10-IPv6 NetStream命令
本章节下载 (174 KB)
1.1.1 display ipv6 netstream cache
1.1.2 display ipv6 netstream export
1.1.3 display ipv6 netstream template
1.1.6 ipv6 netstream aggregation
1.1.7 ipv6 netstream export rate
1.1.8 ipv6 netstream export host
1.1.9 ipv6 netstream export source
1.1.10 ipv6 netstream export v9-template refresh-rate packet
1.1.11 ipv6 netstream export v9-template refresh-rate time
1.1.12 ipv6 netstream export version 9
1.1.13 ipv6 netstream max-entry
1.1.14 ipv6 netstream timeout active
1.1.15 ipv6 netstream timeout inactive
1.1.16 reset ipv6 netstream statistics
集中式设备:
display ipv6 netstream cache [ verbose ]
分布式设备:
display ipv6 netstream cache [ verbose ] [ slot slot-number ]
【缺省级别】
1:监控级
verbose:显示IPv6 NetStream流缓冲区的详细信息。
slot slot-number:查看指定单板上的IPv6 NetStream流缓冲区信息。slot-number表示单板的槽位号。如果不指定该参数,则显示当前所有IPv6 NetStream流缓冲区信息。
【描述】
display ipv6 netstream cache命令用来查看IPv6 NetStream流缓存区的配置和状态信息。
# 集中式路由器上查看IPv6 NetStream流缓冲区信息。
<Sysname> display ipv6 netstream cache verbose
IPv6 netstream cache information:
Stream active timeout (in minutes) : 30
Stream inactive timeout (in seconds): 30
Stream max entry number : 620000
IPv6 active stream entry number : 0
MPLS active stream entry number : 1000
IPv6 stream entry been counted : 0
MPLS stream entry been counted : 0
Last statistics reset time : Never
IPv6 packet size distribution (814306 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
.000 .000 .000 .000 1.00 .000 .000 .000 .000 .000 .000 .000
Protocol Total Packets Stream Packets Active(sec) Idle(sec)
Streams /Sec /Sec /stream /stream /stream
Type DstIP(Port) SrcIP(Port) Pro TC FlowLbl If(Direc) Pkts
DstMAC(VLAN) SrcMAC(VLAN)
TopLblType(IP/MASK)Lbl-Exp-S-List
IP& 30::2(1025) 20::CD(1000) 6 0 0x0 RAGG1.1(I) 824
MPLS BGP(0.48.0.0/0) 1:1028-0-1
TcpFlag: 16
DstMask: 64 SrcMask: 64
DstAS: 0 SrcAS: 0
Nexthop: 30::2
BgpNexthop: ::
OutVRF: 0 InVRF: 0
SamplerMode: 0 SamplerInt: 0
Active: 13 Bytes/Pkt: 1490
IP& 30::2(1025) 20::CE(1000) 6 0 0x0 RAGG1.1(I) 803
TcpFlag: 16
DstAS: 0 SrcAS: 0
Nexthop: 30::2
BgpNexthop: ::
OutVRF: 0 InVRF: 0
IP& 30::2(1025) 20::CF(1000) 6 0 0x0 RAGG1.1(I) 833
TcpFlag: 16
DstAS: 0 SrcAS: 0
Nexthop: 30::2
BgpNexthop: ::
OutVRF: 0 InVRF: 0
# 分布式路由器上查看IPv6 NetStream流缓冲区信息
<Sysname> display ipv6 netstream cache verbose slot 1
Stream active timeout (in minutes) : 1
Stream inactive timeout (in seconds): 60
Stream max entry number : 630000
MPLS stream entry been counted : 77000
IPv6 packet size distribution (363441954 total packets):
MPLS 77000 5535 1 4718 60 0
IP& 30::2(1025) 20::C7(1000) 6 0 0x0 RAGG1.1(O) 271
MPLS UNKNOWN(0.0.0.0/0) 1:1028-0-1
TcpFlag: 16
DstAS: 0 SrcAS: 0
Nexthop: ::D01:102
BgpNexthop: ::FFFF:303:303
OutVRF: 0 InVRF: 0
Active: 3 Bytes/Pkt: 1490
IP& 30::2(1025) 20::E7(1000) 6 0 0x0 RAGG1.1(O) 282
TcpFlag: 16
DstAS: 0 SrcAS: 0
Nexthop: ::D01:102
OutVRF: 0 InVRF: 0
IP& 30::2(1025) 20::105(1000) 6 0 0x0 RAGG1.1(O) 271
TcpFlag: 16
DstAS: 0 SrcAS: 0
Nexthop: ::D01:102
OutVRF: 0 InVRF: 0
IP& 30::2(1025) 20::130(1000) 6 0 0x0 RAGG1.1(O) 283
TcpFlag: 16
DstAS: 0 SrcAS: 0
Nexthop: ::D01:102
OutVRF: 0 InVRF: 0
表1-1 display ipv6 netstream cache命令显示信息描述表
IPv6 netstream cache information |
NetStream流缓存区信息 |
Stream active timeout (in minutes) |
当前的活跃老化时间(以分钟为单位) |
Stream inactive timeout (in seconds) |
当前的不活跃老化时间(以秒为单位) |
Stream max entry number |
NetStream流缓存区中允许的最大流数 |
IPv6 Active stream entry |
NetStream流缓存区中活跃的IPv6流数 |
MPLS Active stream entry |
NetStream流缓存区中活跃的MPLS流数 |
IPv6 Stream entry been counted |
被统计的IPv6流数 |
MPLS Stream entry been counted |
被统计的MPLS流数 |
Last statistics reset time |
上次清除统计的时间,此时间为清除时刻的绝对时间,它不会随系统时间的修改而变化 该字段只在执行了reset ipv6 netstream statistics命令后才会出现,否则显示: Last statistics reset time : Never |
IPv6 packet size distribution (814306 total packets): |
IPv6报文按大小分布情况,括号中为IPv6报文总数。分布值按各项占报文总数的比率显示,只显示3位小数,如“.027”表示长度为545~576字节的报文数占报文总数的0.027。 |
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480 512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 >4608 |
IPv6报文尺寸区间(报文长度不包括二层链路层的头)。长度不超过576字节时,以32字节为单位递增,例如:“1-32”是长度为1~32个字节的报文数目,“64”是长度为33~64字节的报文数。长度超过1024字节时,以512字节为单位递增,例如“1536”是长度为1025~1536字节的报文数。长度为577~1024间的报文记录存放在1024项中。 |
Protocol Total Streams Packets /Sec Stream/Sec Packets/stream Active(sec)/stream Idle(sec)/stream |
按协议分类的报文统计信息:协议号、总流数、每秒的报文数、每秒的流数、平均每条流的报文数、平均每条流的活跃时间、平均每条流的非活跃时间 |
Type DstIP(Port) SrcIP(Port) Pro TC FlowLbl If(Direc) Pkts |
当前流缓存区中活跃流的IP层信息: 流的类型、目的IPv6地址(目的端口号)、源IPv6地址(源端口号)、协议、流量分类、流标签、接口名(方向)、包数 其中流的类型有五种:IP流(IP)、不带IP选项的MPLS流(MPLS)、带IP选项的MPLS流(IP&MPLS) |
DstMAC(VLAN) SrcMAC(VLAN) |
当前流缓存区中活跃流的二层信息:目的MAC地址、目的VLAN ID、源MAC地址、源VLAN ID |
TopLblType(IP/MASK) Lbl-Exp-S-List |
当前流缓存区中活跃流的MPLS信息:栈顶标签的类型(栈顶标签对应的IP地址及掩码长度)、标签列表 标签主要的三部分: l 20比特的Label字段表示标签值 l 3比特的EXP字段用来实现QOS l 1比特S字段置1表示已达栈底 标签列表中至多列出三层标签 |
TcpFlag: DstMask: SrcMask: DstAS: SrcAS Nexthop: BgpNexthop: OutVRF: InVRF: Active: Bytes/Pkt: |
当前流缓存区中活跃流的其他信息:TCP标记、目的掩码、源掩码、目的自治系统、源自治系统、路由下一跳、BGP下一跳、出方向报文所属VPN 、入方向报文所属VPN、流活跃时间、平均每个包的字节数 |
【缺省级别】
1:监控级
无
【描述】
display ipv6 netstream export命令用来查看IPv6 NetStream统计输出报文的各种信息。
# 路由器上查看IPv6 NetStream统计输出信息。
<Sysname> display ipv6 netstream export
IPv6 export information:
Stream source interface : GigabitEthernet1/0/1
Stream destination VPN-instance : VPN1
Stream destination IP (UDP) : 10.10.0.10 (30000)
Version 9 exported stream number : 16
Version 9 exported UDP datagram number (failed) : 16 (0)
AS aggregation export information:
Stream destination VPN -instance : VPN1
Version 9 exported UDP datagram number (failed) : 2 (0)
表1-2 display ipv6 netstream export命令显示信息描述表
IPv6 export information |
IPv6 NetStream统计输出信息 |
Stream source interface |
输出信息的源接口 |
Stream destination vpn-instance |
输出信息的目的主机所在的VPN |
Stream destination IP (UDP) |
输出信息(UDP)的目的地址和目的端口号 |
Version 9 exported stream number |
已发送的流信息数 |
Version 9 exported UDP datagram number (failed) |
已发送的UDP报文数(发送失败数) |
AS aggregation export information |
启用自治系统聚合的版本9统计输出信息。没有启用的聚合功能不显示(各项信息同上) |
集中式设备:
分布式设备:
display ipv6 netstream template [ slot slot-number ]
【缺省级别】
1:监控级
slot slot-number:查看指定单板上的模板信息。slot-number表示单板的槽位号。如果不指定该参数,则显示模板的配置信息。
【描述】
display ipv6 netstream template命令用来查看模板的配置和状态信息。
# 分布式路由器上查看NetStream模板信息。
<Sysname> display ipv6 netstream template slot 5
Stream template refresh-rate packet : 20
Stream template refresh-rate time(in minute) : 30
Active stream templates : 4
Added stream templates : 4
as outbound template:
Template ID : 3293
Packets : 0
Last template export time : Never
Field count : 14
Field type Field length (byte)
Flows 4
Out packets 8
Out bytes 8
First switched 4
Last switched 4
Source AS 4
Destination AS 4
Input SNMP 4
Output SNMP 4
IP protocol version 1
Direction 1
Sampling algorithm 1
PAD 1
Sampling interval 4
as inbound template:
Template ID : 3292
Packets : 0
Field count : 14
Flows 4
In packets 8
In bytes 8
First switched 4
Last switched 4
Source AS 4
Destination AS 4
Input SNMP 4
Output SNMP 4
Direction 1
PAD 1
Sampling interval 4
IPv6 outbound template:
Template ID : 3305
Packets : 0
Field count : 27
Out packets 8
Out bytes 8
First switched 4
Last switched 4
Input SNMP 4
Output SNMP 4
IPv6 source address 16
IPv6 destination address 16
IPv6 nexthop 16
PAD 1
IPv6 flow label 3
Source AS 4
Destination AS 4
L4 source port 2
L4 destination port 2
TCP flags 1
Protocol 1
Source ToS 1
IPv6 source mask 1
IPv6 destination mask 1
Direction 1
Forwarding offset 1
Out VPN ID 2
PAD 1
Sampling interval 4
表1-3 display ipv6 netstream template命令显示信息描述表
Stream template refresh-rate packet |
模板的包刷新率 |
Stream template refresh-rate time(minute) |
模板的时间刷新率(以分钟为单位) |
Active stream templates |
当前活跃的模板数 |
Added stream templates |
系统启动以来创建的模板总数 |
AS outbound template |
AS出方向模板信息 |
AS inbound template |
AS入方向模板信息 |
Packets |
使用该模板的发送报文数。由于一个报文中可能携带多条流,不同的流会使用到不同的模板,这里的Packets实际上是流数 |
Last template export time |
该模板最近的一次输出时间 |
Template ID |
模板ID |
Field count |
模板的域总数 |
Field type |
域类型 |
Field length (byte) |
域长度,以字节为单位 |
enable
undo enable
NetStream聚合视图
【缺省级别】
3:管理级
无
【描述】
enable命令用来使能当前聚合视图对应的聚合方式。undo enable命令用来禁止该聚合方式。
缺省情况下,未使能任何聚合方式。
相关配置可参考命令ipv6 netstream aggregation。
# 使能NetStream的自治系统聚合方式。
[Sysname] ipv6 netstream aggregation as
[Sysname-aggregation-as] enable
ipv6 netstream [ inbound | outbound ]
undo ipv6 netstream [ inbound | outbound ]
【缺省级别】
3:管理级
inbound:入方向的NetStream统计。
outbound:出方向的NetStream统计。
【描述】
ipv6 netstream命令用来配置当前接口IPv6 NetStream统计功能。undo ipv6 netstream命令用来恢复缺省情况。
缺省情况下,当前接口下未使能IPv6 NetStream统计功能。
# 在GigabitEthernet1/0/1接口上启动NetStream入统计功能。
[Sysname-GigabitEthernet1/0/1] ipv6 netstream inbound
【缺省级别】
3:管理级
as:自治系统聚合,根据NetStream流的源自治系统号、目的自治系统号、输入接口索引和输出接口索引4个关键值对流分类。
bgp-nexthop:边界网关-下一跳聚合,根据NetStream流的BGP下一跳IPv6地址、输出接口索引2个关键值对流分类。
destination-prefix:目的前缀聚合,根据NetStream流的目的自治系统号、目的掩码长度、目的前缀和输出接口索引4个关键值对流分类。
prefix:源和目的前缀聚合,根据NetStream流的源自治系统号、目的自治系统号、源掩码长度、目的掩码长度,源前缀、目的前缀、输入接口索引和输出接口索引8个关键值对流分类。
protocol-port:协议-端口聚合,根据NetStream流的协议号、源端口和目的端口3个关键值对流分类。
source-prefix:源前缀聚合,根据NetStream流的源自治系统号、源掩码长度、源前缀和输入接口索引4个关键值对流分类。
【描述】
ipv6 netstream aggregation命令用来进入NetStream聚合视图。
需要注意的是:在聚合视图下,可以启用或关闭聚合功能,以及设置NetStream统计输出报文源接口、目的地址以及目的端口号。
相关配置可参考命令enable、ipv6 netstream export host和ipv6 netstream export source。
# 进入NetStream自治系统聚合视图。
[Sysname-ns6-aggregation-as]
ipv6 netstream export rate rate
undo ipv6 netstream export rate
【缺省级别】
3:管理级
rate:NetStream统计输出报文的最大输出速度,单位为每秒允许输出最大报文个数。取值范围是1~1000。
【描述】
ipv6 netstream export rate命令用来配置输出速率限制,并设定IPv6 NetStream统计输出报文的最大输出速率。undo ipv6 netstream export rate命令用来关闭输出速率限制功能。
缺省情况下,IPv6 NetStream 统计输出报文的输出速率不受限制。
需要注意的是,设定值由各单板单独控制。因为老化定时器时长不同,多核产品在输出时,该配置可能不太精确。
# 设置每秒最多允许10个报文被输出。
[Sysname] ipv6 netstream export rate 10
ipv6 netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ]
undo ipv6 netstream export host [ ip-address [ vpn-instance vpn-instance-name ]
系统视图/NetStream聚合视图
【缺省级别】
3:管理级
ip-address:NetStream统计输出报文的目的地址,目前只支持IPv4地址形式。
udp-port:NetStream统计输出报文的目的端口号,取值范围为0~65535。
vpn-instance vpn-instance-name:NetStream统计输出报文查询的VPN名称。
【描述】
ipv6 netstream export host命令用来配置NetStream统计输出报文的目的地址和目的端口号,还可以指定在哪个私网中查询路由。undo ipv6 netstream export host命令用来删除已有配置。
缺省情况下,系统视图下没有配置目的地址和目的端口号,聚合视图下目的地址和目的端口号为系统视图下所配置的值。
l 如果某类聚合视图没有使能,则查看不到它的目的地址和目的端口号。
l 未指定地址时为取消指定本视图下配置的所有地址。
l 不同聚合视图下可以配置不同的目的主机。
l 聚合视图下若没有配置目的主机,则使用系统视图下的配置。
l 一个视图下最多可配置4组主机地址,包括不同VPN的主机。在同一视图下,若先后配置了IP地址相同、UDP端口号不同的目的主机地址,则后配置的目的主机地址生效。特别在用户配置了不同的VPN名称时,允许配置相同的IP地址和UDP端口号。
l 普通流统计输出报文会发给系统视图下配置的所有目的主机。聚合流统计输出报文会发给聚合类型对应的聚合视图下配置的所有目的主机。为了减少对网络带宽的占用,可以只在聚合视图下配置ipv6 netstream export host命令,此时设备只会输出聚合流信息。
相关配置可参考命令ipv6 netstream aggregation和ipv6 netstream export source。
# 设置NetStream统计输出报文的目的地址为1.1.1.1,UDP端口号为5000,在vpn0中查询路由。
[Sysname] ipv6 netstream export host 1.1.1.1 5000 vpn-instance vpn0
ipv6 netstream export source interface interface-type interface-number
undo ipv6 netstream export source
系统视图/NetStream聚合视图
【缺省级别】
3:管理级
interface-type interface-number:NetStream统计输出报文的源接口,由接口类型和接口编号组成。
【描述】
ipv6 netstream export source interface命令用来配置NetStream统计输出报文的源接口。undo ipv6 netstream export source命令用来取消配置的输出报文的源接口。
缺省情况下,采用统计输出报文的出接口(即与服务器相连的接口)作为源接口。
l 不同聚合视图下可以配置不同的源接口。
l 聚合视图下若没有配置源接口,则使用系统视图下的配置。
l 建议使用网管口作为源接口,与服务器相连,并向服务器输出统计信息。
# 将NetStream统计输出报文源接口设置为GigabitEthernet1/0/1。
[Sysname] ipv6 netstream export source interface gigabitethernet 1/0/1
ipv6 netstream export v9-template refresh-rate packet packets
undo ipv6 netstream export v9-template refresh-rate packet
【缺省级别】
3:管理级
packets:NetStream统计输出报文版本9模板的包刷新率,单位为上报报文的个数,即每隔多少个包发送一次模板,通知NDA更新模板。取值范围是1~600,缺省为20。
【描述】
ipv6 netstream export v9-template refresh-rate packet命令用来配置NetStream统计输出报文版本9模板的包刷新率。undo ipv6 netstream export v9-template refresh-rate packet命令用来恢复缺省情况。
缺省情况下,每隔20个包设备发送一次模板。
l 由于容量问题,NDA接受到的版本9数据模板会被定期老化,因此用户需要配置版本9模板的刷新率,及时更新模板。
l 可以同时配置包刷新率和时间刷新率,只要满足任意一个刷新条件,设备就会将符合条件的模板发送给NDA。
相关配置可参考命令ipv6 netstream export v9-template refresh-rate time。
# 将NetStream统计输出报文版本9模板的包刷新率设为100。
[Sysname] ipv6 netstream export v9-template refresh-rate packet 100
ipv6 netstream export v9-template refresh-rate time minutes
undo ipv6 netstream export v9-template refresh-rate time
【缺省级别】
3:管理级
minutes:NetStream统计输出报文版本9模板的时间刷新率,单位为分钟,即每隔多少分钟发送一次模板,通知NDA更新模板。取值范围是1~3600,缺省为30。
【描述】
ipv6 netstream export v9-template refresh-rate time命令用来配置NetStream统计输出报文版本9模板的时间刷新率。undo ipv6 netstream export v9-template refresh-rate time命令用来恢复缺省情况。
缺省情况下,每隔30分钟设备发送一次模板。
l 由于V9版本是基于模板方式、可支持自定义格式,所以设备上需要定期刷新模板,通知NDA最新的V9模版格式。用户可以根据实际情况,配置版本9模板的刷新率,及时更新模板。
相关配置可参考命令ipv6 netstream export v9-template refresh-rate packet。
# 将NetStream统计输出报文版本9模板的时间刷新率设为60分钟。
[Sysname] ipv6 netstream export v9-template refresh-rate time 60
ipv6 netstream export version 9 [ origin-as | peer-as ] [ bgp-nexthop ]
undo ipv6 netstream export version
【缺省级别】
3:管理级
origin-as:流信息中记录的自治系统号为起始自治系统号。
peer-as:流信息中记录的自治系统号为邻接自治系统号。
bgp-nexthop:流信息中记录BGP下一跳。
【描述】
ipv6 netstream export version 9命令用来配置IPv6 NetStream统计输出报文以及其自治系统选项、BGP下一跳选项。undo ipv6 netstream export version命令用来恢复缺省情况。
缺省情况下,IPv6普通流信息、IPv6聚合统计流信息和带IPv6 选项信息的MPLS流信息都通过版本9的NetStream统计输出报文发送。自治系统选项使用邻接自治系统号(peer-as),流信息中不记录BGP下一跳地址。
需要注意的是,流信息中会记录流的源IPv6地址和目的IPv6地址的自治系统号。因为每个IPv6地址对应两个自治系统号:起始自治系统号和邻接自治系统号,系统将根据用户配置的自治系统选项来选择记录哪个自治系统号。
# 将NetStream统计采用起始自治系统号作为给定IPv6地址的自治系统号。
[Sysname] ipv6 netstream export version 9 origin-as
ipv6 netstream max-entry { max-entries | aging | disable-caching }
undo ipv6 netstream max-entry
【缺省级别】
3:管理级
max-entries:NetStream流缓存区大小,取值范围为1000~620000。
aging:在达到最大流表个数时,进行强制老化。
disable-caching:在达到最大流表个数时,禁止创建流。
【描述】
ipv6 netstream max-entry命令用来配置NetStream流缓存区大小,即所能容纳NetStream流的最大数量,以及在达到最大流表个数时,是进行强制老化,还是禁止创建流。undo ipv6 netstream max-entry命令用来恢复缺省情况。
缺省情况下,NetStream流缓存区大小为620000,在达到最大流表个数时进行强制老化。该命令仅SR6602支持。
# 设置NetStream流缓存区的大小为5000。
[Sysname] ipv6 netstream max-entry 5000
# 设置NetStream在达到最大流表个数时,禁止创建流。
[Sysname] ipv6 netstream max-entry disable-caching
ipv6 netstream timeout active minutes
undo ipv6 netstream timeout active
【缺省级别】
3:管理级
minutes:NetStream流活跃老化时间,单位为分钟。取值范围是1~60,缺省为30。
【描述】
ipv6 netstream timeout active命令用来配置NetStream流的活跃老化时间。undo ipv6 netstream timeout active命令用来恢复缺省情况。
缺省情况下,IPv6普通流信息的活跃老化时间为30分钟。
相关配置可参考命令ipv6 netstream timeout inactive。
NetStream活跃老化时间和不活跃老化时间可以同时配置,满足任一个老化时间就会对流进行老化,时间精度为10秒钟。
# 将NetStream流活跃老化时间设置为60分钟。
[Sysname] ipv6 netstream timeout active 60
ipv6 netstream timeout inactive seconds
undo ipv6 netstream timeout inactive
【缺省级别】
3:管理级
seconds:NetStream流不活跃老化时间,单位为秒。取值范围是10~600,缺省为30。
【描述】
ipv6 netstream timeout inactive命令用来配置NetStream流的不活跃老化时间。undo ipv6 netstream timeout inactive命令用来恢复缺省情况。
缺省情况下,IPv6普通流信息的不活跃老化时间为30秒。
相关配置可参考命令ipv6 netstream timeout active。
# 将NetStream流不活跃老化时间设置为60秒。
[Sysname] ipv6 netstream timeout inactive 60
【缺省级别】
2:系统级
无
【描述】
reset ipv6 netstream statistics命令用来将流缓存区中所有流强制老化,并清除IPv6 NetStream缓冲区的状态信息和输出报文信息。
在执行清除缓存区中老化流的动作时,命令行需要给出提示,告知用户这个动作可能要持续几分钟,在这段时间内不能统计。但此时不把命令行挂住。
# 将流缓存区中所有流老化,并清除NetStream缓冲区的状态信息和输出报文信息。
<Sysname> reset ipv6 netstream statistics
This process may take a few minutes.
Netstream statistic function is disabled during this process.
