选择区域语言: EN CN HK
02-接口管理命令参考
03-WAN接口命令
本章节下载  (609.99 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/SR_Router/SR6600/Command/Command_Manual/H3C_SR6600_CR-R2603(V1.15)/02/201212/765808_30005_0.htm
03-WAN接口命令
1 WAN接口配置命令
1.1 串口基本配置命令
1.1.1 bandwidth
1.1.2 baudrate
1.1.3 clock
1.1.4 code
1.1.5 crc
1.1.6 description
1.1.7 detect
1.1.8 display interface serial
1.1.9 idle-mark
1.1.10 invert receive-clock
1.1.11 invert transmit-clock
1.1.12 loopback
1.1.13 mtu
1.1.14 phy-mru
1.1.15 reset counters interface
1.1.16 reverse-rts
1.1.17 shutdown
1.1.18 sub-interface rate-statistic
1.1.19 timer hold
1.1.20 virtualbaudrate
1.2 CE1接口基本配置命令
1.2.1 alarm
1.2.2 cable (CE1 interface)
1.2.3 channel-set (CE1 interface)
1.2.4 clock (CE1 interface)
1.2.5 clock-change auto
1.2.6 code (CE1 interface)
1.2.7 controller e1
1.2.8 crc
1.2.9 data-coding (CE1 interface)
1.2.10 description (CE1 interface)
1.2.11 detect-ais
1.2.12 display controller e1
1.2.13 error-diffusion restraint config
1.2.14 error-diffusion restraint enable
1.2.15 frame-format (CE1 interface)
1.2.16 idlecode (CE1 interface)
1.2.17 itf (CE1 interface)
1.2.18 loopback (CE1 interface)
1.2.19 reset counters controller e1
1.2.20 shutdown (CE1 interface)
1.2.21 using (CE1 interface)
1.3 CT1接口基本配置命令
1.3.1 alarm (CT1 interface)
1.3.2 alarm-threshold
1.3.3 bert (CT1 interface)
1.3.4 cable (CT1 interface)
1.3.5 channel-set (CT1 interface)
1.3.6 clock (CT1 interface)
1.3.7 code (CT1 interface)
1.3.8 controller t1
1.3.9 crc
1.3.10 data-coding (CT1 interface)
1.3.11 description (CT1 interface)
1.3.12 display controller t1
1.3.13 error-diffusion restraint config
1.3.14 error-diffusion restraint enable
1.3.15 fdl
1.3.16 frame-format (CT1 interface)
1.3.17 idlecode (CT1 interface)
1.3.18 itf (CT1 interface)
1.3.19 loopback (CT1 interface)
1.3.20 reset counters controller t1
1.3.21 sendloopcode
1.3.22 shutdown (CT1 interface)
1.4 E1-F接口基本配置命令
1.4.1 crc
1.4.2 display fe1
1.4.3 error-diffusion restraint config
1.4.4 error-diffusion restraint enable
1.4.5 fe1 alarm
1.4.6 fe1 cable
1.4.7 fe1 clock
1.4.8 fe1 code
1.4.9 fe1 data-coding
1.4.10 fe1 detect-ais
1.4.11 fe1 frame-format
1.4.12 fe1 idlecode
1.4.13 fe1 itf
1.4.14 fe1 loopback
1.4.15 fe1 timeslot-list
1.4.16 fe1 unframed
1.5 T1-F接口基本配置命令
1.5.1 crc
1.5.2 display ft1
1.5.3 error-diffusion restraint config
1.5.4 error-diffusion restraint enable
1.5.5 ft1 alarm
1.5.6 ft1 alarm-threshold
1.5.7 ft1 bert
1.5.8 ft1 cable
1.5.9 ft1 clock
1.5.10 ft1 code
1.5.11 ft1 data-coding
1.5.12 ft1 fdl
1.5.13 ft1 frame-format
1.5.14 ft1 idlecode
1.5.15 ft1 itf
1.5.16 ft1 loopback
1.5.17 ft1 sendloopcode
1.5.18 ft1 timeslot-list
1.6 CE3接口基本配置命令
1.6.1 bert (CE3 interface)
1.6.2 clock (CE3 interface)
1.6.3 controller e3
1.6.4 crc
1.6.5 description (CE3 interface)
1.6.6 display controller e3
1.6.7 e1 bert
1.6.8 e1 channel-set
1.6.9 e1 set clock
1.6.10 e1 set frame-format
1.6.11 e1 set loopback
1.6.12 e1 shutdown
1.6.13 e1 unframed
1.6.14 fe3
1.6.15 loopback (CE3 interface)
1.6.16 national-bit
1.6.17 reset counters controller e3
1.6.18 shutdown (CE3 interface)
1.6.19 using (CE3 Interface)
1.7 CT3接口基本配置命令
1.7.1 alarm (CT3 interface)
1.7.2 bert (CT3 interface)
1.7.3 cable (CT3 interface)
1.7.4 clock (CT3 interface)
1.7.5 controller t3
1.7.6 crc
1.7.7 description (CT3 interface)
1.7.8 display controller t3
1.7.9 feac
1.7.10 frame-format (CT3 interface)
1.7.11 ft3
1.7.12 loopback (CT3 interface)
1.7.13 mdl (CT3 interface)
1.7.14 reset counters controller t3
1.7.15 shutdown (CT3 interface)
1.7.16 t1 alarm
1.7.17 t1 bert
1.7.18 t1 channel-set
1.7.19 t1 sendloopcode
1.7.20 t1 set clock
1.7.21 t1 set frame-format
1.7.22 t1 set loopback
1.7.23 t1 set fdl
1.7.24 t1 show
1.7.25 t1 shutdown
1.7.26 t1 unframed
1.7.27 using (CT3 interface)
1 WAN接口配置命令
1.1  串口基本配置命令
1.1.1  bandwidth
bandwidth bandwidth-value
undo bandwidth
串口视图/ E1-F接口视图/T1-F接口视图/CE3接口视图/CT3接口视图/CE1接口视图/CT1接口视图
【缺省级别】
2:系统级
bandwidth-value:ifspeed节点的值,取值范围为1~4294967295,单位为kbps。
【描述】
bandwidth命令用来设置接口的期望带宽。undo bandwidth命令用来恢复缺省值。
接口的期望带宽可以通过第三方软件查询MIB节点ifspeed的值来获取。
期望带宽供网管监控接口带宽使用,不会对接口实际带宽造成影响。
# 设置串口Serial2/1/1的期望带宽为50kbps。
[Sysname] interface serial 2/1/1
[Sysname-Serial2/1/1] bandwidth 50
1.1.2  baudrate
baudrate baudrate
undo baudrate
同步串口视图
【缺省级别】
2:系统级
baudrate:同步串口的波特率,单位为bps。
【描述】
baudrate命令用来设置同步串口的波特率。undo baudrate命令用来恢复缺省情况。
缺省情况下,同步串口的波特率为64000bps。
同步串口支持的波特率有:
1200bps、2400bps、4800bps、9600bps、19200bps、38400bps、56000bps、57600bps、64000bps、72000bps、115200bps、128000bps、192000bps、256000bps、384000bps、512000bps、1024000bps、2048000bps、4096000bps。
另外同步串口对于不同的物理电气规程,所支持的波特率范围有所不同。
l              V.24 DTE/DCE:1200bps~64000bps
l              V.35 DCE/DCE、X.21 DTE/DCE、EIA/TIA-449 DTE/DCE以及EIA-530 DTE/DCE:1200bps~4096000bps
l          在设置同步串口波特率时,要注意同步串口的外接电缆的电气规程等因素;
l          DCE设备和DTE设备之间线路传输的波特率,由DCE设备决定。
# 设置DCE设备的同步串口的波特率为115200bps。
[Sysname] interface serial 2/0/0
[Sysname-Serial2/0/0] baudrate 115200
1.1.3  clock
clock { dteclk1 | dteclk2 | dteclk3 | dteclk4 | dteclkauto }
clock { dceclk1 | dceclk2 | dceclk3 }
undo clock
同步串口视图
【缺省级别】
2:系统级
dteclk1:设置接口时钟方式为DTE时钟选择方式1。
dteclk2:设置接口时钟方式为DTE时钟选择方式2。
dteclk3:设置接口时钟方式为DTE时钟选择方式3。
dteclk4:设置接口时钟方式为DTE时钟选择方式4。
dteclkauto:设置接口时钟方式为DTE自动协商。
dceclk1:设置接口时钟方式为DCE时钟选择方式1。
dceclk2:设置接口时钟方式为DCE时钟选择方式2。
dceclk3:设置接口时钟方式为DCE时钟选择方式3。
当接口工作在DTE方式时,支持命令clock { dteclk1 | dteclk2 | dteclk3 | dteclk4 | dteclkauto };当接口工作在DCE方式时,支持命令clock { dceclk1 | dceclk2 | dceclk3 }。
【描述】
clock命令用来设置同步串口的时钟选择方式。undo clock命令用来恢复缺省情况。
缺省情况下,同步串口DTE侧的时钟为dteclk1,同步串口DCE侧的时钟为dceclk1
同步串口有两种工作方式:DTE和DCE,不同的工作方式有不同的工作时钟选择。
l              如果同步串口作为DCE设备,则需要向对端DTE设备提供时钟DCEclk;
l              如果同步串口作为DTE设备,则需要接受对端DCE设备提供的时钟,由于同步设备的接收和发送时钟是独立的,则DTE设备的接收时钟可以选择DCE设备的发送或接收时钟,DTE设备的发送时钟也可以选择DCE设备的发送或接收时钟,由此产生五种组合,即在DTE侧可以有五种时钟选择。
图1-1 同步串口时钟选择示意图
其中,TxClk为发送时钟,RxClk为接收时钟。
四种选择方法规定如下表所示。
表1-1 同步串口DTE侧时钟的选择方法
选择方法
意义
DTEclk1
TxClk = TxClk, RxClk = RxClk
DTEclk2
TxClk = TxClk, RxClk = TxClk
DTEclk3
TxClk = RxClk, RxClk = TxClk
DTEclk4
TxClk = RxClk, RxClk = RxClk
其中,‘=’前为DTE侧时钟,‘=’后为DCE侧时钟。
表1-2 同步串口DCE侧时钟的选择方法
选择方法
意义
DCEclk1
TxClk = Local, RxClk = Local
DCEclk2
TxClk = Local, RxClk = Line
DCEclk3
TxClk = Line, RxClk = Line
其中,‘=’前为DCE侧时钟,‘=’后为时钟信号来源。
# 设置同步串口作为DTE设备的时钟选择方式为DTEclk2。
[Sysname-Serial2/0/0] clock dteclk2
1.1.4  code
code { nrz | nrzi }
undo code
同步串口视图
【缺省级别】
2:系统级
nrz:采用NRZ(不归零)的数字信号编码格式。
nrzi采用NRZI(反向不归零)的数字信号编码格式。
【描述】
code命令用来配置同步串口的数字信号编码格式。undo code命令用来恢复缺省情况。
缺省情况下,同步串口的数字信号编码格式为NRZ。
# 配置同步串口的数字信号编码格式为NRZI。
[Sysname-Serial2/0/0] code nrzi
1.1.5  crc
crc { 16 | 32 | none }
undo crc
同步串口视图
【缺省级别】
2:系统级
16:同步串口使用16位CRC校验方式。
32:同步串口使用32位CRC校验方式。
none:同步串口不进行CRC校验。
【描述】
crc命令用来配置同步串口的CRC校验方式。undo crc命令用来恢复缺省情况。
缺省情况下,采用16位CRC校验方式。
# 同步串口下配置CRC校验为32位CRC校验方式。
[Sysname-Serial2/0/0] crc 32
1.1.6  description
串口视图
【缺省级别】
2:系统级
text:接口描述字符串,为1~80个字符的字符串。
【描述】
description命令用来配置接口的描述字符串。undo description命令用来恢复缺省情况。
缺省情况下,接口的描述字符串为“该接口的接口名 Interface”,比如:Serial2/0/0 Interface。
# 配置Serial2/0/0的描述字符串为“router-interface”。
[Sysname-Serial2/0/0] description router-interface
1.1.7  detect
异步串口:
detect dsr-dtr
undo detect dsr-dtr
同步串口:
detect { dcd | dsr-dtr }
undo detect { dcd | dsr-dtr }
同/异步串口视图
【缺省级别】
2:系统级
dsr-dtr:检测DSU/CSU(Data Service Unit/Channel Service Unit,表示数字MODEM)的DSR(Data Set Ready)和DTR(Data Terminal Ready)信号。
dcd:检测同步串口DSU/CSU的DCD(Data Carrier Detect)信号。
【描述】
detect命令用来启用串口的数据载波检测和串口的电平检测功能。undo detect命令用来禁止该功能。
缺省情况下,启用串口的数据载波检测和串口的电平检测功能。
如果设置禁止异步串口进行电平检测,系统将不检测异步串口是否外接电缆,自动向用户报告异步串口的状态为up,且DTR = up、DSR = up;如果设置允许异步串口进行电平检测,则系统将不仅检测异步串口是否外接电缆,同时还要检测DSR信号,只有当该信号有效时,系统才认为异步串口处于up状态,否则,为down状态。
系统在判断同步串口的状态(up或down)时,缺省情况下将同时检测DSR信号、DCD信号以及接口是否外接电缆。只有当三个信号全部有效时,系统才认为同步串口处于up状态,否则为down状态。如果禁止同步串口进行电平检测,系统检测到外接电缆后,接口状态为up,且DTR = up、DSR = up。
# 启用同步串口的数据载波检测功能。
[Sysname-Serial2/0/0] detect dcd
display interface [ serial ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface serial interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:显示指定Serial接口的信息。
down:显示当前状态为down的接口的信息以及down的原因。不指定该参数时,将不会根据接口状态来过滤显示信息。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display interface serial命令用来显示Serial接口的相关信息。
l              如果不指定serial参数,将显示设备支持的所有接口的相关信息。
l              如果指定serial参数,不指定interface-number参数,将显示所有已创建的Serial接口的相关信息。
# 显示Serial接口1/0/1的详细信息。
<Sysname> display interface serial 1/0/1
Serial1/0/1 current state: UP
Description: Serial1/0/1 Interface
The Maximum Transmit Unit is 1500, Hold timer is 10(sec)
Internet Address is 9.9.9.6/24 Primary
Link layer protocol is PPP
LCP opened, IPCP opened
Output queue : (Urgent queuing : Size/Length/Discards)  0/100/0
Output queue : (Protocol queuing : Size/Length/Discards)  0/500/0
Output queue : (FIFO queuing : Size/Length/Discards)  0/75/0
Physical layer is synchronous, Baudrate is 64000 bps
Interface is DCE, Cable type is V35, Clock mode is DCECLK
    Last 70 seconds input rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
    Last 70 seconds output rate 2.40 bytes/sec, 19 bits/sec, 0.20 packets/sec
    Input: 6668 packets, 80414 bytes
           0 broadcasts, 0 multicasts
           0 errors, 0 runts, 0 giants
           0 CRC, 0 align errors, 0 overruns
           0 dribbles, 0 aborts, 0 no buffers
           0 frame errors
    Output:6670 packets, 80446 bytes
           0 errors, 0 underruns, 0 collisions
           0 deferred
    DCD=UP  DTR=UP  DSR=UP  RTS=UP  CTS=UP
# 显示Serial接口1/0/1的概要信息。
<Sysname> display interface serial 1/0/1 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
S1/0/1                 UP   UP(s)    --
# 显示所有状态为down的Serial接口的概要信息。
<Sysname> display interface serial brief down
S1/0/1                 ADM  Administratively
表1-3 display interface serial命令显示信息描述表
串口当前的物理状态,状态可能为:
l      DOWN(Administratively):表示该串口已经通过shutdown命令被关闭,即管理状态为关闭
l      DOWN:表示该串口的物理状态为关闭(可能因为没有物理连线或者线路故障)
l      UP:该串口的管理状态和物理状态均为开启
该接口的链路协议状态
接口描述信息
接口的最大传输单元(MTU)。缺省值为1500字节。表示长度大于MTU的报文,将会被分片后再发送。如果设置了不准分片,报文会被丢弃
报文的生命周期。报文如果在生命周期内没有被送出去,则将丢弃
接口的IP地址
串口的数据链路层协议
表示PPP连接建立成功
输出队列(紧急队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
链路层的协议报文,比如PPP 的协商报文和Keepalive 报文等将进入这个队列
输出队列(协议队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
协议队列(Protocol queue)是指IP优先级为6 的报文将进入协议队列
输出队列(先进先出队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数)
物理层链路信息,串口的带宽
同步串口DCE侧的时钟选择方式和线缆类型
最后一次清除接口统计信息的时间
最近70秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近70秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
           0 frame errors
接口收到的总报文数和总字节数:
l      broadcasts:接收的广播报文的数目
l      multicasts:接收的组播报文的数目
l      errors:在物理层检测时发现的错误报文数目
l      runts:接口接收到小于规定的最小报文长度报文数
l      giants:接收到长度大于规定长度的报文数目
l      CRC:接收长度正常但CRC 校验错误的报文数目
l      align errors:排列错误
l      overruns:接收的报文速度大于转发处理能力导致无法处理的报文
l      aborts:接收报文的异常错误
l      no buffers:在接收报文时由于内部缓存满,导致帧丢弃
l      frame errors:帧错误
           0 deferred
接口发送的报文数和总字节数
l      underruns:因为接口读取内存的速度小于转发的速度而无法发送报文数目
l      collisions:发送报文时,检测到冲突的报文数目
l      deferred:因为延时或超时无法发送报文的数目
DSR(Data Set Ready)、DTR(Data Terminal Ready)和DCD(Data Carrier Detect)信号处于up状态,关于DSR、DTR和DCD请参考detect命令
RST(Request to Send)和(CTS)Clear to Send处于up状态
三层接口的概要信息
l      如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
l      如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display standby state命令可以查看该备份接口对应的主接口
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的网络层协议状态显示是UP的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
接口名称缩写
Link
接口物理连接状态,取值可能为:
l      UP:表示本链路物理上是连通的
l      ADM:表示本链路被手工关闭了,需要执行undo shutdown命令才能恢复真实的物理状态
Protocol
接口协议连接状态,取值为UP(s)
Main IP
接口主IP地址
接口的描述信息
Cause
接口物理连接状态为DOWN的原因,取值为Administratively时表示本链路被手工关闭了,需要执行undo shutdown命令才能恢复真实的物理状态
1.1.9  idle-mark
idle-mark
undo idle-mark
同步串口视图
【缺省级别】
2:系统级
【描述】
idle-mark命令用来配置同步串口的线路空闲码为“0xFF”。undo idle-mark命令用来恢复缺省情况。
缺省情况下,同步串口的线路空闲码为“0x7E”。
通常情况下,同步串口使用编码“0x7E”来表示线路的空闲状态,而有的设备在空闲时间采用编码“0xFF”(即全“1”的高电平)来表示线路的空闲状态。为了更好的兼容这种设备,需要设置同步串口的线路空闲码。
# 设置同步串口的线路空闲码为“0xFF”。
[Sysname] interface serial 1/0/0
[Sysname-Serial1/0/0] idle-mark
undo invert receive-clock
同步串口视图
【缺省级别】
2:系统级
【描述】
invert receive-clock命令用来允许翻转DTE侧同步串口的接收时钟信号。undo invert receive-clock命令用来恢复缺省情况。
缺省情况下,同步串口作为DTE侧时,禁止翻转接收时钟信号。
在某些特殊情况下,为了消除线路上半个时钟周期的时延,可以将DTE侧同步串口的接收时钟信号翻转。只有某些特殊的DCE设备需要配置该命令,对于通常的应用,时钟不应作翻转。
相关配置可参考命令physical-modeinvert transmit-clockclock
# 将DTE侧同步串口的接收时钟翻转。
[Sysname-Serial1/0/0] invert receive-clock
undo invert transmit-clock
同步串口视图
【缺省级别】
2:系统级
【描述】
invert transmit-clock命令用来允许翻转DTE侧同步串口的发送时钟信号。undo invert transmit-clock命令用来恢复缺省情况。
缺省情况下,同步串口作为DTE侧时,禁止翻转发送时钟信号。
在某些特殊情况下,为了消除线路上半个时钟周期的时延,可以将DTE侧同步串口的发送时钟信号翻转。只有某些特殊的DCE设备需要配置该命令,对于通常的应用,时钟不应作翻转。
相关配置可参考命令physical-modeinvert receive-clockclock
# 将DTE侧同步串口的发送时钟翻转。
[Sysname-Serial1/0/0] invert transmit-clock
1.1.12  loopback
loopback
undo loopback
串口视图
【缺省级别】
2:系统级
【描述】
loopback命令用来使能对内自环。undo loopback命令用来恢复缺省情况。
缺省情况下,禁止对内自环。
只有在进行某些特殊功能测试时,才将串口设为对内自环。
# 允许串口对内自环对外环回。
[Sysname-Serial1/0/0] loopback
1.1.13  mtu
mtu size
undo mtu
串口视图
【缺省级别】
2:系统级
【描述】
mtu命令用来设置接口的最大传输单元(MTU)值。undo mtu命令用来恢复缺省情况。
缺省情况下,接口的MTU值为1500。
由于QoS队列长度有限,如果MTU太小而报文尺寸较大,可能会造成分片过多,报文被QoS队列丢弃。为避免这种情况,可适当增大QoS队列的长度。接口缺省使用的队列调度机制是FIFO,可以在接口视图下使用命令qos fifo queue-length改变该队列长度。QoS队列的具体配置请参见“ACL和QoS配置指导”中的“拥塞管理”。
接口的MTU影响IP协议报文在该接口上传输时的分片与重组。
需要注意的是,配置了mtu命令后需要执行命令shutdownundo shutdown,这样该配置才能在接口上生效。
# 配置接口Serial1/0/0的MTU值为1200字节。
[Sysname-Serial1/0/0] mtu 1200
1.1.14  phy-mru
phy-mru mrusize
undo phy-mru
异步串口视图
【缺省级别】
2:系统级
mrusize:设置最大接收包长,取值范围为4~1700,单位为字节。
【描述】
phy-mru命令用来设置异步串口工作在流方式下的最大接收包长。undo phy-mru命令用来恢复缺省情况。
缺省情况下,异步串口工作在流方式下的最大接收包长为1700字节。
需要注意的是,phy-mru命令只有在异步流模式下能够成功配置。
# 设置异步串口工作在流方式下的最大接收包长为1500字节。
[Sysname-Serial1/0/0] physical-mode async
 [Sysname-Serial1/0/0] phy-mru 1500
reset counters interface [ serial [ interface-number ] ]
【缺省级别】
2:系统级
serial interface-number:指定Serial接口。
【描述】
reset counters interface命令用来清除指定Serial接口的统计信息。
l              如果不指定serialinterface-number,则清除所有接口的统计信息;
l              如果指定serial而不指定interface-number,则清除所有Serial接口的统计信息;
l              如果同时指定serialinterface-number,则清除指定Serial接口的统计信息。
# 清除Serial接口的统计信息。
<Sysname> reset counters interface serial 1/0/0
1.1.16  reverse-rts
reverse-rts
undo reverse-rts
同步串口视图
【缺省级别】
2:系统级
【描述】
reverse-rts命令用来为了特定的调试需要,在同步方式下翻转RTS信号。undo reverse-rts命令用来恢复缺省情况。
缺省情况下,不翻转RTS信号。
reverse-rts命令常用于硬件流控方式下,本端发送时不允许对端发送数据的情况。
# 翻转RTS信号。
[Sysname-Serial1/0/0] reverse-rts
1.1.17  shutdown
shutdown
串口视图
【缺省级别】
2:系统级
【描述】
shutdown命令用来关闭接口。undo shutdown命令用来打开接口。
缺省情况下,接口为激活状态。
在某些特殊情况下,如修改接口的工作参数时,改动不能立即生效,需要关闭和重启接口后,才能生效。
# 关闭串口Serial1/0/0。
[Sysname-Serial1/0/0] shutdown
undo sub-interface rate-statistic
串口视图
【缺省级别】
2:系统级
【描述】
sub-interface rate-statistic命令用来开启串口子接口的速率统计功能。undo sub-interface rate-statistic命令用来关闭串口子接口的速率统计功能。
缺省情况下,串口子接口的速率统计功能处于关闭状态。
l          开启本功能后可能需要耗费大量系统资源,请谨慎使用。
l          支持该功能的串口子接口包括同步串口,同异步串口,子通道串口,但不包括纯异步串口。
# 开启串口子接口的速率统计功能。
[Sysname-Serial1/0/0] sub-interface rate-statistic
1.1.19  timer hold
timer hold seconds
undo timer hold
串口视图
【缺省级别】
2:系统级
seconds:接口发送keepalive报文的周期,取值范围为0~32767,单位为秒。
【描述】
timer hold命令用来配置轮询时间间隔,轮询时间间隔指的是接口发送keepalive报文的周期。undo timer hold命令用来恢复缺省情况。
缺省情况下,轮询时间间隔为10秒。
# 允许Serial1/0/0轮询时间间隔为20秒。
[Sysname-Serial1/0/0] timer hold 20
virtualbaudrate virtualbaudrate
undo virtualbaudrate
同步串口视图
【缺省级别】
2:系统级
virtualbaudrate:指定的波特率,需要与DCE侧的配置保持一致。其取值范围为1200、2400、4800、9600、19200、38400、56000、57600、64000、72000、115200、128000、192000、256000、384000、512000、768000、1024000、2048000、4096000,单位bps。
【描述】
virtualbaudrate命令用来配置DTE接口的虚拟波特率。undo virtualbaudrate命令用来取消虚拟波特率的配置。
当串口工作为DTE模式时,接口波特率通过协商从对端(DCE侧)获得。virtualbaudrate命令给用户提供一种手工配置DTE侧波特率的方式。
相关配置可参考命令baudrateclock
l          baudratevirtualbaudrate不能在链路的同一端配置,baudrate用于DCE端,virtualburdrate用于DTE端(仅同步模式)。
l          通过display interface命令看到的是接口的baudrate;而在DTE端,通过display interface命令看到的是接口的virtualbaudrate
# 为DTE接口设置虚拟波特率为19200bps。
[Sysname-Serial1/0/0] virtualbaudrate 19200
1.2  CE1接口基本配置命令
1.2.1  alarm
alarm detect rai
undo alarm detect rai
CE1
【缺省级别】
2:系统级
detect:接口的定时检测功能。
raiRemote Alarm Indication,即远端告警指示信号。
【描述】
alarm命令用来配置检测远端告警信号。undo alarm命令用来取消检测。
缺省情况下,检测远端告警信号。
CE1方式的情况下,可以使用该命令。
# 取消CE1接口的检测远端告警信号功能。
[Sysname] controller e1 2/0/0
[Sysname-E1 2/0/0] undo alarm detect ais
cable { long | short }
undo cable
CE1接口视图
【缺省级别】
2:系统级
long:表示接收器的衰减为-43db。
short:表示接收器的衰减为-10db。
【描述】
cable命令用来设置CE1接口匹配的传输线路类型。undo cable命令用来恢复缺省情况。
缺省情况下,CE1接口匹配的传输线路类型为long
# 配置CE1接口匹配的传输线路为short
[Sysname-E1 2/0/0] cable short
channel-set set-number timeslot-list list
undo channel-set [ set-number ]
CE1接口视图
【缺省级别】
2:系统级
set-number:该接口上时隙捆绑形成的channel set编号,其取值范围为030
timeslot-list list:被捆绑的时隙。list为时隙编号,其取值范围为131。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
【描述】
channel-set命令用来将CE1接口的时隙捆绑为channel setundo channel-set命令用来取消已有的捆绑。
缺省情况下,不捆绑任何channel set
CE1接口使用CE1工作方式时,它在物理上分为32个时隙,对应编号为031
使用时,可以将除0时隙外的全部时隙分成若干通道组(channel set),每组时隙捆绑以后,将自动创建一个Serial接口,其逻辑特性与同步串口相同。
Serial接口的编号是serial interface-number:set-number。其中interface-number是CE1接口的编号,set-number是channel set的编号。
在一个CE1接口上同一个时间内只能支持一种时隙捆绑方式。
# 将CE1接口的1、2、5、10-15和18时隙捆绑为0号channel-set。
[Sysname-E1 2/0/0] channel-set 0 timeslot-list 1,2,5,10-15,18
# 对端路由器的CE1接口,做相同的配置。
clock { master | slave }
undo clock
CE1接口视图
【缺省级别】
2:系统级
master:使用内部时钟。
slave:使用线路时钟。
【描述】
clock命令用来设置CE1接口的时钟方式。undo clock命令用来恢复缺省情况。
缺省情况下,接口使用线路时钟(slave)方式。
当CE1接口作为DCE设备使用时,应使用内部时钟,即master时钟方式;作为DTE设备使用时,应使用线路时钟,即slave时钟方式。
# 设置CE1接口的时钟使用内部时钟。
[Sysname-E1 2/0/0] clock master
clock-change auto
undo clock-change auto
CE1接口视图
【缺省级别】
2:系统级
auto:时钟自动切换功能。
【描述】
clock-change auto命令用来配置接口在slave模式下收到AIS/LOS/LOF告警后,接口自动切换成master模式。当告警消除后,接口自动切换成用户配置的时钟模式。undo clock-change auto命令用来取消时钟自动切换功能,接口恢复成当前用户配置的时钟模式。
缺省情况下,时钟自动切换功能处于关闭状态。
相关配置可参考命令clock
# 开启时钟自动切换功能。
[Sysname-E1 2/0/0] undo clock-change atuo
code { ami | hdb3 }
undo code
CE1接口视图
【缺省级别】
2:系统级
ami:采用ami(Alternate Mark Inversion)线路编码格式。
hdb3:采用hdb3(High Density Bipolar 3)线路编码格式。
【描述】
code命令用来设置CE1接口的线路编码格式。undo code命令用来恢复缺省情况。
缺省情况下,CE1接口的线路编码格式为hdb3
l              设置接口的线路编解码格式时,请注意与对端设备保持一致。
l              线路编码采用ami方式时,在该接口上需要同时配置data-coding inverted,才能保证接口正常工作。
相关配置可参考命令data-coding
# 设置接口E1 2/0/0的线路编解码方式为ami
[Sysname-E1 2/0/0] code ami
1.2.7  controller e1
controller e1 number
【缺省级别】
2:系统级
number:CE1接口的编号。
【描述】
controller e1命令用来进入CE1接口的视图。
# 进入接口E1 2/0/0的视图。
[Sysname-E1 2/0/0]
1.2.8  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置CE1接口通过各种方式形成的同步串口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
# 配置接口E1 1/0/0在非通道化模式下形成的串口使用32位CRC校验。
[Sysname-E1 2/0/0] using e1
[Sysname-E1 2/0/0] quit
[Sysname] interface serial 1/0/0:0
[Sysname-Serial1/0/0:0] crc 32
data-coding { inverted | normal }
undo data-coding
CE1接口视图
【缺省级别】
2:系统级
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
【描述】
data-coding inverted命令用来设置CE1接口对用户数据进行翻转。data-coding normal命令用来设置CE1接口不对用户数据进行翻转。undo data-coding命令用来恢复缺省情况。
缺省情况下,CE1接口不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当E1接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现过多连0的缺陷。
需注意的是,只有通信的E1线路两端的CE1接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置CE1接口对数据进行翻转。
[Sysname-E1 2/0/0] data-coding inverted
CE1接口视图
【缺省级别】
2:系统级
【描述】
description命令用来配置CE1接口的描述字符串。undo description命令用来恢复缺省情况。
缺省情况下,CE1接口的描述字符串为“该接口的接口名 Interface”,比如:E1 2/0/0 Interface。
# 配置接口E1 2/0/0的描述字符串为“E1-interface”。
[Sysname-E1 2/0/0] description E1-interface
1.2.11  detect-ais
detect-ais
undo detect-ais
CE1接口视图
【缺省级别】
2:系统级
【描述】
detect-ais命令用来配置当前接口进行AIS检测。undo detect-ais命令用来取消AIS检测。
缺省情况下,进行AIS检测。
# 设置E1接口进行AIS检测。
[Sysname-E1 2/0/0] detect-ais
display controller e1 [ interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:接口编号。
【描述】
display controller e1命令用来显示CE1接口的相关信息。
# 显示E1接口的相关信息。
<Sysname> display controller e1 2/0/0
E1 2/0/0 current state: UP
Description : E1 2/0/0 Interface
Basic Configuration:
  Work mode is E1 framed, Cable type is 75 Ohm unbalanced.
  Frame-format is no-crc4.
  Line code is hdb3, Source clock is slave.
  Idle code is 7e, Itf type is 7e, Itf number is 4.
  Loop back is not set.
Alarm State:
  Receiver alarm state is None.
Historical Statistics:
    Data in current interval (150 seconds elapsed):
    0 Loss Frame Alignment Secs, 0 Framing Error Secs,
    0 CRC Error Secs, 0 Alarm Indication Secs, 0 Loss-of-signals Secs,
    0 Code Violations Secs, 0 Slip Secs, 0 E-Bit error Secs.
表1-4 display controller e1命令显示信息描述表
E1接口当前的状态
E1接口的描述信息
Work mode
E1接口的工作模式(E1/CE1
Cable type
E1接口的线缆类型
Frame-format
E1接口的帧格式(crc4/no crc4)
Source Clock
接口的源时钟(master/slave)
Line Code
线路码(Ami/hdb3)
Idle Code
空闲码(7e/ff)
Itf type
帧间填充码(7e/ff)
Itf number
帧间填充码的个数
Loopback
接口是否设置了环回
Alarm State
告警状态
历史统计数据
清零记录
当前时间间隔内的各种错误发生持续的时间统计,错误包括:帧没对齐,帧错误,警告,丢信号,违规码时间,滑帧
error-diffusion restraint config detect-timer renew-timer threshold
undo error-diffusion restraint config
【缺省级别】
2:系统级
detect-timer:检测定时器,取值范围为30~600,单位为秒。
renew-timer:恢复定时器,取值范围为120~2400,单位为秒。
threshold:错包率门限百分比,取值范围为5~100。
【描述】
error-diffusion restraint config命令用来设置错包扩散抑制功能的三个参数。undo error-diffusion restraint config命令用来恢复缺省情况。
缺省情况下,detect-timer为30秒,renew-timer为600秒,threshold为百分之20。
renew-timer的值不能小于detect-timer的4倍,在detect-timer时间内如果接收到的报文总数小于100,不进行错包统计。
本命令只对CT1接口、CE1接口、E1-F接口和T1-F接口起作用。
# 配置错包扩散抑制功能的检测定时器为100秒,恢复定时器为2400秒,错误门限为15%。
[Sysname] error-diffusion restraint config 100 2400 15
undo error-diffusion restraint enable
【缺省级别】
2:系统级
【描述】
error-diffusion restraint enable命令用来使能错包扩散抑制功能。undo error-diffusion restraint enable命令用来关闭错包扩散抑制功能。
缺省情况下,使能错包扩散抑制功能。
本命令只对CT1接口、CE1接口、E1-F接口和T1-F 接口起作用。
# 使能错包扩散抑制功能。
[Sysname] error-diffusion restraint enable
frame-format { crc4 | no-crc4 }
undo frame-format
CE1接口视图
【缺省级别】
2:系统级
crc4:设置CE1接口的帧格式为CRC4帧格式。
no-crc4:设置CE1接口的帧格式为非CRC4帧格式。
【描述】
frame-format命令用来设置CE1接口的帧格式。undo frame-format命令用来恢复缺省情况。
缺省情况下,CE1接口的帧格式为no-crc4
CE1接口工作在CE1方式下时,支持crc4no-crc4两种帧格式。其中crc4帧格式支持对物理帧进行4比特的循环冗余校验,而no-crc4帧格式则不支持对物理帧进行4比特的循环冗余校验。
# 设置接口E1 2/0/0的帧格式为crc4
[Sysname-E1 2/0/0] frame-format crc4
idlecode { 7e | ff }
undo idlecode
CE1接口视图
【缺省级别】
2:系统级
7e:线路空闲码为0x7e格式。
ff:线路空闲码为0xff格式。
【描述】
idlecode命令用来设置CE1接口的线路空闲码类型。undo idlecode命令用来恢复缺省情况。
缺省情况下,CE1接口的线路空闲码类型为0x7e
CE1接口的线路空闲码类型是指在没有被绑定到逻辑通道的时隙上发送的码型。CE1接口的线路空闲码类型有两种:0x7e和0xff。
# 设置CE1接口的线路空闲码类型为0x7e。
[Sysname-E1 2/0/0] idlecode 7e
itf { number number | type { 7e | ff } }
undo itf { number | type }
CE1接口视图
【缺省级别】
2:系统级
number number:设置帧间填充字节的个数,取值范围为0~14,单位为字节。
type { 7e | ff }:设置帧间填充字节(Interframe filling flag)类型,7e表示帧间填充符为0x7e格式,ff表示帧间填充符为0xff格式。
【描述】
itf命令用来设置CE1接口的帧间填充字节类型和个数。undo itf命令用来恢复缺省情况。
缺省情况下,CE1接口的帧间填充字节类型为0x7e,字节个数为4个。
CE1接口的帧间填充符是指已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。CE1接口的帧间填充符类型有两种:0x7e0xff
# 设置CE1接口的帧间填充字节类型为0xff。
[Sysname-E1 2/0/0] itf type ff
# 设置CE1接口的帧间填充字节个数为5。
[Sysname-E1 2/0/0] itf number 5
loopback { local | payload | remote }
undo loopback
CE1接口视图
【缺省级别】
2:系统级
local:使能接口对内自环。
remote:使能接口对外环回。
payload:使能接口对外净荷环回。
【描述】
loopback命令用来设置CE1接口使能环回检测功能并设置检测方式。undo loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
自环环回功能主要用于检测接口或电缆本身的状况,正常工作时应禁止这些功能。
对于将CE1接口时隙经捆绑而形成的串口,如果将串口的链路层协议配置为PPP,设置自环后,链路层协议状态将上报为down,这属于正常情况。
# 设置接口E1 2/0/0对内自环。
[Sysname-E1 2/0/0] loopback local
reset counters controller e1 interface-number
【缺省级别】
2:系统级
【描述】
reset counters controller e1命令用来清除CE1接口的controller计数器。controller计数器值可以用display controller e1命令来查看。
单独清除CE1接口的controller计数器只能使用reset counters controller e1命令,不能使用reset counters interface命令,该命令会清除所有接口的计数器。
# 清除CE1接口2/0/0的controller计数器。
<Sysname> reset counters controller e1 2/0/0
shutdown
CE1接口视图
【缺省级别】
2:系统级
【描述】
shutdown命令用来关闭CE1接口。undo shutdown命令用来打开CE1接口。
缺省情况下,CE1接口为打开状态。
# 关闭接口E1 2/0/0。
[Sysname-E1 2/0/0] shutdown
using { ce1 | e1 }
undo using
CE1接口视图
【缺省级别】
2:系统级
ce1:接口工作在CE1工作方式。
e1:接口工作在E1工作方式。
【描述】
using命令用来设置CE1接口的工作方式。undo using命令用来恢复缺省工作方式。
缺省情况下,CE1接口的工作方式为CE1工作方式。
CE1接口拥有两种工作方式:E1工作方式和CE1工作方式。
当CE1接口使用E1工作方式时,它相当于一个不分时隙、数据带宽为2.048Mbps的接口,其逻辑特性与同步串口相同。当CE1接口使用CE1工作方式时,它在物理上分为32个时隙,对应编号为0~31,其中0时隙用于传输同步信息。
在将CE1的接口工作方式改为E1方式后,系统会自动创建一个Serial口。Serial接口的编号是serial interface-number:0。其中interface-number是CE1接口的编号。
# 设置CE1接口的工作在E1工作方式。
1.3  CT1接口基本配置命令
alarm detect rai
CT1接口视图
【缺省级别】
2:系统级
detect:接口的定时检测功能。
rai:Remote Alarm Indication,即远端告警指示信号。
【描述】
缺省情况下,检测远端告警信号。
在接口帧格式采用esf的情况下,可以使用该命令。
# 取消CT1接口的检测远端告警信号功能。
[Sysname] controller t1 2/0/0
[Sysname-T1 2/0/0] undo alarm detect rai
alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
CT1接口视图
【缺省级别】
2:系统级
ais:AIS告警的门限值。AIS告警有两个门限值,分别为level-1level-2level-1的门限为在一个SF/ESF帧内,比特流中的0的个数小等于2,则AIS告警产生;level-2的门限在SF格式时为,一个SF帧内码流的0个数小等于3;在ESF格式时为一个ESF帧内码流的0个数小等于5。缺省情况下,AIS告警门限值为level-1。
lfaLFA告警的门限值。LFA告警有四个门限值可以配置,分别为level-1level-2level-3level-4level-1为4个帧同步比特中丢失了2个;level-2为5个帧同步比特中丢失了2个;leve-3为6个帧同步比特中丢失了2个;level-4仅仅对ESF格式有效,在连续4个ESF帧中出现错误时产生LFA告警。缺省情况下,LFA告警门限值为level-1。
los:LOS告警的门限值。LOS告警有两个门限值,分别为pulse-detectionpulse-recoverypulse-detection配置LOS的检测时长门限,取值范围为16~4096,这个时长门限的单位为“脉冲周期”;pulse-recovery配置LOS的脉冲门限,取值范围为1~256,就是在检测时长内(即pulse-detection配置的若干个脉冲周期内),检测到的脉冲个数如果小于pulse-recovery所配置的值,则LOS告警产生。在缺省情况,pulse-detection参数的值为176,pulse-recovery的值为22,即如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失,LOS告警产生。
【描述】
alarm-threshold命令用来配置CT1接口告警的门限值。undo alarm-threshold命令将告警门限值恢复为缺省情况。
缺省情况下,对于LOS告警,pulse-detection参数的值为176,pulse-recovery的值为22,即默认的情况下,如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失LOS告警产生;对于AIS告警,缺省值为level-1;对于LFA告警,缺省值为level-1
# 将LOS告警的检测时长配置为300个脉冲周期。
[Sysname-T1 2/0/0] alarm-threshold los pulse-detection 300
bert pattern { 2^20 | 2^15 } time minutes [ unframed ]
undo bert
CT1接口视图
【缺省级别】
2:系统级
pattern:设置BERT测试模式,包括2^15(测试码流长度为2的15次方个bit)和2^20(测试码流长度为2的20次方个bit)。
time minutes:设置BERT测试事件,取值范围为1~1440,单位为分钟。
unframed:设置测试数据流覆盖帧的开销位。
【描述】
bert命令用来进行线路位(Bit)错误率的测试。undo bert命令用来取消进行线路位(Bit)错误率的测试。
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前我们CT1单板支持2^20和2^15两种测试模式。
BERT测试方式为,本端发出测试数据流,经过线路某处环回来,检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对方设置远端环回等。利用bert命令配置好测试模式,指定测试时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。
BERT测试状态和测试结果详见CT1接口显示部分。
# 执行2^20格式的BERT测试10分钟。
[Sysname-T1 2/0/0] bert pattern 2^20 time 10
cable { long { 0db | -7.5db | -15db | -22.5db } | short { 133ft | 266ft | 399ft | 533ft | 655ft } }
undo cable
CT1接口视图
【缺省级别】
2:系统级
long:匹配655英尺以上的传输线路,可选参数有0db-7.5db-15db-22.5db,可根据接收端信号质量选择不同的衰减参数,当线路质量越差时,信号衰减越大,需要用户对这种衰减进行相应补偿,此时,不需要外接CSU。
short:匹配655英尺以下的传输线路,可选参数有133ft266ft399ft533ft655ft,可根据传输线路的长度,选择相应的长度参数。
【描述】
cable命令用来设置CT1接口匹配的传输线路的衰减或长度。undo cable命令用来恢复缺省情况。
缺省情况下,CT1接口匹配的传输线路衰减为long 0db
本命令主要作用是配置发送时的信号波形,以适应不同传输需要。实际使用中,可根据接收端收到的信号质量的好坏,来决定是否使用此命令。如果信号质量较好,可以使用缺省设置。使用缺省配置时,CT1接口不需外接CSU设备。
# 将CT1接口匹配的传输线路设为133英尺。
[Sysname-T1 2/0/0] cable short 133ft
channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
CT1接口视图
【缺省级别】
2:系统级
set-number:该接口上时隙捆绑形成的channel set编号,取值范围为0~23。
timeslot-list list:被捆绑的时隙。list为时隙编号,取值范围为1~24。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
speed { 56k | 64k }:时隙捆绑速率,单位为kbps。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。系统默认为64K
【描述】
channel-set命令用来将CT1接口的时隙捆绑为通道组(channel set)。undo channel-set命令用来取消相应的通道组。
缺省情况下,不捆绑任何channel set。
CT1接口在物理上分为24个时隙,对应编号为1~24。使用时,可以将全部时隙分成若干通道组(channel set),每组时隙捆绑以后,系统将自动创建一个Serial接口,其逻辑特性与同步串口相同。
Serial接口的编号是serial interface-number:set-number。其中interface-number是CT1接口的编号,set-number是channel set的编号。
在一个CT1接口上,同一个时间内只能支持一种时隙捆绑方式。
# 将CT1接口的1、2、5、10-15和18时隙捆绑为0号channel-set。
[Sysname-T1 2/0/0] channel-set 0 timeslot-list 1,2,5,10-15,18
undo clock
CT1接口视图
【缺省级别】
2:系统级
master:使用内部时钟方式。
slave:使用线路时钟方式。
【描述】
clock命令用来设置CT1接口的时钟方式。undo clock命令用来恢复缺省情况。
当CT1接口作为DCE设备使用时,应选择内部时钟,即master时钟方式;作为DTE设备使用时,应选择线路时钟,即slave时钟方式。
当两台路由器的CT1接口直接相连时,必须使两端分别工作在线路时钟方式(slave)和内部时钟方式(master)。当路由器的CT1接口与交换机连接时,交换机是DCE设备,负责提供时钟;而路由器的接口需工作在线路时钟方式(slave)。
# 设置CT1接口的时钟为内部时钟。
[Sysname-T1 2/0/0] clock master
code { ami | b8zs }
undo code
CT1接口视图
【缺省级别】
2:系统级
b8zs:采用b8zs(Bipolar with 8-Zero Substitution)线路编码格式。
【描述】
code命令用来设置CT1接口的线路编码格式。undo code命令用来恢复缺省情况。
缺省情况下,CT1接口的线路编码格式为b8zs
# 设置接口T1 2/0/0的线路编解码方式为ami
[Sysname-T1 2/0/0] code ami
1.3.8  controller t1
controller t1 number
【缺省级别】
2:系统级
number:CT1接口的编号。
【描述】
controller t1命令用来进入CT1接口的视图。
# 进入接口CT1 2/0/0的视图。
[Sysname-T1 2/0/0]
1.3.9  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置CT1接口通过各种方式形成的同步串口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
# 设置接口T1 2/0/0通过channel-set形成的同步串口使用32位CRC校验。
[Sysname-T1 2/0/0] channel-set 1 timeslot-list 2-6
[Sysname-T1 2/0/0] quit
[Sysname] interface serial 2/0/0:1
[Sysname-Serial2/0/0:1] crc 32
undo data-coding
CT1接口视图
【缺省级别】
2:系统级
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
【描述】
data-coding inverted命令用来设置CT1接口对用户数据进行翻转。data-coding normal命令用来设置CT1接口不对用户数据进行翻转。undo data-coding命令用来恢复缺省情况。
缺省情况下,CT1接口不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当T1接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现过多连0的缺陷。
需注意的是,只有通信的T1线路两端的CT1接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置CT1接口对数据进行翻转。
[Sysname-T1 2/0/0] data-coding inverted
CT1接口视图
【缺省级别】
2:系统级
【描述】
description命令用来配置CT1接口的描述字符串。undo description命令用来恢复缺省情况。
缺省情况下,CT1接口的描述字符串为“该接口的接口名 Interface”,比如:T1 2/0/0 Interface。
# 配置接口T1 2/0/0的描述字符串为“T1-interface”。
[Sysname-T1 2/0] description T1-interface
display controller t1 [ interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
【描述】
display controller t1命令用来显示CT1接口的相关信息。
# 显示T1接口的相关信息。
<Sysname> display controller t1 2/0/0
T1 2/0/0 current state :DOWN
Description : T1 2/0/0 Interface
  Work mode is T1 framed, Cable type is 100 Ohm balanced.
  Frame-format is esf, fdl is none, Line code is b8zs.
  Source clock is slave, Data-coding is normal.
  Idle code is ff, Itf type is ff, Itf number is 2.
Alarm State:
  Receiver alarm state is Loss-of-Signal.
  Transmitter is sending remote alarm.
  Pulse density violation detected.
SendLoopCode History:
  inband-llb-up:0 times, inband-llb-down:0 times.
  fdl-ansi-llb-up:0 times, fdl-ansi-llb-down:0 times.
  fdl-ansi-plb-up:0 times, fdl-ansi-plb-down:0 times.
BERT state:(stopped, not completed)
  Test pattern: 2^15, Status: Not Sync, Sync Detected: 0
    Time: 0 minute(s), Time past: 0 minute(s)
    Bit Errors (since test started): 0 bits
    Bits Received (since test started): 0 Kbits
    Bit Errors (since latest sync): 0 bits
    Bits Received (since latest sync): 0 Kbits
  Data in current interval (285 seconds elapsed):
    0 Line Code Violations, 0 Path Code Violations
    0 Ais Alarm Secs, 286 Los Alarm Secs
    7 Slip Secs, 286 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 286 Unavail Secs
  Data in Interval 1:
    0 Ais Alarm Secs, 901 Los Alarm Secs
    22 Slip Secs, 901 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 901 Unavail Secs
  Data in Interval 2:
    0 Ais Alarm Secs, 900 Los Alarm Secs
    23 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
  Total Data (last 2 15 minute intervals):
    0 Ais Alarm Secs, 2087 Los Alarm Secs
    52 Slip Secs, 2087 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 2087 Unavail Secs
表1-5 display controller t1命令显示信息描述表
接口物理上的up/down状态
T1接口的描述信息
Basic Configuration
接口基本配置
T1接口的工作模式(T1/CT1)
T 1接口的线缆类型(100 Ohm balanced)
Frame-format is esf
T 1接口的帧格式(esf/sf)
fdl is none
FDL格式(ansi/att/none
Line code is b8zs
线路编码格式(b8zs/ami)
接口的时钟源模式(master/slave)
包括正常和数据翻转两种模式(normal/inverted)
Idle code is ff
空闲码(7e/ff)
Itf type is ff
帧间填充码的类型(7e/ff)
Itf number is 2
帧间填充码的字节数为2个
接口是否设置了环回(local/payload/remote/no set)
Alarm State
告警状态
收到的告警类型:none、LOS、LOF、RAI、AIS
发出的告警类型:RAI、none
脉冲密度不符合规范要求
向对端发送环回码的历史记录,包括每种码的发送次数和最近发送的是哪种码
BERT测试状态:completed(自然完成)还是stopped(人为中止)还是running(正在测试)
Test pattern: 2^15
测试模式(2^20/2^15
Status: Not Sync
是否处于同步状态
Sync Detected: 0
测试以来检测到的同步次数
Time: 0 minute(s)
预设的测试时间
已经过去的测试时间
测试以来收到的错误的比特数
测试以来收到的总比特数
最近的同步以来收到的错误的比特数
最近的同步以来收到的总比特数
历史信息
清零记录
当前时间间隔内的统计信息(15分钟为一个时间间隔)。 这些数据是按照T1规范对物理层所作的各种信息统计,如AIS告警、RAI告警、LOS信号、LFA等。详细解释参见T1规范ANSI T1.403和AT&T TR 54016
Data in Interval 1:
第1间隔内的统计信息
统计内容同上
Data in Interval 2:
第2间隔内的统计信息
统计内容同上
所有间隔内的统计信息
统计内容同上
【缺省级别】
2:系统级
【描述】
本命令只对CT1、CE1接口、E1-F接口和T1-F 接口起作用。
[Sysname] error-diffusion restraint cofing 100 2400 15
【缺省级别】
2:系统级
【描述】
缺省情况下,使能错包扩散抑制功能。
# 使能错包扩散抑制功能。
1.3.15  fdl
fdl { ansi | att | both | none }
undo fdl
CT1接口视图
【缺省级别】
2:系统级
ansi:使能FDL,遵循ANSI T1.403规范。
att:使能FDL,遵循AT&T TR 54016规范。
both:使能FDL,同时遵循ANSI T1.403规范和AT&T TR 54016规范。
none:禁止FDL。
【描述】
fdl命令用来配置CT1接口在ESF格式时FDL比特位的使用模式。undo fdl命令用来恢复缺省情况。
缺省情况下,禁止FDL(none)。
FDL(Facility Data Link,设备数据链路)是T1的ESF帧格式中4kbps的一个带宽,CT1接口在配置为扩展超帧(ESF,extended Super Frame)格式时,其中的FDL位可用来传递报警信息、性能信息及环回码等,相关的规范包括ANSI T1.403和ATT TR 54016。在实际应用中,经常需要对FDL的使用及规范进行各种配置,包括:禁止FDL、使能并遵循ANSI规范、使能并遵循AT&T规范或者使能并遵循这两种规范。
实际应用中,可以根据对方FDL的模式调整本端FDL的模式。
# 设置接口T1 2/0/0 FDL使能并遵循AT&T规范。
[Sysname-T1 2/0/0] fdl att
frame-format { esf | sf }
undo frame-format
CT1接口视图
【缺省级别】
2:系统级
esf:设置CT1接口的帧格式为扩展超帧格式(Extended Super Frame)。
sf:设置CT1接口的帧格式为超帧格式(Super Frame)。
【描述】
frame-format命令用来设置CT1接口的帧格式。undo frame-format命令用来恢复缺省情况。
缺省情况下,CT1接口的帧格式为esf
CT1接口支持超帧(SFSuper Frame)和扩展超帧(ESFextended Super Frame)两种帧格式。在超帧格式中,多个帧可以共享相同的帧同步信息和信令信息,从而有更多的有效位来传送用户数据。实际应用中,经常需要对系统进行测试,扩展超帧技术可以用来满足在测试时不影响正常业务运行的要求。
# 设置T1接口的帧格式为超帧格式。
[Sysname-T1 2/0/0] frame-format sf
undo idlecode
CT1接口视图
【缺省级别】
2:系统级
7e:线路空闲码为0x7e格式。
ff:线路空闲码为0xff格式。
【描述】
idlecode命令用来设置CT1接口的线路空闲码类型。undo idlecode命令用来恢复缺省情况。
缺省情况下,CT1接口的线路空闲码类型为0x7e
CT1接口的线路空闲码类型是指在没有被绑定到逻辑通道的时隙上发送的码型。CT1接口的线路空闲码类型有两种:0x7e和0xff。
# 设置CT1接口的线路空闲码类型为0x7e。
[Sysname-T1 2/0/0] idlecode 7e
undo itf { type | number }
CT1接口视图
【缺省级别】
2:系统级
【描述】
itf命令用来设置CT1接口的帧间填充字节类型和个数。undo itf命令用来恢复缺省情况。
缺省情况下,CT1接口的帧间填充字节类型为0x7e,字节个数为4个。
CT1接口的帧间填充符是指在已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。CT1接口的帧间填充符类型有两种:0x7e0xff
# 设置CT1接口的帧间填充字节类型为0xff。
[Sysname-T1 2/0/0] itf type ff
# 设置CT1接口的帧间填充字节个数为5。
[Sysname-T1 2/0/0] itf number 5
undo loopback
CT1接口视图
【缺省级别】
2:系统级
local:设置CT1接口对内自环。
payload: 设置CT1接口对外净荷环回。
remote:设置CT1接口对外环回。
【描述】
loopback命令用来设置CT1接口进行对内自环、对外环回或对外净荷环回。undo loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
自环环回功能主要用于检测接口或电缆本身的状况,正常工作时,应禁止这些功能。
对于CT1接口经时隙捆绑形成串口,如果将链路层协议配置为PPP,设置自环后,链路层协议状态将上报为down。这属于正常情况。
# 设置接口T1进行对外环回。
[Sysname-T1 2/0/0] loopback remote
reset counters controller t1 interface-number
【缺省级别】
2:系统级
【描述】
reset counters controller t1命令用来清除CT1接口的controller计数器。controller计数器值可以用display controller t1命令来查看。
单独清除CT1接口的controller计数器只能使用reset counters controller t1命令,不能使用reset counters interface命令,该命令会清除所有接口的计数器。
# 清除CT1接口2/0/0的controller计数器。
<Sysname> reset counters controller t1 2/0/0
1.3.21  sendloopcode
sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
CT1接口视图
【缺省级别】
2:系统级
fdl-ansi-llb-down发送FDL承载的符合ANSI规范的线路环回去激活码,解除环回。
fdl-ansi-llb-up发送FDL承载的符合ANSI规范的线路环回激活码,启动远端环回。
fdl-ansi-plb-down发送FDL承载的符合ANSI规范的净荷环回去激活码,解除环回。
fdl-ansi-plb-up发送FDL承载的符合ANSI规范的净荷环回激活码,启动远端环回。
fdl-att-plb-down:发送FDL承载的符合AT&T规范的净荷环回去激活码,解除环回。
fdl-att-plb-up:发送FDL承载的符合AT&T规范的净荷环回激活码,启动远端环回。
inband-llb-down发送符合ANSI规范和AT&T规范的带内线路环回去激活码,解除环回。
inband-llb-up发送符合ANSI规范和AT&T规范的带内线路环回激活码,启动远端环回。
【描述】
sendloopcode命令用来配置发送远程环回控制码。
缺省情况下,不发送远程环回控制码。
CT1接口下可以通过发送环回控制码对远端的CT1接口进行环回的自动配置。LLB为线路环回(Line Loop Back),这种方式下一个T1的PCM帧的全部193位(包括1位同步位及192位有效带宽)都被环回;PLB为净荷环回(Payload Loop Back),这种方式下仅192位有效带宽被环回。环回码的格式规范包括ANSI T1.403和AT&T TR 54016。SF格式下的LLB环回码占用有效带宽;ESF格式下对LLB和PLB的环回码均使用ESF帧的FDL比特位收发。
这条命令需要和远端T1设备配合使用,当对方能检测符合上述格式的各种环回码时,对方能够根据检测到的环回码类型设置相应的环回模式。持续发送5秒钟,不影响其他接口的正常工作。
配置该命令时要求远端的CT1接口能自动检测到来自网上的环回控制码。
# 发送带内线路环回激活码。
[Sysname-T1 2/0/0] sendloopcode inband-llb-up
shutdown
CT1接口视图
【缺省级别】
2:系统级
【描述】
shutdown命令用来关闭CT1接口。undo shutdown命令用来打开CT1接口。
缺省情况下,CT1接口为打开状态。
# 关闭接口T1 2/0/0。
[Sysname-T1 2/0/0] shutdown
1.4  E1-F接口基本配置命令
1.4.1  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置E1-F接口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
# 设置E1-F接口2/0/0使用32位CRC校验。
1.4.2  display fe1
display fe1 [ serial interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
serial interface-number:显示指定E1-F接口的信息。interface-number为串口编号。如果不指定接口,则显示所有的E1-F接口的信息。
【描述】
display fe1命令用来显示E1-F接口的状态信息。
若指定的接口不是E1-F接口而是一个普通串口,则系统会提示该串口不是E1-F接口。
# 显示E1-F接口的相关信息。
<Sysname> display fe1 serial 2/0/0
 Serial2/0/0
    E1 FRAMED
Physical type is  FE1 - 75 OHM unbalanced
    Frame-format is  NONE,Line Code is HDB3,Source Clock is SLAVE
  Alarm State:
    Data in current interval (19349 seconds elapsed):
    129 Loss Frame Alignment Secs, 0 Framing Error Secs,
    0 CRC Error Secs, 0 Alarm Indication Secs, 129 Loss-of-signals Secs,
表1-6 display fe1命令显示信息描述表
E1 FRAMED
工作模式(FRAMED/UN FRAMED
Physical type
接口类型(75欧非平衡/120欧平衡)
Frame-format
帧格式(crc4/no-crc4)
Line Code
线路编码格式(ami/hdb3)
Source Clock
时钟方式(master/slave)
Alarm State: Receiver alarm state is None
告警信息
历史统计信息
【缺省级别】
2:系统级
【描述】
【缺省级别】
2:系统级
【描述】
缺省情况下,使能错包扩散抑制功能。
# 使能错包扩散抑制功能。
1.4.5  fe1 alarm
fe1 alarm detect rai
undo fe1 alarm detect rai
E1-F接口视图
【缺省级别】
2:系统级
detect:接口的定时检测功能。
【描述】
fe1 alarm命令用来配置检测远端告警信号。undo fe1 alarm命令用来取消检测。
缺省情况下,检测远端告警信号。
在成帧方式的情况下,可以使用该命令。
# 取消检测远端告警信号功能。
[Sysname-Serial2/0/0] undo fe1 alarm detect rai
1.4.6  fe1 cable
fe1 cable { long | short }
undo fe1 cable
E1-F接口视图
【缺省级别】
2:系统级
long:表示设置支持长电缆类型。
short:表示设置支持短电缆类型。
【描述】
fe1 cable命令用来设置接口支持的电缆类型。undo fe1 cable命令用来恢复缺省情况。
缺省情况下,E1-F接口支持长电缆类型。
# 配置E1-F接口2/0/0支持的电缆类型为short
[Sysname-Serial2/0/0] fe1 cable short
1.4.7  fe1 clock
fe1 clock { master | slave }
undo fe1 clock
E1-F接口视图
【缺省级别】
2:系统级
master:使用内部时钟模式。
slave:使用线路时钟模式。
【描述】
fe1 clock命令用来设置E1-F接口的时钟方式。undo fe1 clock命令用来恢复缺省情况。
当E1-F接口作为DCE设备使用时,应选择内部时钟,即master时钟方式;作为DTE设备使用时,应选择线路时钟,即slave时钟方式。
# 设置E1-F接口的时钟为master方式。
[Sysname-Serial2/0/0] fe1 clock master
1.4.8  fe1 code
fe1 code { ami | hdb3 }
undo fe1 code
E1-F接口视图
【缺省级别】
2:系统级
【描述】
fe1 code命令用来设置E1-F接口的线路编码格式。undo fe1 code命令用来恢复缺省情况。
缺省情况下,E1-F接口的线路编码格式为hdb3
l              设置接口的线路编解码格式时请注意与对端设备保持一致。
l              线路编码采用ami方式时,在该接口上需要同时配置fe1 data-coding inverted,才能保证接口正常工作。
相关配置可参考命令fe1 data-coding
# 设置接口E1-F接口的线路编解码方式为ami
[Sysname-Serial2/0/0] fe1 code ami
fe1 data-coding { inverted | normal }
undo fe1 data-coding
E1-F接口视图
【缺省级别】
2:系统级
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
【描述】
fe1 data-coding命令用来设置E1-F接口是否对用户数据进行翻转。undo fe1 data-coding命令用来恢复缺省情况。
缺省情况下,不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当E1-F接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现的过多连0的缺陷。
需注意的是,只有通信的E1-F线路两端的E1-F接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置E1-F接口对数据翻转。
[Sysname-Serial2/0/0] fe1 data-coding inverted
fe1 detect-ais
undo fe1 detect-ais
E1-F接口视图
【缺省级别】
2:系统级
【描述】
fe1 detect-ais命令用来配置当前接口进行AIS检测。undo fe1 detect-ais命令用来取消AIS检测。
缺省情况下,进行AIS检测。
# 设置E1-F接口进行AIS检测。
[Sysname-Serial2/0/0] fe1 detect-ais
fe1 frame-format { crc4 | no-crc4 }
undo fe1 frame-format
E1-F接口视图
【缺省级别】
2:系统级
crc4:设置E1-F接口的帧格式为CRC4帧格式。
no-crc4:设置E1-F接口的帧格式为非CRC4帧格式。
【描述】
fe1 frame-format命令用来设置E1-F接口的帧格式。undo fe1 frame-format命令用来恢复缺省情况。
缺省情况下,E1-F接口的帧格式为no-crc4
E1-F接口工作在成帧方式下时,支持crc4no-crc4两种帧格式。其中crc4帧格式支持对物理帧进行4比特的循环冗余校验,而no-crc4帧格式则不支持。
# 设置E1-F接口的帧格式为crc4
[Sysname-Serial2/0/0] fe1 frame-format crc4
1.4.12  fe1 idlecode
fe1 idlecode { 7e | ff }
undo fe1 idlecode
E1-F接口视图
【缺省级别】
2:系统级
7e:线路空闲码为0x7e格式。
ff:线路空闲码为0xff格式。
【描述】
fe1 idlecode命令用来设置E1-F接口的线路空闲码类型。undo fe1 idlecode命令用来恢复缺省情况。
缺省情况下,E1-F接口的线路空闲码类型为0x7e
E1-F接口的线路空闲码类型是指在没有被绑定到逻辑通道的时隙上发送的码型。E1-F接口的线路空闲码类型有两种:0x7e和0xff。
# 设置E1-F接口的线路空闲码类型为0x7e。
[Sysname-Serial2/0/0] fe1 idlecode 7e
1.4.13  fe1 itf
fe1 itf { number number | type { 7e | ff } }
undo fe1 itf { number | type }
E1-F接口视图
【缺省级别】
2:系统级
type { 7e | ff }:设置帧间填充字节(Interframe filling flag)类型,7e表示帧间填充符为0x7e格式,ff表示帧间填充符为0xff格式,缺省值为7e
【描述】
fe1 itf命令用来设置E1-F接口的帧间填充字节类型和个数。undo fe1 itf命令用来恢复缺省情况。
缺省情况下,E1-F接口的帧间填充字节类型为0x7e,字节个数为4个。
E1-F接口的帧间填充符是指在已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。E1-F接口的帧间填充符类型有两种:0x7e0xff
# 设置E1-F接口的帧间填充字节类型为0xff。
[Sysname-Serial2/0/0] fe1 itf type ff
# 设置E1-F接口的帧间填充字节个数为5。
[Sysname-Serial2/0/0] fe1 itf number 5
1.4.14  fe1 loopback
fe1 loopback { local | payload | remote }
undo fe1 loopback
E1-F接口视图
【缺省级别】
2:系统级
local:设置接口对内自环。
payload:设置接口净荷环回。
remote:设置接口对外环回。
【描述】
fe1 loopback命令用来设置E1-F接口进行对内自环、净荷环回或者对外环回。undo fe1 loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
自环、环回功能主要用于检测接口或电缆本身的状况,正常工作时应禁止这些功能。
在接口上,本命令可以根据不同的参数,分别打开对内自环、净荷环回或者对外环回功能,但不能同时启用。
# 设置E1-F接口进行对内自环。
[Sysname-Serial2/0/0] fe1 loopback local
fe1 timeslot-list list
undo fe1 timeslot-list
E1-F接口视图
【缺省级别】
2:系统级
list:被捆绑的时隙编号,取值范围为1~31。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以用number1,number2-number3的形式同时指定多个时隙。
【描述】
fe1 timeslot-list命令用来设置E1-F接口的时隙捆绑。undo fe1 timeslot-list命令用来恢复缺省情况。
缺省情况下,E1-F接口捆绑所有的时隙,即E1-F接口的缺省速率为1984kbps。
在对E1-F接口进行时隙捆绑后,接口的速率会同时改变。例如,当用户将1~10这十个时隙捆绑之后,接口的速率就会变为10×64kbps。
与CE1接口不同的是,在E1-F接口上只能捆绑出一个通道组(channel set),捆绑出的通道组就对应当前的同步串口。而在CE1接口上可以捆绑出多个通道组,并且每捆绑一个通道组,系统都会自动生成一个与之相对应的同步串口。
因为E1-F接口的0时隙被用于传输同步信息,所以,当对E1-F接口的时隙进行全部捆绑时,实际捆绑的时隙为1~31时隙。
当E1-F接口的工作方式为非成帧方式时,不能配置fe1 timeslot-list命令。
相关配置可参考命令fe1 unframed
# 将E1-F接口上的1、2、5、10~15、18时隙捆绑起来。
[Sysname-Serial2/0/0] fe1 timeslot-list 1,2,5,10-15,18
1.4.16  fe1 unframed
fe1 unframed
undo fe1 unframed
E1-F接口视图
【缺省级别】
2:系统级
【描述】
fe1 unframed命令用来设置E1-F接口的工作方式为非成帧方式。undo fe1 unframed命令用来恢复E1-F接口的工作方式为成帧方式。
缺省情况下,E1-F接口工作在成帧方式。
当E1-F接口工作在非成帧的工作方式时,它相当于一个不分时隙、数据带宽为2048kbps的接口,其逻辑特性与同步串口相同。
当E1-F接口工作在成帧的工作方式时,它在物理上分为32个时隙,对应编号为0~31,其中0时隙用于传输同步信息。
相关配置可参考命令fe1 timeslot-list
# 设置E1-F接口的工作方式为非成帧方式。
[Sysname-Serial2/0/0] fe1 unframed
1.5  T1-F接口基本配置命令
1.5.1  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置T1-F接口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
# 设置T1-F接口2/0/0使用32位CRC校验。
1.5.2  display ft1
display ft1 [ serial interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
serial interface-number:显示指定T1-F接口的信息。interface-number为串口编号。如果不指定接口,则显示所有的T1-F接口的信息。
【描述】
display ft1命令用来显示T1-F接口的配置和状态信息。
若指定的接口不是T1-F接口而是一个普通串口,则系统会提示该串口不是T1-F接口。
# 显示T1-F接口的相关信息。
<Sysname> display ft1 serial 2/0/0
Serial2/0/0
Input: 0 packets, 0 bytes
           0 frame errors
    Output:0 packets, 0 bytes
           0 deferred
Alarm State:
  Data in Interval 1:
  Data in Interval 2:
表1-7 display ft1命令显示信息描述表
Seria2/0/0
Basic Configuration
接口的基本配置
Input:/Output
输入/输出统计信息
T1-F接口的工作模式(T1/CT1)
T1-F接口的线缆类型(100 Ohm balanced)
Frame-format is esf
T1-F接口的帧格式(esf/sf)
fdl is none
FDL格式(ansi/att/none
Line code is b8zs
线路编码格式(b8zs/ami)
Idle code is ff
空闲码(7e/ff)
Itf type is ff
帧间填充码的类型(7e/ff)
Itf number is 2
帧间填充码的字节数为2个
接口是否设置了环回(local/payload/remote/not set)
Alarm State
告警状态
发出的告警类型:RAI、none
.脉冲密度不符合规范要求
Test pattern: 2^15
测试模式(2^20/2^15
Status: Not Sync
是否处于同步状态
Sync Detected: 0
测试以来检测到的同步次数
Time: 0 minute(s)
预设的测试时间,
已经过去的测试时间
测试以来收到的比特错误数
测试以来收到的比特总数
最近的同步以来收到的比特错误数
最近的同步以来收到的比特总数
历史信息
清零记录
Data in Interval 1:
第1间隔内的统计信息
统计内容同上
Data in Interval 2:
第2间隔内的统计信息
统计内容同上
所有间隔内的统计信息
统计内容同上
【缺省级别】
2:系统级
【描述】
【缺省级别】
2:系统级
【描述】
缺省情况下,使能错包扩散抑制功能。
# 使能错包扩散抑制功能。
1.5.5  ft1 alarm
ft1 alarm detect rai
undo ft1 alarm detect rai
T1-F接口视图
【缺省级别】
2:系统级
detect:接口的定时检测功能。
【描述】
ft1 alarm命令用来配置检测远端告警信号。undo ft1 alarm命令用来取消检测。
缺省情况下,检测远端告警信号。
# 取消检测远端告警信号功能。
[Sysname-Serial2/0/0] undo ft1 alarm detect rai
ft1 alarm-threshold { ais { level-1 | level-2 } | lfa { level-1 | level-2 | level-3 | level-4 } | los { pulse-detection | pulse-recovery } value }
undo ft1 alarm-threshold { ais | lfa | los { pulse-detection | pulse-recovery } }
T1-F接口视图
【缺省级别】
2:系统级
ais AIS告警的门限值。AIS告警有两个门限值,分别为level-1level-2。level-1的门限为在一个SF/ESF帧内,比特流中的0的个数小等于2,则AIS告警产生;level-2的门限在SF格式时为,一个SF帧内码流的0个数小等于3;在ESF格式时为一个ESF帧内码流的0个数小等于5。缺省情况下,AIS告警门限值为level-1。lfa LFA告警的门限值。LFA告警有四个门限值可以配置,分别为level-1level-2level-3level-4level-1为4个帧同步比特中丢失了2个;level-2为5个帧同步比特中丢失了2个;leve-3为6个帧同步比特中丢失了2个;level-4仅仅对ESF格式有效,在连续4个ESF帧中出现错误时产生LFA告警。缺省情况下,LFA告警门限值为level-1。
losLOS告警的门限值。LOS告警有两个门限值,分别为pulse-detectionpulse-recoverypulse-detection配置LOS的检测时长门限,取值范围为16~4096,这个时长门限的单位为“脉冲周期”;pulse-recovery配置LOS的脉冲门限,取值范围为1~256,就是在检测时长内(即pulse-detection配置的若干个脉冲周期内),检测到的脉冲个数如果小于pulse-recovery所配置的值,则LOS告警产生。在缺省情况,pulse-detection参数的值为176,pulse-recovery的值为22,即如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失,LOS告警产生。
【描述】
ft1 alarm-threshold命令用来配置T1-F接口告警的门限值。undo ft1 alarm-threshold命令用来恢复缺省情况。
缺省情况下,对于LOS告警,pulse-detection参数的值为176,pulse-recovery的值为22,即缺省情况下,如果在176个脉冲周期内检测到的脉冲数小于22个则认为载波丢失LOS告警产生;对于AIS告警,缺省值为level-1;对于LFA告警,缺省值为level-1。
实际使用中,可以根据实际情况配置各个告警门限。
[Sysname-Serial2/0/0] ft1 alarm-threshold los pulse-detection 300
1.5.7  ft1 bert
ft1 bert pattern { 2^20 | 2^15 } time minutes [ unframed ]
undo ft1 bert
T1-F接口视图
【缺省级别】
2:系统级
time minutes:设置BERT测试事件,以分钟计,最长1440分钟。
【描述】
ft1 bert命令用来进行线路位(Bit)错误率的测试。undo ft1 bert命令用来取消进行线路位(Bit)错误率的测试。
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前我们T1-F单板支持2^20和 2^15两种测试模式。
BERT测试状态和测试结果详见T1-F接口显示部分。
[Sysname-Serial2/0/0] ft1 bert pattern 2^20 time 10
1.5.8  ft1 cable
ft1 cable { long decibel | short length }
undo ft1 cable
T1-F接口视图
【缺省级别】
2:系统级
long decibel:匹配655英尺以上的传输线路,参数decibel的值可以为0db-7.5db-15db-22.5db,可根据接收端信号质量选择不同的衰减参数,此时不需要外接CSU。
short length:匹配655英尺以下的传输线路,参数length的值可以为133ft、266ft399ft533ft655ft可根据传输线路的长度选择相应的长度参数。
【描述】
ft1 cable命令用来设置T1-F接口匹配的传输线路的衰减或长度。undo ft1 cable命令用来恢复缺省情况。
缺省情况下,T1-F接口匹配的传输线路衰减为long 0db
本命令主要作用是配置发送时的信号波形,以适应不同传输需要。实际使用中可根据接收端收到的信号质量的好坏来决定是否使用此命令。如果信号质量较好可以使用缺省设置。
# 将T1-F接口匹配的传输线路设为133英尺。
[Sysname-Serial2/0/0] ft1 cable short 133ft
1.5.9  ft1 clock
ft1 clock { master | slave }
undo ft1 clock
T1-F接口视图
【缺省级别】
2:系统级
master:使用内部时钟模式。
slave:使用线路时钟模式。
【描述】
ft1 clock命令用来设置T1-F接口的时钟方式。undo ft1 clock命令用来恢复缺省情况。
当T1-F接口作为DCE设备使用时,应选择内部时钟,即master时钟方式;作为DTE设备使用时,应选择线路时钟,即slave时钟方式。
当两台路由器的T1-F接口直接相连时,必须使两端分别工作在线路时钟方式(slave)和内部时钟方式(master)。当路由器的T1-F接口与交换机连接时,交换机是DCE设备,负责提供时钟;而路由器的接口需工作在线路时钟方式(slave)。
# 设置T1-F接口的时钟为master方式。
[Sysname-Serial2/0/0] ft1 clock master
1.5.10  ft1 code
ft1 code { ami | b8zs }
undo ft1 code
T1-F接口视图
【缺省级别】
2:系统级
【描述】
ft1 code命令用来设置T1-F接口的线路编码格式。undo ft1 code命令用来恢复缺省情况。
缺省情况下,T1-F接口的线路编码格式为b8zs
l              线路编码采用ami方式时,在该接口上需要同时配置ft1 data-coding inverted,才能保证接口正常工作。
相关配置可参考命令ft1 data-coding
# 设置接口T1-F接口的线路编解码方式为AMI
[Sysname-Serial2/0/0] ft1 code ami
ft1 data-coding { inverted | normal }
undo ft1 data-coding
T1-F接口视图
【缺省级别】
2:系统级
inverted:对用户数据进行翻转。
normal:不对用户数据进行翻转。
【描述】
ft1 data-coding命令用来设置T1-F接口是否对用户数据进行翻转。undo ft1 data-coding命令用来恢复缺省情况。
缺省情况下,不对用户数据进行翻转。
HDLC协议为了防止有效数据中的7e被当作填充符,会在连续5个1后插入一个0。然后可以进行数据翻转,数据翻转后,0变成1,1变成0。数据翻转的作用是:当T1-F接口配置为AMI编码时,能保证每8个连续比特中至少有一个1,从而弥补AMI码中易出现的过多连0的缺陷。
需注意的是,只有通信的T1-F线路两端的T1-F接口保持一致(都进行翻转或都不进行数据翻转),才能正常通信。
# 设置T1-F接口对数据翻转。
[Sysname-Serial2/0/0] ft1 data-coding inverted
1.5.12  ft1 fdl
ft1 fdl { ansi | att | both | none }
undo ft1 fdl
T1-F接口视图
【缺省级别】
2:系统级
ansi设置T1-F接口的FDL支持ANSI T1.403 规范。
att设置T1-F接口的FDL支持AT&T TR 54016 规范。
none禁止FDL的使用。
【描述】
ft1 fdl命令用来配置T1-F接口在ESF格式时FDL比特位的使用模式。undo ft1 fdl命令用来恢复缺省情况。
缺省情况下,FDL为禁止状态。
FDLT1ESF帧格式中4kbps的一个带宽,可以用来传递性能信息或者环回码之类。
# 设置T1-F接口的FDL支持ANSI规范。
[Sysname-Serial2/0/0] ft1 fdl ansi
ft1 frame-format { esf | sf }
undo ft1 frame-format
T1-F接口视图
【缺省级别】
2:系统级
esf:设置T1-F接口的帧格式为扩展超帧格式(Extended Super Frame)。
sf:设置T1-F接口的帧格式为超帧格式(Super Frame)。
【描述】
ft1 frame-format命令用来设置T1-F接口的帧格式。undo ft1 frame-format命令用来恢复缺省情况。
缺省情况下,T1-F接口的帧格式为esf
T1-F接口支持超帧(SFSuper Frame)和扩展超帧(ESFextended Super Frame)两种帧格式。在超帧格式中,多个帧可以共享相同的帧同步信息和信令信息,从而有更多的有效位来传送用户数据。实际应用中,经常需要对系统进行测试,扩展超帧技术可以用来满足在测试时不影响正常业务运行的要求。
# 设置T1-F接口的帧格式为超帧格式。
[Sysname-Serial2/0/0] ft1 frame-format sf
1.5.14  ft1 idlecode
ft1 idlecode { 7e | ff }
undo ft1 idlecode
T1-F接口视图
【缺省级别】
2:系统级
7e:线路空闲码为0x7e格式。
ff:线路空闲码为0xff格式。
【描述】
ft1 idlecode命令用来设置T1-F接口的线路空闲码类型。undo ft1 idlecode命令用来恢复缺省情况。
缺省情况下,T1-F接口的线路空闲码类型为0x7e
T1-F接口的线路空闲码类型是指在没有被绑定到逻辑通道的时隙上发送的码型。T1-F接口的线路空闲码类型有两种:0x7e和0xff。
# 设置T1-F接口的线路空闲码类型为0x7e。
[Sysname-Serial2/0/0] ft1 idlecode 7e
1.5.15  ft1 itf
ft1 itf { number number | type { 7e | ff } }
undo ft1 itf { number | type }
T1-F接口视图
【缺省级别】
2:系统级
【描述】
ft1 itf命令用来设置T1-F接口的帧间填充字节类型和个数。undo ft1 itf命令用来恢复缺省情况。
缺省情况下,T1-F接口的帧间填充字节类型为0x7e,字节个数为4个。
T1-F接口的帧间填充符是指在已经被绑定到逻辑通道的时隙在没有发送业务数据时发送的码型。T1-F接口的帧间填充符类型有两种:0x7e0xff
同时配置了ft1 code ami命令和ft1 data-coding inverted命令后,不能配置ft1 itf type ff命令,否则T1-F接口不能正常工作。
# 设置T1-F接口的帧间填充字节类型为0xff。
[Sysname-Serial2/0/0] ft1 itf type ff
# 设置T1-F接口的帧间填充字节个数为5。
[Sysname-Serial2/0/0] ft1 itf number 5
1.5.16  ft1 loopback
ft1 loopback { local | payload | remote }
undo ft1 loopback
T1-F接口视图
【缺省级别】
2:系统级
local:设置接口对内自环。
payload:设置接口净荷环回。
remote:设置接口对外环回。
【描述】
ft1 loopback命令用来设置T1-F接口进行对内自环、净荷环回或对外环回。undo ft1 loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
# 设置T1-F接口进行对内自环。
[Sysname-Serial2/0/0] ft1 loopback local
ft1 sendloopcode { fdl-ansi-llb-down | fdl-ansi-llb-up | fdl-ansi-plb-down | fdl-ansi-plb-up | fdl-att-plb-down | fdl-att-plb-up | inband-llb-down | inband-llb-up }
T1-F接口视图
【缺省级别】
2:系统级
fdl-ansi-llb-down:发送FDL承载的符合ANSI规范的线路环回去激活码,解除环回。
fdl-ansi-llb-up:发送FDL承载的符合ANSI规范的线路环回激活码,启动远端环回。
fdl-ansi-plb-down:发送FDL承载的符合ANSI规范的净荷环回去激活码,解除环回。
fdl-ansi-plb-up:发送FDL承载的符合ANSI规范的净荷环回激活码,启动远端环回。
inband-llb-down:发送符合ANSI规范和AT&T规范的带内线路环回去激活码,解除环回。
inband-llb-up:发送符合ANSI规范和AT&T规范的带内线路环回激活码,启动远端环回。
【描述】
ft1 sendloopcode命令用来配置发送远程环回控制码。
缺省情况下,不发送远程环回控制码。
T1-F接口下可以通过发送环回控制码对远端的T1-F接口进行环回的自动配置。LLB为线路环回(Line Loop Back),这种方式下一个T1的PCM帧的全部193位(包括1位同步位及192位有效带宽)都被环回;PLB为净荷环回(Payload Loop Back),这种方式下仅192位有效带宽被环回。环回码的格式规范包括ANSI T1.403和AT&T TR 54016。SF格式下的LLB环回码占用有效带宽(1-24时隙);ESF格式下对LLB和PLB的环回码均使用ESF帧的FDL比特位收发。
#发送带内line loop back的激活码。
[Sysname-Serial2/0/0] ft1 sendloopcode inband-llb-up
ft1 timeslot-list list [ speed { 56k | 64k } ]
undo ft1 timeslot-list
T1-F接口视图
【缺省级别】
2:系统级
list:被捆绑的时隙编号,取值范围为1~24。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以用number1,number2-number3的形式同时指定多个时隙。
speed { 56k | 64k }:时隙捆绑速率,单位为kbps。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。时隙的缺省速率为64kbps。
【描述】
ft1 timeslot-list命令用来设置T1-F接口的时隙捆绑。undo ft1 timeslot-list命令用来恢复缺省情况。
缺省情况下,T1-F接口均捆绑所有的时隙,即T1-F接口的缺省速率为1536kbps。
在对T1-F接口进行时隙捆绑后,接口的速率会同时改变。例如,当用户将1~10这十个时隙捆绑之后,接口的速率就会变为10×64kbps(或10×56kbps)。
与CT1接口不同的是,在T1-F接口上只能捆绑出一个通道组(channel set),捆绑出的通道组就对应当前的同步串口。而在CT1接口上,可以捆绑出多个通道组,并且每捆绑一个通道组,系统都会自动生成一个同步串口,与之相对应。
# 将T1-F接口上的1、2、5、10~15、18时隙捆绑起来。
[Sysname-Serial2/0/0] ft1 timeslot-list 1,2,5,10-15,18
1.6  CE3接口基本配置命令
bert pattern { 2^7 | 2^11 | 2^15 | qrss } time number [ unframed ]
undo bert
CE3接口视图
【缺省级别】
2:系统级
pattern:设置BERT测试模式,包括2^7,2^11,2^15和QRSS。
2^7:发送的码流长度为2的7次方个bit。
2^11:发送的码流长度为2的11次方个bit。
2^15:发送的码流长度为2的15次方个bit。
qrss:发送码流长度为2的20次方个bit,且码流中不允许连续14个以上的0。
time number :设置BERT测试的持续时间,单位为分钟,取值范围为1~1440。
unframed:设置测试数据流填充帧的开销位。
【描述】
bert命令用来进行线路位(Bit)错误率的测试。undo bert命令用来取消该测试。
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前CE3接口支持2^7,2^11,2^15和QRSS这几种测试模式。
BERT测试方式为,本端发出测试数据流,经过线路某处环回回来,本端检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对端设置为远端环回等。
利用bert命令配置好测试模式,指定测试持续时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。BERT测试状态和测试结果的说明详见CE3接口显示部分。
# 在CE3接口2/0/0上执行QRSS格式的BERT测试10分钟。
[Sysname] interface e3 2/0/0
[Sysname-E3 2/0/0] bert pattern qrss time 10
undo clock
CE3接口视图
【缺省级别】
2:系统级
master:使用内部时钟模式。
slave:使用线路时钟模式。
【描述】
clock命令用来配置CE3接口的时钟模式。undo clock命令用来恢复缺省情况。
缺省情况下,CE3接口的时钟模式为线路时钟。
使用内部时钟还是线路时钟,主要根据所连接的对端设备而定,如果与传输设备相连,本端通常设置为使用线路时钟。
如果是两台路由器的CE3接口直接相连,则应该把一端路由器时钟设置为内部时钟模式,另一端路由器时钟设置为线路时钟模式。
# 设置CE3接口的时钟为内部时钟模式。
[Sysname] controller e3 2/0
[Sysname-E3 2/0/0] clock master
1.6.3  controller e3
controller e3 interface-number
【缺省级别】
2:系统级
interface-number:CE3接口的编号。
【描述】
controller e3命令用来进入CE3接口视图。
相关配置可参考命令display controller e3
# 进入接口E3 2/0/0的视图。
[Sysname] controller e3 2/0/0
[Sysname-E3 2/0/0]
1.6.4  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置CE3接口通过各种方式形成的同步串口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
相关配置可参考命令e1 channel-sete1 unframedusing
# 设置E3接口2/0在非通道化模式下形成的同步串口使用32位CRC校验。
[Sysname-E3 2/0/0] using e3
[Sysname-E3 2/0/0] quit
[Sysname] interface serial 2/0/0/0:0
[Sysname-Serial2/0/0/0:0] crc 32
# 设置CE3接口2/0在通道化模式下形成的同步串口使用16位CRC校验。
[Sysname-E3 2/0/0] e1 3 channel-set 5 timeslot-list 1-20
[Sysname] interface serial 2/0/0/3:5
[Sysname-Serial2/0/0/3:5] crc 16
CE3接口视图
【缺省级别】
2:系统级
【描述】
description命令用来配置CE3接口的描述字符串。undo description命令用来恢复缺省情况。
缺省情况下,CE3接口的描述字符串为“该接口的接口名 Interface”,比如:E3 2/0/0 Interface。
# 配置接口E3 2/0/0的描述字符串为“E3-interface”。
[Sysname-E3 2/0/0] description E3-interface
display controller e3 [ interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:CE3接口编号。
【描述】
display controller e3命令用来查看CE3接口的状态信息。
本命令可以显示CE3接口的状态信息,同时,还可以显示CE3接口工作在CE3模式时每个E1通道的相关信息。
# 显示接口E3 2/0/0的相关信息。
<Sysname> display controller e3 2/0/0
  E3 2/0/0 is up
  Description : E3 2/0/0 Interface
  Applique type is CE3 - 75 OHM unbalanced  Frame-format G751, line code HDB3, clock slave, national-bit 1,loopback not set
  Alarm: none
  ERROR: 0 BPV, 0 EXZ, 0 FrmErr, 0 FEBE
E3-0  CE1 1 is up
  Frame-format NO-CRC4, clock master, loopback not set
E3-0  CE1 2 is up
  Frame-format NO-CRC4, clock slave, loopback local
E3-0  CE1 3 is up
  Frame-format NO-CRC4, clock slave, loopback remote
E3-0  CE1 4 is up
  Frame-format CRC4, clock slave, loopback not set
E3-0  CE1 5 is up
  Frame-format NO-CRC4, clock slave, loopback not set
E3-0  CE1 6 is up
E3-0  CE1 7 is up
E3-0  CE1 8 is up
E3-0  CE1 9 is up
E3-0  CE1 10 is up
E3-0  CE1 11 is up
E3-0  CE1 12 is up
E3-0  CE1 13 is up
E3-0  CE1 14 is up
E3-0  CE1 15 is up
E3-0  CE1 16 is up
1.6.7  e1 bert
e1 line-number bert pattern { 2^11 | 2^15 | 2^20 | 2^23 | qrss } time number [ unframed ]
undo e1 line-number bert
CE3接口视图
【缺省级别】
2:系统级
line-number :E1通道号,取值范围为1~28。
pattern:设置BERT测试模式,包括2^11、2^15、2^20、2^23和QRSS。
2^20:发送的码流长度为2的20次方个bit。
2^23:发送的码流长度为2的23次方个bit。
qrss:发送的码流长度为2的20次方个bit,且码流中不允许连续14个以上的0。
time number:设置BERT测试的持续时间,单位为分钟,取值范围为1~1440。
【描述】
e1 bert命令用来进行CE3接口下某E1通道的线路位(Bit)错误率的测试。undo e1 bert命令用来取消该测试。
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前E1通道支持2^11、2^15、2^20、2^23和QRSS这几种测试模式。
BERT测试方式如下:本端发出测试数据流,经过线路某处环回回来,检测收到的测试数据流与发出的测试数据流是否一致,位错误率达到多少,从而为用户判断线路状态提供依据。因此,要求线路中某处能环回发出的数据流,如将对端设置为远端环回等。
# 在E1通道1上执行QRSS格式的BERT测试10分钟。
[Sysname-E3 2/0/0] e1 1 bert pattern qrss time 10
e1 line-number channel-set set-number timeslot-list list
undo e1 line-number channel-set set-number
CE3接口视图
【缺省级别】
2:系统级
line-number:E1通道的顺序号,取值范围为1~16。
set-number:指定E1通道上时隙捆绑形成的channel set的编号,取值范围为0~30。
timeslot-list list:被捆绑的时隙。list为时隙编号,取值范围为1~31。在指定捆绑的时隙时,可以用number的形式指定单个时隙,也可以用number1-number2的形式指定一个范围内的时隙,还可以使用number1,number2-number3的形式,同时指定多个时隙。
【描述】
e1 channel-set命令用来对E1通道进行时隙捆绑。undo e1 channel-set命令用来取消时隙捆绑。
CE3接口支持通道化到E1,每个E1最多可捆绑出31个通道。
当E1通道工作在成帧方式(CE1方式)时,可以对其进行时隙捆绑。系统会自动创建一个Serial接口,编号为serial number /line-number:set-number,如E3 1/0的第一个e1的channel-group 0生成的串口为1/0/1:0。此接口的速率为N×64kbps,其逻辑特性与同步串口相同,可以视其为同步串口,进行进一步的配置。
相关配置可参考命令e1 unframed
# 在接口E3 2/0/0的第一个E1通道上捆绑出一个128kbps的串口。
[Sysname-E3 2/0/0] e1 1 channel-set 1 timeslot-list 1,2
1.6.9  e1 set clock
e1 line-number set clock { master | slave }
undo e1 line-number set clock
CE3接口视图
【缺省级别】
2:系统级
line-number:E1通道的编号,取值范围为1~16。
master:使用内部时钟模式。
slave:使用线路时钟模式。
【描述】
e1 set clock命令用来配置CE3接口下E1通道的时钟模式。undo e1 set clock命令用来恢复缺省情况。
缺省情况下,CE3接口下E1通道的时钟模式为线路时钟。
当CE3接口工作在通道化方式下,各个E1通道均能独立设置时钟。
# 设置E3接口下第一个E1通道的时钟为线路时钟模式。
[Sysname-E3 2/0/0] e1 1 set clock slave
e1 line-number set frame-format { crc4 | no-crc4 }
undo e1 line-number set frame-format
CE3接口视图
【缺省级别】
2:系统级
line-number:E1通道的顺序号取值范围为1~16。
crc4:E1通道的帧格式为crc4。
no-crc4:E1通道的帧格式为no-crc4。
【描述】
e1 set frame-format命令用来配置E1通道的帧格式。undo e1 set frame-format命令用来恢复缺省情况。
缺省情况下,E1通道的帧格式为no-crc4
只有当E1通道工作在成帧方式时(使用命令undo e1 unframed),才能配置本命令。
# 设置E3接口下第一个E1通道的帧格式为crc4。
[Sysname-E3 2/0/0] e1 1 set frame-format crc4
e1 line-number set loopback { local | payload | remote }
undo e1 line-number set loopback
CE3接口视图
【缺省级别】
2:系统级
local:允许E1通道对内自环。
payload:设置接口净荷环回。
remote:允许E1通道对外远端环回。
【描述】
e1 set loopback命令用来设置E3接口下E1子接口的自环方式。undo e1 set loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
如果E1通道的链路层协议为PPP,设置自环或环回后,链路层协议状态将上报为DOWN。这属于正常情况。
# 设置E3接口下第一个E1通道的自环方式为local
[Sysname-E3 2/0/0] e1 1 set loopback local
1.6.12  e1 shutdown
e1 line-number shutdown
undo e1 line-number shutdown
CE3接口视图
【缺省级别】
2:系统级
【描述】
e1 shutdown命令用来关闭CE3接口的某个E1通道。undo e1 shutdown命令用来恢复缺省情况。
缺省情况下,E1通道是打开的。
该命令对于E1通道及其捆绑出的串口均有效。对指定E1通道执行e1 shutdown操作后,该E1通道捆绑形成的串口将shutdown,停止收发数据。如果执行undo e1 shutdown操作,则所有该E1通道捆绑形成的串口将被重新启用。
# 关闭E3接口下第一个E1通道。
[Sysname-E3 2/0/0] e1 1 shutdown
1.6.13  e1 unframed
e1 line-number unframed
undo e1 line-number unframed
CE3接口视图
【缺省级别】
2:系统级
【描述】
e1 unframed命令用来配置CE3接口的E1通道工作在非成帧方式(E1方式)。undo e1 unframed命令用来恢复缺省情况。
缺省情况下,E1通道工作在成帧方式。
当E1配置成非成帧方式后,它将不包含帧控制信息,也不分时隙,不能进行时隙捆绑。此时,系统会自动创建一个Serial接口,编号为serial number/line-umber:0。此接口的速率为2048kbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 设置E3接口下第一个E1通道工作在非成帧方式。
[Sysname-E3 2/0/0] e1 1 unframed
1.6.14  fe3
fe3 { dsu-mode { 0 | 1 } | subrate number }
undo fe3 { dsu-mode | subrate }
CE3接口视图(FE3模式)
【缺省级别】
2:系统级
dsu-mode:设置FE3(Fractional E3)的DSU模式,支持常用的几家厂商的FE3 DSU模式,如下:
0:Digital Link,支持子速率范围为358~34010kbps,共95个速率等级,级差358kbps。
1:Kentrox,支持子速率范围为500~24500,34010kbps,共50个速率等级,级差500kbps。
subrate number:工作在FE3模式下的CE3接口的子速率。number的取值范围为1~34010,单位是kbps。
【描述】
fe3命令用于配置CE3接口工作在FE3模式,并配置DSU模式或子速率。undo fe3 命令用来恢复缺省情况。
缺省情况下,DSU模式为1,即Kentrox模式;子速率为34010kbps。
FE3(Fractional E3,或称Subrate E3)是E3的一种非标准应用模式。目前各厂商支持的速率等级均不一样,使用fe3命令可以使我们的设备和其他厂家设备的FE3 DSU模式兼容,实现互通。
l              该命令仅在支持FE3特性的CE3单板上有效,如CE3单板不支持FE3特性系统将提示该命令无效。
l              该命令仅能在E3模式下使用,在CE3模式下该命令不可见。
l              通过fe3 subrate设置的速率值是一个大概值。由于通过fe3 dsu-mode命令配置的各DSU的子速率值是离散的,因此,当再通过fe3 subrate命令指定子速率后,E3接口会根据当前配置的DSU模式计算出与这个指定子速率最匹配的精确速率(精确到bps),并设置硬件电路支持该速率。
l              通过display interface serial interface-number:0命令可以查看E3接口的DSU模式、子速率设置值、接口实际速率和接口的波特率。接口实际速率为不含开销在内的纯数据带宽,接口波特率(34368kbps)为E3线路的实际速率(含开销位在内)。
# 设置E3接口2/0工作在FE3模式,DSU模式为1,子速率为3000kbps。
[Sysname-E3 2/0/0] fe3 dsu-mode 1
[Sysname-E3 2/0/0] fe3 subrate 3000
undo loopback
CE3接口视图
【缺省级别】
2:系统级
local:允许CE3接口对内自环。
payload:允许CE3接口对外载荷环回。
remote:允许CE3接口对外远端环回。
【描述】
loopback命令用来配置CE3接口的自环方式。undo loopback命令用来恢复缺省情况。
缺省情况下,禁止环回检测功能。
只有在进行某些特殊功能测试时,才需要将CE3接口设为自环。
如果将CE3接口的链路层协议配置为PPP,设置环回后,链路层协议状态将上报为Down,这属于正常情况。
# 允许接口E3 2/0/0对内自环。
[Sysname-E3 2/0/0] loopback local
1.6.16  national-bit
national-bit { 0 | 1 }
undo national-bit
CE3接口视图
【缺省级别】
2:系统级
0:配置CE3接口的National bit 为0。表明这个接口只能进行国内通信。
1:配置CE3接口的National bit 为1。表明这个接口只能进行国际通信。
【描述】
national-bit命令用来配置CE3接口的National bit位。undo national-bit命令用来恢复缺省情况。
缺省情况下,CE3接口的National bit 为1。
只有在某些特殊情况下,才需要将E3 接口的National bit设为0。
相关配置可参考命令controller e3
# 设置接口E3 2/0/0的national-bit位为0。
[Sysname-E3 2/0/0] national-bit 0
reset counters controller e3 interface-number
【缺省级别】
2:系统级
【描述】
reset counters controller e3命令用来清除CE3接口的controller计数器。controller计数器值可以用display controller e3命令来查看。
单独清除CE3接口的controller计数器只能使用reset counters controller e3命令,不能使用reset counters interface命令,该命令会清除所有接口的计数器。
# 清除CE3接口2/0的controller计数器。
<Sysname> reset counters controller e3 2/0/0
shutdown
CE3接口视图
【缺省级别】
2:系统级
【描述】
shutdown命令用来关闭CE3接口。undo shutdown命令用来打开CE3接口。
缺省情况下,CE3接口为打开状态。
# 关闭接口E3 2/0/0。
[Sysname-E3 2/0/0] shutdown
using { ce3 | e3 }
undo using
CE3接口视图
【缺省级别】
2:系统级
ce3:设置CE3接口工作在通道化模式。
e3:设置CE3接口工作在非通道化模式。
【描述】
using命令用来配置CE3接口的工作模式。undo using命令用来恢复缺省情况。
缺省情况下,CE3接口工作在通道化模式。
只有当CE3接口工作在通道化模式时,才能够对E1通道进行配置。
当CE3接口工作在非通道化模式时,系统会自动创建一个Serial接口,编号为serial number/0:0。此接口的速率为34.368Mbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 配置接口E3 2/0/0工作在非通道化模式。
1.7  CT3接口基本配置命令
alarm { detect | generate { ais | febe | idle | rai } }
undo alarm { detect | generate { ais | febe | idle | rai } }
CT3接口视图
【缺省级别】
2:系统级
detect:打开或关闭CT3接口的定时检测各种告警的功能,缺省情况下,检测功能处于打开状态。
generate:发送某种告警信号,如AIS、RAI、IDLE和FEBE。可用于线路状态测试,缺省情况下,不发送告警信号。
ais:Alarm Indication Signal,即告警指示信号。
febe:Far End Block Error,即远端块错误。
idle:空闲信号。
【描述】
alarm命令用来配置CT3接口的告警信号检测与发送功能。用户可打开或关闭告警信号的检测开关,也可发送某种告警信号以测试线路状态等。undo alarm命令用于取消各设置。
上电后,CT3接口的告警信号定时检测功能是打开的,并能通过接口显示实时报告接口告警状态,如LOS、LOF、AIS、RAI等。当检测到LOS、LOF或AIS后,会向对方发送RAI告警信号。
主要的告警信号包括:LOS为Loss Of Signal,即信号丢失;LOF为Loss Of Frame,即帧同步丢失;AIS为Alarm Indication Signal,即告警指示信号;RAI为Remote Alarm Indication,即远端告警指示信号;FEBE为Far End Block Error,即远端块错误;IDLE为空闲信号。各信号具体格式遵循T3规范ANSI T1.107-1995。
接口一次只能发送一种告警信号(包括在使用detect功能时检测到LOS、LOF或AIS后而产生的RAI告警信号),发送另一种告警信号前必须使用undo alarm命令取消前一种告警信号。detect功能产生的告警信号(RAI)必须通过undo alarm detect命令取消。
告警的收发状态详见CT3接口显示部分。
# 打开CT3接口2/0/0的告警检测功能。
[Sysname] controller t3 2/0/0
[Sysname-T3 2/0/0] alarm detect
# 在CT3接口2/0/0上发送AIS告警信号。
[Sysname-T3 2/0/0] alarm generate ais
undo bert
CT3接口视图
【缺省级别】
2:系统级
【描述】
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前CT3接口支持2^7,2^11,2^15和QRSS这几种测试模式。
利用bert命令配置好测试模式,指定测试持续时间,开始测试后,可以查看接口状态中的BERT测试状态和测试结果。BERT测试状态和测试结果的说明详见CT3接口显示部分。
# 在CT3接口2/0/0上执行QRSS格式的BERT测试10分钟。
[Sysname-T3 2/0/0] bert pattern qrss time 10
1.7.3  cable (CT3 interface)
cable feet
undo cable
CT3接口视图
【缺省级别】
2:系统级
feet:电缆长度,取值范围为0~450,单位为英尺(feet)。
【描述】
cable命令用来配置CT3接口所连接电缆的长度。undo cable命令用来恢复缺省情况。
缺省情况下,CT3接口所连接电缆的长度的值为49英尺。
CT3接口所连接电缆的长度是指从路由器到配线架之间电缆的长度。
# 设置接口T3 2/0/0的电缆长度为50英尺。
[Sysname-T3 2/0/0] cable 50
1.7.4  clock (CT3 interface)
undo clock
CT3接口视图
【缺省级别】
2:系统级
master:使用内部时钟模式。
slave:使用线路时钟模式。
【描述】
clock命令用来配置CT3接口的时钟模式。undo clock命令用来恢复缺省情况。
缺省情况下,CT3接口的时钟模式为线路时钟。
使用内部时钟还是线路时钟主要根据所连接的对端设备而定,如果与传输设备相连,本端通常设置为使用线路时钟。
如果是两台路由器的CT3接口直接相连,则应该把一端路由器时钟设置为内部时钟模式,另一端路由器时钟设置为线路时钟模式。
# 设置CT3接口的时钟为内部时钟模式。
[Sysname-T3 2/0/0] clock master
1.7.5  controller t3
controller t3 interface-number
【缺省级别】
2:系统级
interface-number:CT3接口的编号。
【描述】
controller t3命令用来进入CT3接口视图。
相关配置可参考命令display controller t3
# 进入接口T3 2/0/0的视图。
[Sysname-T3 2/0/0]
1.7.6  crc
undo crc
同步串口视图
【缺省级别】
2:系统级
16:使用16位CRC校验。
32:使用32位CRC校验。
none:不使用CRC校验。
【描述】
crc命令用来配置CT3接口通过各种方式形成的同步串口的CRC校验模式。undo crc命令用来恢复缺省情况。
缺省情况下,使用16位CRC校验。
相关配置可参考命令t1 channel-sett1 unframedusing
# 设置T3接口2/0/0在非通道化模式下形成的同步串口使用32位CRC校验。
[Sysname-T3 2/0/0] using t3
[Sysname-T3 2/0/0] quit
# 设置CT3接口2/0/0在通道化模式下形成的同步串口使用16CRC校验。
[Sysname-T3 2/0/0] t1 2 channel-set 4 timeslot-list 5-11
[Sysname] interface serial 2/0/0/2:4
[Sysname-Serial2/0/0/2:4] crc 16
1.7.7  description (CT3 interface)
CT3接口视图
【缺省级别】
2:系统级
【描述】
description命令用来配置CT3接口的描述字符串。undo description命令用来恢复缺省情况。
缺省情况下,CT3接口的描述字符串为“该接口的接口名 Interface”,比如:T3 2/0/0 Interface。
# 配置接口T3 2/0/0的描述字符串为“T3-interface”。
[Sysname-T3 2/0/0] description T3-interface
1.7.8  display controller t3
display controller t3 [ interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display controller t3命令用来查看CT3接口的状态信息。
本命令可以显示CT3接口的状态信息,同时还可以显示CT3接口工作在CT3模式时每个T1通道的相关信息。
# 显示接口T3 2/0/0的相关信息。
<Sysname> display controller t3 2/0/0
T3 2/0/0 current state :UP
Description : T3 2/0/0 Interface
sic Configuration:
  Work mode is CT3, cable length is 49 feet.
  Frame-format is C-BIT Parity, line code is B3ZS.
  Source clock is slave, loopback is not set.
Alarm state:
  Receiver alarm state is none.
MDL state:
  No message is sent now.
  Message data elements:
    EIC: line, LIC: line, FIC: line, UNIT: line
    FI: line, PORT_NO: line, GEN_NO: line
  Periodical detection is disabled.
FEAC state:
  No code is sent now.
  Periodical detection is enabled, no code received now.
  Test pattern: 2^7, Status: Not Sync, Sync Detected: 0
    Bit errors (since test started): 0 bits
    Bits received (since test started): 0 Mbits
    Bit errors (since latest sync): 0 bits
    Bits received (since latest sync): 0 Mbits
Last clearing of counters: 14:39:02 UTC Sat 06/25/2005
  Data in current interval (22 seconds elapsed):
    0 Line Code Violations, 0 Far End Block Error
    0 C-Bit Coding Violation, 0 P-bit Coding Violation
    0 Framing Bit Err, 0 Severely Err Framing Secs
    0 C-bit Err Secs, 0 C-bit Severely Err Secs
    0 P-bit Err Secs, 0 P-bit Severely Err Secs
    0 Unavailable Secs, 0 Line Err Secs
T3 2/0/0  CT1 1 is up
  Frame-format ESF, clock slave, loopback not set
  FDL Performance Report is disabled
  Transmitter is sending none
  Line loop back deactivate code using inband signal last sent
    Test pattern: 2^11, Status: Not Sync, Sync Detected: 0
    Bits received (since test started): 0 Kbits
    Bits received (since latest sync): 0 Kbits
表1-8 display controller t3命令显示信息解释
接口的物理up/down状态
接口描述信息
Basic Configuration
接口基本配置信息
工作模式为通道化T3,线缆长度49feet;
工作模式包括通道化(CT3)和非通道化(T3)
帧格式为C-bit,线路编码为B3ZS;
帧格式包括C-bit和M23
时钟源为从模式,未设置环回。
时钟源包括master和slave两种模式,环回包括local、remote和payload三种
Alarm state
告警状态
显示接口收到的告警类别,包括:LOS、LOF、AIS、RAI。
当收到LOS、LOF、AIS之一时,向对方发送RAI,显示:Transmitter is sending RAI
MDL state:
MDL状态
当前没有发送MDL消息。
发送MDL消息(如path和idle-signal)时,显示如下:
Message sent now: path. idle signal
MDL数据元素
EIC、LIC、FIC和UNIT为四种MDL消息的公共元素,用户可设置
FI、PORT_NO和GEN_NO分别为消息path、idle-signal和test-signal的私有元素,用户可设置
MDL周期性检测被禁止。上电后默认为禁止。
当该检测功能被使能时,显示:
Periodical detection is enabled.
No message was received.
当检测到MDL消息时显示如:
Message received now: path.idle signal.
    path/FI: line
    idle Signal/PORT_NO: line
FEAC state:
FEAC状态
No code is sent now. DS3 Line Loop Back Deactivate was last sent.
当前没有FEAC信号发出,上次发出的FEAC信号为DS3 Line Loop Back Deactivate
FEAC周期性检测功能被使能。上电后默认使能。
当前未收到FEAC信号
DS3 Line Loop Back Deactivate last received.
上次收到的FEAC信号为DS3 Line Loop Back Deactivate
BERT状态(停止)
根据用户进行BERT操作的情况,有三种状态:
running-BERT测试正在进行;
complete-BERT测试自然完成(即达到测试时间);
stopped-BERT测试被提前中止
BERT测试模式,包括2^7、2^11、2^15以及QRSS等。
同步状态:是否同步。
子测试开始后检测到的同步次数
总的测试时间、已经完成的测试时间
自测试开始后收到的错误比特数
自测试开始后收到的总比特数
自上一次同步以来收到的错误比特数
自上一次同步以来收到的总比特数
历史统计数据
上次清0时间
从未清零显示Never,否则显示时间如:
当前interval(15分钟为一个interval)内的各项错误计数(已过去的时间为22秒)
线路信号错误数,包括:BPV错误、EXZ错误
Far End Block Error
远端块错误数
C-Bit Coding violation
C比特错误数
P比特错误数
Framing Bit Err
帧比特错误数
帧比特严重错误的秒数
C-bit Err Secs
C比特错误的秒数
C比特严重错误的秒数,指1秒内C比特错误数超过44的秒
P-bit Err Secs
P比特错误的秒数
P特严重错误的秒数,指1秒内P比特错误数超过44的秒
Unavailable Secs
服务无法获取的秒数
Line Err Secs
线路错误的秒数,包括:LOS、BPV、EXZ、C比特错误、P比特错误等
Data in Interval 1:
Interval 1内的数据
Total Data (last 17 15 minute intervals):
总的数据(前17个interval)
CT3接口下T1通道1的up/down状态
T1通道的帧格式,包括ESF和SF
时钟方式包括slave和master,环回包括local、remote和payload
禁止用FDL链路传输性能报告信息(PPR),可用fdl ansi命令使能
T1通道发送器在发送RAI。当收到LOS、LOF或AIS时,发RAI
Receiver alarm state is LOF
T1通道接收到的告警状态,包括:LOS、LOF、AIS和RAI
Line loop back activate code using inband signal last sent
上次发送的环回码:Line loop back activate code using inband signal
BERT测试状态。包括running、complete和stopped
测试模式、同步状态、检测到的同步次数
总测试时间、已经过去的测试时间
测试以来收到的错误比特数
测试以来收到的总比特数
上次同步以来收到的错误比特数
上次同步以来收到的总比特数
1.7.9  feac
feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
undo feac { detect | generate { ds3-los | ds3-ais | ds3-oof | ds3-idle | ds3-eqptfail | loopback { ds3-line | ds3-payload } } }
CT3接口视图
【缺省级别】
2:系统级
detect:打开CT3接口上的定时检测FEAC链路信号功能,缺省情况下,定时检测FEAC链路信号功能处于打开状态。
generate:发送FEAC信号,包括ds3-losds3-aisds3-oofds3-idleds3-eqptfail。缺省情况下,不发送FEAC信号。
loopback:发送环回码,用于激活对端的线路环回(ds3-line)或者净荷环回(ds3-payload)。缺省情况下,不发送环回码。
【描述】
feac命令用来配置CT3接口的FEAC链路信号的检测和传输功能。undo feac命令用来取消已有的FEAC配置。
FEAC是远端告警与控制信号(Far End Alarm and Control signal),是利用C-bit帧格式中第一个子帧中的第三个C比特组成的一条数据链路,可用于传输各种告警状态信号,也可用于传输环回控制码,用来激活或者取消对端的环回,进行环回测试。ANSI T1.107a中规定,FEAC可用于传输多种告警信号(本命令中实现如上几种,多用于线路测试),并规定这条链路的数据帧为基于位的BOP(Bit Oriented Protocol)协议格式。
上电后,CT3接口的FEAC定时检测功能是打开的,但不发送任何FEAC信号。
当用feac generate loopback { ds3-line | ds3-payload }激活对端环回后,可用undo feac generate loopback { ds3-line | ds3-payload }取消对端环回。
需要注意的是,当利用该命令配置远端环回前,最好禁止本端的FEAC检测,以免发出的环回码在对方配好环回后被返回来,造成本端也配置为环回,引起线路上的环路死锁。
FEAC链路的收发状态的说明详见CT3接口显示部分。
# 打开CT3接口2/0/0的FEAC链路数据检测功能。
[Sysname-T3 2/0/0] feac detect
# 在CT3接口2/0/0上发送ds3-los信号。
[Sysname-T3 2/0/0] feac generate ds3-los
# 在CT3接口2/0/0上发送环回码给对端,设置对端为线路环回。
[Sysname-T3 2/0/0] feac generate loopback ds3-line
1.7.10  frame-format (CT3 interface)
frame-format { c-bit | m23 }
undo frame-format
CT3接口视图
【缺省级别】
2:系统级
c-bit:设置帧格式为C-bit
m23:设置帧格式为m23
【描述】
frame-format命令用来配置CT3接口所使用的帧格式。undo frame-format命令用来恢复CT3接口帧格式的缺省值。
缺省情况下,CT3接口的帧格式为c-bit
# 设置接口T3 2/0/0的帧格式为m23
[Sysname-T3 2/0/0] frame-format m23
1.7.11  ft3
ft3 { dsu-mode { 0 | 1 | 2 | 3 | 4 } | subrate number }
undo ft3 { dsu-mode | subrate }
CT3接口视图(FT3模式)
【缺省级别】
2:系统级
dsu-mode:设置FT3(Fractional T3)的DSU模式,支持常用的几家厂商的FT3 DSU模式,如下:
0:Digital Link,支持子速率范围为300~44210kbps,共147个速率等级,级差300746bps。
1:Kentrox,支持子速率范围为1500~35000kbps及44210kbps,共57个速率等级,级差1500000bps。
2:Larscom,支持子速率范围为3100~44210kbps,共14个速率等级,级差3157835bps。
3:Adtran,支持子速率范围为75~44210kbps,共588个速率等级,级差75187bps。
4:Verilink,支持子速率范围为1500~44210kbps,共20个速率等级,级差1578918bps。
subrate number:工作在FT3模式下的CT3接口的子速率。number的取值范围为1~44210,单位是kbps。
【描述】
ft3命令用于配置CT3接口工作在FT3模式,并配置DSU模式或子速率。undo ft3 命令用来恢复缺省情况。
缺省情况下,DSU模式为0,即Digital Link模式;子速率为44210kbps。
FT3(Fractional T3,或称Subrate T3)是T3的一种非标准应用模式。目前各厂商支持的速率等级均不一样,使用ft3命令可以使我们的设备和其他厂家设备的FT3 DSU模式兼容,实现互通。
l              该命令仅在支持FT3特性的CT3单板上有效,如CT3单板不支持FT3特性系统将提示该命令无效。
l              该命令仅能在T3模式下使用,在CT3模式下该命令不可见。
l              通过ft3 subrate设置的速率值是一个大概值。由于通过ft3 dsu-mode命令配置的各DSU的子速率值是离散的,因此,当再通过ft3 subrate命令指定子速率后,T3接口会根据当前配置的DSU模式计算出与这个指定子速率最匹配的精确速率(精确到bps),并设置硬件电路支持该速率。
l              通过display interface serial interface-number:0命令可以查看T3接口的DSU模式、子速率设置值、接口实际速率和接口的波特率。接口实际速率为不含开销在内的纯数据带宽,接口波特率(44736kbps)为T3线路的实际速率(含开销位在内)。
# 设置T3接口2/0/0工作在FT3模式,DSU模式为1,子速率为3000kbps。
[Sysname-T3 2/0/0] ft3 dsu-mode 1
[Sysname-T3 2/0/0] ft3 subrate 3000
1.7.12  loopback (CT3 interface)
undo loopback
CT3接口视图
【缺省级别】
2:系统级
local:允许CT3接口对内自环。
payload:允许CT3接口对外载荷环回。
remote:允许CT3接口对外远端环回。
【描述】
loopback命令用来配置CT3接口的使能环回检测功能并设置检测方式。undo loopback命令用来禁止CT3接口的环回检测功能。
CT3接口两种对外环回的区别在于:对外载荷环回(payload)需要处理帧头开销,而对外远端环回(remote)则不对帧进行处理。
缺省情况下,环回检测功能是禁止的。
环回功能通常用于进行某些特殊测试,正常工作时,不要启动环回。
如果将CT3接口的链路层协议配置为PPP,设置环回后,链路层协议状态将上报为down,这属于正常情况。
# 允许接口T3 2/0/0对内自环。
[Sysname-T3 2/0/0] loopback local
1.7.13  mdl (CT3 interface)
mdl { data { eic string | fic string | gen-no string | lic string | pfi string | port-no string | unit string } | detect | generate { idle-signal | path | test-signal } }
undo mdl [ data [ eic | fic | gen-no | lic | pfi | port-no | unit ] | detect | generate [ idle-signal |  path | test-signal ] ]
CT3接口视图
【缺省级别】
2:系统级
detect:打开CT3接口上的定时检测MDL消息功能。
data:设置MDL消息参数,其中eic、lic、fic和unit为三类MDL消息的公有参数,pfi、port-no和gen-no分别为消息path、idle signal和test signal的私有参数。这些参数为用户可定义的字符串,长度各有限制。
eic string:Equipment ID,为1~10个字符的字符串,缺省值为line。
fic string:Frame ID,为1~10个字符的字符串,缺省值为line。
gen-no string:Generator number in test signal message,test signal消息的私有参数,为1~38个字符的字符串,缺省值为line。
lic string:Location ID,为1~11个字符的字符串,缺省值为line。
pfi string:Facility ID in path message,path消息的私有参数,为1~38个字符的字符串,缺省值为line。
port-no string:Port number in idle signal message,idle signal消息的私有参数,为1~38个字符的字符串,缺省值为line。
unit string:Unit,为1~6个字符的字符串,缺省值为line。
generate:按照data中配置的参数定时发送MDL消息,包括path、idle signal和test signal,可以同时发送。
【描述】
mdl命令用来配置CT3接口的MDL链路消息检测与传输功能。undo mdl命令用来取消已有的MDL配置,undo mdl data { eic | lic | fic | unit | pfi | port-no | gen-no }用来恢复各字符串的缺省值。
MDL是维护数据链路(Maintenance Data Link),是利用C-bit帧格式中第五个子帧中的3个C比特组成的一条数据链路,可用于传输一些维护性的消息。ANSI T1.107a中规定,MDL可用于传输三种消息:path、idle signal和test signal,并规定这条链路的数据帧为LAPD协议格式。
MDL链路的收发状态详见CT3接口显示部分。
上电后,CT3接口的MDL定时检测功能是禁止的,消息参数为缺省值,不发送任何消息。
# 打开CT3接口2/0/0的MDL检测功能。
[Sysname-T3 2/0/0] mdl detect
# 配置CT3接口2/0/0的MDL的lic参数为字符串“hello”。
[Sysname-T3 2/0/0] mdl data lic hello
# 设置CT3接口2/0/0发送path消息。
[Sysname-T3 2/0/0] mdl generate path
1.7.14  reset counters controller t3
reset counters controller t3 interface-number
【缺省级别】
2:系统级
【描述】
reset counters controller t3命令用来清除CT3接口的controller计数器。controller计数器值可以用display controller t3命令来查看。
单独清除CT3接口的controller计数器只能使用reset counters controller t3命令,不能使用reset counters interface命令,该命令会清除所有接口的计数器。
# 清除CT3接口2/0/0的controller计数器。
<Sysname> reset counters controller t3 2/0/0
1.7.15  shutdown (CT3 interface)
shutdown
CT3接口视图
【缺省级别】
2:系统级
【描述】
shutdown命令用来关闭CT3接口。undo shutdown命令用来打开CT3接口。
缺省情况下,CT3接口为打开状态。
# 关闭接口T3 2/0/0。
[Sysname-T3 2/0/0] shutdown
1.7.16  t1 alarm
t1 line-number alarm { detect | generate { ais | rai } }
undo t1 line-number alarm { detect | generate { ais | rai } }
CT3接口视图
【缺省级别】
2:系统级
detect:打开CT3接口下某个T1通道的告警信号检测功能。
line-number:T1通道号,取值范围为1~28。
generate:发送某种告警信号,如AIS、RAI。可用于线路状态测试,缺省情况下,不发送告警信号。
【描述】
t1 alarm命令用来配置CT3接口下某个T1通道的告警信号检测与发送功能。用户可以打开告警信号的检测开关,也可发送某种告警信号以测试线路状态等。undo t1 alarm命令用于取消各设置。
上电后,CT3接口下各T1通道的告警信号定时检测功能是打开的,并能通过接口显示实时报告接口告警状态,如LOS、LOF、AIS、RAI等。当检测到LOS、LOF或AIS后,会向对方发送RAI告警信号。
主要的告警信号包括:LOS为Loss Of Signal,即信号丢失;LOF为Loss Of Frame,即帧同步丢失;AIS为Alarm Indication Signal,即告警指示信号;RAI为Remote Alarm Indication,即远端告警指示信号。各信号具体格式遵循T1规范ANSI T1.403。
一次只能发送一种告警信号(包括在使用detect功能时检测到LOS、LOF或AIS后而产生的RAI告警信号),发送另一种告警信号前必须使用undo t1 alarm命令取消前一种告警信号。detect功能产生的告警信号(RAI)必须通过undo t1 alarm detect命令取消。
告警的收发状态详见CT3接口显示部分。
# 打开CT3接口2/0/0的T1通道1的告警检测功能。
[Sysname-T3 2/0/0] t1 1 alarm detect
# 在CT3接口2/0/0的T1通道1上发送AIS告警信号。
[Sysname-T3 2/0/0] t1 1 alarm generate ais
1.7.17  t1 bert
t1 line-number bert pattern { 2^11 | 2^15 | 2^20 | 2^23 | qrss } time number [ unframed ]
undo t1 line-number bert
CT3接口视图
【缺省级别】
2:系统级
line-number :T1通道号,取值范围为1~28。
【描述】
t1 bert命令用来进行CT3接口下某T1通道的线路位(Bit)错误率的测试。undo t1 bert命令用来取消该测试。
缺省情况下,不进行线路位错误率的测试。
ITU O.151、ITU O.153及ANSI T1.403-1999定义了各种BERT测试模式,目前T1通道支持2^11、2^15、2^20、2^23和QRSS这几种测试模式。
# 在T1通道1上执行QRSS格式的BERT测试10分钟。
[Sysname-T3 2/0/0] t1 1 bert pattern qrss time 10
1.7.18  t1 channel-set
t1 line-number channel-set set-number timeslot-list list [ speed { 56k | 64k } ]
undo t1 line-number channel-set set-number
CT3接口视图
【缺省级别】
2:系统级
line-number:T1通道的顺序号,取值范围为1~28。
set-number:指定T1通道上时隙捆绑形成的channel set的编号,取值范围为0~23。
speed:配置时隙捆绑的方式。选用参数56k时,捆绑方式为N×56kbps;选用参数64k时,捆绑方式为N×64kbps。缺省情况下,speed的取值为64k。
【描述】
t1 channel-set命令用来对T1通道进行时隙捆绑。undo t1 channel-set命令用来取消时隙捆绑。
当T1通道工作在成帧方式(CT1方式)时,可以对其进行时隙捆绑。系统会自动创建一个Serial接口,编号为serial number/ line-number:set-number。此接口的速率为N×64kbps(或N×56kbps),其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
相关配置可参考命令t1 unframed
# 在T3 2/0/0接口的第一个T1通道上捆绑出一个128kbps的串口。
[Sysname-T3 2/0/0] t1 1 channel-set 1 timeslot-list 1,2
1.7.19  t1 sendloopcode
t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
undo t1 line-number sendloopcode { fdl-ansi-line-up | fdl-ansi-payload-up | fdl-att-payload-up | inband-line-up }
CT3接口视图
【缺省级别】
2:系统级
fdl-ansi-line-up:发送FDL承载的符合ANSI规范的线路环回激活码,启动远端环回。
fdl-ansi-payload-up:发送FDL承载的符合ANSI规范的净荷环回激活码,启动远端环回。
fdl-att-payload-up发送FDL承载的符合AT&T规范的净荷环回激活码,启动远端环回。
inband-line-up:发送符合ANSI规范和AT&T规范的带内线路环回激活码,启动远端环回。
【描述】
t1 sendloopcode命令用来设置对端CT3接口的某个T1通道的环回模式。undo t1 sendloopcode命令用来取消对应的配置。
环回测试是一种有效的问题诊断方法。除了在远端设备上通过命令行配置环回外,还可发送环回控制码,设置远端设备的环回。ANSI T1.403规范定义了T1接口下的环回控制码类型和格式。按照环回类型,可分为line环回(数据流不经过成帧器)和payload环回(数据流经过成帧器)两种;按照传输环回控制码的载体,可分为利用inband信号(即T1的192位有效数据带宽或193位全部带宽)和利用ESF帧格式中的FDL链路两种。
# 在CT3接口2/0/0发送inband信号,配置对端CT3接口的T1通道1为line环回。
[Sysname-T3 2/0/0] t1 1 sendloopcode inband-line-up
1.7.20  t1 set clock
t1 line-number set clock { master | slave }
undo t1 line-number set clock
CT3接口视图
【缺省级别】
2:系统级
master:设置T1通道使用内部时钟。
slave设置T1通道使用线路时钟。
【描述】
t1 set clock命令用来配置CT3接口下T1通道的时钟模式。undo t1 set clock命令用来恢复缺省设置。
缺省情况下,CT3接口下T1通道的时钟模式为线路时钟。
当CT3接口工作在通道化工作方式下,各个T1通道均能独立设置时钟。
# 设置T3接口下第一个T1通道的时钟为线路时钟模式。
[Sysname-T3 2/0/0] t1 1 set clock slave
1.7.21  t1 set frame-format
t1 line-number set frame-format { esf | sf }
undo t1 line-number set frame-format
CT3接口视图
【缺省级别】
2:系统级
line-numbe:T1通道号,取值范围为1~28。
esf:设置T1通道使用扩展超帧(Extended Super Frame)格式。
sf:设置T1通道使用超帧(Super Frame)格式。
【描述】
t1 set frame-format命令用来配置T1通道的帧格式。undo t1 set frame-format命令用来恢复缺省情况。
缺省情况下,T1通道的帧格式为esf
只有当T1通道工作在成帧方式时(使用命令undo t1 unframed),才能配置本命令。
# 设置T3接口下第一个T1通道的帧格式为sf。
[Sysname-T3 2/0/0] t1 1 set frame-format sf
1.7.22  t1 set loopback
t1 line-number set loopback { local | remote | payload }
undo t1 line-number set loopback
CT3接口视图
【缺省级别】
2:系统级
local:设置T1通道进行对内自环。
remote:设置T1通道进行对外远端环回。
payload:设置T1通道进行净荷环回。
【描述】
t1 set loopback命令用来设置T3接口下T1子接口的自环方式。undo t1 set loopback命令用来禁止T1自环。
缺省情况下,禁止T1自环。
如果T1通道的链路层协议为PPP,设置自环或远端环回后,链路层协议状态将上报为DOWN,这属于正常情况。
环回功能通常用于进行某些特殊测试,正常工作时不要启动环回。
# 设置T3接口下第一个T1通道的自环方式为local
[Sysname-T3 2/0/0] t1 1 set loopback local
1.7.23  t1 set fdl
t1 line-number set fdl { ansi | att | both | none }
undo t1 line-number set fdl
CT3接口视图
【缺省级别】
2:系统级
fdl:设置T1通道的FDL链路格式。
ansi:设置T1通道的FDL链路格式为ANSI T1.403规范所定义。
att设置T1通道的FDL链路格式为AT&T TR 54016 规范所定义。
none禁止T1通道FDL的使用。
【描述】
t1 set fdl命令用来设置CT3接口下T1通道的FDL链路格式。undo t1 set fdl命令用来取消T1通道的FDL链路传输。
缺省情况下,FDL为禁止状态。
FDL是T1的ESF帧格式中的一条4kbps的数据链路,可用于传输PPR(Periodical Performance Report)数据,也可传输环回控制码,配置远端环回。ANSI T1.403规范定义,PPR数据格式为LAPD协议格式,环回控制码格式为BOP(Bit Oriented Protocol)协议格式。这里的t1 set fdl命令仅用于启动PPR数据传输,对环回码的发送和检测没有影响,即收发环回码无需配置fdl。
需要注意的是:只有在CT3接口下的T1通道工作在通道化模式下,且T1帧格式为ESF时候,该配置才有效。
# 设置CT3接口2/0/0的T1通道1的FDL格式为ansi
[Sysname-T3 2/0/0] t1 1 set fdl ansi
1.7.24  t1 show
t1 line-number show
CT3接口视图
【缺省级别】
2:系统级
show:显示T1通道物理线路状态。
【描述】
t1 show命令用来快捷显示CT3接口下某个T1通道线路状态。
# 显示T1通道1的线路状态。
[Sysname] interface t3 2/0/0
[Sysname-T3 2/0/0] t1 1 show
表1-9 t1 show命令显示信息解释
T1通道的帧格式,包括ESF和SF
禁止用FDL链路传输性能报告信息(PPR),可用t1 set fdl ansi命令使能
T1通道接收到的告警,包括:LOS、LOF、AIS和RAI
BERT测试状态。包括running、complete和stopped(not completed)
测试模式、同步状态、检测到的同步次数
总测试时间、已经过去的测试时间
测试以来收到的错误比特数
测试以来收到的总比特数
上次同步以来收到的错误比特数
上次同步以来收到的总比特数
1.7.25  t1 shutdown
t1 line-number shutdown
undo t1 line-number shutdown
CT3接口视图
【缺省级别】
2:系统级
【描述】
t1 shutdown命令用来关闭CT3接口的某个T1通道。undo t1 shutdown命令用来打开T1通道。
缺省情况下,T1通道是打开的。
该命令对于T1通道及其捆绑出的串口均有效。对指定T1通道执t1 shutdown操作后,该T1通道捆绑形成的串口将shutdown,停止收发数据。如果执行undo t1 shutdown操作,则所有该T1通道捆绑形成的串口将被重新启用。
# 关闭T3接口下第一个T1通道。
[Sysname-T3 2/0/0] t1 1 shutdown
1.7.26  t1 unframed
t1 line-number unframed
undo t1 line-number unframed
CT3接口视图
【缺省级别】
2:系统级
【描述】
t1 unframed命令用来配置CT3接口的T1通道工作在非成帧方式(T1方式)。undo t1 unframed命令用来配置CT3接口的T1通道工作在成帧方式(CT1方式)。
缺省情况下,T1通道工作在成帧方式。
当T1配置成非成帧方式后,它将不包含帧控制信息,也不分时隙,不能进行时隙捆绑。此时,系统会自动创建一个Serial接口,编号为serial number/line-umber:0。此接口的速率为1544kbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 设置T3接口下第一个T1通道工作在非成帧方式。
[Sysname-T3 2/0/0] t1 1 unframed
1.7.27  using (CT3 interface)
using { ct3 | t3 }
undo using
CT3接口视图
【缺省级别】
2:系统级
ct3:设置CT3接口工作在通道化模式。
t3:设置CT3接口工作在非通道化模式。
【描述】
using命令用来配置CT3接口的工作模式。undo using命令用来恢复缺省情况。
缺省情况下,CT3接口工作在通道化模式。
只有当CT3接口工作在通道化模式时,才能够对T1通道进行配置。
当CT3接口工作在非通道化模式时,系统会自动创建一个Serial接口,编号为serial number/0:0。此接口的速率为44.736Mbps,其逻辑特性与同步串口相同,可以视其为同步串口进行进一步的配置。
# 配置接口T3 2/0/0工作在非通道化模式。
