01-正文
本章节下载: 01-正文 (564.36 KB)
1.1.4 debugging system internal arp event
1.1.5 debugging system internal arp features
1.1.6 debugging system internal arp notify
1.1.7 debugging system internal arp sync
1.1.8 debugging system internal igmp-snooping fsm tracing
1.1.9 debugging system internal ike detail
1.1.10 debugging system internal ipsec packet detail
1.1.11 debugging system internal ipv6 fib prefix
1.1.12 debugging system internal mld-snooping fsm tracing
1.1.13 debugging system internal nd
1.1.14 debugging system internal nd sub-features
1.1.15 debugging system internal stg
1.1.16 debugging system internal stp
1.1.17 debugging system internal vlan
1.1.18 debugging system internal wlan forward packet
1.1.20 display debugging wlan radio
1.1.21 display fastforward session table
1.1.22 display system internal acl
1.1.23 display system internal arp ifcb
1.1.24 display system internal arp machash
1.1.25 display system internal arp probe
1.1.26 display system internal arp rbhash
1.1.27 display system internal arp reload
1.1.28 display system internal arp rule
1.1.29 display system internal arp statistics
1.1.30 display system internal dbm
1.1.31 display system internal dot11 characteristics
1.1.32 display system internal dot11 verbose
1.1.33 display system internal ethernet character
1.1.34 display system internal ethernet controlblock
1.1.35 display system internal ifmgr down
1.1.36 display system internal ifmgr entry
1.1.37 display system internal ifmgr event
1.1.38 display system internal ifmgr hotplug
1.1.39 display system internal ifmgr index
1.1.40 display system internal ifmgr list
1.1.41 display system internal ifmgr name
1.1.42 display system internal ifmgr type
1.1.43 display system internal ike phase2-sa count
1.1.44 display system internal ike phase2-sa verbose
1.1.45 display system internal ike received-message count
1.1.46 display system internal ike sent-message count
1.1.47 display system internal ip address
1.1.48 display system internal ipsec block-flow
1.1.49 display system internal ipsec received-message
1.1.50 display system internal ipsec sent-message
1.1.51 display system internal ipsec sp
1.1.52 display system internal ipv6 address
1.1.53 display system internal ipv6 fib prefix
1.1.54 display system internal ipv6 fib prefix entry-status
1.1.55 display system internal ipv6 fib prefix ipv6-address
1.1.56 display system internal ipv6 l2-multicast fast-forwarding cache verbose
1.1.57 display system internal ipv6 l2-multicast ip forwarding verbose
1.1.58 display system internal ipv6 l2-multicast ip verbose
1.1.59 display system internal ipv6 l2-multicast ipc statistics
1.1.60 display system internal ipv6 l2-multicast mac forwarding verbose
1.1.61 display system internal ipv6 l2-multicast mac verbose
1.1.62 display system internal ipv6 multicast forwarding vlan reference
1.1.63 display system internal ipv6 multicast forwarding-table dummy
1.1.64 display system internal ipv6 muticast fast-forwarding cache verbose
1.1.65 display system internal ipv6 rib event attribute
1.1.66 display system internal ipv6 rib event policy
1.1.67 display system internal ipv6 rib event prefix
1.1.68 display system internal ipv6 rib event protocol
1.1.69 display system internal ipv6 rib event statistics
1.1.70 display system internal ipv6 rib instance
1.1.71 display system internal ipv6 rib log
1.1.72 display system internal ipv6 rib memory
1.1.73 display system internal ipv6 rib nib log
1.1.74 display system internal ipv6 rib prefix
1.1.75 display system internal ipv6 rib summary
1.1.76 display system internal ipv6 route-direct interface
1.1.77 display system internal ipv6 route-static nib log
1.1.78 display system internal ipv6 tcp port-info
1.1.79 display system internal ipv6 udp port-info
1.1.80 display system internal kernel memory dump
1.1.81 display system internal kernel memory pool
1.1.82 display system internal l2-multicast fast-forwarding cache verbose
1.1.83 display system internal l2-multicast ip forwarding verbose
1.1.84 display system internal l2-multicast ip verbose
1.1.85 display system internal l2-multicast ipc statistics
1.1.86 display system internal l2-multicast mac forwarding verbose
1.1.87 display system internal l2-multicast mac verbose
1.1.88 display system internal link-aggregation global
1.1.89 display system internal link-aggregation interface
1.1.90 display system internal lipc dump
1.1.91 display system internal lipc dump configuration
1.1.92 display system internal lipc history
1.1.93 display system internal lipc lcmp statistics
1.1.94 display system internal lipc lgmp group
1.1.95 display system internal lipc lgmp group-list
1.1.96 display system internal lipc lgmp physical-group
1.1.97 display system internal lipc lgmp physical-group-list
1.1.98 display system internal lipc lgmp statistics
1.1.99 display system internal lipc lip statistics
1.1.100 display system internal lipc loop statistics
1.1.101 display system internal lipc mtcp group
1.1.102 display system internal lipc mtcp group all
1.1.103 display system internal lipc mtcp performance
1.1.104 display system internal lipc mtcp statistics
1.1.105 display system internal lipc pcb mbuf statistics
1.1.106 display system internal lipc pcb statistics
1.1.107 display system internal lipc physical
1.1.108 display system internal lipc publish global-cb
1.1.109 display system internal lipc publish statistics
1.1.110 display system internal lipc stcp event
1.1.111 display system internal lipc stcp global-server
1.1.112 display system internal lipc stcp links
1.1.113 display system internal lipc stcp performance
1.1.114 display system internal lipc stcp port
1.1.115 display system internal lipc stcp statistics
1.1.116 display system internal lipc stcp status
1.1.117 display system internal lipc stream
1.1.118 display system internal lipc sudp pcb-info
1.1.119 display system internal lipc sudp statistics
1.1.120 display system internal lipc sudp { global-port | local-port }
1.1.121 display system internal lipc topology history
1.1.122 display system internal lipc topology link
1.1.123 display system internal lipc topology node
1.1.124 display system internal lipc topology process-time
1.1.125 display system internal lipc topology statistics
1.1.126 display system internal lipc topology status
1.1.127 display system internal lps
1.1.128 display system internal mac-address configuration
1.1.129 display system internal mac-address learned
1.1.130 display system internal mac-address protocol
1.1.131 display system internal mac-address statistics
1.1.132 display system internal mac-forwarding controlblock
1.1.133 display system internal multicast capability
1.1.134 display system internal multicast forwarding vlan reference
1.1.135 display system internal multicast forwarding-table dummy
1.1.136 display system internal multicast forwarding-table verbose
1.1.137 display system internal multicast record
1.1.138 display system internal nat
1.1.139 display system internal nat aging-queue
1.1.140 display system internal nat statistics
1.1.141 display system internal nd dad
1.1.142 display system internal nd entry
1.1.143 display system internal nd ifcb
1.1.144 display system internal nd machash
1.1.145 display system internal nd probe
1.1.146 display system internal nd rbhash
1.1.147 display system internal nd reload
1.1.148 display system internal nd rule
1.1.149 display system internal nd static
1.1.150 display system internal nd statistics
1.1.151 display system internal ppp statistics
1.1.152 display system internal process state
1.1.153 display system internal rawip
1.1.154 display system internal rib event attribute
1.1.155 display system internal rib event policy
1.1.156 display system internal rib event protocol
1.1.157 display system internal rib event statistics
1.1.158 display system internal rib instance
1.1.159 display system internal rib log
1.1.160 display system internal rib memory
1.1.161 display system internal rib nib log
1.1.162 display system internal rib prefix
1.1.163 display system internal rib summary
1.1.164 display system internal route-direct interface
1.1.165 display system internal route-static nib log
1.1.166 display system internal session
1.1.167 display system internal session aging-queue
1.1.168 display system internal session relation-table ipv4
1.1.169 display system internal session relation-table ipv6
1.1.170 display system internal session table ipv4
1.1.171 display system internal session table ipv6
1.1.172 display system internal startup cache
1.1.173 display system internal stp bridge-info
1.1.174 display system internal stp port-info
1.1.175 display system internal tcp port-info
1.1.176 display system internal udp port-info
1.1.177 display system internal vlan
1.1.178 display system internal wlan band-navigation
1.1.179 display system internal wlan client ip
1.1.180 display system internal wlan mesh-ap
1.1.181 display system internal wlan mesh-forwarding statistics
1.1.182 display system internal wlan mesh-mac
1.1.183 display system internal wlan mesh-packet statistics
1.1.184 display system internal wlan mesh-security
1.4.1 memory boundary-check enable
1.4.2 memory boundary-check scan
1.6.1 reset system internal arp statistics
1.6.2 reset system internal ipv6 multicast forwarding-table dummy
1.6.3 reset system internal ipv6 rib log
1.6.4 reset system internal ipv6 rib nib log
1.6.5 reset system internal ipv6 rib summary
1.6.6 reset system internal ipv6 route-static nib log
1.6.7 reset system internal lipc dump buffer
1.6.8 reset system internal mac-address statistics
1.6.9 reset system internal multicast forwarding-table dummy
1.6.10 reset system internal multicast record
1.6.11 reset system internal nat statistics
1.6.12 reset system internal nd statistics
1.6.13 reset system internal ppp statistics
1.6.14 reset system internal rib log
1.6.15 reset system internal rib nib log
1.6.16 reset system internal rib summary
1.6.17 reset system internal route-static nib log
本手册中的命令,仅供专业技术人员进行问题定位和调试所用,不建议用户使用。
debugging lipc命令用来打开LIPC的debug开关。
undo debugging lipc命令用来恢复缺省情况。
debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo } [ lip lip ]
undo debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo | stream } [ lip lip ]
LIPC的debug开关处于关闭状态。
detail:用来打开LIPC的报文详细内容的调试信息开关。
dump port:表示端口号,取值范围为0~65535。
lgmp:用来打开LIPC的LGMP模块的调试信息开关。
mbuf:用来打开LIPC的MBUF模块的调试信息开关。
mtcp:用来打开LIPC的MTCP模块调试信息开关。
pub:用来打开LIPC的PUB模块的调试信息开关。
stcp:用来打开LIPC的STCP模块的调试信息开关。
stream:用来打开LIPC的STREAM模块的调试信息开关。
topo:用来打开LIPC的TOPO模块的调试信息开关。
lip lip:表示远端节点号,取值范围为0~65535。设备只有一个节点,该参数无意思,无需选择。
debugging lipc mtcp命令用来打开LIPC组播传输控制协议的调试信息开关。
undo debugging lipc mtcp命令用来恢复缺省情况。
debugging lipc mtcp [ group group-id ] [ lip lip ]
undo debugging lipc mtcp [ group group-id ] [ lip lip ]
LIPC组播传输控制协议调试信息开关处于关闭状态。
Probe视图
group group-id:要调试的组播端口号,取值范围为0~65535。不指定该参数时,表示所有组播组。
debugging lipc stcp命令用来打开LIPC单播的调试信息开关。
undo debugging lipc stcp命令用来恢复缺省情况。
debugging lipc stcp [ port port1 [ port port2 ] ] [ lip lip ]
undo debugging lipc stcp [ port port1 [ port port2 ] ] [ lip lip ]
LIPC单播调试信息开关处于关闭状态。
Probe视图
port port1 [ port port2 ]:port1和port2分别为连接的本地和对端端口号,取值范围为0~65535,缺省值为0。。
debugging system internal arp event命令用来打开ARP事件调试信息开关。
undo debugging system internal arp event命令用来关闭ARP事件调试信息开关。
ARP事件调试信息开关处于关闭状态。
Probe视图
debugging system internal arp features命令用来打开ARP子特性的调试信息开关。
undo debugging system internal arp features命令用来关闭ARP子特性的调试信息开关。
debugging system internal arp features { notify | packet }
undo debugging system internal arp features { notify | packet }
ARP子特性的调试信息开关处于关闭状态。
Probe视图
notify:表示ARP子特性的外部通知调试开关。
packet:表示ARP子特性报文调试开关。
debugging system internal arp notify命令用来打开ARP的外部通知调试信息开关。
undo debugging system internal arp notify命令用来关闭ARP的外部通知调试信息开关。
ARP的外部通知调试信息开关处于关闭状态。
Probe视图
debugging system internal arp sync命令用来打开ARP表项的同步调试开关。
undo debugging system internal arp sync命令用来关闭ARP表项的同步调试开关。
ARP表项的同步调试信息开关处于关闭状态。
Probe视图
debugging system internal igmp-snooping fsm tracing命令用来打开IGMP Snooping状态机的Trace日志调试信息开关。
undo debugging system internal igmp-snooping fsm tracing命令用来关闭IGMP Snooping状态机的Trace日志调试信息开关。
debugging system internal igmp-snooping fsm tracing [ vlan vlan-id [ group-address source-address ] ]
IGMP Snooping状态机的Trace日志调试信息开关处于关闭状态。
Probe视图
vlan vlan-id:输出指定VLAN内的信息,vlan-id表示VLAN的编号,取值范围为1~4094。如果未指定本参数,将输出所有VLAN内的信息。
group-address:输出指定组播组的信息。如果未指定本参数,将输出所有组播组的信息。
source-address:输出指定组播源的信息。如果未指定本参数,将输出所有组播源的信息。
debugging system internal ike detail { event | packet [ remote-address { ipv4-address | ipv6 ipv6-address } [ local-address { ipv4-address | ipv6 ipv6-address } | remote-port port-number ] * ] }
undo debugging system internal ike detail { event | packet }
Probe视图
event:表示事件调试信息开关。
packet:表示报文调试信息开关。
remote-address:根据对端地址过滤调试信息。
local-address:根据本端地址过滤调试信息。
ipv4-address:表示IPv4地址。
ipv6 ipv6-address:表示IPv6地址。
remote-port remote-port:根据对端端口过滤调试信息。port-number表示对端端口号,取值范围为0~65535。
【描述】
debugging system internal ike detail命令用来打开IKE详细调试开关。undo debugging system internal ike detail命令用来关闭IKE详细调试开关。
缺省情况下,IKE详细调试开关处于关闭状态。
debugging system internal ipsec packet detail命令用来打开IPsec转发过程的调试信息开关。
undo debugging system internal ipsec packet detail命令用来关闭IPsec转发过程的调试信息开关。
debugging system internal ipsec packet detail [ acl [ ipv6 ] acl-number | { ipv6-policy | policy } policy-name [ policy-sequence-number ] | profile profile-name | remote { ipv4-address | ipv6 ipv6-address } | spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-number ]
undo debugging system internal ipsec packet detail [ acl [ ipv6 ] acl-number | { ipv6-policy | policy } policy-name [ policy-sequence-number ] | profile profile-name | remote { ipv4-address | ipv6 ipv6-address } | spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-number ]
Probe视图
acl [ ipv6 ] acl-number:显示符合指定高级ACL的调试信息。ipv6表示IPv6类型的高级ACL,若不指定,则表示IPv4类型的高级ACL。acl-number是高级ACL的变化,取值范围为3000~3999。
{ ipv6-policy | policy } policy-name [ policy-sequence-number ]:显示指定IPv4或IPv6 IPsec安全策略的调试信息。
· ipv6-policy:IPv6 IPsec安全策略。
· policy:IPv4 IPsec安全策略。
· policy-name:IPsec安全策略的名称,为1~63个字符的字符串,不区分大小写。
· policy-sequence-number:IPsec安全策略的顺序号,取值范围为1~65535,若不指定此参数,则表示显示指定名称IPsec安全策略中所有IPsec安全策略表项的调试信息。
profile profile-name:显示指定IPsec安全框架的调试信息。profile-name是IPsec安全框架的名称,为1~63个字符的字符串,不区分大小写。
remote { ipv4-address | ipv6 ipv6-address }:显示符合指定IPsec隧道对端IPv4/IPv6地址的过滤信息。
· ipv4-address:IPsec隧道的对端IPv4地址。
· ipv6 ipv6-address:IPsec隧道的对端IPv6地址。
spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-number:显示符合SA的三元组信息(对端IP地址、安全协议、安全参数索引)的过滤信息。
· ipv4-address:对端的IPv4地址。
· ipv6 ipv6-address:对端的IPv6地址。
· ah:AH协议。
· esp:ESP协议。
· spi-number:安全参数索引,取值范围为256~4294967295。
命令用于在Probe视图下查看IPsec转发过程中报文详细信息,包括加密前报文信息、加密后报文详细信息、解密前报文详细信息、解密后报文详细信息。
debugging system internal ipv6 fib prefix命令用来打开IPv6 FIB调试信息开关。
undo debugging system internal ipv6 fib prefix命令用来关闭IPv6 FIB调试信息开关。
debugging system internal ipv6 fib prefix { all | message | hardware }
undo debugging system internal ipv6 fib prefix { all | message | hardware }
IPv6 FIB调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开前缀消息调试开关,打印路由下发和板间同步的IPv6 FIB前缀消息。
hardware:打开下驱动信息调试开关,打印下发驱动信息以及驱动返回的消息。
debugging system internal mld-snooping fsm tracing命令用来打开MLD Snooping状态机的Trace日志调试信息开关。
undo debugging system internal mld-snooping fsm tracing命令用来关闭MLD Snooping状态机的Trace日志调试信息开关。
debugging system internal mld-snooping fsm tracing [ vlan vlan-id [ ipv6-group-address ipv6-source-address ] ]
MLD Snooping状态机的Trace日志调试信息开关处于关闭状态。
Probe视图
group ipv6-group-address:输出指定IPv6组播组的信息。如果未指定本参数,将输出所有IPv6组播组的信息。
source ipv6-source-address:输出指定IPv6组播源的信息。如果未指定本参数,将输出所有IPv6组播源的信息。
debugging system internal nd { notify | sync }
undo debugging system internal nd { notify | sync }
Probe视图
notify:表示邻居发现的通知调试开关。
sync: 表示邻居发现的同步调试开关。
【描述】
debugging system internal nd命令用来打开邻居发现的调试信息开关。undo debugging system internal nd命令用来关闭邻居发现的调试信息开关。
缺省情况下,邻居发现的调试信息开关处于关闭状态。
debugging system internal nd sub-features { all | event | packet }
undo debugging system internal nd sub-features
Probe视图
all:表示ND子特性的所有调试信息开关。
event:表示ND子特性的事件调试信息开关。
packet:表示ND子特性的报文调试信息开关。
【描述】
debugging system internal nd sub-features命令用来打开ND子特性的调试开关。undo debugging system internal nd sub-features命令用来关闭ND子特性的调试开关。
缺省情况下,ND子特性的调试开关处于关闭状态。
debugging system internal stg命令用来开启STG调试信息开关。
undo debugging system internal stg命令用来关闭STG调试信息开关。
debugging system internal stg { all | bind | error | map | state | tc }
undo debugging system internal stg { all | bind | error | map | state | tc }
STG调试信息开关处于关闭状态。
Probe视图
all:表示STG所有调试信息开关。
bind:表示STG与VLAN绑定调试信息开关。
error:表示STG错误调试信息开关。
map:表示STG与STI映射事件调试信息开关。
state:表示STG状态设置调试信息开关。
tc:表示TC事件调试信息开关。
debugging system internal stp命令用来开启生成树进程间通信调试开关。
undo debugging system internal stp命令用来关闭生成树进程间通信调试开关。
debugging system internal stp ipc
undo debugging system internal stp ipc
生成树进程间通信调试开关处于关闭状态。
Probe视图
ipc:表示生成树进程间通信调试信息开关。
debugging system internal vlan命令用来打开VLAN的调试开关。
undo debugging system internal vlan命令用来关闭VLAN的调试开关。
debugging system internal vlan { all | error | event | execution | hardware }
undo debugging system internal vlan { all | error | event | execution | hardware }
VLAN的调试开关处于关闭状态。
Probe视图
all:表示VLAN的所有调试信息开关。
error:表示VLAN的错误调试信息开关。
event:表示VLAN的事件调试信息开关。
execution:表示VLAN的执行调试信息开关。
hardware:表示VLAN的硬件调试信息开关。
debugging system internal wlan forward packet用来打开WLAN转发WLAN转发报文调试开关,并设置过滤调试信息的规则。
undo debugging system internal wlan forward packet命令用来关闭WLAN转发报文调试开关,并删除所有设置的过滤调试信息的规则。
debugging system internal wlan forward packet content content-hex [ offset bytes ]
WLAN转发报文的调试开关处于关闭状态。
Probe视图
packet:WLAN转发报文调试信息开关。
content content-hex:指定用来过滤WLAN转发报文调试信息的过滤信息。contents-hex表示过滤信息,可以输入多条,信息之间使用符号“&”相隔,表示过滤信息之间是“与”的关系,当过滤信息依次全部匹配成功时,才会打印WLAN转发报文的调试信息。其中每条过滤信息表示报文十六进制内容,形式为H:H:H,H代表用十六进制表示的报文中一个字节的内容,H之间使用“:”相隔,H的个数范围1~256。
offset bytes:表示从指定的偏移位置开始匹配调试信息,bytes表示偏移量,取值范围0~127,单位为字节,缺省值为0字节。当使用“&”指定多条规则时,不可指定offset。
debugging wlan radio命令用来配置Radio调试信息开关。
undo debugging wlan radio命令用来关闭Radio调试信息开关。
debugging wlan radio { all | error | event } { all | bandwidth | channel | channellist | power | preamble | radiobkp | radiostate | rate | scanconfig | statis | type | wlanid }
undo debugging wlan radio { all | error | event } { all | bandwidth | channel | channellist | power | preamble | radiobkp | radiostate | rate | scanconfig | statis | type | wlanid }
Radio调试信息开关处于关闭状态。
Probe视图
all:表示Radio所有类型调试信息开关。
error:表示Radio的错误类型调试信息开关。
event:表示Radio的事件类型调试信息开关。
all:表示Radio所有场景调试信息开关。
channel:表示Radio工作信道信息场景的调试信息开关。
type:表示Radio工作类型场景的调试信息开关。
radiostate:表示Radio工作状态场景的调试信息开关。
power:表示Radio发射功率场景的调试信息开关。
rate:表示Radio协商速率场景的调试信息开关。
wlanid:表示Radio wlan id场景的调试信息开关。
bandwidth:表示Radio带宽场景的调试信息开关。
channellist:表示Radio信道列表场景的调试信息开关。
radiobkp:表示Radio数据备份场景的调试信息开关。
scanconfig:表示Radio扫描配置场景的调试信息开关。
statis:表示Radio统计信息上报场景的调试信息开关。
preamble:表示Radio前导码场景的调试信息开关。
display debugging wlan radio命令用来显示Radio调试信息开关状态。
Probe视图
display fastforward session table命令用来显示未经过安全业务处理的会话表项。
display fastforward session table { ipv4 | ipv6 } [ source-ip source-ip ] [ destination-ip destination-ip ] [ verbose ]
Probe视图
ipv4:显示IPv4会话表项。
ipv6:显示IPv6会话表项。
source-ip source-ip:显示指定源IP地址的会话表项。其中,source-ip表示发起方到响应方会话的源IP地址。
destination-ip destination-ip:显示指定目的IP地址的会话表项。其中,destination-ip表示发起方到响应方会话的目的IP地址。
verbose:显示详细的会话表项。不指定该参数表示显示会话表项的概要信息。
如果除ipv4、ipv6外不指定任何参数,则显示所有未经过安全业务处理的IPv4或IPv6会话表项。
display system internal acl命令用来显示ACL的配置和运行情况。
display system internal acl [ ipv6 | mac ] { acl-number | name acl-name }
Probe视图
ipv6:指定ACL类型为IPv6 ACL。
mac:指定ACL类型为二层ACL。若未指定以上两种类型,则表示IPv4 ACL。
acl-number:显示指定编号的ACL的配置和运行情况。acl-number表示ACL的编号,取值范围及其代表的ACL类型如下:
· 2000~2999:表示基本ACL。
· 3000~3999:表示高级ACL。
· 4000~4999:表示二层ACL。
name acl-name:显示指定名称的ACL的配置和运行情况。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。
display system internal arp ifcb命令用来查看指定板上二层或三层接口ARP控制块信息
display system internal arp ifcb interface interface-type interface-number
Probe视图
interface interface-type interface-number :显示指定二层或三层接口上的ARP控制块信息,interface-type interface-number为接口类型和接口编号。
display system internal arp machash命令用来显示指定板上machash表项信息。
display system internal arp machash vlan vlan-id ip ip-address
Probe视图
vlan vlan-id:显示指定VLAN上machash表项信息。vlan-id表示指定VLAN的id。
ip ip-address:显示指定IP上machash表项信息。ip-address表示指定IP的IP地址
display system internal arp probe命令用来显示指定板上ARP探测链表项。
Probe视图
display system internal arp rbhash命令用来显示指定板上rbhash表项信息。
display system internal arp rbhash vlan vlan-id ip ip-address
Probe视图
vlan vlan-id:显示指定VLAN上rbhash表项信息。vlan-id表示指定VLAN的编号。
ip ip-address:显示指定IP上rbhash表项信息。
display system internal arp reload命令用来显示指定板上ARP重刷链表项。
Probe视图
display system internal arp rule命令用来显示ARP规则信息。
display system internal arp rule { all | interface interface-type interface-number [ ip-address ] }
Probe视图
all:显示所有ARP规则信息。
interface interface-type interface-number:显示指定接口的ARP规则信息,interface-type interface-number表示接口类型和接口编号。
ip-address:显示指定IP地址的ARP规则信息。
display system internal arp statistics命令用来显示指定板ARP统计信息。
Probe视图
display system internal dbm命令用来显示数据库信息。
display system internal dbm { all | name dbname [ key keyname ] }
Probe视图
all:表示所有数据库。
name dbname:指定数据库名。
key keyname:指定key的名称,在数据库中以key名称标识一项数据。
display system internal dot11 characteristics命令用来显示802.11侦听特征的统计信息和详细信息。
display system internal dot11 characteristics { bss bssid | interface wlan-radio interface-number }
Probe视图
bss bssid:显示BSS实体的特征统计信息和详细信息,包括BSS接收报文方向和发送报文方向。
interface wlan-radio interface-number:显示指定射频接口的特征统计信息和详细信息。
display system internal dot11 verbose命令用来显示802.11协议socket的详细信息。
Probe视图
display system internal ethernet character命令用来显示以太网模块侦听的特征统计信息和详细信息。
display system internal ethernet character { global | interface interface-type interface-number }
Probe视图
global:显示全局的以太特征。全局特征表示对设备上所有报文进行匹配。
interface interface-type interface-number:表示接口类型和接口编号。
以太网模块主要实现链路层报文接收去封装和发送加封装等处理。上层应用模块(如STP,LLDP等)需要侦听处理协议报文,指定侦听的范围(如指定接口上的报文或者设备上所有报文),侦听的协议报文具有指定的特征(如特殊的以太协议类型、特定的MAC等),并将这些特征下发给以太网模块,以太网模块在指定阶段(如收包MAC阶段/收包LLC阶段/发包三层口阶段等)会根据注册的特征库对报文进行匹配。匹配上了这些特征就交给这个阶段处理,不匹配就交给下一个阶段处理。
display system internal ethernet controlblock命令用来显示接口的控制块信息,它记录了链路层参数的值。
display system internal ethernet controlblock interface { interface-type interface-number }
Probe视图
display system internal ifmgr down命令用来显示已注册的down类型。
Probe视图
display system internal ifmgr entry命令用来显示指定接口的数据结构信息。
display system internal ifmgr entry { para | help }
Probe视图
para:指定显示时的参数。表示接口名或接口索引,格式为:1*接口索引,2*接口名。
help:显示命令参数的帮助信息,用于指导用户输入合法参数。
display system internal ifmgr event命令用来显示接口事件的注册信息,包括哪些模块注册了该事件,以及模块在哪些接口上注册了该事件。
display system internal ifmgr event { para | help }
Probe视图
para:指定显示时的参数。para为事件或接口类型,如果同时指定事件和接口类型,事件和接口中间需用“*”连接,格式为:event*type。
display system internal ifmgr hotplug命令用来显示板或子卡的热插拔信息。
display system internal ifmgr hotplug [ para | help ]
Probe视图
para:指定显示时的参数。para为槽位号或者槽位号和子槽位号(格式为slot-number*subslot-number),用于显示该板或子卡的热插拔信息。不指定该参数以及help参数时,显示所有板的热插拔信息;
display system internal ifmgr index命令用来显示接口索引节点的相关信息。
display system internal ifmgr index { para | help }
Probe视图
para:指定显示时的参数。为接口索引值的十进制形式。
display system internal ifmgr list命令用来显示接口树信息。
display system internal ifmgr list [ para | help ]
Probe视图
para:指定显示时的参数。para为接口类型对应的数值,该数值可通过help参数获取。
接口树用于管理设备上存在的接口。树上的节点对应接口,子节点对应接口下创建的子接口,每个节点的信息包括接口的名称和索引。
不指定para和help参数时,显示所有类型接口的接口树信息。
display system internal ifmgr name命令用来显示接口名字解析树信息。该树用于解析接口名字,以及命令行上输入接口名字时的帮助检查。
display system internal ifmgr name { para | help }
Probe视图
para:指定显示时的参数,为接口全名或简名。
display system internal ifmgr type命令用来按类型显示接口的信息。
display system internal ifmgr type { para | help }
Probe视图
para:指定显示时的参数。para为接口类型,为1~127个字符的字符串。
display system internal ike phase2-sa count命令用来显示IKE第二阶段SA的个数。
display system internal ike phase2-sa count [ phase1-connection-id connection-id ]
Probe视图
phase1-connection-id connection-id:指定IKE第一阶段的连接标识,可以根据此表示显示第二阶段SA的个数,取值范围为1~2000000000。
通过display ike sa可以查看IKE第一阶段的连接标识。
display system internal ike phase2-sa verbose命令用来显示IKE第二阶段SA的详细信息。
Probe视图
display system internal ike received-message count命令用来显示IKE接收消息的个数。
display system internal ike received-message count [ verbose ipsec-doi ]
Probe视图
verbose:显示IKE收到消息个数的详细信息。
ipsec-doi:显示接收IPsec-DOI消息个数的详细信息。
display system internal ike sent-message count命令用来显示IKE发送消息的个数。
display system internal ike sent-message count [ verbose ipsec-doi ]
Probe视图
verbose:显示IKE发送消息个数的详细信息。
ipsec-doi:显示发送给IPsec-DOI消息个数的详细信息。
display system internal ip address命令用来显示地址详细信息
display system internal ip address [ ip-address | interface interface-type interface-number ]
Probe视图
ip-address:显示指定IP地址。
interface interface-type interface-number:显示指定接口的IP地址,interface-type interface-number表示接口类型和接口编号。
display system internal ipsec block-flow命令用来显示IPsec阻流表信息。
Probe视图
阻流表是为了阻止相同流量重复触发IPsec协商,以节省系统资源。阻流表默认协商成功或者失败后就会删除。
display system internal ipsec received-message count命令用来显示IPsec接收自IKE的消息个数。
Probe视图
display system internal ipsec sent-message count命令用来显示IPsec发送给IKE的消息个数。
Probe视图
display system internal ipsec sp命令用来显示IPsec的SP信息。
display system internal ipsec sp { brief | sp-id sp-id }
Probe视图
brief:表示显示IPsec SP的摘要信息。
sp-id sp-id:表示显示指定IPsec SP的详细信息。sp-id是IPsec SP的ID号,取值范围为0~4294967295。
SP是IPsec Security Policy生成的动态数据,有可能每个板都会有SP信息,查看时需要区分板号。
display system internal ipv6 address命令用来显示IPv6地址详细信息
display system internal ipv6 address [ ipv6-address | [ interface interface-type interface-number [ gateway | multicast | prefix | unicast ] ] ]
Probe视图
ipv6-address:显示的指定IPv6地址。
interface interface-type interface-number:显示指定接口的IPv6地址,interface-type interface-number表示接口类型和接口编号。
gateway:显示指定接口的网关地址信息。
multicast:显示指定接口的组播地址信息。
prefix:显示指定接口的ipv6前缀信息。
unicast:显示指定接口的单播地址信息。
display system internal ipv6 fib prefix命令用来显示IPv6 FIB前缀基本信息。
Probe视图
display system internal ipv6 fib prefix entry-status命令用来显示下驱动失败或者待老化的IPv6 FIB表项信息信息。
display system internal ipv6 fib prefix entry-status status
Probe视图
entry-status status:用于匹配IPv6 FIB表项;取值范围为<A,F>,“A”表示需要被老化的IPv6 FIB表项,“F”表示下刷驱动失败的IPv6 FIB表项。
display system internal ipv6 fib prefix ipv6-address命令用来显示IPv6 FIB前缀详细信息。
display system internal ipv6 fib prefix ipv6-address [ prefix-length ]
Probe视图
ipv6-address:显示目的地址为指定IPv6地址的IPv6 FIB前缀详细信息。
prefix-length:指定IPv6地址的前缀长度,取值范围为0~128。
display system internal ipv6 l2-multicast fast-forwarding cache verbose命令用来显示IPv6二层组播软转发表详细信息。
display system internal ipv6 l2-multicast fast-forwarding cache verbose [ vlan vlan_id ] [ ipv6-source-address | ipv6-group-address ] *
Probe视图
vlan vlan-id:显示指定VLAN内的状态信息。vlan-id为VLAN的编号,取值范围为1~4094。
ipv6-source-address:组播源地址,显示包含指定组播源的二层组播软转发项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播快速转发项,取值范围为FFxy::/16(但不包括FFx1::/16和FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。
display system internal ipv6 l2-multicast ip forwarding verbose命令用来显示IPv6二层组播的IP转发表详细信息。
display system internal ipv6 l2-multicast ip forwarding verbose [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ]
Probe视图
group ipv6-group-address:显示指定IPv6组播组的信息。如果未指定本参数,将显示所有IPv6组播组的信息。
source ipv6-source-address:显示指定IPv6组播源的信息。如果未指定本参数,将显示所有IPv6组播源的信息。
vlan vlan-id:显示指定VLAN内的信息。vlan-id为VLAN的编号,取值范围为1~4094。如果未指定本参数,将显示所有VLAN内的信息。
display system internal ipv6 l2-multicast ip verbose命令用来显示IPv6二层组播的IP组播组详细信息。
display system internal ipv6 l2-multicast ip verbose [ group ipv6-group-address | source ipv6-source-address] * [ vlan vlan-id ]
Probe视图
display system internal ipv6 l2-multicast ipc statistics命令用来显示IPv6二层组播板间消息的统计信息。
Probe视图
display system internal ipv6 l2-multicast mac forwarding verbose命令用来显示IPv6二层组播的MAC转发表详细信息。
display system internal ipv6 l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ]
Probe视图
mac-address:显示指定MAC组播组的信息。如果未指定本参数,将显示所有MAC组播组的信息。
display system internal ipv6 l2-multicast mac verbose命令用来显示IPv6二层组播的MAC组播组详细信息。
display system internal ipv6 l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ]
Probe视图
display system internal ipv6 multicast forwarding vlan reference命令用来显示VLAN出接口与IPv6二层组播表项之间的映射关系。
display system internal ipv6 multicast forwarding vlan reference [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ]
Probe视图
display system internal ipv6 multicast forwarding-table dummy命令用来显示IPv6组播临时转发表的信息。
display system internal ipv6 multicast forwarding-table dummy [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | statistics ] *
Probe视图
ipv6-group-address:显示指定IPv6组播组的信息,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的信息。
prefix-length:指定IPv6组播源或IPv6组播组地址的前缀长度。对于IPv6组播源地址,其取值范围为0~128,缺省值为128;对于IPv6组播组地址,其取值范围为8~128,缺省值为128。
statistics:显示统计信息。
display system internal ipv6 multicast fast-forwarding cache verbose命令用来显示IPv6组播快速转发表项信息。
display system internal ipv6 multicast fast-forwarding cache verbose [ ipv6-source-address | ipv6-group-address ] *
Probe视图
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播快速转发项。
display system internal ipv6 rib event attribute命令用来显示IPv6 RIB的路由属性事件信息。
Probe视图
display system internal ipv6 rib event policy命令用来显示IPv6 RIB的路由策略事件信息。
Probe视图
display system internal ipv6 rib event prefix命令用来显示IPv6 RIB的路由前缀事件信息。
Probe视图
display system internal ipv6 rib event protocol命令用来显示IPv6 RIB的协议事件信息。
Probe视图
display system internal ipv6 rib event statistics用来显示IPv6 RIB的统计事件信息。
Probe视图
display system internal ipv6 rib instance命令用来显示IPv6 RIB的协议进程信息。
Probe视图
display system internal ipv6 rib log命令用来显示IPv6 RIB的日志信息。
display system internal ipv6 rib log [ reverse ]
display system internal ipv6 rib event log
Probe视图
rib:显示IPv6 RIB的日志信息。
event:显示IPv6 RIB路由变化通知的日志信息。
reverse:按时间新旧显示日志信息。
display system internal ipv6 rib memory命令用来显示IPv6 RIB的内存信息。
Probe视图
display system internal ipv6 rib nib log命令用来显示系统内部IPv6 NIB子模块运行状态的日志信息。
display system internal ipv6 rib nib log [ reverse ]
Probe视图
nib:显示IPv6 NIB子模块的运行状态。
display system internal ipv6 rib prefix命令用来显示IPv6路由表前缀信息。
display system internal ipv6 rib prefix ipv6-address prefix-length
Probe视图
ipv6-address:指定IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
display system internal ipv6 rib summary命令用来显示IPv6 RIB的统计信息。
Probe视图
display system internal ipv6 route-direct interface命令用来显示IPv6地址接口的信息。
display system internal ipv6 route-direct interface [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
ipv6-address:IPv6地址。
display system internal ipv6 route-static nib log命令用来显示IPv6静态路由NIB子模块日志信息。
display system internal ipv6 route-static nib log [ reverse ]
Probe视图
display system internal ipv6 tcp port-info命令用来显示IPv6 TCP模块非保留端口的使用信息。
Probe视图
display system internal ipv6 udp port-info命令用来显示IPv6 UDP模块非保留端口的使用信息。
Probe视图
display system internal kernel memory dump命令用来查看指定内核内存地址的内容。
display system internal kernel memory dump address address-hex length memory-length
Probe视图
address address-hex:表示内存起始地址。
length memory-length:表示要查看的内存大小,取值范围为1~1024,单位为字节。
display system internal kernel memory pool命令用来显示内核态正在使用的内存池的统计信息。
display system internal kernel memory pool [ name name-string ]
display system internal kernel memory pool tag [ tag-value ]
display system internal kernel memory pool name name-string tag tag-value
Probe视图
name name-string:表示内存池的名字。
tag tag-value:指定内存池使用者的标识。
不指定name和tag参数时,显示系统内存池使用情况的概要信息。
仅指定name name-string时,显示指定内存池使用情况的概要信息;
仅指定tag时,显示所有内存池使用情况的概要信息,以tag为关键字进行显示;
仅指定tag tag-value时,显示指定tag使用的内存池概要信息;
指定name name-string tag tag-value时,显示指定tag和内存池中内存对象的使用信息。
display system internal l2-multicast fast-forwarding cache verbose命令用来显示IPv4二层组播软转发表详细信息。
display system internal l2-multicast fast-forwarding cache verbose [ vlan vlan_id ] [ source-address | group-address ] *
Probe视图
group-address:组播组地址,显示指定组播组的二层组播软转发项,取值范围为224.0.1.0~239.255.255.255。
display system internal l2-multicast ip forwarding verbose命令用来显示二层组播的IP转发表详细信息。
display system internal l2-multicast ip forwarding verbose [ group group-address | source source-address ] * [ vlan vlan-id ]
Probe视图
group group-address:显示指定组播组的信息。如果未指定本参数,将显示所有组播组的信息。
source source-address:显示指定组播源的信息。如果未指定本参数,将显示所有组播源的信息。
display system internal l2-multicast ip verbose命令用来显示二层组播的IP组播组详细信息。
display system internal l2-multicast ip verbose [ group group-address | source source-address ] * [ vlan vlan-id ]
Probe视图
display system internal l2-multicast ipc statistics命令用来显示二层组播板间消息的统计信息。
Probe视图
display system internal l2-multicast mac forwarding verbose命令用来显示二层组播的MAC转发表详细信息。
display system internal l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ]
Probe视图
display system internal l2-multicast mac verbose命令用来显示二层组播的MAC组播组详细信息。
display system internal l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ]
Probe视图
display system internal link-aggregation global命令用来显示聚合模块的系统内部全局信息。
Probe视图
display system internal link-aggregation interface命令用来显示聚合模块的系统内部接口信息。
display system internal link-aggregation interface bridge-aggregation interface-number [ kernel | statistics [ ipv4 | ipv6 ] ]
display system internal link-aggregation interface interface-type interface-number [ kernel | lacp | lacppdu | statistics [ ipv4 | ipv6 ] ]
Probe视图
bridge-aggregation:显示二层聚合接口所对应聚合组的系统内部信息。
interface-number:聚合接口的编号。设备固定取值为1。必须是当前已经创建的聚合接口编号。
interface-type interface-number:聚合成员口。其中,interface-type为接口类型,interface-number为接口编号。
kernel:内核数据。
statistics:数据统计值。
ipv4:IPv4报文统计值。
ipv6:IPv6报文统计值。
lacp:动态聚合数据。
lacppdu:LACP报文统计值。
· 如果未指定kernel、lacp、lacppdu和statistics参数,则显示LAGG主线程中接口的基本数据。
· 如果未指定ipv4、ipv6参数,则显示所有报文统计值。
· 部分显示数据重复,实际上是保存在不同的线程中,定位问题时可互相佐证,利于问题的分析。
display system internal lipc dump命令用来显示LIPC抓包记录。
display system internal lipc dump [ lip lip ]
Probe视图
display system internal lipc dump configuration命令用来显示配置的LIPC抓包规则。
display system internal lipc dump configuration [ lip lip ]
Probe视图
lip lip:表示远端节点号,取值范围为0~65535。不指定该参数时,表示全局主用主控板所在节点。
display system internal lipc history命令用来以图表方式显示LIPC各协议的历史流量信息。
display system internal lipc history [ mtcp | publish | stcp ] { recv | send } { by-min | by-sec } [ lip lip ]
Probe视图
mtcp:显示组播传输控制协议的历史流量信息。不指定mtcp、publish和stcp参数时,表示显示三种协议报文流量总和的历史信息。
publish:显示可靠发布协议的历史流量信息。不指定mtcp、publish和stcp参数时,表示显示三种协议报文流量总和的历史信息。
stcp:显示单播传输控制协议的历史流量信息。不指定mtcp、publish和stcp参数时,表示显示三种协议报文流量总和的历史信息。
recv:显示当前协议的历史接收流量。
send:显示当前协议的历史发送流量。
by-min:以分钟为单位显示最近30分钟内的历史流量。
by-sec:以秒为单位显示最近30秒内的历史流量。
display system internal lipc lcmp statistics命令用来显示LIPC LCMP全局统计信息,包括收发包计数和错误计数。
display system internal lipc lcmp statistics [ lip lip ]
Probe视图
display system internal lipc lgmp group命令用来显示一个指定组播组信息,包含成员信息和组播组相关的统计信息。
display system internal lipc lgmp group groupID [ lip lip ]
Probe视图
groupID:表示组播组号,取值范围为0~4294967295。
display system internal lipc lgmp group-list命令用来查看系统中所有已经创建的组播组数目、组播端口号,以及组播组的HASH分布情况。
display system internal lipc lgmp group-list [ lip lip ]
Probe视图
display system internal lipc lgmp physical-group命令用来显示指定的硬件组播组信息。
display system internal lipc lgmp physical-group phyID [ lip lip ]
Probe视图
physical-group phyID:表示硬件组播组ID,取值范围为0~4294967295。
display system internal lipc lgmp physical-group-list命令用来显示所有的硬件组播组信息,以便了解硬件组播组的使用情况。
display system internal lipc lgmp physical-group-list [ lip lip ]
Probe视图
display system internal lipc lgmp statistics命令用来显示LIPC LGMP模块的统计信息。
display system internal lipc lgmp statistics [ lip lip ]
Probe视图
display system internal lipc lip statistics命令用来显示LIPC LIP全局统计信息。包括LIP报文的收发计数和出错计数。
display system internal lipc lip statistics [ lip lip ]
Probe视图
display system internal lipc loop statistics命令用来显示本地环回的统计信息。
display system internal lipc loop statistics [ lip lip ]
Probe视图
display system internal lipc mtcp group命令用来显示LIPC显示某个组播组的成员信息或统计信息或状态机的历史变迁轨迹。
display system internal lipc mtcp group portID { history | member | statistics } [ lip lip ]
Probe视图
portID:组播组的端口号,一个端口号标识一个组播组,取值范围为0~4294967295。
history:显示该组播组状态机的历史变迁轨迹。
member:显示该组播组的成员信息。
statistics:显示该组播组的统计信息。
display system internal lipc mtcp group all命令用来显示所有包含本节点的组播组的统计信息。
display system internal lipc mtcp group all [ lip lip ]
Probe视图
display system internal lipc mtcp performance命令显示LIPC组播性能信息。
display system internal lipc mtcp performance [ lip lip ]
Probe视图
必须打开相应得性能统计开关后,该命令才能输出性能信息。
· lipc performance
display system internal lipc mtcp statistics命令用来显示LIPC组播的全局统计信息。
display system internal lipc mtcp statistics [ lip lip ]
Probe视图
display system internal lipc pcb mbuf statistics命令用来显示LIPC各个PCB下的MBUF使用情况。
display system internal lipc pcb mbuf statistics [ lip lip ]
Probe视图
lip lip:表示节点号,取值范围为0~65535。设备只有一个节点,该参数无意思,无需选择。
display system internal lipc pcb statistics命令用来显示LIPC PCB模块全局统计信息。
display system internal lipc pcb statistics [ lip lip ]
Probe视图
display system internal lipc physical命令用来显示驱动适配层的全局统计信息。用于统计LIPC与驱动交互的各种信息,包括收发包计数,驱动错误计数和驱动上报事件计数。
display system internal lipc physical [ lip lip ]
Probe视图
display system internal lipc publish global-cb命令用来显示LIPC PUBLISH模块全局控制块信息。
display system internal lipc publish global-cb [ lip lip ]
Probe视图
一般用于诊断Pub模块在某个节点上是否乱序。
display system internal lipc publish statistics命令用来显示LIPC PUBLISH模块统计信息。
display system internal lipc publish statistics [ lip lip ]
Probe视图
display system internal lipc stcp event命令用来显示LIPC单播事件的信息。
display system internal lipc stcp event { sync | trans } [ lip lip ]
Probe视图
sync:显示LIPC单播控制报文事件信息。
trans:显示LIPC单播数据报文事件信息。
该命令主要记录本节点和其他节点的连接/DACK/销毁/时序交互信息。当设备上连接很多时,该命令记录的条目很容易满(512条),此时会将最老的记录清除掉。因此,发现问题时,应当尽早执行该命令,获取事件信息,便于定位分析。
display system internal lipc stcp global-server命令显示LIPC单播的全局知名端口信息。
display system internal lipc stcp global-server [ lip lip ]
Probe视图
display system internal lipc stcp links命令用来显示单播的连接信息。包括收发包信息、状态信息、缓存信息等。
display system internal lipc stcp links { all | detail port | global gport | listening | local lport | singledetail lport rport } [ lip lip ]
Probe视图
all:表示显示本节点所有的单播连接信息。
detail port:表示指定端口号的具体信息,取值范围为0~65535。
global gport:表示全局知名端口号,取值范围为100~8100。
listening:表示显示本节点处于侦听状态的连接。
local lport:表示本地端口号,取值范围为10100~65535。
singledetail lport rport:表示指定本地端口号和目的端口号的具体信息,取值范围为0~65535。
display system internal lipc stcp performance命令用来显示单播的性能信息。
display system internal lipc stcp performance [ lip lip ]
Probe视图
必须使用lipc performance命令打开相应的性能统计开关后,该命令才能输出性能信息。
· lipc performance
display system internal lipc stcp port命令用来显示单播支持的知名端口的指定操作的统计信息。
display system internal lipc stcp port { close | connect | get-port | half-close| recv-get-port | resend | send } [ lip lip ]
Probe视图
close:显示当前节点各端口的连接关闭次数。
connect:显示当前节点各端口的连接请求次数。
get-port:显示当前节点各全局知名端口的目的节点请求次数。
half-close:显示各端口的连接半关闭次数。
recv-get-port:显示当前节点收到的全局知名端口目的节点请求次数。
resend:显示各端口的重传次数。
send:显示各端口的发送次数。
display system internal lipc stcp statistics命令用来显示LIPC单播的全局统计信息,用于分析单播的全局工作情况。
display system internal lipc stcp statistics [ lip lip ]
Probe视图
display system internal lipc stcp status命令用来显示单播的传输状态。主要记录单播对象的传输序号、ACK序号、发送标志、接收状态。该命令通常用于分析单播的数据可靠传输问题。
display system internal lipc stcp status { recv | send } [ lip lip ]
Probe视图
recv:显示接收端的单播传输状态。
send:显示发送端的单播传输状态。
display system internal lipc stream命令用来查看流模式单播的记录信息。
display system internal lipc stream { ack | reass | send } port portID [ lip lip ]
Probe视图
ack:表示查看指定端口号的收到ACK的记录。
reass:表示查看指定端口号的接收重组队列信息。
send:表示查看指定端口号的发送报文分片记录。
port portID:表示端口号,为0~65535的整数。
display system internal lipc sudp pcb-info命令用来查看SUDP模块的PCB详细信息。
display system internal lipc sudp pcb-info { all-port | global-port | local-port | specific-port portID } [ lip lip ]
Probe视图
all-port:显示所有PCB信息。
global-port:显示全局知名端口的PCB信息。
local-port:显示本地知名端口的PCB信息。
specific-port portID:表示指定端口号,取值范围为0~65535。
display system internal lipc sudp statistics命令用来显示LIPC SUDP模块的全局统计信息。
display system internal lipc sudp statistics [ lip lip ]
Probe视图
display system internal lipc sudp命令用来查看所有SUDP全局知名端口号或本地端口号的信息。
display system internal lipc sudp { global-port | local-port } [ lip lip ]
Probe视图
global-port:表示查看所有SUDP全局知名端口号的信息。
local-port:表示查看所有SUDP本地端口号的信息。
display system internal lipc topology history命令用来查看拓扑链接信息的历史变迁记录。
display system internal lipc topology history [ lip lip ]
Probe视图
display system internal lipc topology link命令用来显示LIPC 的拓扑链接信息。
display system internal lipc topology link [ lip lip ]
Probe视图
display system internal lipc topology node命令用来查看拓扑节点相关的统计信息。
display system internal lipc topology node nodeID [ lip lip ]
Probe视图
nodeID:表示节点号,取值范围为0~65535。
记录了该节点上事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
display system internal lipc topology process-time命令用来查看发生拓扑事件时,通知各个模块耗时。
display system internal lipc topology process-time [ lip lip ]
Probe视图
display system internal lipc topology statistics命令用来查看拓扑相关的全局统计。记录了该全局事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
display system internal lipc topology statistics [ lip lip ]
Probe视图
display system internal lipc topology status命令用来显示节点的拓扑状态信息。
display system internal lipc topology status [ lip lip ]
Probe视图
display system internal lps命令用来显示LPS(Linux Packet Socket)信息。
Probe视图
lps:显示LPS信息。
display system internal mac-address configuration命令用来显示MAC地址表的配置信息。
display system internal mac-address configuration { blackhole | multicast | static } [ count ]
Probe视图
blackhole:显示黑洞MAC地址表项。
multicast:显示组播MAC地址表项。
static:显示静态MAC地址表项。
count:显示MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的MAC地址表的具体内容。
display system internal mac-address learned命令用来显示动态MAC地址表项。
display system internal mac-address learned [ mac-address [ vlan vlan-id ] | [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] ]
Probe视图
mac-address:显示指定MAC地址的动态MAC地址表项,mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
vlan vlan-id:显示指定VLAN的动态MAC地址表项。vlan-id的取值范围为1~4094。
interface interface-type interface-number:显示指定接口的动态MAC地址表项。interface-type interface-number为接口类型和接口编号。
count:显示动态MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)动态MAC地址表项的数量,而不显示动态MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的动态MAC地址表项的具体内容。
display system internal mac-address protocol命令用来显示指定协议或特性生成的MAC地址或VLAN接口的MAC地址。
display system internal mac-address protocol [ auth | client | dot1x | security | vlan-interface ] [ count ]
Probe视图
auth:显示MAC地址认证特性的MAC地址表项。
client:显示在线用户的MAC地址表项。目前,仅显示无线在线用户的MAC地址表项。
dot1x:显示802.1X特性的MAC地址表项。
security:显示端口安全特性中学习到的MAC地址表项。
vlan-interface:显示VLAN接口的MAC地址表项。
count:显示MAC地址表项的数量。如果指定了本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果未指定本参数,则显示符合条件的MAC地址表项的具体内容。
display system internal mac-address statistics命令用来显示MAC地址表的统计信息。
Probe视图
display system internal mac-forwarding controlblock命令用来显示二层转发的接口控制信息。
display system internal mac-forwarding controlblock interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的二层转发控制信息。其中,interface-type interface-number为指定接口类型和接口编号。
display system internal multicast capability命令用来显示组播能力的信息。
Probe视图
display system internal multicast forwarding vlan reference命令用来显示VLAN出接口与二层组播表项之间的映射关系。
display system internal multicast forwarding vlan reference [ group group-address | source source-address ] * [ vlan vlan-id ]
Probe视图
display system internal multicast forwarding-table dummy命令用来显示组播临时转发表的信息。
display system internal multicast forwarding-table dummy [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | statistics ] *
Probe视图
group-address:显示指定组播组的信息,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将显示所有组播组的信息。
mask-length:指定组播组或组播源地址的掩码长度。对于组播组地址,其取值范围为4~32,缺省值为32;对于组播源地址,其取值范围为0~32,缺省值为32。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
statistics:显示统计信息。
display system internal multicast forwarding-table verbose命令用来显示组播转发表的详细信息。
display system internal multicast forwarding-table verbose [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
Probe视图
incoming-interface:显示指定入接口的信息。如果未指定本参数,将显示所有入接口的信息。
outgoing-interface:显示指定出接口的信息。如果未指定本参数,将显示所有出接口的信息。
exclude:显示不包含指定接口的信息。
include:显示包含指定接口的信息。
match:显示包含且仅包含指定接口的信息。
display system internal multicast record命令用来显示组播表项的操作记录。
display system internal multicast record { statistics | { { all | fail } [ { group [ group-address | ipv6-group-address ] | source [ source-address | ipv6-source-address ] } * | item item-list | filter { exclude | include } { { add-l2-ip | add-l2-ip-port | add-l2-ip-slot | add-l2-mac | add-l2-mac-port | add-l2-mac-slot | add-l3-ipm | add-l3-oif | add-l3-port | add-l3-slot | del-l2-ip | del-l2-ip-port | del-l2-ip-slot | del-l2-mac | del-l2-mac-port | del-l2-mac-slot | del-l3-ipm | del-l3-oif | del-l3-port | del-l3-slot | set-l3-data-group | set-l3-iif } * | ipmc-type-all } ] [ verbose ] } }
Probe视图
statistics:显示组播表项操作记录的统计信息。
all:显示组播表项的所有操作记录。
fail:显示组播表项的失败操作记录。
group-address:组播组地址,显示指定组播组的记录。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的记录。
source-address:组播源地址,显示包含指定组播源的记录。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的记录。
item item-list:记录列表,表示一条或多条记录。表示方式为item-list = start-item [ to end-item ]。其中,start-item和end-item的取值范围均为1~500000。
filter:显示指定模式下的组播表项操作记录。
exclude:显示排除满足指定条件的组播表项操作记录。
include:显示包含满足指定条件的组播表项操作记录。
add-l2-ip:表示添加二层IP表项的操作记录。
add-l2-ip-port:表示添加二层IP表项端口的操作记录。
add-l2-ip-slot:表示添加二层IP表项板信息的操作记录。
add-l2-mac:表示添加二层MAC表项的操作记录。
add-l2-mac-port:表示添加二层MAC表项端口的操作记录。
add-l2-mac-slot:表示添加二层MAC表项板信息的操作记录。
add-l3-ipm:表示添加三层组播表项的操作记录。
add-l3-oif:表示添加三层表项出接口的操作记录。
add-l3-port:表示添加三层表项出端口的操作记录。
add-l3-slot:表示添加三层表项分布式转发的出接口板信息的操作记录。
del-l2-ip:表示删除二层IP表项的操作记录。
del-l2-ip-port:表示删除二层IP表项端口的操作记录。
del-l2-ip-slot:表示删除二层IP表项板信息的操作记录。
del-l2-mac:表示删除二层MAC表项的操作记录。
del-l2-mac-port:表示删除二层MAC表项端口的操作记录。
del-l2-mac-slot:表示删除二层MAC表项板信息的操作记录。
del-l3-ipm:表示删除三层组播表项的操作记录。
del-l3-oif:表示删除三层表项出接口的操作记录。
del-l3-port:表示删除三层表项出端口的操作记录。
del-l3-slot:表示删除三层表项分布式转发的出接口板信息的操作记录。
set-l3-data-group:表示设置三层表项对应的Data-Group地址。
set-l3-iif:表示设置三层表项入接口的操作记录。
ipmc-type-all:表示全部类型。
verbose:显示详细信息。如果记录的出接口和出端口显示不全时,需要指定本参数。
display system internal nat命令用来显示内核的NAT配置信息。
Probe视图
display system internal nat aging-queue命令用来显示NAT模块老化队列的统计信息。
display system internal nat aging-queue no-pat [ verbose ]
Probe视图
no-pat:显示NO-PAT表项老化队列的统计信息。
verbose:显示NAT老化队列的详细统计信息。若不指定该参数,则只显示NAT老化队列上NAT表项的个数统计信息。
display system internal nat statistics命令用来显示NAT统计信息。
Probe视图
当配置有NAT业务的组网环境中,出现网络丢包时,可以通过该命令查看NAT统计信息,确定丢包是否与NAT业务有关。
display system internal nd dad命令用来显示DAD链信息。
Probe视图
display system internal nd entry命令用来显示各板上的ND表项信息。
Probe视图
display system internal nd ifcb命令用来显示接口的ND控制块信息。
display system internal nd ifcb interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的ND控制块信息。interface-type interface-number为接口类型和接口编号。
display system internal nd machash命令用来显示各板上的machash表项。
display system internal nd machash vlan vlan-id ipv6-address
Probe视图
vlan vlan-id:显示指定VLAN的信息。vlan-id表示指定VLAN的编号。
ipv6-address:指定IPv6地址。
display system internal nd probe命令用来显示探测链信息。
Probe视图
display system internal nd rbhash命令用来显示指定板上rbhash表项信息。
display system internal nd rbhash vlan vlan-id ipv6-address
Probe视图
ipv6-address:显示指定IPv6地址上rbhash表项信息。
display system internal nd reload命令用来显示重刷链信息。
Probe视图
display system internal nd rule命令用来显示ND规则信息。
display system internal nd rule { all | interface interface-type interface-number [ ipv6-address ] }
Probe视图
all:显示所有ND规则信息。
interface interface-type interface-number:显示指定接口的ND规则信息,interface-type interface-number表示接口类型和接口编号。
ipv6-address:显示的指定IPv6地址的ND规则信息。
display system internal nd static命令用来显示ND静态配置。
display system internal nd static ipv6-address interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的信息。interface-type interface-number为接口类型和接口编号。
display system internal nd statistics命令用来显示各板上的ND统计信息。
Probe视图
display system internal ppp statistics命令用来显示PPP的统计信息。
display system internal ppp statistics { aggregation | all | interface-event }
Probe视图
aggregation:显示PPP的聚合处理统计信息。
all:显示PPP的所有统计信息。
interface-event:显示PPP的接口处理统计信息。
在主用设备和备用设备上都可以查询PPP的统计信息。
display system internal process state命令用来显示服务的运行状态。
Probe视图
display system internal rawip命令用来显示设备上所有RawIP连接的摘要信息。
Probe视图
display system internal rib event attribute命令用来显示IPv4 RIB的路由属性事件信息。
Probe视图
display system internal rib event policy命令用来显示IPv4 RIB的路由策略事件信息。
Probe视图
display system internal rib event protocol命令用来显示IPv4 RIB的协议事件信息。
Probe视图
display system internal rib event statistics用来显示IPv4 RIB的统计事件信息。
Probe视图
display system internal rib instance命令用来显示RIB的协议进程信息。
Probe视图
display system internal rib log命令用来显示RIB的日志信息。
display system internal rib log [ reverse ]
display system internal rib event log
Probe视图
rib:显示RIB的日志信息。
event:显示RIB路由变化通知的日志信息。
display system internal rib memory命令用来显示RIB的内存信息。
Probe视图
display system internal rib nib log命令用来显示系统内部NIB子模块运行状态的日志记录。
display system internal rib nib log [ reverse ]
Probe视图
nib:显示NIB子模块的运行状态。
display system internal rib prefix命令用来显示IPv4路由表前缀信息。
display system internal rib prefix ip-address mask-length
Probe视图
ip-address:指定IPv4目的地址。
mask-length:IP地址掩码,取值范围为0~32。
display system internal rib summary命令用来显示IPv4 RIB的统计信息。
Probe视图
display system internal route-direct interface命令用来显示IPv4地址接口的信息。
display system internal route-direct interface [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
ip-address:接口IP地址,点分十进制,显示指定IP地址和掩码/掩码长度接口的信息。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
display system internal route-static nib log命令用来显示静态路由NIB子模块日志信息。
display system internal route-static nib log [ reverse ]
Probe视图
display system internal session命令用来显示会话的配置信息。
display system internal session [ verbose | interface [ interface-type interface-number ] ]
Probe视图
verbose:显示会话配置的详细信息。不指定该参数时,显示会话配置的概要信息。
interface interface-type interface-number:表示使用指定接口的会话配置信息。interface-type interface-number表示接口类型和接口编号。
display system internal session aging-queue命令用来显示会话管理模块老化队列的统计信息。
display system internal session aging-queue [ { ipv4 | ipv6 } hot-backup-relation | relation ] [ verbose ] [ core core-number ]
Probe视图
ipv4:显示IPv4热备份关联表项老化队列的统计信息。
ipv6:显示IPv6热备份关联表项老化队列的统计信息。
hotback-relation:显示热备份关联表项老化队列的统计信息。
relation:显示关联表项老化队列的统计信息。
core core-number:显示指定内核上的会话老化队列统计信息,core-number表示多核CPU的内核编号。
verbose:显示会话模块老化队列的详细统计信息。若不指定该参数,则只显示会话管理模块老化队列上关联表项的个数统计信息。
如果不指定任何参数,则显示会话表项老化队列的统计信息。
display system internal session relation-table ipv4命令用来显示IPv4关联表详细信息。
display system internal session relation-table ipv4 [ source-ip source-ip ] [ destination-ip destination-ip ]
Probe视图
source-ip source-ip:显示指定源IPv4地址的关联表表项。source-ip表示发起方到响应方关联表的源IPv4地址。
destination-ip destination-ip:显示指定目的IPv4地址的关联表表项。destination-ip表示发起方到响应方关联表的目的IPv4地址。
display system internal session relation-table ipv6命令用来显示IPv6关联表详细详细信息。
display system internal session relation-table ipv6 [ source-ip source-ip ] [ destination-ip destination-ip ]
Probe视图
source-ip source-ip:显示指定源IPv6地址的关联表表项。source-ip表示发起方到响应方关联表的源IPv6地址。
destination-ip destination-ip:显示指定目的IPv6地址的关联表表项。 destination-ip表示发起方到响应方关联表的目的IPv6地址。
display system internal session table ipv4命令用来显示IPv4单播会话表项详细信息。
display system internal session table ipv4 [ [ responder ] { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * ]
Probe视图
responder:表示以响应方的信息筛选显示IPv4单播会话表项。若不指定该参数时,则以发起方的信息筛选显示IPv4单播会话表项。
source-ip source-ip:显示指定源IP地址的单播会话表项。source-ip表示报文的源IPv4地址。
destination-ip destination-ip:显示指定目的IPv4地址的单播会话表项详细信息。destination-ip表示报文的目的IPv4地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv4单播会话表项详细信息。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv4单播会话表项详细信息。其中,source-port表示报文的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv4单播会话表项详细信息。其中,destination-port表示报文的目的端口号,取值为0~65535。
display system internal session table ipv6命令用来显示IPv6单播会话表项详细信息。
display system internal session table ipv6 [ source-ip source-ip ] [ destination-ip destination-ip] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
Probe视图
source-ip source-ip:显示指定源IPv6地址的单播会话表项。 source-ip表示发起方到响应方会话的源IPv6地址。
destination-ip destination-ip:显示指定目的IPv6地址的单播会话表项。destination-ip表示发起方到响应方会话的目的IPv6地址。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv6单播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPV6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv6单播会话表项。其中,source-port表示发起方到响应方会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv6单播会话表项。其中,destination-port表示发起方到响应方会话的目的端口号,取值为0~65535。
display system internal startup cache命令用来显示设备本次启动时使用的二进制配置文件的路径,如flash:/startup.mdb。
Probe视图
用户执行save命令保存配置时,系统会自动生成一个字符串类型的配置文件和一个二进制类型的配置文件。
· 字符串类型的配置文件是一个文本文件,文件名后缀为“.cfg”,可以通过more命令查看该文件的内容。
· 二进制类型的配置文件是字符串类型的配置文件的二进制格式,文件名后缀为“.mdb”。在设备启动和运行时,系统软件能够解析该类配置文件,而用户却不能读取和编辑文件内容。
两个文件保存的配置相同,但格式不同。设备启动的时候,会优先使用二进制类型的配置文件,以便提高加载配置的速度。如果没有找到合适的二进制类型的配置文件,才使用字符串类型的配置文件。
当设备本次启动使用的是二进制类型的配置文件时,使用该命令会显示该二进制文件的路径;当设备本次启动使用的是字符串类型的配置文件时,使用该命令将显示None。
display system internal stp bridge-info命令用来显示生成树指定实例桥配置信息及运行状态。
display system internal stp bridge-info instance instance-id
Probe视图
instance instance-id:显示指定实例的生成树桥配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
display system internal stp port-info命令用来显示生成树指定实例端口配置信息及运行状态。
display system internal stp port-info instance instance-id interface interface-type interface-number
Probe视图
instance instance-id:显示指定实例的生成树端口配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
interface interface-type interface-number:显示指定端口上的生成树端口信息和运行状态,interface-type interface-number表示端口类型和端口编号。
display system internal tcp port-info命令用来显示TCP模块非保留端口的使用信息。
Probe视图
display system internal udp port-info命令用来显示UDP模块非保留端口的使用信息。
Probe视图
display system internal vlan命令用来查看VLAN模块相关的内部信息。
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary }
Probe视图
instance vlan-id:显示指定VLAN的VLAN模块信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
interface interface-type interface-number:显示指定端口的VLAN模块信息。interface-type interface-number为端口类型和端口编号。
summary:显示VLAN模块的摘要信息。
display system internal wlan band-navigation命令用来显示AP扫描到的客户端的频谱导航信息。
display system internal wlan band-navigation ap ap-id [ client mac-address ]
Probe视图
ap-id:AP ID,取值范围为1~65535。
client mac-address:显示AP扫描到的指定客户端的频谱导航信息。mac-address为客户端MAC地址,格式为H-H-H。如果不指定该参数,将显示AP扫描到的所有客户端的频谱导航信息。
display system internal wlan client ip命令用来显示客户端的IP地址信息。
display system internal wlan client ip [ mac-address mac-address ]
Probe视图
mac-address mac-address:显示指定MAC地址的客户端IP地址信息。如果未指定本参数,则显示所有客户端的IP地址信息。
display system internal wlan mesh-ap命令用来显示AP上的Mesh信息。
Probe视图
display system internal wlan mesh-forwarding statistics命令用来显示Mesh转发统计计数。
Probe视图
display system internal wlan mesh-mac命令用来显示学习的MAC地址。
display system internal wlan mesh-mac [ mac-address [ vlan vlan-id ] ] [ source mac-learn ] [ type { mp | sta } ]
Probe视图
mac-address:指定要显示的MAC地址。
vlan vlan-id:显示从指定vlan学习的MAC地址。
source:指定MAC地址的学习方式。
mac-learn:基本学习方式。
type:MAC地址所属设备的类型。
mp:显示MP设备的MAC地址。
sta:显示Station设备的MAC地址。
display system internal wlan mesh-packet statistics命令用来显示报文处理统计计数。
Probe视图。
display system internal wlan mesh-security命令用来显示Mesh安全状态信息。
Probe视图
follow命令用来通过跟踪栈信息来调试指定的进程或者线程。
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ]
Probe视图
job job-id:任务ID,用于唯一标识一个进程,该ID不会随着进程的重启而改变,取值范围为1~2147483647。
process pid:进程ID,该ID可能会随着进程的重启而改变,取值范围为1~2147483647。
thread thread-id:线程ID,用于指定进程内某一指定线程,取值范围为1~2147483647。
delay seconds:指定每次跟踪操作的间隔时间,取值范围为0~255秒,缺省为5秒。
iteration count:指定跟踪调试的次数的次数,取值范围为1~255次,缺省为5次。
对于用户态进程,follow命令会分别显示当前进程的内核态堆栈和用户态堆栈信息,并以user stack/kernel stack提示符加以区分;对于内核态进程,则只显示内核态堆栈信息。
不指定thread参数时,默认显示指定进程内所有线程。
lipc connection detect命令用来检测本节点和所有相连节点的连通性。
Probe视图
执行该命令后,本节点会向本节点所有相连节点连续发送5个ping报文,如果在200ms内收到目的节点的任何一个回复报文则认为该节点可达,否则不可达。
lipc dump命令用来配置LIPC各协议报文的抓包规则。
undo lipc dump命令用来清除抓包规则。
lipc dump lgmp [ port port ] [ recv | send ] [ lip lip ]
undo lipc dump [ lgmp [ port port ] [ recv | send ] ] [ lip lip ]
lipc dump { mtcp | stcp | sudp } [ port port ] [ ack | ctrl | data ] [ recv | send ] [ lip lip ]
undo lipc dump [ { mtcp | stcp | sudp } [ port port ] [ ack | ctrl | data ] [ recv | send ] ] [ lip lip ]
lipc dump { publish | topology } [ recv | send ] [ lip lip ]
undo lipc dump [ { publish | topology } [ recv | send ] ] [ lip lip ]
未配置协议报文的抓包规则。
Probe视图
lgmp:配置组播管理协议报文的抓包规则。
mtcp:配置组播传输控制协议报文的抓包规则。
stcp:配置单播传输控制协议报文的抓包规则。
sudp:配置单播用户数据报协议报文的抓包规则。
publish:配置可靠发布协议报文的抓包规则。
topology:配置拓扑协议报文的抓包规则。
port port:匹配协议端口号,不指定本参数时,表示匹配该协议所有端口。
ack:匹配该协议的确认报文。不指定ack、ctrl和data参数时,表示匹配确认、控制和数据报文。
ctrl:匹配该协议的控制报文。不指定ack、ctrl和data参数时,表示匹配确认、控制和数据报文。
data:匹配该协议的数据报文。不指定ack、ctrl和data参数时,表示匹配确认、控制和数据报文。
recv:匹配该协议的接收报文。不指定recv和send参数时,表示匹配接收和发送报文。
send:匹配该协议的发送报文。不指定recv和send参数时,表示匹配接收和发送报文。
多次执行该命令,只要有字段取值不同,则作为不同的规则,系统最多支持配置5条协议报文的抓包规则。
所有下发的规则会被记录到系统,使用display system internal lipc dump configuration命令可以查看。
同一个报文被多个协议规则同时匹配成功,仅会有一条记录。协议规则和内容规则互相独立,如一个报文同时被协议规则和内容规则匹配成功,则会有两条不同的记录。
报文匹配成功后记录到抓包缓存区,使用display system internal lipc dump命令可以查看。
lipc dump buffer命令用来申请或释放指定节点的LIPC抓包缓存。
lipc dump buffer { alloc [ max-record num ] | free } [ lip lip ]
Probe视图
alloc:申请缓存。
free:释放缓存。
max-record num:信息的最大记录缓存字节数,取值范围为1~10000,单位为KB,缺省值为10KB。
开启抓包功能后,系统会缺省申请10KB缓存来缓存捕获的报文。如果要捕获的报文较多,请先使用本命令提前申请内存,再开启抓包功能。
lipc dump enable命令用来开启本节点的LIPC抓包功能。
undo lipc dump enable命令用来关闭本节点的LIPC抓包功能。
lipc dump enable [ loop] [ lip lip ]
undo lipc dump enable [ lip lip ]
本节点的LIPC抓包功能处于关闭状态。
Probe视图
loop:表示开启循环记录模式,即缓存区满后会删除旧记录来保存新记录。不指定本参数时,表示非循环模式,缓存区满后不再继续记录。
开启本节点的LIPC抓包功能时,如未申请抓包缓存,系统会在开启抓包功能的同时申请10KB的抓包缓存。
关闭本节点的LIPC抓包功能时,不会清除抓包规则和抓包缓存区。
lipc dump offset命令用来配置报文内容抓包规则。
lipc dump offset offset length length value value [ recv | send ] [ lip lip ]
undo lipc dump [ offset offset length length value value [ recv | send ] ] [ lip lip ]
未配置报文内容抓包规则。
Probe视图
offset:信息的偏移量,取值范围为0~65535。报文偏移起始位置为LIP报文头位置。
length length:信息的长度。取值为1、2、4、8,单位为字节。
value value:信息的内容的十六进制字符串形式(字符串不带“0x”)。length取值为1时,value的取值范围为0~0xFF;length取值为2时,value的取值范围为0~0xFFFF;length取值为4时,value的取值范围为0~0xFFFFFFFF;length取值为8时,value的取值范围为0~0xFFFFFFFFFFFFFFFF。
recv:匹配接收报文。不指定recv和send参数时,表示匹配接收和发送报文。
send:匹配发送报文。不指定recv和send参数时,表示匹配接收和发送报文。
下发内容匹配规则并开启抓包功能后,系统从驱动层收到的报文,从报文的第offset个字节开始取length长的内容,内容的值为value时,记录这个报文的前48字节内容到抓包缓存区。协议抓包规则和内容抓包规则抓取到的报文存放在同一个缓冲区,使用display system internal lipc dump命令可以查看捕获到的报文。
多次执行该命令,只要有字段取值不同,则作为不同的规则,系统最多支持配置5条不同的报文内容抓包规则。
清除报文内容抓包规则时,需要offset、length、value三个字段完全匹配时才清除该规则,否则提示规则不存在。
同一个报文被多个内容匹配规则同时匹配成功,仅会有一条记录。协议规则和内容规则互相独立,如一个报文同时被协议规则和内容规则匹配成功,则会有两条不同的记录。报文匹配成功后记录到抓包缓存区,可使用display system internal lipc dump命令查看。
lipc dump-port命令打开指定单播端口的dump开关。
lipc dump-port port &<1-5> [ lip lip ]
undo lipc dump-port [ lip lip ]
单播端口的dump开关是关闭的。
Probe视图
port &<1-5>:表示单播端口号,取值范围为0~65535。&<1-5>表示前面的参数最多可以输入5次。
打开指定单播端口的dump开关后,系统会在/proc/lipc/dumpinfo文件中记录该端口的所有报文收发信息。
lipc performance命令用来配置单播或者组播的性能统计功能,用于评测LIPC的传输性能。
lipc performance { mtcp | stcp } { clear | off | on } [ lip lip ]
性能统计开关是关闭的。
Probe视图
mtcp:MTCP子模块的信息。
stcp:STCP子模块的信息。
clear:清除单播或者组播的性能统计信息。
off:关闭单播或者组播的性能统计开关。
on:打开单播或者组播的性能统计开关。
lipc ping命令用来检查本节点与目的节点LIPC通信链路的连通性和稳定性。
lipc ping lip lip [ length length ] [ times times ] [ summary ]
Probe视图
lip lip:指定目的端的LIP地址,取值范围0~65535。
length length:指定发送的LIPC回显请求报文的长度(不包括LIPC报文头),取值范围为0~32767,单位为字节,缺省值为100字节。
times times:指定LIPC回显请求报文的发送次数,取值范围为0~32767,缺省值为3。
summary:只显示统计信息。不指定该参数时,系统将显示包括统计信息在内的详细信息。
lipc timeout命令用来设置LIPC拓扑链路的超时时间。
lipc timeout time [ lip lip ]
拓扑链路的超时时间为60秒。
Probe视图
timeout time:表示超时时间,取值范围为3-65535。
如果本节点的TOPOLOGY模块在超时时间内一直没有收到UP节点的心跳报文,则会断开与该节点的所有单播、组播连接。
通常,只有在使用KDB或者KGDB调试内核时,才需要修改该数值,以避免其他节点认为正处于内核调试状态的节点链路Down。
list命令用来查看系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息,且文件路径中不能包含文件链接。
list file-path
Probe视图
file-path:要查看的文件或目录的路径,区分大小写。
memory boundary-check enable命令用来开启内存越界检查功能。
undo memory boundary-check enable命令用来恢复缺省情况。
memory boundary-check enable job job-id
undo memory boundary-check enable job job-id
内存越界检查功能处于关闭状态。
Probe视图
开启指定进程的内存越界检查功能后,该进程每次释放内存前都会进行内存越界检查,以便确保申请和释放操作的正确性。如果发生内存越界,将内存越界信息记录到内存文件中(所有进程的越界信息都会记录到一个文件中)。
· memory boundary-check scan
memory boundary-check scan命令用来触发一次内存越界检查,并显示检查的结果。若有内存被写越界,则打印出该出错处地址往前偏移16字节,一共128字节的内存内容。
memory boundary-check scan job job-id
Probe视图
使用前必须使能内存越界检测功能,否则使用该命令检查,无效果。
执行该命令后,系统会从出错处地址往前偏移16字节,一共显示128字节的内存内容;当系统中存在多处内存越界时,只记录并显示地址最小的一条检查结果。
· memory boundary-check enable
monitor lipc命令用来以交互模式显示各协议的实时统计信息。统计信息包括收发包信息、状态信息、缓存信息等。
monitor lipc { mtcp | stcp | sudp } { recv | send } [ lip lip ]
Probe视图
mtcp:显示组播传输控制协议的实时统计信息。
stcp:显示单播传输控制协议的实时统计信息。
sudp:显示单播用户数据报的实时统计信息。
recv:显示该协议接收报文的实时统计信息。
send:显示该协议发送报文的实时统计信息。
信息的统计周期为5秒。统计结果以报文发送或接收量降序排列,最多同时显示10个数据,每隔5秒刷新一次。命令执行后前5秒内系统需统计信息,无统计信息输出。
用户可以通过输入q或Q来停止执行命令行,退回到命令行视图。
multicast record limit命令用来配置组播表项操作记录的最大数目。
undo multicast record limit命令用来恢复缺省情况。
multicast record [ fail ] limit limit-value
undo multicast record [ fail ] limit
组播表项操作记录的最大数目为0,即不记录组播表项的操作信息。
Probe视图
fail:表示组播表项的失败操作记录。
limit-value:表示操作记录的最大数目,取值范围为0~500000。
probe命令用来从系统视图进入Probe视图。
probe
在Probe视图下,用户可以通过命令查看系统的状态和信息,以便对系统故障进行诊断。
reset system internal arp statistics命令用来清除指定板上的ARP统计信息。
Probe视图
reset system internal ipv6 multicast forwarding-table dummy命令用来清除IPv6组播临时转发表中的表项。
reset system internal ipv6 multicast forwarding-table dummy { { ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] } * | all }
Probe视图
ipv6-group-address:清除指定IPv6组播组的表项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。如果未指定本参数,将清除所有IPv6组播组的表项。
ipv6-source-address:清除指定IPv6组播源的表项。如果未指定本参数,将清除所有IPv6组播源的表项。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
all:清除所有表项。
reset system internal ipv6 rib log命令用来清除IPv6 RIB相关的日志内容。
reset system internal ipv6 rib [ event ] log
Probe视图
event:IPv6 RIB路由变化相关的日志。
reset system internal ipv6 rib nib log命令用来清除IPv6 NIB子模块日志。
Probe视图
reset system internal ipv6 rib summary命令用来清除IPv6 RIB的统计摘要信息。
Probe视图
reset system internal ipv6 route-static nib log命令用来清除IPv6静态路由NIB子模块日志。
Probe视图
reset system internal lipc dump buffer命令用来清空本节点的LIPC抓包缓存。
reset system internal lipc dump buffer [ lip lip ]
Probe视图
reset system internal mac-address statistics命令用来清除MAC地址表的统计信息
Probe视图
reset system internal multicast forwarding-table dummy命令用来清除组播临时转发表中的表项。
reset system internal multicast forwarding-table dummy { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] } * | all }
Probe视图
source-address:清除指定组播源的表项。如果未指定本参数,将清除所有组播源的表项。
group-address:清除指定组播组的表项,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将清除所有组播组的表项。
mask-length:指定组播源或组播组地址的掩码长度。对于组播源地址,其取值范围为0~32,缺省值为32;对于组播组地址,其取值范围为4~32,缺省值为32。
mask:指定组播源或组播组地址的掩码,缺省值为255.255.255.255。
all:清除所有表项。
reset system internal multicast record命令用来清除组播表项的操作记录。
Probe视图
reset system internal nat statistics命令用来清除NAT统计信息。
Probe视图
reset system internal nd statistics命令用来清除各板上的ND统计信息。
Probe视图
reset system internal ppp statistics命令用来清除PPP的统计信息。
reset system internal ppp statistics { aggregation | all | interface-event }
Probe视图
aggregation:清除PPP的聚合处理统计信息。
all:清除PPP的所有统计信息。
interface-event:清除PPP的接口处理统计信息。
在主用设备和备用设备上都可以清除PPP的统计信息。
reset system internal rib log命令用来清除RIB相关的日志内容。
reset system internal rib [ event ] log
Probe视图
event:RIB路由变化相关的日志。
reset system internal rib nib log命令用来清除NIB子模块日志。
Probe视图
reset system internal rib summary命令用来清除IPv4 RIB的统计摘要信息。
Probe视图
reset system internal route-static nib log命令用来清除静态路由NIB子模块日志。
Probe视图
view命令用来查看系统目录(/proc/、/sys/、/var/)下的文件的内容。
view file-path
Probe视图
file-path:要查看文件的路径,区分大小写。
执行该命令显示的文件路径中不能包含文件链接。文件链接类似于文件的快捷方式,文件链接指向另一个文件或目录。通过文件链接可以访问到其所指向的文件或目录。
