选择区域语言: EN CN HK
12-网络管理和监控命令参考
09-NetStream命令
本章节下载  (183.03 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/SR_Router/SR6600/Command/Command_Manual/H3C_SR6600_CR-R2420(V1.12)/12/201212/765625_30005_0.htm
09-NetStream命令
1 NetStream配置命令
1.1  NetStream配置命令
1.1.1  display ip netstream cache
集中式设备:
display ip netstream cache [ verbose ]
分布式设备:
display ip netstream cache [ verbose ] [ slot slot-number ]
【缺省级别】
1:监控级
verbose:显示NetStream流缓冲区的详细信息。
slot slot-number:查看指定单板上的NetStream流缓冲区信息。slot-number表示单板的槽位号。如果不指定该参数,则显示当前所有NetStream流缓冲区信息。(分布式设备)
【描述】
display ip netstream cache命令用来查看NetStream流缓存区信息。
# 集中式路由器上查看NetStream流缓冲区信息。
<Sysname> display ip netstream cache verbose
IP netstream cache information:
  Stream active timeout (in minutes)  : 30
  Stream inactive timeout (in seconds): 30
  Stream max entry number             : 10000
    IP active stream entry number     : 3
  MPLS active stream entry number     : 0
    IP stream entry been counted      : 3
  MPLS stream entry been counted      : 0
  Last statistics reset time          : Never
IP packet size distribution (63 total packets):
 1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
 .000 .857 .142 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
  512  544  576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
 Protocol          Total   Packets   Stream  Packets Active(sec) Idle(sec)
                 Streams      /Sec     /Sec  /stream   /stream    /stream
 ICMP                  1         0        0        5         0         31
 TCP-BGP               2         0        0        2         0         31
Type DstIP(Port)            SrcIP(Port)            Pro ToS If(Direc)   Pkts
     DstMAC(VLAN)           SrcMAC(VLAN)
     TopLblType(IP/MASK)    Lbl-Exp-S-List
IP   224.0.0.5(0)           5.5.5.1(0)             89  192 GE1/0/1(I)   32
IP   5.5.5.2(1172)          5.5.5.1(179)           6   0   GE1/0/1(I)   7
IP   5.5.5.2(1172)          5.5.5.1(179)           6   192 GE1/0/1(I)   14
# 分布式路由器上查看NetStream流缓冲区信息。
<Sysname> display ip netstream cache verbose slot 1
IP packet size distribution (59 total packets):
 .000 .847 .152 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
 ICMP                  1         0        0        5         0         31
IP   224.0.0.5(0)           5.5.5.1(0)             89  192 GE2/0/1(I)   30
     TcpFlag:       0
     DstMask:      32       SrcMask:      24       Nexthop:           0.0.0.0
     DstAS:         0       SrcAS:         0       BgpNexthop:        0.0.0.0
     OutVRF:        0       InVRF:         0
     SamplerMode:   0       SamplerInt:    0
     Active:      280       Bytes/Pkt:    64
IP   5.5.5.2(1172)          5.5.5.1(179)           6   0   GE2/0/1(I)   6
     TcpFlag:      16
     DstMask:      32       SrcMask:      24       Nexthop:         127.0.0.1
     OutVRF:        0       InVRF:         0
     Active:       90       Bytes/Pkt:    40
IP   5.5.5.2(1172)          5.5.5.1(179)           6   192 GE2/0/1(I)   13
     TcpFlag:      26
     OutVRF:        0       InVRF:         0
     Active:      108       Bytes/Pkt:    55
表1-1 display ip netstream cache verbose命令显示信息描述表
NetStream流缓存区信息
当前的活跃老化时间(以分钟为单位)
当前的不活跃老化时间(以秒为单位)
NetStream流缓存区中允许的最大流数
IP Active stream entry number
NetStream流缓存区中活跃的IP流数
MPLS Active stream entry number
NetStream流缓存区中活跃的MPLS流数
IP Stream entries been counted
被统计的IP流数
MPLS Stream entries been counted
被统计的MPLS流数
上次清除统计的时间,此时间为清除时刻的绝对时间,它不会随系统时间的修改而变化
该字段只在执行了reset ip netstream statistics命令后才会出现,否则显示:
IP报文按大小分布情况,括号中为IP报文总数。
分布值按占IP报文总数的比率显示,只显示3位小数,如“.027”表示占IP报文总数的0.027
320  352  384  416  448  480 512  544  576
IP报文尺寸区间(报文长度不包括二层链路层的头)。长度不超过576字节时,以32字节为单位递增,例如:“1-32”是长度为1~32个字节的报文数目,“64”是长度为33~64字节的报文数。长度超过1024字节时,以512字节为单位递增,例如“1536”是长度为1025~1536字节的报文数。长度在577~1024间的报文记录在1024项中
Protocol     Total Streams     Packets /Sec
Stream/Sec   Packets/stream
Active(sec)/stream     Idle(sec)/stream
按协议分类的报文统计信息:协议号、总流数、每秒的报文数、每秒的流数、平均每条流的报文数、平均每条流的活跃时间、平均每条流的非活跃时间
当前流缓存区中活跃流的IP层信息:流的类型、目的IP地址(目的端口号)、源IP地址(源端口号)、协议、ToS、接口名(方向)、包数
其中流的类型有五种:IP流(IP)、不带IP选项的MPLS流(MPLS)、带IP选项的MPLS流(IP&MPLS)
当前流缓存区中活跃流的二层信息:目的MAC地址、目的VLAN ID、源MAC地址、源VLAN ID
当前流缓存区中活跃流的MPLS信息:栈顶标签的类型(栈顶标签对应的IP地址及掩码长度)、标签列表
标签主要的三部分:20比特的Label字段表示标签值,3比特的EXP字段用来实现QoS,1比特S字段置1表示已达栈底
标签列表中至多列出三层标签
TcpFlag:
DstMask:      SrcMask:             Nexthop:
DstAS:           SrcAS:            BgpNexthop:
OutVRF:       InVRF:
SamplerMode:                     SamplerInt:
Active:       Bytes/Pkt:
当前流缓存区中活跃流的其他信息
TCP标记:
目的掩码、源掩码、路由下一跳、目的自治系统、源自治系统、BGP下一跳、出方向报文所属VPN 、入方向报文所属VPN、采样模式(F/D/R)、采样间隔、流活跃时间、平均每个包的字节数
NetStream采样模式,目前支持三种:0不采样,统计所有报文;1规则采样;2随机采样
1.1.2  display ip netstream export
【缺省级别】
1:监控级
【描述】
display ip netstream export命令用来查看NetStream统计输出报文的各种信息。
# 查看NetStream统计输出信息。
<Sysname> display ip netstream export
IP export information:
Stream source interface                         : GigabitEthernet1/0/1
Stream destination VPN-instance                 : VPN1
  Stream destination IP (UDP)                     : 10.10.0.10 (30000)
  Version 5 exported stream number                : 16
  Version 5 exported UDP datagram number (failed) : 16 (0)
  Version 9 exported stream number                : 20
  Version 9 exported UDP datagram number (failed) : 2 (0)
MPLS export information:
AS aggreagtion export information:
  Version 8 exported stream number                : 16
  Version 8 exported UDP datagram number (failed) : 2 (0)
  Version 9 exported stream number                : 16
表1-2 display ip netstream export命令显示信息描述表
版本5统计输出信息
输出信息的源接口
Stream destination vpn-instance
输出信息的目的主机所在的VPN
输出信息(UDP)的目的地址和目的端口号
使用版本5格式发送的流信息数
使用版本5格式发送的UDP报文数(发送失败数)
使用版本9格式发送的流信息数
使用版本9格式发送的UDP报文数(发送失败数)
AS aggregation export information
启用自治系统聚合的版本8统计输出信息。没有启用的聚合功能不显示(各项信息同上)
版本9 MPLS流统计输出信息
使用版本8格式发送的流信息数
使用版本8格式发送的UDP报文数(发送失败数)
1.1.3  display ip netstream template
集中式设备:
分布式设备:
display ip netstream template [ slot slot-number ]
【缺省级别】
1:监控级
slot slot-number:查看指定单板上的模板信息。slot-number表示单板的槽位号。如果不指定该参数,则显示模板的配置信息。(分布式设备)
【描述】
display ip netstream template命令用来查看NetStream模板的配置和状态信息。
# 使能自治系统进行聚合方式。查看NetStream模板信息。
<Sysname> display ip netstream template
Stream template refresh-rate packet            : 30
Stream template refresh-rate time (in minutes) : 20
Active stream templates                        : 2
Added stream templates                         : 2
AS outbound template:
 Template ID                : 3258
 Packets                    : 0
 Last template export time  : 01/01/2008, 00:05:17
 Field count                : 14
 Field type                   Field length (byte)
 Flows                        4
 Out packets                  8
 Out bytes                    8
 First switched               4
 Last switched                4
 Source AS                    2
 Destination AS               2
 Input SNMP                   2
 Output SNMP                  2
 Direction                    1
 Sampling algorithm           1
 PAD                          1
 PAD                          1
 Sampling interval            4
AS inbound template:
 Template ID                : 3257
 Packets                    : 3
 Last template export time  : 01/01/2008, 00:01:02
 Field count                : 14
 Flows                        4
 In packets                   8
 In bytes                     8
 First switched               4
 Last switched                4
 Source AS                    2
 Destination AS               2
 Input SNMP                   2
 Output SNMP                  2
 Direction                    1
 PAD                          1
 PAD                          1
 Sampling interval            4
表1-3 display ip netstream template命令显示信息描述表
模板的包刷新率
Stream template refresh-rate time(in minute)
模板的时间刷新率(以分钟为单位)
当前活跃的模板数
系统启动以来创建的模板总数
根据不同的聚合方式,下面的显示信息会有差异,请以实际配置的聚合方式为准,这里以“自治系统”聚合方式为例
AS出方向模板信息
AS inbound template
AS入方向模板信息
Packets
使用该模板的发送报文数。由于一个报文中可能携带多条流,不同的流会使用到不同的模板,这里的Packets实际上是流数。
该模板最近的一次输出时间
Template ID
模板ID
Field count
模板的域总数
Field type
域类型
Field length (byte)
域长度,以字节为单位
Flows
聚合流数量
Out/In packets
输出/输入的数据包大小
Out/In bytes
输出/输入的数据大小,以字节为单位
First switched
记录转发第一个报文时的系统时间,单位为毫秒
Last switched
记录转发最后一个报文时的系统时间,单位为毫秒
Source AS
源AS号
Destination AS
目的AS
Input SNMP
输入接口的索引
Output SNMP
输出接口的索引
Direction
方向字段
Sampling algorithm
采样算法
PAD
空白占位符
PAD
空白占位符
Sampling interval
采样率
1.1.4  enable
enable
undo enable
NetStream聚合视图
【缺省级别】
3:管理级
【描述】
enable命令用来使能当前聚合视图对应的聚合方式。undo enable命令用来禁止该聚合方式。
缺省情况下,未使能任何NetStream聚合功能。
相关配置可参考命令ip netstream aggregation
# 使能NetStream的自治系统聚合方式。
[Sysname] ip netstream aggregation as
[Sysname-ns-aggregation-as] enable
1.1.5  ip netstream
ip netstream { inbound | outbound }
undo ip netstream { inbound | outbound }
【缺省级别】
3:管理级
inbound:入方向的NetStream统计。
outbound:出方向的NetStream统计。
【描述】
ip netstream命令用来在当前接口启动NetStream统计功能。undo ip netstream命令用来在当前接口关闭NetStream统计功能。
缺省情况下,接口未启动NetStream统计功能。
# 在GE1/0/1接口上启动NetStream入统计功能。
[Sysname-GigabitEthernet1/0/1] ip netstream inbound
1.1.6  ip netstream aggregation
ip netstream aggregation { as | destination-prefix | prefix | prefix-port | protocol-port | source-prefix | tos-as | tos-bgp-nexthop | tos-destination-prefix | tos-prefix | tos-protocol-port | tos-source-prefix }
【缺省级别】
3:管理级
as:自治系统聚合,根据NetStream流的源自治系统号、目的自治系统号、输入接口索引和输出接口索引4个关键值对流分类。
destination-prefix:目的前缀聚合,根据NetStream流的目的自治系统号、目的掩码长度、目的前缀和输出接口索引4个关键值对流分类。
prefix:源和目的前缀聚合,根据NetStream流的源自治系统号、目的自治系统号、源掩码长度、目的掩码长度,源前缀、目的前缀、输入接口索引和输出接口索引8个关键值对流分类。
prefix-port:前缀端口聚合,根据NetStream流的源前缀、目的前缀、源掩码长度、目的掩码长度、ToS、协议号、源端口、目的端口、输入接口索引、输出接口索引10个关键值对流分类。
protocol-port:协议-端口聚合,根据NetStream流的协议号、源端口和目的端口3个关键值对流分类。
source-prefix:源前缀聚合,根据NetStream流的源自治系统号、源掩码长度、源前缀和输入接口索引4个关键值对流分类。
tos-as:服务类型-自治系统聚合,根据NetStream流的ToS、源自治系统号、目的自治系统号、输入接口索引和输出接口索引5个关键值对流分类。
tos-bgp-nexthop:边界网关-下一跳-服务类型聚合,根据NetStream流的ToS、BGP下一跳IP地址、输出接口索引3个关键值对流分类。边界网关-下一跳-服务类型聚合只在V9模板下生效。
tos-destination-prefix:服务类型-目的前缀聚合,根据NetStream流的ToS、目的自治系统号、目的掩码长度、目的前缀和输出接口索引5个关键值对流分类。
tos-prefix:服务类型-前缀聚合,根据NetStream流的ToS、源自治系统号、源前缀、源掩码长度、目的自治系统号、目的掩码长度、目的前缀、输入接口索引和输出接口索引9个关键值对流分类。
tos-protocol-port:服务类型-协议-端口聚合,根据NetStream流的ToS、协议号、源端口、目的端口、输入接口索引和输出接口索引6个关键值对流分类。
tos-source-prefix:服务类型-源前缀聚合,根据NetStream流的ToS、源自治系统号、源前缀、源掩码长度和输入接口索引5个关键值对流分类。
【描述】
ip netstream aggregation命令用来设置NetStream流聚合方式,并进入相应的NetStream聚合视图。在聚合视图下,可以启用或关闭聚合功能,以及设置NetStream统计输出报文源接口、目的IP地址以及目的端口号。
相关配置可参考命令enableip netstream export hostip netstream export source
# 进入NetStream自治系统聚合视图。
1.1.7  ip netstream export host
ip netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ]
undo ip netstream export host [ ip-address [ vpn-instance vpn-instance-name ] ]
系统视图/NetStream聚合视图
【缺省级别】
3:管理级
ip-address:NetStream统计输出报文的目的IP地址。
udp-port:NetStream统计输出报文的目的端口号,取值范围为0~65535。
vpn-instance vpn-instance-name:NetStream统计输出报文查询的VPN名称。
【描述】
ip netstream export host命令用来配置NetStream统计输出报文的目的IP地址和目的端口号,还可以指定在哪个私网中查询路由。undo ip netstream export host命令用来删除已有配置,未指定IP地址时为取消指定本视图下配置的所有IP地址。
缺省情况下,系统视图下没有配置目的IP地址和目的端口号,聚合视图下目的IP地址和目的端口号为系统视图下所配置的值。
l              如果某类聚合视图没有使能,则查看不到它的目的IP地址和目的端口号。
l              不同聚合视图下可以配置不同的目的主机。
l              聚合视图下若没有配置目的主机,则使用系统视图下的配置。
l              一个视图下最多可配置4组主机地址,包括不同VPN的主机。在同一视图下,若先后配置了IP地址相同、UDP端口号不同的目的主机地址,则后配置的目的主机地址生效。特别在用户配置了不同的VPN名称时,允许配置相同的IP地址和UDP端口号。
l              普通流统计输出报文会发给系统视图下配置的所有目的主机。聚合流统计输出报文会发给聚合类型对应的聚合视图下配置的所有目的主机。为了减少对网络带宽的占用,可以只在聚合视图下配置ip netstream export host命令,此时设备只会输出聚合流信息。
相关配置可参考命令ip netstream aggregationip netstream export source
# 设置NetStream统计输出报文的目的IP地址为172.16.105.48,UDP端口号为5000,在vpn1中查询路由。
[Sysname] ip netstream export host 172.16.105.48 5000 vpn-instance vpn1
1.1.8  ip netstream export rate
ip netstream export rate rate
undo ip netstream export rate
【缺省级别】
3:管理级
rate:NetStream统计输出报文的最大输出速度,单位为每秒允许输出最大报文个数。取值范围是1~1000。
【描述】
ip netstream export rate命令用来配置输出速率限制。undo ip netstream export rate命令用来关闭输出速率限制功能。
缺省情况下,NetStream统计输出报文的输出速率不受限制。
# 设置每秒最多允许10个报文被输出。
[Sysname] ip netstream export rate 10
1.1.9  ip netstream export source
ip netstream export source interface interface-type interface-number
undo ip netstream export source
系统视图/NetStream聚合视图
【缺省级别】
3:管理级
interface-type interface-number:NetStream统计输出报文的源接口,由接口类型和接口编号组成。
【描述】
ip netstream export source interface命令用来配置NetStream统计输出报文的源接口。undo ip netstream export source命令用来取消配置的输出报文的源接口。
缺省情况下,采用统计输出报文的出接口(即与服务器相连的接口)作为源接口。
l              不同聚合视图下可以配置不同的源接口。
l              聚合视图下若没有配置源接口,则使用系统视图下的配置。
l              建议使用网管口作为源接口,与服务器相连,并向服务器输出统计信息。
# 将NetStream统计输出报文源接口设置为GE1/0/1。
[Sysname] ip netstream export source interface gigabitethernet 1/0/1
1.1.10  ip netstream export v9-template refresh-rate packet
ip netstream export v9-template refresh-rate packet packets
undo ip netstream export v9-template refresh-rate packet
【缺省级别】
3:管理级
packets:NetStream统计输出报文版本9模板的包刷新率,单位为上报报文的个数,即每隔多少个包发送一次模板,通知NDA更新模板。取值范围为1~600,缺省值为20。
【描述】
ip netstream export v9-template refresh-rate packet命令用来配置NetStream统计输出报文版本9模板的包刷新率。undo ip netstream export v9-template refresh-rate packet命令用来恢复缺省情况。
缺省情况下,每隔20个包设备发送一次版本9模板。
l              由于容量问题,NDA接收到的版本9数据模板会被定期老化,因此用户需要配置版本9模板的刷新率,及时更新模板。
l              可以同时配置包刷新率和时间刷新率,只要满足任意一个刷新条件,设备就会将符合条件的模板发送给NDA。
相关配置可参考命令ip netstream export v9-template refresh-rate time
# 将NetStream统计输出报文版本9模板的包刷新率设为100。
[Sysname] ip netstream export v9-template refresh-rate packet 100
1.1.11  ip netstream export v9-template refresh-rate time
ip netstream export v9-template refresh-rate time minutes
undo ip netstream export v9-template refresh-rate time
【缺省级别】
3:管理级
minutes:NetStream统计输出报文版本9模板的时间刷新率,单位为分钟,即每隔多少分钟发送一次模板,通知NDA更新模板。取值范围为1~3600,缺省值为30分钟。
【描述】
ip netstream export v9-template refresh-rate time命令用来配置NetStream统计输出报文版本9模板的时间刷新率。undo ip netstream export v9-template refresh-rate time命令用来恢复缺省情况。
缺省情况下,每隔30分钟设备发送一次版本9模板。
l              由于V9版本是基于模板方式、可支持自定义格式,所以设备上需要定期刷新模板,通知NDA最新的V9模版格式。用户可以根据实际情况,配置版本9模板的刷新率,及时更新模板。
相关配置可参考命令ip netstream export v9-template refresh-rate packet
# 将NetStream统计输出报文版本9模板的时间刷新率设为60分钟。
[Sysname] ip netstream export v9-template refresh-rate time 60
1.1.12  ip netstream export version
ip netstream export version 5 [ origin-as | peer-as ]
ip netstream export version 9 [ origin-as | peer-as ] [ bgp-nexthop ]
undo ip netstream export version
【缺省级别】
3:管理级
origin-as:流信息中记录的自治系统号为起始自治系统号。
peer-as:流信息中记录的自治系统号为邻接自治系统号。
bgp-nexthop:流信息中记录BGP下一跳。
【描述】
ip netstream export version 5命令用来配置NetStream版本5的AS参数。ip netstream export version 9命令用来配置NetStream版本9的AS参数和BGP下一跳选项。undo ip netstream export version命令用来恢复缺省情况。
缺省情况下,普通流信息通过版本5的NetStream统计输出报文发送,聚合流信息通过版本8的NetStream统计输出报文发送,MPLS流信息不输出。自治系统选项使用邻接自治系统号(peer-as),流信息中不记录BGP下一跳地址。
l              流信息中会记录流的源IP地址和目的IP地址的自治系统号。因为每个IP地址对应两个自治系统号:起始自治系统号和邻接自治系统号,系统将根据用户配置的自治系统选项来选择记录哪个自治系统号。
l              只有在版本号为9时,才可以配置BGP下一跳。
# 将NetStream统计输出报文版本号设为5,并采用起始自治系统号作为给定IP地址的自治系统号。
[Sysname] ip netstream export version 5 origin-as
1.1.13  ip netstream filter
ip netstream filter acl acl-number { inbound | outbound }
undo ip netstream filter acl acl-number { inbound | outbound }
【缺省级别】
3:管理级
acl acl-number:ACL规则号,取值范围为2000~3999和4000~4999。
inbound:入方向过滤。
outbound:出方向过滤。
【描述】
ip netstream filter命令用来启用按指定条件对流进行过滤。undo ip netstream filter命令用来禁用按指定条件对流进行过滤。
在采样和过滤都使能的情况下,先进行过滤处理。
缺省情况下,未设置任何ACL规则对流进行过滤。
# 在接口GE1/0/1上配置根据规则号为2003的ACL规则进行出方向过滤。
[Sysname-GigabitEthernet1/0/1] ip netstream filter acl 2003 outbound
[Sysname-GigabitEthernet1/0/1] ip netstream outbound
1.1.14  ip netstream max-entry
ip netstream max-entry { max-entries | aging | disable-caching }
undo ip netstream max-entry
【缺省级别】
3:管理级
max-entries:NetStream流缓存区大小,取值范围为1000~620000。
aging:在达到最大流表个数时,进行强制老化。
disable-caching:在达到最大流表个数时,禁止新建流。
【描述】
ip netstream max-entry命令用来配置NetStream流缓存区大小,即所能容纳NetStream流的最大数量,以及当流达到流缓存区的最大数量时,是进行强制老化,还是禁止建流。undo ip netstream max-entry命令用来恢复缺省情况。
缺省情况下,NetStream流缓存区大小为620000,在达到最大流表个数时进行强制老化。该命令仅SR6602支持。
# 设置NetStream流缓存区的大小为5000。
[Sysname] ip netstream max-entry 5000
# 设置NetStream在达到最大流表个数时,禁止建流。
[Sysname] ip netstream max-entry disable-caching
# 设置NetStream在达到最大流表个数时,进行强制老化。
[Sysname] ip netstream max-entry aging
1.1.15  ip netstream mpls
ip netstream mpls [ label-positions label-position1 [ label-position2  [ label-position3 ] ] ] [ no-ip-fields ]
undo ip netstream mpls
【缺省级别】
3:管理级
label-positions:统计的标签位置。
no-ip-fields:不统计IP选项。
label-position1:指定统计的第一个标签位置,取值范围为1~6。
label-position2:指定统计的第二个标签位置,取值范围为1~6。
label-position3:指定统计的第三个标签位置,取值范围为1~6。
【描述】
ip netstream mpls命令用来启动统计和输出MPLS格式的报文,通过参数no-ip-fields可设定是否带IP内容进行输出,不带任何参数时,表示使用首标签并且带有IP内容进行输出。undo ip netstream mpls用来禁用统计和输出MPLS格式的报文。
缺省情况下,禁用统计和输出MPLS格式报文。
需要注意的是:该命令不仅使能IPv4 NetStream对MPLS报文的统计功能,同时也使能了IPv6 NetStream对MPLS报文的统计功能。
# 启动MPLS统计,使用首标签不带IP选项。
[Sysname] ip netstream mpls no-ip-fields
1.1.16  ip netstream sampler
ip netstream sampler sampler-name { inbound | outbound }
undo ip netstream sampler sampler-name { inbound | outbound }
【缺省级别】
3:管理级
sampler sampler-name:采样器名称,最长32个字符。
inbound:入方向采样。
outbound:出方向采样。
【描述】
ip netstream sampler命令用来启用NetStream采样功能。undo ip netstream sampler命令用来禁用NetStream采样功能。
缺省情况下,未使能采样功能。
# 使能NetStream入方向采样,使用名为abc的采样器。
[Sysname-GigabitEthernet1/0/1] ip netstream sampler abc inbound
1.1.17  ip netstream timeout active
ip netstream timeout active minutes
undo ip netstream timeout active
【缺省级别】
3:管理级
minutes:活跃老化时间,单位为分钟。取值范围为1~60,缺省为30。
【描述】
ip netstream timeout active命令用来配置NetStream流的活跃老化时间。undo ip netstream timeout active命令用来恢复缺省情况。
缺省情况下,普通流信息的活跃老化时间为30分钟。
相关配置可参考命令ip netstream timeout inactive
# 将NetStream流活跃老化时间设置为60分钟。
[Sysname] ip netstream timeout active 60
1.1.18  ip netstream timeout inactive
ip netstream timeout inactive seconds
undo ip netstream timeout inactive
【缺省级别】
3:管理级
seconds:不活跃老化时间,单位为秒。取值范围为10~600,缺省值为30。
【描述】
ip netstream timeout inactive命令用来配置NetStream流的不活跃老化时间。undo ip netstream timeout inactive命令用来恢复缺省情况。
缺省情况下,普通流信息的不活跃老化时间为30秒。
相关配置可参考命令ip netstream timeout active
NetStream活跃老化时间和不活跃老化时间可以同时配置,满足任一个老化时间就会对流进行老化,时间精度为10秒钟。
# 将NetStream流不活跃老化时间设置为60秒。
[Sysname] ip netstream timeout inactive 60
1.1.19  reset ip netstream statistics
【缺省级别】
2:系统级
【描述】
reset ip netstream statistics命令用来将流缓存区中所有流强制老化,并清除NetStream缓冲区的状态信息和输出报文信息。
需要注意的是:在执行清除缓冲区中老化流的动作时,命令行需要给出提示,告知用户这个动作可能要持续几分钟,在这段时间内不能统计,命令行仍可继续操作。
# 将流缓存区中所有流老化,并清除NetStream缓冲区的状态信息和输出报文信息。
<Sysname> reset ip netstream statistics
This process may take a few minutes.
Netstream statistic function is disabled during this process.
