选择区域语言: EN CN HK
08-IP组播配置指导
06-MSDP配置
本章节下载  (582.75 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/MSR/MSR_50/Configure/Operation_Manual/H3C_MSR_CG-R2207(V1.11)/08/201212/768447_30005_0.htm
06-MSDP配置
1 MSDP配置...................................................................................................................................... 1-1
1.1 MSDP简介.............................................................................................................................. 1-1
1.1.1 MSDP概述.................................................................................................................... 1-1
1.1.2 MSDP原理.................................................................................................................... 1-1
1.1.3 多实例的MSDP............................................................................................................. 1-6
1.1.4 协议规范........................................................................................................................ 1-6
1.2 MSDP配置任务简介................................................................................................................. 1-7
1.3 配置MSDP基本功能................................................................................................................ 1-7
1.3.1 配置准备........................................................................................................................ 1-7
1.3.2 使能MSDP.................................................................................................................... 1-7
1.3.3 创建MSDP对等体连接................................................................................................... 1-8
1.3.4 配置静态RPF对等体...................................................................................................... 1-9
1.4 配置MSDP对等体连接............................................................................................................. 1-9
1.4.1 配置准备........................................................................................................................ 1-9
1.4.2 配置MSDP对等体描述信息........................................................................................... 1-10
1.4.3 配置MSDP全连接组.................................................................................................... 1-10
1.4.4 配置MSDP对等体连接控制........................................................................................... 1-11
1.5 配置SA消息.......................................................................................................................... 1-11
1.5.1 配置准备...................................................................................................................... 1-11
1.5.2 配置SA消息内容......................................................................................................... 1-12
1.5.3 配置SA请求消息......................................................................................................... 1-12
1.5.4 配置SA消息过滤规则................................................................................................... 1-13
1.5.5 配置SA消息缓存......................................................................................................... 1-14
1.6 MSDP显示和维护.................................................................................................................. 1-14
1.7 MSDP典型配置举例............................................................................................................... 1-15
1.7.1 PIM-SM域间组播配置举例............................................................................................ 1-15
1.7.2 借助静态RPF对等体的AS间组播配置举例.................................................................... 1-20
1.7.3 Anycast RP应用配置举例............................................................................................. 1-24
1.7.4 SA消息过滤机制配置举例............................................................................................. 1-29
1.8 常见配置错误举例................................................................................................................... 1-32
1.8.1 MSDP对等体一直处于down状态.................................................................................. 1-32
1.8.2 路由器SA缓存中没有SA表项...................................................................................... 1-33
1.8.3 Anycast RP应用中RP间互通信息异常.......................................................................... 1-33
1 MSDP配置
本文中所提到的DR(Designated Router,指定路由器)、BSR(BootStrap Router,自举路由器)、C-BSR(Candidate-BSR,候选BSR)、RP(Rendezvous Point,汇集点)、C-RP(Candidate RP,候选RP)、SPT(Shortest Path Tree,最短路径树)和RPT(Rendezvous Point Tree,共享树或汇集树)等概念的详细介绍,请参见“IP组播配置指导”中的“PIM”。
1.1  MSDP简介
1.1.1  MSDP概述
MSDP是Multicast Source Discovery Protocol(组播源发现协议)的简称,是为了解决多个PIM-SM(Protocol Independent Multicast Sparse Mode,协议无关组播—稀疏模式)域之间的互连而开发的一种域间组播解决方案,用来发现其它PIM-SM域内的组播源信息。
在基本的PIM-SM模式下,组播源只向本PIM-SM域内的RP注册,且各域的组播源信息是相互隔离的,因此RP仅知道本域内的组播源信息,只能在本域内建立组播分发树,将本域内组播源发出的组播数据分发给本地用户。如果能够有一种机制,将其它域内的组播源信息传递给本域内的RP,则本域内的RP就可以向其它域内的组播源发起加入过程并建立组播分发树,从而实现组播数据的跨域传输。
基于这一设想,MSDP通过在网络中选取适当的路由器建立MSDP对等体关系,以连通各PIM-SM域的RP。通过在各MSDP对等体之间交互SA(Source Active,信源有效)消息来共享组播源信息。
l          MSDP的适用前提:域内组播路由协议必须是PIM-SM。
l          MSDP仅对ASM(Any-Source Multicast,任意信源组播)模型有意义。
1.1.2  MSDP原理
1. MSDP对等体
通过在网络中配置一对或多对MSDP对等体,形成彼此相连的一张“MSDP连通图”,以连通各个PIM-SM域的RP。通过这些MSDP对等体之间的接力,可以把某RP发出的SA消息传递给其它所有的RP。
图1-1 MSDP对等体的位置
图1-1所示,MSDP对等体可以创建在任意的PIM-SM路由器上,在不同角色的PIM-SM路由器上所创建的MSDP对等体的功能有所不同:
(1)        在RP上创建的MSDP对等体
l              源端MSDP对等体:即离组播源(Source)最近的MSDP对等体(通常也就是源端RP,如RP 1)。源端RP创建SA消息并发送给远端MSDP对等体,通告在本RP上注册的组播源信息。源端MSDP对等体必须配置在RP上,否则将无法向外发布组播源信息。
l              接收者端MSDP对等体:即离接收者(Receiver)最近的MSDP对等体(如RP 3)。接收者端MSDP对等体在收到SA消息后,根据该消息中所包含的组播源信息,跨域加入以该组播源为根的SPT;当来自该组播源的组播数据到达后,再沿RPT向本地接收者转发。
l              中间MSDP对等体:即拥有多个远端MSDP对等体的MSDP对等体(如RP 2)。中间MSDP对等体把从一个远端MSDP对等体收到的SA消息转发给其它远端MSDP对等体,其作用相当于传输组播源信息的中转站。
(2)        在普通的PIM-SM路由器(非RP)上创建的MSDP对等体
如Router A和Router B,其作用仅限于将收到的SA消息转发出去。
对于通过BSR机制动态选举RP的PIM-SM网络来说,RP是由C-RP选举产生的。为了增强其网络的健壮性,一个PIM-SM域内往往存在不止一个C-RP。由于无法预计RP选举的结果,为了保证选举获胜的C-RP能始终位于“MSDP连通图”上,需要在所有的C-RP之间建立MSDP对等体关系。而选举落败的C-RP在“MSDP连通图”上所担当的角色相当于普通的PIM-SM路由器。
2. MSDP实现域间组播
图1-2所示,PIM-SM 1域内存在激活的组播源(Source),RP 1通过组播源注册过程了解到了该组播源的存在。如果PIM-SM 2和PIM-SM 3域也希望知道该组播源的具体位置,进而能够从该组播源获取组播数据,则需要在RP 1与RP 3、RP 2与RP 3之间分别建立MSDP对等体关系。
图1-2 MSDP实现域间组播示意图
借助MSDP对等体进行PIM-SM域间组播的工作过程如下:
(1)        当PIM-SM 1域内的组播源向组播组G发送第一个组播数据包时,DR 1将该组播数据封装在注册消息(Register Message)中,并发给RP 1。RP 1因此获知了该组播源的相关信息。
(2)        RP 1作为源端RP,创建SA消息,并周期性地向其它MSDP对等体发送。SA消息中包含组播源的地址S、组播组的地址G以及创建该SA消息的源端RP(即RP 1)的地址。
(3)        MSDP对等体对收到的SA消息进行RPF(Reverse Path Forwarding,逆向路径转发)检查,以及各种转发策略的过滤,从而只接受和转发来自正确路径并通过过滤的SA消息,以避免SA消息传递环路;另外,可以在MSDP对等体之间配置MSDP全连接组(Mesh Group),以避免SA消息在MSDP对等体之间的泛滥。
(4)        SA消息在MSDP对等体之间转发,最终该组播源的相关信息将传遍所有建立了MSDP对等体关系的PIM-SM域(即PIM-SM 2和PIM-SM 3)。
(5)        PIM-SM 2中的RP 2在收到该SA消息后,检查本域内是否有组播组G的接收者(Receiver)存在:
l              如果有接收者,RP 2与接收者之间维护组播组G的RPT。RP 2创建(S,G)表项,向源端的DR 1逐跳发送(S,G)加入消息(Join Message),从而跨越各PIM-SM域直接加入以该组播源为根的SPT。组播数据沿SPT到达RP 2后,再沿RPT向接收者转发。当接收者端的DR 2收到来自组播源的组播数据后,可以自行决定是否发起从RPT向SPT的切换;
l              如果没有接收者,RP 2不会创建(S,G)表项,也不加入以该组播源为根的SPT。
l          MSDP全连接组:要求所有组成员之间两两建立MSDP对等体关系,且所有组成员均使用相同的组名称。
l          在使用MSDP进行域间组播时,RP在收到组播源的信息后就不再需要依赖其它PIM-SM域内的RP,此时接收者可以跨越各PIM-SM域内的RP,而直接加入基于组播源的SPT。
3. SA消息的RPF检查规则
图1-3所示,网络中有五个自治系统AS 1~AS 5,AS内部使用IGP互联,AS之间使用BGP或MBGP互联。每个AS中包含至少一个PIM-SM域,且每个PIM-SM域中包含至少一个RP。各RP之间建立起MSDP对等体关系,其中RP 3、RP 4和RP 5之间建立MSDP全连接组,并在RP 7上将RP 6配置为其静态RPF对等体。
设备对于来自静态RPF对等体的SA消息不进行RPF检查,直接接受并向其它对等体转发。
图1-3 SA消息的RPF检查规则
对照图1-3,这些MSDP对等体将按照如下RPF检查规则处理收到的SA消息:
(1)        当RP 2收到RP 1发来的SA消息时:由于SA消息中所携带的源端RP的地址与MSDP对等体的地址相同,说明发出SA消息的MSDP对等体就是创建该SA消息的RP,于是RP 2接受该SA消息并向其它对等体(RP 3)转发。
(2)        当RP 3收到RP 2发来的SA消息时:由于SA消息来自同一个AS的MSDP对等体(RP 2),且该对等体是到源端RP最佳路径上的下一跳,于是RP 3接受该SA消息并向其它对等体(RP 4和RP 5)转发。
(3)        当RP 4和RP 5分别收到RP 3发来的SA消息时:由于SA消息来自同一个全连接组的MSDP对等体(RP 3),于是RP 4和RP 5均接受该SA消息并不再向本组其它成员转发,而只向本组之外的其它MSDP对等体(RP 6)转发。
(4)        当RP 6收到RP 4和RP 5(假设RP 5的IP地址较大)发来的SA消息时:尽管同处AS 3的RP 4和RP 5都与RP 6建立了MSDP对等体关系,但RP 6只接受IP地址较高的MSDP对等体(RP 5)发来的SA消息。
(5)        当RP 7收到RP 6发来的SA消息时:由于SA消息来自其静态RPF对等体(RP 6),于是RP 7接受该SA消息并向其它对等体(RP 8)转发。
(6)        当RP 8收到RP 7发来的SA消息时:属于不同AS的MSDP对等体之间存在BGP或MBGP路由。由于SA消息来自不同AS的MSDP对等体(RP 7),且该对等体是到源端RP的BGP或MBGP路由的下一跳,于是RP 8接受该SA消息并向其它对等体(RP 9)转发。
(7)        当RP 9收到RP 8发来的SA消息时:由于只有一个MSDP对等体(RP 8),于是RP 9接受该SA消息。
对于由其它路径到来的SA消息,MSDP对等体将不接受也不转发。
4. MSDP实现域内Anycast RP
Anycast RP(任播RP)是指在同一个PIM-SM域内设置两个或多个具有相同地址的RP,并在这些RP之间建立MSDP对等体关系,以实现域内各RP之间的负载分担和冗余备份。
图1-4所示,在一个PIM-SM域内,组播源(Source)向组播组G发送组播数据,接收者(Receiver)是组播组G的成员。分别在Router A和Router B上配置相同的IP地址(称为Anycast RP地址,通常使用私有地址),同时将这些接口配置为C-RP,并在Router A和Router B之间建立MSDP对等体关系。
通常在设备的逻辑接口(如Loopback接口)上配置Anycast RP地址。
图1-4 MSDP实现域内Anycast RP示意图
Anycast RP的工作过程如下:
(1)        组播源选择距离最近的RP进行注册。如:Source向RP 1注册,注册消息中封装有Source发出的组播数据。当该注册消息到达RP 1后,进行解封装。
(2)        接收者向距离最近的RP发送加入消息,加入以该RP为根的RPT。如:Receiver加入以RP 2为根的RPT。
(3)        RP之间通过发送SA消息,共享注册的组播源信息。如:RP 1创建一个SA消息,发送给RP 2,该SA消息中封装有Source发出的组播数据。当该SA消息到达RP 2后,进行解封装。
(4)        接收者沿RPT收到组播数据后,直接加入以该组播源为根的SPT。如:RP 2沿RPT将组播数据向下转发。当Receiver收到来自Source的组播数据后,直接加入以Source为根的SPT。
Anycast RP的意义如下:
l              RP路径最优:组播源向距离最近的RP进行注册,建立路径最优的SPT;接收者向距离最近的RP发起加入,建立路径最优的RPT。
l              RP间的负载分担:每个RP上只需维护PIM-SM域内的部分源/组信息、转发部分的组播数据,从而实现了RP间的负载分担。
l              RP间的冗余备份:当某RP失效后,原先在该RP上注册或加入的组播源或接收者会自动选择就近的RP进行注册或加入操作,从而实现了RP间的冗余备份。
l          必须为Anycast RP地址配置32位的子网掩码(即255.255.255.255),也即将其配置为一个主机地址。
l          MSDP对等体的地址不能与Anycast RP地址相同。
1.1.3  多实例的MSDP
属于同一实例的组播路由器各接口之间可以建立MSDP对等体。通过在MSDP对等体之间交互SA消息,可以实现跨域的VPN组播。
应用多实例的组播路由器,为其所支持的每一个实例都独立维护了一套MSDP机制,包括:SA缓存、对等体连接、定时器、发送缓存和PIM交互的缓冲区。同时,保证不同实例之间信息隔离。所以,只有属于同一实例的MSDP和PIM-SM信息才可以交互。
1.1.4  协议规范
与MSDP相关的协议规范有:
l              RFC 3618:Multicast Source Discovery Protocol (MSDP)
l              RFC 3446:Anycast Rendevous Point (RP) mechanism using Protocol Independent Multicast (PIM) and Multicast Source Discovery Protocol (MSDP)
1.2  MSDP配置任务简介
表1-1 MSDP配置任务简介
配置任务
详细配置
配置MSDP基本功能
使能MSDP
1.3.2
创建MSDP对等体连接
1.3.3
配置静态RPF对等体
1.3.4
配置MSDP对等体连接
配置MSDP对等体描述信息
1.4.2
配置MSDP全连接组
1.4.3
配置MSDP对等体连接控制
1.4.4
配置SA消息
配置SA消息内容
1.5.2
配置SA请求消息
1.5.3
配置SA消息过滤规则
1.5.4
配置SA消息缓存
1.5.5
1.3  配置MSDP基本功能
本节的所有配置都是在PIM-SM域内的RP上进行的,这些RP将成为MSDP对等体的一端。
1.3.1  配置准备
在配置MSDP基本功能之前,需完成以下任务:
l              配置任一单播路由协议,实现域内网络层互通
l              配置PIM-SM,实现域内组播
在配置MSDP基本功能之前,需准备以下数据:
l              MSDP对等体的IP地址
l              表示RP地址过滤策略的地址前缀列表
1.3.2  使能MSDP
在配置MSDP各功能之前,必须先使能MSDP。
1. 使能公网实例中的MSDP
表1-2 使能公网实例中的MSDP
使能IP组播路由
multicast routing-enable
缺省情况下,IP组播路由处于关闭状态
使能MSDP,并进入公网实例MSDP视图
msdp
缺省情况下,MSDP处于关闭状态
2. 使能VPN实例中的MSDP
表1-3 使能VPN实例中的MSDP
创建VPN实例,并进入VPN实例视图
配置VPN实例的RD
缺省情况下,VPN实例没有RD
使能IP组播路由
缺省情况下,IP组播路由处于关闭状态
退回系统视图
使能MSDP,并进入VPN实例MSDP视图
msdp vpn-instance vpn-instance-name
缺省情况下,MSDP处于关闭状态
l          有关ip vpn-instanceroute-distinguisher命令的详细介绍,请参见“MPLS命令参考”中的“MPLS L3VPN”。
l          有关multicast routing-enable命令的详细介绍,请参见“IP组播命令参考”中的“组播路由与转发”。
1.3.3  创建MSDP对等体连接
MSDP对等体使用地址对来标识,即本端MSDP对等体地址和远端MSDP对等体地址。需要在互为对等体的两端都创建MSDP对等体连接。
表1-4 创建MSDP对等体连接
进入公网实例或VPN实例MSDP视图
msdp [ vpn-instance vpn-instance-name ]
创建MSDP对等体连接
peer peer-address connect-interface interface-type interface-number
缺省情况下,没有创建MSDP对等体连接
如果某接口同时作为MSDP对等体和BGP/MBGP对等体中的一端,则建议为MSDP对等体配置与BGP或MBGP对等体相同的IP地址。
1.3.4  配置静态RPF对等体
通过配置静态RPF对等体可以免除对收到的SA消息进行RPF检查。
表1-5 配置静态RPF对等体
进入公网实例或VPN实例MSDP视图
配置静态RPF对等体
static-rpf-peer peer-address [ rp-policy ip-prefix-name ]
缺省情况下,没有配置静态RPF对等体
如果在一台路由器上只配置了一个MSDP对等体,则该MSDP对等体将被当作静态RPF对等体。
1.4  配置MSDP对等体连接
1.4.1  配置准备
在配置MSDP对等体连接之前,需完成以下任务:
l              配置MSDP基本功能
在配置MSDP对等体连接之前,需准备以下数据:
l              MSDP对等体的描述信息
l              MSDP全连接组的名称
l              建立MSDP对等体连接的重试周期
1.4.2  配置MSDP对等体描述信息
管理员可以通过MSDP对等体的描述信息方便地区分不同的MSDP对等体,从而更好地管理MSDP对等体。
表1-6 配置MSDP对等体描述信息
进入公网实例或VPN实例MSDP视图
配置MSDP对等体的描述信息
peer peer-address description text
缺省情况下,MSDP对等体没有描述信息
1.4.3  配置MSDP全连接组
一个自治系统内可能包含多个MSDP对等体,为了避免这些MSDP对等体之间泛滥SA消息,可以使用MSDP全连接组来优化数据流量。
构成全连接组的MSDP对等体,一方面将来自组外并通过了RPF检查的SA消息转发给组内的其它成员;另一方面,对来自组内成员的SA消息不经RPF检查就接受,也不在组内进行重复转发。这种操作既避免了SA消息的泛滥,同时还由于不需要在MSDP对等体之间运行BGP或MBGP,所以也就简化了对等体RPF检查机制。
通过为多个MSDP对等体配置相同的全连接组名称,可以建立MSDP全连接组。
表1-7 配置MSDP全连接组
进入公网实例或VPN实例MSDP视图
把MSDP对等体加入全连接组
peer peer-address mesh-group name
缺省情况下,MSDP对等体不属于任何全连接组
l          在配置MSDP全连接组之前,应使各路由器之间保持两两互连。
l          如果在同一MSDP对等体上多次配置加入全连接组,最后一个配置有效。
1.4.4  配置MSDP对等体连接控制
MSDP对等体之间使用TCP进行连接(端口号为639),用户可以手工关闭或重建MSDP对等体连接,灵活控制MSDP对等体之间的会话。当关闭了MSDP对等体连接后,MSDP对等体之间不再传递SA消息,TCP连接关闭,并不再重试建立连接,但配置信息会被保留。
当新创建了MSDP对等体、或重新启动了被关闭的MSDP对等体连接、或发生故障的MSDP对等体尝试恢复工作时,需要在MSDP对等体之间建立TCP连接。用户可以灵活地调整建立MSDP对等体连接的重试周期。
表1-8 配置MSDP对等体连接控制
进入公网实例或VPN实例MSDP视图
手工关闭MSDP对等体连接
shutdown peer-address
缺省情况下,MSDP对等体处于连接状态
配置建立MSDP对等体连接的重试周期
timer retry interval
缺省情况下,建立MSDP对等体连接的重试周期为30秒
1.5  配置SA消息
1.5.1  配置准备
在配置SA消息传递之前,需完成以下任务:
l              配置MSDP基本功能
在配置SA消息传递之前,需准备以下数据:
l              表示SA请求消息过滤规则的ACL规则
l              表示SA消息创建规则的ACL规则
l              表示接收或转发SA消息的过滤规则的ACL规则
l              封装在SA消息中组播数据报文的TTL(Time to live,生存时间)阈值
l              可缓存从指定MSDP对等体学到的(S,G)表项的最大数量
1.5.2  配置SA消息内容
某些组播源发送组播数据的时间间隔较长,超出了(S,G)表项的超时时间。在这种情况下,源端DR只能将组播数据逐个封装在注册消息中,发送给源端RP。源端RP使用SA消息将(S,G)信息传输给远端RP。然后,远端RP向源端DR发起加入过程,并创建SPT。由于(S,G)表项已超时,远端用户将永远无法收到该组播源发出的组播数据。
当在源端RP上使能了在SA消息中封装注册消息的功能后,源端RP会将注册消息封装在SA消息中发送出去。远端RP收到该SA消息后解封装,将注册消息中包含的组播数据沿RPT传输给本端用户。
MSDP对等体之间传递SA消息,当路由器对收到的SA消息进行RPF检查时,如果发现对端RP的地址与本地RP的地址相同,就会丢弃该SA消息。但在Anycast RP应用中,要求在同一个PIM-SM域内的两台或多台路由器上配置IP地址相同的RP,并在这些路由器之间建立MSDP对等体关系,因此必须为SA消息指定一个与实际RP的地址不同的逻辑RP地址(即逻辑接口上的RP地址),以通过RPF检查。
表1-9 配置SA消息内容
进入公网实例或VPN实例MSDP视图
使能在SA消息中封装注册消息
encap-data-enable
缺省情况下,在SA消息中只包含(S,G)表项,不封装注册消息
配置接口地址为SA消息的RP地址
originating-rp interface-type interface-number
缺省情况下,SA消息的RP地址为PIM的RP地址
1.5.3  配置SA请求消息
缺省情况下,当一个新接收者加入时,路由器不会主动向其MSDP对等体发送SA请求消息,而是等待其MSDP对等体在下一个周期发来的SA消息,这将延迟接收者获取组播源信息的时间。为了尽快让新接收者了解到当前活跃的组播源信息,需要主动向MSDP对等体发送SA请求消息。
表1-10 配置SA请求消息
进入公网实例或VPN实例MSDP视图
使能发送SA请求消息
peer peer-address request-sa-enable
缺省情况下,路由器收到新的组加入消息时,不向其MSDP对等体发送SA请求消息,而是等待下一周期SA消息的到来
配置SA请求消息的过滤规则
peer peer-address sa-request-policy [ acl acl-number ]
缺省情况下,不对SA请求消息进行过滤
在使能发送SA请求消息功能之前,必须首先关闭SA消息缓存机制,否则设备不会向外发送SA请求消息。
1.5.4  配置SA消息过滤规则
通过配置SA消息的创建规则,路由器可以在创建SA消息时,对其通告的(S,G)表项进行过滤,从而实现在创建SA消息时对组播源消息传播的控制。
通过配置接收或转发SA消息的过滤规则,路由器可以在接收或转发SA消息时,对其通告的(S,G)转发项进行过滤,从而实现在接收和转发SA消息时,对组播源消息传播的控制。
通过配置封装在SA消息中组播数据报文的TTL阈值,可以对组播数据报文在SA消息中的封装以及传输范围进行限制:
l              路由器在创建封装有组播数据报文的SA消息之前,先检查该组播数据报文IP头的TTL值:如果小于阈值,则不创建该SA消息;如果大于或等于阈值,则将组播数据报文封装在SA消息中并转发出去。
l              路由器在收到封装有组播数据报文的SA消息之后,先将该组播数据报文IP头的TTL值减1,再检查此时的TTL值:如果小于阈值,则不再向其指定的MSDP对等体转发;如果大于或等于阈值,则重新将组播数据报文封装在SA消息中并转发出去。
表1-11 配置SA消息过滤规则
进入公网实例或VPN实例MSDP视图
配置SA消息的创建规则
import-source [ acl acl-number ]
缺省情况下,在创建SA消息时,对其通告的(S,G)表项不作限制
配置接收或转发SA消息的过滤规则
peer peer-address sa-policy { import | export } [ acl acl-number ]
缺省情况下,不对接收或转发的SA消息进行过滤
peer peer-address minimum-ttl ttl-value
缺省情况下,封装在SA消息中组播数据报文的TTL阈值为0
1.5.5  配置SA消息缓存
为了减少获取组播信息的延迟时间,可以在路由器上使能SA消息缓存机制,即在本地缓存SA消息中所包含的(S,G)表项。缓存的(S,G)表项越多,所占用的内存空间越大。
在使能了SA消息缓存机制后,当收到一个新的组加入消息(*,G)时,路由器首先查找SA缓存:
l              如果缓存中没有对应的(S,G),便等候其MSDP对等体在下一个周期发来的SA消息;
l              如果缓存中有对应的(S,G),则直接加入以S为根的SPT。
为了有效防止路由器受到DoS(Denial of Service,拒绝服务)攻击,可以在路由器上配置可缓存(S,G)表项的最大数量。
表1-12 配置SA消息缓存
进入公网实例或VPN实例MSDP视图
使能SA消息缓存机制
cache-sa-enable
在缺省情况下,SA消息缓存机制处于使能状态,即在设备收到SA消息后缓存其中包含的(S,G)表项
配置可缓存从指定MSDP对等体学到的(S,G)表项的最大数量
peer peer-address sa-cache-maximum sa-limit
缺省情况下,可缓存从任一MSDP对等体学到的(S,G)表项的最大数量为8192
1.6  MSDP显示和维护
在完成上述配置后,在任意视图下执行display命令可以显示配置后MSDP的运行情况,通过查看显示信息验证配置的效果。
在用户视图下执行reset命令可以清除MSDP的统计信息。
表1-13 MSDP显示和维护
查看MSDP对等体的简要信息
display msdp [ all-instance | vpn-instance vpn-instance-name ] brief [ state { connect | down | listen | shutdown | up } ] [ | { begin | exclude | include } regular-expression ]
查看MSDP对等体的详细状态信息
display msdp [ all-instance | vpn-instance vpn-instance-name ] peer-status [ peer-address ] [ | { begin | exclude | include } regular-expression ]
查看SA缓存中的(S,G)表项信息
display msdp [ all-instance | vpn-instance vpn-instance-name ] sa-cache [ group-address | source-address | as-number ] * [ | { begin | exclude | include } regular-expression ]
查看SA缓存中(S,G)表项的数量
display msdp [ all-instance | vpn-instance vpn-instance-name ] sa-count [ as-number ] [ | { begin | exclude | include } regular-expression ]
重置与MSDP对等体的TCP连接
reset msdp [ all-instance | vpn-instance vpn-instance-name ] peer [ peer-address ]
清除SA缓存中的(S,G)表项
reset msdp [ all-instance | vpn-instance vpn-instance-name ] sa-cache [ group-address ]
清除MSDP对等体的统计信息
reset msdp [ all-instance | vpn-instance vpn-instance-name ] statistics [ peer-address ]
1.7  MSDP典型配置举例
l              网络中存在两个自治系统:AS 100和AS 200,各AS内部采用OSPF协议、AS之间则采用BGP协议以保证单播路由的畅通;
l              PIM-SM 1属于AS 100,PIM-SM 2和PIM-SM 3属于AS 200,每个PIM-SM域分别拥有至少一个组播源(Source)或接收者(Receiver);
l              将Router B、Router C和Router E各自的Loopback0接口分别配置为各自PIM-SM域的C-BSR和C-RP;
l              通过在各PIM-SM域的RP之间建立MSDP对等体,从而实现各PIM-SM域之间组播源信息的共享。
图1-5 PIM-SM域间组播配置组网图
设备
接口
IP地址
设备
接口
IP地址
Router A
Eth1/1
10.110.1.2/24
Router D
Eth1/1
10.110.4.2/24
Eth1/2
10.110.2.1/24
Eth1/2
10.110.5.1/24
Eth1/3
10.110.3.1/24
Router E
Eth1/1
10.110.6.1/24
Router B
Eth1/1
10.110.1.1/24
S2/0
192.168.3.2/24
POS5/0
192.168.1.1/24
Loop0
3.3.3.3/32
Loop0
1.1.1.1/32
Router F
Eth1/1
10.110.6.2/24
Router C
Eth1/1
10.110.4.1/24
Eth1/2
10.110.7.1/24
S2/0
192.168.3.1/24
Source 1
10.110.2.100/24
POS5/0
192.168.1.2/24
Source 2
10.110.5.100/24
Loop0
2.2.2.2/32
(1)        配置IP地址和单播路由协议
配置AS内的各路由器之间采用OSPF协议进行互连,确保各AS内部在网络层互通,并且各路由器之间能够借助单播路由协议实现动态路由更新,具体配置过程略。
(2)        使能IP组播路由,使能PIM-SM和IGMP,并配置BSR的服务边界
# 在Router A上使能IP组播路由,在各接口上使能PIM-SM,并在主机侧接口Ethernet1/3上使能IGMP。
[RouterA] multicast routing-enable
[RouterA] interface ethernet 1/1
[RouterA-Ethernet1/1] pim sm
[RouterA-Ethernet1/1] quit
[RouterA] interface ethernet 1/2
[RouterA-Ethernet1/2] pim sm
[RouterA-Ethernet1/2] quit
[RouterA] interface ethernet 1/3
[RouterA-Ethernet1/3] igmp enable
[RouterA-Ethernet1/3] pim sm
[RouterA-Ethernet1/3] quit
Router BRouter CRouter DRouter ERouter F上的配置与Router A相似,配置过程略。
# Router B上配置BSR的服务边界。
[RouterB] interface pos 5/0
[RouterB-Pos5/0] pim bsr-boundary
[RouterB-Pos5/0] quit
Router CRouter E上的配置与Router B相似,配置过程略。
(3)        配置C-BSRC-RP的位置
# Router B上将Loopback0接口配置为C-BSRC-RP
[RouterB] pim
[RouterB-pim] c-bsr loopback 0
[RouterB-pim] c-rp loopback 0
[RouterB-pim] quit
Router C和Router E上的配置与Router B相似,配置过程略。
(4)        配置BGP协议,将BGP与OSPF互相引入
# 在Router B上配置EBGP对等体,并引入OSPF路由。
[RouterB] bgp 100
[RouterB-bgp] router-id 1.1.1.1
[RouterB-bgp] peer 192.168.1.2 as-number 200
[RouterB-bgp] import-route ospf 1
[RouterB-bgp] quit
# Router C上配置EBGP对等体,并引入OSPF路由。
[RouterC] bgp 200
[RouterC-bgp] router-id 2.2.2.2
[RouterC-bgp] peer 192.168.1.1 as-number 100
[RouterC-bgp] import-route ospf 1
[RouterC-bgp] quit
# Router BOSPF中引入BGP
[RouterB] ospf 1
[RouterB-ospf-1] import-route bgp
[RouterB-ospf-1] quit
# Router COSPF中引入BGP
[RouterC] ospf 1
[RouterC-ospf-1] import-route bgp
[RouterC-ospf-1] quit
(5)        配置MSDP对等体
# 在Router B上配置MSDP对等体。
[RouterB] msdp
[RouterB-msdp] peer 192.168.1.2 connect-interface pos 5/0
[RouterB-msdp] quit
# 在Router C上配置MSDP对等体。
[RouterC] msdp
[RouterC-msdp] peer 192.168.1.1 connect-interface pos 5/0
[RouterC-msdp] peer 192.168.3.2 connect-interface serial 2/0
[RouterC-msdp] quit
# 在Router E上配置MSDP对等体。
[RouterE] msdp
[RouterE-msdp] peer 192.168.3.1 connect-interface serial 2/0
[RouterE-msdp] quit
(6)        检验配置效果
通过使用display bgp peer命令可以查看路由器之间BGP对等体的关系。例如:
# 查看Router BBGP对等体关系的信息。
[RouterB] display bgp peer
 BGP local router ID : 1.1.1.1
 Local AS number : 100
 Total number of peers : 1                 Peers in established state : 1
  Peer                    AS  MsgRcvd  MsgSent OutQ PrefRcv Up/Down  State
  192.168.1.2            200       24       21    0       6 00:13:09 Established
# 查看Router C上BGP对等体关系的信息。
[RouterC] display bgp peer
 BGP local router ID : 2.2.2.2
 Local AS number : 200
  192.168.1.1            100       18       16    0       1 00:12:04 Established
通过使用display bgp routing-table命令可以查看路由器上的BGP路由表。例如:
# 查看Router C上BGP路由表的信息。
[RouterC] display bgp routing-table
 Total Number of Routes: 5
 BGP Local router ID is 2.2.2.2
 Status codes: * - valid, ^ - VPNv4 best, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? - incomplete
     Network            NextHop         MED        LocPrf     PrefVal Path/Ogn
* >  1.1.1.1/32         192.168.1.1     0                     0       100?
* >i 2.2.2.2/32         0.0.0.0         0                     0       ?
* >  192.168.1.0        0.0.0.0         0                     0       ?
* >  192.168.1.1/32     0.0.0.0         0                     0       ?
* >  192.168.1.2/32     0.0.0.0         0                     0       ?
当PIM-SM 1和PIM-SM 2域内的组播源Source 1和Source 2发送组播信息时,PIM-SM 1和PIM-SM 3域内的接收者能收到该组播信息。通过使用display msdp brief命令可以查看路由器之间MSDP对等体建立情况。例如:
# 查看Router B上MSDP对等体建立情况的简要信息。
[RouterB] display msdp brief
MSDP Peer Brief Information of VPN-Instance: public net
  Configured   Up           Listen       Connect      Shutdown     Down
  1            1            0            0            0            0
  Peer's Address    State    Up/Down time    AS     SA Count   Reset Count
  192.168.1.2       Up       00:12:27        200    13         0
# 查看Router C上MSDP对等体建立情况的简要信息。
[RouterC] display msdp brief
  2            2            0            0            0            0
  192.168.3.2       Up       00:15:32        200    8          0
  192.168.1.1       UP       00:06:39        100    13         0
# 查看Router E上MSDP对等体建立情况的简要信息。
[RouterE] display msdp brief
  1            1            0            0            0            0
  192.168.3.1       Up       01:07:08        200    8          0
# 查看Router B上MSDP对等体的详细信息。
[RouterB] display msdp peer-status
MSDP Peer Information of VPN-Instance: public net
  MSDP Peer 192.168.1.2, AS 200
  Description:
  Information about connection status:
    State: Up
    Up/down time: 00:15:47
    Resets: 0
    Connection interface: Pos5/0 (192.168.1.1)
    Number of sent/received messages: 16/16
    Number of discarded output messages: 0
    Elapsed time since last connection or counters clear: 00:17:51
  Information about (Source, Group)-based SA filtering policy:
    Import policy: none
    Export policy: none
  Information about SA-Requests:
    Policy to accept SA-Request messages: none
    Sending SA-Requests status: disable
  Minimum TTL to forward SA with encapsulated data: 0
  SAs learned from this peer: 0, SA-cache maximum for the peer: none
  Input queue size: 0, Output queue size: 0
  Counters for MSDP message:
    Count of RPF check failure: 0
    Incoming/outgoing SA messages: 0/0
    Incoming/outgoing SA requests: 0/0
    Incoming/outgoing SA responses: 0/0
    Incoming/outgoing data packets: 0/0
l              将Router A、Router D和Router G各自的Loopback0接口分别配置为各自PIM-SM域的C-BSR和C-RP;
l              根据RPF规则,设备接受来自其静态RPF对等体且被过滤策略所允许的SA消息。通过在各PIM-SM域的RP之间建立MSDP对等体,并在各MSDP对等体之间建立静态RPF对等体,从而在不改变单播拓扑的基础上实现各PIM-SM域之间组播源信息的共享。
图1-6 借助静态RPF对等体的AS间组播配置组网图
设备
接口
IP地址
设备
接口
IP地址
Source 1
192.168.1.100/24
Router D
Eth1/1
10.110.5.1/24
Source 2
192.168.3.100/24
POS5/0
10.110.3.2/24
Router A
Eth1/1
10.110.1.1/24
Loop0
2.2.2.2/32
Eth1/2
10.110.2.1/24
Router E
Eth1/1
10.110.5.2/24
Loop0
1.1.1.1/32
Eth1/2
192.168.3.1/24
Router B
Eth1/1
10.110.1.2/24
Router F
Eth1/1
10.110.6.1/24
Eth1/2
192.168.1.1/24
S2/0
10.110.4.2/24
POS5/0
10.110.3.1/24
Router G
Eth1/1
10.110.6.2/24
Router C
Eth1/1
10.110.2.2/24
Eth1/2
192.168.4.1/24
Eth1/2
192.168.2.1/24
Loop0
3.3.3.3/32
S2/0
10.110.4.1/24
(1)        配置IP地址和单播路由协议
请按照图1-6配置各接口的IP地址和掩码,具体配置过程略。
配置AS内的各路由器之间采用OSPF协议进行互连,确保AS内部在网络层互通,并且各路由器之间能够借助单播路由协议实现动态路由更新,具体配置过程略。
# 在Router C上使能IP组播路由,在各接口上使能PIM-SM,并在主机侧接口Ethernet1/2上使能IGMP。
<RouterC> system-view
[RouterC] multicast routing-enable
[RouterC] interface ethernet 1/1
[RouterC-Ethernet1/1] pim sm
[RouterC-Ethernet1/1] quit
[RouterC] interface ethernet 1/2
[RouterC-Ethernet1/2] igmp enable
[RouterC-Ethernet1/2] pim sm
[RouterC-Ethernet1/2] quit
[RouterC] interface serial 2/0
[RouterC-Serial2/0] pim sm
[RouterC-Serial2/0] quit
Router ARouter BRouter DRouter ERouter FRouter G上的配置与Router C相似,配置过程略。
Router CRouter DRouter F上的配置与Router B相似,配置过程略。
(3)        配置C-BSRC-RP的位置
# Router A上将Loopback0接口配置为C-BSRC-RP
[RouterA] pim
[RouterA-pim] c-bsr loopback 0
[RouterA-pim] c-rp loopback 0
[RouterA-pim] quit
Router D和Router G上的配置与Router A相似,配置过程略。
[RouterB] bgp 100
[RouterB-bgp] router-id 1.1.1.2
[RouterB-bgp] peer 10.110.3.2 as-number 200
[RouterB-bgp] quit
# Router D上配置EBGP对等体,并引入OSPF路由。
[RouterD] bgp 200
[RouterD-bgp] router-id 2.2.2.2
[RouterD-bgp] peer 10.110.3.1 as-number 100
[RouterD-bgp] import-route ospf 1
[RouterD-bgp] quit
[RouterC] bgp 100
[RouterC-bgp] router-id 1.1.1.3
[RouterC-bgp] peer 10.110.4.2 as-number 200
[RouterC-bgp] quit
# Router F上配置EBGP对等体,并引入OSPF路由。
[RouterF] bgp 200
[RouterF-bgp] router-id 3.3.3.1
[RouterF-bgp] peer 10.110.4.1 as-number 100
[RouterF-bgp] import-route ospf 1
[RouterF-bgp] quit
# 在Router B的OSPF中引入BGP。
[RouterB] ospf 1
# Router DOSPF中引入BGP
[RouterD] ospf 1
[RouterD-ospf-1] import-route bgp
[RouterD-ospf-1] quit
[RouterC] ospf 1
# Router FOSPF中引入BGP
[RouterF] ospf 1
[RouterF-ospf-1] import-route bgp
[RouterF-ospf-1] quit
(5)        配置MSDP对等体及静态RPF对等体
# 配置Router D和Router G作为Router A的MSDP对等体及静态RPF对等体。
[RouterA] ip ip-prefix list-dg permit 10.110.0.0 16 greater-equal 16 less-equal 32
[RouterA] msdp
[RouterA-msdp] peer 10.110.3.2 connect-interface ethernet 1/1
[RouterA-msdp] peer 10.110.6.2 connect-interface ethernet 1/2
[RouterA-msdp] static-rpf-peer 10.110.3.2 rp-policy list-dg
[RouterA-msdp] static-rpf-peer 10.110.6.2 rp-policy list-dg
[RouterA-msdp] quit
# 配置Router A作为Router D的MSDP对等体及静态RPF对等体。
[RouterD] ip ip-prefix list-a permit 10.110.0.0 16 greater-equal 16 less-equal 32
[RouterD] msdp
[RouterD-msdp] peer 10.110.1.1 connect-interface pos 5/0
[RouterD-msdp] static-rpf-peer 10.110.1.1 rp-policy list-a
[RouterD-msdp] quit
# 配置Router A作为Router G的MSDP对等体及静态RPF对等体。
[RouterG] ip ip-prefix list-a permit 10.110.0.0 16 greater-equal 16 less-equal 32
[RouterG] msdp
[RouterG-msdp] peer 10.110.2.1 connect-interface ethernet 1/1
[RouterG-msdp] static-rpf-peer 10.110.2.1 rp-policy list-a
[RouterG-msdp] quit
(6)        检验配置效果
通过使用display bgp peer命令可以查看路由器之间BGP对等体建立情况。Router A上无任何信息输出,说明Router A与Router D、Router A与Router G之间均未建立BGP对等体关系。
当PIM-SM 1和PIM-SM 2域内的组播源Source 1和Source 2发送组播信息时,PIM-SM 1和PIM-SM 3域内的接收者能收到该组播信息,通过使用display msdp brief命令可以查看路由器之间MSDP对等体的建立情况。例如:
# 查看Router A上MSDP对等体的简要信息。
[RouterA] display msdp brief
  2            2            0            0            0            0
  10.110.3.2        Up       01:07:08        ?      8          0
  10.110.6.2        Up       00:16:39        ?      13         0
# 查看Router D上MSDP对等体的简要信息。
[RouterD] display msdp brief
  1            1            0            0            0            0
  10.110.1.1        Up       01:07:09        ?      8          0
# 查看Router G上MSDP对等体的简要信息。
[RouterG] display msdp brief
  1            1            0            0            0            0
  10.110.2.1        Up       00:16:40        ?      13         0
l              PIM-SM域内拥有多个组播源(Source)和接收者(Receiver),并在域内运行OSPF协议以提供单播路由;
l              通过配置Anycast RP,使接收者侧DR能够向拓扑距离最近的RP发起加入,组播源侧DR也向拓扑距离最近的RP发起注册;
l              将Router B和Router D各自的Loopback10接口配置为C-BSR、Loopback20接口配置为C-RP;
l              Router B的Router ID为1.1.1.1,Router D的Router ID为2.2.2.2,在Router B和Router D之间建立MSDP对等体关系。
图1-7 Anycast RP应用配置组网图
设备
接口
IP地址
设备
接口
IP地址
Source 1
10.110.5.100/24
Router C
POS5/0
192.168.1.2/24
Source 2
10.110.6.100/24
POS5/1
192.168.2.2/24
Router A
Eth1/1
10.110.5.1/24
Router D
Eth1/1
10.110.3.1/24
S2/0
10.110.2.2/24
S2/0
10.110.4.1/24
Router B
Eth1/1
10.110.1.1/24
POS5/0
192.168.2.1/24
S2/0
10.110.2.1/24
Loop0
2.2.2.2/32
POS5/0
192.168.1.1/24
Loop10
4.4.4.4/32
Loop0
1.1.1.1/32
Loop20
10.1.1.1/32
Loop10
3.3.3.3/32
Router E
Eth1/1
10.110.6.1/24
Loop20
10.1.1.1/32
S2/0
10.110.4.2/24
(1)        配置IP地址和单播路由协议
请按照图1-7配置各接口的IP地址和子网掩码,具体配置过程略。
配置PIM-SM域内的各路由器之间采用OSPF协议进行互连,确保PIM-SM域内部在网络层互通,并且各路由器之间能够借助单播路由协议实现动态路由更新,具体配置过程略。
(2)        使能IP组播路由,并使能PIM-SM和IGMP
# 在Router B上使能IP组播路由,在各接口上使能PIM-SM,并在主机侧接口Ethernet1/1上使能IGMP。
<RouterB> system-view
[RouterB] multicast routing-enable
[RouterB] interface ethernet 1/1
[RouterB-Ethernet1/1] igmp enable
[RouterB-Ethernet1/1] pim sm
[RouterB-Ethernet1/1] quit
[RouterB] interface serial 2/0
[RouterB-Serial2/0] pim sm
[RouterB-Serial2/0] quit
[RouterB-Pos5/0] pim sm
[RouterB-LoopBack0] pim sm
[RouterB-LoopBack0] quit
[RouterB] interface loopback 10
[RouterB-LoopBack10] pim sm
[RouterB-LoopBack10] quit
[RouterB] interface loopback 20
[RouterB-LoopBack20] pim sm
[RouterB-LoopBack20] quit
Router A、Router C、Router D和Router E上的配置与Router B相似,配置过程略。
(3)        配置C-BSR和C-RP的位置
# 在RouterB上将Loopback10配置为C-BSR,将Loopback20配置为C-RP。
[RouterB] pim
[RouterB-pim] c-bsr loopback 10
[RouterB-pim] c-rp loopback 20
[RouterB-pim] quit
Router D上的配置与Router B相似,配置过程略。
(4)        配置MSDP对等体
# 在Router B的Loopback0接口上配置MSDP对等体。
[RouterB] msdp
[RouterB-msdp] originating-rp loopback 0
[RouterB-msdp] peer 2.2.2.2 connect-interface loopback 0
[RouterB-msdp] quit
# 在Router D的Loopback0接口上配置MSDP对等体。
[RouterD] msdp
[RouterD-msdp] originating-rp loopback 0
[RouterD-msdp] peer 1.1.1.1 connect-interface loopback 0
[RouterD-msdp] quit
(5)        检验配置效果
# 查看Router B上MSDP对等体的简要信息。
  1            1            0            0            0            0
  2.2.2.2           Up       00:10:17        ?      0          0
  1            1            0            0            0            0
  1.1.1.1           Up       00:10:18        ?      0          0
通过使用display pim routing-table命令可以查看路由器上的PIM路由。
当Source 1(10.110.5.100/24)开始向组播组G(225.1.1.1)发送组播信息时,Host A加入组播组G。通过比较Router B与Router D上PIM路由的显示信息,可知当前的有效RP为Router B:Source 1向Router B注册,Host A向Router B加入。
# 查看Router B上的PIM路由的信息。
[RouterB] display pim routing-table
 (*, 225.1.1.1)
     RP: 10.1.1.1 (local)
     Protocol: pim-sm, Flag: WC
     UpTime: 00:15:04
     Upstream interface: Register
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: Ethernet1/1
             Protocol: igmp, UpTime: 00:15:04, Expires: -
 (10.110.5.100, 225.1.1.1)
     Protocol: pim-sm, Flag: SPT 2MSDP ACT
     UpTime: 00:46:28
     Upstream interface: Serial2/0
         Upstream neighbor: 10.110.2.2
         RPF prime neighbor: 10.110.2.2
         1: Ethernet1/1
             Protocol: pim-sm, UpTime:  - , Expires:  -
# 查看Router D上的PIM路由的信息。
[RouterD] display pim routing-table
Router D上没有信息输出。
Host A离开组播组G,Source 1也停止向组播组G发送组播数据。当Source 210.110.6.100/24)开始向组播组G发送组播信息时,Host B加入组播组G。通过比较Router B与Router D上PIM路由的显示信息,可知当前的有效RP为Router D:Source 2向Router D注册,Host B向Router D加入。
Router B上没有信息输出。
 (*, 225.1.1.1)
     UpTime: 00:12:07
         1: Ethernet1/1
             Protocol: igmp, UpTime: 00:12:07, Expires: -
 (10.110.6.100, 225.1.1.1)
     UpTime: 00:40:22
         Upstream neighbor: 10.110.4.2
         RPF prime neighbor: 10.110.4.2
         1: Ethernet1/1
1.7.4  SA消息过滤机制配置举例
l              网络中存在三个PIM-SM域,各域内部以及域之间均运行OSPF协议以提供单播路由;
l              将Router A、Router C和Router D各自的Loopback0接口分别配置为各自PIM-SM域的C-BSR和C-RP;
l              分别在Router A与Router C、Router C与Router D之间建立MSDP对等体关系;
l              组播源Source 1向组播组225.1.1.0/30和226.1.1.0/30发送组播数据,组播源Source 2向组播组227.1.1.0/30发送组播数据;
l              通过配置SA消息过滤规则,使接收者Host A和Host B只能接收发往组播组225.1.1.0/30和226.1.1.0/30的组播数据,而Host C则只能接收发往组播组226.1.1.0/30和227.1.1.0/30的组播数据。
图1-8 SA消息过滤机制配置组网图
设备
接口
IP地址
设备
接口
IP地址
Source 1
10.110.3.100/24
Router C
Eth1/1
10.110.4.1/24
Source 2
10.110.6.100/24
S2/1
10.110.5.1/24
Router A
Eth1/1
10.110.1.1/24
POS5/1
192.168.1.2/24
S2/1
10.110.2.1/24
POS5/2
192.168.2.2/24
POS5/1
192.168.1.1/24
Loop0
2.2.2.2/32
Loop0
1.1.1.1/32
Router D
Eth1/1
10.110.6.1/24
Router B
Eth1/1
10.110.3.1/24
Eth1/2
10.110.7.1/24
S2/1
10.110.2.2/24
S2/1
10.110.5.2/24
POS5/1
192.168.2.1/24
Loop0
3.3.3.3/32
(1)        配置IP地址和单播路由协议
请按照图1-8配置各接口的IP地址和掩码,具体配置过程略。
配置各路由器之间采用OSPF协议进行互连,确保PIM-SM域内部以及各PIM-SM域之间在网络层互通,并且各路由器之间能够借助单播路由协议实现动态路由更新,具体配置过程略。
# 在Router A上使能IP组播路由,在各接口上使能PIM-SM,并在主机侧接口Ethernet1/1上使能IGMP。
[RouterA-Ethernet1/1] igmp enable
[RouterA] interface serial 2/1
[RouterA-Serial2/1] pim sm
[RouterA-Serial2/1] quit
[RouterA] interface pos 5/1
[RouterA-Pos5/1] pim sm
[RouterA-Pos5/1] quit
[RouterA-LoopBack0] pim sm
[RouterA-LoopBack0] quit
Router BRouter CRouter D上的配置与Router A相似,配置过程略。
# Router C上配置BSR的服务边界。
[RouterC] interface pos 5/1
[RouterC-Pos5/1] pim bsr-boundary
[RouterC-Pos5/1] quit
[RouterC] interface pos 5/2
[RouterC-Pos5/2] pim bsr-boundary
[RouterC-Pos5/2] quit
[RouterC] interface serial 2/1
[RouterC-Serial2/1] pim bsr-boundary
[RouterC-Serial2/1] quit
Router A、Router B和Router D上的配置与Router C相似,配置过程略。
(3)        配置C-BSR和C-RP的位置
# 在Router A上将Loopback0接口配置为C-BSR和C-RP。
[RouterA] pim
[RouterA-pim] quit
Router C和Router D上的配置与Router A相似,配置过程略。
(4)        配置MSDP对等体
# 在Router A上配置MSDP对等体。
[RouterA] msdp
[RouterA-msdp] peer 192.168.1.2 connect-interface pos 5/1
[RouterA-msdp] quit
# Router C上配置MSDP对等体。
[RouterC] msdp
[RouterC-msdp] peer 192.168.1.1 connect-interface pos 5/1
[RouterC-msdp] peer 10.110.5.2 connect-interface serial 2/1
[RouterC-msdp] quit
# 在Router D上配置MSDP对等体。
[RouterD] msdp
[RouterD-msdp] peer 10.110.5.1 connect-interface serial 2/1
[RouterD-msdp] quit
(5)        配置SA消息过滤规则
# 在Router C上配置不向Router D转发有关(Source 1,225.1.1.0/30)的SA消息。
[RouterC] acl number 3001
[RouterC-acl-adv-3001] rule deny ip source 10.110.3.100 0 destination 225.1.1.0 0.0.0.3
[RouterC-acl-adv-3001] rule permit ip source any destination any
[RouterC-acl-adv-3001] quit
[RouterC] msdp
[RouterC-msdp] peer 10.110.5.2 sa-policy export acl 3001
[RouterC-msdp] quit
# Router D上配置不创建有关Source 2SA消息。
[RouterD] acl number 2001
[RouterD-acl-basic-2001] rule deny source 10.110.6.100 0
[RouterD-acl-basic-2001] quit
[RouterD] msdp
[RouterD-msdp] import-source acl 2001
[RouterD-msdp] quit
(6)        检验配置效果
通过使用display msdp sa-cache命令可以查看路由器上SA缓存中的(S,G)表项信息。例如:
# 查看Router C上SA缓存中的(S,G)表项信息。
[RouterC] display msdp sa-cache
MSDP Source-Active Cache Information of VPN-Instance: public net
 MSDP Total Source-Active Cache - 8 entries
 MSDP matched 8 entries
(Source, Group)              Origin RP       Pro  AS     Uptime   Expires
(10.110.3.100, 225.1.1.0)    1.1.1.1         ?    ?      02:03:30 00:05:31
(10.110.3.100, 225.1.1.1)    1.1.1.1         ?    ?      02:03:30 00:05:31
(10.110.3.100, 225.1.1.2)    1.1.1.1         ?    ?      02:03:30 00:05:31
(10.110.3.100, 225.1.1.3)    1.1.1.1         ?    ?      02:03:30 00:05:31
(10.110.3.100, 226.1.1.0)    1.1.1.1         ?    ?      02:03:30 00:05:31
(10.110.3.100, 226.1.1.1)    1.1.1.1         ?    ?      02:03:30 00:05:31
(10.110.3.100, 226.1.1.2)    1.1.1.1         ?    ?      02:03:30 00:05:31
(10.110.3.100, 226.1.1.3)    1.1.1.1         ?    ?      02:03:30 00:05:31
# 查看Router D上SA缓存中的(S,G)表项信息。
[RouterD] display msdp sa-cache
 MSDP Total Source-Active Cache - 4 entries
 MSDP matched 4 entries
(10.110.3.100, 226.1.1.0)    1.1.1.1         ?    ?      00:32:53 00:05:07
(10.110.3.100, 226.1.1.1)    1.1.1.1         ?    ?      00:32:53 00:05:07
(10.110.3.100, 226.1.1.2)    1.1.1.1         ?    ?      00:32:53 00:05:07
(10.110.3.100, 226.1.1.3)    1.1.1.1         ?    ?      00:32:53 00:05:07
1.8  常见配置错误举例
1. 故障现象
配置了MSDP对等体,但其状态一直显示为down。
2. 分析
l              所配置的本地接口地址与MSDP对等体地址之间,建立起基于TCP连接的MSDP对等体关系;
l              如果本地接口地址与对端路由器上所配置的MSDP对等体地址不一致,TCP连接就不会建立起来;
l              如果两个MSDP对等体之间没有路由,TCP连接也不会建立起来。
3. 处理过程
(1)        检查各路由器之间的路由是否通达。通过命令display ip routing-table查看各路由器之间单播路由是否正确。
(2)        检查将成为MSDP对等体的两个路由器间是否存在到达对方的单播路由。
(3)        检查MSDP对等体之间的接口地址是否匹配。通过命令display current-configuration查看本地接口地址是否与对端MSDP对等体地址一致,应确保一致。
1. 故障现象
MSDP没有将(S,G)转发项通过SA消息发送出去。
2. 分析
l              命令import-source用于控制将本域的(S,G)表项通过SA消息发送给MSDP对等体。如果没有指定参数acl-number则表示默认过滤掉所有的(S,G)表项,即不通告本域的所有(S,G)表项;
l              未配置import-source命令时,系统将发送本域的所有(S,G)信息。如果MSDP没有将本域的(S,G)表项通过SA消息发送出去,应检查import-source命令的配置是否正确。
3. 处理过程
(3)        检查命令import-source及其参数acl-number的配置情况,确保ACL规则能够过滤合适的(S,G)信息。
1. 故障现象
在Anycast RP的应用中,各RP之间没有互相交换其本地注册的(S,G)信息。
2. 分析
l              在Anycast RP应用中,通过将同一PIM-SM域内的RP配置为MSDP对等体,可以实现RP间的负载分担;
l              MSDP对等体地址不能与Anycast RP地址相同,且C-BSR和C-RP必须配置在不同的设备或接口上;
l              在使用originating-rp命令进行配置后,MSDP将利用该命令所指定的接口地址替换SA消息中的RP地址;
l              当MSDP对等体对收到的SA消息进行RPF检查时,如果发现RP地址与本地配置的RP地址相同,将拒绝接收SA消息。
3. 处理过程
(3)        检查originating-rp命令的配置情况。在Anycast RP的应用环境中,一定要配置originating-rp命令,而且originating-rp命令所指定的接口地址要与建立MSDP对等体连接的本地接口地址相同。
(4)        检查所配置的C-BSR地址是否与Anycast RP的地址不同,应确保两个地址不同。
