选择区域语言: EN CN HK
07-IP组播命令参考
01-IGMP Snooping命令
本章节下载  (202.99 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/SR_Router/SR6600/Command/Command_Manual/H3C_SR6600_CR-R2420(V1.12)/07/201212/765557_30005_0.htm
01-IGMP Snooping命令
1 IGMP Snooping配置命令
1.1 IGMP Snooping配置命令
1.1.1 display igmp-snooping group
1.1.2 display igmp-snooping statistics
1.1.3 dot1p-priority (IGMP-Snooping view)
1.1.4 entry-limit (IGMP-Snooping view)
1.1.5 fast-leave (IGMP-Snooping view)
1.1.6 group-policy (IGMP-Snooping view)
1.1.7 host-aging-time (IGMP-Snooping view)
1.1.8 igmp-snooping
1.1.9 igmp-snooping dot1p-priority
1.1.10 igmp-snooping drop-unknown
1.1.11 igmp-snooping enable
1.1.12 igmp-snooping fast-leave
1.1.13 igmp-snooping general-query source-ip
1.1.14 igmp-snooping group-limit
1.1.15 igmp-snooping group-policy
1.1.16 igmp-snooping host-aging-time
1.1.17 igmp-snooping host-join
1.1.18 igmp-snooping last-member-query-interval
1.1.19 igmp-snooping leave source-ip
1.1.20 igmp-snooping max-response-time
1.1.21 igmp-snooping overflow-replace
1.1.22 igmp-snooping proxying enable
1.1.23 igmp-snooping querier
1.1.24 igmp-snooping query-interval
1.1.25 igmp-snooping report source-ip
1.1.26 igmp-snooping router-aging-time
1.1.27 igmp-snooping source-deny
1.1.28 igmp-snooping special-query source-ip
1.1.29 igmp-snooping static-group
1.1.30 igmp-snooping static-router-port
1.1.31 igmp-snooping version
1.1.32 last-member-query-interval (IGMP-Snooping view)
1.1.33 max-response-time (IGMP-Snooping view)
1.1.34 overflow-replace (IGMP-Snooping view)
1.1.35 report-aggregation (IGMP-Snooping view)
1.1.36 reset igmp-snooping group
1.1.37 reset igmp-snooping statistics
1.1.38 router-aging-time (IGMP-Snooping view)
l          H3C SR6602路由器不支持IGMP Snooping功能。
l          安装了SAP高密以太网接口板的分布式路由器支持IGMP Snooping功能。
1 IGMP Snooping配置命令
集中式设备:
display igmp-snooping group [ vlan vlan-id ] [ verbose ]
分布式设备:
display igmp-snooping group [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
【缺省级别】
1:监控级
vlan vlan-id:查看指定VLAN内IGMP Snooping组播组的信息。vlan-id为指定VLAN的编号,取值范围为1~4094。如果不指定该参数,将显示所有VLAN内IGMP Snooping组播组的信息。
slot slot-number:查看指定单板上IGMP Snooping组播组的信息。slot-number表示接口板所在槽位的编号。如果不指定该参数,将显示主控板上IGMP Snooping组播组的信息。(分布式设备,SR 6604、6608、6616)
verbose:查看IGMP Snooping组播组的详细信息。
【描述】
display igmp-snooping group命令用来查看IGMP Snooping组播组的信息。
# 查看VLAN 2内IGMP Snooping组播组的详细信息。
<Sysname> display igmp-snooping group vlan 2 verbose
  Total 1 IP Group(s).
  Total 1 IP Source(s).
  Total 1 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, C-Copy port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):2.
    Router port(s):total 1 port(s).
            GE1/0/1                (D) ( 00:01:30 )
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:224.1.1.1
        (0.0.0.0, 224.1.1.1):
          Attribute:    Host Port
          Host port(s):total 1 port(s).
            GE1/0/2                (D) ( 00:03:23 )
    MAC group(s):
      MAC group address:0100-5e01-0101
            GE1/0/2
表1-1 display igmp-snooping group命令显示信息描述表
IP组播组的数量
IP组播源的数量
MAC组播组的数量
端口标志:D代表动态端口,S代表静态端口,C代表由(*G)表项拷贝到(SG)表项下的端口
子VLAN标志:R代表本表项下的真实出口子VLAN,C代表由(*,G)表项拷贝到(S,G)表项下的出口子VLAN
Router port unit board
路由器端口所在单板的编号(以掩码表示)。本字段的支持情况与设备的型号有关,请以设备的实际情况为准
Router port(s)
路由器端口的数量
( 00:01:30 )
动态路由器/成员端口的老化剩余时间,需要注意的是:
l      在分布式设备上,如果某非聚合端口不属于主控板,则须指定其所在单板的槽位号(即slot slot-number参数)才能显示出该时间值;而对于聚合端口则无此限制
IP group address
IP组播组的地址
SG)表项,0.0.0.0表示所有组播源
MAC group address
MAC组播组的地址
Attribute
IP组播组的属性
Host port unit board
成员端口所在单板的编号(以掩码表示)。本字段的支持情况与设备的型号有关,请以设备的实际情况为准
Host port(s)
成员端口的数量
【缺省级别】
1:监控级
【描述】
display igmp-snooping statistics命令用来查看IGMP Snooping窥探到的IGMP报文的统计信息。
# 查看IGMP Snooping窥探到的IGMP报文的统计信息。
<Sysname> display igmp-snooping statistics
  Received IGMP general queries:0.
  Received IGMPv1 reports:0.
  Received IGMPv2 reports:19.
  Received IGMP leaves:0.
  Received IGMPv2 specific queries:0.
  Sent     IGMPv2 specific queries:0.
  Received IGMPv3 reports:1.
  Received IGMPv3 reports with right and wrong records:0.
  Received IGMPv3 specific queries:0.
  Received IGMPv3 specific sg queries:0.
  Sent     IGMPv3 specific queries:0.
  Sent     IGMPv3 specific sg queries:0.
  Received error IGMP messages:19.
表1-2 display igmp-snooping statistics命令显示信息描述表
general queries
普遍组查询报文
specific queries
特定组查询报文
reports
报告报文
leaves
离开报文
包含错误和正确纪录的报告报文
specific sg queries
特定源组查询报文
error IGMP messages
错误的IGMP报文
dot1p-priority priority-number
undo dot1p-priority
IGMP-Snooping视图
【缺省级别】
2:系统级
priority-number:IGMP报文的802.1p优先级,取值范围为0~7。该数值越大,优先级越高。
【描述】
dot1p-priority命令用来全局配置IGMP报文的802.1p优先级。undo dot1p-priority命令用来恢复缺省情况。
缺省情况下,IGMP报文的802.1p优先级为0。
# 全局配置IGMP报文的802.1p优先级为3。
[Sysname] igmp-snooping
[Sysname-igmp-snooping] dot1p-priority 3
entry-limit limit
undo entry-limit
IGMP-Snooping视图
【缺省级别】
2:系统级
limit:全局IGMP Snooping转发表项的最大数量,取值范围是0~4000。
【描述】
entry-limit命令用来配置全局IGMP Snooping转发表项的最大数量。undo entry-limit命令用来恢复缺省情况。
缺省情况下,全局IGMP Snooping转发表项的最大数量与设备的型号有关,请以设备的实际情况为准。
相关配置可参考“IP组播命令参考/组播VLAN”中的命令multicast-vlan entry-limit
# 配置全局IGMP Snooping转发表项的最大数量为512个。
[Sysname-igmp-snooping] entry-limit 512
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
IGMP-Snooping视图
【缺省级别】
2:系统级
vlan vlan-list:在指定VLAN内配置端口快速离开功能。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
fast-leave命令用来全局使能端口快速离开功能。端口快速离开是指当SR 66交换单板从某端口收到主机发送的离开某组播组的IGMP离开组报文时,直接把该端口从对应转发表项的出端口列表中删除。undo fast-leave命令用来全局关闭端口快速离开功能。
缺省情况下,端口快速离开功能处于关闭状态。
l              对于同时支持IGMP Snooping和IGMP的SR 66交换单板来说,本命令对使能了IGMP Snooping的VLAN或相应VLAN接口上使能了IGMP的VLAN都有效。
l              如果不指定VLAN,则该配置将对所有VLAN有效;如果指定了VLAN,则该配置只对指定VLAN有效。
相关配置可参考命令igmp-snooping fast-leave
# 使能VLAN 2内的端口快速离开功能。
[Sysname-igmp-snooping] fast-leave vlan 2
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
IGMP-Snooping视图
【缺省级别】
2:系统级
acl-number:指定基本或高级访问控制列表编号,取值范围为2000~3999。在这里,高级ACL规则中指定的源地址是指IGMP报文中的组播源地址(对于IGMPv1/v2报文和未携带组播源地址的IS_EX/TO_EX类型的IGMPv3报文,视其组播源地址为0.0.0.0),而并非指IP报文的源地址。
vlan vlan-list:在指定VLAN内配置组播组过滤器。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
group-policy命令用来配置全局组播组过滤器,以限定VLAN内的主机所能加入的组播组。undo group-policy命令用来删除全局组播组过滤器。
缺省情况下,没有配置全局组播组过滤器,即各VLAN内主机可以加入任意合法的组播组。
l              当指定的ACL不存在或者其规则为空时,将过滤掉所有的组播组。
l              可以为端口在不同的VLAN内配置不同的ACL规则,但在相同VLAN内所配置的新规则会取代旧规则。
相关配置可参考命令igmp-snooping group-policy
# 限定VLAN 2内的主机只能加入组播组225.1.1.1。
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname-igmp-snooping] group-policy 2000 vlan 2
host-aging-time interval
undo host-aging-time
IGMP-Snooping视图
【缺省级别】
2:系统级
interval:动态成员端口的老化时间,取值范围为200~1000,单位为秒。
【描述】
host-aging-time命令用来全局配置动态成员端口的老化时间。undo host-aging-time命令用来恢复缺省情况。
缺省情况下,动态成员端口的老化时间为260秒。
对于同时支持IGMP Snooping和IGMP的SR 66交换单板来说,本命令只对使能了IGMP Snooping的VLAN有效,而对相应VLAN接口上使能了IGMP的VLAN无效。
相关配置可参考命令igmp-snooping host-aging-time
# 全局配置动态成员端口的老化时间为300秒。
[Sysname-igmp-snooping] host-aging-time 300
1.1.8  igmp-snooping
igmp-snooping
undo igmp-snooping
【缺省级别】
2:系统级
【描述】
igmp-snooping命令用来全局使能IGMP Snooping,并进入IGMP-Snooping视图。undo igmp-snooping命令用来全局关闭IGMP Snooping。
缺省情况下,IGMP Snooping处于关闭状态。
相关配置可参考命令igmp-snooping enable
# 全局使能IGMP Snooping,并进入IGMP-Snooping视图。
igmp-snooping dot1p-priority priority-number
undo igmp-snooping dot1p-priority
VLAN视图
【缺省级别】
2:系统级
【描述】
igmp-snooping dot1p-priority命令用来在VLAN内配置IGMP报文的802.1p优先级。undo igmp-snooping dot1p-priority命令用来恢复缺省情况。
在配置本命令之前,必须先在VLAN内使能IGMP Snooping。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP报文的802.1p优先级为3。
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] igmp-snooping dot1p-priority 3
undo igmp-snooping drop-unknown
VLAN视图
【缺省级别】
2:系统级
【描述】
igmp-snooping drop-unknown命令用来在VLAN内使能丢弃未知组播数据报文的功能。undo igmp-snooping drop-unknown命令用来在VLAN内关闭丢弃未知组播数据报文的功能。
缺省情况下,丢弃未知组播数据报文的功能处于关闭状态,即对未知组播数据报文进行广播。
相关配置可参考命令igmp-snooping enabledrop-unknown
# 在VLAN 2内使能IGMP Snooping,并使能丢弃未知组播数据报文的功能。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping drop-unknown
undo igmp-snooping enable
VLAN视图
【缺省级别】
2:系统级
【描述】
igmp-snooping enable命令用来在VLAN内使能IGMP Snooping。undo igmp-snooping enable命令用来在VLAN内关闭IGMP Snooping。
缺省情况下,VLAN内的IGMP Snooping处于关闭状态。
在VLAN内使能IGMP Snooping之前,必须先全局使能IGMP Snooping,否则将无法在VLAN内使能IGMP Snooping。
# 在VLAN 2内使能IGMP Snooping。
[Sysname] vlan 2
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
以太网接口视图/二层聚合接口视图/端口组视图
【缺省级别】
2:系统级
【描述】
igmp-snooping fast-leave命令用来在端口上使能端口快速离开功能。端口快速离开是指当SR 66交换单板从某端口收到主机发送的离开某组播组的IGMP离开组报文时,直接把该端口从对应转发表项的出端口列表中删除。undo igmp-snooping fast-leave命令用来在端口上关闭端口快速离开功能。
l              在以太网接口或二层聚合接口视图下配置时,如果未指定VLAN,则该配置将对该接口所属的每个VLAN分别生效;如果指定了VLAN,则只有当该接口属于指定VLAN时,该配置才生效。
l              在端口组视图下配置时,如果未指定VLAN,则该配置将对该端口组内的所有端口都生效;如果指定了VLAN,则该配置只对该端口组内属于指定VLAN的那些端口生效。
相关配置可参考命令fast-leave
# 在VLAN 2内的端口GibitEthernet1/0/1上使能端口快速离开功能。
[Sysname] interface GibitEthernet 1/0/1
[Sysname-GibitEthernet1/0/1] igmp-snooping fast-leave vlan 2
igmp-snooping general-query source-ip { ip-address | current-interface }
undo igmp-snooping general-query source-ip
VLAN视图
【缺省级别】
2:系统级
ip-address:指定任意合法IP地址作为发送IGMP普遍组查询报文时的源IP地址。
current-interface:指定当前VLAN接口的IP地址作为IGMP普遍组查询报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为IGMP普遍组查询报文的源IP地址。
【描述】
igmp-snooping general-query source-ip命令用来配置IGMP普遍组查询报文的源IP地址。undo igmp-snooping general-query source-ip命令用来恢复缺省情况。
缺省情况下,IGMP普遍组查询报文的源IP地址为0.0.0.0。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP普遍组查询报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip 10.1.1.1
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
【缺省级别】
2:系统级
limit:允许端口加入的组播组最大数量,取值范围是1~1000。
vlan vlan-list:在指定VLAN内允许端口加入的组播组最大数量。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
igmp-snooping group-limit命令用来配置允许端口加入的组播组最大数量undo igmp-snooping group-limit命令用来恢复缺省情况。
缺省情况下,允许端口加入的组播组最大数量与设备的型号有关,请以设备的实际情况为准。
l              对于同时支持IGMP Snooping和IGMP的SR 66交换单板来说,还可以使用igmp group-limit命令限制接口上的组播组数量。而对于同一个VLAN,如果既对该VLAN内的端口进行限制,又对该VLAN接口进行限制,可能导致二、三层表项不一致,因此在这种情况下建议只限制VLAN接口上的组播组数量。
相关配置可参考“IP组播命令参考/IGMP”中的命令igmp group-limit
# 在VLAN 2内的端口GibitEthernet1/0/1上配置允许加入的组播组最大数量为10个。
[Sysname-GibitEthernet1/0/1] igmp-snooping group-limit 10 vlan 2
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
【缺省级别】
2:系统级
【描述】
igmp-snooping group-policy命令用来在端口上配置组播组过滤器,以限定该端口下的主机所能加入的组播组。undo igmp-snooping group-policy命令用来在端口上删除组播组过滤器。
缺省情况下,端口上没有配置组播组过滤器,即该端口下的主机可以加入任意合法的组播组。
相关配置可参考命令group-policy
# 限定端口GibitEthernet1/0/1下VLAN 2内的主机只能加入组播组225.1.1.1。
[Sysname-GibitEthernet1/0/1] igmp-snooping group-policy 2000 vlan 2
igmp-snooping host-aging-time interval
undo igmp-snooping host-aging-time
VLAN视图
【缺省级别】
2:系统级
【描述】
igmp-snooping host-aging-time命令用来在VLAN内配置动态成员端口的老化时间。undo igmp-snooping host-aging-time命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping enablehost-aging-time
# 在VLAN 2内使能IGMP Snooping,并配置动态成员端口的老化时间为300秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
【缺省级别】
2:系统级
group-address:模拟主机要加入的组播组的地址,取值范围为224.0.1.0~239.255.255.255。
source-address:模拟主机要加入的组播源的地址,取值为有效的单播地址或0.0.0.0。如果取值为0.0.0.0,表示不指定组播源。
vlan vlan-id:指定端口所属的VLAN。vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
igmp-snooping host-join命令用来配置模拟主机加入组播组或组播源组。模拟主机加入就是将SR 66交换单板的端口配置成为组播组的成员。undo igmp-snooping host-join命令用来恢复缺省情况。
缺省情况下,没有配置模拟主机加入组播组或组播源组。
l              对于同时支持IGMP Snooping和IGMP的SR 66交换单板来说,本命令对使能了IGMP Snooping的VLAN或相应VLAN接口上使能了IGMP的VLAN都有效,且模拟主机所采用的IGMP版本与VLAN内的IGMP Snooping版本或VLAN接口上的IGMP版本保持一致。
l              只有当IGMP Snooping的版本为3时,配置参数source-ip source-address才会有实际的意义;当IGMP Snooping的版本为2时,虽然也可以配置参数source-ip source-address,但模拟主机在收到查询报文时并不会进行响应。
l              在以太网接口或二层聚合接口视图下配置时,只有当该接口属于指定VLAN时,该配置才生效;在端口组视图下配置时,该配置只对该端口组内属于指定VLAN的那些端口有效。
# 在VLAN 2内的端口GibitEthernet1/0/1上配置模拟主机加入组播源组(1.1.1.1,232.1.1.1)。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-GibitEthernet1/0/1] igmp-snooping host-join 232.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping last-member-query-interval interval
undo igmp-snooping last-member-query-interval
VLAN视图
【缺省级别】
2:系统级
interval:发送IGMP特定组查询报文的时间间隔,取值范围为1~5,单位为秒。
【描述】
igmp-snooping last-member-query-interval命令用来在VLAN内配置发送IGMP特定组查询报文的时间间隔。undo igmp-snooping last-member-query-interval命令用来恢复缺省情况。
缺省情况下,发送IGMP特定组查询报文的时间间隔为1秒。
相关配置可参考命令igmp-snooping enablelast-member-query-interval
# 在VLAN 2内使能IGMP Snooping,并配置发送IGMP特定组查询报文的时间间隔为3秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
igmp-snooping leave source-ip { ip-address | current-interface }
undo igmp-snooping leave source-ip
VLAN视图
【缺省级别】
2:系统级
ip-address:指定任意合法的IP地址作为代理发送IGMP离开报文的源IP地址。
current-interface:指定当前VLAN接口的IP地址作为代理发送IGMP离开报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为代理发送IGMP离开报文的源IP地址。
【描述】
igmp-snooping leave source-ip命令用来配置代理发送IGMP离开报文的源IP地址。undo igmp-snooping leave source-ip命令用来恢复缺省情况。
缺省情况下,代理发送IGMP离开报文的源IP地址为0.0.0.0。
l              在配置本命令之前,必须先在VLAN内使能IGMP Snooping。
l              模拟主机发送的IGMP离开报文的源IP地址也采用本命令所配置的源IP地址。
# 在VLAN 2内使能IGMP Snooping,并配置代理发送IGMP离开报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping leave source-ip 10.1.1.1
igmp-snooping max-response-time interval
undo igmp-snooping max-response-time
VLAN视图
【缺省级别】
2:系统级
interval:IGMP普遍组查询的最大响应时间,取值范围为1~25,单位为秒。
【描述】
igmp-snooping max-response-time命令用来在VLAN内配置IGMP普遍组查询的最大响应时间。undo igmp-snooping max-response-time命令用来恢复缺省情况。
缺省情况下,IGMP普遍组查询的最大响应时间为10秒。
相关配置可参考命令igmp-snooping enablemax-response-timeigmp-snooping query-interval
# 在VLAN 2内使能IGMP Snooping,并配置IGMP普遍组查询的最大响应时间为5秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
【缺省级别】
2:系统级
vlan vlan-list:在指定VLAN内配置组播组替换功能。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
igmp-snooping overflow-replace命令用来在端口上使能组播组替换功能。undo igmp-snooping overflow-replace命令用来关闭端口上的组播组替换功能。
缺省情况下,组播组替换功能处于关闭状态。
相关配置可参考命令overflow-replace
# 在VLAN 2内的端口GibitEthernet1/0/1上使能组播组替换功能。
[Sysname-GibitEthernet1/0/1] igmp-snooping overflow-replace vlan 2
undo igmp-snooping proxying enable
VLAN视图
【缺省级别】
2:系统级
【描述】
igmp-snooping proxying enable命令用来在VLAN内使能IGMP Snooping代理功能。undo igmp-snooping proxying enable命令用来在VLAN内关闭IGMP Snooping代理功能。
缺省情况下,VLAN内的IGMP Snooping代理功能处于关闭状态。
# 在VLAN 2内使能IGMP Snooping,并使能IGMP Snooping代理功能。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping proxying enable
undo igmp-snooping querier
VLAN视图
【缺省级别】
2:系统级
【描述】
igmp-snooping querier命令用来使能IGMP Snooping查询器。undo igmp-snooping querier命令用来关闭IGMP Snooping查询器。
缺省情况下,IGMP Snooping查询器处于关闭状态。
l              在组播VLAN的子VLAN内配置本命令时不能生效。
相关配置可参考命令igmp-snooping enable,以及“IP组播命令参考/组播VLAN”中的命令subvlan
# 在VLAN 2内使能IGMP Snooping,并使能IGMP Snooping查询器。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
igmp-snooping query-interval interval
undo igmp-snooping query-interval
VLAN视图
【缺省级别】
2:系统级
interval:发送IGMP普遍组查询报文的时间间隔,取值范围为2~300,单位为秒。
【描述】
igmp-snooping query-interval命令用来配置发送IGMP普遍组查询报文的时间间隔。undo igmp-snooping query-interval命令用来恢复缺省情况。
缺省情况下,发送IGMP普遍组查询报文的时间间隔为60秒。
相关配置可参考命令igmp-snooping enableigmp-snooping querierigmp-snooping max-response-timemax-response-time
# 在VLAN 2内使能IGMP Snooping,并配置发送IGMP普遍组查询报文的时间间隔为20秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
igmp-snooping report source-ip { ip-address | current-interface }
undo igmp-snooping report source-ip
VLAN视图
【缺省级别】
2:系统级
ip-address指定任意合法的IP地址作为代理发送IGMP报告报文的源IP地址。
current-interface:指定当前VLAN接口的IP地址作为代理发送IGMP报告报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为代理发送IGMP报告报文的源IP地址。
【描述】
igmp-snooping report source-ip命令用来配置代理发送IGMP报告报文的源IP地址。undo igmp-snooping report source-ip命令用来恢复缺省情况。
缺省情况下,代理发送IGMP报告报文的源IP地址为0.0.0.0。
l              模拟主机发送的IGMP报告报文的源IP地址也采用本命令所配置的源IP地址。
# 在VLAN 2内使能IGMP Snooping,并配置代理发送IGMP报告报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping report source-ip 10.1.1.1
igmp-snooping router-aging-time interval
undo igmp-snooping router-aging-time
VLAN视图
【缺省级别】
2:系统级
interval:动态路由器端口的老化时间,取值范围为1~1000,单位为秒。
【描述】
igmp-snooping router-aging-time命令用来在VLAN内配置动态路由器端口的老化时间。undo igmp-snooping router-aging-time命令用来恢复缺省情况。
缺省情况下,动态路由器端口的老化时间为105秒。
相关配置可参考命令igmp-snooping enablerouter-aging-time
# 在VLAN 2内使能IGMP Snooping,并配置动态路由器端口的老化时间为100秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
undo igmp-snooping source-deny
以太网接口视图/端口组视图
【缺省级别】
2:系统级
【描述】
igmp-snooping source-deny命令用来使能组播数据报文源端口过滤功能。undo igmp-snooping source-deny命令用来关闭组播数据报文源端口过滤功能。
缺省情况下,组播数据报文源端口过滤功能处于关闭状态。
# 在GibitEthernet1/0/1上使能组播数据报文源端口过滤功能。
[Sysname-GibitEthernet1/0/1] igmp-snooping source-deny
igmp-snooping special-query source-ip { ip-address | current-interface }
undo igmp-snooping special-query source-ip
VLAN视图
【缺省级别】
2:系统级
ip-address:指定IP地址作为发送IGMP特定组查询报文时的源IP地址。
current-interface:指定当前VLAN接口的IP地址作为IGMP特定组查询报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为IGMP特定组查询报文的源IP地址。
【描述】
igmp-snooping special-query source-ip命令用来配置IGMP特定组查询报文的源IP地址。undo igmp-snooping special-query source-ip命令用来恢复缺省情况。
缺省情况下,IGMP特定组查询报文的源IP地址为0.0.0.0。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP特定组查询报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip 10.1.1.1
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
【缺省级别】
2:系统级
group-address:静态加入的组播组地址,取值范围为224.0.1.0~239.255.255.255。
source-address:静态加入的组播源地址,取值为有效的单播地址或0.0.0.0。如果取值为0.0.0.0,表示不指定组播源。
【描述】
igmp-snooping static-group命令用来配置静态成员端口,即配置端口静态加入组播组或组播源组。undo igmp-snooping static-group命令用来恢复缺省情况。
缺省情况下,端口不是静态成员端口。
l              只有当IGMP Snooping的版本为3时,配置参数source-ip source-address才会有实际的意义;当IGMP Snooping的版本为2时,虽然也可以配置参数source-ip source-address,但该配置将不能生效。
# 在VLAN 2内的端口GibitEthernet1/0/1上配置静态加入组播源组(1.1.1.1,232.1.1.1)。
[Sysname] vlan 2
[Sysname-GibitEthernet1/0/1] igmp-snooping static-group 232.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port vlan vlan-id
【缺省级别】
2:系统级
vlan vlan-id:在指定VLAN内配置静态路由器端口。vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
igmp-snooping static-router-port命令用来配置静态路由器端口。undo igmp-snooping static-router-port命令用来恢复缺省情况。
缺省情况下,端口不是静态路由器端口。
相关配置可参考“IP组播命令参考/组播VLAN”中的命令subvlan
# 在VLAN 2内的端口GibitEthernet1/0/1上配置静态路由器端口。
[Sysname-GibitEthernet1/0/1] igmp-snooping static-router-port vlan 2
igmp-snooping version version-number
undo igmp-snooping version
VLAN视图
【缺省级别】
2:系统级
version-number:表示IGMP Snooping的版本号,取值范围为2~3。
【描述】
igmp-snooping version命令用来配置IGMP Snooping的版本。undo igmp-snooping version命令用来恢复缺省情况。
缺省情况下,IGMP Snooping的版本为2。
# 在VLAN 2内使能IGMP Snooping,并将其版本配置为3。
[Sysname] vlan 2
undo last-member-query-interval
IGMP-Snooping视图
【缺省级别】
2:系统级
【描述】
last-member-query-interval命令用来全局配置发送IGMP特定组查询报文的时间间隔。undo last-member-query-interval命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping last-member-query-interval
# 全局配置发送IGMP特定组查询报文的时间间隔为3秒。
[Sysname-igmp-snooping] last-member-query-interval 3
undo max-response-time
IGMP-Snooping视图
【缺省级别】
2:系统级
【描述】
max-response-time命令用来全局配置IGMP普遍组查询的最大响应时间。undo max-response-time命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping max-response-timeigmp-snooping query-interval
# 全局配置IGMP普遍组查询的最大响应时间为5秒。
[Sysname-igmp-snooping] max-response-time 5
undo overflow-replace [ vlan vlan-list ]
IGMP-Snooping视图
【缺省级别】
2:系统级
【描述】
overflow-replace命令用来全局使能组播组替换功能。undo overflow-replace命令用来全局关闭组播组替换功能。
相关配置可参考命令igmp-snooping overflow-replace
# 在VLAN 2内全局使能组播组替换功能。
[Sysname-igmp-snooping] overflow-replace vlan 2
report-aggregation
undo report-aggregation
IGMP-Snooping视图
【缺省级别】
2:系统级
【描述】
report-aggregation命令用来使能IGMP成员关系报告报文抑制功能。undo report-aggregation命令用来关闭IGMP成员关系报告报文抑制功能。
缺省情况下,IGMP成员关系报告报文抑制功能处于使能状态。
# 关闭IGMP成员关系报告报文抑制功能。
[Sysname-igmp-snooping] undo report-aggregation
reset igmp-snooping group { group-address | all } [ vlan vlan-id ]
【缺省级别】
2:系统级
group-address:清除指定IGMP Snooping组播组的信息,取值范围为224.0.1.0~239.255.255.255。
all:清除所有IGMP Snooping组播组的信息。
vlan vlan-id:清除指定VLAN内IGMP Snooping组播组的信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
reset igmp-snooping group命令用来清除IGMP Snooping组播组的信息。
l              对于同时支持IGMP Snooping和IGMP的SR 66交换单板来说,本命令只对使能了IGMP Snooping的VLAN有效,而对相应VLAN接口上使能了IGMP的VLAN无效。
l              通过本命令不能够清除以静态方式加入的IGMP Snooping组播组的信息。
# 清除所有IGMP Snooping组播组的信息。
<Sysname> reset igmp-snooping group all
【缺省级别】
2:系统级
【描述】
reset igmp-snooping statistics命令用来清除IGMP Snooping窥探到的所有IGMP报文的统计信息。
# 清除IGMP Snooping窥探到的所有IGMP报文的统计信息。
<Sysname> reset igmp-snooping statistics
undo router-aging-time
IGMP-Snooping视图
【缺省级别】
2:系统级
【描述】
router-aging-time命令用来全局配置动态路由器端口的老化时间。undo router-aging-time命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping router-aging-time
# 全局配置动态路由器端口的老化时间为100秒。
[Sysname-igmp-snooping] router-aging-time 100
