选择区域语言: EN CN HK
02-接口管理命令参考
02-WAN接口命令
本章节下载  (808.4 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/MSR/MSR_50/Command/Command_Manual/H3C_MSR_CR(V5)-R2311-V1.12/02/201212/767979_30005_0.htm
02-WAN接口命令
1 WAN接口
1.1 WAN接口公共命令
1.1.1 bandwidth
1.1.2 default
1.1.3 description
1.1.4 link-delay
1.1.5 shutdown
1.2 串口、AUX接口及AM接口配置命令
1.2.1 async mode
1.2.2 baudrate
1.2.3 clock
1.2.4 code
1.2.5 country-code
1.2.6 crc
1.2.7 detect
1.2.8 display interface analogmodem
1.2.9 display interface aux
1.2.10 display interface serial
1.2.11 eliminate-pulse
1.2.12 idle-mark
1.2.13 invert receive-clock
1.2.14 invert transmit-clock
1.2.15 itf
1.2.16 loopback
1.2.17 mtu
1.2.18 physical-mode
1.2.19 phy-mru
1.2.20 reset counters interface
1.2.21 reset counters interface
1.2.22 reset counters interface
1.2.23 reverse-rts
1.2.24 timer hold
1.2.25 virtualbaudrate
1.3 3G Modem基本配置命令
1.3.1 autodeploy sms enable
1.3.2 display cellular
1.3.3 display interface cellular
1.3.4 dm-port open
1.3.5 mode cdma
1.3.6 mode td-scdma
1.3.7 mode wcdma
1.3.8 modem auto-recovery enable
1.3.9 modem reboot
1.3.10 modem response
1.3.11 pin modify
1.3.12 pin unlock
1.3.13 pin verification
1.3.14 pin verify
1.3.15 plmn search
1.3.16 plmn select
1.3.17 profile create
1.3.18 recovery track
1.3.19 reset counters interface
1.3.20 rssi
1.3.21 trust-imsi
1.3.22 sms sending-enable
1.3.23 snmp-agent trap enable sms
1.3.24 sms send
1.3.25 sms delete
1.3.26 display sms
1.3.27 display sms statistics
1.3.28 sms forward
1.4 CE1/PRI接口基本配置命令
1.4.1 alarm
1.4.2 cable (CE1/PRI interface)
1.4.3 channel-set (CE1/PRI interface)
1.4.4 clock (CE1/PRI interface)
1.4.5 clock-change auto
1.4.6 code (CE1/PRI interface)
1.4.7 controller e1
1.4.8 crc
1.4.9 data-coding (CE1/PRI interface)
1.4.10 detect-ais
1.4.11 display controller e1
1.4.12 error-diffusion restraint config
1.4.13 error-diffusion restraint enable
1.4.14 error-diffusion restraint restart-channel
1.4.15 frame-format (CE1/PRI interface)
1.4.16 idlecode (CE1/PRI interface)
1.4.17 itf (CE1/PRI interface)
1.4.18 loopback (CE1/PRI interfacei)
1.4.19 pri-set (CE1/PRI interface)
1.4.20 reset counters controller e1
1.4.21 using (CE1/PRI interface)
1.5 CT1/PRI接口基本配置命令
1.5.1 alarm (CT1/PRI interface)
1.5.2 alarm-threshold
1.5.3 bert (CT1/PRI interface)
1.5.4 cable (CT1/PRI interface)
1.5.5 channel-set (CT1/PRI interface)
1.5.6 clock (CT1/PRI interface)
1.5.7 code (CT1/PRI interface)
1.5.8 controller t1
1.5.9 crc
1.5.10 data-coding (CT1/PRI interface)
1.5.11 display controller t1
1.5.12 error-diffusion restraint config
1.5.13 error-diffusion restraint enable
1.5.14 error-diffusion restraint restart-channel
1.5.15 fdl
1.5.16 frame-format (CT1/PRI interface)
1.5.17 idlecode (CT1/PRI interface)
1.5.18 itf (CT1/PRI interface)
1.5.19 loopback (CT1/PRI interface)
1.5.20 pri-set (CT1/PRI interface)
1.5.21 reset counters controller t1
1.5.22 sendloopcode
1.5.23 clock-change auto
1.5.24 crc
1.5.25 display fe1
1.5.26 fe1 alarm
1.5.27 fe1 cable
1.5.28 fe1 clock
1.5.29 fe1 code
1.5.30 fe1 data-coding
1.5.31 fe1 detect-ais
1.5.32 fe1 frame-format
1.5.33 fe1 idlecode
1.5.34 fe1 itf
1.5.35 fe1 loopback
1.5.36 fe1 timeslot-list
1.5.37 fe1 unframed
1.5.38 crc
1.5.39 display ft1
1.5.40 ft1 alarm
1.5.41 ft1 alarm-threshold
1.5.42 ft1 bert
1.5.43 ft1 cable
1.5.44 ft1 clock
1.5.45 ft1 code
1.5.46 ft1 data-coding
1.5.47 ft1 fdl
1.5.48 ft1 frame-format
1.5.49 ft1 idlecode
1.5.50 ft1 itf
1.5.51 ft1 loopback
1.5.52 ft1 sendloopcode
1.5.53 ft1 timeslot-list
1.6 CE3接口基本配置命令
1.6.1 bert (CE3 interface)
1.6.2 clock (CE3 interface)
1.6.3 controller e3
1.6.4 crc
1.6.5 display controller e3
1.6.6 e1 bert
1.6.7 e1 channel-set
1.6.8 e1 set clock
1.6.9 e1 set frame-format
1.6.10 e1 set loopback
1.6.11 e1 shutdown
1.6.12 e1 unframed
1.6.13 fe3
1.6.14 loopback (CE3 interface)
1.6.15 national-bit
1.6.16 reset counters controller e3
1.6.17 using (CE3 Interface)
1.6.18 alarm (CT3 interface)
1.6.19 bert (CT3 interface)
1.6.20 cable (CT3 interface)
1.6.21 clock (CT3 interface)
1.6.22 controller t3
1.6.23 crc
1.6.24 display controller t3
1.6.25 feac
1.6.26 frame-format (CT3 interface)
1.6.27 ft3
1.6.28 loopback (CT3 interface)
1.6.29 mdl (CT3 interface)
1.6.30 reset counters controller t3
1.6.31 t1 alarm
1.6.32 t1 bert
1.6.33 t1 channel-set
1.6.34 t1 sendloopcode
1.6.35 t1 set clock
1.6.36 t1 set frame-format
1.6.37 t1 set loopback
1.6.38 t1 set fdl
1.6.39 t1 show
1.6.40 t1 shutdown
1.6.41 t1 unframed
1.6.42 using (CT3 interface)
1.7 ISDN BRI接口配置命令
1.7.1 display interface bri
1.7.2 loopback (ISDN BRI interfacei)
1.7.3 mtu (ISDN BRI interface)
1.7.4 reset counters interface
1 WAN接口
·       MSR 30-11不支持USB接口。
·       硬件版本低于Hardware 2.2的CE3、CT3接口模块不支持配置子速率。使用display version可以查看接口模块硬件版本号。
·       MSR 900路由器仅支持AUX接口和USB 3G Modem接口。
·       MSR 930路由器仅支持AUX接口和3G Modem接口,MSR 930-SA还支持串口。
1.1  WAN接口公共命令
1.1.1  bandwidth
bandwidth bandwidth-value
undo bandwidth
串口视图/AUX接口视图/AM接口视图/Cellular接口视图/E1-F接口视图/T1-F接口视图/ISDN BRI接口视图/CE3接口视图/CT3接口视图
CE1/PRI接口视图
CT1/PRI接口视图
【缺省级别】
2:系统级
bandwidth-value:表示接口的期望带宽,取值范围为1~4294967295,单位为kbit/s。
【描述】
bandwidth命令用来设置接口的期望带宽。undo bandwidth命令用来恢复缺省值。
接口的期望带宽可以通过第三方软件查询MIB节点ifspeed的值来获取。
期望带宽供网管监控接口带宽使用,不会对接口实际带宽造成影响。
# 设置串口Serial2/0的期望带宽为50 kbit/s。
[Sysname] interface serial 2/0
[Sysname-Serial2/0] bandwidth 50
1.1.2  default
default
串口视图/AUX接口视图/AM接口视图/Cellular接口视图/E1-F接口视图/T1-F接口视图/ ISDN BRI接口视图/CE3接口视图/CT3接口视图
CE1/PRI接口视图
CT1/PRI接口视图
【缺省级别】
2:系统级
【描述】
default命令用来恢复当前接口的缺省配置。
需要注意的是,接口下的某些配置取消后,会对现有功能产生影响,建议您在执行该命令前,完全了解其对网络产生的影响。
# 将串口接口 2/0恢复为缺省配置。
[Sysname-Serial2/0] default
This command will restore the default settings. Continue? [Y/N]:y
1.1.3  description
CE1/PRI接口视图
CT1/PRI接口视图
【缺省级别】
2:系统级
text:接口描述信息,为1~240个字符的字符串,可以包含字母(区分大小写)、数字、特殊字符(包括~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /)、空格以及符合unicode编码规范的其它文字和符号。
【描述】
description命令用来配置接口的描述信息。undo description命令用来恢复缺省情况。
缺省情况下,接口的描述信息为“该接口的接口名 Interface”,比如:Serial2/0 Interface。
# 配置Serial2/0的描述信息为“router-interface”。
[Sysname-Serial2/0] description router-interface
1.1.4  link-delay
link-delay delay-time
undo link-delay
E1-F接口视图
T1-F接口视图
CE3接口视图
CT3接口视图
CE1/PRI接口视图
CT1/PRI接口视图
【缺省级别】
2:系统级
delay-time:接口物理连接状态抑制时间值,取值范围为0~10,单位为秒。取值为0时,表示关闭WAN接口物理连接状态抑制功能,与undo link-delay命令等效。
【描述】
link-delay命令用来设置WAN接口物理连接状态抑制时间。undo link-delay命令用来恢复缺省情况。
缺省情况下,WAN接口没有开启状态抑制功能。系统每5秒检测一次接口物理连接状态,当连接状态发生变化后,系统会在0~5秒内检测并上报连接状态的变化。
当配置delay-time参数值为1~10时,例如取值为2,则接口连接状态发生变化后,系统会在2~7秒内检测并上报连接状态的变化。
对于CE3、CT3、CE1/PRI和CT1/PRI接口,本命令需要配置在controller视图下,对于E1-F和T1-F接口,本命令需要配置在对应的Serial接口视图下。对于其他同/异步串口对应的Serial接口视图下,该命令不可用。
本命令对自然关闭状态(down)下的端口有效,对手工关闭状态(使用shutdown命令)下的端口无效。
# 设置CE1/PRI接口物理连接状态抑制时间值为2,即系统会在2~7秒内检测并上报接口连接状态的变化:
[Sysname] controller e1 2/0
[Sysname-E1 2/0] link-delay 2
1.1.5  shutdown
shutdown
CE1/PRI接口视图
CT1/PRI接口视图
【缺省级别】
2:系统级
【描述】
shutdown命令用来关闭接口。undo shutdown命令用来打开接口。
缺省情况下,接口处于开启状态。
修改接口工作参数后,需要先执行shutdown命令关闭接口,再执行undo shutdown命令重新开启接口,才能使修改的配置生效。
# 关闭串口Serial2/0。
[Sysname-Serial2/0] shutdown
1.2.1  async mode
async mode { flow | protocol }
undo async mode
异步串口视图/AUX接口视图/AM接口视图
【缺省级别】
2:系统级
flow:流模式,也称交互模式。指物理连接建立之后,链路的两端进行交互,主叫端向接收端发送配置命令(与用户从远端手工键入配置命令效果相同),设置接收端的链路层协议工作参数,然后建立链路。一般用于拨号等人机交互的情况。
protocol:协议模式。指物理连接建立之后,接口直接采用已有的链路层协议配置参数建立链路。
【描述】
async mode命令用来设置异步串口的工作模式。undo async mode命令用来恢复缺省情况。
缺省情况下,异步串口工作在协议模式(protocol),AUX接口缺省工作在流模式(flow)。
当异步串口工作在流模式时,允许进行PPP的配置,但配置并不生效;当异步串口的工作方式切换到协议模式(protocol)时,已配置的PPP协议内容生效。
# 设置异步串口工作在流方式。
[Sysname] interface async 1/0
[Sysname-async1/0] async mode flow
1.2.2  baudrate
baudrate baudrate
undo baudrate
同步串口视图
【缺省级别】
2:系统级
baudrate:同步串口的波特率,单位为bps。
【描述】
baudrate命令用来设置同步串口的波特率。undo baudrate命令用来恢复缺省情况。
缺省情况下,同步串口的波特率为64000bps。
同步串口支持的波特率有:
1200bps、2400bps、4800bps、9600bps、19200bps、38400bps、56000bps、57600bps、64000bps、72000bps、115200bps、128000bps、192000bps、256000bps、384000bps、512000bps、1024000bps、2048000bps、4096000bps。
另外同步串口对于不同的物理电气规程,所支持的波特率范围有所不同。
·              V.24 DTE/DCE:1200bps~64000bps
·              V.35 DCE/DCE、X.21 DTE/DCE、EIA/TIA-449 DTE/DCE以及EIA-530 DTE/DCE:1200bps~4096000bps
·       在设置同步串口波特率时,要注意同步串口的外接电缆的电气规程等因素;
·       DCE设备和DTE设备之间线路传输的波特率,由DCE设备决定。
# 设置DCE设备的同步串口的波特率为115200bps。
[Sysname-Serial2/0] baudrate 115200
1.2.3  clock
clock { dteclk1 | dteclk2 | dteclk3 | dteclk4 | dteclk5 | dteclkauto }
undo clock
同步串口视图
【缺省级别】
2:系统级
dteclk1:设置接口时钟方式为DTE时钟选择方式1。
dteclk2:设置接口时钟方式为DTE时钟选择方式2。
dteclk3:设置接口时钟方式为DTE时钟选择方式3。
dteclk4:设置接口时钟方式为DTE时钟选择方式4。
dteclk5:设置接口时钟方式为DTE时钟选择方式5。
dteclkauto:设置接口时钟方式为DTE自动协商。
【描述】
clock命令用来设置同步串口工作在DTE方式时的时钟选择方式。undo clock命令用来恢复缺省情况。
缺省情况下,同步串口DTE侧的时钟为dteclk1
同步串口作为DTE设备,则需要接受对端DCE设备提供的时钟,由于同步设备的接收和发送时钟是独立的,则DTE设备的接收时钟可以选择DCE设备的发送或接收时钟,DTE设备的发送时钟也可以选择DCE设备的发送或接收时钟,由此产生五种组合,即在DTE侧可以有五种时钟选择。
图1-1 同步串口时钟选择示意图
其中,TxClk为发送时钟,RxClk为接收时钟。
四种选择方法规定如下表所示。
表1-1 同步串口DTE侧时钟的选择方法
选择方法
意义
DTEclk1
TxClk = TxClk, RxClk = RxClk
DTEclk2
TxClk = TxClk, RxClk = TxClk
DTEclk3
TxClk = RxClk, RxClk = TxClk
DTEclk4
TxClk = RxClk, RxClk = RxClk
DTEclk5
TxClk = Local, RxClk = Local
其中,‘=’前为DTE侧时钟,‘=’后为DCE侧时钟。
# 设置同步串口工作在DTE方式时的时钟选择方式为DTEclk2。
[Sysname-Serial2/0] clock dteclk2
1.2.4  code
code { nrz | nrzi }
undo code
同步串口视图
【缺省级别】
2:系统级
nrz:采用NRZ(不归零)的数字信号编码格式。
nrzi采用NRZI(反向不归零)的数字信号编码格式。
【描述】
code命令用来配置同步串口的数字信号编码格式。undo code命令用来恢复缺省情况。
缺省情况下,同步串口的数字信号编码格式为NRZ。
# 配置同步串口的数字信号编码格式为NRZI。
[Sysname-Serial2/0] code nrzi
1.2.5  country-code
country-code area-name
undo country-code
AM接口视图
【缺省级别】
2:系统级
area-name:地区名称,包括:australia、austria、belgium、brazil、bulgaria、canada、china、czechoslovakia、denmark、finland、france、germany、greece、hongkong、hungary、india、ireland、israel、italy、japan、korea、luxembourg、malaysia、mexico、netherlands、new-zealand、norway、philippines、poland、portugal、russia、singapore、southafrica、spain、sweden、switzerland、taiwan、united-kingdom、united-states。
【描述】
country-code命令用来设置AM接口的编码格式。undo country-code命令用来恢复缺省情况。
缺省情况下,地区编码格式为united-states。
在不同的地区,Modem的编码格式有所不同,为了适应不同地区的编码格式,可以配置此命令。
# 设置AM接口的编码格式为china。
[Sysname] interface analogmodem 2/0
[Sysname-Analogmodem2/0] country-code china
1.2.6  crc
crc { 16 | 32 | none }
undo crc
同步串口视图
【缺省级别】
2:系统级
16:同步串口使用16位CRC校验方式。
32:同步串口使用32位CRC校验方式。
none:同步串口不进行CRC校验。
【描述】
crc命令用来配置同步串口的CRC校验方式。undo crc命令用来恢复缺省情况。
缺省情况下,采用16位CRC校验方式。
# 同步串口下配置CRC校验为32位CRC校验方式。
[Sysname-Serial2/0] crc 32
1.2.7  detect
异步串口:
detect dsr-dtr
undo detect dsr-dtr
同步串口:
detect { dcd | dsr-dtr }
undo detect { dcd | dsr-dtr }
同/异步串口视图
【缺省级别】
2:系统级
dsr-dtr:检测DSU/CSU(Data Service Unit/Channel Service Unit,数据服务单元/信道服务单元,表示数字MODEM)的DSR(Data Set Ready,数据置位就绪)和DTR(Data Terminal Ready,数据终端就绪)信号。
dcd:检测同步串口DSU/CSU的DCD(Data Carrier Detect,数据载波检测)信号。
【描述】
detect命令用来启用串口的数据载波检测和串口的电平检测功能。undo detect命令用来禁止该功能。
缺省情况下,启用串口的数据载波检测和串口的电平检测功能。
如果设置禁止异步串口进行电平检测,系统将不检测异步串口是否外接电缆,自动向用户报告异步串口的状态为up,且DTR = up、DSR = up;如果设置允许异步串口进行电平检测,则系统将不仅检测异步串口是否外接电缆,同时还要检测DSR信号,只有当该信号有效时,系统才认为异步串口处于up状态,否则,为down状态。
系统在判断同步串口的状态(up或down)时,缺省情况下将同时检测DSR信号、DCD信号以及接口是否外接电缆。只有当三个信号全部有效时,系统才认为同步串口处于up状态,否则为down状态。如果禁止同步串口进行电平检测,系统检测到外接电缆后,接口状态为up,且DTR = up、DSR = up。
# 启用同步串口的数据载波检测功能。
[Sysname-Serial2/0] detect dcd
display interface [ analogmodem ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface analogmodem interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:显示指定AM接口的信息。
down:显示当前状态为down的接口的信息以及down的原因。不指定该参数时,将不会根据接口状态来过滤显示信息。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display interface analogmodem命令用来显示AM接口的相关信息。
·              如果不指定analogmodem参数,将显示设备支持的所有接口的相关信息。
·              如果指定analogmodem参数,不指定interface-number参数,将显示所有已创建的AM接口的相关信息。
# 显示AM接口2/0的详细信息。
<Sysname> display interface analogmodem 2/0
Analogmodem2/0 current state: UP
Description: Analogmodem2/0 Interface
The Maximum Transmit Unit is 1500, Hold timer is 10(sec)
Internet Address is 6.6.5.5/24 Primary
Link layer protocol is PPP
LCP opened, IPCP opened
Physical is Analogmodem2/0, baudrate: 64000
Output queue : (Urgent queuing : Size/Length/Discards)  0/100/0
Output queue : (Protocol queuing : Size/Length/Discards)  0/500/0
Output queue : (FIFO queuing : Size/Length/Discards)  0/75/0
Physical layer is asynchronous, Baudrate is 57600 bps
Phy-mru is 1700
    Last 300 seconds input rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
    Last 300 seconds output rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
    Input: 0 packets, 0 bytes
           0 broadcasts, 0 multicasts
           0 errors, 0 runts, 0 giants
           0 CRC, 0 align errors, 0 overruns
           0 dribbles, 0 aborts, 0 no buffers
           0 frame errors
    Output:0 packets, 0 bytes
           0 errors, 0 underruns, 0 collisions
           0 deferred
DCD=DOWN  DTR=UP  DSR=UP  RTS=UP  CTS=UP
# 显示AM接口2/0的概要信息。
<Sysname> display interface analogmodem 2/0 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
analogmodem2/0       DOWN DOWN    --
# 显示所有状态为down的AM接口的概要信息。
<Sysname> display interface analogmodem brief down
analogmodem2/0       DOWN Not connected
表1-2 display interface analogmodem命令显示信息描述表
AM接口当前的物理状态,状态可能为:
·       DOWN(Administratively):表示该AM接口已经通过shutdown命令被关闭,即管理状态为关闭
·       DOWN:表示该AM接口的物理状态为关闭(可能因为没有物理连线或者线路故障)
·       UP:该AM接口的管理状态和物理状态均为开启
该接口的链路协议状态
接口描述信息
接口的最大传输单元(MTU)。缺省值为1500字节。表示长度大于MTU的报文,将会被分片后再发送。如果设置了不准分片,报文会被丢弃
报文的生命周期。报文如果在生命周期内没有被送出去,则将丢弃
接口的IP地址
AM接口的数据链路层协议
表示PPP连接建立成功
物理层链路信息,AM接口的带宽
输出队列(紧急队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
链路层的协议报文,比如PPP 的协商报文和Keepalive 报文等将进入这个队列
输出队列(协议队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
协议队列(Protocol queue)是指IP优先级为6 的报文将进入协议队列
输出队列(先进先出队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
物理层链路信息,接口的带宽
Phy-mru is 1700
最大接收包长为1700字节
最后一次清除接口统计信息的时间
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
           0 frame errors
接口收到的总报文数和总字节数:
·       broadcasts:接收的广播报文的数目
·       multicasts:接收的组播报文的数目
·       errors:在物理层检测时发现的错误报文数目
·       runts:接口接收到小于规定的最小报文长度报文数
·       giants:接收到长度大于规定长度的报文数目
·       CRC:接收长度正常但CRC 校验错误的报文数目
·       align errors:排列错误
·       overruns:接收的报文速度大于转发处理能力导致无法处理的报文
·       aborts:接收报文的异常错误
·       no buffers:在接收报文时由于内部缓存满,导致帧丢弃
·       frame errors:帧错误
           0 deferred
接口发送的报文数和总字节数
·       underruns:因为接口读取内存的速度小于转发的速度而无法发送报文数目
·       collisions:发送报文时,检测到冲突的报文数目
·       deferred:因为延时或超时无法发送报文的数目
DCD=DOWN  DTR=UP  DSR=DOWN  RTS=UP  CTS= DOWN
DSR(Data Set Ready)、DTR(Data Terminal Ready)和DCD(Data Carrier Detect)的信号状态,关于DSR、DTR和DCD请参考detect命令
RST(Request to Send)和(CTS)Clear to Send的状态
三层接口的概要信息
·       如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·       如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display standby state命令可以查看该备份接口对应的主接口
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的网络层协议状态显示是UP的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
接口名称缩写
Link
接口物理连接状态,取值可能为:
·       UP:表示本链路物理上是连通的
·       ADM:表示本链路被手工关闭了,需要执行undo shutdown命令才能恢复真实的物理状态
Protocol
接口协议连接状态,取值为UP(s)
Main IP
接口主IP地址
接口的描述信息
Cause
接口物理连接状态为DOWN的原因,取值为Administratively时表示本链路被手工关闭了,需要执行undo shutdown命令才能恢复真实的物理状态
display interface [ aux ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface aux interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:显示指定AUX接口的信息。
【描述】
display interface aux命令用来显示AUX接口的相关信息。
·              如果不指定aux参数,将显示设备支持的所有接口的相关信息。
·              如果指定aux参数,不指定interface-number参数,将显示所有已创建的AUX接口的相关信息。
# 显示AUX接口0的详细信息。
<Sysname> display interface aux 0
Aux0 current state: UP
Description: Aux0 Interface
Physical layer is asynchronous, Baudrate is 9600 bps
Phy-mru is 1700
           0 frame errors
           0 deferred
    DCD=DOWN  DTR=UP  DSR=DOWN  RTS=UP  CTS=DOWN
# 显示AUX接口0的概要信息。
<Sysname> display interface aux 0 brief
Aux0                 DOWN DOWN    --
# 显示所有状态为down的AUX接口的概要信息。
<Sysname> display interface aux brief down
Aux0                 DOWN Not connected
表1-3 display interface aux命令显示信息描述表
Aux0 current state
AUX接口当前的物理状态,状态可能为:
·       DOWN(Administratively):表示该AUX接口已经通过shutdown命令被关闭,即管理状态为关闭
·       DOWN:表示该AUX接口的物理状态为关闭(可能因为没有物理连线或者线路故障)
·       UP:该AUX接口的管理状态和物理状态均为开启
该接口的链路协议状态
接口描述信息
接口的IP地址
AUX接口的数据链路层协议
表示PPP连接建立成功
物理层链路信息,AUX接口的带宽
Phy-mru is 1700
最大接收包长为1700字节
最后一次清除接口统计信息的时间
           0 frame errors
接口收到的总报文数和总字节数:
·       align errors:排列错误
·       aborts:接收报文的异常错误
·       frame errors:帧错误
           0 deferred
接口发送的报文数和总字节数
三层接口的概要信息
接口名称缩写
Link
接口物理连接状态,取值可能为:
·       UP:表示本链路物理上是连通的
Protocol
接口协议连接状态,取值为UP(s)
Main IP
接口主IP地址
接口的描述信息
Cause
display interface [ serial ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface serial interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:显示指定Serial接口的信息。
【描述】
display interface serial命令用来显示Serial接口的相关信息。
·              如果不指定serial参数,将显示设备支持的所有接口的相关信息。
·              如果指定serial参数,不指定interface-number参数,将显示所有已创建的Serial接口的相关信息。
# 显示Serial接口7/1的详细信息。
<Sysname> display interface serial 7/1
Serial7/1 current state: UP
Description: Serial7/1 Interface
Internet Address is 9.9.9.6/24 Primary
Physical layer is synchronous, Baudrate is 64000 bps
Interface is DCE, Cable type is V35, Clock mode is DCECLK
    Last 70 seconds input rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
    Last 70 seconds output rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
    Input: 6668 packets, 80414 bytes
           0 frame errors
    Output:6670 packets, 80446 bytes
           0 deferred
    DCD=UP  DTR=UP  DSR=UP  RTS=UP  CTS=UP
# 显示Serial接口7/1的概要信息。
<Sysname> display interface serial 7/1 brief
S7/1                 UP   UP(s)    --
# 显示所有状态为down的Serial接口的概要信息。
<Sysname> display interface serial brief down
S7/1                 ADM  Administratively
表1-4 display interface serial命令显示信息描述表
串口当前的物理状态,状态可能为:
·       DOWN(Administratively):表示该串口已经通过shutdown命令被关闭,即管理状态为关闭
·       DOWN:表示该串口的物理状态为关闭(可能因为没有物理连线或者线路故障)
·       UP:该串口的管理状态和物理状态均为开启
该接口的链路协议状态
接口描述信息
接口的IP地址
串口的数据链路层协议
表示PPP连接建立成功
物理层链路信息,串口的带宽
同步串口DCE侧的时钟选择方式
最后一次清除接口统计信息的时间
最近70秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近70秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
           0 frame errors
接口收到的总报文数和总字节数:
·       align errors:排列错误
·       aborts:接收报文的异常错误
·       frame errors:帧错误
           0 deferred
接口发送的报文数和总字节数
DSR(Data Set Ready)、DTR(Data Terminal Ready)和DCD(Data Carrier Detect)信号处于up状态,关于DSR、DTR和DCD请参考detect命令
RST(Request to Send)和(CTS)Clear to Send处于up状态
三层接口的概要信息
接口名称缩写
Link
接口物理连接状态,取值可能为:
·       UP:表示本链路物理上是连通的
Protocol
接口协议连接状态,取值为UP(s)
Main IP
接口主IP地址
接口的描述信息
Cause
eliminate-pulse
undo eliminate-pulse
异步串口视图
【缺省级别】
2:系统级
【描述】
eliminate-pulse命令用来消除脉冲宽度小于3.472μs的脉冲,增加信号的可靠性。undo eliminate-pulse命令用来恢复缺省情况。
缺省情况下,消除脉冲宽度小于1.472μs的脉冲。
在线路干扰较大时可以配置本命令。
·       波特率等于115200bps时不能配置该命令,同时配置该命令后,波特率不能等于115200bps。
·       本命令仅用于8ASE/16ASE接口卡/模块。
# 配置接口Async1/0消除脉冲宽度小于3.472μs的脉冲。
[Sysname-Async1/0] eliminate-pulse
1.2.12  idle-mark
idle-mark
undo idle-mark
同步串口视图
【缺省级别】
2:系统级
【描述】
idle-mark命令用来配置同步串口的线路空闲码为“0xFF”。undo idle-mark命令用来恢复缺省情况。
缺省情况下,同步串口的线路空闲码为“0x7E”。
通常情况下,同步串口使用编码“0x7E”来表示线路的空闲状态,而有的设备在空闲时间采用编码“0xFF”(即全“1”的高电平)来表示线路的空闲状态。为了更好的兼容这种设备,需要设置同步串口的线路空闲码。
# 设置同步串口的线路空闲码为“0xFF”。
[Sysname-Serial2/0] idle-mark
undo invert receive-clock
同步串口视图
【缺省级别】
2:系统级
【描述】
invert receive-clock命令用来允许翻转DTE侧同步串口的接收时钟信号。undo invert receive-clock命令用来恢复缺省情况。
缺省情况下,同步串口作为DTE侧时,禁止翻转接收时钟信号。
在某些特殊情况下,为了消除线路上半个时钟周期的时延,可以将DTE侧同步串口的接收时钟信号翻转。只有某些特殊的DCE设备需要配置该命令,对于通常的应用,时钟不应作翻转。
相关配置可参考命令physical-modeinvert transmit-clockclock
# 将DTE侧同步串口的接收时钟翻转。
[Sysname-Serial2/0] invert receive-clock
undo invert transmit-clock
同步串口视图
【缺省级别】
2:系统级
【描述】
invert transmit-clock命令用来允许翻转DTE侧同步串口的发送时钟信号。undo invert transmit-clock命令用来恢复缺省情况。
缺省情况下,同步串口作为DTE侧时,禁止翻转发送时钟信号。
在某些特殊情况下,为了消除线路上半个时钟周期的时延,可以将DTE侧同步串口的发送时钟信号翻转。只有某些特殊的DCE设备需要配置该命令,对于通常的应用,时钟不应作翻转。
相关配置可参考命令physical-modeinvert receive-clockclock
# 将DTE侧同步串口的发送时钟翻转。
[Sysname-Serial2/0] invert transmit-clock
1.2.15  itf
itf number number
undo itf number
同步串口接口视图
【缺省级别】
2:系统级
number number:设置帧间填充字节的个数,取值范围为0~14,单位为字节。
【描述】
itf命令用来设置帧间填充字节的个数。undo itf命令用来恢复缺省情况。
缺省情况下,帧间填充字节个数为4
# 设置串口的帧间填充字节个数为5。
[Sysname-Serial2/0] itf number 5
1.2.16  loopback
loopback
undo loopback
串口视图/AUX接口视图/AM接口视图
【缺省级别】
2:系统级
【描述】
loopback命令用来使能对内自环。undo loopback命令用来恢复缺省情况。
缺省情况下,禁止对内自环。
只有在进行某些特殊功能测试时,才将串口设为对内自环。
# 允许串口对内自环对外环回。
[Sysname-Serial2/0] loopback
1.2.17  mtu
mtu size
undo mtu
【缺省级别】
2:系统级
【描述】
mtu命令用来设置接口的最大传输单元(MTU)值。undo mtu命令用来恢复缺省情况。
缺省情况下,接口的MTU值为1500。
由于QoS队列长度有限,如果MTU太小而报文尺寸较大,可能会造成分片过多,报文被QoS队列丢弃。为避免这种情况,可适当增大QoS队列的长度。接口缺省使用的队列调度机制是FIFO,可以在接口视图下使用命令qos fifo queue-length改变该队列长度。QoS队列的具体配置请参见“ACL和QoS配置指导”中的“拥塞管理”。
接口的MTU影响IP协议报文在该接口上传输时的分片与重组。
需要注意的是,配置了mtu命令后需要执行命令shutdownundo shutdown,这样该配置才能在接口上生效。
# 配置接口Serial2/0的MTU值为1200字节。
[Sysname-Serial2/0] mtu 1200
physical-mode { async | sync }
同/异步串口视图
【缺省级别】
2:系统级
async设置同/异步串口工作在异步方式。
sync:设置同/异步串口工作在同步方式。
【描述】
physical-mode命令用来设置同/异步串口的工作方式。
缺省情况下,同/异步串口工作在同步(sync)方式。
# 设置同/异步串口工作在异步方式。
[Sysname-Serial2/0] physical-mode async
1.2.19  phy-mru
phy-mru mrusize
undo phy-mru
【缺省级别】
2:系统级
mrusize:设置最大接收包长,取值范围为4~1700,单位为字节。
【描述】
phy-mru命令用来设置异步串口工作在流方式下的最大接收包长。undo phy-mru命令用来恢复缺省情况。
缺省情况下,异步串口工作在流方式下的最大接收包长为1700字节。
需要注意的是,phy-mru命令只有在异步流模式下能够成功配置。
# 设置异步串口工作在流方式下的最大接收包长为1500字节。
[Sysname-Serial2/0] async mode flow
[Sysname-Serial2/0] phy-mru 1500
reset counters interface [ analogmodem [ interface-number ] ]
【缺省级别】
2:系统级
analogmodem interface-number:指定AM接口。
【描述】
reset counters interface命令用来清除指定AM接口的统计信息。
·              如果不指定analogmodeminterface-number,则清除所有接口的统计信息;
·              如果指定analogmodem而不指定interface-number,则清除所有AM接口的统计信息;
·              如果同时指定analogmodeminterface-number,则清除指定AM接口的统计信息。
# 清除AM接口的统计信息。
<Sysname> reset counters interface analogmodem 2/0
reset counters interface [ aux [ interface-number ] ]
【缺省级别】
2:系统级
aux interface-number:指定AUX接口。
【描述】
reset counters interface命令用来清除指定AUX接口的统计信息。
·              如果不指定auxinterface-number,则清除所有接口的统计信息;
·              如果指定aux而不指定interface-number,则清除所有AUX接口的统计信息;
·              如果同时指定auxinterface-number,则清除指定AUX接口的统计信息。
# 清除AUX接口的统计信息。
<Sysname> reset counters interface aux 2/0
reset counters interface [ serial [ interface-number ] ]
【缺省级别】
2:系统级
serial interface-number:指定Serial接口。
【描述】
reset counters interface命令用来清除指定Serial接口的统计信息。
·              如果不指定serialinterface-number,则清除所有接口的统计信息;
·              如果指定serial而不指定interface-number,则清除所有Serial接口的统计信息;
·              如果同时指定serialinterface-number,则清除指定Serial接口的统计信息。
# 清除Serial接口的统计信息。
<Sysname> reset counters interface serial 2/0
1.2.23  reverse-rts
reverse-rts
undo reverse-rts
同步串口视图
【缺省级别】
2:系统级
【描述】
reverse-rts命令用来为了特定的调试需要,在同步方式下翻转RTS信号。undo reverse-rts命令用来恢复缺省情况。
缺省情况下,不翻转RTS信号。
reverse-rts命令常用于硬件流控方式下,本端发送时不允许对端发送数据的情况。
# 翻转RTS信号。
[Sysname-Serial2/0] reverse-rts
1.2.24  timer hold
timer hold seconds
undo timer hold
【缺省级别】
2:系统级
seconds:接口发送keepalive报文的周期,取值范围为0~32767,单位为秒。
【描述】
timer hold命令用来配置轮询时间间隔,轮询时间间隔指的是接口发送keepalive报文的周期。undo timer hold命令用来恢复缺省情况。
缺省情况下,轮询时间间隔为10秒。
# 允许Serial2/0轮询时间间隔为20秒。
[Sysname-Serial2/0] timer hold 20
virtualbaudrate virtualbaudrate
undo virtualbaudrate
同步串口视图
【缺省级别】
2:系统级
virtualbaudrate:指定的波特率,需要与DCE侧的配置保持一致。其取值范围为1200、2400、4800、9600、19200、38400、56000、57600、64000、72000、115200、128000、192000、256000、384000、512000、768000、1024000、2048000、4096000,单位bps。
【描述】
virtualbaudrate命令用来配置DTE接口的虚拟波特率。undo virtualbaudrate命令用来取消虚拟波特率的配置。
当串口工作为DTE模式时,接口波特率通过协商从对端(DCE侧)获得。virtualbaudrate命令给用户提供一种手工配置DTE侧波特率的方式。
需要注意的是,如果接口时钟方式为dteclk5时钟模式,配置的虚拟波特率就是线路速率。
相关配置可参考命令baudrateclock
·       baudratevirtualbaudrate不能在链路的同一端配置,baudrate用于DCE端,virtualburdrate用于DTE端(仅同步模式)。
·       通过display interface命令看到的是接口的baudrate;而在DTE端,通过display interface命令看到的是接口的virtualbaudrate
# 为DTE接口设置虚拟波特率为19200bps。
[Sysname-Serial2/0] virtualbaudrate 19200
1.3  3G Modem基本配置命令
undo autodeploy sms enable
【缺省级别】
2:系统级
【描述】
autodeploy sms enable命令用于使能路由器短信部署功能。
undo autodeploy sms enable命令用于关闭路由器短信部署功能。
缺省情况下,路由器短信部署功能处于使能状态
# 关闭短信部署功能
[Sysname]undo autodeploy sms enable
display cellular interface-number all [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:所有3G Modem的呼叫连接信息。
【描述】
display cellular用来显示3G Modem的呼叫连接信息。
# 显示3G Modem的呼叫连接信息(WCDMA制式)。
<Sysname> display cellular 0/0 all
Modem State:
Hardware Information
Model = E176G
Modem Firmware Version = 11.124.05.04.112
Hardware Version = CD25TCPV
International Mobile Subscriber Identity (IMSI) = 460016004345081
International Mobile Equipment Identity (IMEI) = 357267023325644
Factory Serial Number (FSN) =  GB5TAA1981305641
Modem Status = Online
Profile Information
Profile 1 = ACTIVE
PDP Type = IPv4, Header Compression = OFF
Data Compression = OFF
Access Point Name (APN) = 3gnet
Packet Session Status = Active
* - Default profile
Network Information
Current Service Status = Service available
Current Service = Combined
Packet Service = Attached
Current Roaming Status = Home
Network Selection Mode = Manual
Network Connection Mode = Auto
Current Network Connection = HSDPA and HSUPA
Mobile Country Code (MCC) = 460
Mobile Network Code (MNC) = 01
Location Area Code (LAC) = 248
Cell ID = 20021
Downstream Bandwidth = 7200000 bps
Radio Information
Current Band = ANY
Current RSSI = -87 dBm
Modem Security Information
PIN Verification = Disabled
PIN Status = Ready
Number of Retries remaining = 3
SIM Status = OK
表1-5 display cellular all命令显示信息描述表(WCDMA制式)
Modem State
3G Modem状态
硬件信息
Model
3G Modem名称
3G Modem的软件版本号
Hardware Version
3G Modem的硬件版本号
SIM卡的IMSI号码串
3G Modem的IMEI串号
3G Modem的产品序列号
Modem Status
3G Modem的状态:
·       online:3G Modem处于上电状态
·       offline:3G Modem处于下电状态或省电模式,cellular接口功能不可用
Profile Information
3G Modem的参数模板信息
Profile 1
3G Modem的PDP设置状态:
·       ACTIVE:已经配置参数模板
·       UNDEFINED:还为配置参数模板,cellular接口不可用,需要通过profile create命令创建profile
PDP Type
PDP类型,只有Profile 1 = ACTIVE时,才显示该信息:
·       IPv4:PDP协议类型为IPv4
·       Ipv6:PDP协议类型为IPv6
·       PPP:PDP协议类型为PPP透传
Header Compression
PDP头压缩模式:
·       ON:使能PDP头压缩
·       OFF:禁止PDP头压缩
Data Compression
PDP数据压缩模式:
·       ON:使能PDP数据压缩
·       OFF:禁止PDP数据压缩
Access Point Name
接入点名称
PDP的激活状态:
·       Active:处于激活状态,3G Modem正在进行PPP传输
·       Inactive:处于非激活状态,3G Modem接口的物理状态为Down
Network Information
网络信息
3G Modem的服务状态:
·       Service available:提供有效服务
·       Emergency:提供有限制服务,Cellular接口功能不可用
·       No service:无法提供服务,Cellular接口功能不可用
·       Low power:处于省电模式,Cellular接口功能不可用
Current Service
当前服务类型:
·       Circuit-switched:仅CS域服务
·       Packet-switched:仅PS域服务
·       Combined:CS和PS域服务都有效
·       Invalid:服务无效
Packet Service
3G Modem PS域附着状态:
·       Detached:分离状态,Cellular接口功能不可用
·       Attached:连接状态
PDP的激活状态:
漫游状态:
·       Roaming:漫游状态
·       Home:本地状态
网络选择模式:
·       Manual:手动选择
·       Automatic:自动选择
网络连接模式:
·       WCDMA only:仅连接WCDMA网络
·       WCDMA precedence:优先连接WCDMA网络
·       GSM only:仅连接GSM网络
·       GSM precedence:优先连接GSM网络
·       Auto
当前网络连接:
·       No Service:无服务
·       GSM:GSM网络
·       GPRS:GPRS网络
·       EDGE:EDGE网络
·       WCDMA:WCDMA网络
·       HSDPA:HSDPA网络
·       HSUPA:HSUPA网络
·       HSDPA and HSUPA:HSDPA和HSUPA网络
·       HSPA+:HSPA+网络
·       Unknown:未知网络
Mobile Country Code
移动国家码,搜索到网络后才能显示该信息。例如:中国大陆的国家码为460
Mobile Network Code
运营商网络代码,成功注册到网络后才能显示该信息。例如:中国联通GSM网络代码为01
Location Area Code
位置码信息,成功注册到网络后才能显示该信息
Cell ID
小区信息,成功注册到网络后才能显示该信息
下行理论带宽,单位bps
Radio Information
无线电通信信息
Current Band
当前频带选择模式:
·       GSM:选择GSM网络频带
·       WCDMA:选择WCDMA网络频带
·       ANY:选择任意频带
·       AUTO:自动选择频带
Current RSSI
当前信号质量:
·       -信号质量的取值范围为-110dBm ~ -51dBm
·       Unknow:无信号,Cellular接口功能不可用
Modem安全信息
PIN Verification
PIN 认证状态:
·       Disabled:未使能PIN认证
·       Enabled:使能了PIN认证
PIN Status
·       Ready:USIM/SIM卡状态正常无认证请求
·       PIN Requirement:USIM/SIM卡有PIN认证请求
·       PUK Requirement:USIM/SIM卡有PUK认证请求
PIN或PUK剩余尝试次数
SIM Status
SIM卡状态:
·       OK:SIM卡状态正常
·       Network Reject:SIM卡被拒绝接入网络,Cellular接口功能不可用
·       Not Insert:未插入SIM卡,Cellular接口功能不可用
# 显示3G Modem的呼叫连接信息(TD-SCDMA制式)。
Modem State:
Model = ET128
Modem Firmware Version = 11.101.01.08.00
Hardware Version =  CS31TCPU
International Mobile Subscriber Identity (IMSI) = 460079011105842
International Mobile Equipment Identity (IMEI) = 860039002369111
Factory Serial Number (FSN) =  GQ4CAB1942911350
Profile Information
Profile 1 = ACTIVE
Access Point Name (APN) = cmnet
* - Default profile
Network Information
Network Selection Mode = Automatic
Network Connection Mode = TD-SCDMA precedence
Mobile Network Name = CHINA MOBILE
Downstream Bandwidth = 2800000 bps
Radio Information
Current RSSI = -75 dBm
PIN Status = Ready
SIM Status = OK
表1-6 display cellular all命令显示信息描述表(TD-SCDMA制式)
Modem State
3G Modem状态
硬件信息
Model
3G Modem名称
3G Modem的软件版本号
Hardware Version
3G Modem的硬件版本号
SIM卡的IMSI号码串
3G Modem的IMEI串号
3G Modem的产品序列号
Modem Status
3G Modem的状态:
Profile Information
3G Modem的参数模板信息
Profile 1
3G Modem的PDP设置状态:
·       ACTIVE:已经配置参数模板
·       UNDEFINED:还未配置参数模板,cellular接口不可用,需要通过profile create命令创建profile
PDP Type
·       IPv4:PDP协议类型为IPv4
·       Ipv6:PDP协议类型为IPv6
·       PPP:PDP协议类型为PPP透传
Header Compression
PDP头压缩模式:
·       ON:使能PDP头压缩
·       OFF:禁止PDP头压缩
Data Compression
PDP数据压缩模式:
·       ON:使能PDP数据压缩
·       OFF:禁止PDP数据压缩
Access Point Name
接入点名称
PDP的激活状态:
Network Information
网络信息
3G Modem的服务状态:
网络选择模式:
·       Manual:手动选择
·       Automatic:自动选择
网络连接模式:
·       TD only:仅连接TD-SCDMA网络
·       TD precedence:优先连接TD-SCDMA网络
·       GSM only:仅连接GSM网络
当前网络连接:
·       No Service:无服务
·       GSM:GSM网络
·       GPRS:GPRS网络
·       EDGE:EDGE网络
·       TD-SCDMA:TD-SCDMA网络
·       HSDPA:HSDPA网络
·       Unknown:未知网络
Mobile Network Name
移动网络名称
下行理论带宽,单位bps
Radio Information
无线电通信信息
Current RSSI
当前信号质量:
Modem安全信息
PIN Verification
PIN 认证状态:
·       Disabled:未使能PIN认证
·       Enabled:使能了PIN认证
PIN Status
PIN或PUK剩余尝试次数
SIM Status
SIM卡状态:
·       OK:SIM卡状态正常
# 显示3G Modem的呼叫连接信息(CDMA制式)。
Modem State:
Model = EC169
Manufacturer = HUAWEI TECHNOLOGIES CO.
Modem Firmware Version = 11.002.03.01.45
Hardware Version =  CE62TCPUVer A
Electronic Serial Number (ESN) = c1836f2d
Preferred Roaming List (PRL) Version = 0
International Mobile Subscriber Identity (IMSI) = 460036101433925
Network Information
Network Connection Mode = HYBRID
Current Network Connection = 1xRTT/EVDO HYBRID
Downstream Bandwidth = 3100000 bps
Radio Information
Current RSSI(1xRTT) = -93 dBm
Current RSSI(EVDO) = -75 dBm
Current Voltage = 3336 mV
PIN Status = Ready
UIM Status = OK
表1-7 display cellular all命令显示信息描述表(SCDMA制式)
Modem State
3G Modem状态
硬件信息
Model
3G Modem名称
Manufacturer
设备生产商
3G Modem的软件版本号
Hardware Version
3G Modem的硬件版本号
3G Modem的产品序列号
Preferred Roaming List (PRL) Vertion
首选漫游列表版本
SIM卡的IMSI号码串
Modem Status
3G Modem的状态:
Network Information
网络信息
3G Modem的服务状态:
漫游状态:
·       Roaming:漫游状态
·       Home:本地状态
网络选择模式:
·       Manual:手动选择
·       Automatic:自动选择
当前网络连接:
·       No Service:无服务
·       1xRTT/EVDO HYBRID: 1xRTT和EVDO混合网络
·       EVDO: EVDO网络
·       1xRTT: 1xRTT网络
·       Unknown:未知网络
下行理论带宽,单位bps
Radio Information
无线电通信信息
Current RSSI (1xRTT)
当前1xRTT网络信号质量:
·       -信号质量的取值范围为-125dBm ~ -75dBm
·       Unknow:无信号
Current RSSI (EVDO)
当前EVDO网络信号质量:
·       -信号质量的取值范围为-120dBm ~ -60dBm
Unknow:无信号
Current Voltage
UIM卡电压值,单位mV
Modem安全信息
PIN Verification
PIN 认证状态:
·       Disabled:未使能PIN认证
·       Enabled:使能了PIN认证
PIN Status
PIN或PUK剩余尝试次数
SIM Status
SIM卡状态:
·       OK:SIM卡状态正常
display interface [ cellular ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface cellular interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:显示指定Cellular接口的信息。
【描述】
display interface cellular命令用来显示Cellular接口的相关信息。
·              如果不指定cellular参数,将显示设备支持的所有接口的相关信息。
·              如果指定cellular参数,不指定interface-number参数,将显示所有已创建的Cellular接口的相关信息。
# 显示Cellular接口0/0的详细信息。
<Sysname> display interface cellular0/0
Cellular0/0 current state: UP
Line protocol current state: UP (spoofing)
Description: Cellular0/0 Interface
The Maximum Transmit Unit is 1448, Hold timer is 10(sec)
Internet Address is negotiated, 124.127.32.235/32
USB Modem State: Present
Transfer time: 00:01:30
    Input: 280 packets, 205297 bytes
           0 frame errors
    Output:189 packets, 210072 bytes
           0 deferred
# 显示Cellular接口0/0的概要信息。
<Sysname> display interface cellular0/0 brief
Cellular0/0          UP   UP(s)    --
# 显示所有状态为down的Cellular接口的概要信息。
<Sysname> display interface cellular brief down
Cellular0/0          DOWN Not connected
表1-8 display interface cellular命令显示信息描述表
Cellular接口当前的物理状态,状态可能为:
·       DOWN(Administratively):表示该Cellular接口已经通过shutdown命令被关闭,即管理状态为关闭
·       DOWN:表示该Cellular接口的物理状态为关闭(可能因为没有物理连线或者线路故障)
·       UP:该Cellular接口的管理状态和物理状态均为开启
该接口的链路协议状态
接口描述信息
接口的IP地址
Cellular接口的数据链路层协议
表示PPP连接建立成功
3G Modem的在位状态(3G Modem是否已经插入设备):
·       Present:在位
·       Not present:不在位
接口UP的持续时间
最后一次清除接口统计信息的时间
           0 frame errors
接口收到的总报文数和总字节数:
·       align errors:排列错误
·       aborts:接收报文的异常错误
·       frame errors:帧错误
           0 deferred
接口发送的报文数和总字节数
三层接口的概要信息
接口名称缩写
Link
接口物理连接状态,取值可能为:
·       UP:表示本链路物理上是连通的
Protocol
接口协议连接状态,取值为UP(s)
Main IP
接口主IP地址
接口的描述信息
Cause
1.3.4  dm-port open
dm-port open
undo dm-port
Cellular接口视图
【缺省级别】
2:系统级
open:打开Cellular接口的调试功能。
【描述】
dm-port open命令用来打开Cellular接口的调试功能。undo dm-port 命令用来关闭Cellular接口的调试功能。
缺省情况下,该功能处于关闭状态。
# 打开Cellular接口的调试功能。
[Sysname] interface cellular 0/0
[Sysname-Cellular0/0] dm-port open
1.3.5  mode cdma
mode cdma { 1xrtt-only | evdo-only | hybrid }
Cellular接口视图
【缺省级别】
2:系统级
1xrtt-only:设置3G Modem只选择1x RTT网络。
evdo-only:设置3G Modem只选择EVDO网络。
hybrid:设置3G Modem只选择EVDO和1x RTT混合网络。
【描述】
mode cdma命令用来选择CDMA网络连接方式。
# 设置3G Modem只选择EVDO网络。
[Sysname-Cellular0/0] mode cdma evdo-only
1.3.6  mode td-scdma
mode td-scdma { gsm-only | gsm-precedence | td-only | td-precedence }
Cellular接口视图
【缺省级别】
2:系统级
gsm-only:设置3G Modem只选择GSM网络。
gsm-precedence:设置3G Modem优先选择GSM网络。
td-only:设置3G Modem只选择TD-SCDMA网络。
td-precedence:设置3G Modem优先选择TD-SCDMA网络。
【描述】
mode td-scdma命令用来选择TD-SCDMA网络连接方式。
# 设置3G Modem优先选择TD-SCDMA网络。
[Sysname-Cellular0/0] mode td-scdma td-precedence
1.3.7  mode wcdma
mode wcdma { gsm-only | gsm-precedence | wcdma-only | wcdma-precedence }
Cellular接口视图
【缺省级别】
2:系统级
wcdma-only:设置3G Modem只选择WCDMA网络。
wcdma-precedence:设置3G Modem优先选择WCDMA网络。
【描述】
mode wcdma命令用来选择WCDMA网络连接方式。
# 设置3G Modem优先选择WCDMA网络。
[Sysname-Cellular0/0] mode wcdma wcdma-precedence
undo modem auto-recovery enable
Cellular接口视图
【缺省级别】
2:系统级
【描述】
modem auto-recovery enable命令用来使能强制自动恢复功能。undo modem auto-recovery enable命令用来恢复缺省情况。
缺省情况下,禁止强制自动恢复功能。
开启此功能时,如果连续多次拨号失败,则自动复位Modem。关闭此功能时,系统仅在3G Modem上次复位后有过至少一次拨号成功记录,并且多次拨号失败的情况下才会自动复位3G Modem。连续几次拨号失败后复位3G Modem,通过modem response命令的auto-recovery参数设置。
·              此功能用于防止因3G网络的异常而导致的链路无法恢复的问题。
·              开启此功能后,需要保证其他配置正确,否则会因配置错误导致Modem复位。
相关配置可参考命令modem response
# 使能强制自动恢复功能。
[Sysname]interface cellular 1/0
[Sysname-Cellular0/0] modem auto-recovery enable
1.3.9  modem reboot
modem reboot
Cellular接口视图
【缺省级别】
2:系统级
【描述】
modem reboot命令用来手动重启3G Modem。
3G Modem在运行过程中能够自动检测异常,并实施自动重启。如果无法自动重启,用户可以通过该命令手动重启3G Modem。
[Sysname-Cellular0/0] modem reboot
modem response timer time auto-recovery threshold
undo modem response
Cellular接口视图
【缺省级别】
2:系统级
time:超时时间,取值范围为1~300,单位为秒,缺省值为10秒。
threshold:3G Modem连续不响应系统命令次数的阈值,达到阈值后系统自动复位3G Modem。取值范围为0~10,缺省值为3。当threshold配置为0时,关闭自动恢复功能。
【描述】
modem response命令用来配置系统向3G Modem下发AT命令后,等待其回复的时间间隔,以及3G Modem连续不响应系统命令次数的阈值,达到系统配置的阈值后,自动复位3G Modem。
undo modem response命令用来恢复缺省配置。
相关配置可参考命令modem auto-recovery enable
# 配置系统向3G Modem下发AT命令时,等待其回复的时间间隔为20秒,配置3G Modem模块连续不响应系统命令次数的阈值为4。
[Sysname-Cellular0/0] modem response timer 20 auto-recovery 4
1.3.11  pin modify
pin modify current-pin new-pin
Cellular接口视图
【缺省级别】
2:系统级
current-pin:插在Modem上的SIM/UIM卡的PIN码,由4-8位数字组成。
new-pin:用户重新设置的PIN码,由4-8位数字组成。
【描述】
pin modify命令用来修改SIM/UIM卡的PIN码,修改后的PIN码保存在SIM/UIM卡上。
# 修改PIN码。
[Sysname-Cellular0/0]pin modify 1234 4321
Warning: PIN will be changed to “4321”. Continue? [Y/N]:y
PIN has been changed successfully.
1.3.12  pin unlock
pin unlock puk new-pin
Cellular接口视图
【缺省级别】
2:系统级
puk:插在Modem上的SIM/UIM卡的PUK,由网络提供商提供,由8位数字组成。
【描述】
pin unlock命令用来对3G Modem上的SIM/UIM卡进行PIN解锁。进行认证时,如果连续三次输入错误的PIN码,则PIN码会被锁住,需要用户使用PUK码才能将PIN码解锁,否则3G Modem的数据通信功能不可用。
# 使用PUK码解锁PIN码。
[Sysname-Cellular0/0] pin unlock 87654321 1234
Warning: PIN will be unlocked and changed to “1234”. Continue? [Y/N]:y
PIN has been unlocked changed successfully.
pin verification { enable | disable } [ pin ]
Cellular接口视图
【缺省级别】
2:系统级
enable:使能PIN码认证功能。
disable:禁止PIN码认证功能。
【描述】
pin verification命令用来使能或禁止3G Modem的PIN码认证功能。
# 开启PIN码认证功能。
[Sysname-Cellular0/0] pin verification enable 1234
1.3.14  pin verify
pin verify [ cipher | simple ] pin
Cellular接口视图
【缺省级别】
2:系统级
simple:以明文方式为插在3G Modem上的SIM/UIM卡设置PIN码,由4-8位数字组成。
cipher:以密文方式为插在3G Modem上的SIM/UIM卡设置PIN码,输入的pin码是经过加密运算后的密文,由37-41个字符的字符串组成,区分大小写。
pin:如果不输入simplecipher关键字时,以明文的方式为插在3G Modem上的SIM/UIM卡设置PIN码,由4-8位数字组成。
【描述】
pin verify命令用来进行3G Modem的PIN码认证。
缺省情况下,没有为插在3G Modem上的SIM/UIM卡设置PIN码。
如果3G Modem使能了PIN认证功能,当Modem复位时,会要求用户输入PIN进行认证,否则Modem数据通信功能不可用。复位Modem的途径包括:重启设备、使用modem reboot命令重启Modem、热拔插USB 3G Modem。对于SIC-3G-CDMA模块,只有设备冷启动后,才需要重新进行PIN码认证。
# 进行PIN码认证功能。
[Sysname-Cellular0/0] pin verify 1234
1.3.15  plmn search
plmn search
Cellular接口视图
【缺省级别】
2:系统级
【描述】
plmn search命令用来搜索移动网络。本命令不属于配置命令,属于一种网络探测命令。
搜索移动网络需要等待几分钟,完成搜索后,命令行会给出提示,显示搜索到的移动网络。
# 搜索移动网络。
[Sysname-Cellular0/0] plmn search
1.3.16  plmn select
plmn select { auto | manual mcc mnc }
Cellular接口视图
【缺省级别】
2:系统级
auto:表示自动选择PLMN(Public Land Mobile Network,公共地带移动网络)。
manual:表示人工指定Modem的PLMN。
mcc:移动国家编码(mobile country code),取值范围为0~65535。
mnc:移动网络编码(mobile network code),取值范围为0~65535。
【描述】
plmn select命令用来配置搜索移动网络的方式。
缺省情况下,采用auto方式。
# 配置搜索移动网络的方式为manual方式。
[Sysname-Cellular0/0] plmn select manual 65524 65524
profile create profile-number { dynamic | static apn } authentication-mode authentication [ user username ] [ password password ]
profile delete profile-number
Cellular接口视图
【缺省级别】
2:系统级
profile-number:3G Modem的参数模板。只能输入1,目前只支持创建1个Profile。
dynamic:由运营商根据CHAP/PAP用户名和密码动态分配接入点。
static apn:指定的接入点名称,由运营商提供,为1~100个字符的字符串。
authentication-mode authentication:认证方式可以是nonepapchap
user username:用户名,由运营商提供。为1~32个字符的字符串,区分大小写。
password password:认证密码,由运营商提供。为1~32个字符的字符串,区分大小写。
【描述】
profile create命令用来 创建3G Modem的参数模板。profile delete命令用来删除3G Modem的参数描述模板。
缺省情况下,不存在参数模板。
# 创建3G Modem的参数模板,指定的接入点名称为cmnet,认证方式采用pap
[Sysname-Cellular0/0] profile create 1 static cmnet authentication-mode pap user abc password abc
recovery track track-entry-number delay delay-time consecutive times
undo recovery track
Cellular接口视图
【缺省级别】
2:系统级
track-entry-number:指定Track项序号,取值范围是1~1024。
delay delay-time:指定3G Modem开始自动恢复,并等待Track模块报告Positive事件的最长时间,单位为分,取值范围是1~1440。如果接口在该时间内没有收到Positive事件,则3G Modem将重复进行自动恢复,直到收到Positive事件或达到用户配置的最大恢复次数。该时间应大于3G Modem完成自动恢复的最大时间和监测模块检测成功并报告Positive事件的最大时间之和。
consecutive times:指定3G Modem连续自动恢复的最大次数,取值范围是0~10。当取值为0时,不限制自动恢复次数。当接口收到Positive事件时,系统会将此计数器清零。
【描述】
recovery track命令用来配置Cellular接口与Track项关联,同时配置3G Modem自动恢复参数。undo recovery track命令用来取消Cellular接口与Track项的关联。
缺省情况下,Cellular接口没有与Track项关联。
本功能将Cellular接口通过Track模块与监测模块实现联动。例如,监测模块使用NQA ICMP-echo测试,当目的主机不可达时,会通过Track模块通知接口Negative事件。当NQA发现链路恢复时,通过Track模块通知接口Positive事件。
配置本功能后,Cellular接口在收到Negative事件时,系统会判断接口曾经是否收到过Positive事件:
(1)      如果收到过,则3G Modem开始自动恢复。同时,如果在delay-time设定的时间内没有收到Positive事件,则重复自动恢复3G Modem。
(2)      如果没有收到过,则说明业务一直没有正常运行,可能是由于配置错误导致,系统将不做任何处理。
·              接口上所关联的Track项可以是尚未创建的Track项。但是,只有通过track命令创建了该Track项后,探测功能才开始生效。
·              监测模块检测成功并通知Track模块报告Positive事件的最大时间与监测模块的配置有关。例如,使用NQA ICMP-echo测试目的主机是否可达时,frequency命令的配置将决定连续两次测试开始的时间间隔,间隔越大,监测模块检测到链路恢复并通知Track模块报告Positive事件的最大时间也越长。因此,在配置recovery track命令的delay参数时,delay-time的值应大于3G Modem自动恢复的最大时间与监测模块frequency命令设置的时间间隔之和。
·              在3G网络正常状态下,3G Modem自动恢复的时间一般在1分钟以内。
·              配置recovery track命令后,只有在收到Positive事件后,3G Modem自动恢复功能才生效。
·              Cellular接口undo shutdown后,只有在收到Positive事件后,3G Modem自动恢复功能才生效。
# 创建ICMP-echo类型的NQA测试组(管理员为admin,操作标签为test)。
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] destination ip 172.31.21.1
# 配置icmp-echo发送频率为5分钟。
[Sysname-nqa-admin-test-icmp-echo] frequency 300000
# 配置联动项1,连续失败3次触发联动。
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
# 启动ICMP-echo测试操作。
[Sysname-nqa-admin-test-icmp-echo] nqa schedule admin test start-time now lifetime forever
# 配置Track项1,关联NQA测试组的联动项1。
[Sysname] track 1 nqa entry admin test reaction 1
# 在cellular 2/0接口上配置3G Modem自动恢复功能与Track 1联动,设置3G Modem开始自动恢复后等待positive事件的最大时间为15分钟,不限制连续自动恢复的次数。
[Sysname] interface cellular 2/0
[Sysname-Cellular2/0]recovery track 1 delay 15 consecutive 0
reset counters interface [ cellular [ interface-number ] ]
【缺省级别】
2:系统级
cellular interface-number:指定Cellular接口。
【描述】
reset counters interface命令用来清除指定Cellular接口的统计信息。
·              如果不指定cellularinterface-number,则清除所有接口的统计信息;
·              如果指定cellular而不指定interface-number,则清除所有Cellular接口的统计信息;
·              如果同时指定cellularinterface-number,则清除指定Cellular接口的统计信息。
# 清除Cellular接口的统计信息。
<Sysname> reset counters interface cellular 0/0
1.3.20  rssi
rssi { gsm | 1xrtt | evdo } { low lowthreshold | medium mediumthreshold }*
undo rssi { gsm | 1xrtt | evdo } [ low | medium ]
Cellular接口视图
【缺省级别】
2:系统级
gsm:gsm网络制式。
1xrtt:1xrtt网络制式。
evdo:evdo网络制式。
low:信号过低阈值类型。
medium:信号正常阈值类型。
lowthreshold:指定信号过低时RSSI的监控阈值,范围为-150~0,缺省值为-150,单位为dBm。
mediumthreshold:指定信号正常时RSSI的监控阈值,范围为-150~0,缺省值为0,单位为dBm。
【描述】
rssi命令用于配置3G网络RSSI监控阈值,用户可以通过监控RSSI值来了解信号强弱的变化。配置mediumthreshold必须大于等于lowthreshold
undo rssi命令用来恢复缺省设置。
在环境因素相同的情况下,当信号强弱发生变化时,RSSI值也会发生变化:
·              如果RSSI值大于mediumthreshold,则发送一次显示信号强的trap信息;
·              如果RSSI值小于等于mediumthreshold且大于lowthreshold,则发送一次显示信号正常的trap信息;
·              如果RSSI值小于等于lowthreshold,则发送一次显示信号弱的trap信息,此后,如果RSSI值一直小于等于lowthreshold,则每10分钟发送一次显示信号弱的trap信息。
# 设置GSM网络制式RSSI的lowthreshold值为-110。
[Sysname-Cellular0/0] rssi gsm low -110
1.3.21  trust-imsi
trust-imsi IMSI-string
undo trust-imsi [ IMSI-string ]
Cellular接口视图
【缺省级别】
2:系统级
IMSI-string表示需要绑定的IMSI,为132个字符的字符串。
【描述】
trust-imsi命令用于配置3G Modem信任的IMSI,启用本地IMSI绑定功能。undo trust-imsi命令用于恢复缺省情况,命令带有参数IMSI-string表示删除指定的IMSI。
缺省情况下,3G Modem未绑定本地IMSI。
一个Cellular接口允许3G Modem最多绑定16条IMSI。
# 配置3G Modem信任的IMSI。
[Sysname] interface Cellular 0/0
[Sysname] trust-imsi 657800192784765
sms sending-enable
undo sms sending-enable
Cellular接口视图
【缺省级别】
2:系统级
【描述】
sms sending-enable命令用于使能路由器发送短信功能,undo sms sending-enable命令用于恢复缺省情况。
缺省情况下,路由器发送短信功能未开启。但转发短信和部署短信处理结果的回应短信功能不受限制。
USB 3G Modem不支持短信发送功能。
# 禁止路由器主动发送短信功能
[Sysname-Cellular0/0] undo sms sending-enable
undo snmp-agent trap enable sms
【缺省级别】
2:系统级
【描述】
snmp trap enable sms命令用于使能路由器以trap方式发送接收到的短信。
undo snmp trap enable sms命令用于关闭路由器以trap方式发送收到的短信内容。
缺省情况下,路由器以trap方式发送短信功能处于使能状态。
# 禁止路由器以trap方式发送收到短信
[Sysname] undo snmp trap enable sms
1.3.24  sms send
sms send destination-number
Cellular接口视图
【缺省级别】
2:系统级
destination-number:发送短信的目的号码。可以包含的字符有“+,0~9,*,#”,其中“+”只能出现在开头,并且只能出现一次,以“+”开头时最大长度为21个字符,以其他字符开头时最大长度为20个字符。
【描述】
sms send命令用来通过3G Modem向指定的目的号码发送短信。
执行命令后根据提示输入短信内容。目前仅支持发送英文短信内容,长度为0~160个字符,短信以“%”字符为结束符,“%”不计入短信内容长度。“换行符”占2个字符,可以出现在短信内容中。
# 在Cellular0/0接口下发短信,目的号码是13612345678,内容是“Hello world!”。
[Sysname-Cellular0/0] sms send 13612345678
Please input SMS content, and quit with the character '%'.
Hello world!%
1.3.25  sms delete
sms delelte { all | sms-id id }
Cellular接口视图
【缺省级别】
2:系统级
all:删除所有短信。
sms-id id:删除指定ID的短信,取值范围是0~255。
【描述】
sms delete命令用来删除保存在SIM卡中的短信。
# 删除Cellular0/0接口下的所有短信。
[Sysname-Cellular0/0] sms delete all
1.3.26  display sms
display sms interface interface-type interface-number { summary | verbose [ sms-id id ] }
【缺省级别】
1:监控级
interface-type:接口类型
interface-number:接口编号。
summary:显示短信的概要信息。
verbose:显示短信的详细内容。
sms-id id:显示指定ID的短信内容,取值范围是0~255。
【描述】
display sms命令用来查看短信的概要信息或者详细内容。
# 查看Cellular0/0接口的短信概要信息。
<Sysname> display sms interface cellular 0/0 summary
Total SMS in SIM: 3
Inbox:
ID  FROM                   DATE        TIME      CONTENT
18  +8618910320369         2012/05/15  10:36:36  1234567890...
17  +8614701219271         2012/05/14  18:03:41  cccccccccc...
16  +8614701219271         2012/05/14  18:03:04  zzzzzzzzzz
表1-9 display sms summary命令显示信息描述表
Total SMS in SIM
SIM卡中短信的数量
Inbox
收件箱
ID
短信ID
FROM
短信源号码
DATE
短信日期
TIME
短信时间
CONTENT
短信内容概要
# 查看Cellular0/0接口的全部短信详细内容。
<Sysname> display sms interface cellular 0/0 verbose
Total SMS in SIM: 3
Inbox:
ID: 18; TIME: 2012/05/15 10:36:36; FROM: +8618910320369
123456789012345@
ID: 17; TIME: 2012/05/14 18:03:41; FROM: +8614701219271
cccccccccccc
ID: 16; TIME: 2012/05/14 18:03:04; FROM: +8614701219271
Zzzzzzzzzz
# 查看Cellular0/0接口的ID为18的短信详细内容。
<Sysname> display sms interface cellular 0/0 verbose sms-id 18
123456789012345@
display sms interface interface-type interface-number statistics
【缺省级别】
1:监控级
interface-type:接口类型
【描述】
display sms statistics命令用来显示短信的统计信息。
# 显示Cellular0/0接口的短信统计信息。
<Sysname> display sms interface cellular 0/0 statistics
Storage records in SIM = 20
Storage records used = 9
Total SMS received since booting up = 8
Total SMS sent successfully since booting up = 5
Total SMS sent failure since booting up = 1
Total SMS deleted since booting up = 2
表1-10 display sms statistics命令显示信息描述表
SIM卡中可存储短信的数量
存储空间中已有短信的数量
Modem启动后收到的短信的数量
Modem启动后发送短信成功的数量
Modem启动后发送短信失败的数量
Modem启动后删除短信的数量
1.3.28  sms forward
sms forward source-number source-number destination-number destination-number
undo sms forward [ source-number source-number [ destination-number destination-number ] ]
Cellular接口视图
【缺省级别】
2:系统级
source-number source-number:转发从该号码发来的短信。source-number为“+*#0123456789.t”中的字符组合形成的字符串。其中“+”只能出现在开头,并且只能出现一次,以“+”开头时最大长度为21个字符,以其他字符开头时最大长度为20个字符。
通过为source-number配置号码匹配规则,可以模糊匹配多个短信源号码,匹配规则如下:
·              “.”表示一位有效数字;
·              “t”表示其后省略0位或多位数字,即表示以“t”前面字符开头的所有号码,“t”前面必须有字符,“t”后面不能有字符,如“138t”表示匹配以138开头的所有号码;
·              “.t”表示匹配任意号码;
·              “+t”是不合法的字符串;
·              如果源号码中包含国家码,如“+86”,则转发规则中的source-number也需要包含“+86”字符,否则会匹配失败。
destination-number destination-number:转发短信至该号码。destination-number为“+*#0123456789”中的字符组合形成的字符串。其中“+”只能出现在开头,并且只能出现一次,以“+”开头时最大长度为21个字符,以其他字符开头时最大长度为20个字符。目的号码不支持模糊匹配。允许用户设置多个短信转发目的号码,号码之间使用空格分隔,如destination-number 13612345678 13566667777。
【描述】
sms forward命令用来配置短信转发规则。undo sms forward命令用来删除短信转发规则。
最多可以配置10条规则。匹配顺序按配置的先后顺序,一旦源号码匹配成功,则不再继续匹配后续规则。
缺省情况下,没有配置短信转发规则。
# 在Cellular0/0接口下配置短信转发,将以0108277开头的源号码的短信转发至目的号码13612345678和13566667777。
[Sysname-Cellular0/0] sms forward source-number 0108277t destination-number 13612345678 13566667777
1.4  CE1/PRI接口基本配置命令
1.4.1  alarm
alarm detect rai
undo alarm detect rai
CE1/PRI接口视图
【缺省级别】
2:系统级
detect:接口的定时检测功能。
raiRemote Alarm Indication,即远端告警指示信号。
【描述】
alarm命令用来配置检测远端告警信号。undo alarm命令用来取消检测。
缺省情况下,检测远端告警信号。
CE1方式的情况下,可以使用该命令。
# 取消CE1/PRI接口的检测远端告警信号功能。
[Sysname-E1 2/0] undo alarm detect ais
cable { long | short }
undo cable
CE1/PRI接口视图
【缺省级别】
2:系统级
long:表示接收器的衰减为-43db。
short:表示接收器的衰减为-10db。
【描述】
cable命令用来设置CE1/PRI接口匹配的传输线路类型。undo cable命令用来恢复缺省情况。
缺省情况下,CE1/PRI接口匹配的传输线路类型为long
# 配置CE1/PRI接口匹配的传输线路为short
[Sysname-E1 2/0] cable short
channel-set set-number timeslot-list list
undo channel-set [ set-number ]
CE1/PRI接口视图
【缺省级别】
2:系统级
set-number:该接口上时隙捆绑形成的channel set编号,其取值范围为030
timeslot-list list:被捆绑的时隙。list为时隙编号,其取值范围为131。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
【描述】
channel-set命令用来将CE1/PRI接口的时隙捆绑为channel setundo channel-set命令用来取消已有的捆绑。
缺省情况下,不捆绑任何channel set
CE1/PRI接口使用CE1/PRI工作方式时,它在物理上分为32个时隙,对应编号为031
使用时,可以将除0时隙外的全部时隙分成若干通道组(channel set),每组时隙捆绑以后,将自动创建一个Serial接口,其逻辑特性与同步串口相同。
Serial接口的编号是serial interface-number:set-number。其中interface-number是CE1/PRI接口的编号,set-number是channel set的编号。
在一个CE1/PRI接口上同一个时间内只能支持一种时隙捆绑方式,即本命令不能和pri-set命令同时使用。
相关配置可参考命令pri-set
# 将CE1/PRI接口的1、2、5、10-15和18时隙捆绑为0号channel-set。
[Sysname-E1 2/0] channel-set 0 timeslot-list 1,2,5,10-15,18
clock { master | slave }
undo clock
CE1/PRI接口视图
【缺省级别】
2:系统级
master:使用内部时钟。
slave:使用线路时钟。
【描述】
clock命令用来设置CE1/PRI接口的时钟方式。undo clock命令用来恢复缺省情况。
缺省情况下,接口使用线路时钟(slave)方式。
当CE1/PRI接口作为DCE设备使用时,应使用内部时钟,即master时钟方式;作为DTE设备使用时,应使用线路时钟,即slave时钟方式。
# 设置CE1/PRI接口的时钟使用内部时钟。
[Sysname-E1 2/0] clock master
clock-change auto
undo clock-change auto
CE1/PRI接口视图
【缺省级别】
2:系统级
auto:时钟自动切换功能。
【描述】
clock-change auto命令用来配置接口在slave模式下收到AIS/LOS/LOF告警后,接口自动切换成master模式。当告警消除后,接口自动切换成用户配置的时钟模式。undo clock-change auto命令用来取消时钟自动切换功能,接口恢复成当前用户配置的时钟模式。
缺省情况下,时钟自动切换功能处于关闭状态。
相关配置可参考命令clock
# 开启时钟自动切换功能。
[Sysname-E1 2/0] clock-change atuo
code { ami | hdb3 }
undo code
CE1/PRI接口视图
【缺省级别】
2:系统级
ami:采用AMI(Alternate Mark Inversion,信号交替反转码)线路编码格式。
hdb3:采用HDB3(High Density Bipolar 3,3阶高密度双极性码)线路编码格式。
【描述】
code命令用来设置CE1/PRI接口的线路编码格式。undo code命令用来恢复缺省情况。
缺省情况下,CE1/PRI接口的线路编码格式为hdb3
·              设置接口的线路编解码格式时,请注意与对端设备保持一致。
·              线路编码采用ami方式时,在该接口上需要同时配置data-coding inverted,才能保证接口正常工作。
相关配置可参考命令data-coding
# 设置接口E1 2/0的线路编解码方式为ami
[Sysname-E1 2/0] code ami
1.4.7  controller e1
controller e1 number
【缺省级别】
2:系统级
number:CE1/PRI接口的编号。
【描述】
controller e1命令用来进入CE1/PRI接口的视图。
# 进入接口E1 2/0的视图。
[Sysname-E1 2/0]
1.4.8  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置CE1/PRI接口通过各种方式形成的同步串口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
# 配置接口E1 2/0在非通道化模式下形成的串口使用32位CRC校验。
[Sysname-E1 2/0] using e1
[Sysname-E1 2/0] quit
[Sysname] interface serial 2/0:0
[Sysname-Serial2/0:0] crc 32
data-coding { inverted | normal }
undo data-coding
CE1/PRI接口视图
【缺省级别】
2:系统级
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
【描述】
data-coding inverted命令用来设置CE1/PRI接口对用户数据进行翻转。data-coding normal命令用来设置CE1/PRI接口不对用户数据进行翻转。undo data-coding命令用来恢复缺省情况。
缺省情况下,CE1/PRI接口不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当E1接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现过多连0的缺陷。
需注意的是,只有通信的E1线路两端的CE1/PRI接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置CE1/PRI接口对数据进行翻转。
[Sysname-E1 2/0] data-coding inverted
1.4.10  detect-ais
detect-ais
undo detect-ais
CE1/PRI接口视图
【缺省级别】
2:系统级
【描述】
detect-ais命令用来配置当前接口进行AIS检测。undo detect-ais命令用来取消AIS检测。
缺省情况下,进行AIS检测。
# 设置E1接口进行AIS检测。
[Sysname-E1 2/0] detect-ais
display controller e1 [ interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display controller e1命令用来显示CE1/PRI接口的相关信息。
# 显示E1接口的相关信息。
<Sysname> display controller e1 2/0
E1 2/0 current state: UP
Description : E1 2/0 Interface
Basic Configuration:
  Work mode is E1 framed, Cable type is 75 Ohm unbalanced.
  Frame-format is no-crc4.
  Line code is hdb3, Source clock is slave.
  Idle code is 7e, Itf type is 7e, Itf number is 4.
  Loop back is not set.
Alarm State:
  Receiver alarm state is None.
Historical Statistics:
    Data in current interval (150 seconds elapsed):
    0 Loss Frame Alignment Secs, 0 Framing Error Secs,
    0 CRC Error Secs, 0 Alarm Indication Secs, 0 Loss-of-signals Secs,
    0 Code Violations Secs, 0 Slip Secs, 0 E-Bit error Secs.
表1-11 display controller e1命令显示信息描述表
E1接口当前的状态
E1接口的描述信息
Work mode
E1接口的工作模式(E1/CE1
Cable type
E1接口的线缆类型
Frame-format
E1接口的帧格式(crc4/no crc4)
Source Clock
接口的源时钟(master/slave)
Line Code
线路码(Ami/hdb3)
Idle Code
空闲码(7e/ff)
Itf type
帧间填充码(7e/ff)
Itf number
帧间填充码的个数
Loopback
接口是否设置了环回
Alarm State
告警状态
历史统计数据
清零记录
当前时间间隔内的各种错误发生持续的时间统计,错误包括:帧没对齐,帧错误,警告,丢信号,违规码时间,滑帧
error-diffusion restraint config detect-timer renew-timer threshold
undo error-diffusion restraint config
【缺省级别】
2:系统级
detect-timer:检测定时器,取值范围为30~600,单位为秒。
renew-timer:恢复定时器,取值范围为120~2400,单位为秒。
threshold:错包率门限百分比,取值范围为5~100。
【描述】
error-diffusion restraint config命令用来设置错包扩散抑制功能的三个参数。undo error-diffusion restraint config命令用来恢复缺省情况。
缺省情况下,detect-timer为30秒,renew-timer为600秒,threshold为百分之20。
renew-timer的值不能小于detect-timer的4倍,在detect-timer时间内如果接收到的报文总数小于100,不进行错包统计。
本命令只对CT1/PRI接口和CE1/PRI接口起作用。
MSR系列路由器各款型对于本节所描述的命令及参数的支持情况有所不同,详细差异信息如下:
表1-12
MSR 20-1X
MSR 20
MSR 30
MSR 50
No
No
Yes
Yes
# 配置错包扩散抑制功能的检测定时器为100秒,恢复定时器为2400秒,错误门限为15%。
[Sysname] error-diffusion restraint config 100 2400 15
undo error-diffusion restraint enable
【缺省级别】
2:系统级
【描述】
error-diffusion restraint enable命令用来使能错包扩散抑制功能。undo error-diffusion restraint enable命令用来关闭错包扩散抑制功能。
缺省情况下,使能错包扩散抑制功能。
表1-13
MSR 20-1X
MSR 20
MSR 30
MSR 50
No
No
Yes
Yes
# 使能错包扩散抑制功能。
[Sysname] error-diffusion restraint enable
error-diffusion restraint restart-channel serial interface-number:set-number
【缺省级别】
2:系统级
serial interface-number:set-number:CE1/PRI接口捆绑形成的通道号,其中interface-number是CE1/PRI接口的编号,set-number是channel set的编号。
【描述】
error-diffusion restraint restart-channel命令用来重启因错包抑制而关闭的通道。
表1-14
MSR 20-1X
MSR 20
MSR 30
MSR 50
No
No
Yes
Yes
# 重启因错包抑制而关闭的通道Serial2/0:0。
[Sysname] error-diffusion restraint restart-channel serial 2/0:0
frame-format { crc4 | no-crc4 }
undo frame-format
CE1/PRI接口视图
【缺省级别】
2:系统级
crc4:设置CE1接口的帧格式为CRC4帧格式。
no-crc4:设置CE1接口的帧格式为非CRC4帧格式。
【描述】
frame-format命令用来设置CE1/PRI接口的帧格式。undo frame-format命令用来恢复缺省情况。
缺省情况下,CE1接口的帧格式为no-crc4
CE1/PRI接口工作在CE1方式下时,支持crc4no-crc4两种帧格式。其中crc4帧格式支持对物理帧进行4比特的循环冗余校验,而no-crc4帧格式则不支持对物理帧进行4比特的循环冗余校验。
# 设置接口E1 2/0的帧格式为crc4
[Sysname-E1 3/0] frame-format crc4
idlecode { 7e | ff }
undo idlecode
CE1/PRI接口视图
【缺省级别】
2:系统级
7e:线路空闲码为0x7e格式。
ff:线路空闲码为0xff格式。
【描述】
idlecode命令用来设置CE1/PRI接口的线路空闲码类型。undo idlecode命令用来恢复缺省情况。
缺省情况下,CE1/PRI接口的线路空闲码类型为0x7e
CE1/PRI接口的线路空闲码类型是指在没有被绑定到逻辑通道的时隙上发送的码型。CE1/PRI接口的线路空闲码类型有两种:0x7e和0xff。
# 设置CE1/PRI接口的线路空闲码类型为0x7e。
[Sysname-E1 2/0] idlecode 7e
itf { number number | type { 7e | ff } }
undo itf { number | type }
CE1/PRI接口视图
【缺省级别】
2:系统级
type { 7e | ff }:设置帧间填充字节(Interframe filling flag)类型,7e表示帧间填充符为0x7e格式,ff表示帧间填充符为0xff格式。
【描述】
itf命令用来设置CE1/PRI接口的帧间填充字节类型和个数。undo itf命令用来恢复缺省情况。
缺省情况下,CE1/PRI接口的帧间填充字节类型为0x7e,字节个数为4个。
CE1/PRI接口的帧间填充符是指已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。CE1/PRI接口的帧间填充符类型有两种:0x7e0xff
# 设置CE1/PRI接口的帧间填充字节类型为0xff。
[Sysname-E1 2/0] itf type ff
# 设置CE1/PRI接口的帧间填充字节个数为5。
[Sysname-E1 2/0] itf number 5
loopback { local | payload | remote }
undo loopback
CE1/PRI接口视图
【缺省级别】
2:系统级
local:使能接口对内自环。
remote:使能接口对外环回。
payload:使能接口对外净荷环回。
【描述】
loopback命令用来设置CE1/PR接口使能环回检测功能并设置检测方式。undo loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
自环环回功能主要用于检测接口或电缆本身的状况,正常工作时应禁止这些功能。
对于将CE1/PRI接口时隙经捆绑而形成的串口,如果将串口的链路层协议配置为PPP,设置自环后,链路层协议状态将上报为down,这属于正常情况。
# 设置接口E1 2/0对内自环。
[Sysname-E1 2/0] loopback local
pri-set [ timeslot-list list ]
undo pri-set
CE1/PRI接口视图
【缺省级别】
2:系统级
timeslot-list list:被捆绑的时隙。list为时隙编号,取值范围为131。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
【描述】
pri-set命令用来将CE1/PRI接口的时隙捆绑为pri setundo pri-set命令用来取消已有的捆绑。
缺省情况下,不创建任何pri set。
在进行pri set捆绑时,CE1/PRI接口上的16时隙将被作为D信道使用,因此,这个时隙不能被单独捆绑。如果捆绑的时隙只有一个16时隙,捆绑将会失败。
将CE1/PRI接口时隙捆绑为pri set时,0时隙被用作传输同步信息,16时隙被用作D通道传输信令,其余时隙被用作B通道传输数据。捆绑时可以将除0时隙之外的时隙捆绑为一个pri set(16时隙作为D信道会被自动捆绑),其逻辑特性与ISDN PRI接口相同。在捆绑为pri set时,如果不指定捆绑的时隙,则为捆绑除0时隙外的其它所有时隙,形成一个类似30B+D的ISDN PRI接口。
接口在时隙捆绑以后将自动创建一个Serial接口,其逻辑特性与ISDN PRI接口相同。Serial接口的编号是serial number:15,其中number是CE1/PRI接口的编号。
在一个CE1/PRI接口上,同一个时间内只能支持一种时隙捆绑方式,即本命令不能和channel-set命令同时使用。
相关配置可参考命令channel-set
# 将CE1/PRI接口的1、2、8~12时隙捆绑为pri set。
[Sysname-E1 2/0] pri-set timeslot-list 1,2,8-12
reset counters controller e1 interface-number
【缺省级别】
2:系统级
【描述】
reset counters controller e1命令用来清除CE1/PRI接口的controller计数器。controller计数器值可以用display controller e1命令来查看。
单独清除CE1/PRI接口的controller计数器只能使用reset counters controller e1命令,不能使用reset counters interface命令,该命令会清除所有接口的计数器。
# 清除CE1/PRI接口2/0的controller计数器。
<Sysname> reset counters controller e1 2/0
using { ce1 | e1 }
undo using
CE1/PRI接口视图
【缺省级别】
2:系统级
ce1:接口工作在CE1/PRI工作方式。
e1:接口工作在E1工作方式。
【描述】
using命令用来设置CE1/PRI接口的工作方式。undo using命令用来恢复缺省工作方式。
缺省情况下,CE1/PRI接口的工作方式为CE1/PRI工作方式。
CE1/PRI接口拥有两种工作方式:E1工作方式和CE1/PRI工作方式。
当CE1/PRI接口使用E1工作方式时,它相当于一个不分时隙、数据带宽为2.048Mbps的接口,其逻辑特性与同步串口相同。当CE1/PRI接口使用CE1/PRI工作方式时,它在物理上分为32个时隙,对应编号为0~31,其中0时隙用于传输同步信息。对该接口有两种使用方法:CE1接口和PRI接口。
在将CE1/PRI的接口工作方式改为E1方式后,系统会自动创建一个Serial口。Serial接口的编号是serial interface-number:0。其中interface-number是CE1/PRI接口的编号。
# 设置CE1/PRI接口的工作在E1工作方式。
1.5  CT1/PRI接口基本配置命令
alarm detect rai
CT1/PRI接口视图
【缺省级别】
2:系统级
detect:接口的定时检测功能。
rai:Remote Alarm Indication,即远端告警指示信号。
【描述】
缺省情况下,检测远端告警信号。
在接口帧格式采用esf的情况下,可以使用该命令。
# 取消CT1/PRI接口的检测远端告警信号功能。
[Sysname] controller t1 2/0
[Sysname-T1 2/0] undo alarm detect rai
alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
CT1/PRI接口视图
【缺省级别】
2:系统级
ais:AIS告警的门限值。AIS告警有两个门限值,分别为level-1level-2level-1的门限为在一个SF/ESF帧内,比特流中的0的个数小等于2,则AIS告警产生;level-2的门限在SF格式时为,一个SF帧内码流的0个数小等于3;在ESF格式时为一个ESF帧内码流的0个数小等于5。缺省情况下,AIS告警门限值为level-1。
lfaLFA告警的门限值。LFA告警有四个门限值可以配置,分别为level-1level-2level-3level-4level-1为4个帧同步比特中丢失了2个;level-2为5个帧同步比特中丢失了2个;leve-3为6个帧同步比特中丢失了2个;level-4仅仅对ESF格式有效,在连续4个ESF帧中出现错误时产生LFA告警。缺省情况下,LFA告警门限值为level-1。
los:LOS告警的门限值。LOS告警有两个门限值,分别为pulse-detectionpulse-recoverypulse-detection配置LOS的检测时长门限,取值范围为16~4096,这个时长门限的单位为“脉冲周期”;pulse-recovery配置LOS的脉冲门限,取值范围为1~256,就是在检测时长内(即pulse-detection配置的若干个脉冲周期内),检测到的脉冲个数如果小于pulse-recovery所配置的值,则LOS告警产生。在缺省情况,pulse-detection参数的值为176,pulse-recovery的值为22,即如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失,LOS告警产生。
【描述】
alarm-threshold命令用来配置CT1接口告警的门限值。undo alarm-threshold命令将告警门限值恢复为缺省情况。
缺省情况下,对于LOS告警,pulse-detection参数的值为176,pulse-recovery的值为22,即默认的情况下,如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失LOS告警产生;对于AIS告警,缺省值为level-1;对于LFA告警,缺省值为level-1
# 将LOS告警的检测时长配置为300个脉冲周期。
[Sysname-T1 2/0] alarm-threshold los pulse-detection 300
bert pattern { 2^20 | 2^15 } time minutes [ unframed ]
undo bert
CT1/PRI接口视图
【缺省级别】
2:系统级
pattern:设置BERT测试模式,包括2^15(测试码流长度为2的15次方个bit)和2^20(测试码流长度为2的20次方个bit)。
time minutes:设置BERT测试事件,取值范围为1~1440,单位为分钟。
unframed:设置测试数据流覆盖帧的开销位。
【描述】
bert命令用来进行线路位(Bit)错误率的测试。undo bert命令用来取消进行线路位(Bit)错误率的测试。
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前我们CT1单板支持2^20和2^15两种测试模式。
BERT测试方式为,本端发出测试数据流,经过线路某处环回来,检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对方设置远端环回等。利用bert命令配置好测试模式,指定测试时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。
BERT测试状态和测试结果详见CT1接口显示部分。
# 执行2^20格式的BERT测试10分钟。
[Sysname-T1 2/0] bert pattern 2^20 time 10
cable { long { 0db | -7.5db | -15db | -22.5db } | short { 133ft | 266ft | 399ft | 533ft | 655ft } }
undo cable
CT1/PRI接口视图
【缺省级别】
2:系统级
long:匹配655英尺以上的传输线路,可选参数有0db-7.5db-15db-22.5db,可根据接收端信号质量选择不同的衰减参数,当线路质量越差时,信号衰减越大,需要用户对这种衰减进行相应补偿,此时,不需要外接CSU。
short:匹配655英尺以下的传输线路,可选参数有133ft266ft399ft533ft655ft,可根据传输线路的长度,选择相应的长度参数。
【描述】
cable命令用来设置CT1/PRI接口匹配的传输线路的衰减或长度。undo cable命令用来恢复缺省情况。
缺省情况下,CT1/PRI接口匹配的传输线路衰减为long 0db
本命令主要作用是配置发送时的信号波形,以适应不同传输需要。实际使用中,可根据接收端收到的信号质量的好坏,来决定是否使用此命令。如果信号质量较好,可以使用缺省设置。使用缺省配置时,CT1/PRI接口不需外接CSU设备。
# 将CT1/PRI接口匹配的传输线路设为133英尺。
[Sysname-T1 2/0] cable short 133ft
channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
CT1/PRI接口视图
【缺省级别】
2:系统级
set-number:该接口上时隙捆绑形成的channel set编号,取值范围为0~23。
timeslot-list list:被捆绑的时隙。list为时隙编号,取值范围为1~24。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
speed { 56k | 64k }:时隙捆绑速率,单位为kbps。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。系统默认为64K
【描述】
channel-set命令用来将CT1/PRI接口的时隙捆绑为通道组(channel set)。undo channel-set命令用来取消相应的通道组。
缺省情况下,不捆绑任何channel set。
CT1/PRI接口在物理上分为24个时隙,对应编号为1~24。使用时,可以将全部时隙分成若干通道组(channel set),每组时隙捆绑以后,系统将自动创建一个Serial接口,其逻辑特性与同步串口相同。
Serial接口的编号是serial interface-number:set-number。其中interface-number是CT1/PRI接口的编号,set-number是channel set的编号。
在一个CT1/PRI接口上,同一个时间内只能支持一种时隙捆绑方式,即本命令不能和pri-set命令同时使用。
# 将CT1/PRI接口的1、2、5、10-15和18时隙捆绑为0号channel-set。
[Sysname-T1 2/0] channel-set 0 timeslot-list 1,2,5,10-15,18
undo clock
CT1/PRI接口视图
【缺省级别】
2:系统级
master:使用内部时钟方式。
slave:使用线路时钟方式。
【描述】
clock命令用来设置CT1/PRI接口的时钟方式。undo clock命令用来恢复缺省情况。
当CT1/PRI接口作为DCE设备使用时,应选择内部时钟,即master时钟方式;作为DTE设备使用时,应选择线路时钟,即slave时钟方式。
当两台路由器的CT1/PRI接口直接相连时,必须使两端分别工作在线路时钟方式(slave)和内部时钟方式(master)。当路由器的CT1/PRI接口与交换机连接时,交换机是DCE设备,负责提供时钟;而路由器的接口需工作在线路时钟方式(slave)。
# 设置CT1/PRI接口的时钟为内部时钟。
[Sysname-T1 2/0] clock master
code { ami | b8zs }
undo code
CT1/PRI接口视图
【缺省级别】
2:系统级
b8zs:采用B8ZS(Bipolar 8-zero substitution,双极性8zero替换码)线路编码格式。
【描述】
code命令用来设置CT1/PRI接口的线路编码格式。undo code命令用来恢复缺省情况。
缺省情况下,CT1/PRI接口的线路编码格式为b8zs
# 设置接口T1 2/0的线路编解码方式为ami
[Sysname-T1 2/0] code ami
1.5.8  controller t1
controller t1 number
【缺省级别】
2:系统级
number:CT1/PRI接口的编号。
【描述】
controller t1命令用来进入CT1/PRI接口的视图。
# 进入接口CT1/PRI 2/0的视图。
[Sysname-T1 2/0]
1.5.9  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置CT1/PRI接口通过各种方式形成的同步串口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
# 设置接口T1 2/0通过channel-set形成的同步串口使用32位CRC校验。
[Sysname-T1 2/0] channel-set 1 timeslot-list 2-6
[Sysname-T1 2/0] quit
[Sysname] interface serial 2/0:1
[Sysname-Serial2/0:1] crc 32
undo data-coding
CT1/PRI接口视图
【缺省级别】
2:系统级
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
【描述】
data-coding inverted命令用来设置CT1/PRI接口对用户数据进行翻转。data-coding normal命令用来设置CT1/PRI接口不对用户数据进行翻转。undo data-coding命令用来恢复缺省情况。
缺省情况下,CT1/PRI接口不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当T1接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现过多连0的缺陷。
需注意的是,只有通信的T1线路两端的CT1/PRI接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置CT1/PRI接口对数据进行翻转。
[Sysname-T1 2/0] data-coding inverted
display controller t1 [ interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
【描述】
display controller t1命令用来显示CT1/PRI接口的相关信息。
# 显示T1接口的相关信息。
<Sysname> display controller t1 2/0
T1 2/0 current state :DOWN
Description : T1 2/0 Interface
  Work mode is T1 framed, Cable type is 100 Ohm balanced.
  Frame-format is esf, fdl is none, Line code is b8zs.
  Source clock is slave, Data-coding is normal.
  Idle code is ff, Itf type is ff, Itf number is 2.
Alarm State:
  Receiver alarm state is Loss-of-Signal.
  Transmitter is sending remote alarm.
  Pulse density violation detected.
SendLoopCode History:
  inband-llb-up:0 times, inband-llb-down:0 times.
  fdl-ansi-llb-up:0 times, fdl-ansi-llb-down:0 times.
  fdl-ansi-plb-up:0 times, fdl-ansi-plb-down:0 times.
BERT state:(stopped, not completed)
  Test pattern: 2^15, Status: Not Sync, Sync Detected: 0
    Time: 0 minute(s), Time past: 0 minute(s)
    Bit Errors (since test started): 0 bits
    Bits Received (since test started): 0 Kbits
    Bit Errors (since latest sync): 0 bits
    Bits Received (since latest sync): 0 Kbits
  Data in current interval (285 seconds elapsed):
    0 Line Code Violations, 0 Path Code Violations
    0 Ais Alarm Secs, 286 Los Alarm Secs
    7 Slip Secs, 286 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 286 Unavail Secs
  Data in Interval 1:
    0 Ais Alarm Secs, 901 Los Alarm Secs
    22 Slip Secs, 901 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 901 Unavail Secs
  Data in Interval 2:
    0 Ais Alarm Secs, 900 Los Alarm Secs
    23 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
  Total Data (last 2 15 minute intervals):
    0 Ais Alarm Secs, 2087 Los Alarm Secs
    52 Slip Secs, 2087 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 2087 Unavail Secs
表1-15 display controller t1命令显示信息描述表
接口物理上的up/down状态
T1接口的描述信息
Basic Configuration
接口基本配置
T1接口的工作模式(T1/CT1)
T 1接口的线缆类型(100 Ohm balanced)
Frame-format is esf
T 1接口的帧格式(esf/sf)
fdl is none
FDL格式(ansi/att/none
Line code is b8zs
线路编码格式(b8zs/ami)
接口的时钟源模式(master/slave)
包括正常和数据翻转两种模式(normal/inverted)
Idle code is ff
空闲码(7e/ff)
Itf type is ff
帧间填充码的类型(7e/ff)
Itf number is 2
帧间填充码的字节数为2个
接口是否设置了环回(local/payload/remote/no set)
Alarm State
告警状态
收到的告警类型:none、LOS、LOF、RAI、AIS
发出的告警类型:RAI、none
脉冲密度不符合规范要求
向对端发送环回码的历史记录,包括每种码的发送次数和最近发送的是哪种码
BERT测试状态:completed(自然完成)还是stopped(人为中止)还是running(正在测试)
Test pattern: 2^15
测试模式(2^20/2^15
Status: Not Sync
是否处于同步状态
Sync Detected: 0
测试以来检测到的同步次数
Time: 0 minute(s)
预设的测试时间
已经过去的测试时间
测试以来收到的错误的比特数
测试以来收到的总比特数
最近的同步以来收到的错误的比特数
最近的同步以来收到的总比特数
历史信息
清零记录
当前时间间隔内的统计信息(15分钟为一个时间间隔)。 这些数据是按照T1规范对物理层所作的各种信息统计,如AIS告警、RAI告警、LOS信号、LFA等。详细解释参见T1规范ANSI T1.403和AT&T TR 54016
Data in Interval 1:
第1间隔内的统计信息
统计内容同上
Data in Interval 2:
第2间隔内的统计信息
统计内容同上
所有间隔内的统计信息
统计内容同上
1.5.12  error-diffusion restraint config
【缺省级别】
2:系统级
【描述】
MSR 20-1X
MSR 20
MSR 30
MSR 50
No
No
Yes
Yes
[Sysname] error-diffusion restraint cofing 100 2400 15
1.5.13  error-diffusion restraint enable
【缺省级别】
2:系统级
【描述】
缺省情况下,使能错包扩散抑制功能。
MSR 20-1X
MSR 20
MSR 30
MSR 50
No
No
Yes
Yes
# 使能错包扩散抑制功能。
1.5.14  error-diffusion restraint restart-channel
【缺省级别】
2:系统级
serial interface-number:set-number:CT1/PRI接口捆绑形成的通道号,其中interface-number是CT1/PRI接口的编号,set-number是channel set的编号。
【描述】
MSR 20-1X
MSR 20
MSR 30
MSR 50
No
No
Yes
Yes
1.5.15  fdl
fdl { ansi | att | both | none }
undo fdl
CT1/PRI接口视图
【缺省级别】
2:系统级
ansi:使能FDL,遵循ANSI T1.403规范。
att:使能FDL,遵循AT&T TR 54016规范。
both:使能FDL,同时遵循ANSI T1.403规范和AT&T TR 54016规范。
none:禁止FDL。
【描述】
fdl命令用来配置CT1/PRI接口在ESF格式时FDL比特位的使用模式。undo fdl命令用来恢复缺省情况。
缺省情况下,禁止FDL(none)。
FDL(Facility Data Link,设备数据链路)是T1的ESF帧格式中4kbps的一个带宽,CT1/PRI接口在配置为ESF(Extended Super Frame,扩展超帧)格式时,其中的FDL位可用来传递报警信息、性能信息及环回码等,相关的规范包括ANSI T1.403和ATT TR 54016。在实际应用中,经常需要对FDL的使用及规范进行各种配置,包括:禁止FDL、使能并遵循ANSI规范、使能并遵循AT&T规范或者使能并遵循这两种规范。
实际应用中,可以根据对方FDL的模式调整本端FDL的模式。
# 设置接口T1 2/0 FDL使能并遵循AT&T规范。
[Sysname-T1 2/0] fdl att
1.5.16  frame-format (CT1/PRI interface)
frame-format { esf | sf }
undo frame-format
CT1/PRI接口视图
【缺省级别】
2:系统级
esf:设置CT1/PRI接口的帧格式为扩展超帧格式(Extended Super Frame)。
sf:设置CT1/PRI接口的帧格式为超帧格式(Super Frame)。
【描述】
frame-format命令用来设置CT1/PRI接口的帧格式。undo frame-format命令用来恢复缺省情况。
缺省情况下,CT1/PRI接口的帧格式为esf
CT1/PRI接口支持超帧(SFSuper Frame)和扩展超帧(ESFextended Super Frame)两种帧格式。在超帧格式中,多个帧可以共享相同的帧同步信息和信令信息,从而有更多的有效位来传送用户数据。实际应用中,经常需要对系统进行测试,扩展超帧技术可以用来满足在测试时不影响正常业务运行的要求。
# 设置T1接口的帧格式为超帧格式。
[Sysname-T1 2/0] frame-format sf
1.5.17  idlecode (CT1/PRI interface)
undo idlecode
CT1/PRI接口视图
【缺省级别】
2:系统级
7e:线路空闲码为0x7e格式。
ff:线路空闲码为0xff格式。
【描述】
idlecode命令用来设置CT1/PRI接口的线路空闲码类型。undo idlecode命令用来恢复缺省情况。
缺省情况下,CT1/PRI接口的线路空闲码类型为0x7e
CT1/PRI接口的线路空闲码类型是指在没有被绑定到逻辑通道的时隙上发送的码型。CT1/PRI接口的线路空闲码类型有两种:0x7e和0xff。
# 设置CT1/PRI接口的线路空闲码类型为0x7e。
[Sysname-T1 2/0] idlecode 7e
1.5.18  itf (CT1/PRI interface)
CT1/PRI接口视图
【缺省级别】
2:系统级
【描述】
itf命令用来设置CT1/PRI接口的帧间填充字节类型和个数。undo itf命令用来恢复缺省情况。
缺省情况下,CT1/PRI接口的帧间填充字节类型为0x7e,字节个数为4个。
CT1/PRI接口的帧间填充符是指在已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。CT1/PRI接口的帧间填充符类型有两种:0x7e0xff
# 设置CT1/PRI接口的帧间填充字节类型为0xff。
[Sysname-T1 2/0] itf type ff
# 设置CT1/PRI接口的帧间填充字节个数为5。
[Sysname-T1 2/0] itf number 5
1.5.19  loopback (CT1/PRI interface)
undo loopback
CT1/PRI接口视图
【缺省级别】
2:系统级
local:设置CT1/PRI接口对内自环。
payload: 设置CT1/PRI接口对外净荷环回。
remote:设置CT1/PRI接口对外环回。
【描述】
loopback命令用来设置CT1/PRI接口进行对内自环、对外环回或对外净荷环回。undo loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
自环环回功能主要用于检测接口或电缆本身的状况,正常工作时,应禁止这些功能。
对于CT1/PRI接口经时隙捆绑形成串口,如果将链路层协议配置为PPP,设置自环后,链路层协议状态将上报为down。这属于正常情况。
# 设置接口T1进行对外环回。
[Sysname-T1 2/0] loopback remote
1.5.20  pri-set (CT1/PRI interface)
undo pri-set
CT1/PRI接口视图
【缺省级别】
2:系统级
list:被捆绑的时隙编号,其取值范围为124。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
【描述】
pri-set命令用来将CT1/PRI接口的时隙捆绑为pri set。undo pri-set命令用来取消已有的捆绑。
缺省情况下,不创建任何pri set。
在进行pri set捆绑时,CT1/PRI接口上的24时隙将被作为D信道使用,因此,这个时隙不能被单独捆绑。如果捆绑的时隙只有一个24时隙,捆绑将会失败。
将CT1/PRI接口时隙捆绑为pri set时,24时隙被用作D通道传输信令,其余时隙被用作B通道传输数据。捆绑时可以将任意时隙捆绑为一个pri set(24时隙作为D信道会被自动捆绑),其逻辑特性与ISDN PRI接口相同。在捆绑为pri set时,如果不指定捆绑的时隙,则会将所有时隙捆绑起来,形成一个类似23B+D的ISDN PRI接口。
接口在时隙捆绑以后将自动创建一个Serial接口,其逻辑特性与ISDN PRI接口相同。Serial接口的编号是serial number:23。其中number是CT1/PRI接口的编号。
在一个CT1/PRI接口上,同一时间内只能支持一种时隙捆绑方式,即本命令不能和channel-set命令同时使用。
# 将CT1/PRI接口的1、2、8~12时隙捆绑为pri set。
[Sysname-T1 2/0] pri-set timeslot-list 1,2,8-12
1.5.21  reset counters controller t1
reset counters controller t1 interface-number
【缺省级别】
2:系统级
【描述】
reset counters controller t1命令用来清除CT1/PRI接口的controller计数器。controller计数器值可以用display controller t1命令来查看。
单独清除CT1/PRI接口的controller计数器只能使用reset counters controller t1命令,不能使用reset counters interface命令,该命令会清除所有接口的计数器。
# 清除CT1/PRI接口2/0的controller计数器。
<Sysname> reset counters controller t1 2/0
1.5.22  sendloopcode
sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
CT1/PRI接口视图
【缺省级别】
2:系统级
fdl-ansi-llb-down发送FDL承载的符合ANSI规范的线路环回去激活码,解除环回。
fdl-ansi-llb-up发送FDL承载的符合ANSI规范的线路环回激活码,启动远端环回。
fdl-ansi-plb-down发送FDL承载的符合ANSI规范的净荷环回去激活码,解除环回。
fdl-ansi-plb-up发送FDL承载的符合ANSI规范的净荷环回激活码,启动远端环回。
fdl-att-plb-down:发送FDL承载的符合AT&T规范的净荷环回去激活码,解除环回。
fdl-att-plb-up:发送FDL承载的符合AT&T规范的净荷环回激活码,启动远端环回。
inband-llb-down发送符合ANSI规范和AT&T规范的带内线路环回去激活码,解除环回。
inband-llb-up发送符合ANSI规范和AT&T规范的带内线路环回激活码,启动远端环回。
【描述】
sendloopcode命令用来配置发送远程环回控制码。
缺省情况下,不发送远程环回控制码。
CT1/PRI接口下可以通过发送环回控制码对远端的CT1/PRI接口进行环回的自动配置。LLB为线路环回(Line Loop Back),这种方式下一个T1的PCM帧的全部193位(包括1位同步位及192位有效带宽)都被环回;PLB为净荷环回(Payload Loop Back),这种方式下仅192位有效带宽被环回。环回码的格式规范包括ANSI T1.403和AT&T TR 54016。SF格式下的LLB环回码占用有效带宽;ESF格式下对LLB和PLB的环回码均使用ESF帧的FDL比特位收发。
这条命令需要和远端T1设备配合使用,当对方能检测符合上述格式的各种环回码时,对方能够根据检测到的环回码类型设置相应的环回模式。持续发送5秒钟,不影响其他接口的正常工作。
配置该命令时要求远端的CT1/PRI接口能自动检测到来自网上的环回控制码。
# 发送带内线路环回激活码。
[Sysname-T1 2/0] sendloopcode inband-llb-up
E1-F接口基本配置命令
1.5.23  clock-change auto
clock-change auto
E1-F接口视图
【缺省级别】
2:系统级
auto:时钟自动切换功能。
【描述】
clock-change auto命令用来配置E1-F接口在slave模式下收到AIS/LOS/LOF告警后,接口自动切换成master模式。当告警消除后,接口自动切换成用户配置的时钟模式。undo clock-change auto命令用来取消时钟自动切换功能,接口恢复成当前用户配置的时钟模式。
相关配置可参考命令fe1 clock
# 开启E1-F接口的时钟自动切换功能。
[Sysname-Serial2/0] clock-change auto
1.5.24  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置E1-F接口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
# 设置E1-F接口2/0使用32位CRC校验。
1.5.25  display fe1
display fe1 [ serial interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
serial interface-number:显示指定E1-F接口的信息。interface-number为串口编号。如果不指定接口,则显示所有的E1-F接口的信息。
【描述】
display fe1命令用来显示E1-F接口的状态信息。
若指定的接口不是E1-F接口而是一个普通串口,则系统会提示该串口不是E1-F接口。
# 显示E1-F接口的相关信息。
<Sysname> display fe1 serial 2/0
Serial2/0
  Loopback is not set.
Alarm State:
  Data in current interval (430546 seconds elapsed):
    430546 Loss Frame Alignment Secs, 0 Framing Error Secs,
    0 CRC Error Secs, 0 Alarm Indication Secs, 430546 Loss-of-signals Secs,
    0 Code Violations Secs, 1 Slip Secs, 0 E-Bit error Secs.
表1-16 display fe1命令显示信息描述表
Basic Configuration
接口基本配置
Work mode
接口的工作模式
Cable type
接口的线缆类型(75欧非平衡/120欧平衡)
Frame-format
帧格式(crc4/no-crc4)
Line Code
线路编码格式(ami/hdb3)
Source Clock
Idle code
空闲码(7e/ff)
Itf type
帧间填充码(7e/ff)
Itf number
帧间填充码的个数
Loopback
接口是否设置了环回
Alarm State
告警状态
历史统计信息
最后一次清除接口统计信息的时间
  Data in current interval (19349 seconds elapsed):
    129 Loss Frame Alignment Secs, 0 Framing Error Secs,
    0 CRC Error Secs, 0 Alarm Indication Secs, 129 Loss-of-signals Secs,
1.5.26  fe1 alarm
fe1 alarm detect rai
undo fe1 alarm detect rai
E1-F接口视图
【缺省级别】
2:系统级
detect:接口的定时检测功能。
【描述】
fe1 alarm命令用来配置检测远端告警信号。undo fe1 alarm命令用来取消检测。
缺省情况下,检测远端告警信号。
在成帧方式的情况下,可以使用该命令。
# 取消检测远端告警信号功能。
[Sysname-Serial2/0] undo fe1 alarm detect rai
1.5.27  fe1 cable
fe1 cable { long | short }
undo fe1 cable
E1-F接口视图
【缺省级别】
2:系统级
long:表示设置支持长电缆类型。
short:表示设置支持短电缆类型。
【描述】
fe1 cable命令用来设置接口支持的电缆类型。undo fe1 cable命令用来恢复缺省情况。
缺省情况下,E1-F接口支持长电缆类型。
# 配置E1-F接口2/0支持的电缆类型为short
[Sysname-Serial2/0] fe1 cable short
1.5.28  fe1 clock
fe1 clock { master | slave }
undo fe1 clock
E1-F接口视图
【缺省级别】
2:系统级
master:使用内部时钟模式。
slave:使用线路时钟模式。
【描述】
fe1 clock命令用来设置E1-F接口的时钟方式。undo fe1 clock命令用来恢复缺省情况。
当E1-F接口作为DCE设备使用时,应选择内部时钟,即master时钟方式;作为DTE设备使用时,应选择线路时钟,即slave时钟方式。
# 设置E1-F接口的时钟为master方式。
[Sysname-Serial2/0] fe1 clock master
1.5.29  fe1 code
fe1 code { ami | hdb3 }
undo fe1 code
E1-F接口视图
【缺省级别】
2:系统级
【描述】
fe1 code命令用来设置E1-F接口的线路编码格式。undo fe1 code命令用来恢复缺省情况。
缺省情况下,E1-F接口的线路编码格式为hdb3
·              设置接口的线路编解码格式时请注意与对端设备保持一致。
·              线路编码采用ami方式时,在该接口上需要同时配置fe1 data-coding inverted,才能保证接口正常工作。
相关配置可参考命令fe1 data-coding
# 设置接口E1-F接口的线路编解码方式为ami
[Sysname-Serial2/0] fe1 code ami
1.5.30  fe1 data-coding
fe1 data-coding { inverted | normal }
undo fe1 data-coding
E1-F接口视图
【缺省级别】
2:系统级
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
【描述】
fe1 data-coding命令用来设置E1-F接口是否对用户数据进行翻转。undo fe1 data-coding命令用来恢复缺省情况。
缺省情况下,不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当E1-F接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现的过多连0的缺陷。
需注意的是,只有通信的E1-F线路两端的E1-F接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置E1-F接口对数据翻转。
[Sysname-Serial2/0] fe1 data-coding inverted
1.5.31  fe1 detect-ais
fe1 detect-ais
undo fe1 detect-ais
E1-F接口视图
【缺省级别】
2:系统级
【描述】
fe1 detect-ais命令用来配置当前接口进行AIS检测。undo fe1 detect-ais命令用来取消AIS检测。
缺省情况下,进行AIS检测。
# 设置E1-F接口进行AIS检测。
[Sysname-Serial2/0] fe1 detect-ais
1.5.32  fe1 frame-format
fe1 frame-format { crc4 | no-crc4 }
undo fe1 frame-format
E1-F接口视图
【缺省级别】
2:系统级
crc4:设置E1-F接口的帧格式为CRC4帧格式。
no-crc4:设置E1-F接口的帧格式为非CRC4帧格式。
【描述】
fe1 frame-format命令用来设置E1-F接口的帧格式。undo fe1 frame-format命令用来恢复缺省情况。
缺省情况下,E1-F接口的帧格式为no-crc4
E1-F接口工作在成帧方式下时,支持crc4no-crc4两种帧格式。其中crc4帧格式支持对物理帧进行4比特的循环冗余校验,而no-crc4帧格式则不支持。
# 设置E1-F接口的帧格式为crc4
[Sysname-Serial2/0] fe1 frame-format crc4
1.5.33  fe1 idlecode
fe1 idlecode { 7e | ff }
undo fe1 idlecode
E1-F接口视图
【缺省级别】
2:系统级
7e:线路空闲码为0x7e格式。
ff:线路空闲码为0xff格式。
【描述】
fe1 idlecode命令用来设置E1-F接口的线路空闲码类型。undo fe1 idlecode命令用来恢复缺省情况。
缺省情况下,E1-F接口的线路空闲码类型为0x7e
E1-F接口的线路空闲码类型是指在没有被绑定到逻辑通道的时隙上发送的码型。E1-F接口的线路空闲码类型有两种:0x7e和0xff。
# 设置E1-F接口的线路空闲码类型为0x7e。
[Sysname-Serial2/0] fe1 idlecode 7e
1.5.34  fe1 itf
fe1 itf { number number | type { 7e | ff } }
undo fe1 itf { number | type }
E1-F接口视图
【缺省级别】
2:系统级
type { 7e | ff }:设置帧间填充字节(Interframe filling flag)类型,7e表示帧间填充符为0x7e格式,ff表示帧间填充符为0xff格式,缺省值为7e
【描述】
fe1 itf命令用来设置E1-F接口的帧间填充字节类型和个数。undo fe1 itf命令用来恢复缺省情况。
缺省情况下,E1-F接口的帧间填充字节类型为0x7e,字节个数为4个。
E1-F接口的帧间填充符是指在已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。E1-F接口的帧间填充符类型有两种:0x7e0xff
# 设置E1-F接口的帧间填充字节类型为0xff。
[Sysname-Serial2/0] fe1 itf type ff
# 设置E1-F接口的帧间填充字节个数为5。
[Sysname-Serial2/0] fe1 itf number 5
1.5.35  fe1 loopback
fe1 loopback { local | payload | remote }
undo fe1 loopback
E1-F接口视图
【缺省级别】
2:系统级
local:设置接口对内自环。
payload:设置接口净荷环回。
remote:设置接口对外环回。
【描述】
fe1 loopback命令用来设置E1-F接口进行对内自环、净荷环回或者对外环回。undo fe1 loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
自环、环回功能主要用于检测接口或电缆本身的状况,正常工作时应禁止这些功能。
在接口上,本命令可以根据不同的参数,分别打开对内自环、净荷环回或者对外环回功能,但不能同时启用。
# 设置E1-F接口进行对内自环。
[Sysname-Serial2/0] fe1 loopback local
1.5.36  fe1 timeslot-list
fe1 timeslot-list list
undo fe1 timeslot-list
E1-F接口视图
【缺省级别】
2:系统级
list:被捆绑的时隙编号,取值范围为1~31。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以用number1,number2-number3的形式同时指定多个时隙。
【描述】
fe1 timeslot-list命令用来设置E1-F接口的时隙捆绑。undo fe1 timeslot-list命令用来恢复缺省情况。
缺省情况下,E1-F接口捆绑所有的时隙,即E1-F接口的缺省速率为1984kbps。
在对E1-F接口进行时隙捆绑后,接口的速率会同时改变。例如,当用户将1~10这十个时隙捆绑之后,接口的速率就会变为10×64kbps。
与CE1/PRI接口不同的是,在E1-F接口上只能捆绑出一个通道组(channel set),捆绑出的通道组就对应当前的同步串口。而在CE1/PRI接口上可以捆绑出多个通道组,并且每捆绑一个通道组,系统都会自动生成一个与之相对应的同步串口。
因为E1-F接口的0时隙被用于传输同步信息,所以,当对E1-F接口的时隙进行全部捆绑时,实际捆绑的时隙为1~31时隙。
当E1-F接口的工作方式为非成帧方式时,不能配置fe1 timeslot-list命令。
相关配置可参考命令fe1 unframed
# 将E1-F接口上的1、2、5、10~15、18时隙捆绑起来。
[Sysname-Serial2/0] fe1 timeslot-list 1,2,5,10-15,18
1.5.37  fe1 unframed
fe1 unframed
undo fe1 unframed
E1-F接口视图
【缺省级别】
2:系统级
【描述】
fe1 unframed命令用来设置E1-F接口的工作方式为非成帧方式。undo fe1 unframed命令用来恢复E1-F接口的工作方式为成帧方式。
缺省情况下,E1-F接口工作在成帧方式。
当E1-F接口工作在非成帧的工作方式时,它相当于一个不分时隙、数据带宽为2048kbps的接口,其逻辑特性与同步串口相同。
当E1-F接口工作在成帧的工作方式时,它在物理上分为32个时隙,对应编号为0~31,其中0时隙用于传输同步信息。
相关配置可参考命令fe1 timeslot-list
# 设置E1-F接口的工作方式为非成帧方式。
[Sysname-Serial2/0] fe1 unframed
T1-F接口基本配置命令
1.5.38  crc
crc { 16 | 32 | none }
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置T1-F接口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
# 设置T1-F接口2/0使用32位CRC校验。
[Sysname-Serial2/0] crc 32
1.5.39  display ft1
display ft1 [ serial interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
serial interface-number:显示指定T1-F接口的信息。interface-number为串口编号。如果不指定接口,则显示所有的T1-F接口的信息。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display ft1命令用来显示T1-F接口的配置和状态信息。
若指定的接口不是T1-F接口而是一个普通串口,则系统会提示该串口不是T1-F接口。
# 显示T1-F接口的相关信息。
<Sysname> display ft1 serial 2/0
Serial2/0
    Input: 0 packets, 0 bytes
           0 broadcasts, 0 multicasts
           0 errors, 0 runts, 0 giants
           0 CRC, 0 align errors, 0 overruns
           0 dribbles, 0 aborts, 0 no buffers
           0 frame errors
    Output:0 packets, 0 bytes
           0 errors, 0 underruns, 0 collisions
           0 deferred
Alarm State:
  Data in Interval 1:
  Data in Interval 2:
表1-17 display ft1命令显示信息描述表
Seria2/0
Basic Configuration
接口的基本配置
Input:/Output
输入/输出统计信息
T1-F接口的工作模式(T1/CT1)
T1-F接口的线缆类型(100 Ohm balanced)
Frame-format is esf
T1-F接口的帧格式(esf/sf)
fdl is none
FDL格式(ansi/att/none
Line code is b8zs
线路编码格式(b8zs/ami)
Idle code is ff
空闲码(7e/ff)
Itf type is ff
帧间填充码的类型(7e/ff)
Itf number is 2
帧间填充码的字节数为2个
接口是否设置了环回(local/payload/remote/not set)
Alarm State
告警状态
发出的告警类型:RAI、none
脉冲密度不符合规范要求
Test pattern: 2^15
测试模式(2^20/2^15
Status: Not Sync
是否处于同步状态
Sync Detected: 0
测试以来检测到的同步次数
Time: 0 minute(s)
预设的测试时间,
已经过去的测试时间
测试以来收到的比特错误数
测试以来收到的比特总数
最近的同步以来收到的比特错误数
最近的同步以来收到的比特总数
历史信息
清零记录
Data in Interval 1:
第1间隔内的统计信息
统计内容同上
Data in Interval 2:
第2间隔内的统计信息
统计内容同上
所有间隔内的统计信息
统计内容同上
1.5.40  ft1 alarm
ft1 alarm detect rai
undo ft1 alarm detect rai
T1-F接口视图
【缺省级别】
2:系统级
detect:接口的定时检测功能。
【描述】
ft1 alarm命令用来配置检测远端告警信号。undo ft1 alarm命令用来取消检测。
缺省情况下,检测远端告警信号。
# 取消检测远端告警信号功能。
[Sysname-Serial2/0] undo ft1 alarm detect rai
1.5.41  ft1 alarm-threshold
ft1 alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo ft1 alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
T1-F接口视图
【缺省级别】
2:系统级
ais AIS告警的门限值。AIS告警有两个门限值,分别为level-1level-2。level-1的门限为在一个SF/ESF帧内,比特流中的0的个数小等于2,则AIS告警产生;level-2的门限在SF格式时为,一个SF帧内码流的0个数小等于3;在ESF格式时为一个ESF帧内码流的0个数小等于5。缺省情况下,AIS告警门限值为level-1。lfa LFA告警的门限值。LFA告警有四个门限值可以配置,分别为level-1level-2level-3level-4level-1为4个帧同步比特中丢失了2个;level-2为5个帧同步比特中丢失了2个;leve-3为6个帧同步比特中丢失了2个;level-4仅仅对ESF格式有效,在连续4个ESF帧中出现错误时产生LFA告警。缺省情况下,LFA告警门限值为level-1。
losLOS告警的门限值。LOS告警有两个门限值,分别为pulse-detectionpulse-recoverypulse-detection配置LOS的检测时长门限,取值范围为16~4096,这个时长门限的单位为“脉冲周期”;pulse-recovery配置LOS的脉冲门限,取值范围为1~256,就是在检测时长内(即pulse-detection配置的若干个脉冲周期内),检测到的脉冲个数如果小于pulse-recovery所配置的值,则LOS告警产生。在缺省情况,pulse-detection参数的值为176,pulse-recovery的值为22,即如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失,LOS告警产生。
【描述】
ft1 alarm-threshold命令用来配置T1-F接口告警的门限值。undo ft1 alarm-threshold命令用来恢复缺省情况。
缺省情况下,对于LOS告警,pulse-detection参数的值为176,pulse-recovery的值为22,即缺省情况下,如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失LOS告警产生;对于AIS告警,缺省值为level-1;对于LFA告警,缺省值为level-1。
实际使用中,可以根据实际情况配置各个告警门限。
[Sysname-Serial2/0] ft1 alarm-threshold los pulse-detection 300
1.5.42  ft1 bert
ft1 bert pattern { 2^20 | 2^15 } time minutes [ unframed ]
undo ft1 bert
T1-F接口视图
【缺省级别】
2:系统级
time minutes:设置BERT测试事件,以分钟计,最长1440分钟。
【描述】
ft1 bert命令用来进行线路位(Bit)错误率的测试。undo ft1 bert命令用来取消进行线路位(Bit)错误率的测试。
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前我们T1-F单板支持2^20和 2^15两种测试模式。
BERT测试状态和测试结果详见T1-F接口显示部分。
[Sysname-Serial2/0] ft1 bert pattern 2^20 time 10
1.5.43  ft1 cable
ft1 cable { long decibel | short length }
undo ft1 cable
T1-F接口视图
【缺省级别】
2:系统级
long decibel:匹配655英尺以上的传输线路,参数decibel的值可以为0db-7.5db-15db-22.5db,可根据接收端信号质量选择不同的衰减参数,此时不需要外接CSU。
short length:匹配655英尺以下的传输线路,参数length的值可以为133ft、266ft399ft533ft655ft可根据传输线路的长度选择相应的长度参数。
【描述】
ft1 cable命令用来设置T1-F接口匹配的传输线路的衰减或长度。undo ft1 cable命令用来恢复缺省情况。
缺省情况下,T1-F接口匹配的传输线路衰减为long 0db
本命令主要作用是配置发送时的信号波形,以适应不同传输需要。实际使用中可根据接收端收到的信号质量的好坏来决定是否使用此命令。如果信号质量较好可以使用缺省设置。
# 将T1-F接口匹配的传输线路设为133英尺。
[Sysname-Serial2/0] ft1 cable short 133ft
1.5.44  ft1 clock
ft1 clock { master | slave }
undo ft1 clock
T1-F接口视图
【缺省级别】
2:系统级
master:使用内部时钟模式。
slave:使用线路时钟模式。
【描述】
ft1 clock命令用来设置T1-F接口的时钟方式。undo ft1 clock命令用来恢复缺省情况。
当T1-F接口作为DCE设备使用时,应选择内部时钟,即master时钟方式;作为DTE设备使用时,应选择线路时钟,即slave时钟方式。
当两台路由器的T1-F接口直接相连时,必须使两端分别工作在线路时钟方式(slave)和内部时钟方式(master)。当路由器的T1-F接口与交换机连接时,交换机是DCE设备,负责提供时钟;而路由器的接口需工作在线路时钟方式(slave)。
# 设置T1-F接口的时钟为master方式。
[Sysname-Serial2/0] ft1 clock master
1.5.45  ft1 code
ft1 code { ami | b8zs }
undo ft1 code
T1-F接口视图
【缺省级别】
2:系统级
【描述】
ft1 code命令用来设置T1-F接口的线路编码格式。undo ft1 code命令用来恢复缺省情况。
缺省情况下,T1-F接口的线路编码格式为b8zs
·              线路编码采用ami方式时,在该接口上需要同时配置ft1 data-coding inverted,才能保证接口正常工作。
相关配置可参考命令ft1 data-coding
# 设置接口T1-F接口的线路编解码方式为AMI
[Sysname-Serial2/0] ft1 code ami
1.5.46  ft1 data-coding
ft1 data-coding { inverted | normal }
undo ft1 data-coding
T1-F接口视图
【缺省级别】
2:系统级
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
【描述】
ft1 data-coding命令用来设置T1-F接口是否对用户数据进行翻转。undo ft1 data-coding命令用来恢复缺省情况。
缺省情况下,不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当T1-F接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现的过多连0的缺陷。
需注意的是,只有通信的T1-F线路两端的T1-F接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置T1-F接口对数据翻转。
[Sysname-Serial2/0] ft1 data-coding inverted
1.5.47  ft1 fdl
ft1 fdl { ansi | att | both | none }
undo ft1 fdl
T1-F接口视图
【缺省级别】
2:系统级
ansi设置T1-F接口的FDL支持ANSI T1.403 规范。
att设置T1-F接口的FDL支持AT&T TR 54016 规范。
none禁止FDL的使用。
【描述】
ft1 fdl命令用来配置T1-F接口在ESF格式时FDL比特位的使用模式。undo ft1 fdl命令用来恢复缺省情况。
缺省情况下,FDL为禁止状态。
FDLT1ESF帧格式中4kbps的一个带宽,可以用来传递性能信息或者环回码之类。
# 设置T1-F接口的FDL支持ANSI规范。
[Sysname-Serial2/0] ft1 fdl ansi
1.5.48  ft1 frame-format
ft1 frame-format { esf | sf }
undo ft1 frame-format
T1-F接口视图
【缺省级别】
2:系统级
esf:设置T1-F接口的帧格式为扩展超帧格式(Extended Super Frame)。
sf:设置T1-F接口的帧格式为超帧格式(Super Frame)。
【描述】
ft1 frame-format命令用来设置T1-F接口的帧格式。undo ft1 frame-format命令用来恢复缺省情况。
缺省情况下,T1-F接口的帧格式为esf
T1-F接口支持超帧(SFSuper Frame)和扩展超帧(ESFextended Super Frame)两种帧格式。在超帧格式中,多个帧可以共享相同的帧同步信息和信令信息,从而有更多的有效位来传送用户数据。实际应用中,经常需要对系统进行测试,扩展超帧技术可以用来满足在测试时不影响正常业务运行的要求。
# 设置T1-F接口的帧格式为超帧格式。
[Sysname-Serial2/0] ft1 frame-format sf
1.5.49  ft1 idlecode
ft1 idlecode { 7e | ff }
undo ft1 idlecode
T1-F接口视图
【缺省级别】
2:系统级
7e:线路空闲码为0x7e格式。
ff:线路空闲码为0xff格式。
【描述】
ft1 idlecode命令用来设置T1-F接口的线路空闲码类型。undo ft1 idlecode命令用来恢复缺省情况。
缺省情况下,T1-F接口的线路空闲码类型为0x7e
T1-F接口的线路空闲码类型是指在没有被绑定到逻辑通道的时隙上发送的码型。T1-F接口的线路空闲码类型有两种:0x7e和0xff。
# 设置T1-F接口的线路空闲码类型为0x7e。
[Sysname-Serial2/0] ft1 idlecode 7e
1.5.50  ft1 itf
ft1 itf { number number | type { 7e | ff } }
undo ft1 itf { number | type }
T1-F接口视图
【缺省级别】
2:系统级
number number:设置帧间填充字节的个数,取值范围为0~14,单位为字节。
【描述】
ft1 itf命令用来设置T1-F接口的帧间填充字节类型和个数。undo ft1 itf命令用来恢复缺省情况。
缺省情况下,T1-F接口的帧间填充字节类型为0x7e,字节个数为4个。
T1-F接口的帧间填充符是指在已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。T1-F接口的帧间填充符类型有两种:0x7e0xff
同时配置了ft1 code ami命令和ft1 data-coding inverted命令后,不能配置ft1 itf type ff命令,否则T1-F接口不能正常工作。
# 设置T1-F接口的帧间填充字节类型为0xff。
[Sysname-Serial2/0] ft1 itf type ff
# 设置T1-F接口的帧间填充字节个数为5。
[Sysname-Serial2/0] ft1 itf number 5
1.5.51  ft1 loopback
ft1 loopback { local | payload | remote }
undo ft1 loopback
T1-F接口视图
【缺省级别】
2:系统级
local:设置接口对内自环。
payload:设置接口净荷环回。
remote:设置接口对外环回。
【描述】
ft1 loopback命令用来设置T1-F接口进行对内自环、净荷环回或对外环回。undo ft1 loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
# 设置T1-F接口进行对内自环。
[Sysname-Serial2/0] ft1 loopback local
1.5.52  ft1 sendloopcode
ft1 sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
T1-F接口视图
【缺省级别】
2:系统级
fdl-ansi-llb-down:发送FDL承载的符合ANSI规范的线路环回去激活码,解除环回。
fdl-ansi-llb-up:发送FDL承载的符合ANSI规范的线路环回激活码,启动远端环回。
fdl-ansi-plb-down:发送FDL承载的符合ANSI规范的净荷环回去激活码,解除环回。
fdl-ansi-plb-up:发送FDL承载的符合ANSI规范的净荷环回激活码,启动远端环回。
inband-llb-down:发送符合ANSI规范和AT&T规范的带内线路环回去激活码,解除环回。
inband-llb-up:发送符合ANSI规范和AT&T规范的带内线路环回激活码,启动远端环回。
【描述】
ft1 sendloopcode命令用来配置发送远程环回控制码。
缺省情况下,不发送远程环回控制码。
T1-F接口下可以通过发送环回控制码对远端的T1-F接口进行环回的自动配置。LLB为线路环回(Line Loop Back),这种方式下一个T1的PCM帧的全部193位(包括1位同步位及192位有效带宽)都被环回;PLB为净荷环回(Payload Loop Back),这种方式下仅192位有效带宽被环回。环回码的格式规范包括ANSI T1.403和AT&T TR 54016。SF格式下的LLB环回码占用有效带宽(1-24时隙);ESF格式下对LLB和PLB的环回码均使用ESF帧的FDL比特位收发。
#发送带内line loop back的激活码。
[Sysname-Serial2/0] ft1 sendloopcode inband-llb-up
1.5.53  ft1 timeslot-list
ft1 timeslot-list list [ speed { 56k | 64k } ]
undo ft1 timeslot-list
T1-F接口视图
【缺省级别】
2:系统级
list:被捆绑的时隙编号,取值范围为1~24。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以用number1,number2-number3的形式同时指定多个时隙。
speed { 56k | 64k }:时隙捆绑速率,单位为kbps。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。时隙的缺省速率为64kbps。
【描述】
ft1 timeslot-list命令用来设置T1-F接口的时隙捆绑。undo ft1 timeslot-list命令用来恢复缺省情况。
缺省情况下,T1-F接口均捆绑所有的时隙,即T1-F接口的缺省速率为1536kbps。
在对T1-F接口进行时隙捆绑后,接口的速率会同时改变。例如,当用户将1~10这十个时隙捆绑之后,接口的速率就会变为10×64kbps(或10×56kbps)。
与CT1/PRI接口不同的是,在T1-F接口上只能捆绑出一个通道组(channel set),捆绑出的通道组就对应当前的同步串口。而在CT1/PRI接口上,可以捆绑出多个通道组,并且每捆绑一个通道组,系统都会自动生成一个同步串口,与之相对应。
# 将T1-F接口上的1、2、5、10~15、18时隙捆绑起来。
[Sysname-Serial2/0] ft1 timeslot-list 1,2,5,10-15,18
1.6  CE3接口基本配置命令
1.6.1  bert (CE3 interface)
bert pattern { 2^7 | 2^11 | 2^15 | qrss } time number [ unframed ]
undo bert
CE3接口视图
【缺省级别】
2:系统级
pattern:设置BERT测试模式,包括2^7,2^11,2^15和QRSS。
2^7:发送的码流长度为2的7次方个bit。
2^11:发送的码流长度为2的11次方个bit。
2^15:发送的码流长度为2的15次方个bit。
qrss:发送码流长度为2的20次方个bit,且码流中不允许连续14个以上的0。
time number :设置BERT测试的持续时间,单位为分钟,取值范围为1~1440。
unframed:设置测试数据流填充帧的开销位。
【描述】
bert命令用来进行线路位(Bit)错误率的测试。undo bert命令用来取消该测试。
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前CE3接口支持2^7,2^11,2^15和QRSS这几种测试模式。
BERT测试方式为,本端发出测试数据流,经过线路某处环回回来,本端检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对端设置为远端环回等。
利用bert命令配置好测试模式,指定测试持续时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。BERT测试状态和测试结果的说明详见CE3接口显示部分。
# 在CE3接口2/0上执行QRSS格式的BERT测试10分钟。
[Sysname] interface e3 2/0
[Sysname-E3 2/0] bert pattern qrss time 10
1.6.2  clock (CE3 interface)
undo clock
CE3接口视图
【缺省级别】
2:系统级
master:使用内部时钟模式。
slave:使用线路时钟模式。
【描述】
clock命令用来配置CE3接口的时钟模式。undo clock命令用来恢复缺省情况。
缺省情况下,CE3接口的时钟模式为线路时钟。
使用内部时钟还是线路时钟,主要根据所连接的对端设备而定,如果与传输设备相连,本端通常设置为使用线路时钟。
如果是两台路由器的CE3接口直接相连,则应该把一端路由器时钟设置为内部时钟模式,另一端路由器时钟设置为线路时钟模式。
# 设置CE3接口的时钟为内部时钟模式。
[Sysname] controller e3 2/0
[Sysname-E3 2/0] clock master
1.6.3  controller e3
controller e3 interface-number
【缺省级别】
2:系统级
interface-number:CE3接口的编号。
【描述】
controller e3命令用来进入CE3接口视图。
相关配置可参考命令display controller e3
# 进入接口E3 2/0的视图。
[Sysname-E3 2/0]
1.6.4  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置CE3接口通过各种方式形成的同步串口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
相关配置可参考命令e1 channel-sete1 unframedusing
# 设置E3接口2/0在非通道化模式下形成的同步串口使用32位CRC校验。
[Sysname-E3 2/0] using e3
[Sysname-E3 2/0] quit
[Sysname] interface serial 2/0/0:0
[Sysname-Serial2/0/0:0] crc 32
# 设置CE3接口2/0在通道化模式下形成的同步串口使用16位CRC校验。
[Sysname-E3 2/0] e1 3 channel-set 5 timeslot-list 1-20
[Sysname] interface serial 2/0/3:5
[Sysname-Serial2/0/3:5] crc 16
1.6.5  display controller e3
display controller e3 [ interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:CE3接口编号。
【描述】
display controller e3命令用来查看CE3接口的状态信息。
本命令可以显示CE3接口的状态信息,同时,还可以显示CE3接口工作在CE3模式时每个E1通道的相关信息。
# 显示接口E3 10/0的相关信息。
<Sysname> display controller e3 10/0
E3 10/0 current state: UP
Description : E3 10/0 Interface
  Frame-format G751, line code HDB3, clock slave, national-bit 1
  Current mode is CE3, loopback not set
  Alarm: none
  ERROR: 2 BPV, 0 EXZ, 0 FrmErr, 0 FEBE
  BERT state:(completed)
  Test pattern: 2^7, Status: Not Sync, Sync Detected: 0
    Time: 2 minute(s), Time past: 2 minute(s)
    Bit errors (since test started): 0 bits
    Bits received (since test started): 0 Mbits
    Bit errors (since latest sync): 0 bits
    Bits received (since latest sync): 0 Mbits
E3 10/0  CE1 1 is up
  Frame-format  NO-CRC4, clock slave, loopback not set
  Receiver alarm state is none
  BERT state:(stopped)
E3 10/0  CE1 2 is up
E3 10/0  CE1 3 is up
E3 10/0  CE1 4 is up
E3 10/0  CE1 5 is up
E3 10/0  CE1 6 is up
E3 10/0  CE1 7 is up
E3 10/0  CE1 8 is up
E3 10/0  CE1 9 is up
E3 10/0  CE1 10 is up
E3 10/0  CE1 11 is up
E3 10/0  CE1 12 is up
E3 10/0  CE1 13 is up
E3 10/0  CE1 14 is up
E3 10/0  CE1 15 is up
E3 10/0  CE1 16 is up
表1-18 display controller e3命令显示信息解释
E3接口的状态
E3接口的描述
帧格式(G751),线路码(HDB3),时钟(master/slave),国家位
工作方式(CE3/ E3),回环方式(payload/remote/local/no loopback)
Alarm: none
告警信息(los、ais、rai、lof)
不同类型的错误统计
BERT测试状态:
·       stopped: 被用户命令停止
·       running:正在测试中
·       completed:已经测试完成
测试模式:
·       2^7
·       2^11
·       2^15
·       QRSS
同步状态:
·       Not Sync:没有同步,表示线路有问题
·       Sync:已经同步,线路没有问题
总的测试时间、已经完成的测试时间
自测试开始后收到的错误比特数
自测试开始后收到的总比特数
自上一次同步以来收到的错误比特数
自上一次同步以来收到的总比特数
E3 10/0  CE1 1 is up
E3下划分的CE1通道
相应E1的帧格式(none/32/16)、时钟、是否设置环回等
显示接口收到的告警类别,包括:LOS、LOF、AIS、RAI。
当收到LOS、LOF、AIS之一时,向对方发送RAI,显示:Transmitter is sending RAI
1.6.6  e1 bert
e1 line-number bert pattern { 2^11 | 2^15 | 2^20 | 2^23 | qrss } time number [ unframed ]
undo e1 line-number bert
CE3接口视图
【缺省级别】
2:系统级
line-number :E1通道号,取值范围为1~28。
pattern:设置BERT测试模式,包括2^11、2^15、2^20、2^23和QRSS。
2^20:发送的码流长度为2的20次方个bit。
2^23:发送的码流长度为2的23次方个bit。
qrss:发送的码流长度为2的20次方个bit,且码流中不允许连续14个以上的0。
time number:设置BERT测试的持续时间,单位为分钟,取值范围为1~1440。
【描述】
e1 bert命令用来进行CE3接口下某E1通道的线路位(Bit)错误率的测试。undo e1 bert命令用来取消该测试。
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前E1通道支持2^11、2^15、2^20、2^23和QRSS这几种测试模式。
BERT测试方式如下:本端发出测试数据流,经过线路某处环回回来,检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对端设置为远端环回等。
# 在E1通道1上执行QRSS格式的BERT测试10分钟。
[Sysname-E3 2/0] e1 1 bert pattern qrss time 10
1.6.7  e1 channel-set
e1 line-number channel-set set-number timeslot-list list
undo e1 line-number channel-set set-number
CE3接口视图
【缺省级别】
2:系统级
line-number:E1通道的顺序号,取值范围为1~16。
set-number:指定E1通道上时隙捆绑形成的channel set的编号,取值范围为0~30。
timeslot-list list:被捆绑的时隙。list为时隙编号,取值范围为1~31。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
【描述】
e1 channel-set命令用来对E1通道进行时隙捆绑。undo e1 channel-set命令用来取消时隙捆绑。
CE3接口支持通道化到E1,每个E1最多可捆绑出31个通道。
当E1通道工作在成帧方式(CE1方式)时,可以对其进行时隙捆绑。系统会自动创建一个Serial接口,编号为serial number /line-number:set-number,如E3 1/0的第一个e1的channel-group 0生成的串口为1/0/1:0。此接口的速率为N×64kbps,其逻辑特性与同步串口相同,可以视其为同步串口,进行进一步的配置。
相关配置可参考命令e1 unframed
# 在接口E3 2/0的第一个E1通道上捆绑出一个128kbps的串口。
[Sysname-E3 2/0] e1 1 channel-set 1 timeslot-list 1,2
1.6.8  e1 set clock
e1 line-number set clock { master | slave }
undo e1 line-number set clock
CE3接口视图
【缺省级别】
2:系统级
line-number:E1通道的编号,取值范围为1~16。
master:使用内部时钟模式。
slave:使用线路时钟模式。
【描述】
e1 set clock命令用来配置CE3接口下E1通道的时钟模式。undo e1 set clock命令用来恢复缺省情况。
缺省情况下,CE3接口下E1通道的时钟模式为线路时钟。
当CE3接口工作在通道化方式下,各个E1通道均能独立设置时钟。
# 设置E3接口下第一个E1通道的时钟为线路时钟模式。
[Sysname-E3 2/0] e1 1 set clock slave
1.6.9  e1 set frame-format
e1 line-number set frame-format { crc4 | no-crc4 }
undo e1 line-number set frame-format
CE3接口视图
【缺省级别】
2:系统级
line-number:E1通道的顺序号取值范围为1~16。
crc4:E1通道的帧格式为crc4。
no-crc4:E1通道的帧格式为no-crc4。
【描述】
e1 set frame-format命令用来配置E1通道的帧格式。undo e1 set frame-format命令用来恢复缺省情况。
缺省情况下,E1通道的帧格式为no-crc4
只有当E1通道工作在成帧方式时(使用命令undo e1 unframed),才能配置本命令。
# 设置E3接口下第一个E1通道的帧格式为crc4。
[Sysname-E3 2/0] e1 1 set frame-format crc4
1.6.10  e1 set loopback
e1 line-number set loopback { local | payload | remote }
undo e1 line-number set loopback
CE3接口视图
【缺省级别】
2:系统级
local:允许E1通道对内自环。
payload:设置接口净荷环回。
remote:允许E1通道对外远端环回。
【描述】
e1 set loopback命令用来设置E3接口下E1子接口的自环方式。undo e1 set loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
如果E1通道的链路层协议为PPP,设置自环或环回后,链路层协议状态将上报为DOWN。这属于正常情况。
# 设置E3接口下第一个E1通道的自环方式为local
[Sysname-E3 2/0] e1 1 set loopback local
1.6.11  e1 shutdown
e1 line-number shutdown
undo e1 line-number shutdown
CE3接口视图
【缺省级别】
2:系统级
【描述】
e1 shutdown命令用来关闭CE3接口的某个E1通道。undo e1 shutdown命令用来恢复缺省情况。
缺省情况下,E1通道是打开的。
该命令对于E1通道及其捆绑出的串口均有效。对指定E1通道执行e1 shutdown操作后,该E1通道捆绑形成的串口将shutdown,停止收发数据。如果执行undo e1 shutdown操作,则所有该E1通道捆绑形成的串口将被重新启用。
# 关闭E3接口下第一个E1通道。
[Sysname-E3 2/0] e1 1 shutdown
1.6.12  e1 unframed
e1 line-number unframed
undo e1 line-number unframed
CE3接口视图
【缺省级别】
2:系统级
【描述】
e1 unframed命令用来配置CE3接口的E1通道工作在非成帧方式(E1方式)。undo e1 unframed命令用来恢复缺省情况。
缺省情况下,E1通道工作在成帧方式。
当E1配置成非成帧方式后,它将不包含帧控制信息,也不分时隙,不能进行时隙捆绑。此时,系统会自动创建一个Serial接口,编号为serial number/line-umber:0。此接口的速率为2048kbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 设置E3接口下第一个E1通道工作在非成帧方式。
[Sysname-E3 2/0] e1 1 unframed
1.6.13  fe3
fe3 { dsu-mode { 0 | 1 } | subrate number }
undo fe3 { dsu-mode | subrate }
CE3接口视图(FE3模式)
【缺省级别】
2:系统级
dsu-mode:设置FE3(Fractional E3)的DSU模式,支持常用的几家厂商的FE3 DSU模式,如下:
0:Digital Link,支持子速率范围为358~34010kbps,共95个速率等级,级差358kbps。
1:Kentrox,支持子速率范围为500~24500,34010kbps,共50个速率等级,级差500kbps。
subrate number:工作在FE3模式下的CE3接口的子速率。number的取值范围为1~34010,单位是kbps。
【描述】
fe3命令用于配置CE3接口工作在FE3模式,并配置DSU模式或子速率。undo fe3 命令用来恢复缺省情况。
缺省情况下,DSU模式为1,即Kentrox模式;子速率为34010kbps。
FE3(Fractional E3,或称Subrate E3)是E3的一种非标准应用模式。目前各厂商支持的速率等级均不一样,使用fe3命令可以使我们的设备和其他厂家设备的FE3 DSU模式兼容,实现互通。
·              该命令仅在支持FE3特性的CE3单板上有效,如CE3单板不支持FE3特性系统将提示该命令无效。
·              该命令仅能在E3模式下使用,在CE3模式下该命令不可见。
·              通过fe3 subrate设置的速率值是一个大概值。由于通过fe3 dsu-mode命令配置的各DSU的子速率值是离散的,因此,当再通过fe3 subrate命令指定子速率后,E3接口会根据当前配置的DSU模式计算出与这个指定子速率最匹配的精确速率(精确到bps),并设置硬件电路支持该速率。
·              通过display interface serial interface-number:0命令可以查看E3接口的DSU模式、子速率设置值、接口实际速率和接口的波特率。接口实际速率为不含开销在内的纯数据带宽,接口波特率(34368kbps)为E3线路的实际速率(含开销位在内)。
# 设置E3接口2/0工作在FE3模式,DSU模式为1,子速率为3000kbps。
[Sysname-E3 2/0] fe3 dsu-mode 1
[Sysname-E3 2/0] fe3 subrate 3000
1.6.14  loopback (CE3 interface)
undo loopback
CE3接口视图
【缺省级别】
2:系统级
local:允许CE3接口对内自环。
payload:允许CE3接口对外载荷环回。
remote:允许CE3接口对外远端环回。
【描述】
loopback命令用来配置CE3接口的自环方式。undo loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
只有在进行某些特殊功能测试时,才需要将CE3接口设为自环。
如果将CE3接口的链路层协议配置为PPP,设置环回后,链路层协议状态将上报为Down,这属于正常情况。
# 允许接口E3 2/0对内自环。
[Sysname-E3 2/0] loopback local
1.6.15  national-bit
national-bit { 0 | 1 }
undo national-bit
CE3接口视图
【缺省级别】
2:系统级
0:配置CE3接口的National bit 为0。表明这个接口只能进行国内通信。
1:配置CE3接口的National bit 为1。表明这个接口只能进行国际通信。
【描述】
national-bit命令用来配置CE3接口的National bit位。undo national-bit命令用来恢复缺省情况。
缺省情况下,CE3接口的National bit 为1。
只有在某些特殊情况下,才需要将E3 接口的National bit设为0。
相关配置可参考命令controller e3
# 设置接口E3 2/0的national-bit位为0。
[Sysname-E3 2/0] national-bit 0
1.6.16  reset counters controller e3
reset counters controller e3 interface-number
【缺省级别】
2:系统级
【描述】
reset counters controller e3命令用来清除CE3接口的controller计数器。controller计数器值可以用display controller e3命令来查看。
单独清除CE3接口的controller计数器只能使用reset counters controller e3命令,不能使用reset counters interface命令,该命令会清除所有接口的计数器。
# 清除CE3接口2/0的controller计数器。
<Sysname> reset counters controller e3 2/0
1.6.17  using (CE3 Interface)
using { ce3 | e3 }
undo using
CE3接口视图
【缺省级别】
2:系统级
ce3:设置CE3接口工作在通道化模式。
e3:设置CE3接口工作在非通道化模式。
【描述】
using命令用来配置CE3接口的工作模式。undo using命令用来恢复缺省情况。
缺省情况下,CE3接口工作在通道化模式。
只有当CE3接口工作在通道化模式时,才能够对E1通道进行配置。
当CE3接口工作在非通道化模式时,系统会自动创建一个Serial接口,编号为serial number/0:0。此接口的速率为34.368Mbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 配置接口E3 2/0工作在非通道化模式。
CT3接口基本配置命令
1.6.18  alarm (CT3 interface)
alarm { detect | generate { ais | febe | idle | rai } }
undo alarm { detect | generate { ais | febe | idle | rai } }
CT3接口视图
【缺省级别】
2:系统级
detect:打开或关闭CT3接口的定时检测各种告警的功能,缺省情况下,检测功能处于打开状态。
generate:发送某种告警信号,如AIS、RAI、IDLE和FEBE。可用于线路状态测试,缺省情况下,不发送告警信号。
ais:Alarm Indication Signal,即告警指示信号。
febe:Far End Block Error,即远端块错误。
idle:空闲信号。
【描述】
alarm命令用来配置CT3接口的告警信号检测与发送功能。用户可打开或关闭告警信号的检测开关,也可发送某种告警信号以测试线路状态等。undo alarm命令用于取消各设置。
上电后,CT3接口的告警信号定时检测功能是打开的,并能通过接口显示实时报告接口告警状态,如LOS、LOF、AIS、RAI等。当检测到LOS、LOF或AIS后,会向对方发送RAI告警信号。
主要的告警信号包括:LOS为Loss Of Signal,即信号丢失;LOF为Loss Of Frame,即帧同步丢失;AIS为Alarm Indication Signal,即告警指示信号;RAI为Remote Alarm Indication,即远端告警指示信号;FEBE为Far End Block Error,即远端块错误;IDLE为空闲信号。各信号具体格式遵循T3规范ANSI T1.107-1995。
接口一次只能发送一种告警信号(包括在使用detect功能时检测到LOS、LOF或AIS后而产生的RAI告警信号),发送另一种告警信号前必须使用undo alarm命令取消前一种告警信号。detect功能产生的告警信号(RAI)必须通过undo alarm detect命令取消。
告警的收发状态详见CT3接口显示部分。
# 打开CT3接口2/0的告警检测功能。
[Sysname] controller t3 2/0
[Sysname-T3 2/0] alarm detect
# 在CT3接口2/0上发送AIS告警信号。
[Sysname-T3 2/0] alarm generate ais
1.6.19  bert (CT3 interface)
undo bert
CT3接口视图
【缺省级别】
2:系统级
【描述】
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前CT3接口支持2^7,2^11,2^15和QRSS这几种测试模式。
利用bert命令配置好测试模式,指定测试持续时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。BERT测试状态和测试结果的说明详见CT3接口显示部分。
# 在CT3接口2/0上执行QRSS格式的BERT测试10分钟。
[Sysname-T3 2/0] bert pattern qrss time 10
1.6.20  cable (CT3 interface)
cable feet
undo cable
CT3接口视图
【缺省级别】
2:系统级
feet:电缆长度,取值范围为0~450,单位为英尺(feet)。
【描述】
cable命令用来配置CT3接口所连接电缆的长度。undo cable命令用来恢复缺省情况。
缺省情况下,CT3接口所连接电缆的长度的值为49英尺。
CT3接口所连接电缆的长度是指从路由器到配线架之间电缆的长度。
# 设置接口T3 2/0的电缆长度为50英尺。
[Sysname-T3 2/0] cable 50
1.6.21  clock (CT3 interface)
undo clock
CT3接口视图
【缺省级别】
2:系统级
master:使用内部时钟模式。
slave:使用线路时钟模式。
【描述】
clock命令用来配置CT3接口的时钟模式。undo clock命令用来恢复缺省情况。
缺省情况下,CT3接口的时钟模式为线路时钟。
使用内部时钟还是线路时钟主要根据所连接的对端设备而定,如果与传输设备相连,本端通常设置为使用线路时钟。
如果是两台路由器的CT3接口直接相连,则应该把一端路由器时钟设置为内部时钟模式,另一端路由器时钟设置为线路时钟模式。
# 设置CT3接口的时钟为内部时钟模式。
[Sysname-T3 2/0] clock master
1.6.22  controller t3
controller t3 interface-number
【缺省级别】
2:系统级
interface-number:CT3接口的编号。
【描述】
controller t3命令用来进入CT3接口视图。
相关配置可参考命令display controller t3
# 进入接口T3 2/0的视图。
[Sysname-T3 2/0]
1.6.23  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置CT3接口通过各种方式形成的同步串口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
相关配置可参考命令t1 channel-sett1 unframedusing
# 设置T3接口2/0在非通道化模式下形成的同步串口使用32位CRC校验。
[Sysname-T3 2/0] using t3
[Sysname-T3 2/0] quit
# 设置CT3接口2/0在通道化模式下形成的同步串口使用16CRC校验。
[Sysname-T3 2/0] t1 2 channel-set 4 timeslot-list 5-11
[Sysname] interface serial 2/0/2:4
[Sysname-Serial2/0/2:4] crc 16
1.6.24  display controller t3
display controller t3 [ interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display controller t3命令用来查看CT3接口的状态信息。
本命令可以显示CT3接口的状态信息,同时还可以显示CT3接口工作在CT3模式时每个T1通道的相关信息。
# 显示接口T3 2/0的相关信息。
<Sysname> display controller t3 2/0
T3 2/0 current state :UP
Description : T3 2/0 Interface
  Work mode is CT3, cable length is 49 feet.
  Frame-format is C-BIT Parity, line code is B3ZS.
  Source clock is slave, loopback is not set.
Alarm state:
  Receiver alarm state is none.
MDL state:
  No message is sent now.
  Message data elements:
    EIC: line, LIC: line, FIC: line, UNIT: line
    FI: line, PORT_NO: line, GEN_NO: line
  Periodical detection is disabled.
FEAC state:
  No code is sent now.
  Periodical detection is enabled, no code received now.
Last clearing of counters: 14:39:02 UTC Sat 06/25/2005
  Data in current interval (22 seconds elapsed):
    0 Line Code Violations, 0 Far End Block Error
    0 C-Bit Coding Violation, 0 P-bit Coding Violation
    0 Framing Bit Err, 0 Severely Err Framing Secs
    0 C-bit Err Secs, 0 C-bit Severely Err Secs
    0 P-bit Err Secs, 0 P-bit Severely Err Secs
    0 Unavailable Secs, 0 Line Err Secs
T3 2/0  CT1 1 is up
  Frame-format ESF, clock slave, loopback not set
  FDL Performance Report is disabled
  Transmitter is sending none
  Line loop back deactivate code using inband signal last sent
    Test pattern: 2^11, Status: Not Sync, Sync Detected: 0
    Bits received (since test started): 0 Kbits
    Bits received (since latest sync): 0 Kbits
表1-19 display controller t3命令显示信息解释
接口的物理up/down状态
接口描述信息
Basic Configuration
接口基本配置信息
工作模式为通道化T3,线缆长度49feet;
工作模式包括通道化(CT3)和非通道化(T3)
帧格式为C-bit,线路编码为B3ZS;
帧格式包括C-bit和M23
时钟源为从模式,未设置环回。
时钟源包括master和slave两种模式,环回包括local、remote和payload三种
Alarm state
告警状态
MDL state:
MDL状态
当前没有发送MDL消息。
发送MDL消息(如path和idle-signal)时,显示如下:
Message sent now: path. idle signal
MDL数据元素
EIC、LIC、FIC和UNIT为四种MDL消息的公共元素,用户可设置
FI、PORT_NO和GEN_NO分别为消息path、idle-signal和test-signal的私有元素,用户可设置
MDL周期性检测被禁止。上电后默认为禁止。
当该检测功能被使能时,显示:
Periodical detection is enabled.
No message was received.
当检测到MDL消息时显示如:
Message received now: path.idle signal.
    path/FI: line
    idle Signal/PORT_NO: line
FEAC state:
FEAC状态
No code is sent now. DS3 Line Loop Back Deactivate was last sent.
当前没有FEAC信号发出,上次发出的FEAC信号为DS3 Line Loop Back Deactivate
FEAC周期性检测功能被使能。上电后默认使能。
当前未收到FEAC信号
DS3 Line Loop Back Deactivate last received.
上次收到的FEAC信号为DS3 Line Loop Back Deactivate
BERT状态(停止)
根据用户进行BERT操作的情况,有三种状态:
running-BERT测试正在进行;
complete-BERT测试自然完成(即达到测试时间);
stopped-BERT测试被提前中止
BERT测试模式,包括2^7、2^11、2^15以及QRSS等。
同步状态:是否同步。
子测试开始后检测到的同步次数
总的测试时间、已经完成的测试时间
自测试开始后收到的错误比特数
自测试开始后收到的总比特数
自上一次同步以来收到的错误比特数
自上一次同步以来收到的总比特数
历史统计数据
上次清0时间
从未清零显示Never,否则显示时间如:
当前interval(15分钟为一个interval)内的各项错误计数(已过去的时间为22秒)
线路信号错误数,包括:BPV错误、EXZ错误
Far End Block Error
远端块错误数
C-Bit Coding violation
C比特错误数
P比特错误数
Framing Bit Err
帧比特错误数
帧比特严重错误的秒数
C-bit Err Secs
C比特错误的秒数
C比特严重错误的秒数,指1秒内C比特错误数超过44的秒
P-bit Err Secs
P比特错误的秒数
P特严重错误的秒数,指1秒内P比特错误数超过44的秒
Unavailable Secs
服务无法获取的秒数
Line Err Secs
线路错误的秒数,包括:LOS、BPV、EXZ、C比特错误、P比特错误等
Data in Interval 1:
Interval 1内的数据
Total Data (last 17 15 minute intervals):
总的数据(前17个interval)
T3 2/0  CT1 1 is up
CT3接口下T1通道1的up/down状态
T1通道的帧格式,包括ESF和SF
时钟方式包括slave和master,环回包括local、remote和payload
禁止用FDL链路传输性能报告信息(PPR),可用fdl ansi命令使能
T1通道发送器在发送RAI。当收到LOS、LOF或AIS时,发RAI
Receiver alarm state is LOF
T1通道接收到的告警状态,包括:LOS、LOF、AIS和RAI
Line loop back activate code using inband signal last sent
上次发送的环回码:Line loop back activate code using inband signal
BERT测试状态。包括running、complete和stopped
测试模式、同步状态、检测到的同步次数
总测试时间、已经过去的测试时间
测试以来收到的错误比特数
测试以来收到的总比特数
上次同步以来收到的错误比特数
上次同步以来收到的总比特数
1.6.25  feac
feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
undo feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
CT3接口视图
【缺省级别】
2:系统级
detect:打开CT3接口上的定时检测FEAC链路信号功能,缺省情况下,定时检测FEAC链路信号功能处于打开状态。
generate:发送FEAC信号,包括ds3-losds3-aisds3-oofds3-idleds3-eqptfail。缺省情况下,不发送FEAC信号。
loopback:发送环回码,用于激活对端的线路环回(ds3-line)或者净荷环回(ds3-payload)。缺省情况下,不发送环回码。
【描述】
feac命令用来配置CT3接口的FEAC链路信号的检测和传输功能。undo feac命令用来取消已有的FEAC配置。
FEAC是远端告警与控制信号(Far End Alarm and Control signal),是利用C-bit帧格式中第一个子帧中的第三个C比特组成的一条数据链路,可用于传输各种告警状态信号,也可用于传输环回控制码,用来激活或者取消对端的环回,进行环回测试。ANSI T1.107a中规定,FEAC可用于传输多种告警信号(本命令中实现如上几种,多用于线路测试),并规定这条链路的数据帧为基于位的BOP(Bit Oriented Protocol)协议格式。
上电后,CT3接口的FEAC定时检测功能是打开的,但不发送任何FEAC信号。
当用feac generate loopback { ds3-line | ds3-payload }激活对端环回后,可用undo feac generate loopback { ds3-line | ds3-payload }取消对端环回。
需要注意的是,当利用该命令配置远端环回前,最好禁止本端的FEAC检测,以免发出的环回码在对方配好环回后被返回来,造成本端也配置为环回,引起线路上的环路死锁。
FEAC链路的收发状态的说明详见CT3接口显示部分。
# 打开CT3接口2/0的FEAC链路数据检测功能。
[Sysname-T3 2/0] feac detect
# 在CT3接口2/0上发送ds3-los信号。
[Sysname-T3 2/0] feac generate ds3-los
# 在CT3接口2/0上发送环回码给对端,设置对端为线路环回。
[Sysname-T3 2/0] feac generate loopback ds3-line
1.6.26  frame-format (CT3 interface)
frame-format { c-bit | m23 }
undo frame-format
CT3接口视图
【缺省级别】
2:系统级
c-bit:设置帧格式为C-bit
m23:设置帧格式为m23
【描述】
frame-format命令用来配置CT3接口所使用的帧格式。undo frame-format命令用来恢复CT3接口帧格式的缺省值。
缺省情况下,CT3接口的帧格式为c-bit
# 设置接口T3 2/0的帧格式为m23
[Sysname-T3 2/0] frame-format m23
1.6.27  ft3
ft3 { dsu-mode { 0 | 1 | 2 | 3 | 4 } | subrate number }
undo ft3 { dsu-mode | subrate }
CT3接口视图(FT3模式)
【缺省级别】
2:系统级
dsu-mode:设置FT3(Fractional T3)的DSU模式,支持常用的几家厂商的FT3 DSU模式,如下:
0:Digital Link,支持子速率范围为300~44210kbps,共147个速率等级,级差300746bps。
1:Kentrox,支持子速率范围为1500~35000kbps及44210kbps,共57个速率等级,级差1500000bps。
2:Larscom,支持子速率范围为3100~44210kbps,共14个速率等级,级差3157835bps。
3:Adtran,支持子速率范围为75~44210kbps,共588个速率等级,级差75187bps。
4:Verilink,支持子速率范围为1500~44210kbps,共20个速率等级,级差1578918bps。
subrate number:工作在FT3模式下的CT3接口的子速率。number的取值范围为1~44210,单位是kbps。
【描述】
ft3命令用于配置CT3接口工作在FT3模式,并配置DSU模式或子速率。undo ft3 命令用来恢复缺省情况。
缺省情况下,DSU模式为0,即Digital Link模式;子速率为44210kbps。
FT3(Fractional T3,或称Subrate T3)是T3的一种非标准应用模式。目前各厂商支持的速率等级均不一样,使用ft3命令可以使我们的设备和其他厂家设备的FT3 DSU模式兼容,实现互通。
·              该命令仅在支持FT3特性的CT3单板上有效,如CT3单板不支持FT3特性系统将提示该命令无效。
·              该命令仅能在T3模式下使用,在CT3模式下该命令不可见。
·              通过ft3 subrate设置的速率值是一个大概值。由于通过ft3 dsu-mode命令配置的各DSU的子速率值是离散的,因此,当再通过ft3 subrate命令指定子速率后,T3接口会根据当前配置的DSU模式计算出与这个指定子速率最匹配的精确速率(精确到bps),并设置硬件电路支持该速率。
·              通过display interface serial interface-number:0命令可以查看T3接口的DSU模式、子速率设置值、接口实际速率和接口的波特率。接口实际速率为不含开销在内的纯数据带宽,接口波特率(44736kbps)为T3线路的实际速率(含开销位在内)。
# 设置T3接口2/0工作在FT3模式,DSU模式为1,子速率为3000kbps。
[Sysname-T3 2/0] ft3 dsu-mode 1
[Sysname-T3 2/0] ft3 subrate 3000
1.6.28  loopback (CT3 interface)
undo loopback
CT3接口视图
【缺省级别】
2:系统级
local:允许CT3接口对内自环。
payload:允许CT3接口对外载荷环回。
remote:允许CT3接口对外远端环回。
【描述】
loopback命令用来配置CT3接口的使能环回检测功能并设置检测方式。undo loopback命令用来禁止CT3接口的环回检测功能。
CT3接口两种对外环回的区别在于:对外载荷环回(payload)需要处理帧头开销,而对外远端环回(remote)则不对帧进行处理。
缺省情况下,环回检测功能是禁止的。
环回功能通常用于进行某些特殊测试,正常工作时,不要启动环回。
如果将CT3接口的链路层协议配置为PPP,设置环回后,链路层协议状态将上报为down,这属于正常情况。
# 允许接口T3 2/0对内自环。
[Sysname-T3 2/0] loopback local
1.6.29  mdl (CT3 interface)
mdl { data { eic string | fic string | gen-no string | lic string | pfi string | port-no string | unit string } | detect | generate { idle-signal | path | test-signal } }
undo mdl [ data [ eic | fic | gen-no | lic | pfi | port-no | unit ] | detect | generate [ idle-signal |  path | test-signal ] ]
CT3接口视图
【缺省级别】
2:系统级
detect:打开CT3接口上的定时检测MDL消息功能。
data:设置MDL消息参数,其中eic、lic、fic和unit为三类MDL消息的公有参数,pfi、port-no和gen-no分别为消息path、idle signal和test signal的私有参数。这些参数为用户可定义的字符串,长度各有限制。
eic string:Equipment ID,为1~10个字符的字符串,缺省值为line。
fic string:Frame ID,为1~10个字符的字符串,缺省值为line。
gen-no string:Generator number in test signal message,test signal消息的私有参数,为1~38个字符的字符串,缺省值为line。
lic string:Location ID,为1~11个字符的字符串,缺省值为line。
pfi string:Facility ID in path message,path消息的私有参数,为1~38个字符的字符串,缺省值为line。
port-no string:Port number in idle signal message,idle signal消息的私有参数,为1~38个字符的字符串,缺省值为line。
unit string:Unit,为1~6个字符的字符串,缺省值为line。
generate:按照data中配置的参数定时发送MDL消息,包括path、idle signal和test signal,可以同时发送。
【描述】
mdl命令用来配置CT3接口的MDL链路消息检测与传输功能。undo mdl命令用来取消已有的MDL配置,undo mdl data { eic | lic | fic | unit | pfi | port-no | gen-no }用来恢复各字符串的缺省值。
MDL是维护数据链路(Maintenance Data Link),是利用C-bit帧格式中第五个子帧中的3个C比特组成的一条数据链路,可用于传输一些维护性的消息。ANSI T1.107a中规定,MDL可用于传输三种消息:path、idle signal和test signal,并规定这条链路的数据帧为LAPD协议格式。
MDL链路的收发状态详见CT3接口显示部分。
上电后,CT3接口的MDL定时检测功能是禁止的,消息参数为缺省值,不发送任何消息。
# 打开CT3接口2/0的MDL检测功能。
[Sysname-T3 2/0] mdl detect
# 配置CT3接口2/0的MDL的lic参数为字符串“hello”。
[Sysname-T3 2/0] mdl data lic hello
# 设置CT3接口2/0发送path消息。
[Sysname-T3 2/0] mdl generate path
1.6.30  reset counters controller t3
reset counters controller t3 interface-number
【缺省级别】
2:系统级
interface-number:接口编号。
【描述】
reset counters controller t3命令用来清除CT3接口的controller计数器。controller计数器值可以用display controller t3命令来查看。
单独清除CT3接口的controller计数器只能使用reset counters controller t3命令,不能使用reset counters interface命令,该命令会清除所有接口的计数器。
# 清除CT3接口2/0的controller计数器。
<Sysname> reset counters controller t3 2/0
1.6.31  t1 alarm
t1 line-number alarm { detect | generate { ais | rai } }
undo t1 line-number alarm { detect | generate { ais | rai } }
CT3接口视图
【缺省级别】
2:系统级
detect:打开CT3接口下某个T1通道的告警信号检测功能。
line-number:T1通道号,取值范围为1~28。
generate:发送某种告警信号,如AIS、RAI。可用于线路状态测试,缺省情况下,不发送告警信号。
【描述】
t1 alarm命令用来配置CT3接口下某个T1通道的告警信号检测与发送功能。用户可以打开告警信号的检测开关,也可发送某种告警信号以测试线路状态等。undo t1 alarm命令用于取消各设置。
上电后,CT3接口下各T1通道的告警信号定时检测功能是打开的,并能通过接口显示实时报告接口告警状态,如LOS、LOF、AIS、RAI等。当检测到LOS、LOF或AIS后,会向对方发送RAI告警信号。
主要的告警信号包括:LOS为Loss Of Signal,即信号丢失;LOF为Loss Of Frame,即帧同步丢失;AIS为Alarm Indication Signal,即告警指示信号;RAI为Remote Alarm Indication,即远端告警指示信号。各信号具体格式遵循T1规范ANSI T1.403。
一次只能发送一种告警信号(包括在使用detect功能时检测到LOS、LOF或AIS后而产生的RAI告警信号),发送另一种告警信号前必须使用undo t1 alarm命令取消前一种告警信号。detect功能产生的告警信号(RAI)必须通过undo t1 alarm detect命令取消。
告警的收发状态详见CT3接口显示部分。
# 打开CT3接口2/0的T1通道1的告警检测功能。
[Sysname-T3 2/0] t1 1 alarm detect
# 在CT3接口2/0的T1通道1上发送AIS告警信号。
[Sysname-T3 2/0] t1 1 alarm generate ais
1.6.32  t1 bert
t1 line-number bert pattern { 2^11 | 2^15 | 2^20 | 2^23 | qrss } time number [ unframed ]
undo t1 line-number bert
CT3接口视图
【缺省级别】
2:系统级
line-number :T1通道号,取值范围为1~28。
【描述】
t1 bert命令用来进行CT3接口下某T1通道的线路位(Bit)错误率的测试。undo t1 bert命令用来取消该测试。
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前T1通道支持2^11、2^15、2^20、2^23和QRSS这几种测试模式。
# 在T1通道1上执行QRSS格式的BERT测试10分钟。
[Sysname-T3 2/0] t1 1 bert pattern qrss time 10
1.6.33  t1 channel-set
t1 line-number channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
undo t1 line-number channel-set set-number
CT3接口视图
【缺省级别】
2:系统级
line-number:T1通道的顺序号,取值范围为1~28。
set-number:指定T1通道上时隙捆绑形成的channel set的编号,取值范围为0~23。
speed:配置时隙捆绑的方式。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。缺省情况下,speed的取值为64k。
【描述】
t1 channel-set命令用来对T1通道进行时隙捆绑。undo t1 channel-set命令用来取消时隙捆绑。
当T1通道工作在成帧方式(CT1方式)时,可以对其进行时隙捆绑。系统会自动创建一个Serial接口,编号为serial number/ line-number:set-number。此接口的速率为N×64kbps(或N×56kbps),其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
相关配置可参考命令t1 unframed
# 在T3 2/0接口的第一个T1通道上捆绑出一个128kbps的串口。
[Sysname-T3 2/0] t1 1 channel-set 1 timeslot-list 1,2
1.6.34  t1 sendloopcode
t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
undo t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
CT3接口视图
【缺省级别】
2:系统级
fdl-ansi-line-up:发送FDL承载的符合ANSI规范的线路环回激活码,启动远端环回。
fdl-ansi-payload-up:发送FDL承载的符合ANSI规范的净荷环回激活码,启动远端环回。
fdl-att-payload-up发送FDL承载的符合AT&T规范的净荷环回激活码,启动远端环回。
inband-line-up:发送符合ANSI规范和AT&T规范的带内线路环回激活码,启动远端环回。
【描述】
t1 sendloopcode命令用来设置对端CT3接口的某个T1通道的环回模式。undo t1 sendloopcode命令用来取消对应的配置。
环回测试是一种有效的问题诊断方法。除了在远端设备上通过命令行配置环回外,还可发送环回控制码,设置远端设备的环回。ANSI T1.403规范定义了T1接口下的环回控制码类型和格式。按照环回类型,可分为line环回(数据流不经过成帧器)和payload环回(数据流经过成帧器)两种;按照传输环回控制码的载体,可分为利用inband信号(即T1的192位有效数据带宽或193位全部带宽)和利用ESF帧格式中的FDL链路两种。
# 在CT3接口2/0发送inband信号,配置对端CT3接口的T1通道1为line环回。
[Sysname-T3 2/0] t1 1 sendloopcode inband-line-up
1.6.35  t1 set clock
t1 line-number set clock { master | slave }
undo t1 line-number set clock
CT3接口视图
【缺省级别】
2:系统级
master:设置T1通道使用内部时钟。
slave设置T1通道使用线路时钟。
【描述】
t1 set clock命令用来配置CT3接口下T1通道的时钟模式。undo t1 set clock命令用来恢复缺省设置。
缺省情况下,CT3接口下T1通道的时钟模式为线路时钟。
当CT3接口工作在通道化工作方式下,各个T1通道均能独立设置时钟。
# 设置T3接口下第一个T1通道的时钟为线路时钟模式。
[Sysname-T3 2/0] t1 1 set clock slave
1.6.36  t1 set frame-format
t1 line-number set frame-format { esf | sf }
undo t1 line-number set frame-format
CT3接口视图
【缺省级别】
2:系统级
line-numbe:T1通道号,取值范围为1~28。
esf:设置T1通道使用扩展超帧(Extended Super Frame)格式。
sf:设置T1通道使用超帧(Super Frame)格式。
【描述】
t1 set frame-format命令用来配置T1通道的帧格式。undo t1 set frame-format命令用来恢复缺省情况。
缺省情况下,T1通道的帧格式为esf
只有当T1通道工作在成帧方式时(使用命令undo t1 unframed),才能配置本命令。
# 设置T3接口下第一个T1通道的帧格式为sf。
[Sysname-T3 2/0] t1 1 set frame-format sf
1.6.37  t1 set loopback
t1 line-number set loopback { local | remote | payload }
undo t1 line-number set loopback
CT3接口视图
【缺省级别】
2:系统级
local:设置T1通道进行对内自环。
remote:设置T1通道进行对外远端环回。
payload:设置T1通道进行净荷环回。
【描述】
t1 set loopback命令用来设置T3接口下T1子接口的自环方式。undo t1 set loopback命令用来禁止T1自环。
缺省情况下,禁止T1自环。
如果T1通道的链路层协议为PPP,设置自环或远端环回后,链路层协议状态将上报为DOWN,这属于正常情况。
环回功能通常用于进行某些特殊测试,正常工作时不要启动环回。
# 设置T3接口下第一个T1通道的自环方式为local
[Sysname-T3 2/0] t1 1 set loopback local
1.6.38  t1 set fdl
t1 line-number set fdl { ansi | att | both | none }
undo t1 line-number set fdl
CT3接口视图
【缺省级别】
2:系统级
fdl:设置T1通道的FDL链路格式。
ansi:设置T1通道的FDL链路格式为ANSI T1.403规范所定义。
att设置T1通道的FDL链路格式为AT&T TR 54016 规范所定义。
none禁止T1通道FDL的使用。
【描述】
t1 set fdl命令用来设置CT3接口下T1通道的FDL链路格式。undo t1 set fdl命令用来取消T1通道的FDL链路传输。
缺省情况下,FDL为禁止状态。
FDL是T1的ESF帧格式中的一条4kbps的数据链路,可用于传输PPR(Periodical Performance Report)数据,也可传输环回控制码,配置远端环回。ANSI T1.403规范定义,PPR数据格式为LAPD协议格式,环回控制码格式为BOP(Bit Oriented Protocol)协议格式。这里的t1 set fdl命令仅用于启动PPR数据传输,对环回码的发送和检测没有影响,即收发环回码无需配置fdl。
需要注意的是:只有在CT3接口下的T1通道工作在通道化模式下,且T1帧格式为ESF时候,该配置才有效。
# 设置CT3接口2/0的T1通道1的FDL格式为ansi
[Sysname-T3 2/0] t1 1 set fdl ansi
1.6.39  t1 show
t1 line-number show
CT3接口视图
【缺省级别】
2:系统级
show:显示T1通道物理线路状态。
【描述】
t1 show命令用来快捷显示CT3接口下某个T1通道线路状态。
# 显示T1通道1的线路状态。
[Sysname] interface t3 2/0
[Sysname-T3 2/0] t1 1 show
T3 2/0  CT1 1 is up
表1-20 t1 show命令显示信息解释
T3 2/0  CT1 1 is up
T1通道的帧格式,包括ESF和SF
禁止用FDL链路传输性能报告信息(PPR),可用t1 set fdl ansi命令使能
T1通道接收到的告警,包括:LOS、LOF、AIS和RAI
BERT测试状态。包括running、complete和stopped(not completed)
测试模式、同步状态、检测到的同步次数
总测试时间、已经过去的测试时间
测试以来收到的错误比特数
测试以来收到的总比特数
上次同步以来收到的错误比特数
上次同步以来收到的总比特数
1.6.40  t1 shutdown
t1 line-number shutdown
undo t1 line-number shutdown
CT3接口视图
【缺省级别】
2:系统级
【描述】
t1 shutdown命令用来关闭CT3接口的某个T1通道。undo t1 shutdown命令用来打开T1通道。
缺省情况下,T1通道是打开的。
该命令对于T1通道及其捆绑出的串口均有效。对指定T1通道执t1 shutdown操作后,该T1通道捆绑形成的串口将shutdown,停止收发数据。如果执行undo t1 shutdown操作,则所有该T1通道捆绑形成的串口将被重新启用。
# 关闭T3接口下第一个T1通道。
[Sysname-T3 2/0] t1 1 shutdown
1.6.41  t1 unframed
t1 line-number unframed
undo t1 line-number unframed
CT3接口视图
【缺省级别】
2:系统级
【描述】
t1 unframed命令用来配置CT3接口的T1通道工作在非成帧方式(T1方式)。undo t1 unframed命令用来配置CT3接口的T1通道工作在成帧方式(CT1方式)。
缺省情况下,T1通道工作在成帧方式。
当T1配置成非成帧方式后,它将不包含帧控制信息,也不分时隙,不能进行时隙捆绑。此时,系统会自动创建一个Serial接口,编号为serial number/line-umber:0。此接口的速率为1544kbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 设置T3接口下第一个T1通道工作在非成帧方式。
[Sysname-T3 2/0] t1 1 unframed
1.6.42  using (CT3 interface)
using { ct3 | t3 }
undo using
CT3接口视图
【缺省级别】
2:系统级
ct3:设置CT3接口工作在通道化模式。
t3:设置CT3接口工作在非通道化模式。
【描述】
using命令用来配置CT3接口的工作模式。undo using命令用来恢复缺省情况。
缺省情况下,CT3接口工作在通道化模式。
只有当CT3接口工作在通道化模式时,才能够对T1通道进行配置。
当CT3接口工作在非通道化模式时,系统会自动创建一个Serial接口,编号为serial number/0:0。此接口的速率为44.736Mbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 配置接口T3 2/0工作在非通道化模式。
1.7  ISDN BRI接口配置命令
1.7.1  display interface bri
display interface [ bri ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface bri interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:显示指定BRI接口的信息。
down:显示当前状态为down的接口的信息以及down的原因。不指定该参数时,将不会根据接口状态来过滤显示信息。
【描述】
display interface bri命令用来显示BRI接口的相关信息。
·              如果不指定bri参数,将显示设备支持的所有接口的相关信息。
·              如果指定bri参数,不指定interface-number参数,将显示所有已创建的BRI接口的相关信息。
# 显示BRI接口2/0的详细信息。
<Sysname> display interface bri 2/0
Bri2/0 current state: UP
Description: Bri2/0 Interface
The Maximum Transmit Unit is 1500, Hold timer is 10(sec)
Baudrate is 128000 bps, Timeslot(s) Used: 1, 2
Internet Address is 6.6.5.5/24 Primary
Encapsulation is ISDN
Output queue : (Urgent queuing : Length)  100
Output queue : (Protocol queuing : Length)  500
Output queue : (FIFO queuing : Length)  75
Last clearing of counters: 17:41:01  Tue 04/19/2011
    Last 300 seconds input rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
    Last 300 seconds output rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
           0 errors, 0 runts, 0 giants,
           0 CRC, 0 align errors, 0 overruns,
           0 frame errors
           0 deferred
# 显示BRI接口2/0的概要信息。
<Sysname> display interface bri 2/0 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Bri2/0               DOWN DOWN    --
# 显示所有状态为down的BRI接口的概要信息。
<Sysname> display interface bri brief down
Bri2/0               DOWN Not connected
表1-21 display interface bri命令显示信息描述表
BRI接口当前的物理状态,状态可能为:
·       DOWN(Administratively):表示该BRI接口已经通过shutdown命令被关闭,即管理状态为关闭
·       DOWN:表示该BRI接口的物理状态为关闭(可能因为没有物理连线或者线路故障)
·       UP:该BRI接口的管理状态和物理状态均为开启
该接口的链路协议状态
接口描述信息
接口的最大传输单元(MTU)。缺省值为1500字节。表示长度大于MTU的报文,将会被分片后再发送。如果设置了不准分片,报文会被丢弃
报文的生命周期。报文如果在生命周期内没有被送出去,则将丢弃
BRI接口的带宽,使用的时隙
接口的IP地址
接口的封装协议为ISDN
输出队列(紧急队列中最大可容纳的消息数)
输出队列(协议队列中最大可容纳的消息数)
协议队列(Protocol queue)是指IP优先级为6 的报文将进入协议队列
输出队列(先进先出队列中最大可容纳的消息数)
最后一次清除接口统计信息的时间
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
           0 frame errors
接口收到的总报文数和总字节数:
·       errors:在物理层检测时发现的错误报文数目
·       runts:接口接收到小于规定的最小报文长度报文数
·       giants:接收到长度大于规定长度的报文数目
·       CRC:接收长度正常但CRC 校验错误的报文数目
·       align errors:排列错误
·       overruns:接收的报文速度大于转发处理能力导致无法处理的报文
·       aborts:接收报文的异常错误
·       no buffers:在接收报文时由于内部缓存满,导致帧丢弃
·       frame errors:帧错误
           0 deferred
接口发送的报文数和总字节数
·       underruns:因为接口读取内存的速度小于转发的速度而无法发送报文数目
·       collisions:发送报文时,检测到冲突的报文数目
·       deferred:因为延时或超时无法发送报文的数目
接口名称缩写
Link
接口物理连接状态,取值可能为:
·       UP:表示本链路物理上是连通的
·       ADM:表示本链路被手工关闭了,需要执行undo shutdown命令才能恢复真实的物理状态
Protocol
接口协议连接状态,取值为UP(s)
Main IP
接口主IP地址
接口的描述信息
Cause
接口物理连接状态为DOWN的原因,取值为Administratively时表示本链路被手工关闭了,需要执行undo shutdown命令才能恢复真实的物理状态
1.7.2  loopback (ISDN BRI interfacei)
loopback { b1 | b2 | both }
undo loopback
ISDN BRI接口视图
【缺省级别】
2:系统级
b1B1通道对外自环。
b2B2通道对外自环。
both:B1和B2通道同时对外自环。
【描述】
loopback命令用来配置BRI接口的对外自环。undo loopback命令用来恢复缺省情况。
缺省情况下,ISDN BRI接口不对外自环。
所谓自环,是指将从线路来的数据返回线路。ISDN BRI接口支持B1、B2通道对外自环以及B1和B2通道同时对外自环。
ISDN BRI接口支持Loopback功能的模块有:4BS(MIM),1BS\1BU\2BS\2BU(SIC);另外有固定ISDN BRI接口的路由器,ISDN BRI接口也支持Loopback功能。
# 配置BRI接口的B1和B2通道同时对外自环。
[Sysname] interface bri 1/0
[Sysname-Bri1/0] loopback both
1.7.3  mtu (ISDN BRI interface)
mtu size
undo mtu
ISDN BRI接口视图
【缺省级别】
2:系统级
【描述】
mtu命令用来配置BRI接口的最大传输单元(MTU)值。undo mtu命令用来恢复缺省情况。
缺省情况下,BRI接口的MTU值为1500。
需要注意的是,配置了mtu命令后需要执行命令shutdownundo shutdown,这样该配置才能在接口上生效。
# 配置BRI接口的MTU值为1200字节。
[Sysname-Bri1/0] mtu 1200
1.7.4  reset counters interface
reset counters interface [ bri [ interface-number ] ]
【缺省级别】
2:系统级
bri interface-number:指定BRI接口。
【描述】
reset counters interface命令用来清除指定BRI接口的统计信息。
·              如果不指定briinterface-number,则清除所有接口的统计信息;
·              如果指定bri而不指定interface-number,则清除所有BRI接口的统计信息;
·              如果同时指定briinterface-number,则清除指定BRI接口的统计信息。
# 清除BRI接口的统计信息。
<Sysname> reset counters interface bri 2/0
