国家 / 地区
09-MPLS命令参考
01-MPLS基础命令
本章节下载  (381.14 KB)
docurl=/cn/Service/Document_Software/Document_Center/Switches/Catalog/S12500/S12500/Command/Command_Manual/H3C_S12500_CR--R1828P04-6W182/09/201407/834830_30005_0.htm
01-MPLS基础命令
目
1 MPLS基础
1.1 MPLS基础配置命令
1.1.1 accept-label
1.1.2 advertise-label
1.1.3 bfd enable
1.1.4 display mpls ilm
1.1.5 display mpls interface
1.1.6 display mpls label
1.1.7 display mpls ldp
1.1.8 display mpls ldp fec
1.1.9 display mpls ldp interface
1.1.10 display mpls ldp lsp
1.1.11 display mpls ldp peer
1.1.12 display mpls ldp remote-peer
1.1.13 display mpls ldp session
1.1.14 display mpls ldp session all statistics
1.1.15 display mpls lsp
1.1.16 display mpls lsp bfd ipv4
1.1.17 display mpls lsp statistics
1.1.18 display mpls nhlfe
1.1.19 display mpls nhlfe reflist
1.1.20 display mpls route-state
1.1.21 display mpls static-lsp
1.1.22 display mpls statistics interface
1.1.23 display mpls statistics lsp
1.1.24 du-readvertise
1.1.25 du-readvertise timer
1.1.26 graceful-restart (MPLS-LDP view)
1.1.27 graceful-restart mpls ldp
1.1.28 graceful-restart timer neighbor-liveness
1.1.29 graceful-restart timer reconnect
1.1.30 graceful-restart timer recovery
1.1.31 hops-count
1.1.32 label advertise
1.1.33 label-distribution
1.1.34 loop-detect
1.1.35 lsp-trigger
1.1.36 lsr-id
1.1.37 md5-password
1.1.38 mpls
1.1.39 mpls ldp (System view)
1.1.40 mpls ldp (Interface view)
1.1.41 mpls ldp remote-peer
1.1.42 mpls ldp timer hello-hold
1.1.43 mpls ldp timer keepalive-hold
1.1.44 mpls ldp transport-address
1.1.45 mpls lspv
1.1.46 mpls lsr-id
1.1.47 mpls mtu
1.1.48 path-vectors
1.1.49 periodic-tracert
1.1.50 ping lsp ipv4
1.1.51 prefix-label advertise
1.1.52 remote-ip
1.1.53 remote-ip bfd
1.1.54 reset mpls ldp
1.1.55 reset mpls statistics interface
1.1.56 reset mpls statistics lsp
1.1.57 static-lsp egress
1.1.58 static-lsp ingress
1.1.59 static-lsp transit
1.1.60 statistics interval
1.1.61 tracert lsp ipv4
1.1.62 ttl expiration enable
1.1.63 ttl expiration pop
1.1.64 ttl propagate
1 MPLS基础
·     除了LDP的GR特性外,MPLS LDP视图下的命令都可以在MPLS-LDP-VPN实例视图下使用。MPLS LDP视图下的命令对公网LDP起作用;MPLS-LDP-VPN实例视图下的命令对LDP实例起作用。文中不再赘述。
·     设备支持两种运行模式:独立运行模式和IRF模式,缺省情况为独立运行模式。有关IRF模式的介绍,请参见“IRF配置指导”中的“IRF”。
1.1  MPLS基础配置命令
1.1.1  accept-label
accept-label peer peer-id ip-prefix ip-prefix-name
undo accept-label peer peer-id
MPLS-LDP视图/MPLS-LDP-VPN实例视图
【缺省级别】
2:系统级
peer peer-id:指定LDP对等体。peer-id为LDP对等体的LSR ID。
ip-prefix ip-prefix-name:指定用来对接收标签进行过滤的IP地址前缀列表。ip-prefix-name表示IP地址前缀列表名,为1~19个字符的字符串。
【描述】
accept-label命令用来配置标签接受控制策略。undo accept-label命令用来恢复缺省情况。
缺省情况下,接受LDP对等体通告的所有标签映射。
标签接受控制策略用来实现对接收的标签映射进行过滤,即上游LSR对指定的下游LSR通告的标签映射进行过滤,只有FEC目的地址通过指定IP地址前缀列表的过滤时,上游LSR才会接受该FEC对应的标签映射,否则上游LSR不会接受且不会保存标签映射。
需要注意的是,上游LSR的配置发生变化时(如执行undo accept-label命令删除标签接受控制策略、修改标签接受控制策略),只有执行reset mpls ldp命令重启LDP会话,触发下游LSR重新通告标签映射,上游LSR才能获取之前没有接受的标签映射。
相关配置可参考“三层技术-IP路由命令参考/路由策略”中的命令ip ip-prefix
# 对于LSR ID为1.1.1.9的LDP对等体通告的标签,只允许接受FEC目的地址属于10.1.1.0/24和10.2.1.0/24网段的标签映射。
[Sysname] ip ip-prefix prefix-from-RTA index 1 permit 10.1.1.0 24
[Sysname] ip ip-prefix prefix-from-RTA index 2 permit 10.2.1.0 24
[Sysname] mpls ldp
[Sysname-mpls-ldp] accept-label peer 1.1.1.9 ip-prefix prefix-from-RTA
advertise-label ip-prefix ip-prefix-name [ peer peer-ip-prefix-name ]
undo advertise-label ip-prefix ip-prefix-name
【缺省级别】
2:系统级
ip-prefix ip-prefix-name:指定用来对通告的标签映射进行过滤的IP地址前缀列表。ip-prefix-name表示IP地址前缀列表名,为1~19个字符的字符串。
peer peer-ip-prefix-name:指定LDP对等体列表。peer-ip-prefix-name表示IP地址前缀列表名,为1~19个字符的字符串。不指定该参数时,表示所有LDP对等体。
【描述】
advertise-label命令用来配置标签通告控制策略。undo advertise-label命令用来恢复缺省情况。
缺省情况下,不对通告的标签映射进行过滤。
LSR按照下面的规则来判断是否向指定的对等体通告标签映射:
·     如果待通告的标签映射的IP地址前缀没有通过地址前缀列表的检查,则不向任何对等体通告该标签映射。
·     如果待通告的标签映射的IP地址前缀通过地址前缀列表的检查,且对等体列表为空,则向所有对等体通告该标签映射。
·     如果待通告的标签映射的IP地址前缀通过地址前缀列表的检查,且对等体列表不为空,则只向通过对等体列表检查的对等体通告该标签映射。
·     如果待通告的标签映射的IP地址前缀通过多于一个地址前缀列表的检查(多次执行advertise-label命令配置多个地址前缀列表),则以第一条命令的配置为准。
# 配置标签通告控制策略:向LSR ID为3.3.3.9的对等体通告网段地址10.1.1.0/24对应的标签映射;向LSR ID为4.4.4.9的对等体通告网段地址10.2.1.0/24对应的标签映射;不通告其他网段地址对应的标签映射。
[Sysname] ip ip-prefix prefix-to-C permit 10.1.1.0 24
[Sysname] ip ip-prefix prefix-to-D permit 10.2.1.0 24
[Sysname] ip ip-prefix peer-C permit 3.3.3.9 32
[Sysname] ip ip-prefix peer-D permit 4.4.4.9 32
[Sysname] mpls ldp
[Sysname-mpls-ldp] advertise-label ip-prefix prefix-to-C peer peer-C
[Sysname-mpls-ldp] advertise-label ip-prefix prefix-to-D peer peer-D
1.1.3  bfd enable
bfd enable destination-address mask-length [ nexthop nexthop-address [ discriminator local local-id remote remote-id ] ]
undo bfd enable destination-address mask-length [ nexthop nexthop-address ]
MPLS-LSPV视图
【缺省级别】
2:系统级
destination-address:与FEC对应的目的地址。
mask-length:与FEC对应的目的地址的掩码长度,取值范围为0~32。
nexthop nexthop-address:指定FEC下一跳地址。如果指定该参数,则只检测指定的LSP;如果不指定该参数,则检测FEC对应的所有LSP。
discriminator:指定BFD会话的鉴别值。
local local-id:指定BFD会话的本地鉴别值。
remote remote-id:指定BFD会话的远端鉴别值,取值范围为1~4294967295。
【描述】
bfd enable命令用来配置使用BFD检测指定FEC对应LSP的连通性。undo bfd enable用来取消使用BFD检测指定FEC对应LSP的连通性。
缺省情况下,未使用BFD检测FEC对应LSP的连通性。
·     执行本命令前,必须先通过mpls lspv命令使能LSP检测功能。
·     BFD会话参数为MPLS LSR-ID对应的Loopback接口下配置的BFD参数,BFD报文的源地址为MPLS LSR-ID。因此,配置BFD检测LSP功能前,需要在Loopback接口下配置IP地址,并将LSR-ID配置为Loopback接口的IP地址,还可以根据需要在Loopback接口下配置BFD会话参数。
# 使用BFD检测到达目的地址1.1.1.9/32的LSP的连通性。
[Sysname] mpls lspv
[Sysname-mpls-lspv] bfd enable 1.1.1.9 32
独立运行模式:
display mpls ilm [ label ] [ verbose ] [ slot slot-number ] [ include text | { | { begin | exclude | include } regular-expression } ]
IRF模式:
display mpls ilm [ label ] [ verbose ] [ chassis chassis-number slot slot-number ] [ include text | { | { begin | exclude | include } regular-expression } ]
【缺省级别】
1:监控级
label:显示指定入标签的ILM表项,取值范围为16~1048575。
verbose:显示详细信息。
slot slot-number显示指定槽号上的ILM表项。slot-number为单板所在的槽位号。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ILM表。chassis-number表示设备在IRF中的成员编号, slot-number表示单板所在的槽位号,可使用display device命令查看。
include text:显示含有指定字符串的ILM表项。text为用户指定的字符串。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display mpls ilm命令用来显示ILM表项信息。
如果不指定入标签,将显示所有ILM表项信息。
# 显示指定入标签的ILM表项。
<Sysname> display mpls ilm 1024
Inlabel In-Interface        Token   VRF-Index Oper   LSP-Type      Swap-Label
1024    Vlan1000            2         0       POP    NORMAL        -
表1-1 display mpls ilm命令显示信息描述表
Inlabel
入标签
In-Interface
入接口
Token
NHLFE表项索引
VRF-Index
VRF索引
Oper
操作类型:POP/POPGO/SWAPGO/NULL
LSP-Type
LSP类型:LDP LSP/CR-LDP/RSVP LSP/BGP LSP/L3VPN LSP/STATIC LSP/STATIC CR-LSP/L2VPN LSP/BGP IPv6 LSP
Swap-Label
交换标签
display mpls interface [ interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:显示指定接口的MPLS相关信息。interface-type interface-number为接口类型和接口编号。如果不指定本参数,则显示所有使能了MPLS能力接口的MPLS相关信息。
verbose:显示详细信息。如果不指定本参数,则显示简要信息。
【描述】
display mpls interface命令用来显示使能了MPLS能力接口的MPLS相关信息。
相关配置可参考命令display mpls statistics interfacempls
# 显示所有使能了MPLS能力接口的MPLS简要信息。
<Sysname> display mpls interface
Interface   Status     TE Attr    LSP Count   CRLSP Count
Vlan1000    Up         En         0           0
Vlan1001    Up         En         0           0
# 显示指定的使能了MPLS能力的接口的详细信息。
<Sysname> display mpls interface vlan-interface 1000 verbose
No             : 1
Interface      : Vlan1000
Status         : Down
TE Attribute   : Disable
LSPCount       : 0
CR-LSPCount    : 0
FRR            : Disabled
表1-2 display mpls interface命令显示信息描述表
No
序号
接口简要名称
Status
接口状态
TE Attr/TE Attribute
接口上是否使能TE
LSP Count/LSPCount
接口上LSP条数
CRLSP Count/CR-LSPCount
接口上CR-LSP条数
FRR
是否使能FRR(快速重路由),如果使能了FRR,还将显示绑定的隧道
有关FRR的介绍请参见“MPLS配置指导”中的“MPLS TE”。
display mpls label { label-value1 [ to label-value2 ] | all } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
label-value1:显示指定标签的使用状态。当与label-value2一起使用时,表示标签范围的开始,取值范围为16~262143。
to label-value2:标签范围的结束,label-value2的取值范围为16~262143。
all:显示所有标签信息。
【描述】
display mpls label命令用来显示MPLS标签的使用状态。
# 显示指定范围内标签的使用状态。
<Sysname> display mpls label 900 to 1500
Label alloc state: '.' means not used, '$' means used
------------------------------Static Label--------------------------------
900:........ ........ ........ ........  ........ ........ ........ ........
964:........ ........ ........ ........  ........ ........ ........ ....
------------------------------Dynamic Label-------------------------------
1024:...$.... ........ ........ ........  ........ ........ ........ ........
1088:........ ........ ........ ........  ........ ........ ........ ........
1152:........ ........ ........ ........  ........ ........ ........ ........
1216:........ ........ ........ ........  ........ ........ ........ ........
1280:........ ........ ........ ........  ........ ........ ........ ........
1344:........ ........ ........ ........  ........ ........ ........ ........
1408:........ ........ ........ ........  ........ ........ ........ ........
1472:........ ........ ........ .....
表1-3 display mpls label命令显示信息描述表
Label alloc state
标签分配状态
'.' means not used
‘.’表示没有使用
'$' means used
‘$’表示已经使用
Static Label
静态绑定的标签
Dynamic Label
动态分配的标签
display mpls ldp [ all [ verbose ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all所有LDP信息。
verbose:显示详细信息。
【描述】
display mpls ldp命令用来显示LDP信息。
如果不指定任何参数,则显示所有LDP的详细信息。
相关配置可参考命令mpls ldp
# 显示所有LDP详细信息。
<Sysname> display mpls ldp all verbose
                           LDP Global Information
 Protocol Version        : V1           Neighbor Liveness    : 60 Sec
 Graceful Restart        : Off          FT Reconnect Timer   : 60 Sec
 MTU Signaling           : Off          Recovery Timer       : 60 Sec
 Nonstop Routing         : Off
                          LDP Instance Information
 Instance ID            : 0          VPN-Instance         :
 Instance Status        : Active     LSR ID               : 1.1.1.1
 Hop Count Limit        : 32         Path Vector Limit    : 32
 Loop Detection         : Off
 DU Re-advertise Timer  : 30 Sec     DU Re-advertise Flag : On
 DU Explicit Request    : Off        Request Retry Flag   : On
 Label Distribution Mode: Ordered    Label Retention Mode : Liberal
表1-4 display mpls ldp命令显示信息描述表
LDP全局信息
Protocol Version
LDP的协议版本
Neighbor Liveness
GR邻居存活定时器的值
Graceful Restart
是否使能Graceful Restart功能
FT Reconnect Timer
GR重连定时器间的值
MTU Signaling
是否支持MTU信令,目前设备不支持MTU信令
Recovery Timer
GR恢复定时器的值
Nonstop Routing
LDP NSR的状态,取值包括:
·     On:使能了LDP NSR功能,但数据备份未完成
·     Off:未使能LDP NSR功能
·     Ready:使能了LDP NSR功能,且数据备份已完成
LDP实例信息
Instance ID
LDP实例序号
VPN-Instance
使能LDP能力的VPN的实例名称,如果是缺省的VPN,显示为空
Instance Status
LDP实例状态
LSR ID
LSR的标识符
Hop Count Limit
环路检测的最大跳数
Path Vector Limit
路径向量方式下LSP的最大跳数
Loop Detection
是否使能环路检测功能
DU模式下重新发布标签的时间间隔
是否使能DU模式下的标签重新发布功能
DU Explicit Request
是否使能DU会话方式发送显式请求消息功能
Request Retry Flag
是否使能重发送请求功能
此实例使用的标签分配控制方式,取值包括:
·     Ordered:有序标签控制方式
·     Independent:独立标签控制方式
此实例使用的标签保持方式,目前取值只能是Liberal,表示自由标签保持方式
display mpls ldp fec [ vpn-instance vpn-instance-name ] dest-addr mask-length [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
vpn-instance vpn-instance-name:显示指定VPN的标签通告信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31字符的字符串,区分大小写。
dest-addr mask-length:显示指定FEC的标签通告信息。dest-addr表示FEC的目的地址,mask-length表示FEC目的地址的掩码长度,取值范围为0~32。
【描述】
display mpls ldp fec命令用来显示指定FEC的标签通告信息。
# 显示指定FEC的标签通告信息。
<Sysname> display mpls ldp fec 3.3.3.9 32
                            LDP FEC Information
 Upstream Info:
 No.               : 1
 Upstream peer     : NULL
 Stale             : No
 Label Request ID  : NULL
 Label Space ID    : 0
 FEC Type          : Generic
 Incomming Label   : NULL
 State             : Established
 Hop Count         : 1
 Path Vector Count : 0
 Path Vector       : NULL
 Downstream Info:
 No.               : 1
 Downstream Peer   : 2.2.2.9
 Stale             : No
 Label Type        : Generic
 Outgoing Label    : 1036
 State             : Established
 Hop Count         : 2
 Path Vector Count : 1
 Path Vector       : 2.2.2.9
 Received MTU      : 1500
 OutIfCount        : 2
 OutGoing Info     : Interface                  Nexthop
                     Vlan200                    21.21.21.2
                     Vlan100                    12.12.12.2
表1-5 display mpls ldp fec命令显示信息描述表
Upstream Info
上游信息
Downstream Info
下游信息
No.
编号
Upstream peer
上游对等体
Downstream Peer
下游对等体
Stale
是否处于GR期间
Label Request ID
标签请求消息的标识符
Label Space ID
标签空间标识符,0表示每平台标签空间,即整个LSR使用一个标签空间
Label Type
标签类型,取值包括Generic、ATM和FR,目前只支持Generic
FEC Type
FEC类型
Incomming Label
入标签值
Outgoing Label
出标签值
当前状态,取值包括:
·     Established:激活状态
·     IDLE:未激活状态
·     Release_Awaited:等待Release消息状态
·     Established (Sending Mapping):正在发送Mapping消息
·     Established (Delay To Withdraw):延迟回收入标签
·     IDLE (Sending Release):正在发送Release消息
·     Release_Awaited (Sending Withdraw):正在发送Withdraw消息
·     Release_Awaited (Aging):正在老化标签
Hop Count
跳数值
Path Vector Count
路径向量中包括的LSR数目
Path Vector
路径向量
Received MTU
最大传输单元
OutIfCount
出接口数目
OutGoing Info
出方向信息
出接口
Nexthop
下一跳地址
display mpls ldp interface [ all [ verbose ] | [ vpn-instance vpn-instance-name ] [ interface-type interface-number | verbose ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:显示所有信息。
verbose:显示详细信息。
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
interface-type interface-number:显示指定接口的信息。interface-type interface-number为接口类型和接口编号。
【描述】
display mpls ldp interface命令用来显示使能了LDP能力接口的LDP相关信息。
如果不指定任何参数,则显示所有使能了LDP能力接口的LDP简要信息。
相关配置可参考命令mpls ldp (System view)和mpls ldp (Interface view)。
# 显示所有使能了LDP能力接口的LDP简要信息。
<Sysname> display mpls ldp interface
     LDP Interface Information in Public Network
 IF-Name         Status       LAM   Transport-Address   Hello-Sent/Rcv
 Vlan1000        Active       DU    172.17.1.1          583/1017
 Vlan1001        Active       DU    172.17.1.1          578/1015
 Vlan1002        Active       DU    172.17.1.1          531/444
 LAM: Label Advertisement Mode         IF-Name: Interface name
# 显示所有使能了LDP能力接口的LDP详细信息。
<Sysname> display mpls ldp interface verbose
 Interface Name : Vlan-interface1000
 LDP ID         : 172.17.1.1:0          Transport Address : 172.17.1.1
 Entity Status  : Active                Interface MTU     : 1500
 Configured Hello Timer     : 15 Sec
 Negotiated Hello Timer     : 15 Sec
 Configured Keepalive Timer : 45 Sec
 Label Advertisement Mode   : Downstream Unsolicited
 Hello Message Sent/Rcvd    : 591/1033 (Message Count)
 Interface Name : Vlan-interface1001
 Hello Message Sent/Rcvd    : 586/1031 (Message Count)
 Interface Name : Vlan-interface1002
 Hello Message Sent/Rcvd    : 539/452 (Message Count)
表1-6 display mpls ldp interface命令显示信息描述表
Interface Name
使能了LDP能力的接口名称
LDP ID
LDP的标识符,用于标识特定LSR的标签空间
由LSR ID和标签空间标识符两部分组成。目前,标签空间标识符取值只能为0,表示每平台标签空间,即整个LSR使用一个标签空间
Transport Address
LDP传输地址,设备采用该地址与LDP对等体建立TCP连接
Entity Status
实体状态,包括激活或非激活两种状态
Interface MTU
接口的最大传输单元
配置的Hello定时器时间
协商的Hello定时器时间
配置的Keepalive定时器时间
标签发布方式,目前取值只能为DU
此接口发送和接收的Hello消息数目
display mpls ldp lsp [ all | [ vpn-instance vpn-instance-name ] [ destination-address mask-length ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all显示所有信息。
dest-addr mask-length:显示指定FEC的信息。dest-addr表示FEC的目的地址,mask-length表示FEC目的地址的掩码长度,取值范围为0~32。
【描述】
display mpls ldp lsp命令用来显示LDP创建的LSP相关信息。
如果不指定任何参数,则显示所有LDP创建的LSP相关信息。
相关配置可参考命令display mpls lsp
# 显示所有LDP创建的LSP相关信息。
<Sysname> display mpls ldp lsp
                              LDP LSP Information
 SN     DestAddress/Mask    In/OutLabel   Next-Hop        In/Out-Interface
 1      3.3.3.3/32          3/NULL        127.0.0.1       -------/InLoop0
 2      10.1.1.0/24         3/NULL        10.1.1.1         -------/GE3/0/1
*3      100.1.1.1/32        Liberal(1025)
A '*' before an LSP means the LSP is not established
A '*' before a Label means the USCB or DSCB is stale
表1-7 display mpls ldp lsp命令显示信息描述表
SN
该LSP的序号。SN前面如果有“*”表示未建立LSP
DestAddress/Mask
该LSP的FEC目的地址和掩码
In/OutLabel
入/出标签值。In/OutLabel前面如果有“*”表示该LSP处于GR过程中。Liberal(number),表示LSP不可用,标签值为number
Next-Hop
下一跳地址
In/Out-Interface
入接口与出接口
display mpls ldp peer [ all [ verbose ] | [ vpn-instance vpn-instance-name ] [ peer-id | verbose ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all显示所有对等体信息。
verbose:显示详细信息。
vpn-instance vpn-instance-name:显示指定VPN的所有对等体信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31字符的字符串,区分大小写。
peer-id:显示指定对等体的信息,peer-id表示对等体的LSR ID。
【描述】
display mpls ldp peer命令用来显示对等体的信息。
相关配置可参考命令mpls ldp
# 显示对等体的简要信息。
<Sysname> display mpls ldp peer
         LDP Peer Information in Public network
 Total number of peers: 3
 Peer-ID                Transport-Address  Discovery-Source
 172.17.1.2:0           172.17.1.2         Vlan1000
 168.1.1.1:0            168.1.1.1          Vlan1001
 100.10.1.1:0           100.10.1.1         Vlan1002
表1-8 display mpls ldp peer命令显示信息描述表
对等体的数量
Peer-ID
对等体的LDP标识符,详细介绍请参见表1-6
Transport-Address
对等体的LDP传输地址
Discovery-Source
发现此对等体的接口
# 显示对等体的详细信息。
<Sysname> display mpls ldp peer verbose
 Peer LDP ID         : 172.17.1.2:0
 Peer Max PDU Length : 4096            Peer Transport Address : 172.17.1.2
 Peer Loop Detection : Off             Peer Path Vector Limit : 0
 Peer FT Flag        : Off             Peer Keepalive Timer   : 45 Sec
 Recovery Timer      : ----            Reconnect Timer        : ----
 Peer Label Advertisement Mode : Downstream Unsolicited
 Peer Discovery Source         : Vlan-interface1000
 Peer LDP ID         : 168.1.1.1:0
 Peer Max PDU Length : 4096            Peer Transport Address : 168.1.1.1
 Peer Discovery Source         : Vlan-interface1001
 Peer LDP ID         : 100.10.1.1:0
 Peer Max PDU Length : 4096            Peer Transport Address : 100.10.1.1
 Peer Discovery Source         : Vlan-interface1002
表1-9 display mpls ldp peer verbose命令显示信息描述表
Peer LDP ID
Peer Max PDU Length
对等体的最大PDU长度
对等体的LDP传输地址
Peer Loop Detection
对等体是否使能环路检测功能
对等体的路径向量的最大跳数
Peer FT Flag
对等体是否使能GR FT功能
对等体Keepalive定时器的值
Reconnect Timer
FT重连定时器的值
Recovery Timer
LDP恢复定时器的值
对等体标签发布方式
发现此对等体的接口
display mpls ldp remote-peer [ remote-name remote-peer-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
remote-name remote-peer-name:显示指定远端对等体的信息。remote-peer-name表示远端对等体的名称,为1~32字符的字符串,不区分大小写。
【描述】
display mpls ldp remote-peer命令用来显示远端对等体信息。
相关配置可参考命令mpls ldpremote-ip
# 显示名称为BJI的远端对等体的信息。
<Sysname> display mpls ldp remote-peer remote-name BJI
                        LDP Remote Entity Information
 Remote Peer Name  : BJI
 Remote Peer IP    : 3.3.3.3          LDP ID : 1.1.1.1:0
 Transport Address : 1.1.1.1
 Configured Hello Timer     : 45 Sec
 Negotiated Hello Timer     : 45 Sec
 Hello Message Sent/Rcvd    : 3/2 (Message Count)
表1-10 display mpls ldp remote-peer命令显示信息描述表
LDP远端对等体的信息
Remote Peer Name
远端对等体的名称
Remote Peer IP
远端对等体的IP地址
LDP ID
本地的LDP标识符,详细介绍请参见表1-6
Transport Address
用来与此远端对等体建立TCP连接的本地LDP传输地址
配置的Keepalive定时器的值
配置的Hello定时器的值
协商的Hello定时器的值
向远端对等体发送/从远端对等体接收的Hello消息数
display mpls ldp session [ all [ verbose ] | [ vpn-instance vpn-instance-name ] [ peer-id | verbose ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:显示所有信息。
verbose:显示详细信息。
vpn-instance vpn-instance-name:显示指定VPN的所有LDP会话信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31字符的字符串,区分大小写。
peer-id:显示指定对等体的LDP会话信息。peer-id表示对等体的LSR ID。
【描述】
display mpls ldp session命令用来显示对等体间会话信息。
如果不指定任何参数,则只显示所有公网LDP对等体间的会话信息。
相关配置可参考命令mpls ldp
# 显示所有公网LDP对等体间的会话信息。
<Sysname> display mpls ldp session
               LDP Session(s) in Public Network
 Total number of sessions: 1
 Peer-ID            Status        LAM  SsnRole  FT   MD5  KA-Sent/Rcv
 1.1.1.1:0          Operational   DU   Active   Off  Off  4582/4582
 LAM : Label Advertisement Mode         FT  : Fault Tolerance
表1-11 display mpls ldp session命令显示信息描述表
LDP会话的总数
Peer-ID
Status
会话的状态,取值包括:
·     Non Existent:尚未建立TCP连接
·     Initialized:TCP连接已经建立
·     Open-Received:接收到可接受的初始化消息
·     Open-Sent:已经发送初始化消息
·     Operational:成功建立会话
LAM
会话的标签发布方式
SsnRole
本地LSR在会话中的角色,取值为:
·     Active:主动方
·     Passive:被动方
FT
对等体是否使能会话的GR FT功能
MD5
对等体是否使能MD5认证功能
KA-Sent/Rcv
本地LSR发送和接收的keepalive消息数
# 显示所有公网LDP对等体间会话的详细信息。
<Sysname> display mpls ldp session verbose
 Peer LDP ID     : 1.1.1.1:0            Local LDP ID   : 3.3.3.3:0
 TCP Connection  : 3.3.3.3 -> 1.1.1.1
 Session State   : Operational          Session Role   : Active
 Session FT Flag : Off                  MD5 Flag       : Off
 Reconnect Timer : ---                  Recovery Timer : ---
 Negotiated Keepalive Timer        : 45 Sec
 Keepalive Message Sent/Rcvd       : 6/6 (Message Count)
 Label Resource Status(Peer/Local) : Available/Available
 Peer Discovery Mechanism          : Extended
 Session existed time              : 000:00:01  (DDD:HH:MM)
 LDP Extended Discovery Source     : Remote peer: 1
 Addresses received from peer: (Count: 2)
 10.1.1.1            1.1.1.1
 Peer LDP ID     : 2.2.2.2:0            Local LDP ID   : 3.3.3.3:0
 TCP Connection  : 3.3.3.3 -> 2.2.2.2
 Keepalive Message Sent/Rcvd       : 25/25 (Message Count)
 Peer Discovery Mechanism          : Basic
 Session existed time              : 000:00:06  (DDD:HH:MM)
 LDP Basic Discovery Source        : Vlan-interface1001
 Addresses received from peer: (Count: 3)
 10.1.1.2            20.1.1.1            2.2.2.2
表1-12 display mpls ldp session verbose命令显示信息描述表
Peer LDP ID
Local LDP ID
TCP connection
该会话的TCP连接信息,即TCP连接两端的IP地址
Session State
会话的状态,取值请参见表1-11
Session Role
本地LSR在会话中的角色,取值为:
·     Active:主动方
·     Passive:被动方
Session FT Flag
对等体是否使能会话的GR FT功能
MD5 Flag
对等体是否使能MD5认证功能
Reconnect Timer
FT重连定时器的值
Recovery Timer
LDP恢复定时器的值
协商的Keepalive定时器的值
本地LSR发送和接收的Keepalive消息数
该会话的标签发布方式
对等体与本地的标签资源状态
对等体的发现机制,取值为:
·     Basic:基本发现机制
·     Extended:扩展发现机制
会话持续时间
会话建立的接口,基本发现时显示为接口名称,扩展发现时显示为远端对等体名称
对等体发送的地址表
Label Acceptance Policy
标签接受控制策略
display mpls ldp session all statistics [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls ldp session all statistics命令用来显示所有LDP会话的统计信息。
# 显示所有LDP会话的统计信息。
<Sysname> display mpls ldp session all statistics
Total number of sessions : 1024
Session(s) in Non-Existent state  : 100
Session(s) in Initialized state   : 200
Session(s) in Open-Received state : 400
Session(s) in Open-Sent state     : 300
Session(s) in Operational state   : 24
表1-13 display mpls ldp session all statistics命令显示信息描述表
当前创建的LDP会话的总数
当前处于Non-Existent状态的LDP会话数目
当前处于Initialized状态的LDP会话数目
当前处于Open-Received状态的LDP会话数目
当前处于Open-Sent状态的LDP会话数目
当前处于Operational状态的LDP会话数目
display mpls lsp [ incoming-interface interface-type interface-number ] [ outgoing-interface interface-type interface-number ] [ in-label in-label-value ] [ out-label out-label-value ] [ asbr | [ vpn-instance vpn-instance-name ] [ protocol { bgp | bgp-ipv6 | crldp | ldp | rsvp-te | static | static-cr } ] ] [ egress | ingress | transit ] [ { exclude | include } { ipv4-dest-addr mask-length | ipv6-dest-addr prefix-length } ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
incoming-interface interface-type interface-number:显示以指定接口为入接口的LSP信息。interface-type interface-number为接口类型和接口编号。
outgoing-interface interface-type interface-number:显示以指定接口为出接口的LSP信息。interface-type interface-number为接口类型和接口编号。
in-label in-label-value:显示以指定值为入标签的LSP信息。in-label-value为入标签值,取值范围为0~1048575。
out-label out-label-value:显示以指定值为出标签的LSP信息。out-label-value为出标签值,取值范围为0~1048575。
asbr:显示ASBR产生的LSP信息。
vpn-instance vpn-instance-name:显示指定VPN的LSP信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31字符的字符串,区分大小写。
protocol:根据建立LSP的协议类型显示LSP信息。
bgp:显示BGP LSP信息。
bgp-ipv6:显示IPv6 BGP(即BGP4+协议)LSP信息。
crldp:显示CR-LDP产生的CR-LSP信息。
ldp:显示LDP LSP信息。
rsvp-te:显示RSVP-TE产生的CR-LSP信息。
static:显示通过手工配置的静态LSP信息。
static-cr:显示通过手工配置的静态CR-LSP信息。
egress:显示交换机作为出节点的LSP信息。
ingress:显示交换机作为入节点的LSP信息。
transit:显示交换机作为中间节点的LSP信息。
exclude:显示不包含指定FEC的LSP信息。
include:显示包含指定FEC的LSP信息。
ipv4-dest-addr mask-length:FEC的目的IPv4地址和掩码长度。其中,mask-length取值范围为0~32。
ipv6-dest-addr prefix-length:FEC的目的IPv6地址和前缀长度。其中,prefix-length取值范围为0~128。
verbose:显示详细信息。
| { begin | exclude | include } regular-expression:使用正则表达式对显示信息进行过滤。有关正则表达式的详细介绍,请参见“基础配置指导”中的“CLI”。其中:
·     begin:从包含指定正则表达式的行开始显示。
·     exclude:只显示不包含指定正则表达式的行。
·     include:只显示包含指定正则表达式的行。
·     regular-expression:表示正则表达式,为1~256个字符的字符串,区分大小写。
【描述】
display mpls lsp命令用来显示LSP信息。
如果不指定任何参数,将显示所有LSP的信息。
相关配置可参考命令display mpls lspdisplay mpls statistics lspdisplay mpls static-lsp
# 显示所有LSP信息。
<Sysname> display mpls lsp
                 LSP Information: L3VPN LSP
FEC              In/Out Label  In/Out IF Route-Distinguisher   Vrf Name
100.1.1.1        1025/1024     -/-       100:1                 N/A (ASBR)
                 LSP Information: LDP LSP
FEC              In/Out Label  In/Out IF                       Vrf Name
100.10.1.0/24    3/NULL        -/InLoop0
168.1.0.0/16     3/NULL        -/Vlan11
172.17.0.0/16    3/NULL        -/Vlan12
表1-14 display mpls lsp命令显示信息描述表
FEC
转发等价类,包括两种形式:
·     IP地址/掩码:表示根据目的地址分配标签
·     IP地址:表示根据下一跳地址分配标签
In/Out Label
入/出标签值
In/Out IF
入/出接口简称
Route-Distinguisher
路由标识符
Vrf Name
VPN实例名称,包括三种形式的取值:
·     为空:表示公网
·     为N/A (ASBR):表示ASBR LSP
·     为其他值:表示MPLS L3VPN实例名称
# 显示所有LSP的详细信息。
<Sysname> display mpls lsp verbose
  No.                 :  1
  VrfName             :
  Fec                 :  1.1.1.9/32
  Nexthop             :  127.0.0.1
  In-Label            :  3
  Out-Label           :  NULL
  In-Interface        :  ----------
  Out-Interface       :  InLoopBack0
  LspIndex            :  10241
  Tunnel ID           :  0x0
  LsrType             :  Egress
  Outgoing Tunnel ID  :  0x0
  Label Operation     :  POP
表1-15 display mpls lsp命令显示信息描述表
No.
序号
VrfName
VPN实例名称,包括三种形式的取值:
·     为空:表示公网
Fec
转发等价类,包括两种形式:
Nexthop
下一跳地址
In-Label
入标签值
Out-Label
出标签值
In-Interface
入接口
Out-Interface
出接口
LspIndex
LSP索引
Tunnel ID
标记(公网)
LsrType
LSR类型,取值包括:
·     Ingress:LSP的入节点
·     Transit:LSP的中间节点
·     Egress:LSP的出节点
Outgoing Tunnel ID
标记(跨域VPN)
Label Operation
执行的标签操作,取值包括:
·     POP:弹出标签
·     PUSH:压入标签
·     SWAP:交换标签
display mpls lsp bfd [ ipv4 destination-address mask-length ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
destination-address mask-length:显示指定FEC对应LSP的BFD检测信息。destination-address为FEC的目的IP地址。mask-length为目的地址的掩码长度,取值范围为0~32。
【描述】
display mpls lsp bfd ipv4命令用来显示BFD对LSP隧道的检测信息。
# 显示BFD对到达目的地址1.1.1.9/32的LSP的检测信息。
<Sysname> display mpls lsp bfd ipv4 1.1.1.9 32
               MPLS BFD Session(s) Information
 FEC            : 1.1.1.9/32        Type           : LSP
 Local Discr    : 1                 Remote Discr   : 1
 Tunnel ID      : 0xd2007           NextHop        : 11.1.1.2
 Session State  : Up                Source IP      : 1.1.1.1
 Local Discr    : 2                 Remote Discr   : 2
 Tunnel ID      : 0xd2008           NextHop        : 12.1.1.2
 Total Session Num: 2
表1-16 display mpls lsp bfd ipv4命令显示信息描述表
FEC
FEC信息
BFD检测的隧道类型,取值包括LSP和TE Tunnel
Local Discr
BFD会话的本地鉴别值
Remote Discr
BFD会话的远端鉴别值
Tunnel ID
隧道ID
NextHop
下一跳地址
Session State
BFD会话状态,取值包括:
·     Init:BFD会话处于初始化状态
·     Up:BFD会话处于up状态
·     Down:BFD会话处于down状态
Source IP
BFD会话主动端(Ingress LSR)的源IP地址
Session Role
BFD会话角色,取值包括
·     Active:BFD会话的发起端
·     Passive:BFD会话的接收端
display mpls lsp statistics [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls lsp statistics命令用来显示LSP的统计信息。
# 显示LSP统计信息。
<Sysname> display mpls lsp statistics
Lsp Type       Total     Ingress   Transit   Egress
STATIC LSP     1         1         0         0
STATIC CRLSP   1         1         0         0
LDP LSP        0         0         0         0
CRLDP CRLSP    0         0         0         0
RSVP CRLSP     1         1         0         0
BGP LSP        0         0         0         0
ASBR LSP       0         0         0         0
BGP IPV6 LSP   0         0         0         0
LSP            1         1         0         0
CRLSP          2         2         0         0
表1-17 display mpls lsp statistics命令显示信息描述表
Lsp Type
LSP的类型,具体类型请参见表1-18
Total
各种类型LSP的总数
Ingress
交换机作为入节点的LSP数量
Transit
交换机作为中间节点的LSP数量
Egress
交换机作为出节点的LSP数量
LSP
所有类型LSP的总数及交换机作为不同类型节点的LSP总数
CRLSP
所有类型CR-LSP的总数及交换机作为不同类型节点的CR-LSP总数
表1-18 LSP类型表
STATIC LSP
静态LSP
STATIC CRLSP
静态CR-LSP
LDP LSP
LDP生成的LSP
CRLDP CRLSP
CR-LDP生成的CR-LSP,设备暂时不支持CR-LDP
RSVP CRLSP
RSVP生成的CR-LSP
BGP LSP
BGP生成的LSP
ASBR LSP
ASBR生成的LSP
BGP IPV6 LSP
IPv6 BGP生成的LSP
独立运行模式:
display mpls nhlfe [ token ] [ verbose ] [ slot slot-number ] [ include text | { | { begin | exclude | include } regular-expression } ]
IRF模式:
display mpls nhlfe [ token ] [ verbose ] [ chassis chassis-number slot slot-number ] [ include text | { | { begin | exclude | include } regular-expression } ]
【缺省级别】
1:监控级
token:NHLFE表项索引,取值范围为0~65535。
verbose:显示详细信息。
slot slot-number显示指定单板上的NHLFE表项。slot-number为单板所在的槽位号。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的NHLFE表项。chassis-number表示设备在IRF中的成员编号, slot-number表示单板的槽位号,可使用display device命令查看。
include text:显示含有指定字符串的NHLFE表项。text为用户指定的字符串。
【描述】
display mpls nhlfe命令用来查看NHLFE表的信息。
如果不指定token参数,将显示所有NHLFE表项信息。
# 显示指定的NHLFE表项。
<Sysname> display mpls nhlfe 2
Out-Interface       Token      Oper     Nexthop         Deep Stack
Vlan1000            2          PUSH     88.1.1.2        1    1024
# 显示所有NHLFE表项。
Total NHLFE Entry: 1
表1-19 display mpls nhlfe命令显示信息描述表
Out-Interface
出接口
Token
NHLFE表项索引
Oper
标签操作类型,取值包括
·     PUSH:压入标签
·     SWAP:交换标签
·     GO:弹出标签
Nexthop
下一跳地址
Deep
MPLS标签栈深度
Stack
MPLS标签值
独立运行模式:
display mpls nhlfe reflist token [ slot slot-number ] [ include text | { | { begin | exclude | include } regular-expression } ]
IRF模式:
display mpls nhlfe reflist token [ chassis chassis-number slot slot-number ] [ include text | { | { begin | exclude | include } regular-expression } ]
【缺省级别】
1:监控级
slot slot-number:显示指定单板上的NHLFE表项使用情况。slot-number为单板所在的槽位号。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的NHLFE表项使用情况。chassis-number表示设备在IRF中的成员编号, slot-number表示单板的槽位号,可使用display device命令查看。
include text:显示含有指定字符串的NHLFE表项使用情况信息。text为用户指定的字符串。
【描述】
display mpls nhlfe reflist命令用来显示NHLFE表项的使用情况。
# 显示指定NHLFE表项的使用情况。
<Sysname> display mpls nhlfe reflist 11
Total reference node: 7
No.     Type            Key-Info
1       ILM             1023(Inlabel)         Vlan1000(In-If)
2       FTN             1(VPN ID)             2.2.2.2/32
3       LPW             ----(SRV ID)          Vlan1001(Private-If)
4       VPW             1(VSI ID)             1(Link ID)
5       FRR             11(Token)             ----
6       INN             11(Token)             ----
7       OAM             1(Index)              ----
8       BFD             1(BFD Discr)          ----
表1-20 display mpls nhlfe reflist命令显示信息描述表
关联节点总数
No.
编号
关联节点的类型
Key-Info
表项的关键参数
编号前带“*”表示该节点无效,等待被删除。
表1-21 关联节点类型及关键参数对应表
类型
关键参数
FTN
前缀类型FEC到NHLFE的映射
·     VPN ID:VPN实例ID
·     地址前缀/掩码
ILM
入标签映射
·     In-Label:入标签
·     In-If:入接口
LPW
VPWS PW发送方向表项
·     SRV ID:服务实例ID
·     Private-If:私网接口
VPW
VPLS PW发送方向表项
·     VSI ID:虚交换实例ID
·     Link ID:链路ID
FRR
FRR的主NHLFE
Token:主NHLFEToken
INN
分层LSP的内层NHLFE
Token:内层NHLFE的Token
OAM
通过OAM检测该NHLFE对应CR-LSP的连通性
Index:OAM实例索引
BFD
通过BFD会话检测该NHLFE的连通性
BFD Discr:BFD会话的本地鉴别值
display mpls route-state [ vpn-instance vpn-instance-name ] [ dest-addr mask-length ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31字符的字符串,区分大小写。
dest-addr mask-length:显示指定目的地址的信息。dest-addr为目的IP地址,mask-length为目的地址的掩码长度,取值范围为0~32。
【描述】
display mpls route-state命令用来显示路由的LSP相关信息。
如果不指定VPN实例,将显示公网的路由信息;如果不指定目的地址和掩码,将显示所有路由信息。
# 显示所有路由的LSP相关信息。
<Sysname> display mpls route-state
DEST/MASK   NEXT-HOP    OUT-INTERFACE  STATE LSP-COUNT  VPN-INDEX
1.1.1.1/32  10.0.0.1    Vlan1000           ESTA  1           0
表1-22 display mpls route-state命令显示信息描述表
DEST/MASK
路由的目的地址和掩码
NEXT-HOP
路由的下一跳地址
OUT-INTERFACE
路由的出接口
STATE
路由的状态
LSP-COUNT
基于此路由建立的LSP数量
VPN-INDEX
VPN实例索引
display mpls static-lsp [ lsp-name lsp-name ] [ { exclude | include } dest-addr mask-length ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
lsp-name lsp-name:显示指定LSP的信息。lsp-name表示标签转发路径名称,为1~15字符的字符串。
dest-addr:FEC的目的地址。
mask-length:FEC目的地址的掩码长度,取值范围为0~32。
verbose:显示详细信息。
【描述】
display mpls static-lsp命令用来显示静态LSP的信息。
# 显示静态LSP的简要信息。
<Sysname> display mpls static-lsp
total statics-lsp : 1
Name       FEC               I/O Label  I/O If                 State
lsp1       3.3.3.9/32        NULL/100   -/Vlan1000             Up
表1-23 display mpls static-lsp命令显示信息描述表
total statics-lsp
静态LSP的总数
Name
LSP名称
FEC
转发等价类
I/O Label
入/出标签值
I/O If
入接口/出接口名称
LSP当前的状态
# 显示静态LSP的详细信息。
<Sysname> display mpls static-lsp verbose
No             : 1
LSP-Name       : lsp1
LSR-Type       : Ingress
FEC            : 3.3.3.9/32
In-Label       : NULL
Out-Label      : 100
In-Interface   : -
Out-Interface  : Vlan1000
NextHop        : 30.1.1.2
Static-Lsp Type: IPTN
Lsp Status     : Up
表1-24 display mpls static-lsp命令显示信息描述表
No
序号
LSP-Name
LSP名称
LSR-Type
LSR的类型,取值为Ingress、Transit和Egress
FEC
转发等价类
In-Label
入标签值
Out-Label
出标签值
In-Interface
入接口名称
Out-Interface
出接口名称
NextHop
下一跳地址
Static-Lsp Type
静态LSP类型
Lsp Status
LSP当前状态
display mpls statistics interface { interface-type interface-number | all } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:显示指定接口的MPLS统计信息。interface-type interface-number为接口类型和接口编号。
all:显示所有接口的MPLS统计信息。
【描述】
display mpls statistics interface命令用来根据使能MPLS能力的接口显示MPLS统计信息。
如果要显示统计信息,请先通过statistics interval命令使能接口的统计功能,否则显示出来的各项统计信息都为0。
相关配置可参考命令statistics interval
# 根据使能MPLS能力的接口显示MPLS统计信息。
<Sysname> display mpls statistics interface all
  Statistics for Interface IN :
  Incoming Interface Vlan-interface1000
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
       Failed Label Lookup     : 0
       Start Time              : 2008/04/28  10:23:55
       End Time                : 2008/04/28  10:23:55
  Statistics for Interface OUT :
  Outgoing Interface Vlan-interface1000
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
  Incoming Interface Vlan-interface1001
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
       Start Time              : 2008/04/28  10:24:04
       End Time                : 2008/04/28  10:24:04
  Outgoing Interface Vlan-interface1001
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
  Incoming Interface Vlan-interface1002
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
       Start Time              : 2008/04/28  10:24:10
       End Time                : 2008/04/28  10:24:10
  Outgoing Interface Vlan-interface1002
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
表1-25 display mpls statistics interface命令显示信息描述表
接口入方向的统计信息
入接口名称
Octets
从该接口进入的字节数
Packets
从该接口进入的报文数
Errors
从该接口进入的报文处理错误数
Disables
从该接口进入的报文被丢弃的次数
Failed Label Lookup
从该接口进入的报文查找标签失败次数
Start Time
该接口入方向的报文统计开始时间
End Time
该接口入方向的报文统计结束时间
接口出方向的统计信息
出接口名称
Octets
从该接口发出的字节数
Packets
从该接口发出的报文数
Errors
从该接口发出的报文处理错误数
Disables
从该接口发出的报文被丢弃的次数
Start Time
该接口出方向的报文统计开始时间
End Time
该接口出方向的报文统计结束时间
display mpls statistics lsp { index | all | name lsp-name } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
index:显示指定LSP索引号对应的LSP统计信息。index表示LSP的索引号,取值范围为0~4294967295。
all:显示所有LSP的统计信息。
name lsp-name:显示指定LSP名称对应的LSP统计信息。lsp-name表示LSP的名称,为1~15个字符的字符串。
【描述】
display mpls statistics lsp命令用来根据LSP显示MPLS统计信息。包括每一条LSP的入口和出口处理的字节数、报文数、错误数,丢弃报文数等。
如果要通过本命令查看MPLS的统计信息,则需要先执行statistics interval命令配置获取统计数据的时间间隔,否则显示出来的各项统计信息都为0。
# 显示所有LSP的MPLS统计信息。
<Sysname> display mpls statistics lsp all
Statistics for Lsp IN : LSP Name /LSP Index :  DynamicLsp/9217
   InSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
       Start Time            : 2008/05/20  15:52:30
       End Time              : 2008/05/20  15:52:30
  Statistics for Lsp OUT : LSP Name /LSP Index :  DynamicLsp/9217
   OutSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
       Start Time            : 0000/00/00  00:00:00
       End Time              : 0000/00/00  00:00:00
  Statistics for Lsp IN : LSP Name /LSP Index :  DynamicLsp/9218
   InSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
  Statistics for Lsp OUT : LSP Name /LSP Index :  DynamicLsp/9218
   OutSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
表1-26 display mpls statistics lsp命令显示信息描述表
LSP入口处理的统计信息
LSP Name /LSP Index
LSP名称和LSP索引值
InSegment
LSP的入表项信息
Octets
LSP入口处理的字节数
Packets
LSP入口处理的报文数
Errors
LSP入口处理的错误数
Down
LSP入口处理丢弃的报文数
Start Time
LSP入口处理的统计开始时间
End Time
LSP入口处理的统计结束时间
LSP出口处理的统计信息
OutSegment
LSP的出表项信息
Octets
LSP出口处理的字节数
Packets
LSP出口处理的报文数
Errors
LSP出口处理的错误数
Down
LSP出口处理丢弃的报文数
Start Time
LSP出口处理的统计开始时间
End Time
LSP出口处理的统计结束时间
对于Ingress节点,不对入方向进行统计,因此,显示信息中InSegment的开始时间和结束时间都为0;Egress节点不对出方向进行统计,显示信息中OutSegment的开始时间和结束时间都为0。
du-readvertise
undo du-readvertise
【缺省级别】
2:系统级
【描述】
du-readvertise命令用来使能DU模式下标签重发布功能。undo du-readvertise命令用来禁止该功能。
缺省情况下,DU模式下已使能标签重发布功能。
# 使能公网LDP的DU模式下标签重发布功能。
[Sysname] mpls ldp
[Sysname-mpls-ldp] du-readvertise
# 使能名为vpn1的LDP实例的DU模式下标签重发布功能。
[Sysname] mpls ldp vpn-instance vpn1
[Sysname-mpls-ldp-vpn-instance-vpn1] du-readvertise
du-readvertise timer value
undo du-readvertise timer
【缺省级别】
2:系统级
value:标签重发布的时间间隔,取值范围为1~65535,单位为秒。
【描述】
du-readvertise timer命令用来配置DU模式下定期重发布标签的时间间隔。undo du-readvertise timer命令用来恢复缺省情况。
缺省情况下,DU模式下定期重发布标签的时间间隔为30秒。
# 配置公网LDP的DU模式下定期重发布标签的时间间隔为100秒。
[Sysname] mpls ldp
[Sysname-mpls-ldp] du-readvertise timer 100
# 设置名为vpn1的LDP实例的DU模式下定期重发布标签的时间间隔为100秒。
[Sysname-mpls-ldp-vpn-instance-vpn1] du-readvertise timer 100
graceful-restart
undo graceful-restart
MPLS-LDP视图
【缺省级别】
2:系统级
【描述】
graceful-restart命令用来使能MPLS LDP协议的GR能力。undo graceful-restart命令用来关闭MPLS LDP协议的GR能力。
缺省情况下,MPLS LDP协议的GR能力处于关闭状态。
需要注意的是,使能或禁止GR功能会导致删除并重建所有的LDP会话,基于这些会话所创建的LSP也将被删除,并需要重建。
# 使能MPLS LDP协议的GR能力。
[Sysname] mpls lsr-id 1.1.1.1
[Sysname] mpls
[Sysname-mpls] quit
[Sysname] mpls ldp
[Sysname-mpls-ldp] graceful-restart
【缺省级别】
1:监控级
【描述】
graceful-restart mpls ldp命令用来平滑重启MPLS LDP。
·     本命令用来在不发生主备倒换的情况下测试MPLS LDP GR功能。其他情况下,请不要使用本命令。
·     执行本命令前需要先使能MPLS LDP GR能力。
相关配置可参考命令graceful-restart (MPLS-LDP view)。
# 平滑重启MPLS LDP。
<Sysname> graceful-restart mpls ldp
graceful-restart timer neighbor-liveness timer
undo graceful-restart timer neighbor-liveness
MPLS-LDP视图
【缺省级别】
2:系统级
timer:LDP邻居存活定时器的值,取值范围为60~300,单位为秒。
【描述】
graceful-restart timer neighbor-liveness命令用来配置LDP邻居存活定时器的值。undo graceful-restart timer neighbor-liveness命令用来恢复缺省情况。
缺省情况下,LDP邻居存活定时器的值为120秒。
·     更改邻居存活定时器的值会导致删除并重建所有的LDP会话,基于这些会话所创建的LSP也将被删除,并需要重建。
·     如果LDP会话配置了MD5认证,则需要适当增加邻居存活定时器的时长,以保证TCP连接能够重新建立。
# 配置LDP邻居存活定时器的值为100秒。
[Sysname] mpls ldp
[Sysname-mpls-ldp] graceful-restart timer neighbor-liveness 100
graceful-restart timer reconnect timer
undo graceful-restart timer reconnect
MPLS-LDP视图
【缺省级别】
2:系统级
timer:FT重连定时器的值,取值范围为60~300,单位为秒。
【描述】
graceful-restart timer reconnect命令用来配置FT重连定时器的值。undo graceful-restart timer reconnect命令用来恢复缺省情况。
缺省情况下,FT重连定时器的值为300秒。
·     FT重连定时器表示TCP连接失败后,LSR保留Stale标签状态的最长时间。
·     更改FT重连定时器的值会导致删除并重建所有的LDP会话,基于这些会话所创建的LSP也将被删除,并需要重建。
# 配置FT重连定时器的值为100秒。
[Sysname] mpls ldp
[Sysname-mpls-ldp] graceful-restart timer reconnect 100
graceful-restart timer recovery timer
undo graceful-restart timer recovery
MPLS-LDP视图
【缺省级别】
2:系统级
timer:LDP恢复定时器的值,取值范围为3~300,单位为秒。
【描述】
graceful-restart timer recovery命令用来配置LDP恢复定时器的值。undo graceful-restart timer recovery命令用来恢复缺省情况。
缺省情况下,LDP恢复定时器的值为300秒。
·     恢复时间表示TCP重建连接后,LSR保持Stale标签状态的最长时间。
·     更改恢复时间定时器的值会导致删除并重建所有的LDP会话,基于这些会话所创建的LSP也将被删除,并需要重建。
# 配置恢复定时器的值为45秒。
[Sysname] mpls ldp
[Sysname-mpls-ldp] graceful-restart timer recovery 45
1.1.31  hops-count
hops-count hop-number
undo hops-count
【缺省级别】
2:系统级
hop-number:跳数值,取值范围为1~32。
【描述】
hops-count命令用来配置环路检测的最大跳数。undo hops-count命令用来恢复缺省配置。
缺省情况下,环路检测最大跳数为32。
此命令应该在所有接口使能LDP之前配置,跳数值的大小决定LSP建立过程中检测到环路的快慢程度,应根据实际的组网情况调整。
相关配置可参考命令loop-detectpath-vectors
# 配置公网LDP的环路检测的最大跳数为25。
[Sysname] mpls ldp
[Sysname-mpls-ldp] hops-count 25
# 配置名为vpn1的LDP实例的环路检测的最大跳数为25。
[Sysname-mpls-ldp-vpn-instance-vpn1] hops-count 25
label advertise { explicit-null | implicit-null | non-null }
undo label advertise
MPLS视图
【缺省级别】
2:系统级
explicit-nullEgress节点向倒数第二跳分配显式空标签,标签值为0
implicit-nullEgress节点向倒数第二跳分配隐式空标签,标签值为3
non-nullEgress节点向倒数第二跳正常分配标签,即分配的标签值不小于1024
目前,设备不支持non-null关键字。
【描述】
label advertise命令用来配置Egress节点向倒数第二跳分配的标签值。undo label advertise命令用来恢复缺省情况。
缺省情况下,Egress节点向倒数第二跳分配隐式空标签(implicit-null)。
·     选择哪种标签值需要根据倒数第二跳节点对PHP特性的支持情况而定。如果倒数第二跳节点支持PHP特性,则可以为其分配显式或隐式空标签;如果倒数第二跳节点不支持PHP特性,则为其正常分配标签。
·     会话建立后,需使用reset mpls ldp命令重启LDP会话,本命令的配置才能生效。
# 配置Egress节点向倒数第二跳分配显式空标签。
[Sysname] mpls
[Sysname-mpls] label advertise explicit-null
label-distribution { independent | ordered }
undo label-distribution
【缺省级别】
2:系统级
independent:独立标签分配控制方式,即LSR可以在任意时间向与它连接的LSR通告标签映射。
ordered:有序标签分配控制方式,即LSR只有收到它的下游LSR为某个FEC分配的标签,或该LSR是某个FEC的出口节点时,才会向它的上游LSR通告此FEC的标签映射。
【描述】
label-distribution命令用来配置标签分配控制方式。undo label-distribution命令用来恢复缺省情况。
缺省情况下,标签分配控制方式为有序方式(ordered)。
需要注意的是,会话建立后,需使用reset mpls ldp命令重启LDP会话,本命令的配置才能生效。
# 配置公网LDP的标签分配控制方式为独立标签分配控制方式。
[Sysname] mpls ldp
[Sysname-mpls-ldp] label-distribution independent
# 配置名为vpn1的LDP实例的标签分配控制方式为独立标签分配控制方式。
[Sysname-mpls-ldp-vpn-instance-vpn1] label-distribution independent
1.1.34  loop-detect
loop-detect
undo loop-detect
【缺省级别】
2:系统级
【描述】
loop-detect命令用来开启环路检测功能。undo loop-detect 命令用来关闭环路检测功能。
缺省情况下,环路检测功能处于关闭状态。
需要在所有接口使能LDP之前进行此配置。
相关配置可参考命令hops-countpath-vectors
# 开启公网LDP的环路检测功能。
[Sysname] mpls ldp
[Sysname-mpls-ldp] loop-detect
# 开启名为vpn1LDP实例的环路检测功能。
[Sysname-mpls-ldp-vpn-instance-vpn1] loop-detect
1.1.35  lsp-trigger
lsp-trigger [ vpn-instance vpn-instance-name ] { all | ip-prefix prefix-name }
undo lsp-trigger [ vpn-instance vpn-instance-name ] { all | ip-prefix prefix-name }
MPLS视图
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:配置指定VPN的LSP触发策略。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
all:所有路由项都会触发LDP建立LSP。
ip-prefix prefix-name:利用IP地址前缀列表对路由项进行过滤,被IP地址前缀列表拒绝的静态路由和IGP路由项不能触发建立LSP。prefix-name表示IP地址前缀列表名,为1~19个字符的字符串。
【描述】
lsp-trigger命令用来配置LSP的触发策略。undo lsp-trigger命令用来恢复缺省情况。
缺省情况下,只有32位掩码的主机路由能够触发LDP建立LSP。
·     IP地址前缀列表只对静态路由和IGP路由有效。
·     LSP的建立需要LSR上有精确匹配的路由项,如果使用32位掩码的Loopback接口,则必须有精确匹配的主机路由才能触发LSP的建立。
·     如果指定vpn-instance vpn-instance-name参数,则配置指定VPN的LSP触发策略;如果未指定vpn-instance vpn-instance-name参数,则配置公网路由的LSP触发策略。
·     有关IP地址前缀列表的介绍请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 配置所有路由项都能够触发LDP建立LSP。
[Sysname] mpls
[Sysname-mpls] lsp-trigger all
1.1.36  lsr-id
lsr-id lsr-id
undo lsr-id
【缺省级别】
2:系统级
lsr-id:LDP的LSR ID。
【描述】
lsr-id命令用来配置LDP的LSR ID。undo lsr-id命令用来删除配置的LSR ID并删除所有LDP会话。
缺省情况下,LDP的LSR ID与MPLS LSR ID相同。
# 配置公网LDP的LSR ID为2.2.2.3。
[Sysname] mpls ldp
[Sysname-mpls-ldp] lsr-id 2.2.2.3
# 配置名为vpn1LDP实例的LSR ID为4.2.2.3。
[Sysname-mpls-ldp-vpn-instance-vpn1] lsr-id 4.2.2.3
1.1.37  md5-password
md5-password { cipher | plain } peer-lsr-id password
undo md5-password peer-lsr-id
【缺省级别】
2:系统级
cipher:以密文形式输入密码,以密文形式显示密码。
plain:以明文形式输入密码,以密文形式显示密码。
peer-lsr-id:对等体的LSR ID。
password:密码字符串,区分大小写。如果采用明文(plain)形式,为1~16个字符的字符串;如果采用密文(cipher)形式,为1~53个字符的密文。
【描述】
md5-password命令来用使能LDP的MD5认证功能。undo md5-password命令用来恢复缺省情况。
缺省情况下,未使能LDP的MD5认证功能。
·     本地配置的密码必须与对等体的配置相同。
·     改变对等体密码会重新创建会话,与原来会话相关的LSP将被删除。
·     只有在相应视图中使能了MPLS LDP后,该命令才会生效。
# 配置公网LDP的MD5认证功能:与对等体3.3.3.3建立LDP会话时进行MD5认证,采用明文形式输入密码,密码为pass。
[Sysname] mpls ldp
[Sysname-mpls-ldp] md5-password plain 3.3.3.3 pass
# 配置名为vpn1的LDP实例的MD5认证功能:与对等体3.3.3.3建立LDP会话时进行MD5认证,采用明文形式输入密码,密码为pass。
[Sysname-mpls-ldp-vpn-instance-vpn1] md5-password plain 3.3.3.3 pass
1.1.38  mpls
mpls
undo mpls
系统视图/接口视图
【缺省级别】
2:系统级
【描述】
·     在系统视图下,mpls命令用来全局使能本节点的MPLS能力,并进入MPLS视图。undo mpls命令用来关闭本节点的MPLS能力。
·     在接口视图下,mpls命令用来使能接口的MPLS能力。undo mpls命令用来关闭接口的MPLS能力。
缺省情况下,未使能本节点和接口的MPLS能力。
·     在使能MPLS能力之前,必须先配置MPLS LSR ID。
·     只有全局使能了本节点的MPLS能力后,才能在接口下使能接口的MPLS能力。
相关配置可参考命令mpls lsr-id
# 使能本节点的MPLS能力,并进入MPLS视图。
<Sysname> System-view
[Sysname] mpls
[Sysname-mpls] quit
# 在接口Vlan-interface1上使能MPLS能力。
[Sysname-Vlan-interface1] mpls
mpls ldp
undo mpls ldp
【缺省级别】
2:系统级
【描述】
mpls ldp命令用来使能本节点的LDP能力,并进入MPLS-LDP视图。undo mpls ldp命令用来关闭LDP能力,并删除所有LDP实例。
缺省情况下,未使能LDP能力。
需要注意的是,配置了MPLS LSR ID并使能本节点的MPLS能力后,才能执行本命令。
# 使能本节点的LDP能力,并进入MPLS-LDP视图。
[Sysname] mpls
[Sysname-mpls] quit
[Sysname] mpls ldp
[Sysname-mpls-ldp]
mpls ldp
undo mpls ldp
【缺省级别】
2:系统级
【描述】
mpls ldp命令用来在接口上使能LDP能力。undo mpls ldp命令用来关闭接口的LDP能力。
缺省情况下,在接口上未使能LDP能力。
使能LDP能力后,接口上将定期发送Hello报文。
在接口视图下使能LDP能力前,需要完成下列操作:
·     在系统视图下使用mpls lsr-id命令设定本节点的LSR ID。
·     在系统视图下使用mpls命令使能MPLS能力。
·     在系统视图下使用mpls ldp命令使能本节点的LDP能力。
·     在接口视图下使用mpls命令使能MPLS能力。
如果接口已与某个VPN实例绑定,则需要使用mpls ldp vpn-instance命令在此VPN上使能LDP能力。mpls ldp vpn-instance命令的详细介绍,请参见“MPLS命令参考”中的“MPLS L3VPN”。
# 在接口Vlan-interface1上使能LDP能力。
[Sysname-Vlan-interface1] mpls ldp
mpls ldp remote-peer remote-peer-name
undo mpls ldp remote-peer remote-peer-name
【缺省级别】
2:系统级
remote-peer-name:远端对等体名称,为1~32个字符的字符串,不区分大小写。
【描述】
mpls ldp remote-peer命令用来创建远端对等体实体并进入MPLS-LDP远端对等体视图。undo mpls ldp remote-peer命令用来删除远端对等体实体。
相关配置可参考命令remote-ip
# 创建远端对等体实体BJI,并进入MPLS-LDP远端对等体视图。
[Sysname] mpls ldp remote-peer BJI
[Sysname-mpls-ldp-remote-bji]
mpls ldp timer hello-hold value
undo mpls ldp timer hello-hold
接口视图/MPLS-LDP远端对等体视图
【缺省级别】
2:系统级
value:Hello保持定时器的值,取值范围为1~65535,单位为秒。
【描述】
mpls ldp timer hello-hold命令用来配置Hello保持定时器的值。undo mpls ldp timer hello-hold命令用来恢复缺省情况。
接口视图下配置的是链路Hello保持定时器的值,MPLS-LDP远端对等体视图下配置的是目标Hello保持定时器的值。
缺省情况下,链路Hello保持定时器的值为15秒,目标Hello保持定时器的值为45秒。
需要注意的是,修改Hello保持定时器的值不会影响已经存在的会话。
相关配置可参考命令mpls ldp(System view)和mpls ldp(Interface view)。
# 在接口Vlan-interface1上为本地会话配置链路Hello保持定时器的值为100秒。
[Sysname-Vlan-interface1] mpls ldp timer hello-hold 100
# 为远端会话配置目标Hello保持定时器的值为1000秒。
[Sysname-mpls-ldp-remote-bji] remote-ip 3.3.3.3
[Sysname-mpls-ldp-remote-bji] mpls ldp timer hello-hold 1000
mpls ldp timer keepalive-hold value
undo mpls ldp timer keepalive-hold
【缺省级别】
2:系统级
value:Keepalive保持定时器的值,取值范围为1~65535,单位为秒。
【描述】
mpls ldp timer keepalive-hold命令用来配置Keepalive保持定时器的值。undo mpls ldp timer keepalive-hold命令用来恢复缺省情况。
接口视图下配置的是链路Keepalive保持定时器的值,MPLS-LDP远端对等体视图下配置的是目标Keepalive保持定时器的值。
缺省情况下,Keepalive保持定时器的值为45秒。
·     如果两个LSR之间使能LDP的链路条数超过1条(多个接口相连),所有链路的Keepalive保持时间必须相同,否则,会话可能不稳定。
·     修改Keepalive保持定时器的值会引起重新创建原始会话。基于此会话建立的LSP也将被删除重建。
# 在接口Vlan-interface1上为本地会话配置链路Keepalive保持定时器的值为50秒。
[Sysname-Vlan-interface1] mpls ldp timer keepalive-hold 50
# 为远端会话配置目标Keepalive保持定时器的值为1000秒。
[Sysname-mpls-ldp-remote-bji] mpls ldp timer keepalive-hold 1000
接口视图下:
mpls ldp transport-address { ip-address | interface }
undo mpls ldp transport-address
MPLS-LDP远端对等体视图下:
mpls ldp transport-address ip-address
【缺省级别】
2:系统级
ip-address:LDP使用此地址作为LDP传输地址。
interface:LDP使用当前接口的IP地址作为LDP传输地址。
【描述】
mpls ldp transport-address命令用来配置LDP传输地址。undo mpls ldp transport-address命令用来恢复缺省情况。
缺省情况下,传输地址为本LSR的LSR ID。
·     在接口视图下,mpls ldp transport-address命令用于配置链路Hello的传输地址。
·     MPLS-LDP远端对等体视图下,mpls ldp transport-address命令用于配置目标Hello的传输地址。
# 在接口Vlan-interface1上为本地会话配置链路Hello的传输地址为本接口的IP地址。
[Sysname-Vlan-interface1] mpls ldp transport-address interface
# 为远端会话配置目标Hello的传输地址为10.1.1.1。
[Sysname-mpls-ldp-remote-bji] mpls ldp transport-address 10.1.1.1
1.1.45  mpls lspv
mpls lspv
undo mpls lspv
【缺省级别】
2:系统级
【描述】
mpls lspv命令用来使能LSP检测功能,并进入MPLS-LSPV视图。undo mpls lspv命令用来关闭LSP检测功能。
缺省情况下,未使能LSP检测功能。
# 使能LSP检测功能,并进入MPLS-LSPV视图。
[Sysname] mpls lspv
[Sysname-mpls-lspv]
1.1.46  mpls lsr-id
mpls lsr-id lsr-id
undo mpls lsr-id
【缺省级别】
2:系统级
lsr-id:LSR的ID,点分十进制格式,用于标识一个LSR。
【描述】
mpls lsr-id命令用来配置本节点的LSR ID。undo mpls lsr-id命令用来删除LSR的ID。
缺省情况下,未配置LSR ID。
配置LSR ID是配置其它MPLS命令的前提。推荐使用LSR某个Loopback接口的地址作为LSR ID。
相关配置可参考命令display mpls interface
# 配置LSR的ID为3.3.3.3。
[Sysname] mpls lsr-id 3.3.3.3
1.1.47  mpls mtu
mpls mtu value
undo mpls mtu
【缺省级别】
2:系统级
value:接口的MPLS MTU值,取值范围为46~65535。
【描述】
mpls mtu命令用来配置接口的MPLS MTU值。undo mpls mtu命令用来恢复缺省情况。
缺省情况下,未配置接口的MPLS MTU值,此时根据接口的MTU值进行分片,分片的长度不包含MPLS标签栈的长度,为分片添加MPLS标签栈后MPLS报文的长度可能会大于接口MTU的值。
·     只有在接口上使能MPLS功能后,该命令才会生效。
·     配置的MPLS MTU值大于接口MTU时,有可能导致数据转发失败。
·     TE隧道接口不支持本命令。
# 配置VLAN接口2的MPLS MTU值为1000。
[Sysname] mpls
[Sysname-mpls] quit
[Sysname-Vlan-interface2] mpls
[Sysname-Vlan-interface2] mpls mtu 1000
1.1.48  path-vectors
path-vectors pv-number
undo path-vectors
【缺省级别】
2:系统级
pv-number:路径向量方式下LSP的最大跳数,取值范围为1~32。
【描述】
path-vectors命令用来配置路径向量方式下LSP的最大跳数。undo path-vectors命令用来恢复缺省情况。
缺省情况下,路径向量方式下LSP的最大跳数为32。
此命令应该在所有接口使能LDP之前配置。
相关配置可参考命令loop-detecthops-count
# 设置公网LDP路径向量方式下LSP的最大跳数为3。
[Sysname] mpls ldp
[Sysname-mpls-ldp] path-vectors 3
# 设置名为vpn1的LDP实例路径向量的LSP最大跳数为3。
[Sysname-mpls-ldp-vpn-instance-vpn1] path-vectors 3
periodic-tracert destination-address mask-length [ -a source-ip | -exp exp-value | -h ttl-value | -m wait-time | -t time-out | -u retry-attempt ] *
undo periodic-tracert destination-address mask-length
MPLS-LSPV视图
【缺省级别】
2:系统级
destination-address:与FEC对应的目的IP地址。
mask-length:与FEC对应的目的IP地址的掩码长度,取值范围为0~32。
-a source-ip:指定MPLS Echo Request报文的源地址,缺省使用MPLS LSR-ID作为MPLS Echo Request报文的源地址。
-exp exp-value:指定标签的Exp值。exp-value取值范围为0~7,缺省值为0。
-h ttl-value:指定MPLS Echo Request报文携带的TTL值。ttl-value取值范围为1~255,缺省值为30。
-m wait-time:指定LSP Tracert功能的检测周期。wait-time取值范围为15~120,单位为分钟,缺省值为60分钟。
-t time-out:指定发送出MPLS Echo Request报文后等待响应的超时时间。time-out取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。
-u retry-attempt:指定MPLS Echo Request报文超时重试的次数。retry-attempt取值范围为1~9,单位为次数,缺省值为3次。
【描述】
periodic-tracert命令用来使能指定FEC的周期性LSP Tracert功能。undo periodic-tracert命令用来取消指定FEC的周期性LSP Tracert功能。
缺省情况下,未使能指定FEC的周期性LSP Tracert功能。
周期性LSP Tracert功能,即周期性地对LSP进行Tracert检测,该功能用来对LSP的错误进行定位,对转发平面和控制平面一致性进行检测,并通过日志记录检测结果。管理员可以通过查看日志信息,了解LSP是否出现故障。
如果同时配置了BFD检测LSP功能和周期性LSP Tracert功能,则周期性LSP Tracert检测到转发平面故障或转发平面与控制平面不一致时,会触发删除原有BFD会话,并基于控制平面重新建立BFD会话。
# 使用周期性LSP Tracert功能,检测到达目的地1.1.1.9/32的LSP的有效性,并检查转发平面与控制平面是否一致。
[Sysname] mpls lspv
[Sysname-mpls-lspv] periodic-tracert 1.1.1.9 32
ping lsp [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -s packet-size | -t time-out | -v ] * ipv4 dest-addr mask-length [ destination-ip-addr-header ]
【缺省级别】
0:访问级
-a source-ip:指定发送的Echo Request报文的源地址。source-ip为源IP地址。
-c count:指定发送Echo Request报文的次数。count为Echo Request报文发送次数,取值范围为1~4294967295,缺省值为5。
-exp exp-value:指定Echo Request报文中的EXP值。exp-value为EXP值,取值范围为0~7,缺省值为0。
-h ttl-value:指定Echo Request报文中的TTL值。ttl-value为TTL值,取值范围为1~255,缺省值为255。
-m wait-time:指定连续发送Echo Request报文的时间间隔。wait-time为发送报文的时间间隔,取值范围为1~10000,单位为毫秒,缺省值为200毫秒。
-r reply-mode:指定接收者对Echo Request报文的应答模式。reply-mode为应答模式,取值范围为1和2,1表示不回应,2表示使用UDP报文回应,缺省值为2。
-s packet-size:指定Echo Request报文的净荷报文长度。packet-size为净荷报文长度,取值范围为65~8100,单位为字节,缺省值为100字节。
-t time-out:指定发送Echo Request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。
-v:指定显示详细的应答信息。
ipv4 dest-addr mask-length:检测指定LSP的可达性。dest-addr为FEC的目的地址,mask-length为FEC目的地址的掩码,取值范围为0~32。
destination-ip-addr-header:指定Echo Request报文中IP头的目的地址,该地址必须是127.0.0.0/8网段的地址(本机环回地址)。
【描述】
ping lsp ipv4命令用来检测MPLS LSP的可达性。
# 检测到达3.3.3.9/32LSP的可达性。
<Sysname> ping lsp ipv4 3.3.3.9 32
LSP Ping FEC: IPV4 PREFIX 3.3.3.9/32 : 100  data bytes, press CTRL_C to break
    Reply from 100.1.2.1: bytes=100 Sequence=0 time = 31 ms
    Reply from 100.1.2.1: bytes=100 Sequence=1 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=2 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=3 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=4 time = 62 ms
  --- FEC: IPV4 PREFIX 3.3.3.9/32 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 31/55/62 ms
undo prefix-label advertise
MPLS-LDP远端对等体视图
【缺省级别】
2:系统级
【描述】
prefix-label advertise命令用来配置通过远端会话通告基于地址前缀的标签。undo prefix-label advertise命令用来恢复缺省情况。
缺省情况下,不会通过远端会话通告基于地址前缀的标签。
本命令的配置只决定设备是否可以通过远端会话向远端对等体通告基于地址前缀的标签。不论是否配置了通过远端会话通告基于地址前缀的标签,设备都可以接收远端对等体通告的标签。
接收到远端对等体通告的标签后,要想建立对应的LDP LSP,必须满足以下三个条件:
·     FEC的路由出接口为MPLS TE隧道接口。
·     MPLS TE隧道的目的地址、通过remote-ip命令指定的远端对等体地址、远端对等体的LSR ID,三者必须相同。
·     MPLS TE隧道接口必须使能MPLS能力。
# 配置通过远端会话通告基于地址前缀的标签。
[Sysname] mpls ldp remote-peer bji
[Sysname-mpls-ldp-remote-bji] prefix-label advertise
1.1.52  remote-ip
remote-ip ip-address
undo remote-ip
MPLS-LDP远端对等体视图
【缺省级别】
2:系统级
ip-address:远端对等体的IP地址。
【描述】
remote-ip命令用来指定LDP远端对等体的IP地址。undo remote-ip命令用来删除配置。
远端对等体的IP地址应该为远端LSR的LSR ID。两个远端对等体使用LSR ID作为传输地址建立TCP连接。
相关配置可参考命令mpls ldp remote-peer
# 配置远端对等体的地址为3.3.3.3。
remote-ip bfd
undo remote-ip bfd
MPLS-LDP远端对等体视图
【缺省级别】
2:系统级
【描述】
remote-ip bfd命令用来为LDP远端对等体开启BFD链路检测功能。undo remote-ip bfd命令用来恢复缺省情况。
缺省情况下,LDP远端对等体的BFD链路检测功能处于关闭状态。
# 为远端对等体bji开启BFD链路检测功能。
[Sysname-mpls-ldp-remote-bji] remote-ip bfd
reset mpls ldp [ all | [ vpn-instance vpn-instance-name ] [ fec mask | peer peer-id ] ]
【缺省级别】
1:监控级
all:重启所有LDP实例的会话,包括公网LDP实例和私网LDP实例。
vpn-instance vpn-instance-name:重启指定LDP实例的会话。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
fec mask:重启指定FEC的LDP会话。fec为FEC的目的IP地址,mask为目的IP地址的掩码。
peer peer-id:重启与指定对等体之间的LDP会话。peer-id为对等体的LSR ID。
【描述】
reset mpls ldp命令用来重启LDP会话。
没有指定任何参数时,该命令用来重启所有公网LDP实例的会话。
# 重启所有公网LDP实例的会话。
<Sysname> reset mpls ldp
# 重启所有LDP实例的会话。
<Sysname> reset mpls ldp all
# 重启指定LDP实例的会话。
<Sysname> reset mpls ldp vpn-instance vpn1
# 重启指定FEC的会话。
<Sysname> reset mpls ldp 2.2.2.2 24
# 重启与指定对等体之间的LDP会话。
<Sysname> reset mpls ldp peer 2.2.2.9
reset mpls statistics interface { interface-type interface-number | all }
【缺省级别】
1:监控级
interface-type interface-number:清除指定接口的统计信息。interface-type interface-number为接口类型和接口编号。
all:清除所有接口的统计信息。
【描述】
reset mpls statistics interface命令用来清除已使能MPLS功能的接口的统计信息。
# 清除已使能MPLS的接口Vlan-interface1的统计信息。
<Sysname> reset mpls statistics interface vlan-interface 1
reset mpls statistics lsp { index | all | name lsp-name }
【缺省级别】
1:监控级
index:清除指定LSP索引号对应的LSP统计信息。index为LSP的索引号,取值范围为0~4294967295。
all:清除所有LSP的统计信息。
name lsp-name:清除指定LSP名称对应的LSP统计信息。lsp-name表示LSP的名称,为1~15个字符的字符串。
【描述】
reset mpls statistics lsp命令用来清除LSP的统计信息。
相关配置可参考命令display mpls statistics lsp
# 清除名为lsp1的LSP统计信息。
<Sysname> reset mpls statistics lsp name lsp1
static-lsp egress lsp-name incoming-interface interface-type interface-number in-label in-label
undo static-lsp egress lsp-name
【缺省级别】
2:系统级
lsp-name:标签转发路径名称,为1~15个字符的字符串。
incoming-interface interface-type interface-number:指定入接口的接口类型和接口编号。
in-label in-label:指定入标签值,in-label取值范围为0,3,16~1023。
【描述】
static-lsp egress命令用来为Egress节点配置静态LSP。undo static-lsp egress命令用来为Egress节点删除一条静态LSP。
相关配置可参考命令static-lsp ingressstatic-lsp transitdisplay mpls static-lsp
# 在Egress节点上配置一条名为bj-sh的静态LSP,入接口为GigabitEthernet2/0/1,入标签为233。
[Sysname] static-lsp egress bj-sh incoming-interface GigabitEthernet 2/0/1 in-label 233
static-lsp ingress lsp-name destination dest-addr { mask | mask-length } { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label
undo static-lsp ingress lsp-name
【缺省级别】
2:系统级
destination dest-addr:指定LSP的目的IP地址。
mask:目的IP地址掩码。
mask-length:目的IP地址掩码长度,取值范围为032
nexthop next-hop-addr:指定下一跳地址。
outgoing-interface interface-type interface-number:指定出接口的接口类型和接口编号。
out-label out-label:指定出标签值,out-label取值范围为0,3,16~1023。
【描述】
static-lsp ingress命令用来为Ingress节点配置静态LSP。undo static-lsp ingress命令用来为Ingress节点删除一条静态LSP。
·     配置静态LSP时,指定的下一跳或出接口必须与路由表中最优下一跳或出接口保持一致。如果是通过静态路由配置路由信息,则静态路由必须与静态LSP指定的下一跳或出接口一致。
·     本地设备上接口的公网IP地址不能被指定为下一跳。
相关配置可参考命令static-lsp egressstatic-lsp transitdisplay mpls static-lsp
# 为Ingress节点配置一条到目的地址202.25.38.1/24的静态LSP,LSP的名称为bj-sh,下一跳地址为202.55.25.33,出标签为237。
[Sysname] static-lsp ingress bj-sh destination 202.25.38.1 24 nexthop 202.55.25.33 out-label 237
static-lsp transit lsp-name incoming-interface interface-type interface-number in-label in-label { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label
undo static-lsp transit lsp-name
【缺省级别】
2:系统级
in-label in-label:指定入标签值,in-label取值范围为16~1023。
【描述】
static-lsp transit命令用来为Transit节点配置静态LSP。undo static-lsp transit命令用来为Transit节点删除一条静态LSP。
相关配置可参考命令static-lsp egressstatic-lsp ingress
需要注意的是,本地设备上接口的公网IP地址不能被指定为下一跳。
# 为Transit节点配置一条名为bj-sh的静态LSP,入接口为GigabitEthernet2/0/1,入标签为123,下一跳地址为202.34.114.7,出标签为253。
[Sysname] static-lsp transit bj-sh incoming-interface GigabitEthernet 2/0/1 in-label 123 nexthop 202.34.114.7 out-label 253
statistics interval interval-time
undo statistics interval
MPLS视图
【缺省级别】
2:系统级
interval-time:统计的时间间隔,取值范围为30~65535,单位为秒。
【描述】
statistics interval命令用来配置获取LSP统计数据的时间间隔。undo statistics interval命令用来恢复缺省情况。
缺省情况下,获取LSP统计数据的时间间隔为0秒,即不获取统计信息。
相关配置可参考命令display mpls statistics interfacedisplay mpls statistics lsp
# 配置获取LSP统计数据的时间间隔为30秒。
[Sysname] mpls
[Sysname-mpls] statistics interval 30
tracert lsp [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -t time-out ] * ipv4 dest-addr mask-length [ destination-ip-addr-header ]
【缺省级别】
0:访问级
-a source-ip:指定Echo Request报文的源地址。source-ip为源IP地址。
-h ttl-value:指定Echo Request报文中的TTL值。ttl-value为TTL值,取值范围为1~255,缺省值为30。
-t time-out:指定发送出Echo Request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。
ipv4 dest-addr mask-length:对指定LSP的错误进行定位。dest-addr为FEC的目的地址,mask-length为FEC目的地址的掩码,取值范围为0~32。
【描述】
tracert lsp ipv4命令用来对MPLS LSP的错误进行定位。
# 对到达目的地址3.3.3.9/32的LSP的错误进行定位。
<Sysname> tracert lsp ipv4 3.3.3.9 32
LSP Trace Route FEC: LDP IPV4 PREFIX 3.3.3.9/32 , press CTRL_C to break.
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   10.4.5.1/[1025]
  1     10.4.5.1           1       Transit   100.3.4.1/[1024]
  2     100.1.4.2          63      Transit   100.1.2.1/[3]
  3     100.1.2.1          129     Egress
undo ttl expiration enable
MPLS视图
【缺省级别】
2:系统级
【描述】
ttl expiration enable命令用来使能MPLS的TTL超时消息发送功能。undo ttl expiration enable命令用来关闭MPLS的TTL超时消息发送功能。
缺省情况下,MPLS的TTL超时消息发送功能处于开启状态。
相关配置可参考命令ttl expiration pop
#关闭MPLS的TTL超时消息发送功能。
[Sysname] mpls
[Sysname-mpls] undo ttl expiration enable
ttl expiration pop
undo ttl expiration pop
MPLS视图
【缺省级别】
2:系统级
【描述】
ttl expiration pop命令用来配置仅有一层标签的MPLS报文TTL超时时,沿本地IP路由返回ICMP报文。undo ttl expiration pop命令用来配置仅有一层标签的MPLS报文TTL超时时,沿LSP返回ICMP报文。
缺省情况下,对于一层标签的MPLS报文,TTL超时时沿本地IP路由返回ICMP差错报文。
多层标签的MPLS报文不受该命令控制,当MPLS报文的TTL超时时,始终沿LSP路径转发ICMP差错报文。
相关配置可参考命令ttl propagate
# 配置仅有一层标签的MPLS报文TTL超时时,沿LSP返回ICMP报文。
[Sysname] mpls
[Sysname-mpls] undo ttl expiration pop
ttl propagate { public | vpn }
undo ttl propagate { public | vpn }
MPLS视图
【缺省级别】
2:系统级
public:对公网报文进行设置。
vpn:对VPN报文进行设置。
【描述】
ttl propagate命令用来使能MPLS的IP TTL复制功能。undo ttl propagate命令用来禁止MPLS的IP TTL复制功能。
缺省情况下,只对公网报文使能MPLS的IP TTL复制功能。
# 使能VPN报文的MPLS IP TTL复制功能。
[Sysname] mpls
[Sysname-mpls] ttl propagate vpn
