国家 / 地区
08-IP组播命令参考
03-组播路由与转发命令
本章节下载  (172.02 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/MSR/MSR_50/Command/Command_Manual/H3C_MSR_CR-R2207(V1.11)/08/201107/720056_30005_0.htm
03-组播路由与转发命令
  录
1 组播路由与转发配置命令................................................................................................................. 1-1
1.1 组播路由与转发配置命令........................................................................................................... 1-1
1.1.1 delete ip rpf-route-static................................................................................................... 1-1
1.1.2 display multicast boundary.............................................................................................. 1-1
1.1.3 display multicast forwarding-table..................................................................................... 1-2
1.1.4 display multicast forwarding-table df-info........................................................................... 1-5
1.1.5 display multicast minimum-ttl.......................................................................................... 1-7
1.1.6 display multicast routing-table......................................................................................... 1-8
1.1.7 display multicast routing-table static................................................................................ 1-9
1.1.8 display multicast rpf-info................................................................................................ 1-11
1.1.9 ip rpf-route-static........................................................................................................... 1-12
1.1.10 mtracert..................................................................................................................... 1-13
1.1.11 multicast boundary...................................................................................................... 1-15
1.1.12 multicast forwarding-table downstream-limit................................................................... 1-16
1.1.13 multicast forwarding-table route-limit............................................................................. 1-16
1.1.14 multicast load-splitting................................................................................................. 1-17
1.1.15 multicast longest-match.............................................................................................. 1-18
1.1.16 multicast minimum-ttl.................................................................................................. 1-18
1.1.17 multicast routing-enable............................................................................................... 1-19
1.1.18 reset multicast forwarding-table.................................................................................... 1-19
1.1.19 reset multicast routing-table......................................................................................... 1-20
1 组播路由与转发配置命令
1.1  组播路由与转发配置命令
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则本配置只针对公网实例。
【描述】
delete ip rpf-route-static命令用来删除所有组播静态路由。
相关配置可参考命令ip rpf-route-static
# 删除公网实例中所有的组播静态路由。
[Sysname] delete ip rpf-route-static
This will erase all multicast static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]:
display multicast [ all-instance | vpn-instance vpn-instance-name ] boundary [ group-address [ mask | mask-length ] ] [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all-instance:指定所有VPN实例。
group-address:查看指定组播组的组播边界信息,取值范围为224.0.0.0~239.255.255.255。
mask:指定组播组地址的掩码,缺省值为255.255.255.255。
mask-length:指定组播组地址的掩码长度,取值范围为4~32,缺省值为32。
interface-type interface-number:查看指定接口上的组播边界信息。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display multicast boundary命令用来查看组播边界的信息。
需要注意的是,如果未指定all-instancevpn-instance参数,则只显示公网实例的相关信息。
相关配置可参考命令multicast boundary
# 查看公网实例所有接口上的组播边界信息。
<Sysname> display multicast boundary
Multicast boundary information of VPN-Instance: public net
 Boundary            Interface
 224.1.1.0/24        Eth1/1
 239.2.2.0/24        Pos5/0
表1-1 display multicast boundary命令显示信息描述表
公网组播边界信息
Boundary
表示组播边界对应的组播组
表示组播边界对应的接口
display multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table [ source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { { exclude | include | match } { interface-type interface-number | register } } | statistics ] * [ port-info ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
source-address:组播源地址,查看包含指定组播源的组播转发项。
group-address:组播组地址,查看指定组播组的组播转发项,取值范围为224.0.0.0~239.255.255.255。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
mask-length:指定组播组或组播源地址的掩码长度。对于组播组地址,其取值范围为4~32,缺省值为32;对于组播源地址,其取值范围为0~32,缺省值为32。
incoming-interface:查看指定入接口的组播转发项。
interface-type interface-number:查看指定接口类型和接口编号的入接口的组播转发项。
register:查看入接口为PIM-SM注册接口的组播转发项。
outgoing-interface:查看指定出接口的组播转发项。
exclude:查看出接口列表中不包含指定接口的组播转发项。
include:查看出接口列表中包含指定接口的组播转发项。
match:查看出接口列表中包含且仅包含指定接口的组播转发项。
statistics:查看组播转发表的统计信息。
port-info:查看二层端口的信息。
【描述】
display multicast forwarding-table命令用来查看组播转发表的信息。
l              如果未指定all-instancevpn-instance参数,则只显示公网实例的相关信息。
l              组播转发表直接用于指导组播数据的转发,通过查看该表可以了解组播数据的转发状态。
相关配置可参考命令multicast forwarding-table downstream-limitmulticast forwarding-table route-limitdisplay multicast routing-table
# 查看公网实例组播转发表的信息。
<Sysname> display multicast forwarding-table
Multicast Forwarding Table of VPN-Instance: public net
Total 1 entry
Total 1 entry matched
00001. (172.168.0.2, 227.0.0.1)
     MID: 0, Flags: 0x100000:0
     Incoming interface: Ethernet1/1
     List of 1 outgoing interfaces:
       1: Ethernet1/2
     Matched 19648 packets(20512512 bytes), Wrong If 0 packets
表1-2 display multicast forwarding-table命令显示信息描述表
公网组播转发表
Total 1 entry
组播转发表中(S,G)表项的总数
组播转发表中匹配的(S,G)表项总数
00001
表示(S,G)表项的序号
(172.168.0.2,227.0.0.1)
表示组播转发表的(S,G)表项
MID
(S,G)表项标识。每个(S,G)表项都有唯一的MID标识,不会重复
Flags
(S,G)表项的当前状态,使用不同的比特位来表示(S,G)表项所处的不同状态。该字段由两部分构成,均为16进制数字,其中“:”前、后的主要取值及含义请分别参见表1-3表1-4
Uptime
表示(S,G)表项已存在时间
Timeout in
表示(S,G)表项的超时剩余时间
Incoming interface
表示(S,G)表项的入接口名称。如果入接口是其它VPN中的接口,则显示该VPN的名称
List of 1 outgoing interface:
1: Ethernet1/2
出接口列表:
出接口序号:出接口名称和编号。如果出接口是其它VPN中的接口,则显示该VPN的名称
(S,G)表项匹配的报文数量(字节数),发生入接口错误的报文个数
(S,G)表项已转发的组播报文数量(字节数)
表1-3 Flags字段(“:”前)的主要取值及含义
取值
含义
0x1
表示需要发送注册终止报文
0x2
表示(S,G)表项对应的组播源是否活动
0x4
表示空的转发项
0x8
表示RP是否为PIM域边界路由器
0x10
表示有注册出接口
0x400
表示(S,G)表项将被删除
0x8000
表示(S,G)表项正在主备倒换后平滑
0x10000
表示平滑过程中(S,G)表项被更新
0x80000
表示(S,G)表项被重复刷新,需要先删除后添加表项
0x100000
添加成功标记
0x1000000
表示双向PIM的组播转发表项
0x2000000
表示服务于双向PIM的RP
表1-4 Flags字段(“:”后)的主要取值及含义
取值
含义
0
表示该表项为非主控板表项,或者表示主控板已向其它板同步了该表项
1
表示主控板将向其它板同步表项的入接口信息
2
表示主控板将向其它板同步表项的出接口信息
4
表示主控板将向其它板同步表项的RP信息
80
表示主控板将向其它板同步表项的封装组信息
80000000
表示主控板将通知其它板添加该表项
40000000
表示主控板将通知其它板删除该表项
display multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table df-info [ rp-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
rp-address:指定双向PIM的RP地址。
【描述】
display multicast forwarding-table df-info命令用来查看组播转发表的DF信息。
# 查看公网实例组播转发表的DF信息。
<Sysname> display multicast forwarding-table df-info
Multicast DF information of VPN-Instance: public net
Total 1 RP
Total 1 RP matched
00001. RP Address: 1.1.1.1
     MID: 0, Flags: 0x2100000:0
     Uptime: 00:08:32
     RPF interface: Ethernet1/1
     List of 1 DF interfaces:
       1: Ethernet1/2
表1-5 display multicast forwarding-table df-info命令显示信息描述表
公网组播转发表的DF信息
Total 1 RP
RP的总数
Total 1 RP matched
匹配到的RP总数
00001
表示RP表项的序号
RP Address
RP地址
MID
RP表项的标识,每个RP表项都有唯一的标识,不会重复
Flags
RP表项的当前状态,使用不同的比特位来表示RP表项所处的不同状态。该字段由两部分构成,均为16进制数字,其中“:”前、后的主要取值及含义请分别参见表1-3表1-4
Uptime
RP表项的存在时间
RPF interface
到RP的RPF接口
DF接口列表
display multicast [ all-instance | vpn-instance vpn-instance-name ] minimum-ttl [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:查看指定接口上组播转发的最小TTL值。如果未指定本参数,将显示所有接口组播转发的最小TTL值。
【描述】
display multicast minimum-ttl命令用来查看组播转发的最小TTL值。
相关配置可参考命令multicast minimum-ttl
# 查看公网实例所有接口上组播转发的最小TTL值。
<Sysname> display multicast minimum-ttl
Multicast TTL information of VPN-Instance: public net
 Interface           TTL
 Eth1/1              5
 Eth1/2              6
表1-6 display multicast minimum-ttl命令显示信息描述表
公网接口上组播转发的TTL值信息
表示接口名称
TTL
表示该接口上组播转发的最小TTL值
display multicast [ all-instance | vpn-instance vpn-instance-name ] routing-table [ source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { { exclude | include | match } { interface-type interface-number | register } } ] * [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
source-address:组播源地址,查看包含指定组播源的组播路由项。
group-address:组播组地址,查看指定组播组的组播路由项,取值范围为224.0.0.0~239.255.255.255。
incoming-interface:查看指定入接口的组播路由项。
interface-type interface-number:查看指定接口类型和接口编号的入接口的组播路由项。
register:查看入接口为PIM-SM注册接口的组播路由项。
outgoing-interface:查看指定出接口的组播路由项。
exclude:查看出接口列表中不包含指定接口的组播路由项。
include:查看出接口列表中包含指定接口的组播路由项。
match:查看出接口列表中包含且仅包含指定接口的组播路由项。
【描述】
display multicast routing-table命令用来查看组播路由表的信息。
l              组播路由表是进行组播数据转发的基础,通过查看该表可以了解(S,G)表项等的建立情况。
相关配置可参考命令display multicast forwarding-table
# 查看公网实例组播路由表的信息。
<Sysname> display multicast routing-table
Multicast routing table of VPN-Instance: public net
 Total 1 entry
       Uptime: 00:00:28
       Upstream Interface: Ethernet1/1
       List of 2 downstream interfaces
           1:  Ethernet1/2
           2:  Ethernet1/3
表1-7 display multicast routing-table命令显示信息描述表
公网组播路由表
Total 1 entry
组播路由表中(S,G)表项的总数
00001
表示(S,G)表项的序号
表示组播路由表的(S,G)表项
Uptime
表示(S,G)表项已经存在的时间
Upstream interface
表示(S,G)表项的上游接口名称,表示组播数据应该从此接口到达名称。如果上游接口是其它VPN中的接口,则显示该VPN的名称
下游接口列表,表示哪些接口需要进行组播转发。如果下游接口是其它VPN中的接口,则显示该VPN的名称
display multicast routing-table [ all-instance | vpn-instance vpn-instance-name ] static [ source-address { mask-length | mask } ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
source-address:查看指定组播源的组播静态路由信息。
mask:指定组播源地址的掩码。
mask-length:指定组播源地址的掩码长度,取值范围为0~32。
【描述】
display multicast routing-table static命令用来查看组播静态路由的信息。
# 查看公网实例全部组播静态路由的信息。
<Sysname> display multicast routing-table static
Multicast Routing Table of VPN-Instance: public net
Routes : 1
 Mroute 10.10.0.0/16
          Interface = Ethernet1/1         RPF Neighbor = 2.2.2.2
          Matched routing protocol = <none>, Route-policy = <none>
          Preference = 1, Order = 1
 Running Configuration = ip rpf-route-static 10.10.0.0 16 2.2.2.2 order 1
表1-8 display multicast routing-table static命令显示信息描述表
公网组播路由表
Routes
路由条数
Mroute
组播路由源地址及其掩码长度
可达组播源的出接口
RPF Neighbor
可达组播源的RPF邻居IP地址
匹配的单播路由协议
Route-policy
路由策略。路由的组播源地址应当匹配路由策略
Preference
路由优先级
Order
路由序号
配置本条组播静态路由的命令行
display multicast [ all-instance | vpn-instance vpn-instance-name ] rpf-info source-address [ group-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
source-address:查看指定组播源的RPF信息。
group-address:查看指定组播组的RPF信息,取值范围为224.0.1.0~239.255.255.255。
【描述】
display multicast rpf-info命令用来查看组播源的RPF信息。
相关配置可参考命令display multicast routing-tabledisplay multicast forwarding-table
# 查看公网组播源192.168.1.55的全部RPF信息。
<Sysname> display multicast rpf-info 192.168.1.55
 RPF information about source 192.168.1.55:
     VPN instance: public net
     RPF interface: Ethernet1/1, RPF neighbor: 10.1.1.1
     Referenced route/mask: 192.168.1.0/24
     Referenced route type: igp
     Load splitting rule: disable
表1-9 display multicast rpf-info命令显示信息描述表
到组播源192.168.1.55的RPF路径信息
RPF interface
表示RPF接口名称。如果RPF接口是其它VPN中的接口,则显示该VPN的名称
RPF neighbor
表示RPF邻居
表示引用的路由及其掩码长度
表示引用的路由类型,可以是下列类型之一:
l      igp:单播路由(内部网关协议)
l      egp:单播路由(外部网关协议)
l      unicast (direct):单播路由(直连)
l      unicast:其它单播路由(如单播静态路由等)
l      mbgp:MBGP路由
l      multicast static:组播静态路由
RPF路由选择规则,可以是根据路由协议的优先级进行选择,或者是按照目的地址对路由表进行最长匹配
Load splitting rule
是否使能了负载分担规则
ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask | mask-length } [ protocol [ process-id ] ] [ route-policy policy-name ] { rpf-nbr-address | interface-type interface-number } [ preference preference ] [ order order-number ]
undo ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask | mask-length } [ protocol [ process-id ] ] [ route-policy policy-name ]
【缺省级别】
2:系统级
source-address:指定组播源地址。
mask:指定组播源地址的掩码。
protocol:匹配的路由必须在指定的单播路由协议中出现,其取值及含义如下:
l              bgp:表示BGP协议;
l              isis:表示IS-IS协议;
l              ospf:表示OSPF协议;
l              rip:表示RIP协议;
l              static:表示静态路由。
process-id:指定单播路由协议的进程号,取值范围为1~65535。当单播路由协议为isisospfrip时,需要指定本参数。
policy-name:指定静态组播路由匹配的路由策略名称,为1~63个字符的字符串,区分大小写。
rpf-nbr-address:指定RPF邻居的IP地址。
interface-type interface-number:指定与RPF邻居相连接口的接口类型和接口编号。
preference:指定路由优先级,取值范围为1~255,缺省值为1。
order-number:指定同网段路由中的配置先后次序,取值范围为1~100。
【描述】
ip rpf-route-static命令用来配置组播静态路由。undo ip rpf-route-static命令用来删除组播静态路由表中的组播静态路由。
缺省情况下,没有配置组播静态路由。
l              参数source-address { mask | mask-length }、protocolpolicy-name为配置组播静态路由的关键要素,三个要素中只要有一个不同就被系统认为是不同的配置。配置组播静态路由时,系统首先判断是否已有此配置,若有就修改相应的字段(配置顺序保持不变);若没有则添加此配置。
l              配置时,若RPF邻居的接口类型是三层以太网接口、Loopback接口或VLAN接口时,则不能用指定接口(interface-type interface-number)的方式来指定RPF邻居,而只能用指定地址(rpf-nbr-address)的方式。
l              配置的组播静态路由并不一定会生效,因为可能出现无法迭代出接口,或者指定的接口处于down状态等情况。因此,配置完成后建议使用display multicast routing-table static命令查看该组播静态路由是否已生效。
相关配置可参考命令delete ip rpf-route-staticdisplay multicast routing-table static
# 配置到组播源10.1.1.1/24的组播静态路由,其RPF邻居的地址是192.168.1.23。
[Sysname] ip rpf-route-static 10.1.1.1 24 192.168.1.23
1.1.10  mtracert
mtracert source-address [ [ last-hop-router-address ] group-address ]
【缺省级别】
1:监控级
group-address:指定组播组地址,取值范围为224.0.1.0~239.255.255.255。
last-hop-router-address:指定最后一跳路由器的地址,缺省值为当前路由器的地址。
【描述】
mtracert命令用来跟踪组播数据的传输路径。
需要注意的是,在跟踪组播数据(S,G)的传输路径时若指定了last-hop-router-address,则该地址所对应的接口必须是(S,G)表项的出接口,否则跟踪将失败。
# 跟踪组播数据(6.6.6.6,225.2.1.1)的传输路径,指定最后一跳路由器的IP地址为5.5.5.8。
<Sysname> mtracert 6.6.6.6 5.5.5.8 225.2.1.1
 Type Ctrl+C to quit mtrace facility
 Tracing reverse path of (6.6.6.6, 225.2.1.1) from last-hop router (5.5.5.8) to source via multicast routing-table
 -1 5.5.5.8
   Incoming interface address: 4.4.4.8
   Previous-hop router address: 4.4.4.7
   Input packet count on incoming interface: 17837
   Output packet count on outgoing interface: 0
   Total number of packets for this source-group pair: 8000
   Protocol: PIM
   Forwarding TTL: 0
   Forwarding code: No error
 -2 4.4.4.7
   Incoming interface address: 6.6.6.7
   Previous-hop router address: 0.0.0.0
   Input packet count on incoming interface: 2
   Output packet count on outgoing interface: 259
   Total number of packets for this source-group pair: 8100
   Protocol: PIM
   Forwarding TTL: 0
表1-10 mtracert命令显示信息描述表
last-hop router
最后一跳路由器
要跟踪的组播数据(S,G)
-1 5.5.5.8
从最后一跳路由器开始每一跳的出接口地址
入接口的IP地址
上一跳的IP地址
入接口收到的组播报文统计
出接口发出的组播报文统计
转发的(S,G)报文统计
Protocol
运行的组播路由协议
Forwarding TTL
报文从出接口转发出去的最小TTL值
Forwarding code
转发代码
multicast boundary group-address { mask | mask-length }
undo multicast boundary { group-address { mask | mask-length } | all }
【缺省级别】
2:系统级
group-address:指定组播组地址,取值范围为224.0.0.0~239.255.255.255。
mask:指定组播组地址的掩码。
mask-length:指定组播组地址的掩码长度,取值范围为4~32。
all:删除该接口上配置的所有组播转发边界。
【描述】
multicast boundary命令用来配置组播转发边界。undo multicast boundary命令用来删除组播转发边界。
缺省情况下,没有配置组播转发边界。
l              组播转发边界为指定地址范围的组播组划定了边界条件,如果组播报文的目的地址与边界条件匹配,就停止转发。
l              一个接口可以作为不同地址范围的组播组的转发边界,即允许在同一接口上多次执行本命令为不同地址范围的组播组设定转发边界。
l              假设A和B为不同地址范围的组播组的集合,且B是A的真子集:如果接口先配置为A的转发边界,再配置为B的转发边界,则该接口仍然为A的转发边界;如果接口先配置为B的转发边界,再配置为A的转发边界,则该接口将变为A的转发边界。
相关配置可参考命令display multicast boundary
# 将接口Ethernet1/1配置为地址范围为239.2.0.0/16的组播组的转发边界。
[Sysname] interface ethernet 1/1
[Sysname-Ethernet1/1] multicast boundary 239.2.0.0 16
multicast forwarding-table downstream-limit limit
undo multicast forwarding-table downstream-limit
系统视图/VPN实例视图
【缺省级别】
2:系统级
limit:指定单条组播转发表项的最大下行节点数目,取值范围为0~128。
【描述】
multicast forwarding-table downstream-limit命令用来配置单条组播转发表项的最大下行节点数目。undo multicast forwarding-table downstream-limit命令用来恢复缺省情况。
缺省情况下,单条组播转发表项的最大下行节点数目为128。
# 配置公网实例中单条组播转发表项的最大下行节点数目为120。
[Sysname] multicast forwarding-table downstream-limit 120
# 配置VPN实例mvpn中单条组播转发表项的最大下行节点数目为60。
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] multicast forwarding-table downstream-limit 60
multicast forwarding-table route-limit limit
undo multicast forwarding-table route-limit
系统视图/VPN实例视图
【缺省级别】
2:系统级
limit:指定组播转发表的最大表项数,取值范围为0到系统所允许的最大值。
【描述】
multicast forwarding-table route-limit命令用来配置组播转发表的最大表项数。undo multicast forwarding-table route-limit命令用来恢复缺省情况。
MSR系列路由器各款型对于本节所描述的命令及参数的支持情况有所不同,详细差异信息如下:参数支持情况、取值范围和缺省值说明:
参数
MSR 900
MSR 20-1X
MSR 20
MSR 30
MSR 50
limit
0~256,缺省值为256
0~256,缺省值为256
0~256,缺省值为256
0~512,缺省值为512
0~1024,缺省值为1024
# 配置公网实例组播转发表的最大表项数为200。
[Sysname] multicast forwarding-table route-limit 200
# 配置VPN实例mvpn的组播转发表的最大表项数为200。
[Sysname-vpn-instance-mvpn] multicast forwarding-table route-limit 200
multicast load-splitting { source | source-group }
undo multicast load-splitting
系统视图/VPN实例视图
【缺省级别】
2:系统级
source:指定仅根据组播源对组播流量进行负载分担。
source-group:指定同时根据组播源与组播组对组播流量进行负载分担。
【描述】
multicast load-splitting命令用来配置对组播流量进行负载分担。undo multicast load-splitting命令用来取消对组播流量进行负载分担。
缺省情况下,不对组播流量进行负载分担。
# 在公网实例中配置仅根据组播源对组播流量进行负载分担。
[Sysname] multicast load-splitting source
# 在VPN实例mvpn中配置仅根据组播源对组播流量进行负载分担。
[Sysname-vpn-instance-mvpn] multicast load-splitting source
undo multicast longest-match
系统视图/VPN实例视图
【缺省级别】
2:系统级
【描述】
multicast longest-match命令用来配置按照最长匹配来选择RPF路由,即选择掩码最长的路由作为RPF路由。undo multicast longest-match命令用来恢复缺省情况。
缺省情况下,选择优先级最高的路由作为RPF路由。
# 在公网实例中配置按照最长匹配原则选择RPF路由。
[Sysname] multicast longest-match
# 在VPN实例mvpn中配置按照最长匹配原则选择RPF路由。
[Sysname-vpn-instance-mvpn] multicast longest-match
multicast minimum-ttl ttl-value
undo multicast minimum-ttl
【缺省级别】
2:系统级
ttl-value:指定接口可以转发的组播报文的最小TTL值,取值范围为1~255。
【描述】
multicast minimum-ttl命令用来配置组播转发的最小TTL值。undo multicast minimum-ttl命令用来恢复缺省情况。
缺省情况下,组播转发的最小TTL值为1。
相关配置可参考命令display multicast minimum-ttl
# 配置接口Ethernet1/1上组播转发的最小TTL值为8。
[Sysname-Ethernet1/1] multicast minimum-ttl 8
undo multicast routing-enable
系统视图/VPN实例视图
【缺省级别】
2:系统级
【描述】
multicast routing-enable命令用来使能IP组播路由。undo multicast routing-enable命令用来关闭IP组播路由。
缺省情况下,IP组播路由处于关闭状态。
l              只有在公网实例或VPN实例中使能了IP组播路由,才能配置相应实例中的其它三层组播功能;
l              没有使能IP组播路由前,设备不转发任何组播报文。
# 使能公网实例中的IP组播路由。
[Sysname] multicast routing-enable
# 使能VPN实例mvpn中的IP组播路由。
[Sysname-vpn-instance-mvpn] route-distinguisher 100:1
[Sysname-vpn-instance-mvpn] multicast routing-enable
reset multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table { { source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } } * | all }
【缺省级别】
2:系统级
source-address:组播源地址,清除包含指定组播源的组播转发项。
group-address:组播组地址,清除指定组播组的组播转发项,取值范围为224.0.0.0~239.255.255.255。
incoming-interface:清除指定入接口的组播转发项。
interface-type interface-number:清除指定接口类型和接口编号的入接口的组播转发项。
register:清除入接口为PIM-SM注册接口的组播转发项。
all:清除组播转发表中的所有组播转发项。
【描述】
reset multicast forwarding-table命令用来清除组播转发表中的转发项。
l              如果未指定all-instancevpn-instance参数,则只清除公网实例的相关表项。
l              清除组播转发表中的转发项后,组播路由表中的相应表项也将随之被删除。
相关配置可参考命令reset multicast routing-tabledisplay multicast routing-tabledisplay multicast forwarding-table
# 从公网实例组播转发表中清除组播组225.5.4.3的相关转发表项。
<Sysname> reset multicast forwarding-table 225.5.4.3
# 从VPN实例mvpn的组播转发表中清除组播组226.1.2.3的相关转发表项。
<Sysname> reset multicast vpn-instance mvpn forwarding-table 226.1.2.3
reset multicast [ all-instance | vpn-instance vpn-instance-name ] routing-table { { source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } } * | all }
【缺省级别】
2:系统级
source-address:组播源地址,清除包含指定组播源的组播路由项。
group-address:组播组地址,清除指定组播组的组播路由项,取值范围为224.0.0.0~239.255.255.255。
incoming-interface:清除指定入接口的组播路由项。
interface-type interface-number:清除指定接口类型和接口编号的入接口的组播路由项。
register:清除入接口为PIM-SM注册接口的组播路由项。
all:清除组播路由表中的所有组播路由项。
【描述】
reset multicast routing-table命令用来清除组播路由表中的路由项。
l              清除组播路由表中的路由项后,组播转发表中的相应表项也将被随之删除。
相关配置可参考命令reset multicast forwarding-tabledisplay multicast routing-tabledisplay multicast forwarding-table
# 从公网实例组播路由表中清除组播组225.5.4.3的相关路由项。
<Sysname> reset multicast routing-table 225.5.4.3
# 从VPN实例mvpn的组播路由表中清除组播组226.1.2.3的相关路由项。
<Sysname> reset multicast vpn-instance mvpn routing-table 226.1.2.3
联系我们 联系我们
回到顶部 回到顶部
