06-三层技术-IP路由配置指导
16-MTR配置
本章节下载  (116.65 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/SR_Router/SR6600/Configure/Operation_Manual/H3C_SR6600_SR6600-X_CG-R3302(V1.20)/06/201401/814817_30005_0.htm
16-MTR配置
 录
1 MTR··············································································································································· 1-1
1.1 MTR概述································································································································ 1-1
1.1.1 MTR简介······················································································································ 1-1
1.1.2 MTR工作机制················································································································ 1-1
1.1.3 MTR支持的应用············································································································· 1-1
1.2 配置MTR································································································································ 1-2
1.3 MTR显示和维护······················································································································ 1-2
1 MTR
1.1  MTR概述
1.1.1  MTR简介
MTR(Multi-Topology Routing,多拓扑路由)是指将一个物理拓扑划分成多个逻辑的拓扑,这些逻辑的拓扑可能是交叉或者重叠的。不同拓扑运行各自的路由计算,实现网络的互通。
例如,IS-IS MTR就是指在一个IS-IS自治域内运行多个独立的IP拓扑,例如IPv4拓扑和IPv6拓扑,而不是将它们视为一个集成的单一拓扑。这有利于IS-IS在路由计算中根据实际组网情况来单独考虑IPv4和IPv6网络。
1.1.2  MTR工作机制
图1-1 MTR工作机制
图1-1所示,可以根据需要对全局拓扑进行划分,分为多个子拓扑,这样不同的流量就可以走不同的拓扑。例如,语音流可以走子拓扑A,视频流可以走子拓扑B。
对于子拓扑A而言,Router B并不存在;而对于子拓扑B而言,它认为Router A和Router D之间,以及Router B和Router C之间并没有可用的链路相连。每一个单独的拓扑都根据路由协议计算出自己的路由,属于本拓扑的流量则根据本拓扑的路由表进行转发。
1.1.3  MTR支持的应用
·     IS-IS MTR:详细情况请参见“三层技术-IP路由配置指导”中的“IS-IS”和“IPv6 IS-IS”。
·     静态路由支持MTR:详细情况请参见“三层技术-IP路由配置指导”中的“静态路由”。
1.2  配置MTR
表1-1 配置MTR
进入拓扑地址族视图
address-family ipv4
创建拓扑,并进入拓扑视图
multiple-topology topology-name
缺省情况下,没有创建任何拓扑
配置拓扑的访问控制列表号
acl acl-number
配置拓扑支持的最大路由数
退回系统视图
进入接口视图
将接口与指定拓扑进行关联
multiple-topology topology-name enable
缺省情况下,接口不关联到任何拓扑
1.3  MTR显示和维护
在完成上述配置后,在任意视图下执行display命令可以显示配置后MTR的运行情况,用户可以通过查看显示信息验证配置的效果。
表1-2 MTR显示和维护
显示拓扑信息
display multiple-topology [ multiple-topology-name ] [ | { begin | exclude | include } regular-expression ]
