国家 / 地区
10-安全命令参考
13-SSL命令
本章节下载  (156.76 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/SR_Router/SR6600/Command/Command_Manual/H3C_SR6600_SR6600-X_CR(V5)-R3303(V1.23)/10/201702/973908_30005_0.htm
13-SSL命令
  录
1 SSL················································································································································· 1-1
1.1 SSL配置命令·························································································································· 1-1
1.1.1 ciphersuite····················································································································· 1-1
1.1.2 client-verify enable·········································································································· 1-2
1.1.3 client-verify weaken········································································································ 1-3
1.1.4 close-mode wait············································································································· 1-3
1.1.5 display ssl client-policy··································································································· 1-4
1.1.6 display ssl server-policy·································································································· 1-5
1.1.7 handshake timeout········································································································· 1-7
1.1.8 pki-domain····················································································································· 1-7
1.1.9 prefer-cipher··················································································································· 1-8
1.1.10 server-verify enable······································································································· 1-9
1.1.11 session······················································································································ 1-10
1.1.12 ssl client-policy·········································································································· 1-10
1.1.13 ssl server-policy·········································································································· 1-11
1.1.14 ssl version ssl3.0 disable····························································································· 1-12
1.1.15 version······················································································································· 1-12
1 SSL
本节命令仅在SR6602路由器上支持。
1.1  SSL配置命令
1.1.1  ciphersuite
在非FIPS模式下:
ciphersuite [ rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha ] *
在FIPS模式下:
ciphersuite [ dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_256_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha ] *
SSL服务器端策略视图
【缺省级别】
2:系统级
dhe_rsa_aes_128_cbc_sha:密钥交换算法采用DH_RSA、数据加密算法采用128位AES_CBC、MAC算法采用SHA。
dhe_rsa_aes_256_cbc_sha:密钥交换算法采用DH_RSA、数据加密算法采用256位AES_CBC、MAC算法采用SHA。
rsa_3des_ede_cbc_sha:密钥交换算法采用RSA、数据加密算法采用3DES_EDE_CBC、MAC算法采用SHA。
rsa_aes_128_cbc_sha:密钥交换算法采用RSA、数据加密算法采用128位AES_CBC、MAC算法采用SHA。
rsa_aes_256_cbc_sha:密钥交换算法采用RSA、数据加密算法采用256位AES_CBC、MAC算法采用SHA。
rsa_des_cbc_sha:密钥交换算法采用RSA、数据加密算法采用DES_CBC、MAC算法采用SHA。
rsa_rc4_128_md5:密钥交换算法采用RSA、数据加密算法采用128位的RC4、MAC算法采用MD5。
rsa_rc4_128_sha:密钥交换算法采用RSA、数据加密算法采用128位的RC4、MAC算法采用SHA。
【描述】
ciphersuite命令用来配置SSL服务器端策略支持的加密套件。
缺省情况下,SSL服务器端策略支持所有的加密套件。
·     如果不指定任何参数,则SSL服务器端策略支持上述6种加密套件。
·     如果多次执行本命令,则新的配置覆盖原有配置。
相关配置可参考命令display ssl server-policy
# 指定SSL服务器端策略支持的加密套件为rsa_rc4_128_md5rsa_rc4_128_sha
[Sysname] ssl server-policy policy1
[Sysname-ssl-server-policy-policy1] ciphersuite rsa_rc4_128_md5 rsa_rc4_128_sha
undo client-verify enable
SSL服务器端策略视图
【缺省级别】
2:系统级
【描述】
client-verify enable命令用来配置SSL服务器端要求对SSL客户端进行基于证书的身份验证。undo client-verify enable命令用来恢复缺省情况。
缺省情况下,SSL服务器端不要求对SSL客户端进行基于证书的身份验证。
执行本命令后:
·     如果通过client-verify weaken命令使能了SSL客户端弱认证功能,则由客户端决定是否对客户端进行身份验证。客户端选择进行身份验证时,只有身份验证通过后,SSL客户端才能访问SSL服务器;客户端选择不进行身份验证时,SSL客户端可以直接访问SSL服务器。
·     如果未使能SSL客户端弱认证功能,则必须对客户端进行身份验证。只有身份验证通过后,SSL客户端才能访问SSL服务器。
相关配置可参考命令client-verify weakendisplay ssl server-policy
# 配置服务器端要求对客户端进行基于证书的身份验证。
[Sysname-ssl-server-policy-policy1] client-verify enable
undo client-verify weaken
SSL服务器端策略视图
【缺省级别】
2:系统级
【描述】
client-verify weaken命令用来使能SSL客户端弱认证功能。undo client-verify weaken命令用来恢复缺省情况。
缺省情况下,未使能SSL客户端弱认证功能。
只有通过client-verify enable命令配置SSL服务器端要求对SSL客户端进行基于证书的身份验证后,本命令才会生效。
·     使能SSL客户端弱认证功能后,由客户端决定是否对客户端进行身份验证。如果客户端选择进行身份验证,则只有身份验证通过后,SSL客户端才能访问SSL服务器;如果客户端选择不进行身份验证,则SSL客户端可以直接访问SSL服务器。
相关配置可参考命令client-verify enabledisplay ssl server-policy
# 使能SSL客户端弱认证功能。
[Sysname-ssl-server-policy-policy1] client-verify weaken
close-mode wait
undo close-mode wait
SSL服务器端策略视图
【缺省级别】
2:系统级
【描述】
close-mode wait命令用来配置SSL连接的关闭模式为wait模式,即发送close-notify警告消息给客户端后,等待客户端的close-notify警告消息,在接收到客户端的close-notify警告消息后才能关闭连接。undo close-mode wait命令用来恢复缺省情况。
缺省情况下,服务器发送close-notify警告消息给客户端,不等待客户端的close-notify警告消息,直接关闭连接。
# 设定SSL连接的关闭模式为wait模式。
[Sysname-ssl-server-policy-policy1] close-mode wait
display ssl client-policy { policy-name | all } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
policy-name:显示指定的SSL客户端策略的信息,为1~16个字符的字符串,不区分大小写。
all:显示所有SSL客户端策略的信息。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display ssl client-policy命令用来显示SSL客户端策略的信息。
# 显示名为policy1的SSL客户端策略信息。
<Sysname> display ssl client-policy policy1
 SSL Client Policy: policy1
     SSL Version: SSL 3.0
     PKI Domain: 1
     Prefer Ciphersuite:
         RSA_RC4_128_SHA
     Server-verify: enabled
表1-1 display ssl client-policy命令显示信息描述表
SSL Client Policy
SSL客户端策略名
SSL Version
SSL客户端策略使用的协议版本号,取值包括SSL 3.0和TLS 1.0
PKI Domain
SSL客户端策略使用的PKI域
Prefer Ciphersuite
SSL客户端策略的首选加密套件
Server-verify
SSL客户端策略的服务器验证模式,取值包括:
·     disabled:不需要对服务器端进行身份验证
·     enabled:需要对服务器端进行身份验证
display ssl server-policy { policy-name | all } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
policy-name:显示指定的SSL服务器端策略的信息,为1~16个字符的字符串,不区分大小写。
all:显示所有SSL服务器端策略的信息。
【描述】
display ssl server-policy命令用来显示SSL服务器端策略的信息。
# 显示名为policy1的SSL服务器端策略的信息。
<Sysname> display ssl server-policy policy1
 SSL Server Policy: policy1
     PKI Domain: domain1
     Ciphersuite:
         RSA_RC4_128_MD5
         RSA_RC4_128_SHA
         RSA_DES_CBC_SHA
         RSA_3DES_EDE_CBC_SHA
         RSA_AES_128_CBC_SHA
         RSA_AES_256_CBC_SHA
     Handshake Timeout: 3600
     Close-mode: wait disabled
     Session Timeout: 3600
     Session Cachesize: 500
     Client-verify: disabled
     Client-verify weaken: disabled
表1-2 display ssl server-policy命令显示信息描述表
SSL Server Policy
SSL服务器端策略名
PKI Domain
SSL服务器端策略使用的PKI域
如果显示为空,则表示未指定SSL服务器端策略使用的PKI域,SSL服务器自己生成证书,而无需从CA获取证书
Ciphersuite
SSL服务器端策略支持的加密套件
Handshake Timeout
SSL服务器端策略的握手连接保持时间,单位为秒
Close-mode
SSL服务器端策略的关闭模式,取值包括:
·     wait disabled:SSL连接的关闭模式为非wait模式,即服务器发送close-notify警告消息给客户端,不等待客户端的close-notify警告消息,直接关闭连接
·     wait enabled:SSL连接的关闭模式为wait模式,即发送close-notify警告消息给客户端后,等待客户端的close-notify警告消息,在接收到客户端的close-notify警告消息后才能关闭连接
Session Timeout
SSL服务器端策略会话缓存的超时时间,单位为秒
Session Cachesize
SSL服务器端策略可以缓存的最大会话数目
Client-verify
SSL服务器端策略的客户端验证模式,取值包括:
·     disabled:不要求对客户端进行身份验证
·     enabled:要求对客户端进行身份验证
是否使能SSL客户端弱认证功能,取值包括
·     disabled:未使能该功能
·     enabled:使能该功能
handshake timeout time
undo handshake timeout
SSL服务器端策略视图
【缺省级别】
2:系统级
time:握手连接的保持时间,取值范围为180~7200,单位为秒。
【描述】
handshake timeout命令用来配置SSL服务器端策略的握手连接保持时间。undo handshake timeout命令用来恢复缺省情况。
缺省情况下,SSL服务器端策略的握手连接保持时间为3600秒。
如果SSL服务器在握手连接保持时间内没有收到SSL客户端的报文,则SSL服务器将终止当前的SSL握手过程。
# 配置SSL服务器端策略的握手连接保持时间为3000秒。
[Sysname-ssl-server-policy-policy1] handshake timeout 3000
1.1.8  pki-domain
pki-domain domain-name
undo pki-domain
SSL服务器端策略视图/SSL客户端策略视图
【缺省级别】
2:系统级
domain-name:PKI域的域名,为1~15个字符的字符串,不区分大小写。
【描述】
pki-domain命令用来配置SSL服务器端策略或SSL客户端策略所使用的PKI域。undo pki-domain命令恢复缺省情况。
缺省情况下,没有配置SSL服务器端策略和SSL客户端策略所使用PKI域。
需要注意的是,如果没有配置SSL服务器端策略所使用的PKI域,则SSL服务器自己生成证书,而无需从CA获取证书。
相关配置可参考命令display ssl server-policydisplay ssl client-policy
# 配置SSL服务器端策略所使用的PKI域为server-domain。
[Sysname-ssl-server-policy-policy1] pki-domain server-domain
# 配置SSL客户端策略所使用的PKI域为client-domain。
[Sysname] ssl client-policy policy1
[Sysname-ssl-client-policy-policy1] pki-domain client-domain
1.1.9  prefer-cipher
在非FIPS模式下:
prefer-cipher { rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha }
undo prefer-cipher
在FIPS模式下:
prefer-cipher { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_256_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha }
undo prefer-cipher
SSL客户端策略视图
【缺省级别】
2:系统级
rsa_3des_ede_cbc_sha:密钥交换算法采用RSA、数据加密算法采用3DES_EDE_CBC算法、MAC算法采用SHA。
rsa_aes_128_cbc_sha:密钥交换算法采用RSA、数据加密算法采用128位AES_CBC算法、MAC算法采用SHA。
rsa_aes_256_cbc_sha:密钥交换算法采用RSA、数据加密算法采用256位AES_CBC算法、MAC算法采用SHA。
rsa_des_cbc_sha:密钥交换算法采用RSA、数据加密算法采用DES_CBC算法、MAC算法采用SHA。
rsa_rc4_128_md5:密钥交换算法采用RSA、数据加密算法采用128位的RC4算法、MAC算法采用MD5。
rsa_rc4_128_sha:密钥交换算法采用RSA、数据加密算法采用128位的RC4算法、MAC算法采用SHA。
【描述】
prefer-cipher命令用来配置SSL客户端策略的首选加密套件。undo prefer-cipher命令用来恢复缺省情况。
缺省情况下,SSL客户端策略的首选加密套件为rsa_rc4_128_md5
相关配置可参考命令display ssl client-policy
# 配置SSL客户端策略的首选加密套件为rsa_aes_128_cbc_sha
[Sysname-ssl-client-policy-policy1] prefer-cipher rsa_aes_128_cbc_sha
undo server-verify enable
SSL客户端策略视图
【缺省级别】
2:系统级
【描述】
server-verify enable命令用来使能基于证书的SSL服务器身份验证,即在SSL握手过程中,客户端需要对服务器端进行基于证书的身份验证。undo server-verify enable命令用来关闭基于证书的SSL服务器身份验证功能,默认SSL服务器身份合法。
缺省情况下,需要进行基于证书的SSL服务器身份验证。
# 配置握手过程中,客户端需要对服务器端进行基于证书的身份验证。
[Sysname-ssl-client-policy-policy1] server-verify enable
1.1.11  session
undo session { cachesize | timeout } *
SSL服务器端策略视图
【缺省级别】
2:系统级
cachesize size:缓存的最大会话数目,size取值范围为100~1000。
timeout time:会话缓存的超时时间,time取值范围为1800~72000,单位为秒。
【描述】
session命令用来配置缓存的最大会话数目和会话缓存的超时时间。undo session命令用来恢复缓存的最大会话数目或会话缓存超时时间为缺省情况。
缺省情况下,缓存的最大会话数目为500个,会话缓存的超时时间为3600秒。
通过SSL握手协议协商会话参数并建立会话的过程比较复杂。为了简化SSL握手过程,SSL允许重用已经协商过的会话参数建立会话。为此,SSL服务器上需要保存已有的会话信息。保存的会话信息的数目和保存时间具有一定的限制:
·     如果缓存的会话数目达到最大值,SSL将拒绝缓存新的会话;
·     会话保存的时间超过设定的时间后,SSL将删除该会话的信息。
# 配置会话缓存的超时时间为4000秒,缓存的最大会话数目为600个。
[Sysname-ssl-server-policy-policy1] session timeout 4000 cachesize 600
ssl client-policy policy-name
undo ssl client-policy { policy-name | all }
【缺省级别】
2:系统级
policy-name:SSL客户端策略名,为1~16个字符的字符串,不区分大小写,该字符串不能是“a”,“al”和“all”。
all:所有SSL客户端策略。
【描述】
ssl client-policy命令用来创建SSL客户端策略,并进入SSL客户端策略视图。undo ssl client-policy命令用来删除已创建的SSL客户端策略。
# 创建名为policy1的SSL客户端策略,并进入该SSL客户端策略视图。
ssl server-policy policy-name
undo ssl server-policy { policy-name | all }
【缺省级别】
2:系统级
policy-name:SSL服务器端策略名,为1~16个字符的字符串,不区分大小写,该字符串不能是“a”,“al”和“all”。
all:所有的SSL服务器端策略。
【描述】
ssl server-policy命令用来创建SSL服务器端策略,并进入SSL服务器端策略视图。undo ssl server-policy命令用来删除已创建的SSL服务器端策略。
需要注意的是,SSL服务器端策略与应用层协议关联后,无法删除该策略。
# 创建名为policy1的SSL服务器端策略,并进入该SSL服务器端策略视图。
undo ssl version ssl3.0 disable
【缺省级别】
系统级
【描述】
ssl version ssl3.0 disable命令用来关闭SSL 3.0版本。
undo ssl version ssl3.0 disable命令用来恢复缺省情况。
缺省情况下,允许使用SSL 3.0版本。
由于SSL 3.0版本存在一些已知的安全漏洞,当设备对系统安全性有较高要求时可以通过命令行关闭SSL 3.0版本。
配置关闭SSL 3.0版本时,需要注意的是:
·     对于SSL客户端,如果在系统视图下关闭了SSL 3.0版本,但在SSL客户端策略视图下配置使用SSL 3.0版本(通过命令version ssl 3.0),则该SSL客户端仍可使用SSL 3.0版本。
·     对于SSL服务器端,如果在系统视图下关闭了SSL 3.0版本,则SSL服务器端只能使用TLS 1.0版本,否则SSL服务器端自动采用对端设备采用的版本。
·     如果对端设备仅支持SSL 3.0版本,则为保持互通,本端设备不应关闭SSL 3.0版本,但为了提高安全性,建议对端设备尽快升级,以支持TLS 1.0版本。
# 关闭SSL 3.0。
[Sysname] ssl version ssl3.0 disable
1.1.15  version
在非FIPS模式下:
version { ssl3.0 | tls1.0 }
undo version
在FIPS模式下:
version tls1.0
undo version
SSL客户端策略视图
【缺省级别】
2:系统级
ssl3.0:版本号为SSL 3.0。
tls1.0:版本号为TLS 1.0。
【描述】
version命令用来配置SSL客户端策略使用的SSL协议版本。undo version命令恢复缺省情况。
缺省情况下,SSL客户端策略使用的SSL协议版本号为TLS 1.0。
# 配置SSL客户端策略使用的SSL协议版本号为SSL 3.0。
[Sysname-ssl-client-policy-policy1] version ssl3.0
联系我们 联系我们
回到顶部 回到顶部
