国家 / 地区
06-三层技术-IP业务配置指导
15-IPv6快速转发配置
本章节下载  (145.32 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/MSR/MSR_50/Configure/Operation_Manual/H3C_MSR_CG(V5)-R2311-V1.12/06/201305/783881_30005_0.htm
15-IPv6快速转发配置
  录
1 IPv6快速转发································································································································· 1-1
1.1 IPv6快速转发简介··················································································································· 1-1
1.2 配置IPv6快速转发··················································································································· 1-1
1.2.1 配置准备······················································································································· 1-1
1.2.2 配置IPv6快速转发········································································································· 1-1
1.3 IPv6快速转发显示和维护·········································································································· 1-2
1.4 IPv6快速转发典型配置举例······································································································ 1-2
1.4.1 IPv6快速转发典型配置举例····························································································· 1-2
1 IPv6快速转发
1.1  IPv6快速转发简介
报文转发效率是衡量设备性能的一项关键指标。按照常规流程,设备收到一个报文后,根据报文的目的地址寻找路由表中与之匹配的路由,然后确定一条最佳的路径,同时还将报文按照数据链路层上使用的协议进行封装,最后进行报文转发。
快速转发是采用高速缓存来处理报文,采用了基于数据流的技术。Internet上的数据基本上都是基于数据流的,一条数据流的传输就是指在两台主机之间的一次特定的应用,比如FTP传输文件的一次操作。
IPv6快速转发使用5元组(源IPv6地址、目的IPv6地址、源端口号、目的端口号和协议号)来标识一条数据流。当一条数据流的第一个报文通过查找路由表转发后,相应的转发信息将被记录到高速缓存中的快速转发表中,该数据流后续报文就可以通过直接查找快速转发表进行转发。这样便大大缩减了IPv6报文的排队流程,减少报文的转发时间,提高IPv6报文的转发效率。
·       系统支持在设备的各个高速链路接口上提供IPv6快速转发功能,高速链路包括以太网、同步PPP、HDLC。
·       不支持在PPP MP链路上提供IPv6快速转发功能,不支持在配置了压缩等业务的PPP链路上提供IPv6快速转发功能。
·       不支持在6PE和隧道上提供IPv6快速转发功能。
1.2  配置IPv6快速转发
1.2.1  配置准备
在进行IPv6快速转发的相关配置以前,必须先使能IPv6。否则即使在接口上配置了IPv6快速转发功能,仍无法快速转发IPv6报文。
1.2.2  配置IPv6快速转发
表1-1 配置IPv6快速转发
进入接口视图
允许接口在入方向和/或出方向进行IPv6快速转发
ipv6 fast-forwarding [ inbound | outbound ]
缺省情况下,允许接口在出入两个方向都进行IPv6快速转发
·       如果要对IPv6报文转发使用基于报文的负载分担,则必须在相应方向上禁止接口进行IPv6快速转发。
·       在接口上配置了IPv6快速转发后,该接口上的IPv6报文调试信息将不再输出,即debugging ipv6 packet命令不起作用了。
·       对单条IPv6数据流而言,只有在该数据流进设备的接口上使能入方向IPv6快速转发功能,同时在出设备的接口上使能出方向IPv6快速转发功能,才能实现该数据流的IPv6快速转发功能。
1.3  IPv6快速转发显示和维护
在完成上述配置后,在任意视图下执行display命令可以显示IPv6快速转发配置后的运行情况,通过查看显示信息验证配置的效果。
在用户视图下执行reset命令可以清除IPv6快速转发表中的内容。
表1-2  IPv6快速转发显示和维护
显示IPv6快速转发表信息
display ipv6 fast-forwarding cache [ ipv6-address | verbose ] [ | { begin | exclude | include } regular-expression ]
清除IPv6快速转发表中的内容
reset ipv6 fast-forwarding cache
1.4  IPv6快速转发典型配置举例
在各设备上实现IPv6快速转发。
图1-1 配置IPv6快速转发组网图
(1)      配置Router A
# 使能IPv6,配置接口的IPv6地址。缺省情况下,允许接口Ethernet1/1在出入两个方向都进行IPv6快速转发。
[RouterA] ipv6
[RouterA] interface ethernet 1/1
[RouterA-Ethernet1/1] ipv6 address 2002::1 64
[RouterA-Ethernet1/1] quit
# 配置静态路由。
[RouterA] ipv6 route-static 2001:: 64 2002::2
(2)      配置Router C
# 使能IPv6,配置接口的IPv6地址。缺省情况下,允许接口Serial2/1在出入两个方向都进行IPv6快速转发。
<RouterC> system-view
[RouterC] ipv6
[RouterC] interface serial 2/1
[RouterC-Serial2/1] ipv6 address 2001::1 64
[RouterC-Serial2/1] quit
# 配置静态路由。
[RouterC] ipv6 route-static 2002:: 64 serial 2/1
(3)      配置Router B
# 使能IPv6,配置接口的IPv6地址。缺省情况下,允许接口Ethernet1/1和Serial2/1在出入两个方向都进行IPv6快速转发。
<RouterB> system-view
[RouterB] ipv6
[RouterB] interface ethernet 1/1
[RouterB-Ethernet1/1] ipv6 address 2002::2 64
[RouterB-Ethernet1/1] quit
[RouterB] interface serial 2/1
[RouterB-Serial2/1] ipv6 address 2001::2 64
[RouterB-Serial2/1] quit
(4)      检验配置结果
# 在Router B查看IPv6快速转发表,这时未建立快转表项,结果如下:
[RouterB] display ipv6 fast-forwarding cache
[RouterB]
# 从Router A上ping Router C的Serial2/1接口IPv6地址,能正确收到应答报文。
[RouterA] ping ipv6 2001::1
  PING 2001::1 : 56  data bytes, press CTRL_C to break
    Reply from 2001::1
    bytes=56 Sequence=1 hop limit=64  time = 69 ms
    Reply from 2001::1
    bytes=56 Sequence=2 hop limit=64  time = 1 ms
    Reply from 2001::1
    bytes=56 Sequence=3 hop limit=64  time = 1 ms
    Reply from 2001::1
    bytes=56 Sequence=4 hop limit=64  time = 1 ms
    Reply from 2001::1
    bytes=56 Sequence=5 hop limit=64  time = 1 ms
  --- 2001::1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 1/14/69 ms
# 在Router B查看快速转发表,已建立快转表项,显示信息如下:
IPv6 Fast-Forwarding cache:  total 2 item(s)
Index: 224[0]
  SIP: 2002::1                                 SPort: 129
  DIP: 2001::1                                 DPort: 0
  Pro: 58                                      Flg: 256
  Input interface: Eth1/1
  Output interface: S2/1
Index: 234[0]
  SIP: 2001::1                                 SPort: 128
  DIP: 2002::1                                 DPort: 0
  Pro: 58                                      Flg: 256
  Input interface: S2/1
  Output interface: Eth1/1
联系我们 联系我们
回到顶部 回到顶部
