虚拟波特率为19200bps。
[Sysname-Serial2/1/1] virtualbaudrate 19200
1.3  CE1接口基本配置命令
1.3.1  alarm-detect
alarm-detect命令用来配置检测远端告警信号。
undo alarm-detect命令用来取消检测远端告警信号。
alarm-detect rai
undo alarm-detect rai
检测远端告警信号。
CE1接口视图
rai:Remote Alarm Indication,即远端告警指示信号。
在CE1方式的情况下,可以使用该命令。
# 配置CE1接口E1 2/1/1检测远端告警信号。
[Sysname] controller e1 2/1/1
[Sysname-E1 2/1/1] alarm-detect rai
cable命令用来配置CE1接口匹配的传输线路类型。
undo cable命令用来恢复缺省情况。
cable { long | short }
undo cable
CE1接口匹配的传输线路类型为long
CE1接口视图
long:表示接收器的衰减为-43db。
short:表示接收器的衰减为-10db。
# 配置CE1接口E1 2/1/1匹配的传输线路类型为short
[Sysname-E1 2/1/1] cable short
channel-set命令用来将CE1接口的时隙捆绑为通道组(channel set)。
undo channel-set命令用来取消已有的通道组。
channel-set set-number timeslot-list list
undo channel-set [ set-number ]
接口上不存在通道组。
CE1接口视图
set-number:该接口上时隙捆绑形成的channel set编号,取值范围为0~30。
timeslot-list list:被捆绑的时隙。list为时隙编号,取值范围为1~31。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
CE1接口使用CE1工作方式时,它在物理上分为32个时隙,对应编号为0~31。
使用时,可以将除0时隙外的全部时隙分成若干通道组(channel set),每组时隙捆绑以后,将自动创建一个Serial接口,其逻辑特性与同步串口相同。
Serial接口的名称是serial interface-number:set-number。其中interface-number是CE1接口的编号,set-number是channel set的编号。
# 将CE1接口E1 2/1/1的1、2、5、10-15和18时隙捆绑为0号channel-set。
[Sysname-E1 2/1/1] channel-set 0 timeslot-list 1,2,5,10-15,18
clock命令用来配置CE1接口的时钟模式。
clock { master | slave }
undo clock
CE1接口的时钟模式为从时钟模式(slave)。
CE1接口视图
master:主时钟模式,使用内部时钟信号。
slave:从时钟模式,使用线路提供的时钟信号。
# 设置CE1接口E1 2/1/1使用主时钟模式。
[Sysname-E1 2/1/1] clock master
clock-change auto命令用来开启接口的时钟自动切换功能。即接口在slave模式下收到AIS/LOS/LOF告警后,自动切换成master模式。当告警消除后,接口自动切换成用户配置的时钟模式。
undo clock-change auto命令用来关闭接口的时钟自动切换功能,接口恢复成当前用户配置的时钟模式。
clock-change auto
时钟自动切换功能处于关闭状态。
CE1接口视图
# 开启CE1接口E1 2/1/1的时钟自动切换功能。
[Sysname-E1 2/1/1] clock-change auto
·     clock
code命令用来配置CE1接口的线路编解码格式。
code { ami | hdb3 }
undo code
CE1接口的线路编解码格式为hdb3
CE1接口视图
ami:采用AMI(Alternate Mark Inversion,信号交替反转码)线路编码格式。
hdb3:采用HDB3(High Density Bipolar 3,3阶高密度双极性码)线路编码格式。
配置接口的线路编解码格式时,请注意与对端设备保持一致。
线路编码采用ami方式时,在该接口上需要同时配置data-coding inverted,才能保证接口正常工作。
# 配置CE1接口E1 2/1/1的线路编解码格式为ami
[Sysname-E1 2/1/1] code ami
·     data-coding
1.3.7  controller e1
controller e1命令用来进入CE1接口视图。
controller e1 interface-number
interface-number:CE1接口的编号。
# 进入CE1接口E1 2/1/1的视图。
[Sysname-E1 2/1/1]
data-coding命令用来设置CE1接口是否对用户数据进行翻转。
undo data-coding命令用来恢复缺省情况。
data-coding { inverted | normal }
undo data-coding
CE1接口不对用户数据进行翻转。
CE1接口视图
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当E1接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现过多连0的缺陷。
需要注意的是,只有通信的E1线路两端的CE1接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置CE1接口E1 2/1/1对用户数据进行翻转。
[Sysname-E1 2/1/1] data-coding inverted
1.3.9  detect-ais
detect-ais命令用来配置当前接口进行AIS检测。
undo detect-ais命令用来取消AIS检测。
detect-ais
undo detect-ais
进行AIS检测。
CE1接口视图
CE1接口工作在E1方式时,可以使用该命令。
# 设置CE1接口E1 2/1/1进行AIS检测。
[Sysname-E1 2/1/1] detect-ais
display controller e1命令用来显示CE1接口的相关信息。
display controller e1 [ interface-number ]
interface-number:CE1接口的编号。不指定本参数,将显示所有CE1接口的相关信息。
# 显示CE1接口E1 2/1/1的相关信息。
<Sysname> display controller e1 2/1/1
E1 2/1/1
Current state: UP
Description: E1 2/1/1 Interface
Basic Configuration:
  Work mode is E1 unframed, Cable type is 75 Ohm unbalanced.
  Line code is hdb3, Source clock is slave.
  Idle code is 7e, Itf type is 7e, Itf number is 4.
  Loop back is not set.
Alarm State:
  Receiver alarm state is None.
Historical Statistics:
    Data in current interval (150 seconds elapsed):
    1502 Loss Frame Alignment Secs, 0 Framing Error Secs,
    0 CRC Error Secs, 0 Alarm Indication Secs, 1821 Loss-of-signals Secs,
    0 Code Violations Secs, 9 Slip Secs, 0 E-Bit error Secs.
表1-3 display controller e1命令显示信息描述表
E1 2/1/1
Current state
E1接口当前的状态
E1接口的描述信息
Work mode
E1接口的工作模式(E1/CE1)
Cable type
E1接口的线缆类型
Frame-format
E1接口的帧格式
Source clock
接口的源时钟(master/slave)
Line code
线路码(Ami/hdb3)
Idle code
空闲码(7e/ff)
Itf type
帧间填充码(7e/ff)
Itf number
帧间填充码的个数
Loop back
接口是否设置了环回
Alarm State
告警状态
历史统计数据
清零记录
当前时间间隔内的各种错误发生持续的时间统计,错误包括:帧没对齐,帧错误,警告,丢信号,违规码时间,滑帧
·     reset counters controller e1
frame-format命令用来设置CE1接口的帧格式。
undo frame-format命令用来恢复缺省情况。
frame-format { crc4 | no-crc4 }
undo frame-format
CE1接口的帧格式为no-crc4
CE1接口视图
crc4:设置CE1接口的帧格式为CRC4帧格式。
no-crc4:设置CE1接口的帧格式为非CRC4帧格式。
当CE1接口工作在CE1方式下时,支持crc4no-crc4两种帧格式。其中crc4帧格式支持对物理帧进行4比特的循环冗余校验,而no-crc4帧格式则不支持对物理帧进行4比特的循环冗余校验。
# 设置接口E1 2/1/1的帧格式为crc4
[Sysname-E1 2/1/1] frame-format crc4
idle-code命令用来设置CE1接口的线路空闲码类型。
undo idle-code
CE1接口的线路空闲码类型为0x7e。
CE1接口视图
7e:线路空闲码为0x7e类型。
ff:线路空闲码为0xff类型。
CE1接口的线路空闲码类型是指在未被绑定到逻辑通道的时隙上发送的码型。
CE1接口的线路空闲码类型有两种:0x7e和0xff。
# 设置CE1接口E1 2/1/1的线路空闲码类型为0x7e。
[Sysname-E1 2/1/1] idle-code 7e
itf命令用来设置CE1接口的帧间填充符类型和个数。
undo itf命令用来恢复缺省情况。
itf { number number | type { 7e | ff } }
undo itf { number | type }
CE1接口的帧间填充符类型为0x7e,帧间填充字节个数为4个。
CE1接口视图
type:设置帧间填充符类型。
7e:表示帧间填充符为0x7e格式。
ff:表示帧间填充符为0xff格式。
CE1接口的帧间填充符是指已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。
CE1接口的帧间填充符类型有两种:0x7e和0xff。
当CE1接口工作在E1方式,且帧间填充符配置为0xff格式时,在没有业务数据时,线路上会发送全“1”的数据,容易产生AIS告警。在此情况下,建议用户通过undo detect-ais命令取消AIS检测,以免系统产生AIS告警。
# 设置CE1接口E1 2/1/1的帧间填充符类型为0xff。
[Sysname-E1 2/1/1] itf type ff
# 设置CE1接口E1 2/1/1的帧间填充字节个数为5。
[Sysname-E1 2/1/1] itf number 5
loopback命令用来开启CE1/PR接口的环回检测功能并设置检测方式。
undo loopback命令用来恢复缺省情况。
loopback { local | payload | remote }
undo loopback
环回检测功能处于关闭状态。
CE1接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
自环、环回功能主要用于检测接口或电缆本身的状况,正常工作时应关闭这些功能。
对于将CE1接口时隙经捆绑而形成的串口,如果串口的链路层协议配置为PPP或HDLC,在设置自环后,其链路层协议状态将上报为down,这属于正常情况。
# 设置CE1接口E1 2/1/1对内自环。
[Sysname-E1 2/1/1] loopback local
reset counters controller e1命令用来清除CE1接口的统计信息。
reset counters controller e1 [ interface-number ]
interface-number:CE1接口的编号。不指定本参数,将清除所有CE1接口的统计信息。
单独清除CE1接口的统计信息只能使用reset counters controller e1命令,不能使用reset counters interface命令,该命令会清除所有接口的统计信息。
CE1接口的统计信息可以用display controller e1命令来查看。
# 清除CE1接口E1 2/1/1的统计信息。
<Sysname> reset counters controller e1 2/1/1
·     display controller e1
using命令用来设置CE1接口的工作方式。
undo using命令用来恢复缺省情况。
using { ce1 | e1 }
undo using
CE1接口的工作方式为CE1工作方式。
CE1接口视图
ce1:接口工作在CE1工作方式。
e1:接口工作在E1工作方式。
CE1接口有两种工作方式:非通道化工作方式和通道化工作方式。其中,非通道化工作方式也称为E1工作方式,通道化工作方式也称为CE1工作方式。
·     当CE1接口使用E1工作方式时,它相当于一个不分时隙、数据带宽为2.048Mbps的接口,其逻辑特性与同步串口相同,接口名是serial interface-number:0。其中interface-number是CE1接口的编号。
·     当CE1接口使用CE1工作方式时,它在物理上分为32个时隙,对应编号为0~31,其中0时隙用于传输同步信息。
# 设置CE1接口E1 2/1/1的工作在E1工作方式。
[Sysname-E1 2/1/1] using e1
1.4  CT1接口基本配置命令
1.4.1  alarm-detect
alarm-detect rai
检测远端告警信号。
CT1接口视图
在接口帧格式采用esf的情况下,可以使用该命令。
# 配置CT1接口T1 2/1/1检测远端告警信号。
[Sysname] controller t1 2/1/1
[Sysname-T1 2/1/1] alarm-detect rai
alarm-threshold命令用来配置CT1接口的告警门限值。
undo alarm-threshold命令用来恢复缺省情况。
alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
对于AIS告警,缺省值为level-1
对于LFA告警,缺省值为level-1
对于LOS告警,pulse-detection参数的值为176,pulse-recovery的值为22,即如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失,LOS告警产生。
CT1接口视图
ais:AIS(Alarm Indication Signal,告警指示信号)告警的门限值。AIS告警有两个门限值,分别为level-1level-2level-1的门限为在一个SF/ESF帧内,比特流中的0的个数小等于2,则AIS告警产生;level-2的门限在SF格式时为,一个SF帧内码流的0个数小等于3;在ESF格式时为一个ESF帧内码流的0个数小等于5。
lfa:LFA(Loss of Frame Alignment,帧失步)告警的门限值。LFA告警有四个门限值可以配置,分别为level-1level-2level-3level-4level-1为4个帧同步比特中丢失了2个;level-2为5个帧同步比特中丢失了2个;leve-3为6个帧同步比特中丢失了2个;level-4仅仅对ESF格式有效,在连续4个ESF帧中出现错误时产生LFA告警。
los:LOS(Loss Of Signal,信号丢失)告警的门限值。LOS告警有两个门限值,分别为pulse-detectionpulse-recoverypulse-detection配置LOS的检测时长门限,取值范围为16~4096,这个时长门限的单位为“脉冲周期”;pulse-recovery配置LOS的脉冲门限,取值范围为1~256,就是在检测时长内(即pulse-detection配置的若干个脉冲周期内),检测到的脉冲个数如果小于pulse-recovery所配置的值,则LOS告警产生。
# 将LOS告警的检测时长配置为300个脉冲周期。
[Sysname-T1 2/1/1] alarm-threshold los pulse-detection 300
bert命令用来进行线路位(Bit)错误率的测试。
undo bert命令用来取消进行线路位(Bit)错误率的测试。
bert pattern { 2^20 | 2^15 } time minutes [ unframed ]
undo bert
不进行线路位错误率的测试。
CT1接口视图
pattern:设置BERT测试模式,包括2^15(测试码流长度为2的15次方个bit)和2^20(测试码流长度为2的20次方个bit)。
time minutes:设置BERT测试时间,取值范围为1~1440,单位为分钟。
unframed:设置测试数据流覆盖帧的开销位。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前CT1接口支持2^20和2^15两种测试模式。
BERT测试方式为,本端发出测试数据流,经过线路某处环回来,检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对方设置远端环回等。利用bert命令配置好测试模式,指定测试时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。
BERT测试状态和测试结果详见CT1接口显示部分。
# 执行2^20格式的BERT测试10分钟。
[Sysname-T1 2/1/1] bert pattern 2^20 time 10
cable命令用来配置CT1接口匹配的传输线路类型。
cable { long { 0db | -7.5db | -15db | -22.5db } | short { 133ft | 266ft | 399ft | 533ft | 655ft } }
undo cable
CT1接口匹配的传输线路类型为long 0db
CT1接口视图
long:匹配655英尺以上的传输线路,可选参数有0db-7.5db-15db-22.5db,可根据接收端信号质量选择不同的衰减参数,当线路质量越差时,信号衰减越大,需要用户对这种衰减进行相应补偿,此时,不需要外接CSU。
short:匹配655英尺以下的传输线路,可选参数有133ft266ft399ft533ft655ft,可根据传输线路的长度,选择相应的长度参数。
本命令主要作用是配置发送时的信号波形,以适应不同传输需要。实际使用中,可根据接收端收到的信号质量的好坏,来决定是否使用此命令。如果信号质量较好,可以使用缺省设置。使用缺省配置时,CT1接口不需外接CSU设备。
# 配置CT1接口T1 2/1/1匹配的传输线路类型为133英尺。
[Sysname-T1 2/1/1] cable short 133ft
channel-set命令用来将CT1接口的时隙捆绑为通道组(channel set)。
channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
接口上不存在通道组。
CT1接口视图
set-number:该接口上时隙捆绑形成的channel set编号,取值范围为0~23。
timeslot-list list:被捆绑的时隙。list为时隙编号,取值范围为1~24。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
speed { 56k | 64k }:时隙捆绑速率,单位为kbps。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。系统默认为64K
CT1接口在物理上分为24个时隙,对应编号为1~24。使用时,可以将全部时隙分成若干通道组(channel set),每组时隙捆绑以后,系统将自动创建一个Serial接口,其逻辑特性与同步串口相同。
Serial接口的名称是serial interface-number:set-number。其中interface-number是CT1接口的编号,set-number是channel set的编号。
# 将CT1接口T1 2/1/1的1、2、5、10-15和18时隙捆绑为0号channel-set。
[Sysname-T1 2/1/1] channel-set 0 timeslot-list 1,2,5,10-15,18
clock命令用来配置CT1接口的时钟模式。
undo clock
CT1接口的时钟模式为从时钟模式(slave)。
CT1接口视图
当CT1接口作为DCE侧使用时,应使用主时钟模式;作为DTE侧使用时,应使用从时钟模式。
当两台路由器的CT1接口直接相连时,必须使两端分别工作在从时钟模式和主时钟模式。当路由器的CT1接口与交换机连接时,交换机是DCE侧,负责提供时钟;而路由器的接口需工作在从时钟模式。
# 设置CT1接口T1 2/1/1使用主时钟模式。
[Sysname-T1 2/1/1] clock master
code命令用来配置CT1接口的线路编解码格式。
code { ami | b8zs }
undo code
CT1接口的线路编解码格式为b8zs
CT1接口视图
b8zs:采用B8ZS(Bipolar 8-zero substitution,双极性8zero替换码)线路编码格式。
# 配置CT1接口T1 2/1/1的线路编解码格式为ami
[Sysname-T1 2/1/1] code ami
·     data-coding
1.4.8  controller t1
controller t1命令用来进入CT1接口视图。
controller t1 interface-number
interface-number:CT1接口的编号。
# 进入CT1接口T1 2/1/1的视图。
[Sysname-T1 2/1/1]
data-coding命令用来设置CT1接口是否对用户数据进行翻转。
undo data-coding
CT1接口不对用户数据进行翻转。
CT1接口视图
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当T1接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现过多连0的缺陷。
需要注意的是,只有通信的T1线路两端的CT1接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置CT1接口T1 2/1/1对用户数据进行翻转。
[Sysname-T1 2/1/1] data-coding inverted
display controller t1命令用来显示CT1接口的相关信息。
display controller t1 [ interface-number ]
interface-number:CT1接口的编号。不指定本参数,将显示所有CT1接口的相关信息。
# 显示CT1接口T1 2/1/1的相关信息。
<Sysname> display controller t1 2/1/1
T1 2/1/1
Current state: DOWN
Description: T1 2/1/1 Interface
  Work mode: T1 framed, Cable type: 100 Ohm balanced
  Frame-format: esf, fdl: none, Line code: b8zs
  Source clock: slave, Data-coding: normal
  Idle code: ff, Itf type: ff, Itf number: 2
  Loop back: not set
Alarm State:
  Receiver alarm state is Loss-of-Signal
  Transmitter is sending remote alarm
  Pulse density violation detected
SendLoopCode History:
  Inband-llb-up: 0 times, Inband-llb-down: 0 times
  Fdl-ansi-llb-up: 0 times, Fdl-ansi-llb-down: 0 times
  Fdl-ansi-plb-up: 0 times, Fdl-ansi-plb-down: 0 times
  Fdl-att-plb-up: 0 times, Fdl-att-plb-down: 0 times
BERT state:(stopped, not completed)
  Test pattern: 2^15, Status: Not Sync, Sync Detected: 0
    Time: 0 minutes, Time past: 0 minutes
    Bit Errors (since test started): 0 bits
    Bits Received (since test started): 0 Kbits
    Bit Errors (since latest sync): 0 bits
    Bits Received (since latest sync): 0 Kbits
  Data in current interval (285 seconds elapsed):
    Line Code Violations: 0, Path Code Violations: 0
    Ais Alarm: 0 seconds, Los Alarm: 286 seconds
    Slip: 7 seconds, Fr Loss: 286 seconds
    Line Err: 0 seconds, Degraded: 0 minutes
    Errored: 0 seconds, Bursty Err: 0 seconds
    Severely Err: 0 seconds, Unavail: 286 seconds
  Data in Interval 1:
    Ais Alarm: 0 seconds, Los Alarm Secs: 901 seconds
    Slip: 22 seconds, Fr Loss: 901 seconds
    Severely Err: 0 seconds, Unavail: 901 seconds
  Data in Interval 2:
    Ais Alarm: 0 seconds, Los Alarm: 900 seconds
    Slip: 23 seconds, Fr Loss: 900 seconds
    Severely Err: 0 seconds, Unavail: 900 seconds
  Total Data (last 2 15 minute intervals):
    Ais Alarm: 0 seconds, Los Alarm: 2087 seconds
    Slip: 52 seconds, Fr Loss: 2087 seconds
    Severely Err: 0 seconds, Unavail: 2087 seconds
表1-4 display controller e1命令显示信息描述表
T1 2/1/1
Current state
T1接口当前的状态
T1接口的描述信息
Basic Configuration
T1接口基本配置
Work mode
T1接口的工作模式(T1/CT1)
Cable type
T1接口的线缆类型
Frame-format
T1接口的帧格式(esf/sf)
fdl
FDL格式(ansi/att/none)
Line code
线路编码格式(b8zs/ami)
Source clock
接口的时钟源模式(master/slave)
Data-coding
包括正常和数据翻转两种模式(normal/inverted)
Idle code
空闲码(7e/ff)
Itf type
帧间填充码(7e/ff)
Itf number
帧间填充码的个数
Loop back
接口是否设置了环回(local/payload/remote/no set)
Alarm State
告警状态
收到的告警类型:none、LOS、LOF、RAI、AIS
发出的告警类型:RAI、none
脉冲密度不符合规范要求
向对端发送环回码的历史记录,包括每种码的发送次数和最近发送的是哪种码
BERT state
BERT测试状态:completed(自然完成)还是stopped(人为中止)还是running(正在测试)
Test pattern
测试模式(2^20/2^15)
Status
是否处于同步状态
Sync Detected
测试以来检测到的同步次数
Time
预设的测试时间
Time past
已经过去的测试时间
测试以来收到的错误的比特数
测试以来收到的总比特数
最近的同步以来收到的错误的比特数
最近的同步以来收到的总比特数
历史信息
Last link flapping
清零记录
当前时间间隔内的统计信息(15分钟为一个时间间隔)。这些数据是按照T1规范对物理层所作的各种信息统计,如AIS告警、RAI告警、LOS信号、LFA等。详细解释参见T1规范ANSI T1.403和AT&T TR 54016
  Data in Interval 1:
第1间隔内的统计信息
统计内容同上
  Data in Interval 2:
第2间隔内的统计信息
统计内容同上
所有间隔内的统计信息
统计内容同上
·     reset counters controller t1
1.4.11  fdl
fdl命令用来配置CT1接口在ESF格式时FDL比特位的使用模式。
undo fdl命令用来恢复缺省情况。
fdl { ansi | att | both | none }
undo fdl
禁止FDL(none)。
CT1接口视图
ansi:使能FDL,遵循ANSI T1.403规范。
att:使能FDL,遵循AT&T TR 54016规范。
both:使能FDL,同时遵循ANSI T1.403规范和AT&T TR 54016规范。
none:禁止FDL。
FDL(Facility Data Link,设备数据链路)是T1的ESF帧格式中4kbps的一个带宽,CT1接口在配置为ESF(Extended Super Frame,扩展超帧)格式时,其中的FDL位可用来传递报警信息、性能信息及环回码等,相关的规范包括ANSI T1.403和ATT TR 54016。在实际应用中,经常需要对FDL的使用及规范进行各种配置,包括:禁止FDL、使能并遵循ANSI规范、使能并遵循AT&T规范或者使能并遵循这两种规范。
实际应用中,可以根据对方FDL的模式调整本端FDL的模式。
# 设置CT1接口T1 2/1/1 FDL使能并遵循AT&T规范。
[Sysname-T1 2/1/1] fdl att
frame-format命令用来设置CT1接口的帧格式。
frame-format { esf | sf }
undo frame-format
CT1接口的帧格式为esf
CT1接口视图
esf:设置CT1接口的帧格式为ESF(Extended Super Frame,扩展超帧)格式。
sf:设置CT1接口的帧格式为SF(Super Frame,超帧)格式。
CT1接口支持超帧和扩展超帧两种帧格式。在超帧格式中,多个帧可以共享相同的帧同步信息和信令信息,从而有更多的有效位来传送用户数据。实际应用中,经常需要对系统进行测试,扩展超帧技术可以用来满足在测试时不影响正常业务运行的要求。
# 设置CT1接口T1 2/1/1的帧格式为超帧格式。
[Sysname-T1 2/1/1] frame-format sf
idle-code命令用来设置CT1接口的线路空闲码类型。
undo idle-code
CT1接口的线路空闲码类型为0x7e。
CT1接口视图
7e:线路空闲码为0x7e类型。
ff:线路空闲码为0xff类型。
CT1接口的线路空闲码类型是指在未被绑定到逻辑通道的时隙上发送的码型。
CT1接口的线路空闲码类型有两种:0x7e和0xff。
# 设置CT1接口T1 2/1/1的线路空闲码类型为0x7e。
[Sysname-T1 2/1/1] idle-code 7e
itf命令用来设置CT1接口的帧间填充符类型和个数。
undo itf命令用来恢复缺省情况。
CT1接口的帧间填充符类型为0x7e,帧间填充字节个数为4个。
CT1接口视图
type:设置帧间填充符类型。
7e:表示帧间填充符为0x7e格式。
ff:表示帧间填充符为0xff格式。
CT1接口的帧间填充符是指已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。
CT1接口的帧间填充符类型有两种:0x7e和0xff。
# 设置CT1接口T1 2/1/1的帧间填充符类型为0xff。
[Sysname-T1 2/1/1] itf type ff
# 设置CT1接口T1 2/1/1的帧间填充字节个数为5。
[Sysname-T1 2/1/1] itf number 5
loopback命令用来开启CT1/PR接口的环回检测功能并设置检测方式。
undo loopback
环回检测功能处于关闭状态。
CT1接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
自环环回功能主要用于检测接口或电缆本身的状况,正常工作时应关闭这些功能。
对于将CT1接口时隙经捆绑而形成的串口,如果串口的链路层协议配置为PPP,在设置自环后,其链路层协议状态将上报为down,这属于正常情况。
# 设置CT1接口T1 2/1/1对内自环。
[Sysname-T1 2/1/1] loopback local
reset counters controller t1命令用来清除CT1接口的统计信息。
reset counters controller t1 [ interface-number ]
interface-number:CT1接口的编号。不指定本参数,将清除所有CT1接口的统计信息。
单独清除CT1接口的统计信息只能使用reset counters controller t1命令,不能使用reset counters interface命令,该命令会清除所有接口的统计信息。
CT1接口的统计信息可以用display controller t1命令来查看。
# 清除CT1接口T1 2/1/1的统计信息。
<Sysname> reset counters controller t1 2/1/1
·     display controller t1
1.4.17  sendloopcode
sendloopcode命令用来配置发送远程环回控制码。
sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
不发送远程环回控制码。
CT1接口视图
fdl-ansi-llb-down:发送FDL承载的符合ANSI规范的线路环回去激活码,解除远端环回。
fdl-ansi-llb-up:发送FDL承载的符合ANSI规范的线路环回激活码,启动远端环回。
fdl-ansi-plb-down:发送FDL承载的符合ANSI规范的净荷环回去激活码,解除远端环回。
fdl-ansi-plb-up:发送FDL承载的符合ANSI规范的净荷环回激活码,启动远端环回。
fdl-att-plb-down:发送FDL承载的符合AT&T规范的净荷环回去激活码,解除远端环回。
fdl-att-plb-up:发送FDL承载的符合AT&T规范的净荷环回激活码,启动远端环回。
inband-llb-down:发送符合ANSI规范和AT&T规范的带内线路环回去激活码,解除远端环回。
inband-llb-up:发送符合ANSI规范和AT&T规范的带内线路环回激活码,启动远端环回。
CT1接口下可以通过发送环回控制码对远端的CT1接口进行环回的自动配置。LLB(Line loopback,线路环回)这种方式下,一个T1的PCM帧的全部193位(包括1位同步位及192位有效净荷)都被环回;PLB(Payload loopback,净荷环回)这种方式下,仅192位有效净荷被环回。环回码的格式规范包括ANSI T1.403和AT&T TR 54016。SF格式下的LLB环回码占用有效带宽;ESF格式下对LLB和PLB的环回码均使用ESF帧的FDL比特位收发。
这条命令需要和远端T1设备配合使用,当对方能检测符合上述格式的各种环回码时,对方能够根据检测到的环回码类型设置相应的环回模式。持续发送5秒钟,不影响其它接口的正常工作。
配置该命令时要求远端的CT1接口能自动检测到来自网上的环回控制码。
# 发送带内线路环回激活码。
[Sysname-T1 2/1/1] sendloopcode inband-llb-up
1.5  E1-F接口配置命令
clock-change auto
时钟自动切换功能处于关闭状态。
E1-F接口视图
# 打开E1-F接口Serial2/1/1时钟自动切换功能。
[Sysname-Serial2/1/1] clock-change auto
·     fe1 clock
1.5.2  crc
crc命令用来配置E1-F接口的CRC校验模式。
undo crc命令用来恢复缺省情况。
undo crc
使用16位CRC校验。
E1-F接口视图
16:E1-F接口使用16位CRC校验。
32:E1-F接口使用32位CRC校验。
none:E1-F接口不进行CRC校验。
# 配置E1-F接口Serial2/1/1使用32位CRC校验。
1.5.3  display fe1
display fe1命令用来显示E1-F接口的相关信息。
display fe1 [ serial interface-number ]
serial interface-number:显示指定E1-F接口的信息。interface-number为串口编号。如果不指定接口,则显示所有的E1-F接口的信息。
若指定的接口不是E1-F接口而是一个普通串口,则系统会提示该串口不是E1-F接口。
# 显示E1-F接口Serial2/1/1的相关信息。
<Sysname> display fe1 serial 2/1/1
Serial2/1/1
  Work mode is E1 framed, Cable type is non-E1 type.
  Frame-format is no-crc4.
  Loopback is not set.
Alarm State:
  Receiver alarm state is Loss-of-Signal.
  Transmitter is sending remote alarm.
  Data in current interval (5144 seconds elapsed):
    5144 Loss Frame Alignment Secs, 0 Framing Error Secs,
    0 CRC Error Secs, 0 Alarm Indication Secs, 5144 Loss-of-signals Secs,
    0 Code Violations Secs, 1 Slip Secs, 0 E-Bit error Secs.
表1-5 display fe1命令显示信息描述表
Basic Configuration
接口基本配置
Work mode
接口的工作模式
Cable type
接口的线缆类型(75欧非平衡/120欧平衡),non-E1 type代表未插入线缆
Frame-format
帧格式(crc4/no-crc4)
Line code
线路编码格式(ami/hdb3)
Source clock
Idle code
空闲码(7e/ff)
Itf type
帧间填充码(7e/ff)
Itf number
帧间填充码的个数
Loopback
接口是否设置了环回
Alarm State
告警状态
历史统计信息
fe1 alarm-detect命令用来配置检测远端告警信号。
undo fe1 alarm-detect命令用来取消检测远端告警信号。
fe1 alarm-detect rai
undo fe1 alarm-detect rai
检测远端告警信号。
E1-F接口视图
在成帧方式的情况下,可以使用该命令。
# 配置E1-F接口Serial2/1/1检测远端告警信号。
[Sysname-Serial2/1/1] fe1 alarm-detect rai
·     fe1 unframed
1.5.5  fe1 cable
fe1 cable命令用来设置接口支持的电缆类型。
undo fe1 cable命令用来恢复缺省情况。
fe1 cable { long | short }
undo fe1 cable
E1-F接口支持长电缆类型。
E1-F接口视图
long:表示设置支持长电缆类型。
short:表示设置支持短电缆类型。
# 设置E1-F接口Serial2/1/1支持的电缆类型为short
[Sysname-Serial2/1/1] fe1 cable short
1.5.6  fe1 clock
fe1 clock命令用来设置E1-F接口的时钟模式。
undo fe1 clock命令用来恢复缺省情况。
fe1 clock { master | slave }
undo fe1 clock
E1-F接口视图
# 设置E1-F接口Serial2/1/1使用主时钟模式。
[Sysname-Serial2/1/1] fe1 clock master
·     clock-change auto
1.5.7  fe1 code
fe1 code命令用来设置E1-F接口的线路编解码格式。
undo fe1 code命令用来恢复缺省情况。
fe1 code { ami | hdb3 }
undo fe1 code
E1-F接口的线路编解码格式为hdb3
E1-F接口视图
线路编码采用ami方式时,在该接口上需要同时配置fe1 data-coding inverted,才能保证接口正常工作。
# 设置E1-F接口Serial2/1/1的线路编解码格式为ami
[Sysname-Serial2/1/1] fe1 code ami
·     fe1 data-coding
fe1 data-coding命令用来设置E1-F接口是否对用户数据进行翻转。
undo fe1 data-coding命令用来恢复缺省情况。
fe1 data-coding { inverted | normal }
E1-F接口不对用户数据进行翻转。
E1-F接口视图
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当E1-F接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现的过多连0的缺陷。
需要注意的是,只有通信的E1-F线路两端的E1-F接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置E1-F接口Serial2/1/1对用户数据进行翻转。
[Sysname-Serial2/1/1] fe1 data-coding inverted
·     fe1 code
fe1 detect-ais命令用来配置当前接口进行AIS(Alarm Indication Signal,告警指示信号)检测。
undo fe1 detect-ais命令用来取消AIS检测。
fe1 detect-ais
undo fe1 detect-ais
进行AIS检测。
E1-F接口视图
在非成帧方式的情况下,可以使用该命令。
# 设置E1-F接口Serial2/1/1进行AIS检测。
[Sysname-Serial2/1/1] fe1 detect-ais
·     fe1 unframed
fe1 frame-format命令用来设置E1-F接口的帧格式。
undo fe1 frame-format命令用来恢复缺省情况。
fe1 frame-format { crc4 | no-crc4 }
E1-F接口的帧格式为no-crc4
E1-F接口视图
crc4:设置E1-F接口的帧格式为CRC4帧格式。
no-crc4:设置E1-F接口的帧格式为非CRC4帧格式。
E1-F接口工作在成帧方式下时,支持crc4no-crc4两种帧格式。其中crc4帧格式支持对物理帧进行4比特的循环冗余校验,而no-crc4帧格式则不支持。
# 设置E1-F接口Serial2/1/1的帧格式为crc4
[Sysname-Serial2/1/1] fe1 frame-format crc4
·     fe1 unframed
fe1 idle-code命令用来设置E1-F接口的线路空闲码类型。
undo fe1 idle-code命令用来恢复缺省情况。
fe1 idle-code { 7e | ff }
undo fe1 idle-code
E1-F接口的线路空闲码类型为0x7e。
E1-F接口视图
7e:线路空闲码为0x7e类型。
ff:线路空闲码为0xff类型。
E1-F接口的线路空闲码类型是指在未被绑定到逻辑通道的时隙上发送的码型。
E1-F接口的线路空闲码类型有两种:0x7e和0xff。
# 设置E1-F接口Serial2/1/1的线路空闲码类型为0x7e。
[Sysname-Serial2/1/1] fe1 idle-code 7e
1.5.12  fe1 itf
fe1 itf命令用来设置E1-F接口的帧间填充符类型和个数。
undo fe1 itf命令用来恢复缺省情况。
fe1 itf { number number | type { 7e | ff } }
undo fe1 itf { number | type }
E1-F接口的帧间填充符类型为0x7e,帧间填充字节个数为4个。
E1-F接口视图
type:设置帧间填充符类型。
7e:表示帧间填充符为0x7e格式。
ff:表示帧间填充符为0xff格式。
E1-F接口的帧间填充符是指在已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。
E1-F接口的帧间填充符类型有两种:0x7e和0xff。
# 设置E1-F接口Serial2/1/1的帧间填充符类型为0xff。
[Sysname-serial2/1/1] fe1 itf type ff
# 设置E1-F接口Serial2/1/1的帧间填充字节个数为5。
[Sysname-Serial2/1/1] fe1 itf number 5
1.5.13  fe1 loopback
fe1 loopback命令用来开启E1-F接口的环回检测功能并设置检测方式。
undo fe1 loopback命令用来恢复缺省情况。
fe1 loopback { local | payload | remote }
undo fe1 loopback
环回检测功能处于关闭状态。
E1-F接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
在接口上,本命令可以分别打开对内自环、对外净荷环回或者对外环回功能,但不能同时启用。
# 设置E1-F接口Serial2/1/1进行对内自环。
[Sysname-Serial2/1/1] fe1 loopback local
fe1 timeslot-list命令用来设置E1-F接口的时隙捆绑。
undo fe1 timeslot-list命令用来恢复缺省情况。
fe1 timeslot-list list
E1-F接口捆绑所有的时隙,即E1-F接口的缺省速率为1984kbps。
E1-F接口视图
list:被捆绑的时隙编号,取值范围为1~31。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以用number1,number2-number3的形式同时指定多个时隙。
在对E1-F接口进行时隙捆绑后,接口的速率会同时改变。例如,当用户将1~10这十个时隙捆绑之后,接口的速率就会变为10×64kbps。
与CE1接口不同的是,在E1-F接口上只能捆绑出一个通道组(channel set),捆绑出的通道组就对应当前的同步串口。而在CE1接口上可以捆绑出多个通道组,并且每捆绑一个通道组,系统都会自动生成一个与之相对应的同步串口。
因为E1-F接口的0时隙被用于传输同步信息,所以,当对E1-F接口的时隙进行全部捆绑时,实际捆绑的时隙为1~31时隙。
当E1-F接口的工作方式为非成帧方式时,不能配置fe1 timeslot-list命令。
# 将E1-F接口Serial2/1/1上的1、2、5、10~15、18时隙捆绑起来。
[Sysname-Serial2/1/1] fe1 timeslot-list 1,2,5,10-15,18
·     fe1 unframed
1.5.15  fe1 unframed
fe1 unframed命令用来设置E1-F接口的工作方式为非成帧方式。
undo fe1 unframed命令用来恢复缺省情况。
fe1 unframed
undo fe1 unframed
E1-F接口工作在成帧方式。
E1-F接口视图
当E1-F接口工作在非成帧的工作方式时,它相当于一个不分时隙、数据带宽为2048kbps的接口,其逻辑特性与同步串口相同。
当E1-F接口工作在成帧的工作方式时,它在物理上分为32个时隙,对应编号为0~31,其中0时隙用于传输同步信息。
# 设置E1-F接口Serial2/1/1的工作方式为非成帧方式。
[Sysname-Serial2/1/1] fe1 unframed
·     fe1 timeslot-list
1.5.16  mtu
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
E1-F接口的MTU值为1500字节。
E1-F接口视图
# 设置E1-F接口Serial2/1/1的MTU值为1430字节。
reset counters interface命令用来清除指定接口的统计信息。
# 清除E1-F接口Serial2/1/1的统计信息。
1.6  T1-F接口配置命令
1.6.1  crc
crc命令用来配置T1-F接口的CRC校验模式。
undo crc命令用来恢复缺省情况。
undo crc
使用16位CRC校验。
T1-F接口视图
16:T1-F接口使用16位CRC校验。
32:T1-F接口使用32位CRC校验。
none:T1-F接口不进行CRC校验。
# 配置T1-F接口Serial2/1/1使用32位CRC校验。
1.6.2  display ft1
display ft1命令用来显示T1-F接口的相关信息。
display ft1 [ serial interface-number ]
serial interface-number:显示指定T1-F接口的信息。interface-number为串口编号。如果不指定接口,则显示所有的T1-F接口的信息。
若指定的接口不是T1-F接口而是一个普通串口,则系统会提示该串口不是T1-F接口。
# 显示T1-F接口2/1/1的相关信息。
<Sysname> display ft1 serial 2/1/1
Serial2/1/1
Input:
  0 packets, 0 bytes
  0 broadcasts, 0 multicasts
  0 aborts, 0 no buffers
  0 frame errors
Output:
  0 packets, 0 bytes
  0 errors, 0 underruns, 0 collisions
  0 deferred
  Loopback: not set
Alarm State:
  Pulse density violation detected.
BERT state: stopped
  Data in Interval 1:
    Ais Alarm: 0 seconds, Los Alarm: 901 seconds
  Data in Interval 2:
表1-6 display ft1命令显示信息描述表
Input/Output
接口输入/输出统计信息
Basic Configuration
接口的基本配置
Work mode
T1-F接口的工作模式(T1/CT1)
Cable type
T1-F接口的线缆类型(100 Ohm balanced)
Frame-format
T1-F接口的帧格式(esf/sf)
fdl
Line code
线路编码格式(b8zs/ami)
Source clock
Data-coding
Idle code
空闲码(7e/ff)
Itf type
帧间填充码的类型(7e/ff)
Itf number
帧间填充码的字节数为2个
Loopback
接口是否设置了环回(local/payload/remote/not set)
Alarm State
告警状态
发出的告警类型:RAI、none
脉冲密度不符合规范要求
BERT state
BERT测试状态:completed(完成)还是stopped(人为中止)还是running(正在测试)
Test pattern
测试模式(2^20/2^15)
Status
是否处于同步状态,Not Sync表示不处于同步状态
Sync Detected
测试以来检测到的同步次数
Time
预设的测试时间
Time past
已经过去的测试时间
测试以来收到的比特错误数
测试以来收到的比特总数
最近的同步以来收到的比特错误数
最近的同步以来收到的比特总数
历史信息
Last link flapping
清零记录
当前时间间隔内的统计信息(15分钟为一个时间间隔)。 这些数据是按照T1规范对物理层所作的各种信息统计,如AIS告警、RAI告警、LOS信号、LFA等。详细解释参见T1规范ANSI T1.403和AT&T TR 54016
  Data in Interval 1:
第1间隔内的统计信息
统计内容同上
  Data in Interval 2:
第2间隔内的统计信息
统计内容同上
所有间隔内的统计信息
统计内容同上
ft1 alarm-detect命令用来配置检测远端告警信号。
undo ft1 alarm-detect命令用来取消检测远端告警信号。
ft1 alarm-detect rai
undo ft1 alarm-detect rai
检测远端告警信号。
T1-F接口视图
# 配置T1-F接口Serial2/1/1检测远端告警信号。
[Sysname-Serial2/1/1] ft1 alarm-detect rai
·     ft1 frame-format
ft1 alarm-threshold命令用来配置T1-F接口告警的门限值。
undo ft1 alarm-threshold命令用来恢复缺省情况。
ft1 alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo ft1 alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
对于AIS告警,缺省值为level-1
对于LFA告警,缺省值为level-1
T1-F接口视图
ais:AIS(Alarm Indication Signal,告警指示信号)告警的门限值。AIS告警有两个门限值,分别为level-1level-2。level-1的门限为在一个SF/ESF帧内,比特流中的0的个数小等于2,则AIS告警产生;level-2的门限在SF格式时为,一个SF帧内码流的0个数小等于3;在ESF格式时为一个ESF帧内码流的0个数小等于5。缺省情况下,AIS告警门限值为level-1。
lfa:LFA(Loss of Frame Alignment,帧失步)告警的门限值。LFA告警有四个门限值可以配置,分别为level-1level-2level-3level-4level-1为4个帧同步比特中丢失了2个;level-2为5个帧同步比特中丢失了2个;leve-3为6个帧同步比特中丢失了2个;level-4仅仅对ESF格式有效,在连续4个ESF帧中出现错误时产生LFA告警。缺省情况下,LFA告警门限值为level-1。
los:LOS(Loss Of Signal,信号丢失)告警的门限值。LOS告警有两个门限值,分别为pulse-detectionpulse-recoverypulse-detection配置LOS的检测时长门限,取值范围为16~4096,这个时长门限的单位为“脉冲周期”;pulse-recovery配置LOS的脉冲门限,取值范围为1~256,就是在检测时长内(即pulse-detection配置的若干个脉冲周期内),检测到的脉冲个数如果小于pulse-recovery所配置的值,则LOS告警产生。在缺省情况,pulse-detection参数的值为176,pulse-recovery的值为22,即如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失,LOS告警产生。
# 将T1-F接口Serial2/1/1的LOS告警的检测时长配置为300个脉冲周期。
[Sysname-Serial2/1/1] ft1 alarm-threshold los pulse-detection 300
·     ft1 frame-format
1.6.5  ft1 bert
ft1 bert命令用来进行线路位(Bit)错误率的测试。
undo ft1 bert命令用来取消进行线路位(Bit)错误率的测试。
ft1 bert pattern { 2^20 | 2^15 } time minutes [ unframed ]
undo ft1 bert
不进行线路位错误率的测试。
T1-F接口视图
time minutes:设置BERT测试的持续时间,取值范围为1~1440,单位为分钟。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前T1-F接口支持2^20和 2^15两种测试模式。
BERT测试方式为,本端发出测试数据流,经过线路某处环回来,检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对方设置远端环回等。利用ft1 bert命令配置好测试模式,指定测试时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。
BERT测试状态和测试结果详见T1-F接口显示部分。
# 设置T1-F接口Serial2/1/1执行2^20格式的BERT测试10分钟。
[Sysname-Serial2/1/1] ft1 bert pattern 2^20 time 10
·     display ft1
1.6.6  ft1 cable
ft1 cable命令用来设置T1-F接口匹配的传输线路的衰减或长度。
undo ft1 cable命令用来恢复缺省情况。
ft1 cable { long decibel | short length }
undo ft1 cable
T1-F接口匹配的传输线路衰减为long 0db
T1-F接口视图
long decibel:匹配655英尺以上的传输线路,参数decibel的值可以为0db-7.5db-15db-22.5db,可根据接收端信号质量选择不同的衰减参数,此时不需要外接CSU。
short length:匹配655英尺以下的传输线路,参数length的值可以为133ft、266ft399ft533ft655ft,可根据传输线路的长度选择相应的长度参数。
本命令主要作用是配置发送时的信号波形,以适应不同传输需要。实际使用中可根据接收端收到的信号质量的好坏来决定是否使用此命令。如果信号质量较好可以使用缺省设置。
# 设置T1-F接口Serial2/1/1匹配的传输线路设为133英尺。
[Sysname-Serial2/1/1] ft1 cable short 133ft
·     ft1 frame-format
1.6.7  ft1 clock
ft1 clock命令用来设置T1-F接口的时钟模式。
undo ft1 clock命令用来恢复缺省情况。
ft1 clock { master | slave }
undo ft1 clock
T1-F接口视图
当T1-F接口作为DCE侧使用时,应使用主时钟模式;作为DTE侧使用时,应使用从时钟模式。
当两台路由器的T1-F接口直接相连时,必须使两端分别工作在从时钟模式和主时钟模式。当路由器的T1-F接口与交换机连接时,交换机是DCE侧,负责提供时钟;而路由器的接口需工作在从时钟模式。
# 设置T1-F接口Serial2/1/1使用主时钟模式。
[Sysname-Serial2/1/1] ft1 clock master
1.6.8  ft1 code
ft1 code命令用来设置T1-F接口的线路编解码格式。
undo ft1 code命令用来恢复缺省情况。
ft1 code { ami | b8zs }
undo ft1 code
T1-F接口的线路编解码格式为b8zs
T1-F接口视图
线路编码采用ami方式时,在该接口上需要同时配置ft1 data-coding inverted,才能保证接口正常工作。
# 设置T1-F接口Serial2/1/1的线路编解码格式为ami
[Sysname-Serial2/1/1] ft1 code ami
·     ft1 data-coding
ft1 data-coding命令用来设置T1-F接口是否对用户数据进行翻转。
undo ft1 data-coding命令用来恢复缺省情况。
ft1 data-coding { inverted | normal }
T1-F接口不对用户数据进行翻转。
T1-F接口视图
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当T1-F接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现的过多连0的缺陷。
需要注意的是,只有通信的T1-F线路两端的T1-F接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置T1-F接口Serial2/1/1对用户数据进行翻转。
[Sysname-Serial2/1/1] ft1 data-coding inverted
·     ft1 code
1.6.10  ft1 fdl
ft1 fdl命令用来配置T1-F接口在ESF格式时FDL比特位的使用模式。
undo ft1 fdl命令用来恢复缺省情况。
ft1 fdl { ansi | att | both | none }
undo ft1 fdl
禁止FDL(none)。
T1-F接口视图
none:禁止FDL。
FDL(Facility Data Link,设备数据链路)是T1的ESF帧格式中4kbps的一个带宽,可以用来传递性能信息或者环回码之类。
# 设置T1-F接口Serial2/1/1的FDL支持ANSI规范。
[Sysname-Serial2/1/1] ft1 fdl ansi
·     ft1 frame-format
ft1 frame-format命令用来设置T1-F接口的帧格式。
undo ft1 frame-format命令用来恢复缺省情况。
ft1 frame-format { esf | sf }
T1-F接口的帧格式为esf
T1-F接口视图
esf:设置T1-F接口的帧格式为ESF(Extended Super Frame,扩展超帧)格式。
sf:设置T1-F接口的帧格式为SF(Super Frame,超帧)格式。
T1-F接口支持超帧和扩展超帧两种帧格式。在超帧格式中,多个帧可以共享相同的帧同步信息和信令信息,从而有更多的有效位来传送用户数据。实际应用中,经常需要对系统进行测试,扩展超帧技术可以用来满足在测试时不影响正常业务运行的要求。
# 设置T1-F接口Serial2/1/1的帧格式为超帧格式。
[Sysname-Serial2/1/1] ft1 frame-format sf
·     ft1 fdl
ft1 idle-code命令用来设置T1-F接口的线路空闲码类型。
undo ft1 idle-code命令用来恢复缺省情况。
ft1 idle-code { 7e | ff }
undo ft1 idle-code
T1-F接口的线路空闲码类型为0x7e。
T1-F接口视图
7e:线路空闲码为0x7e类型。
ff:线路空闲码为0xff类型。
T1-F接口的线路空闲码类型是指在未被绑定到逻辑通道的时隙上发送的码型。
T1-F接口的线路空闲码类型有两种:0x7e和0xff。
# 设置T1-F接口Serial2/1/1的线路空闲码类型为0x7e。
[Sysname-Serial2/1/1] ft1 idle-code 7e
1.6.13  ft1 itf
ft1 itf命令用来设置T1-F接口的帧间填充符类型和个数。
undo ft1 itf命令用来恢复缺省情况。
ft1 itf { number number | type { 7e | ff } }
undo ft1 itf { number | type }
T1-F接口的帧间填充符类型为0x7e,帧间填充字节个数为4个。
T1-F接口视图
type:设置帧间填充符类型。
7e:表示帧间填充符为0x7e格式。
ff:表示帧间填充符为0xff格式。
T1-F接口的帧间填充符是指在已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。
T1-F接口的帧间填充符类型有两种:0x7e和0xff。
同时配置了ft1 code ami命令和ft1 data-coding inverted命令后,不能配置ft1 itf type ff命令,否则T1-F接口不能正常工作。
# 设置T1-F接口Serial2/1/1的帧间填充符类型为0xff。
[Sysname-Serial2/1/1] ft1 itf type ff
# 设置T1-F接口Serial2/1/1的帧间填充字节个数为5。
[Sysname-Serial2/1/1] ft1 itf number 5
·     ft1 code
·     ft1 data-coding
1.6.14  ft1 loopback
ft1 loopback命令用来开启T1-F接口的环回检测功能并设置检测方式。
undo ft1 loopback命令用来恢复缺省情况。
ft1 loopback { local | payload | remote }
undo ft1 loopback
环回检测功能处于关闭状态。
T1-F接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
# 设置T1-F接口Serial2/1/1进行对内自环。
[Sysname-Serial2/1/1] ft1 loopback local
ft1 sendloopcode命令用来配置发送远程环回控制码。
ft1 sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
不发送远程环回控制码。
T1-F接口视图
T1-F接口下可以通过发送环回控制码对远端的T1-F接口进行环回的自动配置。
SF格式下的LLB环回码占用有效带宽(1-24时隙);ESF格式下对LLB和PLB的环回码均使用ESF帧的FDL比特位收发。
# 设置T1-F接口Serial2/1/1发送带内线路环回激活码。
[Sysname-Serial2/1/1] ft1 sendloopcode inband-llb-up
·     ft1 frame-format
ft1 timeslot-list命令用来设置T1-F接口的时隙捆绑。
undo ft1 timeslot-list命令用来恢复缺省情况。
ft1 timeslot-list list [ speed { 56k | 64k } ]
T1-F接口捆绑所有的时隙,时隙的缺省速率为64kbps,即T1-F接口的缺省速率为1536kbps。
T1-F接口视图
list:被捆绑的时隙编号,取值范围为1~24。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以用number1,number2-number3的形式同时指定多个时隙。
speed { 56k | 64k }:时隙捆绑速率,单位为kbps。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。时隙的缺省速率为64kbps。
在对T1-F接口进行时隙捆绑后,接口的速率会同时改变。例如,当用户将1~10这十个时隙捆绑之后,接口的速率就会变为10×64kbps(或10×56kbps)。
与CT1接口不同的是,在T1-F接口上只能捆绑出一个通道组(channel set),捆绑出的通道组就对应当前的同步串口。而在CT1接口上,可以捆绑出多个通道组,并且每捆绑一个通道组,系统都会自动生成一个同步串口,与之相对应。
# 将T1-F接口Serial2/1/1上的1、2、5、10~15、18时隙捆绑起来。
[Sysname-Serial2/1/1] ft1 timeslot-list 1,2,5,10-15,18
1.6.17  mtu
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
T1-F接口的MTU值为1500字节。
T1-F接口视图
接口的MTU影响IP协议报文在该接口上传输时的分片与重组。
# 设置T1-F接口Serial2/1/1的MTU值为1430字节。
# 清除T1-F接口Serial2/1/1的统计信息。
1.7  CT3接口配置命令
1.7.1  alarm
alarm命令用来配置CT3接口的告警信号检测与发送功能。
undo alarm命令用来恢复缺省情况。
alarm { detect | generate { ais | febe | idle | rai } }
undo alarm { detect | generate { ais | febe | idle | rai } }
告警信号检测功能处于打开状态,发送功能处于关闭状态。
CT3接口视图
detect: CT3接口的定时检测各种告警的功能。
generate:发送某种告警信号,如AIS、RAI、IDLE和FEBE。可用于线路状态测试。
·     ais:Alarm Indication Signal,即告警指示信号。
·     febe:Far End Block Error,即远端块错误。
·     idle:空闲信号。
·     rai:Remote Alarm Indication,即远端告警指示信号。
上电后,CT3接口的告警信号定时检测功能是打开的,并能通过接口显示实时报告接口告警状态,如LOS、LOF、AIS、RAI等。当检测到LOS、LOF或AIS后,会向对方发送RAI告警信号。
主要的告警信号包括:LOS(Loss Of Signal,信号丢失)、LOF(Loss Of Frame,帧同步丢失)、AIS(Alarm Indication Signal,告警指示信号)、RAI(Remote Alarm Indication,远端告警指示信号)、FEBE(Far End Block Error,远端块错误)、IDLE为空闲信号。各信号具体格式遵循T3规范ANSI T1.107-1995。
接口一次只能发送一种告警信号(包括在使用detect功能时检测到LOS、LOF或AIS后而产生的RAI告警信号),发送另一种告警信号前必须使用undo alarm命令取消前一种告警信号。detect功能产生的告警信号(RAI)必须通过undo alarm detect命令取消。
告警的收发状态详见CT3接口显示部分。
# 打开CT3接口T3 2/1/0的告警检测功能。
[Sysname] controller t3 2/1/0
[Sysname-T3 2/1/0] alarm detect
# 在CT3接口T3 2/1/0上发送AIS告警信号。
 [Sysname-T3 2/1/0] alarm generate ais
1.7.2  cable
cable 命令用来配置CT3接口所连接电缆的长度。
cable feet
undo cable
CT3接口所连接电缆的长度为49英尺。
CT3接口视图
feet:电缆长度,取值范围为0~450,单位为英尺(feet)。
CT3接口所连接电缆的长度是指从路由器到配线架之间电缆的长度。
# 设置CT3接口T3 2/1/0的电缆长度为50英尺。
[Sysname-T3 2/1/0] cable 50
1.7.3  clock
clock命令用来设置CT3接口的时钟模式。
undo clock
CT3接口视图
使用主时钟模式还是从时钟模式,主要根据所连接的对端设备而定,如果与传输设备相连,本端通常设置为从时钟模式。
如果是两台路由器的CT3接口直接相连,则应该把一端路由器时钟设置为主时钟模式,另一端路由器时钟设置为从时钟模式。
# 设置CT3接口T3 2/1/0使用主时钟模式。
[Sysname-T3 2/1/0] clock master
1.7.4  controller t3
controller t3命令用来进入CT3接口视图。
controller t3 interface-number
interface-number:CT3接口的编号。
# 进入CT3接口T3 2/1/0的视图。
[Sysname-T3 2/1/0]
display controller t3命令用来显示CT3接口或T1通道的相关信息。
display controller t3 [ interface-number ] [ t1 line-number ]
interface-number:CT3接口编号。不指定本参数,将显示所有CT3接口的相关信息。
t1 line-number:T1通道的顺序号,取值范围为1~28。
本命令可以显示CT3接口的状态信息,同时还可以显示CT3接口工作在CT3模式时每个T1通道的相关信息。
# 显示CT3接口T3 2/1/0的相关信息。
<Sysname> display controller t3 2/1/0
T3 2/1/0
Current state: UP
Description: T3 2/1/0 Interface
  Work mode is CT3, cable length is 49 feet
  Frame-format is C-BIT Parity, line code is B3ZS
  Source clock is slave, loopback is not set
Alarm state:
  Receiver alarm state is none
MDL state:
  No message is sent now.
  Message data elements:
    EIC: line, LIC: line, FIC: line, UNIT: line
    FI: line, PORT_NO: line
    GEN_NO: line
  Periodical detection is disabled
FEAC state:
  No code is sent now. DS3 LOS(because of receive Alarm) was last sent.
  Periodical detection is enabled, no code received now.
 DS3 Out-of-Frame last received.
BERT state:(stopped)
  Data in current interval (22 seconds elapsed):
    1 Line Code Violations, 0 Far End Block Error
0 C-Bit Coding Violation, 1 P-bit Coding Violation
0 ulFraming Bit Err, 0 Severely Err ulFraming Secs
0 C-bit Err Secs, 0 C-bit Severely Err Secs
1 P-bit Err Secs, 0 P-bit Severely Err Secs
56 Unavailable Secs, 1 Line Err Secs
 T3 2/1/0  CT1 1 is up
   Frame-format ESF, clock slave, loopback not set
   FDL Performance Report is disabled
——(略)
表1-7 display controller t3命令显示信息解释
T3 2/1/0
Current state
接口的物理up/down状态
接口描述信息
最近一次使用reset counters controller t3命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters controller t3命令清除过该接口下的统计信息,则显示Never)
Basic Configuration
接口基本配置信息
Work mode
工作模式,包括通道化(CT3)和非通道化(T3)
cable length
线缆长度
Frame-format
帧格式,包括C-bit和M23
line code
线路编码
Source clock
时钟模式,包括master和slave
loopback
接口是否设置了环回
Alarm state
告警状态
显示接口收到的告警类别,包括:LOS、LOF、AIS、RAI。
当收到LOS、LOF、AIS之一时,向对方发送RAI,显示:Transmitter is sending RAI
MDL state
MDL状态
当前没有发送MDL消息
发送MDL消息(如path和idle-signal)时,显示如下:
Message sent now: path. idle signal
MDL数据元素
EIC、LIC、FIC和UNIT为四种MDL消息的公共元素,用户可设置
FI和PORT_NO分别为消息path和idle-signal的私有元素,用户可设置
GEN_NO: line
GEN_NO为消息test-signal的私有元素,用户可设置
Periodical detection is disabled.
MDL周期性检测被禁止。上电后默认为禁止。
当该检测功能被使能时,显示:
Periodical detection is enabled.
No message was received.
当检测到MDL消息时显示如:
Message received now: path.idle signal.
    path/FI: line
    idle Signal/PORT_NO: line
FEAC state:
FEAC状态
当前没有FEAC信号发出,上次收到的FEAC信号为DS3 LOS
FEAC周期性检测功能被使能。上电后默认使能。
当前未收到FEAC信号
上次收到的FEAC信号为DS3 Line Loop Back Deactivate
BERT状态(暂不支持)
历史统计数据
当前interval(15分钟为一个interval)内的各项错误计数(已过去的时间为22秒)
线路信号错误数,包括:BPV错误、EXZ错误
Far End Block Error
远端块错误数
C-Bit Coding violation
C比特错误数
P比特错误数
ulFraming Bit Err
帧比特错误数
帧比特严重错误的秒数
C-bit Err Secs
C比特错误的秒数
C比特严重错误的秒数,指1秒内C比特错误数超过44的秒
P-bit Err Secs
P比特错误的秒数
P特严重错误的秒数,指1秒内P比特错误数超过44的秒
Unavailable Secs
服务无法获取的秒数
Line Err Secs
线路错误的秒数,包括:LOS、BPV、EXZ、C比特错误、P比特错误等
Data in Interval 1:
Interval 1内的数据
Total Data (last 17 15 minute intervals):
总的数据(前17个interval)
CT3接口下T1通道1的up/down状态
T1通道的帧格式,包括ESF和SF
时钟方式包括slave和master,环回包括local、remote和payload
禁止用FDL链路传输性能报告信息(PPR),可用t1 fdl命令使能
T1通道发送器在发送RAI。当收到LOS、LOF或AIS时,发RAI
T1通道接收到的告警状态,包括:LOS、LOF、AIS和RAI
Line loop back activate code using inband signal last sent
上次发送的环回码:Line loop back activate code using inband signal
·     reset counters controller t3
1.7.6  feac
feac命令用来配置CT3接口的FEAC链路信号的检测和传输功能。
undo feac命令用来取消已有的FEAC配置。
feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
undo feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
CT3接口的FEAC定时检测功能处于打开状态,传输功能处于关闭状态。
CT3接口视图
detect:CT3接口上的定时检测FEAC链路信号功能。
generate:发送FEAC信号,包括ds3-losds3-aisds3-oofds3-idleds3-eqptfail
loopback:发送环回码,用于激活对端的线路环回(ds3-line)或者净荷环回(ds3-payload)。
FEAC(Far End Alarm and Control signal,远端告警与控制信号)是利用C-bit帧格式中第一个子帧中的第三个C比特组成的一条数据链路,可用于传输各种告警状态信号,也可用于传输环回控制码,用来激活或者取消对端的环回,进行环回测试。ANSI T1.107a中规定,FEAC可用于传输多种告警信号,并规定这条链路的数据帧为基于位的BOP(Bit Oriented Protocol)协议格式。
当用feac generate loopback { ds3-line | ds3-payload }激活对端环回后,可用undo feac generate loopback { ds3-line | ds3-payload }取消对端环回。
当利用该命令配置远端环回前,最好禁止本端的FEAC检测,以免发出的环回码在对方配好环回后被返回来,造成本端也配置为环回,引起线路上的环路死锁。
FEAC链路的收发状态的说明详见CT3接口显示部分。
# 打开CT3接口T3 2/1/0的FEAC链路数据检测功能。
[Sysname-T3 2/1/0] feac detect
# 在CT3接口T3 2/1/0上发送ds3-los信号。
[Sysname-T3 2/1/0] feac generate ds3-los
# 在CT3接口T3 2/1/0上发送环回码给对端,设置对端为线路环回。
[Sysname-T3 2/1/0] feac generate loopback ds3-line
1.7.7  frame-format
frame-format命令用来配置CT3接口所使用的帧格式。
frame-format { c-bit | m23 }
undo frame-format
CT3接口的帧格式为c-bit
CT3接口视图
c-bit:设置帧格式为C-bit。
m23:设置帧格式为m23。
只有当CT3接口工作在通道化模式时,才能配置本命令。
# 设置CT3接口T3 2/1/0的帧格式为m23
[Sysname-T3 2/1/0] frame-format m23
·     using
1.7.8  ft3
ft3命令用于配置CT3接口工作在FT3模式,并配置DSU模式或子速率。
undo ft3命令用来恢复缺省情况。
ft3 { dsu-mode { 0 | 2 | 3 | 4 } | subrate number }
undo ft3 { dsu-mode | subrate }
DSU模式为0,即Digital Link模式;子速率为44210kbps。
CT3接口视图
dsu-mode:设置FT3的DSU模式,支持常用的几家厂商的FT3 DSU模式,如下:
·     0:Digital Link,支持子速率范围为300~44210kbps,共147个速率等级,级差300746bps。
·     2:Larscom,支持子速率范围为3100~44210kbps,共14个速率等级,级差3157835bps。
·     3:Adtran,支持子速率范围为75~44210kbps,共588个速率等级,级差75187bps。
·     4:Verilink,支持子速率范围为1500~44210kbps,共20个速率等级,级差1578918bps。
subrate number:工作在FT3模式下的CT3接口的子速率。number的取值范围为1~44210,单位为kbps。
FT3(Fractional T3,或称Subrate T3)是T3的一种非标准应用模式。目前各厂商支持的速率等级均不一样,使用ft3命令可以使我们的设备和其它厂家设备的FT3 DSU模式兼容,实现互通。
该命令仅能在T3模式下使用,在CT3模式下该命令不可见。
通过ft3 subrate设置的速率值是一个大概值。由于通过ft3 dsu-mode命令配置的各DSU的子速率值是离散的,因此,当再通过ft3 subrate命令指定子速率后,T3接口会根据当前配置的DSU模式计算出与这个指定子速率最匹配的精确速率(精确到bps),并设置硬件电路支持该速率。
通过display interface serial interface-number:0命令可以查看T3接口的DSU模式、子速率设置值、接口实际速率和接口的波特率。接口实际速率为不含开销在内的纯数据带宽,接口波特率(44736kbps)为T3线路的实际速率(含开销位在内)。
# 设置T3接口T3 2/1/0工作在FT3模式,DSU模式为2,子速率为3000kbps。
[Sysname-T3 2/1/0] using t3
[Sysname-T3 2/1/0] ft3 dsu-mode 2
[Sysname-T3 2/1/0] ft3 subrate 3000
1.7.9  loopback
loopback命令用来开启CT3接口的环回检测功能并设置检测方式。
undo loopback
环回检测功能处于关闭状态。
CT3接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
CT3接口两种对外环回的区别在于:对外载荷环回(payload)需要处理帧头开销,而对外远端环回(remote)则不对帧进行处理。
如果CT3接口的链路层协议配置为PPP或HDLC,在设置环回后,其链路层协议状态将上报为down,这属于正常情况。
# 设置CT3接口T3 2/1/0对内自环。
[Sysname-T3 2/1/0] loopback local
1.7.10  mdl
mdl命令用来配置CT3接口的MDL链路消息检测与传输功能。
undo mdl命令用来恢复缺省情况。
mdl { data { eic string | fic string | gen-no string | lic string | pfi string | port-no string | unit string } | detect | generate { idle-signal | path | test-signal } }
undo mdl [ data [ eic | fic | gen-no | lic | pfi | port-no | unit ] | detect | generate [ idle-signal |  path | test-signal ] ]
上电后,CT3接口的MDL定时检测功能处于关闭状态,不发送任何消息。
CT3接口视图
data:设置MDL消息参数,其中eic、lic、fic和unit为三类MDL消息的公有参数,pfi、port-no和gen-no分别为消息path、idle signal和test signal的私有参数。这些参数为用户可定义的字符串,长度各有限制。
eic string:Equipment ID,为1~10个字符的字符串,缺省值为line。
fic string:Frame ID,为1~10个字符的字符串,缺省值为line。
gen-no string:Generator number in test signal message,test signal消息的私有参数,为1~38个字符的字符串,缺省值为line。
lic string:Location ID,为1~11个字符的字符串,缺省值为line。
pfi string:Facility ID in path message,path消息的私有参数,为1~38个字符的字符串,缺省值为line。
port-no string:Port number in idle signal message,idle signal消息的私有参数,为1~38个字符的字符串,缺省值为line。
unit string:Unit,为1~6个字符的字符串,缺省值为line。
detect:CT3接口上的定时检测MDL消息功能。
generate:按照data中配置的参数定时发送MDL消息,包括path、idle signal和test signal,可以同时发送。
MDL(Maintenance Data Link,维护数据链路)是利用C-bit帧格式中第五个子帧中的3个C比特组成的一条数据链路,可用于传输一些维护性的消息。ANSI T1.107a中规定,MDL可用于传输三种消息:path、idle signal和test signal,并规定这条链路的数据帧为LAPD协议格式。
MDL链路的收发状态详见CT3接口显示部分。
# 打开CT3接口T3 2/1/0的MDL检测功能。
[Sysname-T3 2/1/0] mdl detect
# 配置CT3接口T3 2/1/0的MDL的lic参数为字符串“hello”。
[Sysname-T3 2/1/0] mdl data lic hello
# 设置CT3接口T3 2/1/0发送path消息。
[Sysname-T3 2/1/0] mdl generate path
1.7.11  reset counters controller t3
reset counters controller t3命令用来清除CT3接口的统计信息。
reset counters controller t3 [ interface-number ]
interface-number:CT3接口编号。不指定本参数,将清除所有CT3接口的统计信息。
单独清除CT3接口的统计信息只能使用reset counters controller t3命令,不能使用reset counters interface命令。
CT3接口的统计信息可以用display controller t3命令来查看。
# 清除接口T3 2/1/0的统计信息。
<Sysname> reset counters controller t3 2/1/0
·     display controller t3
1.7.12  t1 alarm
t1 alarm命令用来配置CT3接口下某个T1通道的告警信号检测与发送功能。
undo t1 alarm命令用来恢复缺省情况。
t1 line-number alarm { detect | generate { ais | rai } }
undo t1 line-number alarm { detect | generate { ais | rai } }
CT3接口视图
line-number:T1通道号,取值范围为1~28。
detect:CT3接口下某个T1通道的告警信号检测功能。
generate:发送某种告警信号,如AIS、RAI。可用于线路状态测试。
上电后,CT3接口下各T1通道的告警信号定时检测功能是打开的,并能通过接口显示实时报告接口告警状态,如LOS、LOF、AIS、RAI等。当检测到LOS、LOF或AIS后,会向对方发送RAI告警信号。
主要的告警信号包括:LOS(Loss Of Signal,信号丢失)、LOF(Loss Of Frame,帧同步丢失)、AIS(Alarm Indication Signal,告警指示信号)、RAI(Remote Alarm Indication,远端告警指示信号)。各信号具体格式遵循T1规范ANSI T1.403。
一次只能发送一种告警信号(包括在使用detect功能时检测到LOS、LOF或AIS后而产生的RAI告警信号),发送另一种告警信号前必须使用undo t1 alarm generate命令取消前一种告警信号。detect功能产生的告警信号(RAI)必须通过undo t1 alarm detect命令取消。
告警的收发状态详见CT3接口显示部分。
# 打开CT3接口2/1/0的T1通道1的告警检测功能。
[Sysname-T3 2/1/0] t1 1 alarm detect
# 在CT3接口2/1/0的T1通道1上发送AIS告警信号。
[Sysname-T3 2/1/0] t1 1 alarm generate ais
1.7.13  t1 channel-set
t1 channel-set命令用来对T1通道进行时隙捆绑。
undo t1 channel-set命令用来取消时隙捆绑。
t1 line-number channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
undo t1 line-number channel-set set-number
不捆绑任何channel set。
CT3接口视图
set-number:指定T1通道上时隙捆绑形成的channel set的编号,取值范围为0~23。
speed { 56k | 64k }:配置时隙捆绑的方式。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。如果不指定速率,缺省采用64kbps。
当T1通道工作在成帧方式(CT1方式)时,可以对其进行时隙捆绑。系统会自动创建一个Serial接口,编号为serial number/line-number:set-number。此接口的速率为N×64kbps(或N×56kbps),其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 在T3 2/1/0接口的第一个T1通道上捆绑出一个128kbps的串口。
[Sysname-T3 2/1/0] t1 1 channel-set 1 timeslot-list 1,2
·     t1 unframed
1.7.14  t1 clock
t1 clock命令用来配置CT3接口下T1通道的时钟模式。
undo t1 clock命令用来恢复缺省情况。
t1 line-number clock { master | slave }
undo t1 line-number clock
CT3接口下T1通道的时钟模式为从时钟模式(slave)。
CT3接口视图
master:设置T1通道的时钟模式为主时钟模式,使用内部时钟信号。
slave:设置T1通道的时钟模式为从时钟模式,使用线路提供的时钟信号。
当CT3接口工作在通道化工作方式下,各个T1通道均能独立设置时钟。
# 设置T3接口下第一个T1通道使用从时钟模式。
[Sysname-T3 2/1/0] t1 1 clock slave
1.7.15  t1 fdl
t1 fdl命令用来设置CT3接口下T1通道的FDL链路格式。
undo t1 fdl命令用来取消T1通道的FDL链路传输。
t1 line-number fdl { ansi | att | both | none }
undo t1 line-number fdl
禁止FDL(none)。
CT3接口视图
att:使能FDL,遵循AT&T TR 54016 规范。
none:禁止FDL。
FDL(Facility Data Link,设备数据链路)是T1的ESF帧格式中的一条4kbps的数据链路,可用于传输PPR(Periodical Performance Report)数据,也可传输环回控制码,配置远端环回。ANSI T1.403规范定义,PPR数据格式为LAPD协议格式,环回控制码格式为BOP(Bit Oriented Protocol)协议格式。这里的t1 fdl命令仅用于启动PPR数据传输,对环回码的发送和检测没有影响,即收发环回码无需配置fdl。
需要注意的是,只有在CT3接口下的T1通道工作在通道化模式下,且T1帧格式为ESF时候,该配置才有效。
# 设置CT3接口T3 2/1/0的T1通道1的FDL格式为ansi。
[Sysname-T3 2/1/0] t1 1 fdl ansi
·     t1 frame-format
1.7.16  t1 frame-format
t1 frame-format命令用来配置T1通道的帧格式。
undo t1 frame-format命令用来恢复缺省情况。
t1 line-number frame-format { esf | sf }
undo t1 line-number frame-format
T1通道的帧格式为esf
CT3接口视图
line-numbe:T1通道号,取值范围为1~28。
esf:设置T1通道的帧格式为ESF(Extended Super Frame,扩展超帧)格式。
sf:设置T1通道的帧格式为SF(Super Frame,超帧)格式。
只有当T1通道工作在成帧方式时(使用命令undo t1 unframed),才能配置本命令。
# 设置T3接口下第一个T1通道的帧格式为超帧格式。
[Sysname-T3 2/1/0] t1 1 frame-format sf
·     t1 unframed
1.7.17  t1 loopback
t1 loopback命令用来开启CT3接口下T1通道的环回检测功能并设置检测方式。
undo t1 loopback命令用来恢复缺省情况。
t1 line-number loopback { local | payload | remote }
undo t1 line-number loopback
环回检测功能处于关闭状态。
CT3接口视图
local:设置T1通道对内自环。
payload:设置T1通道对外净荷环回。
remote:设置T1通道对外环回。
如果T1通道的链路层协议为PPP或HDLC,在设置自环或远端环回后,其链路层协议状态将上报为down,这属于正常情况。
环回功能通常用于进行某些特殊测试,正常工作时不要启动环回。
# 设置T3接口下第一个T1通道进行对内自环。
[Sysname-T3 2/1/0] t1 1 loopback local
1.7.18  t1 sendloopcode
t1 sendloopcode命令用来设置对端CT3接口的某个T1通道的环回模式。
undo t1 sendloopcode命令用来取消对应的配置。
t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
undo t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
不设置sendloopcode
CT3接口视图
fdl-ansi-line-up:发送FDL承载的符合ANSI规范的线路环回激活码,启动远端环回。
fdl-ansi-payload-up:发送FDL承载的符合ANSI规范的净荷环回激活码,启动远端环回。
fdl-att-payload-up发送FDL承载的符合AT&T规范的净荷环回激活码,启动远端环回。
inband-line-up:发送符合ANSI规范和AT&T规范的带内线路环回激活码,启动远端环回。
环回测试是一种有效的问题诊断方法。除了在远端设备上通过命令行配置环回外,还可发送环回控制码,设置远端设备的环回。ANSI T1.403规范定义了T1接口下的环回控制码类型和格式。按照环回类型,可分为line环回(数据流不经过成帧器)和payload环回(数据流经过成帧器)两种;按照传输环回控制码的载体,可分为利用inband信号(即T1的192位有效数据带宽或193位全部带宽)和利用ESF帧格式中的FDL链路两种。
# 在CT3接口2/1/0发送inband信号,配置对端CT3接口的T1通道1为line环回。
[Sysname-T3 2/1/0] t1 1 sendloopcode inband-line-up
1.7.19  t1 show
t1 show命令用来快捷显示CT3接口下某个T1通道线路状态。
t1 line-number show
CT3接口视图
show:显示T1通道物理线路状态。
# 显示T1通道1的线路状态。
[Sysname-T3 2/1/0] t1 1 show
T3 2/1/0  CT1 1: up
表1-8 t1 show命令显示信息解释
T3 2/1/0  CT1 1: up
Frame-format
T1通道的帧格式,包括ESF和SF
clock
时钟模式,包括slave和master
loopback
环回设置
禁止用FDL链路传输性能报告信息(PPR),可用t1 fdl ansi命令使能
T1通道接收到的告警,包括:LOS、LOF、AIS和RAI
BERT state
BERT测试状态(暂不支持)
1.7.20  t1 shutdown
t1 shutdown命令用来关闭CT3接口的某个T1通道。
undo t1 shutdown命令用来打开T1通道。
t1 line-number shutdown
undo t1 line-number shutdown
T1通道处于打开状态。
CT3接口视图
该命令对于T1通道及其捆绑出的串口均有效。对指定T1通道执t1 shutdown操作后,该T1通道捆绑形成的串口将shutdown,停止收发数据。如果执行undo t1 shutdown操作,则所有该T1通道捆绑形成的串口将被重新启用。
# 关闭T3接口下第一个T1通道。
[Sysname-T3 2/1/0] t1 1 shutdown
1.7.21  t1 unframed
t1 unframed命令用来配置CT3接口的T1通道工作在非成帧方式(T1方式)。
undo t1 unframed命令用来配置CT3接口的T1通道工作在成帧方式(CT1方式)。
t1 line-number unframed
undo t1 line-number unframed
T1通道工作在成帧方式。
CT3接口视图
当T1配置成非成帧方式后,它将不包含帧控制信息,也不分时隙,不能进行时隙捆绑。此时,系统会自动创建一个Serial接口,编号为serial number/line-umber:0。此接口的速率为1544kbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 设置T3接口下第一个T1通道工作在非成帧方式。
[Sysname-T3 2/1/0] t1 1 unframed
·     t1 channel-set
1.7.22  using
using命令用来配置CT3接口的工作模式。
using { ct3 | t3 }
undo using
CT3接口工作在CT3模式。
CT3接口视图
ct3:设置接口工作在通道化模式(CT3模式)。
t3:设置接口工作在非通道化模式(T3模式)。
只有当CT3接口工作在通道化模式时,才能够对T1通道进行配置。
当CT3接口工作在非通道化模式时,系统会自动创建一个Serial接口,编号为serial number/0:0。此接口的速率为44.736Mbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 配置接口T3 2/1/0工作在非通道化模式。
1.8  T3接口配置命令
1.8.1  alarm
alarm命令用来配置T3接口的告警信号检测与发送功能。
T3接口视图
detect: T3接口的定时检测各种告警的功能。
·     idle:空闲信号。
上电后,T3接口的告警信号定时检测功能是打开的,并能通过接口显示实时报告接口告警状态,如LOS、LOF、AIS、RAI等。当检测到LOS、LOF或AIS后,会向对方发送RAI告警信号。
对于MIM-1T3-V2接口模块,使用alarm generate命令发送告警信号后,将不会发送使用detect功能时检测到LOS、LOF或AIS后而产生的RAI告警信号。
告警的收发状态详见T3接口显示部分。
# 打开T3接口T3 2/1/0的告警检测功能。
# 在T3接口T3 2/1/0上发送AIS告警信号。
1.8.2  cable
cable 命令用来配置T3接口所连接电缆的长度。
cable feet
undo cable
T3接口所连接电缆的长度为49英尺。
T3接口视图
# 设置T3接口T3 2/1/0的电缆长度为50英尺。
1.8.3  clock
clock命令用来设置T3接口的时钟模式。
undo clock命令用来恢复缺省情况。
undo clock
T3接口视图
如果是两台路由器的T3接口直接相连,则应该把一端路由器时钟设置为主时钟模式,另一端路由器时钟设置为从时钟模式。
# 设置T3接口T3 2/1/0使用主时钟模式。
1.8.4  controller t3
controller t3命令用来进入T3接口视图。
interface-number:T3接口的编号。
# 进入T3接口T3 2/1/0的视图。
[Sysname-T3 2/1/0]
1.8.5  display controller t3
display controller t3命令用来显示T3接口的相关信息。
interface-number:T3接口编号。不指定本参数,将显示所有T3接口的相关信息。
# 显示T3接口T3 2/1/0的相关信息。
T3 2/1/0
Current state: DOWN
  Work mode is Fractional T3, cable length is 49 feet.
  Frame-format is C-BIT Parity, line code is B3ZS.
  Source clock is slave, loopback is not set.
Alarm state:
  Receiver alarm state is none.
    0 Line Code Violations, 0 Far End Block Error
    0 C-Bit Coding Violation, 0 P-bit Coding Violation
    0 P-bit Err Secs, 0 P-bit Severely Err Secs
    0 Unavailable Secs, 0 Line Err Secs
  Data in current interval (279 seconds elapsed):
  Data in Interval 1:
  Data in Interval 2:
  Data in Interval 3:
  Data in Interval 4:
  Data in Interval 5:
    514739731 Line Code Violations, 0 Far End Block Error
    14 Unavailable Secs, 15 Line Err Secs
  Total Data (last 5 15 minute intervals):
表1-9 display controller t3命令显示信息解释
T3 2/1/0
Current state
接口的物理up/down状态
接口描述信息
Basic Configuration
接口基本配置信息
Work mode
工作模式
cable length
线缆长度
Frame-format
帧格式(暂不支持)
line code
线路编码
Source clock
时钟模式,包括master和slave
loopback
接口是否设置了环回
Alarm state
告警状态
历史统计数据
当前interval(15分钟为一个interval)内的各项错误计数(已过去的时间为279秒)
Far End Block Error
远端块错误数
C比特错误数
P比特错误数
ulFraming Bit Err
帧比特错误数
帧比特严重错误的秒数
C-bit Err Secs
C比特错误的秒数
P-bit Err Secs
P比特错误的秒数
Unavailable Secs
服务无法获取的秒数
Line Err Secs
Data in Interval 1:
Interval 1内的数据
总的数据(前5个interval)
1.8.6  ft3
ft3命令用于配置T3接口工作在FT3模式,并配置子速率。
undo ft3命令用来恢复缺省情况。
ft3 subrate number
undo ft3 subrate
子速率为44210kbps。
T3接口视图
subrate number:工作在FT3模式下的T3接口的子速率。number的取值范围为1~44210,单位为kbps。
通过ft3 subrate设置的速率值是一个大概值。由于DSU的子速率值是离散的,因此,当通过ft3 subrate命令指定子速率后,T3接口会根据当前的DSU模式(只能为0:Digital Link,支持子速率范围为300~44210kbps,共147个速率等级,级差300746bps)计算出与这个指定子速率最匹配的精确速率(精确到bps),并设置硬件电路支持该速率。
通过display interface serial interface-number:0命令可以查看T3接口的子速率设置值、接口实际速率和接口的波特率。接口实际速率为不含开销在内的纯数据带宽,接口波特率(44736kbps)为T3线路的实际速率(含开销位在内)。
# 设置T3接口T3 2/1/0工作在FT3模式,子速率为3000kbps。
1.8.7  loopback
loopback命令用来开启T3接口的环回检测功能并设置检测方式。
undo loopback
环回检测功能处于关闭状态。
T3接口视图
local:设置接口对内自环。
payload:设置接口对外净荷环回。
remote:设置接口对外环回。
如果T3接口的链路层协议配置为PPP或HDLC,在设置环回后,其链路层协议状态将上报为down,这属于正常情况。
# 设置T3接口T3 2/1/0对内自环。
1.8.8  reset counters controller t3
reset counters controller t3命令用来清除T3接口的统计信息。
interface-number:T3接口编号。不指定本参数,将清除所有T3接口的统计信息。
单独清除T3接口的统计信息只能使用reset counters controller t3命令,不能使用reset counters interface命令。
1.8.9  using t3
using t3命令用来创建T3接口的Serial接口。
using t3
undo using
T3接口未创建Serial接口。
T3接口视图
配置本命令后,系统会自动创建一个Serial接口,编号为serial number/0:0。此接口的速率为44.736Mbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 创建接口T3 2/1/0的Serial接口。
